[GRASS-SVN] r38050 - grass/branches/releasebranch_6_4/lib/python
svn_grass at osgeo.org
Wed Jun 24 08:06:47 EDT 2009
Author: martinl
Date: 2009-06-24 08:06:46 -0400 (Wed, 24 Jun 2009)
New Revision: 38050
Removed:
grass/branches/releasebranch_6_4/lib/python/README.txt
out-dated python readme removed
Deleted: grass/branches/releasebranch_6_4/lib/python/README.txt
--- grass/branches/releasebranch_6_4/lib/python/README.txt 2009-06-24 12:06:07 UTC (rev 38049)
+++ grass/branches/releasebranch_6_4/lib/python/README.txt 2009-06-24 12:06:46 UTC (rev 38050)
@@ -1,217 +0,0 @@
-GRASS scripting tasks for Python provided by "grass.py".
-Usage: "import grass"
-def make_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **options):
-Return a list of strings suitable for use as the args parameter to
-Popen() or call(). Example:
->>> grass.make_command("g.message", flags = 'w', message = 'this is a warning')
-['g.message', '-w', 'message=this is a warning']
-def start_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **kwargs):
-Returns a Popen object with the command created by make_command.
-Accepts any of the arguments which Popen() accepts apart from "args"
-and "shell". Example:
->>> p = grass.start_command("g.gisenv", stdout = subprocess.PIPE)
->>> print p
-<subprocess.Popen object at 0xb7c12f6c>
->>> print p.communicate()[0]
-GISDBASE='/opt/grass-data';
-LOCATION_NAME='spearfish60';
-MAPSET='glynn';
-GRASS_DB_ENCODING='ascii';
-GRASS_GUI='text';
-MONITOR='x0';
-def pipe_command(*args, **kwargs):
-Passes all arguments to start_command, but also adds
-"stdout = subprocess.PIPE". Returns the Popen object. Example:
->>> p = grass.pipe_command("g.gisenv")
->>> print p
-MAPSET='glynn';
-GRASS_GUI='text';
-MONITOR='x0';
-def run_command(*args, **kwargs):
-Passes all arguments to start_command, then waits for the process to
-complete, returning its exit code. Similar to subprocess.call(), but
-with the make_command() interface.
-def read_command(*args, **kwargs):
-complete, returning its stdout (i.e. similar to shell "backticks").
-def message(msg, flag = None):
-def debug(msg):
-def verbose(msg):
-def info(msg):
-def warning(msg):
-def error(msg):
-These all run g.message, differing only in which flag (if any) is used.
-def fatal(msg):
-Like error(), but also calls sys.exit(1).
-def parser():
-Interface to g.parser, intended to be run from the top-level, e.g.:
- if __name__ == "__main__":
- options, flags = grass.parser()
- main()
-Thereafter, the global variables "options" and "flags" will be
-dictionaries containing option/flag values, keyed by lower-case
-option/flag names. The values in "options" are strings, those in
-"flags" are Python booleans.
-def tempfile():
-Returns the name of a temporary file, created with g.tempfile.
-def gisenv():
-Returns the output from running g.gisenv (with no arguments), as a
-dictionary. Example:
->>> env = grass.gisenv()
->>> print env['GISDBASE']
-/opt/grass-data
-def region():
-Returns the output from running "g.region -g", as a dictionary.
-Example:
->>> region = grass.region()
->>> [region[key] for key in "nsew"]
-['4928000', '4914020', '609000', '590010']
->>> (region['nsres'], region['ewres'])
-('30', '30')
-def use_temp_region():
-Copies the current region to a temporary region with "g.region save=",
-then sets WIND_OVERRIDE to refer to that region. Installs an atexit
-handler to delete the temporary region upon termination.
-def del_temp_region():
-Unsets WIND_OVERRIDE and removes any region named by it.
-def find_file(name, element = 'cell'):
-Returns the output from running g.findfile as a dictionary. Example:
->>> result = grass.find_file('fields', element = 'vector')
->>> print result['fullname']
-fields at PERMANENT
->>> print result['file']
-/opt/grass-data/spearfish60/PERMANENT/vector/fields
-def list_grouped(type):
-Returns the output from running g.list, as a dictionary where the keys
-are mapset names and the values are lists of maps in that mapset.
-Example:
->>> grass.list_grouped('rast')['PERMANENT']
-['aspect', 'erosion1', 'quads', 'soils', 'strm.dist', ...
-def list_pairs(type):
-Returns the output from running g.list, as a list of (map, mapset)
-pairs. Example:
->>> grass.list_pairs('rast')
-[('aspect', 'PERMANENT'), ('erosion1', 'PERMANENT'), ('quads', 'PERMANENT'), ...
-def list_strings(type):
-Returns the output from running g.list, as a list of qualified names.
-Example:
->>> grass.list_strings('rast')
-['aspect at PERMANENT', 'erosion1 at PERMANENT', 'quads at PERMANENT', 'soils at PERMANENT', ...
-def parse_color(val, dflt = None):
-Parses the string "val" as a GRASS colour, which can be either one of
-the named colours or an R:G:B tuple e.g. 255:255:255. Returns an
-(r,g,b) triple whose components are floating point values between 0
-and 1. Example:
->>> grass.parse_color("red")
-(1.0, 0.0, 0.0)
->>> grass.parse_color("255:0:0")
-(1.0, 0.0, 0.0)
