[GRASS-SVN] r37743 - grass-addons/vector/v.autokrige
svn_grass at osgeo.org
Fri Jun 5 10:18:25 EDT 2009
Author: mathieug
Date: 2009-06-05 10:18:25 -0400 (Fri, 05 Jun 2009)
New Revision: 37743
grass-addons/vector/v.autokrige/v.autokrige.py
v.autokrige.py : a port of v.autokrige to python (working beta version). Modified variogram ouptut and R output log.
Modified: grass-addons/vector/v.autokrige/v.autokrige.py
--- grass-addons/vector/v.autokrige/v.autokrige.py 2009-06-05 14:14:13 UTC (rev 37742)
+++ grass-addons/vector/v.autokrige/v.autokrige.py 2009-06-05 14:18:25 UTC (rev 37743)
@@ -93,6 +93,10 @@
#% key: r
#% description: Don't set region from sites extent. Region would have been previously set in grass.
#%end
+#%flag
+#% key: l
+#% description: Log R output to v.autokrige.log.
+#%end
import sys
import os
@@ -102,7 +106,7 @@
##see http://trac.osgeo.org/grass/browser/grass/trunk/lib/python
from grass import core as grass
-##only needed to use debugger
+##only needed to use debugger. See http://aspn.activestate.com/ASPN/Downloads/Komodo/RemoteDebugging
from dbgp.client import brk
class AutoKrige():
@@ -121,9 +125,11 @@
##flags
self.varianceFlag = True if flags['v'] is True else False
self.regionFlag = True if flags['r'] is True else False
+ self.logROutput = True if flags['l'] is True else False
#others
self.RscriptFile = None
- self.logfile='v.autokrige.log'
+ logfilename = 'v.autokrige.log'
+ self.logfile = os.path.join(os.getenv('LOGDIR'),logfilename) if os.getenv('LOGDIR') else logfilename
def __checkLayers(self, input, output):
@@ -207,6 +213,7 @@
options(echo = FALSE)
args <- commandArgs()
##start at index 5 because first arguments are R options
+ cat("arguments:","\n")
sitesG <- args[5]
column <- args[6]
rastername <- args[7]
@@ -218,6 +225,40 @@
if(args[12] == "NA") {sill = NA} else {sill <- as.numeric(args[12])}
writevarrast <- as.logical(args[13])
+ ##print arguments
+ cat("sitesG:",sitesG,"\n")
+ cat("column:",column,"\n")
+ cat("rastername:",rastername,"\n")
+ cat("cellsize:",cellsize,"\n")
+ cat("modelslist:",modelslist,"\n")
+ cat("range:",range,"\n")
+ cat("nugget:",nugget,"\n")
+ cat("sill:",sill,"\n")
+ cat("writevarrast:",writevarrast,"\n")
+ ##variogram plot function
+ plot.autoKrigeVariogramAndFittedModel = function(x, sp.layout = NULL, ...)
+ ##Function adapted from plot.autoKrige in automap package.
+ ##Prints only the variogram and model as we already have the map output in GRASS.
+ library(lattice)
+ shift = 0.03
+ labels = as.character(x$exp_var$np)
+ vario = xyplot(gamma ~ dist, data = x$exp_var, panel = automap:::autokrige.vgm.panel,
+ labels = labels, shift = shift, model = x$var_model,# subscripts = TRUE,
+ direction = c(x$exp_var$dir.hor[1], x$exp_var$dir.ver[1]),
+ ylim = c(min(0, 1.04 * min(x$exp_var$gamma)), 1.04 * max(x$exp_var$gamma)),
+ xlim = c(0, 1.04 * max(x$exp_var$dist)), xlab = "Distance", ylab = "Semi-variance",
+ main = "Experimental variogram and fitted variogram model", mode = "direct",...)
+ print(vario, position = c(0,0,1,1))
+ ##autokrige script
tryCatch({
##libraries
library(spgrass6)
@@ -263,45 +304,50 @@
##plot experimental and model variogram
cat("plot kriging results","\n")
+ ##see R FAQ 7.19. Plotting to png can produce errors if R version < 2.7
+ ##we use the pdf driver then we will convert to png
options(device="pdf")
- try(automap:::plot.autoKrige(kriging_result))
+ try(plot.autoKrigeVariogramAndFittedModel(kriging_result))
cat("R script done","\n")
quit(status = 0)
}, interrupt = function(ex) {
- cat("An interrupt was detected.\n");
+ cat("An interrupt was detected while executing R script.\n");
quit(status = 4)
error = function(ex) {
cat("Error while executing R script.\n");
quit(status = 5)
+ ) ## tryCatch()
fileHandle.write(script)
fileHandle.close()
return RscriptFile
def __finalize(self, output, colormap):
- """We don't want to stop execution if an error occurs here."""
+ Group operations non-related to kriging.
+ We don't want to stop execution if an error occurs here.
try:
##convert plot to png
- self.__execShellCommand('convert -alpha off Rplots.pdf Rplots.png')
+ self.__execShellCommand('convert -alpha off Rplots.pdf autokrige_result.png')
+ grass.try_remove('Rplots.pdf')
##apply colormap
grass.run_command("r.colors", map = output, rules = colormap, quiet = True)
except:
pass
- def __execShellCommand(self, command, stderrRedirection=False, writeToLog=False):
+ def __execShellCommand(self, command, stderrRedirection=False, logFile=False):
"""General purpose function, maybe should be added in some way to core.py """
+ if logFile is not False:
+ command = command + ' >> ' + logFile
if stderrRedirection is True:
command = command + " 2>&1"
p = Popen(command, shell=True, stdout=PIPE)
retcode = p.wait()
com = p.communicate()
- if writeToLog is True:
- fileHandle = open(self.logfile, 'w')
- fileHandle.write(com[0])
- fileHandle.close()
if retcode == 0:
return com[0]
else:
@@ -330,7 +376,8 @@
self.output + ' ' + str(cellsize) + ' "' + RargsDict['models'] + '" ' + \
RargsDict['range'] + ' ' + RargsDict['nugget'] + ' ' + RargsDict['sill'] \
+ ' ' + writeVarRast + ' < "' + self.RscriptFile + '"'
- self.__execShellCommand(autoKrigeCommand, stderrRedirection=True, writeToLog=True)
+ logFileArg = self.logfile if self.logROutput is True else False
+ self.__execShellCommand(autoKrigeCommand, stderrRedirection=True, logFile=logFileArg)
##5)Finalize output
self.__finalize(self.output, self.colormap)
@@ -348,10 +395,10 @@
autoKrige = AutoKrige(options, flags)
autoKrige.runAutoKrige()
except AutoKrigeError, e1:
- print >> sys.stderr, "Error in v.autokrige.py \n:", e1.message
+ print >> sys.stderr, "Error \n:", e1.message
exitStatus = 1
except:
- errorMessage = "Unexpected error while executing v.autokrige.py \n:"
+ errorMessage = "Unexpected error \n:"
print >> sys.stderr, errorMessage
traceback.print_exc()
exitStatus = 1
