[GRASS-SVN] r38330 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Thu Jul 9 08:34:10 EDT 2009
Author: aghisla
Date: 2009-07-09 08:34:09 -0400 (Thu, 09 Jul 2009)
New Revision: 38330
grass-addons/vector/v.krige/v.krige.py
completed CLI implementation.
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-07-09 10:38:25 UTC (rev 38329)
+++ grass-addons/vector/v.krige/v.krige.py 2009-07-09 12:34:09 UTC (rev 38330)
@@ -119,45 +119,45 @@
#classes in alphabetical order. methods in logical order :)
class Controller():
- """ Executes analysis. """
+ """ Executes analysis. For the moment, only with gstat functions."""
- def ImportMap(self, Map):
- return robjects.r.readVECT6(Map, type= 'point')
+ def ImportMap(self, map):
+ return robjects.r.readVECT6(map, type= 'point')
- def CreateGrid(self, InputData):
+ def CreateGrid(self, inputdata):
Grid = robjects.r.gmeta2grd()
- ##create the spatialgriddataframe with these settings
GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
data=robjects.r['data.frame']
(k=robjects.r.rep(1,Region['cols']*Region['rows'])),
- proj4string=robjects.r.CRS(robjects.r.proj4string(InputData)))
+ proj4string=robjects.r.CRS(robjects.r.proj4string(inputdata)))
return GridPredicted
- def ComposeFormula(self, Column):
+ def ComposeFormula(self, column):
# will change when the formula will need to be more complex. Not yet.
- Formula = robjects.r['as.formula'](robjects.r.paste(Column, "~ 1"))
+ Formula = robjects.r['as.formula'](robjects.r.paste(column, "~ 1"))
return Formula
- def FitVariogram(self, Formula, InputData, Model, AutoFit, Sill=0, Nugget=0, Range=0):
- if AutoFit:
+ def FitVariogram(self, formula, inputdata, model, autofit, sill=0, nugget=0, range=0):
+ if autofit:
robjects.r.require("automap")
- VariogramModel = robjects.r.autofitVariogram(Formula, InputData)
+ VariogramModel = robjects.r.autofitVariogram(formula, inputdata)
return VariogramModel.r['var_model'][0]
else:
- DataVariogram = robjects.r.variogram(Formula, InputData)
+ DataVariogram = robjects.r.variogram(formula, inputdata)
VariogramModel = robjects.r['fit.variogram'](DataVariogram,
- model = robjects.r.vgm(psill = Sill,
- model = Model,
- nugget = Nugget,
- range = Range))
+ model = robjects.r.vgm(psill = sill,
+ model = model,
+ nugget = nugget,
+ range = range))
- def DoKriging():
- pass
- def ExportMap():
- pass
+ def DoKriging(self, formula, inputdata, grid, model):
+ KrigingResult = robjects.r.krige(formula, inputdata, grid, model)
+ return KrigingResult
+ def ExportMap(self, map, column, name, overwrite):
+ robjects.r.writeRAST6(map, vname = name, zcol = column, overwrite = overwrite)
class KrigingPanel(wx.Panel):
""" Main panel. Contains all widgets except Menus and Statusbar. """
def __init__(self, parent, *args, **kwargs):
@@ -299,22 +299,31 @@
self.parent.log.write(_("Variogram fitting"))
Formula = self.Controller.ComposeFormula(Column)
- Variogram = self.Controller.FitVariogram(Formula, InputData, ModelShortName)
+ Variogram = self.Controller.FitVariogram(Formula,
+ InputData,
+ ModelShortName,
+ autofit = SelectedPanel.VariogramCheckBox.IsChecked(),
+ sill = Sill,
+ nugget = Nugget,
+ range = Range)
# print variogram?
#robjects.r.plot(Variogram.r['exp_var'], Variogram.r['var_model']) #does not work.
#see if it caused by automap/gstat dedicated plot function.
self.parent.log.write(_("Variogram fitted."))
- #### go on refactoring from here
#4. Kriging
self.parent.log.write('Kriging...')
- KrigingResult = SelectedPanel.DoKriging(formula = Formula, data = InputData, grid = GridPredicted, model = Variogram)
+ KrigingResult = self.Controller.DoKriging(formula = Formula,
+ inputdata = InputData,
+ grid = GridPredicted,
+ model = Variogram)
self.parent.log.write('Kriging performed.')
#5. Format output
- SelectedPanel.ExportMap(map = KrigingResult, col='var1.pred', name = self.OutputMapName.GetValue(),
- overwrite = self.OverwriteCheckBox.GetValue())
+ self.Controller.ExportMap(map = KrigingResult,
+ column='var1.pred',
+ name = self.OutputMapName.GetValue(),
+ overwrite = self.OverwriteCheckBox.GetValue())
self.parent.log.write('Yippee! Succeeded! Ready for another run.')
def OnCloseWindow(self, event):
@@ -404,26 +413,6 @@
self.ParametersSizer.Insert(before=1, item= self.ModelChoicebox)
self.SetSizerAndFit(self.Sizer)
- def FitVariogram(self, formula, data):
- print "SHOULD BE OVERRIDDEN"
- if self.VariogramCheckBox.IsChecked():
- robjects.r.require("automap")
- VariogramModel = robjects.r.autofitVariogram(formula, data)
- return VariogramModel.r['var_model'][0]
- else:
- DataVariogram = robjects.r.variogram(formula, data)
- ModelShortName = self.ModelChoicebox.GetStringSelection().split()[0]
- VariogramModel = robjects.r['fit.variogram'](DataVariogram,
- model = robjects.r.vgm(psill = self.SillCtrl.GetValue(),
- model = ModelShortName,
- nugget = self.NuggetCtrl.GetValue(),
- range = self.RangeCtrl.GetValue()))
- def DoKriging(self, formula, data, grid, model):
- KrigingResult = robjects.r.krige(formula, data, grid, model)
- return KrigingResult
def HideOptions(self, event):
self.ModelChoicebox.Enable(not event.IsChecked())
@@ -441,12 +430,6 @@
n.Hide()
self.Sizer.Add(wx.StaticText(self, id= wx.ID_ANY, label = _("Work in progress! No functionality provided.")))
- def FitVariogram(self, Formula, InputData):
- pass
- def DoKriging():
- pass
def main(argv=None):
@@ -479,7 +462,13 @@
except ImportError, e:
grass.message(_("R package automap is missing, no variogram autofit available."))
+ if argv[0]['output'] is '':
+ argv[0]['output'] = argv[0]['input'] + '_kriging'
+ ## check for output map with same name NOW
+ #if argv[0]['output'] == grass.find_file():
+ # pass
# Import packages
robjects.r.require(argv[0]['package'])
robjects.r.require("spgrass6")
@@ -488,25 +477,31 @@
grass.message(_("Importing data..."))
InputData = controller.ImportMap(argv[0]['input'])
grass.message("Imported.")
+ GridPredicted = controller.CreateGrid(InputData)
# Fit Variogram
- grass.message("Fitting variogram...")
+ grass.message(_("Fitting variogram..."))
Formula = controller.ComposeFormula(argv[0]['column'])
Variogram = controller.FitVariogram(Formula,
InputData,
- Model = argv[0]['model'],
- AutoFit = argv[0]['model'] is '',
- Sill = argv[0]['sill'],
- Nugget = argv[0]['nugget'],
- Range = argv[0]['range']
- grass.message("Variogram fitted.")
+ model = argv[0]['model'],
+ autofit = argv[0]['model'] is '',
+ sill = argv[0]['sill'],
+ nugget = argv[0]['nugget'],
+ range = argv[0]['range'])
+ grass.message(_("Variogram fitted."))
# Krige
- grass.message("Kriging...")
+ grass.message(_("Kriging..."))
+ KrigingResult = controller.DoKriging(Formula, InputData, GridPredicted, Variogram)
+ grass.message(_("Kriging performed."))
# Export map
+ controller.ExportMap(map = KrigingResult,
+ name = argv[0]['output'],
+ overwrite = argv[1]['o'])
+ grass.message(_("Map exported. "))
if __name__ == '__main__':
if len(sys.argv) > 1:
