[GRASS-SVN] r37999 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Sat Jun 20 08:36:33 EDT 2009
Author: martinl
Date: 2009-06-20 08:36:33 -0400 (Sat, 20 Jun 2009)
New Revision: 37999
grass-addons/vector/v.krige/v.krige.py
use gselect.ColumnSelect
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-06-20 12:19:03 UTC (rev 37998)
+++ grass-addons/vector/v.krige/v.krige.py 2009-06-20 12:36:33 UTC (rev 37999)
@@ -61,24 +61,26 @@
# 1. Input data
InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label='Input Data'),
- orient=wx.HORIZONTAL)
+ orient=wx.HORIZONTAL)
- self.InputDataLabel = wx.StaticText(self, id=wx.ID_ANY, label="Point dataset")
- self.InputDataChoicebox = gselect.VectorSelect(parent = self,
+ flexSizer = wx.FlexGridSizer(cols=2, hgap=5, vgap=5)
+ flexSizer.AddGrowableCol(1)
+ flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label="Point dataset:"),
+ flag = wx.ALIGN_CENTER_VERTICAL)
+ self.InputDataMap = gselect.VectorSelect(parent = self,
ftype = 'point')
+ flexSizer.Add(item = self.InputDataMap)
- ### self.ColumnList = self.__getColumns(self.InputDataChoicebox.GetStringSelection())
- self.InputDataColumnLabel = wx.StaticText(self, id=wx.ID_ANY, label="Column")
- self.InputDataColumn = wx.Choice(self, id=wx.ID_ANY, pos=wx.DefaultPosition)
- ### choices=self.ColumnList)
+ flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label="Column:"),
+ flag=wx.ALIGN_CENTER_VERTICAL)
+ self.InputDataColumn = gselect.ColumnSelect(self, id=wx.ID_ANY)
+ flexSizer.Add(item = self.InputDataColumn)
- self.InputDataChoicebox.Bind(wx.EVT_CHOICE, self.OnInputDataChanged)
+ self.InputDataMap.GetChildren()[0].Bind(wx.EVT_TEXT, self.OnInputDataChanged)
- InputBoxSizer.Add(self.InputDataLabel, proportion=0, flag=wx.CENTER | wx.ALL, border=self.border)
- InputBoxSizer.Add(self.InputDataChoicebox, proportion=0, flag=wx.CENTER| wx.ALL, border=self.border)
- InputBoxSizer.Add(self.InputDataColumnLabel, proportion=0, flag=wx.CENTER | wx.ALL, border=self.border)
- InputBoxSizer.Add(self.InputDataColumn, proportion=0, flag=wx.CENTER| wx.ALL, border=self.border)
+ InputBoxSizer.Add(item = flexSizer)
# 2. Kriging. In book pages one for each R package. Includes variogram fit.
KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label='Kriging'), wx.HORIZONTAL)
@@ -139,29 +141,15 @@
else:
pass
- def __getColumns(self, layer):
- """ Lists the numerical columns of the given layer. """
- # filter it to pick up numerical cols
- NumericalColumnList = list()
- try:
- ColumnList = grass.db_describe(layer)['cols']
- except TypeError:
- return NumericalColumnList
- for i in ColumnList:
- if i[1] == 'INTEGER' or i[1] == 'DOUBLE PRECISION':
- NumericalColumnList.append(i[0])
- def OnInputDataChanged(self,event):
- """ Refreshes list of columns. """
- table = event.GetString()
- cols = self.__getColumns(table)
- self.InputDataColumn.SetItems(cols)
- self.InputDataColumn.SetSelection(0)
+ def OnInputDataChanged(self, event):
+ """Refreshes list of columns
- event.Skip() #?
+ @todo: layer select
+ self.InputDataColumn.InsertColumns(vector = event.GetString(),
+ layer = 1, excludeKey = True,
+ type = ['integer', 'double precision'])
def OnRunButton(self,event):
""" Execute R analysis. """
@@ -172,7 +160,7 @@
#0. require packages. See creation of the notebook pages and note after import directives.
#1. get the data in R format, i.e. SpatialPointsDataFrame
- self.InputData = robjects.r.readVECT6(self.InputDataChoicebox.GetStringSelection(), type= 'point')
+ self.InputData = robjects.r.readVECT6(self.InputDataMap.GetStringSelection(), type= 'point')
#2. collect options
#@TODO(anne): let user pick up the column name from a list. this is hardwired code.
self.Column = self.InputDataColumn.GetStringSelection()
