[GRASS-SVN] r38051 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Jun 24 08:10:18 EDT 2009
Author: martinl
Date: 2009-06-24 08:10:18 -0400 (Wed, 24 Jun 2009)
New Revision: 38051
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
fix VectorSelect filter
(merge from trunk, r38048)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2009-06-24 12:06:46 UTC (rev 38050)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2009-06-24 12:10:18 UTC (rev 38051)
@@ -1,4 +1,4 @@
@package gselect
@brief Custom control that selects elements
@@ -36,7 +36,8 @@
class Select(wx.combo.ComboCtrl):
def __init__(self, parent, id, size = globalvar.DIALOG_GSELECT_SIZE,
- type=None, multiple=False, mapsets=None, exceptOf=[]):
+ type = None, multiple = False, mapsets = None, exclude = [],
+ updateOnPopup = True):
"""!Custom control to create a ComboBox with a tree control
to display and select GIS elements within acessible mapsets.
Elements can be selected with mouse. Can allow multiple selections, when
@@ -52,17 +53,23 @@
self.SetPopupExtents(0,100)
if type:
self.tcp.SetData(type = type, mapsets = mapsets,
- exceptOf = exceptOf, multiple = multiple)
+ exclude = exclude, multiple = multiple,
+ updateOnPopup = updateOnPopup)
- def SetElementList(self, type, mapsets = None, exceptOf = []):
+ def SetElementList(self, type, mapsets = None, exclude = []):
"""!Set element list
@param type GIS element type
@param mapsets list of acceptable mapsets (None for all in search path)
- @param exceptOf list of GIS elements to be excluded"""
+ @param exclude list of GIS elements to be excluded
- exceptOf = exceptOf)
+ exclude = exclude)
+ def GetElementList(self):
+ """!Load elements"""
+ self.tcp.GetElementList()
class VectorSelect(Select):
def __init__(self, parent, ftype, **kwargs):
"""!Custom to create a ComboBox with a tree control to display and
@@ -74,6 +81,8 @@
Select.__init__(self, parent = parent, id = wx.ID_ANY,
type = 'vector', **kwargs)
+ self.ftype = ftype
# remove vector maps which do not contain given feature type
self.tcp.SetFilter(self.__filterElements)
@@ -86,7 +95,8 @@
# skip Mapset items
vectorName = self.tcp.seltree.GetItemText(item)
try:
- if int(grass.vector_info_topo(vectorName)['points']) < 1:
+ print vectorName, int(grass.vector_info_topo(vectorName)[self.ftype])
+ if int(grass.vector_info_topo(vectorName)[self.ftype]) < 1:
self.tcp.seltree.Delete(item)
except KeyError:
@@ -111,7 +121,7 @@
self.multiple = False
self.type = None
self.mapsets = []
- self.exceptOf = []
+ self.exclude = []
self.SetFilter(None)
@@ -160,11 +170,21 @@
"""!Set filter for GIS elements, see e.g. VectorSelect"""
self.filterElements = filter
- def OnPopup(self):
+ def OnPopup(self, force = False):
"""!Limited only for first selected"""
+ if not force and not self.updateOnPopup:
+ return
+ self.GetElementList()
+ """!Get filtered list of GIS elements in accessible mapsets
+ and display as tree with all relevant elements displayed
+ beneath each mapset branch
# update list
self.seltree.DeleteAllItems()
- self.GetElementList(self.type, self.mapsets, self.exceptOf)
+ self._getElementList(self.type, self.mapsets, self.exclude)
if self.filterElements:
self.filterElements(self.seltree.GetRootItem())
@@ -192,13 +212,13 @@
def GetAdjustedSize(self, minWidth, prefHeight, maxHeight):
return wx.Size(minWidth, min(200, maxHeight))
- def GetElementList(self, element, mapsets=None, exceptOf=[]):
+ def _getElementList(self, element, mapsets=None, exclude=[]):
"""!Get list of GIS elements in accessible mapsets and display as tree
with all relevant elements displayed beneath each mapset branch
@param element GIS element
@param mapsets list of acceptable mapsets (None for all mapsets in search path)
# get current mapset
curr_mapset = grass.gisenv()['MAPSET']
@@ -282,7 +302,7 @@
for elem in elem_list:
if elem != '':
fullqElem = elem + '@' + dir
- if len(exceptOf) > 0 and fullqElem in exceptOf:
+ if len(exclude) > 0 and fullqElem in exclude:
continue
self.AddItem(fullqElem, parent=dir_node)
except:
@@ -371,10 +391,12 @@
self.type = kargs['type']
if kargs.has_key('mapsets'):
self.mapsets = kargs['mapsets']
- if kargs.has_key('exceptOf'):
- self.exceptOf = kargs['exceptOf']
+ if kargs.has_key('exclude'):
+ self.exclude = kargs['exclude']
if kargs.has_key('multiple'):
self.multiple = kargs['multiple']
+ if kargs.has_key('updateOnPopup'):
+ self.updateOnPopup = kargs['updateOnPopup']
class VectorDBInfo:
"""!Class providing information about attribute tables
@@ -460,7 +482,7 @@
@param layer vector layer number
- return self.layers[layer]['key']
+ return str(self.layers[layer]['key'])
def GetTable(self, layer):
"""!Get table name of given layer
