[GRASS-SVN] r37742 - grass-addons/vector/v.autokrige2
svn_grass at osgeo.org
Fri Jun 5 10:14:13 EDT 2009
Author: aghisla
Date: 2009-06-05 10:14:13 -0400 (Fri, 05 Jun 2009)
New Revision: 37742
grass-addons/vector/v.autokrige2/v.autokrige2.py
interface configuration simplified, preparing automap integration
Modified: grass-addons/vector/v.autokrige2/v.autokrige2.py
--- grass-addons/vector/v.autokrige2/v.autokrige2.py 2009-06-05 12:47:11 UTC (rev 37741)
+++ grass-addons/vector/v.autokrige2/v.autokrige2.py 2009-06-05 14:14:13 UTC (rev 37742)
@@ -16,12 +16,9 @@
for details.
-#list of parameters
-#import directives. to be completed.
import wx
import sys
-#import wx.lib.flatnotebook as FN # self.notebook attribute in Kriging Module's __init__
+import gcmd
#classes in alphabetical order
@@ -32,49 +29,46 @@
def __init__(self, parent, *args, **kwargs):
wx.Panel.__init__(self, parent, *args, **kwargs)
- self.parent = parent
-# widgettery. They are all Panels into StaticBox Sizers.
-# 1. Input Data. Combobox with all point layers of the mapset with xyz data: see how to call d.vect.
-# whateverNameOfFunction(ltype='vector',
-# lname=name,
-# lchecked=True,
-# lopacity=1.0,
-# lcmd=['d.vect', 'map=%s' % name])
-# 2. Variogram.
-# RadioButton (default choice): Auto-fit Variogram
-# RadioButton: Choose variogram parameters -> Button that opens a dialog with the variogram plot and controls.
-# 3. Kriging.
-# 2 Notebook pages, one for R package gstat and other for geoR. Each page will have the available options, zB:
-# RadioButton (default): Ordinary Kriging
-# RadioButton: Block Kriging
-# RadioButton: Cokriging
-# n. OK - Cancel buttons
+ self.parent = parent
-# Implementation.
# 1. Input data
InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, -1, 'Input Data'), wx.HORIZONTAL)
- self.SampleList = ['input map1','input map 2'] # fake list. See how to deal with GRASS maps, filtering them accordingly.
+ self.SampleList = self.__getVectors()
self.InputDataLabel = wx.StaticText(self, -1, "Point dataset")
- self.InputDataCombobox=wx.ComboBox(self, -1, "", (-1,-1), (-1,-1), self.SampleList, wx.CB_DROPDOWN) # see ho to get rid of position and size.
+ self.InputDataChoicebox = wx.Choice(self, -1, self.SampleList)
InputBoxSizer.Add(self.InputDataLabel, -1, wx.ALIGN_LEFT, 1)
- InputBoxSizer.Add(self.InputDataCombobox, -1, wx.EXPAND, 1)
-# 2. Variogram.
-# VariogramBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, -1, 'Variogram'), wx.VERTICAL). # discarded. radiobox is p-e-r-f-e-c-t.
- self.RadioList = ["Auto-fit variogram", "Choose variogram parameters"]
- VariogramRadioBox = wx.RadioBox(self, -1, "Variogram Fitting", (-1,-1), wx.DefaultSize, self.RadioList, 1, wx.RA_SPECIFY_COLS)
+ InputBoxSizer.Add(self.InputDataChoicebox, -1, wx.EXPAND, 1)
-# 3. Kriging.
- #@TODO(anne): examine gstat and geoR f(x)s and fill the notebook.
+# 2. Kriging. In book pages one for each R package. Includes variogram fit.
+ KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self, -1, 'Kriging'), wx.HORIZONTAL)
+ self.RPackagesBook = RPackagesBook(parent= self)
+ KrigingSizer.Add(self.RPackagesBook, wx.EXPAND)
# Main Sizer. Add each child sizer as soon as it is ready.
Sizer = wx.BoxSizer(wx.VERTICAL)
Sizer.Add(InputBoxSizer, 0, wx.EXPAND, 5)
- Sizer.Add(VariogramRadioBox, 0, wx.EXPAND, 5)
-# Sizer.Add(next)
+ Sizer.Add(KrigingSizer, 0, wx.EXPAND, 5)
self.SetSizerAndFit(Sizer)
+ def __getVectors(self, *args, **kwargs):
+ """Get list of tables for given location and mapset"""
+ vectors = []
+ cmdVectors = gcmd.Command(['g.list',
+ 'vect', '--q',
+# 'driver=%s' % driver,
+# 'database=%s' % database
+ rerr=None) # what does it mean? is it useful?
+ if cmdVectors.returncode != 0:
+ wx.MessageBox(parent=self,
+ message=_("Unable to get list of vectors. Check if the location is correct."),
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ return vectors
+ for vector in cmdVectors.ReadStdOutput():
+ vectors.append(vector)
+ return vectors
class KrigingModule(wx.Frame):
@@ -87,16 +81,8 @@
self.log = Log(self) # writes on statusbar
self.CreateStatusBar()
# debug: remove before flight
- self.log.write("Are you reading this? This proves it is very beta version.")
+ self.log.write("Under construction.")
-# # sizer stuff. Improvable.
-# vsizer1 = wx.BoxSizer(orient=wx.VERTICAL)
-# # uncommment this line when panels will be ready to be added
-## vsizer1.Add(item=, proportion=1, flag=wx.EXPAND | wx.ALL, border=10)
-# self.SetSizerAndFit(vsizer1)
-# self.SetAutoLayout(True)
-# vsizer1.Fit(self)
#@TODO(anne): set minimum size around objects.
self.Panel = KrigingPanel(self)
@@ -113,6 +99,47 @@
"""Update status bar"""
self.parent.SetStatusText(text_string.strip())
+class RPackagesBook(wx.Notebook):
+ Book whose pages are the three R packages providing kriging facilities.
+ def __init__(self, parent, *args, **kwargs):
+ wx.Notebook.__init__(self, parent, *args, **kwargs)
+ self.__createAutomapPage()
+ self.__createGstatPage()
+ self.__createGeoRPage()
+ # consider refactor this!
+ def __createAutomapPage(self):
+ self.AutomapPanel = wx.Panel(self, -1)
+ self.AddPage(page=self.AutomapPanel, text="automap")
+ self.RadioList = ["Auto-fit variogram", "Choose variogram parameters"]
+ VariogramRadioBox = wx.RadioBox(self.AutomapPanel, -1, "Variogram Fitting", (-1,-1), wx.DefaultSize,
+ self.RadioList, 1, wx.RA_SPECIFY_COLS)
+ # add stuff to panel
+ def __createGstatPage(self):
+ self.GstatPanel = wx.Panel(self, -1)
+ self.AddPage(page=self.GstatPanel, text="gstat")
+ def __createGeoRPage(self):
+ self.GeoRPanel = wx.Panel(self, -1)
+ self.AddPage(page=self.GeoRPanel, text="geoR")
+ def __getColumns(self, driver, database, table):
+ """Get list of column of given table"""
+ columns = []
+# change accordingly
+# cmdColumn = gcmd.Command(['db.columns',
+# '--q',
+# 'database=%s' % database,
+# 'table=%s' % table],
+# rerr = None)
+ for column in cmdColumn.ReadStdOutput():
+ columns.append(column)
+ return columns
#main
def main(argv=None):
if argv is None:
@@ -139,20 +166,3 @@
if __name__ == '__main__':
main()
-## notebook stuff. If used, uncomment also import directive for flat notebook.
-# self.notebook = FN.FlatNotebook(parent=self.panel, id=wx.ID_ANY,
-# style=FN.FNB_BOTTOM |
-# FN.FNB_NO_NAV_BUTTONS |
-# FN.FNB_FANCY_TABS | FN.FNB_NO_X_BUTTON)
-# # use this block to add pages to the flat notebook widget
-## dbmStyle = globalvar.FNPageStyle
-# ## start block
-# self.collectDataPage = FN.FlatNotebook(self.panel, id=wx.ID_ANY)
-# self.notebook.AddPage(self.collectDataPage, text=("Collect Data"))
-## self.browsePage.SetTabAreaColour(globalvar.FNPageColor)
-# ## end block
-# def __createCollectDataPage(self):
-# pass
