[GRASS-SVN] r36554 - in grass/trunk: lib/python scripts/r.fillnulls
scripts/v.centroids
svn_grass at osgeo.org
Tue Mar 31 17:40:33 EDT 2009
Author: martinl
Date: 2009-03-31 17:40:33 -0400 (Tue, 31 Mar 2009)
New Revision: 36554
grass/trunk/lib/python/grass.py
grass/trunk/scripts/r.fillnulls/r.fillnulls.py
grass/trunk/scripts/v.centroids/v.centroids.py
grass.py: vector_info_topo() added
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py 2009-03-31 21:26:43 UTC (rev 36553)
+++ grass/trunk/lib/python/grass.py 2009-03-31 21:40:33 UTC (rev 36554)
@@ -216,7 +216,7 @@
# key-value parsers
-def parse_key_val(s, sep = '=', dflt = None):
+def parse_key_val(s, sep = '=', dflt = None, val_type = None):
"""Parse a string into a dictionary, where entries are separated
by newlines and the key and value are separated by `sep' (default: `=')
@@ -228,7 +228,10 @@
v = kv[1]
else:
v = dflt
- result[k] = v
+ if val_type:
+ result[k] = val_type(v)
+ else:
+ result[k] = v
return result
# interface to g.gisenv
@@ -542,6 +545,13 @@
run_command('v.support', map = map, cmdhist = os.environ['CMDLINE'])
+# run "v.info -t" and parse output
+def vector_info_topo(map):
+ """Return information about a vector map (interface to `v.info -t')."""
+ s = read_command('v.info', flags = 't', map = map)
+ return parse_key_val(s, val_type = int)
# add raster history
def raster_history(map):
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py 2009-03-31 21:26:43 UTC (rev 36553)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py 2009-03-31 21:40:33 UTC (rev 36554)
@@ -123,13 +123,7 @@
grass.fatal("abandoned. Removing temporary maps, restoring user mask if needed:")
# count number of points to control segmax parameter for interpolation:
- s = grass.read_command('v.info -t', map = vecttmp)
- for l in s.splitlines():
- if "points" in l:
- s = l.split('=')[1].strip()
- s = s.split()[0].strip()
- pointsnumber = int(s)
- break
+ pointsnumber = grass.vector_info_topo(map = vecttmp)['points']
grass.message("Interpolating %d points" % pointsnumber)
Modified: grass/trunk/scripts/v.centroids/v.centroids.py
--- grass/trunk/scripts/v.centroids/v.centroids.py 2009-03-31 21:26:43 UTC (rev 36553)
+++ grass/trunk/scripts/v.centroids/v.centroids.py 2009-03-31 21:40:33 UTC (rev 36554)
@@ -78,13 +78,7 @@
num_bound = 0
tenv = os.environ.copy()
tenv['LC_ALL'] = 'C'
- lines = grass.read_command("v.info -t", map = options['input'], env = tenv).splitlines()
- e = re.compile("boundaries= +([0-9]+) +")
- for line in lines:
- mo = e.search(line)
- if mo:
- num_bound = int(mo.group(1))
- break
+ num_bound = grass.vector_info_topo(map = options['input'])['boundaries']
if num_bound == 0:
grass.fatal("Input vector map contains no boundaries.")
