[GRASS-SVN] r37316 - in grass/branches/develbranch_6: include lib/vector/Vlib
Wed May 20 17:56:34 EDT 2009
Author: martinl
Date: 2009-05-20 17:56:34 -0400 (Wed, 20 May 2009)
New Revision: 37316
   grass/branches/develbranch_6/include/Vect.h
   grass/branches/develbranch_6/lib/vector/Vlib/geos.c
progress in geos support (new Vlib fns)
Modified: grass/branches/develbranch_6/include/Vect.h
--- grass/branches/develbranch_6/include/Vect.h	2009-05-20 21:24:51 UTC (rev 37315)
+++ grass/branches/develbranch_6/include/Vect.h	2009-05-20 21:56:34 UTC (rev 37316)
@@ -471,9 +471,11 @@
     /* GEOS support */
 #ifdef HAVE_GEOS
-GEOSGeometry *Vect_read_line_geos(const struct Map_info *, int);
-GEOSGeometry *Vect_read_area_geos(const struct Map_info *, int);
-GEOSGeometry *Vect_line_to_geos(const struct Map_info *, const struct line_pnts*, int);
+GEOSGeometry *Vect_read_line_geos(struct Map_info *, int);
+GEOSGeometry *Vect_line_to_geos(struct Map_info *, const struct line_pnts*, int);
+GEOSGeometry *Vect_read_area_geos(struct Map_info *, int);
+GEOSCoordSequence *Vect_get_area_points_geos(struct Map_info *, int);
+GEOSCoordSequence *Vect_get_isle_points_geos(struct Map_info *, int);
 #endif
 #endif /* GRASS_VECT_H */
Modified: grass/branches/develbranch_6/lib/vector/Vlib/geos.c
--- grass/branches/develbranch_6/lib/vector/Vlib/geos.c	2009-05-20 21:24:51 UTC (rev 37315)
+++ grass/branches/develbranch_6/lib/vector/Vlib/geos.c	2009-05-20 21:56:34 UTC (rev 37316)
@@ -5,8 +5,6 @@
   Higher level functions for reading/writing/manipulating vectors.
-  Note: current GEOS support is *very* slow
   (C) 2009 by the GRASS Development Team
   This program is free software under the GNU General Public License
@@ -23,22 +21,28 @@
 #ifdef HAVE_GEOS
 #include <geos_c.h>
-static struct line_pnts *Points;
 static GEOSGeometry *Vect__read_line_geos(struct Map_info *, long);
+static GEOSCoordSequence *V1_read_line_geos(struct Map_info *, long);
+static GEOSCoordSequence *V2_read_line_geos(struct Map_info *, int);
    \brief Read vector feature and stores it as GEOSGeometry instance
-   Note: Free allocated memory by GEOSGeom_destroy().
+   Supported feature types:
+    - GV_POINT     -> POINT
+    - GV_LINE      -> LINESTRING
+    - GV_BOUNDARY  -> LINESTRING / LINEARRING
+   You should free allocated memory by GEOSGeom_destroy().
    \param Map pointer to Map_info structure
    \param line feature id
    \return pointer to GEOSGeometry instance
+   \return empty GEOSGeometry for unsupported feature type
    \return NULL on error
-GEOSGeometry *Vect_read_line_geos(const struct Map_info *Map, int line)
+GEOSGeometry *Vect_read_line_geos(struct Map_info *Map, int line)
     P_LINE *Line;
@@ -64,9 +68,9 @@
-   \brief Read vector area and stores it as GEOSGeometry instance
+   \brief Read vector area and stores it as GEOSGeometry instance (polygon)
    \param area area id
@@ -74,21 +78,14 @@
-GEOSGeometry *Vect_read_area_geos(const struct Map_info * Map, int area)
+GEOSGeometry *Vect_read_area_geos(struct Map_info * Map, int area)
-    int i, type, nholes, isle;
+    int i, nholes, isle;
     GEOSGeometry *boundary, **holes;
+    G_debug(3, "Vect_read_area_geos(): area = %d", area);
-    if (!Points)
-	Points = Vect_new_line_struct();
-    G_debug(3, "Vect_read_area_geos(area=%d)", area);
-    if (Vect_get_area_points(Map, area, Points) == -1) {
-	G_fatal_error(_("Vect_read_area_geos(): unable to read area id %d"),
-		      area);
-    boundary = Vect_line_to_geos(Map, Points, GV_BOUNDARY);
+    boundary = GEOSGeom_createLinearRing(Vect_get_area_points_geos(Map, area));
     if (!boundary) {
 		      area);
@@ -100,12 +97,12 @@
 	isle = Vect_get_area_isle(Map, area, i);
 	if (isle < 1)
 	    continue;
-	if (Vect_get_isle_points(Map, isle, Points) < 0)
+	holes[i] = GEOSGeom_createLinearRing(Vect_get_isle_points_geos(Map, isle));
+	if (!(holes[i]))
 	    G_fatal_error(_("Vect_read_area_geos(): unable to read isle id %d of area id %d"),
 			  isle, area);
-	holes[i] = Vect_line_to_geos(Map, Points, GV_BOUNDARY);
     return GEOSGeom_createPolygon(boundary, holes, nholes);
@@ -115,9 +112,9 @@
    Supported types:
    - GV_POINT    -> POINT
-   - GV_BOUNDARY -> LINERING
+   - GV_BOUNDARY -> LINEARRING
    \param type feature type (see supported types)
@@ -125,7 +122,7 @@
-GEOSGeometry *Vect_line_to_geos(const struct Map_info * Map,
+GEOSGeometry *Vect_line_to_geos(struct Map_info * Map,
 				const struct line_pnts * points, int type)
     int i, with_z;
@@ -180,8 +177,10 @@
   \brief Read line from coor file
-  \param offset lineoffset
+  \param offset line offset
@@ -190,17 +189,99 @@
 GEOSGeometry *Vect__read_line_geos(struct Map_info *Map, long offset)
-    int i;
-    int n_points;
     int type;
-    char rhead;
     double *x, *y, *z;
     GEOSGeometry *geom;
     GEOSCoordSequence *pseq;
-    G_debug(3, "Vect__read_line_geos(): offset = %ld", offset);
+    pseq = V1_read_line_geos(Map, offset);
+    if (!pseq)
+	G_fatal_error(_("Unable to read line offset %ld"), offset);
+    if (type & GV_POINT) {
+	G_debug(3, "    geos_type = point");
+	geom = GEOSGeom_createPoint(pseq);
+    else if (type & GV_LINE) {
+	G_debug(3, "    geos_type = linestring");
+	geom = GEOSGeom_createLineString(pseq);
+    else { /* boundary */
+	if (GEOSisRing(geom)) {
+	    /* GEOSGeom_destroy(geom); */
+	    geom = GEOSGeom_createLinearRing(pseq);
+	    G_debug(3, "    geos_type = linearring");
+	else {
+    G_free((void *) x);
+    G_free((void *) y);
+    if (z)
+	G_free((void *) z);
+    /* GEOSCoordSeq_destroy(pseq); */
+    return geom;
+  \brief Read line from coor file into GEOSCoordSequence
+  You should free allocated memory by GEOSCoordSeq_destroy().
+  \param Map pointer to Map_info
+  \param line line id
+  \return pointer to GEOSCoordSequence
+  \return empty GEOSCoordSequence for dead line or unsuppored feature type
+  \return NULL end of file
+GEOSCoordSequence *V2_read_line_geos(struct Map_info *Map, int line)
+    P_LINE *Line;
+    G_debug(3, "V2_read_line_geos(): line = %d", line);
+    Line = Map->plus.Line[line];
+    if (Line == NULL)
+	G_fatal_error("V2_read_line_geos(): %s %d",
+		      _("Attempt to read dead line"), line);
+    return V1_read_line_geos(Map, Line->offset);
+  \brief Read feature from coor file into GEOSCoordSequence
+  Note: Function reads only points, lines and boundaries, other
+  feature types are ignored (empty coord array is returned)!
+GEOSCoordSequence *V1_read_line_geos(struct Map_info *Map, long offset)
+    int i, n_points, type;
+    char rhead;
+    double *x, *y, *z;
+    GEOSCoordSequence *pseq;
+    G_debug(3, "V1_read_line_geos(): offset = %ld", offset);
     Map->head.last_offset = offset;
     /* reads must set in_head, but writes use default */
@@ -212,14 +293,14 @@
 	return NULL;            /* end of file */
     if (!(rhead & 0x01))	/* dead line */
-	return NULL;
+	return GEOSCoordSeq_create(0, (Map->head.with_z) ? 3 : 2);
     rhead >>= 2;
     type = dig_type_from_store((int)rhead);
     /* read only points / lines / boundaries */
     if (!(type & (GV_POINT | GV_LINES)))
-	return NULL;
     if (type & GV_POINTS) {
 	n_points = 1;
@@ -227,9 +308,6 @@
     else {
 	if (0 >= dig__fread_port_I(&n_points, 1, &(Map->dig_fp)))
 	    return NULL;
-	if (n_points < 2)
-	    /* line / boundary is not valid */
-	    return NULL;
     G_debug(3, "    n_points = %d dim = %d", n_points, (Map->head.with_z) ? 3 : 2);
@@ -256,42 +334,182 @@
     for (i = 0; i < n_points; i++) {
-	GEOSCoordSeq_setX(pseq, i, x[i]);
+	GEOSCoordSeq_setX(pseq, i, x[i]);
 	GEOSCoordSeq_setY(pseq, i, y[i]);
 	if (Map->head.with_z)
 	    GEOSCoordSeq_setZ(pseq, i, z[i]);
     G_debug(3, "    off = %ld", dig_ftell(&(Map->dig_fp)));
+    if (z)
+    return pseq;
-    if (type & GV_POINT) {
-	G_debug(3, "    geos_type = point");
-	geom = GEOSGeom_createPoint(pseq);
+   \brief Returns the polygon array of points, i.e. outer ring (shell)
+   See also Vect_get_area_points().
+   \param area area id
+   \return empty GEOSCoordSequence for dead area
+   \return NULL on error
+GEOSCoordSequence *Vect_get_area_points_geos(struct Map_info *Map, int area)
+    int i, j, k;
+    int line, aline;
+    unsigned int n_points, n_points_shell;
+    double x, y, z;
+    struct Plus_head *Plus;
+    P_AREA *Area;
+    GEOSCoordSequence **pseq, *pseq_shell;
+    G_debug(3, "Vect_get_area_points_geos(): area = %d", area);
+    Plus = &(Map->plus);
+    Area = Plus->Area[area];
+    if (Area == NULL) {		/* dead area */
+	G_warning(_("Attempt to read points of nonexistent area id %d"), area);
+	return NULL;		/* error , because we should not read dead areas */
-    else if (type & GV_LINE) {
-	G_debug(3, "    geos_type = linestring");
-	geom = GEOSGeom_createLineString(pseq);
+    G_debug(3, "  n_lines = %d", Area->n_lines);
+    pseq = (GEOSCoordSequence **) G_malloc(Area->n_lines * sizeof(GEOSCoordSequence *));
+    n_points_shell = 0;
+    for (i = 0; i < Area->n_lines; i++) {
+	line = Area->lines[i];
+	aline = abs(line);
+	G_debug(3, "  append line(%d) = %d", i, line);
+	  TODO
+	if (line > 0)
+	    dir = GV_FORWARD;
+	else
+	    dir = GV_BACKWARD;
+	pseq[i] = V2_read_line_geos(Map, aline);
+	if (!(pseq[i])) {
+	    G_fatal_error(_("Unable to read feature id %d"), aline);
+	GEOSCoordSeq_getSize(pseq[i], &n_points);
+	G_debug(3, "  line n_points = %d", n_points);
+	n_points_shell += n_points;
-    else { /* boundary */
-	if (GEOSisRing(geom)) {
-	    /* GEOSGeom_destroy(geom); */
-	    geom = GEOSGeom_createLinearRing(pseq);
-	    G_debug(3, "    geos_type = linearring");
+    /* create shell (outer ring) */
+    pseq_shell = GEOSCoordSeq_create(n_points_shell, Map->head.with_z ? 3 : 2);
+    k = 0;
+	for (j = 0; j < (int) n_points; j++, k++) {
+	    GEOSCoordSeq_getX(pseq[i], j, &x);
+	    GEOSCoordSeq_setX(pseq_shell, k, x);
+	    GEOSCoordSeq_getY(pseq[i], j, &y);
+	    GEOSCoordSeq_setY(pseq_shell, k, y);
+	    if (Map->head.with_z) {
+		GEOSCoordSeq_getY(pseq[i], j, &z);
+		GEOSCoordSeq_setZ(pseq_shell, k, z);
-	else {
-    G_free((void *) x);
-    G_free((void *) y);
-    if (z)
-	G_free((void *) z);
+    G_free((void *) pseq);
+    return pseq_shell;
+   \brief Returns the polygon (isle) array of points (inner ring)
+   See also Vect_get_isle_points().
+   \param isle isel id
+   \return pointer to GEOSGeometry
+   \return NULL on error or dead line
+GEOSCoordSequence *Vect_get_isle_points_geos(struct Map_info *Map, int isle)
+    int i, j, k;
+    int line, aline;
+    unsigned n_points, n_points_shell;
+    double x, y, z;
+    P_ISLE *Isle;
+    G_debug(3, "Vect_get_isle_points_geos(): isle = %d", isle);
+    Isle = Plus->Isle[isle];
-    /* GEOSCoordSeq_destroy(pseq); */
+    G_debug(3, "  n_lines = %d", Isle->n_lines);
+    for (i = 0; i < Isle->n_lines; i++) {
+	line = Isle->lines[i];
+	if (!(pseq[i])) {
+	  TODO
+	if (line > 0)
+	    dir = GV_FORWARD;
+	else
+    k = 0;
-    return geom;
 #endif /* HAVE_GEOS */
