[GRASS-SVN] r36553 - grass/trunk/scripts/v.centroids
Tue Mar 31 17:26:43 EDT 2009
Author: neteler
Date: 2009-03-31 17:26:43 -0400 (Tue, 31 Mar 2009)
New Revision: 36553
   grass/trunk/scripts/v.centroids/v.centroids.py
Don't use locale dependent output for parsing (untested)
Modified: grass/trunk/scripts/v.centroids/v.centroids.py
--- grass/trunk/scripts/v.centroids/v.centroids.py	2009-03-31 21:22:40 UTC (rev 36552)
+++ grass/trunk/scripts/v.centroids/v.centroids.py	2009-03-31 21:26:43 UTC (rev 36553)
@@ -78,8 +78,8 @@
 	num_bound = 0
 	tenv = os.environ.copy()
 	tenv['LC_ALL'] = 'C'
-	lines = grass.read_command("v.info", map = options['input'], env = tenv).splitlines()
-	e = re.compile("Number of boundaries: +([0-9]+) +")
+	lines = grass.read_command("v.info -t", map = options['input'], env = tenv).splitlines()
+	e = re.compile("boundaries= +([0-9]+) +")
 	for line in lines:
 	    mo = e.search(line)
 	    if mo:
