[GRASS-SVN] r36259 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Mar 8 13:22:52 EDT 2009
Author: cmbarton
Date: 2009-03-08 13:22:51 -0400 (Sun, 08 Mar 2009)
New Revision: 36259
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/profile.py
Limit total points plotted in profile module to 500 to prevent hanging with large, high resolution maps.
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/profile.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/profile.py 2009-03-08 17:22:13 UTC (rev 36258)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/profile.py 2009-03-08 17:22:51 UTC (rev 36259)
@@ -149,6 +149,8 @@
self.ppoints = ''
# plot draw object
self.profile = None
+ # total transect length
+ self.transect_length = 0.0
# title of window
self.ptitle = _('Profile of')
@@ -273,6 +275,41 @@
+ # create list of coordinates for transect segment markers
+ if len(self.mapwin.polycoords) > 0:
+ for point in self.mapwin.polycoords:
+ # get value of raster cell at coordinate point
+ ret = gcmd.RunCommand('r.what',
+ parent = self,
+ read = True,
+ input = self.raster[0]['name'],
+ east_north = '%d,%d' % (point[0],point[1]))
+ val = ret.splitlines()[0].split('|')[3]
+ # calculate distance between coordinate points
+ if lasteast and lastnorth:
+ dist = math.sqrt(math.pow((lasteast-point[0]),2) + math.pow((lastnorth-point[1]),2))
+ cumdist += dist
+ #store total transect length
+ self.transect_length = cumdist
+ # build a list of distance,value pairs for each segment of transect
+ self.seglist.append((cumdist,val))
+ lasteast = point[0]
+ lastnorth = point[1]
+ # delete first and last segment point
+ try:
+ self.seglist.pop(0)
+ self.seglist.pop()
+ except:
+ pass
# create datalist for each raster map
@@ -310,36 +347,6 @@
else:
self.ylabel = self.ylabel.rstrip(',')
- # create list of coordinates for transect segment markers
- if len(self.mapwin.polycoords) > 0:
- for point in self.mapwin.polycoords:
- # get value of raster cell at coordinate point
- p = gcmd.Command(['r.what',
- 'input=%s' % self.raster[0]['name'],
- 'east_north=%d,%d' % (point[0],point[1])])
- outlist = p.ReadStdOutput()
- val = outlist[0].split('|')[3]
- # calculate distance between coordinate points
- if lasteast and lastnorth:
- dist = math.sqrt(math.pow((lasteast-point[0]),2) + math.pow((lastnorth-point[1]),2))
- cumdist += dist
- # build a list of distance,value pairs for each segment of transect
- self.seglist.append((cumdist,val))
- lasteast = point[0]
- lastnorth = point[1]
- # delete first and last segment point
- try:
- self.seglist.pop(0)
- self.seglist.pop()
- except:
- pass
def SetGraphStyle(self):
Set plot and text options
@@ -406,11 +413,24 @@
datalist = []
import subprocess
+ # keep total number of transect points to 500 or less to avoid
+ # freezing with large, high resolution maps
+ region = grass.region()
+ curr_res = min(float(region['nsres']),float(region['ewres']))
+ transect_rec = 0
+ print "transect length=",self.transect_length
+ print "current res=",curr_res
+ if self.transect_length / curr_res > 500:
+ transect_res = self.transect_length / 500
+ else: transect_res = curr_res
+ print "transect res=",transect_res
try:
p = grass.read_command("r.profile",
input=raster,
profile=coords,
+ res=transect_res,
null="nan",
quiet=True
