[GRASS-SVN] r37317 - in grass/trunk: include lib/vector/Vlib
svn_grass at osgeo.org
Wed May 20 18:10:00 EDT 2009
Author: martinl
Date: 2009-05-20 18:10:00 -0400 (Wed, 20 May 2009)
New Revision: 37317
grass/trunk/include/Vect.h
grass/trunk/lib/vector/Vlib/geos.c
progress in geos support (new Vlib fns)
(merge from devbr6, r37316)
Modified: grass/trunk/include/Vect.h
--- grass/trunk/include/Vect.h 2009-05-20 21:56:34 UTC (rev 37316)
+++ grass/trunk/include/Vect.h 2009-05-20 22:10:00 UTC (rev 37317)
@@ -470,9 +470,11 @@
/* GEOS support */
#ifdef HAVE_GEOS
-GEOSGeometry *Vect_read_line_geos(const struct Map_info *, int);
-GEOSGeometry *Vect_read_area_geos(const struct Map_info *, int);
-GEOSGeometry *Vect_line_to_geos(const struct Map_info *, const struct line_pnts*, int);
+GEOSGeometry *Vect_read_line_geos(struct Map_info *, int);
+GEOSGeometry *Vect_line_to_geos(struct Map_info *, const struct line_pnts*, int);
+GEOSGeometry *Vect_read_area_geos(struct Map_info *, int);
+GEOSCoordSequence *Vect_get_area_points_geos(struct Map_info *, int);
+GEOSCoordSequence *Vect_get_isle_points_geos(struct Map_info *, int);
#endif
#endif /* GRASS_VECT_H */
Modified: grass/trunk/lib/vector/Vlib/geos.c
--- grass/trunk/lib/vector/Vlib/geos.c 2009-05-20 21:56:34 UTC (rev 37316)
+++ grass/trunk/lib/vector/Vlib/geos.c 2009-05-20 22:10:00 UTC (rev 37317)
@@ -1,16 +1,16 @@
- * \file geos.c
- * \brief Vector library - GEOS support
- * Higher level functions for reading/writing/manipulating vectors.
- * (C) 2009 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Martin Landa <landa.martin gmail.com>
+ \file geos.c
+ \brief Vector library - GEOS support
+ Higher level functions for reading/writing/manipulating vectors.
+ (C) 2009 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Martin Landa <landa.martin gmail.com>
#include <grass/config.h>
@@ -21,44 +21,56 @@
#ifdef HAVE_GEOS
#include <geos_c.h>
-static struct line_pnts *Points;
+static GEOSGeometry *Vect__read_line_geos(struct Map_info *, long);
+static GEOSCoordSequence *V1_read_line_geos(struct Map_info *, long);
+static GEOSCoordSequence *V2_read_line_geos(struct Map_info *, int);
\brief Read vector feature and stores it as GEOSGeometry instance
- Note: Free allocated memory by GEOSGeom_destroy().
+ Supported feature types:
+ - GV_POINT -> POINT
+ - GV_LINE -> LINESTRING
+ - GV_BOUNDARY -> LINESTRING / LINEARRING
+ You should free allocated memory by GEOSGeom_destroy().
\param Map pointer to Map_info structure
\param line feature id
\return pointer to GEOSGeometry instance
+ \return empty GEOSGeometry for unsupported feature type
\return NULL on error
-GEOSGeometry *Vect_read_line_geos(const struct Map_info *Map, int line)
+GEOSGeometry *Vect_read_line_geos(struct Map_info *Map, int line)
- int type, dim;
+ P_LINE *Line;
- if (!Points)
- Points = Vect_new_line_struct();
- G_debug(3, "Vect_read_line_geos(line=%d)", line);
- if (Vect_is_3d(Map))
- dim = 3;
- else
- dim = 2;
- type = Vect_read_line(Map, Points, NULL, line);
- if (type < 1) /* ignore dead lines */
- return NULL;
- return Vect_line_to_geos(Map, Points, type);
+ G_debug(3, "Vect_read_line_geos(): line = %d", line);
+ if (!VECT_OPEN(Map))
+ G_fatal_error("Vect_read_line_geos(): %s", _("vector map is not opened"));
+ if (line < 1 || line > Map->plus.n_lines)
+ G_fatal_error(_("Vect_read_line_geos(): feature id %d is not reasonable "
+ "(max features in vector map <%s>: %d)"),
+ line, Vect_get_full_name(Map), Map->plus.n_lines);
+ if (Map->format != GV_FORMAT_NATIVE)
+ G_fatal_error("Vect_read_line_geos(): %s", _("only native format supported"));
+ Line = Map->plus.Line[line];
+ if (Line == NULL)
+ G_fatal_error("Vect_read_line_geos(): %s %d",
+ _("Attempt to read dead line"), line);
+ return Vect__read_line_geos(Map, Line->offset);
- \brief Read vector area and stores it as GEOSGeometry instance
+ \brief Read vector area and stores it as GEOSGeometry instance (polygon)
\param area area id
@@ -66,26 +78,14 @@
-GEOSGeometry *Vect_read_area_geos(const struct Map_info * Map, int area)
+GEOSGeometry *Vect_read_area_geos(struct Map_info * Map, int area)
- int i, dim, nholes, isle;
+ int i, nholes, isle;
GEOSGeometry *boundary, **holes;
+ G_debug(3, "Vect_read_area_geos(): area = %d", area);
- if (!Points)
- G_debug(3, "Vect_read_area_geos(area=%d)", area);
- dim = 3;
- else
- dim = 2;
- if (Vect_get_area_points(Map, area, Points) == -1) {
- G_fatal_error(_("Vect_read_area_geos(): unable to read area id %d"),
- area);
- boundary = Vect_line_to_geos(Map, Points, GV_BOUNDARY);
+ boundary = GEOSGeom_createLinearRing(Vect_get_area_points_geos(Map, area));
if (!boundary) {
area);
@@ -97,12 +97,12 @@
isle = Vect_get_area_isle(Map, area, i);
if (isle < 1)
continue;
- if (Vect_get_isle_points(Map, isle, Points) < 0)
+ holes[i] = GEOSGeom_createLinearRing(Vect_get_isle_points_geos(Map, isle));
+ if (!(holes[i]))
G_fatal_error(_("Vect_read_area_geos(): unable to read isle id %d of area id %d"),
isle, area);
- holes[i] = Vect_line_to_geos(Map, Points, GV_BOUNDARY);
return GEOSGeom_createPolygon(boundary, holes, nholes);
@@ -112,9 +112,9 @@
Supported types:
- GV_POINT -> POINT
- - GV_BOUNDARY -> LINERING
+ - GV_BOUNDARY -> LINEARRING
\param type feature type (see supported types)
@@ -122,38 +122,38 @@
-GEOSGeometry *Vect_line_to_geos(const struct Map_info * Map,
+GEOSGeometry *Vect_line_to_geos(struct Map_info * Map,
const struct line_pnts * points, int type)
- int i, dim;
+ int i, with_z;
GEOSGeometry *geom;
GEOSCoordSequence *pseq;
- G_debug(3, "Vect_line_to_geos(type=%d)", type);
+ G_debug(3, "Vect_line_to_geos(): type = %d", type);
+ with_z = Vect_is_3d(Map);
+ /* read only points / lines / boundaries */
+ if (!(type & (GV_POINT | GV_LINES)))
+ return NULL;
- dim = 3;
- else
- dim = 2;
- if (type == GV_POINT) {
+ if (type == GV_POINT) {
if (points->n_points != 1)
+ /* point is not valid */
return NULL;
- else { /* GV_LINES */
+ else {
if (points->n_points < 2)
+ /* line/boundary is not valid */
return NULL;
- if (!(type & (GV_POINT | GV_LINES)))
- return NULL;
- pseq = GEOSCoordSeq_create(points->n_points, dim);
+ pseq = GEOSCoordSeq_create(points->n_points, with_z ? 3 : 2);
for (i = 0; i < points->n_points; i++) {
GEOSCoordSeq_setX(pseq, i, points->x[i]);
GEOSCoordSeq_setY(pseq, i, points->y[i]);
- if (dim == 3)
+ if (with_z)
GEOSCoordSeq_setZ(pseq, i, points->z[i]);
@@ -161,16 +161,355 @@
geom = GEOSGeom_createPoint(pseq);
else if (type == GV_LINE)
geom = GEOSGeom_createLineString(pseq);
- else { /* GV_BOUNDARY */
+ else { /* boundary */
if (GEOSisRing(geom)) {
/* GEOSGeom_destroy(geom); */
geom = GEOSGeom_createLinearRing(pseq);
/* GEOSCoordSeq_destroy(pseq); */
return geom;
+ \brief Read line from coor file
+ \param Map pointer to Map_info
+ \param offset line offset
+ \return pointer to GEOSGeometry
+ \return NULL on error
+ \return NULL dead line
+ \return NULL end of file
+GEOSGeometry *Vect__read_line_geos(struct Map_info *Map, long offset)
+ int type;
+ double *x, *y, *z;
+ GEOSGeometry *geom;
+ GEOSCoordSequence *pseq;
+ pseq = V1_read_line_geos(Map, offset);
+ if (!pseq)
+ G_fatal_error(_("Unable to read line offset %ld"), offset);
+ if (type & GV_POINT) {
+ G_debug(3, " geos_type = point");
+ geom = GEOSGeom_createPoint(pseq);
+ else if (type & GV_LINE) {
+ G_debug(3, " geos_type = linestring");
+ geom = GEOSGeom_createLineString(pseq);
+ if (GEOSisRing(geom)) {
+ /* GEOSGeom_destroy(geom); */
+ geom = GEOSGeom_createLinearRing(pseq);
+ G_debug(3, " geos_type = linearring");
+ else {
+ G_free((void *) x);
+ G_free((void *) y);
+ if (z)
+ G_free((void *) z);
+ /* GEOSCoordSeq_destroy(pseq); */
+ return geom;
+ \brief Read line from coor file into GEOSCoordSequence
+ You should free allocated memory by GEOSCoordSeq_destroy().
+ \param line line id
+ \return pointer to GEOSCoordSequence
+ \return empty GEOSCoordSequence for dead line or unsuppored feature type
+GEOSCoordSequence *V2_read_line_geos(struct Map_info *Map, int line)
+ P_LINE *Line;
+ G_debug(3, "V2_read_line_geos(): line = %d", line);
+ if (Line == NULL)
+ G_fatal_error("V2_read_line_geos(): %s %d",
+ return V1_read_line_geos(Map, Line->offset);
+ \brief Read feature from coor file into GEOSCoordSequence
+ Note: Function reads only points, lines and boundaries, other
+ feature types are ignored (empty coord array is returned)!
+GEOSCoordSequence *V1_read_line_geos(struct Map_info *Map, long offset)
+ int i, n_points, type;
+ char rhead;
+ G_debug(3, "V1_read_line_geos(): offset = %ld", offset);
+ Map->head.last_offset = offset;
+ /* reads must set in_head, but writes use default */
+ dig_set_cur_port(&(Map->head.port));
+ dig_fseek(&(Map->dig_fp), offset, 0);
+ if (0 >= dig__fread_port_C(&rhead, 1, &(Map->dig_fp)))
+ return NULL; /* end of file */
+ if (!(rhead & 0x01)) /* dead line */
+ return GEOSCoordSeq_create(0, (Map->head.with_z) ? 3 : 2);
+ rhead >>= 2;
+ type = dig_type_from_store((int)rhead);
+ if (type & GV_POINTS) {
+ n_points = 1;
+ else {
+ if (0 >= dig__fread_port_I(&n_points, 1, &(Map->dig_fp)))
+ return NULL;
+ G_debug(3, " n_points = %d dim = %d", n_points, (Map->head.with_z) ? 3 : 2);
+ pseq = GEOSCoordSeq_create(n_points, (Map->head.with_z) ? 3 : 2);
+ x = (double *) G_malloc(n_points * sizeof(double));
+ y = (double *) G_malloc(n_points * sizeof(double));
+ if (Map->head.with_z)
+ z = (double *) G_malloc(n_points * sizeof(double));
+ else
+ z = NULL;
+ if (0 >= dig__fread_port_D(x, n_points, &(Map->dig_fp)))
+ if (0 >= dig__fread_port_D(y, n_points, &(Map->dig_fp)))
+ if (Map->head.with_z) {
+ if (0 >= dig__fread_port_D(z, n_points, &(Map->dig_fp)))
+ for (i = 0; i < n_points; i++) {
+ GEOSCoordSeq_setX(pseq, i, x[i]);
+ GEOSCoordSeq_setY(pseq, i, y[i]);
+ GEOSCoordSeq_setZ(pseq, i, z[i]);
+ G_debug(3, " off = %ld", dig_ftell(&(Map->dig_fp)));
+ if (z)
+ return pseq;
+ \brief Returns the polygon array of points, i.e. outer ring (shell)
+ See also Vect_get_area_points().
+ \param area area id
+ \return empty GEOSCoordSequence for dead area
+GEOSCoordSequence *Vect_get_area_points_geos(struct Map_info *Map, int area)
+ int i, j, k;
+ int line, aline;
+ unsigned int n_points, n_points_shell;
+ double x, y, z;
+ struct Plus_head *Plus;
+ P_AREA *Area;
+ GEOSCoordSequence **pseq, *pseq_shell;
+ G_debug(3, "Vect_get_area_points_geos(): area = %d", area);
+ Plus = &(Map->plus);
+ Area = Plus->Area[area];
+ if (Area == NULL) { /* dead area */
+ G_warning(_("Attempt to read points of nonexistent area id %d"), area);
+ return NULL; /* error , because we should not read dead areas */
+ G_debug(3, " n_lines = %d", Area->n_lines);
+ pseq = (GEOSCoordSequence **) G_malloc(Area->n_lines * sizeof(GEOSCoordSequence *));
+ n_points_shell = 0;
+ for (i = 0; i < Area->n_lines; i++) {
+ line = Area->lines[i];
+ aline = abs(line);
+ G_debug(3, " append line(%d) = %d", i, line);
+ TODO
+ if (line > 0)
+ dir = GV_FORWARD;
+ else
+ dir = GV_BACKWARD;
+ pseq[i] = V2_read_line_geos(Map, aline);
+ if (!(pseq[i])) {
+ G_fatal_error(_("Unable to read feature id %d"), aline);
+ GEOSCoordSeq_getSize(pseq[i], &n_points);
+ G_debug(3, " line n_points = %d", n_points);
+ n_points_shell += n_points;
+ /* create shell (outer ring) */
+ pseq_shell = GEOSCoordSeq_create(n_points_shell, Map->head.with_z ? 3 : 2);
+ k = 0;
+ for (j = 0; j < (int) n_points; j++, k++) {
+ GEOSCoordSeq_getX(pseq[i], j, &x);
+ GEOSCoordSeq_setX(pseq_shell, k, x);
+ GEOSCoordSeq_getY(pseq[i], j, &y);
+ GEOSCoordSeq_setY(pseq_shell, k, y);
+ GEOSCoordSeq_getY(pseq[i], j, &z);
+ GEOSCoordSeq_setZ(pseq_shell, k, z);
+ G_free((void *) pseq);
+ return pseq_shell;
+ \brief Returns the polygon (isle) array of points (inner ring)
+ See also Vect_get_isle_points().
+ \param isle isel id
+ \return NULL on error or dead line
+GEOSCoordSequence *Vect_get_isle_points_geos(struct Map_info *Map, int isle)
+ int i, j, k;
+ int line, aline;
+ unsigned n_points, n_points_shell;
+ double x, y, z;
+ P_ISLE *Isle;
+ G_debug(3, "Vect_get_isle_points_geos(): isle = %d", isle);
+ Isle = Plus->Isle[isle];
+ G_debug(3, " n_lines = %d", Isle->n_lines);
+ for (i = 0; i < Isle->n_lines; i++) {
+ line = Isle->lines[i];
+ if (!(pseq[i])) {
+ TODO
+ if (line > 0)
+ dir = GV_FORWARD;
+ else
+ k = 0;
#endif /* HAVE_GEOS */
