[GRASS-SVN] r38332 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Thu Jul 9 10:05:25 EDT 2009
Author: martinl
Date: 2009-07-09 10:05:24 -0400 (Thu, 09 Jul 2009)
New Revision: 38332
grass-addons/vector/v.krige/v.krige.py
cosmetics in CLI, -o flag replaced by --o
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-07-09 12:55:33 UTC (rev 38331)
+++ grass-addons/vector/v.krige/v.krige.py 2009-07-09 14:05:24 UTC (rev 38332)
@@ -26,7 +26,7 @@
#% key: input
#% type: string
#% gisprompt: old,vector,vector
-#% description: Name of point vector map containing sample data.
+#% description: Name of point vector map containing sample data
#% required: yes
#%end
#%option
@@ -38,8 +38,9 @@
#%option
#% key: output
#% type: string
-#% gisprompt: old,raster,raster
-#% description: Name of output map. If omitted, will be <input name>_kriging
+#% gisprompt: new,cell,raster
+#% label: Name for output raster map
+#% description: If omitted, will be <input name>_kriging
#% required : no
#%end
#%option
@@ -47,7 +48,7 @@
#% type: string
#% options: gstat, geor
#% answer: gstat
-#% description: R package to use. Choices: gstat, geor
+#% description: R package to use
#% required: no
#%end
#%option
@@ -55,35 +56,31 @@
#% type: string
#% options: Exp,Sph,Gau,Mat,Lin
#% multiple: yes
-#% description: Variogram model(s). Leave empty to
+#% label: Variogram model(s)
+#% description: Leave empty to
#% required: no
#%end
#%option
#% key: range
#% type: integer
-#% description: Range value. Automatically fixed if not set
+#% label: Range value
+#% description: Automatically fixed if not set
#% required : no
#%end
#%option
#% key: nugget
#% type: double
-#% description: Nugget value. Automatically fixed if not set
+#% label: Nugget value
#% required : no
#%end
#%option
#% key: sill
#% type: double
-#% description: Sill value. Automatically fixed if not set
+#% label: Sill value
#% required : no
#%end
-#%flag
-#% key: o
-#% description: Overwrite output map with same name
-#%end
-# #%flag
-# #% key:
-# #% description:
-# #%end
import os, sys
@@ -499,9 +496,9 @@
# Export map
controller.ExportMap(map = KrigingResult,
column='var1.pred',
- name = argv[0]['output'],
- overwrite = argv[1]['o'])
- grass.message(_("Map exported. "))
+ name = argv[0]['output'])
+ grass.message(_("Map exported."))
if __name__ == '__main__':
if len(sys.argv) > 1:
