[GRASS-SVN] r38533 - grass/branches/develbranch_6/gui/wxpython/xml
svn_grass at osgeo.org
Wed Jul 29 03:36:27 EDT 2009
Author: martinl
Date: 2009-07-29 03:36:26 -0400 (Wed, 29 Jul 2009)
New Revision: 38533
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
Link to GDAL/OGR moved to 'File' item menu (see trac #643)
(merge from trunk, r38532)
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2009-07-29 07:21:40 UTC (rev 38532)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2009-07-29 07:36:26 UTC (rev 38533)
@@ -63,6 +63,19 @@
</menuitem>
<separator />
<menuitem>
+ <label>Link to GDAL</label>
+ <help>Link GDAL supported raster file to a binary raster map layer.</help>
+ <keywords>raster,import</keywords>
+ <handler>self.OnMenuCmd</handler>
+ <command>r.external</command>
+ </menuitem>
+ <menuitem>
+ <label>Multiple link to GDAL</label>
+ <help>Link GDAL supported raster files to a binary raster map layers.</help>
+ <handler>self.OnLinkGdalLayers</handler>
+ </menuitem>
+ <separator />
+ <menuitem>
<label>Aggregate ASCII xyz import</label>
<help>Create a raster map from an assemblage of many coordinates using univariate statistics.</help>
<keywords>raster,import,LIDAR</keywords>
@@ -158,6 +171,19 @@
</menuitem>
<separator />
<menuitem>
+ <label>Link to OGR</label>
+ <help>Creates a new vector as a read-only link to OGR layer.</help>
+ <keywords>vector</keywords>
+ <command>v.external</command>
+ </menuitem>
+ <menuitem>
+ <label>Multiple link to OGR</label>
+ <help>Creates a new vectors as a read-only link to OGR layers.</help>
+ <handler>self.OnLinkOgrLayers</handler>
+ </menuitem>
+ <separator />
+ <menuitem>
<label>ASCII points/GRASS ASCII vector import</label>
<help>Creates a vector map from ASCII points file or ASCII vector file.</help>
<keywords>vector,import</keywords>
@@ -824,19 +850,6 @@
</menuitem>
<separator />
<menuitem>
- <label>Link to GDAL</label>
- <help>Link GDAL supported raster file to a binary raster map layer.</help>
- <keywords>raster,import</keywords>
- <handler>self.OnMenuCmd</handler>
- <command>r.external</command>
- </menuitem>
- <menuitem>
- <label>Multiple link to GDAL</label>
- <help>Link GDAL supported raster files to a binary raster map layers.</help>
- <handler>self.OnLinkGdalLayers</handler>
- </menuitem>
- <separator />
- <menuitem>
<label>Reproject raster</label>
<help>Re-projects a raster map from one location to the current location.</help>
<keywords>raster,projection</keywords>
@@ -1796,19 +1809,6 @@
</menuitem>
<separator />
<menuitem>
- <label>Link to OGR</label>
- <help>Creates a new vector as a read-only link to OGR layer.</help>
- <keywords>vector</keywords>
- <command>v.external</command>
- </menuitem>
- <menuitem>
- <label>Multiple link to OGR</label>
- <help>Creates a new vectors as a read-only link to OGR layers.</help>
- <handler>self.OnLinkOgrLayers</handler>
- </menuitem>
- <separator />
- <menuitem>
<label>Create labels</label>
<help>Creates paint labels for a vector map from attached attributes.</help>
<keywords>vector,paint labels</keywords>
