[GRASS-SVN] r38027 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Mon Jun 22 12:40:17 EDT 2009
Author: aghisla
Date: 2009-06-22 12:40:17 -0400 (Mon, 22 Jun 2009)
New Revision: 38027
grass-addons/vector/v.krige/v.krige.py
restored access to vector and column comboboxes
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-06-22 11:56:33 UTC (rev 38026)
+++ grass-addons/vector/v.krige/v.krige.py 2009-06-22 16:40:17 UTC (rev 38027)
@@ -160,17 +160,16 @@
#0. require packages. See creation of the notebook pages and note after import directives.
#1. get the data in R format, i.e. SpatialPointsDataFrame
- self.InputData = robjects.r.readVECT6(self.InputDataMap.GetStringSelection(), type= 'point')
+ self.InputData = robjects.r.readVECT6(self.InputDataMap.GetValue(), type= 'point')
#2. collect options
- #@TODO(anne): let user pick up the column name from a list. this is hardwired code.
- self.Column = self.InputDataColumn.GetStringSelection()
+ self.Column = self.InputDataColumn.GetValue()
#@TODO(anne): pick up parameters if user chooses to set variogram parameters.
#3. Fit variogram
self.parent.log.write('Variogram fitting')
self.Formula = robjects.r['as.formula'](robjects.r.paste(self.Column, "~ 1"))
Variogram = self.SelectedPanel.FitVariogram(self.Formula, self.InputData)
# print variogram?
+# robjects.r.plot(Variogram.r['exp_var'], Variogram.r['var_model'])
self.parent.log.write('Variogram fitted.')
#4. Kriging
@@ -218,11 +217,11 @@
wx.Panel.__init__(self, parent, *args, **kwargs)
# unlock options as soon as they are available. Stone soup!
- self.VariogramSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY,
+ VariogramSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY,
label='Variogram fitting'), wx.VERTICAL)
VariogramCheckBox = wx.CheckBox(self, id=wx.ID_ANY, label="Auto-fit variogram")
VariogramCheckBox.SetValue(state = True) # check it by default
- self.ParametersSizer = wx.BoxSizer(wx.VERTICAL)
+ ParametersSizer = wx.FlexGridSizer(cols=3, hgap=5, vgap=5)
for n in ["Sill", "Nugget", "Range"]:
setattr(self, n+"Sizer", (wx.BoxSizer(wx.HORIZONTAL)))
@@ -231,10 +230,10 @@
a = getattr(self, n+"Sizer")
a.Add(getattr(self, n+"Text"), proportion=0, flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER | wx.ALL, border=3)
a.Add(getattr(self, n+"Ctrl"), proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=3)
- self.ParametersSizer.Add(a, proportion = 0, flag=wx.EXPAND | wx.ALL, border=3)
+ ParametersSizer.Add(a)#, proportion = 0, flag=wx.EXPAND | wx.ALL, border=3)
- self.VariogramSizer.Add(VariogramCheckBox, proportion=1, flag=wx.EXPAND | wx.ALL, border=3)
- self.VariogramSizer.Add(self.ParametersSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
+ VariogramSizer.Add(VariogramCheckBox, proportion=1, flag=wx.EXPAND | wx.ALL, border=3)
+ VariogramSizer.Add(ParametersSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
#@TODO(anne); hides Parameters when Autofit variogram is selected
# VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
@@ -244,7 +243,7 @@
choices=self.KrigingList, majorDimension=1, style=wx.RA_SPECIFY_COLS)
- Sizer.Add(self.VariogramSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
+ Sizer.Add(VariogramSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
Sizer.Add(KrigingRadioBox, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
self.SetSizerAndFit(Sizer)
@@ -267,6 +266,11 @@
def FitVariogram(self, Formula, InputData):
return robjects.r.autofitVariogram(Formula, InputData)
+ def DoKriging():
+ #BUG: remove grid creation when automap command will be corrected.
+ #PredictionGrid = grass.run_command("v.mkgrid")
+ pass
def main(argv=None):
if argv is None:
argv = sys.argv
