[GRASS-SVN] r38333 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Thu Jul 9 10:12:27 EDT 2009
Author: martinl
Date: 2009-07-09 10:12:27 -0400 (Thu, 09 Jul 2009)
New Revision: 38333
grass-addons/vector/v.krige/v.krige.py
cosmetics in variables name
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-07-09 14:05:24 UTC (rev 38332)
+++ grass-addons/vector/v.krige/v.krige.py 2009-07-09 14:12:27 UTC (rev 38333)
@@ -438,7 +438,7 @@
# data availability when clicking Run button. Quite late.
if not haveRpy2:
sys.exit(1)
#@FIXME: solve this double ifelse. the control should not be done twice.
if argv is None:
argv = sys.argv[1:] #stripping first item, the full name of this script
@@ -449,43 +449,44 @@
k.Show()
app.MainLoop()
else:
+ options, flags = argv
#CLI
#@TODO: Work on verbosity. Sometimes it's too verbose (R), sometimes not enough.
controller = Controller()
- #print argv[0]
- #print argv[1]
- if argv[0]['model'] is '':
+ #print options
+ #print flags
+ if options['model'] is '':
try:
robjects.r.require("automap")
except ImportError, e:
grass.message(_("R package automap is missing, no variogram autofit available."))
- if argv[0]['output'] is '':
- argv[0]['output'] = argv[0]['input'] + '_kriging'
+ if options['output'] is '':
+ options['output'] = options['input'] + '_kriging'
## check for output map with same name NOW
- #if argv[0]['output'] == grass.find_file():
+ #if options['output'] == grass.find_file():
# pass
# Import packages
- robjects.r.require(argv[0]['package'])
+ robjects.r.require(options['package'])
robjects.r.require("spgrass6")
# Get data and create grid
grass.message(_("Importing data..."))
- InputData = controller.ImportMap(argv[0]['input'])
+ InputData = controller.ImportMap(options['input'])
grass.message("Imported.")
GridPredicted = controller.CreateGrid(InputData)
# Fit Variogram
grass.message(_("Fitting variogram..."))
- Formula = controller.ComposeFormula(argv[0]['column'])
+ Formula = controller.ComposeFormula(options['column'])
Variogram = controller.FitVariogram(Formula,
InputData,
- model = argv[0]['model'],
- autofit = argv[0]['model'] is '',
- sill = argv[0]['sill'],
- nugget = argv[0]['nugget'],
- range = argv[0]['range'])
+ model = options['model'],
+ autofit = options['model'] is '',
+ sill = options['sill'],
+ nugget = options['nugget'],
+ range = options['range'])
grass.message(_("Variogram fitted."))
# Krige
@@ -496,7 +497,7 @@
# Export map
controller.ExportMap(map = KrigingResult,
column='var1.pred',
- name = argv[0]['output'])
+ name = options['output'])
grass.message(_("Map exported."))
