[GRASS-SVN] r38534 - grass/branches/releasebranch_6_4/gui/wxpython/xml
Wed Jul 29 03:45:30 EDT 2009
Author: martinl
Date: 2009-07-29 03:45:30 -0400 (Wed, 29 Jul 2009)
New Revision: 38534
   grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
Link to GDAL/OGR moved to 'File' item menu (see trac #643)
    (merge from trunk, r38532)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
--- grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml	2009-07-29 07:36:26 UTC (rev 38533)
+++ grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml	2009-07-29 07:45:30 UTC (rev 38534)
@@ -62,6 +62,19 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
+	      <label>Link to GDAL</label>
+	      <help>Link GDAL supported raster file to a binary raster map layer.</help>
+	      <keywords>raster,import</keywords>
+              <handler>self.OnMenuCmd</handler>
+	      <command>r.external</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Multiple link to GDAL</label>
+	      <help>Link GDAL supported raster files to a binary raster map layers.</help>
+              <handler>self.OnLinkGdalLayers</handler>
+	    </menuitem>
+	    <separator />
+	    <menuitem>
 	      <label>Aggregate ASCII xyz import</label>
 	      <help>Create a raster map from an assemblage of many coordinates using univariate statistics.</help>
@@ -147,6 +160,19 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
+	      <label>Link to OGR</label>
+	      <help>Creates a new vector as a read-only link to OGR layer.</help>
+	      <keywords>vector</keywords>
+	      <command>v.external</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Multiple link to OGR</label>
+	      <help>Creates a new vectors as a read-only link to OGR layers.</help>
+              <handler>self.OnLinkOgrLayers</handler>
+	    </menuitem>
+	    <separator />
+	    <menuitem>
 	      <label>ASCII points/GRASS ASCII vector import</label>
 	      <help>Creates a vector map from ASCII points file or ASCII vector file.</help>
@@ -737,18 +763,6 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
-	      <label>Link to GDAL</label>
-	      <help>Link GDAL supported raster file to a binary raster map layer.</help>
-	      <handler>self.OnMenuCmd</handler>
-	      <command>r.external</command>
-	    </menuitem>
-	    <menuitem>
-	      <label>Multiple link to GDAL</label>
-	      <help>Link GDAL supported raster files to a binary raster map layers.</help>
-              <handler>self.OnLinkGdalLayers</handler>
-	    </menuitem>
-	    <separator />
-	    <menuitem>
 	      <label>Reproject raster</label>
 	      <help>Re-projects a raster map from one location to the current location.</help>
@@ -1593,18 +1607,6 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
-	      <label>Link to OGR</label>
-	      <help>Creates a new vector as a read-only link to OGR layer.</help>
-	      <command>v.external</command>
-	    </menuitem>
-	    <menuitem>
-	      <label>Multiple link to OGR</label>
-	      <help>Creates a new vectors as a read-only link to OGR layers.</help>
-              <handler>self.OnLinkOgrLayers</handler>
-	    </menuitem>
-	    <separator />
-	    <menuitem>
 	      <label>Create labels</label>
 	      <help>Creates paint labels for a vector map from attached attributes.</help>
@@ -2401,4 +2403,4 @@
       </items>
     </menu>
   </menubar>
-</menudata>
\ No newline at end of file
+</menudata>
