[GRASS-SVN] r37974 - grass/trunk/imagery/i.evapo.time_integration
svn_grass at osgeo.org
Fri Jun 19 15:20:09 EDT 2009
Author: martinl
Date: 2009-06-19 15:20:09 -0400 (Fri, 19 Jun 2009)
New Revision: 37974
grass/trunk/imagery/i.evapo.time_integration/
grass/trunk/imagery/i.evapo.time_integration/main.c
Please follow SUBMITTING rules - see r37961
Property changes on: grass/trunk/imagery/i.evapo.time_integration
___________________________________________________________________
+ OBJ.*
Modified: grass/trunk/imagery/i.evapo.time_integration/main.c
--- grass/trunk/imagery/i.evapo.time_integration/main.c 2009-06-19 19:07:31 UTC (rev 37973)
+++ grass/trunk/imagery/i.evapo.time_integration/main.c 2009-06-19 19:20:09 UTC (rev 37974)
@@ -7,7 +7,7 @@
* PURPOSE: Integrate in time the evapotranspiration from satellite,
* following a daily pattern from meteorological ETo.
- * COPYRIGHT: (C) 2008-09 by the GRASS Development Team
+ * COPYRIGHT: (C) 2008-2009 by the GRASS Development Team
* This program is free software under the GNU Lesser General Public
* License. Read the file COPYING that comes with GRASS for details.
@@ -62,8 +62,7 @@
double startperiod, endperiod; /*first and last days (DOYs) of the period studied */
void *inrast[MAXFILES], *inrast1[MAXFILES], *inrast2[MAXFILES];
DCELL *outrast;
- int data_format; /* 0=double 1=float 2=32bit signed int 5=8bit unsigned int (ie text) */
RASTER_MAP_TYPE in_data_type[MAXFILES]; /* ETa */
RASTER_MAP_TYPE in_data_type1[MAXFILES]; /* DOY of ETa */
RASTER_MAP_TYPE in_data_type2[MAXFILES]; /* ETo */
@@ -73,46 +72,46 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("evapotranspiration,temporal,integration");
- module->description =_("Temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)\n");
+ module->description =_("Computes temporal integration of satellite "
+ "ET actual (ETa) following the daily ET reference "
+ "(ETo) from meteorological station(s)");
+ module->keywords = _("imagery, evapotranspiration, temporal, integration");
/* Define the different options */
input = G_define_standard_option(G_OPT_R_INPUTS);
- input->key = _("eta");
- input->description = _("Names of satellite ETa layers [mm/d or cm/d]");
+ input->key = "eta";
+ input->description = _("Names of satellite ETa raster maps [mm/d or cm/d]");
input1 = G_define_standard_option(G_OPT_R_INPUTS);
- input1->key = _("eta_doy");
+ input1->key = "eta_doy";
input1->description =
- _("Names of satellite ETa Day of Year (DOY) layers [0-400] [-]");
+ _("Names of satellite ETa Day of Year (DOY) raster maps [0-400] [-]");
input2 = G_define_standard_option(G_OPT_R_INPUTS);
- input2->key = _("eto");
+ input2->key = "eto";
input2->description =
- _("Names of meteorological station ETo layers [0-400] [mm/d or cm/d]");
+ _("Names of meteorological station ETo raster maps [0-400] [mm/d or cm/d]");
input3 = G_define_option();
- input3->key = _("eto_doy_min");
+ input3->key = "eto_doy_min";
input3->type = TYPE_DOUBLE;
input3->required = YES;
input3->description = _("Value of DOY for ETo first day");
input4 = G_define_option();
- input4->key = _("start_period");
+ input4->key = "start_period";
input4->type = TYPE_DOUBLE;
input4->required = YES;
- input4->description = _("Value of DOY for the first day of the period studied ");
+ input4->description = _("Value of DOY for the first day of the period studied");
input5 = G_define_option();
- input5->key = _("end_period");
+ input5->key = "end_period";
input5->type = TYPE_DOUBLE;
input5->required = YES;
- input5->description = _("Value of DOY for the last day of the period studied ");
+ input5->description = _("Value of DOY for the last day of the period studied");
output = G_define_standard_option(G_OPT_R_OUTPUT);
- output->description =
- _("Name of the output temporally integrated ETa layer");
/* init nfiles */
nfiles = 1;
nfiles1 = 1;
@@ -121,7 +120,7 @@
if (G_parser(argc, argv))
- exit(-1);
+ exit(EXIT_FAILURE);
ok = 1;
names = input->answers;
@@ -150,13 +149,13 @@
for (; *ptr != NULL; ptr++) {
if (nfiles > MAXFILES)
- G_fatal_error(_("%s - too many ETa files. Only %d allowed"),
- G_program_name(), MAXFILES);
+ G_fatal_error(_("Too many ETa files. Only %d allowed."),
+ MAXFILES);
name = *ptr;
/* find map in mapset */
- mapset = G_find_cell2(name, "");
+ mapset = (char *) G_find_cell2(name, "");
if (mapset == NULL) {
- G_fatal_error(_("raster map <%s> not found"), name);
+ G_fatal_error(_("Raster map <%s> not found"), name);
ok = 0;
if (!ok)
@@ -171,7 +170,7 @@
if ((infd[nfiles] = G_open_cell_old(name, mapset)) < 0)
G_fatal_error(_("Unable to open raster map <%s>"), name);
if ((G_get_cellhd(name, mapset, &cellhd)) < 0)
- G_fatal_error(_("Unable to read file header of <%s>"), name);
+ G_fatal_error(_("Unable to read file header of raster map <%s>"), name);
inrast[nfiles] = G_allocate_raster_buf(in_data_type[nfiles]);
nfiles++;
@@ -183,13 +182,13 @@
ok = 1;
for (; *ptr1 != NULL; ptr1++) {
if (nfiles1 > MAXFILES)
+ MAXFILES);
name1 = *ptr1;
- mapset = G_find_cell2(name1, "");
+ mapset = (char *) G_find_cell2(name1, "");
- G_fatal_error(_("raster map <%s> not found"), name1);
+ G_fatal_error(_("Raster map <%s> not found"), name1);
ok = 0;
if (!ok)
@@ -204,7 +203,7 @@
if ((infd1[nfiles1] = G_open_cell_old(name1, mapset)) < 0)
G_fatal_error(_("Unable to open raster map <%s>"), name1);
if ((G_get_cellhd(name1, mapset, &cellhd)) < 0)
- G_fatal_error(_("Unable to read file header of <%s>"), name1);
+ G_fatal_error(_("Unable to read file header of raster map <%s>"), name1);
inrast1[nfiles1] = G_allocate_raster_buf(in_data_type1[nfiles1]);
nfiles1++;
@@ -222,13 +221,13 @@
ok = 1;
for (; *ptr2 != NULL; ptr2++) {
+ MAXFILES);
name2 = *ptr2;
- mapset = G_find_cell2(name2, "");
+ mapset = (char *) G_find_cell2(name2, "");
- G_fatal_error(_("raster map <%s> not found"), name2);
+ G_fatal_error(_("Raster map <%s> not found"), name2);
ok = 0;
if (!ok)
@@ -244,7 +243,7 @@
G_fatal_error(_("Unable to open raster map <%s>"), name2);
if ((G_get_cellhd(name2, mapset, &cellhd)) < 0) {
- G_fatal_error(_("Unable to read file header of <%s>"), name2);
+ G_fatal_error(_("Unable to read file header of raster map <%s>"), name2);
inrast2[nfiles2] = G_allocate_d_raster_buf();
nfiles2++;
@@ -261,7 +260,7 @@
/* Create New raster files */
if ((outfd = G_open_raster_new(result, 1)) < 0)
- G_fatal_error(_("Could not open <%s>"), result);
+ G_fatal_error(_("Unable to create raster map <%s>"), result);
/* Process pixels */
@@ -280,15 +279,15 @@
/* read input map */
for (i = 1; i <= nfiles; i++)
if ((G_get_d_raster_row(infd[i], inrast[i], row)) < 0)
- G_fatal_error(_("Could not read from <%s>"), name);
+ G_fatal_error(_("Unable to read raster map <%s> row %d"), name, row);
for (i = 1; i <= nfiles1; i++)
if ((G_get_d_raster_row(infd1[i], inrast1[i], row)) < 0)
- G_fatal_error(_("Could not read from <%s>"), name1);
+ G_fatal_error(_("Unable to read raster map <%s> row %d"), name1, row);
for (i = 1; i <= nfiles2; i++)
if ((G_get_d_raster_row (infd2[i], inrast2[i], row)) < 0)
- G_fatal_error(_("Could not read from <%s>"), name2);
+ G_fatal_error(_("Unable to read raster map <%s> row %d"), name2, row);
/*process the data */
for (col = 0; col < ncols; col++)
