[GRASS-SVN] r37975 - grass/trunk/scripts/v.out.gps
svn_grass at osgeo.org
Fri Jun 19 16:37:42 EDT 2009
Author: glynn
Date: 2009-06-19 16:37:41 -0400 (Fri, 19 Jun 2009)
New Revision: 37975
Added:
grass/trunk/scripts/v.out.gps/v.out.gps.py
Convert v.out.gps to Python (untested)
Added: grass/trunk/scripts/v.out.gps/v.out.gps.py
--- grass/trunk/scripts/v.out.gps/v.out.gps.py (rev 0)
+++ grass/trunk/scripts/v.out.gps/v.out.gps.py 2009-06-19 20:37:41 UTC (rev 37975)
@@ -0,0 +1,334 @@
+#!/usr/bin/env python
+# MODULE: v.out.gps
+# PURPOSE: Exports a GRASS vector map to a GPS receiver
+# or data file using GpsBabel
+# COPYRIGHT: (c) 2008-2009 Hamish Bowman, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# AUTHOR: Hamish Bowman, Dunedin, New Zealand
+# Converted to Python by Glynn Clements
+# REQUIREMENTS:
+# - GpsBabel from http://gpsbabel.sourceforge.net
+# - cs2cs from PROJ.4 (for m.proj) http://proj.osgeo.org
+# - report supported GpsBabel formats:
+# gpsbabel -^2 | tr '\t' ';' | sort -t';' -k3
+# How to do it
+# http://www.gdal.org/ogr/drv_gpx.html
+# gpsbabel [options] -i INTYPE -f INFILE -o OUTTYPE -F OUTFILE
+#%Module
+#% description: Exports a vector map to a GPS receiver or file format supported by GpsBabel.
+#% keywords: vector, export, GPS
+#%End
+#%flag
+#% key: w
+#% description: Export as waypoints
+#%end
+#%flag
+#% key: r
+#% description: Export as routes
+#%end
+#%flag
+#% key: t
+#% description: Export as tracks
+#%end
+############ TODO:
+##%flag
+##% key: z
+##% description: Export altitude from 3D vector's z-coordinate
+##%end
+#%option
+#% key: input
+#% type: string
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#% required: yes
+#%end
+#%option
+#% key: type
+#% type: string
+#% description: Feature type(s)
+#% options: point,centroid,line,boundary
+#% multiple: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% description: Name for output file or GPS device
+#% gisprompt: new_file,file,output
+#% key_desc: name
+#% required: yes
+#%end
+#%option
+#% key: format
+#% type: string
+#% description: GpsBabel supported output format
+#% answer: gpx
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% label: Layer number
+#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
+#% answer: 1
+#% required : no
+#% guisection: Subset
+#%end
+#%option
+#% key: where
+#% type: string
+#% label: WHERE conditions of SQL statement without 'where' keyword
+#% description: Example: income < 1000 and inhab >= 10000
+#% required : no
+#%end
+import sys
+import os
+import atexit
+import string
+import grass.script as grass
+def cleanup():
+ grass.verbose("Cleaning up ...")
+ if tmp:
+ grass.try_remove(tmp)
+ if tmp_proj:
+ grass.try_remove(tmp_proj)
+ if tmp_gpx:
+ grass.try_remove(tmp_gpx)
+ # only try to remove map if it exists to avoid ugly warnings
+ if tmp_vogb:
+ if grass.find_file(tmp_vogb, element = 'vector')['name']:
+ grass.run_command('g.remove', vect = tmp_vogb, quiet = True)
+ if tmp_extr:
+ if grass.find_file(tmp_extr, element = 'vector')['name']:
+tmp = None
+tmp_proj = None
+tmp_gpx = None
+tmp_extr = None
+tmp_vogb = None
+def main():
+ global tmp, tmp_proj, tmp_gpx, tmp_extr, tmp_vogb
+ format = options['format']
+ input = options['input']
+ layer = options['layer']
+ output = options['output']
+ type = options['type']
+ where = options['where']
+ wpt = flags['w']
+ rte = flags['r']
+ trk = flags['t']
+ nflags = len(filter(None, [wpt, rte, trk]))
+ if nflags > 1:
+ grass.fatal("One feature at a time please.")
+ if nflags < 1:
+ grass.fatal("No features requested for export.")
+ # set some reasonable defaults
+ if not type:
+ if wpt:
+ type = 'point'
+ else:
+ type = 'line'
+ #### check for gpsbabel
+ ### FIXME: may need --help or similar?
+ if not grass.find_program("gpsbabel"):
+ grass.fatal("The gpsbabel program was not found, please install it first.\n" +
+ "http://gpsbabel.sourceforge.net")
+ #### check for cs2cs
+ if not grass.find_program("cs2cs"):
+ grass.fatal("The cs2cs program was not found, please install it first.\n" +
+ "http://proj.osgeo.org")
+ # check if we will overwrite data
+ if os.path.exists(output) and not grass.overwrite():
+ grass.fatal("Output file already exists.")
+ #### set temporary files
+ tmp = grass.tempfile()
+ # SQL extract if needed
+ if where:
+ grass.verbose("Extracting data ...")
+ tmp_extr = "tmp_vogb_extr_%d" % os.getpid()
+ ret = grass.run_command('v.extract', input = "$GIS_OPT_INPUT",
+ output = tmp_extr, type = type, layer = layer,
+ where = where, quiet = True)
+ if ret != 0:
+ grass.fatal("Error executing SQL query")
+ kv = grass.vector_info_topo(tmp_extr)
+ if kv['primitives'] == 0:
+ grass.fatal("SQL query returned an empty map (no %s features?)" % type)
+ inmap = tmp_extr
+ else:
+ # g.copy "$GIS_OPT_INPUT,tmp_vogb_extr_$$" # to get a copy of DB into local mapset
+ # INMAP="tmp_vogb_extr_$$"
+ inmap = input
+ #### set up projection info
+ # TODO: check if we are already in ll/WGS84. If so skip m.proj step.
+ # TODO: multi layer will probably fail badly due to sed 's/^ 1 /'
+ # output as old GRASS 4 vector ascii and fight with dig_ascii/?
+ # Change to s/^ \([0-9] .*\) /# \1/' ??? mmph.
+ # reproject to lat/lon WGS84
+ grass.verbose("Reprojecting data ...")
+ re1 = re.compile(r'^\([PLBCFKA]\)')
+ re2 = re.compile(r'^ 1 ')
+ re3 = re.compile(r'\t\([-\.0-9]*\) .*')
+ re4 = re.compile(r'^\([-\.0-9]\)')
+ re5 = re.compile(r'^#')
+ tmp_proj = tmp + ".proj"
+ tf = open(tmp_proj, 'w')
+ p1 = grass.pipe_command('v.out.ascii', input = inmap, format = 'standard')
+ p2 = grass.feed_command('m.proj', flags = 'od', quiet = True, stdout = tf)
+ tf.close()
+ lineno = 0
+ for line in p1.stdout:
+ lineno += 1
+ if lineno < 11:
+ continue
+ line = re1.sub(r'#\1', line)
+ line = re2.sub(r'# 1 ', line)
+ p2.stdin.write(line)
+ p2.stdin.close()
+ p1.wait()
+ p2.wait()
+ if p1.returncode != 0 or p2.returncode != 0:
+ grass.fatal("Error reprojecting data")
+ tmp_vogb = "tmp_vogb_epsg4326_%d" % os.getpid()
+ p3 = grass.feed_command('v.in.ascii', out = tmp_vogb, format = 'standard', flags = 'n', quiet = True)
+ tf = open(tmp_proj, 'r')
+ for line in tf:
+ line = re3.sub(r' \1', line)
+ line = re4.sub(r' \1', line)
+ line = re5.sub('', line)
+ p3.stdin.write(line)
+ p3.stdin.close()
+ tf.close()
+ p3.wait()
+ if p3.returncode != 0:
+ # don't v.db.connect directly as source table will be removed with
+ # temporary map in that case. So we make a temp copy of it to work with.
+ kv = vector_db(inmap)
+ if layer in kv:
+ db_params = kv[layer]
+ db_table = db_params['table']
+ db_key = db_params['key']
+ db_database = db_params['database']
+ db_driver = db_params['driver']
+ ret = grass.run_command('db.copy',
+ from_driver = db_driver,
+ from_database = db_database,
+ from_table = db_table,
+ to_table = tmp_vogb)
+ if ret != 0:
+ grass.fatal("Error copying temporary DB")
+ ret = grass.run_command('v.db.connect', map = tmp_vogb, table = tmp_vogb, quiet = True)
+ if ret != 0:
+ grass.fatal("Error reconnecting temporary DB")
+ # export as GPX using v.out.ogr
+ if trk:
+ linetype = "FORCE_GPX_TRACK=YES"
+ elif rte:
+ else:
+ linetype = None
+ # BUG: cat is being reported as evelation and attribute output is skipped.
+ # (v.out.ogr DB reading or ->OGR GPX driver bug ?)
+ # v.out.ogr -> shapefile -> GPX works, but we try to avoid that as it's
+ # lossy. Also that would allow ogr2ogr -a_srs $IN_PROJ -t_srs EPSG:4326
+ # so skip m.proj pains.. if that is done ogr2ogr -s_srs MUST HAVE +wktext
+ # with PROJ.4 terms or else the +nadgrids will be ignored! best to feed
+ # it IN_PROJ="`g.proj -jf` +wktext" in that case.
+ grass.verbose("Exporting data ...")
+ tmp_gpx = tmp + ".gpx"
+ ret = grass.run_command('v.out.ogr', input = tmp_vogb, dsn = tmp_gpx,
+ type = type, format = 'GPX', lco = linetype,
+ dsco = "GPX_USE_EXTENSIONS=YES", quiet = True)
+ if ret != 0:
+ grass.fatal("Error exporting data")
+ if format == 'gpx':
+ # short circuit, we have what we came for.
+ grass.try_remove(output)
+ os.rename(tmp_gpx, output)
+ grass.verbose("Fast exit.")
+ sys.exit()
+ # run gpsbabel
+ if wpt:
+ gtype = '-w'
+ elif trk:
+ gtype = '-t'
+ elif rte:
+ gtype = '-r'
+ else:
+ gtype = ''
+ grass.verbose("Running GpsBabel ...")
+ ret = grass.call(['gpsbabel',
+ gtype,
+ '-i', 'gpx',
+ '-f', tmp + '.gpx',
+ '-o', format,
+ '-F', output])
+ if ret != 0:
+ grass.fatal("Error running GpsBabel")
+ grass.verbose("Done.")
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ main()
Property changes on: grass/trunk/scripts/v.out.gps/v.out.gps.py
___________________________________________________________________
