[GRASS-SVN] r38000 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Jun 20 08:38:05 EDT 2009
Author: martinl
Date: 2009-06-20 08:38:05 -0400 (Sat, 20 Jun 2009)
New Revision: 38000
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
wxGUI: VectorSelect implemented
(merge from trunk, r37998)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2009-06-20 12:36:33 UTC (rev 37999)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2009-06-20 12:38:05 UTC (rev 38000)
@@ -5,6 +5,7 @@
Classes:
- Select
+ - VectorSelect
- TreeCrtlComboPopup
- VectorDBInfo
- LayerSelect
@@ -34,10 +35,9 @@
from preferences import globalSettings as UserSettings
class Select(wx.combo.ComboCtrl):
- def __init__(self, parent, id, size,
+ def __init__(self, parent, id, size = globalvar.DIALOG_GSELECT_SIZE,
type=None, multiple=False, mapsets=None, exceptOf=[]):
- Custom control to create a ComboBox with a tree control
+ """!Custom control to create a ComboBox with a tree control
to display and select GIS elements within acessible mapsets.
Elements can be selected with mouse. Can allow multiple selections, when
argument multiple=True. Multiple selections are separated by commas.
@@ -51,22 +51,59 @@
self.SetPopupControl(self.tcp)
self.SetPopupExtents(0,100)
if type:
- self.tcp.GetElementList(type, mapsets, exceptOf)
self.tcp.SetData(type = type, mapsets = mapsets,
exceptOf = exceptOf, multiple = multiple)
def SetElementList(self, type, mapsets = None, exceptOf = []):
- self.tcp.seltree.DeleteAllItems()
- self.tcp.GetElementList(type)
+ """!Set element list
+ @param type GIS element type
+ @param mapsets list of acceptable mapsets (None for all in search path)
+ @param exceptOf list of GIS elements to be excluded"""
exceptOf = exceptOf)
+class VectorSelect(Select):
+ def __init__(self, parent, ftype, **kwargs):
+ """!Custom to create a ComboBox with a tree control to display and
+ select vector maps. Control allows to filter vector maps. If you
+ don't need this feature use Select class instead
+ @ftype filter vector maps based on feature type
+ Select.__init__(self, parent = parent, id = wx.ID_ANY,
+ type = 'vector', **kwargs)
+ # remove vector maps which do not contain given feature type
+ self.tcp.SetFilter(self.__filterElements)
+ def __filterElements(self, parentItem):
+ """!Filter vector maps in given mapset"""
+ root = self.tcp.seltree.GetRootItem()
+ item, cookie = self.tcp.seltree.GetFirstChild(parentItem)
+ while item:
+ if self.tcp.seltree.GetItemParent(item) != root:
+ # skip Mapset items
+ vectorName = self.tcp.seltree.GetItemText(item)
+ try:
+ if int(grass.vector_info_topo(vectorName)['points']) < 1:
+ self.tcp.seltree.Delete(item)
+ except KeyError:
+ if not item:
+ item, cookie = self.tcp.seltree.GetNextChild(parentItem, cookie)
+ continue
+ if self.tcp.seltree.ItemHasChildren(item):
+ item = self.__filterElements(item)
class TreeCtrlComboPopup(wx.combo.ComboPopup):
- Create a tree ComboBox for selecting maps and other GIS elements
+ """!Create a tree ComboBox for selecting maps and other GIS elements
in accessible mapsets within the current location
# overridden ComboPopup methods
def Init(self):
self.value = [] # for multiple is False -> len(self.value) in [0,1]
@@ -76,6 +113,8 @@
self.mapsets = []
self.exceptOf = []
+ self.SetFilter(None)
def Create(self, parent):
self.seltree = wx.TreeCtrl(parent, style=wx.TR_HIDE_ROOT
|wx.TR_HAS_BUTTONS
@@ -117,12 +156,18 @@
return str
+ def SetFilter(self, filter):
+ """!Set filter for GIS elements, see e.g. VectorSelect"""
+ self.filterElements = filter
def OnPopup(self):
"""!Limited only for first selected"""
# update list
self.seltree.DeleteAllItems()
self.GetElementList(self.type, self.mapsets, self.exceptOf)
+ if self.filterElements:
+ self.filterElements(self.seltree.GetRootItem())
if len(self.value) > 0:
root = self.seltree.GetRootItem()
if not root:
@@ -148,9 +193,12 @@
return wx.Size(minWidth, min(200, maxHeight))
def GetElementList(self, element, mapsets=None, exceptOf=[]):
- Get list of GIS elements in accessible mapsets and display as tree
+ """!Get list of GIS elements in accessible mapsets and display as tree
with all relevant elements displayed beneath each mapset branch
+ @param element GIS element
+ @param mapsets list of acceptable mapsets (None for all mapsets in search path)
# get current mapset
curr_mapset = grass.gisenv()['MAPSET']
@@ -429,8 +477,7 @@
return self.tables[table]
class LayerSelect(wx.Choice):
- Creates combo box for selecting data layers defined for vector.
+ """!Creates combo box for selecting data layers defined for vector.
The 'layer' terminology is likely to change for GRASS 7
@@ -482,9 +529,8 @@
self.SetStringSelection(str(self.default))
class DriverSelect(wx.ComboBox):
+ """!Creates combo box for selecting database driver.
- Creates combo box for selecting database driver.
def __init__(self, parent, choices, value,
id=wx.ID_ANY, pos=wx.DefaultPosition,
size=globalvar.DIALOG_LAYER_SIZE, **kargs):
@@ -497,9 +543,8 @@
self.SetStringSelection(value)
class DatabaseSelect(wx.TextCtrl):
def __init__(self, parent, value='',
size=globalvar.DIALOG_TEXTCTRL_SIZE, **kargs):
@@ -509,9 +554,8 @@
self.SetName("DatabaseSelect")
class TableSelect(wx.ComboBox):
+ """!Creates combo box for selecting attribute tables from the database
- Creates combo box for selecting attribute tables from the database
id=wx.ID_ANY, value='', pos=wx.DefaultPosition,
size=globalvar.DIALOG_COMBOBOX_SIZE,
