[GRASS-SVN] r37951 - in grass/trunk/imagery: . i.eb.g0
svn_grass at osgeo.org
Fri Jun 19 07:44:03 EDT 2009
Author: ychemin
Date: 2009-06-19 07:44:02 -0400 (Fri, 19 Jun 2009)
New Revision: 37951
Added:
grass/trunk/imagery/i.eb.g0/
grass/trunk/imagery/i.eb.g0/Makefile
grass/trunk/imagery/i.eb.g0/g0.c
grass/trunk/imagery/i.eb.g0/i.eb.g0.html
grass/trunk/imagery/i.eb.g0/main.c
grass/trunk/imagery/Makefile
Added soil heat flux module
Modified: grass/trunk/imagery/Makefile
--- grass/trunk/imagery/Makefile 2009-06-19 11:02:05 UTC (rev 37950)
+++ grass/trunk/imagery/Makefile 2009-06-19 11:44:02 UTC (rev 37951)
@@ -5,6 +5,7 @@
i.atcorr \
i.cca \
i.cluster \
+ i.eb.g0 \
i.emissivity \
i.find \
i.gensig \
Added: grass/trunk/imagery/i.eb.g0/Makefile
--- grass/trunk/imagery/i.eb.g0/Makefile (rev 0)
+++ grass/trunk/imagery/i.eb.g0/Makefile 2009-06-19 11:44:02 UTC (rev 37951)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR = ../..
+PGM = i.eb.g0
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LARGEFILES),)
+ EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
+endif
+default: cmd
Added: grass/trunk/imagery/i.eb.g0/g0.c
--- grass/trunk/imagery/i.eb.g0/g0.c (rev 0)
+++ grass/trunk/imagery/i.eb.g0/g0.c 2009-06-19 11:44:02 UTC (rev 37951)
@@ -0,0 +1,28 @@
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+ double g_0(double bbalb, double ndvi, double tempk, double rnet,
+ double time, int roerink)
+ double a, b, result;
+ double r0_coef;
+ if (time <= 9.0 || time > 15.0)
+ r0_coef = 1.1;
+ else if (time > 9.0 && time <= 11.0)
+ r0_coef = 1.0;
+ else if (time > 11.0 && time <= 13.0)
+ r0_coef = 0.9;
+ else if (time > 13.0 && time <= 15.0)
+ r0_coef = 1.0;
+ a = (0.0032 * (bbalb / r0_coef) +
+ 0.0062 * (bbalb / r0_coef) * (bbalb / r0_coef));
+ b = (1 - 0.978 * pow(ndvi, 4));
+ /* Spain (Bastiaanssen, 1995) */
+ result = (rnet * (tempk - 273.15) / bbalb) * a * b;
+ /* HAPEX-Sahel (Roerink, 1995) */
+ if (roerink)
+ result = result * 1.430 - 0.0845;
+ return result;
Added: grass/trunk/imagery/i.eb.g0/i.eb.g0.html
--- grass/trunk/imagery/i.eb.g0/i.eb.g0.html (rev 0)
+++ grass/trunk/imagery/i.eb.g0/i.eb.g0.html 2009-06-19 11:44:02 UTC (rev 37951)
@@ -0,0 +1,37 @@
+<H2>DESCRIPTION</H2>
+<EM>i.eb.g0</EM> calculates the soil heat flux approximation (g0) after [1]. Main reference for implementation is [3].
+It takes input of Albedo, NDVI, Surface Skin temperature, Net Radiation (see r.sun), time of satellite overpass, and a flag for the Roerink empirical modification from the HAPEX-Sahel experiment.
+<H2>NOTES</H2>
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="r.sun.html">r.sun</A><br>
+<A HREF="i.albedo.html">i.albedo</A><br>
+<A HREF="i.emissivity.html">i.emissivity</A><br>
+<A HREF="i.eb.h_SEBAL01.html">i.eb.h_SEBAL01</A><br>
+<A HREF="i.eb.evapfr.html">i.eb.evapfr</A><br>
+</em>
+<H2>REFERENCES</H2>
+ <p>[1] Bastiaanssen, W.G.M., 1995.
+ Estimation of Land surface parameters by remote sensing under clear-sky conditions. PhD thesis, Wageningen University, Wageningen, The Netherlands.
+ <p>[2] Chemin Y., Alexandridis T.A., 2001. Improving spatial resolution of ET seasonal for irrigated rice in Zhanghe, China. Asian Journal of Geoinformatics. 5(1):3-11,2004.
+ <p>[3] Alexandridis T.K., Cherif I., Chemin Y., Silleos N.G., Stavrinos E., Zalidis G.C. Integrated methodology for estimating water use in Mediterranean agricultural areas. Remote Sensing. -(-):,2009. (submitted))
+<H2>AUTHORS</H2>
+Yann Chemin, Asian Institute of Technology, Thailand<BR>
+<p>
+<i>Last changed: $Date: 2006/10/08 21:30:42 $</i>
Added: grass/trunk/imagery/i.eb.g0/main.c
--- grass/trunk/imagery/i.eb.g0/main.c (rev 0)
+++ grass/trunk/imagery/i.eb.g0/main.c 2009-06-19 11:44:02 UTC (rev 37951)
@@ -0,0 +1,193 @@
+ * MODULE: i.eb.g0
+ * AUTHOR(S): Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE: Calculates an approximation of soil heat flux
+ * as seen in Bastiaanssen (1995) using time of
+ * satellite overpass.
+ * COPYRIGHT: (C) 2006-2007 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+double g_0(double bbalb, double ndvi, double tempk, double rnet,
+ double time, int roerink);
+int main(int argc, char *argv[])
+ int nrows, ncols;
+ int row, col;
+ int roerink = 0; /*Roerink Flag for HAPEX-Sahel conditions */
+ struct GModule *module;
+ struct Option *input1, *input2, *input3, *input4, *input5, *output1;
+ struct Flag *flag1;
+ struct History history; /*metadata */
+ struct Colors colors; /*metadata */
+ char *result; /*output raster name */
+ int infd_albedo, infd_ndvi, infd_tempk, infd_rnet, infd_time;
+ int outfd;
+ char *albedo, *ndvi, *tempk, *rnet, *time;
+ void *inrast_albedo, *inrast_ndvi, *inrast_tempk, *inrast_rnet,
+ *inrast_time;
+ DCELL * outrast;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->keywords = _("soil heat flux, energy balance, SEBAL");
+ module->description =
+ _("soil heat flux approximation (Bastiaanssen, 1995)");
+ /* Define the different options */
+ input1 = G_define_standard_option(G_OPT_R_INPUT);
+ input1->key = "albedo";
+ input1->description = _("Name of the Albedo map [0.0;1.0]");
+ input1->answer = "albedo";
+ input2 = G_define_standard_option(G_OPT_R_INPUT);
+ input2->key = "ndvi";
+ input2->description = _("Name of the ndvi map [-1.0;+1.0]");
+ input2->answer = "ndvi";
+ input3 = G_define_standard_option(G_OPT_R_INPUT);
+ input3->key = "tempk";
+ input3->description =
+ _("Name of the Surface temperature map [degree Kelvin]");
+ input3->answer = "tempk";
+ input4 = G_define_standard_option(G_OPT_R_INPUT);
+ input4->key = "rnet";
+ input4->description = _("Name of the Net Radiation map [W/m2]");
+ input4->answer = "rnet";
+ input5 = G_define_standard_option(G_OPT_R_INPUT);
+ input5->key = "time";
+ input5->description =
+ _("Name of the time of satellite overpass map [local UTC]");
+ input5->answer = "time";
+ output1 = G_define_standard_option(G_OPT_R_OUTPUT);
+ output1->key = "g0";
+ output1->description = _("Name of the output g0 layer");
+ output1->answer = "g0";
+ flag1 = G_define_flag();
+ flag1->key = 'r';
+ flag1->description =
+ _("HAPEX-Sahel empirical correction (Roerink, 1995)");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ albedo = input1->answer;
+ ndvi = input2->answer;
+ tempk = input3->answer;
+ rnet = input4->answer;
+ time = input5->answer;
+ result = output1->answer;
+ roerink = flag1->answer;
+ if ((infd_albedo = G_open_cell_old(albedo, "")) < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), albedo);
+ inrast_albedo = G_allocate_d_raster_buf();
+ if ((infd_ndvi = G_open_cell_old(ndvi, "")) < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), ndvi);
+ inrast_ndvi = G_allocate_d_raster_buf();
+ if ((infd_tempk = G_open_cell_old(tempk, "")) < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), tempk);
+ inrast_tempk = G_allocate_d_raster_buf();
+ if ((infd_rnet = G_open_cell_old(rnet, "")) < 0)
+ G_fatal_error(_("Unable to open raster map [%s]"), rnet);
+ inrast_rnet = G_allocate_d_raster_buf();
+ if ((infd_time = G_open_cell_old(time, "")) < 0)
+ G_fatal_error(_("Unable to open raster map [%s]"), time);
+ inrast_time = G_allocate_d_raster_buf();
+ nrows = G_window_rows();
+ ncols = G_window_cols();
+ outrast = G_allocate_d_raster_buf();
+ /* Create New raster files */
+ if ((outfd = G_open_raster_new(result,DCELL_TYPE)) < 0)
+ G_fatal_error(_("Unable to open raster map<%s>"), result);
+ /* Process pixels */
+ for (row = 0; row < nrows; row++)
+ DCELL d;
+ DCELL d_albedo;
+ DCELL d_ndvi;
+ DCELL d_tempk;
+ DCELL d_rnet;
+ DCELL d_time;
+ G_percent(row, nrows, 2);
+ /* read input maps */
+ if (G_get_d_raster_row(infd_albedo, inrast_albedo, row) < 0)
+ G_fatal_error(_("Unable to read from <%s>"), albedo);
+ if (G_get_d_raster_row(infd_ndvi, inrast_ndvi, row)<0)
+ G_fatal_error(_("Unable to read from <%s>"), ndvi);
+ if (G_get_d_raster_row(infd_tempk, inrast_tempk, row)< 0)
+ G_fatal_error(_("Unable to read from <%s>"), tempk);
+ if (G_get_d_raster_row(infd_rnet, inrast_rnet, row)<0)
+ G_fatal_error(_("Unable to read from <%s>"), rnet);
+ if (G_get_d_raster_row(infd_time, inrast_time, row)<0)
+ G_fatal_error(_("Unable to read from <%s>"), time);
+ /*process the data */
+ for (col = 0; col < ncols; col++)
+ d_albedo = ((DCELL *) inrast_albedo)[col];
+ d_ndvi = ((DCELL *) inrast_ndvi)[col];
+ d_tempk = ((DCELL *) inrast_tempk)[col];
+ d_rnet = ((DCELL *) inrast_rnet)[col];
+ d_time = ((DCELL *) inrast_time)[col];
+ if (G_is_d_null_value(&d_albedo) ||
+ G_is_d_null_value(&d_ndvi) ||
+ G_is_d_null_value(&d_tempk) ||
+ G_is_d_null_value(&d_rnet) ||
+ G_is_d_null_value(&d_time)) {
+ G_set_d_null_value(&outrast[col], 1);
+ else {
+ /* calculate soil heat flux */
+ d=g_0(d_albedo,d_ndvi,d_tempk,d_rnet,d_time,roerink);
+ outrast[col] = d;
+ if (G_put_d_raster_row(outfd, outrast) < 0)
+ G_fatal_error(_("Unable to write to output raster map"));
+ G_free(inrast_albedo);
+ G_free(inrast_ndvi);
+ G_free(inrast_tempk);
+ G_free(inrast_rnet);
+ G_free(inrast_time);
+ G_close_cell(infd_albedo);
+ G_close_cell(infd_ndvi);
+ G_close_cell(infd_tempk);
+ G_close_cell(infd_rnet);
+ G_close_cell(infd_time);
+ G_free(outrast);
+ G_close_cell(outfd);
+ /* Colors in grey shade */
+ G_init_colors(&colors);
+ G_add_color_rule(0.0, 0, 0, 0, 200.0, 255, 255, 255, &colors);
+ G_short_history(result, "raster", &history);
+ G_command_history(&history);
+ G_write_history(result, &history);
+ exit(EXIT_SUCCESS);
