[GRASS-SVN] r35667 - in grass/trunk: general/g.proj include lib/proj
svn_grass at osgeo.org
Thu Jan 29 10:29:28 EST 2009
Author: pkelly
Date: 2009-01-29 10:29:28 -0500 (Thu, 29 Jan 2009)
New Revision: 35667
grass/trunk/general/g.proj/Makefile
grass/trunk/general/g.proj/datumtrans.c
grass/trunk/general/g.proj/output.c
grass/trunk/include/gprojects.h
grass/trunk/lib/proj/convert.c
grass/trunk/lib/proj/datum.c
grass/trunk/lib/proj/ellipse.c
grass/trunk/lib/proj/get_proj.c
Use pj_dalloc() to free string allocated by pj_get_def() [fixes bug 468].
Fix some memory leaks in proj-related stuff.
Modified: grass/trunk/general/g.proj/Makefile
--- grass/trunk/general/g.proj/Makefile 2009-01-28 12:17:43 UTC (rev 35666)
+++ grass/trunk/general/g.proj/Makefile 2009-01-29 15:29:28 UTC (rev 35667)
@@ -3,7 +3,7 @@
PGM = g.proj
EXTRA_INC = $(PROJINC)
-LIBES = $(GPROJLIB) $(GISLIB)
+LIBES = $(PROJLIB) $(GPROJLIB) $(GISLIB)
DEPENDENCIES= $(GPROJDEP) $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/general/g.proj/datumtrans.c
--- grass/trunk/general/g.proj/datumtrans.c 2009-01-28 12:17:43 UTC (rev 35666)
+++ grass/trunk/general/g.proj/datumtrans.c 2009-01-29 15:29:28 UTC (rev 35667)
@@ -42,15 +42,16 @@
char *params, *datum = NULL;
int paramsets, status;
- struct gpj_datum dstruct;
if (cellhd.proj == PROJECTION_XY)
return 0;
status = GPJ__get_datum_params(projinfo, &datum, ¶ms);
+ G_free(params);
if (datum) {
/* A datum name is specified; need to determine if
* there are parameters to choose from for this datum */
+ struct gpj_datum dstruct;
if (GPJ_get_datum_by_name(datum, &dstruct) > 0) {
char *defparams;
@@ -58,6 +59,8 @@
paramsets =
GPJ_get_default_datum_params_by_name(dstruct.name,
&defparams);
+ G_free(defparams);
+ GPJ_free_datum(&dstruct);
if (status == 1 && paramsets > 1)
/* Parameters are missing and there is a choice to be made */
@@ -94,21 +97,23 @@
if (list != NULL) {
if (datumtrans == -1) {
do {
+ struct gpj_datum_transform_list *old = list;
fprintf(stdout, "---\n%d\nUsed in %s\n%s\n%s\n",
list->count, list->where_used,
list->params, list->comment);
list = list->next;
+ GPJ_free_datum_transform(old);
} while (list != NULL);
exit(EXIT_SUCCESS);
else {
do {
- if (list->count == datumtrans) {
+ if (list->count == datumtrans)
chosenparams = G_store(list->params);
- break;
list = list->next;
@@ -146,6 +151,7 @@
projinfo = temp_projinfo;
+ G_free(datum);
return force;
Modified: grass/trunk/general/g.proj/output.c
--- grass/trunk/general/g.proj/output.c 2009-01-28 12:17:43 UTC (rev 35666)
+++ grass/trunk/general/g.proj/output.c 2009-01-29 15:29:28 UTC (rev 35667)
@@ -17,6 +17,9 @@
#include <stdio.h>
#include <string.h>
#include <errno.h>
+#include <proj_api.h>
#include <grass/gis.h>
#include <grass/gprojects.h>
#include <grass/glocale.h>
@@ -102,6 +105,7 @@
pj_get_kv(&pjinfo, projinfo, projunits);
proj4 = pj_get_def(pjinfo.pj, 0);
+ pj_free(pjinfo.pj);
/* GRASS-style PROJ.4 strings don't include a unit factor as this is
* handled separately in GRASS - must include it here though */
@@ -109,7 +113,8 @@
if (unfact != NULL && (strcmp(pjinfo.proj, "ll") != 0))
G_asprintf(&proj4mod, "%s +to_meter=%s", proj4, unfact);
else
- proj4mod = proj4;
+ proj4mod = G_store(proj4);
+ pj_dalloc(proj4);
for (i = proj4mod; *i; i++) {
/* Don't print the first space */
@@ -122,6 +127,7 @@
fputc(*i, stdout);
fputc('\n', stdout);
+ G_free(proj4mod);
return;
Modified: grass/trunk/include/gprojects.h
--- grass/trunk/include/gprojects.h 2009-01-28 12:17:43 UTC (rev 35666)
+++ grass/trunk/include/gprojects.h 2009-01-29 15:29:28 UTC (rev 35667)
@@ -95,8 +95,8 @@
int GPJ_get_datum_params(char **, char **);
int GPJ__get_datum_params(struct Key_Value *, char **, char **);
void GPJ_free_datum(struct gpj_datum *);
-struct gpj_datum_transform_list *GPJ_get_datum_transform_by_name(const char
- *inputname);
+struct gpj_datum_transform_list *GPJ_get_datum_transform_by_name(const char *);
+void GPJ_free_datum_transform(struct gpj_datum_transform_list *);
/* ellipse.c */
int GPJ_get_ellipsoid_by_name(const char *, struct gpj_ellps *);
Modified: grass/trunk/lib/proj/convert.c
--- grass/trunk/lib/proj/convert.c 2009-01-28 12:17:43 UTC (rev 35666)
+++ grass/trunk/lib/proj/convert.c 2009-01-29 15:29:28 UTC (rev 35667)
@@ -93,9 +93,9 @@
struct gpj_ellps estruct;
size_t len;
- const char *ellps, *unit, *unfact;
- char *ellpslong, *datum, *params, *towgs84, *datumlongname,
- *start, *end, *buff;
+ const char *ellpskv, *unit, *unfact;
+ char *ellps, *ellpslong, *datum, *params, *towgs84, *datumlongname,
+ *start, *end;
const char *sysname, *osrunit, *osrunfact;
double a, es, rf;
int haveparams = 0;
@@ -114,19 +114,22 @@
G_warning(_("Unable get PROJ.4-style parameter string"));
return NULL;
unit = G_find_key_value("unit", proj_units);
unfact = G_find_key_value("meters", proj_units);
else
- proj4mod = proj4;
+ pj_dalloc(proj4);
if ((errcode = OSRImportFromProj4(hSRS, proj4mod)) != OGRERR_NONE) {
G_warning(_("OGR can't parse PROJ.4-style parameter string: "
"%s (OGR Error code was %d)"), proj4mod, errcode);
return NULL;
+ G_free(proj4mod);
if ((errcode = OSRExportToWkt(hSRS, &wkt)) != OGRERR_NONE) {
G_warning(_("OGR can't get WKT-style parameter string "
@@ -134,14 +137,19 @@
return NULL;
- ellps = G_find_key_value("ellps", proj_info);
+ ellpskv = G_find_key_value("ellps", proj_info);
GPJ__get_ellipsoid_params(proj_info, &a, &es, &rf);
haveparams = GPJ__get_datum_params(proj_info, &datum, ¶ms);
+ if(ellpskv != NULL)
+ ellps = G_store(ellpskv);
+ else
+ ellps = NULL;
if ((datum == NULL) || (GPJ_get_datum_by_name(datum, &dstruct) < 0)) {
- datumlongname = "unknown";
+ datumlongname = G_store("unknown");
if (ellps == NULL)
- ellps = "unnamed";
+ ellps = G_store("unnamed");
else {
datumlongname = G_store(dstruct.longname);
@@ -149,6 +157,7 @@
ellps = G_store(dstruct.ellps);
+ G_free(datum);
if (GPJ_get_ellipsoid_by_name(ellps, &estruct) > 0) {
ellpslong = G_store(estruct.longname);
DatumNameMassage(&ellpslong);
@@ -171,16 +180,17 @@
if (G_strcasecmp(paramkey, "towgs84") == 0)
G_asprintf(&towgs84, ",TOWGS84[%s]", paramvalue);
else
- towgs84 = "";
+ towgs84 = G_store("");
+ G_free(params);
else
- towgs84 = "";
sysname = OSRGetAttrValue(hSRS, "PROJCS", 0);
if (sysname == NULL) {
/* Not a projected co-ordinate system */
- start = "";
- end = "";
+ start = G_store("");
+ end = G_store("");
else {
if ((strcmp(sysname, "unnamed") == 0) &&
@@ -194,8 +204,9 @@
osrunfact = OSRGetAttrValue(hSRS, "UNIT", 1);
if ((unfact == NULL) || (G_strcasecmp(osrunit, "unknown") != 0))
- end = "";
else {
+ char *buff;
double unfactf = atof(unfact);
G_asprintf(&buff, ",UNIT[\"%s\",", osrunit);
@@ -203,6 +214,7 @@
startmod = strstr(lastpart, buff);
len = strlen(lastpart) - strlen(startmod);
lastpart[len] = '\0';
+ G_free(buff);
if (unit == NULL)
unit = "unknown";
@@ -210,27 +222,21 @@
+ OSRDestroySpatialReference(hSRS);
G_asprintf(&modwkt,
"%sGEOGCS[\"%s\",DATUM[\"%s\",SPHEROID[\"%s\",%.16g,%.16g]%s],%s%s",
start, ellps, datumlongname, ellpslong, a, rf, towgs84,
lastpart, end);
hSRS2 = OSRNewSpatialReference(modwkt);
+ G_free(modwkt);
- OSRDestroySpatialReference(hSRS);
- G_free(modwkt);
CPLFree(wkt);
- if (proj4 != proj4mod)
- G_free(proj4);
- G_free(proj4mod);
- G_free(datum);
- G_free(params);
+ G_free(start);
+ G_free(ellps);
G_free(datumlongname);
- pj_free(pjinfo.pj);
G_free(ellpslong);
- /* Other string pointers may or may not need to be freed depending
- * on sequence of execution so just leave them. */
+ G_free(towgs84);
+ G_free(end);
return hSRS2;
@@ -451,13 +457,11 @@
if (list != NULL) {
do {
- break;
old = list;
list = list->next;
- G_free(old);
@@ -476,6 +480,7 @@
+ G_free(pszDatumName);
Modified: grass/trunk/lib/proj/datum.c
--- grass/trunk/lib/proj/datum.c 2009-01-28 12:17:43 UTC (rev 35666)
+++ grass/trunk/lib/proj/datum.c 2009-01-29 15:29:28 UTC (rev 35667)
@@ -85,7 +85,7 @@
int GPJ_get_default_datum_params_by_name(const char *name, char **params)
struct gpj_datum_transform_list *list, *old;
- int count = 1;
+ int count = 0;
list = GPJ_get_datum_transform_by_name(name);
@@ -98,14 +98,13 @@
* (will normally be a 3-parameter transformation) */
*params = G_store(list->params);
- while (list->next != NULL) {
+ while (list != NULL) {
count++;
old = list;
list = list->next;
- G_free(old);
- G_free(list);
return count;
@@ -311,6 +310,21 @@
+ * \brief Free the memory used by a gpj_datum_transform_list struct
+ * \param item gpj_datum_transform_list struct to be freed
+void GPJ_free_datum_transform(struct gpj_datum_transform_list *item)
+ G_free(item->params);
+ G_free(item->where_used);
+ G_free(item->comment);
+ G_free(item);
+ return;
* \brief Read the current GRASS datum.table from disk and store in
* memory
Modified: grass/trunk/lib/proj/ellipse.c
--- grass/trunk/lib/proj/ellipse.c 2009-01-28 12:17:43 UTC (rev 35666)
+++ grass/trunk/lib/proj/ellipse.c 2009-01-29 15:29:28 UTC (rev 35667)
@@ -55,7 +55,7 @@
const char *str, *str3;
- char *str1;
+ char *str1, *ellps;
str = G_find_key_value("datum", proj_keys);
@@ -63,25 +63,25 @@
/* If 'datum' key is present, look up correct ellipsoid
* from datum.table */
- str = G_store(dstruct.ellps);
+ ellps = G_store(dstruct.ellps);
else
/* else use ellipsoid defined in PROJ_INFO */
- str = G_find_key_value("ellps", proj_keys);
+ ellps = G_store(G_find_key_value("ellps", proj_keys));
- if (str != NULL) {
- if (GPJ_get_ellipsoid_by_name(str, &estruct) < 0) {
- G_fatal_error(_("Invalid ellipsoid <%s> in file"), str);
- else {
- *a = estruct.a;
- *e2 = estruct.es;
- *rf = estruct.rf;
- GPJ_free_ellps(&estruct);
- return 1;
+ if (ellps != NULL) {
+ if (GPJ_get_ellipsoid_by_name(ellps, &estruct) < 0)
+ G_fatal_error(_("Invalid ellipsoid <%s> in file"), ellps);
+ *a = estruct.a;
+ *e2 = estruct.es;
+ *rf = estruct.rf;
+ GPJ_free_ellps(&estruct);
+ G_free(ellps);
+ return 1;
else {
str3 = G_find_key_value("a", proj_keys);
Modified: grass/trunk/lib/proj/get_proj.c
--- grass/trunk/lib/proj/get_proj.c 2009-01-28 12:17:43 UTC (rev 35666)
+++ grass/trunk/lib/proj/get_proj.c 2009-01-29 15:29:28 UTC (rev 35667)
@@ -213,12 +213,12 @@
alloc_options(buffa);
returnval = 3;
- G_free(datum);
/* else there'll be no datum transformation taking place here... */
else {
returnval = 4;
+ G_free(datum);
/* Set finder function for locating datum conversion tables PK */
pj_set_finder(FINDERFUNC);
