[GRASS-SVN] r37909 - in grass/trunk/gui/wxpython: gui_modules vdigit
svn_grass at osgeo.org
Tue Jun 16 14:35:04 EDT 2009
Author: martinl
Date: 2009-06-16 14:35:03 -0400 (Tue, 16 Jun 2009)
New Revision: 37909
grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
grass/trunk/gui/wxpython/vdigit/digit.h
grass/trunk/gui/wxpython/vdigit/line.cpp
wxGUI/vdigit: geometry attributes - area size/perimeter
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2009-06-16 10:28:08 UTC (rev 37908)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2009-06-16 18:35:03 UTC (rev 37909)
@@ -1145,7 +1145,11 @@
cats=cats,
pos=posWindow,
action="add")
+ if not point:
+ self.__geomAttrb(fid, addRecordDlg, 'area', digitClass)
+ self.__geomAttrb(fid, addRecordDlg, 'perimeter', digitClass)
if addRecordDlg.mapDBInfo and \
addRecordDlg.ShowModal() == wx.ID_OK:
sqlfile = tempfile.NamedTemporaryFile(mode="w")
@@ -1166,17 +1170,25 @@
self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
self.DrawLines(pdc=self.pdcTmp)
- def __geomAttrb(self):
+ def __geomAttrb(self, fid, dialog, attrb, digit):
"""!Trac geometry attributes?"""
- ret = list()
- for key, val in UserSettings.Get(group = 'vdigit', key = 'geomAttrb',
- internal = True).iteritems():
- if not val['enabled'] or not val['column']:
- continue
- ret.append((key, val['column']))
- return ret
+ if UserSettings.Get(group = 'vdigit', key = 'geomAttrb',
+ subkey = [attrb, 'enabled'], internal = True):
+ val = -1
+ if attrb == 'length':
+ val = digit.GetLineLength(fid)
+ elif attrb == 'area':
+ val = digit.GetAreaSize(fid)
+ elif attrb == 'perimeter':
+ val = digit.GetAreaPerimeter(fid)
+ if val > 0:
+ layer = int(UserSettings.Get(group='vdigit', key="layer", subkey='value'))
+ column = UserSettings.Get(group = 'vdigit', key = 'geomAttrb',
+ subkey = [attrb, 'column'], internal = True)
+ dialog.SetColumnValue(layer, column, val)
+ dialog.OnReset()
def __updateATM(self):
"""!Update open Attribute Table Manager
@@ -1948,6 +1960,7 @@
self.redrawAll = True
# add new record into atribute table
+ print UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled'), line, fid
if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') and \
(line is True or \
(not line and fid > 0)):
@@ -1964,13 +1977,12 @@
cats=cats,
pos=posWindow,
action="add")
- layer = int(UserSettings.Get(group='vdigit', key="layer", subkey='value'))
- for attrb, column in self.__geomAttrb():
- if attrb is 'length':
- val = digitClass.GetLineLength(fid)
- addRecordDlg.SetColumnValue(layer, column, val)
- addRecordDlg.OnReset()
+ self.__geomAttrb(fid, addRecordDlg, 'length', digitClass)
+ # auto-placing centroid
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2009-06-16 10:28:08 UTC (rev 37908)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2009-06-16 18:35:03 UTC (rev 37909)
@@ -559,6 +559,8 @@
'column' : '' }
self.internalSettings['vdigit']['geomAttrb']['area'] = { 'enabled' : False,
'column' : '' }
+ self.internalSettings['vdigit']['geomAttrb']['perimeter'] = { 'enabled' : False,
+ 'column' : '' }
def ReadSettingsFile(self, settings=None):
"""!Reads settings file (mapset, location, gisdbase)"""
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2009-06-16 10:28:08 UTC (rev 37908)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2009-06-16 18:35:03 UTC (rev 37909)
@@ -610,10 +610,30 @@
@param line feature id
@return line length
- @return 0 for non-linear features
+ @return -1 on error
return self.digit.GetLineLength(line)
+ def GetAreaSize(self, centroid):
+ """!Get area size
+ @param centroid centroid id
+ @return area size
+ return self.digit.GetAreaSize(centroid)
+ def GetAreaPerimeter(self, centroid):
+ """!Get area perimeter
+ @return area size
+ return self.digit.GetAreaPerimeter(centroid)
def SetLineCats(self, line, layer, cats, add=True):
"""!Set categories for given line and layer
@@ -1493,10 +1513,11 @@
box = wx.StaticBox (parent = panel, id = wx.ID_ANY,
label = " %s " % _("Geometry attributes"))
sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- flexSizer = wx.FlexGridSizer(cols=2, hgap=3, vgap=3)
+ flexSizer = wx.FlexGridSizer(cols=3, hgap=3, vgap=3)
flexSizer.AddGrowableCol(0)
self.geomAttrb = { 'length' : { 'label' : _('length') },
- 'area' : { 'label' : _('area') } }
+ 'area' : { 'label' : _('area') },
+ 'perimeter' : { 'label' : _('perimeter') } }
digitToolbar = self.parent.toolbars['vdigit']
try:
@@ -1504,22 +1525,29 @@
except AttributeError:
vectorName = None # no vector selected for editing
layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
- for attrb in self.geomAttrb.keys():
+ for attrb in ['length', 'area', 'perimeter']:
# checkbox
check = wx.CheckBox(parent = panel, id = wx.ID_ANY,
label = self.geomAttrb[attrb]['label'])
### self.deleteRecord.SetValue(UserSettings.Get(group='vdigit', key="delRecord", subkey='enabled'))
check.Bind(wx.EVT_CHECKBOX, self.OnGeomAttrb)
# column (only numeric)
- column = gselect.ColumnSelect(parent = panel)
+ column = gselect.ColumnSelect(parent = panel, size=(200, -1))
column.InsertColumns(vector = vectorName,
layer = layer, excludeKey = True,
type = ['integer', 'double precision'])
+ # units
+ ### TODO: more units
+ units = wx.Choice(parent = panel, id = wx.ID_ANY,
+ choices = [_("map units")])
# default values
check.SetValue(UserSettings.Get(group='vdigit', key='geomAttrb',
subkey=[attrb, 'enabled'],
internal=True))
+ column.SetStringSelection(UserSettings.Get(group='vdigit', key='geomAttrb',
+ subkey=[attrb, 'column'],
+ internal=True))
if not vectorName:
check.Enable(False)
@@ -1528,12 +1556,14 @@
if not check.IsChecked():
column.Enable(False)
- self.geomAttrb[attrb]['check'] = check.GetId()
+ self.geomAttrb[attrb]['check'] = check.GetId()
self.geomAttrb[attrb]['column'] = column.GetId()
+ self.geomAttrb[attrb]['units'] = units.GetId()
flexSizer.Add(item = check, proportion = 0,
flag = wx.ALIGN_CENTER_VERTICAL)
flexSizer.Add(item = column, proportion = 0)
+ flexSizer.Add(item = units, proportion = 0)
sizer.Add(item=flexSizer, proportion=1,
flag=wx.ALL | wx.EXPAND, border=1)
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h 2009-06-16 10:28:08 UTC (rev 37908)
+++ grass/trunk/gui/wxpython/vdigit/digit.h 2009-06-16 18:35:03 UTC (rev 37909)
@@ -83,7 +83,9 @@
int, int, double);
double GetLineLength(int);
+ double GetAreaSize(int);
+ double GetAreaPerimeter(int);
int CopyCats(std::vector<int>, std::vector<int>, bool);
int GetCategory(int);
std::map<int, std::vector<int> > GetLineCats(int);
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2009-06-16 10:28:08 UTC (rev 37908)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2009-06-16 18:35:03 UTC (rev 37909)
@@ -1046,7 +1046,7 @@
\param line feature id
\return line length
- \return 0 for non-linear features
+ \return -1 for non-linear features
double Digit::GetLineLength(int line)
@@ -1056,18 +1056,75 @@
struct line_pnts *points;
if (!Vect_line_alive(display->mapInfo, line))
- return 0;
+ return -1;
points = Vect_new_line_struct();
type = Vect_read_line(display->mapInfo, points, NULL, line);
- if (!(type & GV_LINES))
- length = 0.0;
- else
+ length = -1;
+ if (type & GV_LINES)
length = Vect_line_length(points);
Vect_destroy_line_struct(points);
return length;
+ \brief Get area size
+ \param centroid centroid id
+ \return area in map units
+ \return -1 on error
+double Digit::GetAreaSize(int centroid)
+ int area;
+ double size;
+ area = Vect_get_centroid_area(display->mapInfo, centroid);
+ size = -1;
+ if (area > 0) {
+ if (!Vect_area_alive(display->mapInfo, area))
+ return -1;
+ size = Vect_get_area_area(display->mapInfo, area);
+ return size;
+ \brief Get area perimeter
+ \return perimeter in map units
+double Digit::GetAreaPerimeter(int centroid)
+ int area;
+ double perimeter;
+ struct line_pnts *points = NULL;
+ perimeter = -1;
+ if (area > 0) {
+ return -1;
+ points = Vect_new_line_struct();
+ Vect_get_area_points(display->mapInfo, area, points);
+ perimeter = Vect_area_perimeter(points);
+ if (points)
+ Vect_destroy_line_struct(points);
+ return perimeter;
