[GRASS-SVN] r38044 - in grass/trunk/scripts: . db.dropcolumn
db.in.ogr
svn_grass at osgeo.org
Tue Jun 23 10:35:40 EDT 2009
Author: martinl
Date: 2009-06-23 10:35:39 -0400 (Tue, 23 Jun 2009)
New Revision: 38044
Added:
grass/trunk/scripts/db.dropcolumn/db.dropcolumn.html
grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
Removed:
grass/trunk/scripts/db.dropcolumn/db.dropcol.html
grass/trunk/scripts/db.dropcolumn/db.dropcol.py
grass/trunk/scripts/Makefile
grass/trunk/scripts/db.dropcolumn/Makefile
grass/trunk/scripts/db.in.ogr/db.in.ogr.py
db.dropcol renamed to db.dropcolumn (module)
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile 2009-06-23 14:14:07 UTC (rev 38043)
+++ grass/trunk/scripts/Makefile 2009-06-23 14:35:39 UTC (rev 38044)
@@ -6,7 +6,7 @@
d.rast.edit \
d.rast.leg \
d.shadedmap \
- db.dropcol \
+ db.dropcolumn \
db.droptable \
db.in.ogr \
db.out.ogr \
Modified: grass/trunk/scripts/db.dropcolumn/Makefile
--- grass/trunk/scripts/db.dropcolumn/Makefile 2009-06-23 14:14:07 UTC (rev 38043)
+++ grass/trunk/scripts/db.dropcolumn/Makefile 2009-06-23 14:35:39 UTC (rev 38044)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM = db.dropcol
+PGM = db.dropcolumn
include $(MODULE_TOPDIR)/include/Make/Script.make
Deleted: grass/trunk/scripts/db.dropcolumn/db.dropcol.html
--- grass/trunk/scripts/db.dropcolumn/db.dropcol.html 2009-06-23 14:14:07 UTC (rev 38043)
+++ grass/trunk/scripts/db.dropcolumn/db.dropcol.html 2009-06-23 14:35:39 UTC (rev 38044)
@@ -1,42 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>db.dropcol</em> drops a column from an attribute table.
-If the <b>-f</b> force flag is not given then nothing is removed, instead
-a preview of the action to be taken is printed.
-<h2>NOTES</h2>
-<em>db.dropcol</em> is a front-end to <em>db.execute</em> to allow easier
-usage with a special workaround for the SQLite driver to support column
-drop.
-<h2>EXAMPLES</h2>
-Dropping a column (Spearfish):
-<p>
-<div class="code"><pre>
-# work on own copy
-g.copy vect=roads,myroads
-db.describe -c myroads
-# only shows what would happen:
-db.dropcol myroads column=label
-# actually drops the column
-db.dropcol -f myroads column=label
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a HREF="db.droptable.html">db.droptable</a></em>,
-<em><a HREF="db.execute.html">db.execute</a></em>,
-<em><a HREF="v.db.dropcol.html">v.db.dropcol</a></em>
-<h2>AUTHOR</h2>
-Markus Neteler
-<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/scripts/db.dropcolumn/db.dropcol.py
--- grass/trunk/scripts/db.dropcolumn/db.dropcol.py 2009-06-23 14:14:07 UTC (rev 38043)
+++ grass/trunk/scripts/db.dropcolumn/db.dropcol.py 2009-06-23 14:35:39 UTC (rev 38044)
@@ -1,116 +0,0 @@
-#!/usr/bin/env python
-# MODULE: db.dropcolumn
-# AUTHOR(S): Markus Neteler
-# Converted to Python by Glynn Clements
-# PURPOSE: interface to db.execute to drop a column from an
-# attribute table
-# - with special trick for SQLite
-# COPYRIGHT: (C) 2007 by Markus Neteler and the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%Module
-#% description: Drops a column from selected attribute table
-#% keywords: database, attribute table
-#%End
-#%flag
-#% key: f
-#% description: Force removal (required for actual deletion of files)
-#%end
-#%option
-#% key: table
-#% type: string
-#% key_desc : name
-#% description: Table from which to drop attribute column
-#% required : yes
-#% gisprompt: old,dbtable,dbtable
-#%end
-#%option
-#% key: column
-#% type: string
-#% description: Name of the column
-#% required : yes
-#% gisprompt: old,dbcolumn,dbcolumn
-#%end
-import sys
-import os
-import string
-import grass.script as grass
-def main():
- table = options['table']
- column = options['column']
- force = flags['f']
- # check if DB parameters are set, and if not set them.
- grass.run_command('db.connect', flags = 'c')
- kv = grass.db_connection()
- database = kv['database']
- driver = kv['driver']
- # schema needed for PG?
- if force:
- grass.message("Forcing ...")
- if column == "cat":
- grass.warning("Deleting <%s> column which may be needed to keep table connected to a vector map" % column)
- cols = [f[0] for f in grass.db_describe()['cols']]
- if column not in cols:
- grass.fatal("Column <%s> not found in table" % column)
- if not force:
- grass.message("Column <%s> would be deleted." % column)
- grass.message("")
- grass.message("You must use the force flag to actually remove it. Exiting.")
- sys.exit(0)
- if driver == "sqlite":
- #echo "Using special trick for SQLite"
- # http://www.sqlite.org/faq.html#q13
- colnames = []
- coltypes = []
- for f in grass.db_describe()['cols']:
- if f[0] == column:
- continue
- colnames.append(f[0])
- coltypes.append("%s %s" % (f[0], f[1]))
- colnames = ", ".join(colnames)
- coltypes = ", ".join(coltypes)
- cmds = [
- "BEGIN TRANSACTION",
- "CREATE TEMPORARY TABLE ${table}_backup(${coldef})",
- "INSERT INTO ${table}_backup SELECT ${colnames} FROM ${table}",
- "DROP TABLE ${table}",
- "CREATE TABLE ${table}(${coldef})",
- "INSERT INTO ${table} SELECT ${colnames} FROM ${table}_backup",
- "DROP TABLE ${table}_backup",
- "COMMIT"
- tmpl = string.Template(';\n'.join(cmds))
- sql = tmpl.substitute(table = table, coldef = coltypes, colnames = colnames)
- else:
- sql = "ALTER TABLE %s DROP COLUMN %s" % (table, column)
- if grass.write_command('db.execute', database = database, driver = driver,
- stdin = sql) != 0:
- grass.fatal("Cannot continue (problem deleting column).")
-if __name__ == "__main__":
- options, flags = grass.parser()
- main()
Copied: grass/trunk/scripts/db.dropcolumn/db.dropcolumn.html (from rev 38043, grass/trunk/scripts/db.dropcolumn/db.dropcol.html)
--- grass/trunk/scripts/db.dropcolumn/db.dropcolumn.html (rev 0)
+++ grass/trunk/scripts/db.dropcolumn/db.dropcolumn.html 2009-06-23 14:35:39 UTC (rev 38044)
@@ -0,0 +1,42 @@
+<h2>DESCRIPTION</h2>
+<em>db.dropcolumn</em> drops a column from an attribute table.
+If the <b>-f</b> force flag is not given then nothing is removed, instead
+a preview of the action to be taken is printed.
+<h2>NOTES</h2>
+<em>db.dropcolumn</em> is a front-end to <em>db.execute</em> to allow easier
+usage with a special workaround for the SQLite driver to support column
+drop.
+<h2>EXAMPLES</h2>
+Dropping a column (Spearfish):
+<p>
+<div class="code"><pre>
+# work on own copy
+g.copy vect=roads,myroads
+db.describe -c myroads
+# only shows what would happen:
+db.dropcolumn myroads column=label
+# actually drops the column
+db.dropcolumn -f myroads column=label
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a HREF="db.droptable.html">db.droptable</a></em>,
+<em><a HREF="db.execute.html">db.execute</a></em>,
+<em><a HREF="v.db.dropcol.html">v.db.dropcol</a></em>
+<h2>AUTHOR</h2>
+Markus Neteler
+<p><i>Last changed: $Date$</i>
Copied: grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py (from rev 38043, grass/trunk/scripts/db.dropcolumn/db.dropcol.py)
--- grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py (rev 0)
+++ grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py 2009-06-23 14:35:39 UTC (rev 38044)
@@ -0,0 +1,116 @@
+#!/usr/bin/env python
+# MODULE: db.dropcolumn
+# AUTHOR(S): Markus Neteler
+# Converted to Python by Glynn Clements
+# PURPOSE: interface to db.execute to drop a column from an
+# attribute table
+# - with special trick for SQLite
+# COPYRIGHT: (C) 2007 by Markus Neteler and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Drops a column from selected attribute table
+#% keywords: database, attribute table
+#%End
+#%flag
+#% key: f
+#% description: Force removal (required for actual deletion of files)
+#%end
+#%option
+#% key: table
+#% type: string
+#% key_desc : name
+#% description: Table from which to drop attribute column
+#% required : yes
+#% gisprompt: old,dbtable,dbtable
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Name of the column
+#% required : yes
+#% gisprompt: old,dbcolumn,dbcolumn
+#%end
+import sys
+import os
+import string
+import grass.script as grass
+def main():
+ table = options['table']
+ column = options['column']
+ force = flags['f']
+ # check if DB parameters are set, and if not set them.
+ grass.run_command('db.connect', flags = 'c')
+ kv = grass.db_connection()
+ database = kv['database']
+ driver = kv['driver']
+ # schema needed for PG?
+ if force:
+ grass.message("Forcing ...")
+ if column == "cat":
+ grass.warning("Deleting <%s> column which may be needed to keep table connected to a vector map" % column)
+ cols = [f[0] for f in grass.db_describe()['cols']]
+ if column not in cols:
+ grass.fatal("Column <%s> not found in table" % column)
+ if not force:
+ grass.message("Column <%s> would be deleted." % column)
+ grass.message("")
+ grass.message("You must use the force flag to actually remove it. Exiting.")
+ sys.exit(0)
+ if driver == "sqlite":
+ #echo "Using special trick for SQLite"
+ # http://www.sqlite.org/faq.html#q13
+ colnames = []
+ coltypes = []
+ for f in grass.db_describe()['cols']:
+ if f[0] == column:
+ continue
+ colnames.append(f[0])
+ coltypes.append("%s %s" % (f[0], f[1]))
+ colnames = ", ".join(colnames)
+ coltypes = ", ".join(coltypes)
+ cmds = [
+ "BEGIN TRANSACTION",
+ "CREATE TEMPORARY TABLE ${table}_backup(${coldef})",
+ "INSERT INTO ${table}_backup SELECT ${colnames} FROM ${table}",
+ "DROP TABLE ${table}",
+ "CREATE TABLE ${table}(${coldef})",
+ "INSERT INTO ${table} SELECT ${colnames} FROM ${table}_backup",
+ "DROP TABLE ${table}_backup",
+ "COMMIT"
+ tmpl = string.Template(';\n'.join(cmds))
+ sql = tmpl.substitute(table = table, coldef = coltypes, colnames = colnames)
+ else:
+ sql = "ALTER TABLE %s DROP COLUMN %s" % (table, column)
+ if grass.write_command('db.execute', database = database, driver = driver,
+ stdin = sql) != 0:
+ grass.fatal("Cannot continue (problem deleting column).")
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2009-06-23 14:14:07 UTC (rev 38043)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2009-06-23 14:35:39 UTC (rev 38044)
@@ -110,7 +110,7 @@
grass.try_remove(vectfile)
# get rid of superfluous auto-added cat column (and cat_ if present)
- grass.run_command('db.dropcol', quiet = True, flags = 'f', table = output,
+ grass.run_command('db.dropcolumn', quiet = True, flags = 'f', table = output,
colum = 'cat', stdout = nuldev, stderr = nuldev)
records = grass.db_describe(output)['nrows']
