[GRASS-SVN] r38532 - grass/trunk/gui/wxpython/xml
Wed Jul 29 03:21:43 EDT 2009
Author: martinl
Date: 2009-07-29 03:21:40 -0400 (Wed, 29 Jul 2009)
New Revision: 38532
   grass/trunk/gui/wxpython/xml/menudata.xml
Link to GDAL/OGR moved to 'File' item menu (see trac #643)
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2009-07-29 07:07:23 UTC (rev 38531)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2009-07-29 07:21:40 UTC (rev 38532)
@@ -63,6 +63,19 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
+	      <label>Link to GDAL</label>
+	      <help>Link GDAL supported raster file to a binary raster map layer.</help>
+	      <keywords>raster,import</keywords>
+              <handler>self.OnMenuCmd</handler>
+	      <command>r.external</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Multiple link to GDAL</label>
+	      <help>Link GDAL supported raster files to a binary raster map layers.</help>
+              <handler>self.OnLinkGdalLayers</handler>
+	    </menuitem>
+	    <separator />
+	    <menuitem>
 	      <label>Aggregate ASCII xyz import</label>
 	      <help>Create a raster map from an assemblage of many coordinates using univariate statistics.</help>
 	      <keywords>raster,import,LIDAR</keywords>
@@ -158,6 +171,19 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
+	      <label>Link to OGR</label>
+	      <help>Creates a new vector as a read-only link to OGR layer.</help>
+	      <keywords>vector</keywords>
+	      <command>v.external</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Multiple link to OGR</label>
+	      <help>Creates a new vectors as a read-only link to OGR layers.</help>
+              <handler>self.OnLinkOgrLayers</handler>
+	    </menuitem>
+	    <separator />
+	    <menuitem>
 	      <label>ASCII points/GRASS ASCII vector import</label>
 	      <help>Creates a vector map from ASCII points file or ASCII vector file.</help>
 	      <keywords>vector,import</keywords>
@@ -817,19 +843,6 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
-	      <label>Link to GDAL</label>
-	      <help>Link GDAL supported raster file to a binary raster map layer.</help>
-	      <keywords>raster,import</keywords>
-              <handler>self.OnMenuCmd</handler>
-	      <command>r.external</command>
-	    </menuitem>
-	    <menuitem>
-	      <label>Multiple link to GDAL</label>
-	      <help>Link GDAL supported raster files to a binary raster map layers.</help>
-              <handler>self.OnLinkGdalLayers</handler>
-	    </menuitem>
-	    <separator />
-	    <menuitem>
 	      <label>Reproject raster</label>
 	      <help>Re-projects a raster map from one location to the current location.</help>
 	      <keywords>raster,projection</keywords>
@@ -1734,19 +1747,6 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
-	      <label>Link to OGR</label>
-	      <help>Creates a new vector as a read-only link to OGR layer.</help>
-	      <keywords>vector</keywords>
-	      <command>v.external</command>
-	    </menuitem>
-	    <menuitem>
-	      <label>Multiple link to OGR</label>
-	      <help>Creates a new vectors as a read-only link to OGR layers.</help>
-              <handler>self.OnLinkOgrLayers</handler>
-	    </menuitem>
-	    <separator />
-	    <menuitem>
 	      <label>Create labels</label>
 	      <help>Creates paint labels for a vector map from attached attributes.</help>
 	      <keywords>vector,paint labels</keywords>
