[GRASS-SVN] r38097 - in grass/trunk/scripts: . v.db.renamecolumn
svn_grass at osgeo.org
Sat Jun 27 07:03:25 EDT 2009
Author: martinl
Date: 2009-06-27 07:03:25 -0400 (Sat, 27 Jun 2009)
New Revision: 38097
Added:
grass/trunk/scripts/v.db.renamecolumn/
grass/trunk/scripts/v.db.renamecolumn/Makefile
grass/trunk/scripts/v.db.renamecolumn/v.db.renamecol.html
grass/trunk/scripts/v.db.renamecolumn/v.db.renamecol.py
Removed:
grass/trunk/scripts/v.db.renamecol/
v.db.renamecol renamed to v.db.renamecolumn (part 2)
Property changes on: grass/trunk/scripts/v.db.renamecolumn
___________________________________________________________________
Added: svn:mergeinfo
Deleted: grass/trunk/scripts/v.db.renamecolumn/Makefile
--- grass/trunk/scripts/v.db.renamecol/Makefile 2009-06-27 10:55:30 UTC (rev 38094)
+++ grass/trunk/scripts/v.db.renamecolumn/Makefile 2009-06-27 11:03:25 UTC (rev 38097)
@@ -1,7 +0,0 @@
-MODULE_TOPDIR = ../..
-PGM = v.db.renamecol
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
Copied: grass/trunk/scripts/v.db.renamecolumn/Makefile (from rev 38096, grass/trunk/scripts/v.db.renamecol/Makefile)
--- grass/trunk/scripts/v.db.renamecolumn/Makefile (rev 0)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.db.renamecolumn
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Deleted: grass/trunk/scripts/v.db.renamecolumn/v.db.renamecol.html
--- grass/trunk/scripts/v.db.renamecol/v.db.renamecol.html 2009-06-27 10:55:30 UTC (rev 38094)
+++ grass/trunk/scripts/v.db.renamecolumn/v.db.renamecol.html 2009-06-27 11:03:25 UTC (rev 38097)
@@ -1,50 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.db.renamecol</em> renames a column in the attribute table connected
-to a given vector map. It automatically checks the connection for the specified
-layer.
-<h2>NOTES</h2>
-If the map table is connected through the DBF or SQLite drivers, the renaming
-is internally done by adding a new column with new name, transferring the contents
-of the old column to the new column and dropping the old column. This is needed
-as DBF or SQLite do not support "ALTER TABLE" command to rename columns. Due to
-this the renamed column is found as last column of the table, it's original position
-cannot be maintained.
-<p>
-The SQLite driver will exit with an error if the column rename involves only a change of
-case, i.e., upper-to-lowercase, or lower-to-uppercase. The SQLite protocol considers "NAME"
-and "name" to be identical column names. In cases like these, the user should rename the original
-column to an intermediary name, then rename the intermediary to the final name.
-<p>
-<h2>EXAMPLES</h2>
-Renaming a column:<br>
-<div class="code"><pre>
-v.info -c myroads
-v.db.renamecol myroads column=label,roadtype
-v.info -c myroads
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a HREF="db.execute.html">db.execute</a></em>,
-<em><a HREF="v.db.addcol.html">v.db.addcol</a></em>,
-<em><a HREF="v.db.addtable.html">v.db.addtable</a></em>,
-<em><a HREF="v.db.connect.html">v.db.connect</a></em>,
-<em><a HREF="v.db.dropcolumn.html">v.db.dropcolumn</a></em>,
-<em><a HREF="v.db.droptable.html">v.db.droptable</a></em>,
-<em><a HREF="v.db.select.html">v.db.select</a></em>,
-<em><a HREF="v.db.update.html">v.db.update</a></em>
-<h2>AUTHOR</h2>
-Markus Neteler
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/scripts/v.db.renamecolumn/v.db.renamecol.html (from rev 38096, grass/trunk/scripts/v.db.renamecol/v.db.renamecol.html)
--- grass/trunk/scripts/v.db.renamecolumn/v.db.renamecol.html (rev 0)
@@ -0,0 +1,50 @@
+<h2>DESCRIPTION</h2>
+<em>v.db.renamecolumn</em> renames a column in the attribute table connected
+to a given vector map. It automatically checks the connection for the specified
+layer.
+<h2>NOTES</h2>
+If the map table is connected through the DBF or SQLite drivers, the renaming
+is internally done by adding a new column with new name, transferring the contents
+of the old column to the new column and dropping the old column. This is needed
+as DBF or SQLite do not support "ALTER TABLE" command to rename columns. Due to
+this the renamed column is found as last column of the table, it's original position
+cannot be maintained.
+<p>
+The SQLite driver will exit with an error if the column rename involves only a change of
+case, i.e., upper-to-lowercase, or lower-to-uppercase. The SQLite protocol considers "NAME"
+and "name" to be identical column names. In cases like these, the user should rename the original
+column to an intermediary name, then rename the intermediary to the final name.
+<p>
+<h2>EXAMPLES</h2>
+Renaming a column:<br>
+<div class="code"><pre>
+v.info -c myroads
+v.db.renamecolumn myroads column=label,roadtype
+v.info -c myroads
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a HREF="db.execute.html">db.execute</a></em>,
+<em><a HREF="v.db.addcol.html">v.db.addcol</a></em>,
+<em><a HREF="v.db.addtable.html">v.db.addtable</a></em>,
+<em><a HREF="v.db.connect.html">v.db.connect</a></em>,
+<em><a HREF="v.db.dropcolumn.html">v.db.dropcolumn</a></em>,
+<em><a HREF="v.db.droptable.html">v.db.droptable</a></em>,
+<em><a HREF="v.db.select.html">v.db.select</a></em>,
+<em><a HREF="v.db.update.html">v.db.update</a></em>
+<h2>AUTHOR</h2>
+Markus Neteler
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/scripts/v.db.renamecolumn/v.db.renamecol.py
--- grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py 2009-06-27 10:55:30 UTC (rev 38094)
+++ grass/trunk/scripts/v.db.renamecolumn/v.db.renamecol.py 2009-06-27 11:03:25 UTC (rev 38097)
@@ -1,118 +0,0 @@
-#!/usr/bin/env python
-# MODULE: v.db.renamecol
-# AUTHOR(S): Markus Neteler
-# Converted to Python by Glynn Clements
-# PURPOSE: interface to db.execute to drop a column from the
-# attribute table connected to a given vector map
-# - Based on v.db.dropcolumn
-# - with special trick for SQLite and DBF (here the new col is
-# added/values copied/old col deleted)
-# COPYRIGHT: (C) 2007 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-# TODO: MySQL untested
-#%Module
-#% description: Renames a column in the attribute table connected to a given vector map.
-#% keywords: vector, database, attribute table
-#%End
-#%option
-#% key: map
-#% type: string
-#% gisprompt: old,vector,vector
-#% key_desc : name
-#% description: Vector map for which to rename attribute column
-#% required : yes
-#%end
-#%option
-#% key: layer
-#% type: integer
-#% description: Layer where to rename column
-#% answer: 1
-#% required : no
-#%end
-#%option
-#% key: column
-#% type: string
-#% description: Old and new name of the column (old,new)
-#% required : yes
-#% multiple: yes
-#% key_desc: oldcol,newcol
-#%end
-import sys
-import os
-import grass.script as grass
-def main():
- map = options['map']
- layer = options['layer']
- column = options['column']
- mapset = grass.gisenv()['MAPSET']
- if not grass.find_file(map, element = 'vector', mapset = mapset):
- grass.fatal("Vector map <%s> not found in current mapset" % map)
- f = grass.vector_layer_db(map, layer)
- table = f['table']
- keycol = f['key']
- database = f['database']
- driver = f['driver']
- if not table:
- grass.fatal("There is no table connected to the input vector map. Cannot rename any column")
- cols = column.split(',')
- oldcol = cols[0]
- newcol = cols[1]
- if driver == "dbf":
- if len(newcol) > 10:
- grass.fatal("Column name <%s> too long. The DBF driver supports column names not longer than 10 characters" % newcol)
- if oldcol == keycol:
- grass.fatal("Cannot rename column <%s> as it is needed to keep table <%s> connected to the input vector map" % (oldcol, table))
- # describe old col
- oldcoltype = None
- for f in grass.db_describe(table)['cols']:
- if f[0] != oldcol:
- continue
- oldcoltype = f[1]
- oldcollength = f[2]
- # old col there?
- if not oldcol:
- grass.fatal("Column <%s> not found in table <%s>" % (coldcol, table))
- # some tricks
- if driver in ['sqlite', 'dbf']:
- if oldcoltype.upper() == "CHARACTER":
- colspec = "%s varchar(%s)" % (newcol, oldcollength)
- else:
- colspec = "%s %s" % (newcol, oldcoltype)
- grass.run_command('v.db.addcol', map = map, layer = layer, column = colspec)
- sql = "UPDATE %s SET %s=%s" % (table, newcol, oldcol)
- grass.write_command('db.execute', database = database, driver = driver, stdin = sql)
- grass.run_command('v.db.dropcolumn', map = map, layer = layer, column = oldcol)
- else:
- sql = "ALTER TABLE %s RENAME %s TO %s" % (table, oldcol, newcol)
- # write cmd history:
- grass.vector_history(map)
-if __name__ == "__main__":
- options, flags = grass.parser()
- main()
Copied: grass/trunk/scripts/v.db.renamecolumn/v.db.renamecol.py (from rev 38096, grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py)
--- grass/trunk/scripts/v.db.renamecolumn/v.db.renamecol.py (rev 0)
@@ -0,0 +1,118 @@
+#!/usr/bin/env python
+# MODULE: v.db.renamecolumn
+# AUTHOR(S): Markus Neteler
+# Converted to Python by Glynn Clements
+# PURPOSE: interface to db.execute to drop a column from the
+# attribute table connected to a given vector map
+# - Based on v.db.dropcolumn
+# - with special trick for SQLite and DBF (here the new col is
+# added/values copied/old col deleted)
+# COPYRIGHT: (C) 2007 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# TODO: MySQL untested
+#%Module
+#% description: Renames a column in the attribute table connected to a given vector map.
+#% keywords: vector, database, attribute table
+#%End
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc : name
+#% description: Vector map for which to rename attribute column
+#% required : yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer where to rename column
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Old and new name of the column (old,new)
+#% required : yes
+#% multiple: yes
+#% key_desc: oldcol,newcol
+#%end
+import sys
+import os
+import grass.script as grass
+def main():
+ map = options['map']
+ layer = options['layer']
+ column = options['column']
+ mapset = grass.gisenv()['MAPSET']
+ if not grass.find_file(map, element = 'vector', mapset = mapset):
+ grass.fatal("Vector map <%s> not found in current mapset" % map)
+ f = grass.vector_layer_db(map, layer)
+ table = f['table']
+ keycol = f['key']
+ database = f['database']
+ driver = f['driver']
+ if not table:
+ grass.fatal("There is no table connected to the input vector map. Cannot rename any column")
+ cols = column.split(',')
+ oldcol = cols[0]
+ newcol = cols[1]
+ if driver == "dbf":
+ if len(newcol) > 10:
+ grass.fatal("Column name <%s> too long. The DBF driver supports column names not longer than 10 characters" % newcol)
+ if oldcol == keycol:
+ grass.fatal("Cannot rename column <%s> as it is needed to keep table <%s> connected to the input vector map" % (oldcol, table))
+ # describe old col
+ oldcoltype = None
+ for f in grass.db_describe(table)['cols']:
+ if f[0] != oldcol:
+ continue
+ oldcoltype = f[1]
+ oldcollength = f[2]
+ # old col there?
+ if not oldcol:
+ grass.fatal("Column <%s> not found in table <%s>" % (coldcol, table))
+ # some tricks
+ if driver in ['sqlite', 'dbf']:
+ if oldcoltype.upper() == "CHARACTER":
+ colspec = "%s varchar(%s)" % (newcol, oldcollength)
+ else:
+ colspec = "%s %s" % (newcol, oldcoltype)
+ grass.run_command('v.db.addcol', map = map, layer = layer, column = colspec)
+ sql = "UPDATE %s SET %s=%s" % (table, newcol, oldcol)
+ grass.write_command('db.execute', database = database, driver = driver, stdin = sql)
+ grass.run_command('v.db.dropcolumn', map = map, layer = layer, column = oldcol)
+ else:
+ sql = "ALTER TABLE %s RENAME %s TO %s" % (table, oldcol, newcol)
+ # write cmd history:
+ grass.vector_history(map)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
