[GRASS-SVN] r38045 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Tue Jun 23 11:42:43 EDT 2009
Author: aghisla
Date: 2009-06-23 11:42:43 -0400 (Tue, 23 Jun 2009)
New Revision: 38045
grass-addons/vector/v.krige/v.krige.py
code preparation for I18N
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-06-23 14:35:39 UTC (rev 38044)
+++ grass-addons/vector/v.krige/v.krige.py 2009-06-23 15:42:43 UTC (rev 38045)
@@ -44,7 +44,9 @@
# For the moment, deps are checked when creating the notebook pages for each package, and the
# data availability when clicking Run button. Quite late.
-#$TODO(anne): add gettext
+### i18N
+import gettext
+gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
#global variables
gisenv = grass.gisenv()
@@ -60,19 +62,19 @@
self.border = 5
# 1. Input data
- InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label='Input Data'),
+ InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Input Data")),
orient=wx.HORIZONTAL)
flexSizer = wx.FlexGridSizer(cols=2, hgap=5, vgap=5)
flexSizer.AddGrowableCol(1)
- flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label="Point dataset:"),
+ flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Point dataset:")),
flag = wx.ALIGN_CENTER_VERTICAL)
self.InputDataMap = gselect.VectorSelect(parent = self,
ftype = 'point')
flexSizer.Add(item = self.InputDataMap)
- flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label="Column:"),
+ flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Column:")),
flag=wx.ALIGN_CENTER_VERTICAL)
self.InputDataColumn = gselect.ColumnSelect(self, id=wx.ID_ANY)
flexSizer.Add(item = self.InputDataColumn)
@@ -82,7 +84,7 @@
InputBoxSizer.Add(item = flexSizer)
# 2. Kriging. In book pages one for each R package. Includes variogram fit.
- KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label='Kriging'), wx.HORIZONTAL)
+ KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Kriging")), wx.HORIZONTAL)
self.RPackagesBook = FN.FlatNotebook(parent=self, id=wx.ID_ANY,
style=FN.FNB_BOTTOM |
@@ -96,8 +98,8 @@
#@TODO(anne): check this dependency at the beginning.
if self.RPackagesBook.GetPageCount() == 0:
wx.MessageBox(parent=self,
- message=("No R package with kriging functions available. Install either automap, gstat or geoR."),
- caption=("Missing Dependency"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ message=_("No R package with kriging functions available. Install either automap, gstat or geoR."),
+ caption=_("Missing Dependency"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
self.RPackagesBook.SetSelection(0)
KrigingSizer.Add(self.RPackagesBook, proportion=1, flag=wx.EXPAND)
@@ -106,7 +108,7 @@
ButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
QuitButton = wx.Button(self, id=wx.ID_EXIT)
QuitButton.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
- RunButton = wx.Button(self, id=wx.ID_ANY, label='Run') # no stock ID for Run button..
+ RunButton = wx.Button(self, id=wx.ID_ANY, label=_("Run")) # no stock ID for Run button..
RunButton.Bind(wx.EVT_BUTTON, self.OnRunButton)
ButtonSizer.Add(QuitButton, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
ButtonSizer.Add(RunButton, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
@@ -165,12 +167,12 @@
self.Column = self.InputDataColumn.GetValue()
#@TODO(anne): pick up parameters if user chooses to set variogram parameters.
#3. Fit variogram
- self.parent.log.write('Variogram fitting')
+ self.parent.log.write(_("Variogram fitting"))
self.Formula = robjects.r['as.formula'](robjects.r.paste(self.Column, "~ 1"))
Variogram = self.SelectedPanel.FitVariogram(self.Formula, self.InputData)
# print variogram?
# robjects.r.plot(Variogram.r['exp_var'], Variogram.r['var_model'])
- self.parent.log.write('Variogram fitted.')
+ self.parent.log.write(_("Variogram fitted."))
#4. Kriging
# self.parent.log.write('Kriging...')
@@ -191,10 +193,10 @@
def __init__(self, parent, *args, **kwargs):
wx.Frame.__init__(self, parent, *args, **kwargs)
# setting properties and all widgettery
- self.SetTitle("Kriging Module")
+ self.SetTitle(_("Kriging Module"))
self.log = Log(self) # writes on statusbar
self.CreateStatusBar()
- self.log.write("Ready.")
+ self.log.write(_("Ready."))
self.Panel = KrigingPanel(self)
# size. It is the minimum size. No way to get it in a single command.
@@ -218,14 +220,14 @@
# unlock options as soon as they are available. Stone soup!
VariogramSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY,
- label='Variogram fitting'), wx.VERTICAL)
- VariogramCheckBox = wx.CheckBox(self, id=wx.ID_ANY, label="Auto-fit variogram")
+ label=_("Variogram fitting")), wx.VERTICAL)
+ VariogramCheckBox = wx.CheckBox(self, id=wx.ID_ANY, label=_("Auto-fit variogram"))
VariogramCheckBox.SetValue(state = True) # check it by default
ParametersSizer = wx.FlexGridSizer(cols=3, hgap=5, vgap=5)
for n in ["Sill", "Nugget", "Range"]:
setattr(self, n+"Sizer", (wx.BoxSizer(wx.HORIZONTAL)))
- setattr(self, n+"Text", (wx.StaticText(self, id= wx.ID_ANY, label = n)))
+ setattr(self, n+"Text", (wx.StaticText(self, id= wx.ID_ANY, label = _(n))))
setattr(self, n+"Ctrl", (wx.SpinCtrl(self, id = wx.ID_ANY, max=sys.maxint)))
a = getattr(self, n+"Sizer")
a.Add(getattr(self, n+"Text"), proportion=0, flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER | wx.ALL, border=3)
@@ -237,8 +239,8 @@
#@TODO(anne); hides Parameters when Autofit variogram is selected
# VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
- self.KrigingList = ["Ordinary kriging", "Universal Kriging", "Block kriging"]
- KrigingRadioBox = wx.RadioBox(self, id=wx.ID_ANY, label="Kriging techniques",
+ self.KrigingList = ["Ordinary kriging", "Universal Kriging", "Block kriging"] #@FIXME: i18n on the list?
+ KrigingRadioBox = wx.RadioBox(self, id=wx.ID_ANY, label=_("Kriging techniques"),
pos=wx.DefaultPosition, size=wx.DefaultSize,
choices=self.KrigingList, majorDimension=1, style=wx.RA_SPECIFY_COLS)
