[GRASS-SVN] r38096 - in grass/trunk: gui/wxpython/docs
gui/wxpython/gui_modules gui/wxpython/xml
raster/r.watershed/front scripts scripts/v.db.renamecol
scripts/v.out.gps vector
svn_grass at osgeo.org
Sat Jun 27 07:02:00 EDT 2009
Author: martinl
Date: 2009-06-27 07:02:00 -0400 (Sat, 27 Jun 2009)
New Revision: 38096
grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/xml/menudata.xml
grass/trunk/raster/r.watershed/front/r.watershed.html
grass/trunk/scripts/Makefile
grass/trunk/scripts/v.db.renamecol/Makefile
grass/trunk/scripts/v.db.renamecol/v.db.renamecol.html
grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py
grass/trunk/scripts/v.out.gps/v.out.gps.html
grass/trunk/vector/vectorintro.html
v.db.renamecol renamed to v.db.renamecolumn (part 1)
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html 2009-06-27 10:57:45 UTC (rev 38095)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html 2009-06-27 11:02:00 UTC (rev 38096)
@@ -31,7 +31,7 @@
<a href="v.db.addcol.html">v.db.addcol</a>,
<a href="v.db.connect.html">v.db.connect</a>,
<a href="v.db.dropcolumn.html">v.db.dropcolumn</a>,
- <a href="v.db.renamecol.html">v.db.renamecol</a>,
+ <a href="v.db.renamecolumn.html">v.db.renamecolumn</a>,
<a href="v.what.html">v.what</a>
</em>
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2009-06-27 10:57:45 UTC (rev 38095)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2009-06-27 11:02:00 UTC (rev 38096)
@@ -1494,7 +1494,7 @@
else:
list.SetItemText(item, nameTo)
- self.listOfCommands.append(('v.db.renamecol',
+ self.listOfCommands.append(('v.db.renamecolumn',
{ 'map' : self.vectorName,
'layer' : self.layer,
'column' : '%s,%s' % (name, nameTo) }
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2009-06-27 10:57:45 UTC (rev 38095)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2009-06-27 11:02:00 UTC (rev 38096)
@@ -2626,7 +2626,7 @@
<help>Renames a column in the attribute table connected to a given vector map.</help>
<keywords>vector,database,attribute table</keywords>
<handler>self.OnMenuCmd</handler>
- <command>v.db.renamecol</command>
+ <command>v.db.renamecolumn</command>
</menuitem>
<separator />
<menuitem>
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html 2009-06-27 10:57:45 UTC (rev 38095)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html 2009-06-27 11:02:00 UTC (rev 38096)
@@ -413,7 +413,7 @@
r.watershed elev=elevation.dem basin=rwater.basin thresh=15000
r.to.vect -s in=rwater.basin out=rwater_basins feature=area
v.db.dropcolumn map=rwater_basins column=label
- v.db.renamecol map=rwater_basins column=value,catchment
+ v.db.renamecolumn map=rwater_basins column=value,catchment
</pre></div>
<br>
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile 2009-06-27 10:57:45 UTC (rev 38095)
+++ grass/trunk/scripts/Makefile 2009-06-27 11:02:00 UTC (rev 38096)
@@ -44,7 +44,7 @@
v.db.join \
v.db.dropcolumn \
v.db.droptable \
- v.db.renamecol \
+ v.db.renamecolumn \
v.db.reconnect.all \
v.db.univar \
v.db.update \
Modified: grass/trunk/scripts/v.db.renamecol/Makefile
--- grass/trunk/scripts/v.db.renamecol/Makefile 2009-06-27 10:57:45 UTC (rev 38095)
+++ grass/trunk/scripts/v.db.renamecol/Makefile 2009-06-27 11:02:00 UTC (rev 38096)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM = v.db.renamecol
+PGM = v.db.renamecolumn
include $(MODULE_TOPDIR)/include/Make/Script.make
Modified: grass/trunk/scripts/v.db.renamecol/v.db.renamecol.html
--- grass/trunk/scripts/v.db.renamecol/v.db.renamecol.html 2009-06-27 10:57:45 UTC (rev 38095)
+++ grass/trunk/scripts/v.db.renamecol/v.db.renamecol.html 2009-06-27 11:02:00 UTC (rev 38096)
@@ -1,6 +1,6 @@
<h2>DESCRIPTION</h2>
-<em>v.db.renamecol</em> renames a column in the attribute table connected
+<em>v.db.renamecolumn</em> renames a column in the attribute table connected
to a given vector map. It automatically checks the connection for the specified
layer.
@@ -27,7 +27,7 @@
Renaming a column:<br>
<div class="code"><pre>
v.info -c myroads
-v.db.renamecol myroads column=label,roadtype
+v.db.renamecolumn myroads column=label,roadtype
v.info -c myroads
</pre></div>
Modified: grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py
--- grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py 2009-06-27 10:57:45 UTC (rev 38095)
+++ grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py 2009-06-27 11:02:00 UTC (rev 38096)
@@ -2,7 +2,7 @@
-# MODULE: v.db.renamecol
+# MODULE: v.db.renamecolumn
# AUTHOR(S): Markus Neteler
# Converted to Python by Glynn Clements
# PURPOSE: interface to db.execute to drop a column from the
Modified: grass/trunk/scripts/v.out.gps/v.out.gps.html
--- grass/trunk/scripts/v.out.gps/v.out.gps.html 2009-06-27 10:57:45 UTC (rev 38095)
+++ grass/trunk/scripts/v.out.gps/v.out.gps.html 2009-06-27 11:02:00 UTC (rev 38096)
@@ -25,7 +25,7 @@
attribute will be placed within the <tt><extensions></tt> metadata
section of the record. Not all fields names are used with all feature
types (e.g. DOP fix error is not meaningful for route lines). You can
-use the <em>v.db.renamecol</em> module to rename columns.
+use the <em>v.db.renamecolumn</em> module to rename columns.
<P>
These are the standard GPX data fields known to OGR:
@@ -87,7 +87,7 @@
<A HREF="v.out.ascii.html">v.out.ascii</A><BR>
<A HREF="v.in.garmin.html">v.in.garmin</A><BR>
<A HREF="v.in.gpsbabel.html">v.in.gpsbabel</A><BR>
-<A HREF="v.db.renamecol.html">v.db.renamecol</A><BR>
+<A HREF="v.db.renamecolumn.html">v.db.renamecolumn</A><BR>
<A HREF="v.extract.html">v.extract</A>
</EM>
<BR>
Modified: grass/trunk/vector/vectorintro.html
--- grass/trunk/vector/vectorintro.html 2009-06-27 10:57:45 UTC (rev 38095)
+++ grass/trunk/vector/vectorintro.html 2009-06-27 11:02:00 UTC (rev 38096)
@@ -199,7 +199,7 @@
along with the definition of table column types. Column adding and dropping
can be done with <a HREF="v.db.addcol.html">v.db.addcol</a> and
<a HREF="v.db.dropcolumn.html">v.db.dropcolumn</a>. A table column can be renamed with
-<a HREF="v.db.renamecol.html">v.db.renamecol</a>. To drop a table from a map, use
+<a HREF="v.db.renamecolumn.html">v.db.renamecolumn</a>. To drop a table from a map, use
<a HREF="v.db.droptable.html">v.db.droptable</a>. Values in a table can be updated
with <a HREF="v.db.update.html">v.db.update</a>. Tables can be joined with with
<a HREF="v.db.join.html">v.db.join</a>.
