[GRASS-SVN] r38221 - in grass-addons/general: . g.extension.add
svn_grass at osgeo.org
Sun Jul 5 05:50:34 EDT 2009
Author: neteler
Date: 2009-07-05 05:50:33 -0400 (Sun, 05 Jul 2009)
New Revision: 38221
Added:
grass-addons/general/g.extension.add/
grass-addons/general/g.extension.add/Makefile
grass-addons/general/g.extension.add/description.html
grass-addons/general/g.extension.add/g.extension.add
replacement for GEM; usable from 6.4.0RC5 onwards
Added: grass-addons/general/g.extension.add/Makefile
--- grass-addons/general/g.extension.add/Makefile (rev 0)
+++ grass-addons/general/g.extension.add/Makefile 2009-07-05 09:50:33 UTC (rev 38221)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../../../grass
+PGM = g.extension.add
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass-addons/general/g.extension.add/Makefile
___________________________________________________________________
Added: svn:eol-style
+ native
Added: grass-addons/general/g.extension.add/description.html
--- grass-addons/general/g.extension.add/description.html (rev 0)
+++ grass-addons/general/g.extension.add/description.html 2009-07-05 09:50:33 UTC (rev 38221)
@@ -0,0 +1,17 @@
+<h2>DESCRIPTION</h2>
+<em>g.extension.add</em> downloads and installs extensions from
+GRASS Addons SVN repository into the local GRASS installation.
+<h2>EXAMPLES</h2>
+Download and install i.landsat.toar into current GRASS installation:
+<div class="code"><pre>
+ g.extension.add extension=i.landsat.toar
+</pre></div>
+<h2>AUTHOR</h2>
+Markus Neteler
+<p><i>Last changed: $Date: 2008-06-28 04:37:22 -0500 (Sat, 28 Jun 2008) $</i>
Added: grass-addons/general/g.extension.add/g.extension.add
--- grass-addons/general/g.extension.add/g.extension.add (rev 0)
+++ grass-addons/general/g.extension.add/g.extension.add 2009-07-05 09:50:33 UTC (rev 38221)
@@ -0,0 +1,120 @@
+#!/bin/sh
+# MODULE: g.extension.add
+# AUTHOR(S): Markus Neteler
+# PURPOSE: tool to download and install extensions from GRASS Addons SVN into
+# local GRASS installation
+# COPYRIGHT: (C) 2009 by the Markus Neteler, GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# TODO: add sudo support where needed (i.e. check first permission to write into
+# $GISBASE directory)
+#%Module
+#% description: Tool to download and install extensions from GRASS Addons SVN repository into local GRASS installation.
+#% keywords: installation, extensions
+#%End
+#%option
+#% key: extension
+#% type: string
+#% key_desc : name
+#% description: Name of extension to install from GRASS Addons SVN repository
+#% required : yes
+#%end
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+# definitions
+SVNURL_ADDONS=https://svn.osgeo.org/grass/grass-addons/
+MYTMP=/tmp
+expand_module_class_name()
+# $1: module class
+ if [ "$1" = "d" ] ; then
+ echo "display"
+ elif [ "$1" = "db" ] ; then
+ echo "database"
+ elif [ "$1" = "g" ] ; then
+ echo "general"
+ elif [ "$1" = "i" ] ; then
+ echo "imagery"
+ elif [ "$1" = "m" ] ; then
+ echo "misc"
+ elif [ "$1" = "ps" ] ; then
+ echo "postscript"
+ elif [ "$1" = "p" ] ; then
+ echo "paint"
+ elif [ "$1" = "r" ] ; then
+ echo "raster"
+ elif [ "$1" = "r3" ] ; then
+ echo "raster3D"
+ elif [ "$1" = "s" ] ; then
+ echo "sites"
+ elif [ "$1" = "v" ] ; then
+ echo "vector"
+ else
+ echo "$1"
+ fi
+MODULE=$GIS_OPT_EXTENSION
+CLASSCHAR=`echo $MODULE | cut -d'.' -f1`
+MODULECLASS=`expand_module_class_name $CLASSCHAR`
+cleanup(){
+ cd ${MYTMP}
+ rm -rf ${MYTMP}/${MODULE}
+cd ${MYTMP}
+g.message message="Fetching ${MODULE} from GRASS-Addons SVN (be patient)..."
+svn co ${SVNURL_ADDONS}/${MODULECLASS}/${MODULE}
+if [ $? -ne 0 ] ; then
+ g.message -e message="GRASS Addon ${MODULE} not found in repository"
+ exit 1
+else
+ cd ${MYTMP}/${MODULE}
+ g.message message="Compiling ${MODULE}..."
+ make MODULE_TOPDIR=${GISBASE}
+ if [ $? -ne 0 ] ; then
+ g.message -e message="Compilation failed, sorry. Please check above error messages."
+ cleanup
+ exit 1
+ else
+ g.message message="Installing ${MODULE}..."
+ # can we write?
+ touch ${GISBASE}/$0.$$
+ sudo make MODULE_TOPDIR=${GISBASE} install
+ else
+ make MODULE_TOPDIR=${GISBASE} install
+ fi
+ g.message -e message="Installation failed, sorry. Please check above error messages."
+ cleanup
+ exit 1
+ fi
+ fi
+ cleanup
+fi
+g.message message="Installation of ${MODULE} successfully finished."
+exit 0
Property changes on: grass-addons/general/g.extension.add/g.extension.add
Added: svn:executable
