[GRASS-SVN] r38028 - in grass/trunk: ps/ps.map raster/r.buffer raster/r.coin raster/r.cross raster/r.distance raster/r.flow raster/r.in.gridatb raster/r.kappa raster/r.mapcalc raster/r.mfilter raster/r.out.gridatb raster/r.out.vrml raster/r.param.scale raster/r.quant raster/r.recode raster/r.report raster/r.stats raster/r.surf.contour raster/r.surf.fractal raster/r.topmodel raster/r.univar raster/r.watershed/ram raster/r.watershed/seg vector/v.to.rast
Mon Jun 22 13:48:21 EDT 2009
Author: martinl
Date: 2009-06-22 13:48:21 -0400 (Mon, 22 Jun 2009)
New Revision: 38028
   grass/trunk/ps/ps.map/do_header.c
   grass/trunk/ps/ps.map/do_labels.c
   grass/trunk/ps/ps.map/ps_clrtbl.c
   grass/trunk/ps/ps.map/ps_fclrtbl.c
   grass/trunk/ps/ps.map/ps_vpoints.c
   grass/trunk/ps/ps.map/r_border.c
   grass/trunk/ps/ps.map/r_cell.c
   grass/trunk/ps/ps.map/r_colortable.c
   grass/trunk/ps/ps.map/r_plt.c
   grass/trunk/ps/ps.map/r_rgb.c
   grass/trunk/ps/ps.map/r_text.c
   grass/trunk/ps/ps.map/r_vlines.c
   grass/trunk/ps/ps.map/r_wind.c
   grass/trunk/raster/r.buffer/main.c
   grass/trunk/raster/r.buffer/read_map.c
   grass/trunk/raster/r.buffer/support.c
   grass/trunk/raster/r.buffer/write_map.c
   grass/trunk/raster/r.coin/print_hdr.c
   grass/trunk/raster/r.cross/cats.c
   grass/trunk/raster/r.cross/cross.c
   grass/trunk/raster/r.cross/main.c
   grass/trunk/raster/r.cross/renumber.c
   grass/trunk/raster/r.distance/distance.c
   grass/trunk/raster/r.distance/edges.c
   grass/trunk/raster/r.distance/labels.c
   grass/trunk/raster/r.flow/io.c
   grass/trunk/raster/r.in.gridatb/adjcellhd.c
   grass/trunk/raster/r.in.gridatb/main.c
   grass/trunk/raster/r.kappa/mask.c
   grass/trunk/raster/r.kappa/prt_hdr.c
   grass/trunk/raster/r.kappa/prt_label.c
   grass/trunk/raster/r.mapcalc/column_shift.c
   grass/trunk/raster/r.mapcalc/map.c
   grass/trunk/raster/r.mapcalc/map3.c
   grass/trunk/raster/r.mapcalc/xabs.c
   grass/trunk/raster/r.mapcalc/xacos.c
   grass/trunk/raster/r.mapcalc/xadd.c
   grass/trunk/raster/r.mapcalc/xand.c
   grass/trunk/raster/r.mapcalc/xand2.c
   grass/trunk/raster/r.mapcalc/xasin.c
   grass/trunk/raster/r.mapcalc/xatan.c
   grass/trunk/raster/r.mapcalc/xbitand.c
   grass/trunk/raster/r.mapcalc/xbitnot.c
   grass/trunk/raster/r.mapcalc/xbitor.c
   grass/trunk/raster/r.mapcalc/xbitxor.c
   grass/trunk/raster/r.mapcalc/xcoor.c
   grass/trunk/raster/r.mapcalc/xcos.c
   grass/trunk/raster/r.mapcalc/xdiv.c
   grass/trunk/raster/r.mapcalc/xdouble.c
   grass/trunk/raster/r.mapcalc/xeq.c
   grass/trunk/raster/r.mapcalc/xeval.c
   grass/trunk/raster/r.mapcalc/xexp.c
   grass/trunk/raster/r.mapcalc/xfloat.c
   grass/trunk/raster/r.mapcalc/xge.c
   grass/trunk/raster/r.mapcalc/xgraph.c
   grass/trunk/raster/r.mapcalc/xgt.c
   grass/trunk/raster/r.mapcalc/xif.c
   grass/trunk/raster/r.mapcalc/xint.c
   grass/trunk/raster/r.mapcalc/xisnull.c
   grass/trunk/raster/r.mapcalc/xle.c
   grass/trunk/raster/r.mapcalc/xlog.c
   grass/trunk/raster/r.mapcalc/xlt.c
   grass/trunk/raster/r.mapcalc/xmax.c
   grass/trunk/raster/r.mapcalc/xmedian.c
   grass/trunk/raster/r.mapcalc/xmin.c
   grass/trunk/raster/r.mapcalc/xmod.c
   grass/trunk/raster/r.mapcalc/xmode.c
   grass/trunk/raster/r.mapcalc/xmul.c
   grass/trunk/raster/r.mapcalc/xne.c
   grass/trunk/raster/r.mapcalc/xneg.c
   grass/trunk/raster/r.mapcalc/xnot.c
   grass/trunk/raster/r.mapcalc/xnull.c
   grass/trunk/raster/r.mapcalc/xor.c
   grass/trunk/raster/r.mapcalc/xor2.c
   grass/trunk/raster/r.mapcalc/xpow.c
   grass/trunk/raster/r.mapcalc/xres.c
   grass/trunk/raster/r.mapcalc/xround.c
   grass/trunk/raster/r.mapcalc/xshiftl.c
   grass/trunk/raster/r.mapcalc/xshiftr.c
   grass/trunk/raster/r.mapcalc/xshiftru.c
   grass/trunk/raster/r.mapcalc/xsin.c
   grass/trunk/raster/r.mapcalc/xsqrt.c
   grass/trunk/raster/r.mapcalc/xsub.c
   grass/trunk/raster/r.mapcalc/xtan.c
   grass/trunk/raster/r.mfilter/apply.c
   grass/trunk/raster/r.mfilter/execute.c
   grass/trunk/raster/r.mfilter/perform.c
   grass/trunk/raster/r.out.gridatb/adjcellhd.c
   grass/trunk/raster/r.out.gridatb/file_io.c
   grass/trunk/raster/r.out.vrml/put_grid.c
   grass/trunk/raster/r.param.scale/close_down.c
   grass/trunk/raster/r.param.scale/write_cols.c
   grass/trunk/raster/r.quant/main.c
   grass/trunk/raster/r.quant/read_rules.c
   grass/trunk/raster/r.recode/read_rules.c
   grass/trunk/raster/r.recode/recode.c
   grass/trunk/raster/r.report/header.c
   grass/trunk/raster/r.report/parse.c
   grass/trunk/raster/r.report/prt_report.c
   grass/trunk/raster/r.report/stats.c
   grass/trunk/raster/r.stats/global.h
   grass/trunk/raster/r.surf.contour/read_cell.c
   grass/trunk/raster/r.surf.fractal/write_rast.c
   grass/trunk/raster/r.topmodel/global.h
   grass/trunk/raster/r.univar/globals.h
   grass/trunk/raster/r.watershed/ram/Gwater.h
   grass/trunk/raster/r.watershed/seg/Gwater.h
   grass/trunk/vector/v.to.rast/do_areas.c
add missing raster.h
Modified: grass/trunk/ps/ps.map/do_header.c
--- grass/trunk/ps/ps.map/do_header.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/do_header.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -5,6 +5,7 @@
 #include <unistd.h>
 #include <string.h>
+#include <grass/raster.h>
 #include "header.h"
 #include "ps_info.h"
 #include "local_proto.h"
Modified: grass/trunk/ps/ps.map/do_labels.c
--- grass/trunk/ps/ps.map/do_labels.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/do_labels.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -8,6 +8,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <grass/glocale.h>
 #include "clr.h"
Modified: grass/trunk/ps/ps.map/ps_clrtbl.c
--- grass/trunk/ps/ps.map/ps_clrtbl.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/ps_clrtbl.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -3,6 +3,7 @@
  ** Author: Paul W. Carlson     April 1992
Modified: grass/trunk/ps/ps.map/ps_fclrtbl.c
--- grass/trunk/ps/ps.map/ps_fclrtbl.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/ps_fclrtbl.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -4,6 +4,7 @@
 #include <string.h>
Modified: grass/trunk/ps/ps.map/ps_vpoints.c
--- grass/trunk/ps/ps.map/ps_vpoints.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/ps_vpoints.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -5,6 +5,7 @@
  ** modified to use G_plot_line() by Olga Waupotitsch on dec,93
 #include <grass/vector.h>
 #include <grass/dbmi.h>
 #include <grass/symbol.h>
Modified: grass/trunk/ps/ps.map/r_border.c
--- grass/trunk/ps/ps.map/r_border.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/r_border.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -10,6 +10,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "border.h"
Modified: grass/trunk/ps/ps.map/r_cell.c
--- grass/trunk/ps/ps.map/r_cell.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/r_cell.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -5,6 +5,7 @@
 #include <string.h>
Modified: grass/trunk/ps/ps.map/r_colortable.c
--- grass/trunk/ps/ps.map/r_colortable.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/r_colortable.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -5,6 +5,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "colortable.h"
Modified: grass/trunk/ps/ps.map/r_plt.c
--- grass/trunk/ps/ps.map/r_plt.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/r_plt.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,4 +1,5 @@
 #include <string.h>
Modified: grass/trunk/ps/ps.map/r_rgb.c
--- grass/trunk/ps/ps.map/r_rgb.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/r_rgb.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -5,6 +5,7 @@
 #include <string.h>
 #include "group.h"
Modified: grass/trunk/ps/ps.map/r_text.c
--- grass/trunk/ps/ps.map/r_text.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/r_text.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -6,6 +6,7 @@
 #include <string.h>
 #include "clr.h"
 #include "labels.h"
Modified: grass/trunk/ps/ps.map/r_vlines.c
--- grass/trunk/ps/ps.map/r_vlines.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/r_vlines.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -8,6 +8,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "vector.h"
Modified: grass/trunk/ps/ps.map/r_wind.c
--- grass/trunk/ps/ps.map/r_wind.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/ps/ps.map/r_wind.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,6 +1,7 @@
 /* parse the "region" instruction */
 #include <string.h>
 #define KEY(x) (strcmp(key,x)==0)
Modified: grass/trunk/raster/r.buffer/main.c
--- grass/trunk/raster/r.buffer/main.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.buffer/main.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -26,6 +26,7 @@
 #include "distance.h"
 struct Distance *distances;
Modified: grass/trunk/raster/r.buffer/read_map.c
--- grass/trunk/raster/r.buffer/read_map.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.buffer/read_map.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -21,8 +21,8 @@
 #include <stdlib.h>
-#include <grass/glocale.h>
     /* read the input map. convert non-nulls to 1 */
Modified: grass/trunk/raster/r.buffer/support.c
--- grass/trunk/raster/r.buffer/support.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.buffer/support.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -19,6 +19,7 @@
Modified: grass/trunk/raster/r.buffer/write_map.c
--- grass/trunk/raster/r.buffer/write_map.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.buffer/write_map.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -21,6 +21,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.coin/print_hdr.c
--- grass/trunk/raster/r.coin/print_hdr.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.coin/print_hdr.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -16,9 +16,9 @@
 #include "coin.h"
 int print_coin_hdr(int Conformat)
     char unit_type[20];
Modified: grass/trunk/raster/r.cross/cats.c
--- grass/trunk/raster/r.cross/cats.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.cross/cats.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -17,6 +17,7 @@
 #include <string.h>
 #include "glob.h"
 static char *get_label(CELL, struct Categories *);
Modified: grass/trunk/raster/r.cross/cross.c
--- grass/trunk/raster/r.cross/cross.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.cross/cross.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include "glob.h"
Modified: grass/trunk/raster/r.cross/main.c
--- grass/trunk/raster/r.cross/main.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.cross/main.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -21,6 +21,7 @@
 #include <stdio.h>
 #include "glob.h"
 int nfiles;
Modified: grass/trunk/raster/r.cross/renumber.c
--- grass/trunk/raster/r.cross/renumber.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.cross/renumber.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include "glob.h"
Modified: grass/trunk/raster/r.distance/distance.c
--- grass/trunk/raster/r.distance/distance.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.distance/distance.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -16,6 +16,8 @@
 #include "defs.h"
 /* given two CatEdgeLists, find the cells which are closest
Modified: grass/trunk/raster/r.distance/edges.c
--- grass/trunk/raster/r.distance/edges.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.distance/edges.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -17,6 +17,9 @@
 #include <stdlib.h>
 #include "defs.h"
 void print_edge_info(struct Map *map)
Modified: grass/trunk/raster/r.distance/labels.c
--- grass/trunk/raster/r.distance/labels.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.distance/labels.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -17,6 +17,9 @@
 #include <stdlib.h>
 #include "defs.h"
 void read_labels(struct Map *map)
Modified: grass/trunk/raster/r.flow/io.c
--- grass/trunk/raster/r.flow/io.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.flow/io.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -27,6 +27,7 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include <unistd.h>
 #include "r.flow.h"
 #include "mem.h"
Modified: grass/trunk/raster/r.in.gridatb/adjcellhd.c
--- grass/trunk/raster/r.in.gridatb/adjcellhd.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.in.gridatb/adjcellhd.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,3 +1,5 @@
Modified: grass/trunk/raster/r.in.gridatb/main.c
--- grass/trunk/raster/r.in.gridatb/main.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.in.gridatb/main.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -19,6 +19,7 @@
 #include <grass/gis.h>
 struct Cell_head cellhd;
Modified: grass/trunk/raster/r.kappa/mask.c
--- grass/trunk/raster/r.kappa/mask.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.kappa/mask.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,6 +1,7 @@
 #include <string.h>
 #include "kappa.h"
Modified: grass/trunk/raster/r.kappa/prt_hdr.c
--- grass/trunk/raster/r.kappa/prt_hdr.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.kappa/prt_hdr.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,4 +1,5 @@
 #include <string.h>
 #include "kappa.h"
Modified: grass/trunk/raster/r.kappa/prt_label.c
--- grass/trunk/raster/r.kappa/prt_label.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.kappa/prt_label.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,3 +1,4 @@
 #include "kappa.h"
Modified: grass/trunk/raster/r.mapcalc/column_shift.c
--- grass/trunk/raster/r.mapcalc/column_shift.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/column_shift.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "expression.h"
 #include "globals.h"
Modified: grass/trunk/raster/r.mapcalc/map.c
--- grass/trunk/raster/r.mapcalc/map.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/map.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -11,6 +11,7 @@
 #include <grass/btree.h>
Modified: grass/trunk/raster/r.mapcalc/map3.c
--- grass/trunk/raster/r.mapcalc/map3.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/map3.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -6,6 +6,7 @@
 #include <grass/G3d.h>
Modified: grass/trunk/raster/r.mapcalc/xabs.c
--- grass/trunk/raster/r.mapcalc/xabs.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xabs.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <math.h>
 #include "func_proto.h"
Modified: grass/trunk/raster/r.mapcalc/xacos.c
--- grass/trunk/raster/r.mapcalc/xacos.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xacos.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -3,6 +3,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xadd.c
--- grass/trunk/raster/r.mapcalc/xadd.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xadd.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xand.c
--- grass/trunk/raster/r.mapcalc/xand.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xand.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xand2.c
--- grass/trunk/raster/r.mapcalc/xand2.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xand2.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xasin.c
--- grass/trunk/raster/r.mapcalc/xasin.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xasin.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -3,6 +3,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xatan.c
--- grass/trunk/raster/r.mapcalc/xatan.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xatan.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -3,6 +3,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xbitand.c
--- grass/trunk/raster/r.mapcalc/xbitand.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xbitand.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xbitnot.c
--- grass/trunk/raster/r.mapcalc/xbitnot.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xbitnot.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xbitor.c
--- grass/trunk/raster/r.mapcalc/xbitor.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xbitor.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xbitxor.c
--- grass/trunk/raster/r.mapcalc/xbitxor.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xbitxor.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xcoor.c
--- grass/trunk/raster/r.mapcalc/xcoor.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xcoor.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
 #include "globals2.h"
Modified: grass/trunk/raster/r.mapcalc/xcos.c
--- grass/trunk/raster/r.mapcalc/xcos.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xcos.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xdiv.c
--- grass/trunk/raster/r.mapcalc/xdiv.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xdiv.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xdouble.c
--- grass/trunk/raster/r.mapcalc/xdouble.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xdouble.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xeq.c
--- grass/trunk/raster/r.mapcalc/xeq.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xeq.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xeval.c
--- grass/trunk/raster/r.mapcalc/xeval.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xeval.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xexp.c
--- grass/trunk/raster/r.mapcalc/xexp.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xexp.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xfloat.c
--- grass/trunk/raster/r.mapcalc/xfloat.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xfloat.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xge.c
--- grass/trunk/raster/r.mapcalc/xge.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xge.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xgraph.c
--- grass/trunk/raster/r.mapcalc/xgraph.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xgraph.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xgt.c
--- grass/trunk/raster/r.mapcalc/xgt.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xgt.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xif.c
--- grass/trunk/raster/r.mapcalc/xif.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xif.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xint.c
--- grass/trunk/raster/r.mapcalc/xint.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xint.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xisnull.c
--- grass/trunk/raster/r.mapcalc/xisnull.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xisnull.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xle.c
--- grass/trunk/raster/r.mapcalc/xle.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xle.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xlog.c
--- grass/trunk/raster/r.mapcalc/xlog.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xlog.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xlt.c
--- grass/trunk/raster/r.mapcalc/xlt.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xlt.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xmax.c
--- grass/trunk/raster/r.mapcalc/xmax.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xmax.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmedian.c
--- grass/trunk/raster/r.mapcalc/xmedian.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xmedian.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -3,6 +3,7 @@
Modified: grass/trunk/raster/r.mapcalc/xmin.c
--- grass/trunk/raster/r.mapcalc/xmin.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xmin.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmod.c
--- grass/trunk/raster/r.mapcalc/xmod.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xmod.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xmode.c
--- grass/trunk/raster/r.mapcalc/xmode.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xmode.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmul.c
--- grass/trunk/raster/r.mapcalc/xmul.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xmul.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xne.c
--- grass/trunk/raster/r.mapcalc/xne.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xne.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xneg.c
--- grass/trunk/raster/r.mapcalc/xneg.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xneg.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xnot.c
--- grass/trunk/raster/r.mapcalc/xnot.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xnot.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xnull.c
--- grass/trunk/raster/r.mapcalc/xnull.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xnull.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xor.c
--- grass/trunk/raster/r.mapcalc/xor.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xor.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xor2.c
--- grass/trunk/raster/r.mapcalc/xor2.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xor2.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xpow.c
--- grass/trunk/raster/r.mapcalc/xpow.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xpow.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xres.c
--- grass/trunk/raster/r.mapcalc/xres.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xres.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xround.c
--- grass/trunk/raster/r.mapcalc/xround.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xround.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <limits.h>
Modified: grass/trunk/raster/r.mapcalc/xshiftl.c
--- grass/trunk/raster/r.mapcalc/xshiftl.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xshiftl.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xshiftr.c
--- grass/trunk/raster/r.mapcalc/xshiftr.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xshiftr.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xshiftru.c
--- grass/trunk/raster/r.mapcalc/xshiftru.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xshiftru.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xsin.c
--- grass/trunk/raster/r.mapcalc/xsin.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xsin.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xsqrt.c
--- grass/trunk/raster/r.mapcalc/xsqrt.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xsqrt.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -2,6 +2,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xsub.c
--- grass/trunk/raster/r.mapcalc/xsub.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xsub.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xtan.c
--- grass/trunk/raster/r.mapcalc/xtan.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mapcalc/xtan.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -3,6 +3,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mfilter/apply.c
--- grass/trunk/raster/r.mfilter/apply.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mfilter/apply.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,3 +1,4 @@
 #include "filter.h"
Modified: grass/trunk/raster/r.mfilter/execute.c
--- grass/trunk/raster/r.mfilter/execute.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mfilter/execute.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
 #include <unistd.h>
 #include <grass/rowio.h>
 #include "glob.h"
 #include "filter.h"
Modified: grass/trunk/raster/r.mfilter/perform.c
--- grass/trunk/raster/r.mfilter/perform.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.mfilter/perform.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,6 +1,7 @@
 #include <unistd.h>
 #include <fcntl.h>
 #include "glob.h"
 #include "filter.h"
Modified: grass/trunk/raster/r.out.gridatb/adjcellhd.c
--- grass/trunk/raster/r.out.gridatb/adjcellhd.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.out.gridatb/adjcellhd.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -5,7 +5,7 @@
     int retval = 0;
-    if (Rast_set_window(cellhd) < 0)
+    if (G_set_window(cellhd) < 0)
 	retval = 1;
     if (cellhd->rows != G_window_rows())
Modified: grass/trunk/raster/r.out.gridatb/file_io.c
--- grass/trunk/raster/r.out.gridatb/file_io.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.out.gridatb/file_io.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,4 +1,5 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.out.vrml/put_grid.c
--- grass/trunk/raster/r.out.vrml/put_grid.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.out.vrml/put_grid.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,3 +1,4 @@
 #include "pv.h"
Modified: grass/trunk/raster/r.param.scale/close_down.c
--- grass/trunk/raster/r.param.scale/close_down.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.param.scale/close_down.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -8,6 +8,7 @@
 #include <string.h>
 #include "param.h"
Modified: grass/trunk/raster/r.param.scale/write_cols.c
--- grass/trunk/raster/r.param.scale/write_cols.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.param.scale/write_cols.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -13,6 +13,7 @@
 #include "param.h"
Modified: grass/trunk/raster/r.quant/main.c
--- grass/trunk/raster/r.quant/main.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.quant/main.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -20,6 +20,7 @@
 #include <unistd.h>
 #include <string.h>
 #include "global.h"
 struct Quant quant_struct;
Modified: grass/trunk/raster/r.quant/read_rules.c
--- grass/trunk/raster/r.quant/read_rules.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.quant/read_rules.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,6 +1,7 @@
 #include <stdio.h>
 #include <unistd.h>
 #include <string.h>
 #include "global.h"
Modified: grass/trunk/raster/r.recode/read_rules.c
--- grass/trunk/raster/r.recode/read_rules.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.recode/read_rules.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,6 +1,7 @@
 #include <stdio.h>
 #include <unistd.h>
 #include <string.h>
 #include "global.h"
Modified: grass/trunk/raster/r.recode/recode.c
--- grass/trunk/raster/r.recode/recode.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.recode/recode.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,4 +1,5 @@
 #include <stdio.h>
 #include "global.h"
 #define F2I(map_type) \
Modified: grass/trunk/raster/r.report/header.c
--- grass/trunk/raster/r.report/header.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.report/header.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,4 +1,5 @@
 #include <string.h>
 #include "global.h"
 static int page = 0;
Modified: grass/trunk/raster/r.report/parse.c
--- grass/trunk/raster/r.report/parse.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.report/parse.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,6 +1,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <unistd.h>
 #include "global.h"
 int parse_command_line(int argc, char *argv[])
Modified: grass/trunk/raster/r.report/prt_report.c
--- grass/trunk/raster/r.report/prt_report.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.report/prt_report.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include <string.h>
 #include "global.h"
 int print_report(int unit1, int unit2)
Modified: grass/trunk/raster/r.report/stats.c
--- grass/trunk/raster/r.report/stats.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.report/stats.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,6 +1,7 @@
 #include <string.h>
 #include <unistd.h>
 #include <stdlib.h>
 #include "global.h"
 static int die(void);
Modified: grass/trunk/raster/r.stats/global.h
--- grass/trunk/raster/r.stats/global.h	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.stats/global.h	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,4 +1,5 @@
 extern char *no_data_str;
 extern int nfiles;
Modified: grass/trunk/raster/r.surf.contour/read_cell.c
--- grass/trunk/raster/r.surf.contour/read_cell.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.surf.contour/read_cell.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,4 +1,5 @@
 #include "contour.h"
 CELL **read_cell(const char *name, const char *mapset)
Modified: grass/trunk/raster/r.surf.fractal/write_rast.c
--- grass/trunk/raster/r.surf.fractal/write_rast.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.surf.fractal/write_rast.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -14,6 +14,7 @@
 #include "frac.h"
Modified: grass/trunk/raster/r.topmodel/global.h
--- grass/trunk/raster/r.topmodel/global.h	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.topmodel/global.h	2009-06-22 17:48:21 UTC (rev 38028)
@@ -5,8 +5,8 @@
 #include <math.h>
 #include <time.h>
 #define	FILL		0x1
 #define	DIR		0x2
 #define	BELEV		0x4
Modified: grass/trunk/raster/r.univar/globals.h
--- grass/trunk/raster/r.univar/globals.h	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.univar/globals.h	2009-06-22 17:48:21 UTC (rev 38028)
@@ -20,6 +20,7 @@
 #include <math.h>
 /*- Parameters and global variables -----------------------------------------*/
Modified: grass/trunk/raster/r.watershed/ram/Gwater.h
--- grass/trunk/raster/r.watershed/ram/Gwater.h	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.watershed/ram/Gwater.h	2009-06-22 17:48:21 UTC (rev 38028)
@@ -8,6 +8,7 @@
 /* last modified 03/26/91                       */
 #include <math.h>
 #include "ramseg.h"
 #include "flag.h"
Modified: grass/trunk/raster/r.watershed/seg/Gwater.h
--- grass/trunk/raster/r.watershed/seg/Gwater.h	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/raster/r.watershed/seg/Gwater.h	2009-06-22 17:48:21 UTC (rev 38028)
@@ -8,6 +8,7 @@
 #include <math.h>
 #include "cseg.h"
 #define AR_SIZE			16
Modified: grass/trunk/vector/v.to.rast/do_areas.c
--- grass/trunk/vector/v.to.rast/do_areas.c	2009-06-22 16:40:17 UTC (rev 38027)
+++ grass/trunk/vector/v.to.rast/do_areas.c	2009-06-22 17:48:21 UTC (rev 38028)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
