[GRASS-SVN] r38220 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Jul 5 05:04:53 EDT 2009
Author: martinl
Date: 2009-07-05 05:04:53 -0400 (Sun, 05 Jul 2009)
New Revision: 38220
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI: launch script with full path
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2009-07-05 08:42:41 UTC (rev 38219)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2009-07-05 09:04:53 UTC (rev 38220)
@@ -65,7 +65,7 @@
def RunCmd(self, callable, onDone, *args, **kwds):
CmdThread.requestId += 1
self.requestCmd = None
self.requestQ.put((CmdThread.requestId, callable, onDone, args, kwds))
@@ -78,6 +78,7 @@
requestTime = time.time()
event = wxCmdRun(cmd=args[0],
pid=requestId)
wx.PostEvent(self.parent, event)
time.sleep(.1)
@@ -411,12 +412,15 @@
# console output window
# if command is not a GRASS command, treat it like a shell command
- try:
- gcmd.Command(cmdlist,
- stdout=self.cmd_stdout,
- stderr=self.cmd_stderr)
- except gcmd.CmdError, e:
- print >> sys.stderr, e
+ # process GRASS command with argument
+ self.cmdThread.RunCmd(GrassCmd,
+ onDone,
+ cmdlist,
+ self.cmd_stdout, self.cmd_stderr)
+ self.btn_abort.Enable()
+ self.cmd_output_timer.Start(50)
+ return None
return None
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-07-05 08:42:41 UTC (rev 38219)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-07-05 09:04:53 UTC (rev 38220)
@@ -304,6 +304,7 @@
for parsed filling.
def __init__(self, grassModule = None):
+ self.path = grassModule
self.name = _('unknown')
self.params = []
self.description = ''
@@ -825,8 +826,9 @@
self.notebookpanel.notebook.SetSelection(self.notebookpanel.goutputId)
try:
+ cmd[0] = self.task.path # full path
self.goutput.RunCmd(cmd)
- except AttributeError,e:
+ except AttributeError, e:
print >> sys.stderr, "%s: Propably not running in wxgui.py session?" % (e)
print >> sys.stderr, "parent window is: %s" % (str(self.parent))
# Send any other command to the shell.
@@ -1815,7 +1817,7 @@
sys.exit()
if sys.argv[1] != 'test':
q=wx.LogNull()
- GrassGUIApp( grassTask( sys.argv[1] ) ).MainLoop()
+ GrassGUIApp(grassTask(sys.argv[1])).MainLoop()
else: #Test
# Test grassTask from within a GRASS session
if os.getenv("GISBASE") is not None:
