[GRASS-SVN] r37374 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Fri May 22 11:36:57 EDT 2009
Author: martinl
Date: 2009-05-22 11:36:57 -0400 (Fri, 22 May 2009)
New Revision: 37374
Added:
grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI prompt in separate module
(merge from trunk, r37373)
Copied: grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py (from rev 37373, grass/trunk/gui/wxpython/gui_modules/prompt.py)
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2009-05-22 15:36:57 UTC (rev 37374)
@@ -0,0 +1,96 @@
+ at package prompt.py
+ at brief GRASS prompt
+Classes:
+ - GPrompt
+(C) 2009 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Martin Landa <landa.martin gmail.com>
+import wx
+class GPrompt:
+ """Interactive GRASS prompt"""
+ def __init__(self, parent):
+ self.parent = parent
+ self.panel, self.input = self.__create()
+ def __create(self):
+ """Create widget"""
+ cmdprompt = wx.Panel(self.parent)
+ label = wx.Button(parent = cmdprompt, id = wx.ID_ANY,
+ label = _("Cmd >"), size = (-1, 25))
+ label.SetToolTipString(_("Click for erasing command prompt"))
+ cmdinput = wx.TextCtrl(parent = cmdprompt, id = wx.ID_ANY,
+ value = "",
+ style = wx.TE_LINEWRAP | wx.TE_PROCESS_ENTER,
+ size = (-1, 25))
+ cmdinput.SetFont(wx.Font(10, wx.FONTFAMILY_MODERN, wx.NORMAL, wx.NORMAL, 0, ''))
+ wx.CallAfter(cmdinput.SetInsertionPoint, 0)
+ label.Bind(wx.EVT_BUTTON, self.OnCmdErase)
+ cmdinput.Bind(wx.EVT_TEXT_ENTER, self.OnRunCmd)
+ cmdinput.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
+ # layout
+ sizer = wx.BoxSizer(wx.HORIZONTAL)
+ sizer.Add(item = label, proportion = 0,
+ flag = wx.EXPAND | wx.LEFT | wx.RIGHT |
+ wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER,
+ border = 3)
+ sizer.Add(item = cmdinput, proportion = 1,
+ flag = wx.EXPAND | wx.ALL,
+ border = 1)
+ cmdprompt.SetSizer(sizer)
+ sizer.Fit(cmdprompt)
+ cmdprompt.Layout()
+ return cmdprompt, cmdinput
+ def GetPanel(self):
+ """Get main widget panel"""
+ return self.panel
+ def OnCmdErase(self, event):
+ """Erase command prompt"""
+ self.input.SetValue('')
+ def OnRunCmd(self, event):
+ """Run command"""
+ cmd = event.GetString()
+ if self.parent.GetName() != "LayerManager":
+ return
+ if cmd[:2] == 'd.' and not self.parent.curr_page:
+ self.parent.NewDisplay(show=True)
+ if len(cmd.split(' ')) > 1:
+ self.parent.goutput.RunCmd(cmd, switchPage = True)
+ else:
+ self.parent.goutput.RunCmd(cmd, switchPage = False)
+ self.OnUpdateStatusBar(None)
+ def OnUpdateStatusBar(self, event):
+ """Update Layer Manager status bar"""
+ return
+ if event is None:
+ self.parent.statusbar.SetStatusText("")
+ else:
+ self.parent.statusbar.SetStatusText(_("Type GRASS command and run by pressing ENTER"))
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2009-05-22 15:32:17 UTC (rev 37373)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2009-05-22 15:36:57 UTC (rev 37374)
@@ -86,6 +86,7 @@
import gui_modules.gdialogs as gdialogs
import gui_modules.colorrules as colorrules
import gui_modules.ogc_services as ogc_services
+import gui_modules.prompt as prompt
from gui_modules.debug import Debug as Debug
from icons.icon import Icons as Icons
@@ -189,58 +190,11 @@
# start with layer manager on top
self.curr_page.maptree.mapdisplay.Raise()
self.Raise()
- def __doLayout(self):
- """Do Layout (unused bacause of aui manager...)"""
- # self.panel = wx.Panel(self,-1, style= wx.EXPAND)
- # sizer= wx.BoxSizer(wx.VERTICAL)
- # self.cmdsizer = wx.BoxSizer(wx.HORIZONTAL)
- # item, proportion, flag, border, userData
- # self.sizer.Add(self.notebook, proportion=1, flag=wx.EXPAND, border=1)
- # self.sizer.Add(self.cmdinput, proportion=0, flag=wx.EXPAND, border=1)
- # self.SetSizer(self.sizer)
- # self.sizer.Fit(self)
- # self.Layout()
def __createCommandPrompt(self):
"""Creates command-line input area"""
- self.cmdprompt = wx.Panel(self)
- label = wx.Button(parent=self.cmdprompt, id=wx.ID_ANY,
- label=_("Cmd >"), size=(-1, 25))
- label.SetToolTipString(_("Click for erasing command prompt"))
- self.cmdinput = wx.TextCtrl(parent=self.cmdprompt, id=wx.ID_ANY,
- value="",
- style=wx.TE_LINEWRAP | wx.TE_PROCESS_ENTER,
- size=(-1, 25))
- self.cmdinput.SetFont(wx.Font(10, wx.FONTFAMILY_MODERN, wx.NORMAL, wx.NORMAL, 0, ''))
- wx.CallAfter(self.cmdinput.SetInsertionPoint, 0)
- label.Bind(wx.EVT_BUTTON, self.OnCmdErase)
- self.Bind(wx.EVT_TEXT_ENTER, self.OnRunCmd, self.cmdinput)
- self.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar, self.cmdinput)
- # layout
- sizer = wx.BoxSizer(wx.HORIZONTAL)
- sizer.Add(item=label, proportion=0,
- flag=wx.EXPAND | wx.LEFT | wx.RIGHT | \
- wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER,
- border=3)
- sizer.Add(item=self.cmdinput, proportion=1,
- flag=wx.EXPAND | wx.ALL,
- border=1)
- self.cmdprompt.SetSizer(sizer)
- sizer.Fit(self.cmdprompt)
- self.cmdprompt.Layout()
- return self.cmdprompt
+ return prompt.GPrompt(self).GetPanel()
def __createMenuBar(self):
"""Creates menubar"""
@@ -452,35 +406,11 @@
self.curr_page = None
event.Skip()
- def OnRunCmd(self, event):
- """Run command"""
- cmd = event.GetString()
- if cmd[:2] == 'd.' and not self.curr_page:
- self.NewDisplay(show=True)
- if len(cmd.split(' ')) > 1:
- self.goutput.RunCmd(cmd, switchPage=True)
- else:
- self.goutput.RunCmd(cmd, switchPage=False)
- self.OnUpdateStatusBar(None)
- def OnCmdErase(self, event):
- """Erase command prompt"""
- self.cmdinput.SetValue('')
def GetLogWindow(self):
"""Get widget for command output"""
return self.goutput
- def OnUpdateStatusBar(self, event):
- if event is None:
- self.statusbar.SetStatusText("")
- else:
- self.statusbar.SetStatusText(_("Type GRASS command and run by pressing ENTER"))
def GetMenuCmd(self, event):
"""Get GRASS command from menu item
