[GRASS-SVN] r36260 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Mar 8 15:34:20 EDT 2009
Author: martinl
Date: 2009-03-08 15:34:20 -0400 (Sun, 08 Mar 2009)
New Revision: 36260
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI: show option name/type in dialog
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-03-08 17:22:51 UTC (rev 36259)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-03-08 19:34:20 UTC (rev 36260)
@@ -1009,6 +1009,19 @@
else:
text_style = wx.FONTWEIGHT_BOLD
+ # title sizer (description, name, type)
+ title_sizer = wx.BoxSizer(wx.HORIZONTAL)
+ title_txt = wx.StaticText(parent=which_panel)
+ self.label_id.append(title_txt.GetId())
+ rtitle_txt = wx.StaticText(parent=which_panel,
+ label = '(' + p['name'] + ', ' + p['type'] + ')')
+ title_sizer.Add(item=title_txt, proportion=1,
+ flag=wx.LEFT | wx.TOP | wx.EXPAND, border=5)
+ title_sizer.Add(item=rtitle_txt, proportion=0,
+ flag=wx.ALIGN_RIGHT | wx.RIGHT | wx.TOP, border=5)
+ which_sizer.Add(item=title_sizer, proportion=0,
+ flag=wx.EXPAND)
# title expansion
if p.get('multiple','no') == 'yes' and len( p.get('values','') ) == 0:
title = _("[multiple]") + " " + title
@@ -1022,12 +1035,11 @@
if p.get('multiple', 'no') == 'yes' and \
p.get('gisprompt',False) == False and \
p.get('type', '') == 'string':
- txt = wx.StaticBox (parent=which_panel, id=0, label=" " + title + ": ")
- self.label_id.append(txt.GetId())
+ title_txt.SetLabel(" " + title + ": ")
if len(valuelist) > 6:
- hSizer=wx.StaticBoxSizer ( box=txt, orient=wx.VERTICAL )
+ hSizer=wx.StaticBoxSizer ( box=title_txt, orient=wx.VERTICAL )
else:
- hSizer=wx.StaticBoxSizer ( box=txt, orient=wx.HORIZONTAL )
+ hSizer=wx.StaticBoxSizer ( box=title_txt, orient=wx.HORIZONTAL )
isEnabled = {}
# copy default values
if p['value'] == '':
@@ -1057,15 +1069,11 @@
which_sizer.Add( item=hSizer, proportion=0,
flag=wx.EXPAND | wx.TOP | wx.RIGHT | wx.LEFT, border=5 )
- elif p.get('gisprompt',False) == False:
+ elif p.get('gisprompt', False) == False:
if len(valuelist) == 1: # -> textctrl
- txt = wx.StaticText(parent=which_panel,
- label = "%s. %s %s" % (title, _('Valid range'),
- str(valuelist[0]) + ':'))
- which_sizer.Add(item=txt, proportion=0,
- flag=wx.ADJUST_MINSIZE | wx.TOP | wx.RIGHT | wx.LEFT, border=5)
+ title_txt.SetLabel("%s. %s %s" % (title, _('Valid range'),
+ str(valuelist[0]) + ':'))
if p.get('type','') == 'integer' and \
p.get('multiple','no') == 'no':
@@ -1081,7 +1089,7 @@
style = wx.BOTTOM | wx.LEFT
else:
txt2 = wx.TextCtrl(parent=which_panel, value = p.get('default',''))
- txt.SetName("TextCtrl")
+ txt2.SetName("TextCtrl")
style = wx.EXPAND | wx.BOTTOM | wx.LEFT
if p.get('value', '') != '':
@@ -1098,10 +1106,7 @@
txt2.Bind(wx.EVT_TEXT, self.OnSetValue)
else:
# list of values (combo)
- txt = wx.StaticText(parent=which_panel, label = title + ':' )
+ title_txt.SetLabel(title + ':')
cb = wx.ComboBox(parent=which_panel, id=wx.ID_ANY, value=p.get('default',''),
size=globalvar.DIALOG_COMBOBOX_SIZE,
choices=valuelist, style=wx.CB_DROPDOWN | wx.CB_READONLY)
@@ -1118,11 +1123,7 @@
and p.get('gisprompt',False) == False
and p.get('prompt','') != 'color'):
- flag=wx.EXPAND | wx.RIGHT | wx.LEFT | wx.TOP, border=5)
+ title_txt.SetLabel(title + ':' )
if p.get('multiple','yes') == 'yes' or \
p.get('type', 'string') in ('string', 'float') or \
len(p.get('key_desc', [])) > 1:
@@ -1154,10 +1155,7 @@
# element selection tree combobox (maps, icons, regions, etc.)
if p.get('gisprompt', False) == True:
- txt = wx.StaticText(parent=which_panel, label = title + ':')
- flag=wx.ADJUST_MINSIZE | wx.RIGHT | wx.LEFT | wx.TOP, border=5)
# GIS element entry
if p.get('prompt','') not in ('color',
'color_none',
@@ -1309,8 +1307,7 @@
# we have to target the button here
p['wxId'] = fbb.GetChildren()[1].GetId()
- if txt is not None:
- # txt.SetFont( wx.Font( fontsize, wx.FONTFAMILY_DEFAULT, wx.NORMAL, text_style, 0, ''))
+ if title_txt is not None:
# create tooltip if given
if len(p['values_desc']) > 0:
if tooltip:
@@ -1322,7 +1319,7 @@
tooltip += p['values'][i] + ': ' + p['values_desc'][i] + os.linesep
tooltip.strip(os.linesep)
if tooltip:
- txt.SetToolTipString(tooltip)
+ title_txt.SetToolTipString(tooltip)
if p == first_param:
if type(p['wxId']) == type(1):
