[GRASS-SVN] r37908 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules vdigit
svn_grass at osgeo.org
Tue Jun 16 06:28:08 EDT 2009
Author: martinl
Date: 2009-06-16 06:28:08 -0400 (Tue, 16 Jun 2009)
New Revision: 37908
grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
grass/branches/develbranch_6/gui/wxpython/vdigit/digit.h
grass/branches/develbranch_6/gui/wxpython/vdigit/line.cpp
wxGUI: register geometry attributes (currently only line length)
(merge from trunk, r37907)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py 2009-06-16 10:25:09 UTC (rev 37907)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py 2009-06-16 10:28:08 UTC (rev 37908)
@@ -182,9 +182,9 @@
sqlCommands = []
# find updated values for each layer/category
for layer in self.mapDBInfo.layers.keys(): # for each layer
- table = self.mapDBInfo.layers[layer]["table"]
- key = self.mapDBInfo.layers[layer]["key"]
- columns = self.mapDBInfo.tables[table]
+ table = self.mapDBInfo.GetTable(layer)
+ key = self.mapDBInfo.GetKeyColumn(layer)
+ columns = self.mapDBInfo.GetTableDesc(table)
for idx in range(len(columns[key]['values'])): # for each category
updatedColumns = []
updatedValues = []
@@ -247,7 +247,7 @@
return sqlCommands
- def OnReset(self, event):
+ def OnReset(self, event = None):
"""!Reset form"""
@@ -257,6 +257,8 @@
for name in columns.keys():
type = columns[name]['type']
value = columns[name]['values'][idx]
+ if value is None:
+ value = ''
try:
id = columns[name]['ids'][idx]
except IndexError:
@@ -484,6 +486,20 @@
return True
+ def SetColumnValue(self, layer, column, value):
+ """!Set attrbute value
+ @param column column name
+ @param value value
+ for key, col in columns.iteritems():
+ if key == column:
+ col['values'] = [col['ctype'](value),]
+ break
class ModifyTableRecord(wx.Dialog):
"""!Dialog for inserting/updating table record"""
def __init__(self, parent, id, title, data, keyEditable=(-1, True),
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2009-06-16 10:25:09 UTC (rev 37907)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2009-06-16 10:28:08 UTC (rev 37908)
@@ -407,6 +407,27 @@
"""!Get vector name"""
return self.map
+ def GetKeyColumn(self, layer):
+ """!Get key column of given layer
+ @param layer vector layer number
+ return self.layers[layer]['key']
+ def GetTable(self, layer):
+ """!Get table name of given layer
+ return self.layers[layer]['table']
+ def GetTableDesc(self, table):
+ """!Get table columns
+ @param table table name
+ return self.tables[table]
class LayerSelect(wx.Choice):
Creates combo box for selecting data layers defined for vector.
@@ -545,16 +566,29 @@
if vector:
self.InsertColumns(vector, layer)
- def InsertColumns(self, vector, layer):
- """!Insert columns for a vector attribute table into the columns combobox"""
+ def InsertColumns(self, vector, layer, excludeKey = False, type = None):
+ """!Insert columns for a vector attribute table into the columns combobox
+ @param vector vector name
+ @param excludeKey exclude key column from the list?
+ @param type only columns of given type (given as list)
dbInfo = VectorDBInfo(vector)
try:
- table = dbInfo.layers[int(layer)]['table']
- columnchoices = dbInfo.tables[table]
+ table = dbInfo.GetTable(int(layer))
+ columnchoices = dbInfo.GetTableDesc(table)
+ keyColumn = dbInfo.GetKeyColumn(int(layer))
columns = len(columnchoices.keys()) * ['']
for key, val in columnchoices.iteritems():
columns[val['index']] = key
+ if excludeKey: # exclude key column
+ columns.remove(keyColumn)
+ if type: # only selected column types
+ for key, value in columnchoices.iteritems():
+ if value['type'] not in type:
+ columns.remove(key)
except (KeyError, ValueError):
columns = []
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2009-06-16 10:25:09 UTC (rev 37907)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2009-06-16 10:28:08 UTC (rev 37908)
@@ -1166,6 +1166,17 @@
self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
self.DrawLines(pdc=self.pdcTmp)
+ def __geomAttrb(self):
+ """!Trac geometry attributes?"""
+ ret = list()
+ for key, val in UserSettings.Get(group = 'vdigit', key = 'geomAttrb',
+ internal = True).iteritems():
+ if not val['enabled'] or not val['column']:
+ continue
+ ret.append((key, val['column']))
+ return ret
def __updateATM(self):
"""!Update open Attribute Table Manager
@@ -1953,6 +1964,13 @@
cats=cats,
pos=posWindow,
action="add")
+ layer = int(UserSettings.Get(group='vdigit', key="layer", subkey='value'))
+ for attrb, column in self.__geomAttrb():
+ if attrb is 'length':
+ val = digitClass.GetLineLength(fid)
+ addRecordDlg.SetColumnValue(layer, column, val)
+ addRecordDlg.OnReset()
if addRecordDlg.mapDBInfo and \
addRecordDlg.ShowModal() == wx.ID_OK:
sqlfile = tempfile.NamedTemporaryFile(mode="w")
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2009-06-16 10:25:09 UTC (rev 37907)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2009-06-16 10:28:08 UTC (rev 37908)
@@ -6,6 +6,7 @@
Sets default display font, etc.
Classes:
+ - Settings
- PreferencesDialog
- DefaultFontDialog
- MapsetAccess
@@ -16,7 +17,7 @@
for details.
@author Michael Barton (Arizona State University)
-Martin Landa <landa.martin gmail.com>
+ at author Martin Landa <landa.martin gmail.com>
import os
@@ -553,6 +554,11 @@
_("histogram"))
self.internalSettings['vdigit']['bgmap'] = {}
self.internalSettings['vdigit']['bgmap']['value'] = ''
+ self.internalSettings['vdigit']['geomAttrb'] = dict()
+ self.internalSettings['vdigit']['geomAttrb']['length'] = { 'enabled' : False,
+ 'column' : '' }
+ self.internalSettings['vdigit']['geomAttrb']['area'] = { 'enabled' : False,
+ 'column' : '' }
def ReadSettingsFile(self, settings=None):
"""!Reads settings file (mapset, location, gisdbase)"""
@@ -743,8 +749,8 @@
else:
return settings[group][key]
else:
- if type(subkey) == type([]) or \
- type(subkey) == type(()):
+ if type(subkey) == type(tuple()) or \
+ type(subkey) == type(list()):
return settings[group][key][subkey[0]][subkey[1]]
else:
return settings[group][key][subkey]
@@ -778,7 +784,8 @@
else:
settings[group][key] = value
else:
- if type(subkey) == type([]):
settings[group][key][subkey[0]][subkey[1]] = value
else:
settings[group][key][subkey] = value
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2009-06-16 10:25:09 UTC (rev 37907)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2009-06-16 10:28:08 UTC (rev 37908)
@@ -604,6 +604,16 @@
return dict(self.digit.GetLineCats(line))
+ def GetLineLength(self, line):
+ """!Get line length
+ @param line feature id
+ @return line length
+ @return 0 for non-linear features
+ return self.digit.GetLineLength(line)
def SetLineCats(self, line, layer, cats, add=True):
"""!Set categories for given line and layer
@@ -1477,6 +1487,59 @@
border.Add(item=sizer, proportion=0,
flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
+ # geometry attributes (currently only length and area are supported)
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY,
+ label = " %s " % _("Geometry attributes"))
+ sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ flexSizer = wx.FlexGridSizer(cols=2, hgap=3, vgap=3)
+ flexSizer.AddGrowableCol(0)
+ self.geomAttrb = { 'length' : { 'label' : _('length') },
+ 'area' : { 'label' : _('area') } }
+ digitToolbar = self.parent.toolbars['vdigit']
+ try:
+ vectorName = digitToolbar.GetLayer().GetName()
+ except AttributeError:
+ vectorName = None # no vector selected for editing
+ layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
+ for attrb in self.geomAttrb.keys():
+ # checkbox
+ check = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = self.geomAttrb[attrb]['label'])
+ ### self.deleteRecord.SetValue(UserSettings.Get(group='vdigit', key="delRecord", subkey='enabled'))
+ check.Bind(wx.EVT_CHECKBOX, self.OnGeomAttrb)
+ # column (only numeric)
+ column = gselect.ColumnSelect(parent = panel)
+ column.InsertColumns(vector = vectorName,
+ layer = layer, excludeKey = True,
+ type = ['integer', 'double precision'])
+ # default values
+ check.SetValue(UserSettings.Get(group='vdigit', key='geomAttrb',
+ subkey=[attrb, 'enabled'],
+ internal=True))
+ if not vectorName:
+ check.Enable(False)
+ column.Enable(False)
+ if not check.IsChecked():
+ self.geomAttrb[attrb]['check'] = check.GetId()
+ self.geomAttrb[attrb]['column'] = column.GetId()
+ flexSizer.Add(item = check, proportion = 0,
+ flag = wx.ALIGN_CENTER_VERTICAL)
+ flexSizer.Add(item = column, proportion = 0)
+ sizer.Add(item=flexSizer, proportion=1,
+ flag=wx.ALL | wx.EXPAND, border=1)
+ border.Add(item=sizer, proportion=0,
+ flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
# bindings
self.Bind(wx.EVT_CHECKBOX, self.OnChangeAddRecord, self.addRecord)
self.Bind(wx.EVT_CHOICE, self.OnChangeCategoryMode, self.categoryMode)
@@ -1511,6 +1574,22 @@
(_("Area (closed boundary + centroid)"), "area"),
(_("Direction"), "direction"),)
+ def OnGeomAttrb(self, event):
+ """!Register geometry attributes (enable/disable)"""
+ checked = event.IsChecked()
+ id = event.GetId()
+ key = None
+ for attrb, val in self.geomAttrb.iteritems():
+ if val['check'] == id:
+ key = attrb
+ break
+ column = self.FindWindowById(self.geomAttrb[key]['column'])
+ if checked:
+ column.Enable()
+ else:
def OnChangeCategoryMode(self, event):
"""!Change category mode"""
@@ -1677,6 +1756,17 @@
UserSettings.Set(group='vdigit', key="delRecord", subkey='enabled',
value=self.deleteRecord.IsChecked())
+ for key, val in self.geomAttrb.iteritems():
+ checked = self.FindWindowById(val['check']).IsChecked()
+ column = self.FindWindowById(val['column']).GetValue()
+ UserSettings.Set(group = 'vdigit', key = 'geomAttrb',
+ subkey = [key, 'enabled'], value = checked,
+ internal = True)
+ subkey = [key, 'column'], value = column,
+ internal = True)
# snapping threshold
self.parent.digit.threshold = self.parent.digit.driver.GetThreshold()
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/digit.h
--- grass/branches/develbranch_6/gui/wxpython/vdigit/digit.h 2009-06-16 10:25:09 UTC (rev 37907)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/digit.h 2009-06-16 10:28:08 UTC (rev 37908)
@@ -82,6 +82,8 @@
double, double, double, bool,
int, int, double);
+ double GetLineLength(int);
int CopyCats(std::vector<int>, std::vector<int>, bool);
int GetCategory(int);
std::map<int, std::vector<int> > GetLineCats(int);
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/line.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/line.cpp 2009-06-16 10:25:09 UTC (rev 37907)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/line.cpp 2009-06-16 10:28:08 UTC (rev 37908)
@@ -1037,3 +1037,37 @@
return ret;
+ \brief Get line length
+ \todo LL locations
+ \param line feature id
+ \return line length
+ \return 0 for non-linear features
+double Digit::GetLineLength(int line)
+ int type;
+ double length;
+ struct line_pnts *points;
+ if (!Vect_line_alive(display->mapInfo, line))
+ return 0;
+ points = Vect_new_line_struct();
+ type = Vect_read_line(display->mapInfo, points, NULL, line);
+ if (!(type & GV_LINES))
+ length = 0.0;
+ else
+ length = Vect_line_length(points);
+ Vect_destroy_line_struct(points);
+ return length;
