[GRASS-SVN] r35666 - grass-addons/vector/v.in.gshhs
svn_grass at osgeo.org
Wed Jan 28 07:17:44 EST 2009
Author: mmetz
Date: 2009-01-28 07:17:43 -0500 (Wed, 28 Jan 2009)
New Revision: 35666
grass-addons/vector/v.in.gshhs/description.html
grass-addons/vector/v.in.gshhs/main.c
lines are split into small pieces, easier on topology
Modified: grass-addons/vector/v.in.gshhs/description.html
--- grass-addons/vector/v.in.gshhs/description.html 2009-01-28 02:07:30 UTC (rev 35665)
+++ grass-addons/vector/v.in.gshhs/description.html 2009-01-28 12:17:43 UTC (rev 35666)
@@ -13,22 +13,20 @@
lake, island in lake, pond in island in lake. The field <tt>type</tt> is
set to these descriptions. All lines of the same type have the same
category. The categories in layer 2 refer to the GSHHS ID of each
-imported line. Each line has a unique category value (the GSHHS ID) in
+imported line. Each line has as category value the GSHHS ID in
layer 2, that may be useful for further processing. An attribute table
for layer 2 is not created.
<p>
The import region is restricted to either the current computational
region or to the extend specified with the options n, s, e, w. Either of
-the two possibilities must be used. All lines that overlap with the
+the two possibilities must be used. All lines that fall into the
specified region are imported, similar to <em>v.in.ogr</em>.
<h2>NOTES</h2>
The GSHHS shorelines are in files named <tt>gshhs_[f|h|i|l|c].b</tt> where
-the letter in brackets indicates the resolution. Only these files can be
-imported, import of world borders and world rivers also included in the zip
-archive is currently not supported.
+the letter in brackets indicates the resolution.
<p>
-The GSHHS shorelines are available at 5 resolutions:
+The 5 available resolutions are:
<ul>
<li>f: full resolution
<li>h: high resolution
@@ -43,15 +41,16 @@
line ID) with <em>v.to.db</em>. Shoreline type can be uploaded from
layer 1 to layer 2 with <em>v.to.db</em>.
<p>
-Long lines can be split with <em>v.split</em>.
-<p>
Lines can be converted to boundaries with <em>v.type</em>.
+<p>
+Import of world borders and world rivers also included in the zip archive
+is currently not supported but works, just ignore the attribute table.
+These world borders and rivers are however outdated and not very accurate.
<h2>SEE ALSO</h2>
<em>
<a HREF="v.db.addtable.html">v.db.addtable</a>,
-<a HREF="v.split.html">v.split</a>,
<a HREF="v.to.db.html">v.to.db</a>,
<a HREF="v.type.html">v.type</a>,
</em>
Modified: grass-addons/vector/v.in.gshhs/main.c
--- grass-addons/vector/v.in.gshhs/main.c 2009-01-28 02:07:30 UTC (rev 35665)
+++ grass-addons/vector/v.in.gshhs/main.c 2009-01-28 12:17:43 UTC (rev 35666)
@@ -38,7 +38,7 @@
int main(int argc, char **argv)
- double w, e, s, n, area, lon, lat;
+ double w, e, s, n, area, lon, lat, lastlon = 0., lastlat = 0.;
double minx = -180., maxx = 180., miny = -90., maxy = 90.;
char *dataname, *outname;
char buf[2000], source;
@@ -49,7 +49,7 @@
FILE *fp;
int k, i, n_read, flip, level, version, greenwich, src;
int max_east = 180000000; /* max_east = 270000000: confuses GRASS */
- int cnt = 1;
+ int cnt = 0, getme = 0;
struct GSHHS_POINT p; /* renamed to avoid conflict */
struct GSHHS h;
struct pj_info info_in;
@@ -199,10 +199,11 @@
sscanf(parm.s->answer, "%lf", &miny);
sscanf(parm.n->answer, "%lf", &maxy);
- if (maxx < minx)
- G_fatal_error("East must be east of West");
+ /* it is a valid request to go over the datum border */
+ if (maxx == minx)
+ G_fatal_error("East and West can not be the same");
- if (maxy < miny)
+ if (maxy <= miny)
G_fatal_error("North must be north of South");
@@ -252,6 +253,9 @@
/* check coordinate accuracy */
+#if 0
+ /* don't check coordinate accuracy, it's either the current window or
+ * e w n s and they have been checked already */
if (maxx < minx) {
G_fatal_error(_("maxx %f < minx %f."), maxx, minx);
@@ -259,7 +263,18 @@
if (maxy < miny) {
G_fatal_error(_("maxy %f < miny %f."), maxy, miny);
+#endif
+ while (maxx > 180.0)
+ maxx -= 360.0;
+ while (maxx < -180.0)
+ maxx += 360.0;
+ while (minx > 180.0)
+ minx -= 360.0;
+ while (minx < -180.0)
+ minx += 360.0;
G_message(_("Using lat/lon bounds N=%f S=%f E=%f W=%f\n"), maxy, miny,
maxx, minx);
@@ -320,10 +335,30 @@
if (h.east > max_east)
e -= 360.0;
- /* got line header now read in points if line box overlaps with region */
- if ((w <= maxx && e >= minx) && (s <= maxy && n >= miny)) {
+ if (e < w)
+ e += 360;
+ /* got line header now read in points if line box falls into region */
+ /* what if the datum border is crossed?
+ * then maxx < minx and both w and e should be >= minx or <=maxx */
+ getme = 1;
+ if (maxx > minx) {
+ if (w > maxx || e < minx || s > maxy || n < miny) /* that should get any overlapping line */
+ getme = 0;
+ else {
+ /* e and w < minx and e and w > maxx */
+ if ((w < minx && e < minx && w > maxx && e > maxx) || s > maxy || n < miny)
+ getme = 0;
+ if (getme) {
Vect_reset_line(Points);
Vect_reset_cats(Cats);
+ /* simple table and cats for layer 1: not unique, just per slevel */
+ Vect_cat_set(Cats, 1, level);
+ /* cats for layer 2 are unique ID, same like GSHHS ID */
+ Vect_cat_set(Cats, 2, h.id);
for (k = 0; k < h.n; k++) {
if (fread
@@ -336,10 +371,22 @@
p.y = swabi4((unsigned int)p.y);
lon = p.x * GSHHS_SCL;
- if (p.x > max_east)
+ if (p.x > max_east) /* GSHHS lon coords are 0 - 360 */
lon -= 360.0;
lat = p.y * GSHHS_SCL;
+ /* chop in 1x1 degree tiles */
+ if (k && ((floor(lon) != floor(lastlon)) || (floor(lat) != floor(lastlat)))) {
+ lastlon = Points->x[Points->n_points - 1]; /* keep last lon for new line */
+ lastlat = Points->y[Points->n_points - 1]; /* keep last lat for new line */
+ Vect_write_line(&VectMap, type, Points, Cats);
+ Vect_reset_line(Points);
+ Vect_append_point(Points, lastlon, lastlat, 0.);
+ lastlon = lon;
+ lastlat = lat;
if (G_projection() != PROJECTION_LL) {
if (pj_do_proj(&lon, &lat, &info_in, &info_out) < 0) {
G_fatal_error("Error in coordinate transformation");
@@ -350,12 +397,7 @@
} /* done with line */
if (k) {
- /* simple table and cats for layer 1: not unique, just per slevel */
- Vect_cat_set(Cats, 1, level);
- /* cats for layer 2 are unique ID, same like GSHHS ID */
- Vect_cat_set(Cats, 2, h.id);
- cnt++;
else {
@@ -363,14 +405,16 @@
"skipped line box west: %f, east: %f, north: %f, south: %f",
w, e, n, s);
fseek(fp, (long)(h.n * sizeof(struct GSHHS_POINT)), SEEK_CUR);
+ cnt++;
- /* max_east = 180000000; *//* Only Eurasiafrica needs 270 */
+ /* max_east = 180000000; *//* Only Eurasiafrica needs 270: only needed for GMT not for GRASS */
n_read =
fread((void *)&h, (size_t) sizeof(struct GSHHS), (size_t) 1, fp);
/* done with gshhs file */
fclose(fp);
+ G_message(_("Skipped lines: %d"), cnt);
Vect_destroy_line_struct(Points);
Vect_destroy_cats_struct(Cats);
