[GRASS-SVN] r38331 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Thu Jul 9 08:55:33 EDT 2009
Author: aghisla
Date: 2009-07-09 08:55:33 -0400 (Thu, 09 Jul 2009)
New Revision: 38331
grass-addons/vector/v.krige/v.krige.html
update documentation: synopsis, examples
Modified: grass-addons/vector/v.krige/v.krige.html
--- grass-addons/vector/v.krige/v.krige.html 2009-07-09 12:34:09 UTC (rev 38330)
+++ grass-addons/vector/v.krige/v.krige.html 2009-07-09 12:55:33 UTC (rev 38331)
@@ -1,16 +1,52 @@
<h2>NAME</h2>
-<i><b>v.krige</b></i> - Performs kriging via R software.
+<em><b>v.krige.py</b></em> - Performs ordinary kriging.
<h2>KEYWORDS</h2>
-TODO
+kriging
<h2>SYNOPSIS</h2>
-<b>v.krige</b><br>
-<b>v.krige help</b><br>
-<b>v.krige</b> <b>map</b>=<em>string</em> [<b>layer</b>=<em>integer</em>] <b>column</b>=<em>string</em> [<b>value</b>=<em>string</em>] [<b>qcolumn</b>=<em>string</em>] [<b>where</b>=<em>string</em>] [--<b>verbose</b>] [--<b>quiet</b>]
+<b>v.krige.py</b><br>
+<b>v.krige.py help</b><br>
+<b>v.krige.py</b> [-<b>o</b>] <b>input</b>=<em>string</em> <b>column</b>=<em>string</em> [<b>output</b>=<em>string</em>] [<b>package</b>=<em>string</em>] [<b>model</b>=<em>string</em>[,<i>string</i>,...]] [<b>range</b>=<em>integer</em>] [<b>nugget</b>=<em>integer</em>] [<b>sill</b>=<em>integer</em>] [--<b>verbose</b>] [--<b>quiet</b>]
+<h3>Flags:</h3>
+<DL>
+<DT><b>-o</b></DT>
+<DD>Overwrite output map with same name</DD>
+<DT><b>--verbose</b></DT>
+<DD>Verbose module output</DD>
+<DT><b>--quiet</b></DT>
+<DD>Quiet module output</DD>
+</DL>
+<h3>Parameters:</h3>
+<DL>
+<DT><b>input</b>=<em>string</em></DT>
+<DD>Name of point vector map containing sample data.</DD>
+<DT><b>column</b>=<em>string</em></DT>
+<DD>Column with numerical value to be interpolated</DD>
+<DT><b>output</b>=<em>string</em></DT>
+<DD>Name of output map. If omitted, will be <input name>_kriging</DD>
+<DT><b>package</b>=<em>string</em></DT>
+<DD>R package to use. Choices: gstat, geor</DD>
+<DD>Options: <em>gstat, geor</em></DD>
+<DD>Default: <em>gstat</em></DD>
+<DT><b>model</b>=<em>string[,<i>string</i>,...]</em></DT>
+<DD>Variogram model(s). Leave empty to</DD>
+<DD>Options: <em>Exp,Sph,Gau,Mat,Lin</em></DD>
+<DT><b>range</b>=<em>integer</em></DT>
+<DD>Range value. Automatically fixed if not set</DD>
+<DT><b>nugget</b>=<em>integer</em></DT>
+<DD>Nugget value. Automatically fixed if not set</DD>
+<DT><b>sill</b>=<em>integer</em></DT>
+<DD>Sill value. Automatically fixed if not set</DD>
<h2>DESCRIPTION</h2>
<i>v.krige</i> allows to perform kriging operations in GRASS environment,
using R software functions in background.
@@ -43,8 +79,28 @@
<h2>EXAMPLES</h2>
-TODO
+Run GUI:
+<br>
+<div class="code"><pre>
+ v.krige.py
+</pre></div>
+<p>
+Run CLI, minimum options required for ordinary kriging with automatic variogram fit (requires package automap):
+<br>
+ v.krige.py input=rs column=elev
+</pre></div>
+<p>
+Run CLI, more options:
+<br>
+ v.krige.py input=rs at PERMANENT column=elev model=Lin sill=2500 nugget=0 range=1000 output=rs_kriging
+</pre></div>
<h2>SEE ALSO</h2>
<h2>AUTHOR</h2>
@@ -52,4 +108,4 @@
Anne Ghisla, Google Summer of Code 2009
<p>
-<i>Last changed: $Date$</i>
\ No newline at end of file
+<i>Last changed: $Date$</i>
