[GRASS-SVN] r37277 - grass/trunk/scripts/m.proj
svn_grass at osgeo.org
Tue May 19 07:24:55 EDT 2009
Author: martinl
Date: 2009-05-19 07:24:54 -0400 (Tue, 19 May 2009)
New Revision: 37277
grass/trunk/scripts/m.proj/m.proj.py
m.proj: output fs optional
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py 2009-05-19 11:00:37 UTC (rev 37276)
+++ grass/trunk/scripts/m.proj/m.proj.py 2009-05-19 11:24:54 UTC (rev 37277)
@@ -47,9 +47,10 @@
#%option
#% key: fs
#% type: string
-#% description: Field separator (format: input,output)
+#% label: Field separator (format: input[,output])
+#% description: Valid field separators are also "space", "tab" or "comma"
#% required : no
-#% key_desc : character,character
+#% key_desc : string
#% answer : |,|
#%end
#%option
@@ -114,17 +115,39 @@
grass.fatal("Output file already exists")
#### parse field separator
- ifs, ofs = fs.split(',')
- if ifs.lower() in ["space", "tab"]:
+ try:
+ ifs, ofs = fs.split(',')
+ except ValueError:
+ ifs = ofs = fs
+ ifs = ifs.lower()
+ ofs = ofs.lower()
+ if ifs in ('space', 'tab'):
ifs = ' '
+ elif ifs == 'comma':
+ ifs = ','
else:
- ifs = ifs[0]
- if ofs.lower() == "space":
+ if len(ifs) > 1:
+ grass.warning("Invalid field separator, using '%s'" % ifs[0])
+ try:
+ ifs = ifs[0]
+ except IndexError:
+ grass.fatal("Invalid field separator '%s'" % ifs)
+ if ofs.lower() == 'space':
ofs = ' '
- elif ofs.lower() == "tab":
+ elif ofs.lower() == 'tab':
ofs = '\t'
+ elif ofs.lower() == 'comma':
+ ofs = ','
else:
- ofs = ofs[0]
+ if len(ofs) > 1:
+ grass.warning("Invalid field separator, using '%s'" % ofs[0])
+ try:
+ ofs = ofs[0]
#### set up projection params
s = grass.read_command("g.proj", flags='j')
