[GRASS-SVN] r37952 - in grass-addons/gipe: . i.water
svn_grass at osgeo.org
Fri Jun 19 07:48:02 EDT 2009
Author: ychemin
Date: 2009-06-19 07:48:02 -0400 (Fri, 19 Jun 2009)
New Revision: 37952
Removed:
grass-addons/gipe/i.eb.g0/
grass-addons/gipe/Makefile.imagery
grass-addons/gipe/i.water/main.c
grass-addons/gipe/readme.gipe
remove i.eb.g0 from addons
Modified: grass-addons/gipe/Makefile.imagery
--- grass-addons/gipe/Makefile.imagery 2009-06-19 11:44:02 UTC (rev 37951)
+++ grass-addons/gipe/Makefile.imagery 2009-06-19 11:48:02 UTC (rev 37952)
@@ -11,7 +11,6 @@
i.eb.deltat \
i.eb.eta \
i.eb.evapfr \
- i.eb.g0 \
i.eb.h0 \
i.eb.h_iter \
i.eb.h_SEBAL95 \
Modified: grass-addons/gipe/i.water/main.c
--- grass-addons/gipe/i.water/main.c 2009-06-19 11:44:02 UTC (rev 37951)
+++ grass-addons/gipe/i.water/main.c 2009-06-19 11:48:02 UTC (rev 37952)
@@ -28,73 +28,49 @@
int main(int argc, char *argv[])
struct Cell_head cellhd; /*region+header info */
char *mapset; /*mapset name */
int nrows, ncols;
int row, col;
struct GModule *module;
struct Option *input1, *input2, *input3, *output1;
struct Flag *flag1;
struct History history; /*metadata */
- /* FMEO Declarations**************** */
char *name; /*input raster name */
char *result1; /*output raster name */
- /*File Descriptors */
int infd_ndvi, infd_albedo, infd_ref7;
int outfd1;
char *ndvi, *albedo, *ref7;
int i = 0, j = 0;
void *inrast_ndvi, *inrast_albedo, *inrast_ref7;
CELL * outrast1;
RASTER_MAP_TYPE data_type_output = CELL_TYPE;
RASTER_MAP_TYPE data_type_ndvi;
RASTER_MAP_TYPE data_type_albedo;
RASTER_MAP_TYPE data_type_ref7;
- G_gisinit(argv[0]);
+ G_gisinit(argv[0]);
module = G_define_module();
module->keywords = _("water, detection");
module->description = _("Water detection, 1 if found, 0 if not");
- /* Define the different options */
- input1 = G_define_standard_option(G_OPT_R_INPUT);
- input1->key = _("ndvi");
+ /* Define the different options */
+ input1 = G_define_standard_option(G_OPT_R_INPUT);
+ input1->key = "ndvi";
input1->description = _("Name of the NDVI layer [-]");
input2 = G_define_standard_option(G_OPT_R_INPUT);
- input2->key = _("albedo");
+ input2->key = "albedo";
input2->required = NO;
input2->description = _("Name of the Albedo layer [-]");
input3 = G_define_standard_option(G_OPT_R_INPUT);
- input3->key = _("Modref7");
+ input3->key = "Modref7";
input3->required = NO;
input3->description =
_("Name of the Modis surface reflectance band 7 layer [-]");
output1 = G_define_standard_option(G_OPT_R_OUTPUT);
output1->description = _("Name of the output water layer [0/1]");
- if (G_parser(argc, argv))
+ if (G_parser(argc, argv))
exit(EXIT_FAILURE);
ndvi = input1->answer;
if (input2->answer)
@@ -106,9 +82,8 @@
result1 = output1->answer;
- mapset = G_find_cell2(ndvi, "");
+ mapset = G_find_cell2(ndvi, "");
if (mapset == NULL) {
G_fatal_error(_("cell file [%s] not found"), ndvi);
@@ -118,10 +93,8 @@
if (G_get_cellhd(ndvi, mapset, &cellhd) < 0)
G_fatal_error(_("Cannot read file header of [%s])"), ndvi);
inrast_ndvi = G_allocate_raster_buf(data_type_ndvi);
- if (input2->answer) {
+ if (input2->answer) {
mapset = G_find_cell2(albedo, "");
G_fatal_error(_("cell file [%s] not found"), albedo);
@@ -133,10 +106,8 @@
G_fatal_error(_("Cannot read file header of [%s]"), albedo);
inrast_albedo = G_allocate_raster_buf(data_type_albedo);
- if (input3->answer) {
+ if (input3->answer) {
mapset = G_find_cell2(ref7, "");
G_fatal_error(_("Cell file [%s] not found"), ref7);
@@ -148,29 +119,24 @@
G_fatal_error(_("Cannot read file header of [%s]"), ref7);
inrast_ref7 = G_allocate_raster_buf(data_type_ref7);
- G_debug(3, "number of rows %d", cellhd.rows);
+ G_debug(3, "number of rows %d", cellhd.rows);
nrows = G_window_rows();
ncols = G_window_cols();
outrast1 = G_allocate_raster_buf(data_type_output);
- /* Create New raster files */
- if ((outfd1 = G_open_raster_new(result1, data_type_output)) < 0)
+ /* Create New raster files */
+ if ((outfd1 = G_open_raster_new(result1, data_type_output)) < 0)
G_fatal_error(_("Could not open <%s>"), result1);
- /* Process pixels */
- for (row = 0; row < nrows; row++)
+ /* Process pixels */
+ for (row = 0; row < nrows; row++)
CELL d;
DCELL d_ndvi;
DCELL d_albedo;
DCELL d_ref7;
G_percent(row, nrows, 2);
- /* read input maps */
- if (G_get_raster_row(infd_ndvi, inrast_ndvi, row, data_type_ndvi)
+ /* read input maps */
+ if (G_get_raster_row(infd_ndvi, inrast_ndvi, row, data_type_ndvi)
< 0)
G_fatal_error(_("Could not read from <%s>"), ndvi);
@@ -183,10 +149,9 @@
< 0)
G_fatal_error(_("Could not read from <%s>"), ref7);
- /*process the data */
- for (col = 0; col < ncols; col++)
+ /*process the data */
+ for (col = 0; col < ncols; col++)
switch (data_type_ndvi) {
case CELL_TYPE:
d_ndvi = (double)((CELL *) inrast_ndvi)[col];
Modified: grass-addons/gipe/readme.gipe
--- grass-addons/gipe/readme.gipe 2009-06-19 11:44:02 UTC (rev 37951)
+++ grass-addons/gipe/readme.gipe 2009-06-19 11:48:02 UTC (rev 37952)
@@ -20,6 +20,7 @@
20081012: Added i.latlong, removed i.latitude and i.longitude
20081012: Moved i.latlong to main SVN
20081020: Moved i.sunhours, i.emissivity to main SVN
+20090619: Moved i.eb.g0 to main SVN
Imagery modules
@@ -48,7 +49,7 @@
i.eb.disp: Energy-Balance: Calculates the displacement height above canopy
i.eb.eta: Energy-Balance: Calculates the Actual Evapotranspiration
i.eb.evapfr: Energy-Balance: Calculates the Evaporative Fraction (and soil moisture)
-i.eb.g0: Energy-Balance: Calculates the Soil Heat Flux
+**i.eb.g0: (Now in main SVN) Energy-Balance: Calculates the Soil Heat Flux
i.eb.h0: Energy-Balance: Calculates the Sensible Heat Flux
i.eb.h_iter: Energy-Balance: Calculates the Sensible Heat Flux after Pawan (2004)
i.eb.h_SEBAL01: Energy-Balance: Calculates the Sensible Heat Flux after SEBAL (small areas)
