[GRASS-SVN] r37375 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Fri May 22 11:53:52 EDT 2009
Author: cdavilam
Date: 2009-05-22 11:53:49 -0400 (Fri, 22 May 2009)
New Revision: 37375
grass/branches/develbranch_6/locale/po/grasslibs_es.po
grass/branches/develbranch_6/locale/po/grasslibs_ru.po
grass/branches/develbranch_6/locale/po/grassmods_es.po
grass/branches/develbranch_6/locale/po/grassmods_ru.po
grass/branches/develbranch_6/locale/po/grasstcl_es.po
grass/branches/develbranch_6/locale/po/grasstcl_ru.po
grass/branches/develbranch_6/locale/po/grasswxpy_es.po
grass/branches/develbranch_6/locale/po/grasswxpy_ru.po
ru: translations by Maxim Dubinin team and updated; es: updated
Modified: grass/branches/develbranch_6/locale/po/grasslibs_es.po
--- grass/branches/develbranch_6/locale/po/grasslibs_es.po 2009-05-22 15:36:57 UTC (rev 37374)
+++ grass/branches/develbranch_6/locale/po/grasslibs_es.po 2009-05-22 15:53:49 UTC (rev 37375)
@@ -14,7 +14,7 @@
msgstr ""
"Project-Id-Version: grasslibs_es\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2009-01-29 21:41+0100\n"
+"POT-Creation-Date: 2009-05-22 17:09+0200\n"
"PO-Revision-Date: 2009-01-29 21:14+0100\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -418,16 +418,16 @@
#: ../lib/gpde/N_arrays_io.c:55 ../lib/gis/legal_name.c:94
#: ../lib/gis/legal_name.c:97 ../lib/gis/opencell.c:1011
-#: ../lib/ogsf/gsd_legend.c:238 ../lib/ogsf/Gs3.c:126 ../lib/ogsf/Gs3.c:200
-#: ../lib/ogsf/Gs3.c:284 ../lib/ogsf/Gs3.c:357 ../lib/ogsf/Gs3.c:472
-#: ../lib/ogsf/Gs3.c:568 ../lib/ogsf/Gs3.c:635 ../lib/ogsf/Gs3.c:692
-#: ../lib/ogsf/Gs3.c:761 ../lib/ogsf/Gs3.c:829 ../lib/ogsf/Gp3.c:54
+#: ../lib/ogsf/gsd_legend.c:238 ../lib/ogsf/Gs3.c:126 ../lib/ogsf/Gs3.c:201
+#: ../lib/ogsf/Gs3.c:286 ../lib/ogsf/Gs3.c:359 ../lib/ogsf/Gs3.c:475
+#: ../lib/ogsf/Gs3.c:572 ../lib/ogsf/Gs3.c:639 ../lib/ogsf/Gs3.c:696
+#: ../lib/ogsf/Gs3.c:766 ../lib/ogsf/Gs3.c:835 ../lib/ogsf/Gp3.c:54
#, c-format
msgid "Raster map <%s> not found"
msgstr "No se encuentra el mapa ráster <%s>"
-#: ../lib/gpde/N_arrays_io.c:67 ../lib/ogsf/Gs3.c:137 ../lib/ogsf/Gs3.c:211
-#: ../lib/ogsf/Gs3.c:368 ../lib/ogsf/Gs3.c:483 ../lib/ogsf/Gs3.c:573
+#: ../lib/gpde/N_arrays_io.c:67 ../lib/ogsf/Gs3.c:137 ../lib/ogsf/Gs3.c:212
+#: ../lib/ogsf/Gs3.c:370 ../lib/ogsf/Gs3.c:486 ../lib/ogsf/Gs3.c:577
#, c-format
msgid "Unable to open raster map <%s>"
msgstr "No se puede abrir el mapa ráster <%s>"
@@ -810,46 +810,59 @@
msgid "Unable to delete isle %d from spatial index"
msgstr "No se puede borrar la isla %d del índice espacial"
-#: ../lib/vector/diglib/plus_area.c:195 ../lib/vector/diglib/plus_area.c:651
-#: ../lib/vector/diglib/plus_area.c:659
+#: ../lib/vector/diglib/plus_area.c:207 ../lib/vector/diglib/plus_area.c:675
+#: ../lib/vector/diglib/plus_area.c:683
#, c-format
msgid "Line %d already has area/isle %d to left"
msgstr "La línea %d ya tiene el area/isla %d a la izquierda"
-#: ../lib/vector/diglib/plus_area.c:205
+#: ../lib/vector/diglib/plus_area.c:217
#, c-format
msgid "Line %d already has area/isle %d to right"
msgstr "La línea %d ya tiene el area/isla %d a la derecha"
-#: ../lib/vector/diglib/plus_area.c:287
+#: ../lib/vector/diglib/plus_area.c:299
msgid "Attempt to delete isle from dead area"
msgstr "Intento de borrar una isla de un área inexistente"
-#: ../lib/vector/diglib/plus_area.c:304
+#: ../lib/vector/diglib/plus_area.c:316
#, c-format
msgid "Attempt to delete not registered isle %d from area %d"
msgstr "Intento de borrar la isla no registrada %d del área %d"
-#: ../lib/vector/diglib/plus_area.c:342
+#: ../lib/vector/diglib/plus_area.c:354
msgid "Attempt to delete dead area"
msgstr "Intento de borrar un área inexistente"
-#: ../lib/vector/diglib/plus_area.c:382
+#: ../lib/vector/diglib/plus_area.c:394
#, c-format
msgid "Dead centroid %d registered for area (bug in the vector library)"
msgstr ""
"Centroide inexistente %d registrado para el área (error en la biblioteca)"
-#: ../lib/vector/diglib/plus_area.c:406
+#: ../lib/vector/diglib/plus_area.c:418
#, c-format
msgid "Attempt to delete area %d info from dead isle %d"
msgstr "Intento de borrar infomación del área %d de la isla inexistente %d"
-#: ../lib/vector/diglib/plus_area.c:749
+#: ../lib/vector/diglib/plus_area.c:773
#, c-format
msgid "Attempt to delete isle %d info from dead area %d"
msgstr "Intento de borrar información de la isla %d de un área inexistente %d"
+#: ../lib/vector/diglib/file.c:157
+msgid "Writing to file loaded to memory not supported"
+msgstr ""
+#: ../lib/vector/diglib/file.c:200
+#, fuzzy
+msgid "Unable to load file to memory, file not open"
+msgstr "No se puede abrir el archivo temporal"
+#: ../lib/vector/diglib/file.c:215
+msgid "Vector memory mode not supported, using 'AUTO'"
+msgstr ""
#: ../lib/vector/diglib/plus.c:288
msgid "Unable read topology for nodes"
@@ -924,7 +937,7 @@
"Intento de leer el ángulo de la línea que no está conectada al nodo: nodo %"
"d, línea %d"
-#: ../lib/vector/vedit/select.c:234
+#: ../lib/vector/vedit/select.c:233
msgid "Unknown query tool"
msgstr "Herramienta de consulta desconocida"
@@ -1251,7 +1264,7 @@
msgid "Output vector map <%s> is used as input"
msgstr "El mapa vectorial de salida <%s> se está usando como entrada"
-#: ../lib/vector/Vlib/read.c:99
+#: ../lib/vector/Vlib/read.c:99 ../lib/vector/Vlib/geos.c:54
msgid "vector map is not opened"
msgstr "el mapa vectorial no está abierto"
@@ -1316,7 +1329,7 @@
msgstr ""
"Demasiadas categorías (%d), no se puede establecer la categoría %d (capa %d)"
-#: ../lib/vector/Vlib/cats.c:376
+#: ../lib/vector/Vlib/cats.c:407
#, c-format
msgid "Unable to convert category string '%s' (from '%s') to category range"
msgstr ""
@@ -1340,19 +1353,19 @@
"No se puede construir el índice espacial a partir de la topología, el mapa "
"vectorial no está abierto en el nivel topológico 2."
-#: ../lib/vector/Vlib/sindex.c:166
+#: ../lib/vector/Vlib/sindex.c:168
msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
msgstr "BUG (Vect_build_sidx_from_topo): el nodo no existe."
-#: ../lib/vector/Vlib/sindex.c:176
+#: ../lib/vector/Vlib/sindex.c:180
msgid "BUG (Vect_build_sidx_from_topo): line does not exist"
msgstr "BUG (Vect_build_sidx_from_topo): la línea no existe."
-#: ../lib/vector/Vlib/sindex.c:193
+#: ../lib/vector/Vlib/sindex.c:199
msgid "BUG (Vect_build_sidx_from_topo): area does not exist"
msgstr "BUG (Vect_build_sidx_from_topo): el área no existe."
-#: ../lib/vector/Vlib/sindex.c:210
+#: ../lib/vector/Vlib/sindex.c:218
msgid "BUG (Vect_build_sidx_from_topo): isle does not exist"
msgstr "BUG (Vect_build_sidx_from_topo): la isla no existe."
@@ -1385,7 +1398,7 @@
msgid "Unable to add network arc"
msgstr "No se puede añadir unarco a la red."
-#: ../lib/vector/Vlib/graph.c:231 ../lib/vector/Vlib/net.c:509
+#: ../lib/vector/Vlib/graph.c:231 ../lib/vector/Vlib/net.c:514
#, c-format
msgid "dglShortestPath error: %s"
msgstr "Error de dglShortestPath: %s"
@@ -1406,43 +1419,43 @@
msgid "Request to find area outside nonexistent isle"
msgstr "Solicitud de encontrar un área fuera de una isla inexistente."
-#: ../lib/vector/Vlib/build_nat.c:507
+#: ../lib/vector/Vlib/build_nat.c:514
msgid "Registering primitives..."
msgstr "Registrando elementos..."
-#: ../lib/vector/Vlib/build_nat.c:516
+#: ../lib/vector/Vlib/build_nat.c:523
msgid "Unable to read vector map"
msgstr "No se puede leer el mapa vectorial."
-#: ../lib/vector/Vlib/build_nat.c:560
+#: ../lib/vector/Vlib/build_nat.c:567
#, c-format
msgid "%d primitives registered"
msgstr "%d Elementos registrados."
-#: ../lib/vector/Vlib/build_nat.c:561
+#: ../lib/vector/Vlib/build_nat.c:568
#, c-format
msgid "%d vertices registered"
msgstr "%d vértices registrados."
-#: ../lib/vector/Vlib/build_nat.c:572
+#: ../lib/vector/Vlib/build_nat.c:579
msgid "Building areas..."
msgstr "Construyendo áreas..."
-#: ../lib/vector/Vlib/build_nat.c:595
+#: ../lib/vector/Vlib/build_nat.c:602
#, c-format
msgid "%d areas built"
msgstr "%d áreas construidas."
-#: ../lib/vector/Vlib/build_nat.c:596
+#: ../lib/vector/Vlib/build_nat.c:603
#, c-format
msgid "%d isles built"
msgstr "%d Islas construidas."
-#: ../lib/vector/Vlib/build_nat.c:605
+#: ../lib/vector/Vlib/build_nat.c:612
msgid "Attaching islands..."
msgstr "Adjuntando islas..."
-#: ../lib/vector/Vlib/build_nat.c:620
+#: ../lib/vector/Vlib/build_nat.c:627
msgid "Attaching centroids..."
msgstr "Adjuntando centroides..."
@@ -1572,7 +1585,8 @@
msgid "Area is composed of dead boundary"
msgstr "El área está compuesta por un contorno inexistente"
-#: ../lib/vector/Vlib/read_nat.c:136
+#: ../lib/vector/Vlib/read_nat.c:136 ../lib/vector/Vlib/geos.c:67
+#: ../lib/vector/Vlib/geos.c:257
msgid "Attempt to read dead line"
msgstr "Intento de leer una línea inexistente"
@@ -1840,11 +1854,11 @@
msgid "Flattening the graph..."
msgstr "Aplanando el gráfo..."
-#: ../lib/vector/Vlib/net.c:439
+#: ../lib/vector/Vlib/net.c:438
msgid "Graph was built"
msgstr "El grafo fue creado"
-#: ../lib/vector/Vlib/net.c:590
+#: ../lib/vector/Vlib/net.c:595
msgid "Wrong line direction in Vect_net_get_line_cost()"
msgstr "Dirección de línea errónea en 'Vect_net_get_line_cost()'"
@@ -1962,6 +1976,46 @@
msgid "Vect_get_point_in_poly() failed"
msgstr "Ha fallado Vect_get_point_in_poly() "
+#: ../lib/vector/Vlib/geos.c:57
+#, fuzzy, c-format
+msgid ""
+"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
+"vector map <%s>: %d)"
+msgstr ""
+"Vect_read_line(): el identificador del razgo id %d no es razonable (El "
+"número máximo de rasgos en el mapa vector es <%s>: %d)"
+#: ../lib/vector/Vlib/geos.c:62
+#, fuzzy
+msgid "only native format supported"
+msgstr "no soportado para este formato/nivel"
+#: ../lib/vector/Vlib/geos.c:92
+#, c-format
+msgid "Vect_read_area_geos(): unable to read area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:106
+#, c-format
+msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:204
+#, fuzzy, c-format
+msgid "Unable to read line offset %ld"
+msgstr "No se puede leer la línea %d"
+#: ../lib/vector/Vlib/geos.c:411
+#, fuzzy, c-format
+msgid "Attempt to read points of nonexistent area id %d"
+msgstr "Intento de leer puntos de un área inexistente."
+#: ../lib/vector/Vlib/geos.c:471
+#, fuzzy, c-format
+msgid "Unable to read feature id %d"
+msgstr "No se puede reescribir el razgo. %d"
#: ../lib/vask/V_support.c:58
#, c-format
msgid "Unable to open file %s"
@@ -2026,15 +2080,15 @@
msgid "Error in datum table file <%s>, line %d"
msgstr "Error en el archivo de la tabla de datum <%s>, línea %d"
-#: ../lib/proj/convert.c:108
+#: ../lib/proj/convert.c:110
msgid "Unable parse GRASS PROJ_INFO file"
msgstr "No se puede analizar el archivo PROJ_INFO de GRASS"
-#: ../lib/proj/convert.c:113
+#: ../lib/proj/convert.c:115
msgid "Unable get PROJ.4-style parameter string"
msgstr "No se puede obtener la cadena de parámetros estilo PROJ.4"
-#: ../lib/proj/convert.c:125
+#: ../lib/proj/convert.c:127
#, c-format
msgid ""
"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
@@ -2042,26 +2096,26 @@
"OGR no puede analizar la cadena de parámetros estilo PROJ.4: %s (El código "
"de error de OGR fue %d)"
-#: ../lib/proj/convert.c:131
+#: ../lib/proj/convert.c:133
#, c-format
msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
msgstr ""
"OGR no puede obtener la cadena de parámetros estilo WKT (El código de error "
"de OGR fue %d)"
-#: ../lib/proj/convert.c:384
+#: ../lib/proj/convert.c:390
msgid "No projection name! Projection parameters likely to be meaningless."
msgstr ""
"¡Ningún nombre de proyección! Los parámetros de proyección probablemente no "
"tengan sentido."
-#: ../lib/proj/convert.c:420
+#: ../lib/proj/convert.c:426
#, c-format
msgid "Datum <%s> not recognised by GRASS and no parameters found"
msgstr ""
"El datum <%s> no es reconocido por GRASS y no se han encontrado parámetos"
-#: ../lib/proj/convert.c:436
+#: ../lib/proj/convert.c:442
#, c-format
msgid ""
"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
@@ -2070,7 +2124,7 @@
"El datum <%s> aparentemente es reconocido por GRASS, pero no se han "
"encontrado parámetros. Quizá quiera revisar esto."
-#: ../lib/proj/convert.c:440
+#: ../lib/proj/convert.c:446
#, c-format
msgid ""
"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
@@ -2558,50 +2612,50 @@
msgid "Too many arguments"
msgstr "Demasiados argumentos"
-#: ../lib/gis/spawn.c:133 ../lib/gis/spawn.c:401
+#: ../lib/gis/spawn.c:133 ../lib/gis/spawn.c:400
msgid "Unable to create a new process"
msgstr "No se puede crear un nuevo proceso"
-#: ../lib/gis/spawn.c:142 ../lib/gis/spawn.c:237 ../lib/gis/spawn.c:424
+#: ../lib/gis/spawn.c:142 ../lib/gis/spawn.c:236 ../lib/gis/spawn.c:423
msgid "Unable to execute command"
msgstr "No se puede ejecutar el comando"
-#: ../lib/gis/spawn.c:262 ../lib/gis/spawn.c:270
+#: ../lib/gis/spawn.c:261 ../lib/gis/spawn.c:269
#, c-format
msgid "G_spawn: unable to restore signal %d"
msgstr "G_spawn: no es posible restablecer la señal %d"
-#: ../lib/gis/spawn.c:301
+#: ../lib/gis/spawn.c:300
#, c-format
msgid "G_spawn: unable to reset signal %d"
-#: ../lib/gis/spawn.c:310
+#: ../lib/gis/spawn.c:309
#, c-format
msgid "G_spawn: unable to ignore signal %d"
msgstr "G_spawn: no es posible ignorar la señal %d"
-#: ../lib/gis/spawn.c:321
+#: ../lib/gis/spawn.c:320
#, c-format
msgid "G_spawn: unable to block signal %d"
msgstr "G_spawn: no es posible bloquear la señal %d"
-#: ../lib/gis/spawn.c:329
+#: ../lib/gis/spawn.c:328
#, c-format
msgid "G_spawn: unable to unblock signal %d"
msgstr "G_spawn: no es posible desbloquear la señal %d"
-#: ../lib/gis/spawn.c:353
+#: ../lib/gis/spawn.c:352
#, c-format
msgid "G_spawn: unable to open file %s"
msgstr "G_spawn: no es posible abrir el archivo %s"
-#: ../lib/gis/spawn.c:358 ../lib/gis/spawn.c:367
+#: ../lib/gis/spawn.c:357 ../lib/gis/spawn.c:366
#, c-format
msgid "G_spawn: unable to duplicate descriptor %d to %d"
msgstr "G_spawn: no es posible duplicar el descriptor %d a %d"
-#: ../lib/gis/spawn.c:416
+#: ../lib/gis/spawn.c:415
#, c-format
msgid "Unable to change directory to %s"
msgstr "No se puede cambiar el directorio a %s"
@@ -2639,7 +2693,7 @@
msgid "MAPSET is not set"
msgstr "directorio de mapas no está inicializado"
-#: ../lib/gis/mapset.c:57 ../lib/gis/gisinit.c:65
+#: ../lib/gis/mapset.c:57 ../lib/gis/gisinit.c:66
#, c-format
msgid "MAPSET %s not found"
msgstr "directorio de mapas %s no encontrado"
@@ -2750,16 +2804,18 @@
msgstr ""
"no es posible escribir el archivo conteniendo los rangos para [%s en %s]"
-#: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:89
-msgid "Incompatible library version for module"
-msgstr "Versión de librería incompatible para el módulo."
+#: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:90
+msgid ""
+"Incompatible library version for module. You need to rebuild GRASS or "
+"untangle multiple installations."
+msgstr ""
-#: ../lib/gis/gisinit.c:62
+#: ../lib/gis/gisinit.c:63
#, c-format
msgid "MAPSET %s - permission denied"
msgstr "directorio de mapas %s - permiso denegado"
-#: ../lib/gis/gisinit.c:108
+#: ../lib/gis/gisinit.c:110
msgid "System not initialized. Programmer forgot to call G_gisinit()."
msgstr ""
"El sistema no está inicializado. El programador olvidó llamar a G_gisinit()."
@@ -3064,24 +3120,11 @@
msgid "LOCATION << %s >> not available"
msgstr "LOCALIZACIÓN << %s >> no disponible"
-#: ../lib/gis/null_val.c:91
+#: ../lib/gis/null_val.c:68
msgid "EmbedGivenNulls: wrong data type!"
msgstr "EmbedGivenNulls: tipo de dato incorrecto!"
-#: ../lib/gis/null_val.c:112
-msgid "Null values have not been initialized. "
-msgstr "Valores nulos no han sido inicializados. "
-#: ../lib/gis/null_val.c:113
-msgid "G_gisinit() must be called first. "
-msgstr "G_gisinit() debe ser llamado primero. "
-#: ../lib/gis/null_val.c:114
-msgid "Please advise GRASS developers of this error.\n"
-msgstr ""
-"Por favor notifique a los desarrolladores de GRASS acerca de este error.\n"
-#: ../lib/gis/null_val.c:223
+#: ../lib/gis/null_val.c:128
msgid "G_set_null_value: wrong data type!"
msgstr "G_set_null_value: ¡tipo de dato incorrecto!"
@@ -3104,9 +3147,9 @@
"G_distance_point_to_line_segment: Esto no debería ocurrir: code=%d P=(%f,%f) "
"S=(%f,%f)(%f,%f)"
-#: ../lib/gis/mapset_msc.c:60
-#, c-format
-msgid "Unable to make mapset element %s (%s)"
+#: ../lib/gis/mapset_msc.c:60 ../lib/gis/mapset_msc.c:64
+#, fuzzy, c-format
+msgid "Unable to make mapset element %s (%s): %s"
msgstr "No se puede generar el elemento %s (%s) del directorio de mapas"
#: ../lib/gis/parser.c:328
@@ -4418,30 +4461,30 @@
msgid "Try using smaller font!"
msgstr "¡Intente utilizar una fuente más pequeña!"
-#: ../lib/ogsf/Gs3.c:133 ../lib/ogsf/Gs3.c:207 ../lib/ogsf/Gs3.c:364
-#: ../lib/ogsf/Gs3.c:479 ../lib/ogsf/Gs3.c:583
+#: ../lib/ogsf/Gs3.c:133 ../lib/ogsf/Gs3.c:208 ../lib/ogsf/Gs3.c:366
+#: ../lib/ogsf/Gs3.c:482 ../lib/ogsf/Gs3.c:587
msgid "Unable to allocate memory for a null buffer"
msgstr "No se puede asignar memoria para un buffer nulo"
-#: ../lib/ogsf/Gs3.c:140 ../lib/ogsf/Gs3.c:214 ../lib/ogsf/Gs3.c:376
-#: ../lib/ogsf/Gs3.c:491 ../lib/ogsf/Gs3.c:586
+#: ../lib/ogsf/Gs3.c:140 ../lib/ogsf/Gs3.c:215 ../lib/ogsf/Gs3.c:378
+#: ../lib/ogsf/Gs3.c:494 ../lib/ogsf/Gs3.c:590
#, c-format
msgid "Loading raster map <%s>..."
msgstr "Cargando el mapa ráster <%s>..."
-#: ../lib/ogsf/Gs3.c:643
+#: ../lib/ogsf/Gs3.c:647
#, c-format
msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
msgstr ""
"El rango de la tabla de colores no corresponde con los datos (mincol=%d, "
"maxcol=%d"
-#: ../lib/ogsf/Gs3.c:705 ../lib/ogsf/Gs3.c:775
+#: ../lib/ogsf/Gs3.c:709 ../lib/ogsf/Gs3.c:780
#, c-format
msgid "Translating colors from raster map <%s>..."
msgstr "Traduciendo colores del mapa raster <%s>..."
-#: ../lib/ogsf/Gs3.c:1012
+#: ../lib/ogsf/Gs3.c:1018
msgid "View not saved by this program,there may be some inconsistancies"
msgstr ""
"La vista no ha sido guardada por este programa, pueden existir algunas "
@@ -4852,3 +4895,16 @@
#: ../lib/rst/interp_float/input2d.c:69
msgid "Bitmap mask created"
msgstr "Se ha creado la máscara de mapa de bits"
+#~ msgid "Incompatible library version for module"
+#~ msgstr "Versión de librería incompatible para el módulo."
+#~ msgid "Null values have not been initialized. "
+#~ msgstr "Valores nulos no han sido inicializados. "
+#~ msgid "G_gisinit() must be called first. "
+#~ msgstr "G_gisinit() debe ser llamado primero. "
+#~ msgid "Please advise GRASS developers of this error.\n"
+#~ msgstr ""
+#~ "Por favor notifique a los desarrolladores de GRASS acerca de este error.\n"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_ru.po
--- grass/branches/develbranch_6/locale/po/grasslibs_ru.po 2009-05-22 15:36:57 UTC (rev 37374)
+++ grass/branches/develbranch_6/locale/po/grasslibs_ru.po 2009-05-22 15:53:49 UTC (rev 37375)
@@ -6,8 +6,8 @@
msgstr ""
"Project-Id-Version: grasslibs_ru\n"
-"POT-Creation-Date: 2009-01-09 16:59+0100\n"
-"PO-Revision-Date: 2008-10-08 20:46-0600\n"
+"PO-Revision-Date: 2009-01-27 22:58-0600\n"
"Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
"Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -410,16 +410,16 @@
#, c-format
msgstr "РаÑÑÑовÑй Ñлой <%s> не найден"
#, c-format
msgstr "Ðевозможно оÑкÑÑÑÑ ÑаÑÑÑовÑй Ñлой <%s>"
@@ -453,7 +453,7 @@
#: ../lib/gpde/N_arrays_io.c:227 ../lib/gpde/N_arrays_io.c:232
#: ../lib/gpde/N_arrays_io.c:237
-#, fuzzy, c-format
+#, c-format
msgid "Unable to write raster row %i"
msgstr "Ðевозможно запиÑаÑÑ ÑÑÑÐ¾ÐºÑ ÑаÑÑÑа %i"
@@ -582,9 +582,9 @@
msgstr "Ðевозможно полÑÑиÑÑ ÑпиÑок ÑÐ°Ð±Ð»Ð¸Ñ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
<%s>"
#: ../lib/db/dbmi_client/copy_tab.c:157
-#, fuzzy, c-format
+#, c-format
msgid "Table <%s> already exists in database <%s>"
-msgstr "ТаблиÑа <%s> Ñже пÑиÑÑÑÑÑвÑÐµÑ Ð² базе даннÑÑ
<%s>"
+msgstr "ТаблиÑа <%s> Ñже еÑÑÑ Ð² базе даннÑÑ
<%s>"
#: ../lib/db/dbmi_client/copy_tab.c:199 ../lib/db/dbmi_client/copy_tab.c:276
#: ../lib/db/dbmi_client/table.c:110 ../lib/sites/sites.c:381
@@ -791,47 +791,60 @@
msgstr "Ðевозможно ÑдалиÑÑ Ð¾ÑÑÑов %d из пÑоÑÑÑанÑÑвенного индекÑа"
#, c-format
msgstr "У линии %d Ñже еÑÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½/оÑÑÑов %d Ñлева"
#, c-format
msgstr "У линии %d Ñже еÑÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½/оÑÑÑов %d ÑпÑава"
msgstr "ÐопÑÑка ÑдалиÑÑ Ð¾ÑÑÑов из Ñже Ñдаленного полигона"
#, c-format
msgstr "ÐопÑÑка ÑдалиÑÑ Ð½ÐµÐ·Ð°ÑегиÑÑÑиÑованнÑй оÑÑÑов %d из полигона %d"
msgstr "ÐопÑÑка ÑдалиÑÑ Ñже ÑдаленнÑй полигон"
#, c-format
msgstr ""
"ÐÐ»Ñ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ð° заÑегиÑÑÑиÑован ÑдаленнÑй ÑенÑÑоид %d (баг в векÑоÑной "
"библиоÑеке)"
#, c-format
msgstr "ÐопÑÑка ÑдалиÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ полигоне %d из Ñже Ñдаленного оÑÑÑова %d"
#, c-format
msgstr "ÐопÑÑка ÑдалиÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾Ð± оÑÑÑове %d из Ñже Ñдаленного полигона %d"
+msgstr ""
+#, fuzzy
+msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÑеменнÑй Ñайл"
+msgstr ""
msgstr "Ðевозможно пÑоÑеÑÑÑ ÑÐ¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð´Ð»Ñ Ñзлов"
@@ -896,14 +909,14 @@
msgstr ""
"ÐопÑÑка ÑÑиÑаÑÑ Ñгол линии, коÑоÑÐ°Ñ Ð½Ðµ Ñоединена Ñ Ñзлом: Ñзел %d, Ð»Ð¸Ð½Ð¸Ñ %d"
msgstr "ÐеизвеÑÑнÑй инÑÑÑÑÐ¼ÐµÐ½Ñ Ð·Ð°Ð¿ÑоÑа"
#: ../lib/vector/vedit/cats.c:66
-#, fuzzy, c-format
+#, c-format
msgid "Unable to set category %d for (feature id %d)"
-msgstr "Ðевозможно ÑÑÑановиÑÑ ÐºÐ°ÑегоÑÐ¸Ñ %d Ð´Ð»Ñ Ð»Ð¸Ð½Ð¸Ð¸ %d"
+msgstr "Ðевозможно ÑÑÑановиÑÑ ÐºÐ°ÑегоÑÐ¸Ñ %d Ð´Ð»Ñ (id обÑекÑа %d)"
#: ../lib/vector/Vlib/intersect.c:127
msgid "3D not supported by Vect_segment_intersection()"
@@ -924,7 +937,7 @@
#: ../lib/vector/Vlib/intersect.c:1164 ../lib/vector/Vlib/intersect.c:1185
#: ../lib/vector/Vlib/intersect.c:1202
msgid "Error while adding point to array. Out of memory"
-msgstr ""
+msgstr "ÐÑибка Ð´Ð¾Ð±Ð°Ð²Ð»ÐµÐ½Ð¸Ñ ÑоÑки в маÑÑив. ÐÐµÑ Ð¿Ð°Ð¼ÑÑи"
#: ../lib/vector/Vlib/build.c:31 ../lib/vector/Vlib/open.c:40
#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/read.c:30
@@ -934,94 +947,91 @@
msgstr "ÐапÑаÑиваемÑй ÑоÑÐ¼Ð°Ñ Ð´Ð»Ñ ÑÑой веÑÑии не ÑкомпилиÑован."
#: ../lib/vector/Vlib/build.c:123
-#, fuzzy, c-format
+#, c-format
msgid "Building topology for vector map <%s>..."
-msgstr "ÐоÑÑÑоение Ñопологии Ð´Ð»Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ <%s>...\n"
+msgstr "ÐоÑÑÑоение Ñопологии Ð´Ð»Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ <%s>..."
#: ../lib/vector/Vlib/build.c:141
-#, fuzzy
msgid "Topology was built"
-msgstr "Ð¢Ð¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð¿Ð¾ÑÑÑоена\n"
+msgstr "Ð¢Ð¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð¿Ð¾ÑÑÑоена"
#: ../lib/vector/Vlib/build.c:153
-#, fuzzy, c-format
+#, c-format
msgid "Number of nodes: %d"
-msgstr "ÐолиÑеÑÑво Ñзлов : %d\n"
+msgstr "ÐолиÑеÑÑво Ñзлов: %d"
#: ../lib/vector/Vlib/build.c:154
-#, fuzzy, c-format
+#, c-format
msgid "Number of primitives: %d"
-msgstr "ÐолиÑеÑÑво пÑимиÑивов: %d\n"
+msgstr "ÐолиÑеÑÑво пÑимиÑивов: %d"
#: ../lib/vector/Vlib/build.c:155
-#, fuzzy, c-format
+#, c-format
msgid "Number of points: %d"
-msgstr "ÐолиÑеÑÑво ÑоÑек : %d\n"
+msgstr "ÐолиÑеÑÑво ÑоÑек: %d"
#: ../lib/vector/Vlib/build.c:156
-#, fuzzy, c-format
+#, c-format
msgid "Number of lines: %d"
-msgstr "ÐолиÑеÑÑво линий : %d\n"
+msgstr "ÐолиÑеÑÑво линий: %d"
#: ../lib/vector/Vlib/build.c:157
-#, fuzzy, c-format
+#, c-format
msgid "Number of boundaries: %d"
-msgstr "ÐолиÑеÑÑво гÑаниÑ: %d\n"
+msgstr "ÐолиÑеÑÑво гÑаниÑ: %d"
#: ../lib/vector/Vlib/build.c:158
-#, fuzzy, c-format
+#, c-format
msgid "Number of centroids: %d"
-msgstr "ÐолиÑеÑÑво ÑенÑÑоидов : %d\n"
+msgstr "ÐолиÑеÑÑво ÑенÑÑоидов: %d"
#: ../lib/vector/Vlib/build.c:161
-#, fuzzy, c-format
+#, c-format
msgid "Number of faces: %d"
-msgstr "ÐолиÑеÑÑво гÑаней : %d\n"
+msgstr "ÐолиÑеÑÑво гÑаней: %d"
#: ../lib/vector/Vlib/build.c:164
-#, fuzzy, c-format
+#, c-format
msgid "Number of kernels: %d"
-msgstr "ÐолиÑеÑÑво ÑÐ´ÐµÑ : %d\n"
+msgstr "ÐолиÑеÑÑво ÑдеÑ: %d"
#: ../lib/vector/Vlib/build.c:205
-#, fuzzy, c-format
+#, c-format
msgid "Number of areas: %d"
-msgstr "ÐолиÑеÑÑво полигонов : %d\n"
+msgstr "ÐолиÑеÑÑво полигонов: %d"
#: ../lib/vector/Vlib/build.c:206
-#, fuzzy, c-format
+#, c-format
msgid "Number of isles: %d"
-msgstr "ÐолиÑеÑÑво оÑÑÑовов : %d\n"
+msgstr "ÐолиÑеÑÑво оÑÑÑовов: %d"
#: ../lib/vector/Vlib/build.c:209
-#, fuzzy, c-format
+#, c-format
msgid "Number of incorrect boundaries: %d"
-msgstr "ÐолиÑеÑÑво непÑавилÑнÑÑ
гÑÐ°Ð½Ð¸Ñ : %d\n"
+msgstr "ÐолиÑеÑÑво непÑавилÑнÑÑ
гÑаниÑ: %d"
#: ../lib/vector/Vlib/build.c:213
-#, fuzzy, c-format
+#, c-format
msgid "Number of centroids outside area: %d"
-msgstr "ÐолиÑеÑÑво ÑенÑÑоидов вне полигонов : %d\n"
+msgstr "ÐолиÑеÑÑво ÑенÑÑоидов вне полигонов: %d"
#: ../lib/vector/Vlib/build.c:217
-#, fuzzy, c-format
+#, c-format
msgid "Number of duplicate centroids: %d"
-msgstr "ÐолиÑеÑÑво ÑенÑÑоидов-дÑпликаÑов : %d\n"
+msgstr "ÐолиÑеÑÑво ÑенÑÑоидов-дÑпликаÑов: %d"
#: ../lib/vector/Vlib/build.c:221
-#, fuzzy, c-format
+#, c-format
msgid "Number of areas without centroid: %d"
-msgstr "ÐолиÑеÑÑво полигонов без ÑенÑÑоидов : %d\n"
+msgstr "ÐолиÑеÑÑво полигонов без ÑенÑÑоидов: %d"
#: ../lib/vector/Vlib/build.c:226
-#, fuzzy
msgid "Number of areas: -"
-msgstr "ÐолиÑеÑÑво полигонов : -\n"
+msgstr "ÐолиÑеÑÑво полигонов: -"
#: ../lib/vector/Vlib/build.c:227
-#, fuzzy
msgid "Number of isles: -"
-msgstr "ÐолиÑеÑÑво оÑÑÑовов : -\n"
+msgstr "ÐолиÑеÑÑво оÑÑÑовов: -"
#: ../lib/vector/Vlib/build.c:256
#, c-format
@@ -1211,7 +1221,7 @@
msgstr "ÐÑÑ
одной векÑоÑнÑй Ñлой <%s> иÑполÑзÑеÑÑÑ ÐºÐ°Ðº иÑÑ
однÑй"
msgstr "векÑоÑнÑй Ñлой не оÑкÑÑÑ"
@@ -1253,9 +1263,9 @@
msgstr "Ðевозможно вÑбÑаÑÑ Ð·Ð°Ð¿Ð¸Ñи из ÑаблиÑÑ <%s> (клÑÑ %s, где %s)"
#: ../lib/vector/Vlib/break_lines.c:115 ../lib/vector/Vlib/break_lines.c:370
-#, fuzzy, c-format
+#, c-format
msgid "Intersections: %5d"
-msgstr "ÐеÑеÑеÑениÑ: "
+msgstr "ÐеÑеÑеÑениÑ: %5d"
#: ../lib/vector/Vlib/poly.c:235
msgid "Unable to find point in polygon"
@@ -1275,7 +1285,7 @@
msgstr ""
"СлиÑком много каÑегоÑий (%d), невозможно ÑÑÑановиÑÑ ÐºÐ°ÑегоÑÐ¸Ñ %d (Ñлой %d)"
#, c-format
msgstr ""
@@ -1299,19 +1309,19 @@
"Ðевозможно поÑÑÑоиÑÑ Ð¿ÑоÑÑÑанÑÑвеннÑй Ð¸Ð½Ð´ÐµÐºÑ Ð¸Ð· Ñопологии, векÑоÑнÑй Ñлой не "
"оÑкÑÑÑ Ð½Ð° вÑоÑом Ñопо ÑÑовне"
msgstr "ÐÑибка (Vect_build_sidx_from_topo): Ñзел не ÑÑÑеÑÑвÑеÑ"
msgstr "ÐÑибка (Vect_build_sidx_from_topo): Ð»Ð¸Ð½Ð¸Ñ Ð½Ðµ ÑÑÑеÑÑвÑеÑ"
msgstr "ÐÑибка (Vect_build_sidx_from_topo): полигон не ÑÑÑеÑÑвÑеÑ"
msgstr "Ðаг (Vect_build_sidx_from_topo): оÑÑÑов не ÑÑÑеÑÑвÑеÑ"
@@ -1343,7 +1353,7 @@
msgstr "Ðевозможно добавиÑÑ ÑеÑевÑÑ Ð´ÑгÑ"
#, c-format
msgstr "оÑибка dglShortestPath : %s"
@@ -1361,53 +1371,48 @@
msgstr "Ðолигон плоÑадÑÑ 0.0 пÑопÑÑен"
#: ../lib/vector/Vlib/build_nat.c:148
-#, fuzzy
-msgstr "ÐопÑÑка найÑи полигон вокÑÑг неÑÑÑеÑÑвÑÑÑего оÑÑÑова"
+msgstr "ÐапÑÐ¾Ñ Ð½Ð°Ð¹Ñи полигон вне неÑÑÑеÑÑвÑÑÑего оÑÑÑова"
-#, fuzzy
-msgstr "РегиÑÑÑиÑÑÑÑÑÑ Ð¿ÑимиÑивÑ:"
+msgstr "РегиÑÑÑиÑÑÑÑÑÑ Ð¿ÑимиÑивÑ..."
msgstr "Ðевозможно пÑоÑиÑаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
-#, fuzzy, c-format
+#, c-format
-msgstr "пÑимиÑивов заÑегиÑÑÑиÑовано"
+msgstr "%d пÑимиÑивов заÑегиÑÑÑиÑовано"
-#, fuzzy, c-format
+#, c-format
-msgstr "Ñзлов заÑегиÑÑÑиÑовано"
+msgstr "%d Ñзлов заÑегиÑÑÑиÑовано"
-#, fuzzy
-msgstr "ÐоÑÑÑоение полигонов:"
+msgstr "ÐоÑÑÑоение полигонов..."
-#, fuzzy, c-format
+#, c-format
-msgstr "полигонов поÑÑÑоено"
+msgstr "%d полигонов поÑÑÑоено"
-#, fuzzy, c-format
+#, c-format
-msgstr "оÑÑÑовов Ñоздано"
+msgstr "%d оÑÑÑовов Ñоздано"
-#, fuzzy
-msgstr "ÐазнаÑаÑÑÑÑ Ð¾ÑÑÑова:"
+msgstr "ÐазнаÑаÑÑÑÑ Ð¾ÑÑÑова..."
-#, fuzzy
-msgstr "ÐазнаÑаÑÑÑÑ ÑенÑÑоидÑ:"
+msgstr "ÐазнаÑаÑÑÑÑ ÑенÑÑоидÑ..."
#: ../lib/vector/Vlib/open_nat.c:145
#, c-format
@@ -1469,9 +1474,8 @@
msgstr "СÑÑÑкÑÑÑа каÑÑÑ Ð·Ð°ÐºÑÑÑа"
#: ../lib/vector/Vlib/area.c:53
-#, fuzzy
msgid "Attempt to read points of nonexistent area"
-msgstr "ÐопÑÑка полÑÑиÑÑ ÑоÑки из неÑÑÑеÑÑвÑÑÑего полигона"
+msgstr "ÐопÑÑка ÑÑиÑаÑÑ ÑоÑки из неÑÑÑеÑÑвÑÑÑего полигона"
#: ../lib/vector/Vlib/area.c:125
#, c-format
@@ -1530,7 +1534,8 @@
msgstr "Ðолигон обÑазова Ñдаленной гÑаниÑей"
msgstr "ÐопÑÑка ÑÑиÑаÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾Ð± Ñдаленной линии"
@@ -1781,11 +1786,11 @@
msgstr "ÐÑпÑÑмление гÑаÑа"
msgstr "ÐÑÐ°Ñ Ð¿Ð¾ÑÑÑоен"
msgstr "ÐепÑавилÑное напÑавление линии в Vect_net_get_line_cost()"
@@ -1886,21 +1891,61 @@
#: ../lib/vector/Vlib/buffer2.c:375
#, fuzzy
msgid "Line is not looped"
-msgstr "ÐаÑÑиÑÑ Ð½Ðµ ÑазÑеÑенÑ"
+msgstr "ÐÐ¸Ð½Ð¸Ñ Ð½Ðµ заÑиклена"
#: ../lib/vector/Vlib/buffer2.c:610 ../lib/vector/Vlib/buffer2.c:621
+#, fuzzy
msgid "Next edge was visited but it is not the first one !!! breaking loop"
-msgstr ""
+msgstr "СледÑÑÑÐ°Ñ Ð³ÑÐ°Ð½Ñ Ð±Ñла пÑовеÑена, но она не пеÑÐ²Ð°Ñ !!! вÑÑ
од из Ñикла"
#: ../lib/vector/Vlib/buffer2.c:673
#, fuzzy
msgid "side != 0 feature not implemented"
-msgstr "не пÑедÑÑмоÑÑено"
+msgstr "ÑÑоÑона != 0 возможноÑÑÑ Ð½ÐµÐ¿ÑедÑÑмоÑÑена"
#: ../lib/vector/Vlib/buffer2.c:923 ../lib/vector/Vlib/buffer2.c:956
+msgstr "Vect_get_point_in_poly() не вÑполнен"
+#, fuzzy, c-format
+msgid ""
msgstr ""
+"Vect_read_line(): Ð»Ð¸Ð½Ð¸Ñ Ñ id %d невозможна (макÑималÑное колиÑеÑÑво обÑекÑом "
+"в векÑоÑном Ñлое <%s>: %d)"
+#, fuzzy
+msgstr "Ð´Ð»Ñ ÑÑого ÑоÑмаÑа/ÑÑÐ¾Ð²Ð½Ñ Ð½Ðµ поддеÑживаеÑÑÑ "
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, fuzzy, c-format
+msgstr "Ðевозможно пÑоÑиÑаÑÑ Ð»Ð¸Ð½Ð¸Ñ %d"
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Ðевозможно пеÑезапиÑаÑÑ Ð¾Ð±ÑÐµÐºÑ %d"
#, c-format
@@ -1965,15 +2010,15 @@
msgstr "ÐÑибка в Ñайле ÑаблиÑÑ Ð´Ð°ÑÑмов <%s>, ÑÑÑока %d"
msgstr "Ðевозможно обÑабоÑаÑÑ PROJ_INFO Ñайл GRASS"
msgstr "Ðевозможно полÑÑиÑÑ ÑÑÑÐ¾ÐºÑ Ð¿Ð°ÑамеÑÑов в ÑÑиле PROJ.4"
#, c-format
msgid ""
@@ -1981,22 +2026,22 @@
"OGR не Ð¼Ð¾Ð¶ÐµÑ Ð¾Ð±ÑабоÑаÑÑ ÑÑÑÐ¾ÐºÑ Ð¿Ð°ÑамеÑÑов в ÑÑиле PROJ.4: %s (Ðод оÑибки OGR "
"%d)"
#, c-format
msgstr ""
"OGR не Ð¼Ð¾Ð¶ÐµÑ Ð¿Ð¾Ð»ÑÑиÑÑ ÑÑÑÐ¾ÐºÑ Ð¿Ð°ÑамеÑÑов в ÑÑиле WKT (Ðод оÑибки OGR %d)"
msgstr "ÐÐµÑ Ð¸Ð¼ÐµÐ½Ð¸ пÑоекÑии! ÐаÑамеÑÑÑ Ð¿ÑоекÑии не имеÑÑ Ð·Ð½Ð°ÑениÑ."
#, c-format
msgstr "ÐаÑÑм <%s> не ÑаÑпознан GRASS, паÑамеÑÑÑ Ð½Ðµ найденÑ"
#, c-format
msgid ""
@@ -2004,14 +2049,14 @@
msgstr ""
"ÐаÑÑм <%s> ÑаÑпознан GRASS, но паÑамеÑÑÑ Ð½Ðµ найденÑ. ÐеобÑ
одимо ваÑе ÑÑаÑÑие."
-#, fuzzy, c-format
+#, c-format
msgid ""
"transform parameters unspecified."
msgstr ""
-"ÐепÑавилÑнÑй Ð½Ð¾Ð¼ÐµÑ ÑÑанÑÑоÑмаÑии %d; валиднÑй диапазон Ð¾Ñ 1 до %d. ÐаÑамеÑÑÑ "
-"ÑÑанÑÑоÑмаÑии даÑÑма оÑÑÐ°Ð²Ð»ÐµÐ½Ñ Ð½ÐµÐ·Ð°Ð¿Ð¾Ð»Ð½ÐµÐ½Ð½Ñми."
+"ÐепÑавилÑнÑй Ð½Ð¾Ð¼ÐµÑ ÑÑанÑÑоÑмаÑии %d; пÑавилÑнÑй диапазон Ð¾Ñ 1 до %d. "
+"ÐаÑамеÑÑÑ ÑÑанÑÑоÑмаÑии даÑÑма оÑÑÐ°Ð²Ð»ÐµÐ½Ñ Ð½ÐµÐ·Ð°Ð¿Ð¾Ð»Ð½ÐµÐ½Ð½Ñми."
#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
#, c-format
@@ -2439,12 +2484,12 @@
#: ../lib/gis/find_file.c:74
#, c-format
msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
-msgstr ""
+msgstr "'%s/%s' бÑл найден в неÑколÑкиÑ
набоÑаÑ
(Ñакже найден в <%s>)"
#: ../lib/gis/find_file.c:82
-#, fuzzy, c-format
+#, c-format
msgid "Using <%s@%s>"
-msgstr "Ðевозможно найÑи <%s@%s>"
+msgstr "ÐÑполÑзÑеÑÑÑ<%s@%s>"
#: ../lib/gis/quant_io.c:89
#, c-format
@@ -2473,50 +2518,50 @@
msgstr "СлиÑком много паÑамеÑÑов"
msgstr "Ðевозможно ÑоздаÑÑ Ð½Ð¾Ð²Ñй пÑоÑеÑÑ"
msgstr "Ðевозможно вÑполниÑÑ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ"
#, c-format
msgstr "G_spawn: невозможно воÑÑÑановиÑÑ Ñигнал %d"
#, c-format
msgstr "G_spawn: невозможно ÑбÑоÑиÑÑ Ñигнал %d"
#, c-format
msgstr "G_spawn: невозможно игноÑиÑоваÑÑ Ñигнал %d"
#, c-format
msgstr "G_spawn: невозможно заблокиÑоваÑÑ Ñигнал %d"
#, c-format
msgstr "G_spawn: невозможно ÑазблокиÑоваÑÑ Ñигнал %d"
#, c-format
msgstr "G_spawn: невозможно оÑкÑÑÑÑ Ñайл %s"
#, c-format
msgstr "G_spawn: невозможно дÑблиÑоваÑÑ Ð´ÐµÑкÑипÑÐ¾Ñ %d to %d"
#, c-format
msgstr "Ðевозможно измениÑÑ Ð¿Ð°Ð¿ÐºÑ %s"
@@ -2554,7 +2599,7 @@
msgstr "ÐÐÐÐРне задан"
#, c-format
msgstr "ÐÐÐÐÐ %s не найден"
@@ -2663,16 +2708,18 @@
msgid "can't write range file for [%s in %s]"
msgstr "невозможно запиÑаÑÑ Ñайл диапазона Ð´Ð»Ñ [%s в %s]"
-msgstr "ÐеÑовмеÑÑÐ¸Ð¼Ð°Ñ Ð²ÐµÑÑÐ¸Ñ Ð±Ð¸Ð±Ð»Ð¸Ð¾Ñеки Ð´Ð»Ñ Ð¼Ð¾Ð´ÑлÑ"
+msgid ""
+msgstr ""
#, c-format
msgstr "ÐÐÐÐÐ %s - доÑÑÑп запÑеÑен"
msgstr ""
"СиÑÑема не иниÑиализиÑована. ÐÑогÑаммиÑÑов не вÑполнен вÑзов G_gisinit()."
@@ -2967,23 +3014,11 @@
msgstr "ÐблаÑÑÑ << %s >> недоÑÑÑпна"
msgstr "EmbedGivenNulls: невеÑнÑй Ñип даннÑÑ
-msgstr "ÐÑлевÑе знаÑÐµÐ½Ð¸Ñ Ð½Ðµ бÑли иниÑиализиÑованÑ."
-msgstr "СнаÑала нÑжно вÑзваÑÑ G_gisinit(). "
-msgstr "СообÑиÑе ÑазÑабоÑÑикам GRASS об ÑÑой оÑибке.\n"
msgstr "G_set_null_value: невеÑнÑй Ñип даннÑÑ
@@ -3006,9 +3041,9 @@
"G_distance_point_to_line_segment: не должно бÑÑÑ: code=%d P=(%f,%f) S=(%f,%f)"
"(%f,%f)"
-#, c-format
+#, fuzzy, c-format
msgstr "Ðевозможно ÑоздаÑÑ ÑÐ»ÐµÐ¼ÐµÐ½Ñ Ð½Ð°Ð±Ð¾Ñа %s (%s)"
@@ -3100,9 +3135,8 @@
msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного векÑоÑного ÑлоÑ"
#: ../lib/gis/parser.c:566
-#, fuzzy
msgid "Feature type"
-msgstr "Тип(Ñ) обÑекÑа(ов)"
+msgstr "Тип обÑекÑа"
#: ../lib/gis/parser.c:573
msgid "Layer number"
@@ -3129,14 +3163,12 @@
msgstr "ÐÑимеÑ: 1,3,7-9,13"
#: ../lib/gis/parser.c:598
-#, fuzzy
msgid "Feature id"
-msgstr "ÐбÑекÑ: "
+msgstr "Id обÑекÑа"
#: ../lib/gis/parser.c:605
-#, fuzzy
msgid "Feature ids"
-msgstr "ÐбÑекÑ: "
+msgstr "Id обÑекÑов"
#: ../lib/gis/parser.c:616
msgid "Name of input file"
@@ -3978,38 +4010,37 @@
#: ../lib/gis/alloc.c:43
#, c-format
msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
-msgstr ""
+msgstr "G_malloc: невозможно вÑделиÑÑ %lu Ð±Ð°Ð¹Ñ Ð² %s:%d"
#: ../lib/gis/alloc.c:76
#, c-format
msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
-msgstr ""
+msgstr "G_calloc: невозможно вÑделиÑÑ %lu * %lu Ð±Ð°Ð¹Ñ Ð² %s:%d"
#: ../lib/gis/alloc.c:114
#, c-format
msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
-msgstr ""
+msgstr "G_realloc: невозможно вÑделиÑÑ %lu Ð±Ð°Ð¹Ñ Ð² %s:%d"
#: ../lib/gis/gdal.c:54
-#, fuzzy, c-format
+#, c-format
msgid "Unable to locate symbol <%s>"
-msgstr "Ðевозможно ÑоздаÑÑ ÑаблиÑÑ <%s>"
+msgstr "Ðевозможно найÑи Ñимвол <%s>"
#: ../lib/gis/gdal.c:94
-#, fuzzy
msgid "Unable to load GDAL library"
-msgstr "Ðевозможно добавиÑÑ ÑеÑевÑÑ Ð´ÑгÑ"
+msgstr "Ðевозможно загÑÑзиÑÑ Ð±Ð¸Ð±Ð»Ð¸Ð¾ÑÐµÐºÑ GDAL"
#: ../lib/nviz/change_view.c:108
#, c-format
msgid "Invalid view position coordinates, using %f,%f"
msgstr "ÐепÑавилÑнÑе кооÑдинаÑÑ Ð¿Ð¾Ð·Ð¸Ñии вида, иÑполÑзÑеÑÑÑ %f,%f"
-#: ../lib/nviz/render.c:109
+#: ../lib/nviz/render.c:108
msgid "Bad server connection"
msgstr "ÐлоÑ
ое Ñоединение Ñ ÑеÑвеÑом"
-#: ../lib/nviz/render.c:118
+#: ../lib/nviz/render.c:117
msgid "Unable to create rendering context"
msgstr "Ðевозможно ÑоздаÑÑ ÐºÐ¾Ð½ÑекÑÑ Ð¾ÑÑиÑовки"
@@ -4057,60 +4088,60 @@
msgstr "Ðевозможно ÑÑÑановиÑÑ Ð½Ð¾Ð²Ñй иÑÑоÑник ÑвеÑа"
#: ../lib/sites/sites.c:97
-#, fuzzy, c-format
+#, c-format
msgid "Attributes for category %d not found"
-msgstr "ÐÐ»Ñ ÐºÐ°ÑегоÑии %d не найдена запиÑÑ Ð² ÐÐ"
+msgstr "ÐÑÑибÑÑÑ Ð´Ð»Ñ ÐºÐ°ÑегоÑии %d не найденÑ"
#: ../lib/sites/sites.c:136
msgid "Category must be integer"
-msgstr ""
+msgstr "ÐаÑегоÑÐ¸Ñ Ð´Ð¾Ð»Ð¶Ð½Ð° бÑÑÑ ÑелоÑиÑленной"
#: ../lib/sites/sites.c:210
msgid "Memory error in writing timestamp"
-msgstr ""
+msgstr "ÐÑибка памÑÑи пÑи запиÑи вÑеменной меÑки"
#: ../lib/sites/sites.c:212
msgid "Illegal TimeStamp string"
-msgstr ""
+msgstr "ÐевеÑÐ½Ð°Ñ ÑÑÑока вÑеменной меÑки"
#: ../lib/sites/sites.c:241
msgid "Memory error in allocating timestamp"
-msgstr ""
+msgstr "ÐÑибка памÑÑи пÑи ÑабоÑе Ñ Ð²Ñеменной меÑкой"
#: ../lib/sites/sites.c:348 ../lib/sites/sites.c:478
msgid ""
"Dev note: Adapted sites library used for vector points. (module should be "
"updated to GRASS 6 vector library)"
msgstr ""
+"ÐамеÑка ÑазÑебоÑÑика: ÐиблиоÑека ÑайÑов адапÑиÑÐ¾Ð²Ð°Ð½Ð½Ð°Ñ Ð´Ð»Ñ Ð²ÐµÐºÑоÑнÑÑ
ÑоÑек. "
+"(модÑÐ»Ñ Ð´Ð¾Ð»Ð¶ÐµÐ½ бÑÑÑ Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½ Ð´Ð»Ñ Ð²ÐµÐºÑоÑной библиоÑеки GRASS 6)"
#: ../lib/sites/sites.c:397
-#, fuzzy
msgid "Cannot fetch row"
-msgstr "Ðевозможно полÑÑиÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ Ñлое"
+msgstr "Ðевозможно полÑÑиÑÑ ÑÑд"
#: ../lib/sites/sites.c:579
msgid "G_oldsite_new_struct: invalid # dims or fields"
-msgstr ""
+msgstr "G_oldsite_new_struct: непÑавилÑное ÑиÑло ÑазмеÑноÑÑей или полей"
#: ../lib/sites/sites.c:1249
-#, fuzzy, c-format
+#, c-format
msgid "Cannot open database %s by driver %s"
-msgstr " "
+msgstr "Ðевозможно оÑкÑÑÑÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
%s Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ Ð´ÑайвеÑа %s"
#: ../lib/sites/sites.c:1257
-#, fuzzy
msgid "Cannot select attributes"
-msgstr "Ðевозможно опиÑаÑÑ ÑаблиÑÑ <%s>"
+msgstr "Ðевозможно вÑбÑаÑÑ Ð°ÑÑибÑÑÑ"
#: ../lib/imagery/list_gp.c:34
#, c-format
msgid "group <%s> is empty\n"
-msgstr ""
+msgstr "гÑÑппа <%s> пÑÑÑа\n"
#: ../lib/imagery/list_gp.c:44
#, c-format
msgid "group <%s> references the following raster maps\n"
-msgstr ""
+msgstr "гÑÑппа <%s> ÑÑÑлаеÑÑÑ Ð½Ð° ÑледÑÑÑие ÑаÑÑÑовÑе Ñлои\n"
#: ../lib/imagery/fopen.c:23
#, c-format
@@ -4145,12 +4176,12 @@
#: ../lib/imagery/list_subgp.c:36
#, c-format
msgid "subgroup <%s> of group <%s> is empty\n"
-msgstr ""
+msgstr "подгÑÑппа <%s> гÑÑÐ¿Ð¿Ñ <%s> пÑÑÑа\n"
#: ../lib/imagery/list_subgp.c:48
#, c-format
msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
+msgstr "подгÑÑппа <%s> гÑÑÐ¿Ð¿Ñ <%s> ÑÑÑлаеÑÑÑ Ð½Ð° ÑледÑÑÑие ÑаÑÑÑовÑе Ñлои\n"
#: ../lib/imagery/target.c:38
#, c-format
@@ -4286,29 +4317,29 @@
msgstr "ÐопÑобÑйÑе иÑполÑзоваÑÑ Ð¼ÐµÐ½ÑÑий ÑÐ°Ð·Ð¼ÐµÑ ÑÑиÑÑа!"
msgstr "Ðевозможно вÑделиÑÑ Ð¿Ð°Ð¼ÑÑÑ Ð´Ð»Ñ Ð½Ñлевого бÑÑеÑа"
#, c-format
msgstr "ЧÑение ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>..."
#, c-format
msgstr ""
"Ðиапазон ÑвеÑовой ÑаблиÑÑ Ð½Ðµ ÑооÑвеÑÑÑвÑÐµÑ Ð´Ð°Ð½Ð½Ñм (mincol=%d, maxcol=%d"
#, c-format
msgstr "ТÑанÑлÑÑÐ¸Ñ ÑвеÑов Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>..."
msgstr "Ðид не ÑоÑ
Ñанен ÑÑой пÑогÑаммой, ÑÑÑеÑÑвÑÑÑ Ð½ÐµÑоÑÑÑковки"
@@ -4703,6 +4734,18 @@
msgstr "Ñоздана биÑмÑп маÑка "
+#~ msgstr "ÐеÑовмеÑÑÐ¸Ð¼Ð°Ñ Ð²ÐµÑÑÐ¸Ñ Ð±Ð¸Ð±Ð»Ð¸Ð¾Ñеки Ð´Ð»Ñ Ð¼Ð¾Ð´ÑлÑ"
+#~ msgstr "ÐÑлевÑе знаÑÐµÐ½Ð¸Ñ Ð½Ðµ бÑли иниÑиализиÑованÑ."
+#~ msgstr "СнаÑала нÑжно вÑзваÑÑ G_gisinit(). "
+#~ msgstr "СообÑиÑе ÑазÑабоÑÑикам GRASS об ÑÑой оÑибке.\n"
#~ msgid "Unable to delete layer/category %d/%d line %d"
#~ msgstr "Ðевозможно ÑдалиÑÑ Ñлой/каÑегоÑÐ¸Ñ %d/%d линии %d"
@@ -4772,6 +4815,10 @@
#~ msgid "G_realloc: out of memory"
#~ msgstr "G_realloc: out of memory"
+#, fuzzy
+#~ msgid "Cannot get layer info"
+#~ msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¾ÑкÑÑÑÑ Ð²Ñем. Ñайл"
#~ msgid "Cannot open database %s"
#~ msgstr "Ðевозможно оÑкÑÑÑÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
%s"
@@ -4787,6 +4834,10 @@
#~ msgid "field missing east"
#~ msgstr "оÑÑÑÑÑÑвÑÐµÑ Ð¿Ð¾Ð»Ðµ east"
+#, fuzzy
+#~ msgid "Cannot describe table <%s>"
+#~ msgstr "Ðевозможно опиÑаÑÑ ÑаблиÑÑ <%s>"
#~ msgid "Unable to connect lines %d,%d"
#~ msgstr "Ðевозможно ÑоединиÑÑ Ð»Ð¸Ð½Ð¸Ð¸ %d,%d"
Modified: grass/branches/develbranch_6/locale/po/grassmods_es.po
--- grass/branches/develbranch_6/locale/po/grassmods_es.po 2009-05-22 15:36:57 UTC (rev 37374)
+++ grass/branches/develbranch_6/locale/po/grassmods_es.po 2009-05-22 15:53:49 UTC (rev 37375)
@@ -14,7 +14,7 @@
msgstr ""
"Project-Id-Version: grassmods_es\n"
"PO-Revision-Date: 2008-01-11 19:44+0100\n"
@@ -30,10 +30,10 @@
#: ../db/base/tables.c:46 ../db/base/droptable.c:44 ../db/base/select.c:62
#: ../db/base/columns.c:45 ../db/base/describe.c:52 ../db/base/databases.c:52
#: ../vector/v.db.connect/main.c:189 ../vector/v.db.connect/main.c:255
-#: ../vector/v.edit/select.c:513 ../vector/v.out.ascii/b2a.c:43
+#: ../vector/v.edit/select.c:513 ../vector/v.out.ascii/b2a.c:44
#: ../vector/v.in.sites/main.c:158 ../vector/v.out.svg/main.c:141
#: ../vector/v.out.vtk/writeVTK.c:634 ../vector/v.drape/main.c:288
-#: ../vector/v.out.ogr/main.c:322 ../vector/v.extract/main.c:286
+#: ../vector/v.out.ogr/main.c:325 ../vector/v.extract/main.c:286
#: ../doc/vector/v.example/main.c:123 ../display/d.vect/main.c:499
#: ../display/d.thematic.area/main.c:231
#, c-format
@@ -157,11 +157,6 @@
#: ../db/base/tables.c:95 ../db/base/drivers.c:74 ../db/base/columns.c:92
#: ../db/base/describe.c:125 ../db/base/connect.c:45
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:2
-#: ../locale/scriptstrings/db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
-#: ../locale/scriptstrings/db.test_to_translate.c:2
msgid "database, attribute table"
msgstr "base de datos, tabla de atributos"
@@ -201,9 +196,9 @@
msgid "Name of file with sql statement"
msgstr "Nombre de archivo con sentencia SQL"
-#: ../db/base/select.c:199 ../locale/scriptstrings/r.tileset_to_translate.c:13
-#: ../raster/r.distance/parse.c:50 ../raster/r.stats/main.c:121
-#: ../raster/r.cats/main.c:72 ../vector/v.db.select/main.c:63
+#: ../db/base/select.c:199 ../raster/r.distance/parse.c:50
+#: ../raster/r.stats/main.c:121 ../raster/r.cats/main.c:72
+#: ../vector/v.db.select/main.c:63
msgid "Output field separator"
msgstr "Separador de campos de salida"
@@ -253,7 +248,7 @@
#: ../vector/v.patch/main.c:139 ../vector/v.patch/main.c:177
#: ../vector/v.random/main.c:199 ../vector/v.out.svg/main.c:154
#: ../vector/v.out.vtk/writeVTK.c:643 ../vector/v.drape/main.c:299
-#: ../vector/v.out.ogr/main.c:332 ../doc/vector/v.example/main.c:134
+#: ../vector/v.out.ogr/main.c:335 ../doc/vector/v.example/main.c:134
#, c-format
msgid "Unable to describe table <%s>"
msgstr "No se puede describir la tabla<%s>"
@@ -629,7 +624,7 @@
msgstr "Cadena char para representar celdas sin datos"
#: ../raster3d/r3.out.ascii/main.c:103 ../raster/r.out.ascii/main.c:104
-#: ../raster/r.out.arc/main.c:88
+#: ../raster/r.out.arc/main.c:89
msgid "Suppress printing of header information"
msgstr "Suprimir la impresión de información de cabecera"
@@ -904,7 +899,7 @@
#: ../vector/v.generalize/simplification.c:341
#: ../vector/v.generalize/point.c:120 ../vector/v.generalize/network.c:93
#: ../vector/v.generalize/network.c:128 ../vector/v.mkgrid/write_grid.c:131
-#: ../vector/v.surf.rst/main.c:859 ../vector/v.mapcalc/list.c:54
+#: ../vector/v.surf.rst/main.c:866 ../vector/v.mapcalc/list.c:54
#: ../vector/v.mapcalc/list.c:501 ../imagery/i.smap/bouman/multialloc.c:115
#: ../imagery/i.ask/popup.c:174
msgid "Out of memory"
@@ -1103,14 +1098,15 @@
#: ../raster/r.coin/inter.c:44 ../raster/r.coin/main.c:127
#: ../raster/r.coin/main.c:130 ../raster/r.distance/parse.c:79
#: ../raster/r.distance/parse.c:86 ../raster/r.reclass/main.c:78
-#: ../raster/r.los/main.c:160 ../raster/r.los/main.c:166
-#: ../raster/r.drain/main.c:140 ../raster/r.out.ascii/main.c:146
-#: ../raster/r.carve/main.c:178 ../raster/r.profile/main.c:142
-#: ../raster/r.texture/main.c:228 ../raster/r.basins.fill/main.c:93
-#: ../raster/r.basins.fill/main.c:105 ../raster/r.sum/main.c:62
-#: ../raster/r.null/null.c:113 ../raster/r.average/main.c:72
-#: ../raster/r.average/main.c:75 ../raster/r.lake/main.c:254
-#: ../raster/r.lake/main.c:265 ../raster/r.out.gridatb/check_ready.c:12
+#: ../raster/r.los/main.c:162 ../raster/r.los/main.c:168
+#: ../raster/r.drain/main.c:189 ../raster/r.drain/main.c:218
+#: ../raster/r.out.ascii/main.c:146 ../raster/r.carve/main.c:178
+#: ../raster/r.profile/main.c:142 ../raster/r.texture/main.c:228
+#: ../raster/r.basins.fill/main.c:93 ../raster/r.basins.fill/main.c:105
+#: ../raster/r.sum/main.c:62 ../raster/r.null/null.c:113
+#: ../raster/r.average/main.c:72 ../raster/r.average/main.c:75
+#: ../raster/r.lake/main.c:254 ../raster/r.lake/main.c:265
+#: ../raster/r.out.gridatb/check_ready.c:12
#: ../raster/r.surf.idw2/read_cell.c:19 ../raster/r.transect/main.c:119
#: ../raster/simwe/simlib/input.c:178 ../raster/simwe/simlib/input.c:184
#: ../raster/simwe/simlib/input.c:189 ../raster/simwe/simlib/input.c:198
@@ -1124,38 +1120,37 @@
#: ../raster/r.grow2/main.c:187 ../raster/r.surf.idw/main.c:108
#: ../raster/r.thin/io.c:96 ../raster/r.flow/io.c:63
#: ../raster/r.topidx/check_ready.c:11 ../raster/r.out.pov/main.c:174
-#: ../raster/r.covar/main.c:95 ../raster/r.out.arc/main.c:114
-#: ../raster/r.report/parse.c:243 ../raster/r.random/main.c:113
-#: ../raster/r.random/main.c:118 ../raster/r.his/main.c:127
+#: ../raster/r.covar/main.c:95 ../raster/r.out.arc/main.c:121
+#: ../raster/r.report/parse.c:243 ../raster/r.random/main.c:119
+#: ../raster/r.random/main.c:124 ../raster/r.his/main.c:127
#: ../raster/r.his/main.c:164 ../raster/r.his/main.c:189
#: ../raster/r.bilinear/main.c:81 ../raster/r.kappa/stats.c:30
#: ../raster/r.kappa/stats.c:35 ../raster/r.kappa/main.c:161
-#: ../raster/r.median/main.c:75 ../raster/r.resamp.rst/main.c:400
-#: ../raster/r.resamp.rst/main.c:426 ../raster/r.stats/main.c:272
+#: ../raster/r.median/main.c:75 ../raster/r.resamp.rst/main.c:396
+#: ../raster/r.resamp.rst/main.c:422 ../raster/r.stats/main.c:272
#: ../raster/r.slope.aspect/main.c:384 ../raster/r.colors/main.c:291
#: ../raster/r.colors/main.c:370 ../raster/r.out.ppm/main.c:116
#: ../raster/r.fill.dir/main.c:172 ../raster/r.mfilter.fp/main.c:126
-#: ../raster/r.cost/main.c:322 ../raster/r.out.vtk/main.c:47
+#: ../raster/r.cost/main.c:340 ../raster/r.out.vtk/main.c:47
#: ../raster/r.out.vtk/main.c:60 ../raster/r.support/modcolr/modcolr.c:45
#: ../raster/r.support/front/front.c:224 ../raster/r.out.bin/main.c:129
-#: ../raster/r.neighbors/main.c:185 ../raster/r.clump/main.c:87
+#: ../raster/r.neighbors/main.c:192 ../raster/r.clump/main.c:87
#: ../raster/r.to.vect/main.c:111 ../raster/r.region/main.c:170
#: ../raster/r.region/main.c:229 ../raster/r.region/main.c:352
#: ../raster/r.out.ppm3/main.c:120 ../raster/r.univar2/r.univar_main.c:148
-#: ../raster/r.watershed/ram/init_vars.c:412
-#: ../raster/r.watershed/seg/init_vars.c:461 ../raster/r.contour/main.c:158
-#: ../raster/r.cross/main.c:125 ../raster/r.cats/main.c:125
-#: ../raster/r.cats/main.c:146 ../raster/r.series/main.c:193
-#: ../raster/r.water.outlet/legal.c:23 ../raster/r.out.tiff/r.out.tiff.c:166
-#: ../raster/r.out.mpeg/main.c:217 ../raster/r.walk/main.c:523
-#: ../raster/r.walk/main.c:526 ../raster/r.mapcalc/map.c:377
-#: ../raster/r.recode/main.c:80 ../raster/r.mfilter/main.c:119
-#: ../raster/r.composite/main.c:155 ../raster/wildfire/r.ros/main.c:322
-#: ../raster/wildfire/r.ros/main.c:335 ../raster/wildfire/r.ros/main.c:340
-#: ../raster/wildfire/r.ros/main.c:345 ../raster/wildfire/r.ros/main.c:350
-#: ../raster/wildfire/r.ros/main.c:368 ../raster/wildfire/r.ros/main.c:372
-#: ../raster/wildfire/r.ros/main.c:391 ../raster/wildfire/r.ros/main.c:395
-#: ../raster/wildfire/r.ros/main.c:408 ../raster/wildfire/r.spread/main.c:356
+#: ../raster/r.contour/main.c:158 ../raster/r.cross/main.c:125
+#: ../raster/r.cats/main.c:125 ../raster/r.cats/main.c:146
+#: ../raster/r.series/main.c:193 ../raster/r.water.outlet/legal.c:23
+#: ../raster/r.out.tiff/r.out.tiff.c:166 ../raster/r.out.mpeg/main.c:217
+#: ../raster/r.walk/main.c:546 ../raster/r.walk/main.c:549
+#: ../raster/r.mapcalc/map.c:377 ../raster/r.recode/main.c:80
+#: ../raster/r.mfilter/main.c:119 ../raster/r.composite/main.c:155
+#: ../raster/wildfire/r.ros/main.c:322 ../raster/wildfire/r.ros/main.c:335
+#: ../raster/wildfire/r.ros/main.c:340 ../raster/wildfire/r.ros/main.c:345
+#: ../raster/wildfire/r.ros/main.c:350 ../raster/wildfire/r.ros/main.c:368
+#: ../raster/wildfire/r.ros/main.c:372 ../raster/wildfire/r.ros/main.c:391
+#: ../raster/wildfire/r.ros/main.c:395 ../raster/wildfire/r.ros/main.c:408
+#: ../raster/wildfire/r.spread/main.c:356
#: ../raster/wildfire/r.spread/main.c:359
#: ../raster/wildfire/r.spread/main.c:362
#: ../raster/wildfire/r.spread/main.c:365
@@ -1163,21 +1158,21 @@
#: ../raster/wildfire/r.spread/main.c:372
#: ../raster/wildfire/r.spread/main.c:375 ../raster/r.resample/main.c:97
#: ../raster/r.buffer/main.c:127 ../raster/r.support.stats/main.c:48
-#: ../raster/r.bitpattern/main.c:101 ../raster/r.sun2/main.c:791
-#: ../raster/r.sun2/main.c:804 ../raster/r.sun2/main.c:821
-#: ../raster/r.sun2/main.c:835 ../raster/r.sun2/main.c:847
-#: ../raster/r.sun2/main.c:859 ../raster/r.sun2/main.c:870
-#: ../raster/r.sun2/main.c:882 ../raster/r.sun2/main.c:894
+#: ../raster/r.bitpattern/main.c:101 ../raster/r.sun2/main.c:813
+#: ../raster/r.sun2/main.c:828 ../raster/r.sun2/main.c:845
+#: ../raster/r.sun2/main.c:859 ../raster/r.sun2/main.c:871
+#: ../raster/r.sun2/main.c:883 ../raster/r.sun2/main.c:894
+#: ../raster/r.sun2/main.c:906 ../raster/r.sun2/main.c:918
#: ../raster/r.horizon/main.c:553 ../vector/v.what.rast/main.c:138
#: ../vector/v.extrude/main.c:179 ../vector/v.sample/main.c:158
-#: ../vector/v.vol.rst/main.c:594 ../vector/v.drape/main.c:245
+#: ../vector/v.vol.rst/main.c:606 ../vector/v.drape/main.c:245
#: ../doc/raster/r.example/main.c:111 ../ps/ps.map/outl_io.c:68
#: ../imagery/i.ifft/ifftmain.c:95 ../imagery/i.ifft/ifftmain.c:105
#: ../imagery/i.gensigset/parse.c:42 ../imagery/i.his.rgb/openfiles.c:31
#: ../imagery/i.his.rgb/openfiles.c:36 ../imagery/i.his.rgb/openfiles.c:41
#: ../imagery/i.group/main.c:205 ../imagery/i.group/main.c:244
#: ../imagery/i.rgb.his/openfiles.c:14 ../imagery/i.rgb.his/openfiles.c:16
-#: ../imagery/i.rgb.his/openfiles.c:18 ../imagery/i.pca/main.c:123
+#: ../imagery/i.rgb.his/openfiles.c:18 ../imagery/i.pca/main.c:129
#: ../imagery/i.class/main.c:127 ../imagery/i.gensig/parse.c:36
#: ../imagery/i.zc/main.c:111 ../imagery/i.fft/fftmain.c:108
#: ../imagery/i.ortho.photo/photo.2target/main.c:197
@@ -1558,7 +1553,7 @@
#: ../raster3d/r3.to.rast/main.c:183 ../raster/r.resamp.stats/main.c:341
#: ../raster/r.resamp.interp/main.c:148
-#: ../raster/r.surf.fractal/write_rast.c:58 ../raster/r.los/main.c:201
+#: ../raster/r.surf.fractal/write_rast.c:58 ../raster/r.los/main.c:203
#: ../raster/r.in.ascii/main.c:206 ../raster/r.carve/main.c:189
#: ../raster/r.texture/main.c:309 ../raster/r.basins.fill/main.c:117
#: ../raster/r.null/null.c:323 ../raster/r.lake/main.c:229
@@ -1578,17 +1573,17 @@
#: ../raster/r.mapcalc/map3.c:580 ../raster/r.mapcalc/map.c:507
#: ../raster/r.composite/main.c:192 ../raster/r.buffer/write_map.c:40
#: ../raster/r.in.arc/main.c:154 ../raster/r.bitpattern/main.c:125
-#: ../raster/r.sun2/main.c:1140 ../raster/r.sun2/main.c:1147
-#: ../raster/r.sun2/main.c:1154 ../raster/r.sun2/main.c:1161
-#: ../raster/r.sun2/main.c:1168 ../raster/r.sun2/main.c:1175
-#: ../vector/lidar/v.surf.bspline/main.c:292 ../vector/v.kernel/main.c:268
-#: ../vector/v.surf.idw/main.c:258 ../vector/v.neighbors/main.c:96
+#: ../raster/r.sun2/main.c:1166 ../raster/r.sun2/main.c:1173
+#: ../raster/r.sun2/main.c:1180 ../raster/r.sun2/main.c:1187
+#: ../raster/r.sun2/main.c:1194 ../raster/r.sun2/main.c:1201
+#: ../vector/lidar/v.surf.bspline/main.c:293 ../vector/v.kernel/main.c:268
+#: ../vector/v.surf.idw/main.c:259 ../vector/v.neighbors/main.c:96
#: ../vector/v.to.rast/vect2rast.c:125 ../vector/v.to.rast/vect2rast.c:129
#: ../doc/raster/r.example/main.c:141 ../imagery/i.ifft/ifftmain.c:219
#: ../imagery/i.his.rgb/openfiles.c:15 ../imagery/i.his.rgb/openfiles.c:17
#: ../imagery/i.his.rgb/openfiles.c:19 ../imagery/i.rgb.his/openfiles.c:29
#: ../imagery/i.rgb.his/openfiles.c:31 ../imagery/i.rgb.his/openfiles.c:33
-#: ../imagery/i.smap/shapiro/opencell.c:30 ../imagery/i.pca/main.c:393
+#: ../imagery/i.smap/shapiro/opencell.c:30 ../imagery/i.pca/main.c:401
#: ../imagery/i.rectify/write.c:49 ../imagery/i.maxlik/open.c:74
#, c-format
msgid "Unable to create raster map <%s>"
@@ -1626,1168 +1621,11 @@
msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
msgstr "Nombre de archivo del mapa ráster %i: %s ya existe. ¡Se sobrescribirá!"
-#: ../locale/scriptstrings/d.m_to_translate.c:1
-msgid "Display manager for GRASS"
-msgstr "Administrador de visualización para GRASS"
-#: ../locale/scriptstrings/d.m_to_translate.c:2
-msgid "Name of .dmrc settings file"
-msgstr "Nombre del archivo de configuración .dmrc"
-#: ../locale/scriptstrings/gis.m_to_translate.c:1
-msgid "GIS manager for GRASS"
-msgstr "Administrador GIS de GRASS"
-#: ../locale/scriptstrings/gis.m_to_translate.c:2
-msgid "Name of GIS manager settings file (.grc)"
-msgstr "Nombre del archivo de preferencias del Administrador GIS (.grc)"
-#: ../locale/scriptstrings/r.li.setup_to_translate.c:1
-msgid "Configuration editor for r.li.'index'"
-msgstr "Editor de configuración para el índice r.li"
-#: ../locale/scriptstrings/r.li.setup_to_translate.c:2
-msgid "raster, landscape structure analysis"
-msgstr "ráster, análisis de estructura del paisaje"
-#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-#, fuzzy
-msgid "Prints a graph of the correlation between data layers (in pairs)."
-msgstr ""
-"presenta un gráfico de la correlación entre dos capas de datos (en pares)"
-#: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#: ../locale/scriptstrings/d.polar_to_translate.c:2
-msgid "display, diagram"
-msgstr "mostrar, diagrama"
-#: ../locale/scriptstrings/d.correlate_to_translate.c:3
-#: ../locale/scriptstrings/d.correlate_to_translate.c:4
-#: ../locale/scriptstrings/d.correlate_to_translate.c:5
-#: ../locale/scriptstrings/d.correlate_to_translate.c:6
-msgid "raster input map"
-msgstr "Mapa ráster de entrada"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:1
-msgid "Selects/starts specified monitor at specified size"
-msgstr "Selecciona/lanza un monitor determinado al tamaño especificado"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:2
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:2
-#: ../locale/scriptstrings/d.resize_to_translate.c:2
-#: ../locale/scriptstrings/d.split_to_translate.c:2
-#: ../display/d.colortable/main.c:66 ../display/d.extend/main.c:31
-msgid "display, setup"
-msgstr "mostrar, configuración"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:3
-msgid "Display monitor to start"
-msgstr "Muestra el monitor para lanzar"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:4
-msgid "Width in pixels of new display monitor"
-msgstr "Anchura en pixels del nuevo monitor"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:5
-msgid "Height in pixels of new display monitor"
-msgstr "Altura en pixels del nuevo monitor"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:1
-msgid "Moves displayed maps to another monitor"
-msgstr "Mueve los mapas que se muestran a otro monitor"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:3
-msgid "clear target monitor before moving"
-msgstr "borra el monitor de destino antes de moverlos"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:4
-msgid "stay with source monitor"
-msgstr "permanecer en el monitor orginal"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:5
-msgid "kill source monitor after moving"
-msgstr "eliminar el monitor original después de moverlo"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:6
-msgid "Target monitor"
-msgstr "Monitor de destino"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:7
-msgid "Source monitor"
-msgstr "Monitor de origen"
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:1
-msgid "Export display monitor to a GpsDrive compatible backdrop image"
-msgstr ""
-"Exporta el monitor visible a una imagen de fondo compatible con GpsDrive"
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:2
-msgid "display, export, GPS"
-msgstr "muestra, exporta, GPS"
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:3
-#, fuzzy
-msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
-msgstr "nombre para el nuevo mapa de imagen (reside en ~/.gpsdrive)"
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:4
-msgid "Make JPEG instead of PNG image"
-msgstr "Crea una imagen JPG en lugar de PNG"
-#: ../locale/scriptstrings/d.out.png_to_translate.c:1
-msgid "Saves active display monitor to PNG file in home directory"
-msgstr "Guarda el monitor activo a un archivo PNG en el directorio home"
-#: ../locale/scriptstrings/d.out.png_to_translate.c:2
-#: ../locale/scriptstrings/d.out.file_to_translate.c:2
-msgid "display, export"
-msgstr "muestra, exporta"
-#: ../locale/scriptstrings/d.out.png_to_translate.c:3
-msgid "Name of PNG file"
-msgstr "Nombre del archivo PNG"
-#: ../locale/scriptstrings/d.out.png_to_translate.c:4
-msgid "Resolution of output file (single=1, double=2, quad=4)"
-msgstr "Resolución del archivo de salida (único=1, doble=2, cuádruple=4)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:1
-msgid "Saves the contents of the active display monitor to a graphics file."
-msgstr "Guarda el contenido del monitor activo en un fichero gráfico."
-#: ../locale/scriptstrings/d.out.file_to_translate.c:3
-msgid "Name for output file (do NOT add extension)"
-msgstr "Nombre para el archivo de salida (NO añadir extensión)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:4
-#: ../visualization/nviz2/cmd/args.c:87
-msgid "Graphics file format"
-msgstr "Formato de archivo gráfico"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:5
-msgid "Dimensions of output file versus current window size"
-msgstr "Dimensiones de archivo de salida versus tamaño de la ventana actual"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:6
-msgid "(same=1, double size=2, quadruple size=4)"
-msgstr "(igual=1, doble tamaño=2, cuádruple tamaño=4)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:7
-#: ../locale/scriptstrings/d.out.file_to_translate.c:9
-#: ../locale/scriptstrings/d.out.file_to_translate.c:12
-#: ../locale/scriptstrings/d.out.file_to_translate.c:15
-#: ../locale/scriptstrings/d.out.file_to_translate.c:28
-#: ../locale/scriptstrings/d.out.file_to_translate.c:30
-msgid "Images"
-msgstr "Imágenes"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:8
-msgid "Width and height of output image (overrides resolution setting)"
-msgstr ""
-"Anchura y altura de la imagen de salida (ignora la configuración de "
-"resolución)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:10
-msgid "Compression for PNG files"
-msgstr "Compresión para archivos PNG"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:11
-msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-msgstr ""
-"(0=ninguna, 1=la más rápida, 9=máxima; sin pérdida, sólo tiempo vs. tamaño "
-"de archivo)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:13
-msgid "File size/quality for JPEG files"
-msgstr "Tamaño/calidad de archivo para archivos JPEG"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:14
-msgid "(10=smallest/worst, 100=largest/best)"
-msgstr "(10=el más pequeño/peor, 100=el más grande/mejor)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:16
-msgid "Paper size for PostScript output"
-msgstr "Tamaño de papel para salida PostScript"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:17
-#: ../locale/scriptstrings/d.out.file_to_translate.c:19
-#: ../locale/scriptstrings/d.out.file_to_translate.c:32
-msgid "PostScript"
-msgstr "PostScript"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:18
-msgid "PostScript level (only limits functionality!)"
-msgstr "Nivel PostScript (¡sólo limita la funcinalidad!)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:20
-msgid "GeoTIFF creation option(s)"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:21
-#: ../raster/r.out.gdal/main.c:185
-msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma."
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:22
-#: ../locale/scriptstrings/d.out.file_to_translate.c:25
-#: ../locale/scriptstrings/d.out.file_to_translate.c:34
-msgid "GeoTIFF"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:23
-msgid "GeoTIFF metadata key(s) and value(s) to add"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:24
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:26
-msgid "Set background color to black (white default)"
-msgstr "Ajustar el color de fondo a negro (blanco por omisión)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:27
-msgid "Set transparent background"
-msgstr "Establecer fondo transparente"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:29
-msgid "Use the Cario driver to render images"
-msgstr "Usar el controlador Cairo para representar las imágenes"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:31
-msgid "Set paper orientation to landscape (for PostScript output)"
-msgstr ""
-"Establecer la orientación del papel a horizontal (para salida PostScript)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:33
-msgid "Do not crop away margins"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:1
-msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-"Dibujar un diagrama polar de un mapa con ángulos como direcciones de "
-"orientación o corriente"
-#: ../locale/scriptstrings/d.polar_to_translate.c:3
-msgid "Name of raster angle map"
-msgstr "Nombre del mapa ráster de ángulos"
-#: ../locale/scriptstrings/d.polar_to_translate.c:4
-msgid "Pixel value to be interpreted as undefined (different from NULL)"
-msgstr "Valor pixel para interpretar como indefinido (distinto de nulo)"
-#: ../locale/scriptstrings/d.polar_to_translate.c:5
-msgid "Name of optional EPS output file"
-msgstr "Nombre del archivo de salida EPS opcional"
-#: ../locale/scriptstrings/d.polar_to_translate.c:6
-msgid "Plot using Xgraph"
-msgstr "Salida gráfica usando Xgraph"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
-#: ../display/d.rast.edit/main.c:61
-msgid "Interactively edit cell values in a raster map."
-msgstr "Editar valores de celda de forma interactiva en un mapa ráster."
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
-#: ../display/d.rast.edit/main.c:59 ../display/d.rast/main.c:51
-msgid "display, raster"
-msgstr "mostrar ráster"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
-#: ../raster/r.random/main.c:57 ../raster/r.resamp.rst/main.c:167
-#: ../raster/r.out.bin/main.c:73 ../raster/r.water.outlet/main.c:54
-#: ../imagery/i.zc/main.c:69
-msgid "Name of input raster map"
-msgstr "Nombre del mapa ráster de entrada"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:9
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
-#: ../raster/r.in.gridatb/main.c:53 ../imagery/i.ifft/ifftmain.c:83
-msgid "Name for output raster map"
-msgstr "Nombre para el mapa ráster de salida"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
-msgid "Name of aspect raster map"
-msgstr "Nombre de mapa ráster de orientación"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
-msgid "Width of display canvas"
-msgstr "Anchura de lienzo de visualización"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
-msgid "Height of display canvas"
-msgstr "Altura de lienzo de visualización"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
-msgid "Minimum size of each cell"
-msgstr "Tamaño mínimo de cada celda"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
-msgid "Maximum number of rows to load"
-msgstr "Número máximo de filas a cargar"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
-msgid "Maximum number of columns to load"
-msgstr "Número máximo de columnas a cargar"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
-msgid "Displays a raster map and its legend on a graphics window"
-msgstr "Muestra un mapa ráster y su leyenda en una ventana gráfica"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
-#: ../locale/scriptstrings/d.redraw_to_translate.c:2
-#: ../visualization/ximgview/main.c:270 ../display/d.histogram/main.c:71
-#: ../display/d.mapgraph/main.c:48 ../display/d.erase/main.c:32
-#: ../display/d.profile/main.c:61 ../display/d.measure/main.c:49
-#: ../display/d.colors/main.c:50 ../display/d.what.vect/main.c:54
-#: ../display/d.font/main.c:46 ../display/d.rast.num/number.c:84
-#: ../display/d.linegraph/linegraph.c:113 ../display/d.colorlist/main.c:35
-#: ../display/d.what.rast/main.c:52 ../display/d.title/main.c:45
-#: ../display/d.geodesic/main.c:45 ../display/d.text/main.c:66
-#: ../display/d.font.freetype/main.c:59 ../display/d.info/main.c:34
-#: ../display/d.save/main.c:79 ../display/d.rast.arrow/arrow.c:110
-#: ../display/d.menu/main.c:66 ../display/d.thematic.area/main.c:78
-#: ../display/d.text.freetype/main.c:138 ../display/d.extract/main.c:50
-#: ../display/d.rgb/main.c:55 ../display/d.where/main.c:42
-#: ../display/d.paint.labels/main.c:46 ../display/d.text.new/main.c:139
-#: ../display/d.ask/main.c:36 ../display/d.his/main.c:65
-#: ../display/d.zoom/main.c:57 ../display/d.rhumbline/main.c:45
-#: ../display/d.nviz/main.c:68 ../display/d.mon/cmd/main.c:48
-#: ../display/d.frame/frame.c:60
-msgid "display"
-msgstr "mostrar"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
-#: ../display/d.legend/main.c:184
-msgid "Flip legend"
-msgstr "Dar la vuelta a la leyenda"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
-#, fuzzy
-msgid "Omit entries with missing label"
-msgstr "omitir las entradas con una etiqueta perdida"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:4
-#: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:90
-msgid "Name of raster map"
-msgstr "Nombre del mapa ráster"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
-msgid "Number of lines to appear in the legend"
-msgstr "Número de líneas que deben aparecer en la leyenda"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
-#, fuzzy
-msgid "Name of raster map to generate legend from"
-msgstr "Nombre del mapa ráster a usar para <%s>"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
-#, fuzzy
-msgid "Name of raster map to print in legend"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
-msgid "Position of vertical map-legend separator (in percent)"
-msgstr ""
-#: ../locale/scriptstrings/d.redraw_to_translate.c:1
-msgid "Redraws the current display frame in the GRASS monitor"
-msgstr "Vuelve a dibujar el marco activo en el monitor GRASS"
-#: ../locale/scriptstrings/d.redraw_to_translate.c:3
-msgid "Redraw all frames"
-msgstr "Redibujar todos los marcos"
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-msgid "Do not preserve individual regions when redrawing all frames"
-msgstr ""
-"No preservar regiones individuales cuando se redibujan todos los marcos"
-#: ../locale/scriptstrings/d.resize_to_translate.c:1
-msgid "Resizes active display monitor"
-msgstr "Modifica el tamaño del monitor activo"
-#: ../locale/scriptstrings/d.resize_to_translate.c:3
-msgid "New width for window"
-msgstr "Nueva anchura de ventana"
-#: ../locale/scriptstrings/d.resize_to_translate.c:4
-msgid "New height for window"
-msgstr "Nueva altura de ventana"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
-msgid "Drapes a color raster over a shaded relief map using d.his"
-msgstr ""
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
-msgid "Name of shaded relief or aspect map"
-msgstr "Nombre del mapa compartido de relieve u orientación"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
-msgid "Name of raster to drape over relief map"
-msgstr "Nombre del ráster superponer sobre mapa de relieve"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
-msgid "Percent to brighten"
-msgstr "Porcentaje para aumentar el brilloConvergencia porcentual"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:1
-msgid "Slide show of GRASS raster/vector maps."
-msgstr "Presentación de mapas ráster/vectoriales de GRASS."
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:2
-msgid "display, slideshow"
-msgstr "muestra, presentación"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:3
-msgid "Show vector maps rather than raster maps"
-msgstr "Muestra mapas vectoriales en vez de mapas ráster"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:4
-msgid "Map prefix. Specify character(s) to view selected maps only"
-msgstr ""
-"Prefijo de mapa. Especificar carácter(es) para ver sólo los mapas "
-"seleccionados"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:5
-msgid "Map number show across the monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:6
-msgid "Map number show down the monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:7
-msgid "Mapsets to use. Specify multiple mapsets comma separated"
-msgstr ""
-"Directorio de mapas a usar. Especificar múltiples directorios separados por "
-"comas"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:8
-msgid "Number of seconds to pause between slides"
-msgstr "Número de segundos de pausa entre diapositivas"
-#: ../locale/scriptstrings/d.split_to_translate.c:1
-msgid ""
-"Divides active display into two frames & displays maps/executes commands in "
-"each frame."
-msgstr ""
-"Divide la visualización activa en dos marcos y muestra los mapas/ejecuta los "
-"comandos en cada uno."
-#: ../locale/scriptstrings/d.split_to_translate.c:3
-#, fuzzy
-msgid "Enter raster map to display in 1st frame"
-msgstr "Introducir mapa ráster a mostrar en el segundo marco"
-#: ../locale/scriptstrings/d.split_to_translate.c:4
-msgid "Enter command to execute in 1st frame"
-msgstr "Introducir comando a ejecutar en el primer marco"
-#: ../locale/scriptstrings/d.split_to_translate.c:5
-msgid "Enter raster map to display in 2nd frame"
-#: ../locale/scriptstrings/d.split_to_translate.c:6
-msgid "Enter command to execute in 2nd frame"
-msgstr "Introducir comando a ejecutar en el segundo marco"
-#: ../locale/scriptstrings/d.split_to_translate.c:7
-msgid "How to split display"
-msgstr "Como dividir la visualización"
-#: ../locale/scriptstrings/d.split.frame_to_translate.c:1
-#, fuzzy
-msgid "Split the display into subframes."
-msgstr "Introducir mapa ráster a mostrar en el primer marco"
-#: ../locale/scriptstrings/d.split.frame_to_translate.c:2
-#, fuzzy
-msgid "Number of subframes"
-msgstr "Número de fotogramas"
-#: ../locale/scriptstrings/d.split.frame_to_translate.c:3
-msgid "Split horizontally not vertically"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:1
-#, fuzzy
-msgid "Displays thematic vector map"
-msgstr "Visualizar mapa vectorial temático"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
-#, fuzzy
-msgid "display, vector, thematic, legend"
-msgstr "mostrar, leyenda"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:3
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:48
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:51
-msgid "Files"
-msgstr "Archivos"
-#: ../display/d.zoom/main.c:100
-msgid "Name of vector map"
-msgstr "Nombre de mapa vectorial"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:7
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:9
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:11
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:13
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:16
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:25
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:46
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:53
-#, fuzzy
-msgid "Theme"
-msgstr "Preferencias de tema"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:6
-#: ../raster/r.to.vect/main.c:64 ../vector/v.to.db/parse.c:36
-msgid "Feature type"
-msgstr "Tipo de elemento"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
-#, fuzzy
-msgid "Name of attribute column to use for thematic display (must be numeric)"
-msgstr ""
-"Columna de atributos a usar para presentación temática (debe ser numérico)"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
-msgid "Type of thematic display"
-msgstr "Tipo de visualización temática"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:12
-msgid "Thematic divisions of data for display"
-msgstr "Divisiones temáticas de los datos a mostrar"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:14
-#, fuzzy
-msgid "Break points for custom breaks option"
-msgstr ""
-"Puntos de ruptura para la opción de ruptura personalizada. Separar valores "
-"por espacios (0 10 20 30...)"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:15
-#, fuzzy
-msgid "Separate values by spaces (0 10 20 30 ...)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:17
-#: ../locale/scriptstrings/v.centroids_to_translate.c:6
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:10
-#: ../locale/scriptstrings/v.report_to_translate.c:6
-#: ../vector/v.out.vtk/main.c:83
-msgid "Layer number"
-msgstr "Número de capa"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:18
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:20
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:23
-#: ../vector/v.in.ascii/in.c:84 ../vector/v.in.ascii/in.c:91
-#: ../vector/v.in.ascii/in.c:103 ../vector/v.in.ascii/in.c:113
-#: ../vector/v.in.ascii/in.c:123 ../vector/v.in.ascii/in.c:133
-#: ../vector/v.in.ascii/in.c:157 ../vector/v.in.ascii/in.c:162
-#: ../vector/v.in.ascii/in.c:168 ../vector/v.out.ascii/out.c:67
-#: ../vector/v.out.ascii/out.c:77 ../vector/v.out.ascii/out.c:84
-#: ../vector/v.out.ascii/out.c:97
-msgid "Points"
-msgstr "Puntos"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
-msgid "Vector point icon for point data"
-msgstr "Icono de punto vectorial para datos de puntos"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
-#, fuzzy
-msgid "Icon size for point data"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
-#, fuzzy
-msgid "Minimum icon size/line width for graduated points/lines)"
-msgstr ""
-"Tamaño máximo de icono/anchura de línea para gradiente de puntos y líneas"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:24
-msgid "Maximum icon size/line width for graduated points and lines"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
-msgid "Number of classes for interval theme (integer)"
-msgstr "Número de clases para tema de intervalo (entero)"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:27
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:30
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:33
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:36
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:39
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:55
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:57
-#: ../display/d.grid/main.c:76 ../display/d.grid/main.c:81
-#: ../display/d.grid/main.c:87
-msgid "Color"
-msgstr "Color"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
-msgid "Color scheme for graduated color mapping"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:29
-#, fuzzy
-msgid "Select 'single_color' for graduated point/line display"
-msgstr ""
-"Esquema de colores para mapas en gradiente de color (seleccionar "
-"'single_color' para mostrar gradiente de puntos/líneas)"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
-#, fuzzy
-msgid "Color for graduated points map"
-msgstr "Color para datos Y"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:32
-#, fuzzy
-msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
-msgstr ""
-"Color para mapa de gradiente de puntos (nombre de color de grass o triplete "
-"R:G:B). Establecer esquema de color a un color."
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
-msgid "Color for graduated lines or point/area outlines"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:35
-#, fuzzy
-msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
-#, fuzzy
-msgid "Beginning color for custom color gradient"
-msgstr ""
-"Color inicial para gradiente de color personalizado. Se debe expresar como "
-"triplete R:G:B."
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
-#, fuzzy
-msgid "Must be expressed as R:G:B triplet"
-msgstr ""
-"Color final para gradiente de color personalizado. Se debe expresar como "
-"triplete R:G:B."
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
-#, fuzzy
-msgid "Ending color for custom color gradient"
-msgstr ""
-"triplete R:G:B."
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:59
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:61
-msgid "Misc"
-msgstr "Miscelánea"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:43
-msgid "Select x11 display monitor for legend"
-msgstr "Seleccionar monitor x11 para la leyenda"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
-msgid "Save thematic map commands to group file for GIS Manager"
-msgstr ""
-"Guardar comandos de mapa temático en archivo de grupo para el Administrador "
-"GIS"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:13
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:8
-msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr "Condiciones WHERE de sentencia SQL sin palabra clave 'where'"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:49
-#, fuzzy
-msgid "Root for the name of psmap instruction files to be in current directory"
-msgstr ""
-"Raíz para el nombre de los archivos de instrucciones psmap para estar en el "
-"directorio actual ((si no se indica, no se creará ningún archivo de "
-"instrucciones psmap)"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
-msgid "If not set, no psmap instruction files will be created)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
-msgid "Name of group file where thematic map commands will be saved"
-msgstr ""
-"Nombre de archivo de grupo en el que se guardarán los comandos del mapa "
-"temático"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:54
-msgid "Create graphic legend in x11 display monitor"
-msgstr "Crear leyenda gráfica en monitor x11"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:56
-msgid "Only draw fills (no outlines) for areas and points"
-msgstr "Dibujar sólo rellenos (no líneas exteriores) para áreas y puntos"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:58
-msgid "Update color values to GRASSRGB column in attribute table"
-msgstr ""
-"Actualizar valores de color a la columna GRASSRGB en la tabla de atributos"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:60
-msgid "Output legend for GIS Manager (for scripting use only)"
-msgstr "Producir leyenda para el Administrador GIS (sólo para uso en scripts)"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:62
-msgid "Use math notation brackets in legend"
-msgstr "Usar corchetes de anotación matemática en la leyenda"
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:1
-msgid "Drops a column from selected attribute table"
-msgstr "Elimina una columna de la tabla de atributos seleccionada"
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:3
-#: ../locale/scriptstrings/db.droptable_to_translate.c:3
-#: ../general/g.mremove/main.c:76
-msgid "Force removal (required for actual deletion of files)"
-msgstr "Forzar eliminación (requerido para la eliminación real de archivos)"
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:4
-msgid "Table from which to drop attribute column"
-msgstr "Tabla de la que eliminar una columna de atributos"
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:5
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:5
-msgid "Name of the column"
-msgstr "Nombre de la columna"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:1
-#, fuzzy
-msgid "Drops an attribute table."
-msgstr "Quitar una tabla de atributos"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:4
-msgid "Table to drop"
-msgstr "Tabla a quitar"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
-msgid "Imports attribute tables in various formats."
-msgstr "Importa tablas de atributos en varios formatos."
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
-msgid "Table file to be imported or DB connection string"
-msgstr "Archivo de tabla a importar o cadena de conexión a base de datos"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
-msgid "Table name of SQL DB table"
-msgstr "Nombre de tabla de tabla de base de datos SQL"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
-msgid "Name for output table"
-msgstr "Nombre para la tabla de salida"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
-msgid "Name for auto-generated unique key column"
-msgstr "Nombre para la columna de clave única autogenerada"
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
-msgid "Exports attribute tables into various formats."
-msgstr "Exporta tablas de atributos a varios formatos."
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
-msgid "GRASS table name"
-msgstr "Nombre de la tabla de GRASS"
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
-msgid "Table file to be exported or DB connection string"
-msgstr "Archivo de tabla a exportar o cadena de conexión a base de datos"
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-msgid "Table format"
-msgstr "Formato de la tabla"
-#: ../locale/scriptstrings/db.test_to_translate.c:1
-msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Probar el controlador de base de datos. La base de datos debe existir y "
-"estar conectada por db. connect."
-#: ../locale/scriptstrings/db.test_to_translate.c:3
-msgid "Test name"
-msgstr "Nombre de prueba"
-#: ../locale/scriptstrings/g.manual_to_translate.c:1
-msgid "Display the HTML man pages of GRASS"
-msgstr "Mostrar las páginas man HTML de GRASS"
-#: ../locale/scriptstrings/g.manual_to_translate.c:2
-msgid "general, manual, help"
-msgstr "general, manual, ayuda"
-#: ../locale/scriptstrings/g.manual_to_translate.c:3
-msgid "Display index"
-msgstr "Mostrar índice"
-#: ../locale/scriptstrings/g.manual_to_translate.c:4
-msgid "Display as MAN text page instead of HTML page in browser"
-msgstr "Mostrar como páginas de texto MAN en vez de páginas HTML en navegador"
-#: ../locale/scriptstrings/g.manual_to_translate.c:5
-msgid "Manual entry to be displayed"
-msgstr "Entrada de manual a mostrar"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr ""
-"Transformación de Brovey para fundir canales multiespectrales y "
-"pancromáticos de alta resolución"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
-#, fuzzy
-msgid "imagery, fusion, Brovey"
-msgstr "ráster imaginería, fusión"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
-#, fuzzy
-msgid "LANDSAT sensor"
-msgstr "Canal rojo LANDSAT"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:4
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
-msgid "Sensor"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
-msgid "QuickBird sensor"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:7
-msgid "SPOT sensor"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
-#, fuzzy
-msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
-msgstr "Mapa ráster de entrada (verde: tm2 | qbird_green | spot1)"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
-#, fuzzy
-msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
-msgstr "Mapa ráster entrada (NIR: tm4 | qbird_nir | spot2)"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
-#, fuzzy
-msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
-msgstr "Mapa ráster de entrada (MIR: tm5 | qbird_red | spot3)"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:12
-#, fuzzy
-msgid "Name of input raster map (etmpan | qbird_pan | spotpan)"
-msgstr "Mapa ráster de entrada (etmpan | qbird_pan | spotpan)"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:13
-#, fuzzy
-msgid "Name for output raster map prefix (e.g. 'brov')"
-msgstr "Prefijo del mapa ráster de salida (ej.: 'brov')"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
-msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-msgstr ""
-"Hace mosaicos de hasta 4 imágenes y extiende colormap; crea mapas *.mosaico"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
-msgid "raster, imagery, mosaicking"
-msgstr "ráster, imaginería, creación de mosaicos"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
-msgid "1st map for mosaic (top of image stack)."
-msgstr "Primer mapa para mosaico (superior de la pila de imágenes)."
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
-msgid "2nd map for mosaic."
-msgstr "Segundo mapa para mosaico."
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:5
-msgid "3rd map for mosaic."
-msgstr "Tercer mapa para mosaico."
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:6
-msgid "4th map for mosaic."
-msgstr "Cuarto mapa para mosaico."
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
-msgid "Import of SPOT VGT NDVI file into a raster map"
-msgstr "Importar archivo SPOT VGT NDVI a un mapa ráster"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
-msgid "raster, imagery, import"
-msgstr "ráster, imaginería, importar"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
-msgid "also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-"importar también mapa de calidad (capa de mapa de estado SM) y filtrar mapa "
-"NDVI"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
-msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-msgstr "archivo SPOT VGT NDVI HDF existente (0001_NDV.HDF)"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:1
-#, fuzzy
-msgid "Performs auto-balancing of colors for LANDSAT images."
-msgstr "Balance automático de colores para imágenes LANDSAT"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
-msgid "raster, imagery, colors"
-msgstr "ráster, imaginería, colores"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
-msgid "LANDSAT red channel"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:4
-msgid "LANDSAT green channel"
-msgstr "Canal verde LANDSAT"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:5
-msgid "LANDSAT blue channel"
-msgstr "Canal azul LANDSAT"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:6
-msgid "Cropping intensity (upper brightness level)"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:7
-msgid "Extend colors to full range of data on each channel"
-msgstr "Extender colores a todo el intervalo de datos de cada canal"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:8
-msgid "Preserve relative colors, adjust brightness only"
-msgstr "Conservar colore relativos, sólo ajustar brillo"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
-msgid "Reset to standard color range"
-msgstr "Restablecer al intervalo de colores estándar"
-#: ../locale/scriptstrings/i.oif_to_translate.c:1
-msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr "Calcula tabla de Factor de Índice Óptimo para bandas LANDSAT 1-5 y 7"
-#: ../locale/scriptstrings/i.oif_to_translate.c:2
-msgid "raster, imagery, statistics"
-msgstr "ráster, imaginería, estadísticas"
-#: ../locale/scriptstrings/i.oif_to_translate.c:3
-msgid "LANDSAT TM band 1."
-msgstr "LANDSAT TM banda 1."
-#: ../locale/scriptstrings/i.oif_to_translate.c:4
-msgid "LANDSAT TM band 2."
-msgstr "LANDSAT TM banda 2."
-#: ../locale/scriptstrings/i.oif_to_translate.c:5
-msgid "LANDSAT TM band 3."
-msgstr "LANDSAT TM banda 3."
-#: ../locale/scriptstrings/i.oif_to_translate.c:6
-msgid "LANDSAT TM band 4."
-msgstr "LANDSAT TM banda 4."
-#: ../locale/scriptstrings/i.oif_to_translate.c:7
-msgid "LANDSAT TM band 5."
-msgstr "LANDSAT TM banda 5."
-#: ../locale/scriptstrings/i.oif_to_translate.c:8
-msgid "LANDSAT TM band 7."
-msgstr "LANDSAT TM banda 7."
-#: ../locale/scriptstrings/i.oif_to_translate.c:9
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:3
-#: ../general/g.region/main.c:133
-msgid "Print in shell script style"
-msgstr "Imprimir en estilo de script de consola"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:1
-#, fuzzy
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-"muestra la respuesta espectral en localizaciones especificadas por el "
-"usuario en grupo o imágenes"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:2
-msgid "imagery, raster, multispectral"
-msgstr "imaginería, ráster, multiespectral"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:3
-#, fuzzy
-msgid "Group input"
-msgstr "entrada de grupo"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:4
-#, fuzzy
-msgid "Raster input maps"
-msgstr "mapas ráster de entrada"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:5
-#, fuzzy
-msgid "Write output to PNG image"
-msgstr "escribir la salida a imagen PNG"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:6
-msgid "Use image list and not group"
-msgstr "Usar lista de imágenes y no grupo"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-msgid "Select multiple points"
-msgstr "Seleccionar múltiples puntos"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:8
-#, fuzzy
-msgid "Label with coordinates instead of numbering"
-msgstr "Etiquetar con coordenadas en vez de numeración"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
-msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr "Transformación Tasseled Cap (Kauth Thomas) para datos LANDSAT-TM"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
-msgid "raster, imagery"
-msgstr "ráster, imaginería"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
-msgid "use transformation rules for LANDSAT-4"
-msgstr "usar reglas de transformación para LANDSAT-4"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
-msgid "use transformation rules for LANDSAT-5"
-msgstr "usar reglas de transformación para LANDSAT-5"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
-msgid "use transformation rules for LANDSAT-7"
-msgstr "usar reglas de transformación para LANDSAT-7"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
-msgid "raster input map (LANDSAT channel 1)"
-msgstr "mapa ráster de entrada (canal LANDSAT 1)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid "raster input map (LANDSAT channel 2)"
-msgstr "mapa ráster de entrada (canal LANDSAT 2)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
-msgid "raster input map (LANDSAT channel 3)"
-msgstr "mapa ráster de entrada (canal LANDSAT 3)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
-msgid "raster input map (LANDSAT channel 4)"
-msgstr "mapa ráster de entrada (canal LANDSAT 4)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-msgid "raster input map (LANDSAT channel 5)"
-msgstr "mapa ráster de entrada (canal LANDSAT 5)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
-msgid "raster input map (LANDSAT channel 7)"
-msgstr "mapa ráster de entrada (canal LANDSAT 7)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
-msgid "raster output TC maps prefix"
-msgstr "prefijo de mapas TC ráster de salida"
-#: ../locale/scriptstrings/m.proj_to_translate.c:1
-msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-msgstr "Convierte coordenadas de una proyección a otra (interfaz cs2cs)."
-#: ../locale/scriptstrings/m.proj_to_translate.c:2
-msgid "miscellaneous, projection"
-msgstr "miscelánea, proyección"
-#: ../locale/scriptstrings/m.proj_to_translate.c:3
-msgid "Input coordinate file (omit to read from stdin)"
-msgstr "Archivo de coordenadas de entrada (omitir para leer de stdin)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:4
-msgid "Output coordinate file (omit to send to stdout)"
-msgstr "Archivo de coordenadas de salida (omitir para enviar a stdout)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
-msgid "Field separator"
-msgstr "Separador de campos"
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
-msgid "Input projection parameters (PROJ.4 style)"
-msgstr "Parámetros de la proyección de entrada (en estilo PROJ.4)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
-msgid "Output projection parameters (PROJ.4 style)"
-msgstr "Parámetros de la proyección de salida (en estilo PROJ.4)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-msgid "Use LL WGS84 as input and current location as output projection"
-msgstr ""
-"Usar LL WGS84 como entrada y la localización actual como proyección de salida"
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
-msgid "Use current location as input and LL WGS84 as output projection"
-msgstr ""
-"Usar la localización actual como entrada y LL WGS84 como proyección de salida"
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
-msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
-"places"
-msgstr ""
-"Producir latitud/longitud en grados decimales u otras proyecciones con "
-"muchos decimales"
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
-msgid "Verbose mode (print projection parameters and filenames to stderr)"
-msgstr ""
-"Modo verboso (imprimir parámetros de proyección y nombres de archivo a "
-"stderr)"
-#: ../locale/scriptstrings/r.blend_to_translate.c:1
-#, fuzzy
-msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"Mezcla los componentes de color de dos mapas ráster en la proporción indicada"
-#: ../locale/scriptstrings/r.blend_to_translate.c:2
#: ../raster/r.describe/main.c:59 ../raster/r.rescale.eq/main.c:52
#: ../raster/r.surf.area/main.c:88 ../raster/r.coin/main.c:66
#: ../raster/r.out.png/r.out.png.c:136 ../raster/r.distance/main.c:38
#: ../raster/r.reclass/main.c:49 ../raster/r.los/main.c:82
-#: ../raster/r.drain/main.c:94 ../raster/r.carve/main.c:77
+#: ../raster/r.drain/main.c:108 ../raster/r.carve/main.c:77
#: ../raster/r.profile/main.c:53 ../raster/r.texture/main.c:74
#: ../raster/r.basins.fill/main.c:53 ../raster/r.sum/main.c:46
#: ../raster/r.sun/main.c:175 ../raster/r.volume/main.c:57
@@ -2801,7 +1639,7 @@
#: ../raster/r.grow2/main.c:128 ../raster/r.circle/dist.c:51
#: ../raster/r.thin/main.c:55 ../raster/r.surf.contour/main.c:50
#: ../raster/r.topidx/main.c:37 ../raster/r.out.pov/main.c:121
-#: ../raster/r.covar/main.c:53 ../raster/r.out.arc/main.c:59
+#: ../raster/r.covar/main.c:53 ../raster/r.out.arc/main.c:60
#: ../raster/r.rescale/main.c:50 ../raster/r.random/main.c:51
#: ../raster/r.sunmask/main.c:125 ../raster/r.his/main.c:63
#: ../raster/r.topmodel/main.c:55 ../raster/r.bilinear/main.c:42
@@ -2810,1432 +1648,23 @@
#: ../raster/r.surf.gauss/main.c:46 ../raster/r.fill.dir/main.c:84
#: ../raster/r.timestamp/main.c:35 ../raster/r.what/main.c:92
#: ../raster/r.out.vtk/main.c:148 ../raster/r.out.bin/main.c:63
-#: ../raster/r.neighbors/main.c:106 ../raster/r.what.color/main.c:88
+#: ../raster/r.neighbors/main.c:107 ../raster/r.what.color/main.c:88
#: ../raster/r.in.gridatb/main.c:41 ../raster/r.to.vect/main.c:50
#: ../raster/r.region/main.c:54 ../raster/r.out.ppm3/main.c:57
-#: ../raster/r.in.mat/main.c:92 ../raster/r.watershed/front/main.c:52
+#: ../raster/r.in.mat/main.c:92 ../raster/r.watershed/front/main.c:56
#: ../raster/r.quant/main.c:41 ../raster/r.cross/main.c:75
#: ../raster/r.cats/main.c:51 ../raster/r.out.mpeg/main.c:384
-#: ../raster/r.walk/main.c:174 ../raster/r.gwflow/main.c:223
+#: ../raster/r.walk/main.c:177 ../raster/r.gwflow/main.c:223
#: ../raster/wildfire/r.ros/main.c:212
#: ../raster/wildfire/r.spreadpath/main.c:72
#: ../raster/wildfire/r.spread/main.c:101 ../raster/r.resample/main.c:54
#: ../raster/r.in.arc/main.c:59 ../raster/r.bitpattern/main.c:62
-#: ../raster/r.grow.distance/main.c:130 ../raster/r.horizon/main.c:178
+#: ../raster/r.grow.distance/main.c:130 ../raster/r.sun2/main.c:226
+#: ../raster/r.horizon/main.c:178
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:153
msgid "raster"
msgstr "ráster"
-#: ../locale/scriptstrings/r.blend_to_translate.c:3
-msgid "Name of first raster map for blending"
-msgstr "Nombre del primer mapa ráster a mezclar"
-#: ../locale/scriptstrings/r.blend_to_translate.c:4
-msgid "Name of second raster map for blending"
-msgstr "Nombre del segundo mapa ráster a mezclar"
-#: ../locale/scriptstrings/r.blend_to_translate.c:5
-#, fuzzy
-msgid "Base name for red, green and blue output maps containing the blend"
-msgstr ""
-"Nombre base para los mapas de salida rojo, verde y azul que contendrán la "
-"mezcla"
-#: ../locale/scriptstrings/r.blend_to_translate.c:6
-msgid "Percentage weight of first map for color blending"
-msgstr "Porcentaje de peso del primer mapa para la mezcla de color"
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Set color rules based on stddev from a map's mean value."
-msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
-#: ../raster/r.colors/main.c:165
-#, fuzzy
-msgid "raster, color table"
-msgstr "ráster, remuestrear"
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
-#, fuzzy
-msgid "Color using standard deviation bands"
-msgstr ""
-"medias y desviaciones estándar para %d banda %s\n"
-"\n"
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
-msgid "Force center at zero"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
-msgid ""
-"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-msgstr ""
-"Rellenar áreas sin datos de los mapas ráster usando la interpolación splines "
-"de v.sufr.rst"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
-msgid "raster, elevation, interpolation"
-msgstr "ráster, elevación, interpolación"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
-msgid "Raster map in which to fill nulls"
-msgstr "Mapa ráster en el que rellenar los nulos"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-msgid ""
-"Output raster map with nulls filled by interpolation from surrounding values"
-msgstr ""
-"Producir mapa ráster con nulos rellenos por interpolación de los valores "
-"circundantes"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
-msgid "Spline tension parameter"
-msgstr "Parámetro de tensión spline"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
-msgid "Spline smoothing parameter"
-msgstr "Parámetro de suavizado spline"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
-msgstr ""
-"Georreferenciar, rectificar e importar imaginería Terra ASTER y MDT "
-"relativos usando gdalwarp."
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
-msgid "Input ASTER image to be georeferenced & rectified"
-msgstr "Imagen ASTER de entrada a georreferenciar y rectificar"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
-msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
-msgstr ""
-"Tipo de procesado de Imaginería ASTER (Nivel 1A, Nivel 1B o MDT relacionado)"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-msgid ""
-"L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
-"single band"
-msgstr ""
-"Banda L1A o L1B a traducir (1, 2, 3n, 3b, 4-14). Sólo se puede traducir una "
-"banda"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
-msgid "Import SRTM HGT files into GRASS"
-msgstr "Importar archivos SRTM HGT a GRASS"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#: ../raster/r.in.bin/main.c:122 ../raster/r.in.gdal/main.c:79
-#: ../raster/r.in.poly/main.c:29 ../raster/r.external/main.c:505
-msgid "raster, import"
-msgstr "ráster, importar"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
-msgid "SRTM input tile (file without .hgt.zip extension)"
-msgstr "Archivo de entrada SRTM (archivo sin extensión .hgt.zip)"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
-msgid "Output raster map (default: input tile)"
-msgstr "Mapa ráster de salida (por omisión: tesela de entrada)"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
-msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
-msgstr ""
-msgid "Downloads and imports data from WMS servers."
-msgstr "Descarga e importa datos de servidores WMS."
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
-msgid "wms"
-msgstr "wms"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
-#: ../vector/v.in.dxf/main.c:82 ../vector/v.in.dwg/main.c:96
-msgid "List available layers and exit"
-msgstr "Listar las capas disponibles y salir"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:21
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:25
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:27
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:29
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:31
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:49
-msgid "Request"
-msgstr "Solicitud"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
-msgid "Skip to downloading (to resume downloads faster)"
-msgstr "Saltar la descarga (para continuar descargas más rápido)"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:42
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:44
-msgid "Download"
-msgstr "Descargar"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
-#, fuzzy
-msgid "Don't request transparent data"
-msgstr "No solicitar datos transparentes."
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
-#, fuzzy
-msgid "Clean existing data out of download directory"
-msgstr "Eliminar datos existentes del directorio de descarga."
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
-#: ../raster/r.in.gdal/main.c:140
-msgid "Keep band numbers instead of using band color names"
-msgstr "Mantener números de banda en vez de usar nombre de color de banda"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:19
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:46
-msgid "Import"
-msgstr "Importar"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
-#, fuzzy
-msgid "Don't reproject the data, just patch it"
-msgstr "No reproyectar los datos, sólo parchearlos."
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid "Use GET method instead of POST data method"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
-msgid "This may be needed to connect to servers which lack POST capability"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
-msgid "Mapserver to request data from"
-msgstr "Servidor de mapas del que solicitar los datos"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
-msgid "Layers to request from map server"
-msgstr "Capas a solicitar del servidor de mapas"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
-msgid "Styles to request from map server"
-msgstr "Estilos a solicitar del servidor de mapas"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
-msgid "Source projection to request from server"
-msgstr "Proyección de origen a solicitar del servidor"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
-msgid "Image format requested from the server"
-msgstr "Formato de imagen solicitado del servidor"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-msgid "Addition query options for server"
-msgstr "Opciones de consulta adicionales para el servidor"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
-msgid "Maximum columns to request at a time"
-msgstr "Máximo de columnas a solicitar a la vez"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
-msgid "Maximum rows to request at a time"
-msgstr "Máximo de filas a solicitar a la vez"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
-msgid "Additional options for r.tileset"
-msgstr "Opciones adicionales para r.tileset"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
-msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
-"Nombre de la región para la que solicitar datos. Región actual si se omite"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
-msgid "Folder to save downloaded data to"
-msgstr "Carpeta en la que guardar los datos descargados"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:41
-msgid "Additional options for wget"
-msgstr "Opciones adicionales para wget"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:43
-msgid "Additional options for curl"
-msgstr "Opciones adicionales para curl"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:45
-msgid "Reprojection method to use"
-msgstr "Método de reproyección a usar"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:47
-msgid "Filename to save capabilities XML file to"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:48
-#, fuzzy
-msgid "Requires list available layers flag"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:50
-#: ../locale/scriptstrings/r.tileset_to_translate.c:14
-msgid "Verbosity level"
-msgstr "Nivel de verbosidad"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:1
-msgid "Calculate new raster map from a r.mapcalc expression."
-msgstr "Calcular un nuevo mapa ráster a partir de una expresión r.mapcalc."
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:2
-msgid "A"
-msgstr "A"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:3
-msgid "B"
-msgstr "B"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:4
-msgid "C"
-msgstr "C"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:5
-msgid "D"
-msgstr "D"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:6
-msgid "E"
-msgstr "E"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:7
-msgid "F"
-msgstr "F"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:8
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:8
-msgid "Formula (e.g. A-B or A*C+B)"
-msgstr "Formula (ej. A-B o A*C+B)"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:10
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:10
-msgid "Show help"
-msgstr "Mostrar ayuda"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:11
-msgid "Expert mode (enter a set of r.mapcalc expressions)"
-msgstr "Modo avanzado (introducir un conjunto de expresiones de r.mapcalc)"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:12
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:12
-msgid "Do not overwrite existing map"
-msgstr "No sobrescribir mapas existentes"
-#: ../locale/scriptstrings/r.mask_to_translate.c:1
-msgid "Create a MASK for limiting raster operation"
-msgstr "Crear una MÁSCARA para limitar la operación ráster"
-#: ../locale/scriptstrings/r.mask_to_translate.c:2
-msgid "raster, mask"
-msgstr "ráster, máscara"
-#: ../locale/scriptstrings/r.mask_to_translate.c:3
-msgid "Raster map to use as MASK"
-msgstr "Mapa ráster a usar como MÁSCARA"
-#: ../locale/scriptstrings/r.mask_to_translate.c:4
-msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-msgstr "Valores de categoría a usar para MÁSCARA (formato: 1 2 3 thru 7 *)"
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-msgid "Create inverse MASK from specified 'maskcats' list"
-msgstr "Crear MASK inversa a partir de la lista 'maskcats' especificada"
-#: ../locale/scriptstrings/r.mask_to_translate.c:6
-msgid "Overwrite existing MASK"
-msgstr "Sobrescribir MÁSCARA existente"
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-msgid "Remove existing MASK (overrides other options)"
-msgstr "Eliminar MÁSCARA existente (ignora otras opciones)"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:1
-msgid "Exports GRASS raster into GDAL supported formats."
-msgstr "Exporta un ráster de GRASS a formatos soportados por GDAL."
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:2
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
-#: ../raster/r.out.ascii/main.c:59 ../raster/r.out.gdal/main.c:126
-#: ../raster/r.out.mat/main.c:64 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.tiff/r.out.tiff.c:99
-msgid "raster, export"
-msgstr "ráster, exportar"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:3
-#: ../raster/r.out.gdal/main.c:130
-msgid "List supported output formats"
-msgstr "Listar formatos de salida soportados"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:4
-msgid "Region sensitive output"
-msgstr "Salida sensible a región"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:6
-#: ../raster/r.out.gdal/main.c:147
-msgid "GIS format to write (case sensitive, see also -l flag)"
-msgstr ""
-"Formato GIS a escribir (sensible a mayúsculas, ver también la opción -l)"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:7
-#: ../raster/r.out.gdal/main.c:168
-msgid "File type"
-msgstr "Tipo de archivo"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:8
-#: ../raster/r.out.mpeg/main.c:406
-msgid "Name for output file"
-msgstr "Nombre para el archivo de salida"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:9
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed"
-msgstr ""
-"Opción de creación para el controlador de formato de salida. Se pueden "
-"indicar múltiples opciones."
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:10
-msgid "Metadata key passed on the output dataset if possible"
-msgstr ""
-"Clave de metadatos pasados al conjunto de datos de salida si es posible"
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"Exportar un mapa ráster a un archivo de texto como valores X, Y, Z basados "
-"en los centros de las celdas."
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#: ../raster/r.stats/main.c:116
-msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr "Nombre para el archivo de salida (si se omite o \"-\" salida a stdout)"
-#: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Crea un mapa ráster plano dando pendiente (inclinación), orientación "
-"(azimut) y un punto."
-#: ../locale/scriptstrings/r.plane_to_translate.c:2
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
-msgid "raster, elevation"
-msgstr "ráster, elevación"
-#: ../locale/scriptstrings/r.plane_to_translate.c:3
-msgid "Name of raster plane to be created"
-msgstr "Nombre del plano ráster a crear"
-#: ../locale/scriptstrings/r.plane_to_translate.c:4
-msgid "Dip of plane. Value must be between -90 and 90 degrees"
-msgstr "Pendiente del plano. El valor debe estar entre -90 y 90 grados"
-#: ../locale/scriptstrings/r.plane_to_translate.c:5
-msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
-msgstr "Azimut del plano. El valor debe estar entre 0 y 360 grados"
-#: ../locale/scriptstrings/r.plane_to_translate.c:6
-msgid "Easting coordinate of a point on the plane"
-msgstr "Coordenada Este de un punto en el plano"
-#: ../locale/scriptstrings/r.plane_to_translate.c:7
-msgid "Northing coordinate of a point on the plane"
-msgstr "Coordenada Norte de un punto en el plano"
-#: ../locale/scriptstrings/r.plane_to_translate.c:8
-msgid "Elevation coordinate of a point on the plane"
-msgstr "Coordenada de elevación de un punto en el plano"
-#: ../locale/scriptstrings/r.plane_to_translate.c:9
-msgid "Type of the raster map to be created"
-msgstr "Tipo de mapa ráster a crear"
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-#, fuzzy
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Reclasifica un mapa ráster mayor o menor que la superficie indicada por el "
-"usuario (en hectáreas)"
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
-msgid "raster, statistics, aggregation"
-msgstr "ráster, estadísticas, agregación"
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
-#, fuzzy
-msgid "Lesser value option that sets the <= area size limit [hectares]"
-msgstr ""
-"Opción de valor menor que establece el <= límite de tamaño de área "
-"(hectáreas)"
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
-#, fuzzy
-msgid "Greater value option that sets the >= area size limit [hectares]"
-msgstr ""
-"Opción de valor mayor que establece el >= límite de tamaño de área "
-"(hectáreas)"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:1
-msgid "Calculates linear regression from two raster maps: y = a + b*x"
-msgstr "Calcula la regresión lineal de dos mapas ráster: y = a + b*x"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:2
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:2
-#: ../raster/r.statistics/main.c:42 ../raster/r.report/main.c:64
-#: ../raster/r.quantile/main.c:243 ../raster/r.stats/main.c:105
-#: ../raster/r.univar2/r.univar_main.c:75
-msgid "raster, statistics"
-msgstr "ráster, estadísticas"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:4
-msgid "Slower but accurate (applies to FP maps only)"
-msgstr ""
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:5
-msgid "Map for x coefficient"
-msgstr "Mapa para el coeficiente X"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:6
-msgid "Map for y coefficient"
-msgstr "Mapa para el coeficiente Y"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:7
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
-msgstr ""
-"Archivo ASCII para guardar los coeficientes de regresión (salida a pantalla "
-"si no se especifica ningún archivo)."
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
-msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-"Crea un mapa compartido de relieve a partir de un mapa de elevaciones (DEM)."
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
-#: ../raster/r.topidx/main.c:42
-msgid "Input elevation map"
-msgstr "Mapa de elevación de entrada"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:4
-msgid "Output shaded relief map name"
-msgstr "Nombre del mapa compartido de relieve de salida"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
-msgid "Altitude of the sun in degrees above the horizon"
-msgstr "Altura del sol sobre el horizonte en grados"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:6
-msgid "Azimuth of the sun in degrees to the east of north"
-msgstr "Azimut del sol al Este del Norte en grados"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:7
-msgid "Factor for exaggerating relief"
-msgstr "Factor para exagerar el relive"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
-msgid "Scale factor for converting horizontal units to elevation units"
-msgstr ""
-"Factor de escala para convertir unidades horizontales a unidades de elevación"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
-#, fuzzy
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
-msgstr ""
-"Establecer factor de escala (aplicable sólo a localizaciones latitud/"
-"longitud)"
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Produce teselado de la proyección del origen para usarlo en la región y "
-"proyección de destino."
-#: ../locale/scriptstrings/r.tileset_to_translate.c:2
-msgid "raster, tiling"
-msgstr "ráster, teselado"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:3
-msgid "Produces shell script output"
-msgstr "Produce salida de script de consola"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:4
-msgid "Produces web map server query string output"
-msgstr "Produce salida de cadena de consulta de servidor web de mapas"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
-"Nombre de la región a usar en vez de la actual para contornos y resolución"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid "Source projection"
-msgstr "Proyeccion del origen"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:7
-#: ../locale/scriptstrings/r.tileset_to_translate.c:9
-msgid "Conversion factor from units to meters in source projection"
-msgstr ""
-"Factor de conversión de las unidades a metros en la proyección de origen"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:8
-msgid "Destination projection, defaults to this location's projection"
-msgstr "Proyección de destino, por omisión la proyección de esta localización"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:10
-msgid "Maximum number of columns for a tile in the source projection"
-msgstr "Número máximo de columnas para una tesela en la proyección de origen"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:11
-msgid "Maximum number of rows for a tile in the source projection"
-msgstr "Número máximo de filas para una tesela en la proyección de origen"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:12
-msgid "Number of cells tiles should overlap in each direction"
-msgstr "El número de teselas de celda debería solapas en cada dirección"
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:1
-msgid "calculates univariate statistics from a GRASS raster map"
-msgstr "Calcula estadísticas univariantes a partir de un mapa ráster de GRASS."
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:3
-msgid "extended statistics (quartiles and percentile)"
-msgstr "estadísticas ampliadas (cuartiles y percentiles)"
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:5
-msgid "Percentile to calculate (requires -e flag)"
-msgstr "Percentil a calcular (requiere la opción -e)"
-msgid "Calculates new grid3D volume from r3.mapcalc expression."
-msgstr "Calcula un nuevo volumen grid3D a partir de una expresión r3.mapcalc."
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:2
-msgid "A (grid3D file)"
-msgstr "A (archivo grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:3
-msgid "B (grid3D file)"
-msgstr "B (archivo grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:4
-msgid "C (grid3D file)"
-msgstr "C (archivo grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:5
-msgid "D (grid3D file)"
-msgstr "D (archivo grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:6
-msgid "E (grid3D file)"
-msgstr "E (archivo grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:7
-msgid "F (grid3D file)"
-msgstr "F (archivo grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:9
-msgid "Name for output grid3D volume"
-msgstr "Nombre para el volumen grid3D de salida"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:11
-msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-msgstr "Modo experto (introducir un conjunto de expresiones r3.mapcalc)"
-#: ../locale/scriptstrings/v.build.all_to_translate.c:1
-msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr ""
-"Reconstruye la topología de todos los mapas vectoriales en el directorio de "
-"mapas actual"
-#: ../locale/scriptstrings/v.build.all_to_translate.c:2
-#: ../vector/v.external/main.c:58 ../vector/v.perturb/main.c:73
-#: ../vector/v.sample/main.c:86 ../vector/v.in.region/main.c:38
-#: ../vector/v.info/main.c:257 ../vector/v.patch/main.c:68
-#: ../vector/v.vol.rst/main.c:202 ../vector/v.mkgrid/main.c:63
-#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.voronoi/dt_main.c:46
-#: ../vector/v.voronoi/vo_main.c:119 ../vector/v.out.vtk/main.c:46
-#: ../vector/v.surf.rst/main.c:160 ../vector/v.buffer/main.c:254
-#: ../vector/v.delaunay2/main.c:62
-msgid "vector"
-msgstr "vectorial"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:1
-msgid "Adds missing centroids to closed boundaries."
-msgstr "Añade los centroides que faltan a contornos cerrados."
-#: ../locale/scriptstrings/v.centroids_to_translate.c:2
-msgid "vector, centroid, area"
-msgstr "vectorial, centroide, área"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:3
-#: ../locale/scriptstrings/v.colors_to_translate.c:3
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:6
-#: ../locale/scriptstrings/v.report_to_translate.c:5
-msgid "Name of input vector map"
-msgstr "Nombre del mapa vectorial de entrada"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:4
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:6
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
-msgid "Name for output vector map"
-msgstr "Nombre para el mapa vectorial de salida"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:5
-msgid "Action to be taken"
-msgstr "Acción a tomar"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:7
-msgid "Category number starting value"
-msgstr "Valor inicial de número de categoría"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:8
-#: ../vector/v.category/main.c:112
-msgid "Category increment"
-msgstr "Incremento de categoría"
-#: ../locale/scriptstrings/v.colors_to_translate.c:1
-msgid ""
-"Set color rules for features in a vector using a numeric attribute column."
-msgstr ""
-#: ../locale/scriptstrings/v.colors_to_translate.c:2
-#, fuzzy
-msgid "vector, color table"
-#: ../locale/scriptstrings/v.colors_to_translate.c:4
-#, fuzzy
-msgid "Name of column containg numeric data"
-msgstr "Nombre de la columna que contiene las coordenadas X"
-#: ../locale/scriptstrings/v.colors_to_translate.c:5
-#, fuzzy
-msgid "Layer number of data column"
-msgstr "Capa a la que añadir la columna"
-#: ../locale/scriptstrings/v.colors_to_translate.c:6
-#, fuzzy
-msgid "Name of color column to populate"
-msgstr "Nombre de la columna a mostrar"
-#: ../locale/scriptstrings/v.colors_to_translate.c:7
-#: ../locale/scriptstrings/v.colors_to_translate.c:10
-#: ../locale/scriptstrings/v.colors_to_translate.c:12
-#: ../locale/scriptstrings/v.colors_to_translate.c:14
-#: ../locale/scriptstrings/v.colors_to_translate.c:17
-#: ../raster/r.colors/main.c:183 ../raster/r.colors/main.c:197
-#: ../raster/r.colors/main.c:215 ../raster/r.colors/main.c:220
-#: ../raster/r.colors/main.c:225 ../raster/r.colors/main.c:230
-#: ../vector/v.label.sa/main.c:149 ../vector/v.label.sa/main.c:159
-#: ../vector/v.label.sa/main.c:166 ../vector/v.label.sa/main.c:176
-#: ../vector/v.label.sa/main.c:186 ../vector/v.label.sa/main.c:196
-#: ../vector/v.label.sa/main.c:203 ../vector/v.label/main.c:153
-#: ../vector/v.label/main.c:177 ../vector/v.label/main.c:190
-#: ../vector/v.label/main.c:196 ../vector/v.label/main.c:206
-#: ../display/d.vect/main.c:164 ../display/d.vect/main.c:174
-#: ../display/d.vect/main.c:181 ../display/d.vect/main.c:192
-#: ../display/d.vect/main.c:344 ../display/d.vect/main.c:350
-msgid "Colors"
-msgstr "Colores"
-#: ../locale/scriptstrings/v.colors_to_translate.c:8
-#, fuzzy
-msgid "Manually set range (min,max)"
-msgstr "Rango de enteros: mínimo, máximo"
-#: ../locale/scriptstrings/v.colors_to_translate.c:9
-#: ../raster/r.colors/main.c:181
-msgid "Type of color table"
-msgstr "Tipo de tabla de colores"
-#: ../locale/scriptstrings/v.colors_to_translate.c:11
-#: ../raster/r.colors/main.c:191
-msgid "Raster map name from which to copy color table"
-msgstr "Nombre del mapa ráster del que copiar la tabla de colores"
-#: ../locale/scriptstrings/v.colors_to_translate.c:13
-msgid "Path to rules file"
-msgstr "Ruta al archivo de reglas"
-#: ../locale/scriptstrings/v.colors_to_translate.c:15
-#, fuzzy
-msgid "Save placeholder raster map for use with d.legend"
-#: ../locale/scriptstrings/v.colors_to_translate.c:16
-#: ../raster/r.colors/main.c:214
-msgid "Invert colors"
-msgstr "Invertir colores"
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-msgid ""
-"Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
-"format"
-msgstr ""
-"Convierte todos los mapas vectoriales del antiguo GRASS < Ver5.7 del "
-"directorio de mapas actual al formato actual."
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:2
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
-#: ../vector/v.in.dxf/main.c:60 ../vector/v.in.ascii/in.c:48
-#: ../vector/v.in.ogr/main.c:101 ../vector/v.in.dwg/main.c:65
-msgid "vector, import"
-msgstr "vectorial, importar"
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
-msgid "run non-interactively"
-msgstr "ejecutar de forma no interactiva"
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Añade una o más columnas a la tabla de atributos conectada a un mapa "
-"vectorial dado."
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.join_to_translate.c:2
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:2
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
-#: ../locale/scriptstrings/v.db.update_to_translate.c:2
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
-#: ../vector/v.db.connect/main.c:50 ../vector/v.distance/main.c:115
-#: ../vector/v.db.select/main.c:52 ../vector/v.to.db/main.c:32
-msgid "vector, database, attribute table"
-msgstr "vectorial, base de datos, tabla de atributos"
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
-msgid "Vector map for which to edit attribute table"
-msgstr "Mapa vectorial para el que editar la tabla de atributos"
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:4
-msgid "Layer where to add column"
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-#, fuzzy
-msgid ""
-"Name and type of the new column(s) (types depend on database backend, but "
-"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-msgstr ""
-"Nombre y tipo de la nueva columna(s) (los tipos dependen de la base de datos "
-"de destino, pero todas soportan VARCHAR(), ENTERO, DOBLE Y FECHA)"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-msgid ""
-"Creates and adds a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"Crea y añade una nueva tabla de atributos a una capa dada de un mapa "
-"vectorial existente."
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
-msgid "Vector map for which to add new attribute table"
-msgstr "Mapa vectorial al que añadir nueva tabla de atributos"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
-msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
-"Nombre de la nueva tabla de atributos (por omisión: nombre del mapa "
-"vectorial)"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
-msgid "Layer where to add new attribute table"
-msgstr "Capa a la que añadir la nueva tabla de atributos"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:1
-msgid "Allows to join a table to a vector map table."
-msgstr "Permite unir una tabla a la tabla de un mapa vectorial."
-#: ../locale/scriptstrings/v.db.join_to_translate.c:3
-msgid "Vector map to which to join other table"
-msgstr "Mapa vectorial al que unir otra tabla"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:4
-msgid "Layer where to join"
-msgstr "Capa a la que unir"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:5
-msgid "Join column in map table"
-msgstr "Columna a unir en la tabla del mapa"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:6
-msgid "Other table name"
-msgstr "Nombre de la otra tabla"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:7
-msgid "Join column in other table"
-msgstr "Columna a unir en la otra tabla"
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
-"Elimina una columna de la tabla de atributos conectada a un mapa vectorial "
-"dado."
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
-msgid "Vector map for which to drop attribute column"
-msgstr "Mapa vectorial del que eliminar una columna de atributos"
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
-msgid "Layer where to drop column"
-msgstr "Capa de la que eliminar una columna"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
-msgid "Removes existing attribute table of a vector map."
-msgstr "Elimina la tabla de atributos existente de un mapa vectorial."
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
-msgid "Force removal (required for actual deletion of table)"
-msgstr "Forzar eliminación (requerido para el borrado real de la tabla)"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
-msgid "Vector map from which to remove attribute table"
-msgstr "Mapa vectorial del que eliminar la tabla de atributos"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
-msgid "Name of existing attribute table (default: vector map name)"
-msgstr ""
-"Nombre de la tabla de atributos existente (por omisión: nombre del mapa "
-"vectorial)"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
-msgid "Layer from which to drop linked attribute table"
-msgstr "Capa de la que eliminar la tabla de atributos asociada"
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
-#, fuzzy
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Cambia el nombre de una columna en la tabla de atributos conectada a un mapa "
-"vectorial dado."
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
-msgid "Vector map for which to rename attribute column"
-msgstr "Mapa vectorial en el que cambiar el nombre de una columna de atributos"
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:4
-msgid "Layer where to rename column"
-msgstr "Capa en la que cambiar el nombre de una columna"
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:5
-msgid "Old and new name of the column (old,new)"
-msgstr "Nombre antiguo y nuevo de la columna (antiguo,nuevo)"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-msgid "Reconnects vectors to a new database."
-msgstr "Conecta vectoriales a una nueva base de datos."
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
-#, fuzzy
-msgid "Name of old database"
-msgstr "Nombre de la nueva base de datos"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-#, fuzzy
-msgid ""
-"The database must be in form printed by v.db.connect -g, i.e. with "
-"substituted variables"
-msgstr ""
-"Nombre de la antigua base de datos. La base de datos debe estar en la forma "
-"impresa por v.db.connect -g, esto es, con variables sustituidas"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
-msgid "Name of new database"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
-msgid "Old schema"
-msgstr "Esquema antiguo"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
-msgid "New schema"
-msgstr "Esquema nuevo"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr ""
-"Calcula estadísticas univariante sobre la columna de tabal seleccionada para "
-"un mapa vectorial de GRASS."
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:2
-#: ../vector/lidar/v.outlier/main.c:66 ../vector/v.univar/main.c:64
-#: ../vector/v.class/main.c:45 ../vector/v.qcount/main.c:69
-#: ../vector/v.random/main.c:84 ../vector/v.kcv/main.c:76
-#: ../vector/v.normal/main.c:79
-msgid "vector, statistics"
-msgstr "vectorial, estadísticas"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:3
-msgid "Extended statistics (quartiles and 90th percentile)"
-msgstr "Estadísticas ampliadas (cuartiles y percentiles 90)"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:4
-msgid "Name of data table"
-msgstr "Nombre de la tabla de datos"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:5
-msgid "Column on which to calculate statistics (must be numeric)"
-msgstr "Columna sobre la que calcular las estadísticas (debe ser numérica)"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:6
-msgid "Database/directory for table"
-msgstr "Base de datos/directorio para la tabla"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:7
-msgid "Database driver"
-msgstr "Controlador de base de datos"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:1
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
-"Permite actualizar una columna en la tabla de atributos conectada a un mapa "
-"vectorial."
-#: ../locale/scriptstrings/v.db.update_to_translate.c:3
-msgid "Vector map to edit the attribute table for"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:4
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-msgid "Layer to which the table to be changed is connected"
-msgstr "Capa al que está conectada la tabla a cambiar"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:5
-msgid "Column to update"
-msgstr "Columna a actualizar"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:6
-#, fuzzy
-msgid ""
-"Value to update the column with (varchar values have to be in single quotes, "
-"e.g. 'grass')"
-msgstr ""
-"Valor con el que actualizar la columna (los valores varchar tienen que estar "
-"entre comillas simples, ej.: 'grass')"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:7
-msgid "Column to query"
-msgstr "Columna a consultar"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid ""
-"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
-"col2>1)"
-msgstr ""
-"Condiciones WHERE para actualizar, sin palabra clave 'where' (ej.: cat=1 o "
-"col1/col2>1)"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Disuelve contornos entre áreas adyacentes que comparten un número de "
-"categoría o atributo común."
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
-msgid "vector, area, dissolve"
-msgstr "vectorial, área, disolver"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
-#, fuzzy
-msgid "Layer number. If -1, all layers are extracted."
-msgstr "Número de capa. Si es -1, se extraerán todas las capas"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:11
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use."
-msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
-msgid "Name of column used to dissolve common boundaries"
-msgstr "Nombre de columna usada para disolver contornos comunes"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
-msgid "Import E00 file into a vector map."
-msgstr "Importar archivo E00 a mapa vectorial."
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:3
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:3
-#: ../raster/r.out.mat/main.c:81 ../raster/r.in.mat/main.c:115
-#: ../raster/r.out.tiff/r.out.tiff.c:136
-msgid "Verbose mode"
-msgstr "Modo verboso"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
-msgid "E00 file"
-msgstr "Archivo E00"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
-msgid "Input type point, line or area"
-msgstr "Tipo de entrada: punto, línea o área"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-"Descarga waypoints, rutas y caminos desde un receptor GPS Garmin a un mapa "
-"vectorial."
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
-msgid "vector, import, GPS"
-msgstr "vectorial, importar, GPS"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:4
-msgid "Download Waypoints from GPS"
-msgstr "Descargar Waypoints desde GPS"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:5
-msgid "Download Routes from GPS"
-msgstr "Descargar Rutas desde GPS"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:6
-msgid "Download Track from GPS"
-msgstr "Descargar Caminos desde GPS"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:7
-msgid "Force import of track or route data as points"
-msgstr "Forzar la importación de datos de pista o ruta como puntos"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:8
-msgid "Use gardump instead of gpstrans as the download program"
-msgstr "Usar gardump en vez de gpstrans como programa de descarga"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:9
-msgid "Import track in 3D (gardump only)"
-msgstr "Importar track en 3D (sólo gardump)"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:10
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:8
-msgid "Do not attempt projection transform from WGS84"
-msgstr "No intentar transformar la proyección a partir de WGS84"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:11
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:10
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
-msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
-"Nombre para el mapa vectorial de salida (omitir para visualización a stdout)"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:12
-msgid "Port Garmin receiver is connected to"
-msgstr "Receptor Garmin conectado al puerto"
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
-#, fuzzy
-msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr ""
-"Importa archivos de país del Servidor de Nombres Geonet (GNS) US-NGA a un "
-"mapa vectorial de puntos de GRASS."
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
-#, fuzzy
-msgid "vector, import, gazetteer"
-msgstr "vectorial, importar, "
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
-#, fuzzy
-msgid "Uncompressed geonames file from (with .txt extension)"
-msgstr "Archivo GNS sin comprimir de NGA (con extensión .txt)"
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:3
-msgid "Uncompressed GNS file from NGA (with .txt extension)"
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-"Importar waypoints, rutas y caminos desde un receptor GPS o un archivo de "
-"descarga de GPS a un mapa vectorial."
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:4
-msgid "Import waypoints"
-msgstr "Importar waypoints"
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:5
-msgid "Import routes"
-msgstr "Importar rutas"
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:6
-msgid "Import track"
-msgstr "Importar caminos"
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:7
-msgid "Force vertices of track or route data as points"
-msgstr "Forzar vértices de caminos o rutas como puntos"
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:9
-msgid "Device or file used to import data"
-msgstr "Dispositivo o archivo usado para importar datos"
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:11
-msgid "Format of GPS input data (use gpsbabel supported formats)"
-msgstr ""
-"Formato de datos de entrada del GPS (usar formatos soportados por gpsbabel)"
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:12
-msgid ""
-"Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-msgstr ""
-"Proyección de los datos de entrada (en estilo PROJ.4). Si no se indica se "
-"asume Latitud/Longitud WGS84"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
-msgid "Import Mapgen or Matlab vector maps into GRASS."
-msgstr "Importar mapas vectoriales Mapgen o Matlab a GRASS."
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
-msgid "Input map is in Matlab format"
-msgstr "El archivo de entrada está en formato Matlab"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
-msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr ""
-"Crear un mapa vectorial 3D de puntos a partir de datos Matlab de 3 columnas"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
-msgid "Name of input file in Mapgen/Matlab format"
-msgstr "Nombre del archivo de entrada en formato Mapgen/Matlab"
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
-"Convierte todos los mapas de lugares del antiguo GRASS < Ver5.7 del "
-"directorio de mapas actual a mapas vectoriales."
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
-msgid "sites, vector, import"
-msgstr "lugares, vectorial, importar"
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
-msgid "Run non-interactively"
-msgstr "Ejecutar de forma no interactiva"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
-msgid "import GetFeature from WFS"
-msgstr "Importar GetFeature de WFS"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
-msgid "GetFeature URL starting with http"
-msgstr "URL de GetFeature comenzando con http"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
-msgid "Vector output map"
-msgstr "Mapa vectorial de salida"
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-msgstr ""
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:2
-#, fuzzy
-msgid "vector, export, GPS"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:3
-#, fuzzy
-msgid "Export as waypoints"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:4
-#, fuzzy
-msgid "Export as routes"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:5
-#, fuzzy
-msgid "Export as tracks"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:7
-#, fuzzy
-msgid "Feature type(s)"
-msgstr "Tipo de elemento"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:8
-#, fuzzy
-msgid "Name for output file or GPS device"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:9
-#, fuzzy
-msgid "GpsBabel supported output format"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:12
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:15
-msgid "Subset"
-msgstr ""
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:14
-msgid "Example: income < 1000 and inhab >= 10000"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from a GRASS raster map based on vector "
-"polygons and uploads statistics to new attribute columns."
-msgstr ""
-"Calcular estadísticas univariantes a partir de un mapa ráster de GRASS "
-"basadas en polígonos vectoriales y carga las estadísticas en nuevas columnas "
-"de atributos."
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
-msgid "vector, raster, statistics"
-msgstr "vectorial, ráster, estadísticas"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
-msgid "Continue if upload column(s) already exist"
-msgstr "Continuar si la columna(s) en la que cargar ya existe"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
-#: ../raster/r.univar2/r.univar_main.c:49
-#: ../raster/r.univar2/r3.univar_main.c:48 ../vector/v.univar/main.c:100
-msgid "Calculate extended statistics"
-msgstr "Calcular estadísticas ampliadas"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
-msgid "Name of vector polygon map"
-msgstr "Nombre del mapa de polígono vectorial"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
-msgid "Name of raster map to calculate statistics from"
-msgstr "Nombre del mapa ráster del que calcular estadísticas"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
-msgid "Column prefix for new attribute columns"
-msgstr "Prefijo de columna para las nuevas columnas de atributos"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
-#: ../raster/r.univar2/r.univar_main.c:40
-#: ../raster/r.univar2/r3.univar_main.c:39 ../vector/v.univar/main.c:92
-msgid "Percentile to calculate (requires extended statistics flag)"
-msgstr "Percentil a calcular (requiere la opción de estadísticas ampliadas)"
-#: ../locale/scriptstrings/v.report_to_translate.c:1
-msgid "Reports geometry statistics for vectors."
-msgstr "Informa estadísticas de geometría para vectoriales."
-#: ../locale/scriptstrings/v.report_to_translate.c:2
-msgid "vector, report, statistics"
-msgstr "vectorial, informe, estadísticas"
-#: ../locale/scriptstrings/v.report_to_translate.c:3
-msgid "Reverse sort the result"
-msgstr "Resultado en orden inverso"
-#: ../locale/scriptstrings/v.report_to_translate.c:4
-msgid "Sort the result"
-msgstr "Ordenar el resultado"
-#: ../locale/scriptstrings/v.report_to_translate.c:7
-msgid "Value to calculate"
-msgstr "Valor a calcular"
-#: ../locale/scriptstrings/v.report_to_translate.c:8
-msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-msgstr ""
-"mi(llas),f(pies),me(tros),k(ilómetros),a(cres),h(ectáreas),p(orcentaje)"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
-msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-"Carga valores vectoriales en las posiciones de puntos vectoriales a la tabla."
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
-msgid "Points vector map to modify"
-msgstr "Mapa vectorial de puntos a modificar"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
-msgid "Layer in the vector to be modified"
-msgstr "Capa del vectorial a modificar"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
-msgid "Column to be updated with the query result"
-msgstr "Columna a actualizar con el resultado de la consulta"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
-msgid "Vector map to be queried"
-msgstr "Mapa vectorial a consultar"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
-#, fuzzy
-msgid "Layer of the query vector containing data"
-msgstr "Capa del vectorial consultado que contiene datos"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
-msgid "Column to be queried"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
-#, fuzzy
-msgid "Maximum query distance in map units"
-msgstr "Distancia de buffer en unidades de mapa"
#: ../raster/r.describe/main.c:61
msgid "Prints terse list of category values found in a raster map layer."
msgstr ""
@@ -4272,7 +1701,7 @@
#: ../raster/r.describe/main.c:107 ../raster/r.distance/parse.c:64
#: ../raster/r.carve/main.c:116 ../raster/r.compress/main.c:82
#: ../raster/r.covar/main.c:67 ../raster/r.colors/main.c:239
-#: ../raster/r.out.ppm/main.c:69 ../raster/r.neighbors/main.c:163
+#: ../raster/r.out.ppm/main.c:69 ../raster/r.neighbors/main.c:170
#: ../raster/r.clump/main.c:68 ../raster/r.out.ppm3/main.c:90
#: ../raster/r.contour/main.c:135 ../raster/r.cross/main.c:100
#: ../raster/r.series/main.c:151 ../raster/r.buffer/main.c:101
@@ -4286,7 +1715,7 @@
#: ../raster/r.compress/main.c:90 ../raster/r.patch/main.c:88
#: ../raster/r.covar/main.c:75 ../raster/r.rescale/main.c:103
#: ../raster/r.slope.aspect/main.c:325 ../raster/r.colors/main.c:248
-#: ../raster/r.random.surface/init.c:109 ../raster/r.neighbors/main.c:277
+#: ../raster/r.random.surface/init.c:109 ../raster/r.neighbors/main.c:291
#: ../raster/r.clump/main.c:77 ../raster/r.to.vect/main.c:97
#: ../raster/r.out.ppm3/main.c:102 ../raster/r.cross/main.c:107
#: ../raster/r.series/main.c:169 ../raster/r.resample/main.c:90
@@ -4389,26 +1818,26 @@
msgstr "Método <%s> desconocido"
#: ../raster/r.resamp.stats/main.c:329 ../raster/r.surf.area/main.c:123
-#: ../raster/r.resamp.interp/main.c:138 ../raster/r.los/main.c:196
-#: ../raster/r.los/main.c:207 ../raster/r.out.ascii/main.c:151
+#: ../raster/r.resamp.interp/main.c:138 ../raster/r.los/main.c:198
+#: ../raster/r.los/main.c:209 ../raster/r.out.ascii/main.c:151
#: ../raster/r.carve/main.c:181 ../raster/r.profile/main.c:144
#: ../raster/r.texture/main.c:234 ../raster/r.sum/main.c:65
#: ../raster/r.null/null.c:318 ../raster/r.lake/main.c:258
-#: ../raster/r.lake/main.c:269 ../raster/r.out.gdal/export_band.c:45
+#: ../raster/r.lake/main.c:269 ../raster/r.out.gdal/export_band.c:46
#: ../raster/r.surf.idw2/read_cell.c:34 ../raster/r.out.mat/main.c:108
#: ../raster/r.to.rast3elev/main.c:160 ../raster/r.grow2/main.c:203
#: ../raster/r.surf.idw/main.c:135 ../raster/r.thin/io.c:100
#: ../raster/r.out.pov/main.c:178 ../raster/r.covar/main.c:98
-#: ../raster/r.out.arc/main.c:118 ../raster/r.random/random.c:41
+#: ../raster/r.out.arc/main.c:125 ../raster/r.random/random.c:41
#: ../raster/r.random/random.c:45 ../raster/r.random/count.c:24
#: ../raster/r.random/count.c:30 ../raster/r.sunmask/main.c:455
-#: ../raster/r.quantile/main.c:300 ../raster/r.his/main.c:131
+#: ../raster/r.quantile/main.c:311 ../raster/r.his/main.c:131
#: ../raster/r.his/main.c:154 ../raster/r.his/main.c:179
-#: ../raster/r.bilinear/main.c:94 ../raster/r.resamp.rst/main.c:405
-#: ../raster/r.resamp.rst/main.c:437 ../raster/r.colors/stats.c:33
+#: ../raster/r.bilinear/main.c:94 ../raster/r.resamp.rst/main.c:401
+#: ../raster/r.resamp.rst/main.c:433 ../raster/r.colors/stats.c:33
#: ../raster/r.out.ppm/main.c:120 ../raster/r.random.surface/init.c:134
-#: ../raster/r.random.surface/main.c:54 ../raster/r.cost/main.c:340
-#: ../raster/r.cost/main.c:590 ../raster/r.out.vtk/main.c:222
+#: ../raster/r.random.surface/main.c:54 ../raster/r.cost/main.c:370
+#: ../raster/r.cost/main.c:657 ../raster/r.out.vtk/main.c:222
#: ../raster/r.out.vtk/main.c:288 ../raster/r.out.vtk/main.c:317
#: ../raster/r.out.vtk/main.c:364 ../raster/r.support/front/front.c:227
#: ../raster/r.out.bin/main.c:133 ../raster/r.clump/main.c:94
@@ -4416,8 +1845,8 @@
#: ../raster/r.to.vect/main.c:114 ../raster/r.out.ppm3/main.c:124
#: ../raster/r.univar2/r.univar_main.c:153 ../raster/r.contour/main.c:162
#: ../raster/r.cross/main.c:129 ../raster/r.cats/main.c:150
-#: ../raster/r.out.tiff/r.out.tiff.c:188 ../raster/r.walk/main.c:545
-#: ../raster/r.walk/main.c:548 ../raster/r.walk/main.c:854
+#: ../raster/r.out.tiff/r.out.tiff.c:188 ../raster/r.walk/main.c:573
+#: ../raster/r.walk/main.c:576 ../raster/r.walk/main.c:922
#: ../raster/r.mapcalc/map3.c:510 ../raster/r.recode/recode.c:48
#: ../raster/r.composite/main.c:159 ../raster/wildfire/r.ros/main.c:475
#: ../raster/wildfire/r.ros/main.c:483 ../raster/wildfire/r.ros/main.c:491
@@ -4434,14 +1863,14 @@
#: ../raster/r.buffer/write_map.c:45 ../raster/r.bitpattern/main.c:108
#: ../raster/r.to.rast3/main.c:366 ../raster/r.grow.distance/main.c:177
#: ../vector/v.what.rast/main.c:141 ../vector/v.extrude/main.c:183
-#: ../vector/v.sample/main.c:161 ../vector/v.vol.rst/main.c:597
+#: ../vector/v.sample/main.c:161 ../vector/v.vol.rst/main.c:609
#: ../vector/v.to.rast/support.c:264 ../vector/v.to.rast/support.c:422
#: ../vector/v.drape/main.c:250 ../doc/raster/r.example/main.c:122
#: ../imagery/i.gensigset/opencell.c:13 ../imagery/i.his.rgb/openfiles.c:33
#: ../imagery/i.his.rgb/openfiles.c:38 ../imagery/i.his.rgb/openfiles.c:43
#: ../imagery/i.rgb.his/openfiles.c:21 ../imagery/i.rgb.his/openfiles.c:23
#: ../imagery/i.rgb.his/openfiles.c:25 ../imagery/i.smap/shapiro/opencell.c:16
-#: ../imagery/i.pca/main.c:126 ../imagery/i.gensig/opencell.c:12
+#: ../imagery/i.pca/main.c:132 ../imagery/i.gensig/opencell.c:12
#: ../imagery/i.cluster/open_files.c:56 ../imagery/i.maxlik/open.c:41
#: ../visualization/xganim/main.c:370 ../display/d.rast.edit/cell.c:92
#: ../display/d.profile/ExtractProf.c:93 ../display/d.profile/What.c:23
@@ -4540,7 +1969,7 @@
#: ../raster/r.param.scale/open_files.c:32
#: ../raster/r.param.scale/open_files.c:36 ../raster/r.reclass/reclass.c:235
-#: ../raster/r.topidx/file_io.c:81 ../raster/r.mfilter.fp/perform.c:84
+#: ../raster/r.topidx/file_io.c:88 ../raster/r.mfilter.fp/perform.c:84
#: ../raster/r.mfilter/perform.c:84 ../imagery/i.cca/main.c:191
#, c-format
msgid "Cannot create raster map <%s>"
@@ -4563,203 +1992,203 @@
msgid "Vertical scale"
msgstr "Escala vertical"
-#: ../raster/r.proj.seg/main.c:135 ../raster/r.proj/main.c:129
+#: ../raster/r.proj.seg/main.c:137 ../raster/r.proj/main.c:129
msgid "raster, projection"
msgstr "ráster, proyección"
-#: ../raster/r.proj.seg/main.c:137 ../raster/r.proj/main.c:131
+#: ../raster/r.proj.seg/main.c:139 ../raster/r.proj/main.c:131
msgid "Re-projects a raster map from one location to the current location."
msgstr ""
"Reproyecta un mapa ráster desde una localización a la localización actual."
-#: ../raster/r.proj.seg/main.c:140 ../raster/r.proj/main.c:134
+#: ../raster/r.proj.seg/main.c:142 ../raster/r.proj/main.c:134
msgid "Name of input raster map to re-project"
msgstr "Nombre del mapa ráster a reproyectar"
-#: ../raster/r.proj.seg/main.c:147 ../raster/r.proj/main.c:141
+#: ../raster/r.proj.seg/main.c:149 ../raster/r.proj/main.c:141
msgid "Location of input raster map"
msgstr "Localización del mapa ráster de entrada"
-#: ../raster/r.proj.seg/main.c:153 ../raster/r.proj/main.c:147
+#: ../raster/r.proj.seg/main.c:155 ../raster/r.proj/main.c:147
msgid "Mapset of input raster map"
msgstr "Directorio de mapas del mapa ráster de entrada"
-#: ../raster/r.proj.seg/main.c:159 ../raster/r.proj/main.c:153
+#: ../raster/r.proj.seg/main.c:161 ../raster/r.proj/main.c:153
#: ../vector/v.proj/main.c:88
msgid "Path to GRASS database of input location"
msgstr "Ruta a la base de datos de GRASS de la localización de entrada"
-#: ../raster/r.proj.seg/main.c:163 ../raster/r.proj/main.c:157
+#: ../raster/r.proj.seg/main.c:165 ../raster/r.proj/main.c:157
msgid "Name for output raster map (default: input)"
msgstr "Nombre para el mapa ráster de salida (por omisión: el de entrada)"
-#: ../raster/r.proj.seg/main.c:173 ../raster/r.proj/main.c:167
+#: ../raster/r.proj.seg/main.c:175 ../raster/r.proj/main.c:167
msgid "Interpolation method to use"
msgstr "Método de interpolación a usar"
-#: ../raster/r.proj.seg/main.c:179
+#: ../raster/r.proj.seg/main.c:181
msgid "Cache size (MiB)"
msgstr "Tamaño de caché (MiB)"
-#: ../raster/r.proj.seg/main.c:185 ../raster/r.proj/main.c:173
+#: ../raster/r.proj.seg/main.c:187 ../raster/r.proj/main.c:173
msgid "Resolution of output map"
msgstr "Resolución del mapa de salida"
-#: ../raster/r.proj.seg/main.c:189 ../raster/r.proj/main.c:177
+#: ../raster/r.proj.seg/main.c:191 ../raster/r.proj/main.c:177
msgid "List raster maps in input location and exit"
msgstr "Listar mapas ráster en la localización de entrada y salir"
-#: ../raster/r.proj.seg/main.c:193 ../raster/r.proj/main.c:181
+#: ../raster/r.proj.seg/main.c:195 ../raster/r.proj/main.c:181
#, fuzzy
msgid "Do not perform region cropping optimization"
msgstr "No realizar optimización de "
-#: ../raster/r.proj.seg/main.c:209 ../raster/r.statistics/main.c:100
-#: ../raster/r.neighbors/main.c:216 ../raster/r.proj/main.c:197
+#: ../raster/r.proj.seg/main.c:211 ../raster/r.statistics/main.c:100
+#: ../raster/r.neighbors/main.c:225 ../raster/r.proj/main.c:197
#, c-format
msgid "<%s=%s> unknown %s"
msgstr "<%s=%s> desconocido %s"
-#: ../raster/r.proj.seg/main.c:216 ../raster/r.proj/main.c:204
+#: ../raster/r.proj.seg/main.c:218 ../raster/r.proj/main.c:204
#: ../vector/v.proj/main.c:121
#, c-format
msgid "option <%s>: <%s> exists."
msgstr "opción <%s>: <%s> existe."
-#: ../raster/r.proj.seg/main.c:221
+#: ../raster/r.proj.seg/main.c:223
msgid "You have to use a different location for input than the current"
msgstr ""
"Tiene que usar una localización diferente para la entrada que la actual"
-#: ../raster/r.proj.seg/main.c:227 ../raster/r.proj/main.c:215
+#: ../raster/r.proj.seg/main.c:229 ../raster/r.proj/main.c:215
msgid "Unable to get projection info of output raster map"
msgstr ""
"No se puede obtener información de la proyección del mapa ráster de salida"
-#: ../raster/r.proj.seg/main.c:230 ../raster/r.proj/main.c:218
+#: ../raster/r.proj.seg/main.c:232 ../raster/r.proj/main.c:218
msgid "Unable to get projection units of output raster map"
msgstr ""
"No se pueden obtener las unidades de la proyección del mapa ráster de salida"
-#: ../raster/r.proj.seg/main.c:233 ../raster/r.proj/main.c:221
+#: ../raster/r.proj.seg/main.c:235 ../raster/r.proj/main.c:221
msgid "Unable to get projection key values of output raster map"
msgstr ""
"No se pueden obtener los valores clave de la proyección del mapa ráster de "
"salida"
-#: ../raster/r.proj.seg/main.c:242 ../raster/r.proj/main.c:230
+#: ../raster/r.proj.seg/main.c:244 ../raster/r.proj/main.c:230
#, c-format
msgid "Mapset <%s> in input location <%s> - %s"
msgstr "Directorio de mapas <%s> en localización de entrada <%s> - %s"
-#: ../raster/r.proj.seg/main.c:244 ../raster/r.in.gdal/main.c:633
+#: ../raster/r.proj.seg/main.c:246 ../raster/r.in.gdal/main.c:633
#: ../raster/r.proj/main.c:232 ../imagery/i.rectify/target.c:33
msgid "permission denied"
msgstr "permiso denegado"
-#: ../raster/r.proj.seg/main.c:245 ../raster/r.in.gdal/main.c:634
+#: ../raster/r.proj.seg/main.c:247 ../raster/r.in.gdal/main.c:634
#: ../raster/r.proj/main.c:233 ../imagery/i.rectify/target.c:33
msgid "not found"
msgstr "no encontrado"
-#: ../raster/r.proj.seg/main.c:250 ../raster/r.proj/main.c:238
+#: ../raster/r.proj.seg/main.c:252 ../raster/r.proj/main.c:238
#, c-format
msgid "Checking location <%s>, mapset <%s>..."
msgstr "Comprobando localización <%s>, directorio de mapas <%s>..."
-#: ../raster/r.proj.seg/main.c:257 ../raster/r.out.gdal/main.c:223
+#: ../raster/r.proj.seg/main.c:259 ../raster/r.out.gdal/main.c:228
#: ../raster/r.in.gdal/main.c:199 ../raster/r.proj/main.c:245
#: ../vector/v.in.ogr/main.c:268 ../vector/v.in.ogr/main.c:320
-#: ../vector/v.proj/main.c:163
+#: ../vector/v.select/main.c:88 ../vector/v.proj/main.c:163
#, c-format
msgid "Required parameter <%s> not set"
msgstr "Parámetro <%s> requerido no establecido"
-#: ../raster/r.proj.seg/main.c:260 ../raster/r.proj/main.c:248
+#: ../raster/r.proj.seg/main.c:262 ../raster/r.proj/main.c:248
#, c-format
msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
msgstr ""
"No se encuentra el mapa ráster <%s> en la localización <%s> en el directorio "
"de mapas <%s>"
-#: ../raster/r.proj.seg/main.c:268 ../raster/r.proj/main.c:256
+#: ../raster/r.proj.seg/main.c:270 ../raster/r.proj/main.c:256
msgid "Unable to get projection info of input map"
msgstr "No se puede obtener información de la proyección del mapa de entrada"
-#: ../raster/r.proj.seg/main.c:271 ../raster/r.proj/main.c:259
+#: ../raster/r.proj.seg/main.c:273 ../raster/r.proj/main.c:259
msgid "Unable to get projection units of input map"
msgstr "No se pueden obtener las unidades de la proyección del mapa de entrada"
-#: ../raster/r.proj.seg/main.c:274 ../raster/r.proj/main.c:262
+#: ../raster/r.proj.seg/main.c:276 ../raster/r.proj/main.c:262
msgid "Unable to get projection key values of input map"
msgstr ""
"No se pueden obtener los valores clave de la proyección del mapa de entrada"
-#: ../raster/r.proj.seg/main.c:288 ../raster/r.proj/main.c:276
+#: ../raster/r.proj.seg/main.c:290 ../raster/r.proj/main.c:276
msgid "Unable to work with unprojected data (xy location)"
msgstr "No se puede trabajar con datos no proyectados (localización XY)"
-#: ../raster/r.proj.seg/main.c:362 ../raster/r.proj/main.c:350
+#: ../raster/r.proj.seg/main.c:364 ../raster/r.proj/main.c:350
msgid "Input:"
msgstr "Entrada:"
-#: ../raster/r.proj.seg/main.c:363 ../raster/r.proj.seg/main.c:374
+#: ../raster/r.proj.seg/main.c:365 ../raster/r.proj.seg/main.c:376
#: ../raster/r.proj/main.c:351 ../raster/r.proj/main.c:362
#, c-format
msgid "Cols: %d (%d)"
msgstr "Columnas: %d (%d)"
-#: ../raster/r.proj.seg/main.c:364 ../raster/r.proj.seg/main.c:375
+#: ../raster/r.proj.seg/main.c:366 ../raster/r.proj.seg/main.c:377
#: ../raster/r.proj/main.c:352 ../raster/r.proj/main.c:363
#, c-format
msgid "Rows: %d (%d)"
msgstr "Filas: %d (%d)"
-#: ../raster/r.proj.seg/main.c:365 ../raster/r.proj.seg/main.c:376
+#: ../raster/r.proj.seg/main.c:367 ../raster/r.proj.seg/main.c:378
#: ../raster/r.proj/main.c:353 ../raster/r.proj/main.c:364
#, c-format
msgid "North: %f (%f)"
msgstr "Norte: %f (%f)"
-#: ../raster/r.proj.seg/main.c:366 ../raster/r.proj.seg/main.c:377
+#: ../raster/r.proj.seg/main.c:368 ../raster/r.proj.seg/main.c:379
#: ../raster/r.proj/main.c:354 ../raster/r.proj/main.c:365
#, c-format
msgid "South: %f (%f)"
msgstr "Sur: %f (%f)"
-#: ../raster/r.proj.seg/main.c:367 ../raster/r.proj.seg/main.c:378
+#: ../raster/r.proj.seg/main.c:369 ../raster/r.proj.seg/main.c:380
#: ../raster/r.proj/main.c:355 ../raster/r.proj/main.c:366
#, c-format
msgid "West: %f (%f)"
msgstr "Oeste: %f (%f)"
-#: ../raster/r.proj.seg/main.c:368 ../raster/r.proj.seg/main.c:379
+#: ../raster/r.proj.seg/main.c:370 ../raster/r.proj.seg/main.c:381
#: ../raster/r.proj/main.c:356 ../raster/r.proj/main.c:367
#, c-format
msgid "East: %f (%f)"
msgstr "Este: %f (%f)"
-#: ../raster/r.proj.seg/main.c:369 ../raster/r.proj.seg/main.c:380
+#: ../raster/r.proj.seg/main.c:371 ../raster/r.proj.seg/main.c:382
#: ../raster/r.proj/main.c:357 ../raster/r.proj/main.c:368
#, c-format
msgid "EW-res: %f"
msgstr "Resolución Este-Oeste: %f"
-#: ../raster/r.proj.seg/main.c:370 ../raster/r.proj.seg/main.c:381
+#: ../raster/r.proj.seg/main.c:372 ../raster/r.proj.seg/main.c:383
#: ../raster/r.proj/main.c:358 ../raster/r.proj/main.c:369
#, c-format
msgid "NS-res: %f"
msgstr "Resolución Norte-Sur: %f"
-#: ../raster/r.proj.seg/main.c:373 ../raster/r.proj/main.c:361
+#: ../raster/r.proj.seg/main.c:375 ../raster/r.proj/main.c:361
msgid "Output:"
msgstr "Salida:"
-#: ../raster/r.proj.seg/main.c:409 ../raster/r.proj/main.c:397
+#: ../raster/r.proj.seg/main.c:411 ../raster/r.proj/main.c:397
msgid "Projecting..."
msgstr "Proyectando..."
-#: ../raster/r.proj.seg/main.c:437 ../raster/r.los/main.c:378
+#: ../raster/r.proj.seg/main.c:439 ../raster/r.los/main.c:380
#: ../raster/r.texture/main.c:356 ../raster/r.texture/main.c:360
#: ../raster/r.texture/main.c:367 ../raster/r.null/null.c:342
#: ../raster/r.buffer/write_map.c:78 ../raster/r.proj/main.c:425
@@ -5034,26 +2463,26 @@
msgstr "Número de imágenes intermedias a producir"
#: ../raster/r.surf.fractal/interface.c:79 ../raster/r.reclass/main.c:81
-#: ../raster/r.los/main.c:171 ../raster/r.in.ascii/main.c:203
-#: ../raster/r.texture/main.c:231 ../raster/r.average/main.c:78
-#: ../raster/r.surf.idw2/main.c:83 ../raster/r.mode/main.c:94
-#: ../raster/r.to.rast3elev/main.c:472 ../raster/r.surf.idw/main.c:112
-#: ../raster/r.in.gdal/main.c:207 ../raster/r.random/main.c:141
-#: ../raster/r.random/main.c:146 ../raster/r.median/main.c:77
-#: ../raster/r.slope.aspect/opennew.c:11 ../raster/r.surf.gauss/main.c:77
-#: ../raster/r.cost/main.c:327 ../raster/r.neighbors/main.c:189
+#: ../raster/r.los/main.c:173 ../raster/r.drain/main.c:206
+#: ../raster/r.in.ascii/main.c:203 ../raster/r.texture/main.c:231
+#: ../raster/r.average/main.c:78 ../raster/r.surf.idw2/main.c:83
+#: ../raster/r.mode/main.c:94 ../raster/r.to.rast3elev/main.c:472
+#: ../raster/r.surf.idw/main.c:112 ../raster/r.in.gdal/main.c:207
+#: ../raster/r.random/main.c:147 ../raster/r.random/main.c:152
+#: ../raster/r.median/main.c:77 ../raster/r.slope.aspect/opennew.c:11
+#: ../raster/r.surf.gauss/main.c:77 ../raster/r.cost/main.c:352
+#: ../raster/r.cost/main.c:356 ../raster/r.neighbors/main.c:196
#: ../raster/r.clump/main.c:90 ../raster/r.in.mat/main.c:388
-#: ../raster/r.watershed/ram/init_vars.c:402
#: ../raster/r.watershed/shed/com_line.c:228
#: ../raster/r.watershed/shed/com_line.c:263
-#: ../raster/r.watershed/seg/init_vars.c:451
-#: ../raster/r.water.outlet/legal.c:10 ../raster/r.walk/main.c:531
-#: ../raster/r.recode/main.c:83 ../raster/wildfire/r.spread/main.c:380
+#: ../raster/r.water.outlet/legal.c:10 ../raster/r.walk/main.c:554
+#: ../raster/r.walk/main.c:558 ../raster/r.recode/main.c:83
+#: ../raster/wildfire/r.spread/main.c:380
#: ../raster/wildfire/r.spread/main.c:389
#: ../raster/wildfire/r.spread/main.c:399 ../raster/r.buffer/main.c:130
#: ../raster/r.bitpattern/main.c:104 ../vector/v.to.rast3/main.c:69
#: ../vector/v.edit/main.c:86 ../vector/v.kernel/main.c:263
-#: ../vector/v.in.ogr/main.c:324 ../vector/v.surf.idw/main.c:131
+#: ../vector/v.in.ogr/main.c:324 ../vector/v.surf.idw/main.c:132
#: ../doc/raster/r.example/main.c:114 ../imagery/i.ifft/ifftmain.c:116
#: ../imagery/i.zc/main.c:119 ../imagery/i.fft/fftmain.c:121
#: ../imagery/i.fft/fftmain.c:124
@@ -5224,53 +2653,53 @@
msgid "Consider earth curvature (current ellipsoid)"
msgstr ""
-#: ../raster/r.los/main.c:148
+#: ../raster/r.los/main.c:150
msgid "Lat/Long support is not (yet) implemented for this module."
msgstr ""
"El soporte para latitud/longitud no está (todavía( implementado para este "
"módulo."
-#: ../raster/r.los/main.c:153
+#: ../raster/r.los/main.c:155
msgid "Specified observer coordinate is outside current region bounds."
msgstr ""
"Las coordenadas del observador especificadas están fuera del contorno de la "
"región actual."
-#: ../raster/r.los/main.c:175 ../raster/r.los/main.c:180
-#: ../raster/r.resamp.rst/main.c:408 ../raster/r.resamp.rst/main.c:431
+#: ../raster/r.los/main.c:177 ../raster/r.los/main.c:182
+#: ../raster/r.resamp.rst/main.c:404 ../raster/r.resamp.rst/main.c:427
#, c-format
msgid "[%s]: Cannot read map header"
msgstr "[%s]: no se puede leer la cabecera del mapa"
-#: ../raster/r.los/main.c:209
+#: ../raster/r.los/main.c:211
msgid "Pattern map should be a binary 0/1 CELL map"
msgstr "El mapa patrón debería ser un mapa de celdas binario 0/1"
-#: ../raster/r.los/main.c:243
+#: ../raster/r.los/main.c:245
msgid ""
"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
msgstr ""
-#: ../raster/r.los/main.c:248
+#: ../raster/r.los/main.c:250
#, fuzzy, c-format
msgid "Using maximum distance from the viewing point (meters): %f"
msgstr "Distancia máxima desde el punto de observación (metros)"
-#: ../raster/r.los/main.c:262 ../raster/r.los/main.c:270
+#: ../raster/r.los/main.c:264 ../raster/r.los/main.c:272
#: ../raster/r.profile/read_rast.c:45 ../raster/r.profile/read_rast.c:73
#: ../raster/r.profile/read_rast.c:101 ../raster/r.null/null.c:334
#: ../raster/r.lake/main.c:288 ../raster/r.lake/main.c:293
-#: ../raster/r.out.gdal/export_band.c:203
-#: ../raster/r.out.gdal/export_band.c:234
-#: ../raster/r.out.gdal/export_band.c:265 ../raster/r.patch/main.c:157
-#: ../raster/r.patch/main.c:164 ../raster/r.topidx/file_io.c:62
-#: ../raster/r.colors/stats.c:46 ../raster/r.colors/stats.c:110
-#: ../raster/r.out.ppm/main.c:188 ../raster/r.cost/main.c:405
-#: ../raster/r.cost/main.c:606 ../raster/r.cost/main.c:921
-#: ../raster/r.cost/main.c:954 ../raster/r.cost/main.c:987
-#: ../raster/r.walk/main.c:697 ../raster/r.walk/main.c:756
-#: ../raster/r.walk/main.c:872 ../raster/r.walk/main.c:1413
-#: ../raster/r.walk/main.c:1448 ../raster/r.walk/main.c:1483
+#: ../raster/r.out.gdal/export_band.c:195
+#: ../raster/r.out.gdal/export_band.c:229
+#: ../raster/r.out.gdal/export_band.c:263 ../raster/r.patch/main.c:157
+#: ../raster/r.patch/main.c:164 ../raster/r.topidx/file_io.c:69
+#: ../raster/r.colors/stats.c:46 ../raster/r.colors/stats.c:113
+#: ../raster/r.out.ppm/main.c:188 ../raster/r.cost/main.c:447
+#: ../raster/r.cost/main.c:673 ../raster/r.cost/main.c:1037
+#: ../raster/r.cost/main.c:1070 ../raster/r.cost/main.c:1103
+#: ../raster/r.walk/main.c:737 ../raster/r.walk/main.c:796
+#: ../raster/r.walk/main.c:940 ../raster/r.walk/main.c:1522
+#: ../raster/r.walk/main.c:1557 ../raster/r.walk/main.c:1592
#: ../raster/r.buffer/read_map.c:63 ../raster/r.buffer/write_map.c:61
#: ../raster/r.bitpattern/main.c:135 ../vector/v.what.rast/main.c:271
#: ../vector/v.what.rast/main.c:276 ../vector/v.to.rast/support.c:436
@@ -5280,67 +2709,131 @@
msgid "Unable to read raster map <%s> row %d"
msgstr "No se puede leer en el mapa ráster <%s> la fila %d"
-#: ../raster/r.drain/main.c:96
+#: ../raster/r.drain/main.c:110
#, fuzzy
msgid "Traces a flow through an elevation model on a raster map."
msgstr ""
"Traza un flujo mediante un modelo de elevación sobre una capa de mapa ráster."
-#: ../raster/r.drain/main.c:109
+#: ../raster/r.drain/main.c:120
+msgid "Name of movement direction map associated with the cost surface"
+msgstr ""
+#: ../raster/r.drain/main.c:131
+msgid ""
+"Output drain vector map (recommended for cost surface made using knight's "
+"move)"
+msgstr ""
+#: ../raster/r.drain/main.c:139
#, fuzzy
msgid "Map coordinates of starting point(s) (E,N)"
msgstr "Las coordenadas E y N del punto(s) de inicio"
-#: ../raster/r.drain/main.c:110 ../raster/r.drain/main.c:116
-#: ../raster/r.cost/main.c:141 ../raster/r.cost/main.c:153
-#: ../raster/r.cost/main.c:162 ../raster/r.cost/main.c:212
+#: ../raster/r.drain/main.c:140 ../raster/r.drain/main.c:146
+#: ../raster/r.cost/main.c:153 ../raster/r.cost/main.c:165
+#: ../raster/r.cost/main.c:174 ../raster/r.cost/main.c:224
msgid "Start"
msgstr ""
-#: ../raster/r.drain/main.c:115
+#: ../raster/r.drain/main.c:145
#, fuzzy
msgid "Name of vector map(s) containing starting point(s)"
msgstr "Mapa(s) vectorial que contiene el punto(s) de inicio"
-#: ../raster/r.drain/main.c:120
+#: ../raster/r.drain/main.c:150
msgid "Copy input cell values on output"
msgstr "Copiar valores de celdas de entrada en la salida"
-#: ../raster/r.drain/main.c:124
+#: ../raster/r.drain/main.c:154
msgid "Accumulate input values along the path"
msgstr "Acumular valores de entrada a lo largo de la ruta"
-#: ../raster/r.drain/main.c:128
+#: ../raster/r.drain/main.c:158
msgid "Count cell numbers along the path"
msgstr "Contar números de celdas a lo largo de la ruta"
-#: ../raster/r.drain/main.c:149
+#: ../raster/r.drain/main.c:163
+msgid ""
+"The input surface is a cost surface (if checked, a direction surface must "
+"also be specified"
+msgstr ""
+#: ../raster/r.drain/main.c:175
+msgid "Directional drain selected... checking for direction raster"
+msgstr ""
+#: ../raster/r.drain/main.c:178
+msgid "Surface/Hydrology drain selected"
+msgstr ""
+#: ../raster/r.drain/main.c:184
+msgid ""
+"Direction raster not specified, if direction flag is on, a direction raster "
+"must be given"
+msgstr ""
+#: ../raster/r.drain/main.c:191
+#, fuzzy, c-format
+msgid "Direction raster found <%s>"
+msgstr "Escribiendo mapa ráster <%s>"
+#: ../raster/r.drain/main.c:198
+#, c-format
+msgid "Direction map <%s> should not be specified for Surface/Hydrology drains"
+msgstr ""
+#: ../raster/r.drain/main.c:204
+#, fuzzy
+msgid "Outputting a vector path"
+msgstr "Producir mapa vectorial de líneas de flujo"
+#: ../raster/r.drain/main.c:209 ../raster/r.flow/io.c:170
+#: ../vector/v.net.visibility/main.c:87 ../vector/v.edit/main.c:100
+#: ../vector/v.in.dxf/main.c:168
+#: ../vector/lidar/v.lidar.edgedetection/main.c:175
+#: ../vector/lidar/v.lidar.correction/main.c:156
+#: ../vector/lidar/v.lidar.correction/main.c:162
+#: ../vector/lidar/v.outlier/main.c:150 ../vector/lidar/v.outlier/main.c:155
+#: ../vector/lidar/v.outlier/main.c:161
+#: ../vector/lidar/v.surf.bspline/main.c:267 ../vector/v.generalize/main.c:312
+#: ../vector/v.mkgrid/main.c:212 ../vector/v.net.path/main.c:139
+#: ../vector/v.voronoi/dt_main.c:92 ../vector/v.voronoi/dt_main.c:98
+#: ../vector/v.voronoi/vo_main.c:164 ../vector/v.drape/main.c:339
+#: ../vector/v.drape/main.c:380 ../vector/v.delaunay2/main.c:103
+#: ../vector/v.delaunay2/main.c:107 ../vector/v.to.3d/main.c:87
+#: ../vector/v.buffer2/main.c:305 ../doc/vector/v.example/main.c:96
+#, c-format
+msgid "Unable to create vector map <%s>"
+msgstr "No se puede crear el mapa vectorial <%s>"
+#: ../raster/r.drain/main.c:227
msgid "Specify just one of the -c, -a and -n flags"
msgstr "Especificar sólo una de las opciones -c y -n"
-#: ../raster/r.drain/main.c:168
+#: ../raster/r.drain/main.c:250
msgid "Metrics allocation"
msgstr "Asignación de métricas"
-#: ../raster/r.drain/main.c:179
+#: ../raster/r.drain/main.c:261
#, c-format
msgid "Starting point %d is outside the current region"
msgstr "El punto de inicio %d está fuera de la región actual"
-#: ../raster/r.drain/main.c:187 ../raster/r.drain/main.c:228
+#: ../raster/r.drain/main.c:269 ../raster/r.drain/main.c:310
msgid "Too many start points"
msgstr "Demasiados puntos de inicio"
-#: ../raster/r.drain/main.c:202 ../raster/r.carve/main.c:172
-#: ../raster/r.cost/main.c:301 ../raster/r.region/main.c:241
+#: ../raster/r.drain/main.c:284 ../raster/r.carve/main.c:172
+#: ../raster/r.cost/main.c:319 ../raster/r.region/main.c:241
#: ../vector/v.db.connect/main.c:123 ../vector/v.perturb/main.c:154
#: ../vector/v.edit/main.c:140
#: ../vector/lidar/v.lidar.edgedetection/main.c:170
#: ../vector/lidar/v.lidar.correction/main.c:147
#: ../vector/lidar/v.outlier/main.c:144
#: ../vector/lidar/v.lidar.growing/main.c:121
-#: ../vector/lidar/v.surf.bspline/main.c:226
-#: ../vector/lidar/v.surf.bspline/main.c:246
+#: ../vector/lidar/v.surf.bspline/main.c:227
+#: ../vector/lidar/v.surf.bspline/main.c:247
#: ../vector/v.net.salesman/main.c:171 ../vector/v.distance/main.c:299
#: ../vector/v.reclass/main.c:107 ../vector/v.to.points/main.c:244
#: ../vector/v.segment/main.c:99 ../vector/v.db.select/main.c:119
@@ -5357,11 +2850,11 @@
#: ../vector/v.kcv/main.c:132 ../vector/v.net/main.c:143
#: ../vector/v.net/main.c:158 ../vector/v.out.dxf/main.c:69
#: ../vector/v.normal/main.c:128 ../vector/v.voronoi/dt_main.c:77
-#: ../vector/v.voronoi/vo_main.c:157 ../vector/v.what/main.c:147
+#: ../vector/v.voronoi/vo_main.c:157 ../vector/v.what/main.c:151
#: ../vector/v.hull/main.c:315 ../vector/v.out.svg/main.c:127
-#: ../vector/v.to.db/parse.c:127 ../vector/v.select/main.c:208
+#: ../vector/v.to.db/parse.c:128 ../vector/v.select/main.c:101
#: ../vector/v.net.alloc/main.c:143 ../vector/v.label/main.c:270
-#: ../vector/v.type/main.c:202 ../vector/v.surf.rst/main.c:537
+#: ../vector/v.type/main.c:202 ../vector/v.surf.rst/main.c:544
#: ../vector/v.to.rast/vect2rast.c:37 ../vector/v.drape/main.c:261
#: ../vector/v.out.ogr/main.c:211 ../vector/v.net.steiner/main.c:428
#: ../vector/v.lrs/v.lrs.label/main.c:286
@@ -5371,7 +2864,7 @@
#: ../vector/v.lrs/v.lrs.where/main.c:127
#: ../vector/v.lrs/v.lrs.where/main.c:135 ../vector/v.buffer/main.c:365
#: ../vector/v.extract/main.c:193 ../vector/v.delaunay2/main.c:93
-#: ../vector/v.buffer2/main.c:268 ../doc/vector/v.example/main.c:73
+#: ../vector/v.buffer2/main.c:296 ../doc/vector/v.example/main.c:73
#: ../visualization/nviz2/cmd/vector.c:83 ../display/d.what.vect/main.c:148
#: ../display/d.vect/main.c:480 ../display/d.vect.chart/main.c:246
#: ../display/d.thematic.area/main.c:212 ../display/d.extract/main.c:98
@@ -5382,33 +2875,38 @@
msgid "Vector map <%s> not found"
msgstr "Mapa vectorial <%s> no encontrado"
-#: ../raster/r.drain/main.c:208 ../raster/r.cost/main.c:496
+#: ../raster/r.drain/main.c:290 ../raster/r.cost/main.c:563
msgid "Failed to guess site file format"
msgstr "No se pudo averiguar el formato de archivo de lugares"
-#: ../raster/r.drain/main.c:234
+#: ../raster/r.drain/main.c:316
#, c-format
msgid "Starting vector map <%s> contains no points in the current region"
msgstr ""
"El comienzo del mapa vectorial <%s> no contiene puntos en la región actual"
-#: ../raster/r.drain/main.c:240
+#: ../raster/r.drain/main.c:322
msgid "No start/stop point(s) specified"
msgstr "No se ha especificado ningún punto de inicio/final"
-#: ../raster/r.drain/main.c:300
+#: ../raster/r.drain/main.c:397
#, fuzzy
msgid "Calculating flow directions..."
msgstr "Calculando medias de clase ..."
-#: ../raster/r.drain/main.c:362 ../raster/r.drain/main.c:415
-#: ../raster/r.random.surface/save.c:100 ../raster/r.cost/main.c:907
+#: ../raster/r.drain/main.c:466 ../raster/r.drain/main.c:519
+#: ../raster/r.random.surface/save.c:100 ../raster/r.cost/main.c:1023
#: ../raster/r.random.cells/indep.c:137 ../raster/r.composite/main.c:199
#: ../imagery/i.smap/shapiro/write_img.c:12
#, fuzzy, c-format
msgid "Writing raster map <%s>..."
msgstr "Escribiendo mapa ráster <%s> ..."
+#: ../raster/r.drain/main.c:684
+#, c-format
+msgid "direction read: %lf, neighbour found: %i"
+msgstr ""
#: ../raster/r.in.ascii/gethead.c:34
msgid "input file is not a Surfer ascii grid file"
msgstr "El archivo de entrada no es un archivo de cuadrícula ASCII Surfer"
@@ -5525,13 +3023,13 @@
msgstr "Se importará archivo ASCII SURFER (Golden Software)"
#: ../raster/r.in.ascii/main.c:128 ../raster/r.in.ascii/main.c:155
-#: ../raster/r.resamp.rst/main.c:619 ../raster/r.resamp.rst/main.c:631
-#: ../raster/r.resamp.rst/main.c:644 ../raster/r.resamp.rst/main.c:658
-#: ../raster/r.resamp.rst/main.c:671 ../raster/r.resamp.rst/main.c:684
+#: ../raster/r.resamp.rst/main.c:615 ../raster/r.resamp.rst/main.c:627
+#: ../raster/r.resamp.rst/main.c:640 ../raster/r.resamp.rst/main.c:654
+#: ../raster/r.resamp.rst/main.c:667 ../raster/r.resamp.rst/main.c:680
#: ../raster/r.in.arc/main.c:114 ../vector/v.in.ascii/in.c:248
-#: ../vector/v.surf.rst/main.c:618 ../vector/v.surf.rst/main.c:627
-#: ../vector/v.surf.rst/main.c:636 ../vector/v.surf.rst/main.c:646
-#: ../vector/v.surf.rst/main.c:655 ../vector/v.surf.rst/main.c:664
+#: ../vector/v.surf.rst/main.c:625 ../vector/v.surf.rst/main.c:634
+#: ../vector/v.surf.rst/main.c:643 ../vector/v.surf.rst/main.c:653
+#: ../vector/v.surf.rst/main.c:662 ../vector/v.surf.rst/main.c:671
#: ../display/d.title/main.c:119 ../display/d.text/main.c:193
#: ../display/d.text.new/main.c:397 ../general/g.setproj/get_stp.c:162
#: ../general/g.setproj/get_stp.c:165 ../general/g.setproj/get_stp.c:282
@@ -5584,6 +3082,12 @@
msgid "Unable to write to file"
msgstr "No se puede escribir en el archivo"
+#: ../raster/r.out.ascii/main.c:59 ../raster/r.out.gdal/main.c:126
+#: ../raster/r.out.mat/main.c:64 ../raster/r.out.ppm/main.c:54
+#: ../raster/r.out.tiff/r.out.tiff.c:99
+msgid "raster, export"
+msgstr "ráster, exportar"
#: ../raster/r.out.ascii/main.c:61
msgid "Converts a raster map layer into an ASCII text file."
msgstr "Convierte una capa de mapa ráster a un archivo de texto ASCII."
@@ -5637,8 +3141,8 @@
msgstr "Utilice -M o -s, no ambas"
#: ../raster/r.out.ascii/main.c:172 ../raster/r.profile/main.c:157
-#: ../raster/r.out.arc/main.c:135 ../raster/r.out.ppm3/main.c:149
-#: ../raster/r.cats/main.c:177 ../vector/v.out.ascii/out.c:160
+#: ../raster/r.out.arc/main.c:142 ../raster/r.out.ppm3/main.c:149
+#: ../raster/r.cats/main.c:177 ../vector/v.out.ascii/out.c:161
#: ../vector/v.out.vtk/main.c:176 ../display/d.nviz/main.c:203
#: ../general/g.pnmcomp/main.c:241 ../general/g.pnmcomp/main.c:258
#, c-format
@@ -5871,7 +3375,7 @@
"Demasiadas categorías (encontradas: %i, máximo: %i). Intente rescalar o "
"reclasificar el mapa"
-#: ../raster/r.texture/h_measure.c:758 ../raster/r.cost/main.c:600
+#: ../raster/r.texture/h_measure.c:758 ../raster/r.cost/main.c:667
#: ../imagery/i.smap/bouman/interp.c:69
msgid "Unable to allocate memory"
msgstr "No se puede asignar memoria"
@@ -5969,8 +3473,9 @@
msgstr "Nada que procesar. Use al menos una de las opciones."
#: ../raster/r.texture/main.c:240 ../raster/r.null/null.c:157
-#: ../raster/r.out.tiff/r.out.tiff.c:169 ../raster/r.bitpattern/main.c:114
-#: ../imagery/i.rectify/main.c:193 ../imagery/i.rectify/main.c:199
+#: ../raster/r.topidx/file_io.c:20 ../raster/r.out.tiff/r.out.tiff.c:169
+#: ../raster/r.bitpattern/main.c:114 ../imagery/i.rectify/main.c:193
+#: ../imagery/i.rectify/main.c:199
#, c-format
msgid "Unable to read header of raster map <%s>"
msgstr "No se puede leer la cabecera del mapa ráster <%s>"
@@ -6027,17 +3532,17 @@
msgid "Name of incidence or density file."
msgstr "Nombre del archivo de incidencia o de densidad."
-#: ../raster/r.sum/main.c:74 ../raster/r.walk/main.c:682
-#: ../raster/r.walk/main.c:744 ../raster/wildfire/r.spread/main.c:514
+#: ../raster/r.sum/main.c:74 ../raster/r.walk/main.c:722
+#: ../raster/r.walk/main.c:784 ../raster/wildfire/r.spread/main.c:514
#, c-format
msgid "Reading %s..."
msgstr "Leyendo %s..."
-#: ../raster/r.sun/main.c:176
+#: ../raster/r.sun/main.c:176 ../raster/r.sun2/main.c:227
msgid "Solar irradiance and irradiation model."
msgstr "Modelo de irradiancia e irradiación solar."
-#: ../raster/r.sun/main.c:178
+#: ../raster/r.sun/main.c:178 ../raster/r.sun2/main.c:229
msgid ""
"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
"for given day, latitude, surface and atmospheric conditions. Solar "
@@ -6056,7 +3561,7 @@
"irradiancia. El efecto de sombreo de la topografía se puede incorporar "
"opcionalmente."
-#: ../raster/r.sun/main.c:208 ../raster/r.sun2/main.c:253
+#: ../raster/r.sun/main.c:208 ../raster/r.sun2/main.c:243
#: ../raster/r.horizon/main.c:226
msgid "Name of the input elevation raster map [meters]"
msgstr "Nombre del mapa ráster de elevación de entrada [metros]"
@@ -6085,19 +3590,19 @@
#: ../raster/simwe/r.sim.water/main.c:174
#: ../raster/simwe/r.sim.water/main.c:182
#: ../raster/simwe/r.sim.water/main.c:189
-#: ../raster/r.watershed/front/main.c:58 ../raster/r.watershed/front/main.c:66
-#: ../raster/r.watershed/front/main.c:74 ../raster/r.watershed/front/main.c:83
-#: ../raster/r.watershed/front/main.c:92
-#: ../raster/r.watershed/front/main.c:101
-#: ../raster/r.watershed/front/main.c:110 ../raster/r.sun2/main.c:254
-#: ../raster/r.sun2/main.c:262 ../raster/r.sun2/main.c:271
-#: ../raster/r.sun2/main.c:279 ../raster/r.sun2/main.c:287
-#: ../raster/r.sun2/main.c:296 ../raster/r.sun2/main.c:306
-#: ../raster/r.sun2/main.c:315 ../raster/r.sun2/main.c:324
-#: ../raster/r.sun2/main.c:333 ../raster/r.sun2/main.c:341
-#: ../raster/r.sun2/main.c:350 ../raster/r.sun2/main.c:359
-#: ../raster/r.sun2/main.c:368 ../raster/r.sun2/main.c:376
-#: ../raster/r.sun2/main.c:384 ../raster/r.horizon/main.c:227
+#: ../raster/r.watershed/front/main.c:62 ../raster/r.watershed/front/main.c:71
+#: ../raster/r.watershed/front/main.c:79 ../raster/r.watershed/front/main.c:88
+#: ../raster/r.watershed/front/main.c:99
+#: ../raster/r.watershed/front/main.c:107
+#: ../raster/r.watershed/front/main.c:115 ../raster/r.sun2/main.c:244
+#: ../raster/r.sun2/main.c:253 ../raster/r.sun2/main.c:262
+#: ../raster/r.sun2/main.c:271 ../raster/r.sun2/main.c:279
+#: ../raster/r.sun2/main.c:288 ../raster/r.sun2/main.c:298
+#: ../raster/r.sun2/main.c:308 ../raster/r.sun2/main.c:318
+#: ../raster/r.sun2/main.c:328 ../raster/r.sun2/main.c:337
+#: ../raster/r.sun2/main.c:347 ../raster/r.sun2/main.c:356
+#: ../raster/r.sun2/main.c:365 ../raster/r.sun2/main.c:373
+#: ../raster/r.sun2/main.c:381 ../raster/r.horizon/main.c:227
#: ../raster/r.horizon/main.c:236 ../raster/r.horizon/main.c:244
#: ../raster/r.horizon/main.c:252 ../raster/r.horizon/main.c:260
#: ../raster/r.horizon/main.c:268 ../raster/r.horizon/main.c:276
@@ -6105,7 +3610,7 @@
msgid "Input_options"
msgstr "Opciones de entrada"
-#: ../raster/r.sun/main.c:217 ../raster/r.sun2/main.c:261
+#: ../raster/r.sun/main.c:217 ../raster/r.sun2/main.c:252
msgid ""
"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
"[decimal degrees]"
@@ -6113,7 +3618,7 @@
"Nombre del mapa ráster de orientación (orientación del terreno o azimut del "
"panel solar) [grados decimales]"
-#: ../raster/r.sun/main.c:227 ../raster/r.sun2/main.c:278
+#: ../raster/r.sun/main.c:227 ../raster/r.sun2/main.c:270
msgid ""
"Name of the input slope raster map (terrain slope or solar panel "
"inclination) [decimal degrees]"
@@ -6121,31 +3626,31 @@
"Nombre del mapa ráster de pendiente de entrada (pendiente del terreno o "
"inclinación del panel solar) [grados decimales]"
-#: ../raster/r.sun/main.c:236 ../raster/r.sun2/main.c:295
+#: ../raster/r.sun/main.c:236 ../raster/r.sun2/main.c:287
msgid ""
"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
msgstr ""
"Nombre del mapa ráster de coeficiente de turbidez atmosférica Linke de "
"entrada [-]"
-#: ../raster/r.sun/main.c:247 ../raster/r.sun2/main.c:305
+#: ../raster/r.sun/main.c:247 ../raster/r.sun2/main.c:297
msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
msgstr "Un valor único del coeficiente de turbidez atmosférica Linke [-]"
-#: ../raster/r.sun/main.c:256 ../raster/r.sun2/main.c:314
+#: ../raster/r.sun/main.c:256 ../raster/r.sun2/main.c:307
msgid "Name of the ground albedo coefficient input raster map [-]"
msgstr ""
"Nombre del mapa ráster de entrada de coeficiente albedo del terreno [-]"
-#: ../raster/r.sun/main.c:267 ../raster/r.sun2/main.c:323
+#: ../raster/r.sun/main.c:267 ../raster/r.sun2/main.c:317
msgid "A single value of the ground albedo coefficient [-]"
msgstr "Un solo valor del coeficiente albedo del terreno [-]"
-#: ../raster/r.sun/main.c:276 ../raster/r.sun2/main.c:332
+#: ../raster/r.sun/main.c:276 ../raster/r.sun2/main.c:327
msgid "Name of the latitudes input raster map [decimal degrees]"
msgstr "Nombre del mapa ráster de latitudes de entrada [grados decimales]"
-#: ../raster/r.sun/main.c:286 ../raster/r.sun2/main.c:340
+#: ../raster/r.sun/main.c:286 ../raster/r.sun2/main.c:336
msgid "A single value of latitude [decimal degrees]"
msgstr "Un valor único de latitud [grados decimales]"
@@ -6159,7 +3664,7 @@
msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
msgstr "Nombre ráster"
-#: ../raster/r.sun/main.c:313 ../raster/r.sun2/main.c:390
+#: ../raster/r.sun/main.c:313 ../raster/r.sun2/main.c:389
msgid "Output incidence angle raster map (mode 1 only)"
msgstr "Mapa ráster de ángulo de incidencia de salida (modo 1 solamente)"
@@ -6172,28 +3677,26 @@
#: ../raster/simwe/r.sim.sediment/main.c:208
#: ../raster/simwe/r.sim.water/main.c:204
#: ../raster/simwe/r.sim.water/main.c:210
-#: ../raster/simwe/r.sim.water/main.c:216 ../raster/r.resamp.rst/main.c:194
-#: ../raster/r.resamp.rst/main.c:202 ../raster/r.resamp.rst/main.c:210
-#: ../raster/r.resamp.rst/main.c:218 ../raster/r.resamp.rst/main.c:226
-#: ../raster/r.resamp.rst/main.c:290 ../raster/r.watershed/front/main.c:119
-#: ../raster/r.watershed/front/main.c:127
-#: ../raster/r.watershed/front/main.c:136
-#: ../raster/r.watershed/front/main.c:144
-#: ../raster/r.watershed/front/main.c:153
-#: ../raster/r.watershed/front/main.c:162
-#: ../raster/r.watershed/front/main.c:171
-#: ../raster/r.watershed/front/main.c:179 ../raster/r.sun2/main.c:391
-#: ../raster/r.sun2/main.c:399 ../raster/r.sun2/main.c:406
-#: ../raster/r.sun2/main.c:414 ../raster/r.sun2/main.c:422
-#: ../raster/r.sun2/main.c:430 ../raster/r.horizon/main.c:301
+#: ../raster/simwe/r.sim.water/main.c:216 ../raster/r.resamp.rst/main.c:182
+#: ../raster/r.resamp.rst/main.c:190 ../raster/r.resamp.rst/main.c:198
+#: ../raster/r.resamp.rst/main.c:206 ../raster/r.resamp.rst/main.c:214
+#: ../raster/r.resamp.rst/main.c:222 ../raster/r.resamp.rst/main.c:286
+#: ../raster/r.watershed/front/main.c:124
+#: ../raster/r.watershed/front/main.c:132
+#: ../raster/r.watershed/front/main.c:141
+#: ../raster/r.watershed/front/main.c:149
+#: ../raster/r.watershed/front/main.c:158
+#: ../raster/r.watershed/front/main.c:167
+#: ../raster/r.watershed/front/main.c:176
+#: ../raster/r.watershed/front/main.c:184 ../raster/r.sun2/main.c:390
+#: ../raster/r.sun2/main.c:399 ../raster/r.sun2/main.c:408
+#: ../raster/r.sun2/main.c:417 ../raster/r.sun2/main.c:426
+#: ../raster/r.sun2/main.c:435 ../raster/r.horizon/main.c:301
#: ../raster/r.horizon/main.c:311 ../raster/r.horizon/main.c:319
-#: ../vector/v.vol.rst/main.c:353 ../vector/v.vol.rst/main.c:370
-#: ../vector/v.vol.rst/main.c:380 ../vector/v.vol.rst/main.c:389
-#: ../vector/v.vol.rst/main.c:398 ../vector/v.vol.rst/main.c:407
-#: ../vector/v.vol.rst/main.c:416 ../vector/v.surf.rst/main.c:200
-#: ../vector/v.surf.rst/main.c:227 ../vector/v.surf.rst/main.c:233
-#: ../vector/v.surf.rst/main.c:239 ../vector/v.surf.rst/main.c:245
-#: ../vector/v.surf.rst/main.c:251
+#: ../vector/v.vol.rst/main.c:362 ../vector/v.vol.rst/main.c:379
+#: ../vector/v.vol.rst/main.c:389 ../vector/v.vol.rst/main.c:398
+#: ../vector/v.vol.rst/main.c:407 ../vector/v.vol.rst/main.c:416
+#: ../vector/v.vol.rst/main.c:425
msgid "Output_options"
msgstr "Opciones de salida"
@@ -6205,11 +3708,11 @@
"Producir mapa ráster de irradiancia [W.m-2] (modo 1) o irradiación [Wh.m-2."
"día-1] (modo 2) de los rayos"
-#: ../raster/r.sun/main.c:331 ../raster/r.sun2/main.c:405
+#: ../raster/r.sun/main.c:331 ../raster/r.sun2/main.c:407
msgid "Output insolation time raster map [h] (mode 2 only)"
msgstr "Producir mapa ráster de tiempo de insolación [h] (modo 2 solamente)"
-#: ../raster/r.sun/main.c:340 ../raster/r.sun2/main.c:413
+#: ../raster/r.sun/main.c:340 ../raster/r.sun2/main.c:416
msgid ""
"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
"day-1] (mode 2)"
@@ -6217,7 +3720,7 @@
"día-1] (modo 2) difusas"
-#: ../raster/r.sun/main.c:349 ../raster/r.sun2/main.c:421
+#: ../raster/r.sun/main.c:349 ../raster/r.sun2/main.c:425
msgid ""
"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
"map [Wh.m-2.day-1] (mode 2)"
@@ -6225,30 +3728,30 @@
"día-1] (modo 2) reflejadas del terreno"
-#: ../raster/r.sun/main.c:356 ../raster/r.sun2/main.c:437
+#: ../raster/r.sun/main.c:356 ../raster/r.sun2/main.c:442
msgid "No. of day of the year (1-365)"
msgstr "Número de día del año (1-365)"
-#: ../raster/r.sun/main.c:364 ../raster/r.sun2/main.c:444
+#: ../raster/r.sun/main.c:364 ../raster/r.sun2/main.c:450
msgid "Time step when computing all-day radiation sums [decimal hours]"
msgstr ""
"Intervalo de tiempo cuando se procesan sumas de radiación de todo el día "
"[horas decimales]"
-#: ../raster/r.sun/main.c:371 ../raster/r.sun2/main.c:451
+#: ../raster/r.sun/main.c:371 ../raster/r.sun2/main.c:457
msgid "Declination value (overriding the internally computed value) [radians]"
msgstr ""
"Valor de declinación (ignorando el valor procesado internamente) [radianes]"
-#: ../raster/r.sun/main.c:379 ../raster/r.sun2/main.c:458
+#: ../raster/r.sun/main.c:379 ../raster/r.sun2/main.c:465
msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
msgstr "Hora local (solar) (a establecer sólo para modo 1) [horas decimales]"
-#: ../raster/r.sun/main.c:384 ../raster/r.sun2/main.c:500
+#: ../raster/r.sun/main.c:384 ../raster/r.sun2/main.c:508
msgid "Incorporate the shadowing effect of terrain"
msgstr "Incorporar el efecto de sombreo del terreno"
-#: ../raster/r.sun/main.c:410 ../raster/r.sun2/main.c:569
+#: ../raster/r.sun/main.c:410 ../raster/r.sun2/main.c:592
msgid "insol_time and incidout are incompatible options"
msgstr "insol_time e incidout son opciones incompatibles"
@@ -6264,15 +3767,15 @@
"Modo 1: ángulo de incidencia solar instantáneo e irradiancia dada una hora "
"local establecida"
-#: ../raster/r.sun/main.c:424
+#: ../raster/r.sun/main.c:424 ../raster/r.sun2/main.c:623
msgid "incidout requires time parameter to be set"
msgstr "incidout requiere que se establezca el parámetro hora local (time)"
-#: ../raster/r.sun/main.c:425
+#: ../raster/r.sun/main.c:425 ../raster/r.sun2/main.c:624
msgid "Mode 2: integrated daily irradiation for a given day of the year"
msgstr "Modo 2: irradiación diaria integrada para un día determinado del año"
-#: ../raster/r.sun/main.c:474 ../raster/r.sun2/main.c:718
+#: ../raster/r.sun/main.c:474 ../raster/r.sun2/main.c:740
#: ../raster/r.horizon/main.c:481
msgid ""
"Can't get projection info of current location: please set latitude via 'lat' "
@@ -6281,7 +3784,7 @@
"No se puede obtener información de proyección de la localización actual: "
"¡por favor establezca la latitud via opción 'lat' o 'latin'!"
-#: ../raster/r.sun/main.c:477 ../raster/r.sun2/main.c:721
+#: ../raster/r.sun/main.c:477 ../raster/r.sun2/main.c:743
#: ../raster/r.horizon/main.c:484 ../display/d.where/main.c:96
#: ../general/g.region/printwindow.c:251 ../general/g.region/printwindow.c:492
#: ../general/g.region/printwindow.c:611
@@ -6289,7 +3792,7 @@
msgstr ""
"No se pueden obtener unidades de la proyección de la localización actual"
-#: ../raster/r.sun/main.c:481 ../raster/r.sun2/main.c:724
+#: ../raster/r.sun/main.c:481 ../raster/r.sun2/main.c:746
#: ../raster/r.horizon/main.c:488 ../ps/ps.map/do_geogrid.c:272
#: ../display/d.where/main.c:99 ../display/d.grid/plot.c:294
#: ../general/g.region/printwindow.c:254 ../general/g.region/printwindow.c:495
@@ -6299,7 +3802,7 @@
"No se pueden obtener los valores clave de la proyección de la localización "
"actual"
-#: ../raster/r.sun/main.c:491 ../raster/r.sun2/main.c:734
+#: ../raster/r.sun/main.c:491 ../raster/r.sun2/main.c:756
#: ../raster/r.horizon/main.c:498 ../ps/ps.map/do_geogrid.c:278
#: ../display/d.where/main.c:106 ../display/d.where/main.c:132
#: ../display/d.grid/plot.c:301 ../display/d.grid/plot.c:328
@@ -6682,7 +4185,7 @@
msgid "Unable to read color file of raster map <%s>"
msgstr "No se puede leer el archivo de color del mapa ráster <%s@%s>"
-#: ../raster/r.out.gdal/main.c:48
+#: ../raster/r.out.gdal/main.c:47
#, c-format
msgid "Supported formats:\n"
msgstr "Formatos soportados:\n"
@@ -6692,6 +4195,10 @@
msgid "Exports GRASS raster maps into GDAL supported formats."
msgstr "Exporta un ráster de GRASS a formatos soportados por GDAL."
+#: ../raster/r.out.gdal/main.c:130
+msgid "List supported output formats"
+msgstr "Listar formatos de salida soportados"
#: ../raster/r.out.gdal/main.c:131 ../raster/r.in.gdal/main.c:135
#: ../raster/r.stats/main.c:149 ../raster/r.stats/main.c:154
#: ../raster/r.stats/main.c:159 ../raster/r.stats/main.c:165
@@ -6700,8 +4207,8 @@
#: ../raster/r.external/main.c:555 ../vector/v.info/main.c:76
#: ../vector/v.info/main.c:82 ../vector/v.info/main.c:87
#: ../vector/v.info/main.c:92 ../vector/v.info/main.c:97
-#: ../vector/v.to.db/parse.c:103 ../vector/v.to.db/parse.c:108
-#: ../vector/v.to.db/parse.c:114 ../imagery/i.group/main.c:78
+#: ../vector/v.to.db/parse.c:104 ../vector/v.to.db/parse.c:109
+#: ../vector/v.to.db/parse.c:115 ../imagery/i.group/main.c:78
#: ../imagery/i.group/main.c:84 ../general/g.region/main.c:87
#: ../general/g.region/main.c:93 ../general/g.region/main.c:98
#: ../general/g.region/main.c:104 ../general/g.region/main.c:110
@@ -6712,7 +4219,7 @@
#: ../raster/r.out.gdal/main.c:135
#, fuzzy
-msgid "Do not export long colortable"
+msgid "Do not write GDAL standard colortable"
msgstr "Eliminar la tabla de colores existente"
#: ../raster/r.out.gdal/main.c:136
@@ -6720,10 +4227,18 @@
msgstr ""
#: ../raster/r.out.gdal/main.c:140
+msgid "Force raster export also if data loss may occur"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:141
+msgid "Overrides saftey checks."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:145
msgid "Name of raster map (or group) to export"
msgstr "Nombre del mapa ráster (o grupo) a exportar"
-#: ../raster/r.out.gdal/main.c:141 ../raster/r.out.gdal/main.c:177
+#: ../raster/r.out.gdal/main.c:146 ../raster/r.out.gdal/main.c:182
#: ../raster/r.in.gdal/main.c:90 ../raster/r.in.gdal/main.c:94
#: ../raster/r.colors/main.c:171 ../raster/r.external/main.c:512
#: ../raster/r.external/main.c:522 ../vector/v.in.ascii/in.c:57
@@ -6731,49 +4246,62 @@
msgid "Required"
msgstr "Requerido"
-#: ../raster/r.out.gdal/main.c:176
+#: ../raster/r.out.gdal/main.c:152
+msgid "GIS format to write (case sensitive, see also -l flag)"
+msgstr ""
+"Formato GIS a escribir (sensible a mayúsculas, ver también la opción -l)"
+#: ../raster/r.out.gdal/main.c:173
+msgid "File type"
+msgstr "Tipo de archivo"
+#: ../raster/r.out.gdal/main.c:181
msgid "Name for output raster file"
msgstr "Nombre para el archivo ráster de salida"
-#: ../raster/r.out.gdal/main.c:183
+#: ../raster/r.out.gdal/main.c:188
#, fuzzy
msgid "Creation option(s) to pass to the output format driver"
msgstr ""
"Opción de creación para el controlador de formato de salida. Se pueden "
"indicar múltiples opciones."
-#: ../raster/r.out.gdal/main.c:192
+#: ../raster/r.out.gdal/main.c:190
+msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:197
msgid "Metadata key(s) and value(s) to include"
msgstr ""
-#: ../raster/r.out.gdal/main.c:194
+#: ../raster/r.out.gdal/main.c:199
msgid ""
"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
"Not supported by all output format drivers."
msgstr ""
-#: ../raster/r.out.gdal/main.c:203
+#: ../raster/r.out.gdal/main.c:208
msgid "Assign a specified nodata value to output bands"
msgstr ""
"Asignar un valor especificado a las celdas sin datos para las bandas de "
"salida"
-#: ../raster/r.out.gdal/main.c:236
+#: ../raster/r.out.gdal/main.c:241
#, c-format
msgid "Raster map or group <%s> not found"
msgstr "No se encontró el mapa ráster o grupo <%s>"
-#: ../raster/r.out.gdal/main.c:240
+#: ../raster/r.out.gdal/main.c:245
#, c-format
msgid "No raster maps in group <%s>"
msgstr "Ningún mapa ráster en el grupo <%s>"
-#: ../raster/r.out.gdal/main.c:254
+#: ../raster/r.out.gdal/main.c:259
#, c-format
msgid "Unable to get <%s> driver"
msgstr "No se puede obtener el controlador <%s>"
-#: ../raster/r.out.gdal/main.c:260
+#: ../raster/r.out.gdal/main.c:265
#, c-format
msgid ""
"Driver <%s> does not support direct writing. Using MEM driver for "
@@ -6782,94 +4310,179 @@
"El controlador <%s> no soporta la escritura directa. Se usa el controlador "
"MEM para datos intermedios."
-#: ../raster/r.out.gdal/main.c:265
+#: ../raster/r.out.gdal/main.c:270
msgid "Unable to get in-memory raster driver"
msgstr "No se puede obtener un controlador ráster en memoria"
-#: ../raster/r.out.gdal/main.c:269
+#: ../raster/r.out.gdal/main.c:274
#, c-format
msgid "Driver <%s> does not support creating rasters"
msgstr "El controlador <%s> no soporta la creación de rásters"
-#: ../raster/r.out.gdal/main.c:399
+#: ../raster/r.out.gdal/main.c:407 ../raster/r.out.gdal/main.c:504
+#: ../raster/r.out.gdal/main.c:521
+#, fuzzy
+msgid "Forcing raster export."
+#: ../raster/r.out.gdal/main.c:409 ../raster/r.out.gdal/main.c:506
+#: ../raster/r.out.gdal/main.c:523
+#, fuzzy
+msgid "Raster export aborted."
+#: ../raster/r.out.gdal/main.c:417
#, c-format
msgid "Exporting to GDAL data type: %s"
msgstr "Exportando al tipo de datos de GDAL: %s"
-#: ../raster/r.out.gdal/main.c:419
+#: ../raster/r.out.gdal/main.c:437
msgid "Output file name not specified"
msgstr "Nombre del vectorial de salida sin especificar"
-#: ../raster/r.out.gdal/main.c:425
+#: ../raster/r.out.gdal/main.c:443
msgid "Unable to create dataset using memory raster driver"
msgstr ""
"No se puede el conjunto de datos usando el controlador ráster en memoria"
-#: ../raster/r.out.gdal/main.c:434
+#: ../raster/r.out.gdal/main.c:452
#, c-format
msgid "Unable to create <%s> dataset using <%s> driver"
msgstr "No se puede crear el conjunto de datos <%s> usando el controlador <%s>"
-#: ../raster/r.out.gdal/main.c:449
+#: ../raster/r.out.gdal/main.c:467
msgid "Unable to set geo transform"
msgstr "No se puede establecer la transformación geo"
-#: ../raster/r.out.gdal/main.c:457
+#: ../raster/r.out.gdal/main.c:475
msgid "Unable to set projection"
msgstr "No se puede establecer la proyección"
-#: ../raster/r.out.gdal/main.c:467
+#: ../raster/r.out.gdal/main.c:485
#, c-format
msgid "Exporting raster map <%s> (band %d)..."
msgstr "Exportando el mapa ráster <%s> (banda %d)..."
-#: ../raster/r.out.gdal/main.c:476
+#: ../raster/r.out.gdal/main.c:516
#, c-format
msgid "Unable to export raster map <%s>"
msgstr "No se puede exportar el mapa ráster <%s>"
-#: ../raster/r.out.gdal/main.c:486
+#: ../raster/r.out.gdal/main.c:533
#, c-format
msgid "Unable to create raster map <%s> using driver <%s>"
msgstr "No se puede crear el mapa ráster <%s> usando el controlador <%s>"
-#: ../raster/r.out.gdal/export_band.c:53
+#: ../raster/r.out.gdal/main.c:556 ../raster/r.out.gdal/main.c:568
+#: ../raster/r.out.gdal/main.c:581 ../raster/r.out.gdal/main.c:594
+#: ../raster/r.out.gdal/main.c:606 ../raster/r.out.gdal/main.c:619
+#: ../raster/r.out.gdal/main.c:633
+msgid "Selected GDAL datatype does not cover data range."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:557 ../raster/r.out.gdal/main.c:569
+#: ../raster/r.out.gdal/main.c:582 ../raster/r.out.gdal/main.c:595
+#: ../raster/r.out.gdal/main.c:657 ../raster/r.out.gdal/main.c:669
+#: ../raster/r.out.gdal/main.c:682 ../raster/r.out.gdal/main.c:695
+#, c-format
+msgid "GDAL datatype: %s, range: %d - %d"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:560 ../raster/r.out.gdal/main.c:572
+#: ../raster/r.out.gdal/main.c:585 ../raster/r.out.gdal/main.c:598
+#: ../raster/r.out.gdal/main.c:610 ../raster/r.out.gdal/main.c:623
+#: ../raster/r.out.gdal/main.c:637
+#, fuzzy, c-format
+msgid "Raster map <%s> range: %g - %g"
+msgstr "El mapa ráster <%s> ya existe"
+#: ../raster/r.out.gdal/main.c:607 ../raster/r.out.gdal/main.c:707
+#, c-format
+msgid "GDAL datatype: %s, range: %u - %u"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:620 ../raster/r.out.gdal/main.c:634
+#: ../raster/r.out.gdal/main.c:720 ../raster/r.out.gdal/main.c:734
+#, c-format
+msgid "GDAL datatype: %s, range: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:655 ../raster/r.out.gdal/main.c:667
+#: ../raster/r.out.gdal/main.c:680
+#, c-format
+msgid ""
+"Specified nodata value %d is not covered by range of selected GDAL datatype."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:693 ../raster/r.out.gdal/main.c:705
+#, c-format
+msgid ""
+"Specified nodata value %lld is not covered by range of selected GDAL "
+"datatype."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:718 ../raster/r.out.gdal/main.c:732
+#, c-format
+msgid ""
+"Specified nodata value %g is not covered by range of selected GDAL datatype."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:54
msgid "Unable to get raster band"
msgstr "No se puede obtener la banda del ráster"
-#: ../raster/r.out.gdal/export_band.c:180
-#: ../raster/r.out.gdal/export_band.c:186
+#: ../raster/r.out.gdal/export_band.c:172
+#: ../raster/r.out.gdal/export_band.c:178
msgid "Unable to allocate buffer for reading raster map"
msgstr "No se puede asignar memoria intermedia para leer el mapa ráster"
-#: ../raster/r.out.gdal/export_band.c:220
-#: ../raster/r.out.gdal/export_band.c:251
-#: ../raster/r.out.gdal/export_band.c:282
+#: ../raster/r.out.gdal/export_band.c:215
+#: ../raster/r.out.gdal/export_band.c:249
+#: ../raster/r.out.gdal/export_band.c:283
msgid "Unable to write GDAL raster file"
msgstr "No se puede escribir el archivo ráster de GDAL"
-#: ../raster/r.out.gdal/export_band.c:291
+#: ../raster/r.out.gdal/export_band.c:292
#, fuzzy, c-format
msgid ""
"Input raster map contains cells with NULL-value (no-data). The value %d was "
-"used to represent no-data values in the input map. You can specify nodata "
-"value by %s parameter."
+"used to represent no-data values in the input map. You can specify a nodata "
+"value with the %s option."
msgstr ""
"El mapa ráster de entrada contiene celdas con valor NULO (sin datos). Para "
"los valores sin datos se usó el valor %d. Puede especificar el valor para "
"para las celdas sin datos con el parámetro %s."
-#: ../raster/r.out.gdal/export_band.c:296
+#: ../raster/r.out.gdal/export_band.c:297
#, fuzzy, c-format
msgid ""
"Input raster map contains cells with NULL-value (no-data). The value %g was "
msgstr ""
+#: ../raster/r.out.gdal/export_band.c:305
+#, c-format
+msgid ""
+"The default nodata value is present in rasterband <%s> and would lead to "
+"data loss. Please specify a different nodata value with the %s parameter."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:311
+#, c-format
+msgid ""
+"The given nodata value is present in rasterband <%s> and would lead to data "
+"loss. Please specify a different nodata value with the %s parameter."
+msgstr ""
+#: ../raster/r.in.bin/main.c:122 ../raster/r.in.gdal/main.c:79
+#: ../raster/r.in.poly/main.c:29 ../raster/r.external/main.c:505
+msgid "raster, import"
+msgstr "ráster, importar"
#: ../raster/r.in.bin/main.c:124
msgid "Import a binary raster file into a GRASS raster map layer."
msgstr "Importar un archivo ráster binario a una capa de mapa ráster de GRASS."
@@ -6888,9 +4501,9 @@
#: ../raster/r.in.bin/main.c:140 ../raster/r.in.bin/main.c:145
#: ../raster/r.in.bin/main.c:174 ../raster/r.in.bin/main.c:227
-#: ../raster/r.resamp.rst/main.c:234 ../raster/r.resamp.rst/main.c:242
-#: ../raster/r.resamp.rst/main.c:250 ../raster/r.resamp.rst/main.c:258
-#: ../raster/r.resamp.rst/main.c:266 ../raster/r.slope.aspect/main.c:184
+#: ../raster/r.resamp.rst/main.c:230 ../raster/r.resamp.rst/main.c:238
+#: ../raster/r.resamp.rst/main.c:246 ../raster/r.resamp.rst/main.c:254
+#: ../raster/r.resamp.rst/main.c:262 ../raster/r.slope.aspect/main.c:184
#: ../raster/r.slope.aspect/main.c:194 ../raster/r.slope.aspect/main.c:273
#: ../raster/r.slope.aspect/main.c:282 ../raster/r.slope.aspect/main.c:293
#: ../vector/lidar/v.lidar.edgedetection/main.c:87
@@ -6905,15 +4518,11 @@
#: ../vector/lidar/v.surf.bspline/main.c:133
#: ../vector/lidar/v.surf.bspline/main.c:142
#: ../vector/lidar/v.surf.bspline/main.c:149
-#: ../vector/lidar/v.surf.bspline/main.c:158 ../vector/v.vol.rst/main.c:261
+#: ../vector/lidar/v.surf.bspline/main.c:159 ../vector/v.vol.rst/main.c:261
#: ../vector/v.vol.rst/main.c:269 ../vector/v.vol.rst/main.c:277
#: ../vector/v.vol.rst/main.c:310 ../vector/v.vol.rst/main.c:319
#: ../vector/v.vol.rst/main.c:328 ../vector/v.vol.rst/main.c:337
-#: ../vector/v.vol.rst/main.c:345 ../vector/v.surf.rst/main.c:194
-#: ../vector/v.surf.rst/main.c:264 ../vector/v.surf.rst/main.c:271
-#: ../vector/v.surf.rst/main.c:279 ../vector/v.surf.rst/main.c:287
-#: ../vector/v.surf.rst/main.c:296 ../vector/v.surf.rst/main.c:305
-#: ../vector/v.surf.rst/main.c:314 ../vector/v.surf.rst/main.c:323
+#: ../vector/v.vol.rst/main.c:346 ../vector/v.vol.rst/main.c:354
#: ../imagery/i.cluster/main.c:105 ../imagery/i.cluster/main.c:121
#: ../imagery/i.cluster/main.c:129 ../imagery/i.cluster/main.c:138
#: ../imagery/i.cluster/main.c:146 ../imagery/i.cluster/main.c:154
@@ -7122,7 +4731,7 @@
"Bases de datos latitud/longitud no soportadas por r.surf.idw2. ¡Utilice r."
"surf.idw en su lugar!"
-#: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:135
+#: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:136
#, c-format
msgid "%s=%s - illegal number of interpolation points"
msgstr "%s=%s - número de puntos de interpolación no admitido"
@@ -7142,8 +4751,8 @@
msgstr "No se puede obtener la fila"
#: ../raster/r.surf.idw2/read_cell.c:38 ../raster/r.surf.idw/main.c:685
-#: ../raster/r.colors/stats.c:41 ../raster/r.colors/stats.c:104
-#: ../raster/r.cost/main.c:393 ../raster/r.cost/main.c:602
+#: ../raster/r.colors/stats.c:41 ../raster/r.colors/stats.c:107
+#: ../raster/r.cost/main.c:435 ../raster/r.cost/main.c:669
#: ../raster/r.series/main.c:195
#, c-format
msgid "Reading raster map <%s>..."
@@ -7312,7 +4921,14 @@
#: ../raster/simwe/r.sim.water/main.c:268
#: ../raster/simwe/r.sim.water/main.c:277
#: ../raster/simwe/r.sim.water/main.c:285
-#: ../raster/simwe/r.sim.water/main.c:294
+#: ../raster/simwe/r.sim.water/main.c:294 ../vector/v.surf.rst/main.c:190
+#: ../vector/v.surf.rst/main.c:195 ../vector/v.surf.rst/main.c:284
+#: ../vector/v.surf.rst/main.c:292 ../vector/v.surf.rst/main.c:300
+#: ../vector/v.surf.rst/main.c:307 ../vector/v.surf.rst/main.c:315
+#: ../vector/v.surf.rst/main.c:323 ../vector/v.surf.rst/main.c:332
+#: ../vector/v.surf.rst/main.c:341 ../vector/v.surf.rst/main.c:350
+#: ../vector/v.surf.rst/main.c:359 ../vector/v.surf.rst/main.c:367
+#: ../vector/v.surf.rst/main.c:374
msgid "Parameters"
msgstr "Parámetros"
@@ -7355,8 +4971,8 @@
msgstr "No está produciendo ningún archivo ráster o de lugares"
#: ../raster/simwe/r.sim.sediment/main.c:358
-#: ../raster/simwe/r.sim.water/main.c:480 ../vector/v.surf.rst/main.c:689
-#: ../vector/v.surf.rst/main.c:741
+#: ../raster/simwe/r.sim.water/main.c:480 ../vector/v.surf.rst/main.c:696
+#: ../vector/v.surf.rst/main.c:748
msgid "Input failed"
msgstr "Falló la entrada"
@@ -7432,7 +5048,8 @@
#: ../raster/simwe/simlib/hydro.c:119
-msgid "nwalk > maxw!"
+#, c-format
+msgid "nwalk (%d) > maxw (%d)!"
msgstr ""
#: ../raster/simwe/simlib/hydro.c:339
@@ -7537,11 +5154,16 @@
msgid "Name for the output binary MAT-File"
msgstr "Nombre para el archivo MAT binario de salida"
-#: ../raster/r.out.mat/main.c:90 ../raster/r.cost/main.c:226
+#: ../raster/r.out.mat/main.c:81 ../raster/r.in.mat/main.c:115
+#: ../raster/r.out.tiff/r.out.tiff.c:136
+msgid "Verbose mode"
+msgstr "Modo verboso"
+#: ../raster/r.out.mat/main.c:90 ../raster/r.cost/main.c:238
#: ../raster/r.in.mat/main.c:125 ../raster/r.out.tiff/r.out.tiff.c:144
#: ../raster/wildfire/r.ros/main.c:314 ../raster/wildfire/r.spread/main.c:255
-#: ../vector/v.kernel/main.c:191 ../display/d.vect/main.c:391
-#: ../display/d.mon/pgms/release.c:36
+#: ../vector/v.kernel/main.c:191 ../visualization/nviz/src/nviz_init.c:156
+#: ../display/d.vect/main.c:391 ../display/d.mon/pgms/release.c:36
msgid ""
"The '-v' flag is superseded and will be removed in future. Please use '--"
"verbose' instead."
@@ -7706,6 +5328,12 @@
msgid "%s: running %s command"
msgstr "%s: ejecutando el comando %s"
+#: ../raster/r.statistics/main.c:42 ../raster/r.report/main.c:64
+#: ../raster/r.quantile/main.c:254 ../raster/r.stats/main.c:105
+#: ../raster/r.univar2/r.univar_main.c:75
+msgid "raster, statistics"
+msgstr "ráster, estadísticas"
#: ../raster/r.statistics/main.c:44
msgid "Calculates category or object oriented statistics."
msgstr "Calcula estadísticas orientadas a categorías u objetos."
@@ -8134,8 +5762,8 @@
#: ../raster/r.proj/readcell.c:27 ../imagery/i.gensigset/read_data.c:27
#: ../imagery/i.gensigset/read_train.c:10 ../imagery/i.his.rgb/h2rmain.c:94
#: ../imagery/i.rgb.his/r2hmain.c:92 ../imagery/i.smap/bouman/read_block.c:16
-#: ../imagery/i.pca/main.c:252 ../imagery/i.pca/main.c:301
-#: ../imagery/i.pca/main.c:313 ../imagery/i.pca/main.c:428
+#: ../imagery/i.pca/main.c:259 ../imagery/i.pca/main.c:310
+#: ../imagery/i.pca/main.c:322 ../imagery/i.pca/main.c:437
#: ../imagery/i.gensig/read_train.c:10 ../imagery/i.gensig/covariance.c:34
#: ../imagery/i.cluster/main.c:290 ../imagery/i.maxlik/main.c:117
#, c-format
@@ -8690,24 +6318,6 @@
msgid "Cannot open segment file %s"
msgstr "No se puede abrir el archivo de segmentos %s"
-#: ../raster/r.flow/io.c:170 ../vector/v.net.visibility/main.c:87
-#: ../vector/v.edit/main.c:100 ../vector/v.in.dxf/main.c:168
-#: ../vector/lidar/v.lidar.edgedetection/main.c:175
-#: ../vector/lidar/v.lidar.correction/main.c:156
-#: ../vector/lidar/v.lidar.correction/main.c:162
-#: ../vector/lidar/v.outlier/main.c:150 ../vector/lidar/v.outlier/main.c:155
-#: ../vector/lidar/v.outlier/main.c:161
-#: ../vector/lidar/v.surf.bspline/main.c:266 ../vector/v.generalize/main.c:312
-#: ../vector/v.mkgrid/main.c:212 ../vector/v.net.path/main.c:139
-#: ../vector/v.voronoi/dt_main.c:92 ../vector/v.voronoi/dt_main.c:98
-#: ../vector/v.voronoi/vo_main.c:164 ../vector/v.drape/main.c:339
-#: ../vector/v.drape/main.c:380 ../vector/v.delaunay2/main.c:103
-#: ../vector/v.delaunay2/main.c:107 ../vector/v.to.3d/main.c:87
-#: ../vector/v.buffer2/main.c:277 ../doc/vector/v.example/main.c:96
-#, c-format
-msgid "Unable to create vector map <%s>"
-msgstr "No se puede crear el mapa vectorial <%s>"
#: ../raster/r.flow/io.c:197
msgid "Cannot reset current region"
msgstr "No se puede restablecer la región actual"
@@ -8753,6 +6363,10 @@
"Crea mapa de índices topográficos [ln(a/tan(beta))] a partir de mapa de "
"elevación."
+#: ../raster/r.topidx/main.c:42
+msgid "Input elevation map"
+msgstr "Mapa de elevación de entrada"
#: ../raster/r.topidx/main.c:46
msgid "Output topographic index map"
msgstr "Producir mapa de índice topográfico"
@@ -8764,11 +6378,19 @@
"Las localizaciones Latitud/Longitud no están soportadas por %s. Por favor "
"reproyecte el mapa primero."
-#: ../raster/r.topidx/file_io.c:29
+#: ../raster/r.topidx/file_io.c:32
+#, c-format
+msgid ""
+"Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx"
+"%.2f]! Needs to be at least identical or the current region resolution lower "
+"than the input map resolution"
+msgstr ""
+#: ../raster/r.topidx/file_io.c:36
msgid "Reading elevation map..."
msgstr "Leyendo mapa de elevación..."
-#: ../raster/r.topidx/file_io.c:83
+#: ../raster/r.topidx/file_io.c:90
msgid "Writing topographic index map..."
msgstr "Escribiendo mapa de índice topográfico..."
@@ -8824,26 +6446,31 @@
msgid "No non-null values"
msgstr "Ningún valor no nulo"
-#: ../raster/r.out.arc/main.c:61
+#: ../raster/r.out.arc/main.c:62
msgid "Converts a raster map layer into an ESRI ARCGRID file."
msgstr "Convierte una capa de mapa ráster en un archivo ARCGRID de ESRI."
-#: ../raster/r.out.arc/main.c:69
+#: ../raster/r.out.arc/main.c:70
msgid "Name of an existing raster map layer"
msgstr "Nombre de una capa de mapa ráster existente"
-#: ../raster/r.out.arc/main.c:77
+#: ../raster/r.out.arc/main.c:78
msgid "Name of an output ARC-GID map (use out=- for stdout)"
msgstr "Nombre de un mapa ARC-GID de salida (usar out=- para stdout)"
-#: ../raster/r.out.arc/main.c:84
+#: ../raster/r.out.arc/main.c:85
msgid "Number of decimal places"
msgstr "Número de posiciones decimales"
-#: ../raster/r.out.arc/main.c:94
+#: ../raster/r.out.arc/main.c:95
msgid "List one entry per line instead of full row"
msgstr "Listar un vacío por línea en vez de fila completa"
+#: ../raster/r.out.arc/main.c:101
+#, fuzzy
+msgid "Use cell center reference in header instead of cell corner"
+msgstr "Listar un vacío por línea en vez de fila completa"
#: ../raster/r.report/stats.c:65
#, c-format
msgid "Unable to open result file <%s>"
@@ -8861,7 +6488,7 @@
msgid "Raster map(s) to report on"
msgstr "Mapa(s) ráster sobre el que informar"
-#: ../raster/r.report/parse.c:44 ../vector/v.to.db/parse.c:84
+#: ../raster/r.report/parse.c:44 ../vector/v.to.db/parse.c:85
msgid "Units"
msgstr "Unidades"
@@ -8995,6 +6622,10 @@
msgid "List supported formats and exit"
msgstr "Listar los formatos soportados y salir"
+#: ../raster/r.in.gdal/main.c:140
+msgid "Keep band numbers instead of using band color names"
+msgstr "Mantener números de banda en vez de usar nombre de color de banda"
#: ../raster/r.in.gdal/main.c:161
msgid "You have to specify a target location different from output location"
msgstr ""
@@ -9198,19 +6829,19 @@
#: ../raster/r.random/random.c:74 ../raster/r.to.vect/main.c:156
#: ../raster/r.contour/main.c:185 ../vector/v.db.connect/main.c:195
#: ../vector/v.db.connect/main.c:303 ../vector/v.to.rast3/main.c:86
-#: ../vector/v.edit/select.c:520 ../vector/v.in.dxf/write_vect.c:187
+#: ../vector/v.edit/select.c:520 ../vector/v.in.dxf/write_vect.c:198
#: ../vector/lidar/v.surf.bspline/crosscorr.c:121
-#: ../vector/lidar/v.surf.bspline/main.c:306 ../vector/v.distance/main.c:360
+#: ../vector/lidar/v.surf.bspline/main.c:307 ../vector/v.distance/main.c:360
#: ../vector/v.distance/main.c:397 ../vector/v.reclass/main.c:126
#: ../vector/v.in.ascii/in.c:317 ../vector/v.to.points/main.c:285
-#: ../vector/v.out.ascii/b2a.c:49 ../vector/v.db.select/main.c:142
+#: ../vector/v.out.ascii/b2a.c:50 ../vector/v.db.select/main.c:142
#: ../vector/v.db.select/main.c:273 ../vector/v.what.rast/main.c:132
#: ../vector/v.extrude/main.c:167 ../vector/v.sample/main.c:207
#: ../vector/v.info/main.c:209 ../vector/v.in.sites/main.c:163
#: ../vector/v.patch/main.c:132 ../vector/v.patch/main.c:162
#: ../vector/v.patch/main.c:274 ../vector/v.patch/main.c:332
#: ../vector/v.surf.idw/read_sites.c:39 ../vector/v.vol.rst/user1.c:97
-#: ../vector/v.vol.rst/main.c:578 ../vector/v.transform/trans_digit.c:58
+#: ../vector/v.vol.rst/main.c:590 ../vector/v.transform/trans_digit.c:58
#: ../vector/v.mkgrid/main.c:226 ../vector/v.random/main.c:160
#: ../vector/v.overlay/main.c:186 ../vector/v.overlay/main.c:287
#: ../vector/v.net.path/path.c:96 ../vector/v.label.sa/labels.c:83
@@ -9218,13 +6849,13 @@
#: ../vector/v.out.svg/main.c:148 ../vector/v.to.db/update.c:46
#: ../vector/v.to.db/query.c:89 ../vector/v.out.vtk/writeVTK.c:639
#: ../vector/v.label/main.c:282 ../vector/v.in.dwg/main.c:194
-#: ../vector/v.surf.rst/main.c:579 ../vector/v.in.db/main.c:119
+#: ../vector/v.surf.rst/main.c:586 ../vector/v.in.db/main.c:119
#: ../vector/v.to.rast/support.c:131 ../vector/v.to.rast/support.c:283
#: ../vector/v.to.rast/vect2rast.c:56 ../vector/v.drape/main.c:293
-#: ../vector/v.out.ogr/main.c:327 ../vector/v.lrs/v.lrs.create/main.c:286
+#: ../vector/v.out.ogr/main.c:330 ../vector/v.lrs/v.lrs.create/main.c:286
#: ../vector/v.lrs/v.lrs.create/main.c:294 ../vector/v.buffer/main.c:387
#: ../vector/v.extract/main.c:291 ../vector/v.to.3d/trans2.c:49
-#: ../vector/v.to.3d/trans3.c:50 ../vector/v.buffer2/main.c:291
+#: ../vector/v.to.3d/trans3.c:50 ../vector/v.buffer2/main.c:319
#: ../doc/vector/v.example/main.c:128 ../ps/ps.map/catval.c:54
#: ../ps/ps.map/catval.c:116 ../ps/ps.map/catval.c:182
#: ../display/d.vect/plot1.c:203 ../display/d.vect/area.c:60
@@ -9282,6 +6913,11 @@
"Crea una capa de mapa ráster y un mapa de puntos vectorial que contiene "
"lugares situados de forma aleatoria."
+#: ../raster/r.random/main.c:57 ../raster/r.out.bin/main.c:73
+#: ../raster/r.water.outlet/main.c:54 ../imagery/i.zc/main.c:69
+msgid "Name of input raster map"
+msgstr "Nombre del mapa ráster de entrada"
#: ../raster/r.random/main.c:62 ../raster/r.median/main.c:58
msgid "Name of cover raster map"
msgstr "Nombre del mapa ráster de cobertura"
@@ -9303,32 +6939,46 @@
msgid "Generate vector points as 3D points"
msgstr "Generar puntos vectoriales como puntos 3D"
-#: ../raster/r.random/main.c:136
+#: ../raster/r.random/main.c:94 ../vector/v.in.ascii/in.c:161
+msgid "Do not build topology in points mode"
+msgstr "No contruir topología en modo de puntos"
+#: ../raster/r.random/main.c:95 ../vector/v.in.ascii/in.c:84
+#: ../vector/v.in.ascii/in.c:91 ../vector/v.in.ascii/in.c:103
+#: ../vector/v.in.ascii/in.c:113 ../vector/v.in.ascii/in.c:123
+#: ../vector/v.in.ascii/in.c:133 ../vector/v.in.ascii/in.c:157
+#: ../vector/v.in.ascii/in.c:162 ../vector/v.in.ascii/in.c:168
+#: ../vector/v.out.ascii/out.c:67 ../vector/v.out.ascii/out.c:77
+#: ../vector/v.out.ascii/out.c:84 ../vector/v.out.ascii/out.c:97
+msgid "Points"
+msgstr "Puntos"
+#: ../raster/r.random/main.c:142
#, c-format
msgid "Note: one (or both) of %s and %s must be specified"
msgstr "Nota: uno (o ambos) de %s y %s se debe especificar"
-#: ../raster/r.random/main.c:154
+#: ../raster/r.random/main.c:160
#, c-format
msgid "<%s=%s> invalid percentage"
msgstr "<%s=%s> porcentaje no válido"
-#: ../raster/r.random/main.c:161
+#: ../raster/r.random/main.c:167
#, c-format
msgid "<%s=%s> invalid number of points"
msgstr "<%s=%s> número de puntos no válido"
-#: ../raster/r.random/main.c:174
+#: ../raster/r.random/main.c:180
#, c-format
msgid "There aren't [%ld] cells in the current region"
msgstr "No hay [%ld] celdas en la región actual"
-#: ../raster/r.random/main.c:177
+#: ../raster/r.random/main.c:183
#, fuzzy, c-format
msgid "There aren't [%ld] non-NULL cells in the current region"
msgstr "No hay [%ld] celdas distintas de cero en la región actual"
-#: ../raster/r.random/main.c:182
+#: ../raster/r.random/main.c:188
msgid "There are no valid locations in the current region"
msgstr "No hay ninguna localización válida en la región actual"
@@ -9674,26 +7324,26 @@
msgid "Computing quantiles"
msgstr "Preprocesando: tolerancias de quantización"
-#: ../raster/r.quantile/main.c:244
+#: ../raster/r.quantile/main.c:255
msgid "Compute quantiles using two passes."
msgstr ""
-#: ../raster/r.quantile/main.c:252
+#: ../raster/r.quantile/main.c:263
#, fuzzy
msgid "Number of quantiles"
msgstr "Número de marcos"
-#: ../raster/r.quantile/main.c:260
+#: ../raster/r.quantile/main.c:271
#, fuzzy
msgid "List of percentiles"
msgstr "Lista de niveles de contorno"
-#: ../raster/r.quantile/main.c:266
+#: ../raster/r.quantile/main.c:277
#, fuzzy
msgid "Number of bins to use"
msgstr "Número de puntos a crear"
-#: ../raster/r.quantile/main.c:271
+#: ../raster/r.quantile/main.c:282
msgid "Generate recode rules based on quantile-defined intervals."
msgstr ""
@@ -9952,209 +7602,208 @@
"entrada a un nuevo mapa ráster (posiblemente con distinta resolución) "
"usando ."
-#: ../raster/r.resamp.rst/main.c:173
+#: ../raster/r.resamp.rst/main.c:168
msgid "Desired east-west resolution"
msgstr "Resolución Este-Oeste deseada"
-#: ../raster/r.resamp.rst/main.c:179
+#: ../raster/r.resamp.rst/main.c:174
msgid "Desired north-south resolution"
msgstr "Resolución Norte-Sur deseada"
-#: ../raster/r.resamp.rst/main.c:186
+#: ../raster/r.resamp.rst/main.c:181
msgid "Output z-file (elevation) map"
msgstr "Producir mapa de archivo Z (altura)"
-#: ../raster/r.resamp.rst/main.c:193
+#: ../raster/r.resamp.rst/main.c:189
msgid "Output slope map (or fx)"
msgstr "Producir mapa de pendientes (o fx)"
-#: ../raster/r.resamp.rst/main.c:201
+#: ../raster/r.resamp.rst/main.c:197
msgid "Output aspect map (or fy)"
msgstr "Producir mapa de orientación (o fy)"
-#: ../raster/r.resamp.rst/main.c:209
+#: ../raster/r.resamp.rst/main.c:205
msgid "Output profile curvature map (or fxx)"
msgstr "Producir mapa de curvatura de perfil (o fxx)"
-#: ../raster/r.resamp.rst/main.c:217
+#: ../raster/r.resamp.rst/main.c:213
msgid "Output tangential curvature map (or fyy)"
msgstr "Producir mapa de curvatura tangencial (o fyy)"
-#: ../raster/r.resamp.rst/main.c:225
+#: ../raster/r.resamp.rst/main.c:221
msgid "Output mean curvature map (or fxy)"
msgstr "Producir mapa de curvatura media (o fxy)"
-#: ../raster/r.resamp.rst/main.c:233
+#: ../raster/r.resamp.rst/main.c:229
msgid "Name of raster map containing smoothing"
msgstr "Nombre del mapa ráster que contiene suavizado"
-#: ../raster/r.resamp.rst/main.c:241
+#: ../raster/r.resamp.rst/main.c:237
msgid "Name of raster map to be used as mask"
msgstr "Nombre del mapa ráster a utilizar como máscara"
-#: ../raster/r.resamp.rst/main.c:249
+#: ../raster/r.resamp.rst/main.c:245
msgid "Rows/columns overlap for segmentation"
msgstr "Solapamiento de filas/columnas para segmentación"
-#: ../raster/r.resamp.rst/main.c:257
+#: ../raster/r.resamp.rst/main.c:253
msgid "Multiplier for z-values"
msgstr "Multiplicador para valores Z"
-#: ../raster/r.resamp.rst/main.c:265
+#: ../raster/r.resamp.rst/main.c:261
msgid "Spline tension value"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:272
+#: ../raster/r.resamp.rst/main.c:268
msgid "Anisotropy angle (in degrees)"
msgstr "Ángulo de anisotropía (en grados)"
-#: ../raster/r.resamp.rst/main.c:273 ../raster/r.resamp.rst/main.c:280
-#: ../vector/v.surf.rst/main.c:360 ../vector/v.surf.rst/main.c:367
+#: ../raster/r.resamp.rst/main.c:269 ../raster/r.resamp.rst/main.c:276
msgid "Anisotropy"
msgstr "Anisotropía"
-#: ../raster/r.resamp.rst/main.c:279 ../vector/v.surf.rst/main.c:366
+#: ../raster/r.resamp.rst/main.c:275 ../vector/v.surf.rst/main.c:373
msgid "Anisotropy scaling factor"
msgstr "Factor de escala de anisotropía"
-#: ../raster/r.resamp.rst/main.c:284
+#: ../raster/r.resamp.rst/main.c:280
msgid "Use dnorm independent tension"
msgstr "Usar tensión independiente de dnorm"
-#: ../raster/r.resamp.rst/main.c:289 ../vector/v.surf.rst/main.c:199
+#: ../raster/r.resamp.rst/main.c:285 ../vector/v.surf.rst/main.c:200
msgid "Output partial derivatives instead of topographic parameters"
msgstr "Producir derivadas parciales en vez de parámetros topográficos"
-#: ../raster/r.resamp.rst/main.c:296 ../general/g.setproj/main.c:107
+#: ../raster/r.resamp.rst/main.c:292 ../general/g.setproj/main.c:107
msgid "Retrieving and setting region failed"
msgstr "Fallo al recuperar y establecer la región"
-#: ../raster/r.resamp.rst/main.c:324
+#: ../raster/r.resamp.rst/main.c:320
msgid "Cannot read ew_res value"
msgstr "No se puede leer el valor ew_res (resolución EW)"
-#: ../raster/r.resamp.rst/main.c:327
+#: ../raster/r.resamp.rst/main.c:323
msgid "Cannot read ns_res value"
msgstr "No se puede leer el valor ns_res (resolución NS)"
-#: ../raster/r.resamp.rst/main.c:330
+#: ../raster/r.resamp.rst/main.c:326
msgid "Invalid value for tension"
msgstr "Valor no válido para tensión"
-#: ../raster/r.resamp.rst/main.c:333
+#: ../raster/r.resamp.rst/main.c:329
msgid "Invalid value for zmult"
msgstr "Valor no válido para zmult"
-#: ../raster/r.resamp.rst/main.c:336
+#: ../raster/r.resamp.rst/main.c:332
msgid "Invalid value for overlap"
msgstr "Valor no válido para solapamiento"
-#: ../raster/r.resamp.rst/main.c:340
+#: ../raster/r.resamp.rst/main.c:336
msgid "Invalid value for theta"
msgstr "Valor no válido para theta"
-#: ../raster/r.resamp.rst/main.c:344
+#: ../raster/r.resamp.rst/main.c:340
msgid "Invalid value for scalex"
msgstr "Valor no válido para scalex"
-#: ../raster/r.resamp.rst/main.c:346
+#: ../raster/r.resamp.rst/main.c:342
msgid "When using anisotropy both theta and scalex must be specified"
msgstr "Cuando se usa anisotropía se deben especificar tanto theta como scalex"
-#: ../raster/r.resamp.rst/main.c:369 ../vector/v.surf.rst/main.c:492
+#: ../raster/r.resamp.rst/main.c:365 ../vector/v.surf.rst/main.c:499
msgid "Not enough memory for az"
msgstr "Memoria insuficiente para az"
-#: ../raster/r.resamp.rst/main.c:374 ../vector/v.surf.rst/main.c:497
+#: ../raster/r.resamp.rst/main.c:370 ../vector/v.surf.rst/main.c:504
msgid "Not enough memory for adx"
msgstr "Memoria insuficiente para adx"
-#: ../raster/r.resamp.rst/main.c:378 ../vector/v.surf.rst/main.c:501
+#: ../raster/r.resamp.rst/main.c:374 ../vector/v.surf.rst/main.c:508
msgid "Not enough memory for ady"
msgstr "Memoria insuficiente para ady"
-#: ../raster/r.resamp.rst/main.c:383 ../vector/v.surf.rst/main.c:506
+#: ../raster/r.resamp.rst/main.c:379 ../vector/v.surf.rst/main.c:513
msgid "Not enough memory for adxx"
msgstr "Memoria insuficiente para adxx"
-#: ../raster/r.resamp.rst/main.c:387 ../vector/v.surf.rst/main.c:510
+#: ../raster/r.resamp.rst/main.c:383 ../vector/v.surf.rst/main.c:517
msgid "Not enough memory for adyy"
msgstr "Memoria insuficiente para adyy"
-#: ../raster/r.resamp.rst/main.c:391 ../vector/v.surf.rst/main.c:514
+#: ../raster/r.resamp.rst/main.c:387 ../vector/v.surf.rst/main.c:521
msgid "Not enough memory for adxy"
msgstr "Memoria insuficiente para adxy"
-#: ../raster/r.resamp.rst/main.c:411
+#: ../raster/r.resamp.rst/main.c:407
#, c-format
msgid "[%s]: Map is the wrong resolution"
msgstr "[%s]: el mapa está en la resolución incorrecta"
-#: ../raster/r.resamp.rst/main.c:419
+#: ../raster/r.resamp.rst/main.c:415
msgid "Smoothing values can not be negative or NULL"
msgstr "Los valores de suavizado no pueden ser negativos ni NULOS"
-#: ../raster/r.resamp.rst/main.c:434
+#: ../raster/r.resamp.rst/main.c:430
msgid "Input map resolution differs from current region resolution!"
msgstr ""
"¡La resolución del mapa de entrada es distinta de la de la región actual!"
-#: ../raster/r.resamp.rst/main.c:454
+#: ../raster/r.resamp.rst/main.c:450
msgid "Processing all selected output files will require"
msgstr "Procesar todos los archivos de salida requerirá"
-#: ../raster/r.resamp.rst/main.c:455
+#: ../raster/r.resamp.rst/main.c:451
#, c-format
msgid "%d bytes of disk space for temp files."
msgstr "%d bytes de espacio en disco para archivos temporales."
-#: ../raster/r.resamp.rst/main.c:480
+#: ../raster/r.resamp.rst/main.c:476
#, c-format
msgid "Cannot get row %d (error = %d)"
msgstr "No se puede obtener la fila %d (error = %d)"
-#: ../raster/r.resamp.rst/main.c:490
+#: ../raster/r.resamp.rst/main.c:486
msgid "Maximum value of a raster map is NULL."
msgstr "El valor máximo de un mapa ráster el NULO."
-#: ../raster/r.resamp.rst/main.c:518
+#: ../raster/r.resamp.rst/main.c:514
msgid "Temporarily changing the region to desired resolution ..."
msgstr "Cambiando temporalmente la región a la resolución deseada..."
-#: ../raster/r.resamp.rst/main.c:524
+#: ../raster/r.resamp.rst/main.c:520
msgid "Changing back to the original region ..."
msgstr "Volviendo a la región original..."
-#: ../raster/r.resamp.rst/main.c:526
+#: ../raster/r.resamp.rst/main.c:522
msgid "Cannot set region to back to the initial region !!!"
msgstr "¡No se puede establecer la región para volver a la región inicial!"
-#: ../raster/r.resamp.rst/main.c:530 ../raster/r.resample/main.c:137
-#: ../vector/v.surf.rst/main.c:594 ../vector/v.surf.rst/main.c:745
+#: ../raster/r.resamp.rst/main.c:526 ../raster/r.resample/main.c:137
+#: ../vector/v.surf.rst/main.c:601 ../vector/v.surf.rst/main.c:752
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:600
msgid "Percent complete: "
msgstr "Porcentaje completado: "
-#: ../raster/r.resamp.rst/main.c:542
+#: ../raster/r.resamp.rst/main.c:538
#, c-format
msgid "dnorm in mainc after grid before out1= %f"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:559
+#: ../raster/r.resamp.rst/main.c:555
#, c-format
msgid "dnorm in mainc after grid before out2= %f"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:610 ../vector/v.surf.rst/main.c:610
+#: ../raster/r.resamp.rst/main.c:606 ../vector/v.surf.rst/main.c:617
msgid "Not enough memory for zero_array_cell"
msgstr "Memoria insuficiente para zero_array_cell"
-#: ../raster/r.resamp.rst/main.c:625 ../raster/r.resamp.rst/main.c:638
-#: ../raster/r.resamp.rst/main.c:651 ../raster/r.resamp.rst/main.c:665
-#: ../raster/r.resamp.rst/main.c:678 ../raster/r.resamp.rst/main.c:691
-#: ../vector/v.surf.rst/main.c:622 ../vector/v.surf.rst/main.c:631
-#: ../vector/v.surf.rst/main.c:640 ../vector/v.surf.rst/main.c:650
-#: ../vector/v.surf.rst/main.c:659 ../vector/v.surf.rst/main.c:668
+#: ../raster/r.resamp.rst/main.c:621 ../raster/r.resamp.rst/main.c:634
+#: ../raster/r.resamp.rst/main.c:647 ../raster/r.resamp.rst/main.c:661
+#: ../raster/r.resamp.rst/main.c:674 ../raster/r.resamp.rst/main.c:687
+#: ../vector/v.surf.rst/main.c:629 ../vector/v.surf.rst/main.c:638
+#: ../vector/v.surf.rst/main.c:647 ../vector/v.surf.rst/main.c:657
+#: ../vector/v.surf.rst/main.c:666 ../vector/v.surf.rst/main.c:675
msgid "Not enough disk space -- cannot write files"
msgstr "Espacio en disco insuficiente -- no se pueden escribir archivos"
@@ -10162,6 +7811,10 @@
msgid "Generates area statistics for raster map layers."
msgstr "Genera estadísticas de superficie para capas de mapa ráster."
+#: ../raster/r.stats/main.c:116
+msgid "Name for output file (if omitted or \"-\" output to stdout)"
+msgstr "Nombre para el archivo de salida (si se omite o \"-\" salida a stdout)"
#: ../raster/r.stats/main.c:144
msgid "One cell (range) per line"
msgstr "Una celda (rango) por línea"
@@ -10335,8 +7988,8 @@
msgid "Scale to apply to z data"
msgstr ""
-#: ../raster/r.in.xyz/main.c:235 ../raster/r.cost/main.c:198
-#: ../raster/r.walk/main.c:257
+#: ../raster/r.in.xyz/main.c:235 ../raster/r.cost/main.c:210
+#: ../raster/r.walk/main.c:268
msgid "Percent of map to keep in memory"
msgstr "Porcentaje de mapa a mantener en memoria"
@@ -10686,10 +8339,38 @@
msgid "Unable to use logarithmic scaling if range includes zero"
msgstr ""
+#: ../raster/r.colors/main.c:165
+#, fuzzy
+msgid "raster, color table"
+msgstr "ráster, remuestrear"
#: ../raster/r.colors/main.c:167
msgid "Creates/modifies the color table associated with a raster map layer."
msgstr "Crea/modifica la tabla de colores asociada a una capa de mapa ráster."
+#: ../raster/r.colors/main.c:181
+msgid "Type of color table"
+msgstr "Tipo de tabla de colores"
+#: ../raster/r.colors/main.c:183 ../raster/r.colors/main.c:197
+#: ../raster/r.colors/main.c:215 ../raster/r.colors/main.c:220
+#: ../raster/r.colors/main.c:225 ../raster/r.colors/main.c:230
+#: ../vector/v.label.sa/main.c:149 ../vector/v.label.sa/main.c:159
+#: ../vector/v.label.sa/main.c:166 ../vector/v.label.sa/main.c:176
+#: ../vector/v.label.sa/main.c:186 ../vector/v.label.sa/main.c:196
+#: ../vector/v.label.sa/main.c:203 ../vector/v.label/main.c:153
+#: ../vector/v.label/main.c:177 ../vector/v.label/main.c:190
+#: ../vector/v.label/main.c:196 ../vector/v.label/main.c:206
+#: ../display/d.vect/main.c:164 ../display/d.vect/main.c:174
+#: ../display/d.vect/main.c:181 ../display/d.vect/main.c:192
+#: ../display/d.vect/main.c:344 ../display/d.vect/main.c:350
+msgid "Colors"
+msgstr "Colores"
+#: ../raster/r.colors/main.c:191
+msgid "Raster map name from which to copy color table"
+msgstr "Nombre del mapa ráster del que copiar la tabla de colores"
#: ../raster/r.colors/main.c:196
#, fuzzy
msgid "Path to rules file (\"-\" to read rules from stdin)"
@@ -10707,6 +8388,10 @@
msgid "List available rules then exit"
msgstr "Listar reglas disponibles y salir"
+#: ../raster/r.colors/main.c:214
+msgid "Invert colors"
+msgstr "Invertir colores"
#: ../raster/r.colors/main.c:219
msgid "Logarithmic scaling"
msgstr "Escalado logarítmico"
@@ -11262,11 +8947,11 @@
msgid "%s higher above pointer wrong"
msgstr "%s más alto sobre el puntero incorrecto"
-#: ../raster/r.cost/main.c:124
+#: ../raster/r.cost/main.c:128
msgid "raster, cost surface, cumulative costs"
msgstr "ráster, superficie de coste, coste acumulado"
-#: ../raster/r.cost/main.c:126
+#: ../raster/r.cost/main.c:130
#, fuzzy
msgid ""
"Creates a raster map showing the cumulative cost of moving between different "
@@ -11277,152 +8962,167 @@
"entre diferentes localizaciones geográficas en una capa de mapa ráster de "
"entrada cuyos valores de categoría de celdas representan coste."
-#: ../raster/r.cost/main.c:133
+#: ../raster/r.cost/main.c:137
msgid "Name of raster map containing grid cell cost information"
msgstr ""
"Nombre del mapa ráster que contiene información de coste de celdas de "
"cuadrícula"
-#: ../raster/r.cost/main.c:140
+#: ../raster/r.cost/main.c:147 ../raster/r.walk/main.c:214
#, fuzzy
+msgid "Name of output raster map to contain movement directions"
+msgstr "Nombre del mapa ráster de entrada que contiene costes de fricción"
+#: ../raster/r.cost/main.c:152
+#, fuzzy
msgid "Name of starting vector points map"
msgstr "Nombre del mapa vectorial de puntos de entrada"
-#: ../raster/r.cost/main.c:146
+#: ../raster/r.cost/main.c:158
#, fuzzy
msgid "Name of stop vector points map"
-#: ../raster/r.cost/main.c:147 ../raster/r.cost/main.c:171
+#: ../raster/r.cost/main.c:159 ../raster/r.cost/main.c:183
msgid "Stop"
msgstr ""
-#: ../raster/r.cost/main.c:152
+#: ../raster/r.cost/main.c:164
#, fuzzy
msgid "Name of starting raster points map"
msgstr "Nombre de un mapa ráster existente"
-#: ../raster/r.cost/main.c:161
+#: ../raster/r.cost/main.c:173
#, fuzzy
msgid "Map grid coordinates of a starting point (E,N)"
msgstr "Coordenadas de cuadrícula E y N del mapa de un punto de inicio (E,N)"
-#: ../raster/r.cost/main.c:170
+#: ../raster/r.cost/main.c:182
#, fuzzy
msgid "Map grid coordinates of a stopping point (E,N)"
msgstr "Coordenadas de cuadrícula E y N del mapa de un punto de final (E,N)"
-#: ../raster/r.cost/main.c:180
+#: ../raster/r.cost/main.c:192
#, fuzzy
msgid "Optional maximum cumulative cost"
msgstr "Un valor de coste acumulativo máximo opcional"
-#: ../raster/r.cost/main.c:189 ../raster/r.walk/main.c:249
+#: ../raster/r.cost/main.c:201 ../raster/r.walk/main.c:260
msgid "Cost assigned to null cells. By default, null cells are excluded"
msgstr ""
"Coste asignado a celdas nulas. Por defecto, las celdas nulas son excluidas"
-#: ../raster/r.cost/main.c:203 ../raster/r.walk/main.c:299
+#: ../raster/r.cost/main.c:215 ../raster/r.walk/main.c:310
msgid "Use the 'Knight's move'; slower, but more accurate"
msgstr "Usar el 'Movimiento de caballero'; más lento, pero más preciso."
-#: ../raster/r.cost/main.c:207
+#: ../raster/r.cost/main.c:219
#, fuzzy
msgid "Keep null values in output raster map"
msgstr "Conservar valores nulos en el mapa de entrada"
-#: ../raster/r.cost/main.c:211 ../raster/r.walk/main.c:307
+#: ../raster/r.cost/main.c:223 ../raster/r.walk/main.c:318
msgid "Start with values in raster map"
msgstr "Comenzar con valores en mapa ráster"
-#: ../raster/r.cost/main.c:217 ../raster/wildfire/r.ros/main.c:301
+#: ../raster/r.cost/main.c:229 ../raster/wildfire/r.ros/main.c:301
#: ../raster/wildfire/r.spreadpath/main.c:110 ../vector/v.kernel/main.c:176
#: ../display/d.vect/main.c:339
msgid "Run verbosely"
msgstr "Ejecutar con comentarios"
-#: ../raster/r.cost/main.c:238 ../raster/r.water.outlet/main.c:84
-#: ../raster/r.walk/main.c:322 ../raster/wildfire/r.spread/main.c:338
+#: ../raster/r.cost/main.c:256 ../raster/r.water.outlet/main.c:84
+#: ../raster/r.walk/main.c:339 ../raster/wildfire/r.spread/main.c:338
msgid "Unable to read current window parameters"
msgstr "No se pueden leer los parámetros de la ventana actual"
-#: ../raster/r.cost/main.c:272
+#: ../raster/r.cost/main.c:290
msgid "Must specify exactly one of start_points, start_rast or coordinate"
msgstr ""
"Se debe especificar exactamente uno de los siguientes parámetros: mapa "
"vectorial de puntos inicial (start_points), mapa ráster de puntos inicial "
"(start_rast) o coordenadas"
-#: ../raster/r.cost/main.c:277 ../raster/r.cost/main.c:529
-#: ../raster/r.cost/main.c:635
+#: ../raster/r.cost/main.c:295 ../raster/r.cost/main.c:596
+#: ../raster/r.cost/main.c:702
msgid "No start points"
msgstr "Ningún punto de inicio"
-#: ../raster/r.cost/main.c:284 ../raster/r.walk/main.c:351
+#: ../raster/r.cost/main.c:302 ../raster/r.walk/main.c:368
#, c-format
msgid "Inappropriate maximum cost: %d"
msgstr "Coste máximo inapropiado: %d"
-#: ../raster/r.cost/main.c:288 ../raster/r.walk/main.c:355
+#: ../raster/r.cost/main.c:306 ../raster/r.walk/main.c:372
#, c-format
msgid "Inappropriate percent memory: %d"
msgstr "Memoria porcentual inapropiada: %d"
-#: ../raster/r.cost/main.c:306
+#: ../raster/r.cost/main.c:324
#, fuzzy
msgid "Assigning negative cost to null cell. Null cells excluded."
msgstr "Aviso: asignando coste negativo a celda nula. Celdas nulas excluidas."
-#: ../raster/r.cost/main.c:372 ../raster/r.walk/main.c:654
+#: ../raster/r.cost/main.c:402 ../raster/r.walk/main.c:682
msgid "Creating some temporary files..."
msgstr "Creando algunos archivos temporales..."
-#: ../raster/r.cost/main.c:457
+#: ../raster/r.cost/main.c:499
#, fuzzy
msgid "Initializing output..."
msgstr "Inicializando la salida "
-#: ../raster/r.cost/main.c:546
+#: ../raster/r.cost/main.c:522 ../raster/r.walk/main.c:880
#, fuzzy
+msgid "Initializing directional output "
+msgstr "Inicializando la salida "
+#: ../raster/r.cost/main.c:613
+#, fuzzy
msgid "Failed to guess site file format\n"
msgstr "No se pudo averiguar el formato de archivo de lugares"
-#: ../raster/r.cost/main.c:650 ../raster/r.walk/main.c:914
+#: ../raster/r.cost/main.c:717 ../raster/r.walk/main.c:982
msgid "Specified starting location outside database window"
msgstr ""
"La localización de inicio especificada está fuera de la ventana de la base "
"de datos"
-#: ../raster/r.cost/main.c:666
+#: ../raster/r.cost/main.c:733
#, fuzzy
msgid "Finding cost path..."
msgstr "Encontrando ruta de coste"
-#: ../raster/r.cost/main.c:891
+#: ../raster/r.cost/main.c:999
#, fuzzy
msgid "No data"
msgstr "Ninguna tabla"
-#: ../raster/r.cost/main.c:895 ../raster/r.walk/main.c:1382
+#: ../raster/r.cost/main.c:1003 ../raster/r.walk/main.c:1483
msgid "Error, ct == pres_cell"
msgstr "Error, ct == pres_cell"
-#: ../raster/r.cost/main.c:1036
+#: ../raster/r.cost/main.c:1133 ../raster/r.walk/main.c:1621
#, fuzzy, c-format
+msgid "Writing movement direction file %s..."
+msgstr "Escribiendo vértices..."
+#: ../raster/r.cost/main.c:1186
+#, fuzzy, c-format
msgid "Peak cost value: %f."
msgstr "Valor de coste pico: %f"
-#: ../raster/r.cost/main.c:1058 ../raster/r.walk/main.c:1564
+#: ../raster/r.cost/main.c:1208 ../raster/r.walk/main.c:1706
#, c-format
msgid "Illegal x coordinate <%s>"
msgstr "Coordenada X no admitida <%s>"
-#: ../raster/r.cost/main.c:1060 ../raster/r.walk/main.c:1566
+#: ../raster/r.cost/main.c:1210 ../raster/r.walk/main.c:1708
#, c-format
msgid "Illegal y coordinate <%s>"
msgstr "Coordenada Y no admitida <%s>"
-#: ../raster/r.cost/main.c:1064 ../raster/r.walk/main.c:1570
+#: ../raster/r.cost/main.c:1214 ../raster/r.walk/main.c:1712
#, c-format
msgid "Warning, ignoring point outside window: %.4f,%.4f"
msgstr "Aviso, se ignoran los puntos fuera de la ventana: %.4f,%.4f"
@@ -12100,7 +9800,7 @@
msgid "Reading map"
msgstr "Leyendo mapa"
-#: ../raster/r.neighbors/main.c:108
+#: ../raster/r.neighbors/main.c:109
msgid ""
"Makes each cell category value a function of the category values assigned to "
"the cells around it, and stores new cell values in an output raster map "
@@ -12110,60 +9810,75 @@
"categoría asignados a las celdas a su alrededor y guarda los nuevos valores "
"de celda en una capa de mapa ráster de salida."
-#: ../raster/r.neighbors/main.c:131
+#: ../raster/r.neighbors/main.c:132
msgid "Neighborhood operation"
msgstr "Operación de vecindad"
-#: ../raster/r.neighbors/main.c:132 ../raster/r.neighbors/main.c:140
-#: ../raster/r.neighbors/main.c:168
+#: ../raster/r.neighbors/main.c:133 ../raster/r.neighbors/main.c:141
+#: ../raster/r.neighbors/main.c:175
#, fuzzy
msgid "Neighborhood"
msgstr "Tamaño de vecindad"
-#: ../raster/r.neighbors/main.c:138
+#: ../raster/r.neighbors/main.c:139
msgid "Neighborhood size"
-#: ../raster/r.neighbors/main.c:147
+#: ../raster/r.neighbors/main.c:148
msgid "Title of the output raster map"
msgstr "Título del mapa ráster de salida"
-#: ../raster/r.neighbors/main.c:154
+#: ../raster/r.neighbors/main.c:155
msgid "File containing weights"
msgstr "Archivo que contiene pesos"
-#: ../raster/r.neighbors/main.c:158
+#: ../raster/r.neighbors/main.c:161
+#, fuzzy
+msgid "Sigma (in cells) for Gaussian filter"
+msgstr "Sensibilidad del filtro de Gauss"
+#: ../raster/r.neighbors/main.c:165
msgid "Do not align output with the input"
msgstr "No alinear la salida con la entrada"
-#: ../raster/r.neighbors/main.c:167
+#: ../raster/r.neighbors/main.c:174
msgid "Use circular neighborhood"
msgstr "Usar vecindario circular"
-#: ../raster/r.neighbors/main.c:175
+#: ../raster/r.neighbors/main.c:182
msgid "Neighborhood size must be positive"
msgstr "El tamaño del vecindario debe ser positivo"
-#: ../raster/r.neighbors/main.c:177
+#: ../raster/r.neighbors/main.c:184
msgid "Neighborhood size must be odd"
msgstr "El tamaño del vecindario debe ser impar"
-#: ../raster/r.neighbors/main.c:181
+#: ../raster/r.neighbors/main.c:188
msgid "weight= and -c are mutually exclusive"
msgstr "weight= y -c son excluyentes mutuamente"
-#: ../raster/r.neighbors/main.c:206 ../raster/r.series/main.c:198
+#: ../raster/r.neighbors/main.c:200
+#, fuzzy
+msgid "weight= and gauss= are mutually exclusive"
+msgstr "weight= y -c son excluyentes mutuamente"
+#: ../raster/r.neighbors/main.c:215 ../raster/r.series/main.c:198
#: ../ps/ps.map/outl_io.c:72
#, c-format
msgid "Unable to open raster map <%s> in mapset <%s>"
msgstr "No se puede abrir el mapa ráster <%s> en el directorio de mapas <%s>"
-#: ../raster/r.neighbors/readweights.c:17
+#: ../raster/r.neighbors/main.c:254
+#, fuzzy, c-format
+msgid "Method %s not compatible with Gaussian filter"
+msgstr "Extensión X-Y del filtro de Gauss"
+#: ../raster/r.neighbors/readweights.c:18
#, c-format
msgid "Unable to open weights file %s"
msgstr "No se puede abrir el archivo de pesos <%s>"
-#: ../raster/r.neighbors/readweights.c:22
+#: ../raster/r.neighbors/readweights.c:23
#, c-format
msgid "Error reading weights file %s"
msgstr "Error al leer el archivo de pesos %s"
@@ -12235,6 +9950,10 @@
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
msgstr "Importa archivo de mapa GRIDTB.FOR (TOPMODEL) a mapa ráster de GRASS"
+#: ../raster/r.in.gridatb/main.c:53 ../imagery/i.ifft/ifftmain.c:83
+msgid "Name for output raster map"
+msgstr "Nombre para el mapa ráster de salida"
#: ../raster/r.in.gridatb/main.c:67
#, c-format
msgid "File not found: %s"
@@ -12304,6 +10023,10 @@
msgid "Converts a raster map into a vector map layer."
msgstr "Convierte un mapa ráster en una capa de mapa vectorial."
+#: ../raster/r.to.vect/main.c:64 ../vector/v.to.db/parse.c:36
+msgid "Feature type"
+msgstr "Tipo de elemento"
#: ../raster/r.to.vect/main.c:68
msgid "Smooth corners of area features"
msgstr "Suavizar esquinas de objetos espaciales de áreas"
@@ -12343,7 +10066,7 @@
"El ráster no es CELL, se ignora la opción '-v', los valores ráster se "
"escribirán en la tabla."
-#: ../raster/r.to.vect/main.c:192 ../vector/v.in.dxf/write_vect.c:207
+#: ../raster/r.to.vect/main.c:192 ../vector/v.in.dxf/write_vect.c:218
#: ../vector/lidar/lidarlib/raster.c:84 ../vector/lidar/lidarlib/raster.c:100
#: ../vector/lidar/lidarlib/raster.c:114 ../vector/lidar/lidarlib/raster.c:132
#: ../vector/lidar/lidarlib/raster.c:148 ../vector/lidar/lidarlib/raster.c:162
@@ -12361,7 +10084,7 @@
msgstr "No se puede crear el índice"
#: ../raster/r.to.vect/main.c:201 ../raster/r.contour/main.c:206
-#: ../vector/v.in.dxf/write_vect.c:212 ../vector/v.distance/main.c:823
+#: ../vector/v.in.dxf/write_vect.c:223 ../vector/v.distance/main.c:823
#: ../vector/v.reclass/main.c:228 ../vector/v.in.ascii/in.c:395
#: ../vector/v.to.points/main.c:306 ../vector/v.sample/main.c:223
#: ../vector/v.in.ogr/main.c:773 ../vector/v.in.sites/main.c:179
@@ -12704,11 +10427,22 @@
msgid "Writing raster map, row %d"
msgstr "Escribiendo mapa, fila %d"
+#: ../raster/r.univar2/r.univar_main.c:40
+#: ../raster/r.univar2/r3.univar_main.c:39 ../vector/v.univar/main.c:92
+msgid "Percentile to calculate (requires extended statistics flag)"
+msgstr "Percentil a calcular (requiere la opción de estadísticas ampliadas)"
#: ../raster/r.univar2/r.univar_main.c:45
#: ../raster/r.univar2/r3.univar_main.c:44 ../vector/v.univar/main.c:96
+#: ../vector/v.what/main.c:89
msgid "Print the stats in shell script style"
msgstr "Imprimir las estadísticas en estilo de script de consola"
+#: ../raster/r.univar2/r.univar_main.c:49
+#: ../raster/r.univar2/r3.univar_main.c:48 ../vector/v.univar/main.c:100
+msgid "Calculate extended statistics"
+msgstr "Calcular estadísticas ampliadas"
#: ../raster/r.univar2/r.univar_main.c:77
msgid ""
"Calculates univariate statistics from the non-null cells of a raster map."
@@ -12734,37 +10468,36 @@
"Calcula estadísticas univariantes a partir de celdas no nulas de un mapa "
"ráster 3D."
-#: ../raster/r.watershed/ram/init_vars.c:84
+#: ../raster/r.watershed/ram/init_vars.c:103
#, c-format
msgid "SECTION 1a (of %1d): Initiating Memory."
msgstr "SECCIÓN 1a (de %1d): iniciando memoria."
-#: ../raster/r.watershed/ram/init_vars.c:139
+#: ../raster/r.watershed/ram/init_vars.c:144
+#: ../raster/r.watershed/seg/init_vars.c:191
msgid "unable to open elevation map layer"
msgstr "no se puede abrir capa de mapa de elevación"
-#: ../raster/r.watershed/ram/init_vars.c:165
+#: ../raster/r.watershed/ram/init_vars.c:212
msgid "unable to open runoff map layer"
msgstr "No se puede abrir la capa del mapa runoff"
-#: ../raster/r.watershed/ram/init_vars.c:187
+#: ../raster/r.watershed/ram/init_vars.c:251
+#: ../raster/r.watershed/seg/init_vars.c:278
msgid "unable to open depression map layer"
msgstr "no se puede abrir la capa del mapa de depresión"
-#: ../raster/r.watershed/ram/init_vars.c:201
+#: ../raster/r.watershed/ram/init_vars.c:268
+#: ../raster/r.watershed/seg/init_vars.c:307
msgid "unable to open blocking map layer"
msgstr "no se puede abrir la capa del mapa de bloqueo"
-#: ../raster/r.watershed/ram/init_vars.c:215
+#: ../raster/r.watershed/ram/init_vars.c:285
msgid "unable to open rill map layer"
msgstr "No se puede abrir la capa del mapa rill"
-#: ../raster/r.watershed/ram/init_vars.c:224
-msgid "unable to open MASK"
-msgstr "no se puede abrir MÁSCARA"
-#: ../raster/r.watershed/ram/init_vars.c:261
-#: ../raster/r.watershed/seg/init_vars.c:258
+#: ../raster/r.watershed/ram/init_vars.c:313
+#: ../raster/r.watershed/seg/init_vars.c:356
#, fuzzy, c-format
msgid "SECTION 1b (of %1d): Determining Offmap Flow."
msgstr "SECCIÓN 1b (de %1d): determinando flujo Offmap."
@@ -12792,63 +10525,87 @@
"USO para delineación de cuenca:\n"
"%s -4 el= mostrar mostrar nombre mostrar máximo"
-#: ../raster/r.watershed/ram/do_cum.c:12 ../raster/r.watershed/seg/do_cum.c:14
-msgid "SECTION 3: Accumulating Surface Flow."
+#: ../raster/r.watershed/ram/do_cum.c:14 ../raster/r.watershed/seg/do_cum.c:17
+#, fuzzy
+msgid "SECTION 3: Accumulating Surface Flow with SFD."
msgstr "SECCIÓN 3: acumulando flujo de superficie."
-#: ../raster/r.watershed/ram/sg_factor.c:12
+#: ../raster/r.watershed/ram/do_cum.c:116
+#: ../raster/r.watershed/seg/do_cum.c:121
+#, fuzzy
+msgid "SECTION 3: Accumulating Surface Flow with MFD."
+msgstr "SECCIÓN 3: acumulando flujo de superficie."
+#: ../raster/r.watershed/ram/do_cum.c:303
+#: ../raster/r.watershed/seg/do_cum.c:320
+#, c-format
+msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:360
+#: ../raster/r.watershed/seg/do_cum.c:380
+#, c-format
+msgid "MFD: A * path already processed when distributing flow: %d of %d cells"
+msgstr ""
+#: ../raster/r.watershed/ram/sg_factor.c:13
#: ../raster/r.watershed/seg/sg_factor.c:12
-msgid "SECTION 4: Length Slope determination."
+#, fuzzy
+msgid "SECTION 4: RUSLE LS and/or S factor determination."
msgstr "SECCIÓN 4: determinación de la pendiente de la longitud."
-#: ../raster/r.watershed/ram/main.c:36 ../raster/r.watershed/ram/main.c:52
-#: ../raster/r.watershed/seg/main.c:43 ../raster/r.watershed/seg/main.c:54
+#: ../raster/r.watershed/ram/main.c:79 ../raster/r.watershed/ram/main.c:95
+#: ../raster/r.watershed/seg/main.c:84 ../raster/r.watershed/seg/main.c:95
#, c-format
msgid "SECTION %d: Closing Maps."
msgstr "SECCIÓN %d: cerrando mapas."
-#: ../raster/r.watershed/ram/main.c:50 ../raster/r.watershed/seg/main.c:52
+#: ../raster/r.watershed/ram/main.c:93 ../raster/r.watershed/seg/main.c:93
#, c-format
msgid "SECTION %d: Watershed determination."
msgstr "SECCIÓN %d: determinación de cuenca hidrográfica."
-#: ../raster/r.watershed/ram/close_maps.c:22
-#: ../raster/r.watershed/ram/close_maps.c:60
+#: ../raster/r.watershed/ram/close_maps.c:30
+#: ../raster/r.watershed/ram/close_maps.c:165
+#: ../raster/r.watershed/seg/close_maps.c:28
msgid "unable to open new accum map layer."
msgstr "no se puede abrir nueva capa de mapa de acumulación."
-#: ../raster/r.watershed/ram/close_maps.c:32
-#: ../raster/r.watershed/ram/close_maps.c:49
-#: ../raster/r.watershed/ram/close_maps.c:81
-#: ../raster/r.watershed/ram/close_maps.c:106
-#: ../raster/r.watershed/ram/close_maps.c:126
-#: ../raster/r.watershed/ram/close_maps.c:146
+#: ../raster/r.watershed/ram/close_maps.c:66
+#: ../raster/r.watershed/ram/close_maps.c:153
+#: ../raster/r.watershed/ram/close_maps.c:186
+#: ../raster/r.watershed/ram/close_maps.c:211
+#: ../raster/r.watershed/ram/close_maps.c:231
+#: ../raster/r.watershed/ram/close_maps.c:251
+#: ../raster/r.watershed/seg/close_maps.c:44
msgid "Close failed."
msgstr "Fallo al cerrar."
-#: ../raster/r.watershed/ram/close_maps.c:39
+#: ../raster/r.watershed/ram/close_maps.c:142
msgid "unable to open new aspect map layer."
msgstr "no se puede abrir nueva capa de mapa de orientación."
-#: ../raster/r.watershed/ram/close_maps.c:96
-msgid "unable to open new L map layer."
+#: ../raster/r.watershed/ram/close_maps.c:201
+#, fuzzy
+msgid "unable to open new LS factor map layer."
msgstr "no se puede abrir nueva capa de mapa L."
-#: ../raster/r.watershed/ram/close_maps.c:114
+#: ../raster/r.watershed/ram/close_maps.c:219
msgid "unable to open new slope length map layer."
msgstr "no se puede abrir nueva capa de mapa de longitud de pendiente."
-#: ../raster/r.watershed/ram/close_maps.c:136
-msgid "unable to open new S map layer."
+#: ../raster/r.watershed/ram/close_maps.c:241
+#, fuzzy
+msgid "unable to open new S factor map layer."
msgstr "no se puede abrir nueva capa de mapa S."
-#: ../raster/r.watershed/ram/do_astar.c:18
-#: ../raster/r.watershed/seg/do_astar.c:21
+#: ../raster/r.watershed/ram/do_astar.c:16
+#: ../raster/r.watershed/seg/do_astar.c:20
msgid "SECTION 2: A * Search."
msgstr "SECCIÓN 2: A * Buscar."
-#: ../raster/r.watershed/ram/do_astar.c:117
-#: ../raster/r.watershed/seg/do_astar.c:117
+#: ../raster/r.watershed/ram/do_astar.c:118
+#: ../raster/r.watershed/seg/do_astar.c:121
msgid "heapsize too large"
msgstr ""
@@ -13450,117 +11207,160 @@
"OK, %s debería empezar a ejecutarse ahora usando el siguiente formulario:\n"
"%s"
-#: ../raster/r.watershed/front/main.c:53
+#: ../raster/r.watershed/front/main.c:57
msgid "Watershed basin analysis program."
msgstr "Programa de análisis de cuenca hidrográfica."
-#: ../raster/r.watershed/front/main.c:57
+#: ../raster/r.watershed/front/main.c:61
msgid "Input map: elevation on which entire analysis is based"
msgstr "Mapa de entrada: elevación en la que se basa todo el análisis"
-#: ../raster/r.watershed/front/main.c:62
+#: ../raster/r.watershed/front/main.c:66
msgid "Input map: locations of real depressions"
msgstr "Mapa de entrada: localizaciones de depresiones reales"
-#: ../raster/r.watershed/front/main.c:70
+#: ../raster/r.watershed/front/main.c:67
+msgid "All non-NULL and non-zero cells are considered as real depressions"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:75
msgid "Input map: amount of overland flow per cell"
msgstr "Mapa de entrada: cantidad de flujo superficial por celda"
-#: ../raster/r.watershed/front/main.c:79
+#: ../raster/r.watershed/front/main.c:84
msgid "Input map or value: percent of disturbed land, for USLE"
msgstr "Mapa o valor de entrada: porcentaje de terreno perturbado, para USLE"
-#: ../raster/r.watershed/front/main.c:88
+#: ../raster/r.watershed/front/main.c:93
#, fuzzy
msgid "Input map: terrain blocking overland surface flow, for USLE"
msgstr "Mapa de entrada: flujo de superficie "
-#: ../raster/r.watershed/front/main.c:97
+#: ../raster/r.watershed/front/main.c:95
+msgid "All non-NULL and non-zero cells are considered as blocking terrain"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:104
msgid "Input value: minimum size of exterior watershed basin"
msgstr "Valor de entrada: tamaño mínimo de la cuenca hidrográfica exterior"
-#: ../raster/r.watershed/front/main.c:106
-msgid "Input value: maximum length of surface flow, for USLE"
+#: ../raster/r.watershed/front/main.c:112
+#, fuzzy
+msgid "Input value: maximum length of surface flow in map units, for USLE"
msgstr "Valor de entrada: longitud máxima de flujo de superficie, para USLE"
-#: ../raster/r.watershed/front/main.c:115
+#: ../raster/r.watershed/front/main.c:120
msgid "Output map: number of cells that drain through each cell"
msgstr "Mapa de salida: número de celdas que drenan a través de cada celda"
-#: ../raster/r.watershed/front/main.c:123
+#: ../raster/r.watershed/front/main.c:128
msgid "Output map: drainage direction"
msgstr "Mapa de salida: dirección de drenaje"
-#: ../raster/r.watershed/front/main.c:132
+#: ../raster/r.watershed/front/main.c:137
msgid "Output map: unique label for each watershed basin"
msgstr "Mapa de salida: etiqueta única para cada cuenca hidrográfica"
-#: ../raster/r.watershed/front/main.c:140
+#: ../raster/r.watershed/front/main.c:145
msgid "Output map: stream segments"
msgstr "Mapa de salida: segmentos de corriente"
-#: ../raster/r.watershed/front/main.c:149
+#: ../raster/r.watershed/front/main.c:154
msgid "Output map: each half-basin is given a unique value"
msgstr "Mapa de salida: se da un valor único a cada semicuenca"
-#: ../raster/r.watershed/front/main.c:158
-msgid "Output map: useful for visual display of results"
+#: ../raster/r.watershed/front/main.c:163
+#, fuzzy
+msgid "Output map: useful for visual display of results. DEPRECATED."
msgstr "Mapa de salida: útil para visualizar los resultados"
-#: ../raster/r.watershed/front/main.c:167
+#: ../raster/r.watershed/front/main.c:172
msgid "Output map: slope length and steepness (LS) factor for USLE"
msgstr ""
"Mapa de salida: factor de longitud e inclinación de la pendiente (LS) para "
"USLE"
-#: ../raster/r.watershed/front/main.c:175
+#: ../raster/r.watershed/front/main.c:180
msgid "Output map: slope steepness (S) factor for USLE"
msgstr "Mapa de salida: factor de inclinación de la pendiente (S) para USLE"
-#: ../raster/r.watershed/front/main.c:186
+#: ../raster/r.watershed/front/main.c:191
+#, fuzzy
+msgid "Convergence factor for MFD (1-10)"
+msgstr "Factor de conversión para valores Z"
+#: ../raster/r.watershed/front/main.c:193
+msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:200
msgid "Maximum memory to be used with -m flag (in MB)"
msgstr ""
-#: ../raster/r.watershed/front/main.c:191
+#: ../raster/r.watershed/front/main.c:204
+msgid "enable MFD flow (default is SFD (D8))"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:206
+msgid "SFD: single flow direction, MFD: multiple flow direction"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:211
msgid "Allow only horizontal and vertical flow of water"
msgstr "Permitir sólo flujo de agua horizontal y vertical"
-#: ../raster/r.watershed/front/main.c:196
+#: ../raster/r.watershed/front/main.c:216
msgid "Enable disk swap memory option: Operation is slow"
msgstr "Activar opción de swapping de memoria a disco: funcionamiento lento"
-#: ../raster/r.watershed/front/main.c:213
+#: ../raster/r.watershed/front/main.c:218
+msgid ""
+"Only needed if memory requirements exceed available RAM; see manual on how "
+"to calculate memory requirements"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:223
+msgid "Use positive flow accumulation even for likely underestimates"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:225
+msgid "See manual for a detailed description of flow accumulation output"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:242
msgid "Sorry, you must choose an output map."
msgstr "Lo siento, debe elegir un mapa de salida."
-#: ../raster/r.watershed/front/main.c:227
+#: ../raster/r.watershed/front/main.c:258
+#, fuzzy
msgid ""
"Sorry, if any of the following options are set:\n"
-" basin, stream, half.basin, slope, or lS\n"
+" basin, stream, half.basin, length.slope, or slope.steepness\n"
" you MUST provide a value for the basin threshold parameter."
msgstr ""
"Lo siento, si alguna de las siguientes opciones es establecida:\n"
" cuenca, corriente, semicuenca, pendiente o IS\n"
" DEBE proporcionar un valor para el parámetro de umbral de cuenca."
-#: ../raster/r.watershed/front/main.c:360
+#: ../raster/r.watershed/front/main.c:401
#, c-format
msgid "Subprocess failed with exit code %d"
msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:95
+#: ../raster/r.watershed/seg/init_vars.c:114
#, c-format
msgid "SECTION 1 beginning: Initiating Variables. %d sections total."
msgstr "Comenzando SECCIÓN 1: iniciando variables. %d secciones totales."
-#: ../raster/r.watershed/seg/init_vars.c:148
+#: ../raster/r.watershed/seg/init_vars.c:150
msgid ""
"Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:226
-msgid "Unable to open MASK"
-msgstr "No se puede abrir MÁSCARA"
+#: ../raster/r.watershed/seg/close_maps.c:52
+#, fuzzy
+msgid "unable to open flow accumulation map layer"
+msgstr "no se puede abrir nueva capa de mapa de acumulación."
#: ../raster/r.in.poly/poly2rast.c:36
#, c-format
@@ -13731,12 +11531,12 @@
#: ../vector/v.to.points/main.c:295 ../vector/v.in.ogr/main.c:762
#: ../vector/v.convert/att.c:80 ../vector/v.overlay/main.c:456
#: ../vector/v.net.path/path.c:109 ../vector/v.in.dwg/main.c:219
-#: ../vector/v.surf.rst/main.c:585
+#: ../vector/v.surf.rst/main.c:592
#, c-format
msgid "Unable to create table: '%s'"
msgstr "No se puede crear la tabla: '%s'"
-#: ../raster/r.contour/main.c:201 ../vector/v.in.dxf/write_vect.c:214
+#: ../raster/r.contour/main.c:201 ../vector/v.in.dxf/write_vect.c:225
#: ../vector/v.reclass/main.c:223 ../vector/v.in.ascii/in.c:505
#: ../vector/v.to.points/main.c:300 ../vector/v.in.ogr/main.c:767
#: ../vector/v.in.sites/main.c:174 ../vector/v.convert/att.c:85
@@ -13933,7 +11733,7 @@
msgid "Watershed basin creation program."
msgstr "Programa de creación de cuenca hidrográfica."
-#: ../raster/r.water.outlet/main.c:61 ../raster/r.walk/main.c:203
+#: ../raster/r.water.outlet/main.c:61 ../raster/r.walk/main.c:206
msgid "Name of raster map to contain results"
msgstr "Nombre del mapa ráster que contendrá los resultados"
@@ -14069,6 +11869,10 @@
msgid "Raster file(s) for View%d"
msgstr "Archivo(s) ráster para la vista%d"
+#: ../raster/r.out.mpeg/main.c:406
+msgid "Name for output file"
+msgstr "Nombre para el archivo de salida"
#: ../raster/r.out.mpeg/main.c:416
msgid "Quality factor (1 = highest quality, lowest compression)"
msgstr "Factor de calidad (1 = calidad más alta, baja compresión)"
@@ -14097,7 +11901,7 @@
msgid "Unable to create temporary files."
msgstr "No se pueden crear archivos temporales."
-#: ../raster/r.walk/main.c:176
+#: ../raster/r.walk/main.c:179
msgid ""
"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
"between different geographic locations on an input elevation raster map "
@@ -14110,219 +11914,219 @@
"representan elevación combinada con una capa de mapa ráster de entrada cuyos "
"valores de celda representan coste de fricción."
-#: ../raster/r.walk/main.c:188
+#: ../raster/r.walk/main.c:191
msgid "Name of elevation input raster map"
msgstr "Nombre del mapa ráster de elevación de entrada"
-#: ../raster/r.walk/main.c:196
+#: ../raster/r.walk/main.c:199
msgid "Name of input raster map containing friction costs"
-#: ../raster/r.walk/main.c:210
+#: ../raster/r.walk/main.c:221
msgid "Starting points vector map"
msgstr "Mapa vectorial de puntos inicial"
-#: ../raster/r.walk/main.c:217
+#: ../raster/r.walk/main.c:228
msgid "Stop points vector map"
msgstr "Mapa vectorial de puntos final"
-#: ../raster/r.walk/main.c:225
+#: ../raster/r.walk/main.c:236
msgid "The map E and N grid coordinates of a starting point (E,N)"
-#: ../raster/r.walk/main.c:233
+#: ../raster/r.walk/main.c:244
msgid "The map E and N grid coordinates of a stopping point (E,N)"
-#: ../raster/r.walk/main.c:241
+#: ../raster/r.walk/main.c:252
msgid "An optional maximum cumulative cost"
-#: ../raster/r.walk/main.c:266
+#: ../raster/r.walk/main.c:277
msgid "Number of the segment to create (segment library)"
msgstr "Número del segmento a crear (biblioteca de segmento)"
-#: ../raster/r.walk/main.c:276
+#: ../raster/r.walk/main.c:287
msgid "Coefficients for walking energy formula parameters a,b,c,d"
msgstr ""
"Coeficientes para los parámetros a,b,c,d de la fórmula de energía de "
"desplazamiento"
-#: ../raster/r.walk/main.c:285
+#: ../raster/r.walk/main.c:296
msgid "Lambda coefficients for combining walking energy and friction cost"
msgstr ""
"Coeficientes lambda para combinar energía de desplazamiento y coste de "
"fricción"
-#: ../raster/r.walk/main.c:294
+#: ../raster/r.walk/main.c:305
msgid "Slope factor determines travel energy cost per height step"
msgstr ""
"El factor de pendiente determina el coste energético del viaje por paso de "
"altura"
-#: ../raster/r.walk/main.c:303
+#: ../raster/r.walk/main.c:314
msgid "Keep null values in output map"
-#: ../raster/r.walk/main.c:360
+#: ../raster/r.walk/main.c:377
#, c-format
msgid "Missing required value: got %d instead of 4"
msgstr "Falta un valor requerido: se obtuvo %d en vez de 4"
-#: ../raster/r.walk/main.c:364
+#: ../raster/r.walk/main.c:381
#, c-format
msgid "Walking costs are a=%lf b=%lf c=%lf d=%lf"
msgstr "Los costes de desplazamiento son a=%lf b=%lf c=%lf d=%lf"
-#: ../raster/r.walk/main.c:369 ../raster/r.walk/main.c:377
-#: ../raster/r.walk/main.c:384
+#: ../raster/r.walk/main.c:386 ../raster/r.walk/main.c:394
+#: ../raster/r.walk/main.c:401
#, c-format
msgid "Missing required value: %d"
msgstr "Falta un valore requerido: %d"
-#: ../raster/r.walk/main.c:372
+#: ../raster/r.walk/main.c:389
#, c-format
msgid "Lambda is %lf"
msgstr "Lambda es %lf"
-#: ../raster/r.walk/main.c:380
+#: ../raster/r.walk/main.c:397
#, c-format
msgid "Slope_factor is %lf"
msgstr "Factor de pendiente es %If"
-#: ../raster/r.walk/main.c:387
+#: ../raster/r.walk/main.c:404
#, c-format
msgid "Nseg is %d"
msgstr "Nseg es %d"
-#: ../raster/r.walk/main.c:393
+#: ../raster/r.walk/main.c:410
msgid "Null cells excluded from cost evaluation."
msgstr "Celdas nulas excluidas de la evaluación de costes."
-#: ../raster/r.walk/main.c:397
+#: ../raster/r.walk/main.c:414
msgid "Input null cell will be retained into output map"
msgstr "Las celdas nulas de entrada se retendrán en el mapa de salida"
-#: ../raster/r.walk/main.c:409
+#: ../raster/r.walk/main.c:426
#, c-format
msgid "Unable to find starting vector <%s> "
msgstr "No se puede encontrar el vector de inicio <%s> "
-#: ../raster/r.walk/main.c:456
+#: ../raster/r.walk/main.c:473
#, c-format
msgid "Unable to find stop vector <%s>"
msgstr "No se puede encontrar el vector de fin <%s>"
-#: ../raster/r.walk/main.c:495
+#: ../raster/r.walk/main.c:512
msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-#: ../raster/r.walk/main.c:556 ../raster/r.walk/main.c:558
+#: ../raster/r.walk/main.c:584 ../raster/r.walk/main.c:586
#, c-format
msgid "Unable to read %s"
msgstr "No se puede leer %s"
-#: ../raster/r.walk/main.c:563
+#: ../raster/r.walk/main.c:591
msgid "Map with different projection"
msgstr "Mapa con diferente proyección"
-#: ../raster/r.walk/main.c:575
+#: ../raster/r.walk/main.c:603
msgid "DTM_Source map is: Integer cell type"
msgstr "Mapa DTM_Origen es: tipo de celda entero"
-#: ../raster/r.walk/main.c:578
+#: ../raster/r.walk/main.c:606
msgid "DTM_Source map is: Floating point (float) cell type"
msgstr "Mapa DTM_Origen es: tipo de celda coma flotante (flotante)"
-#: ../raster/r.walk/main.c:581
+#: ../raster/r.walk/main.c:609
msgid "DTM_Source map is: Floating point (double) cell type"
msgstr "Mapa DTM_Origen es: tipo de celda coma flotante (doble)"
-#: ../raster/r.walk/main.c:584 ../raster/r.walk/main.c:599
-#: ../raster/r.walk/main.c:636
+#: ../raster/r.walk/main.c:612 ../raster/r.walk/main.c:627
+#: ../raster/r.walk/main.c:664
#, c-format
msgid " %d rows, %d cols"
msgstr " %d filas, %d columnas"
-#: ../raster/r.walk/main.c:590
+#: ../raster/r.walk/main.c:618
msgid "COST_Source map is: Integer cell type"
msgstr "Mapa COST_Origen es: tipo de celda entero"
-#: ../raster/r.walk/main.c:593
+#: ../raster/r.walk/main.c:621
msgid "COST_Source map is: Floating point (float) cell type"
msgstr "Mapa COST_Origen es: tipo de celda coma flotante (flotante)"
-#: ../raster/r.walk/main.c:596
+#: ../raster/r.walk/main.c:624
msgid "COST_Source map is: Floating point (double) cell type"
msgstr "Mapa COST_Origen es: tipo de celda coma flotante (doble)"
-#: ../raster/r.walk/main.c:627
+#: ../raster/r.walk/main.c:655
msgid "Output map is: Integer cell type"
msgstr "El mapa de salida es: tipo de celda entero"
-#: ../raster/r.walk/main.c:630
+#: ../raster/r.walk/main.c:658
msgid "Output map is: Floating point (float) cell type"
msgstr "El mapa de salida es: tipo de celda de coma flotante"
-#: ../raster/r.walk/main.c:633
+#: ../raster/r.walk/main.c:661
msgid "Output map is: Floating point (double) cell type"
msgstr "El mapa de salida es: tipo de celda de coma flotante (doble)"
-#: ../raster/r.walk/main.c:638
+#: ../raster/r.walk/main.c:666
#, c-format
msgid " EW resolution %s (%lf)"
msgstr " Resolución EW %s (%lf)"
-#: ../raster/r.walk/main.c:640
+#: ../raster/r.walk/main.c:668
#, c-format
msgid " NS resolution %s (%lf)"
msgstr " Resolución NS %s (%lf)"
-#: ../raster/r.walk/main.c:812
+#: ../raster/r.walk/main.c:852
msgid "Initializing output "
-#: ../raster/r.walk/main.c:820
+#: ../raster/r.walk/main.c:860 ../raster/r.walk/main.c:889
msgid "Unable to allocate memory for segment fbuff == NULL"
msgstr "No se puede asigna memoria para el segmento fbuff == NULO"
-#: ../raster/r.walk/main.c:849
+#: ../raster/r.walk/main.c:917
#, c-format
msgid "Raster output map <%s> not found (no start_points given)"
msgstr ""
"No se encuentra el mapa ráster de salida <%s> (no se indican puntos de "
"inicio)"
-#: ../raster/r.walk/main.c:864
+#: ../raster/r.walk/main.c:932
#, c-format
msgid "Memory allocation error on reading start points from raster map %s"
msgstr ""
"Error de asignación de memoria al leer los puntos de inicio del mapa ráster %"
"s"
-#: ../raster/r.walk/main.c:867
+#: ../raster/r.walk/main.c:935
#, c-format
msgid "Reading %s... "
msgstr "Leyendo %s... "
-#: ../raster/r.walk/main.c:931
+#: ../raster/r.walk/main.c:999
msgid "Finding cost path"
-#: ../raster/r.walk/main.c:1378
+#: ../raster/r.walk/main.c:1479
msgid "End of map!"
msgstr "¡Final del mapa!"
-#: ../raster/r.walk/main.c:1396
+#: ../raster/r.walk/main.c:1505
#, c-format
msgid "Writing output raster map %s... "
msgstr "Escribiendo mapa ráster de salida %s... "
-#: ../raster/r.walk/main.c:1400
+#: ../raster/r.walk/main.c:1509
msgid "Will copy input map null values into output map"
msgstr "Copiará los valores nulos del mapa de entrada en el mapa de salida"
-#: ../raster/r.walk/main.c:1407
+#: ../raster/r.walk/main.c:1516
msgid ""
"Integer cell type.\n"
"Writing..."
@@ -14330,7 +12134,7 @@
"Tipo de celda entero.\n"
"Escribiendo..."
-#: ../raster/r.walk/main.c:1442
+#: ../raster/r.walk/main.c:1551
msgid ""
"Float cell type.\n"
"Writing..."
@@ -14338,7 +12142,7 @@
"Tipo de celda flotante.\n"
"Escribiendo..."
-#: ../raster/r.walk/main.c:1477
+#: ../raster/r.walk/main.c:1586
msgid ""
"Double cell type.\n"
"Writing..."
@@ -14346,7 +12150,7 @@
"Tipo de celda doble.\n"
"Escribiendo..."
-#: ../raster/r.walk/main.c:1513
+#: ../raster/r.walk/main.c:1637
#, c-format
msgid "Peak cost value: %f"
@@ -14538,27 +12342,31 @@
msgid "Enter the rule or 'help' for the format description"
msgstr "Introducir la regla o 'help' para una descripción del formato"
-#: ../raster/r.recode/read_rules.c:84
+#: ../raster/r.recode/read_rules.c:87
msgid "Enter a rule in one of these formats:"
msgstr "Introduzca una regla en uno de estos formatos:"
-#: ../raster/r.recode/read_rules.c:85
+#: ../raster/r.recode/read_rules.c:89
msgid "old_low:old_high:new_low:new_high"
msgstr ""
-#: ../raster/r.recode/read_rules.c:86
+#: ../raster/r.recode/read_rules.c:90
msgid "old_low:old_high:new_val (i.e. new_high == new_low)"
msgstr ""
-#: ../raster/r.recode/read_rules.c:87
+#: ../raster/r.recode/read_rules.c:91
msgid "*:old_val:new_val (interval [inf, old_val])"
msgstr "*:old_val:new_val (intervalo [inf, old_val])"
-#: ../raster/r.recode/read_rules.c:88
+#: ../raster/r.recode/read_rules.c:92
msgid "old_val:*:new_val (interval [old_val, inf])"
msgstr "old_val:*:new_val (intervalo [old_val, inf])"
-#: ../raster/r.recode/read_rules.c:127
+#: ../raster/r.recode/read_rules.c:94
+msgid "When finished type \"end\"."
+msgstr ""
+#: ../raster/r.recode/read_rules.c:134
#, fuzzy, c-format
msgid "'%s' is not a valid rule"
msgstr "%s no es una regla válida"
@@ -15318,60 +13126,40 @@
msgid "Unable to set window"
msgstr "No se puede establecer el tamaño"
-#: ../raster/r.sun2/main.c:225
-#, fuzzy
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in a local text file. Alternatively, "
-"a local time can be specified to compute solar incidence angle and/or "
-"irradiance raster maps. The shadowing effect of the topography is optionally "
-"incorporated."
-msgstr ""
-"Procesa mapas ráster de irradiación solar directa (rayo), difusa y reflejada "
-"para un día, latitud, superficie y condiciones atmosféricas dados. Los "
-"parámetros solares (ej. horas de salida y puesta del sol, declinación, "
-"irradiancia extraterrestre, duración del día) se guardan en el archivo "
-"histórico del mapa. De forma alternativa, se puede especificar una hora "
-"local para procesar el ángulo de incidencia solar y/o mapas ráster de "
-"irradiancia. El efecto de sombreo de la topografía se puede incorporar "
-"opcionalmente."
-#: ../raster/r.sun2/main.c:270
+#: ../raster/r.sun2/main.c:261
msgid "A single value of the orientation (aspect), 270 is south"
msgstr ""
-#: ../raster/r.sun2/main.c:286
+#: ../raster/r.sun2/main.c:278
#, fuzzy
msgid "A single value of inclination (slope)"
msgstr "Un valor único de latitud [grados decimales]"
-#: ../raster/r.sun2/main.c:349
+#: ../raster/r.sun2/main.c:346
#, fuzzy
msgid "Name of the longitude input raster map [decimal degrees]"
msgstr "Nombre del mapa ráster de latitudes de entrada [grados decimales]"
-#: ../raster/r.sun2/main.c:358
+#: ../raster/r.sun2/main.c:355
#, fuzzy
msgid "Name of real-sky beam radiation coefficient input raster map [-]"
msgstr "Nombre ráster"
-#: ../raster/r.sun2/main.c:367
+#: ../raster/r.sun2/main.c:364
#, fuzzy
msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
-#: ../raster/r.sun2/main.c:375
+#: ../raster/r.sun2/main.c:372
#, fuzzy
msgid "The horizon information input map prefix"
msgstr "La información de la proyección no se actualizará."
-#: ../raster/r.sun2/main.c:383 ../raster/r.horizon/main.c:243
+#: ../raster/r.sun2/main.c:380 ../raster/r.horizon/main.c:243
msgid "Angle step size for multidirectional horizon [degrees]"
msgstr ""
-#: ../raster/r.sun2/main.c:429
+#: ../raster/r.sun2/main.c:434
#, fuzzy
msgid ""
"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
@@ -15380,52 +13168,52 @@
"Producir mapa ráster de irradiancia [W.m-2] (modo 1) o irradiación [Wh.m-2."
"día-1] (modo 2) de los rayos"
-#: ../raster/r.sun2/main.c:479 ../raster/r.horizon/main.c:318
+#: ../raster/r.sun2/main.c:487 ../raster/r.horizon/main.c:318
msgid "Sampling distance step coefficient (0.5-1.5)"
msgstr ""
-#: ../raster/r.sun2/main.c:487
+#: ../raster/r.sun2/main.c:495
msgid "Read the input files in this number of chunks"
msgstr ""
-#: ../raster/r.sun2/main.c:494
+#: ../raster/r.sun2/main.c:502
msgid "Civil time zone value, if none, the time will be local solar time"
msgstr ""
-#: ../raster/r.sun2/main.c:505
+#: ../raster/r.sun2/main.c:513
msgid "Use the low-memory version of the program"
msgstr ""
-#: ../raster/r.sun2/main.c:537
+#: ../raster/r.sun2/main.c:560
msgid "You must give the longitude raster if you use civil time"
msgstr ""
-#: ../raster/r.sun2/main.c:576
+#: ../raster/r.sun2/main.c:599
#, fuzzy
msgid "Error reading time step size"
msgstr "Error al leer el archivo temporal"
-#: ../raster/r.sun2/main.c:580
+#: ../raster/r.sun2/main.c:603
#, fuzzy
msgid "Error reading horizon step size"
msgstr "Leyendo coordenadas del archivo."
-#: ../raster/r.sun2/main.c:584
+#: ../raster/r.sun2/main.c:607
#, fuzzy
msgid "The horizon step size must be greater than 0."
msgstr "%s = %s -- debe ser mayor que cero"
-#: ../raster/r.sun2/main.c:588
+#: ../raster/r.sun2/main.c:610
msgid ""
"If you use the horizon option you must also set the 'horizonstep' parameter."
msgstr ""
-#: ../raster/r.sun2/main.c:595
+#: ../raster/r.sun2/main.c:617
#, fuzzy
msgid "Time and insol_time are incompatible options"
msgstr "Hora local (time) e insol_time son opciones incompatibles"
-#: ../raster/r.sun2/main.c:596
+#: ../raster/r.sun2/main.c:618
#, fuzzy
msgid ""
"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
@@ -15434,27 +13222,17 @@
"Modo 1: ángulo de incidencia solar instantáneo e irradiancia dada una hora "
"local establecida"
-#: ../raster/r.sun2/main.c:601
-#, fuzzy
-msgid "incidout requres time parameter to be set"
-msgstr "incidout requiere que se establezca el parámetro hora local (time)"
-#: ../raster/r.sun2/main.c:602
-#, fuzzy
-msgid "Mode 2: integrated daily irradiation"
-msgstr "Modo 2: irradiación diaria integrada para un día determinado del año"
-#: ../raster/r.sun2/main.c:655
+#: ../raster/r.sun2/main.c:679
msgid "If you use -s and no horizon rasters, numpartitions must be =1"
msgstr ""
-#: ../raster/r.sun2/main.c:669
+#: ../raster/r.sun2/main.c:691
msgid ""
"If you want to save memory and to use shadows, you must use pre-calculated "
"horizons."
msgstr ""
-#: ../raster/r.sun2/main.c:927
+#: ../raster/r.sun2/main.c:951
#, fuzzy, c-format
msgid "Horizon file no. %d <%s> not found"
msgstr "Archivo 3Dview <%s> no encontrado"
@@ -15590,11 +13368,11 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:180
#: ../vector/lidar/v.lidar.correction/main.c:151
#: ../vector/lidar/v.lidar.growing/main.c:127
-#: ../vector/lidar/v.lidar.growing/main.c:130 ../vector/v.out.ascii/out.c:145
+#: ../vector/lidar/v.lidar.growing/main.c:130 ../vector/v.out.ascii/out.c:146
#: ../vector/v.generalize/main.c:305 ../vector/v.net/main.c:164
-#: ../vector/v.support/main.c:135 ../vector/v.surf.rst/main.c:541
-#: ../vector/v.surf.rst/main.c:696 ../vector/v.surf.rst/main.c:785
-#: ../vector/v.to.3d/main.c:71 ../vector/v.buffer2/main.c:273
+#: ../vector/v.support/main.c:135 ../vector/v.surf.rst/main.c:548
+#: ../vector/v.surf.rst/main.c:703 ../vector/v.surf.rst/main.c:792
+#: ../vector/v.to.3d/main.c:71 ../vector/v.buffer2/main.c:301
#: ../doc/vector/v.example/main.c:85 ../display/d.what.vect/main.c:126
#, c-format
msgid "Unable to open vector map <%s>"
@@ -15609,6 +13387,11 @@
msgid "Lat-long projection"
msgstr "Proyección latitud/longitud"
+#: ../vector/v.db.connect/main.c:50 ../vector/v.distance/main.c:115
+#: ../vector/v.db.select/main.c:52 ../vector/v.to.db/main.c:32
+msgid "vector, database, attribute table"
+msgstr "vectorial, base de datos, tabla de atributos"
#: ../vector/v.db.connect/main.c:52
msgid "Prints/sets DB connection for a vector map to attribute table."
msgstr ""
@@ -15672,7 +13455,7 @@
msgid "Vector map <%s> is connected by:"
msgstr "El mapa vectorial <%s> está conectado por:"
-#: ../vector/v.db.connect/main.c:157 ../display/d.what.vect/what.c:435
+#: ../vector/v.db.connect/main.c:157 ../display/d.what.vect/what.c:446
#: ../display/d.vect/main.c:495 ../display/d.thematic.area/main.c:227
#, c-format
msgid "Database connection not defined"
@@ -15689,7 +13472,7 @@
#: ../vector/v.db.connect/main.c:185 ../vector/v.edit/select.c:506
#: ../vector/lidar/v.surf.bspline/crosscorr.c:112
#: ../vector/v.distance/main.c:355 ../vector/v.distance/main.c:391
-#: ../vector/v.reclass/main.c:121 ../vector/v.out.ascii/b2a.c:37
+#: ../vector/v.reclass/main.c:121 ../vector/v.out.ascii/b2a.c:38
#: ../vector/v.db.select/main.c:136 ../vector/v.what.rast/main.c:126
#: ../vector/v.extrude/main.c:162 ../vector/v.sample/main.c:167
#: ../vector/v.generalize/misc.c:160 ../vector/v.info/main.c:200
@@ -15697,7 +13480,7 @@
#: ../vector/v.to.rast/support.c:126 ../vector/v.to.rast/support.c:277
#: ../vector/v.to.rast/vect2rast.c:51 ../vector/v.drape/main.c:271
#: ../vector/v.extract/main.c:278 ../vector/v.to.3d/trans2.c:44
-#: ../vector/v.to.3d/trans3.c:45 ../vector/v.buffer2/main.c:286
+#: ../vector/v.to.3d/trans3.c:45 ../vector/v.buffer2/main.c:314
#: ../doc/vector/v.example/main.c:103 ../display/d.vect/plot1.c:197
#: ../display/d.vect/area.c:54 ../display/d.vect.chart/plot.c:38
#: ../display/d.thematic.area/plot1.c:193
@@ -15780,7 +13563,7 @@
msgid "Unable to get layer info for vector map"
msgstr "No se puede obtener información de la capa para el mapa vectorial"
-#: ../vector/v.to.rast3/main.c:96 ../vector/lidar/v.surf.bspline/main.c:319
+#: ../vector/v.to.rast3/main.c:96 ../vector/lidar/v.surf.bspline/main.c:320
#: ../vector/v.univar/main.c:159 ../vector/v.class/main.c:126
#: ../vector/v.sample/main.c:185 ../vector/v.surf.idw/read_sites.c:52
#: ../vector/v.normal/main.c:154 ../vector/v.buffer/main.c:397
@@ -15791,10 +13574,10 @@
#: ../vector/v.to.rast3/main.c:100
#: ../vector/lidar/v.surf.bspline/crosscorr.c:131
-#: ../vector/lidar/v.surf.bspline/main.c:316 ../vector/v.univar/main.c:156
+#: ../vector/lidar/v.surf.bspline/main.c:317 ../vector/v.univar/main.c:156
#: ../vector/v.class/main.c:123 ../vector/v.what.rast/main.c:158
#: ../vector/v.sample/main.c:266 ../vector/v.surf.idw/read_sites.c:49
-#: ../vector/v.buffer/main.c:402 ../vector/v.buffer2/main.c:307
+#: ../vector/v.buffer/main.c:402 ../vector/v.buffer2/main.c:335
msgid "Column type not supported"
msgstr "Tipo de columna no soportado"
@@ -15812,6 +13595,17 @@
msgid "Unable to close new 3d raster map"
msgstr "No se puede cerrar el nuevo mapa ráster 3D"
+#: ../vector/v.external/main.c:58 ../vector/v.perturb/main.c:73
+#: ../vector/v.sample/main.c:86 ../vector/v.in.region/main.c:38
+#: ../vector/v.info/main.c:257 ../vector/v.patch/main.c:68
+#: ../vector/v.vol.rst/main.c:202 ../vector/v.mkgrid/main.c:63
+#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.voronoi/dt_main.c:46
+#: ../vector/v.voronoi/vo_main.c:119 ../vector/v.out.vtk/main.c:46
+#: ../vector/v.surf.rst/main.c:160 ../vector/v.buffer/main.c:254
+#: ../vector/v.delaunay2/main.c:62
+msgid "vector"
+msgstr "vectorial"
#: ../vector/v.external/main.c:60
msgid "Creates a new vector as a read-only link to OGR layer."
msgstr "Crea un nuevo vectorial como un enlace de sólo lectura a una capa OGR."
@@ -16143,9 +13937,10 @@
#: ../vector/v.in.ogr/main.c:130 ../vector/v.in.ogr/main.c:144
#: ../vector/v.in.ogr/main.c:166 ../vector/v.category/main.c:92
#: ../vector/v.category/main.c:97 ../vector/v.category/main.c:101
-#: ../vector/v.select/main.c:147 ../vector/v.select/main.c:152
-#: ../vector/v.select/main.c:161 ../vector/v.select/main.c:166
-#: ../vector/v.select/main.c:191 ../vector/v.extract/main.c:107
+#: ../vector/v.select/args.c:16 ../vector/v.select/args.c:21
+#: ../vector/v.select/args.c:30 ../vector/v.select/args.c:35
+#: ../vector/v.select/args.c:83 ../vector/v.surf.rst/main.c:210
+#: ../vector/v.surf.rst/main.c:213 ../vector/v.extract/main.c:107
#: ../vector/v.extract/main.c:117 ../vector/v.extract/main.c:123
#: ../vector/v.extract/main.c:127 ../vector/v.extract/main.c:130
#: ../vector/v.extract/main.c:138 ../vector/v.extract/main.c:148
@@ -16275,7 +14070,7 @@
msgid "Pair: value,step (e.g. 1100,10)"
msgstr "Par: valor, paso (ej.: 1100,10)"
-#: ../vector/v.edit/args.c:201 ../vector/v.select/main.c:190
+#: ../vector/v.edit/args.c:201 ../vector/v.select/args.c:82
#: ../vector/v.extract/main.c:106
msgid "Reverse selection"
msgstr "Invertir selección"
@@ -16355,7 +14150,7 @@
msgid "Layer %d: %s"
msgstr "Capa %d: %s"
-#: ../vector/v.in.dxf/write_vect.c:219
+#: ../vector/v.in.dxf/write_vect.c:230
#, fuzzy, c-format
msgid "Unable to add database link for vector map <%s>"
msgstr "No se puede obtener información de la capa para el mapa vectorial <%s>"
@@ -16364,6 +14159,11 @@
msgid "end of file while looking for HEADER"
msgstr "final del archivo mientras se buscaba la CABECERA"
+#: ../vector/v.in.dxf/main.c:60 ../vector/v.in.ascii/in.c:48
+#: ../vector/v.in.ogr/main.c:101 ../vector/v.in.dwg/main.c:65
+msgid "vector, import"
+msgstr "vectorial, importar"
#: ../vector/v.in.dxf/main.c:62
msgid "Converts files in DXF format to GRASS vector map format."
msgstr ""
@@ -16382,6 +14182,10 @@
msgid "Import polyface meshes as 3D wire frame"
msgstr "Importar"
+#: ../vector/v.in.dxf/main.c:82 ../vector/v.in.dwg/main.c:96
+msgid "List available layers and exit"
+msgstr "Listar las capas disponibles y salir"
#: ../vector/v.in.dxf/main.c:83 ../vector/v.in.dxf/main.c:89
#: ../vector/v.in.dxf/main.c:94 ../vector/v.in.dxf/main.c:108
#, fuzzy
@@ -16489,14 +14293,12 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:86
#: ../vector/lidar/v.lidar.correction/main.c:90
#: ../vector/lidar/v.outlier/main.c:95
-#: ../vector/lidar/v.surf.bspline/main.c:112
msgid "Interpolation spline step value in east direction"
msgstr "Valor de paso spline de interpolación en dirección Este"
#: ../vector/lidar/v.lidar.edgedetection/main.c:95
#: ../vector/lidar/v.lidar.correction/main.c:98
#: ../vector/lidar/v.outlier/main.c:103
-#: ../vector/lidar/v.surf.bspline/main.c:122
msgid "Interpolation spline step value in north direction"
msgstr "Valor de paso spline de interpolación en dirección Norte"
@@ -16524,13 +14326,13 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:157
#: ../vector/lidar/v.outlier/main.c:126
-#: ../vector/lidar/v.surf.bspline/main.c:185
+#: ../vector/lidar/v.surf.bspline/main.c:186
msgid "Unable to read name of database"
msgstr "No se puede leer el nombre de la base de datos"
#: ../vector/lidar/v.lidar.edgedetection/main.c:160
#: ../vector/lidar/v.outlier/main.c:129
-#: ../vector/lidar/v.surf.bspline/main.c:188
+#: ../vector/lidar/v.surf.bspline/main.c:189
msgid "Unable to read name of driver"
msgstr "No se puede leer el nombre del controlador"
@@ -16538,8 +14340,8 @@
#: ../vector/lidar/v.lidar.correction/main.c:176
#: ../vector/lidar/v.outlier/main.c:188
#: ../vector/lidar/v.lidar.growing/main.c:151
-#: ../vector/lidar/v.surf.bspline/main.c:203
-#: ../vector/lidar/v.surf.bspline/main.c:371
+#: ../vector/lidar/v.surf.bspline/main.c:204
+#: ../vector/lidar/v.surf.bspline/main.c:372
#, c-format
msgid "No database connection for driver <%s> is defined. Run db.connect."
msgstr ""
@@ -16608,7 +14410,7 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:370
#: ../vector/lidar/v.lidar.correction/main.c:335
#: ../vector/lidar/v.outlier/main.c:345
-#: ../vector/lidar/v.surf.bspline/main.c:713
+#: ../vector/lidar/v.surf.bspline/main.c:714
msgid "Auxiliar table could not be dropped"
msgstr "La tabla auxiliar no se pudo eliminar"
@@ -16685,6 +14487,13 @@
msgid "Correction and creation of terrain vector"
msgstr "vectorial"
+#: ../vector/lidar/v.outlier/main.c:66 ../vector/v.univar/main.c:64
+#: ../vector/v.class/main.c:45 ../vector/v.qcount/main.c:69
+#: ../vector/v.random/main.c:84 ../vector/v.kcv/main.c:76
+#: ../vector/v.normal/main.c:79
+msgid "vector, statistics"
+msgstr "vectorial, estadísticas"
#: ../vector/lidar/v.outlier/main.c:67
#, fuzzy
msgid "Removes outliers from vector point data."
@@ -16700,8 +14509,8 @@
msgstr "Nombre del mapa vectorial para visualización en QGIS"
#: ../vector/lidar/v.outlier/main.c:109
-#: ../vector/lidar/v.surf.bspline/main.c:140
-msgid "Tychonov regularization weight"
+#, fuzzy
+msgid "Tykhonov regularization weight"
msgstr "Peso de regularización Tychonov"
#: ../vector/lidar/v.outlier/main.c:116
@@ -16709,8 +14518,8 @@
msgstr ""
#: ../vector/lidar/v.outlier/main.c:167
-#: ../vector/lidar/v.surf.bspline/main.c:230
-#: ../vector/lidar/v.surf.bspline/main.c:250
+#: ../vector/lidar/v.surf.bspline/main.c:231
+#: ../vector/lidar/v.surf.bspline/main.c:251
#, c-format
msgid "Unable to open vector map <%s> at the topological level"
msgstr "No se puede abrir el mapa vectorial <%s> al nivel topológico"
@@ -16743,8 +14552,9 @@
msgstr "Estableciendo regiones y cajas"
#: ../vector/lidar/v.lidar.growing/main.c:176
-msgid "It was impossible to open table"
-msgstr "Fue imposible abrir la tabla"
+#, fuzzy, c-format
+msgid "Unable to create table <%s_edge_Interpolation>"
+msgstr "No se puede crear la tabla <%s>"
#: ../vector/lidar/v.lidar.growing/main.c:223
#, c-format
@@ -16868,7 +14678,10 @@
msgstr "Interpolación bicúbica o bilineal con regularización Tykhonov"
#: ../vector/lidar/v.surf.bspline/main.c:87
-msgid "Find best parameters using a cross validation method"
+#, fuzzy
+msgid ""
+"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
+"cross validation method"
msgstr ""
"Encontrar los mejores parámetros usando un método de validación cruzada"
@@ -16876,21 +14689,37 @@
msgid "Name of input vector map of sparse points"
msgstr "Nombre del mapa vectorial de entrada de puntos esparcidos"
+#: ../vector/lidar/v.surf.bspline/main.c:112
+#, fuzzy
+msgid "Length of each spline step in the east-west direction"
+msgstr "Valor de paso spline de interpolación en dirección Este"
+#: ../vector/lidar/v.surf.bspline/main.c:122
+#, fuzzy
+msgid "Length of each spline step in the north-south direction"
+msgstr "Valor de paso spline de interpolación en dirección Norte"
#: ../vector/lidar/v.surf.bspline/main.c:130
-msgid "Spline type of interpolation"
-msgstr "Tipo spline de interpolación"
+#, fuzzy
+msgid "Spline interpolation algorithm"
+msgstr "Algoritmo de generalización"
-#: ../vector/lidar/v.surf.bspline/main.c:147 ../vector/v.surf.rst/main.c:206
+#: ../vector/lidar/v.surf.bspline/main.c:140
+#, fuzzy
+msgid "Tykhonov regularization parameter (affects smoothing)"
+msgstr "Peso de regularización Tychonov"
+#: ../vector/lidar/v.surf.bspline/main.c:147 ../vector/v.surf.rst/main.c:207
msgid "If set to 0, z coordinates are used. (3D vector only)"
msgstr ""
"Valor de campo. Si se establece a 0, se usarán las coordenadas Z (sólo "
"vectoriales 3D)"
-#: ../vector/lidar/v.surf.bspline/main.c:157
+#: ../vector/lidar/v.surf.bspline/main.c:158
msgid "Attribute table column with values to interpolate (if layer>0)"
msgstr "Columna de la tabla de atributos con valores a interpolar (si capa>0)"
-#: ../vector/lidar/v.surf.bspline/main.c:211
+#: ../vector/lidar/v.surf.bspline/main.c:212
#, c-format
msgid ""
"It was not possible to drop <%s> table. Nothing will be done. Try to drop it "
@@ -16899,29 +14728,29 @@
"No fue posible quitar la tabla <%s>. No se hará nada. Intente quitarla "
"manualmente."
-#: ../vector/lidar/v.surf.bspline/main.c:219
+#: ../vector/lidar/v.surf.bspline/main.c:220
msgid "Choose either vector or raster output, not both"
msgstr "Elija salida vectorial o ráster, no ambas"
-#: ../vector/lidar/v.surf.bspline/main.c:222
+#: ../vector/lidar/v.surf.bspline/main.c:223
msgid "No raster nor vector output"
msgstr "Ninguna salida ráster ni vectorial"
-#: ../vector/lidar/v.surf.bspline/main.c:236
+#: ../vector/lidar/v.surf.bspline/main.c:237
#, fuzzy, c-format
msgid ""
-"No vector map of sparse points to interpolate was specified. Interpolation will be done "
-"with <%s> vector map"
+"No vector map of sparse points to interpolate was specified. Interpolation "
+"will be done with <%s> vector map"
msgstr ""
"Ningún mapa vectorial a interpolar. La interpolación se hará con el mapa "
"vectorial <%s>"
-#: ../vector/lidar/v.surf.bspline/main.c:242
+#: ../vector/lidar/v.surf.bspline/main.c:243
#, fuzzy, c-format
msgid "Vector map <%s> of sparse points will be interpolated"
msgstr "El mapa vectorial <%s> se interpolará"
-#: ../vector/lidar/v.surf.bspline/main.c:258
+#: ../vector/lidar/v.surf.bspline/main.c:259
#, c-format
msgid ""
"Sorry, <%s> driver is not allowed for vector output in this module. Try with "
@@ -16930,24 +14759,24 @@
"Lo siento, el controlador <%s> no está permitido para salida vectorial en "
"este módulo. Pruebe con una salida ráster u otro controlador."
-#: ../vector/lidar/v.surf.bspline/main.c:300
+#: ../vector/lidar/v.surf.bspline/main.c:301
msgid "Cannot read field info"
msgstr "No se puede leer la información del campo"
-#: ../vector/lidar/v.surf.bspline/main.c:321
+#: ../vector/lidar/v.surf.bspline/main.c:322
#, c-format
msgid "[%d] records selected from table"
msgstr "[%d] registros seleccionados de la tabla"
-#: ../vector/lidar/v.surf.bspline/main.c:334
+#: ../vector/lidar/v.surf.bspline/main.c:335
msgid "Cross validation didn't finish correctly"
msgstr "La validación cruzada no terminó correctamente"
-#: ../vector/lidar/v.surf.bspline/main.c:347
+#: ../vector/lidar/v.surf.bspline/main.c:348
msgid "Cross Validation was success!"
msgstr "¡La validación cruzada fue un éxito!"
-#: ../vector/lidar/v.surf.bspline/main.c:363
+#: ../vector/lidar/v.surf.bspline/main.c:364
#, c-format
msgid ""
"Interpolation: The region resolution is too high: %d cells. Consider to "
@@ -16956,23 +14785,23 @@
"Interpolación: la resolución de la región es demasiado alta: %d celdas. "
"Considere cambiarla."
-#: ../vector/lidar/v.surf.bspline/main.c:384
+#: ../vector/lidar/v.surf.bspline/main.c:385
msgid ""
"Cannot allocate memory for auxiliar matrix.Consider changing region "
"resolution"
msgstr ""
-#: ../vector/lidar/v.surf.bspline/main.c:558
+#: ../vector/lidar/v.surf.bspline/main.c:559
#, c-format
msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
msgstr "Interpolación: (%d,%d): Ningún registro para el punto (cat = %d)"
-#: ../vector/lidar/v.surf.bspline/main.c:619
+#: ../vector/lidar/v.surf.bspline/main.c:620
#, c-format
msgid "Interpolation: Creating table: It was impossible to create table <%s>."
msgstr "Interpolación: creando tabla: no se pudo crear la tabla <%s>."
-#: ../vector/lidar/v.surf.bspline/main.c:692
+#: ../vector/lidar/v.surf.bspline/main.c:693
msgid "No data within this subzone. Consider changing the spline step."
msgstr ""
@@ -17194,7 +15023,7 @@
"puede actualizar"
#: ../vector/v.distance/main.c:373 ../vector/v.distance/main.c:407
-#: ../vector/v.reclass/main.c:137 ../vector/v.out.ascii/b2a.c:222
+#: ../vector/v.reclass/main.c:137 ../vector/v.out.ascii/b2a.c:227
#: ../vector/v.to.3d/trans2.c:56 ../vector/v.to.3d/trans3.c:57
#, c-format
msgid "Column <%s> not found in table <%s>"
@@ -17529,10 +15358,6 @@
msgid "Do not create table in points mode"
msgstr "No crear tabla en modo de puntos"
-#: ../vector/v.in.ascii/in.c:161
-msgid "Do not build topology in points mode"
-msgstr "No contruir topología en modo de puntos"
#: ../vector/v.in.ascii/in.c:167
msgid "Only import points falling within current region (points mode)"
msgstr ""
@@ -17734,7 +15559,7 @@
#: ../vector/v.to.points/main.c:213 ../vector/v.in.ogr/main.c:213
#: ../vector/v.overlay/main.c:120 ../vector/v.voronoi/vo_main.c:139
-#: ../vector/v.select/main.c:186
+#: ../vector/v.select/args.c:78
msgid "Do not create attribute table"
msgstr "No crear la tabla de atributos"
@@ -17752,22 +15577,22 @@
msgid "%d points written to output vector map"
msgstr "Escritos [%d] puntos en el mapa vectorial de salida"
-#: ../vector/v.out.ascii/b2a.c:148
+#: ../vector/v.out.ascii/b2a.c:150
#, c-format
msgid "got type %d"
msgstr "se obtuvo el tipo %d"
-#: ../vector/v.out.ascii/b2a.c:187
+#: ../vector/v.out.ascii/b2a.c:192
#, c-format
msgid "Feature has more categories. Only first category (%d) is exported."
msgstr ""
-#: ../vector/v.out.ascii/b2a.c:197
+#: ../vector/v.out.ascii/b2a.c:202
#, fuzzy, c-format
msgid "Unable to select record from table <%s> (key %s, column %s)"
msgstr "No se pueden seleccionar registros de la tabla LRS: %s"
-#: ../vector/v.out.ascii/b2a.c:224
+#: ../vector/v.out.ascii/b2a.c:229
#, fuzzy, c-format
msgid "Column <%s>: unsupported data type"
msgstr "Columna <%s>: tipo de datos no válido"
@@ -17813,29 +15638,29 @@
"Sólo exportar los puntos que caen dentro de la región 3D actual (modo de "
"puntos)"
-#: ../vector/v.out.ascii/out.c:110
+#: ../vector/v.out.ascii/out.c:111
#, c-format
msgid "Parameter '%s' ignored in standard mode"
msgstr ""
-#: ../vector/v.out.ascii/out.c:118
+#: ../vector/v.out.ascii/out.c:119
msgid "Format 'point' is not supported for old version"
msgstr "El formato 'punto' no está soportado por la versión antigua"
-#: ../vector/v.out.ascii/out.c:122
+#: ../vector/v.out.ascii/out.c:123
msgid "'output' must be given for old version"
msgstr "se debe proporcionar 'salida' para la versión antigua"
-#: ../vector/v.out.ascii/out.c:139 ../vector/v.out.vtk/main.c:186
+#: ../vector/v.out.ascii/out.c:140 ../vector/v.out.vtk/main.c:186
#, fuzzy
msgid "Failed to interpret 'dp' parameter as an integer"
msgstr "No se pudo interpretar el parámetro 'dp' como entero"
-#: ../vector/v.out.ascii/out.c:176
+#: ../vector/v.out.ascii/out.c:177
msgid "dig_att file already exist"
msgstr "el archivo dig_att ya existe"
-#: ../vector/v.out.ascii/out.c:179
+#: ../vector/v.out.ascii/out.c:180
#, fuzzy, c-format
msgid "Unable to open dig_att file <%s>"
msgstr "No se puede abrir el archivo dig_att <%s>\n"
@@ -18146,7 +15971,7 @@
#: ../vector/v.label.sa/labels.c:178 ../vector/v.label/main.c:329
#: ../vector/v.buffer/main.c:454 ../vector/v.buffer/main.c:466
#: ../vector/v.buffer/main.c:531 ../vector/v.buffer/main.c:543
-#: ../vector/v.buffer2/main.c:358 ../vector/v.buffer2/main.c:424
+#: ../vector/v.buffer2/main.c:386 ../vector/v.buffer2/main.c:452
#, c-format
msgid "No record for category %d in table <%s>"
msgstr "No hay registro para la categoría %d en la tabla <%s>"
@@ -18193,7 +16018,8 @@
"de categoría de la primera línea a polilínea;multi;Asignar múltiples números "
"de categoría a polilínea"
-#: ../vector/v.build.polylines/main.c:128
+#: ../vector/v.build.polylines/main.c:128 ../vector/v.buffer2/main.c:210
+#: ../vector/v.buffer2/main.c:222
msgid "Unused"
msgstr ""
@@ -18742,7 +16568,7 @@
msgid "Calculating centrality measures..."
msgstr "Calculando medias de clase ..."
-#: ../vector/v.generalize/misc.c:124 ../vector/v.select/main.c:477
+#: ../vector/v.generalize/misc.c:124 ../vector/v.select/main.c:478
#: ../vector/v.extract/main.c:427
msgid "Writing attributes..."
msgstr "Escribiendo atributos..."
@@ -19193,8 +17019,8 @@
#: ../vector/v.in.ogr/main.c:985 ../vector/v.overlay/area_area.c:68
#: ../vector/v.voronoi/dt_main.c:142 ../vector/v.buffer/main.c:661
-#: ../vector/v.buffer/main.c:741 ../vector/v.buffer2/main.c:505
-#: ../vector/v.buffer2/main.c:576
+#: ../vector/v.buffer/main.c:741 ../vector/v.buffer2/main.c:533
+#: ../vector/v.buffer2/main.c:604
msgid "Cannot calculate area centroid"
msgstr "Imposible calcular el centroide del área"
@@ -19238,39 +17064,44 @@
"Los datos de entrada contienen elementos 3D. El vectorial creado es 2D. Use "
"la opción -z para importar vectoriales 3D."
-#: ../vector/v.in.ogr/geom.c:233
+#: ../vector/v.in.ogr/geom.c:192 ../vector/v.in.ogr/geom.c:205
+#: ../vector/v.in.ogr/geom.c:229 ../vector/v.in.ogr/geom.c:271
+msgid "Skipping empty geometry feature"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:245
#, c-format
msgid "Degenerate polygon ([%d] vertices)"
msgstr "Degenerar polígono ([%d] vértices)"
-#: ../vector/v.in.ogr/geom.c:238
+#: ../vector/v.in.ogr/geom.c:250
#, c-format
msgid "Area size [%.1e], area not imported"
msgstr "Tamaño de área [%.1e]. Área no importada"
-#: ../vector/v.in.ogr/geom.c:265
+#: ../vector/v.in.ogr/geom.c:282
#, c-format
msgid "Degenerate island ([%d] vertices)"
msgstr "Degenerar isla ([%d] vértices)"
-#: ../vector/v.in.ogr/geom.c:270
+#: ../vector/v.in.ogr/geom.c:287
#, c-format
msgid "Island size [%.1e], island not imported"
msgstr "Tamaño de isla [%.1e]. Isla no importada"
-#: ../vector/v.in.ogr/geom.c:289
+#: ../vector/v.in.ogr/geom.c:308
msgid "Cannot calculate centroid"
msgstr "No se puede calcular el centroide"
-#: ../vector/v.in.ogr/geom.c:320
+#: ../vector/v.in.ogr/geom.c:339
msgid "No centroid written for polygon with 0 vertices"
msgstr "Ningún centroide escrito para polígonos con 0 vértices"
-#: ../vector/v.in.ogr/geom.c:341
+#: ../vector/v.in.ogr/geom.c:360
msgid "Cannot write part of geometry"
msgstr "No se puede escribir parte de la geometría"
-#: ../vector/v.in.ogr/geom.c:347
+#: ../vector/v.in.ogr/geom.c:366
msgid "Unknown geometry type"
msgstr "Tipo de geometría desconocido"
@@ -19490,19 +17321,19 @@
msgid "If set to 0, z coordinates are used (3D vector only)"
msgstr "Si se establece a 0, se usarán las coordenadas Z (sólo vectoriales 3D)"
-#: ../vector/v.surf.idw/main.c:117
+#: ../vector/v.surf.idw/main.c:118
msgid "Attribute table column with values to interpolate"
msgstr "Columna de la tabla de atributos con valores a interpolar"
-#: ../vector/v.surf.idw/main.c:118
+#: ../vector/v.surf.idw/main.c:119
msgid "Required if layer > 0"
msgstr "Requerido si capa > 0"
-#: ../vector/v.surf.idw/main.c:122
+#: ../vector/v.surf.idw/main.c:123
msgid "Don't index points by raster cell"
msgstr "No indexar puntos por celda ráster"
-#: ../vector/v.surf.idw/main.c:123
+#: ../vector/v.surf.idw/main.c:124
msgid ""
"Slower but uses less memory and includes points from outside region in the "
"interpolation"
@@ -19510,15 +17341,15 @@
"Más lento pero usa menos memoria e incluye puntos de la región exterior en "
"la interpolación"
-#: ../vector/v.surf.idw/main.c:141
+#: ../vector/v.surf.idw/main.c:142
msgid "No attribute column specified"
msgstr "Ninguna columna de atributos especificada"
-#: ../vector/v.surf.idw/main.c:176
+#: ../vector/v.surf.idw/main.c:177
msgid "No data points found"
msgstr "No se han encontrado puntos de datos"
-#: ../vector/v.surf.idw/main.c:261
+#: ../vector/v.surf.idw/main.c:262
#, c-format
msgid "Interpolating raster map <%s> (%d rows, %d cols)... "
msgstr "Interpolando mapa ráster <%s> (%d filas, %d columnas)... "
@@ -19552,11 +17383,11 @@
msgid "Name of the column containing w attribute to interpolate"
msgstr "Nombre de la columna que contiene los datos a interpolar"
-#: ../vector/v.vol.rst/main.c:260 ../vector/v.surf.rst/main.c:263
+#: ../vector/v.vol.rst/main.c:260 ../vector/v.surf.rst/main.c:299
msgid "Tension parameter"
msgstr "Parámetro tensión"
-#: ../vector/v.vol.rst/main.c:268 ../vector/v.surf.rst/main.c:270
+#: ../vector/v.vol.rst/main.c:268 ../vector/v.surf.rst/main.c:306
msgid "Smoothing parameter"
msgstr "Parámetro suavizado"
@@ -19564,13 +17395,11 @@
msgid "Name of the column with smoothing parameters"
msgstr "Nombre de la columna con parámetros de suavizado"
-#: ../vector/v.vol.rst/main.c:286 ../vector/v.surf.rst/main.c:330
+#: ../vector/v.vol.rst/main.c:286 ../vector/v.surf.rst/main.c:256
msgid "Output deviations vector point file"
msgstr "Producir archivo de puntos vectorial de desviaciones"
#: ../vector/v.vol.rst/main.c:287 ../vector/v.vol.rst/main.c:295
-#: ../vector/v.surf.rst/main.c:331 ../vector/v.surf.rst/main.c:338
-#: ../vector/v.surf.rst/main.c:345 ../vector/v.surf.rst/main.c:352
msgid "Analysis"
msgstr "Análisis"
@@ -19578,90 +17407,95 @@
msgid "Output cross-validation vector map"
msgstr "Producir mapa vectorial de validación cruzada"
-#: ../vector/v.vol.rst/main.c:302 ../vector/v.surf.rst/main.c:256
+#: ../vector/v.vol.rst/main.c:302 ../vector/v.surf.rst/main.c:283
msgid "Name of the raster map used as mask"
msgstr "Nombre del mapa ráster usado como máscara"
-#: ../vector/v.vol.rst/main.c:309 ../vector/v.surf.rst/main.c:286
+#: ../vector/v.vol.rst/main.c:309 ../vector/v.surf.rst/main.c:322
msgid "Maximum number of points in a segment"
msgstr "Número máximo de puntos en un segmento"
-#: ../vector/v.vol.rst/main.c:318 ../vector/v.surf.rst/main.c:295
+#: ../vector/v.vol.rst/main.c:318 ../vector/v.surf.rst/main.c:331
msgid "Minimum number of points for approximation in a segment (>segmax)"
msgstr "Número mínimo de puntos para aproximación en un segmento (>segmax)"
-#: ../vector/v.vol.rst/main.c:327 ../vector/v.surf.rst/main.c:304
+#: ../vector/v.vol.rst/main.c:327
+#, fuzzy
+msgid "Maximum number of points for approximation in a segment (>npmin)"
+msgstr "Número mínimo de puntos para aproximación en un segmento (>segmax)"
+#: ../vector/v.vol.rst/main.c:336 ../vector/v.surf.rst/main.c:340
msgid "Minimum distance between points (to remove almost identical points)"
msgstr "Distancia mínima entre puntos (para eliminar puntos casi indénticos)"
-#: ../vector/v.vol.rst/main.c:336
+#: ../vector/v.vol.rst/main.c:345
msgid "Conversion factor for w-values used for interpolation"
msgstr "Factor de conversión para valores W usados para interpolación"
-#: ../vector/v.vol.rst/main.c:344
+#: ../vector/v.vol.rst/main.c:353
msgid "Conversion factor for z-values"
-#: ../vector/v.vol.rst/main.c:352
+#: ../vector/v.vol.rst/main.c:361
msgid "Output cross-section raster map"
msgstr "Producir mapa ráster de sección cruzada"
-#: ../vector/v.vol.rst/main.c:361
+#: ../vector/v.vol.rst/main.c:370
msgid "Output elevation g3d-file"
msgstr "Producir archivo G3D de elevación"
-#: ../vector/v.vol.rst/main.c:369
+#: ../vector/v.vol.rst/main.c:378
msgid "Output gradient magnitude g3d-file"
msgstr "Producir archivo G3D de magnitud de gradiente"
-#: ../vector/v.vol.rst/main.c:379
+#: ../vector/v.vol.rst/main.c:388
msgid "Output gradient horizontal angle g3d-file"
msgstr "Producir archivo G3D de ángulo horizontal de gradiente"
-#: ../vector/v.vol.rst/main.c:388
+#: ../vector/v.vol.rst/main.c:397
msgid "Output gradient vertical angle g3d-file"
msgstr "Producir archivo G3D de ángulo vertical de gradiente"
-#: ../vector/v.vol.rst/main.c:397
+#: ../vector/v.vol.rst/main.c:406
msgid "Output change of gradient g3d-file"
msgstr "Producir archivo G3D de cambio de gradiente"
-#: ../vector/v.vol.rst/main.c:406
+#: ../vector/v.vol.rst/main.c:415
msgid "Output gaussian curvature g3d-file"
msgstr "Producir archivo G3D de curvatura gausiana"
-#: ../vector/v.vol.rst/main.c:415
+#: ../vector/v.vol.rst/main.c:424
msgid "Output mean curvature g3d-file"
msgstr "Producir archivo G3D de curvatura media"
-#: ../vector/v.vol.rst/main.c:421
+#: ../vector/v.vol.rst/main.c:430
msgid "Perform a cross-validation procedure without volume interpolation"
msgstr ""
"Realizar un procedimiento de validación cruzada sin interpolación de volumen"
-#: ../vector/v.vol.rst/main.c:457
+#: ../vector/v.vol.rst/main.c:467
msgid "Smoothing must be a positive value"
msgstr "El suavizado debe ser un valor positivo"
-#: ../vector/v.vol.rst/main.c:463
+#: ../vector/v.vol.rst/main.c:473
msgid "Both crossvalidation options (-c, cvdev) must be specified"
msgstr ""
"Se deben especificar las dos opciones (-c, cvdev) de validación cruzada"
-#: ../vector/v.vol.rst/main.c:465
+#: ../vector/v.vol.rst/main.c:475
msgid "Both crossvalidation and deviations file specified"
msgstr "Especificadas tanto validación cruzada como archivo de desviaciones"
-#: ../vector/v.vol.rst/main.c:548
+#: ../vector/v.vol.rst/main.c:557
msgid "Vector is not 3D"
msgstr "El vectorial no es 3D"
-#: ../vector/v.vol.rst/main.c:584
+#: ../vector/v.vol.rst/main.c:596
#, c-format
msgid "Cannot create table: %s"
msgstr "No se puede crear la tabla: %s"
-#: ../vector/v.vol.rst/main.c:600
+#: ../vector/v.vol.rst/main.c:612
#, c-format
msgid "Cannot open %s"
msgstr "No se puede abrir %s"
@@ -19703,7 +17537,7 @@
msgid "Counting sites in quadrats..."
msgstr "lugares."
-#: ../vector/v.out.pov/main.c:207 ../vector/v.out.ogr/main.c:641
+#: ../vector/v.out.pov/main.c:207 ../vector/v.out.ogr/main.c:644
#, c-format
msgid "%d features written"
msgstr "%d elementos escritos"
@@ -20031,6 +17865,10 @@
msgid "Feature ids (by default all features are processed)"
msgstr ""
+#: ../vector/v.category/main.c:112
+msgid "Category increment"
+msgstr "Incremento de categoría"
#: ../vector/v.category/main.c:116
msgid "Shell script style, currently only for report"
msgstr "Estilo de script de consola, actualmente sólo para informes"
@@ -20069,7 +17907,7 @@
msgid "Output vector wasn't entered"
msgstr "No se indicó el vectorial de salida"
-#: ../vector/v.category/main.c:229 ../vector/v.select/main.c:242
+#: ../vector/v.category/main.c:229 ../vector/v.select/main.c:147
#, fuzzy
msgid "Processing features..."
msgstr "Procesando áreas de la entrada A..."
@@ -20403,7 +18241,7 @@
msgstr "Atributo no encontrado"
#: ../vector/v.overlay/area_area.c:43 ../vector/v.buffer/main.c:625
-#: ../vector/v.buffer2/main.c:477
+#: ../vector/v.buffer2/main.c:505
msgid "Removing duplicates..."
msgstr "Eliminando duplicados..."
@@ -20412,7 +18250,7 @@
msgstr "Limpiando límites y nodos..."
#: ../vector/v.overlay/area_area.c:55 ../vector/v.buffer/main.c:637
-#: ../vector/v.buffer2/main.c:489
+#: ../vector/v.buffer2/main.c:517
msgid "Attaching islands..."
msgstr "Adjuntando islas..."
@@ -20426,7 +18264,7 @@
msgstr "Escribiendo centroides..."
#: ../vector/v.overlay/area_area.c:264 ../vector/v.buffer/main.c:751
-#: ../vector/v.buffer2/main.c:598
+#: ../vector/v.buffer2/main.c:626
msgid "Attaching centroids..."
msgstr "Adjuntando centroides..."
@@ -20434,32 +18272,32 @@
msgid "Overlays two vector maps."
msgstr "Superpone dos mapas vectoriales."
-#: ../vector/v.overlay/main.c:59 ../vector/v.select/main.c:141
+#: ../vector/v.overlay/main.c:59 ../vector/v.select/args.c:10
#, fuzzy
msgid "Name of input vector map (A)"
msgstr "Nombre del mapa vectorial de entrada"
-#: ../vector/v.overlay/main.c:63 ../vector/v.select/main.c:145
+#: ../vector/v.overlay/main.c:63 ../vector/v.select/args.c:14
#, fuzzy
msgid "Feature type (vector map A)"
msgstr "Nombre de mapa vectorial"
-#: ../vector/v.overlay/main.c:69 ../vector/v.select/main.c:150
+#: ../vector/v.overlay/main.c:69 ../vector/v.select/args.c:19
#, fuzzy
msgid "Layer number (vector map A)"
-#: ../vector/v.overlay/main.c:73 ../vector/v.select/main.c:155
+#: ../vector/v.overlay/main.c:73 ../vector/v.select/args.c:24
#, fuzzy
msgid "Name of input vector map (B)"
-#: ../vector/v.overlay/main.c:77 ../vector/v.select/main.c:159
+#: ../vector/v.overlay/main.c:77 ../vector/v.select/args.c:28
#, fuzzy
msgid "Feature type (vector map B)"
-#: ../vector/v.overlay/main.c:83 ../vector/v.select/main.c:164
+#: ../vector/v.overlay/main.c:83 ../vector/v.select/args.c:33
#, fuzzy
msgid "Layer number (vector map B)"
@@ -20525,7 +18363,7 @@
msgstr "Tipo de columna '%s' desconocido"
#: ../vector/v.overlay/main.c:357 ../vector/v.out.svg/main.c:370
-#: ../vector/v.out.vtk/writeVTK.c:579 ../vector/v.out.ogr/main.c:700
+#: ../vector/v.out.vtk/writeVTK.c:579 ../vector/v.out.ogr/main.c:703
#: ../vector/v.lrs/v.lrs.label/main.c:347
msgid "Unable to fetch data from table"
msgstr "No se pueden recopilar datos de la tabla"
@@ -20767,14 +18605,14 @@
"with a smaller weight is hidden."
msgstr ""
-#: ../vector/v.label.sa/font.c:55
+#: ../vector/v.label.sa/font.c:56
#, c-format
msgid "%s: Unable to read font definition file; use the default"
msgstr ""
"%s: no se puede leer el archivo de definición de fuentes; se usa el "
"predeterminado"
-#: ../vector/v.label.sa/font.c:61
+#: ../vector/v.label.sa/font.c:62
#, c-format
msgid "%s: No font definition file"
msgstr "%s: ningún archivo de definición de fuentes"
@@ -21228,13 +19066,13 @@
"Desplazamiento en unidades de mapa, positivo hacia la derecha, negativo "
"hacia la izquierda."
-#: ../vector/v.what/what.c:90 ../vector/v.what/what.c:92
-#: ../display/d.what.vect/what.c:173 ../display/d.what.vect/what.c:175
+#: ../vector/v.what/what.c:105 ../vector/v.what/what.c:107
+#: ../display/d.what.vect/what.c:179 ../display/d.what.vect/what.c:181
#, c-format
msgid "Nothing Found.\n"
msgstr "No se ha encontrado nada.\n"
-#: ../vector/v.what/what.c:135
+#: ../vector/v.what/what.c:157
#, fuzzy, c-format
msgid ""
"Id: %d\n"
@@ -21247,15 +19085,26 @@
"Izquierda: %d \n"
"Derecha: %d \n"
-#: ../vector/v.what/what.c:139 ../vector/v.what/what.c:173
-#: ../display/d.what.vect/what.c:235
+#: ../vector/v.what/what.c:162 ../vector/v.what/what.c:217
+#: ../display/d.what.vect/what.c:241
#, c-format
msgid "Length: %f\n"
msgstr "Longitud: %f\n"
-#: ../vector/v.what/what.c:155
+#: ../vector/v.what/what.c:180
#, fuzzy, c-format
msgid ""
+"Node[%d]=%d\n"
+"Number_lines=%d\n"
+"Coordinates=%.6f,%.6f,%.6f\n"
+msgstr ""
+" Nodo[%d]: %d \n"
+"Número de líneas: %d\n"
+"Coordenadas: %.6f, %.6f, %.6f\n"
+#: ../vector/v.what/what.c:185
+#, fuzzy, c-format
+msgid ""
"Node[%d]: %d\n"
"Number of lines: %d\n"
"Coordinates: %.6f, %.6f, %.6f\n"
@@ -21264,7 +19113,7 @@
-#: ../vector/v.what/what.c:163
+#: ../vector/v.what/what.c:199
#, fuzzy, c-format
msgid ""
"Id: %5d\n"
@@ -21273,27 +19122,27 @@
" Linea: %5d \n"
"Ángulo: %.8f\n"
-#: ../vector/v.what/what.c:170
+#: ../vector/v.what/what.c:214
#, c-format
msgid "Type: %s"
msgstr "Tipo: %s"
-#: ../vector/v.what/what.c:171
+#: ../vector/v.what/what.c:215
#, fuzzy, c-format
msgid "Id: %d\n"
msgstr "Isla[%d]: %d\n"
-#: ../vector/v.what/what.c:182 ../display/d.what.vect/what.c:289
+#: ../vector/v.what/what.c:231 ../display/d.what.vect/what.c:295
#, c-format
msgid "Point height: %f\n"
msgstr "Altura del punto: %f\n"
-#: ../vector/v.what/what.c:193 ../display/d.what.vect/what.c:307
+#: ../vector/v.what/what.c:248 ../display/d.what.vect/what.c:313
#, c-format
msgid "Line height: %f\n"
msgstr "Altura de la línea: %f\n"
-#: ../vector/v.what/what.c:197
+#: ../vector/v.what/what.c:259
#, fuzzy, c-format
msgid ""
"Line height min: %f\n"
@@ -21302,7 +19151,7 @@
"Altura mínima de línea: %f \n"
"Altura máxima de línea: %f\n"
-#: ../vector/v.what/what.c:206
+#: ../vector/v.what/what.c:273
#, fuzzy, c-format
msgid ""
"Type: Area\n"
@@ -21311,12 +19160,12 @@
"Tipo de objeto: Área \n"
"Altura del área: %f\n"
-#: ../vector/v.what/what.c:210
+#: ../vector/v.what/what.c:281
#, fuzzy, c-format
msgid "Type: Area\n"
msgstr "Tipo de objeto: Área \n"
-#: ../vector/v.what/what.c:217
+#: ../vector/v.what/what.c:303
#, fuzzy, c-format
msgid ""
"Area: %d\n"
@@ -21325,17 +19174,17 @@
"Área: %d \n"
"Número de islas: %d\n"
-#: ../vector/v.what/what.c:222
+#: ../vector/v.what/what.c:313
#, c-format
msgid "Isle[%d]: %d\n"
-#: ../vector/v.what/what.c:229
+#: ../vector/v.what/what.c:326
#, c-format
msgid "Island: %d In area: %d\n"
msgstr "Isla: %d en área: %d\n"
-#: ../vector/v.what/what.c:234 ../vector/v.what/what.c:241
+#: ../vector/v.what/what.c:339 ../vector/v.what/what.c:346
#, fuzzy, c-format
msgid ""
"Sq Meters: %.3f\n"
@@ -21344,7 +19193,7 @@
"Metros cuadrados: %.3f\n"
"Hectáreas: %.3f\n"
-#: ../vector/v.what/what.c:236 ../vector/v.what/what.c:244
+#: ../vector/v.what/what.c:341 ../vector/v.what/what.c:349
#, fuzzy, c-format
msgid ""
"Acres: %.3f\n"
@@ -21353,7 +19202,7 @@
"Acres: %.3f\n"
"Millas cuadradas: %.4f\n"
-#: ../vector/v.what/what.c:262
+#: ../vector/v.what/what.c:372
#, fuzzy, c-format
msgid ""
"Layer: %d\n"
@@ -21362,7 +19211,7 @@
"Capa: %d\n"
"Categoría: %d\n"
-#: ../vector/v.what/what.c:269
+#: ../vector/v.what/what.c:386
#, c-format
msgid ""
"\n"
@@ -21401,16 +19250,17 @@
msgid "Print attribute information"
msgstr "Imprimir información de atributos"
-#: ../vector/v.what/main.c:155
+#: ../vector/v.what/main.c:159
#, c-format
msgid "You must build topology on vector map <%s>"
msgstr "Debe construir la topología en el mapa vectorial <%s>"
-#: ../vector/v.what/main.c:158 ../display/d.what.vect/main.c:154
+#: ../vector/v.what/main.c:162 ../vector/v.select/main.c:141
+#: ../display/d.what.vect/main.c:154
msgid "Building spatial index..."
msgstr "Construyendo el índice espacial..."
-#: ../vector/v.what/main.c:174
+#: ../vector/v.what/main.c:178
#, c-format
msgid "Unknown input format, skipping: '%s'"
msgstr "Formato de entrada desconocido, se salta: '%s'"
@@ -21530,21 +19380,21 @@
"Conexión a base de datos no definida para la capa %d. Use v.db.connect "
"primero."
-#: ../vector/v.to.db/update.c:81
+#: ../vector/v.to.db/update.c:82
msgid "Updating database..."
msgstr "Actualizando base de datos..."
-#: ../vector/v.to.db/update.c:113
+#: ../vector/v.to.db/update.c:115
#, fuzzy, c-format
msgid "More elements of category %d, nothing loaded to database"
msgstr "Más elementos de la categoría [%d], nada cargado a la base de datos"
-#: ../vector/v.to.db/update.c:211
+#: ../vector/v.to.db/update.c:213
#, fuzzy, c-format
msgid "Record (cat %d) already exists (not inserted)"
msgstr "Categoría [%d]: la fila ya existe (no se inserta)"
-#: ../vector/v.to.db/update.c:219 ../vector/v.to.3d/trans3.c:120
+#: ../vector/v.to.db/update.c:221 ../vector/v.to.3d/trans3.c:120
#, fuzzy, c-format
msgid "Record (cat %d) does not exist (not updated)"
msgstr "Categoría [%d]: la fila no existe (no se actualiza)"
@@ -21601,7 +19451,7 @@
msgid "Query layer number (read from)"
msgstr ""
-#: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:98
+#: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:99
msgid "Query"
msgstr "Consulta"
@@ -21609,94 +19459,102 @@
msgid "Value to upload"
msgstr "Valor a cargar"
-#: ../vector/v.to.db/parse.c:86
-msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-msgstr "mi(llas),f(pies),me(tros),k(ilómetros),a(cres),h(ectáreas)"
+#: ../vector/v.to.db/parse.c:87
+#, fuzzy
+msgid ""
+"mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
+msgstr ""
+"mi(llas),f(pies),me(tros),k(ilómetros),a(cres),h(ectáreas),p(orcentaje)"
-#: ../vector/v.to.db/parse.c:92
+#: ../vector/v.to.db/parse.c:93
#, fuzzy
msgid "Name of attribute column used for 'query' option"
msgstr "Columna de consulta usada para la opción 'query' (consulta)"
-#: ../vector/v.to.db/parse.c:93
+#: ../vector/v.to.db/parse.c:94
msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
msgstr "Ej.: 'categoría', 'cuenta(*)', 'suma(valores)'"
-#: ../vector/v.to.db/parse.c:102
+#: ../vector/v.to.db/parse.c:103
msgid "Print only"
msgstr "Sólo imprimir"
-#: ../vector/v.to.db/parse.c:107
+#: ../vector/v.to.db/parse.c:108
#, fuzzy
msgid "Only print SQL statements"
msgstr "Sólo imprimir sentencias SQL"
-#: ../vector/v.to.db/parse.c:113
+#: ../vector/v.to.db/parse.c:114
msgid "In print mode prints totals for options: length,area,count"
msgstr ""
"En modo impresión imprime totales para las opciones: longitud,área,cuenta"
-#: ../vector/v.to.db/parse.c:149
+#: ../vector/v.to.db/parse.c:150
msgid "This option requires one column"
msgstr "Esta opción requiere una columna"
-#: ../vector/v.to.db/parse.c:154
+#: ../vector/v.to.db/parse.c:155
msgid "This option requires two columns"
msgstr "Esta opción requiere dos columnas"
-#: ../vector/v.to.db/parse.c:159
+#: ../vector/v.to.db/parse.c:160
msgid "This option requires at least two columns"
msgstr "Esta opción requiere al menos dos columnas"
-#: ../vector/v.to.db/parse.c:165
+#: ../vector/v.to.db/parse.c:166
msgid "Parameter 'qcolumn' must be specified for 'option=query'"
msgstr "Se debe especificar el parámetro 'qcolumn' para 'option=query'"
-#: ../vector/v.to.db/parse.c:170
+#: ../vector/v.to.db/parse.c:171
msgid "The 'sides' option makes sense only for boundaries"
msgstr "La opción 'lados' sólo tiene sentido para perímetros"
-#: ../vector/v.to.db/parse.c:173
+#: ../vector/v.to.db/parse.c:174
#, fuzzy
msgid "The 'sinuous' option makes sense only for lines"
+#: ../vector/v.to.db/parse.c:177
+#, fuzzy
+msgid "The 'azimuth' option makes sense only for lines"
+msgstr "La opción 'lados' sólo tiene sentido para perímetros"
#: ../vector/v.to.db/areas.c:28 ../vector/v.to.rast/do_areas.c:33
#, fuzzy
msgid "Reading areas..."
msgstr "Leyendo datos..."
-#: ../vector/v.to.db/report.c:181
+#: ../vector/v.to.db/report.c:187
#, fuzzy, c-format
msgid "%d categories read from vector map (layer %d)"
msgstr "%d categorías leídas del mapa"
-#: ../vector/v.to.db/report.c:185
+#: ../vector/v.to.db/report.c:191
#, fuzzy, c-format
msgid "%d records selected from table (layer %d)"
msgstr "%d registros seleccionados de la tabla"
-#: ../vector/v.to.db/report.c:188
+#: ../vector/v.to.db/report.c:194
#, fuzzy, c-format
msgid "%d categories read from vector map exist in selection from table"
msgstr "%d categorías leídas del mapa existen en la selección de la tabla"
-#: ../vector/v.to.db/report.c:191
+#: ../vector/v.to.db/report.c:197
#, fuzzy, c-format
msgid "%d categories read from vector map don't exist in selection from table"
msgstr "%d categorías leídas del mapa no existen en la selección de la tabla"
-#: ../vector/v.to.db/report.c:193
+#: ../vector/v.to.db/report.c:199
#, fuzzy, c-format
msgid "%d records updated/inserted (layer %d)"
msgstr "%d registros actualizados/insertados"
-#: ../vector/v.to.db/report.c:196
+#: ../vector/v.to.db/report.c:202
#, fuzzy, c-format
msgid "%d update/insert errors (layer %d)"
msgstr "%d errores de actualización/inserción"
-#: ../vector/v.to.db/report.c:199
+#: ../vector/v.to.db/report.c:205
#, c-format
msgid "%d categories with more points (coordinates not loaded)"
msgstr "%d categorías con más puntos (coordenadas no cargadas)"
@@ -21706,7 +19564,7 @@
"No coordinates to generate the output! Maybe an empty vector type chosen?"
msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:575 ../vector/v.out.ogr/main.c:695
+#: ../vector/v.out.vtk/writeVTK.c:575 ../vector/v.out.ogr/main.c:698
#, c-format
msgid "Cannot select attributes for cat = %d"
msgstr "No se pueden seleccionar atributos para la categoría = %d"
@@ -21743,6 +19601,10 @@
msgid "Path to resulting VTK file"
msgstr "Ruta al archivo VTK resultante"
+#: ../vector/v.out.vtk/main.c:83
+msgid "Layer number"
+msgstr "Número de capa"
#: ../vector/v.out.vtk/main.c:93
msgid "Export numeric attribute table fields as VTK scalar variables"
msgstr ""
@@ -21817,58 +19679,113 @@
msgid "Unable to open history file for vector map <%s>"
msgstr "No se puede abrir el archivo histórico del vectorial <%s>"
-#: ../vector/v.select/main.c:136
+#: ../vector/v.select/main.c:52
#, fuzzy
-msgid "vector, query"
+msgid "vector, spatial query"
msgstr "vectorial, consultar"
-#: ../vector/v.select/main.c:138
+#: ../vector/v.select/main.c:54
#, fuzzy
msgid ""
"Selects features from vector map (A) by features from other vector map (B)."
msgstr ""
"Seleccionar elementos de la entrada A mediante elementos de la entrada B"
-#: ../vector/v.select/main.c:178
+#: ../vector/v.select/main.c:80
#, fuzzy
-msgid "Operator defines required relation between features"
-msgstr "Valores que describen la relación entre los dos elementos más próximos"
+msgid "Unknown operator"
+msgstr "Operación desconocida"
-#: ../vector/v.select/main.c:180
-#, fuzzy
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
+#: ../vector/v.select/main.c:83
+#, c-format
+msgid "Enable GEOS operators (flag '%c') to use '%s'"
msgstr ""
-"El elemento se escribe en la salida si el resultado de la operación 'entrada "
-"A operador entrada B' es verdadero. Un elemento de entrada se considera "
-"verdadero si se define la categoría de la capa dada."
-#: ../vector/v.select/main.c:182
-msgid "overlap;features partially or completely overlap"
-msgstr ""
+#: ../vector/v.select/main.c:122
+#, fuzzy
+msgid "Output from v.select"
+msgstr "Formato de salida"
-#: ../vector/v.select/main.c:322
+#: ../vector/v.select/main.c:170
+#, fuzzy, c-format
+msgid "Unable to read line id %d from vector map <%s>"
+msgstr "No se puede obtener información de la capa para el mapa vectorial <%s>"
+#: ../vector/v.select/main.c:276
#, fuzzy
msgid "Processing areas..."
-#: ../vector/v.select/main.c:443
+#: ../vector/v.select/main.c:299
+#, fuzzy, c-format
+msgid "Unable to read area id %d from vector map <%s>"
+msgstr "No se pueden procesar las áreas del mapa vectorial<%s>"
+#: ../vector/v.select/main.c:444
#, fuzzy
msgid "Writing selected features..."
-#: ../vector/v.select/main.c:509
+#: ../vector/v.select/main.c:510
#, fuzzy, c-format
msgid "Layer %d - no table"
msgstr "Capa <%s> no disponible"
-#: ../vector/v.select/main.c:524
+#: ../vector/v.select/main.c:525
#, fuzzy, c-format
msgid "Layer %d - unable to copy table"
msgstr "No se puede copiar la tabla"
+#: ../vector/v.select/main.c:540
+#, fuzzy, c-format
+msgid "%d features without category skipped"
+msgstr "%d puntos sin categoría saltados"
+#: ../vector/v.select/main.c:543
+#, fuzzy, c-format
+msgid "%d features written to output."
+msgstr "%ld bytes escritos a '%s'"
+#: ../vector/v.select/args.c:45
+#, fuzzy
+msgid "Operator defines required relation between features"
+msgstr "Valores que describen la relación entre los dos elementos más próximos"
+#: ../vector/v.select/args.c:47
+#, fuzzy
+msgid ""
+"A feature is written to output if the result of operation 'ainput operator "
+"binput' is true. An input feature is considered to be true, if category of "
+"given layer is defined."
+msgstr ""
+"El elemento se escribe en la salida si el resultado de la operación 'entrada "
+"A operador entrada B' es verdadero. Un elemento de entrada se considera "
+"verdadero si se define la categoría de la capa dada."
+#: ../vector/v.select/args.c:52
+msgid "overlap;features partially or completely overlap"
+msgstr ""
+#: ../vector/v.select/args.c:57
+msgid ""
+"equals;features are spatially equals (requires flag 'g');disjoint;features "
+"do not spatially intersect (requires flag 'g');intersects;features spatially "
+"intersect (requires flag 'g');touches;features spatially touches (requires "
+"flag 'g');crosses;features spatially crosses (requires flag 'g');within;"
+"feature A is completely inside feature B (requires flag 'g');contains;"
+"feature B is completely inside feature A (requires flag 'g');overlap;"
+"features spatilly overlap;relate;feature A is spatially related to feature B "
+"(requires 'relate' option and flag 'g');"
+msgstr ""
+#: ../vector/v.select/args.c:73
+msgid "Intersection Matrix Pattern used for 'relate' operator"
+msgstr ""
+#: ../vector/v.select/args.c:87
+msgid "Use GEOS operators"
+msgstr ""
#: ../vector/v.net.alloc/main.c:63
msgid "Allocate subnets for nearest centres (direction from centre)."
msgstr ""
@@ -22110,90 +20027,100 @@
msgid "Perform cross-validation procedure without raster approximation"
msgstr "Realiza un procedimiento de validación cruzada sin aproximación ráster"
-#: ../vector/v.surf.rst/main.c:193
+#: ../vector/v.surf.rst/main.c:194
msgid "Use scale dependent tension"
msgstr "Usar tensión dependiente de la escala"
-#: ../vector/v.surf.rst/main.c:214
-msgid ""
-"Name of the attribute column with values to be used for approximation (if "
-"layer>0)"
-msgstr ""
-"Nombre de la columna de atributos con valores a usar para la aproximación "
-"(si capa>0)"
+#: ../vector/v.surf.rst/main.c:201 ../vector/v.surf.rst/main.c:219
+#: ../vector/v.surf.rst/main.c:225 ../vector/v.surf.rst/main.c:231
+#: ../vector/v.surf.rst/main.c:237 ../vector/v.surf.rst/main.c:243
+#: ../vector/v.surf.rst/main.c:249 ../vector/v.surf.rst/main.c:257
+#: ../vector/v.surf.rst/main.c:264 ../vector/v.surf.rst/main.c:271
+#: ../vector/v.surf.rst/main.c:278
+#, fuzzy
+msgid "Outputs"
+msgstr "Salida:"
-#: ../vector/v.surf.rst/main.c:221
+#: ../vector/v.surf.rst/main.c:218
msgid "Output surface raster map (elevation)"
msgstr "Producir mapa ráster de superficie (elevación)"
-#: ../vector/v.surf.rst/main.c:226
+#: ../vector/v.surf.rst/main.c:224
msgid "Output slope raster map"
msgstr "Producir mapa ráster de pendiente"
-#: ../vector/v.surf.rst/main.c:232
+#: ../vector/v.surf.rst/main.c:230
msgid "Output aspect raster map"
msgstr "Producir mapa ráster de orientación"
-#: ../vector/v.surf.rst/main.c:238
+#: ../vector/v.surf.rst/main.c:236
msgid "Output profile curvature raster map"
msgstr "Producir mapa ráster de curvatura de perfil"
-#: ../vector/v.surf.rst/main.c:244
+#: ../vector/v.surf.rst/main.c:242
msgid "Output tangential curvature raster map"
msgstr "Producir mapa ráster de curvatura tangencial"
-#: ../vector/v.surf.rst/main.c:250
+#: ../vector/v.surf.rst/main.c:248
msgid "Output mean curvature raster map"
msgstr "Producir mapa ráster de curvatura media"
-#: ../vector/v.surf.rst/main.c:278
+#: ../vector/v.surf.rst/main.c:263
+msgid "Output cross-validation errors vector point file"
+msgstr "Producir archivo de puntos vectorial de errores de validación cruzada"
+#: ../vector/v.surf.rst/main.c:270
+#, fuzzy
+msgid "Output vector map showing quadtree segmentation"
+msgstr "Producir mapa vectorial que muestre segmentación quadtree"
+#: ../vector/v.surf.rst/main.c:277
+msgid "Output vector map showing overlapping windows"
+msgstr "Producir mapa vectorial que muestre ventanas solapadas"
+#: ../vector/v.surf.rst/main.c:291
+msgid ""
+"Name of the attribute column with values to be used for approximation (if "
+"layer>0)"
+msgstr ""
+"Nombre de la columna de atributos con valores a usar para la aproximación "
+"(si capa>0)"
+#: ../vector/v.surf.rst/main.c:314
msgid "Name of the attribute column with smoothing parameters"
msgstr "Nombre de la columna de atributos con los parámetros de suavizado"
-#: ../vector/v.surf.rst/main.c:313
+#: ../vector/v.surf.rst/main.c:349
msgid ""
"Maximum distance between points on isoline (to insert additional points)"
msgstr ""
"Distancia mínima entre puntos en isolíneas (para insertar puntos adicionales)"
-#: ../vector/v.surf.rst/main.c:322
+#: ../vector/v.surf.rst/main.c:358
msgid "Conversion factor for values used for approximation"
msgstr "Factor de conversión para valores usados para aproximación"
-#: ../vector/v.surf.rst/main.c:337
-msgid "Output cross-validation errors vector point file"
-msgstr "Producir archivo de puntos vectorial de errores de validación cruzada"
-#: ../vector/v.surf.rst/main.c:344
-#, fuzzy
-msgid "Output vector map showing quadtree segmentation"
-msgstr "Producir mapa vectorial que muestre segmentación quadtree"
-#: ../vector/v.surf.rst/main.c:351
-msgid "Output vector map showing overlapping windows"
-msgstr "Producir mapa vectorial que muestre ventanas solapadas"
-#: ../vector/v.surf.rst/main.c:359
+#: ../vector/v.surf.rst/main.c:366
msgid "Anisotropy angle (in degrees counterclockwise from East)"
msgstr "Ángulo de anisotropía (en grados en sentido horario desde el Este)"
-#: ../vector/v.surf.rst/main.c:394 ../vector/v.surf.rst/main.c:399
-#: ../vector/v.surf.rst/main.c:404 ../vector/v.surf.rst/main.c:409
+#: ../vector/v.surf.rst/main.c:401 ../vector/v.surf.rst/main.c:406
+#: ../vector/v.surf.rst/main.c:411 ../vector/v.surf.rst/main.c:416
#, fuzzy, c-format
msgid "Output vector map name <%s> is not valid map name"
msgstr "El nombre del vectorial de salida no se especificó"
-#: ../vector/v.surf.rst/main.c:422
+#: ../vector/v.surf.rst/main.c:429
#, fuzzy
msgid "You are not outputting any raster or vector maps"
msgstr "No se está produciendo ningún mapa ráster ni vectorial"
-#: ../vector/v.surf.rst/main.c:426 ../vector/v.extract/main.c:274
+#: ../vector/v.surf.rst/main.c:433 ../vector/v.extract/main.c:274
#: ../display/d.vect/main.c:492
msgid "'layer' must be > 0 for 'where'."
msgstr "'layer' (capa) debe ser >0 para 'where' (donde)."
-#: ../vector/v.surf.rst/main.c:435
+#: ../vector/v.surf.rst/main.c:442
msgid ""
"Both cross-validation options (-c flag and cvdev vector output) must be "
"specified"
@@ -22201,7 +20128,7 @@
"Se deben especificar las dos opciones de validación cruzada (opción -c y "
"salida vectorial cvdev)"
-#: ../vector/v.surf.rst/main.c:438
+#: ../vector/v.surf.rst/main.c:445
msgid ""
"The cross-validation cannot be computed simultaneously with output raster or "
"devi file"
@@ -22209,36 +20136,36 @@
"La validación cruzada no se puede procesar de forma simultánea a la salida "
"ráster o archivo devi"
-#: ../vector/v.surf.rst/main.c:456
+#: ../vector/v.surf.rst/main.c:463
msgid "Using anisotropy - both theta and scalex have to be specified"
msgstr "Usando anisotropía se deben especificar tanto theta como scalex"
-#: ../vector/v.surf.rst/main.c:464
+#: ../vector/v.surf.rst/main.c:471
msgid "Both smatt and smooth options specified - using constant"
msgstr "Constantes smatt y smooth especificadas - se usa una constante"
-#: ../vector/v.surf.rst/main.c:474
+#: ../vector/v.surf.rst/main.c:481
msgid "The computation will last too long - lower npmin is suggested"
msgstr "El procesado tardará demasiado - se sugiere un npmin más bajo"
-#: ../vector/v.surf.rst/main.c:521
+#: ../vector/v.surf.rst/main.c:528
#, fuzzy
msgid "Cannot create quaddata"
msgstr "No se pueden crear datos quad"
-#: ../vector/v.surf.rst/main.c:527
+#: ../vector/v.surf.rst/main.c:534
msgid "Cannot create quadfunc"
msgstr "No se puede crear función quad"
-#: ../vector/v.surf.rst/main.c:530
+#: ../vector/v.surf.rst/main.c:537
msgid "Cannot create tree"
msgstr "No se puede crear el árbol"
-#: ../vector/v.surf.rst/main.c:534
+#: ../vector/v.surf.rst/main.c:541
msgid "Cannot create tree info"
msgstr "No se puede crear información del árbol"
-#: ../vector/v.surf.rst/main.c:727
+#: ../vector/v.surf.rst/main.c:734
#, c-format
msgid ""
"Processing all selected output files\n"
@@ -22247,11 +20174,11 @@
"Procesar todos los archivos de salida seleccionados\n"
"necesitará %d bytes en disco para archivos temporales"
-#: ../vector/v.surf.rst/main.c:751
+#: ../vector/v.surf.rst/main.c:758
msgid "Interp_segmets failed"
msgstr "falló Interp_segmets"
-#: ../vector/v.surf.rst/main.c:768
+#: ../vector/v.surf.rst/main.c:775
msgid "Cannot write raster maps -- try to increase resolution"
msgstr ""
"No se pueden escribir los mapas ráster -- intente aumentar la resolución"
@@ -22674,17 +20601,22 @@
msgid "The combination of types is not supported by all formats."
msgstr "La combinación de tipos no está soportada por todos lo formatos."
-#: ../vector/v.out.ogr/main.c:246
+#: ../vector/v.out.ogr/main.c:218
+msgid ""
+"The map contains islands. To preserve them in the output map, use the -c flag"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:249
#, fuzzy, c-format
msgid "OGR driver <%s> not found"
msgstr "Controlador %s no encontrado"
-#: ../vector/v.out.ogr/main.c:263
+#: ../vector/v.out.ogr/main.c:266
#, fuzzy, c-format
msgid "Unable to open OGR data source '%s'"
msgstr "No se puede abrir el origen de datos <%s>"
-#: ../vector/v.out.ogr/main.c:284 ../vector/v.out.ogr/main.c:291
+#: ../vector/v.out.ogr/main.c:287 ../vector/v.out.ogr/main.c:294
#, c-format
msgid ""
"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
@@ -22694,23 +20626,23 @@
"para el formato (parámetro 'Ico') para exportar en 3D en vez de 2D "
"(predeterminado)."
-#: ../vector/v.out.ogr/main.c:303
+#: ../vector/v.out.ogr/main.c:306
#, fuzzy
msgid "Unable to create OGR layer"
msgstr "No se puede crear la cara"
-#: ../vector/v.out.ogr/main.c:312
+#: ../vector/v.out.ogr/main.c:315
msgid "No attribute table found -> using only category numbers as attributes"
msgstr ""
"No se encontró ninguna tabla de atributos -> sólo se usan los números de "
"categoría como atributos"
-#: ../vector/v.out.ogr/main.c:374
+#: ../vector/v.out.ogr/main.c:377
#, c-format
msgid "Key column '%s' not found"
msgstr "Columna clave '%s' no encontrada"
-#: ../vector/v.out.ogr/main.c:386
+#: ../vector/v.out.ogr/main.c:389
#, fuzzy, c-format
msgid ""
"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
@@ -22718,7 +20650,7 @@
"%d punto(s) encontrado(s), pero no se ha solicitado exportarlos. Verificar "
"el parámetro 'tipo'."
-#: ../vector/v.out.ogr/main.c:391
+#: ../vector/v.out.ogr/main.c:394
#, fuzzy, c-format
msgid ""
"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
@@ -22726,7 +20658,7 @@
"%d línea(s) encontrada(s), pero no se ha solicitado exportarlas. Verificar "
-#: ../vector/v.out.ogr/main.c:397
+#: ../vector/v.out.ogr/main.c:400
#, fuzzy, c-format
msgid ""
"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
@@ -22735,7 +20667,7 @@
"%d límite(s) encontrado(s), pero no se ha solicitado exportarlos. Verificar "
-#: ../vector/v.out.ogr/main.c:403
+#: ../vector/v.out.ogr/main.c:406
#, fuzzy, c-format
msgid ""
"%d centroid(s) found, but not requested to be exported. Verify 'type' "
@@ -22744,7 +20676,7 @@
"%d centroide(s) encontrado(s), pero no se ha solicitado exportarlos. "
"Verificar el parámetro 'tipo'."
-#: ../vector/v.out.ogr/main.c:408
+#: ../vector/v.out.ogr/main.c:411
#, fuzzy, c-format
msgid ""
"%d areas found, but not requested to be exported. Verify 'type' parameter."
@@ -22752,7 +20684,7 @@
"%d superficie(s) encontrada(s), pero no se ha solicitado exportarlas. "
-#: ../vector/v.out.ogr/main.c:413
+#: ../vector/v.out.ogr/main.c:416
#, fuzzy, c-format
msgid ""
"%d faces found, but not requested to be exported. Verify 'type' parameter."
@@ -22760,32 +20692,32 @@
"%d cara(s) encontrada(s), pero no se ha solicitado exportarlas. Verificar el "
"parámetro 'tipo'."
-#: ../vector/v.out.ogr/main.c:421
+#: ../vector/v.out.ogr/main.c:424
#, c-format
msgid "Exporting %i points/lines..."
msgstr "Exportando %i puntos/líneas..."
-#: ../vector/v.out.ogr/main.c:499
+#: ../vector/v.out.ogr/main.c:502
#, fuzzy, c-format
msgid "Exporting %i areas (may take some time)..."
msgstr "Exportando %i superficies (puede llevar algún tiempo) ..."
-#: ../vector/v.out.ogr/main.c:571
+#: ../vector/v.out.ogr/main.c:574
#, c-format
msgid "Exporting %i faces (may take some time) ..."
msgstr "Exportando %i caras (puede llevar algún tiempo) ..."
-#: ../vector/v.out.ogr/main.c:643
+#: ../vector/v.out.ogr/main.c:646
#, fuzzy, c-format
msgid "%d features without category were written"
-#: ../vector/v.out.ogr/main.c:645
+#: ../vector/v.out.ogr/main.c:648
#, fuzzy, c-format
msgid "%d features without attributes were written"
-#: ../vector/v.out.ogr/main.c:647
+#: ../vector/v.out.ogr/main.c:650
#, fuzzy, c-format
msgid "%d features found without category were skipped"
@@ -23385,7 +21317,7 @@
"Crear un buffer alrededor de los elementos de tipo dado (las áreas deben "
"contener centroide)."
-#: ../vector/v.buffer/main.c:271
+#: ../vector/v.buffer/main.c:271 ../vector/v.buffer2/main.c:221
msgid "Buffer distance in map units"
msgstr "Distancia de buffer en unidades de mapa"
@@ -23409,7 +21341,7 @@
msgid "Stop the process at a certain stage"
msgstr "Detener el proceso en un estado determinado"
-#: ../vector/v.buffer/main.c:319 ../vector/v.buffer2/main.c:228
+#: ../vector/v.buffer/main.c:319 ../vector/v.buffer2/main.c:247
msgid ""
"The bufcol option may contain bugs during the cleaning step. If you "
"encounter problems, use the debug option or clean manually with v.clean "
@@ -23421,8 +21353,8 @@
"type=area"
#: ../vector/v.buffer/main.c:335 ../vector/v.buffer/main.c:485
-#: ../vector/v.buffer/main.c:562 ../vector/v.buffer2/main.c:378
-#: ../vector/v.buffer2/main.c:444
+#: ../vector/v.buffer/main.c:562 ../vector/v.buffer2/main.c:406
+#: ../vector/v.buffer2/main.c:472
#, c-format
msgid "The tolerance in map units: %g"
msgstr "La tolerancia en unidades de mapa: %g"
@@ -23437,7 +21369,7 @@
msgstr "Buffers de líneas... "
#: ../vector/v.buffer/main.c:473 ../vector/v.buffer/main.c:550
-#: ../vector/v.buffer2/main.c:364 ../vector/v.buffer2/main.c:430
+#: ../vector/v.buffer2/main.c:392 ../vector/v.buffer2/main.c:458
#, c-format
msgid "Attribute is of invalid size (%.3f) for category %d"
msgstr "Atributo de tamaño no válido (%.3f) para la categoría %d"
@@ -23451,15 +21383,15 @@
msgid "Areas buffers... "
msgstr "Buffers de áreas... "
-#: ../vector/v.buffer/main.c:607 ../vector/v.buffer2/main.c:468
+#: ../vector/v.buffer/main.c:607 ../vector/v.buffer2/main.c:496
msgid "Building parts of topology..."
msgstr "Construyendo partes de la topología..."
-#: ../vector/v.buffer/main.c:619 ../vector/v.buffer2/main.c:471
+#: ../vector/v.buffer/main.c:619 ../vector/v.buffer2/main.c:499
msgid "Snapping boundaries..."
msgstr "Autoensamblando contornos..."
-#: ../vector/v.buffer/main.c:622 ../vector/v.buffer2/main.c:474
+#: ../vector/v.buffer/main.c:622 ../vector/v.buffer2/main.c:502
msgid "Breaking boundaries..."
msgstr "Rompiendo los bordes..."
@@ -23845,39 +21777,60 @@
msgid "Name of column to use for buffer distances"
msgstr "Columna de atributos a usar para distancias de buffer"
-#: ../vector/v.buffer2/main.c:208
+#: ../vector/v.buffer2/main.c:212
+msgid "This does nothing. It is retained for backwards compatibility"
+msgstr ""
+#: ../vector/v.buffer2/main.c:219
+msgid ""
+"This is an alias to the distance option. It is retained for backwards "
+"compatibility"
+msgstr ""
+#: ../vector/v.buffer2/main.c:226
msgid "Make outside corners straight"
msgstr ""
-#: ../vector/v.buffer2/main.c:212
+#: ../vector/v.buffer2/main.c:230
msgid "Don't make caps at the ends of polylines"
msgstr ""
-#: ../vector/v.buffer2/main.c:224
+#: ../vector/v.buffer2/main.c:243
msgid "Select a buffer distance/minordistance/angle or column, but not both."
msgstr ""
-#: ../vector/v.buffer2/main.c:235
+#: ../vector/v.buffer2/main.c:253
+msgid ""
+"The buffer option has been replaced by the distance option and will be "
+"removed in future."
+msgstr ""
+#: ../vector/v.buffer2/main.c:256
+#, fuzzy
+msgid "Use the distance option instead of the buffer option."
+msgstr "Usar radianes en vez de grados para la rotación"
+#: ../vector/v.buffer2/main.c:260
#, fuzzy, c-format
msgid "The tolerance was reset to %g"
msgstr "Se restableció la tolerancia a %g (unidades de mapa)"
-#: ../vector/v.buffer2/main.c:256
+#: ../vector/v.buffer2/main.c:284
#, fuzzy, c-format
msgid "The tolerance in map units = %g"
-#: ../vector/v.buffer2/main.c:301
+#: ../vector/v.buffer2/main.c:329
#, fuzzy, c-format
msgid "Unable to select data from table <%s>"
msgstr "No se pueden seleccionar datos de la tabla"
-#: ../vector/v.buffer2/main.c:341
+#: ../vector/v.buffer2/main.c:369
#, fuzzy
msgid "Buffering lines..."
msgstr "Rompiendo líneas..."
-#: ../vector/v.buffer2/main.c:408
+#: ../vector/v.buffer2/main.c:436
#, fuzzy
msgid "Buffering areas..."
msgstr "Elevando áreas..."
@@ -23933,7 +21886,7 @@
msgid "Read error in vector map"
msgstr "Error de lectura en el mapa vectorial"
-#: ../ps/ps.map/ps_vlines.c:118 ../ps/ps.map/ps_vareas.c:100
+#: ../ps/ps.map/ps_vlines.c:118 ../ps/ps.map/ps_vareas.c:101
#: ../ps/ps.map/ps_vpoints.c:164 ../ps/ps.map/ps_vpoints.c:175
#: ../ps/ps.map/ps_vpoints.c:199 ../ps/ps.map/ps_vpoints.c:240
#: ../ps/ps.map/ps_vpoints.c:250
@@ -23941,7 +21894,7 @@
msgid "No record for category [%d]"
msgstr "No hay registro para la categoría [%d]"
-#: ../ps/ps.map/ps_vlines.c:124 ../ps/ps.map/ps_vareas.c:106
+#: ../ps/ps.map/ps_vlines.c:124 ../ps/ps.map/ps_vareas.c:107
#: ../ps/ps.map/ps_vpoints.c:205
#, c-format
msgid "Invalid RGB color definition in column <%s> for category [%d]"
@@ -23985,10 +21938,11 @@
msgstr "No se pueden leer los colores para la barra de colores"
#: ../ps/ps.map/ps_clrtbl.c:47
+#, fuzzy
msgid ""
"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using CELL rasters. No colortable will be "
-"assigned to this output postscript file."
+"required for 'colortable' when using categorical legends; see the r.category "
+"help page. Colortable creation has been skipped."
msgstr ""
"Su archivo de categorías no es válido. Se requiere un archivo de categorías "
"y etiquetas para la 'tabla de color' cuando se usan rásters CELL. No se "
@@ -24796,60 +22750,81 @@
"Programa de Análisis de Componentes Principales (PCA) para el procesado de "
"imágenes."
-#: ../imagery/i.pca/main.c:78
-msgid "Rescaling range output (For no rescaling use 0,0)"
+#: ../imagery/i.pca/main.c:69
+#, fuzzy
+msgid "Name of two or more input raster maps"
+msgstr "Nombre del mapa ráster de entrada"
+#: ../imagery/i.pca/main.c:72
+#, fuzzy
+msgid "Base name for output raster maps"
+msgstr "Nombre para el mapa ráster de salida"
+#: ../imagery/i.pca/main.c:74
+#, fuzzy
+msgid "A numerical suffix will be added for each component map"
+msgstr "Número de niveles a usar para cada componente"
+#: ../imagery/i.pca/main.c:83
+#, fuzzy
+msgid "Rescaling range for output maps (for no rescaling use 0,0)"
msgstr "Re-escalar rango de salida (para no re-escalar use 0,0)"
-#: ../imagery/i.pca/main.c:87
+#: ../imagery/i.pca/main.c:93
msgid "Sorry, at least 2 input bands must be provided"
msgstr "Lo siento, se deben facilitar al menos dos bandas de entrada"
-#: ../imagery/i.pca/main.c:130
+#: ../imagery/i.pca/main.c:136
#, fuzzy
msgid "Calculating covariance matrix..."
msgstr "Calculando la matriz de covarianza:"
-#: ../imagery/i.pca/main.c:206
+#: ../imagery/i.pca/main.c:212
#, fuzzy
msgid "Scale range length should be > 0. Using default values: 0,255."
msgstr ""
"La longitud del rango de escala debe ser >0. Se usan los valores por "
"defecto: 0,255"
-#: ../imagery/i.pca/main.c:243 ../imagery/i.pca/main.c:292
-#: ../imagery/i.pca/main.c:425
+#: ../imagery/i.pca/main.c:249 ../imagery/i.pca/main.c:299
+#: ../imagery/i.pca/main.c:434
#, fuzzy
msgid "Unable allocate memory for row buffer"
msgstr "No se puede asignar memoria para el buffer de filas"
-#: ../imagery/i.pca/main.c:245
+#: ../imagery/i.pca/main.c:251
#, fuzzy, c-format
-msgid "Computing Means for band %d..."
+msgid "Computing means for band %d..."
msgstr "Calculando medias para la banda %d:"
-#: ../imagery/i.pca/main.c:294
+#: ../imagery/i.pca/main.c:301
#, fuzzy, c-format
msgid "Computing row %d of covariance matrix..."
msgstr "Calculando la fila %d de la matriz de covarianza:"
-#: ../imagery/i.pca/main.c:310
+#: ../imagery/i.pca/main.c:319
#, fuzzy
msgid "Unable to allocate memory for row buffer"
-#: ../imagery/i.pca/main.c:373
+#: ../imagery/i.pca/main.c:381
#, fuzzy
msgid "Unable to allocate memory for raster row"
msgstr "No se puede asignar memoria para la fila del ráster"
-#: ../imagery/i.pca/main.c:401
+#: ../imagery/i.pca/main.c:390
#, fuzzy, c-format
-msgid "Rescaling the data <%s> to range %d,%d..."
+msgid "Transforming <%s>..."
+msgstr "Trasponiendo la matriz de valores propios..."
+#: ../imagery/i.pca/main.c:409
+#, fuzzy, c-format
+msgid "Rescaling <%s> to range %d,%d..."
msgstr "%s: reescalando los datos al rango [%d, %d]:"
-#: ../imagery/i.pca/support.c:43
-msgid "Eigen values:"
-msgstr "Valores Eigen:"
+#: ../imagery/i.pca/support.c:44
+msgid "Eigen values, (vectors), and [percent importance]:"
+msgstr ""
#: ../imagery/i.class/complete_reg.c:12
msgid "Too few points for region. Must have at least 3 points."
@@ -26372,6 +24347,27 @@
msgid "Unable to map image file"
msgstr "No se puede mapear el archivo de imagen"
+#: ../visualization/ximgview/main.c:270 ../display/d.histogram/main.c:71
+#: ../display/d.mapgraph/main.c:48 ../display/d.erase/main.c:32
+#: ../display/d.profile/main.c:61 ../display/d.measure/main.c:49
+#: ../display/d.colors/main.c:50 ../display/d.what.vect/main.c:54
+#: ../display/d.font/main.c:46 ../display/d.rast.num/number.c:84
+#: ../display/d.linegraph/linegraph.c:113 ../display/d.colorlist/main.c:35
+#: ../display/d.what.rast/main.c:52 ../display/d.title/main.c:45
+#: ../display/d.geodesic/main.c:45 ../display/d.text/main.c:66
+#: ../display/d.font.freetype/main.c:59 ../display/d.info/main.c:34
+#: ../display/d.save/main.c:79 ../display/d.rast.arrow/arrow.c:110
+#: ../display/d.menu/main.c:66 ../display/d.thematic.area/main.c:78
+#: ../display/d.text.freetype/main.c:138 ../display/d.extract/main.c:50
+#: ../display/d.rgb/main.c:55 ../display/d.where/main.c:42
+#: ../display/d.paint.labels/main.c:46 ../display/d.text.new/main.c:139
+#: ../display/d.ask/main.c:36 ../display/d.his/main.c:65
+#: ../display/d.zoom/main.c:57 ../display/d.rhumbline/main.c:45
+#: ../display/d.nviz/main.c:68 ../display/d.mon/cmd/main.c:48
+#: ../display/d.frame/frame.c:60
+msgid "display"
+msgstr "mostrar"
#: ../visualization/ximgview/main.c:271
msgid "View BMP images from the PNG driver."
msgstr "Ver imágenes BMP desde el controlador PNG."
@@ -26452,42 +24448,47 @@
msgid "Quickstart - Do not load any data"
msgstr "Inicio rápido - No cargar ningún dato"
-#: ../visualization/nviz/src/nviz_init.c:104
-msgid "Script kill option"
-msgstr "Opción de matar el script"
+#: ../visualization/nviz/src/nviz_init.c:105
+msgid "Exit after completing script launched from the command line"
+msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:108
-msgid "Start in Demo mode"
-msgstr "Empezar en modo Demo"
+#: ../visualization/nviz/src/nviz_init.c:110
+msgid "Start in Demo mode (skip the \"please wait\" message)"
+msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:112
-msgid "Output more comments (default=quiet)"
-msgstr "Mostrar más comentarios (por omisión=silencio)"
+#: ../visualization/nviz/src/nviz_init.c:114
+#, fuzzy
+msgid "Verbose module output"
+msgstr "Modo verboso"
-#: ../visualization/nviz/src/nviz_init.c:118
+#: ../visualization/nviz/src/nviz_init.c:120
msgid "Set alternative panel path"
msgstr "Establecer ruta de panel alternativa"
-#: ../visualization/nviz/src/nviz_init.c:124
+#: ../visualization/nviz/src/nviz_init.c:126
msgid "Execute script file at startup"
msgstr "Ejecutar archivo de comandos al inicio"
-#: ../visualization/nviz/src/nviz_init.c:130
+#: ../visualization/nviz/src/nviz_init.c:132
#, fuzzy
msgid "Load previously saved state file"
msgstr "Cargar archivo de estado guardado previamente"
-#: ../visualization/nviz/src/nviz_init.c:279
+#: ../visualization/nviz/src/nviz_init.c:286
msgid "Number of elevation files does not match number of colors files"
msgstr ""
"El número de archivos de elevación no se ajusta al número de archivos de "
"colores"
-#: ../visualization/nviz/src/nviz_init.c:290
+#: ../visualization/nviz/src/nviz_init.c:297
#, fuzzy
msgid "Loading data failed"
msgstr "Leyendo datos: "
+#: ../visualization/nviz/src/nviz_init.c:405
+msgid "Entering script mode ..."
+msgstr ""
#: ../visualization/nviz2/cmd/vector.c:181
#, fuzzy
msgid "Unknown icon marker"
@@ -26574,6 +24575,10 @@
msgid "Image"
msgstr "Imágenes"
+#: ../visualization/nviz2/cmd/args.c:87
+msgid "Graphics file format"
+msgstr "Formato de archivo gráfico"
#: ../visualization/nviz2/cmd/args.c:97
#, fuzzy
msgid "Width and height of output image"
@@ -26856,6 +24861,14 @@
msgid "Cannot use current window"
msgstr "No se puede usar la ventana actual"
+#: ../display/d.rast.edit/main.c:59 ../display/d.rast/main.c:51
+msgid "display, raster"
+msgstr "mostrar ráster"
+#: ../display/d.rast.edit/main.c:61
+msgid "Interactively edit cell values in a raster map."
+msgstr "Editar valores de celda de forma interactiva en un mapa ráster."
#: ../display/d.histogram/main.c:73
msgid ""
"Displays a histogram in the form of a pie or bar chart for a user-specified "
@@ -27083,67 +25096,67 @@
msgid "warning: %s - vector map not found\n"
msgstr "atención: %s - mapa vectorial encontrado\n"
-#: ../display/d.what.vect/what.c:231
+#: ../display/d.what.vect/what.c:237
#, c-format
msgid "Line: %d Type: %s Left: %d Right: %d "
msgstr "Línea: %d Tipo: %s Izquierda: %d Derecha: %d "
-#: ../display/d.what.vect/what.c:251
+#: ../display/d.what.vect/what.c:257
#, c-format
msgid " Node[%d]: %d Number of lines: %d Coordinates: %.6f, %.6f, %.6f\n"
msgstr " Nodo[%d]: %d Número de líneas: %d Coordenadas: %.6f, %.6f, %.6f\n"
-#: ../display/d.what.vect/what.c:260
+#: ../display/d.what.vect/what.c:266
#, c-format
msgid " Line: %5d Angle: %.8f\n"
msgstr " Línea: %5d Ángulo: %.8f\n"
-#: ../display/d.what.vect/what.c:269
+#: ../display/d.what.vect/what.c:275
#, c-format
msgid "length %f\n"
msgstr "longitud %f\n"
-#: ../display/d.what.vect/what.c:316
+#: ../display/d.what.vect/what.c:322
#, c-format
msgid "Line height min: %f max: %f\n"
msgstr "Altura de la línea: mínimo: %f máximo: %f\n"
-#: ../display/d.what.vect/what.c:337
+#: ../display/d.what.vect/what.c:343
#, c-format
msgid "Area height: %f\n"
msgstr "Altura del área: %f\n"
-#: ../display/d.what.vect/what.c:346
+#: ../display/d.what.vect/what.c:352
#, c-format
msgid "Area\n"
msgstr "Área\n"
-#: ../display/d.what.vect/what.c:361
+#: ../display/d.what.vect/what.c:374
#, c-format
msgid "Area: %d Number of isles: %d\n"
msgstr "Área: %d Número de islas: %d\n"
-#: ../display/d.what.vect/what.c:366
+#: ../display/d.what.vect/what.c:379
#, c-format
msgid " Isle[%d]: %d\n"
msgstr " Isla[%d]: %d\n"
-#: ../display/d.what.vect/what.c:373
+#: ../display/d.what.vect/what.c:386
#, c-format
-#: ../display/d.what.vect/what.c:380 ../display/d.what.vect/what.c:389
+#: ../display/d.what.vect/what.c:393 ../display/d.what.vect/what.c:401
#, c-format
msgid "Size - Sq Meters: %.3f\t\tHectares: %.3f\n"
msgstr "Tamaño - Metros cuadrados: %.3f\t\tHectáreas: %.3f\n"
-#: ../display/d.what.vect/what.c:384 ../display/d.what.vect/what.c:393
+#: ../display/d.what.vect/what.c:397 ../display/d.what.vect/what.c:405
#, c-format
msgid " Acres: %.3f\t\tSq Miles: %.4f\n"
msgstr " Acres: %.3f\t\tMIllas cuadradas: %.4f\n"
-#: ../display/d.what.vect/what.c:422
+#: ../display/d.what.vect/what.c:433
#, c-format
msgid ""
"Layer: %d\n"
@@ -27152,7 +25165,7 @@
"Capa: %d\n"
"categoría: %d\n"
-#: ../display/d.what.vect/what.c:447
+#: ../display/d.what.vect/what.c:458
#, c-format
msgid ""
"driver: %s\n"
@@ -27165,7 +25178,7 @@
"tabla: %s\n"
"columna de clave: %s\n"
-#: ../display/d.what.vect/what.c:512
+#: ../display/d.what.vect/what.c:523
#, c-format
msgid ""
"\n"
@@ -27176,22 +25189,22 @@
"Pulsar el botón del ratón en el lugar deseado\n"
"\n"
-#: ../display/d.what.vect/what.c:517
+#: ../display/d.what.vect/what.c:528
#, c-format
msgid "Buttons\n"
msgstr "Botones\n"
-#: ../display/d.what.vect/what.c:518
+#: ../display/d.what.vect/what.c:529
#, c-format
msgid " Left: what's here\n"
msgstr " Izquierda: qué hay aquí\n"
-#: ../display/d.what.vect/what.c:520
+#: ../display/d.what.vect/what.c:531
#, c-format
msgid " Middle: toggle flash color\n"
msgstr " Centro: fijar color de parpadeo\n"
-#: ../display/d.what.vect/what.c:525
+#: ../display/d.what.vect/what.c:536
#, c-format
msgid " Right: quit\n"
msgstr " Derecha: salir\n"
@@ -27656,6 +25669,10 @@
msgstr ""
"Mostrar una leyenda para un mapa ráster en el marco activo de la pantalla."
+#: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:90
+msgid "Name of raster map"
+msgstr "Nombre del mapa ráster"
#: ../display/d.legend/main.c:99
msgid "Sets the legend's text color"
msgstr "Establece el color de texto de la leyenda"
@@ -27706,6 +25723,10 @@
msgid "Draw smooth gradient"
msgstr "Dibujar gradiente suave"
+#: ../display/d.legend/main.c:184
+msgid "Flip legend"
+msgstr "Dar la vuelta a la leyenda"
#: ../display/d.legend/main.c:205 ../display/d.menu/main.c:113
#: ../display/d.menu/main.c:119 ../display/d.menu/main.c:125
#, c-format
@@ -28979,6 +27000,10 @@
"Permite al usuario cambiar la configuración de la región geográfica actual "
"de forma interactiva, con el ratón."
+#: ../display/d.zoom/main.c:100
+msgid "Name of vector map"
+msgstr "Nombre de mapa vectorial"
#: ../display/d.zoom/main.c:108
msgid "Magnification: >1.0 zooms in, <1.0 zooms out"
msgstr "Zum: >1.0 acercar, <1.0 alejar"
@@ -29127,6 +27152,11 @@
msgid "Grid color"
msgstr "Color de cuadrícula"
+#: ../display/d.grid/main.c:76 ../display/d.grid/main.c:81
+#: ../display/d.grid/main.c:87
+msgid "Color"
+msgstr "Color"
#: ../display/d.grid/main.c:95
msgid "Font size for gridline coordinate labels"
msgstr "Tamaño de fuente para las etiquetas de coordenadas de la cuadrícula"
@@ -29292,6 +27322,10 @@
"Saltando este punto, el punto seleccionado está fuera de la región. ¿Quizás "
"la distancia setback lo sitúa más allá del borde?"
+#: ../display/d.colortable/main.c:66 ../display/d.extend/main.c:31
+msgid "display, setup"
+msgstr "mostrar, configuración"
#: ../display/d.colortable/main.c:68
msgid "Displays the color table associated with a raster map layer."
msgstr "Muestra la tabla de colores asociada a una capa de mapa ráster."
@@ -29794,12 +27828,12 @@
msgid "<%s> already exists in mapset <%s>"
msgstr "<%s> ya existe en el directorio de mapas<%s>"
-#: ../general/manage/cmd/rename.c:88
-#, c-format
-msgid "%s=%s,%s: files are the same, no rename required"
+#: ../general/manage/cmd/rename.c:89
+#, fuzzy, c-format
+msgid "%s=%s,%s: files could be the same, no rename possible"
msgstr "%s=%s,%s: los archivos son iguales, no se necesita cambiar el nombre"
-#: ../general/manage/cmd/rename.c:98
+#: ../general/manage/cmd/rename.c:99
msgid "Renaming reclass maps"
msgstr "Cambiando el nombre de los mapas reclasificados"
@@ -30226,12 +28260,12 @@
msgid "Display summary information"
msgstr "Mostrar información de resumen"
-#: ../general/g.mapsets/main_cmd.c:52 ../general/g.mapset/main.c:48
+#: ../general/g.mapsets/main.c:59 ../general/g.mapset/main.c:48
#, fuzzy
msgid "general, settings"
msgstr "ráster, proyección"
-#: ../general/g.mapsets/main_cmd.c:54
+#: ../general/g.mapsets/main.c:61
msgid ""
"Modifies the user's current mapset search path, affecting the user's access "
"to data existing under the other GRASS mapsets in the current location."
@@ -30240,50 +28274,70 @@
"afectado al acceso del usuario a datos existentes bajo otros directorios de "
"mapas de GRASS en la localización actual."
-#: ../general/g.mapsets/main_cmd.c:63
+#: ../general/g.mapsets/main.c:70
msgid "Name(s) of existing mapset(s)"
msgstr "Nombre(s) de directorio(s) de mapas existente(s)"
-#: ../general/g.mapsets/main_cmd.c:71
+#: ../general/g.mapsets/main.c:78
msgid "Name(s) of existing mapset(s) to add to search list"
msgstr "Nombre(s) de directorio(s) de mapas a añadir a la lista de búsqueda"
-#: ../general/g.mapsets/main_cmd.c:79
+#: ../general/g.mapsets/main.c:86
#, fuzzy
msgid "Name(s) of existing mapset(s) to remove from search list"
-#: ../general/g.mapsets/main_cmd.c:83
+#: ../general/g.mapsets/main.c:93
msgid "List all available mapsets"
msgstr "Listar todos los directorios de mapas disponibles"
-#: ../general/g.mapsets/main_cmd.c:87
+#: ../general/g.mapsets/main.c:97
msgid "Print current mapset search path"
msgstr "Imprimir la ruta de búsqueda del directorio de mapas actual"
-#: ../general/g.mapsets/main_cmd.c:91
+#: ../general/g.mapsets/main.c:101
msgid "Show mapset selection dialog"
msgstr ""
-#: ../general/g.mapsets/main_cmd.c:115 ../general/g.mapsets/main_cmd.c:144
+#: ../general/g.mapsets/main.c:126 ../general/g.mapsets/main.c:155
#, fuzzy, c-format
msgid "Mapset <%s> not found"
msgstr "%s: no se encontró <%s>"
-#: ../general/g.mapsets/main_cmd.c:146
+#: ../general/g.mapsets/main.c:157
#, fuzzy, c-format
msgid "Mapset <%s> added to search path"
msgstr "Directorio de mapas a listar (predeterminado: ruta de búsqueda actual)"
-#: ../general/g.mapsets/main_cmd.c:170
+#: ../general/g.mapsets/main.c:183
#, c-format
msgid "Mapset <%s> removed from search path"
msgstr ""
-#: ../general/g.mapsets/main_cmd.c:192
+#: ../general/g.mapsets/main.c:216
msgid "Cannot open SEARCH_PATH for write"
msgstr "No se puede abrir SEARCH_PATH para escritura"
+#: ../general/g.mapsets/dsply_path.c:19
+#, fuzzy, c-format
+msgid "Your mapset search list:\n"
+msgstr "Imprimir la ruta de búsqueda del directorio de mapas actual"
+#: ../general/g.mapsets/dsply_path.c:29
+#, fuzzy, c-format
+msgid "<%s> not found in mapset list"
+msgstr "Columna <%s> no encontrada en la tabla <%s>"
+#: ../general/g.mapsets/dsply_maps.c:23
+#, fuzzy, c-format
+msgid "Available mapsets:"
+msgstr "Listar todos los directorios de mapas disponibles"
+#: ../general/g.mapsets/dsply_maps.c:33
+#, c-format
+msgid "** no mapsets **\n"
+msgstr ""
#: ../general/g.findfile/main.c:37
msgid "Searches for GRASS data base files and sets variables for the shell."
msgstr ""
@@ -30383,6 +28437,10 @@
msgid "Print the maximum bounding box in lat/long on WGS84"
msgstr "Imprimir los límites máximos en latitud/longitud en WGS84"
+#: ../general/g.region/main.c:133
+msgid "Print in shell script style"
+msgstr "Imprimir en estilo de script de consola"
#: ../general/g.region/main.c:139
msgid ""
"Align region to resolution (default = align to bounds, works only for 2D "
@@ -30626,23 +28684,32 @@
#: ../general/g.gui/main.c:45
msgid ""
"tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - "
-"Display Manager (d.m);wxpython;wxPython based next generation GUI"
+"Display Manager (d.m);wxpython;wxPython based next generation GUI;text;"
+"command line interface only"
msgstr ""
-#: ../general/g.gui/main.c:53
+#: ../general/g.gui/main.c:54
#, fuzzy
msgid "Name of workspace file"
msgstr "Nombre de archivo de color"
-#: ../general/g.gui/main.c:57
+#: ../general/g.gui/main.c:58
msgid "Update default GUI setting"
msgstr ""
-#: ../general/g.gui/main.c:75
+#: ../general/g.gui/main.c:63
+msgid "Do not launch GUI after updating the default GUI setting"
+msgstr ""
+#: ../general/g.gui/main.c:89
#, c-format
msgid "<%s> is now the default GUI"
msgstr ""
+#: ../general/g.gui/main.c:106
+msgid "The old d.m GUI is not available for WinGRASS"
+msgstr ""
#: ../general/g.version/main.c:35
msgid "Displays version and copyright information."
msgstr "Muestra información de versión y copyright."
@@ -30655,6 +28722,10 @@
msgid "Print the GRASS build information"
msgstr "Imprimir la información de la instalación de GRASS"
+#: ../general/g.version/main.c:48
+msgid "Print the GIS library revision number and time"
+msgstr ""
#: ../general/g.setproj/main.c:78
#, fuzzy
msgid "general, projection"
@@ -31020,6 +29091,10 @@
msgid "Use extended regular expressions instead of wildcards"
msgstr "Usar expresiones regulares en vez de comodines"
+#: ../general/g.mremove/main.c:76
+msgid "Force removal (required for actual deletion of files)"
+msgstr "Forzar eliminación (requerido para la eliminación real de archivos)"
#: ../general/g.mremove/main.c:80
#, fuzzy
msgid "Remove base maps"
@@ -31080,6 +29155,1690 @@
msgid "Pretty printing in human readable format"
msgstr "Suprimir la impresión de información de cabecera"
+#~ msgid "Display manager for GRASS"
+#~ msgstr "Administrador de visualización para GRASS"
+#~ msgid "Name of .dmrc settings file"
+#~ msgstr "Nombre del archivo de configuración .dmrc"
+#~ msgid "GIS manager for GRASS"
+#~ msgstr "Administrador GIS de GRASS"
+#~ msgid "Name of GIS manager settings file (.grc)"
+#~ msgstr "Nombre del archivo de preferencias del Administrador GIS (.grc)"
+#~ msgid "Configuration editor for r.li.'index'"
+#~ msgstr "Editor de configuración para el índice r.li"
+#~ msgid "raster, landscape structure analysis"
+#~ msgstr "ráster, análisis de estructura del paisaje"
+#, fuzzy
+#~ msgid "Prints a graph of the correlation between data layers (in pairs)."
+#~ msgstr ""
+#~ "presenta un gráfico de la correlación entre dos capas de datos (en pares)"
+#~ msgid "display, diagram"
+#~ msgstr "mostrar, diagrama"
+#~ msgid "raster input map"
+#~ msgstr "Mapa ráster de entrada"
+#~ msgid "Selects/starts specified monitor at specified size"
+#~ msgstr "Selecciona/lanza un monitor determinado al tamaño especificado"
+#~ msgid "Display monitor to start"
+#~ msgstr "Muestra el monitor para lanzar"
+#~ msgid "Width in pixels of new display monitor"
+#~ msgstr "Anchura en pixels del nuevo monitor"
+#~ msgid "Height in pixels of new display monitor"
+#~ msgstr "Altura en pixels del nuevo monitor"
+#~ msgid "Moves displayed maps to another monitor"
+#~ msgstr "Mueve los mapas que se muestran a otro monitor"
+#~ msgid "clear target monitor before moving"
+#~ msgstr "borra el monitor de destino antes de moverlos"
+#~ msgid "stay with source monitor"
+#~ msgstr "permanecer en el monitor orginal"
+#~ msgid "kill source monitor after moving"
+#~ msgstr "eliminar el monitor original después de moverlo"
+#~ msgid "Target monitor"
+#~ msgstr "Monitor de destino"
+#~ msgid "Source monitor"
+#~ msgstr "Monitor de origen"
+#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
+#~ msgstr ""
+#~ "Exporta el monitor visible a una imagen de fondo compatible con GpsDrive"
+#~ msgid "display, export, GPS"
+#~ msgstr "muestra, exporta, GPS"
+#, fuzzy
+#~ msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
+#~ msgstr "nombre para el nuevo mapa de imagen (reside en ~/.gpsdrive)"
+#~ msgid "Make JPEG instead of PNG image"
+#~ msgstr "Crea una imagen JPG en lugar de PNG"
+#~ msgid "Saves active display monitor to PNG file in home directory"
+#~ msgstr "Guarda el monitor activo a un archivo PNG en el directorio home"
+#~ msgid "display, export"
+#~ msgstr "muestra, exporta"
+#~ msgid "Name of PNG file"
+#~ msgstr "Nombre del archivo PNG"
+#~ msgid "Resolution of output file (single=1, double=2, quad=4)"
+#~ msgstr "Resolución del archivo de salida (único=1, doble=2, cuádruple=4)"
+#~ msgid "Saves the contents of the active display monitor to a graphics file."
+#~ msgstr "Guarda el contenido del monitor activo en un fichero gráfico."
+#~ msgid "Name for output file (do NOT add extension)"
+#~ msgstr "Nombre para el archivo de salida (NO añadir extensión)"
+#~ msgid "Dimensions of output file versus current window size"
+#~ msgstr "Dimensiones de archivo de salida versus tamaño de la ventana actual"
+#~ msgid "(same=1, double size=2, quadruple size=4)"
+#~ msgstr "(igual=1, doble tamaño=2, cuádruple tamaño=4)"
+#~ msgid "Images"
+#~ msgstr "Imágenes"
+#~ msgid "Width and height of output image (overrides resolution setting)"
+#~ msgstr ""
+#~ "Anchura y altura de la imagen de salida (ignora la configuración de "
+#~ "resolución)"
+#~ msgid "Compression for PNG files"
+#~ msgstr "Compresión para archivos PNG"
+#~ msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
+#~ msgstr ""
+#~ "(0=ninguna, 1=la más rápida, 9=máxima; sin pérdida, sólo tiempo vs. "
+#~ "tamaño de archivo)"
+#~ msgid "File size/quality for JPEG files"
+#~ msgstr "Tamaño/calidad de archivo para archivos JPEG"
+#~ msgid "(10=smallest/worst, 100=largest/best)"
+#~ msgstr "(10=el más pequeño/peor, 100=el más grande/mejor)"
+#~ msgid "Paper size for PostScript output"
+#~ msgstr "Tamaño de papel para salida PostScript"
+#~ msgid "PostScript"
+#~ msgstr "PostScript"
+#~ msgid "PostScript level (only limits functionality!)"
+#~ msgstr "Nivel PostScript (¡sólo limita la funcinalidad!)"
+#~ msgid "Set background color to black (white default)"
+#~ msgstr "Ajustar el color de fondo a negro (blanco por omisión)"
+#~ msgid "Set transparent background"
+#~ msgstr "Establecer fondo transparente"
+#~ msgid "Use the Cario driver to render images"
+#~ msgstr "Usar el controlador Cairo para representar las imágenes"
+#~ msgid "Set paper orientation to landscape (for PostScript output)"
+#~ msgstr ""
+#~ "Establecer la orientación del papel a horizontal (para salida PostScript)"
+#~ msgid "Draws polar diagram of angle map such as aspect or flow directions"
+#~ msgstr ""
+#~ "Dibujar un diagrama polar de un mapa con ángulos como direcciones de "
+#~ "orientación o corriente"
+#~ msgid "Name of raster angle map"
+#~ msgstr "Nombre del mapa ráster de ángulos"
+#~ msgid "Pixel value to be interpreted as undefined (different from NULL)"
+#~ msgstr "Valor pixel para interpretar como indefinido (distinto de nulo)"
+#~ msgid "Name of optional EPS output file"
+#~ msgstr "Nombre del archivo de salida EPS opcional"
+#~ msgid "Plot using Xgraph"
+#~ msgstr "Salida gráfica usando Xgraph"
+#~ msgid "Name of aspect raster map"
+#~ msgstr "Nombre de mapa ráster de orientación"
+#~ msgid "Width of display canvas"
+#~ msgstr "Anchura de lienzo de visualización"
+#~ msgid "Height of display canvas"
+#~ msgstr "Altura de lienzo de visualización"
+#~ msgid "Minimum size of each cell"
+#~ msgstr "Tamaño mínimo de cada celda"
+#~ msgid "Maximum number of rows to load"
+#~ msgstr "Número máximo de filas a cargar"
+#~ msgid "Maximum number of columns to load"
+#~ msgstr "Número máximo de columnas a cargar"
+#~ msgid "Displays a raster map and its legend on a graphics window"
+#~ msgstr "Muestra un mapa ráster y su leyenda en una ventana gráfica"
+#, fuzzy
+#~ msgid "Omit entries with missing label"
+#~ msgstr "omitir las entradas con una etiqueta perdida"
+#~ msgid "Number of lines to appear in the legend"
+#~ msgstr "Número de líneas que deben aparecer en la leyenda"
+#, fuzzy
+#~ msgid "Name of raster map to generate legend from"
+#~ msgstr "Nombre del mapa ráster a usar para <%s>"
+#, fuzzy
+#~ msgid "Name of raster map to print in legend"
+#~ msgid "Redraws the current display frame in the GRASS monitor"
+#~ msgstr "Vuelve a dibujar el marco activo en el monitor GRASS"
+#~ msgid "Redraw all frames"
+#~ msgstr "Redibujar todos los marcos"
+#~ msgid "Do not preserve individual regions when redrawing all frames"
+#~ msgstr ""
+#~ "No preservar regiones individuales cuando se redibujan todos los marcos"
+#~ msgid "Resizes active display monitor"
+#~ msgstr "Modifica el tamaño del monitor activo"
+#~ msgid "New width for window"
+#~ msgstr "Nueva anchura de ventana"
+#~ msgid "New height for window"
+#~ msgstr "Nueva altura de ventana"
+#~ msgid "Name of shaded relief or aspect map"
+#~ msgstr "Nombre del mapa compartido de relieve u orientación"
+#~ msgid "Name of raster to drape over relief map"
+#~ msgstr "Nombre del ráster superponer sobre mapa de relieve"
+#~ msgid "Percent to brighten"
+#~ msgstr "Porcentaje para aumentar el brilloConvergencia porcentual"
+#~ msgid "Slide show of GRASS raster/vector maps."
+#~ msgstr "Presentación de mapas ráster/vectoriales de GRASS."
+#~ msgid "display, slideshow"
+#~ msgstr "muestra, presentación"
+#~ msgid "Show vector maps rather than raster maps"
+#~ msgstr "Muestra mapas vectoriales en vez de mapas ráster"
+#~ msgid "Map prefix. Specify character(s) to view selected maps only"
+#~ msgstr ""
+#~ "Prefijo de mapa. Especificar carácter(es) para ver sólo los mapas "
+#~ "seleccionados"
+#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
+#~ msgstr ""
+#~ "Directorio de mapas a usar. Especificar múltiples directorios separados "
+#~ "por comas"
+#~ msgid "Number of seconds to pause between slides"
+#~ msgstr "Número de segundos de pausa entre diapositivas"
+#~ msgid ""
+#~ "Divides active display into two frames & displays maps/executes commands "
+#~ "in each frame."
+#~ msgstr ""
+#~ "Divide la visualización activa en dos marcos y muestra los mapas/ejecuta "
+#~ "los comandos en cada uno."
+#, fuzzy
+#~ msgid "Enter raster map to display in 1st frame"
+#~ msgstr "Introducir mapa ráster a mostrar en el segundo marco"
+#~ msgid "Enter command to execute in 1st frame"
+#~ msgstr "Introducir comando a ejecutar en el primer marco"
+#~ msgid "Enter raster map to display in 2nd frame"
+#~ msgid "Enter command to execute in 2nd frame"
+#~ msgstr "Introducir comando a ejecutar en el segundo marco"
+#~ msgid "How to split display"
+#~ msgstr "Como dividir la visualización"
+#, fuzzy
+#~ msgid "Split the display into subframes."
+#~ msgstr "Introducir mapa ráster a mostrar en el primer marco"
+#, fuzzy
+#~ msgid "Number of subframes"
+#~ msgstr "Número de fotogramas"
+#, fuzzy
+#~ msgid "Displays thematic vector map"
+#~ msgstr "Visualizar mapa vectorial temático"
+#, fuzzy
+#~ msgid "display, vector, thematic, legend"
+#~ msgstr "mostrar, leyenda"
+#~ msgid "Files"
+#~ msgstr "Archivos"
+#, fuzzy
+#~ msgid "Theme"
+#~ msgstr "Preferencias de tema"
+#, fuzzy
+#~ msgid ""
+#~ "Name of attribute column to use for thematic display (must be numeric)"
+#~ msgstr ""
+#~ "Columna de atributos a usar para presentación temática (debe ser numérico)"
+#~ msgid "Type of thematic display"
+#~ msgstr "Tipo de visualización temática"
+#~ msgid "Thematic divisions of data for display"
+#~ msgstr "Divisiones temáticas de los datos a mostrar"
+#, fuzzy
+#~ msgid "Break points for custom breaks option"
+#~ msgstr ""
+#~ "Puntos de ruptura para la opción de ruptura personalizada. Separar "
+#~ "valores por espacios (0 10 20 30...)"
+#, fuzzy
+#~ msgid "Separate values by spaces (0 10 20 30 ...)"
+#~ msgstr ""
+#~ msgid "Vector point icon for point data"
+#~ msgstr "Icono de punto vectorial para datos de puntos"
+#, fuzzy
+#~ msgid "Icon size for point data"
+#, fuzzy
+#~ msgid "Minimum icon size/line width for graduated points/lines)"
+#~ msgstr ""
+#~ "Tamaño máximo de icono/anchura de línea para gradiente de puntos y líneas"
+#~ msgid "Maximum icon size/line width for graduated points and lines"
+#~ msgstr ""
+#~ msgid "Number of classes for interval theme (integer)"
+#~ msgstr "Número de clases para tema de intervalo (entero)"
+#, fuzzy
+#~ msgid "Select 'single_color' for graduated point/line display"
+#~ msgstr ""
+#~ "Esquema de colores para mapas en gradiente de color (seleccionar "
+#~ "'single_color' para mostrar gradiente de puntos/líneas)"
+#, fuzzy
+#~ msgid "Color for graduated points map"
+#~ msgstr "Color para datos Y"
+#, fuzzy
+#~ msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
+#~ msgstr ""
+#~ "Color para mapa de gradiente de puntos (nombre de color de grass o "
+#~ "triplete R:G:B). Establecer esquema de color a un color."
+#, fuzzy
+#~ msgid ""
+#~ "GRASS named color or R:G:B triplet. Set color scheme to single color."
+#~ msgstr ""
+#, fuzzy
+#~ msgid "Beginning color for custom color gradient"
+#~ msgstr ""
+#~ "Color inicial para gradiente de color personalizado. Se debe expresar "
+#~ "como triplete R:G:B."
+#, fuzzy
+#~ msgid "Must be expressed as R:G:B triplet"
+#~ msgstr ""
+#~ "Color final para gradiente de color personalizado. Se debe expresar como "
+#~ "triplete R:G:B."
+#, fuzzy
+#~ msgid "Ending color for custom color gradient"
+#~ msgstr ""
+#~ msgid "Misc"
+#~ msgstr "Miscelánea"
+#~ msgid "Select x11 display monitor for legend"
+#~ msgstr "Seleccionar monitor x11 para la leyenda"
+#~ msgid "Save thematic map commands to group file for GIS Manager"
+#~ msgstr ""
+#~ "Guardar comandos de mapa temático en archivo de grupo para el "
+#~ "Administrador GIS"
+#~ msgid "WHERE conditions of SQL statement without 'where' keyword"
+#~ msgstr "Condiciones WHERE de sentencia SQL sin palabra clave 'where'"
+#, fuzzy
+#~ msgid ""
+#~ "Root for the name of psmap instruction files to be in current directory"
+#~ msgstr ""
+#~ "Raíz para el nombre de los archivos de instrucciones psmap para estar en "
+#~ "el directorio actual ((si no se indica, no se creará ningún archivo de "
+#~ "instrucciones psmap)"
+#~ msgid "Name of group file where thematic map commands will be saved"
+#~ msgstr ""
+#~ "Nombre de archivo de grupo en el que se guardarán los comandos del mapa "
+#~ "temático"
+#~ msgid "Create graphic legend in x11 display monitor"
+#~ msgstr "Crear leyenda gráfica en monitor x11"
+#~ msgid "Only draw fills (no outlines) for areas and points"
+#~ msgstr "Dibujar sólo rellenos (no líneas exteriores) para áreas y puntos"
+#~ msgid "Update color values to GRASSRGB column in attribute table"
+#~ msgstr ""
+#~ "Actualizar valores de color a la columna GRASSRGB en la tabla de atributos"
+#~ msgid "Output legend for GIS Manager (for scripting use only)"
+#~ msgstr ""
+#~ "Producir leyenda para el Administrador GIS (sólo para uso en scripts)"
+#~ msgid "Use math notation brackets in legend"
+#~ msgstr "Usar corchetes de anotación matemática en la leyenda"
+#~ msgid "Drops a column from selected attribute table"
+#~ msgstr "Elimina una columna de la tabla de atributos seleccionada"
+#~ msgid "Table from which to drop attribute column"
+#~ msgstr "Tabla de la que eliminar una columna de atributos"
+#~ msgid "Name of the column"
+#~ msgstr "Nombre de la columna"
+#, fuzzy
+#~ msgid "Drops an attribute table."
+#~ msgstr "Quitar una tabla de atributos"
+#~ msgid "Table to drop"
+#~ msgstr "Tabla a quitar"
+#~ msgid "Imports attribute tables in various formats."
+#~ msgstr "Importa tablas de atributos en varios formatos."
+#~ msgid "Table file to be imported or DB connection string"
+#~ msgstr "Archivo de tabla a importar o cadena de conexión a base de datos"
+#~ msgid "Table name of SQL DB table"
+#~ msgstr "Nombre de tabla de tabla de base de datos SQL"
+#~ msgid "Name for output table"
+#~ msgstr "Nombre para la tabla de salida"
+#~ msgid "Name for auto-generated unique key column"
+#~ msgstr "Nombre para la columna de clave única autogenerada"
+#~ msgid "Exports attribute tables into various formats."
+#~ msgstr "Exporta tablas de atributos a varios formatos."
+#~ msgid "GRASS table name"
+#~ msgstr "Nombre de la tabla de GRASS"
+#~ msgid "Table file to be exported or DB connection string"
+#~ msgstr "Archivo de tabla a exportar o cadena de conexión a base de datos"
+#~ msgid "Table format"
+#~ msgstr "Formato de la tabla"
+#~ msgid "Test database driver, database must exist and set by db.connect."
+#~ msgstr ""
+#~ "Probar el controlador de base de datos. La base de datos debe existir y "
+#~ "estar conectada por db. connect."
+#~ msgid "Test name"
+#~ msgstr "Nombre de prueba"
+#~ msgid "Display the HTML man pages of GRASS"
+#~ msgstr "Mostrar las páginas man HTML de GRASS"
+#~ msgid "general, manual, help"
+#~ msgstr "general, manual, ayuda"
+#~ msgid "Display index"
+#~ msgstr "Mostrar índice"
+#~ msgid "Display as MAN text page instead of HTML page in browser"
+#~ msgstr ""
+#~ "Mostrar como páginas de texto MAN en vez de páginas HTML en navegador"
+#~ msgid "Manual entry to be displayed"
+#~ msgstr "Entrada de manual a mostrar"
+#~ msgid ""
+#~ "Brovey transform to merge multispectral and high-res panchromatic channels"
+#~ msgstr ""
+#~ "Transformación de Brovey para fundir canales multiespectrales y "
+#~ "pancromáticos de alta resolución"
+#, fuzzy
+#~ msgid "imagery, fusion, Brovey"
+#~ msgstr "ráster imaginería, fusión"
+#, fuzzy
+#~ msgid "LANDSAT sensor"
+#~ msgstr "Canal rojo LANDSAT"
+#, fuzzy
+#~ msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
+#~ msgstr "Mapa ráster de entrada (verde: tm2 | qbird_green | spot1)"
+#, fuzzy
+#~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
+#~ msgstr "Mapa ráster entrada (NIR: tm4 | qbird_nir | spot2)"
+#, fuzzy
+#~ msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
+#~ msgstr "Mapa ráster de entrada (MIR: tm5 | qbird_red | spot3)"
+#, fuzzy
+#~ msgid "Name of input raster map (etmpan | qbird_pan | spotpan)"
+#~ msgstr "Mapa ráster de entrada (etmpan | qbird_pan | spotpan)"
+#, fuzzy
+#~ msgid "Name for output raster map prefix (e.g. 'brov')"
+#~ msgstr "Prefijo del mapa ráster de salida (ej.: 'brov')"
+#~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
+#~ msgstr ""
+#~ "Hace mosaicos de hasta 4 imágenes y extiende colormap; crea mapas *."
+#~ "mosaico"
+#~ msgid "raster, imagery, mosaicking"
+#~ msgstr "ráster, imaginería, creación de mosaicos"
+#~ msgid "1st map for mosaic (top of image stack)."
+#~ msgstr "Primer mapa para mosaico (superior de la pila de imágenes)."
+#~ msgid "2nd map for mosaic."
+#~ msgstr "Segundo mapa para mosaico."
+#~ msgid "3rd map for mosaic."
+#~ msgstr "Tercer mapa para mosaico."
+#~ msgid "4th map for mosaic."
+#~ msgstr "Cuarto mapa para mosaico."
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#~ msgstr "Importar archivo SPOT VGT NDVI a un mapa ráster"
+#~ msgid "raster, imagery, import"
+#~ msgstr "ráster, imaginería, importar"
+#~ msgid "also import quality map (SM status map layer) and filter NDVI map"
+#~ msgstr ""
+#~ "importar también mapa de calidad (capa de mapa de estado SM) y filtrar "
+#~ "mapa NDVI"
+#~ msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
+#~ msgstr "archivo SPOT VGT NDVI HDF existente (0001_NDV.HDF)"
+#, fuzzy
+#~ msgid "Performs auto-balancing of colors for LANDSAT images."
+#~ msgstr "Balance automático de colores para imágenes LANDSAT"
+#~ msgid "raster, imagery, colors"
+#~ msgstr "ráster, imaginería, colores"
+#~ msgid "LANDSAT red channel"
+#~ msgid "LANDSAT green channel"
+#~ msgstr "Canal verde LANDSAT"
+#~ msgid "LANDSAT blue channel"
+#~ msgstr "Canal azul LANDSAT"
+#~ msgid "Extend colors to full range of data on each channel"
+#~ msgstr "Extender colores a todo el intervalo de datos de cada canal"
+#~ msgid "Preserve relative colors, adjust brightness only"
+#~ msgstr "Conservar colore relativos, sólo ajustar brillo"
+#~ msgid "Reset to standard color range"
+#~ msgstr "Restablecer al intervalo de colores estándar"
+#~ msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
+#~ msgstr ""
+#~ "Calcula tabla de Factor de Índice Óptimo para bandas LANDSAT 1-5 y 7"
+#~ msgid "raster, imagery, statistics"
+#~ msgstr "ráster, imaginería, estadísticas"
+#~ msgid "LANDSAT TM band 1."
+#~ msgstr "LANDSAT TM banda 1."
+#~ msgid "LANDSAT TM band 2."
+#~ msgstr "LANDSAT TM banda 2."
+#~ msgid "LANDSAT TM band 3."
+#~ msgstr "LANDSAT TM banda 3."
+#~ msgid "LANDSAT TM band 4."
+#~ msgstr "LANDSAT TM banda 4."
+#~ msgid "LANDSAT TM band 5."
+#~ msgstr "LANDSAT TM banda 5."
+#~ msgid "LANDSAT TM band 7."
+#~ msgstr "LANDSAT TM banda 7."
+#, fuzzy
+#~ msgid ""
+#~ "Displays spectral response at user specified locations in group or images."
+#~ msgstr ""
+#~ "muestra la respuesta espectral en localizaciones especificadas por el "
+#~ "usuario en grupo o imágenes"
+#~ msgid "imagery, raster, multispectral"
+#~ msgstr "imaginería, ráster, multiespectral"
+#, fuzzy
+#~ msgid "Group input"
+#~ msgstr "entrada de grupo"
+#, fuzzy
+#~ msgid "Raster input maps"
+#~ msgstr "mapas ráster de entrada"
+#, fuzzy
+#~ msgid "Write output to PNG image"
+#~ msgstr "escribir la salida a imagen PNG"
+#~ msgid "Use image list and not group"
+#~ msgstr "Usar lista de imágenes y no grupo"
+#~ msgid "Select multiple points"
+#~ msgstr "Seleccionar múltiples puntos"
+#, fuzzy
+#~ msgid "Label with coordinates instead of numbering"
+#~ msgstr "Etiquetar con coordenadas en vez de numeración"
+#~ msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
+#~ msgstr "Transformación Tasseled Cap (Kauth Thomas) para datos LANDSAT-TM"
+#~ msgid "raster, imagery"
+#~ msgstr "ráster, imaginería"
+#~ msgid "use transformation rules for LANDSAT-4"
+#~ msgstr "usar reglas de transformación para LANDSAT-4"
+#~ msgid "use transformation rules for LANDSAT-5"
+#~ msgstr "usar reglas de transformación para LANDSAT-5"
+#~ msgid "use transformation rules for LANDSAT-7"
+#~ msgstr "usar reglas de transformación para LANDSAT-7"
+#~ msgid "raster input map (LANDSAT channel 1)"
+#~ msgstr "mapa ráster de entrada (canal LANDSAT 1)"
+#~ msgid "raster input map (LANDSAT channel 2)"
+#~ msgstr "mapa ráster de entrada (canal LANDSAT 2)"
+#~ msgid "raster input map (LANDSAT channel 3)"
+#~ msgstr "mapa ráster de entrada (canal LANDSAT 3)"
+#~ msgid "raster input map (LANDSAT channel 4)"
+#~ msgstr "mapa ráster de entrada (canal LANDSAT 4)"
+#~ msgid "raster input map (LANDSAT channel 5)"
+#~ msgstr "mapa ráster de entrada (canal LANDSAT 5)"
+#~ msgid "raster input map (LANDSAT channel 7)"
+#~ msgstr "mapa ráster de entrada (canal LANDSAT 7)"
+#~ msgid "raster output TC maps prefix"
+#~ msgstr "prefijo de mapas TC ráster de salida"
+#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+#~ msgstr "Convierte coordenadas de una proyección a otra (interfaz cs2cs)."
+#~ msgid "miscellaneous, projection"
+#~ msgstr "miscelánea, proyección"
+#~ msgid "Input coordinate file (omit to read from stdin)"
+#~ msgstr "Archivo de coordenadas de entrada (omitir para leer de stdin)"
+#~ msgid "Output coordinate file (omit to send to stdout)"
+#~ msgstr "Archivo de coordenadas de salida (omitir para enviar a stdout)"
+#~ msgid "Field separator"
+#~ msgstr "Separador de campos"
+#~ msgid "Input projection parameters (PROJ.4 style)"
+#~ msgstr "Parámetros de la proyección de entrada (en estilo PROJ.4)"
+#~ msgid "Output projection parameters (PROJ.4 style)"
+#~ msgstr "Parámetros de la proyección de salida (en estilo PROJ.4)"
+#~ msgid "Use LL WGS84 as input and current location as output projection"
+#~ msgstr ""
+#~ "Usar LL WGS84 como entrada y la localización actual como proyección de "
+#~ "salida"
+#~ msgid "Use current location as input and LL WGS84 as output projection"
+#~ msgstr ""
+#~ "Usar la localización actual como entrada y LL WGS84 como proyección de "
+#~ "salida"
+#~ msgid ""
+#~ "Output long/lat in decimal degrees or other projections with many decimal "
+#~ "places"
+#~ msgstr ""
+#~ "Producir latitud/longitud en grados decimales u otras proyecciones con "
+#~ "muchos decimales"
+#~ msgid "Verbose mode (print projection parameters and filenames to stderr)"
+#~ msgstr ""
+#~ "Modo verboso (imprimir parámetros de proyección y nombres de archivo a "
+#~ "stderr)"
+#, fuzzy
+#~ msgid "Blends color components of two raster maps by a given ratio."
+#~ msgstr ""
+#~ "Mezcla los componentes de color de dos mapas ráster en la proporción "
+#~ "indicada"
+#~ msgid "Name of first raster map for blending"
+#~ msgstr "Nombre del primer mapa ráster a mezclar"
+#~ msgid "Name of second raster map for blending"
+#~ msgstr "Nombre del segundo mapa ráster a mezclar"
+#, fuzzy
+#~ msgid "Base name for red, green and blue output maps containing the blend"
+#~ msgstr ""
+#~ "Nombre base para los mapas de salida rojo, verde y azul que contendrán la "
+#~ "mezcla"
+#~ msgid "Percentage weight of first map for color blending"
+#~ msgstr "Porcentaje de peso del primer mapa para la mezcla de color"
+#, fuzzy
+#~ msgid "Color using standard deviation bands"
+#~ msgstr ""
+#~ "medias y desviaciones estándar para %d banda %s\n"
+#~ "\n"
+#~ msgid ""
+#~ "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+#~ msgstr ""
+#~ "Rellenar áreas sin datos de los mapas ráster usando la interpolación "
+#~ "splines de v.sufr.rst"
+#~ msgid "raster, elevation, interpolation"
+#~ msgstr "ráster, elevación, interpolación"
+#~ msgid "Raster map in which to fill nulls"
+#~ msgstr "Mapa ráster en el que rellenar los nulos"
+#~ msgid ""
+#~ "Output raster map with nulls filled by interpolation from surrounding "
+#~ "values"
+#~ msgstr ""
+#~ "Producir mapa ráster con nulos rellenos por interpolación de los valores "
+#~ "circundantes"
+#~ msgid "Spline tension parameter"
+#~ msgstr "Parámetro de tensión spline"
+#~ msgid "Spline smoothing parameter"
+#~ msgstr "Parámetro de suavizado spline"
+#~ msgid ""
+#~ "Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+#~ "using gdalwarp."
+#~ msgstr ""
+#~ "Georreferenciar, rectificar e importar imaginería Terra ASTER y MDT "
+#~ "relativos usando gdalwarp."
+#~ msgid "Input ASTER image to be georeferenced & rectified"
+#~ msgstr "Imagen ASTER de entrada a georreferenciar y rectificar"
+#~ msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
+#~ msgstr ""
+#~ "Tipo de procesado de Imaginería ASTER (Nivel 1A, Nivel 1B o MDT "
+#~ "relacionado)"
+#~ msgid ""
+#~ "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
+#~ "single band"
+#~ msgstr ""
+#~ "Banda L1A o L1B a traducir (1, 2, 3n, 3b, 4-14). Sólo se puede traducir "
+#~ "una banda"
+#~ msgid "Import SRTM HGT files into GRASS"
+#~ msgstr "Importar archivos SRTM HGT a GRASS"
+#~ msgid "SRTM input tile (file without .hgt.zip extension)"
+#~ msgstr "Archivo de entrada SRTM (archivo sin extensión .hgt.zip)"
+#~ msgid "Output raster map (default: input tile)"
+#~ msgstr "Mapa ráster de salida (por omisión: tesela de entrada)"
+#~ msgid "Downloads and imports data from WMS servers."
+#~ msgstr "Descarga e importa datos de servidores WMS."
+#~ msgid "wms"
+#~ msgstr "wms"
+#~ msgid "Request"
+#~ msgstr "Solicitud"
+#~ msgid "Skip to downloading (to resume downloads faster)"
+#~ msgstr "Saltar la descarga (para continuar descargas más rápido)"
+#~ msgid "Download"
+#~ msgstr "Descargar"
+#, fuzzy
+#~ msgid "Don't request transparent data"
+#~ msgstr "No solicitar datos transparentes."
+#, fuzzy
+#~ msgid "Clean existing data out of download directory"
+#~ msgstr "Eliminar datos existentes del directorio de descarga."
+#~ msgid "Import"
+#~ msgstr "Importar"
+#, fuzzy
+#~ msgid "Don't reproject the data, just patch it"
+#~ msgstr "No reproyectar los datos, sólo parchearlos."
+#~ msgid "Mapserver to request data from"
+#~ msgstr "Servidor de mapas del que solicitar los datos"
+#~ msgid "Layers to request from map server"
+#~ msgstr "Capas a solicitar del servidor de mapas"
+#~ msgid "Styles to request from map server"
+#~ msgstr "Estilos a solicitar del servidor de mapas"
+#~ msgid "Source projection to request from server"
+#~ msgstr "Proyección de origen a solicitar del servidor"
+#~ msgid "Image format requested from the server"
+#~ msgstr "Formato de imagen solicitado del servidor"
+#~ msgid "Addition query options for server"
+#~ msgstr "Opciones de consulta adicionales para el servidor"
+#~ msgid "Maximum columns to request at a time"
+#~ msgstr "Máximo de columnas a solicitar a la vez"
+#~ msgid "Maximum rows to request at a time"
+#~ msgstr "Máximo de filas a solicitar a la vez"
+#~ msgid "Additional options for r.tileset"
+#~ msgstr "Opciones adicionales para r.tileset"
+#~ msgid "Named region to request data for. Current region used if omitted"
+#~ msgstr ""
+#~ "Nombre de la región para la que solicitar datos. Región actual si se omite"
+#~ msgid "Folder to save downloaded data to"
+#~ msgstr "Carpeta en la que guardar los datos descargados"
+#~ msgid "Additional options for wget"
+#~ msgstr "Opciones adicionales para wget"
+#~ msgid "Additional options for curl"
+#~ msgstr "Opciones adicionales para curl"
+#~ msgid "Reprojection method to use"
+#~ msgstr "Método de reproyección a usar"
+#, fuzzy
+#~ msgid "Requires list available layers flag"
+#~ msgstr "Listar las capas disponibles y salir"
+#~ msgid "Verbosity level"
+#~ msgstr "Nivel de verbosidad"
+#~ msgid "Calculate new raster map from a r.mapcalc expression."
+#~ msgstr "Calcular un nuevo mapa ráster a partir de una expresión r.mapcalc."
+#~ msgid "A"
+#~ msgstr "A"
+#~ msgid "B"
+#~ msgstr "B"
+#~ msgid "C"
+#~ msgstr "C"
+#~ msgid "D"
+#~ msgstr "D"
+#~ msgid "E"
+#~ msgstr "E"
+#~ msgid "F"
+#~ msgstr "F"
+#~ msgid "Formula (e.g. A-B or A*C+B)"
+#~ msgstr "Formula (ej. A-B o A*C+B)"
+#~ msgid "Show help"
+#~ msgstr "Mostrar ayuda"
+#~ msgid "Expert mode (enter a set of r.mapcalc expressions)"
+#~ msgstr "Modo avanzado (introducir un conjunto de expresiones de r.mapcalc)"
+#~ msgid "Do not overwrite existing map"
+#~ msgstr "No sobrescribir mapas existentes"
+#~ msgid "Create a MASK for limiting raster operation"
+#~ msgstr "Crear una MÁSCARA para limitar la operación ráster"
+#~ msgid "raster, mask"
+#~ msgstr "ráster, máscara"
+#~ msgid "Raster map to use as MASK"
+#~ msgstr "Mapa ráster a usar como MÁSCARA"
+#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
+#~ msgstr "Valores de categoría a usar para MÁSCARA (formato: 1 2 3 thru 7 *)"
+#~ msgid "Create inverse MASK from specified 'maskcats' list"
+#~ msgstr "Crear MASK inversa a partir de la lista 'maskcats' especificada"
+#~ msgid "Overwrite existing MASK"
+#~ msgstr "Sobrescribir MÁSCARA existente"
+#~ msgid "Remove existing MASK (overrides other options)"
+#~ msgstr "Eliminar MÁSCARA existente (ignora otras opciones)"
+#~ msgid "Exports GRASS raster into GDAL supported formats."
+#~ msgstr "Exporta un ráster de GRASS a formatos soportados por GDAL."
+#~ msgid "Region sensitive output"
+#~ msgstr "Salida sensible a región"
+#~ msgid ""
+#~ "Creation option to the output format driver. Multiple options may be "
+#~ "listed"
+#~ msgstr ""
+#~ "Opción de creación para el controlador de formato de salida. Se pueden "
+#~ "indicar múltiples opciones."
+#~ msgid "Metadata key passed on the output dataset if possible"
+#~ msgstr ""
+#~ "Clave de metadatos pasados al conjunto de datos de salida si es posible"
+#~ msgid ""
+#~ "Export a raster map to a text file as x,y,z values based on cell centers."
+#~ msgstr ""
+#~ "Exportar un mapa ráster a un archivo de texto como valores X, Y, Z "
+#~ "basados en los centros de las celdas."
+#~ msgid ""
+#~ "Creates raster plane map given dip (inclination), aspect (azimuth) and "
+#~ "one point."
+#~ msgstr ""
+#~ "Crea un mapa ráster plano dando pendiente (inclinación), orientación "
+#~ "(azimut) y un punto."
+#~ msgid "raster, elevation"
+#~ msgstr "ráster, elevación"
+#~ msgid "Name of raster plane to be created"
+#~ msgstr "Nombre del plano ráster a crear"
+#~ msgid "Dip of plane. Value must be between -90 and 90 degrees"
+#~ msgstr "Pendiente del plano. El valor debe estar entre -90 y 90 grados"
+#~ msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
+#~ msgstr "Azimut del plano. El valor debe estar entre 0 y 360 grados"
+#~ msgid "Easting coordinate of a point on the plane"
+#~ msgstr "Coordenada Este de un punto en el plano"
+#~ msgid "Northing coordinate of a point on the plane"
+#~ msgstr "Coordenada Norte de un punto en el plano"
+#~ msgid "Elevation coordinate of a point on the plane"
+#~ msgstr "Coordenada de elevación de un punto en el plano"
+#~ msgid "Type of the raster map to be created"
+#~ msgstr "Tipo de mapa ráster a crear"
+#, fuzzy
+#~ msgid ""
+#~ "Reclasses a raster map greater or less than user specified area size (in "
+#~ "hectares)."
+#~ msgstr ""
+#~ "Reclasifica un mapa ráster mayor o menor que la superficie indicada por "
+#~ "el usuario (en hectáreas)"
+#~ msgid "raster, statistics, aggregation"
+#~ msgstr "ráster, estadísticas, agregación"
+#, fuzzy
+#~ msgid "Lesser value option that sets the <= area size limit [hectares]"
+#~ msgstr ""
+#~ "Opción de valor menor que establece el <= límite de tamaño de área "
+#~ "(hectáreas)"
+#, fuzzy
+#~ msgid "Greater value option that sets the >= area size limit [hectares]"
+#~ msgstr ""
+#~ "Opción de valor mayor que establece el >= límite de tamaño de área "
+#~ "(hectáreas)"
+#~ msgid "Calculates linear regression from two raster maps: y = a + b*x"
+#~ msgstr "Calcula la regresión lineal de dos mapas ráster: y = a + b*x"
+#~ msgid "Map for x coefficient"
+#~ msgstr "Mapa para el coeficiente X"
+#~ msgid "Map for y coefficient"
+#~ msgstr "Mapa para el coeficiente Y"
+#~ msgid ""
+#~ "ASCII file for storing regression coefficients (output to screen if file "
+#~ "not specified)."
+#~ msgstr ""
+#~ "Archivo ASCII para guardar los coeficientes de regresión (salida a "
+#~ "pantalla si no se especifica ningún archivo)."
+#~ msgid "Creates shaded relief map from an elevation map (DEM)."
+#~ msgstr ""
+#~ "Crea un mapa compartido de relieve a partir de un mapa de elevaciones "
+#~ "(DEM)."
+#~ msgid "Output shaded relief map name"
+#~ msgstr "Nombre del mapa compartido de relieve de salida"
+#~ msgid "Altitude of the sun in degrees above the horizon"
+#~ msgstr "Altura del sol sobre el horizonte en grados"
+#~ msgid "Azimuth of the sun in degrees to the east of north"
+#~ msgstr "Azimut del sol al Este del Norte en grados"
+#~ msgid "Factor for exaggerating relief"
+#~ msgstr "Factor para exagerar el relive"
+#~ msgid "Scale factor for converting horizontal units to elevation units"
+#~ msgstr ""
+#~ "Factor de escala para convertir unidades horizontales a unidades de "
+#~ "elevación"
+#, fuzzy
+#~ msgid ""
+#~ "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+#~ msgstr ""
+#~ "Establecer factor de escala (aplicable sólo a localizaciones latitud/"
+#~ "longitud)"
+#~ msgid ""
+#~ "Produces tilings of the source projection for use in the destination "
+#~ "region and projection."
+#~ msgstr ""
+#~ "Produce teselado de la proyección del origen para usarlo en la región y "
+#~ "proyección de destino."
+#~ msgid "raster, tiling"
+#~ msgstr "ráster, teselado"
+#~ msgid "Produces shell script output"
+#~ msgstr "Produce salida de script de consola"
+#~ msgid "Produces web map server query string output"
+#~ msgstr "Produce salida de cadena de consulta de servidor web de mapas"
+#~ msgid ""
+#~ "Name of region to use instead of current region for bounds and resolution"
+#~ msgstr ""
+#~ "Nombre de la región a usar en vez de la actual para contornos y resolución"
+#~ msgid "Source projection"
+#~ msgstr "Proyeccion del origen"
+#~ msgid "Conversion factor from units to meters in source projection"
+#~ msgstr ""
+#~ "Factor de conversión de las unidades a metros en la proyección de origen"
+#~ msgid "Destination projection, defaults to this location's projection"
+#~ msgstr ""
+#~ "Proyección de destino, por omisión la proyección de esta localización"
+#~ msgid "Maximum number of columns for a tile in the source projection"
+#~ msgstr ""
+#~ "Número máximo de columnas para una tesela en la proyección de origen"
+#~ msgid "Maximum number of rows for a tile in the source projection"
+#~ msgstr "Número máximo de filas para una tesela en la proyección de origen"
+#~ msgid "Number of cells tiles should overlap in each direction"
+#~ msgstr "El número de teselas de celda debería solapas en cada dirección"
+#~ msgid "calculates univariate statistics from a GRASS raster map"
+#~ msgstr ""
+#~ "Calcula estadísticas univariantes a partir de un mapa ráster de GRASS."
+#~ msgid "extended statistics (quartiles and percentile)"
+#~ msgstr "estadísticas ampliadas (cuartiles y percentiles)"
+#~ msgid "Percentile to calculate (requires -e flag)"
+#~ msgstr "Percentil a calcular (requiere la opción -e)"
+#~ msgid "Calculates new grid3D volume from r3.mapcalc expression."
+#~ msgstr ""
+#~ "Calcula un nuevo volumen grid3D a partir de una expresión r3.mapcalc."
+#~ msgid "A (grid3D file)"
+#~ msgstr "A (archivo grid3D)"
+#~ msgid "B (grid3D file)"
+#~ msgstr "B (archivo grid3D)"
+#~ msgid "C (grid3D file)"
+#~ msgstr "C (archivo grid3D)"
+#~ msgid "D (grid3D file)"
+#~ msgstr "D (archivo grid3D)"
+#~ msgid "E (grid3D file)"
+#~ msgstr "E (archivo grid3D)"
+#~ msgid "F (grid3D file)"
+#~ msgstr "F (archivo grid3D)"
+#~ msgid "Name for output grid3D volume"
+#~ msgstr "Nombre para el volumen grid3D de salida"
+#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
+#~ msgstr "Modo experto (introducir un conjunto de expresiones r3.mapcalc)"
+#~ msgid "Rebuilds topology on all vector maps in the current mapset."
+#~ msgstr ""
+#~ "Reconstruye la topología de todos los mapas vectoriales en el directorio "
+#~ "de mapas actual"
+#~ msgid "Adds missing centroids to closed boundaries."
+#~ msgstr "Añade los centroides que faltan a contornos cerrados."
+#~ msgid "vector, centroid, area"
+#~ msgstr "vectorial, centroide, área"
+#~ msgid "Name of input vector map"
+#~ msgstr "Nombre del mapa vectorial de entrada"
+#~ msgid "Name for output vector map"
+#~ msgstr "Nombre para el mapa vectorial de salida"
+#~ msgid "Action to be taken"
+#~ msgstr "Acción a tomar"
+#~ msgid "Category number starting value"
+#~ msgstr "Valor inicial de número de categoría"
+#, fuzzy
+#~ msgid "vector, color table"
+#~ msgstr "ráster, remuestrear"
+#, fuzzy
+#~ msgid "Name of column containg numeric data"
+#~ msgstr "Nombre de la columna que contiene las coordenadas X"
+#, fuzzy
+#~ msgid "Layer number of data column"
+#~ msgstr "Capa a la que añadir la columna"
+#, fuzzy
+#~ msgid "Name of color column to populate"
+#~ msgstr "Nombre de la columna a mostrar"
+#, fuzzy
+#~ msgid "Manually set range (min,max)"
+#~ msgstr "Rango de enteros: mínimo, máximo"
+#~ msgid "Path to rules file"
+#~ msgstr "Ruta al archivo de reglas"
+#, fuzzy
+#~ msgid "Save placeholder raster map for use with d.legend"
+#~ msgid ""
+#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+#~ "format"
+#~ msgstr ""
+#~ "Convierte todos los mapas vectoriales del antiguo GRASS < Ver5.7 del "
+#~ "directorio de mapas actual al formato actual."
+#~ msgid "run non-interactively"
+#~ msgstr "ejecutar de forma no interactiva"
+#~ msgid ""
+#~ "Adds one or more columns to the attribute table connected to a given "
+#~ "vector map."
+#~ msgstr ""
+#~ "Añade una o más columnas a la tabla de atributos conectada a un mapa "
+#~ "vectorial dado."
+#~ msgid "Vector map for which to edit attribute table"
+#~ msgstr "Mapa vectorial para el que editar la tabla de atributos"
+#~ msgid "Layer where to add column"
+#, fuzzy
+#~ msgid ""
+#~ "Name and type of the new column(s) (types depend on database backend, but "
+#~ "all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
+#~ msgstr ""
+#~ "Nombre y tipo de la nueva columna(s) (los tipos dependen de la base de "
+#~ "datos de destino, pero todas soportan VARCHAR(), ENTERO, DOBLE Y FECHA)"
+#~ msgid ""
+#~ "Creates and adds a new attribute table to a given layer of an existing "
+#~ "vector map."
+#~ msgstr ""
+#~ "Crea y añade una nueva tabla de atributos a una capa dada de un mapa "
+#~ "vectorial existente."
+#~ msgid "Vector map for which to add new attribute table"
+#~ msgstr "Mapa vectorial al que añadir nueva tabla de atributos"
+#~ msgid "Name of new attribute table (default: vector map name)"
+#~ msgstr ""
+#~ "Nombre de la nueva tabla de atributos (por omisión: nombre del mapa "
+#~ "vectorial)"
+#~ msgid "Layer where to add new attribute table"
+#~ msgstr "Capa a la que añadir la nueva tabla de atributos"
+#~ msgid "Allows to join a table to a vector map table."
+#~ msgstr "Permite unir una tabla a la tabla de un mapa vectorial."
+#~ msgid "Vector map to which to join other table"
+#~ msgstr "Mapa vectorial al que unir otra tabla"
+#~ msgid "Layer where to join"
+#~ msgstr "Capa a la que unir"
+#~ msgid "Join column in map table"
+#~ msgstr "Columna a unir en la tabla del mapa"
+#~ msgid "Other table name"
+#~ msgstr "Nombre de la otra tabla"
+#~ msgid "Join column in other table"
+#~ msgstr "Columna a unir en la otra tabla"
+#~ msgid ""
+#~ "Drops a column from the attribute table connected to a given vector map."
+#~ msgstr ""
+#~ "Elimina una columna de la tabla de atributos conectada a un mapa "
+#~ msgid "Vector map for which to drop attribute column"
+#~ msgstr "Mapa vectorial del que eliminar una columna de atributos"
+#~ msgid "Layer where to drop column"
+#~ msgstr "Capa de la que eliminar una columna"
+#~ msgid "Removes existing attribute table of a vector map."
+#~ msgstr "Elimina la tabla de atributos existente de un mapa vectorial."
+#~ msgid "Force removal (required for actual deletion of table)"
+#~ msgstr "Forzar eliminación (requerido para el borrado real de la tabla)"
+#~ msgid "Vector map from which to remove attribute table"
+#~ msgstr "Mapa vectorial del que eliminar la tabla de atributos"
+#~ msgid "Name of existing attribute table (default: vector map name)"
+#~ msgstr ""
+#~ "Nombre de la tabla de atributos existente (por omisión: nombre del mapa "
+#~ "vectorial)"
+#~ msgid "Layer from which to drop linked attribute table"
+#~ msgstr "Capa de la que eliminar la tabla de atributos asociada"
+#, fuzzy
+#~ msgid ""
+#~ "Renames a column in the attribute table connected to a given vector map."
+#~ msgstr ""
+#~ "Cambia el nombre de una columna en la tabla de atributos conectada a un "
+#~ "mapa vectorial dado."
+#~ msgid "Vector map for which to rename attribute column"
+#~ msgstr ""
+#~ "Mapa vectorial en el que cambiar el nombre de una columna de atributos"
+#~ msgid "Layer where to rename column"
+#~ msgstr "Capa en la que cambiar el nombre de una columna"
+#~ msgid "Old and new name of the column (old,new)"
+#~ msgstr "Nombre antiguo y nuevo de la columna (antiguo,nuevo)"
+#~ msgid "Reconnects vectors to a new database."
+#~ msgstr "Conecta vectoriales a una nueva base de datos."
+#, fuzzy
+#~ msgid "Name of old database"
+#~ msgstr "Nombre de la nueva base de datos"
+#, fuzzy
+#~ msgid ""
+#~ "The database must be in form printed by v.db.connect -g, i.e. with "
+#~ "substituted variables"
+#~ msgstr ""
+#~ "Nombre de la antigua base de datos. La base de datos debe estar en la "
+#~ "forma impresa por v.db.connect -g, esto es, con variables sustituidas"
+#~ msgid "Name of new database"
+#~ msgid "Old schema"
+#~ msgstr "Esquema antiguo"
+#~ msgid "New schema"
+#~ msgstr "Esquema nuevo"
+#~ msgid ""
+#~ "Calculates univariate statistics on selected table column for a GRASS "
+#~ "vector map."
+#~ msgstr ""
+#~ "Calcula estadísticas univariante sobre la columna de tabal seleccionada "
+#~ "para un mapa vectorial de GRASS."
+#~ msgid "Extended statistics (quartiles and 90th percentile)"
+#~ msgstr "Estadísticas ampliadas (cuartiles y percentiles 90)"
+#~ msgid "Name of data table"
+#~ msgstr "Nombre de la tabla de datos"
+#~ msgid "Column on which to calculate statistics (must be numeric)"
+#~ msgstr "Columna sobre la que calcular las estadísticas (debe ser numérica)"
+#~ msgid "Database/directory for table"
+#~ msgstr "Base de datos/directorio para la tabla"
+#~ msgid "Database driver"
+#~ msgstr "Controlador de base de datos"
+#~ msgid ""
+#~ "Allows to update a column in the attribute table connected to a vector "
+#~ "map."
+#~ msgstr ""
+#~ "Permite actualizar una columna en la tabla de atributos conectada a un "
+#~ "mapa vectorial."
+#~ msgid "Vector map to edit the attribute table for"
+#~ msgid "Layer to which the table to be changed is connected"
+#~ msgstr "Capa al que está conectada la tabla a cambiar"
+#~ msgid "Column to update"
+#~ msgstr "Columna a actualizar"
+#, fuzzy
+#~ msgid ""
+#~ "Value to update the column with (varchar values have to be in single "
+#~ "quotes, e.g. 'grass')"
+#~ msgstr ""
+#~ "Valor con el que actualizar la columna (los valores varchar tienen que "
+#~ "estar entre comillas simples, ej.: 'grass')"
+#~ msgid "Column to query"
+#~ msgstr "Columna a consultar"
+#~ msgid ""
+#~ "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
+#~ "col2>1)"
+#~ msgstr ""
+#~ "Condiciones WHERE para actualizar, sin palabra clave 'where' (ej.: cat=1 "
+#~ "o col1/col2>1)"
+#~ msgid ""
+#~ "Dissolves boundaries between adjacent areas sharing a common category "
+#~ "number or attribute."
+#~ msgstr ""
+#~ "Disuelve contornos entre áreas adyacentes que comparten un número de "
+#~ "categoría o atributo común."
+#~ msgid "vector, area, dissolve"
+#~ msgstr "vectorial, área, disolver"
+#, fuzzy
+#~ msgid "Layer number. If -1, all layers are extracted."
+#~ msgstr "Número de capa. Si es -1, se extraerán todas las capas"
+#~ msgid "Name of column used to dissolve common boundaries"
+#~ msgstr "Nombre de columna usada para disolver contornos comunes"
+#~ msgid "Import E00 file into a vector map."
+#~ msgstr "Importar archivo E00 a mapa vectorial."
+#~ msgid "E00 file"
+#~ msgstr "Archivo E00"
+#~ msgid "Input type point, line or area"
+#~ msgstr "Tipo de entrada: punto, línea o área"
+#~ msgid ""
+#~ "Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
+#~ "vector map."
+#~ msgstr ""
+#~ "Descarga waypoints, rutas y caminos desde un receptor GPS Garmin a un "
+#~ msgid "vector, import, GPS"
+#~ msgstr "vectorial, importar, GPS"
+#~ msgid "Download Waypoints from GPS"
+#~ msgstr "Descargar Waypoints desde GPS"
+#~ msgid "Download Routes from GPS"
+#~ msgstr "Descargar Rutas desde GPS"
+#~ msgid "Download Track from GPS"
+#~ msgstr "Descargar Caminos desde GPS"
+#~ msgid "Force import of track or route data as points"
+#~ msgstr "Forzar la importación de datos de pista o ruta como puntos"
+#~ msgid "Use gardump instead of gpstrans as the download program"
+#~ msgstr "Usar gardump en vez de gpstrans como programa de descarga"
+#~ msgid "Import track in 3D (gardump only)"
+#~ msgstr "Importar track en 3D (sólo gardump)"
+#~ msgid "Do not attempt projection transform from WGS84"
+#~ msgstr "No intentar transformar la proyección a partir de WGS84"
+#~ msgid "Name for output vector map (omit for display to stdout)"
+#~ msgstr ""
+#~ "Nombre para el mapa vectorial de salida (omitir para visualización a "
+#~ "stdout)"
+#~ msgid "Port Garmin receiver is connected to"
+#~ msgstr "Receptor Garmin conectado al puerto"
+#, fuzzy
+#~ msgid "Imports geonames.org country files into a GRASS vector points map."
+#~ msgstr ""
+#~ "Importa archivos de país del Servidor de Nombres Geonet (GNS) US-NGA a un "
+#~ "mapa vectorial de puntos de GRASS."
+#, fuzzy
+#~ msgid "vector, import, gazetteer"
+#~ msgstr "vectorial, importar, "
+#, fuzzy
+#~ msgid "Uncompressed geonames file from (with .txt extension)"
+#~ msgstr "Archivo GNS sin comprimir de NGA (con extensión .txt)"
+#~ msgid ""
+#~ "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS "
+#~ "vector points map."
+#~ msgstr ""
+#~ msgid "Uncompressed GNS file from NGA (with .txt extension)"
+#~ msgid ""
+#~ "Import waypoints, routes, and tracks from a GPS receiver or GPS download "
+#~ "file into a vector map."
+#~ msgstr ""
+#~ "Importar waypoints, rutas y caminos desde un receptor GPS o un archivo de "
+#~ "descarga de GPS a un mapa vectorial."
+#~ msgid "Import waypoints"
+#~ msgstr "Importar waypoints"
+#~ msgid "Import routes"
+#~ msgstr "Importar rutas"
+#~ msgid "Import track"
+#~ msgstr "Importar caminos"
+#~ msgid "Force vertices of track or route data as points"
+#~ msgstr "Forzar vértices de caminos o rutas como puntos"
+#~ msgid "Device or file used to import data"
+#~ msgstr "Dispositivo o archivo usado para importar datos"
+#~ msgid "Format of GPS input data (use gpsbabel supported formats)"
+#~ msgstr ""
+#~ "Formato de datos de entrada del GPS (usar formatos soportados por "
+#~ "gpsbabel)"
+#~ msgid ""
+#~ "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is "
+#~ "assumed"
+#~ msgstr ""
+#~ "Proyección de los datos de entrada (en estilo PROJ.4). Si no se indica se "
+#~ "asume Latitud/Longitud WGS84"
+#~ msgid "Import Mapgen or Matlab vector maps into GRASS."
+#~ msgstr "Importar mapas vectoriales Mapgen o Matlab a GRASS."
+#~ msgid "Input map is in Matlab format"
+#~ msgstr "El archivo de entrada está en formato Matlab"
+#~ msgid "Create a 3D vector points map from 3 column Matlab data"
+#~ msgstr ""
+#~ "Crear un mapa vectorial 3D de puntos a partir de datos Matlab de 3 "
+#~ "columnas"
+#~ msgid "Name of input file in Mapgen/Matlab format"
+#~ msgstr "Nombre del archivo de entrada en formato Mapgen/Matlab"
+#~ msgid ""
+#~ "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector "
+#~ "maps."
+#~ msgstr ""
+#~ "Convierte todos los mapas de lugares del antiguo GRASS < Ver5.7 del "
+#~ "directorio de mapas actual a mapas vectoriales."
+#~ msgid "sites, vector, import"
+#~ msgstr "lugares, vectorial, importar"
+#~ msgid "Run non-interactively"
+#~ msgstr "Ejecutar de forma no interactiva"
+#~ msgid "import GetFeature from WFS"
+#~ msgstr "Importar GetFeature de WFS"
+#~ msgid "GetFeature URL starting with http"
+#~ msgstr "URL de GetFeature comenzando con http"
+#~ msgid "Vector output map"
+#~ msgstr "Mapa vectorial de salida"
+#, fuzzy
+#~ msgid "vector, export, GPS"
+#, fuzzy
+#~ msgid "Export as waypoints"
+#, fuzzy
+#~ msgid "Export as routes"
+#, fuzzy
+#~ msgid "Export as tracks"
+#, fuzzy
+#~ msgid "Feature type(s)"
+#~ msgstr "Tipo de elemento"
+#, fuzzy
+#~ msgid "Name for output file or GPS device"
+#~ msgstr "Nombre para el archivo de salida"
+#, fuzzy
+#~ msgid "GpsBabel supported output format"
+#~ msgstr "Listar formatos de salida soportados"
+#~ msgid ""
+#~ "Calculates univariate statistics from a GRASS raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "Calcular estadísticas univariantes a partir de un mapa ráster de GRASS "
+#~ "basadas en polígonos vectoriales y carga las estadísticas en nuevas "
+#~ "columnas de atributos."
+#~ msgid "vector, raster, statistics"
+#~ msgstr "vectorial, ráster, estadísticas"
+#~ msgid "Continue if upload column(s) already exist"
+#~ msgstr "Continuar si la columna(s) en la que cargar ya existe"
+#~ msgid "Name of vector polygon map"
+#~ msgstr "Nombre del mapa de polígono vectorial"
+#~ msgid "Name of raster map to calculate statistics from"
+#~ msgstr "Nombre del mapa ráster del que calcular estadísticas"
+#~ msgid "Column prefix for new attribute columns"
+#~ msgstr "Prefijo de columna para las nuevas columnas de atributos"
+#~ msgid "Reports geometry statistics for vectors."
+#~ msgstr "Informa estadísticas de geometría para vectoriales."
+#~ msgid "vector, report, statistics"
+#~ msgstr "vectorial, informe, estadísticas"
+#~ msgid "Reverse sort the result"
+#~ msgstr "Resultado en orden inverso"
+#~ msgid "Sort the result"
+#~ msgstr "Ordenar el resultado"
+#~ msgid "Value to calculate"
+#~ msgstr "Valor a calcular"
+#~ msgid "Uploads vector values at positions of vector points to the table."
+#~ msgstr ""
+#~ "Carga valores vectoriales en las posiciones de puntos vectoriales a la "
+#~ "tabla."
+#~ msgid "Points vector map to modify"
+#~ msgstr "Mapa vectorial de puntos a modificar"
+#~ msgid "Layer in the vector to be modified"
+#~ msgstr "Capa del vectorial a modificar"
+#~ msgid "Column to be updated with the query result"
+#~ msgstr "Columna a actualizar con el resultado de la consulta"
+#~ msgid "Vector map to be queried"
+#~ msgstr "Mapa vectorial a consultar"
+#, fuzzy
+#~ msgid "Layer of the query vector containing data"
+#~ msgstr "Capa del vectorial consultado que contiene datos"
+#~ msgid "Column to be queried"
+#, fuzzy
+#~ msgid "Maximum query distance in map units"
+#~ msgstr "Distancia de buffer en unidades de mapa"
+#~ msgid "unable to open MASK"
+#~ msgstr "no se puede abrir MÁSCARA"
+#~ msgid "Unable to open MASK"
+#~ msgstr "No se puede abrir MÁSCARA"
+#, fuzzy
+#~ msgid ""
+#~ "Computes direct (beam), diffuse and reflected solar irradiation raster "
+#~ "maps for given day, latitude, surface and atmospheric conditions. Solar "
+#~ "parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+#~ "irradiance, daylight length) are saved in a local text file. "
+#~ "Alternatively, a local time can be specified to compute solar incidence "
+#~ "angle and/or irradiance raster maps. The shadowing effect of the "
+#~ "topography is optionally incorporated."
+#~ msgstr ""
+#~ "Procesa mapas ráster de irradiación solar directa (rayo), difusa y "
+#~ "reflejada para un día, latitud, superficie y condiciones atmosféricas "
+#~ "dados. Los parámetros solares (ej. horas de salida y puesta del sol, "
+#~ "declinación, irradiancia extraterrestre, duración del día) se guardan en "
+#~ "el archivo histórico del mapa. De forma alternativa, se puede especificar "
+#~ "una hora local para procesar el ángulo de incidencia solar y/o mapas "
+#~ "ráster de irradiancia. El efecto de sombreo de la topografía se puede "
+#~ "incorporar opcionalmente."
+#, fuzzy
+#~ msgid "incidout requres time parameter to be set"
+#~ msgstr "incidout requiere que se establezca el parámetro hora local (time)"
+#, fuzzy
+#~ msgid "Mode 2: integrated daily irradiation"
+#~ msgstr ""
+#~ "Modo 2: irradiación diaria integrada para un día determinado del año"
+#~ msgid "It was impossible to open table"
+#~ msgstr "Fue imposible abrir la tabla"
+#~ msgid "Spline type of interpolation"
+#~ msgstr "Tipo spline de interpolación"
+#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
+#~ msgstr "mi(llas),f(pies),me(tros),k(ilómetros),a(cres),h(ectáreas)"
+#~ msgid "Eigen values:"
+#~ msgstr "Valores Eigen:"
+#~ msgid "Script kill option"
+#~ msgstr "Opción de matar el script"
+#~ msgid "Start in Demo mode"
+#~ msgstr "Empezar en modo Demo"
+#~ msgid "Output more comments (default=quiet)"
+#~ msgstr "Mostrar más comentarios (por omisión=silencio)"
#~ msgid "Use db.select for SELECT SQL statements"
#~ msgstr "Usar db.select para sentencias SQL SELECT"
@@ -31959,10 +31718,6 @@
#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
#~ msgstr "Nombre del mapa ráster de derivadas de Y [m/m] o [pies/pies]"
-#, fuzzy
-#~ msgid "Output"
-#~ msgstr "Salida:"
#~ msgid "Threshold distance set to %g map units (based on 2D resolution)"
#~ msgstr ""
#~ "Distancia umbral establecida a %g unidades de mapa (basado en resolución "
Modified: grass/branches/develbranch_6/locale/po/grassmods_ru.po
--- grass/branches/develbranch_6/locale/po/grassmods_ru.po 2009-05-22 15:36:57 UTC (rev 37374)
+++ grass/branches/develbranch_6/locale/po/grassmods_ru.po 2009-05-22 15:53:49 UTC (rev 37375)
@@ -6,12 +6,12 @@
msgstr ""
"Project-Id-Version: grassmods_ru\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2009-01-09 17:00+0100\n"
-"PO-Revision-Date: 2008-10-10 20:19-0600\n"
+"POT-Creation-Date: 2009-05-22 17:09+0200\n"
+"PO-Revision-Date: 2009-05-15 00:23-0600\n"
"Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
"Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=utf-8\n"
+"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"X-Generator: KBabel 1.9.1\n"
@@ -19,10 +19,10 @@
#: ../db/base/tables.c:46 ../db/base/droptable.c:44 ../db/base/select.c:62
#: ../db/base/columns.c:45 ../db/base/describe.c:52 ../db/base/databases.c:52
#: ../vector/v.db.connect/main.c:189 ../vector/v.db.connect/main.c:255
-#: ../vector/v.edit/select.c:513 ../vector/v.out.ascii/b2a.c:43
+#: ../vector/v.edit/select.c:513 ../vector/v.out.ascii/b2a.c:44
#: ../vector/v.in.sites/main.c:158 ../vector/v.out.svg/main.c:141
#: ../vector/v.out.vtk/writeVTK.c:634 ../vector/v.drape/main.c:288
-#: ../vector/v.out.ogr/main.c:322 ../vector/v.extract/main.c:286
+#: ../vector/v.out.ogr/main.c:325 ../vector/v.extract/main.c:286
#: ../doc/vector/v.example/main.c:123 ../display/d.vect/main.c:499
#: ../display/d.thematic.area/main.c:231
#, c-format
@@ -57,10 +57,6 @@
msgid "Ignore SQL errors and continue"
msgstr "ÐÑопÑÑÑиÑÑ Ð¾Ñибки SQL и пÑодолжиÑÑ"
-#: ../db/base/execute.c:150
-msgid "Use db.select for SELECT SQL statements"
-msgstr "ÐÑполÑзоваÑÑ db.select Ð´Ð»Ñ SQL-опеÑаÑоÑа SELECT"
#: ../db/base/createdb.c:71 ../db/base/dropdb.c:71 ../db/base/droptable.c:78
#: ../db/base/databases.c:90 ../db/db.login/main.c:43
msgid "database, SQL"
@@ -75,7 +71,6 @@
msgstr "ÐопиÑоваÑÑ ÑаблиÑÑ."
#: ../db/base/copy.c:37
-#, fuzzy
msgid ""
"Either 'from_table' (optionally with 'where') can be used or 'select' "
"option, but not 'from_table' and 'select' at the same time."
@@ -147,11 +142,6 @@
#: ../db/base/tables.c:95 ../db/base/drivers.c:74 ../db/base/columns.c:92
#: ../db/base/describe.c:125 ../db/base/connect.c:45
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:2
-#: ../locale/scriptstrings/db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
-#: ../locale/scriptstrings/db.test_to_translate.c:2
msgid "database, attribute table"
msgstr "база даннÑÑ
, аÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
@@ -191,9 +181,9 @@
msgid "Name of file with sql statement"
msgstr "Ðазвание Ñайла, ÑодеÑжаÑего SQL-опеÑаÑоÑ"
-#: ../db/base/select.c:199 ../locale/scriptstrings/r.tileset_to_translate.c:13
-#: ../raster/r.distance/parse.c:50 ../raster/r.stats/main.c:121
-#: ../raster/r.cats/main.c:72 ../vector/v.db.select/main.c:63
+#: ../db/base/select.c:199 ../raster/r.distance/parse.c:50
+#: ../raster/r.stats/main.c:121 ../raster/r.cats/main.c:72
+#: ../vector/v.db.select/main.c:63
msgid "Output field separator"
msgstr "ÐÑÑ
одной ÑазделиÑÐµÐ»Ñ Ð¿Ð¾Ð»ÐµÐ¹"
@@ -238,11 +228,11 @@
msgstr "СпиÑок вÑеÑ
ÑÑолбÑов в данной ÑаблиÑе."
#: ../db/base/describe.c:63 ../vector/v.db.connect/main.c:200
-#: ../vector/v.in.ascii/in.c:405 ../vector/v.info/main.c:214
+#: ../vector/v.in.ascii/in.c:408 ../vector/v.info/main.c:214
#: ../vector/v.patch/main.c:139 ../vector/v.patch/main.c:177
#: ../vector/v.random/main.c:199 ../vector/v.out.svg/main.c:154
#: ../vector/v.out.vtk/writeVTK.c:643 ../vector/v.drape/main.c:299
-#: ../vector/v.out.ogr/main.c:332 ../doc/vector/v.example/main.c:134
+#: ../vector/v.out.ogr/main.c:335 ../doc/vector/v.example/main.c:134
#, c-format
msgid "Unable to describe table <%s>"
msgstr "Ðевозможно опиÑаÑÑ ÑаблиÑÑ <%s>"
@@ -369,9 +359,8 @@
msgstr "ÐаÑÐ¾Ð»Ñ ÑоÑ
Ñанен в Ñайле"
#: ../db/drivers/sqlite/db.c:84
-#, fuzzy
msgid "Unable to open database: "
-msgstr "Ðевозможно оÑкÑÑÑÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
<%s>"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
#: ../db/drivers/sqlite/describe.c:159
#, c-format
@@ -614,7 +603,7 @@
msgstr "СÑÑока Ñимволов Ð´Ð»Ñ Ð¾ÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð¿ÑÑÑÑÑ
ÑÑеек"
#: ../raster3d/r3.out.ascii/main.c:103 ../raster/r.out.ascii/main.c:104
-#: ../raster/r.out.arc/main.c:88
+#: ../raster/r.out.arc/main.c:89
msgid "Suppress printing of header information"
msgstr "Ðе вÑводиÑÑ Ð½Ð° пеÑаÑÑ ÑодеÑжимое заголовка"
@@ -890,7 +879,7 @@
#: ../vector/v.generalize/simplification.c:341
#: ../vector/v.generalize/point.c:120 ../vector/v.generalize/network.c:93
#: ../vector/v.generalize/network.c:128 ../vector/v.mkgrid/write_grid.c:131
-#: ../vector/v.surf.rst/main.c:859 ../vector/v.mapcalc/list.c:54
+#: ../vector/v.surf.rst/main.c:866 ../vector/v.mapcalc/list.c:54
#: ../vector/v.mapcalc/list.c:501 ../imagery/i.smap/bouman/multialloc.c:115
#: ../imagery/i.ask/popup.c:174
msgid "Out of memory"
@@ -1095,14 +1084,15 @@
#: ../raster/r.coin/inter.c:44 ../raster/r.coin/main.c:127
#: ../raster/r.coin/main.c:130 ../raster/r.distance/parse.c:79
#: ../raster/r.distance/parse.c:86 ../raster/r.reclass/main.c:78
-#: ../raster/r.los/main.c:160 ../raster/r.los/main.c:166
-#: ../raster/r.drain/main.c:153 ../raster/r.out.ascii/main.c:146
-#: ../raster/r.carve/main.c:178 ../raster/r.profile/main.c:142
-#: ../raster/r.texture/main.c:228 ../raster/r.basins.fill/main.c:93
-#: ../raster/r.basins.fill/main.c:105 ../raster/r.sum/main.c:62
-#: ../raster/r.null/null.c:113 ../raster/r.average/main.c:72
-#: ../raster/r.average/main.c:75 ../raster/r.lake/main.c:254
-#: ../raster/r.lake/main.c:265 ../raster/r.out.gridatb/check_ready.c:12
+#: ../raster/r.los/main.c:162 ../raster/r.los/main.c:168
+#: ../raster/r.drain/main.c:189 ../raster/r.drain/main.c:218
+#: ../raster/r.out.ascii/main.c:146 ../raster/r.carve/main.c:178
+#: ../raster/r.profile/main.c:142 ../raster/r.texture/main.c:228
+#: ../raster/r.basins.fill/main.c:93 ../raster/r.basins.fill/main.c:105
+#: ../raster/r.sum/main.c:62 ../raster/r.null/null.c:113
+#: ../raster/r.average/main.c:72 ../raster/r.average/main.c:75
+#: ../raster/r.lake/main.c:254 ../raster/r.lake/main.c:265
+#: ../raster/r.out.gridatb/check_ready.c:12
#: ../raster/r.surf.idw2/read_cell.c:19 ../raster/r.transect/main.c:119
#: ../raster/simwe/simlib/input.c:178 ../raster/simwe/simlib/input.c:184
#: ../raster/simwe/simlib/input.c:189 ../raster/simwe/simlib/input.c:198
@@ -1116,38 +1106,37 @@
#: ../raster/r.grow2/main.c:187 ../raster/r.surf.idw/main.c:108
#: ../raster/r.thin/io.c:96 ../raster/r.flow/io.c:63
#: ../raster/r.topidx/check_ready.c:11 ../raster/r.out.pov/main.c:174
-#: ../raster/r.covar/main.c:95 ../raster/r.out.arc/main.c:114
-#: ../raster/r.report/parse.c:243 ../raster/r.random/main.c:113
-#: ../raster/r.random/main.c:118 ../raster/r.his/main.c:127
+#: ../raster/r.covar/main.c:95 ../raster/r.out.arc/main.c:121
+#: ../raster/r.report/parse.c:243 ../raster/r.random/main.c:119
+#: ../raster/r.random/main.c:124 ../raster/r.his/main.c:127
#: ../raster/r.his/main.c:164 ../raster/r.his/main.c:189
#: ../raster/r.bilinear/main.c:81 ../raster/r.kappa/stats.c:30
#: ../raster/r.kappa/stats.c:35 ../raster/r.kappa/main.c:161
-#: ../raster/r.median/main.c:75 ../raster/r.resamp.rst/main.c:400
-#: ../raster/r.resamp.rst/main.c:426 ../raster/r.stats/main.c:272
+#: ../raster/r.median/main.c:75 ../raster/r.resamp.rst/main.c:396
+#: ../raster/r.resamp.rst/main.c:422 ../raster/r.stats/main.c:272
#: ../raster/r.slope.aspect/main.c:384 ../raster/r.colors/main.c:291
#: ../raster/r.colors/main.c:370 ../raster/r.out.ppm/main.c:116
#: ../raster/r.fill.dir/main.c:172 ../raster/r.mfilter.fp/main.c:126
-#: ../raster/r.cost/main.c:322 ../raster/r.out.vtk/main.c:47
+#: ../raster/r.cost/main.c:340 ../raster/r.out.vtk/main.c:47
#: ../raster/r.out.vtk/main.c:60 ../raster/r.support/modcolr/modcolr.c:45
#: ../raster/r.support/front/front.c:224 ../raster/r.out.bin/main.c:129
-#: ../raster/r.neighbors/main.c:185 ../raster/r.clump/main.c:87
+#: ../raster/r.neighbors/main.c:192 ../raster/r.clump/main.c:87
#: ../raster/r.to.vect/main.c:111 ../raster/r.region/main.c:170
#: ../raster/r.region/main.c:229 ../raster/r.region/main.c:352
#: ../raster/r.out.ppm3/main.c:120 ../raster/r.univar2/r.univar_main.c:148
-#: ../raster/r.watershed/ram/init_vars.c:412
-#: ../raster/r.watershed/seg/init_vars.c:461 ../raster/r.contour/main.c:158
-#: ../raster/r.cross/main.c:125 ../raster/r.cats/main.c:125
-#: ../raster/r.cats/main.c:146 ../raster/r.series/main.c:193
-#: ../raster/r.water.outlet/legal.c:23 ../raster/r.out.tiff/r.out.tiff.c:166
-#: ../raster/r.out.mpeg/main.c:217 ../raster/r.walk/main.c:523
-#: ../raster/r.walk/main.c:526 ../raster/r.mapcalc/map.c:377
-#: ../raster/r.recode/main.c:80 ../raster/r.mfilter/main.c:119
-#: ../raster/r.composite/main.c:155 ../raster/wildfire/r.ros/main.c:322
-#: ../raster/wildfire/r.ros/main.c:335 ../raster/wildfire/r.ros/main.c:340
-#: ../raster/wildfire/r.ros/main.c:345 ../raster/wildfire/r.ros/main.c:350
-#: ../raster/wildfire/r.ros/main.c:368 ../raster/wildfire/r.ros/main.c:372
-#: ../raster/wildfire/r.ros/main.c:391 ../raster/wildfire/r.ros/main.c:395
-#: ../raster/wildfire/r.ros/main.c:408 ../raster/wildfire/r.spread/main.c:356
+#: ../raster/r.contour/main.c:158 ../raster/r.cross/main.c:125
+#: ../raster/r.cats/main.c:125 ../raster/r.cats/main.c:146
+#: ../raster/r.series/main.c:193 ../raster/r.water.outlet/legal.c:23
+#: ../raster/r.out.tiff/r.out.tiff.c:166 ../raster/r.out.mpeg/main.c:217
+#: ../raster/r.walk/main.c:546 ../raster/r.walk/main.c:549
+#: ../raster/r.mapcalc/map.c:377 ../raster/r.recode/main.c:80
+#: ../raster/r.mfilter/main.c:119 ../raster/r.composite/main.c:155
+#: ../raster/wildfire/r.ros/main.c:322 ../raster/wildfire/r.ros/main.c:335
+#: ../raster/wildfire/r.ros/main.c:340 ../raster/wildfire/r.ros/main.c:345
+#: ../raster/wildfire/r.ros/main.c:350 ../raster/wildfire/r.ros/main.c:368
+#: ../raster/wildfire/r.ros/main.c:372 ../raster/wildfire/r.ros/main.c:391
+#: ../raster/wildfire/r.ros/main.c:395 ../raster/wildfire/r.ros/main.c:408
+#: ../raster/wildfire/r.spread/main.c:356
#: ../raster/wildfire/r.spread/main.c:359
#: ../raster/wildfire/r.spread/main.c:362
#: ../raster/wildfire/r.spread/main.c:365
@@ -1155,23 +1144,23 @@
#: ../raster/wildfire/r.spread/main.c:372
#: ../raster/wildfire/r.spread/main.c:375 ../raster/r.resample/main.c:97
#: ../raster/r.buffer/main.c:127 ../raster/r.support.stats/main.c:48
-#: ../raster/r.bitpattern/main.c:101 ../raster/r.sun2/main.c:809
-#: ../raster/r.sun2/main.c:826 ../raster/r.sun2/main.c:841
-#: ../raster/r.sun2/main.c:854 ../raster/r.sun2/main.c:867
-#: ../raster/r.sun2/main.c:879 ../raster/r.sun2/main.c:895
-#: ../raster/r.sun2/main.c:908 ../raster/r.horizon/main.c:553
-#: ../vector/v.what.rast/main.c:138 ../vector/v.extrude/main.c:179
-#: ../vector/v.sample/main.c:158 ../vector/v.vol.rst/main.c:594
-#: ../vector/v.drape/main.c:245 ../doc/raster/r.example/main.c:111
-#: ../ps/ps.map/outl_io.c:68 ../imagery/i.ifft/ifftmain.c:95
-#: ../imagery/i.ifft/ifftmain.c:105 ../imagery/i.gensigset/parse.c:42
-#: ../imagery/i.his.rgb/openfiles.c:31 ../imagery/i.his.rgb/openfiles.c:36
-#: ../imagery/i.his.rgb/openfiles.c:41 ../imagery/i.group/main.c:205
-#: ../imagery/i.group/main.c:244 ../imagery/i.rgb.his/openfiles.c:14
-#: ../imagery/i.rgb.his/openfiles.c:16 ../imagery/i.rgb.his/openfiles.c:18
-#: ../imagery/i.pca/main.c:123 ../imagery/i.class/main.c:127
-#: ../imagery/i.gensig/parse.c:36 ../imagery/i.zc/main.c:111
-#: ../imagery/i.fft/fftmain.c:108
+#: ../raster/r.bitpattern/main.c:101 ../raster/r.sun2/main.c:813
+#: ../raster/r.sun2/main.c:828 ../raster/r.sun2/main.c:845
+#: ../raster/r.sun2/main.c:859 ../raster/r.sun2/main.c:871
+#: ../raster/r.sun2/main.c:883 ../raster/r.sun2/main.c:894
+#: ../raster/r.sun2/main.c:906 ../raster/r.sun2/main.c:918
+#: ../raster/r.horizon/main.c:553 ../vector/v.what.rast/main.c:138
+#: ../vector/v.extrude/main.c:179 ../vector/v.sample/main.c:158
+#: ../vector/v.vol.rst/main.c:606 ../vector/v.drape/main.c:245
+#: ../doc/raster/r.example/main.c:111 ../ps/ps.map/outl_io.c:68
+#: ../imagery/i.ifft/ifftmain.c:95 ../imagery/i.ifft/ifftmain.c:105
+#: ../imagery/i.gensigset/parse.c:42 ../imagery/i.his.rgb/openfiles.c:31
+#: ../imagery/i.his.rgb/openfiles.c:36 ../imagery/i.his.rgb/openfiles.c:41
+#: ../imagery/i.group/main.c:205 ../imagery/i.group/main.c:244
+#: ../imagery/i.rgb.his/openfiles.c:14 ../imagery/i.rgb.his/openfiles.c:16
+#: ../imagery/i.rgb.his/openfiles.c:18 ../imagery/i.pca/main.c:129
+#: ../imagery/i.class/main.c:127 ../imagery/i.gensig/parse.c:36
+#: ../imagery/i.zc/main.c:111 ../imagery/i.fft/fftmain.c:108
#: ../imagery/i.ortho.photo/photo.2target/main.c:197
#: ../imagery/i.ortho.photo/photo.2target/main.c:227
#: ../visualization/xganim/main.c:366 ../visualization/nviz2/cmd/surface.c:56
@@ -1545,7 +1534,7 @@
#: ../raster3d/r3.to.rast/main.c:183 ../raster/r.resamp.stats/main.c:341
#: ../raster/r.resamp.interp/main.c:148
-#: ../raster/r.surf.fractal/write_rast.c:58 ../raster/r.los/main.c:201
+#: ../raster/r.surf.fractal/write_rast.c:58 ../raster/r.los/main.c:203
#: ../raster/r.in.ascii/main.c:206 ../raster/r.carve/main.c:189
#: ../raster/r.texture/main.c:309 ../raster/r.basins.fill/main.c:117
#: ../raster/r.null/null.c:323 ../raster/r.lake/main.c:229
@@ -1565,17 +1554,17 @@
#: ../raster/r.mapcalc/map3.c:580 ../raster/r.mapcalc/map.c:507
#: ../raster/r.composite/main.c:192 ../raster/r.buffer/write_map.c:40
#: ../raster/r.in.arc/main.c:154 ../raster/r.bitpattern/main.c:125
-#: ../raster/r.sun2/main.c:1169 ../raster/r.sun2/main.c:1176
-#: ../raster/r.sun2/main.c:1183 ../raster/r.sun2/main.c:1190
-#: ../raster/r.sun2/main.c:1197 ../raster/r.sun2/main.c:1204
-#: ../vector/lidar/v.surf.bspline/main.c:290 ../vector/v.kernel/main.c:268
-#: ../vector/v.surf.idw/main.c:258 ../vector/v.neighbors/main.c:96
+#: ../raster/r.sun2/main.c:1166 ../raster/r.sun2/main.c:1173
+#: ../raster/r.sun2/main.c:1180 ../raster/r.sun2/main.c:1187
+#: ../raster/r.sun2/main.c:1194 ../raster/r.sun2/main.c:1201
+#: ../vector/lidar/v.surf.bspline/main.c:293 ../vector/v.kernel/main.c:268
+#: ../vector/v.surf.idw/main.c:259 ../vector/v.neighbors/main.c:96
#: ../vector/v.to.rast/vect2rast.c:125 ../vector/v.to.rast/vect2rast.c:129
#: ../doc/raster/r.example/main.c:141 ../imagery/i.ifft/ifftmain.c:219
#: ../imagery/i.his.rgb/openfiles.c:15 ../imagery/i.his.rgb/openfiles.c:17
#: ../imagery/i.his.rgb/openfiles.c:19 ../imagery/i.rgb.his/openfiles.c:29
#: ../imagery/i.rgb.his/openfiles.c:31 ../imagery/i.rgb.his/openfiles.c:33
-#: ../imagery/i.smap/shapiro/opencell.c:30 ../imagery/i.pca/main.c:393
+#: ../imagery/i.smap/shapiro/opencell.c:30 ../imagery/i.pca/main.c:401
#: ../imagery/i.rectify/write.c:49 ../imagery/i.maxlik/open.c:74
#, c-format
msgid "Unable to create raster map <%s>"
@@ -1613,1150 +1602,11 @@
msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
msgstr "РаÑÑÑовÑй Ñлой %d ÐÐ¼Ñ Ñайла: %s Ñже ÑÑÑеÑÑвÑеÑ. ÐÑÐ´ÐµÑ Ð¿ÐµÑезапиÑан!"
-#: ../locale/scriptstrings/d.m_to_translate.c:1
-msgid "Display manager for GRASS"
-msgstr "ÐоказаÑÑ Ð¼ÐµÐ½ÐµÐ´Ð¶ÐµÑ GRASS"
-#: ../locale/scriptstrings/d.m_to_translate.c:2
-msgid "Name of .dmrc settings file"
-msgstr "Ðазвание .dmrc Ñайла наÑÑÑоек"
-#: ../locale/scriptstrings/gis.m_to_translate.c:1
-msgid "GIS manager for GRASS"
-msgstr "GIS Ð¼ÐµÐ½ÐµÐ´Ð¶ÐµÑ Ð´Ð»Ñ GRASS"
-#: ../locale/scriptstrings/gis.m_to_translate.c:2
-msgid "Name of GIS manager settings file (.grc)"
-msgstr "Ðазвание Ñайла наÑÑÑоек GIS менеджеÑа (.grc)"
-#: ../locale/scriptstrings/r.li.setup_to_translate.c:1
-msgid "Configuration editor for r.li.'index'"
-msgstr "РедакÑÐ¾Ñ ÐºÐ¾Ð½ÑигÑÑаÑии Ð´Ð»Ñ r.li.'index'"
-#: ../locale/scriptstrings/r.li.setup_to_translate.c:2
-msgid "raster, landscape structure analysis"
-msgstr "ÑаÑÑÑ, ÑÑÑÑкÑÑÑнÑй анализ ландÑаÑÑа"
-#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-msgid "Prints a graph of the correlation between data layers (in pairs)."
-msgstr "ÐÑобÑажаÑÑ Ð³ÑаÑик коÑÑелÑÑии Ð¼ÐµÐ¶Ð´Ñ ÑлоÑми даннÑÑ
(паÑами)."
-#: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#: ../locale/scriptstrings/d.polar_to_translate.c:2
-msgid "display, diagram"
-msgstr "показ, диагÑамма"
-#: ../locale/scriptstrings/d.correlate_to_translate.c:3
-#: ../locale/scriptstrings/d.correlate_to_translate.c:4
-#: ../locale/scriptstrings/d.correlate_to_translate.c:5
-#: ../locale/scriptstrings/d.correlate_to_translate.c:6
-msgid "raster input map"
-msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:1
-msgid "Selects/starts specified monitor at specified size"
-msgstr "ÐÑбÑаÑÑ/задаÑÑ Ð¼Ð¾Ð½Ð¸ÑÐ¾Ñ Ñ Ð¾Ð¿ÑеделеннÑми ÑазмеÑами"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:2
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:2
-#: ../locale/scriptstrings/d.resize_to_translate.c:2
-#: ../locale/scriptstrings/d.split_to_translate.c:2
-#: ../display/d.colortable/main.c:66 ../display/d.extend/main.c:31
-msgid "display, setup"
-msgstr "показ, наÑÑÑойка"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:3
-msgid "Display monitor to start"
-msgstr "ÐÑобÑажаÑÑ Ð¼Ð¾Ð½Ð¸ÑÐ¾Ñ Ð¿Ñи запÑÑке"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:4
-msgid "Width in pixels of new display monitor"
-msgstr "ШиÑина в пикÑелÑÑ
Ð´Ð»Ñ Ð½Ð¾Ð²Ð¾Ð³Ð¾ мониÑоÑа"
-#: ../locale/scriptstrings/d.monsize_to_translate.c:5
-msgid "Height in pixels of new display monitor"
-msgstr "ÐÑÑоÑа в пикÑелÑÑ
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:1
-msgid "Moves displayed maps to another monitor"
-msgstr "ÐеÑемеÑÑиÑÑ Ð¿ÑоÑмаÑÑиваемÑе Ñлои на дÑÑгой мониÑоÑ"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:3
-msgid "clear target monitor before moving"
-msgstr "оÑиÑÑиÑÑ Ñелевой мониÑÐ¾Ñ Ð¿ÐµÑед пеÑемеÑением"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:4
-msgid "stay with source monitor"
-msgstr "оÑÑаваÑÑÑÑ Ð½Ð° иÑÑ
одном мониÑоÑе"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:5
-msgid "kill source monitor after moving"
-msgstr "ÑдалиÑÑ Ð¸ÑÑ
однÑй мониÑÐ¾Ñ Ð¿Ð¾Ñле пеÑемеÑениÑ"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:6
-msgid "Target monitor"
-msgstr "Целевой мониÑоÑ"
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:7
-msgid "Source monitor"
-msgstr "ÐÑÑ
однÑй мониÑоÑ"
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:1
-msgid "Export display monitor to a GpsDrive compatible backdrop image"
-msgstr ""
-"ÐкÑпоÑÑиÑоваÑÑ Ð´Ð¸Ñплей мониÑоÑа в Ñоновое изобÑажение ÑовмеÑÑимое Ñ GpsDrive"
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:2
-msgid "display, export, GPS"
-msgstr "диÑплей, ÑкÑпоÑÑ, GPS"
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:3
-#, fuzzy
-msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
-msgstr "Ð¸Ð¼Ñ Ð½Ð¾Ð²Ð¾Ð³Ð¾ обÑаза ÑÐ»Ð¾Ñ (наÑ
одиÑÑÑ Ð² ~/.gpsdrive)"
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:4
-msgid "Make JPEG instead of PNG image"
-msgstr "СоздаÑÑ JPEG на оÑнове PNG"
-#: ../locale/scriptstrings/d.out.png_to_translate.c:1
-msgid "Saves active display monitor to PNG file in home directory"
-msgstr "СоÑ
ÑаниÑÑ ÑодеÑжимое мониÑоÑа в Ñайл PNG в домаÑней папке"
-#: ../locale/scriptstrings/d.out.png_to_translate.c:2
-#: ../locale/scriptstrings/d.out.file_to_translate.c:2
-msgid "display, export"
-msgstr "диÑплей, ÑкÑпоÑÑ"
-#: ../locale/scriptstrings/d.out.png_to_translate.c:3
-msgid "Name of PNG file"
-msgstr "Ðазвание Ñайла PNG"
-#: ../locale/scriptstrings/d.out.png_to_translate.c:4
-msgid "Resolution of output file (single=1, double=2, quad=4)"
-msgstr ""
-"РазÑеÑение Ð´Ð»Ñ Ð²ÑÑ
одного Ñайла (один к одномÑ=1, двойной=2, ÑеÑÑÑеÑ
кÑаÑнÑй=4)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:1
-msgid "Saves the contents of the active display monitor to a graphics file."
-msgstr "СоÑ
Ñанение ÑодеÑÐ¶Ð°Ð½Ð¸Ñ Ð°ÐºÑивного мониÑоÑа в гÑаÑиÑеÑкий Ñайл."
-#: ../locale/scriptstrings/d.out.file_to_translate.c:3
-msgid "Name for output file (do NOT add extension)"
-msgstr "Ðазвание Ð´Ð»Ñ Ñайла вÑвода (ÐÐ ÑказÑваÑÑ ÑаÑÑиÑение)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:4
-#: ../visualization/nviz2/cmd/args.c:87
-msgid "Graphics file format"
-msgstr "ФоÑÐ¼Ð°Ñ Ð³ÑаÑиÑеÑкого Ñайла"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:5
-msgid "Dimensions of output file versus current window size"
-msgstr "Ð Ð°Ð·Ð¼ÐµÑ Ð²ÑÑ
одного Ñайла оÑноÑиÑелÑно ÑекÑÑего ÑазмеÑа окна"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:6
-msgid "(same=1, double size=2, quadruple size=4)"
-msgstr "(один к одномÑ=1, двойной ÑазмеÑ=2, ÑеÑÑÑеÑ
кÑаÑнÑй ÑазмеÑ=4)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:7
-#: ../locale/scriptstrings/d.out.file_to_translate.c:9
-#: ../locale/scriptstrings/d.out.file_to_translate.c:12
-#: ../locale/scriptstrings/d.out.file_to_translate.c:15
-#: ../locale/scriptstrings/d.out.file_to_translate.c:28
-#: ../locale/scriptstrings/d.out.file_to_translate.c:30
-msgid "Images"
-msgstr "ÐзобÑажениÑ"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:8
-msgid "Width and height of output image (overrides resolution setting)"
-msgstr "ШиÑина и вÑÑоÑа вÑÑ
одного изобÑÐ°Ð¶ÐµÐ½Ð¸Ñ (оÑменÑÑÑ Ð½Ð°ÑÑÑойки ÑазÑеÑениÑ)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:10
-msgid "Compression for PNG files"
-msgstr "СжаÑие Ð´Ð»Ñ PNG Ñайла"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:11
-msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-msgstr ""
-"(0=неÑ, 1=бÑÑÑÑо, 9=наиболÑÑее; без поÑеÑÑ, ÑолÑко вÑÐµÐ¼Ñ vs. ÑÐ°Ð·Ð¼ÐµÑ Ñайла)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:13
-msgid "File size/quality for JPEG files"
-msgstr "РазмеÑ/каÑеÑÑво Ñайла JPEG"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:14
-msgid "(10=smallest/worst, 100=largest/best)"
-msgstr "(10=незнаÑиÑелÑно/плоÑ
о, 100=знаÑиÑелÑно/Ñ
оÑоÑо)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:16
-msgid "Paper size for PostScript output"
-msgstr "Размег бÑмаги Ð´Ð»Ñ Ð²Ñвода PostScript"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:17
-#: ../locale/scriptstrings/d.out.file_to_translate.c:19
-#: ../locale/scriptstrings/d.out.file_to_translate.c:32
-msgid "PostScript"
-msgstr "PostScript"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:18
-msgid "PostScript level (only limits functionality!)"
-msgstr "УÑÐ¾Ð²ÐµÐ½Ñ PostScript (огÑаниÑÐµÐ½Ð½Ð°Ñ ÑÑнкÑионалÑноÑÑÑ!)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:20
-msgid "GeoTIFF creation option(s)"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:21
-#: ../raster/r.out.gdal/main.c:185
-msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma."
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:22
-#: ../locale/scriptstrings/d.out.file_to_translate.c:25
-#: ../locale/scriptstrings/d.out.file_to_translate.c:34
-msgid "GeoTIFF"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:23
-msgid "GeoTIFF metadata key(s) and value(s) to add"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:24
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:26
-msgid "Set background color to black (white default)"
-msgstr "СделаÑÑ Ñон ÑеÑнÑм (по ÑмолÑÐ°Ð½Ð¸Ñ - белÑй)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:27
-msgid "Set transparent background"
-msgstr "СделаÑÑ Ñон пÑозÑаÑнÑм"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:29
-msgid "Use the Cario driver to render images"
-msgstr "ÐÑполÑзоваÑÑ Ð´ÑÐ°Ð¹Ð²ÐµÑ Cario Ð´Ð»Ñ ÑендеÑинга изобÑажений"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:31
-msgid "Set paper orientation to landscape (for PostScript output)"
-msgstr "ÐлÑÐ±Ð¾Ð¼Ð½Ð°Ñ Ð¾ÑиенÑаÑÐ¸Ñ Ð±Ñмаги (Ð´Ð»Ñ Ð²Ñвода PostScript)"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:33
-msgid "Do not crop away margins"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:1
-msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-"СоздаÑÑ Ð¿Ð¾Ð»ÑÑнÑÑ Ð´Ð¸Ð°Ð³ÑÐ°Ð¼Ð¼Ñ ÑÐ»Ð¾Ñ Ñглов, Ñакого как ÑÐºÐ»Ð¾Ð½Ñ Ð¸Ð»Ð¸ напÑÐ°Ð²Ð»ÐµÐ½Ð¸Ñ "
-"поÑока"
-#: ../locale/scriptstrings/d.polar_to_translate.c:3
-msgid "Name of raster angle map"
-msgstr "Ðазвание ÑаÑÑÑового ÑÐ»Ð¾Ñ Ñглов"
-#: ../locale/scriptstrings/d.polar_to_translate.c:4
-msgid "Pixel value to be interpreted as undefined (different from NULL)"
-msgstr ""
-"ÐнаÑение пикÑÐµÐ»Ñ Ð±Ñло инÑеÑпÑеÑиÑовано как неопÑеделенное (оÑлиÑное Ð¾Ñ NULL)"
-#: ../locale/scriptstrings/d.polar_to_translate.c:5
-msgid "Name of optional EPS output file"
-msgstr "Ðазвание дополниÑелÑного EPS Ñайла вÑвода"
-#: ../locale/scriptstrings/d.polar_to_translate.c:6
-msgid "Plot using Xgraph"
-msgstr "ÐеÑаÑÑ Ñ Ð¸ÑполÑзованием Xgraph"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
-#: ../display/d.rast.edit/main.c:61
-msgid "Interactively edit cell values in a raster map."
-msgstr "ÐнÑеÑакÑивное ÑедакÑиÑование знаÑений ÑÑеек ÑаÑÑÑового ÑлоÑ"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
-#: ../display/d.rast.edit/main.c:59 ../display/d.rast/main.c:51
-msgid "display, raster"
-msgstr "показ, ÑаÑÑÑ"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
-#: ../raster/r.random/main.c:57 ../raster/r.resamp.rst/main.c:167
-#: ../raster/r.out.bin/main.c:73 ../raster/r.water.outlet/main.c:54
-#: ../imagery/i.zc/main.c:69
-msgid "Name of input raster map"
-msgstr "Ðазвание вводного ÑаÑÑÑового ÑлоÑ"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:9
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
-#: ../raster/r.in.gridatb/main.c:53 ../imagery/i.ifft/ifftmain.c:83
-msgid "Name for output raster map"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
-msgid "Name of aspect raster map"
-msgstr "Ðазвание Ð²Ð´Ð¾Ð»Ñ ÑÑоÑÐ¾Ð½Ñ ÑаÑÑÑового ÑлоÑ"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
-msgid "Width of display canvas"
-msgstr "ШиÑина полей диÑплеÑ"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
-msgid "Height of display canvas"
-msgstr "ÐÑÑоÑа полей диÑплеÑ"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
-msgid "Minimum size of each cell"
-msgstr "ÐинималÑнÑй ÑÐ°Ð·Ð¼ÐµÑ ÐºÐ°Ð¶Ð´Ð¾Ð¹ ÑÑейки"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
-msgid "Maximum number of rows to load"
-msgstr "ÐакÑималÑное колиÑеÑÑво загÑÑжаемÑÑ
ÑÑÑок"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
-msgid "Maximum number of columns to load"
ÑÑолбÑов "
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
-msgid "Displays a raster map and its legend on a graphics window"
-msgstr "ÐоказаÑÑ ÑаÑÑÑовÑй Ñлой и его Ð»ÐµÐ³ÐµÐ½Ð´Ñ Ð² окне гÑаÑики"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
-#: ../locale/scriptstrings/d.redraw_to_translate.c:2
-#: ../visualization/ximgview/main.c:270 ../display/d.histogram/main.c:71
-#: ../display/d.mapgraph/main.c:48 ../display/d.erase/main.c:32
-#: ../display/d.profile/main.c:61 ../display/d.measure/main.c:49
-#: ../display/d.colors/main.c:50 ../display/d.what.vect/main.c:54
-#: ../display/d.font/main.c:46 ../display/d.rast.num/number.c:84
-#: ../display/d.linegraph/linegraph.c:113 ../display/d.colorlist/main.c:35
-#: ../display/d.what.rast/main.c:52 ../display/d.title/main.c:45
-#: ../display/d.geodesic/main.c:45 ../display/d.text/main.c:66
-#: ../display/d.font.freetype/main.c:59 ../display/d.info/main.c:34
-#: ../display/d.save/main.c:79 ../display/d.rast.arrow/arrow.c:110
-#: ../display/d.menu/main.c:66 ../display/d.thematic.area/main.c:78
-#: ../display/d.text.freetype/main.c:138 ../display/d.extract/main.c:50
-#: ../display/d.rgb/main.c:55 ../display/d.where/main.c:42
-#: ../display/d.paint.labels/main.c:46 ../display/d.text.new/main.c:139
-#: ../display/d.ask/main.c:36 ../display/d.his/main.c:65
-#: ../display/d.zoom/main.c:57 ../display/d.rhumbline/main.c:45
-#: ../display/d.nviz/main.c:68 ../display/d.mon/cmd/main.c:48
-#: ../display/d.frame/frame.c:60
-msgid "display"
-msgstr "показаÑÑ/диÑплей"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
-#: ../display/d.legend/main.c:184
-msgid "Flip legend"
-msgstr "ÐеÑевеÑнÑÑÑ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
-msgid "Omit entries with missing label"
-msgstr "ÐÑопÑÑÑиÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ñ Ð¾ÑÑÑÑÑÑвÑÑÑей подпиÑÑÑ"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:4
-#: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:90
-msgid "Name of raster map"
-msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑлоÑ"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
-msgid "Number of lines to appear in the legend"
-msgstr "ЧиÑло линий в легенде"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
-msgid "Name of raster map to generate legend from"
-msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¸ÑполÑзÑемого Ð´Ð»Ñ ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
-#, fuzzy
-msgid "Name of raster map to print in legend"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
-msgid "Position of vertical map-legend separator (in percent)"
-msgstr ""
-#: ../locale/scriptstrings/d.redraw_to_translate.c:1
-msgid "Redraws the current display frame in the GRASS monitor"
-msgstr "ÐеÑеÑиÑоваÑÑ ÑекÑÑей ÑÑейм диÑÐ¿Ð»ÐµÑ Ð² GRASS мониÑоÑе"
-#: ../locale/scriptstrings/d.redraw_to_translate.c:3
-msgid "Redraw all frames"
-msgstr "ÐеÑеÑиÑоваÑÑ Ð²Ñе ÑÑеймÑ"
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-msgid "Do not preserve individual regions when redrawing all frames"
-msgstr "Ðе ÑоÑ
ÑанÑÑÑ Ð¸Ð½Ð´Ð¸Ð²Ð¸Ð´ÑалÑнÑе ÑегионÑ, пÑи пеÑеÑиÑовке вÑеÑ
ÑÑеймов"
-#: ../locale/scriptstrings/d.resize_to_translate.c:1
-msgid "Resizes active display monitor"
-msgstr "ÐзмениÑÑ ÑÐ°Ð·Ð¼ÐµÑ Ð°ÐºÑивного мониÑоÑа"
-#: ../locale/scriptstrings/d.resize_to_translate.c:3
-msgid "New width for window"
-msgstr "ÐÐ¾Ð²Ð°Ñ ÑиÑина Ð´Ð»Ñ Ð¾ÐºÐ½Ð°"
-#: ../locale/scriptstrings/d.resize_to_translate.c:4
-msgid "New height for window"
-msgstr "ÐÐ¾Ð²Ð°Ñ Ð²ÑÑоÑа Ð´Ð»Ñ Ð¾ÐºÐ½Ð°"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
-msgid "Drapes a color raster over a shaded relief map using d.his"
-msgstr ""
-"ÐÑапиÑоваÑÑ ÑвеÑной ÑаÑÑÑ Ð¿Ð¾Ð²ÐµÑÑ
ÑÐ»Ð¾Ñ Ñеневой оÑмÑвки ÑелÑеÑа иÑполÑзÑÑ d.his"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
-msgid "Name of shaded relief or aspect map"
-msgstr "ÐÐ¼Ñ ÑÐ»Ð¾Ñ Ñеневого ÑелÑеÑа или ÑкÑпозиÑий "
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
-msgid "Name of raster to drape over relief map"
-msgstr "ÐÐ¼Ñ ÑаÑÑÑа дÑапиÑÑемого по ÑелÑеÑÑ "
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
-msgid "Percent to brighten"
-msgstr "ÐÑоÑÐµÐ½Ñ ÑвелиÑÐµÐ½Ð¸Ñ ÑÑкоÑÑи"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:1
-msgid "Slide show of GRASS raster/vector maps."
-msgstr "СлайдÑÐ¾Ñ ÑаÑÑÑовÑÑ
/векÑоÑнÑÑ
Ñлоев GRASS"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:2
-msgid "display, slideshow"
-msgstr "показаÑÑ, ÑлайдÑоÑ"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:3
-msgid "Show vector maps rather than raster maps"
-msgstr "ÐоказаÑÑ Ð²ÐµÐºÑоÑнÑе Ñлои вмеÑÑо ÑаÑÑÑовÑÑ
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:4
-msgid "Map prefix. Specify character(s) to view selected maps only"
-msgstr "ÐÑеÑÐ¸ÐºÑ ÑлоÑ. УкажиÑе Ñимвол(Ñ) Ð´Ð»Ñ Ð¿ÑоÑмоÑÑа вÑбÑаннÑÑ
Ñлоев"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:5
-#, fuzzy
-msgid "Map number show across the monitor"
-msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ Ð¿Ð¾ÐºÐ°Ð·ÑваемÑй попеÑек мониÑоÑа"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:6
-#, fuzzy
-msgid "Map number show down the monitor"
-msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ Ð¿Ð¾ÐºÐ°Ð·ÑваемÑй ÑвеÑÑ
Ñ Ð²Ð½Ð¸Ð· мониÑоÑа"
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:7
-msgid "Mapsets to use. Specify multiple mapsets comma separated"
-msgstr "ÐÑполÑзÑемÑе набоÑÑ. УкажиÑе неÑколÑко набоÑов ÑеÑез запÑÑÑÑ "
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:8
-msgid "Number of seconds to pause between slides"
-msgstr "ÐÑÐµÐ¼Ñ Ð² ÑекÑндаÑ
Ð´Ð»Ñ Ð¿Ð°ÑÐ·Ñ Ð¼ÐµÐ¶Ð´Ñ Ñлайдами"
-#: ../locale/scriptstrings/d.split_to_translate.c:1
-msgid ""
-"Divides active display into two frames & displays maps/executes commands in "
-"each frame."
-msgstr ""
-"РазделиÑÑ Ð°ÐºÑивнÑй диÑплей на два ÑÑейма и показаÑÑ Ñлои/вÑполниÑÑ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ Ð² "
-"каждом ÑÑейме "
-#: ../locale/scriptstrings/d.split_to_translate.c:3
-msgid "Enter raster map to display in 1st frame"
-msgstr "ÐведиÑе ÑаÑÑÑовÑй Ñлой Ð´Ð»Ñ Ð¿Ð¾ÐºÐ°Ð·Ð° в пеÑвом ÑÑейме"
-#: ../locale/scriptstrings/d.split_to_translate.c:4
-msgid "Enter command to execute in 1st frame"
-msgstr "ÐведиÑе ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ Ð´Ð»Ñ Ð¸ÑÐ¿Ð¾Ð»Ð½ÐµÐ½Ð¸Ñ Ð² 1-м ÑÑейме"
-#: ../locale/scriptstrings/d.split_to_translate.c:5
-msgid "Enter raster map to display in 2nd frame"
-msgstr "ÐведиÑе ÑаÑÑÑовÑй Ñлой Ð´Ð»Ñ Ð¿Ð¾ÐºÐ°Ð·Ð° в вÑоÑом ÑÑейме"
-#: ../locale/scriptstrings/d.split_to_translate.c:6
-msgid "Enter command to execute in 2nd frame"
-msgstr "ÐведиÑе ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ Ð´Ð»Ñ Ð¸ÑÐ¿Ð¾Ð»Ð½ÐµÐ½Ð¸Ñ Ð²Ð¾ 2-м ÑÑейме"
-#: ../locale/scriptstrings/d.split_to_translate.c:7
-msgid "How to split display"
-msgstr "Ðак ÑазделиÑÑ Ð´Ð¸Ñплей "
-#: ../locale/scriptstrings/d.split.frame_to_translate.c:1
-#, fuzzy
-msgid "Split the display into subframes."
-#: ../locale/scriptstrings/d.split.frame_to_translate.c:2
-#, fuzzy
-msgid "Number of subframes"
-msgstr "ЧиÑло ÑÑеймов"
-#: ../locale/scriptstrings/d.split.frame_to_translate.c:3
-msgid "Split horizontally not vertically"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:1
-#, fuzzy
-msgid "Displays thematic vector map"
-msgstr "ÐÑобÑазиÑÑ ÑемаÑиÑеÑкий векÑоÑнÑй Ñлой"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
-#, fuzzy
-msgid "display, vector, thematic, legend"
-msgstr "диÑплей, легенда "
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:3
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:48
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:51
-msgid "Files"
-msgstr "ФайлÑ"
-#: ../display/d.zoom/main.c:100
-msgid "Name of vector map"
-msgstr "ÐÐ¼Ñ Ð²ÐµÐºÑоÑного ÑлоÑ"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:7
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:9
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:11
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:13
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:16
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:25
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:46
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:53
-#, fuzzy
-msgid "Theme"
-msgstr "Theme_prefs"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:6
-#: ../raster/r.to.vect/main.c:64 ../vector/v.to.db/parse.c:36
-msgid "Feature type"
-msgstr "Тип обÑекÑа"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
-#, fuzzy
-msgid "Name of attribute column to use for thematic display (must be numeric)"
-msgstr ""
-"Ðоле, иÑполÑзÑемое Ð´Ð»Ñ ÑемаÑиÑеÑкого оÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ (должно бÑÑÑ ÑиÑловÑм)"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
-msgid "Type of thematic display"
-msgstr "Тип ÑемаÑиÑеÑкой каÑÑÑ"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:12
-msgid "Thematic divisions of data for display"
-msgstr "ТемаÑиÑеÑкое Ñазделение даннÑÑ
Ð´Ð»Ñ Ð¾ÑобÑажениÑ"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:14
-#, fuzzy
-msgid "Break points for custom breaks option"
-msgstr ""
-"ТоÑки ÑазÑÑва Ð´Ð»Ñ Ð¾Ð¿Ñии вÑбоÑа ÑазÑÑвов. РазделиÑе знаÑÐµÐ½Ð¸Ñ Ð¿Ñобелами ( 0 10 "
-"20 30 ...)"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:15
-#, fuzzy
-msgid "Separate values by spaces (0 10 20 30 ...)"
-msgstr ""
-"20 30 ...)"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:17
-#: ../locale/scriptstrings/v.centroids_to_translate.c:6
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:10
-#: ../locale/scriptstrings/v.report_to_translate.c:6
-#: ../vector/v.out.vtk/main.c:83
-msgid "Layer number"
-msgstr "ÐÐ¾Ð¼ÐµÑ ÑлоÑ"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:18
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:20
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:23
-#: ../vector/v.out.ascii/out.c:67 ../vector/v.out.ascii/out.c:77
-#: ../vector/v.out.ascii/out.c:84 ../vector/v.out.ascii/out.c:97
-msgid "Points"
-msgstr "ТоÑки"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
-msgid "Vector point icon for point data"
-msgstr "ÐекÑоÑнÑй ÑоÑеÑнÑй знаÑок Ð´Ð»Ñ ÑоÑеÑнÑÑ
даннÑÑ
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
-#, fuzzy
-msgid "Icon size for point data"
даннÑÑ
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
-#, fuzzy
-msgid "Minimum icon size/line width for graduated points/lines)"
-msgstr ""
-"ÐакÑималÑнÑй ÑÐ°Ð·Ð¼ÐµÑ Ð¸ÐºÐ¾Ð½ÐºÐ¸/ÑиÑина линии Ð´Ð»Ñ ÐºÐ°Ð»Ð¸Ð±ÑованнÑÑ
ÑоÑек и линий"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:24
-msgid "Maximum icon size/line width for graduated points and lines"
-msgstr ""
ÑоÑек и линий"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
-msgid "Number of classes for interval theme (integer)"
-msgstr "ЧиÑло клаÑÑов Ð´Ð»Ñ Ð¸Ð½ÑеÑвалÑного ÑÐ»Ð¾Ñ (Ñелое)"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:27
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:30
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:33
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:36
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:39
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:55
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:57
-#: ../display/d.grid/main.c:76 ../display/d.grid/main.c:81
-#: ../display/d.grid/main.c:87
-msgid "Color"
-msgstr "ЦвеÑ"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
-msgid "Color scheme for graduated color mapping"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:29
-#, fuzzy
-msgid "Select 'single_color' for graduated point/line display"
-msgstr ""
-"ЦвеÑÐ¾Ð²Ð°Ñ ÑÑ
ема Ð´Ð»Ñ Ð³ÑадÑиÑованного ÑвеÑового оÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ (вÑбеÑиÑе "
-"''single_color' Ð´Ð»Ñ Ð¾ÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð³ÑадÑиÑованнÑÑ
ÑоÑек/линий)"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
-#, fuzzy
-msgid "Color for graduated points map"
-msgstr "Ð¦Ð²ÐµÑ Ð´Ð»Ñ Ð´Ð°Ð½Ð½ÑÑ
Y"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:32
-#, fuzzy
-msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
-msgstr ""
-"Ð¦Ð²ÐµÑ Ð´Ð»Ñ Ð³ÑадÑиÑованного ÑÐ»Ð¾Ñ ÑоÑек (ÑÐ²ÐµÑ grass или ÑÑÐ¸Ð¿Ð»ÐµÑ R:G:B). ÐÑбеÑиÑе "
-"ÑвеÑовÑÑ ÑÑ
ÐµÐ¼Ñ Ð´Ð»Ñ Ð¾Ð´Ð½Ð¾Ð³Ð¾ ÑвеÑа."
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
-msgid "Color for graduated lines or point/area outlines"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:35
-#, fuzzy
-msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
-msgstr ""
-"ÑвеÑовÑÑ ÑÑ
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
-#, fuzzy
-msgid "Beginning color for custom color gradient"
-msgstr ""
-"ÐаÑалÑнÑй ÑÐ²ÐµÑ Ð´Ð»Ñ Ð¿Ð¾Ð»ÑзоваÑелÑÑкого ÑвеÑового гÑадиенÑа. Ðолжен бÑÑÑ Ð·Ð°Ð´Ð°Ð½ "
-"как ÑÑÐ¸Ð¿Ð»ÐµÑ R:G:B."
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
-#, fuzzy
-msgid "Must be expressed as R:G:B triplet"
-msgstr ""
-"ÐонеÑнÑй ÑÐ²ÐµÑ Ð´Ð»Ñ Ð¿Ð¾Ð»ÑзоваÑелÑÑкого ÑвеÑового гÑадиенÑа. Ðолжен бÑÑÑ Ð·Ð°Ð´Ð°Ð½ "
-"как ÑÑÐ¸Ð¿Ð»ÐµÑ R:G:B"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
-#, fuzzy
-msgid "Ending color for custom color gradient"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:59
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:61
-msgid "Misc"
-msgstr "Разное"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:43
-msgid "Select x11 display monitor for legend"
-msgstr "ÐÑбеÑиÑе Ñ
11 мониÑÐ¾Ñ Ð´Ð»Ñ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
-msgid "Save thematic map commands to group file for GIS Manager"
-msgstr ""
-"СоÑ
ÑаниÑÑ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ ÑемаÑиÑеÑкиÑ
Ñлоев в гÑÑпповой Ñайл Ð´Ð»Ñ Ð¼ÐµÐ½ÐµÐ´Ð¶ÐµÑа ÐÐС"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:13
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:8
-msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr "WHERE ÑÑÐ»Ð¾Ð²Ð¸Ñ SQL ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ Ð½Ðµ имеÑÑ ÐºÐ»ÑÑевого Ñлова 'where'"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:49
-#, fuzzy
-msgid "Root for the name of psmap instruction files to be in current directory"
-msgstr ""
-"ÐоÑÐµÐ½Ñ Ð¸Ð¼ÐµÐ½Ð¸ Ñайлов инÑÑÑÑкÑии psmap в ÑекÑÑей папке (еÑли не ÑÑÑановлено, "
-"ÑÐ°Ð¹Ð»Ñ Ð¸Ð½ÑÑÑÑкÑии psmap не бÑдÑÑ ÑозданÑ) "
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
-msgid "If not set, no psmap instruction files will be created)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
-msgid "Name of group file where thematic map commands will be saved"
-msgstr "ÐÐ¼Ñ Ð³ÑÑÐ¿Ð¿Ñ Ñайлов, кÑда бÑдÑÑ Ð·Ð°Ð¿Ð¸ÑÐ°Ð½Ñ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ Ð´Ð»Ñ ÑемаÑиÑеÑкиÑ
Ñлоев"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:54
-msgid "Create graphic legend in x11 display monitor"
-msgstr "СоздаÑÑ Ð³ÑаÑиÑеÑкÑÑ Ð»ÐµÐ³ÐµÐ½Ð´Ñ Ð² x11 мониÑоÑе"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:56
-msgid "Only draw fills (no outlines) for areas and points"
-msgstr "ÐÑÑиÑоваÑÑ ÑолÑко заливки без гÑÐ°Ð½Ð¸Ñ Ð´Ð»Ñ Ð¿Ð»Ð¾ÑаднÑÑ
ÑÑаÑÑков и ÑоÑек"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:58
-msgid "Update color values to GRASSRGB column in attribute table"
-msgstr "ÐбновиÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÑвеÑов в ÑÑолбÑе GRASSRGB аÑÑибÑÑивной ÑаблиÑÑ"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:60
-msgid "Output legend for GIS Manager (for scripting use only)"
-msgstr "РезÑлÑÑиÑÑÑÑÐ°Ñ Ð»ÐµÐ³ÐµÐ½Ð´Ð° Ð´Ð»Ñ Ð¼ÐµÐ½ÐµÐ´Ð¶ÐµÑа ÐÐС (ÑолÑко Ð´Ð»Ñ ÑкÑипÑов)"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:62
-msgid "Use math notation brackets in legend"
-msgstr "ÐÑполÑзоваÑÑ Ð¼Ð°ÑемаÑиÑеÑкое обознаÑение Ñкобок в легенде "
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:1
-msgid "Drops a column from selected attribute table"
-msgstr "УдалиÑÑ ÑÑÐ¾Ð»Ð±ÐµÑ Ð¸Ð· вÑбÑанной ÑаблиÑÑ Ð°ÑÑибÑÑов"
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:3
-#: ../locale/scriptstrings/db.droptable_to_translate.c:3
-#: ../general/g.mremove/main.c:76
-msgid "Force removal (required for actual deletion of files)"
-msgstr "Силовое Ñдаление (необÑ
одимо Ð´Ð»Ñ ÑеалÑного ÑÐ´Ð°Ð»ÐµÐ½Ð¸Ñ Ñайлов)"
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:4
-msgid "Table from which to drop attribute column"
-msgstr "ТаблиÑа из коÑоÑой ÑдалиÑÑ ÑÑолбеÑ"
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:5
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:5
-msgid "Name of the column"
-msgstr "ÐÐ¼Ñ ÑÑолбÑа"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:1
-msgid "Drops an attribute table."
-msgstr "УдалиÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:4
-msgid "Table to drop"
-msgstr "УдалÑÐµÐ¼Ð°Ñ ÑаблиÑа"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
-msgid "Imports attribute tables in various formats."
-msgstr "ÐмпоÑÑ Ð°ÑÑибÑÑивнÑÑ
ÑÐ°Ð±Ð»Ð¸Ñ Ð² ÑазлиÑнÑÑ
ÑоÑмаÑаÑ
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
-msgid "Table file to be imported or DB connection string"
-msgstr "Файл ÑаблиÑÑ Ð´Ð»Ñ Ð¸Ð¼Ð¿Ð¾ÑÑа или ÑÑÑока ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ñ ÐÐ"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
-msgid "Table name of SQL DB table"
-msgstr "Ðазвание ÑаблиÑÑ SQL DB"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
-msgid "Name for output table"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного Ñайла"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
-msgid "Name for auto-generated unique key column"
-msgstr "ÐÐ¼Ñ Ð°Ð²ÑомаÑиÑеÑки Ñоздаваемого ÑÑолбÑа ÑникалÑного клÑÑа"
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
-msgid "Exports attribute tables into various formats."
ÑоÑмаÑаÑ
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
-msgid "GRASS table name"
-msgstr "ÐÐ¼Ñ ÑаблиÑÑ GRASS"
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
-msgid "Table file to be exported or DB connection string"
-msgstr "Файл ÑаблиÑÑ Ð´Ð»Ñ ÑкÑпоÑÑа или ÑÑÑока ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ñ ÐÐ"
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-msgid "Table format"
-msgstr "ФоÑÐ¼Ð°Ñ ÑаблиÑÑ"
-#: ../locale/scriptstrings/db.test_to_translate.c:1
-msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"ÐÑовеÑиÑÑ Ð´ÑÐ°Ð¹Ð²ÐµÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
, база даннÑÑ
должна ÑÑÑеÑÑвоваÑÑ Ð¸ "
-"ÑÑÑановлена db.connect."
-#: ../locale/scriptstrings/db.test_to_translate.c:3
-msgid "Test name"
-msgstr "ÐÐ¼Ñ ÑеÑÑа"
-#: ../locale/scriptstrings/g.manual_to_translate.c:1
-msgid "Display the HTML man pages of GRASS"
-msgstr "ÐоказаÑÑ HTML ÑÑÑаниÑÑ ÑÑководÑÑва GRASS"
-#: ../locale/scriptstrings/g.manual_to_translate.c:2
-msgid "general, manual, help"
-msgstr "обÑее, ÑÑководÑÑво, помоÑÑ"
-#: ../locale/scriptstrings/g.manual_to_translate.c:3
-msgid "Display index"
-msgstr "ÐоказаÑÑ Ð¸Ð½Ð´ÐµÐºÑ"
-#: ../locale/scriptstrings/g.manual_to_translate.c:4
-msgid "Display as MAN text page instead of HTML page in browser"
-msgstr "ÐоказаÑÑ ÑÑÑаниÑÑ ÐºÐ°Ðº ÑекÑÑ, вмеÑÑо HTML в бÑаÑзеÑе"
-#: ../locale/scriptstrings/g.manual_to_translate.c:5
-msgid "Manual entry to be displayed"
-msgstr "Ð ÑÑной ввод Ð´Ð»Ñ Ð¿Ð¾ÐºÐ°Ð·Ð°"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr ""
-"ТÑанÑÑоÑмаÑÐ¸Ñ Ð±ÑÑви Ð´Ð»Ñ ÑлиÑÐ½Ð¸Ñ Ð¼ÑлÑÑиÑпекÑÑалÑнÑÑ
каналов и "
-"панÑ
ÑомаÑиÑеÑкиÑ
каналов вÑÑокого ÑазÑеÑениÑ"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
-#, fuzzy
-msgid "imagery, fusion, Brovey"
-msgstr "ÑаÑÑÑ, изобÑажениÑ, ÑлиÑние"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
-#, fuzzy
-msgid "LANDSAT sensor"
-msgstr "кÑаÑнÑй канал LANDSAT"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:4
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
-msgid "Sensor"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
-msgid "QuickBird sensor"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:7
-msgid "SPOT sensor"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
-#, fuzzy
-msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
-msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (green: tm2 | qbird_green | spot1)"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
-#, fuzzy
-msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
-msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (NIR: tm4 | qbird_nir | spot2)"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
-#, fuzzy
-msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
-msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (MIR; tm5 | qbird_red | spot3)"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:12
-#, fuzzy
-msgid "Name of input raster map (etmpan | qbird_pan | spotpan)"
-msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (etmpan | qbird_pan | spotpan)"
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:13
-#, fuzzy
-msgid "Name for output raster map prefix (e.g. 'brov')"
-msgstr "пÑеÑÐ¸ÐºÑ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (напÑÐ¸Ð¼ÐµÑ 'brov')"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
-msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-msgstr ""
-"ÐозаиÑиÑоваÑÑ Ð´Ð¾ 4 изобÑажений и ÑаÑÑиÑиÑÑ ÑвеÑовÑÑ ÑаблиÑÑ; ÑоздаÑÑ Ñлой *."
-"mosaic"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
-msgid "raster, imagery, mosaicking"
-msgstr "ÑаÑÑÑ, изобÑажениÑ, мозаиÑиÑование"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
-msgid "1st map for mosaic (top of image stack)."
-msgstr "пеÑвÑй Ñлой Ð´Ð»Ñ Ð¼Ð¾Ð·Ð°Ð¸ÐºÐ¸ (веÑÑ
ÑÑÑка изобÑажений)."
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
-msgid "2nd map for mosaic."
-msgstr "ÐÑоÑой Ñлой Ð´Ð»Ñ Ð¼Ð¾Ð·Ð°Ð¸ÐºÐ¸"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:5
-msgid "3rd map for mosaic."
-msgstr "ТÑеÑий Ñлой Ð´Ð»Ñ Ð¼Ð¾Ð·Ð°Ð¸ÐºÐ¸"
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:6
-msgid "4th map for mosaic."
-msgstr "ЧеÑвеÑÑÑй Ñлой Ð´Ð»Ñ Ð¼Ð¾Ð·Ð°Ð¸ÐºÐ¸"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
-msgid "Import of SPOT VGT NDVI file into a raster map"
-msgstr "ÐмпоÑÑ Ñайла SPOT VGT NDVI в ÑаÑÑÑовÑй Ñлой"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
-msgid "raster, imagery, import"
-msgstr "ÑаÑÑÑ, изобÑажениÑ, импоÑÑ"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
-msgid "also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-"Ñакже импоÑÑиÑоваÑÑ Ñлой каÑеÑÑва (Ñлой ÑÑаÑÑÑа SM) и Ñлой оÑÑилÑÑÑованного "
-"NDVI"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
-msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-msgstr "ÑÑÑеÑÑвÑÑÑий Ñайл SPOT VGT NDVI HDF (0001_NDV.HDF)"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:1
-#, fuzzy
-msgid "Performs auto-balancing of colors for LANDSAT images."
-msgstr "ÐвÑомаÑиÑеÑÐºÐ°Ñ Ð±Ð°Ð»Ð°Ð½ÑиÑовка ÑвеÑов Ð´Ð»Ñ Ð¸Ð·Ð¾Ð±ÑÐ°Ð¶ÐµÐ½Ð¸Ñ LANDSAT"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
-msgid "raster, imagery, colors"
-msgstr "ÑаÑÑÑ, изобÑажениÑ, ÑвеÑа"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
-msgid "LANDSAT red channel"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:4
-msgid "LANDSAT green channel"
-msgstr "зеленÑй канал LANDSAT"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:5
-msgid "LANDSAT blue channel"
-msgstr "Ñиний канал LANDSAT"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:6
-msgid "Cropping intensity (upper brightness level)"
-msgstr "ÐбÑезка инÑенÑивноÑÑи (веÑÑ
ний ÑÑÐ¾Ð²ÐµÐ½Ñ ÑÑкоÑÑи)"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:7
-msgid "Extend colors to full range of data on each channel"
-msgstr "РаÑÑиÑиÑÑ ÑвеÑа до полного диапазона даннÑÑ
по ÐºÐ°Ð¶Ð´Ð¾Ð¼Ñ ÐºÐ°Ð½Ð°Ð»Ñ"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:8
-msgid "Preserve relative colors, adjust brightness only"
-msgstr "СоÑ
ÑаниÑÑ Ð¾ÑноÑиÑелÑнÑе ÑвеÑа, подÑÑÑоиÑÑ ÑолÑко ÑÑкоÑÑÑ"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
-msgid "Reset to standard color range"
-msgstr "СбÑоÑиÑÑ Ð² ÑÑандаÑÑнÑй ÑвеÑовой диапазон"
-#: ../locale/scriptstrings/i.oif_to_translate.c:1
-msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
-"РаÑÑÑиÑаÑÑ ÑаблиÑÑ Optimum-Index-Factor Ð´Ð»Ñ ÐºÐ°Ð½Ð°Ð»Ð¾Ð² LANDSAT TM 1-5 и 7"
-#: ../locale/scriptstrings/i.oif_to_translate.c:2
-msgid "raster, imagery, statistics"
-msgstr "ÑаÑÑÑ, изобÑажениÑ, ÑÑаÑиÑÑика"
-#: ../locale/scriptstrings/i.oif_to_translate.c:3
-msgid "LANDSAT TM band 1."
-msgstr "LANDSAT TM канал 1."
-#: ../locale/scriptstrings/i.oif_to_translate.c:4
-msgid "LANDSAT TM band 2."
-msgstr "LANDSAT TM канал 2."
-#: ../locale/scriptstrings/i.oif_to_translate.c:5
-msgid "LANDSAT TM band 3."
-msgstr "LANDSAT TM канал 3."
-#: ../locale/scriptstrings/i.oif_to_translate.c:6
-msgid "LANDSAT TM band 4."
-msgstr "LANDSAT TM канал 4."
-#: ../locale/scriptstrings/i.oif_to_translate.c:7
-msgid "LANDSAT TM band 5."
-msgstr "LANDSAT TM канал 5."
-#: ../locale/scriptstrings/i.oif_to_translate.c:8
-msgid "LANDSAT TM band 7."
-msgstr "LANDSAT TM канал 7."
-#: ../locale/scriptstrings/i.oif_to_translate.c:9
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:3
-#: ../general/g.region/main.c:133
-msgid "Print in shell script style"
-msgstr "ÐÑвеÑÑи ÑÑаÑиÑÑÐ¸ÐºÑ Ð² ÑÑиле shell"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:1
-#, fuzzy
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-"ÐоказаÑÑ ÑпекÑÑалÑное оÑÑажение Ð´Ð»Ñ Ð³ÑÑпп или изобÑажений, опÑеделеннÑÑ
-"полÑзоваÑелем"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:2
-msgid "imagery, raster, multispectral"
-msgstr "изобÑажениÑ, ÑаÑÑÑ, мÑлÑÑиÑпекÑÑалÑнÑе"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:3
-#, fuzzy
-msgid "Group input"
-msgstr "иÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð³ÑÑппа"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:4
-#, fuzzy
-msgid "Raster input maps"
-msgstr "иÑÑ
однÑе ÑаÑÑÑовÑе Ñлои"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:5
-#, fuzzy
-msgid "Write output to PNG image"
-msgstr "запиÑаÑÑ ÑезÑлÑÑÐ°Ñ Ð² изобÑажение PNG"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:6
-msgid "Use image list and not group"
-msgstr "ÐÑполÑзоваÑÑ ÑпиÑок изобÑажений, но не гÑÑппÑ"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-msgid "Select multiple points"
-msgstr "ÐÑÐ±Ð¾Ñ Ð½ÐµÑколÑкиÑ
ÑоÑек"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:8
-#, fuzzy
-msgid "Label with coordinates instead of numbering"
-msgstr "подпиÑаÑÑ ÐºÐ¾Ð¾ÑдинаÑами вмеÑÑо ÑиÑел"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
-msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr "ТÑанÑÑоÑмаÑÐ¸Ñ Tasseled Cap (Kauth Thomas) Ð´Ð»Ñ Ð´Ð°Ð½Ð½ÑÑ
LANDSAT-TM"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
-msgid "raster, imagery"
-msgstr "ÑаÑÑÑ, изобÑажениÑ"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
-msgid "use transformation rules for LANDSAT-4"
-msgstr "иÑполÑзоваÑÑ Ð¿Ñавила ÑÑанÑÑоÑмаÑии Ð´Ð»Ñ LANDSAT-4"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
-msgid "use transformation rules for LANDSAT-5"
-msgstr "иÑполÑзоваÑÑ Ð¿Ñавила ÑÑанÑÑоÑмаÑии Ð´Ð»Ñ LANDSAT-5"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
-msgid "use transformation rules for LANDSAT-7"
-msgstr "иÑполÑзоваÑÑ Ð¿Ñавила ÑÑанÑÑоÑмаÑии Ð´Ð»Ñ LANDSAT-7"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
-msgid "raster input map (LANDSAT channel 1)"
-msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (1 канал LANDSAT)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid "raster input map (LANDSAT channel 2)"
-msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (2 канал LANDSAT)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
-msgid "raster input map (LANDSAT channel 3)"
-msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (3 канал LANDSAT)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
-msgid "raster input map (LANDSAT channel 4)"
-msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (4 канал LANDSAT)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-msgid "raster input map (LANDSAT channel 5)"
-msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (5 канал LANDSAT)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
-msgid "raster input map (LANDSAT channel 7)"
-msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (7 канал LANDSAT)"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
-msgid "raster output TC maps prefix"
однÑÑ
ÑаÑÑÑовÑÑ
Ñлоев TC"
-#: ../locale/scriptstrings/m.proj_to_translate.c:1
-msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-"ÐонвеÑÑиÑоваÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ Ð¸Ð· одной пÑоекÑии в дÑÑгÑÑ (иÑполÑзÑÐµÑ cs2cs)."
-#: ../locale/scriptstrings/m.proj_to_translate.c:2
-msgid "miscellaneous, projection"
-msgstr "Ñазное, пÑоекÑиÑ"
-#: ../locale/scriptstrings/m.proj_to_translate.c:3
-msgid "Input coordinate file (omit to read from stdin)"
-msgstr "ÐÑÑ
однÑй Ñайл кооÑÐ´Ð¸Ð½Ð°Ñ (не ÑказÑвайÑе Ð´Ð»Ñ ÑÑÐµÐ½Ð¸Ñ Ð¸Ð· stdin)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:4
-msgid "Output coordinate file (omit to send to stdout)"
-msgstr "ÐÑÑ
одной Ñайл кооÑÐ´Ð¸Ð½Ð°Ñ (пÑопÑÑÑиÑÑ Ð²Ñвод в stdout)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
-msgid "Field separator"
-msgstr "РазделиÑÐµÐ»Ñ Ð¿Ð¾Ð»ÐµÐ¹"
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
-msgid "Input projection parameters (PROJ.4 style)"
-msgstr "ÐÑÑ
однÑе паÑамеÑÑÑ Ð¿ÑоекÑии (ÑÑÐ¸Ð»Ñ PROJ.4)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
-msgid "Output projection parameters (PROJ.4 style)"
-msgstr "ÐÑÑ
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-msgid "Use LL WGS84 as input and current location as output projection"
-msgstr ""
-"ÐÑполÑзоваÑÑ LL WGS84 как иÑÑ
однÑÑ Ð¸ ÑекÑÑÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ ÐºÐ°Ðº вÑÑ
однÑÑ Ð¿ÑоекÑии"
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
-msgid "Use current location as input and LL WGS84 as output projection"
-msgstr ""
-"ÐÑполÑзоваÑÑ ÑекÑÑÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ ÐºÐ°Ðº иÑÑ
однÑÑ Ð¸ LL WGS84 как вÑÑ
однÑÑ Ð¿ÑоекÑии"
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
-msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
-"places"
-msgstr ""
-"ÐÑÑ
однÑе знаÑÐµÐ½Ð¸Ñ long/lat в деÑÑÑиÑнÑÑ
гÑадÑÑаÑ
или дÑÑгой пÑоекÑии в "
-"ÑоÑмаÑе Ñ Ð¼Ð½Ð¾Ð³Ð¸Ð¼Ð¸ ÑиÑлами поÑле запÑÑой"
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
-msgid "Verbose mode (print projection parameters and filenames to stderr)"
-msgstr ""
-"РаÑÑиÑеннÑй Ñежим (вÑводиÑÑ Ð¿Ð°ÑамеÑÑÑ Ð¿ÑоекÑии и имена Ñайлов в stderr)"
-#: ../locale/scriptstrings/r.blend_to_translate.c:1
-msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"СмеÑаÑÑ ÑвеÑовÑе компоненÑÑ Ð´Ð²ÑÑ
ÑаÑÑÑовÑÑ
Ñлоев иÑполÑзÑÑ Ð·Ð°Ð´Ð°Ð½Ð½Ð¾Ðµ "
-"ÑооÑноÑение."
-#: ../locale/scriptstrings/r.blend_to_translate.c:2
#: ../raster/r.describe/main.c:59 ../raster/r.rescale.eq/main.c:52
#: ../raster/r.surf.area/main.c:88 ../raster/r.coin/main.c:66
#: ../raster/r.out.png/r.out.png.c:136 ../raster/r.distance/main.c:38
#: ../raster/r.reclass/main.c:49 ../raster/r.los/main.c:82
-#: ../raster/r.drain/main.c:103 ../raster/r.carve/main.c:77
+#: ../raster/r.drain/main.c:108 ../raster/r.carve/main.c:77
#: ../raster/r.profile/main.c:53 ../raster/r.texture/main.c:74
#: ../raster/r.basins.fill/main.c:53 ../raster/r.sum/main.c:46
#: ../raster/r.sun/main.c:175 ../raster/r.volume/main.c:57
@@ -2770,7 +1620,7 @@
#: ../raster/r.grow2/main.c:128 ../raster/r.circle/dist.c:51
#: ../raster/r.thin/main.c:55 ../raster/r.surf.contour/main.c:50
#: ../raster/r.topidx/main.c:37 ../raster/r.out.pov/main.c:121
-#: ../raster/r.covar/main.c:53 ../raster/r.out.arc/main.c:59
+#: ../raster/r.covar/main.c:53 ../raster/r.out.arc/main.c:60
#: ../raster/r.rescale/main.c:50 ../raster/r.random/main.c:51
#: ../raster/r.sunmask/main.c:125 ../raster/r.his/main.c:63
#: ../raster/r.topmodel/main.c:55 ../raster/r.bilinear/main.c:42
@@ -2779,1400 +1629,23 @@
#: ../raster/r.surf.gauss/main.c:46 ../raster/r.fill.dir/main.c:84
#: ../raster/r.timestamp/main.c:35 ../raster/r.what/main.c:92
#: ../raster/r.out.vtk/main.c:148 ../raster/r.out.bin/main.c:63
-#: ../raster/r.neighbors/main.c:106 ../raster/r.what.color/main.c:88
+#: ../raster/r.neighbors/main.c:107 ../raster/r.what.color/main.c:88
#: ../raster/r.in.gridatb/main.c:41 ../raster/r.to.vect/main.c:50
#: ../raster/r.region/main.c:54 ../raster/r.out.ppm3/main.c:57
-#: ../raster/r.in.mat/main.c:92 ../raster/r.watershed/front/main.c:52
+#: ../raster/r.in.mat/main.c:92 ../raster/r.watershed/front/main.c:56
#: ../raster/r.quant/main.c:41 ../raster/r.cross/main.c:75
#: ../raster/r.cats/main.c:51 ../raster/r.out.mpeg/main.c:384
-#: ../raster/r.walk/main.c:174 ../raster/r.gwflow/main.c:223
+#: ../raster/r.walk/main.c:177 ../raster/r.gwflow/main.c:223
#: ../raster/wildfire/r.ros/main.c:212
#: ../raster/wildfire/r.spreadpath/main.c:72
#: ../raster/wildfire/r.spread/main.c:101 ../raster/r.resample/main.c:54
#: ../raster/r.in.arc/main.c:59 ../raster/r.bitpattern/main.c:62
-#: ../raster/r.grow.distance/main.c:130 ../raster/r.horizon/main.c:178
+#: ../raster/r.grow.distance/main.c:130 ../raster/r.sun2/main.c:226
+#: ../raster/r.horizon/main.c:178
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:153
msgid "raster"
msgstr "ÑаÑÑÑ"
-#: ../locale/scriptstrings/r.blend_to_translate.c:3
-msgid "Name of first raster map for blending"
-msgstr "ÐÐ¼Ñ Ð¿ÐµÑвого ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð´Ð»Ñ ÑмеÑиваниÑ"
-#: ../locale/scriptstrings/r.blend_to_translate.c:4
-msgid "Name of second raster map for blending"
-msgstr "ÐÐ¼Ñ Ð²ÑоÑого ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð´Ð»Ñ ÑмеÑиваниÑ"
-#: ../locale/scriptstrings/r.blend_to_translate.c:5
-msgid "Base name for red, green and blue output maps containing the blend"
-msgstr ""
-"Ðазовое Ð¸Ð¼Ñ Ð´Ð»Ñ Ñлоев ÑодеÑжаÑиÑ
кÑаÑнÑй, зеленÑй и Ñиний Ð´Ð»Ñ ÑмеÑиваниÑ"
-#: ../locale/scriptstrings/r.blend_to_translate.c:6
-msgid "Percentage weight of first map for color blending"
-msgstr "ÐÑоÑенÑнÑй Ð²ÐµÑ Ð¿ÐµÑвого ÑÐ»Ð¾Ñ Ð´Ð»Ñ ÑвеÑового ÑмеÑиваниÑ"
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Set color rules based on stddev from a map's mean value."
-msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
-#: ../raster/r.colors/main.c:165
-msgid "raster, color table"
-msgstr "ÑаÑÑÑ, ÑвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа"
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
-#, fuzzy
-msgid "Color using standard deviation bands"
-msgstr ""
-"ÑÑедние и ÑÑандаÑÑнÑе оÑÐºÐ»Ð¾Ð½ÐµÐ½Ð¸Ñ Ð´Ð»Ñ %d band%s\n"
-"\n"
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
-msgid "Force center at zero"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
-msgid ""
-"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-msgstr ""
-"ÐаполниÑÑ no-data знаÑÐµÐ½Ð¸Ñ ÑаÑÑÑовÑÑ
Ñлоев, иÑполÑзÑÑ Ñплайн-инÑеÑполÑÑÐ¸Ñ v."
-"surf.rst"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
-msgid "raster, elevation, interpolation"
-msgstr "ÑаÑÑÑ, вÑÑоÑа, инÑеÑполÑÑиÑ"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
-msgid "Raster map in which to fill nulls"
-msgstr "РаÑÑÑовÑй Ñлой Ð´Ð»Ñ Ð·Ð°Ð¿Ð¾Ð»Ð½ÐµÐ½Ð¸Ñ Ð½Ñлей"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-msgid ""
-"Output raster map with nulls filled by interpolation from surrounding values"
-msgstr ""
-"ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой Ñ Ð½ÑлÑми заполненнÑми инÑеÑполÑÑией окÑÑжаÑÑиÑ
-"знаÑений"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
-msgid "Spline tension parameter"
-msgstr "паÑамеÑÑ tenstion Ñплайн-инÑеÑполÑÑии"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
-msgid "Spline smoothing parameter"
-msgstr "ÐаÑамеÑÑ ÑÐ³Ð»Ð°Ð¶Ð¸Ð²Ð°Ð½Ð¸Ñ Ñплайна"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
-msgstr ""
-"ÐÑивÑзаÑÑ, ÑÑанÑÑоÑмиÑоваÑÑ Ð¸ импоÑÑиÑоваÑÑ ÑÑÐµÐ¼ÐºÑ Terra-ASTER и "
-"оÑноÑиÑелÑнÑе ЦÐРиÑполÑзÑÑ gdalwarp."
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
-msgid "Input ASTER image to be georeferenced & rectified"
-msgstr "ÐÑÑ
одное изобÑажение ASTER Ð´Ð»Ñ Ð¿ÑивÑзки и ÑÑанÑÑоÑмаÑии"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
-msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
-msgstr "Тип даннÑÑ
ASTER (Level 1A, Level 1B, или оÑноÑиÑелÑнÑй DEM)"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-msgid ""
-"L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
-"single band"
-msgstr ""
-"канал L1A или L1B Ð´Ð»Ñ Ð¿ÐµÑевода (1, 2, 3n, 3b, 4-14). Ðожно пеÑевеÑÑи ÑолÑко "
-"один канал"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
-msgid "Import SRTM HGT files into GRASS"
-msgstr "ÐмпоÑÑ Ñайлов SRTM HGT в GRASS"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#: ../raster/r.in.bin/main.c:122 ../raster/r.in.gdal/main.c:79
-#: ../raster/r.in.poly/main.c:29 ../raster/r.external/main.c:505
-msgid "raster, import"
-msgstr "ÑаÑÑÑ, импоÑÑ"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
-msgid "SRTM input tile (file without .hgt.zip extension)"
-msgstr "иÑÑ
однÑй ÑÑÐ°Ð³Ð¼ÐµÐ½Ñ SRTM (Ñайл без ÑаÑÑиÑÐµÐ½Ð¸Ñ .hgt.zip)"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
-msgid "Output raster map (default: input tile)"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (по ÑмолÑаниÑ: Ð¸Ð¼Ñ Ð¸ÑÑ
одного)"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
-msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
-msgstr "ÐÑÑ
однÑе даннÑе 1-arcsec (по ÑмолÑаниÑ: 3-arcsec)"
-msgid "Downloads and imports data from WMS servers."
-msgstr "ÐагÑÑзиÑÑ Ð¸ импоÑÑиÑоваÑÑ Ð´Ð°Ð½Ð½Ñе Ñ ÑеÑвеÑов WMS."
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
-msgid "wms"
-msgstr "wms"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
-#: ../vector/v.in.dxf/main.c:82 ../vector/v.in.dwg/main.c:96
-msgid "List available layers and exit"
-msgstr "ÐоказаÑÑ Ð´Ð¾ÑÑÑпнÑе Ñлои и вÑйÑи"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:21
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:25
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:27
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:29
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:31
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:49
-msgid "Request"
-msgstr "ÐапÑоÑ"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
-msgid "Skip to downloading (to resume downloads faster)"
-msgstr "ÐÑопÑÑÑиÑÑ Ð¸ наÑаÑÑ Ð·Ð°Ð³ÑÑÐ·ÐºÑ (Ð´Ð»Ñ Ð±ÑÑÑÑого пÑÐ¾Ð´Ð¾Ð»Ð¶ÐµÐ½Ð¸Ñ Ð·Ð°Ð³ÑÑзки)"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:42
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:44
-msgid "Download"
-msgstr "СкаÑаÑÑ"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
-msgid "Don't request transparent data"
-msgstr "Ðе запÑаÑиваÑÑ Ð¿ÑозÑаÑнÑе даннÑе"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
-msgid "Clean existing data out of download directory"
-msgstr "ÐÑиÑÑиÑÑ ÑÑÑеÑÑвÑÑÑие даннÑе из папки загÑÑзки"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
-#: ../raster/r.in.gdal/main.c:140
-msgid "Keep band numbers instead of using band color names"
-msgstr "СоÑ
ÑанÑÑÑ Ð½Ð¾Ð¼ÐµÑа каналов вмеÑÑо иÑполÑÐ·Ð¾Ð²Ð°Ð½Ð¸Ñ Ð¸Ð¼ÐµÐ½ ÑвеÑов каналов"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:19
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:46
-msgid "Import"
-msgstr "ÐмпоÑÑ"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
-msgid "Don't reproject the data, just patch it"
-msgstr "Ðе пеÑепÑоекÑиÑоваÑÑ Ð´Ð°Ð½Ð½Ñе, ÑолÑко залаÑаÑÑ"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid "Use GET method instead of POST data method"
-msgstr "ÐÑполÑзоваÑÑ Ð¼ÐµÑод GET вмеÑÑо меÑода POST"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
-msgid "This may be needed to connect to servers which lack POST capability"
-msgstr ""
-"Ðозможно ÑÑо понадобиÑÑÑ Ð´Ð»Ñ ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ñ ÑеÑвеÑами без возможноÑÑи POST"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
-msgid "Mapserver to request data from"
-msgstr "ÐаÑÑогÑаÑиÑеÑкий ÑеÑÐ²ÐµÑ Ð´Ð»Ñ Ð·Ð°Ð¿ÑоÑа даннÑÑ
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
-msgid "Layers to request from map server"
-msgstr "Слои, запÑаÑиваемÑе Ñ ÐºÐ°ÑÑогÑаÑиÑеÑкого ÑеÑвеÑа"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
-msgid "Styles to request from map server"
-msgstr "СÑили, запÑаÑиваемÑе Ñ ÐºÐ°ÑÑогÑаÑиÑеÑкого ÑеÑвеÑа"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
-msgid "Source projection to request from server"
-msgstr "ÐÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð¿ÑоекÑиÑ, запÑаÑÐ¸Ð²Ð°ÐµÐ¼Ð°Ñ Ñ ÑеÑвеÑа"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
-msgid "Image format requested from the server"
-msgstr "ФоÑÐ¼Ð°Ñ Ð¸Ð·Ð¾Ð±ÑажениÑ, запÑаÑиваемÑй Ñ ÑеÑвеÑа"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-msgid "Addition query options for server"
-msgstr "ÐополниÑелÑнÑе опÑии запÑоÑа к ÑеÑвеÑÑ"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
-msgid "Maximum columns to request at a time"
-msgstr "ÐакÑималÑное колиÑеÑÑво ÑÑолбÑов запÑаÑиваемое единовÑеменно"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
-msgid "Maximum rows to request at a time"
-msgstr "ÐинималÑное колиÑеÑÑво ÑÑолбÑов запÑаÑиваемое единовÑеменно"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
-msgid "Additional options for r.tileset"
-msgstr "ÐополниÑелÑнÑе опÑии Ð´Ð»Ñ r.tileset"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
-msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
-"Регион Ñ Ð½Ð°Ð·Ð²Ð°Ð½Ð¸ÐµÐ¼ Ð´Ð»Ñ ÐºÐ¾ÑоÑого запÑоÑиÑÑ Ð´Ð°Ð½Ð½Ñе. ÐÑли не Ñказан, "
-"иÑполÑзÑеÑÑÑ ÑекÑÑий Ñегион"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
-msgid "Folder to save downloaded data to"
-msgstr "ÐаÑалог Ð´Ð»Ñ ÑоÑ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ Ð·Ð°Ð³ÑÑженнÑÑ
даннÑÑ
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:41
-msgid "Additional options for wget"
-msgstr "ÐополниÑелÑнÑе опÑии Ð´Ð»Ñ wget"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:43
-msgid "Additional options for curl"
-msgstr "ÐополниÑелÑнÑе опÑии Ð´Ð»Ñ curl"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:45
-msgid "Reprojection method to use"
-msgstr "ÐÑполÑзÑемÑй меÑод пеÑепÑоеÑиÑованиÑ"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:47
-msgid "Filename to save capabilities XML file to"
-msgstr "ÐÐ¼Ñ Ñайла Ð´Ð»Ñ ÑоÑ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ Ñайла возможноÑÑей XML"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:48
-msgid "Requires list available layers flag"
-msgstr "ТÑебÑеÑÑÑ Ñлаг вÑвеÑÑи ÑпиÑок доÑÑÑпнÑÑ
Ñлоев"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:50
-#: ../locale/scriptstrings/r.tileset_to_translate.c:14
-msgid "Verbosity level"
-msgstr "УÑÐ¾Ð²ÐµÐ½Ñ Ð²Ñвода инÑоÑмаÑии"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:1
-msgid "Calculate new raster map from a r.mapcalc expression."
-msgstr "РаÑÑÑиÑаÑÑ Ð½Ð¾Ð²Ñй ÑаÑÑÑовÑй Ñлой иÑполÑзÑÑ Ð²ÑÑажение r.mapcalc."
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:2
-msgid "A"
-msgstr "A"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:3
-msgid "B"
-msgstr "B"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:4
-msgid "C"
-msgstr "C"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:5
-msgid "D"
-msgstr "D"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:6
-msgid "E"
-msgstr "E"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:7
-msgid "F"
-msgstr "F"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:8
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:8
-msgid "Formula (e.g. A-B or A*C+B)"
-msgstr "ФоÑмÑла (напÑÐ¸Ð¼ÐµÑ A-B или A*C+B)"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:10
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:10
-msgid "Show help"
-msgstr "ÐоказаÑÑ Ð¿Ð¾Ð¼Ð¾ÑÑ"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:11
-msgid "Expert mode (enter a set of r.mapcalc expressions)"
-msgstr "ÐкÑпеÑÑнÑй Ñежим (ввеÑÑи Ð½Ð°Ð±Ð¾Ñ Ð²ÑÑажений r.mapcalc)"
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:12
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:12
-msgid "Do not overwrite existing map"
-msgstr "Ðе пеÑезапиÑÑваÑÑ ÑÑÑеÑÑвÑÑÑие Ñлои "
-#: ../locale/scriptstrings/r.mask_to_translate.c:1
-msgid "Create a MASK for limiting raster operation"
-msgstr "СоздаÑÑ MASK Ð´Ð»Ñ Ð¾Ð³ÑаниÑÐµÐ½Ð¸Ñ ÑаÑÑÑовÑÑ
опеÑаÑий"
-#: ../locale/scriptstrings/r.mask_to_translate.c:2
-msgid "raster, mask"
-msgstr "ÑаÑÑÑ, маÑка"
-#: ../locale/scriptstrings/r.mask_to_translate.c:3
-msgid "Raster map to use as MASK"
-msgstr "РаÑÑÑовÑй Ñлой, иÑполÑзÑемÑй в каÑеÑÑве MASK"
-#: ../locale/scriptstrings/r.mask_to_translate.c:4
-msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-msgstr "ÐнаÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий Ð´Ð»Ñ MASK (ÑоÑмаÑ: 1 2 3 до 7 *)"
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-msgid "Create inverse MASK from specified 'maskcats' list"
-msgstr "СоздаÑÑ Ð¸Ð½Ð²ÐµÑÑиÑованнÑÑ MASK из заданного ÑпиÑка 'maskcats'"
-#: ../locale/scriptstrings/r.mask_to_translate.c:6
-msgid "Overwrite existing MASK"
-msgstr "ÐеÑезапиÑаÑÑ ÑÑÑеÑÑвÑÑÑÑÑ MASK"
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-msgid "Remove existing MASK (overrides other options)"
-msgstr "УдалиÑÑ ÑÑÑеÑÑвÑÑÑÑÑ MASK (заменÑÐµÑ Ð´ÑÑгие опÑии)"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:1
-msgid "Exports GRASS raster into GDAL supported formats."
-msgstr "ÐкÑпоÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ GRASS в ÑоÑмаÑÑ Ð¿Ð¾Ð´Ð´ÐµÑживаемÑе GDAL."
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:2
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
-#: ../raster/r.out.ascii/main.c:59 ../raster/r.out.gdal/main.c:126
-#: ../raster/r.out.mat/main.c:64 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.tiff/r.out.tiff.c:99
-msgid "raster, export"
-msgstr "ÑаÑÑÑ, ÑкÑпоÑÑ"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:3
-#: ../raster/r.out.gdal/main.c:130
-msgid "List supported output formats"
-msgstr "ÐеÑеÑиÑлиÑÑ Ð¿Ð¾Ð´Ð´ÐµÑживаемÑе вÑÑ
однÑе ÑоÑмаÑÑ"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:4
-msgid "Region sensitive output"
-msgstr "ÐÑвод завиÑÑÑий Ð¾Ñ Ñегиона"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:6
-#: ../raster/r.out.gdal/main.c:147
-msgid "GIS format to write (case sensitive, see also -l flag)"
-msgstr "GIS ÑоÑÐ¼Ð°Ñ Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи (ÑегиÑÑÑозавиÑимÑй, Ñм. Ñакже паÑамеÑÑ -l)"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:7
-#: ../raster/r.out.gdal/main.c:168
-msgid "File type"
-msgstr "Тип Ñайла"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:8
-#: ../raster/r.out.mpeg/main.c:406
-msgid "Name for output file"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного Ñайла"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:9
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed"
-msgstr ""
-"ÐпÑии ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð´Ð»Ñ Ð´ÑайвеÑа вÑÑ
одного ÑоÑмаÑа. Ðозможно неÑколÑко опÑий"
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:10
-msgid "Metadata key passed on the output dataset if possible"
-msgstr "ÐеÑаданнÑе пеÑедаваемÑе еÑли возможно вÑÑ
Ð¾Ð´Ð½Ð¾Ð¼Ñ Ð½Ð°Ð±Ð¾ÑÑ Ð´Ð°Ð½Ð½ÑÑ
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"ÐкÑпоÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð² ÑекÑÑовÑй Ñайл как знаÑÐµÐ½Ð¸Ñ x,y,z ÑенÑÑов ÑÑеек."
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#: ../raster/r.stats/main.c:116
-msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного Ñайла (еÑли не Ñказано или '-' вÑвод в stdout)"
-#: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"СоздаÑÑ ÑаÑÑÑовÑй Ñлой Ð·Ð½Ð°Ñ Ð¿Ð°Ð´ÐµÐ½Ð¸Ðµ (наклонение), ÑкÑпозиÑÐ¸Ñ (азимÑÑ) и Ð¾Ð´Ð½Ñ "
-"ÑоÑкÑ."
-#: ../locale/scriptstrings/r.plane_to_translate.c:2
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
-msgid "raster, elevation"
-msgstr "ÑаÑÑÑ, вÑÑоÑа"
-#: ../locale/scriptstrings/r.plane_to_translate.c:3
-msgid "Name of raster plane to be created"
-msgstr "ÐÐ¼Ñ Ñоздаваемой ÑаÑÑÑовой плоÑкоÑÑи"
-#: ../locale/scriptstrings/r.plane_to_translate.c:4
-msgid "Dip of plane. Value must be between -90 and 90 degrees"
-msgstr "ÐзимÑÑ Ð¿Ð»Ð¾ÑкоÑÑи. ÐнаÑение должно бÑÑÑ Ð¼ÐµÐ¶Ð´Ñ -90 и 90 гÑадÑÑами"
-#: ../locale/scriptstrings/r.plane_to_translate.c:5
-msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
-msgstr "ÐзимÑÑ Ð¿Ð»Ð¾ÑкоÑÑи. ÐнаÑение должно бÑÑÑ Ð¼ÐµÐ¶Ð´Ñ 0 и 360 гÑадÑÑами"
-#: ../locale/scriptstrings/r.plane_to_translate.c:6
-msgid "Easting coordinate of a point on the plane"
-msgstr "ÐоÑÑоÑÐ½Ð°Ñ ÐºÐ¾Ð¾ÑдинаÑа ÑоÑки на плоÑкоÑÑи "
-#: ../locale/scriptstrings/r.plane_to_translate.c:7
-msgid "Northing coordinate of a point on the plane"
-msgstr "СевеÑÐ½Ð°Ñ ÐºÐ¾Ð¾ÑдинаÑа ÑоÑки на плоÑкоÑÑи "
-#: ../locale/scriptstrings/r.plane_to_translate.c:8
-msgid "Elevation coordinate of a point on the plane"
-msgstr "ÐÑÑоÑÐ½Ð°Ñ ÐºÐ¾Ð¾ÑдинаÑа ÑоÑки на плоÑкоÑÑи "
-#: ../locale/scriptstrings/r.plane_to_translate.c:9
-msgid "Type of the raster map to be created"
-msgstr "Тип Ñоздаваемого ÑаÑÑÑового ÑлоÑ"
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-#, fuzzy
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"ÐеÑеклаÑÑиÑиÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой болÑÑе или менÑÑе Ñем плоÑÐ°Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ð°Ñ "
-"полÑзоваÑелем (в гекÑаÑаÑ
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
-msgid "raster, statistics, aggregation"
-msgstr "ÑаÑÑÑ, ÑÑаÑиÑÑика, аггÑегаÑиÑ"
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
-#, fuzzy
-msgid "Lesser value option that sets the <= area size limit [hectares]"
-msgstr ""
-"менÑÑее знаÑение опÑии, коÑоÑÐ°Ñ ÑÑÑÐ°Ð½Ð°Ð²Ð»Ð¸Ð²Ð°ÐµÑ <= Ð»Ð¸Ð¼Ð¸Ñ Ð¿Ð»Ð¾Ñади полигона "
-"[гекÑаÑÑ]"
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
-#, fuzzy
-msgid "Greater value option that sets the >= area size limit [hectares]"
-msgstr ""
-"болÑÑее знаÑение опÑии, коÑоÑÐ°Ñ ÑÑÑÐ°Ð½Ð°Ð²Ð»Ð¸Ð²Ð°ÐµÑ >= Ð»Ð¸Ð¼Ð¸Ñ Ð¿Ð»Ð¾Ñади полигона "
-"[гекÑаÑÑ]"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:1
-msgid "Calculates linear regression from two raster maps: y = a + b*x"
-msgstr "РаÑÑÑиÑаÑÑ Ð»Ð¸Ð½ÐµÐ¹Ð½ÑÑ ÑегÑеÑÑÐ¸Ñ Ð´Ð»Ñ Ð´Ð²ÑÑ
ÑаÑÑÑовÑÑ
Ñлоев: y = a + b*x"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:2
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:2
-#: ../raster/r.statistics/main.c:42 ../raster/r.report/main.c:64
-#: ../raster/r.quantile/main.c:243 ../raster/r.stats/main.c:105
-#: ../raster/r.univar2/r.univar_main.c:75
-msgid "raster, statistics"
-msgstr "ÑаÑÑÑ, ÑÑаÑиÑÑика"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:4
-msgid "Slower but accurate (applies to FP maps only)"
-msgstr "Ðедленнее, но ÑоÑнее (пÑименимо ÑолÑко Ð´Ð»Ñ FP Ñлоев)"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:5
-msgid "Map for x coefficient"
-msgstr "Слой Ð´Ð»Ñ ÐºÐ¾ÑÑÑиÑиенÑа x"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:6
-msgid "Map for y coefficient"
-msgstr "Слой Ð´Ð»Ñ ÐºÐ¾ÑÑÑиÑиенÑа y"
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:7
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
-msgstr ""
-"Ñайл ASCII Ð´Ð»Ñ ÑоÑ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ ÐºÐ¾ÑÑÑиÑиенÑов ÑегÑеÑÑии (вÑвод на ÑкÑан, еÑли Ñайл "
-"не задан)."
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
-msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr "СоздаÑÑ Ñлой Ñеневого ÑелÑеÑа из ÑÐ»Ð¾Ñ ÑелÑеÑа (DEM)."
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
-#: ../raster/r.topidx/main.c:42
-msgid "Input elevation map"
-msgstr "ÐÑÑ
однÑй Ñлой вÑÑоÑ"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:4
-msgid "Output shaded relief map name"
-msgstr "ÐÑвеÑÑи Ð¸Ð¼Ñ ÑÐ»Ð¾Ñ Ñеневой оÑмÑвки ÑелÑеÑа"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
-msgid "Altitude of the sun in degrees above the horizon"
-msgstr "ÐÑÑоÑа ÑолнÑа над гоÑизонÑом в гÑадÑÑаÑ
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:6
-msgid "Azimuth of the sun in degrees to the east of north"
-msgstr "ÐзимÑÑ ÑолнÑа в гÑадÑÑаÑ
к воÑÑÐ¾ÐºÑ Ð¾Ñ ÑевеÑа"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:7
-msgid "Factor for exaggerating relief"
-msgstr "ФакÑÐ¾Ñ Ð¼Ð°ÑÑÑабиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð´Ð»Ñ Ð²ÑÑоÑ"
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
-msgid "Scale factor for converting horizontal units to elevation units"
-msgstr ""
-"ФакÑÐ¾Ñ Ð¼Ð°ÑÑÑабиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð´Ð»Ñ ÐºÐ¾Ð½Ð²ÐµÑÑаÑии гоÑизонÑалÑнÑÑ
ÐµÐ´Ð¸Ð½Ð¸Ñ Ð² вÑÑоÑнÑе "
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
-msgstr ""
-"ÐадаÑÑ ÑакÑÐ¾Ñ Ð¼Ð°ÑÑÑабиÑÐ¾Ð²Ð°Ð½Ð¸Ñ (ÑолÑко Ð´Ð»Ñ ÑоÑек в lat./long., еÑли пÑÑÑо: "
-"scale=1)"
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"СоздаÑÑ ÑÐ°Ð¹Ð»Ñ Ð² иÑÑ
одной пÑоекÑии Ð´Ð»Ñ Ð¸ÑполÑÐ·Ð¾Ð²Ð°Ð½Ð¸Ñ Ñ Ð²ÑÑ
однÑм Ñегионом и "
-"пÑоекÑией."
-#: ../locale/scriptstrings/r.tileset_to_translate.c:2
-msgid "raster, tiling"
-msgstr "ÑаÑÑÑ, плиÑки"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:3
-msgid "Produces shell script output"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:4
-msgid "Produces web map server query string output"
-msgstr "СоздаÑÑ ÑÑÑÐ¾ÐºÑ Ð·Ð°Ð¿ÑоÑа вÑвода к каÑÑогÑаÑиÑеÑÐºÐ¾Ð¼Ñ Ð²ÐµÐ± ÑеÑвеÑÑ"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
-"Ðазвание Ñегиона Ð´Ð»Ñ Ð¸ÑполÑÐ·Ð¾Ð²Ð°Ð½Ð¸Ñ Ð²Ð¼ÐµÑÑо ÑекÑÑего Ð´Ð»Ñ Ð³ÑÐ°Ð½Ð¸Ñ Ð¸ ÑазÑеÑениÑ"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid "Source projection"
-msgstr "ÐÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð¿ÑоекÑиÑ"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:7
-#: ../locale/scriptstrings/r.tileset_to_translate.c:9
-msgid "Conversion factor from units to meters in source projection"
-msgstr "ÐоÑÑÑиÑÐ¸ÐµÐ½Ñ Ð¿ÐµÑеÑÑеÑа из ÐµÐ´Ð¸Ð½Ð¸Ñ Ð² меÑÑÑ Ð² иÑÑ
одной пÑоекÑии"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:8
-msgid "Destination projection, defaults to this location's projection"
-msgstr "ÐонеÑÐ½Ð°Ñ Ð¿ÑоекÑиÑ, по ÑмолÑÐ°Ð½Ð¸Ñ Ð¿ÑоекÑÐ¸Ñ Ð¾Ð±Ð»Ð°ÑÑи "
-#: ../locale/scriptstrings/r.tileset_to_translate.c:10
-msgid "Maximum number of columns for a tile in the source projection"
-msgstr "ÐакÑималÑное ÑиÑло ÑÑолбÑов Ð´Ð»Ñ ÑÑагменÑа в иÑÑ
одной пÑоекÑии"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:11
-msgid "Maximum number of rows for a tile in the source projection"
-msgstr "ÐакÑималÑное ÑиÑло ÑÑдов Ð´Ð»Ñ ÑÑагменÑа в иÑÑ
одной пÑоекÑии"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:12
-#, fuzzy
-msgid "Number of cells tiles should overlap in each direction"
-msgstr "ЧиÑло ÑÑеек должно пеÑеÑекаÑÑÑÑ Ð²Ð¾ вÑеÑ
напÑавлениÑÑ
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:1
-msgid "calculates univariate statistics from a GRASS raster map"
-msgstr "РаÑÑÑиÑаÑÑ Ð¾Ð´Ð½Ð¾Ð¼ÐµÑнÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ GRASS"
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:3
-msgid "extended statistics (quartiles and percentile)"
-msgstr "ÑаÑÑиÑÐµÐ½Ð½Ð°Ñ ÑÑаÑиÑÑика (кваÑÑили и пеÑÑенÑили)"
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:5
-msgid "Percentile to calculate (requires -e flag)"
-msgstr "ÐÑÑиÑлÑемÑй пÑоÑенÑÐ¸Ð»Ñ (ÑÑебÑÐµÑ Ð¿Ð°ÑамеÑÑа -e)"
-msgid "Calculates new grid3D volume from r3.mapcalc expression."
-msgstr "РаÑÑÑиÑаÑÑ Ð½Ð¾Ð²Ñй grid3D обÑем Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ Ð²ÑÑÐ°Ð¶ÐµÐ½Ð¸Ñ r3.mapcalc"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:2
-msgid "A (grid3D file)"
-msgstr "A (Ñайл grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:3
-msgid "B (grid3D file)"
-msgstr "B (Ñайл grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:4
-msgid "C (grid3D file)"
-msgstr "C (Ñайл grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:5
-msgid "D (grid3D file)"
-msgstr "D (Ñайл grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:6
-msgid "E (grid3D file)"
-msgstr "E (Ñайл grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:7
-msgid "F (grid3D file)"
-msgstr "F (Ñайл grid3D)"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:9
-msgid "Name for output grid3D volume"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного обÑема grid3D"
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:11
-msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-msgstr "ÐкÑпеÑÑнÑй Ñежим (введиÑе Ð½Ð°Ð±Ð¾Ñ Ð²ÑÑажений r3.mapcalc)"
-#: ../locale/scriptstrings/v.build.all_to_translate.c:1
-msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr "ÐеÑеÑÑÑоиÑÑ ÑÐ¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð´Ð»Ñ Ð²ÑеÑ
векÑоÑнÑÑ
Ñлоев ÑекÑÑего набоÑа."
-#: ../locale/scriptstrings/v.build.all_to_translate.c:2
-#: ../vector/v.external/main.c:58 ../vector/v.perturb/main.c:73
-#: ../vector/v.sample/main.c:86 ../vector/v.in.region/main.c:38
-#: ../vector/v.info/main.c:257 ../vector/v.patch/main.c:68
-#: ../vector/v.vol.rst/main.c:202 ../vector/v.mkgrid/main.c:63
-#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.voronoi/dt_main.c:46
-#: ../vector/v.voronoi/vo_main.c:119 ../vector/v.out.vtk/main.c:46
-#: ../vector/v.surf.rst/main.c:160 ../vector/v.buffer/main.c:254
-#: ../vector/v.delaunay2/main.c:62
-msgid "vector"
-msgstr "векÑоÑ"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:1
-msgid "Adds missing centroids to closed boundaries."
-msgstr "ÐобавиÑÑ Ð¿ÑопÑÑеннÑе ÑенÑÑÐ¾Ð¸Ð´Ñ Ðº замкнÑÑÑм гÑаниÑам."
-#: ../locale/scriptstrings/v.centroids_to_translate.c:2
-msgid "vector, centroid, area"
-msgstr "векÑоÑ, ÑенÑÑоид, полигон"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:3
-#: ../locale/scriptstrings/v.colors_to_translate.c:3
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:6
-#: ../locale/scriptstrings/v.report_to_translate.c:5
-msgid "Name of input vector map"
-msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного векÑоÑного ÑлоÑ"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:4
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:6
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
-msgid "Name for output vector map"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
-#: ../locale/scriptstrings/v.centroids_to_translate.c:5
-msgid "Action to be taken"
-msgstr "ÐÑполниÑÑ Ð´ÐµÐ¹ÑÑвие"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:7
-msgid "Category number starting value"
-msgstr "ÐаÑалÑнÑй Ð½Ð¾Ð¼ÐµÑ ÐºÐ°ÑегоÑии"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:8
-#: ../vector/v.category/main.c:112
-msgid "Category increment"
-msgstr "Шаг номеÑа каÑегоÑии"
-#: ../locale/scriptstrings/v.colors_to_translate.c:1
-msgid ""
-"Set color rules for features in a vector using a numeric attribute column."
-msgstr ""
-#: ../locale/scriptstrings/v.colors_to_translate.c:2
-#, fuzzy
-msgid "vector, color table"
-#: ../locale/scriptstrings/v.colors_to_translate.c:4
-#, fuzzy
-msgid "Name of column containg numeric data"
-msgstr "ÐÐ¼Ñ ÑÑолбÑа, ÑодеÑжаÑего кооÑдинаÑÑ x"
-#: ../locale/scriptstrings/v.colors_to_translate.c:5
-#, fuzzy
-msgid "Layer number of data column"
-msgstr "Слой к коÑоÑÐ¾Ð¼Ñ Ð´Ð¾Ð±Ð°Ð²Ð¸ÑÑ ÑÑолбеÑ"
-#: ../locale/scriptstrings/v.colors_to_translate.c:6
-#, fuzzy
-msgid "Name of color column to populate"
-msgstr "ÐÐ¼Ñ Ð¿Ð¾ÐºÐ°Ð·Ñваемого полÑ"
-#: ../locale/scriptstrings/v.colors_to_translate.c:7
-#: ../locale/scriptstrings/v.colors_to_translate.c:10
-#: ../locale/scriptstrings/v.colors_to_translate.c:12
-#: ../locale/scriptstrings/v.colors_to_translate.c:14
-#: ../locale/scriptstrings/v.colors_to_translate.c:17
-#: ../raster/r.colors/main.c:183 ../raster/r.colors/main.c:197
-#: ../raster/r.colors/main.c:215 ../raster/r.colors/main.c:220
-#: ../raster/r.colors/main.c:225 ../raster/r.colors/main.c:230
-#: ../vector/v.label.sa/main.c:149 ../vector/v.label.sa/main.c:159
-#: ../vector/v.label.sa/main.c:166 ../vector/v.label.sa/main.c:176
-#: ../vector/v.label.sa/main.c:186 ../vector/v.label.sa/main.c:196
-#: ../vector/v.label.sa/main.c:203 ../vector/v.label/main.c:153
-#: ../vector/v.label/main.c:177 ../vector/v.label/main.c:190
-#: ../vector/v.label/main.c:196 ../vector/v.label/main.c:206
-#: ../display/d.vect/main.c:164 ../display/d.vect/main.c:174
-#: ../display/d.vect/main.c:181 ../display/d.vect/main.c:192
-#: ../display/d.vect/main.c:344 ../display/d.vect/main.c:350
-msgid "Colors"
-msgstr "ЦвеÑа"
-#: ../locale/scriptstrings/v.colors_to_translate.c:8
-#, fuzzy
-msgid "Manually set range (min,max)"
-msgstr "ЦелоÑиÑленнÑй диапазон: минимÑм, макÑимÑм"
-#: ../locale/scriptstrings/v.colors_to_translate.c:9
-#: ../raster/r.colors/main.c:181
-msgid "Type of color table"
-msgstr "Тип ÑвеÑовой ÑаблиÑÑ"
-#: ../locale/scriptstrings/v.colors_to_translate.c:11
-#: ../raster/r.colors/main.c:191
-msgid "Raster map name from which to copy color table"
-msgstr "ÐÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¸Ð· коÑоÑого бÑÐ´ÐµÑ ÑкопиÑована ÑвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа"
-#: ../locale/scriptstrings/v.colors_to_translate.c:13
-msgid "Path to rules file"
-msgstr "ÐÑÑÑ Ðº Ñайлам пÑавил"
-#: ../locale/scriptstrings/v.colors_to_translate.c:15
-msgid "Save placeholder raster map for use with d.legend"
-msgstr ""
-#: ../locale/scriptstrings/v.colors_to_translate.c:16
-#: ../raster/r.colors/main.c:214
-msgid "Invert colors"
-msgstr "ÐнвеÑÑиÑоваÑÑ ÑвеÑа"
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-msgid ""
-"Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
-"format"
-msgstr ""
-"ÐонвеÑÑиÑоваÑÑ Ð²Ñе ÑÑаÑÑе Ñлои GRASS < Ver5.7 в ÑекÑÑем набоÑе в ÑекÑÑий "
-"ÑоÑмаÑ"
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:2
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
-#: ../vector/v.in.dxf/main.c:60 ../vector/v.in.ascii/in.c:48
-#: ../vector/v.in.ogr/main.c:101 ../vector/v.in.dwg/main.c:65
-#: ../vector/v.in.db/main.c:52
-msgid "vector, import"
-msgstr "векÑоÑ, импоÑÑ"
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
-msgid "run non-interactively"
-msgstr "запÑÑÑиÑÑ Ð±ÐµÐ· инÑеÑакÑивноÑÑи"
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"ÐобавиÑÑ Ð¾Ð´Ð½Ð¾ или более полей к аÑÑибÑÑивной ÑаблиÑе, ÑвÑзанной Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ñм "
-"векÑоÑнÑм Ñлоем."
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.join_to_translate.c:2
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:2
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
-#: ../locale/scriptstrings/v.db.update_to_translate.c:2
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
-#: ../vector/v.db.connect/main.c:50 ../vector/v.distance/main.c:115
-#: ../vector/v.db.select/main.c:52 ../vector/v.to.db/main.c:32
-msgid "vector, database, attribute table"
-msgstr "векÑоÑ, база даннÑÑ
, аÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
-msgid "Vector map for which to edit attribute table"
-msgstr "ÐекÑоÑнÑй Ñлой Ð´Ð»Ñ ÐºÐ¾ÑоÑого ÑедакÑиÑоваÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ"
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:4
-msgid "Layer where to add column"
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-msgid ""
-"Name and type of the new column(s) (types depend on database backend, but "
-"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-msgstr ""
-"ÐÐ¼Ñ Ð¸ Ñип нового Ð¿Ð¾Ð»Ñ (полей) (ÑÐ¸Ð¿Ñ Ð·Ð°Ð²Ð¸ÑÑÑ Ð¾Ñ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
, но вÑе "
-"поддеÑживаÑÑ VARCHAR(), INT, DOUBLE and DATE)"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-msgid ""
-"Creates and adds a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"СоздаÑÑ Ð¸ добавиÑÑ Ð½Ð¾Ð²ÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ Ð² даннÑй Ñлой ÑÑÑеÑÑвÑÑÑего "
-"векÑоÑного ÑлоÑ."
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
-msgid "Vector map for which to add new attribute table"
-msgstr "ÐекÑоÑнÑй Ñлой, коÑоÑÐ¾Ð¼Ñ Ð´Ð¾Ð±Ð°Ð²Ð»ÑеÑÑÑ Ð½Ð¾Ð²Ð°Ñ Ð°ÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
-msgid "Name of new attribute table (default: vector map name)"
-msgstr "ÐÐ¼Ñ Ð½Ð¾Ð²Ð¾Ð¹ аÑÑибÑÑивной ÑаблиÑÑ (по ÑмолÑаниÑ: Ð¸Ð¼Ñ Ð²ÐµÐºÑоÑного ÑлоÑ)"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
-msgid "Layer where to add new attribute table"
-msgstr "Слой коÑоÑÐ¾Ð¼Ñ Ð´Ð¾Ð±Ð°Ð²Ð»ÑеÑÑÑ Ð½Ð¾Ð²Ð°Ñ Ð°ÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:1
-msgid "Allows to join a table to a vector map table."
-msgstr "ÐÑиÑоединиÑÑ ÑаблиÑÑ Ð²ÐµÐºÑоÑÐ½Ð¾Ð¼Ñ ÑлоÑ."
-#: ../locale/scriptstrings/v.db.join_to_translate.c:3
-msgid "Vector map to which to join other table"
-msgstr "ÐекÑоÑнÑй Ñлой к коÑоÑÐ¾Ð¼Ñ Ð¿ÑиÑоединиÑÑ Ð´ÑÑгÑÑ ÑаблиÑÑ"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:4
-#, fuzzy
-msgid "Layer where to join"
-msgstr "Слой к коÑоÑÐ¾Ð¼Ñ Ð´Ð¾Ð±Ð°Ð²Ð¸ÑÑ Ñоединение"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:5
-msgid "Join column in map table"
-msgstr "Ðоле ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ð² ÑаблиÑе ÑлоÑ"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:6
-msgid "Other table name"
-msgstr "ÐÐ¼Ñ Ð´ÑÑгой ÑаблиÑÑ"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:7
-msgid "Join column in other table"
-msgstr "Ðоле ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ð² дÑÑгой ÑаблиÑе"
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
-"УдалиÑÑ Ð¿Ð¾Ð»Ðµ в аÑÑибÑÑивной ÑаблиÑе, ÑвÑзанной Ñ Ð´Ð°Ð½Ð½Ñм векÑоÑнÑм Ñлоем."
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
-msgid "Vector map for which to drop attribute column"
-msgstr "ÐекÑоÑнÑй Ñлой из ÑаблиÑÑ ÐºÐ¾ÑоÑого ÑдалÑеÑÑÑ Ð¿Ð¾Ð»Ðµ"
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
-msgid "Layer where to drop column"
-msgstr "Слой Ñ ÐºÐ¾ÑоÑого ÑдалиÑÑ ÑÑолбеÑ"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
-msgid "Removes existing attribute table of a vector map."
-msgstr "УдалиÑÑ ÑÑÑеÑÑвÑÑÑÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ Ð¸Ð· векÑоÑного ÑлоÑ."
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
-msgid "Force removal (required for actual deletion of table)"
-msgstr "Силовое Ñдаление (ÑÑебÑеÑÑÑ Ð´Ð»Ñ ÑизиÑеÑкого ÑÐ´Ð°Ð»ÐµÐ½Ð¸Ñ ÑаблиÑÑ)"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
-msgid "Vector map from which to remove attribute table"
-msgstr "ÐекÑоÑнÑй Ñлой из коÑоÑого ÑдалÑеÑÑÑ ÑаблиÑа аÑÑибÑÑов"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
-msgid "Name of existing attribute table (default: vector map name)"
-msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑей ÑаблиÑÑ Ð°ÑÑибÑÑов (по ÑмолÑаниÑ: Ð¸Ð¼Ñ Ð²ÐµÐºÑоÑного ÑлоÑ)"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
-msgid "Layer from which to drop linked attribute table"
-msgstr "Слой из коÑоÑого ÑдалÑеÑÑÑ ÑвÑÐ·Ð°Ð½Ð½Ð°Ñ Ð°ÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"ÐеÑеименоваÑÑ Ð¿Ð¾Ð»Ðµ в аÑÑибÑÑивной ÑаблиÑе, ÑвÑзанной Ñ Ð´Ð°Ð½Ð½Ñм векÑоÑнÑм "
-"Ñлоем."
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
-msgid "Vector map for which to rename attribute column"
-msgstr "Ðоле аÑÑибÑÑов векÑоÑного ÑÐ»Ð¾Ñ Ð¸ÑполÑзÑемое Ð´Ð»Ñ Ð¿ÐµÑеименованиÑ"
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:4
-msgid "Layer where to rename column"
-msgstr "Слой в коÑоÑом пеÑеименовÑваеÑÑÑ Ð¿Ð¾Ð»Ðµ"
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:5
-msgid "Old and new name of the column (old,new)"
-msgstr "СÑаÑое и новое Ð¸Ð¼Ñ ÑÑолбÑа (ÑÑаÑое,новое)"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-msgid "Reconnects vectors to a new database."
-msgstr "ÐеÑеÑоединиÑÑ Ð²ÐµÐºÑоÑа Ñ Ð½Ð¾Ð²Ð¾Ð¹ базой даннÑÑ
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
-#, fuzzy
-msgid "Name of old database"
-msgstr "ÐÐ¼Ñ Ð½Ð¾Ð²Ð¾Ð¹ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-#, fuzzy
-msgid ""
-"The database must be in form printed by v.db.connect -g, i.e. with "
-"substituted variables"
-msgstr ""
-"ÐÐ¼Ñ ÑÑаÑой Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
. Ðаза даннÑÑ
должна бÑÑÑ Ñказана в ÑоÑме задаваемой v."
-"db.connect -g, Ñо еÑÑÑ Ñ Ð¿Ð¾Ð´Ð¼ÐµÐ½ÐµÐ½Ð½Ñми пеÑеменнÑми."
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
-msgid "Name of new database"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
-msgid "Old schema"
-msgstr "СÑаÑÐ°Ñ ÑÑ
ема"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
-msgid "New schema"
-msgstr "ÐÐ¾Ð²Ð°Ñ ÑÑ
ема"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr ""
-"РаÑÑÑиÑаÑÑ Ð¾Ð´Ð½Ð¾Ð¼ÐµÑнÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð¿Ð¾ вÑбÑÐ°Ð½Ð½Ð¾Ð¼Ñ Ð¿Ð¾Ð»Ñ ÑаблиÑÑ Ð´Ð»Ñ Ð²ÐµÐºÑоÑного "
-"ÑÐ»Ð¾Ñ GRASS."
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:2
-#: ../vector/lidar/v.outlier/main.c:66 ../vector/v.univar/main.c:64
-#: ../vector/v.class/main.c:45 ../vector/v.qcount/main.c:69
-#: ../vector/v.random/main.c:84 ../vector/v.kcv/main.c:76
-#: ../vector/v.normal/main.c:79
-msgid "vector, statistics"
-msgstr "векÑоÑ, ÑÑаÑиÑÑика"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:3
-msgid "Extended statistics (quartiles and 90th percentile)"
-msgstr "РаÑÑиÑÐµÐ½Ð½Ð°Ñ ÑÑаÑиÑÑика (кваÑÑили и 90 пеÑÑенÑилÑ)"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:4
-msgid "Name of data table"
-msgstr "ÐÐ¼Ñ ÑаблиÑÑ"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:5
-msgid "Column on which to calculate statistics (must be numeric)"
-msgstr "СÑÐ¾Ð»Ð±ÐµÑ Ð´Ð»Ñ ÐºÐ¾ÑоÑого ÑаÑÑÑиÑаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ (должен бÑÑÑ ÑиÑловой)"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:6
-msgid "Database/directory for table"
-msgstr "Ðаза даннÑÑ
/каÑалог Ð´Ð»Ñ ÑаблиÑÑ"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:7
-msgid "Database driver"
-msgstr "ÐÑÐ°Ð¹Ð²ÐµÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../locale/scriptstrings/v.db.update_to_translate.c:1
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
-msgstr "ÐбновиÑÑ Ð¿Ð¾Ð»Ðµ в аÑÑибÑÑивной ÑаблиÑе, ÑвÑзанной Ñ Ð²ÐµÐºÑоÑнÑм Ñлоем."
-#: ../locale/scriptstrings/v.db.update_to_translate.c:3
-msgid "Vector map to edit the attribute table for"
-msgstr "ÐекÑоÑнÑй Ñлой Ð´Ð»Ñ ÑедакÑиÑÐ¾Ð²Ð°Ð½Ð¸Ñ ÑаблиÑÑ"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:4
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-msgid "Layer to which the table to be changed is connected"
-msgstr "Слой Ñ ÐºÐ¾ÑоÑÑм Ñоединена изменÑÐµÐ¼Ð°Ñ ÑаблиÑа"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:5
-msgid "Column to update"
-msgstr "ÐбновлÑемÑй ÑÑолбеÑ"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:6
-msgid ""
-"Value to update the column with (varchar values have to be in single quotes, "
-"e.g. 'grass')"
-msgstr ""
-"ÐнаÑение иÑполÑзÑемое Ð´Ð»Ñ Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½Ð¸Ñ ÑÑолбÑа (знаÑÐµÐ½Ð¸Ñ varchar Ð´Ð¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ Ð² "
-"одиноÑнÑÑ
кавÑÑкаÑ
, напÑÐ¸Ð¼ÐµÑ 'grass')"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:7
-msgid "Column to query"
-msgstr "ÐапÑаÑиваемÑй ÑÑолбеÑ"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid ""
-"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
-"col2>1)"
-msgstr ""
-"ÐбновлÑемое ÑÑловие WHERE, без клÑÑевого Ñлова 'where' (напÑÐ¸Ð¼ÐµÑ cat=1 или "
-"col1/col2>1)"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"РаÑÑвоÑиÑÑ Ð³ÑаниÑÑ Ð¼ÐµÐ¶Ð´Ñ Ð¿ÑилегаÑÑими полигонами имеÑÑими одинаковое "
-"знаÑение каÑегоÑии или аÑÑибÑÑа."
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
-msgid "vector, area, dissolve"
-msgstr "векÑоÑ, полигон, ÑаÑÑвоÑиÑÑ"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
-#, fuzzy
-msgid "Layer number. If -1, all layers are extracted."
-msgstr "ÐÐ¾Ð¼ÐµÑ ÑлоÑ. ÐÑли -1, полÑÑаÑÑÑÑ Ð²Ñе Ñлои"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:11
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use."
-msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
-msgid "Name of column used to dissolve common boundaries"
-msgstr "ÐÐ¼Ñ Ð¿Ð¾Ð»Ñ Ð¸ÑполÑзÑемого Ð´Ð»Ñ ÑаÑÑвоÑÐµÐ½Ð¸Ñ Ð¾Ð±ÑиÑ
гÑÐ°Ð½Ð¸Ñ "
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
-msgid "Import E00 file into a vector map."
-msgstr "ÐмпоÑÑ Ñайла E00 в векÑоÑнÑй Ñлой."
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:3
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:3
-#: ../raster/r.out.mat/main.c:81 ../raster/r.in.mat/main.c:115
-#: ../raster/r.out.tiff/r.out.tiff.c:136
-msgid "Verbose mode"
-msgstr "Режим ÑаÑÑиÑенной инÑоÑмаÑии"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
-msgid "E00 file"
-msgstr "Ñайл E00"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
-msgid "Input type point, line or area"
-msgstr "ÐÑÑ
однÑй Ñип ÑоÑка, линий или полигон"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-"ÐагÑÑзиÑÑ ÑоÑки, маÑÑÑÑÑÑ Ð¸ ÑÑÑки из пÑиемника Garmin GPS в векÑоÑнÑй Ñлой."
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
-msgid "vector, import, GPS"
-msgstr "векÑоÑ, импоÑÑ, GPS"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:4
-msgid "Download Waypoints from GPS"
-msgstr "ÐагÑÑзиÑÑ ÑоÑки Ñ GPS"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:5
-msgid "Download Routes from GPS"
-msgstr "ÐагÑÑзиÑÑ Ð¼Ð°ÑÑÑÑÑÑ Ñ GPS"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:6
-msgid "Download Track from GPS"
-msgstr "ÐагÑÑзиÑÑ ÑÑÑк из GPS"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:7
-msgid "Force import of track or route data as points"
-msgstr "ÐмпоÑÑиÑоваÑÑ ÑÑÑки и маÑÑÑÑÑÑ ÐºÐ°Ðº ÑоÑки"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:8
-msgid "Use gardump instead of gpstrans as the download program"
-msgstr "ÐÑполÑзоваÑÑ Ð´Ð»Ñ Ð·Ð°Ð³ÑÑзки gardump вмеÑÑо gpstrans"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:9
-msgid "Import track in 3D (gardump only)"
-msgstr "ÐмпоÑÑиÑоваÑÑ ÑÑÑк в 3D (ÑолÑко Ð´Ð»Ñ gardump)"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:10
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:8
-msgid "Do not attempt projection transform from WGS84"
-msgstr "Ðе пÑÑаÑÑÑÑ Ð¿ÐµÑепÑоекÑиÑоваÑÑ Ð¸Ð· WGS84"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:11
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:10
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
-msgid "Name for output vector map (omit for display to stdout)"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного векÑоÑного ÑÐ»Ð¾Ñ (не задаваÑÑ Ð´Ð»Ñ Ð²Ñвода в stdout)"
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:12
-msgid "Port Garmin receiver is connected to"
-msgstr "ÐоÑÑ Ðº коÑоÑÐ¾Ð¼Ñ Ð¿ÑиÑоединен Garmin "
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
-msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr "ÐмпоÑÑ Ñайлов ÑÑÑан geonames.org в ÑоÑеÑнÑй векÑоÑнÑй Ñлой GRASS."
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
-msgid "vector, import, gazetteer"
-msgstr "векÑоÑ, импоÑÑ, каÑалог"
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
-msgid "Uncompressed geonames file from (with .txt extension)"
-msgstr "ÐеÑжаÑÑй Ñайл geonames из (Ñ ÑаÑÑиÑением .txt)"
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-"ÐмпоÑÑ Ñайлов ÑÑÑан US-NGA GEOnet Names Server (GNS) в ÑоÑеÑнÑй векÑоÑнÑй "
-"Ñлой GRASS."
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:3
-msgid "Uncompressed GNS file from NGA (with .txt extension)"
-msgstr "ÐеÑжаÑÑй Ñайл GNS из NGA (Ñ ÑаÑÑиÑением .txt)"
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-"ÐмпоÑÑиÑоваÑÑ Ð¿ÑÑевÑе ÑоÑки, маÑÑÑÑÑÑ, и ÑÑеки из GPS или Ñайла ÑкаÑанного "
-"из GPS в векÑоÑнÑй Ñлой."
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:4
-msgid "Import waypoints"
-msgstr "ÐмпоÑÑ Ð¿ÑÑевÑÑ
ÑоÑек"
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:5
-msgid "Import routes"
-msgstr "ÐмпоÑÑиÑоваÑÑ Ð¼Ð°ÑÑÑÑÑÑ"
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:6
-msgid "Import track"
-msgstr "ÐмпоÑÑ ÑÑÑка"
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:7
-msgid "Force vertices of track or route data as points"
-msgstr "ÐеÑÑÐ¸Ð½Ñ ÑÑÑка или маÑÑÑÑÑа как ÑоÑки"
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:9
-msgid "Device or file used to import data"
-msgstr "УÑÑÑойÑÑво или Ñайл иÑполÑзÑемÑй Ð´Ð»Ñ Ð¸Ð¼Ð¿Ð¾ÑÑа даннÑÑ
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:11
-msgid "Format of GPS input data (use gpsbabel supported formats)"
-msgstr ""
-"ФоÑÐ¼Ð°Ñ Ð¸ÑÑ
однÑÑ
даннÑÑ
GPS (иÑполÑзоваÑÑ ÑоÑмаÑÑ Ð¿Ð¾Ð´Ð´ÐµÑживаемÑе gpsbabel)"
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:12
-msgid ""
-"Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-msgstr ""
-"ÐÑоекÑÐ¸Ñ Ð¸ÑÑ
однÑÑ
даннÑÑ
(в ÑÑиле PROJ.4), еÑли не задана, подÑазÑмеваеÑÑÑ "
-"Lat/Lon WGS84"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
-msgid "Import Mapgen or Matlab vector maps into GRASS."
-msgstr "ÐмпоÑÑ Ð² GRASS векÑоÑнÑÑ
Ñлоев ÑоÑмаÑа Mapgen или Matlab."
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
-msgid "Input map is in Matlab format"
-msgstr "ÐÑÑ
однÑй Ñлой в ÑоÑмаÑе Matlab"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
-msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑй 3D ÑоÑеÑнÑй Ñлой из 3 ÑÑолбÑов даннÑÑ
Matlab"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
-msgid "Name of input file in Mapgen/Matlab format"
-msgstr " ÐÐ¼Ñ Ð¸ÑÑ
одного Ñайла в ÑоÑмаÑе Mapgen/Matlab"
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
-"ÐонвеÑÑиÑоваÑÑ Ð²Ñе ÑÑаÑÑе Ñлои ÑайÑов GRASS < Ver5.7 в ÑекÑÑем набоÑе в "
-"векÑоÑнÑе Ñлои."
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
-msgid "sites, vector, import"
-msgstr "ÑайÑÑ, векÑоÑ, импоÑÑ"
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
-msgid "Run non-interactively"
-msgstr "ÐÑполниÑÑ Ð±ÐµÐ· инÑеÑакÑивноÑÑи"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
-msgid "import GetFeature from WFS"
-msgstr "импоÑÑиÑоваÑÑ GetFeature из WFS"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
-msgid "GetFeature URL starting with http"
-msgstr "GetFeature URL наÑинаÑÑийÑÑ Ñ http"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
-msgid "Vector output map"
-msgstr "ÐÑÑ
одной векÑоÑнÑй Ñлой"
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-msgstr ""
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:2
-#, fuzzy
-msgid "vector, export, GPS"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:3
-#, fuzzy
-msgid "Export as waypoints"
ÑоÑек"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:4
-#, fuzzy
-msgid "Export as routes"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:5
-#, fuzzy
-msgid "Export as tracks"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:7
-#, fuzzy
-msgid "Feature type(s)"
-msgstr "Тип обÑекÑа"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:8
-#, fuzzy
-msgid "Name for output file or GPS device"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного Ñайла"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:9
-#, fuzzy
-msgid "GpsBabel supported output format"
однÑе ÑоÑмаÑÑ"
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:12
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:15
-msgid "Subset"
-msgstr ""
-#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:14
-msgid "Example: income < 1000 and inhab >= 10000"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from a GRASS raster map based on vector "
-"polygons and uploads statistics to new attribute columns."
-msgstr ""
-"ÐÑÑиÑление одномеÑной ÑÑаÑиÑÑики по ÑаÑÑÑÐ¾Ð²Ð¾Ð¼Ñ ÑÐ»Ð¾Ñ GRASS, иÑполÑзÑÑ "
-"векÑоÑнÑе полигонÑ. ÐагÑÑзка ÑÑаÑиÑÑики в новÑй ÑÑÐ¾Ð»Ð±ÐµÑ Ð°ÑÑибÑÑов."
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
-msgid "vector, raster, statistics"
-msgstr "векÑоÑ, ÑаÑÑÑ, ÑÑаÑиÑÑика"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
-msgid "Continue if upload column(s) already exist"
-msgstr "ÐÑодолжиÑÑ, еÑли загÑÑжаемÑй ÑÑÐ¾Ð»Ð±ÐµÑ (ÑÑолбÑÑ) Ñже ÑÑÑеÑÑвÑÑÑ"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
-#: ../raster/r.univar2/r.univar_main.c:49
-#: ../raster/r.univar2/r3.univar_main.c:48 ../vector/v.univar/main.c:100
-msgid "Calculate extended statistics"
-msgstr "РаÑÑÑиÑаÑÑ Ð´Ð¾Ð¿Ð¾Ð»Ð½Ð¸ÑелÑнÑÑ ÑÑаÑиÑÑикÑ"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
-msgid "Name of vector polygon map"
-msgstr "ÐÐ¼Ñ Ð²ÐµÐºÑоÑного полигоналÑного ÑлоÑ"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
-msgid "Name of raster map to calculate statistics from"
-msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð´Ð»Ñ Ð²ÑÑиÑÐ»ÐµÐ½Ð¸Ñ ÑÑаÑиÑÑики"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
-msgid "Column prefix for new attribute columns"
-msgstr "ÐÑеÑÐ¸ÐºÑ Ð´Ð»Ñ Ð½Ð¾Ð²Ð¾Ð³Ð¾ ÑÑолбÑа аÑÑибÑÑов"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
-#: ../raster/r.univar2/r.univar_main.c:40
-#: ../raster/r.univar2/r3.univar_main.c:39 ../vector/v.univar/main.c:92
-msgid "Percentile to calculate (requires extended statistics flag)"
-msgstr ""
-"ÐÑÑиÑлÑемÑй пÑоÑенÑÐ¸Ð»Ñ (ÑÑебÑÐµÑ ÑÑÑановки Ñлага ÑаÑÑиÑенной ÑÑаÑиÑÑики)"
-#: ../locale/scriptstrings/v.report_to_translate.c:1
-msgid "Reports geometry statistics for vectors."
-msgstr "ÐÑÑÐµÑ Ð³ÐµÐ¾Ð¼ÐµÑÑиÑеÑкой ÑÑаÑиÑÑики Ð´Ð»Ñ Ð²ÐµÐºÑоÑов."
-#: ../locale/scriptstrings/v.report_to_translate.c:2
-msgid "vector, report, statistics"
-msgstr "векÑоÑ, оÑÑеÑ, ÑÑаÑиÑÑика"
-#: ../locale/scriptstrings/v.report_to_translate.c:3
-msgid "Reverse sort the result"
-msgstr "ÐбÑаÑÐ½Ð°Ñ ÑоÑÑиÑовка ÑезÑлÑÑаÑа"
-#: ../locale/scriptstrings/v.report_to_translate.c:4
-msgid "Sort the result"
-msgstr "СоÑÑиÑовка ÑезÑлÑÑаÑа"
-#: ../locale/scriptstrings/v.report_to_translate.c:7
-msgid "Value to calculate"
-msgstr "ÐÑÑиÑлÑемое знаÑение"
-#: ../locale/scriptstrings/v.report_to_translate.c:8
-msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-msgstr ""
-"mi (мили), f (ÑÑÑÑ), me (меÑÑÑ), k (киломеÑÑÑ), a (акÑÑ), h (гекÑаÑÑ), p "
-"(пÑоÑенÑÑ)"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
-msgid "Uploads vector values at positions of vector points to the table."
-msgstr "ÐагÑÑзка знаÑений векÑоÑа в позиÑиÑÑ
векÑоÑнÑÑ
ÑоÑек в ÑаблиÑÑ."
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
-msgid "Points vector map to modify"
-msgstr "ÐзменÑемÑй ÑоÑеÑнÑй векÑоÑнÑй ÑлоÑ"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
-msgid "Layer in the vector to be modified"
-msgstr "ÐзменÑемÑй Ñлой векÑоÑа"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
-msgid "Column to be updated with the query result"
-msgstr "СÑолбеÑ, коÑоÑÑй бÑÐ´ÐµÑ Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½ по ÑезÑлÑÑаÑÑ Ð·Ð°Ð¿ÑоÑа"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
-msgid "Vector map to be queried"
-msgstr "ÐапÑаÑиваемÑй векÑоÑнÑй Ñлой"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
-#, fuzzy
-msgid "Layer of the query vector containing data"
-msgstr "Слой векÑоÑа запÑоÑа ÑодеÑжаÑего даннÑе"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
-msgid "Column to be queried"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
-msgid "Maximum query distance in map units"
-msgstr "ÐакÑималÑное ÑаÑÑÑоÑние запÑоÑа в единиÑаÑ
ÑÐ»Ð¾Ñ "
#: ../raster/r.describe/main.c:61
msgid "Prints terse list of category values found in a raster map layer."
msgstr "ÐÑÐ²Ð¾Ð´Ð¸Ñ ÐºÑаÑкий ÑпиÑок знаÑений каÑегоÑий, найденнÑÑ
в ÑаÑÑÑовом Ñлое."
@@ -4208,7 +1681,7 @@
#: ../raster/r.describe/main.c:107 ../raster/r.distance/parse.c:64
#: ../raster/r.carve/main.c:116 ../raster/r.compress/main.c:82
#: ../raster/r.covar/main.c:67 ../raster/r.colors/main.c:239
-#: ../raster/r.out.ppm/main.c:69 ../raster/r.neighbors/main.c:163
+#: ../raster/r.out.ppm/main.c:69 ../raster/r.neighbors/main.c:170
#: ../raster/r.clump/main.c:68 ../raster/r.out.ppm3/main.c:90
#: ../raster/r.contour/main.c:135 ../raster/r.cross/main.c:100
#: ../raster/r.series/main.c:151 ../raster/r.buffer/main.c:101
@@ -4222,7 +1695,7 @@
#: ../raster/r.compress/main.c:90 ../raster/r.patch/main.c:88
#: ../raster/r.covar/main.c:75 ../raster/r.rescale/main.c:103
#: ../raster/r.slope.aspect/main.c:325 ../raster/r.colors/main.c:248
-#: ../raster/r.random.surface/init.c:109 ../raster/r.neighbors/main.c:277
+#: ../raster/r.random.surface/init.c:109 ../raster/r.neighbors/main.c:291
#: ../raster/r.clump/main.c:77 ../raster/r.to.vect/main.c:97
#: ../raster/r.out.ppm3/main.c:102 ../raster/r.cross/main.c:107
#: ../raster/r.series/main.c:169 ../raster/r.resample/main.c:90
@@ -4323,42 +1796,42 @@
msgstr "ÐеизвеÑÑнÑй меÑод <%s>"
#: ../raster/r.resamp.stats/main.c:329 ../raster/r.surf.area/main.c:123
-#: ../raster/r.resamp.interp/main.c:138 ../raster/r.los/main.c:196
-#: ../raster/r.los/main.c:207 ../raster/r.out.ascii/main.c:151
+#: ../raster/r.resamp.interp/main.c:138 ../raster/r.los/main.c:198
+#: ../raster/r.los/main.c:209 ../raster/r.out.ascii/main.c:151
#: ../raster/r.carve/main.c:181 ../raster/r.profile/main.c:144
#: ../raster/r.texture/main.c:234 ../raster/r.sum/main.c:65
#: ../raster/r.null/null.c:318 ../raster/r.lake/main.c:258
-#: ../raster/r.lake/main.c:269 ../raster/r.out.gdal/export_band.c:45
+#: ../raster/r.lake/main.c:269 ../raster/r.out.gdal/export_band.c:46
#: ../raster/r.surf.idw2/read_cell.c:34 ../raster/r.out.mat/main.c:108
#: ../raster/r.to.rast3elev/main.c:160 ../raster/r.grow2/main.c:203
#: ../raster/r.surf.idw/main.c:135 ../raster/r.thin/io.c:100
#: ../raster/r.out.pov/main.c:178 ../raster/r.covar/main.c:98
-#: ../raster/r.out.arc/main.c:118 ../raster/r.random/random.c:41
+#: ../raster/r.out.arc/main.c:125 ../raster/r.random/random.c:41
#: ../raster/r.random/random.c:45 ../raster/r.random/count.c:24
#: ../raster/r.random/count.c:30 ../raster/r.sunmask/main.c:455
-#: ../raster/r.quantile/main.c:300 ../raster/r.his/main.c:131
+#: ../raster/r.quantile/main.c:311 ../raster/r.his/main.c:131
#: ../raster/r.his/main.c:154 ../raster/r.his/main.c:179
-#: ../raster/r.bilinear/main.c:94 ../raster/r.resamp.rst/main.c:405
-#: ../raster/r.resamp.rst/main.c:437 ../raster/r.colors/stats.c:33
+#: ../raster/r.bilinear/main.c:94 ../raster/r.resamp.rst/main.c:401
+#: ../raster/r.resamp.rst/main.c:433 ../raster/r.colors/stats.c:33
#: ../raster/r.out.ppm/main.c:120 ../raster/r.random.surface/init.c:134
-#: ../raster/r.random.surface/main.c:54 ../raster/r.cost/main.c:340
-#: ../raster/r.out.vtk/main.c:222 ../raster/r.out.vtk/main.c:288
-#: ../raster/r.out.vtk/main.c:317 ../raster/r.out.vtk/main.c:364
-#: ../raster/r.support/front/front.c:227 ../raster/r.out.bin/main.c:133
-#: ../raster/r.clump/main.c:94 ../raster/r.random.cells/indep.c:134
-#: ../raster/r.random.cells/init.c:68 ../raster/r.to.vect/main.c:114
-#: ../raster/r.out.ppm3/main.c:124 ../raster/r.univar2/r.univar_main.c:153
-#: ../raster/r.contour/main.c:162 ../raster/r.cross/main.c:129
-#: ../raster/r.cats/main.c:150 ../raster/r.out.tiff/r.out.tiff.c:188
-#: ../raster/r.walk/main.c:545 ../raster/r.walk/main.c:548
-#: ../raster/r.walk/main.c:854 ../raster/r.mapcalc/map3.c:510
-#: ../raster/r.recode/recode.c:48 ../raster/r.composite/main.c:159
-#: ../raster/wildfire/r.ros/main.c:475 ../raster/wildfire/r.ros/main.c:483
-#: ../raster/wildfire/r.ros/main.c:491 ../raster/wildfire/r.ros/main.c:499
-#: ../raster/wildfire/r.ros/main.c:507 ../raster/wildfire/r.ros/main.c:515
-#: ../raster/wildfire/r.ros/main.c:523 ../raster/wildfire/r.ros/main.c:532
-#: ../raster/wildfire/r.ros/main.c:540 ../raster/wildfire/r.ros/main.c:549
-#: ../raster/wildfire/r.spread/main.c:411
+#: ../raster/r.random.surface/main.c:54 ../raster/r.cost/main.c:370
+#: ../raster/r.cost/main.c:657 ../raster/r.out.vtk/main.c:222
+#: ../raster/r.out.vtk/main.c:288 ../raster/r.out.vtk/main.c:317
+#: ../raster/r.out.vtk/main.c:364 ../raster/r.support/front/front.c:227
+#: ../raster/r.out.bin/main.c:133 ../raster/r.clump/main.c:94
+#: ../raster/r.random.cells/indep.c:134 ../raster/r.random.cells/init.c:68
+#: ../raster/r.to.vect/main.c:114 ../raster/r.out.ppm3/main.c:124
+#: ../raster/r.univar2/r.univar_main.c:153 ../raster/r.contour/main.c:162
+#: ../raster/r.cross/main.c:129 ../raster/r.cats/main.c:150
+#: ../raster/r.out.tiff/r.out.tiff.c:188 ../raster/r.walk/main.c:573
+#: ../raster/r.walk/main.c:576 ../raster/r.walk/main.c:922
+#: ../raster/r.mapcalc/map3.c:510 ../raster/r.recode/recode.c:48
+#: ../raster/r.composite/main.c:159 ../raster/wildfire/r.ros/main.c:475
+#: ../raster/wildfire/r.ros/main.c:483 ../raster/wildfire/r.ros/main.c:491
+#: ../raster/wildfire/r.ros/main.c:499 ../raster/wildfire/r.ros/main.c:507
+#: ../raster/wildfire/r.ros/main.c:515 ../raster/wildfire/r.ros/main.c:523
+#: ../raster/wildfire/r.ros/main.c:532 ../raster/wildfire/r.ros/main.c:540
+#: ../raster/wildfire/r.ros/main.c:549 ../raster/wildfire/r.spread/main.c:411
#: ../raster/wildfire/r.spread/main.c:415
#: ../raster/wildfire/r.spread/main.c:419
#: ../raster/wildfire/r.spread/main.c:425
@@ -4368,14 +1841,14 @@
#: ../raster/r.buffer/write_map.c:45 ../raster/r.bitpattern/main.c:108
#: ../raster/r.to.rast3/main.c:366 ../raster/r.grow.distance/main.c:177
#: ../vector/v.what.rast/main.c:141 ../vector/v.extrude/main.c:183
-#: ../vector/v.sample/main.c:161 ../vector/v.vol.rst/main.c:597
+#: ../vector/v.sample/main.c:161 ../vector/v.vol.rst/main.c:609
#: ../vector/v.to.rast/support.c:264 ../vector/v.to.rast/support.c:422
#: ../vector/v.drape/main.c:250 ../doc/raster/r.example/main.c:122
#: ../imagery/i.gensigset/opencell.c:13 ../imagery/i.his.rgb/openfiles.c:33
#: ../imagery/i.his.rgb/openfiles.c:38 ../imagery/i.his.rgb/openfiles.c:43
#: ../imagery/i.rgb.his/openfiles.c:21 ../imagery/i.rgb.his/openfiles.c:23
#: ../imagery/i.rgb.his/openfiles.c:25 ../imagery/i.smap/shapiro/opencell.c:16
-#: ../imagery/i.pca/main.c:126 ../imagery/i.gensig/opencell.c:12
+#: ../imagery/i.pca/main.c:132 ../imagery/i.gensig/opencell.c:12
#: ../imagery/i.cluster/open_files.c:56 ../imagery/i.maxlik/open.c:41
#: ../visualization/xganim/main.c:370 ../display/d.rast.edit/cell.c:92
#: ../display/d.profile/ExtractProf.c:93 ../display/d.profile/What.c:23
@@ -4472,14 +1945,15 @@
#: ../raster/r.param.scale/open_files.c:32
#: ../raster/r.param.scale/open_files.c:36 ../raster/r.reclass/reclass.c:235
-#: ../raster/r.topidx/file_io.c:81 ../raster/r.mfilter.fp/perform.c:84
+#: ../raster/r.topidx/file_io.c:88 ../raster/r.mfilter.fp/perform.c:84
#: ../raster/r.mfilter/perform.c:84 ../imagery/i.cca/main.c:191
#, c-format
msgid "Cannot create raster map <%s>"
msgstr "Ðе Ð¼Ð¾Ð³Ñ ÑоздаÑÑ ÑаÑÑÑовÑй Ñлой <%s>"
-#: ../raster/r.param.scale/main.c:45
-msgid "Lat/Long location is not supported"
+#: ../raster/r.param.scale/main.c:35
+#, fuzzy
+msgid "Lat/Long locations are not supported by this module"
msgstr "ÐблаÑÑÑ Lat/Long не поддеÑживаеÑÑÑ"
#: ../raster/r.surf.area/main.c:89
@@ -4494,193 +1968,193 @@
msgid "Vertical scale"
msgstr "ÐеÑÑикалÑнÑй маÑÑÑаб"
-#: ../raster/r.proj.seg/main.c:135 ../raster/r.proj/main.c:129
+#: ../raster/r.proj.seg/main.c:137 ../raster/r.proj/main.c:129
msgid "raster, projection"
msgstr "ÑаÑÑÑ, пÑоекÑиÑ"
-#: ../raster/r.proj.seg/main.c:137 ../raster/r.proj/main.c:131
+#: ../raster/r.proj.seg/main.c:139 ../raster/r.proj/main.c:131
msgid "Re-projects a raster map from one location to the current location."
msgstr "ÐеÑепÑоеÑиÑование ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð² ÑекÑÑÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ."
-#: ../raster/r.proj.seg/main.c:140 ../raster/r.proj/main.c:134
+#: ../raster/r.proj.seg/main.c:142 ../raster/r.proj/main.c:134
msgid "Name of input raster map to re-project"
msgstr "ÐÐ¼Ñ Ð¿ÐµÑепÑоеÑиÑÑемого ÑаÑÑÑового ÑлоÑ"
-#: ../raster/r.proj.seg/main.c:147 ../raster/r.proj/main.c:141
+#: ../raster/r.proj.seg/main.c:149 ../raster/r.proj/main.c:141
msgid "Location of input raster map"
msgstr "ÐблаÑÑÑ Ð¸ÑÑ
одного ÑаÑÑÑового ÑлоÑ"
-#: ../raster/r.proj.seg/main.c:153 ../raster/r.proj/main.c:147
+#: ../raster/r.proj.seg/main.c:155 ../raster/r.proj/main.c:147
msgid "Mapset of input raster map"
msgstr "ÐÐ°Ð±Ð¾Ñ Ð´Ð»Ñ Ð¸ÑÑ
-#: ../raster/r.proj.seg/main.c:159 ../raster/r.proj/main.c:153
+#: ../raster/r.proj.seg/main.c:161 ../raster/r.proj/main.c:153
#: ../vector/v.proj/main.c:88
msgid "Path to GRASS database of input location"
msgstr "ÐÑÑÑ Ðº базе даннÑÑ
GRASS иÑÑ
одной облаÑÑи"
-#: ../raster/r.proj.seg/main.c:163 ../raster/r.proj/main.c:157
+#: ../raster/r.proj.seg/main.c:165 ../raster/r.proj/main.c:157
msgid "Name for output raster map (default: input)"
msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного)"
-#: ../raster/r.proj.seg/main.c:173 ../raster/r.proj/main.c:167
+#: ../raster/r.proj.seg/main.c:175 ../raster/r.proj/main.c:167
msgid "Interpolation method to use"
msgstr "ÐÑполÑзÑемÑй меÑод инÑеÑполÑÑии"
-#: ../raster/r.proj.seg/main.c:179
+#: ../raster/r.proj.seg/main.c:181
msgid "Cache size (MiB)"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ ÐºÑÑа (MiB)"
-#: ../raster/r.proj.seg/main.c:185 ../raster/r.proj/main.c:173
+#: ../raster/r.proj.seg/main.c:187 ../raster/r.proj/main.c:173
msgid "Resolution of output map"
msgstr "РазÑеÑение вÑÑ
одного ÑлоÑ"
-#: ../raster/r.proj.seg/main.c:189 ../raster/r.proj/main.c:177
+#: ../raster/r.proj.seg/main.c:191 ../raster/r.proj/main.c:177
msgid "List raster maps in input location and exit"
msgstr "ÐÑвеÑÑи ÑпиÑок ÑаÑÑÑовÑÑ
Ñлоев иÑÑ
одной облаÑÑи и вÑйÑи"
-#: ../raster/r.proj.seg/main.c:193 ../raster/r.proj/main.c:181
+#: ../raster/r.proj.seg/main.c:195 ../raster/r.proj/main.c:181
msgid "Do not perform region cropping optimization"
msgstr "Ðе вÑполнÑÑÑ Ð¾Ð¿ÑимизаÑÐ¸Ñ Ð¾Ð±Ñезки Ñегиона"
-#: ../raster/r.proj.seg/main.c:209 ../raster/r.statistics/main.c:100
-#: ../raster/r.neighbors/main.c:216 ../raster/r.proj/main.c:197
+#: ../raster/r.proj.seg/main.c:211 ../raster/r.statistics/main.c:100
+#: ../raster/r.neighbors/main.c:225 ../raster/r.proj/main.c:197
#, c-format
msgid "<%s=%s> unknown %s"
msgstr "<%s=%s> неизвеÑÑно %s"
-#: ../raster/r.proj.seg/main.c:216 ../raster/r.proj/main.c:204
+#: ../raster/r.proj.seg/main.c:218 ../raster/r.proj/main.c:204
#: ../vector/v.proj/main.c:121
#, c-format
msgid "option <%s>: <%s> exists."
msgstr "опÑÐ¸Ñ <%s>: <%s> ÑÑÑеÑÑвÑеÑ."
-#: ../raster/r.proj.seg/main.c:221
+#: ../raster/r.proj.seg/main.c:223
msgid "You have to use a different location for input than the current"
msgstr "ÐеобÑ
одимо ÑказаÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ, оÑлиÑнÑÑ Ð¾Ñ ÑекÑÑей"
-#: ../raster/r.proj.seg/main.c:227 ../raster/r.proj/main.c:215
+#: ../raster/r.proj.seg/main.c:229 ../raster/r.proj/main.c:215
msgid "Unable to get projection info of output raster map"
msgstr "Ðевозможно полÑÑиÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ пÑоекÑии вÑÑ
-#: ../raster/r.proj.seg/main.c:230 ../raster/r.proj/main.c:218
+#: ../raster/r.proj.seg/main.c:232 ../raster/r.proj/main.c:218
msgid "Unable to get projection units of output raster map"
msgstr "Ðевозможно полÑÑиÑÑ ÐµÐ´Ð¸Ð½Ð¸ÑÑ Ð¿ÑоекÑии вÑÑ
-#: ../raster/r.proj.seg/main.c:233 ../raster/r.proj/main.c:221
+#: ../raster/r.proj.seg/main.c:235 ../raster/r.proj/main.c:221
msgid "Unable to get projection key values of output raster map"
msgstr "Ðевозможно полÑÑиÑÑ Ð¿Ð°ÑамеÑÑÑ Ð¿ÑоекÑии вÑÑ
-#: ../raster/r.proj.seg/main.c:242 ../raster/r.proj/main.c:230
+#: ../raster/r.proj.seg/main.c:244 ../raster/r.proj/main.c:230
#, c-format
msgid "Mapset <%s> in input location <%s> - %s"
msgstr "ÐÐ°Ð±Ð¾Ñ <%s> в иÑÑ
одной облаÑÑи <%s> - %s"
-#: ../raster/r.proj.seg/main.c:244 ../raster/r.in.gdal/main.c:633
+#: ../raster/r.proj.seg/main.c:246 ../raster/r.in.gdal/main.c:633
#: ../raster/r.proj/main.c:232 ../imagery/i.rectify/target.c:33
msgid "permission denied"
msgstr "недоÑÑаÑоÑнÑе пÑава доÑÑÑпа"
-#: ../raster/r.proj.seg/main.c:245 ../raster/r.in.gdal/main.c:634
+#: ../raster/r.proj.seg/main.c:247 ../raster/r.in.gdal/main.c:634
#: ../raster/r.proj/main.c:233 ../imagery/i.rectify/target.c:33
msgid "not found"
msgstr "не найдено"
-#: ../raster/r.proj.seg/main.c:250 ../raster/r.proj/main.c:238
+#: ../raster/r.proj.seg/main.c:252 ../raster/r.proj/main.c:238
#, c-format
msgid "Checking location <%s>, mapset <%s>..."
msgstr "ÐÑовеÑка облаÑÑи <%s>, Ð½Ð°Ð±Ð¾Ñ <%s>..."
-#: ../raster/r.proj.seg/main.c:257 ../raster/r.out.gdal/main.c:223
+#: ../raster/r.proj.seg/main.c:259 ../raster/r.out.gdal/main.c:228
#: ../raster/r.in.gdal/main.c:199 ../raster/r.proj/main.c:245
#: ../vector/v.in.ogr/main.c:268 ../vector/v.in.ogr/main.c:320
-#: ../vector/v.proj/main.c:163
+#: ../vector/v.select/main.c:88 ../vector/v.proj/main.c:163
#, c-format
msgid "Required parameter <%s> not set"
msgstr "Ðе Ñказан обÑзаÑелÑнÑй паÑамеÑÑ <%s>"
-#: ../raster/r.proj.seg/main.c:260 ../raster/r.proj/main.c:248
+#: ../raster/r.proj.seg/main.c:262 ../raster/r.proj/main.c:248
#, c-format
msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
msgstr "Ðе найден ÑаÑÑÑовÑй Ñлой <%s> в облаÑÑи <%s> в набоÑе <%s>"
-#: ../raster/r.proj.seg/main.c:268 ../raster/r.proj/main.c:256
+#: ../raster/r.proj.seg/main.c:270 ../raster/r.proj/main.c:256
msgid "Unable to get projection info of input map"
msgstr "Ðевозможно полÑÑиÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ пÑоекÑии иÑÑ
-#: ../raster/r.proj.seg/main.c:271 ../raster/r.proj/main.c:259
+#: ../raster/r.proj.seg/main.c:273 ../raster/r.proj/main.c:259
msgid "Unable to get projection units of input map"
msgstr "Ðевозможно полÑÑиÑÑ ÐµÐ´Ð¸Ð½Ð¸ÑÑ Ð¿ÑоекÑии иÑÑ
одного ÑлоÑ"
-#: ../raster/r.proj.seg/main.c:274 ../raster/r.proj/main.c:262
+#: ../raster/r.proj.seg/main.c:276 ../raster/r.proj/main.c:262
msgid "Unable to get projection key values of input map"
msgstr "Ðевозможно полÑÑиÑÑ Ð¿Ð°ÑамеÑÑÑ Ð¿ÑоекÑии иÑÑ
-#: ../raster/r.proj.seg/main.c:288 ../raster/r.proj/main.c:276
+#: ../raster/r.proj.seg/main.c:290 ../raster/r.proj/main.c:276
msgid "Unable to work with unprojected data (xy location)"
msgstr "Ðевозможно ÑабоÑаÑÑ Ñ Ð½ÐµÑпÑоеÑиÑованнÑми даннÑми (облаÑÑÑ xy)"
-#: ../raster/r.proj.seg/main.c:362 ../raster/r.proj/main.c:350
+#: ../raster/r.proj.seg/main.c:364 ../raster/r.proj/main.c:350
msgid "Input:"
msgstr "ÐÑ
од:"
-#: ../raster/r.proj.seg/main.c:363 ../raster/r.proj.seg/main.c:374
+#: ../raster/r.proj.seg/main.c:365 ../raster/r.proj.seg/main.c:376
#: ../raster/r.proj/main.c:351 ../raster/r.proj/main.c:362
#, c-format
msgid "Cols: %d (%d)"
msgstr "СÑолбÑÑ: %d (%d)"
-#: ../raster/r.proj.seg/main.c:364 ../raster/r.proj.seg/main.c:375
+#: ../raster/r.proj.seg/main.c:366 ../raster/r.proj.seg/main.c:377
#: ../raster/r.proj/main.c:352 ../raster/r.proj/main.c:363
#, c-format
msgid "Rows: %d (%d)"
msgstr "СÑÑоки: %d (%d)"
-#: ../raster/r.proj.seg/main.c:365 ../raster/r.proj.seg/main.c:376
+#: ../raster/r.proj.seg/main.c:367 ../raster/r.proj.seg/main.c:378
#: ../raster/r.proj/main.c:353 ../raster/r.proj/main.c:364
#, c-format
msgid "North: %f (%f)"
msgstr "СевеÑ: %f (%f)"
-#: ../raster/r.proj.seg/main.c:366 ../raster/r.proj.seg/main.c:377
+#: ../raster/r.proj.seg/main.c:368 ../raster/r.proj.seg/main.c:379
#: ../raster/r.proj/main.c:354 ../raster/r.proj/main.c:365
#, c-format
msgid "South: %f (%f)"
msgstr "Юг: %f (%f)"
-#: ../raster/r.proj.seg/main.c:367 ../raster/r.proj.seg/main.c:378
+#: ../raster/r.proj.seg/main.c:369 ../raster/r.proj.seg/main.c:380
#: ../raster/r.proj/main.c:355 ../raster/r.proj/main.c:366
#, c-format
msgid "West: %f (%f)"
msgstr "Ðапад: %f (%f)"
-#: ../raster/r.proj.seg/main.c:368 ../raster/r.proj.seg/main.c:379
+#: ../raster/r.proj.seg/main.c:370 ../raster/r.proj.seg/main.c:381
#: ../raster/r.proj/main.c:356 ../raster/r.proj/main.c:367
#, c-format
msgid "East: %f (%f)"
msgstr "ÐоÑÑок: %f (%f)"
-#: ../raster/r.proj.seg/main.c:369 ../raster/r.proj.seg/main.c:380
+#: ../raster/r.proj.seg/main.c:371 ../raster/r.proj.seg/main.c:382
#: ../raster/r.proj/main.c:357 ../raster/r.proj/main.c:368
#, c-format
msgid "EW-res: %f"
msgstr "ÑазÑеÑение EW: %f"
-#: ../raster/r.proj.seg/main.c:370 ../raster/r.proj.seg/main.c:381
+#: ../raster/r.proj.seg/main.c:372 ../raster/r.proj.seg/main.c:383
#: ../raster/r.proj/main.c:358 ../raster/r.proj/main.c:369
#, c-format
msgid "NS-res: %f"
msgstr "ÑазÑеÑение NS: %f"
-#: ../raster/r.proj.seg/main.c:373 ../raster/r.proj/main.c:361
+#: ../raster/r.proj.seg/main.c:375 ../raster/r.proj/main.c:361
msgid "Output:"
msgstr "ÐÑÑ
од:"
-#: ../raster/r.proj.seg/main.c:409 ../raster/r.proj/main.c:397
+#: ../raster/r.proj.seg/main.c:411 ../raster/r.proj/main.c:397
msgid "Projecting..."
msgstr "ÐÑоекÑиÑование..."
-#: ../raster/r.proj.seg/main.c:437 ../raster/r.los/main.c:378
+#: ../raster/r.proj.seg/main.c:439 ../raster/r.los/main.c:380
#: ../raster/r.texture/main.c:356 ../raster/r.texture/main.c:360
#: ../raster/r.texture/main.c:367 ../raster/r.null/null.c:342
#: ../raster/r.buffer/write_map.c:78 ../raster/r.proj/main.c:425
@@ -4928,14 +2402,12 @@
msgstr "ÐбÑабоÑка..."
#: ../raster/r.surf.fractal/process.c:53
-#, fuzzy
msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr "Ðевозможно вÑделиÑÑ Ð±ÑÑÐµÑ Ð´Ð»Ñ ÑÑÐµÐ½Ð¸Ñ ÑаÑÑÑового ÑлоÑ"
+msgstr "Ðевозможно вÑделиÑÑ Ð±ÑÑÐµÑ Ð´Ð°Ð½Ð½ÑÑ
. ÐÑовеÑÑÑе ÑекÑÑие Ñегион Ñ g.region."
#: ../raster/r.surf.fractal/interface.c:36
-#, fuzzy
msgid "raster, DEM, fractal"
-msgstr "ÑаÑÑÑ, ÑвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа"
+msgstr "ÑаÑÑÑ, ЦÐÐ , ÑÑакÑал"
#: ../raster/r.surf.fractal/interface.c:38
msgid "Creates a fractal surface of a given fractal dimension."
@@ -4950,26 +2422,26 @@
msgstr "ЧиÑло ÑоздаваемÑÑ
пÑомежÑÑоÑнÑÑ
изобÑажений"
#: ../raster/r.surf.fractal/interface.c:79 ../raster/r.reclass/main.c:81
-#: ../raster/r.los/main.c:171 ../raster/r.in.ascii/main.c:203
-#: ../raster/r.texture/main.c:231 ../raster/r.average/main.c:78
-#: ../raster/r.surf.idw2/main.c:83 ../raster/r.mode/main.c:94
-#: ../raster/r.to.rast3elev/main.c:472 ../raster/r.surf.idw/main.c:112
-#: ../raster/r.in.gdal/main.c:207 ../raster/r.random/main.c:141
-#: ../raster/r.random/main.c:146 ../raster/r.median/main.c:77
-#: ../raster/r.slope.aspect/opennew.c:11 ../raster/r.surf.gauss/main.c:77
-#: ../raster/r.cost/main.c:327 ../raster/r.neighbors/main.c:189
+#: ../raster/r.los/main.c:173 ../raster/r.drain/main.c:206
+#: ../raster/r.in.ascii/main.c:203 ../raster/r.texture/main.c:231
+#: ../raster/r.average/main.c:78 ../raster/r.surf.idw2/main.c:83
+#: ../raster/r.mode/main.c:94 ../raster/r.to.rast3elev/main.c:472
+#: ../raster/r.surf.idw/main.c:112 ../raster/r.in.gdal/main.c:207
+#: ../raster/r.random/main.c:147 ../raster/r.random/main.c:152
+#: ../raster/r.median/main.c:77 ../raster/r.slope.aspect/opennew.c:11
+#: ../raster/r.surf.gauss/main.c:77 ../raster/r.cost/main.c:352
+#: ../raster/r.cost/main.c:356 ../raster/r.neighbors/main.c:196
#: ../raster/r.clump/main.c:90 ../raster/r.in.mat/main.c:388
-#: ../raster/r.watershed/ram/init_vars.c:402
#: ../raster/r.watershed/shed/com_line.c:228
#: ../raster/r.watershed/shed/com_line.c:263
-#: ../raster/r.watershed/seg/init_vars.c:451
-#: ../raster/r.water.outlet/legal.c:10 ../raster/r.walk/main.c:531
-#: ../raster/r.recode/main.c:83 ../raster/wildfire/r.spread/main.c:380
+#: ../raster/r.water.outlet/legal.c:10 ../raster/r.walk/main.c:554
+#: ../raster/r.walk/main.c:558 ../raster/r.recode/main.c:83
+#: ../raster/wildfire/r.spread/main.c:380
#: ../raster/wildfire/r.spread/main.c:389
#: ../raster/wildfire/r.spread/main.c:399 ../raster/r.buffer/main.c:130
#: ../raster/r.bitpattern/main.c:104 ../vector/v.to.rast3/main.c:69
#: ../vector/v.edit/main.c:86 ../vector/v.kernel/main.c:263
-#: ../vector/v.in.ogr/main.c:324 ../vector/v.surf.idw/main.c:131
+#: ../vector/v.in.ogr/main.c:324 ../vector/v.surf.idw/main.c:132
#: ../doc/raster/r.example/main.c:114 ../imagery/i.ifft/ifftmain.c:116
#: ../imagery/i.zc/main.c:119 ../imagery/i.fft/fftmain.c:121
#: ../imagery/i.fft/fftmain.c:124
@@ -4981,26 +2453,25 @@
msgstr "<%s> - некоÑÑекÑное Ð¸Ð¼Ñ Ñайла"
#: ../raster/r.surf.fractal/interface.c:88
-#, fuzzy, c-format
+#, c-format
msgid "Fractal dimension of %.2lf must be between 2 and 3."
-msgstr "ФÑакÑалÑÐ½Ð°Ñ ÑазмеÑноÑÑÑ [%.2lf] должна бÑÑÑ Ð¼ÐµÐ¶Ð´Ñ 2 и 3"
+msgstr "ФÑакÑалÑÐ½Ð°Ñ ÑазмеÑноÑÑÑ %.2lf должна бÑÑÑ Ð¼ÐµÐ¶Ð´Ñ 2 и 3."
#: ../raster/r.surf.fractal/spec_syn.c:61
-#, fuzzy
msgid "Preliminary surface calculations..."
-msgstr "ÐÑедваÑиÑелÑнÑе вÑÑиÑÐ»ÐµÐ½Ð¸Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑи."
+msgstr "ÐÑедваÑиÑелÑнÑе ÑаÑÑеÑÑ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑи..."
#: ../raster/r.surf.fractal/spec_syn.c:120
-#, fuzzy, c-format
+#, c-format
msgid "Calculating surface %d (of %d)..."
-msgstr "ÐÑÑиÑление повеÑÑ
ноÑÑи %d (Ð´Ð»Ñ %d)"
+msgstr "РаÑÑÐµÑ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑи %d (из %d)..."
#: ../raster/r.surf.fractal/main.c:39 ../raster/r.circle/dist.c:155
#: ../raster/r.in.gdal/main.c:925 ../raster/r.recode/main.c:108
#: ../raster/r.composite/main.c:273
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> created."
-msgstr "РаÑÑÑовÑй Ñлой <%s> Ñже ÑÑÑеÑÑвÑеÑ"
+msgstr "РаÑÑÑовÑй Ñлой <%s> Ñоздан."
#: ../raster/r.reclass/reclass.c:49 ../raster/r.reclass/reclass.c:109
msgid "Too many categories"
@@ -5140,118 +2611,182 @@
msgid "Consider earth curvature (current ellipsoid)"
msgstr "УÑиÑÑваÑÑ ÐºÑÐ¸Ð²Ð¸Ð·Ð½Ñ Ðемли (ÑекÑÑий ÑллипÑоид)"
-#: ../raster/r.los/main.c:148
+#: ../raster/r.los/main.c:150
msgid "Lat/Long support is not (yet) implemented for this module."
msgstr "ÐоддеÑжка Lat/Long в ÑÑом модÑле (еÑе) не Ñеализована."
-#: ../raster/r.los/main.c:153
+#: ../raster/r.los/main.c:155
msgid "Specified observer coordinate is outside current region bounds."
msgstr "УказаннÑе кооÑдинаÑÑ Ð½Ð°Ñ
одÑÑÑÑ Ð·Ð° пÑеделами гÑÐ°Ð½Ð¸Ñ ÑекÑÑей облаÑÑи"
-#: ../raster/r.los/main.c:175 ../raster/r.los/main.c:180
-#: ../raster/r.resamp.rst/main.c:408 ../raster/r.resamp.rst/main.c:431
+#: ../raster/r.los/main.c:177 ../raster/r.los/main.c:182
+#: ../raster/r.resamp.rst/main.c:404 ../raster/r.resamp.rst/main.c:427
#, c-format
msgid "[%s]: Cannot read map header"
msgstr "[%s]: Ðе Ð¼Ð¾Ð³Ñ Ð¿ÑоÑеÑÑÑ Ð·Ð°Ð³Ð¾Ð»Ð¾Ð²Ð¾Ðº каÑÑÑ"
-#: ../raster/r.los/main.c:209
+#: ../raster/r.los/main.c:211
msgid "Pattern map should be a binary 0/1 CELL map"
msgstr "Слой Ñаблона должен бÑÑÑ Ð±Ð¸Ð½Ð°ÑнÑм Ñлоем (Ñ ÑÑейками 0/1)"
-#: ../raster/r.los/main.c:243
+#: ../raster/r.los/main.c:245
msgid ""
"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
msgstr ""
"Ðозникла пÑоблема Ñ Ð¿Ð¾Ð»ÑÑением ÑекÑÑиÑ
паÑамеÑÑов ÑллипÑоида, иÑполÑзÑеÑÑÑ "
"ÑÑеÑа (6370997.0)"
-#: ../raster/r.los/main.c:248
+#: ../raster/r.los/main.c:250
#, c-format
msgid "Using maximum distance from the viewing point (meters): %f"
msgstr ""
"ÐÑполÑзÑемое макÑималÑное ÑаÑÑÑоÑние Ð¾Ñ Ð½Ð°Ð±Ð»Ñдаемой ÑоÑки (в меÑÑаÑ
): %f"
-#: ../raster/r.los/main.c:262 ../raster/r.los/main.c:270
+#: ../raster/r.los/main.c:264 ../raster/r.los/main.c:272
#: ../raster/r.profile/read_rast.c:45 ../raster/r.profile/read_rast.c:73
#: ../raster/r.profile/read_rast.c:101 ../raster/r.null/null.c:334
#: ../raster/r.lake/main.c:288 ../raster/r.lake/main.c:293
-#: ../raster/r.out.gdal/export_band.c:203
-#: ../raster/r.out.gdal/export_band.c:234
-#: ../raster/r.out.gdal/export_band.c:265 ../raster/r.patch/main.c:157
-#: ../raster/r.patch/main.c:164 ../raster/r.topidx/file_io.c:62
-#: ../raster/r.colors/stats.c:46 ../raster/r.colors/stats.c:110
-#: ../raster/r.out.ppm/main.c:188 ../raster/r.cost/main.c:405
-#: ../raster/r.cost/main.c:609 ../raster/r.walk/main.c:697
-#: ../raster/r.walk/main.c:756 ../raster/r.walk/main.c:872
-#: ../raster/r.walk/main.c:1413 ../raster/r.walk/main.c:1448
-#: ../raster/r.walk/main.c:1483 ../raster/r.buffer/read_map.c:63
-#: ../raster/r.buffer/write_map.c:61 ../raster/r.bitpattern/main.c:135
-#: ../vector/v.what.rast/main.c:271 ../vector/v.what.rast/main.c:276
-#: ../vector/v.to.rast/support.c:436 ../doc/raster/r.example/main.c:154
-#: ../imagery/i.gensigset/get_train.c:36 ../imagery/i.gensig/get_train.c:32
+#: ../raster/r.out.gdal/export_band.c:195
+#: ../raster/r.out.gdal/export_band.c:229
+#: ../raster/r.out.gdal/export_band.c:263 ../raster/r.patch/main.c:157
+#: ../raster/r.patch/main.c:164 ../raster/r.topidx/file_io.c:69
+#: ../raster/r.colors/stats.c:46 ../raster/r.colors/stats.c:113
+#: ../raster/r.out.ppm/main.c:188 ../raster/r.cost/main.c:447
+#: ../raster/r.cost/main.c:673 ../raster/r.cost/main.c:1037
+#: ../raster/r.cost/main.c:1070 ../raster/r.cost/main.c:1103
+#: ../raster/r.walk/main.c:737 ../raster/r.walk/main.c:796
+#: ../raster/r.walk/main.c:940 ../raster/r.walk/main.c:1522
+#: ../raster/r.walk/main.c:1557 ../raster/r.walk/main.c:1592
+#: ../raster/r.buffer/read_map.c:63 ../raster/r.buffer/write_map.c:61
+#: ../raster/r.bitpattern/main.c:135 ../vector/v.what.rast/main.c:271
+#: ../vector/v.what.rast/main.c:276 ../vector/v.to.rast/support.c:436
+#: ../doc/raster/r.example/main.c:154 ../imagery/i.gensigset/get_train.c:36
+#: ../imagery/i.gensig/get_train.c:32
#, c-format
msgid "Unable to read raster map <%s> row %d"
msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¿ÑоÑеÑÑÑ ÑаÑÑÑовÑй Ñлой <%s>, ÑÑÑока %d"
-#: ../raster/r.drain/main.c:105
-msgid "Traces a flow through an elevation model on a raster map layer."
-msgstr "ÐÑоведение поÑока ÑеÑез Ð¼Ð¾Ð´ÐµÐ»Ñ Ð²ÑÑÐ¾Ñ Ð½Ð° ÑаÑÑÑовом Ñлое каÑÑÑ."
+#: ../raster/r.drain/main.c:110
+msgid "Traces a flow through an elevation model on a raster map."
+msgstr "ÐÑоведение поÑока ÑеÑез Ð¼Ð¾Ð´ÐµÐ»Ñ Ð²ÑÑÐ¾Ñ Ð´Ð»Ñ ÑаÑÑÑового ÑлоÑ."
-#: ../raster/r.drain/main.c:109 ../raster/r.fill.dir/main.c:91
-msgid "Name of existing raster map containing elevation surface"
-msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑего ÑаÑÑÑового ÑлоÑ, ÑодеÑжаÑего повеÑÑ
ноÑÑÑ Ð²ÑÑоÑ"
+#: ../raster/r.drain/main.c:120
+msgid "Name of movement direction map associated with the cost surface"
+msgstr ""
-#: ../raster/r.drain/main.c:112
-msgid "Output drain raster map"
-msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой водоÑÑока"
+#: ../raster/r.drain/main.c:131
+msgid ""
+"Output drain vector map (recommended for cost surface made using knight's "
+"move)"
+msgstr ""
-#: ../raster/r.drain/main.c:120
-msgid "The E and N coordinates of starting point(s)"
+#: ../raster/r.drain/main.c:139
+msgid "Map coordinates of starting point(s) (E,N)"
msgstr "ÐооÑдинаÑÑ E и N наÑалÑной ÑоÑки (ÑоÑек)"
-#: ../raster/r.drain/main.c:129
-msgid "Vector map(s) containing starting point(s)"
-msgstr "ÐекÑоÑнÑй Ñлой (Ñлои) ÑодеÑжаÑий наÑалÑнÑÑ ÑоÑÐºÑ (ÑоÑки)"
+#: ../raster/r.drain/main.c:140 ../raster/r.drain/main.c:146
+#: ../raster/r.cost/main.c:153 ../raster/r.cost/main.c:165
+#: ../raster/r.cost/main.c:174 ../raster/r.cost/main.c:224
+msgid "Start"
+msgstr "СÑаÑÑ"
-#: ../raster/r.drain/main.c:133
+#: ../raster/r.drain/main.c:145
+msgid "Name of vector map(s) containing starting point(s)"
+msgstr "ÐÐ¼Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ (Ñлоев) ÑодеÑжаÑего наÑалÑнÑÑ ÑоÑÐºÑ (ÑоÑки)"
+#: ../raster/r.drain/main.c:150
msgid "Copy input cell values on output"
msgstr "СкопиÑоваÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ð²Ñ
однÑÑ
ÑÑеек в вÑÑ
однÑе ÑÑейки"
-#: ../raster/r.drain/main.c:137
+#: ../raster/r.drain/main.c:154
msgid "Accumulate input values along the path"
msgstr "Ð¡Ð±Ð¾Ñ Ð²Ñ
однÑÑ
даннÑÑ
Ð²Ð´Ð¾Ð»Ñ Ð¿ÑÑи"
-#: ../raster/r.drain/main.c:141
+#: ../raster/r.drain/main.c:158
msgid "Count cell numbers along the path"
msgstr "СÑиÑаÑÑ ÑиÑло ÑÑеек Ð²Ð´Ð¾Ð»Ñ Ð¿ÑÑи"
-#: ../raster/r.drain/main.c:162
+#: ../raster/r.drain/main.c:163
+msgid ""
+"The input surface is a cost surface (if checked, a direction surface must "
+"also be specified"
+msgstr ""
+#: ../raster/r.drain/main.c:175
+msgid "Directional drain selected... checking for direction raster"
+msgstr ""
+#: ../raster/r.drain/main.c:178
+msgid "Surface/Hydrology drain selected"
+msgstr ""
+#: ../raster/r.drain/main.c:184
+msgid ""
+"Direction raster not specified, if direction flag is on, a direction raster "
+"must be given"
+msgstr ""
+#: ../raster/r.drain/main.c:191
+#, fuzzy, c-format
+msgid "Direction raster found <%s>"
+msgstr "ÐапиÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
+#: ../raster/r.drain/main.c:198
+#, c-format
+msgid "Direction map <%s> should not be specified for Surface/Hydrology drains"
+msgstr ""
+#: ../raster/r.drain/main.c:204
+#, fuzzy
+msgid "Outputting a vector path"
+msgstr "ÐÑÑ
одной векÑоÑнÑй Ñлой линий поÑоков"
+#: ../raster/r.drain/main.c:209 ../raster/r.flow/io.c:170
+#: ../vector/v.net.visibility/main.c:87 ../vector/v.edit/main.c:100
+#: ../vector/v.in.dxf/main.c:168
+#: ../vector/lidar/v.lidar.edgedetection/main.c:175
+#: ../vector/lidar/v.lidar.correction/main.c:156
+#: ../vector/lidar/v.lidar.correction/main.c:162
+#: ../vector/lidar/v.outlier/main.c:150 ../vector/lidar/v.outlier/main.c:155
+#: ../vector/lidar/v.outlier/main.c:161
+#: ../vector/lidar/v.surf.bspline/main.c:267 ../vector/v.generalize/main.c:312
+#: ../vector/v.mkgrid/main.c:212 ../vector/v.net.path/main.c:139
+#: ../vector/v.voronoi/dt_main.c:92 ../vector/v.voronoi/dt_main.c:98
+#: ../vector/v.voronoi/vo_main.c:164 ../vector/v.drape/main.c:339
+#: ../vector/v.drape/main.c:380 ../vector/v.delaunay2/main.c:103
+#: ../vector/v.delaunay2/main.c:107 ../vector/v.to.3d/main.c:87
+#: ../vector/v.buffer2/main.c:305 ../doc/vector/v.example/main.c:96
+#, c-format
+msgid "Unable to create vector map <%s>"
+msgstr "Ðевозможно ÑоздаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s>"
+#: ../raster/r.drain/main.c:227
msgid "Specify just one of the -c, -a and -n flags"
msgstr "УкажиÑе один из Ñлагов -c, -a, -n"
-#: ../raster/r.drain/main.c:181
+#: ../raster/r.drain/main.c:250
msgid "Metrics allocation"
msgstr "ÐÑделение меÑÑик"
-#: ../raster/r.drain/main.c:192
+#: ../raster/r.drain/main.c:261
#, c-format
msgid "Starting point %d is outside the current region"
msgstr "ÐаÑалÑÐ½Ð°Ñ ÑоÑка %d наÑ
одиÑÑÑ Ð·Ð° пÑеделами ÑекÑÑей облаÑÑи"
-#: ../raster/r.drain/main.c:200 ../raster/r.drain/main.c:241
+#: ../raster/r.drain/main.c:269 ../raster/r.drain/main.c:310
msgid "Too many start points"
msgstr "СлиÑком много наÑалÑнÑÑ
ÑоÑек"
-#: ../raster/r.drain/main.c:215 ../raster/r.carve/main.c:172
-#: ../raster/r.cost/main.c:301 ../raster/r.region/main.c:241
+#: ../raster/r.drain/main.c:284 ../raster/r.carve/main.c:172
+#: ../raster/r.cost/main.c:319 ../raster/r.region/main.c:241
#: ../vector/v.db.connect/main.c:123 ../vector/v.perturb/main.c:154
#: ../vector/v.edit/main.c:140
#: ../vector/lidar/v.lidar.edgedetection/main.c:170
#: ../vector/lidar/v.lidar.correction/main.c:147
#: ../vector/lidar/v.outlier/main.c:144
#: ../vector/lidar/v.lidar.growing/main.c:121
-#: ../vector/lidar/v.surf.bspline/main.c:224
-#: ../vector/lidar/v.surf.bspline/main.c:244
+#: ../vector/lidar/v.surf.bspline/main.c:227
+#: ../vector/lidar/v.surf.bspline/main.c:247
#: ../vector/v.net.salesman/main.c:171 ../vector/v.distance/main.c:299
#: ../vector/v.reclass/main.c:107 ../vector/v.to.points/main.c:244
#: ../vector/v.segment/main.c:99 ../vector/v.db.select/main.c:119
@@ -5268,11 +2803,11 @@
#: ../vector/v.kcv/main.c:132 ../vector/v.net/main.c:143
#: ../vector/v.net/main.c:158 ../vector/v.out.dxf/main.c:69
#: ../vector/v.normal/main.c:128 ../vector/v.voronoi/dt_main.c:77
-#: ../vector/v.voronoi/vo_main.c:157 ../vector/v.what/main.c:147
+#: ../vector/v.voronoi/vo_main.c:157 ../vector/v.what/main.c:151
#: ../vector/v.hull/main.c:315 ../vector/v.out.svg/main.c:127
-#: ../vector/v.to.db/parse.c:127 ../vector/v.select/main.c:208
+#: ../vector/v.to.db/parse.c:128 ../vector/v.select/main.c:101
#: ../vector/v.net.alloc/main.c:143 ../vector/v.label/main.c:270
-#: ../vector/v.type/main.c:202 ../vector/v.surf.rst/main.c:537
+#: ../vector/v.type/main.c:202 ../vector/v.surf.rst/main.c:544
#: ../vector/v.to.rast/vect2rast.c:37 ../vector/v.drape/main.c:261
#: ../vector/v.out.ogr/main.c:211 ../vector/v.net.steiner/main.c:428
#: ../vector/v.lrs/v.lrs.label/main.c:286
@@ -5282,7 +2817,7 @@
#: ../vector/v.lrs/v.lrs.where/main.c:127
#: ../vector/v.lrs/v.lrs.where/main.c:135 ../vector/v.buffer/main.c:365
#: ../vector/v.extract/main.c:193 ../vector/v.delaunay2/main.c:93
-#: ../vector/v.buffer2/main.c:269 ../doc/vector/v.example/main.c:73
+#: ../vector/v.buffer2/main.c:296 ../doc/vector/v.example/main.c:73
#: ../visualization/nviz2/cmd/vector.c:83 ../display/d.what.vect/main.c:148
#: ../display/d.vect/main.c:480 ../display/d.vect.chart/main.c:246
#: ../display/d.thematic.area/main.c:212 ../display/d.extract/main.c:98
@@ -5293,19 +2828,36 @@
msgid "Vector map <%s> not found"
msgstr "ÐекÑоÑнÑй Ñлой <%s> не найден"
-#: ../raster/r.drain/main.c:221
+#: ../raster/r.drain/main.c:290 ../raster/r.cost/main.c:563
msgid "Failed to guess site file format"
msgstr "Ðе ÑдалоÑÑ Ð¾Ð¿ÑеделиÑÑ ÑоÑÐ¼Ð°Ñ Ñайла ÑоÑек"
-#: ../raster/r.drain/main.c:247
+#: ../raster/r.drain/main.c:316
#, c-format
msgid "Starting vector map <%s> contains no points in the current region"
msgstr "ÐаÑалÑнÑй векÑоÑнÑй Ñлой <%s> не ÑодеÑÐ¶Ð¸Ñ ÑоÑек в ÑекÑÑем Ñегионе"
-#: ../raster/r.drain/main.c:253
+#: ../raster/r.drain/main.c:322
msgid "No start/stop point(s) specified"
msgstr "Ðе Ñказана наÑалÑнаÑ/конеÑÐ½Ð°Ñ ÑоÑка(и)"
+#: ../raster/r.drain/main.c:397
+msgid "Calculating flow directions..."
+msgstr "РаÑÑÐµÑ Ð½Ð°Ð¿ÑÐ°Ð²Ð»ÐµÐ½Ð¸Ñ ÑÑока..."
+#: ../raster/r.drain/main.c:466 ../raster/r.drain/main.c:519
+#: ../raster/r.random.surface/save.c:100 ../raster/r.cost/main.c:1023
+#: ../raster/r.random.cells/indep.c:137 ../raster/r.composite/main.c:199
+#: ../imagery/i.smap/shapiro/write_img.c:12
+#, c-format
+msgid "Writing raster map <%s>..."
+msgstr "ÐапиÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>..."
+#: ../raster/r.drain/main.c:684
+#, c-format
+msgid "direction read: %lf, neighbour found: %i"
+msgstr ""
#: ../raster/r.in.ascii/gethead.c:34
msgid "input file is not a Surfer ascii grid file"
msgstr "иÑÑ
однÑй Ñайл не ÑвлÑеÑÑÑ Ñайлом Surfer ASCII grid"
@@ -5419,13 +2971,13 @@
msgstr "ÐÑÐ´ÐµÑ Ð¸Ð¼Ð¿Ð¾ÑÑиÑован Ñайл SURFER (Golden Software) ASCII"
#: ../raster/r.in.ascii/main.c:128 ../raster/r.in.ascii/main.c:155
-#: ../raster/r.resamp.rst/main.c:619 ../raster/r.resamp.rst/main.c:631
-#: ../raster/r.resamp.rst/main.c:644 ../raster/r.resamp.rst/main.c:658
-#: ../raster/r.resamp.rst/main.c:671 ../raster/r.resamp.rst/main.c:684
-#: ../raster/r.in.arc/main.c:114 ../vector/v.in.ascii/in.c:245
-#: ../vector/v.surf.rst/main.c:618 ../vector/v.surf.rst/main.c:627
-#: ../vector/v.surf.rst/main.c:636 ../vector/v.surf.rst/main.c:646
-#: ../vector/v.surf.rst/main.c:655 ../vector/v.surf.rst/main.c:664
+#: ../raster/r.resamp.rst/main.c:615 ../raster/r.resamp.rst/main.c:627
+#: ../raster/r.resamp.rst/main.c:640 ../raster/r.resamp.rst/main.c:654
+#: ../raster/r.resamp.rst/main.c:667 ../raster/r.resamp.rst/main.c:680
+#: ../raster/r.in.arc/main.c:114 ../vector/v.in.ascii/in.c:248
+#: ../vector/v.surf.rst/main.c:625 ../vector/v.surf.rst/main.c:634
+#: ../vector/v.surf.rst/main.c:643 ../vector/v.surf.rst/main.c:653
+#: ../vector/v.surf.rst/main.c:662 ../vector/v.surf.rst/main.c:671
#: ../display/d.title/main.c:119 ../display/d.text/main.c:193
#: ../display/d.text.new/main.c:397 ../general/g.setproj/get_stp.c:162
#: ../general/g.setproj/get_stp.c:165 ../general/g.setproj/get_stp.c:282
@@ -5479,6 +3031,12 @@
msgid "Unable to write to file"
msgstr "ÐÑибка запиÑи в Ñайл"
+#: ../raster/r.out.ascii/main.c:59 ../raster/r.out.gdal/main.c:126
+#: ../raster/r.out.mat/main.c:64 ../raster/r.out.ppm/main.c:54
+#: ../raster/r.out.tiff/r.out.tiff.c:99
+msgid "raster, export"
+msgstr "ÑаÑÑÑ, ÑкÑпоÑÑ"
#: ../raster/r.out.ascii/main.c:61
msgid "Converts a raster map layer into an ASCII text file."
msgstr "ÐонвеÑÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой в ÑекÑÑовÑй Ñайл ASCII."
@@ -5534,8 +3092,8 @@
msgstr "ÐÑполÑзÑйÑе паÑамеÑÑ -M или -s, но не оба"
#: ../raster/r.out.ascii/main.c:172 ../raster/r.profile/main.c:157
-#: ../raster/r.out.arc/main.c:135 ../raster/r.out.ppm3/main.c:149
-#: ../raster/r.cats/main.c:177 ../vector/v.out.ascii/out.c:160
+#: ../raster/r.out.arc/main.c:142 ../raster/r.out.ppm3/main.c:149
+#: ../raster/r.cats/main.c:177 ../vector/v.out.ascii/out.c:161
#: ../vector/v.out.vtk/main.c:176 ../display/d.nviz/main.c:203
#: ../general/g.pnmcomp/main.c:241 ../general/g.pnmcomp/main.c:258
#, c-format
@@ -5558,6 +3116,7 @@
msgstr "ЧÑение ÑаÑÑÑового ÑлоÑ..."
#: ../raster/r.carve/raster.c:32 ../raster/r.in.poly/poly2rast.c:73
+#: ../vector/v.to.rast/vect2rast.c:182
msgid "Writing raster map..."
msgstr "ÐапиÑÑ ÑаÑÑÑового ÑлоÑ..."
@@ -5770,7 +3329,7 @@
"СлиÑком много каÑегоÑий (найдено: %i, макÑимÑм: %i). ÐопÑобÑйÑе измениÑÑ "
"маÑÑÑаб или пеÑеклаÑÑиÑиÑиÑоваÑÑ Ñлой"
-#: ../raster/r.texture/h_measure.c:758 ../raster/r.cost/main.c:603
+#: ../raster/r.texture/h_measure.c:758 ../raster/r.cost/main.c:667
#: ../imagery/i.smap/bouman/interp.c:69
msgid "Unable to allocate memory"
msgstr "ÐÑибка вÑÐ´ÐµÐ»ÐµÐ½Ð¸Ñ Ð¿Ð°Ð¼ÑÑи"
@@ -5786,7 +3345,6 @@
msgstr "Создание из ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¸Ð·Ð¾Ð±Ñажений Ñ ÑекÑÑÑÑнÑми обÑекÑами."
#: ../raster/r.texture/main.c:87
-#, fuzzy
msgid "Prefix for output raster map(s)"
msgstr "ÐÑеÑÐ¸ÐºÑ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (Ñлоев)"
@@ -5870,16 +3428,17 @@
msgstr "ÐÐµÑ Ð·Ð°Ð´Ð°Ð½Ð¸Ñ Ð´Ð»Ñ Ð¾Ð±ÑабоÑки. УкажиÑе Ñ
оÑÑ Ð±Ñ Ð¾Ð´Ð¸Ð½ Ñлаг."
#: ../raster/r.texture/main.c:240 ../raster/r.null/null.c:157
-#: ../raster/r.out.tiff/r.out.tiff.c:169 ../raster/r.bitpattern/main.c:114
-#: ../imagery/i.rectify/main.c:193 ../imagery/i.rectify/main.c:199
+#: ../raster/r.topidx/file_io.c:20 ../raster/r.out.tiff/r.out.tiff.c:169
+#: ../raster/r.bitpattern/main.c:114 ../imagery/i.rectify/main.c:193
+#: ../imagery/i.rectify/main.c:199
#, c-format
msgid "Unable to read header of raster map <%s>"
msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¿ÑоÑеÑÑÑ Ð·Ð°Ð³Ð¾Ð»Ð¾Ð²Ð¾Ðº ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
#: ../raster/r.texture/main.c:373
-#, fuzzy, c-format
+#, c-format
msgid "Calculated measure #%d <%s> (56 measures available)"
-msgstr "ÐÑÑиÑÐ»ÐµÐ½Ð½Ð°Ñ Ð¼ÐµÑа #%d (доÑÑÑпно 56 меÑ)"
+msgstr "ÐÑÑиÑÐ»ÐµÐ½Ð½Ð°Ñ Ð¼ÐµÑа #%d <%s> (доÑÑÑпно 56 меÑ)"
#: ../raster/r.basins.fill/main.c:55
msgid "Generates a raster map layer showing watershed subbasins."
@@ -5907,12 +3466,10 @@
#: ../raster/r.basins.fill/main.c:142
-#, fuzzy
msgid "Forward sweep complete"
msgstr "ÐÑÑÐ¼Ð°Ñ ÑазвеÑÑка завеÑÑена"
#: ../raster/r.basins.fill/main.c:159
-#, fuzzy
msgid "Reverse sweep complete"
msgstr "ÐбÑаÑÐ½Ð°Ñ ÑазвеÑÑка завеÑÑена"
@@ -5930,17 +3487,17 @@
msgid "Name of incidence or density file."
msgstr "ÐÐ¼Ñ Ñайла наклона или плоÑноÑÑи."
-#: ../raster/r.sum/main.c:74 ../raster/r.walk/main.c:682
-#: ../raster/r.walk/main.c:744 ../raster/wildfire/r.spread/main.c:514
+#: ../raster/r.sum/main.c:74 ../raster/r.walk/main.c:722
+#: ../raster/r.walk/main.c:784 ../raster/wildfire/r.spread/main.c:514
#, c-format
msgid "Reading %s..."
msgstr "ЧÑение %s ..."
-#: ../raster/r.sun/main.c:176
+#: ../raster/r.sun/main.c:176 ../raster/r.sun2/main.c:227
msgid "Solar irradiance and irradiation model."
msgstr "ÐÐ¾Ð´ÐµÐ»Ñ ÑолнеÑной оÑвеÑенноÑÑи и иÑÑадиаÑии (ÑаÑпÑоÑÑÑанениÑ)."
-#: ../raster/r.sun/main.c:178
+#: ../raster/r.sun/main.c:178 ../raster/r.sun2/main.c:229
msgid ""
"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
"for given day, latitude, surface and atmospheric conditions. Solar "
@@ -5958,7 +3515,7 @@
"вÑÑиÑлении Ñгла Ð¿Ð°Ð´ÐµÐ½Ð¸Ñ ÑолнеÑнÑÑ
лÑÑей и/или оÑвеÑенноÑÑи ÑаÑÑÑовÑÑ
Ñлоев. "
"ÐÑÑÐµÐºÑ Ð·Ð°ÑÐµÐ½ÐµÐ½Ð¸Ñ ÑопогÑаÑии подклÑÑаеÑÑÑ Ð¾Ð¿ÑионалÑно."
-#: ../raster/r.sun/main.c:208 ../raster/r.sun2/main.c:255
+#: ../raster/r.sun/main.c:208 ../raster/r.sun2/main.c:243
#: ../raster/r.horizon/main.c:226
msgid "Name of the input elevation raster map [meters]"
msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð²ÑÑÐ¾Ñ [меÑÑÑ]"
@@ -5987,19 +3544,19 @@
#: ../raster/simwe/r.sim.water/main.c:174
#: ../raster/simwe/r.sim.water/main.c:182
#: ../raster/simwe/r.sim.water/main.c:189
-#: ../raster/r.watershed/front/main.c:58 ../raster/r.watershed/front/main.c:66
-#: ../raster/r.watershed/front/main.c:74 ../raster/r.watershed/front/main.c:83
-#: ../raster/r.watershed/front/main.c:92
-#: ../raster/r.watershed/front/main.c:101
-#: ../raster/r.watershed/front/main.c:110 ../raster/r.sun2/main.c:256
-#: ../raster/r.sun2/main.c:264 ../raster/r.sun2/main.c:273
-#: ../raster/r.sun2/main.c:281 ../raster/r.sun2/main.c:289
-#: ../raster/r.sun2/main.c:298 ../raster/r.sun2/main.c:308
-#: ../raster/r.sun2/main.c:317 ../raster/r.sun2/main.c:326
-#: ../raster/r.sun2/main.c:335 ../raster/r.sun2/main.c:343
-#: ../raster/r.sun2/main.c:352 ../raster/r.sun2/main.c:361
-#: ../raster/r.sun2/main.c:370 ../raster/r.sun2/main.c:378
-#: ../raster/r.sun2/main.c:386 ../raster/r.horizon/main.c:227
+#: ../raster/r.watershed/front/main.c:62 ../raster/r.watershed/front/main.c:71
+#: ../raster/r.watershed/front/main.c:79 ../raster/r.watershed/front/main.c:88
+#: ../raster/r.watershed/front/main.c:99
+#: ../raster/r.watershed/front/main.c:107
+#: ../raster/r.watershed/front/main.c:115 ../raster/r.sun2/main.c:244
+#: ../raster/r.sun2/main.c:253 ../raster/r.sun2/main.c:262
+#: ../raster/r.sun2/main.c:271 ../raster/r.sun2/main.c:279
+#: ../raster/r.sun2/main.c:288 ../raster/r.sun2/main.c:298
+#: ../raster/r.sun2/main.c:308 ../raster/r.sun2/main.c:318
+#: ../raster/r.sun2/main.c:328 ../raster/r.sun2/main.c:337
+#: ../raster/r.sun2/main.c:347 ../raster/r.sun2/main.c:356
+#: ../raster/r.sun2/main.c:365 ../raster/r.sun2/main.c:373
+#: ../raster/r.sun2/main.c:381 ../raster/r.horizon/main.c:227
#: ../raster/r.horizon/main.c:236 ../raster/r.horizon/main.c:244
#: ../raster/r.horizon/main.c:252 ../raster/r.horizon/main.c:260
#: ../raster/r.horizon/main.c:268 ../raster/r.horizon/main.c:276
@@ -6007,7 +3564,7 @@
msgid "Input_options"
msgstr "Input_options"
-#: ../raster/r.sun/main.c:217 ../raster/r.sun2/main.c:263
+#: ../raster/r.sun/main.c:217 ../raster/r.sun2/main.c:252
msgid ""
"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
"[decimal degrees]"
@@ -6015,7 +3572,7 @@
"ÐÐ¼Ñ Ð¸ÑÑ
одного ÑÐ»Ð¾Ñ ÑкÑпозиÑий (ÑкÑпозиÑÐ¸Ñ ÑелÑеÑа или азимÑÑ Ð½Ð° ÑолнÑе) "
"[деÑÑÑиÑнÑе доли гÑадÑÑов]"
-#: ../raster/r.sun/main.c:227 ../raster/r.sun2/main.c:280
+#: ../raster/r.sun/main.c:227 ../raster/r.sun2/main.c:270
msgid ""
"Name of the input slope raster map (terrain slope or solar panel "
"inclination) [decimal degrees]"
@@ -6023,29 +3580,29 @@
"ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ ÐºÑÑÑÐ¸Ð·Ð½Ñ (кÑÑÑизна Ñклона или ÑолнеÑнÑй Ñгол) "
"[деÑÑÑиÑнÑе доли гÑадÑÑа]"
-#: ../raster/r.sun/main.c:236 ../raster/r.sun2/main.c:297
+#: ../raster/r.sun/main.c:236 ../raster/r.sun2/main.c:287
msgid ""
"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
msgstr ""
"ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ ÐºÐ¾ÑÑÑиÑиенÑа Linke непÑозÑаÑноÑÑи аÑмоÑÑеÑÑ [-]"
-#: ../raster/r.sun/main.c:247 ../raster/r.sun2/main.c:307
+#: ../raster/r.sun/main.c:247 ../raster/r.sun2/main.c:297
msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
msgstr "Ðдиное знаÑение коÑÑÑиÑиенÑа Linke непÑозÑаÑноÑÑи аÑмоÑÑеÑÑ [-]"
-#: ../raster/r.sun/main.c:256 ../raster/r.sun2/main.c:316
+#: ../raster/r.sun/main.c:256 ../raster/r.sun2/main.c:307
msgid "Name of the ground albedo coefficient input raster map [-]"
msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ ÐºÐ¾ÑÑÑиÑиенÑа алÑбедо [-]"
-#: ../raster/r.sun/main.c:267 ../raster/r.sun2/main.c:325
+#: ../raster/r.sun/main.c:267 ../raster/r.sun2/main.c:317
msgid "A single value of the ground albedo coefficient [-]"
msgstr "Ðдиное знаÑение коÑÑÑиÑиенÑа алÑбедо земной повеÑÑ
ноÑÑи [-]"
-#: ../raster/r.sun/main.c:276 ../raster/r.sun2/main.c:334
+#: ../raster/r.sun/main.c:276 ../raster/r.sun2/main.c:327
msgid "Name of the latitudes input raster map [decimal degrees]"
msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ ÑиÑÐ¾Ñ [деÑÑÑиÑнÑе доли гÑадÑÑа]"
-#: ../raster/r.sun/main.c:286 ../raster/r.sun2/main.c:342
+#: ../raster/r.sun/main.c:286 ../raster/r.sun2/main.c:336
msgid "A single value of latitude [decimal degrees]"
msgstr "Ðдиное знаÑение ÑиÑоÑÑ [деÑÑÑиÑнÑе доли гÑадÑÑа]"
@@ -6061,7 +3618,7 @@
"ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ ÐºÐ¾ÑÑÑиÑиенÑа ÑакÑиÑеÑкого небеÑного ÑаÑÑеÑнного "
"излÑÑÐµÐ½Ð¸Ñ [-]"
-#: ../raster/r.sun/main.c:313 ../raster/r.sun2/main.c:392
+#: ../raster/r.sun/main.c:313 ../raster/r.sun2/main.c:389
msgid "Output incidence angle raster map (mode 1 only)"
msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой Ñгла Ð¿Ð°Ð´ÐµÐ½Ð¸Ñ (ÑолÑко меÑод 1)"
@@ -6074,32 +3631,30 @@
#: ../raster/simwe/r.sim.sediment/main.c:208
#: ../raster/simwe/r.sim.water/main.c:204
#: ../raster/simwe/r.sim.water/main.c:210
-#: ../raster/simwe/r.sim.water/main.c:216 ../raster/r.resamp.rst/main.c:194
-#: ../raster/r.resamp.rst/main.c:202 ../raster/r.resamp.rst/main.c:210
-#: ../raster/r.resamp.rst/main.c:218 ../raster/r.resamp.rst/main.c:226
-#: ../raster/r.resamp.rst/main.c:290 ../raster/r.watershed/front/main.c:119
-#: ../raster/r.watershed/front/main.c:127
-#: ../raster/r.watershed/front/main.c:136
-#: ../raster/r.watershed/front/main.c:144
-#: ../raster/r.watershed/front/main.c:153
-#: ../raster/r.watershed/front/main.c:162
-#: ../raster/r.watershed/front/main.c:171
-#: ../raster/r.watershed/front/main.c:179 ../raster/r.sun2/main.c:393
-#: ../raster/r.sun2/main.c:401 ../raster/r.sun2/main.c:408
-#: ../raster/r.sun2/main.c:416 ../raster/r.sun2/main.c:424
-#: ../raster/r.sun2/main.c:432 ../raster/r.horizon/main.c:301
+#: ../raster/simwe/r.sim.water/main.c:216 ../raster/r.resamp.rst/main.c:182
+#: ../raster/r.resamp.rst/main.c:190 ../raster/r.resamp.rst/main.c:198
+#: ../raster/r.resamp.rst/main.c:206 ../raster/r.resamp.rst/main.c:214
+#: ../raster/r.resamp.rst/main.c:222 ../raster/r.resamp.rst/main.c:286
+#: ../raster/r.watershed/front/main.c:124
+#: ../raster/r.watershed/front/main.c:132
+#: ../raster/r.watershed/front/main.c:141
+#: ../raster/r.watershed/front/main.c:149
+#: ../raster/r.watershed/front/main.c:158
+#: ../raster/r.watershed/front/main.c:167
+#: ../raster/r.watershed/front/main.c:176
+#: ../raster/r.watershed/front/main.c:184 ../raster/r.sun2/main.c:390
+#: ../raster/r.sun2/main.c:399 ../raster/r.sun2/main.c:408
+#: ../raster/r.sun2/main.c:417 ../raster/r.sun2/main.c:426
+#: ../raster/r.sun2/main.c:435 ../raster/r.horizon/main.c:301
#: ../raster/r.horizon/main.c:311 ../raster/r.horizon/main.c:319
-#: ../vector/v.vol.rst/main.c:353 ../vector/v.vol.rst/main.c:370
-#: ../vector/v.vol.rst/main.c:380 ../vector/v.vol.rst/main.c:389
-#: ../vector/v.vol.rst/main.c:398 ../vector/v.vol.rst/main.c:407
-#: ../vector/v.vol.rst/main.c:416 ../vector/v.surf.rst/main.c:200
-#: ../vector/v.surf.rst/main.c:227 ../vector/v.surf.rst/main.c:233
-#: ../vector/v.surf.rst/main.c:239 ../vector/v.surf.rst/main.c:245
-#: ../vector/v.surf.rst/main.c:251
+#: ../vector/v.vol.rst/main.c:362 ../vector/v.vol.rst/main.c:379
+#: ../vector/v.vol.rst/main.c:389 ../vector/v.vol.rst/main.c:398
+#: ../vector/v.vol.rst/main.c:407 ../vector/v.vol.rst/main.c:416
+#: ../vector/v.vol.rst/main.c:425
msgid "Output_options"
msgstr "Output_options"
-#: ../raster/r.sun/main.c:322 ../raster/r.sun2/main.c:400
+#: ../raster/r.sun/main.c:322 ../raster/r.sun2/main.c:398
msgid ""
"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
"day-1] (mode 2)"
@@ -6111,7 +3666,7 @@
msgid "Output insolation time raster map [h] (mode 2 only)"
msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой вÑемени инÑолÑÑии [Ñ] (ÑолÑко меÑод 2)"
-#: ../raster/r.sun/main.c:340 ../raster/r.sun2/main.c:415
+#: ../raster/r.sun/main.c:340 ../raster/r.sun2/main.c:416
msgid ""
"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
"day-1] (mode 2)"
@@ -6119,7 +3674,7 @@
"ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой ÑаÑÑеÑнной оÑвеÑенноÑÑи [W.m-2] (меÑод 1) или "
"иÑÑадиаÑии [Wh.m-2.day-1] (меÑод 2)"
-#: ../raster/r.sun/main.c:349 ../raster/r.sun2/main.c:423
+#: ../raster/r.sun/main.c:349 ../raster/r.sun2/main.c:425
msgid ""
"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
"map [Wh.m-2.day-1] (mode 2)"
@@ -6127,32 +3682,32 @@
"ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой оÑÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð¾ÑвеÑÐµÐ½Ð¸Ñ Ð·ÐµÐ¼Ð½Ð¾Ð¹ повеÑÑ
ноÑÑÑÑ [W.m-2] "
"(меÑод 1) или иÑÑадиаÑии [Wh.m-2.day-1] (меÑод 2)"
-#: ../raster/r.sun/main.c:356 ../raster/r.sun2/main.c:439
+#: ../raster/r.sun/main.c:356 ../raster/r.sun2/main.c:442
msgid "No. of day of the year (1-365)"
msgstr "ÐÐ¾Ð¼ÐµÑ Ð´Ð½Ñ Ð² Ð³Ð¾Ð´Ñ (1-365)"
-#: ../raster/r.sun/main.c:364 ../raster/r.sun2/main.c:446
+#: ../raster/r.sun/main.c:364 ../raster/r.sun2/main.c:450
msgid "Time step when computing all-day radiation sums [decimal hours]"
msgstr ""
"ÐÑеменной инÑеÑвал Ð´Ð»Ñ ÐºÐ¾ÑоÑого вÑÑиÑлÑеÑÑÑ ÑÑммаÑÐ½Ð°Ñ Ð´Ð½ÐµÐ²Ð½Ð°Ñ Ð¾ÑвеÑенноÑÑÑ "
"[деÑÑÑиÑнÑе доли ÑаÑов]"
-#: ../raster/r.sun/main.c:371 ../raster/r.sun2/main.c:453
+#: ../raster/r.sun/main.c:371 ../raster/r.sun2/main.c:457
msgid "Declination value (overriding the internally computed value) [radians]"
msgstr ""
"ÐнаÑение наклона (пеÑезапиÑаÑÑ Ð²Ð½ÑÑÑеннее вÑÑиÑлÑемое знаÑение) [ÑадианÑ]"
-#: ../raster/r.sun/main.c:379 ../raster/r.sun2/main.c:460
+#: ../raster/r.sun/main.c:379 ../raster/r.sun2/main.c:465
msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
msgstr ""
"ÐокалÑное (ÑолнеÑное) вÑÐµÐ¼Ñ (ÑÑÑанавливаеÑÑÑ ÑолÑко Ð´Ð»Ñ 1 меÑода) "
-#: ../raster/r.sun/main.c:384 ../raster/r.sun2/main.c:502
+#: ../raster/r.sun/main.c:384 ../raster/r.sun2/main.c:508
msgid "Incorporate the shadowing effect of terrain"
msgstr "ÐклÑÑение ÑÑÑекÑа заÑÐµÐ½ÐµÐ½Ð¸Ñ Ð¼ÐµÑÑноÑÑи "
-#: ../raster/r.sun/main.c:410 ../raster/r.sun2/main.c:571
+#: ../raster/r.sun/main.c:410 ../raster/r.sun2/main.c:592
msgid "insol_time and incidout are incompatible options"
msgstr "insol_time и incidout ÑвлÑÑÑÑÑ Ð½ÐµÑовмеÑÑимÑми опÑиÑми"
@@ -6168,15 +3723,15 @@
"ÐеÑод 1: ÑаÑÑÐµÑ Ñгла Ð¿Ð°Ð´ÐµÐ½Ð¸Ñ ÑолнеÑнÑÑ
лÑÑей и оÑвеÑенноÑÑи Ð´Ð»Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ð¾Ð³Ð¾ "
"локалÑного вÑемени"
-#: ../raster/r.sun/main.c:424
+#: ../raster/r.sun/main.c:424 ../raster/r.sun2/main.c:623
msgid "incidout requires time parameter to be set"
msgstr "incidout ÑÑебÑÐµÑ ÑÑÑановленного паÑамеÑÑа вÑемени"
-#: ../raster/r.sun/main.c:425
+#: ../raster/r.sun/main.c:425 ../raster/r.sun2/main.c:624
msgid "Mode 2: integrated daily irradiation for a given day of the year"
msgstr "ÐеÑод 2: обÑÐ°Ñ Ð´Ð½ÐµÐ²Ð½Ð°Ñ Ð¸ÑÑадиаÑÐ¸Ñ Ð´Ð»Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ð¾Ð³Ð¾ Ð´Ð½Ñ Ð³Ð¾Ð´Ð°"
-#: ../raster/r.sun/main.c:474 ../raster/r.sun2/main.c:720
+#: ../raster/r.sun/main.c:474 ../raster/r.sun2/main.c:740
#: ../raster/r.horizon/main.c:481
msgid ""
"Can't get projection info of current location: please set latitude via 'lat' "
@@ -6185,14 +3740,14 @@
"Ðевозможно полÑÑиÑÑ Ð´Ð°Ð½Ð½Ñе пÑоекÑии ÑекÑÑей облаÑÑи: пожалÑйÑÑа ÑÑÑановиÑе "
"ÑиÑоÑÑ ÑеÑез опÑÐ¸Ñ 'lat' или 'latin'!"
-#: ../raster/r.sun/main.c:477 ../raster/r.sun2/main.c:723
+#: ../raster/r.sun/main.c:477 ../raster/r.sun2/main.c:743
#: ../raster/r.horizon/main.c:484 ../display/d.where/main.c:96
#: ../general/g.region/printwindow.c:251 ../general/g.region/printwindow.c:492
#: ../general/g.region/printwindow.c:611
msgid "Can't get projection units of current location"
msgstr "Ðевозможно полÑÑиÑÑ ÐµÐ´Ð¸Ð½Ð¸ÑÑ Ð¿ÑоекÑии Ð´Ð»Ñ ÑекÑÑей облаÑÑи"
-#: ../raster/r.sun/main.c:481 ../raster/r.sun2/main.c:726
+#: ../raster/r.sun/main.c:481 ../raster/r.sun2/main.c:746
#: ../raster/r.horizon/main.c:488 ../ps/ps.map/do_geogrid.c:272
#: ../display/d.where/main.c:99 ../display/d.grid/plot.c:294
#: ../general/g.region/printwindow.c:254 ../general/g.region/printwindow.c:495
@@ -6200,7 +3755,7 @@
msgid "Can't get projection key values of current location"
msgstr "Ðевозможно полÑÑиÑÑ Ð·Ð½Ð°Ñение паÑамеÑÑов пÑоекÑии Ð´Ð»Ñ ÑекÑÑей облаÑÑи"
-#: ../raster/r.sun/main.c:491 ../raster/r.sun2/main.c:736
+#: ../raster/r.sun/main.c:491 ../raster/r.sun2/main.c:756
#: ../raster/r.horizon/main.c:498 ../ps/ps.map/do_geogrid.c:278
#: ../display/d.where/main.c:106 ../display/d.where/main.c:132
#: ../display/d.grid/plot.c:301 ../display/d.grid/plot.c:328
@@ -6329,14 +3884,12 @@
msgstr "ÐаннÑе или Ñайл гÑÑпп не оÑкÑÑÑ"
#: ../raster/r.null/null.c:58
-#, fuzzy
msgid "raster, null data"
-msgstr "ÑаÑÑÑ, меÑаданнÑе"
+msgstr "ÑаÑÑÑ, null даннÑе"
#: ../raster/r.null/null.c:59
-#, fuzzy
msgid "Manages NULL-values of given raster map."
-msgstr "ÐÐ°Ð±Ð¾Ñ Ð´Ð»Ñ Ð¸ÑÑ
+msgstr "УпÑавление NULL-знаÑениÑми заданного ÑаÑÑÑового ÑлоÑ."
#: ../raster/r.null/null.c:62
msgid "Raster map for which to edit null file"
@@ -6370,64 +3923,64 @@
msgstr ""
#: ../raster/r.null/null.c:123
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> is not in your mapset <%s>"
-msgstr "РаÑÑÑовÑй Ñлой <%s> не найден в ÑекÑÑем набоÑе"
+msgstr "РаÑÑÑовÑй Ñлой <%s> не найден в ÑекÑÑем набоÑе <%s>"
#: ../raster/r.null/null.c:130
-#, fuzzy, c-format
+#, c-format
msgid "%s is illegal entry for null"
-msgstr "ÐедопÑÑÑимое знаÑение Ð´Ð»Ñ null"
+msgstr "%s - недопÑÑÑимое знаÑение Ð´Ð»Ñ null"
#: ../raster/r.null/null.c:137
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> already has a null bitmap file"
-msgstr "РаÑÑÑовÑй Ñлой <%s> Ñже ÑÑÑеÑÑвÑÐµÑ Ð¸ бÑÐ´ÐµÑ Ð¿ÐµÑезапиÑан"
+msgstr "РаÑÑÑовÑй Ñлой <%s> Ñже Ð¸Ð¼ÐµÐµÑ Ð±Ð¸ÑмÑп"
#: ../raster/r.null/null.c:141
-#, fuzzy, c-format
+#, c-format
msgid "<%s> is integer raster map (CELL)"
-msgstr " "
+msgstr "<%s> ÑелоÑиÑленное знаÑение ÑаÑÑÑа (CELL)"
#: ../raster/r.null/null.c:145
#, c-format
msgid "<%s> is integer raster map (CELL). Using null=%d."
-msgstr ""
+msgstr "<%s> ÑелоÑиÑленное знаÑение ÑаÑÑÑа (CELL). ÐÑполÑзÑеÑÑÑ null=%d."
#: ../raster/r.null/null.c:151
-#, fuzzy, c-format
+#, c-format
msgid "<%s> is floating pointing raster map"
-msgstr "ÐаÑало ÑоÑеÑного ÑаÑÑÑового ÑлоÑ"
+msgstr "<%s> ÑаÑÑÑовÑй Ñлой Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей запÑÑой"
#: ../raster/r.null/null.c:169
-#, fuzzy, c-format
+#, c-format
msgid "Writing new null file for raster map <%s>..."
-msgstr "ÐапиÑÑ Ð½Ñлевого Ñайла Ð´Ð»Ñ [%s]... "
+msgstr "ÐапиÑÑ Ð½Ñлевого Ñайла Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>... "
#: ../raster/r.null/null.c:176
-#, fuzzy, c-format
+#, c-format
msgid "Error writing null row %d"
-msgstr "ÐÑибка запиÑи нÑлевой ÑÑÑоки [%d]."
+msgstr "ÐÑибка запиÑи нÑлевой ÑÑÑоки %d"
#: ../raster/r.null/null.c:181 ../raster/r.null/null.c:194
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> modified."
-msgstr "РаÑÑÑовÑй Ñлой <%s> не найден"
+msgstr "РаÑÑÑовÑй Ñлой <%s> изменен."
#: ../raster/r.null/null.c:188
-#, fuzzy, c-format
+#, c-format
msgid "Removing null file for raster map <%s>..."
-msgstr "УдалÑеÑÑÑ Ð½Ñлевой Ñайл Ð´Ð»Ñ [%s]...\n"
+msgstr "УдалÑеÑÑÑ Ð½Ñлевой Ñайл Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>..."
#: ../raster/r.null/null.c:258
-#, fuzzy, c-format
+#, c-format
msgid "%s: %s: illegal value spec"
-msgstr "%s: знаÑение не ÑооÑвеÑÑвÑÐµÑ ÑпеÑиÑикаÑии"
+msgstr "%s: %s: знаÑение не ÑооÑвеÑÑвÑÐµÑ ÑпеÑиÑикаÑии"
#: ../raster/r.null/null.c:327
-#, fuzzy, c-format
+#, c-format
msgid "Writing new data for raster map <%s>..."
-msgstr "ÐапиÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>..."
+msgstr "ÐапиÑÑ Ð½Ð¾Ð²ÑÑ
даннÑÑ
#: ../raster/r.average/main.c:53
msgid ""
@@ -6495,9 +4048,8 @@
msgstr "ÐеÑепиÑаÑÑ Ñлой заÑÑавки Ñлоем ÑезÑлÑÑаÑа (озеÑо)"
#: ../raster/r.lake/main.c:206
-#, fuzzy
msgid "Both seed map and coordinates cannot be specified"
-msgstr "Слой заÑÑавки и его кооÑдинаÑÑ Ð½Ðµ могÑÑ Ð±ÑÑÑ Ð·Ð°Ð´Ð°Ð½Ñ Ð¾Ð´Ð½Ð¾Ð²Ñеменно"
+msgstr "Слой заÑÑавки и кооÑдинаÑÑ Ð½Ðµ могÑÑ Ð±ÑÑÑ Ð·Ð°Ð´Ð°Ð½Ñ Ð¾Ð´Ð½Ð¾Ð²Ñеменно"
#: ../raster/r.lake/main.c:209
msgid "Seed map or seed coordinates must be set!"
@@ -6508,7 +4060,6 @@
msgstr "ÐÐ¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ ÑÐºÐ°Ð·Ð°Ð½Ñ ÐºÐ¾Ð¾ÑдинаÑÑ Ð·Ð°ÑÑавки и вÑÑ
одной Ñлой озеÑа!"
#: ../raster/r.lake/main.c:215
-#, fuzzy
msgid "Both lake and overwrite cannot be specified"
msgstr "ÐзеÑо и пеÑезапиÑÑ Ð½Ðµ могÑÑ Ð±ÑÑÑ Ð¾Ð¿ÑÐµÐ´ÐµÐ»ÐµÐ½Ñ Ð¾Ð´Ð½Ð¾Ð²Ñеменно"
@@ -6557,16 +4108,19 @@
msgid "Unable to read color file of raster map <%s>"
msgstr "Ðевозможно пÑоÑиÑаÑÑ ÑвеÑовой Ñайл Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
-#: ../raster/r.out.gdal/main.c:48
+#: ../raster/r.out.gdal/main.c:47
#, c-format
msgid "Supported formats:\n"
msgstr "ÐоддеÑживаемÑе ÑоÑмаÑÑ:\n"
#: ../raster/r.out.gdal/main.c:125
-#, fuzzy
msgid "Exports GRASS raster maps into GDAL supported formats."
msgstr "ÐкÑпоÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ GRASS в ÑоÑмаÑÑ Ð¿Ð¾Ð´Ð´ÐµÑживаемÑе GDAL."
+#: ../raster/r.out.gdal/main.c:130
+msgid "List supported output formats"
+msgstr "ÐеÑеÑиÑлиÑÑ Ð¿Ð¾Ð´Ð´ÐµÑживаемÑе вÑÑ
однÑе ÑоÑмаÑÑ"
#: ../raster/r.out.gdal/main.c:131 ../raster/r.in.gdal/main.c:135
#: ../raster/r.stats/main.c:149 ../raster/r.stats/main.c:154
#: ../raster/r.stats/main.c:159 ../raster/r.stats/main.c:165
@@ -6575,8 +4129,8 @@
#: ../raster/r.external/main.c:555 ../vector/v.info/main.c:76
#: ../vector/v.info/main.c:82 ../vector/v.info/main.c:87
#: ../vector/v.info/main.c:92 ../vector/v.info/main.c:97
-#: ../vector/v.to.db/parse.c:103 ../vector/v.to.db/parse.c:108
-#: ../vector/v.to.db/parse.c:114 ../imagery/i.group/main.c:78
+#: ../vector/v.to.db/parse.c:104 ../vector/v.to.db/parse.c:109
+#: ../vector/v.to.db/parse.c:115 ../imagery/i.group/main.c:78
#: ../imagery/i.group/main.c:84 ../general/g.region/main.c:87
#: ../general/g.region/main.c:93 ../general/g.region/main.c:98
#: ../general/g.region/main.c:104 ../general/g.region/main.c:110
@@ -6587,18 +4141,26 @@
#: ../raster/r.out.gdal/main.c:135
#, fuzzy
-msgid "Do not export long colortable"
-msgstr "УдалиÑÑ ÑÑÑеÑÑвÑÑÑÑÑ ÑвеÑовÑÑ ÑаблиÑÑ"
+msgid "Do not write GDAL standard colortable"
+msgstr "Ðе ÑкÑпоÑÑиÑоваÑÑ Ð´Ð»Ð¸Ð½Ð½ÑÑ ÑвеÑовÑÑ ÑаблиÑÑ"
#: ../raster/r.out.gdal/main.c:136
msgid "Only applicable to Byte or UInt16 data types."
-msgstr ""
+msgstr "ÐÑименÑемо ÑолÑко Ð´Ð»Ñ Ñипов даннÑÑ
Byte или UInt16."
#: ../raster/r.out.gdal/main.c:140
+msgid "Force raster export also if data loss may occur"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:141
+msgid "Overrides saftey checks."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:145
msgid "Name of raster map (or group) to export"
msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ (или гÑÑппÑ) Ð´Ð»Ñ ÑкÑпоÑÑа"
-#: ../raster/r.out.gdal/main.c:141 ../raster/r.out.gdal/main.c:177
+#: ../raster/r.out.gdal/main.c:146 ../raster/r.out.gdal/main.c:182
#: ../raster/r.in.gdal/main.c:90 ../raster/r.in.gdal/main.c:94
#: ../raster/r.colors/main.c:171 ../raster/r.external/main.c:512
#: ../raster/r.external/main.c:522 ../vector/v.in.ascii/in.c:57
@@ -6606,46 +4168,58 @@
msgid "Required"
msgstr "ÐеобÑ
одимо"
-#: ../raster/r.out.gdal/main.c:176
+#: ../raster/r.out.gdal/main.c:152
+msgid "GIS format to write (case sensitive, see also -l flag)"
+msgstr "GIS ÑоÑÐ¼Ð°Ñ Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи (ÑегиÑÑÑозавиÑимÑй, Ñм. Ñакже паÑамеÑÑ -l)"
+#: ../raster/r.out.gdal/main.c:173
+msgid "File type"
+msgstr "Тип Ñайла"
+#: ../raster/r.out.gdal/main.c:181
msgid "Name for output raster file"
msgstr "ÐÐ¼Ñ Ð´Ð»Ñ Ð²ÑÑ
одного ÑаÑÑÑового Ñайла"
-#: ../raster/r.out.gdal/main.c:183
-#, fuzzy
+#: ../raster/r.out.gdal/main.c:188
msgid "Creation option(s) to pass to the output format driver"
-msgstr ""
-"ÐпÑии ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð´Ð»Ñ Ð´ÑайвеÑа вÑÑ
одного ÑоÑмаÑа. Ðозможно неÑколÑко опÑий"
+msgstr "ÐпÑии ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð´Ð»Ñ Ð´ÑайвеÑа вÑÑ
одного ÑоÑмаÑа"
-#: ../raster/r.out.gdal/main.c:192
+#: ../raster/r.out.gdal/main.c:190
+msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma."
+msgstr "ФоÑÐ¼Ð°Ñ \"NAME=VALUE\", ÑазделиÑÐµÐ»Ñ - запÑÑаÑ."
+#: ../raster/r.out.gdal/main.c:197
msgid "Metadata key(s) and value(s) to include"
-msgstr ""
+msgstr "ÐлÑÑ(и) меÑаданнÑÑ
и вклÑÑаемÑе знаÑениÑ"
-#: ../raster/r.out.gdal/main.c:194
+#: ../raster/r.out.gdal/main.c:199
msgid ""
"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
"Not supported by all output format drivers."
msgstr ""
+"ФоÑÐ¼Ð°Ñ \"META-TAG=VALUE\", ÑазделиÑÐµÐ»Ñ Ð·Ð½Ð°Ñений - запÑÑаÑ. ÐоддеÑживаеÑÑÑ Ð½Ðµ "
+"вÑеми дÑайвеÑами вÑÑ
однÑÑ
ÑоÑмаÑов."
-#: ../raster/r.out.gdal/main.c:203
+#: ../raster/r.out.gdal/main.c:208
msgid "Assign a specified nodata value to output bands"
msgstr "ÐазнаÑиÑÑ Ñказанное знаÑение nodata Ð´Ð»Ñ Ð²ÑÑ
однÑÑ
каналов"
-#: ../raster/r.out.gdal/main.c:236
+#: ../raster/r.out.gdal/main.c:241
#, c-format
msgid "Raster map or group <%s> not found"
msgstr "РаÑÑÑовÑй Ñлой или гÑÑппа <%s> не найденÑ"
-#: ../raster/r.out.gdal/main.c:240
+#: ../raster/r.out.gdal/main.c:245
#, c-format
msgid "No raster maps in group <%s>"
msgstr "ÐÐµÑ ÑаÑÑÑовÑÑ
Ñлоев в гÑÑппе <%s>"
-#: ../raster/r.out.gdal/main.c:254
+#: ../raster/r.out.gdal/main.c:259
#, c-format
msgid "Unable to get <%s> driver"
msgstr "Ðевозможно полÑÑиÑÑ Ð´ÑÐ°Ð¹Ð²ÐµÑ <%s>"
-#: ../raster/r.out.gdal/main.c:260
+#: ../raster/r.out.gdal/main.c:265
#, c-format
msgid ""
"Driver <%s> does not support direct writing. Using MEM driver for "
@@ -6654,93 +4228,178 @@
"ÐÑÐ°Ð¹Ð²ÐµÑ <%s> не поддеÑÐ¶Ð¸Ð²Ð°ÐµÑ Ð¿ÑÑмÑÑ Ð·Ð°Ð¿Ð¸ÑÑ. ÐÑполÑзÑйÑе MEM дÑÐ°Ð¹Ð²ÐµÑ Ð´Ð»Ñ "
"пÑомежÑÑоÑного набоÑа даннÑÑ
-#: ../raster/r.out.gdal/main.c:265
+#: ../raster/r.out.gdal/main.c:270
msgid "Unable to get in-memory raster driver"
msgstr "Ðевозможно полÑÑиÑÑ Ð´ÑÐ°Ð¹Ð²ÐµÑ ÑаÑÑÑа из опеÑаÑивной памÑÑи"
-#: ../raster/r.out.gdal/main.c:269
+#: ../raster/r.out.gdal/main.c:274
#, c-format
msgid "Driver <%s> does not support creating rasters"
msgstr "ÐÑайвеÑ<%s> не поддеÑÐ¶Ð¸Ð²Ð°ÐµÑ Ñоздание ÑаÑÑÑов"
-#: ../raster/r.out.gdal/main.c:399
+#: ../raster/r.out.gdal/main.c:407 ../raster/r.out.gdal/main.c:504
+#: ../raster/r.out.gdal/main.c:521
+#, fuzzy
+msgid "Forcing raster export."
+#: ../raster/r.out.gdal/main.c:409 ../raster/r.out.gdal/main.c:506
+#: ../raster/r.out.gdal/main.c:523
+#, fuzzy
+msgid "Raster export aborted."
+msgstr "ÐмпоÑÑиÑÑемÑй ÑаÑÑÑовÑй Ñайл"
+#: ../raster/r.out.gdal/main.c:417
#, c-format
msgid "Exporting to GDAL data type: %s"
msgstr "ÐкÑпоÑÑ Ð² Ñип даннÑÑ
GDAL: %s"
-#: ../raster/r.out.gdal/main.c:419
+#: ../raster/r.out.gdal/main.c:437
msgid "Output file name not specified"
msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного Ñайла не задано"
-#: ../raster/r.out.gdal/main.c:425
+#: ../raster/r.out.gdal/main.c:443
msgid "Unable to create dataset using memory raster driver"
msgstr "Ðевозможно ÑоздаÑÑ Ð½Ð°Ð±Ð¾Ñ Ð´Ð°Ð½Ð½ÑÑ
иÑполÑзÑÑ Ð´ÑÐ°Ð¹Ð²ÐµÑ ÑаÑÑÑа"
-#: ../raster/r.out.gdal/main.c:434
+#: ../raster/r.out.gdal/main.c:452
#, c-format
msgid "Unable to create <%s> dataset using <%s> driver"
<%s> , иÑполÑзÑÑ Ð´ÑÐ°Ð¹Ð²ÐµÑ <%s>"
-#: ../raster/r.out.gdal/main.c:449
+#: ../raster/r.out.gdal/main.c:467
msgid "Unable to set geo transform"
msgstr "Ðевозможно ÑÑÑановиÑÑ Ð¿Ð°ÑамеÑÑÑ ÑÑанÑÑоÑмаÑии"
-#: ../raster/r.out.gdal/main.c:457
+#: ../raster/r.out.gdal/main.c:475
msgid "Unable to set projection"
msgstr "Ðевозможно ÑÑÑановиÑÑ Ð¿ÑоекÑиÑ"
-#: ../raster/r.out.gdal/main.c:467
+#: ../raster/r.out.gdal/main.c:485
#, c-format
msgid "Exporting raster map <%s> (band %d)..."
msgstr "ÐкÑпоÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s> (band %d)..."
-#: ../raster/r.out.gdal/main.c:476
+#: ../raster/r.out.gdal/main.c:516
#, c-format
msgid "Unable to export raster map <%s>"
msgstr "Ðевозможно ÑкÑпоÑÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой <%s>"
-#: ../raster/r.out.gdal/main.c:486
+#: ../raster/r.out.gdal/main.c:533
#, c-format
msgid "Unable to create raster map <%s> using driver <%s>"
msgstr "Ðевозможно ÑоздаÑÑ ÑаÑÑÑовÑй Ñлой <%s> , иÑполÑзÑÑÑ Ð´ÑÐ°Ð¹Ð²ÐµÑ <%s>"
-#: ../raster/r.out.gdal/export_band.c:53
+#: ../raster/r.out.gdal/main.c:556 ../raster/r.out.gdal/main.c:568
+#: ../raster/r.out.gdal/main.c:581 ../raster/r.out.gdal/main.c:594
+#: ../raster/r.out.gdal/main.c:606 ../raster/r.out.gdal/main.c:619
+#: ../raster/r.out.gdal/main.c:633
+msgid "Selected GDAL datatype does not cover data range."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:557 ../raster/r.out.gdal/main.c:569
+#: ../raster/r.out.gdal/main.c:582 ../raster/r.out.gdal/main.c:595
+#: ../raster/r.out.gdal/main.c:657 ../raster/r.out.gdal/main.c:669
+#: ../raster/r.out.gdal/main.c:682 ../raster/r.out.gdal/main.c:695
+#, c-format
+msgid "GDAL datatype: %s, range: %d - %d"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:560 ../raster/r.out.gdal/main.c:572
+#: ../raster/r.out.gdal/main.c:585 ../raster/r.out.gdal/main.c:598
+#: ../raster/r.out.gdal/main.c:610 ../raster/r.out.gdal/main.c:623
+#: ../raster/r.out.gdal/main.c:637
+#, fuzzy, c-format
+msgid "Raster map <%s> range: %g - %g"
+#: ../raster/r.out.gdal/main.c:607 ../raster/r.out.gdal/main.c:707
+#, c-format
+msgid "GDAL datatype: %s, range: %u - %u"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:620 ../raster/r.out.gdal/main.c:634
+#: ../raster/r.out.gdal/main.c:720 ../raster/r.out.gdal/main.c:734
+#, c-format
+msgid "GDAL datatype: %s, range: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:655 ../raster/r.out.gdal/main.c:667
+#: ../raster/r.out.gdal/main.c:680
+#, c-format
+msgid ""
+"Specified nodata value %d is not covered by range of selected GDAL datatype."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:693 ../raster/r.out.gdal/main.c:705
+#, c-format
+msgid ""
+"Specified nodata value %lld is not covered by range of selected GDAL "
+"datatype."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:718 ../raster/r.out.gdal/main.c:732
+#, c-format
+msgid ""
+"Specified nodata value %g is not covered by range of selected GDAL datatype."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:54
msgid "Unable to get raster band"
msgstr "Ðевозможно полÑÑиÑÑ ÐºÐ°Ð½Ð°Ð» ÑаÑÑÑа"
-#: ../raster/r.out.gdal/export_band.c:180
-#: ../raster/r.out.gdal/export_band.c:186
+#: ../raster/r.out.gdal/export_band.c:172
+#: ../raster/r.out.gdal/export_band.c:178
msgid "Unable to allocate buffer for reading raster map"
-#: ../raster/r.out.gdal/export_band.c:220
-#: ../raster/r.out.gdal/export_band.c:251
-#: ../raster/r.out.gdal/export_band.c:282
+#: ../raster/r.out.gdal/export_band.c:215
+#: ../raster/r.out.gdal/export_band.c:249
+#: ../raster/r.out.gdal/export_band.c:283
msgid "Unable to write GDAL raster file"
msgstr "Ðевозможна запиÑÑ ÑаÑÑÑового Ñайла GDAL"
-#: ../raster/r.out.gdal/export_band.c:291
+#: ../raster/r.out.gdal/export_band.c:292
#, fuzzy, c-format
msgid ""
"Input raster map contains cells with NULL-value (no-data). The value %d was "
-"used to represent no-data values in the input map. You can specify nodata "
-"value by %s parameter."
+"used to represent no-data values in the input map. You can specify a nodata "
+"value with the %s option."
msgstr ""
"ÐÑÑ
однÑй ÑаÑÑÑовÑй Ñлой Ñ ÑÑейками NULL-знаÑений (no-data). ÐнаÑение %d "
-"иÑполÑзовалоÑÑ Ð´Ð»Ñ Ð¾ÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð·Ð½Ð°Ñений no-data Ñ Ð¸ÑÑ
одного ÑлоÑ. ÐÑ Ð¼Ð¾Ð¶ÐµÑе "
+"иÑполÑзовалоÑÑ Ð´Ð»Ñ Ð¾ÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð·Ð½Ð°Ñений no-data иÑÑ
"задаÑÑ Ð·Ð½Ð°Ñение no-data ÑеÑез паÑамеÑÑ %s."
-#: ../raster/r.out.gdal/export_band.c:296
+#: ../raster/r.out.gdal/export_band.c:297
#, fuzzy, c-format
msgid ""
"Input raster map contains cells with NULL-value (no-data). The value %g was "
msgstr ""
"ÐÑÑ
однÑй ÑаÑÑÑовÑй Ñлой Ñ ÑÑейками NULL-знаÑений (no-data). ÐнаÑение %g "
+#: ../raster/r.out.gdal/export_band.c:305
+#, c-format
+msgid ""
+"The default nodata value is present in rasterband <%s> and would lead to "
+"data loss. Please specify a different nodata value with the %s parameter."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:311
+#, c-format
+msgid ""
+"The given nodata value is present in rasterband <%s> and would lead to data "
+"loss. Please specify a different nodata value with the %s parameter."
+msgstr ""
+#: ../raster/r.in.bin/main.c:122 ../raster/r.in.gdal/main.c:79
+#: ../raster/r.in.poly/main.c:29 ../raster/r.external/main.c:505
+msgid "raster, import"
+msgstr "ÑаÑÑÑ, импоÑÑ"
#: ../raster/r.in.bin/main.c:124
msgid "Import a binary raster file into a GRASS raster map layer."
msgstr "ÐмпоÑÑ Ð±Ð¸Ð½Ð°Ñного ÑаÑÑÑового Ñайла в ÑаÑÑÑовÑй Ñлой GRASS."
@@ -6761,9 +4420,9 @@
#: ../raster/r.in.bin/main.c:140 ../raster/r.in.bin/main.c:145
#: ../raster/r.in.bin/main.c:174 ../raster/r.in.bin/main.c:227
-#: ../raster/r.resamp.rst/main.c:234 ../raster/r.resamp.rst/main.c:242
-#: ../raster/r.resamp.rst/main.c:250 ../raster/r.resamp.rst/main.c:258
-#: ../raster/r.resamp.rst/main.c:266 ../raster/r.slope.aspect/main.c:184
+#: ../raster/r.resamp.rst/main.c:230 ../raster/r.resamp.rst/main.c:238
+#: ../raster/r.resamp.rst/main.c:246 ../raster/r.resamp.rst/main.c:254
+#: ../raster/r.resamp.rst/main.c:262 ../raster/r.slope.aspect/main.c:184
#: ../raster/r.slope.aspect/main.c:194 ../raster/r.slope.aspect/main.c:273
#: ../raster/r.slope.aspect/main.c:282 ../raster/r.slope.aspect/main.c:293
#: ../vector/lidar/v.lidar.edgedetection/main.c:87
@@ -6773,20 +4432,16 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:123
#: ../vector/lidar/v.lidar.edgedetection/main.c:131
#: ../vector/lidar/v.lidar.edgedetection/main.c:140
-#: ../vector/lidar/v.surf.bspline/main.c:111
-#: ../vector/lidar/v.surf.bspline/main.c:121
-#: ../vector/lidar/v.surf.bspline/main.c:131
-#: ../vector/lidar/v.surf.bspline/main.c:140
-#: ../vector/lidar/v.surf.bspline/main.c:147
-#: ../vector/lidar/v.surf.bspline/main.c:156 ../vector/v.vol.rst/main.c:261
+#: ../vector/lidar/v.surf.bspline/main.c:113
+#: ../vector/lidar/v.surf.bspline/main.c:123
+#: ../vector/lidar/v.surf.bspline/main.c:133
+#: ../vector/lidar/v.surf.bspline/main.c:142
+#: ../vector/lidar/v.surf.bspline/main.c:149
+#: ../vector/lidar/v.surf.bspline/main.c:159 ../vector/v.vol.rst/main.c:261
#: ../vector/v.vol.rst/main.c:269 ../vector/v.vol.rst/main.c:277
#: ../vector/v.vol.rst/main.c:310 ../vector/v.vol.rst/main.c:319
#: ../vector/v.vol.rst/main.c:328 ../vector/v.vol.rst/main.c:337
-#: ../vector/v.vol.rst/main.c:345 ../vector/v.surf.rst/main.c:194
-#: ../vector/v.surf.rst/main.c:264 ../vector/v.surf.rst/main.c:271
-#: ../vector/v.surf.rst/main.c:279 ../vector/v.surf.rst/main.c:287
-#: ../vector/v.surf.rst/main.c:296 ../vector/v.surf.rst/main.c:305
-#: ../vector/v.surf.rst/main.c:314 ../vector/v.surf.rst/main.c:323
+#: ../vector/v.vol.rst/main.c:346 ../vector/v.vol.rst/main.c:354
#: ../imagery/i.cluster/main.c:105 ../imagery/i.cluster/main.c:121
#: ../imagery/i.cluster/main.c:129 ../imagery/i.cluster/main.c:138
#: ../imagery/i.cluster/main.c:146 ../imagery/i.cluster/main.c:154
@@ -6993,7 +4648,7 @@
msgstr ""
"r.surf.idw2 не поддеÑÐ¶Ð¸Ð²Ð°ÐµÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
в Lat/long. ÐÑполÑзÑйÑе r.surf.idw!"
-#: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:135
+#: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:136
#, c-format
msgid "%s=%s - illegal number of interpolation points"
msgstr "%s=%s - невеÑное колиÑеÑÑво ÑоÑек инÑеÑполÑÑии"
@@ -7013,7 +4668,8 @@
msgstr "Ðевозможно полÑÑиÑÑ ÑÑÑокÑ"
#: ../raster/r.surf.idw2/read_cell.c:38 ../raster/r.surf.idw/main.c:685
-#: ../raster/r.colors/stats.c:41 ../raster/r.colors/stats.c:104
+#: ../raster/r.colors/stats.c:41 ../raster/r.colors/stats.c:107
+#: ../raster/r.cost/main.c:435 ../raster/r.cost/main.c:669
#: ../raster/r.series/main.c:195
#, c-format
msgid "Reading raster map <%s>..."
@@ -7035,9 +4691,9 @@
msgstr "ÐпÑеделение ÑÑанÑекÑÑ"
#: ../raster/r.transect/main.c:155
-#, fuzzy, c-format
+#, c-format
msgid "End coordinate: %.15g, %.15g"
-msgstr "ÐекоÑÑекÑнÑе кооÑдинаÑÑ %s %s"
+msgstr "ÐонеÑÐ½Ð°Ñ ÐºÐ¾Ð¾ÑдинаÑа: %.15g, %.15g"
#: ../raster/r.mode/main.c:52
msgid ""
@@ -7156,7 +4812,6 @@
msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой ÑÑозии-оÑÐ»Ð¾Ð¶ÐµÐ½Ð¸Ñ [кг/м2Ñ]"
#: ../raster/simwe/r.sim.sediment/main.c:214
-#, fuzzy
msgid "Number of walkers"
msgstr "ÐолиÑеÑÑво walkers"
@@ -7170,7 +4825,14 @@
#: ../raster/simwe/r.sim.water/main.c:268
#: ../raster/simwe/r.sim.water/main.c:277
#: ../raster/simwe/r.sim.water/main.c:285
-#: ../raster/simwe/r.sim.water/main.c:294
+#: ../raster/simwe/r.sim.water/main.c:294 ../vector/v.surf.rst/main.c:190
+#: ../vector/v.surf.rst/main.c:195 ../vector/v.surf.rst/main.c:284
+#: ../vector/v.surf.rst/main.c:292 ../vector/v.surf.rst/main.c:300
+#: ../vector/v.surf.rst/main.c:307 ../vector/v.surf.rst/main.c:315
+#: ../vector/v.surf.rst/main.c:323 ../vector/v.surf.rst/main.c:332
+#: ../vector/v.surf.rst/main.c:341 ../vector/v.surf.rst/main.c:350
+#: ../vector/v.surf.rst/main.c:359 ../vector/v.surf.rst/main.c:367
+#: ../vector/v.surf.rst/main.c:374
msgid "Parameters"
msgstr "ÐаÑамеÑÑÑ"
@@ -7207,13 +4869,12 @@
msgstr "ÐÑполÑзÑеÑÑÑ Ð¼ÐµÑÑиÑеÑкий ÑакÑÐ¾Ñ Ð¿ÐµÑеÑÑеÑа %f, step=%f"
#: ../raster/simwe/r.sim.sediment/main.c:355
-#, fuzzy
msgid "You are not outputting any raster or site files"
-msgstr "Ðе вÑводиÑÑÑ ÑаÑÑÑовÑÑ
Ñлоев или Ñайлов ÑайÑов."
+msgstr "Ðе вÑводиÑÑÑ ÑаÑÑÑовÑÑ
Ñлоев или Ñайлов ÑайÑов"
#: ../raster/simwe/r.sim.sediment/main.c:358
-#: ../raster/simwe/r.sim.water/main.c:480 ../vector/v.surf.rst/main.c:689
-#: ../vector/v.surf.rst/main.c:741
+#: ../raster/simwe/r.sim.water/main.c:480 ../vector/v.surf.rst/main.c:696
+#: ../vector/v.surf.rst/main.c:748
msgid "Input failed"
msgstr "Ðвод пÑеÑван"
@@ -7294,7 +4955,8 @@
msgstr "невозможно запиÑаÑÑ elt Ñайл"
#: ../raster/simwe/simlib/hydro.c:119
-msgid "nwalk > maxw!"
+#, fuzzy, c-format
+msgid "nwalk (%d) > maxw (%d)!"
msgstr "nwalk > maxw!"
#: ../raster/simwe/simlib/hydro.c:339
@@ -7348,7 +5010,6 @@
msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой оÑибки ÑимÑлÑÑии [м]"
#: ../raster/simwe/r.sim.water/main.c:232
-#, fuzzy
msgid "Number of walkers, default is twice the no. of cells"
msgstr "ЧиÑло walkers, по ÑмолÑÐ°Ð½Ð¸Ñ Ð´Ð²Ð°Ð¶Ð´Ñ ÑиÑло ÑÑеек"
@@ -7373,9 +5034,8 @@
msgstr "РезÑлÑÑÐ°Ñ Ð²ÑеменнÑÑ
ÑеÑий"
#: ../raster/simwe/r.sim.water/main.c:477
-#, fuzzy
msgid "You are not outputting any raster maps"
-msgstr "Ðе вÑводиÑÑÑ Ð½Ð¸ ÑаÑÑÑовÑÑ
, ни векÑоÑнÑÑ
Ñлоев"
+msgstr "Ðе вÑводиÑÑÑ Ð½Ð¸ ÑаÑÑÑовÑÑ
Ñлоев"
#: ../raster/r.out.mat/main.c:65
msgid "Exports a GRASS raster to a binary MAT-File."
@@ -7385,11 +5045,16 @@
msgid "Name for the output binary MAT-File"
msgstr "Ðазвание вÑÑ
одного бинаÑного Ñайла MAT "
-#: ../raster/r.out.mat/main.c:90 ../raster/r.cost/main.c:226
+#: ../raster/r.out.mat/main.c:81 ../raster/r.in.mat/main.c:115
+#: ../raster/r.out.tiff/r.out.tiff.c:136
+msgid "Verbose mode"
+msgstr "Режим ÑаÑÑиÑенной инÑоÑмаÑии"
+#: ../raster/r.out.mat/main.c:90 ../raster/r.cost/main.c:238
#: ../raster/r.in.mat/main.c:125 ../raster/r.out.tiff/r.out.tiff.c:144
#: ../raster/wildfire/r.ros/main.c:314 ../raster/wildfire/r.spread/main.c:255
-#: ../vector/v.kernel/main.c:191 ../display/d.vect/main.c:391
-#: ../display/d.mon/pgms/release.c:36
+#: ../vector/v.kernel/main.c:191 ../visualization/nviz/src/nviz_init.c:156
+#: ../display/d.vect/main.c:391 ../display/d.mon/pgms/release.c:36
msgid ""
"The '-v' flag is superseded and will be removed in future. Please use '--"
"verbose' instead."
@@ -7550,6 +5215,12 @@
msgid "%s: running %s command"
msgstr "%s: вÑполнÑеÑÑÑ ÐºÐ¾Ð¼Ð°Ð½Ð´Ð° %s"
+#: ../raster/r.statistics/main.c:42 ../raster/r.report/main.c:64
+#: ../raster/r.quantile/main.c:254 ../raster/r.stats/main.c:105
+#: ../raster/r.univar2/r.univar_main.c:75
+msgid "raster, statistics"
+msgstr "ÑаÑÑÑ, ÑÑаÑиÑÑика"
#: ../raster/r.statistics/main.c:44
msgid "Calculates category or object oriented statistics."
msgstr "РаÑÑÑиÑаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð¿Ð¾ каÑегоÑиÑм или обÑекÑам."
@@ -7943,12 +5614,10 @@
"Ñлага"
#: ../raster/r.surf.idw/main.c:69
-#, fuzzy
msgid "raster, interpolation"
-msgstr "векÑоÑ, инÑеÑполÑÑиÑ"
+msgstr "ÑаÑÑÑ, инÑеÑполÑÑиÑ"
#: ../raster/r.surf.idw/main.c:71
-#, fuzzy
msgid "Surface interpolation utility for raster map."
msgstr "УÑилиÑа инÑеÑполÑÑии повеÑÑ
ноÑÑи Ð´Ð»Ñ ÑаÑÑÑовÑÑ
Ñлоев."
@@ -7957,14 +5626,14 @@
msgstr "ÐÑвод - оÑибка инÑеÑполÑÑии"
#: ../raster/r.surf.idw/main.c:92
-#, fuzzy, c-format
+#, c-format
msgid "Illegal value for '%s' (%s)"
+msgstr "ÐедопÑÑÑимое знаÑение Ð´Ð»Ñ '%s' (%s)"
#: ../raster/r.surf.idw/main.c:233
-#, fuzzy, c-format
+#, c-format
msgid "Interpolating raster map <%s> (%d rows)... "
-msgstr "ÐнÑеÑполиÑование ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>... %d ÑÑÑок... "
+msgstr "ÐнÑеÑполиÑование ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s> (%d ÑÑÑок)... "
#: ../raster/r.surf.idw/main.c:241
msgid "Cannot read row"
@@ -7974,8 +5643,8 @@
#: ../raster/r.proj/readcell.c:27 ../imagery/i.gensigset/read_data.c:27
#: ../imagery/i.gensigset/read_train.c:10 ../imagery/i.his.rgb/h2rmain.c:94
#: ../imagery/i.rgb.his/r2hmain.c:92 ../imagery/i.smap/bouman/read_block.c:16
-#: ../imagery/i.pca/main.c:252 ../imagery/i.pca/main.c:301
-#: ../imagery/i.pca/main.c:313 ../imagery/i.pca/main.c:428
+#: ../imagery/i.pca/main.c:259 ../imagery/i.pca/main.c:310
+#: ../imagery/i.pca/main.c:322 ../imagery/i.pca/main.c:437
#: ../imagery/i.gensig/read_train.c:10 ../imagery/i.gensig/covariance.c:34
#: ../imagery/i.cluster/main.c:290 ../imagery/i.maxlik/main.c:117
#, c-format
@@ -8225,7 +5894,6 @@
msgstr "Ðевозможно ÑÑение Ñайла заголовка ÑаÑÑÑа"
#: ../raster/r.li/r.li.daemon/daemon.c:458
-#, fuzzy
msgid "Irregular maskedoverlay areas definition"
msgstr "ÐпÑеделение неÑегÑлÑÑнÑÑ
полигонов maskedoverlay"
@@ -8273,7 +5941,7 @@
msgstr "CHILD[pid = %i]: невозможно оÑкÑÑÑÑ Ð¼Ð°ÑÐºÑ %s ... пÑодолжаем без неÑ!!!"
#: ../raster/r.li/r.li.daemon/ipc.c:48
-#, fuzzy, c-format
+#, c-format
msgid ""
"\t\t\t\tAREA MESSAGE: \n"
" \t\t\t\taid = %i \n"
@@ -8292,7 +5960,7 @@
#: ../raster/r.li/r.li.daemon/ipc.c:57
-#, fuzzy, c-format
+#, c-format
msgid ""
" \t\t\t\tMASKEDAREA MESSAGE: \n"
@@ -8313,7 +5981,7 @@
#: ../raster/r.li/r.li.daemon/ipc.c:68
-#, fuzzy, c-format
+#, c-format
msgid ""
" \t\t\t\tDONE MESSAGE: \n"
@@ -8341,14 +6009,13 @@
#: ../raster/r.li/r.li.daemon/ipc.c:81
-#, fuzzy, c-format
+#, c-format
msgid ""
" \t\t\t\tTERM MESSAGE: \n"
" \t\t\t\tpid = %i \n"
msgstr ""
-" \t\t\t\tСообÑение об оÑибке: \n"
-" \t\t\t\taid = %i \n"
+" \t\t\t\tTERM MESSAGE: \n"
@@ -8522,24 +6189,6 @@
msgid "Cannot open segment file %s"
msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл ÑегменÑа %s"
-#: ../raster/r.flow/io.c:170 ../vector/v.net.visibility/main.c:87
-#: ../vector/v.edit/main.c:100 ../vector/v.in.dxf/main.c:168
-#: ../vector/lidar/v.lidar.edgedetection/main.c:175
-#: ../vector/lidar/v.lidar.correction/main.c:156
-#: ../vector/lidar/v.lidar.correction/main.c:162
-#: ../vector/lidar/v.outlier/main.c:150 ../vector/lidar/v.outlier/main.c:155
-#: ../vector/lidar/v.outlier/main.c:161
-#: ../vector/lidar/v.surf.bspline/main.c:264 ../vector/v.generalize/main.c:312
-#: ../vector/v.mkgrid/main.c:212 ../vector/v.net.path/main.c:139
-#: ../vector/v.voronoi/dt_main.c:92 ../vector/v.voronoi/dt_main.c:98
-#: ../vector/v.voronoi/vo_main.c:164 ../vector/v.drape/main.c:339
-#: ../vector/v.drape/main.c:380 ../vector/v.delaunay2/main.c:103
-#: ../vector/v.delaunay2/main.c:107 ../vector/v.to.3d/main.c:87
-#: ../vector/v.buffer2/main.c:278 ../doc/vector/v.example/main.c:96
-#, c-format
-msgid "Unable to create vector map <%s>"
-msgstr "Ðевозможно ÑоздаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s>"
#: ../raster/r.flow/io.c:197
msgid "Cannot reset current region"
msgstr "Ðевозможно ÑбÑоÑиÑÑ ÑекÑÑий Ñегион"
@@ -8583,6 +6232,10 @@
msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
msgstr "Ð¡Ð¾Ð·Ð´Ð°ÐµÑ Ñлой ÑопогÑаÑиÑеÑкого индекÑа [ln(a/tan(beta))] из ÑÐ»Ð¾Ñ Ð²ÑÑоÑ"
+#: ../raster/r.topidx/main.c:42
+msgid "Input elevation map"
+msgstr "ÐÑÑ
однÑй Ñлой вÑÑоÑ"
#: ../raster/r.topidx/main.c:46
msgid "Output topographic index map"
msgstr "ÐÑÑ
одной Ñлой ÑопогÑаÑиÑеÑкого индекÑа"
@@ -8592,11 +6245,19 @@
msgid "Lat/Long location is not supported by %s. Please reproject map first."
msgstr "облаÑÑÑ Lat/Long не поддеÑживаеÑÑÑ %s. СнаÑала пеÑепÑоекÑиÑÑйÑе Ñлой."
-#: ../raster/r.topidx/file_io.c:29
+#: ../raster/r.topidx/file_io.c:32
+#, c-format
+msgid ""
+"Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx"
+"%.2f]! Needs to be at least identical or the current region resolution lower "
+"than the input map resolution"
+msgstr ""
+#: ../raster/r.topidx/file_io.c:36
msgid "Reading elevation map..."
msgstr "ЧÑение ÑÐ»Ð¾Ñ Ð²ÑÑоÑ..."
-#: ../raster/r.topidx/file_io.c:83
+#: ../raster/r.topidx/file_io.c:90
msgid "Writing topographic index map..."
msgstr "ÐапиÑÑ ÑопогÑаÑиÑеÑкого индекÑного ÑлоÑ..."
@@ -8651,28 +6312,33 @@
msgid "No non-null values"
msgstr "ÐÐµÑ Ð½Ðµ-нÑлевÑÑ
знаÑений"
-#: ../raster/r.out.arc/main.c:61
+#: ../raster/r.out.arc/main.c:62
msgid "Converts a raster map layer into an ESRI ARCGRID file."
msgstr "ÐонвеÑÑиÑÑÐµÑ ÑаÑÑÑовÑй Ñлой в Ñайл ESRI ARCGRID."
-#: ../raster/r.out.arc/main.c:69
+#: ../raster/r.out.arc/main.c:70
msgid "Name of an existing raster map layer"
msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑего ÑаÑÑÑового ÑлоÑ"
-#: ../raster/r.out.arc/main.c:77
+#: ../raster/r.out.arc/main.c:78
msgid "Name of an output ARC-GID map (use out=- for stdout)"
msgstr ""
"ÐÐ¼Ñ Ð²ÑÑ
одного ÑÐ»Ð¾Ñ ARC-GID (иÑполÑзÑйÑе out=- Ð´Ð»Ñ stdout (ÑÑандаÑÑного "
"вÑвода))"
-#: ../raster/r.out.arc/main.c:84
+#: ../raster/r.out.arc/main.c:85
msgid "Number of decimal places"
msgstr "ÐолиÑеÑÑво деÑÑÑиÑнÑÑ
ÑазÑÑдов"
-#: ../raster/r.out.arc/main.c:94
+#: ../raster/r.out.arc/main.c:95
msgid "List one entry per line instead of full row"
msgstr "ÐÑводиÑÑ Ð¿Ð¾ одной запиÑи в линии вмеÑÑо полной ÑÑÑоки"
+#: ../raster/r.out.arc/main.c:101
+#, fuzzy
+msgid "Use cell center reference in header instead of cell corner"
+msgstr "ÐÑводиÑÑ Ð¿Ð¾ одной запиÑи в линии вмеÑÑо полной ÑÑÑоки"
#: ../raster/r.report/stats.c:65
#, c-format
msgid "Unable to open result file <%s>"
@@ -8690,18 +6356,17 @@
msgid "Raster map(s) to report on"
msgstr "РаÑÑÑовÑй Ñлой (Ñлои) Ð´Ð»Ñ Ð¾ÑÑÑÑа"
-#: ../raster/r.report/parse.c:44 ../vector/v.to.db/parse.c:84
+#: ../raster/r.report/parse.c:44 ../vector/v.to.db/parse.c:85
msgid "Units"
msgstr "ÐдиниÑÑ"
#: ../raster/r.report/parse.c:46
-#, fuzzy
msgid ""
"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
"cover"
msgstr ""
-"mi(мили),me(меÑÑÑ),k(киломеÑÑÑ),a(акÑÑ),h(гекÑаÑÑ),c(колиÑеÑÑво ÑÑеек),p"
-"(пÑоÑенÑ)"
+"mi;мили;me;меÑÑÑ;k;киломеÑÑÑ;a;акÑÑ;h;гекÑаÑÑ;c;колиÑеÑÑво ÑÑеек;p;пÑоÑÐµÐ½Ñ "
+"покÑова"
#: ../raster/r.report/parse.c:56
msgid "Character representing no data cell value"
@@ -8819,6 +6484,10 @@
msgid "List supported formats and exit"
msgstr "ÐеÑеÑиÑлиÑÑ Ð¿Ð¾Ð´Ð´ÐµÑживаемÑе ÑоÑмаÑÑ Ð¸ вÑйÑи"
+#: ../raster/r.in.gdal/main.c:140
+msgid "Keep band numbers instead of using band color names"
+msgstr "СоÑ
ÑанÑÑÑ Ð½Ð¾Ð¼ÐµÑа каналов вмеÑÑо иÑполÑÐ·Ð¾Ð²Ð°Ð½Ð¸Ñ Ð¸Ð¼ÐµÐ½ ÑвеÑов каналов"
#: ../raster/r.in.gdal/main.c:161
msgid "You have to specify a target location different from output location"
msgstr "ÐÑ Ð´Ð¾Ð»Ð¶Ð½Ñ ÑказаÑÑ ÑелевÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ, оÑлиÑнÑÑ Ð¾Ñ Ð²ÑÑ
одной облаÑÑи"
@@ -9011,33 +6680,33 @@
#: ../raster/r.random/random.c:74 ../raster/r.to.vect/main.c:156
#: ../raster/r.contour/main.c:185 ../vector/v.db.connect/main.c:195
#: ../vector/v.db.connect/main.c:303 ../vector/v.to.rast3/main.c:86
-#: ../vector/v.edit/select.c:520 ../vector/v.in.dxf/write_vect.c:187
+#: ../vector/v.edit/select.c:520 ../vector/v.in.dxf/write_vect.c:198
#: ../vector/lidar/v.surf.bspline/crosscorr.c:121
-#: ../vector/lidar/v.surf.bspline/main.c:304 ../vector/v.distance/main.c:360
+#: ../vector/lidar/v.surf.bspline/main.c:307 ../vector/v.distance/main.c:360
#: ../vector/v.distance/main.c:397 ../vector/v.reclass/main.c:126
-#: ../vector/v.in.ascii/in.c:314 ../vector/v.to.points/main.c:285
-#: ../vector/v.out.ascii/b2a.c:49 ../vector/v.db.select/main.c:142
+#: ../vector/v.in.ascii/in.c:317 ../vector/v.to.points/main.c:285
+#: ../vector/v.out.ascii/b2a.c:50 ../vector/v.db.select/main.c:142
#: ../vector/v.db.select/main.c:273 ../vector/v.what.rast/main.c:132
#: ../vector/v.extrude/main.c:167 ../vector/v.sample/main.c:207
#: ../vector/v.info/main.c:209 ../vector/v.in.sites/main.c:163
#: ../vector/v.patch/main.c:132 ../vector/v.patch/main.c:162
#: ../vector/v.patch/main.c:274 ../vector/v.patch/main.c:332
#: ../vector/v.surf.idw/read_sites.c:39 ../vector/v.vol.rst/user1.c:97
-#: ../vector/v.vol.rst/main.c:578 ../vector/v.transform/trans_digit.c:58
+#: ../vector/v.vol.rst/main.c:590 ../vector/v.transform/trans_digit.c:58
#: ../vector/v.mkgrid/main.c:226 ../vector/v.random/main.c:160
#: ../vector/v.overlay/main.c:186 ../vector/v.overlay/main.c:287
#: ../vector/v.net.path/path.c:96 ../vector/v.label.sa/labels.c:83
#: ../vector/v.kcv/main.c:181 ../vector/v.normal/main.c:141
-#: ../vector/v.out.svg/main.c:148 ../vector/v.to.db/update.c:39
+#: ../vector/v.out.svg/main.c:148 ../vector/v.to.db/update.c:46
#: ../vector/v.to.db/query.c:89 ../vector/v.out.vtk/writeVTK.c:639
#: ../vector/v.label/main.c:282 ../vector/v.in.dwg/main.c:194
-#: ../vector/v.surf.rst/main.c:579 ../vector/v.in.db/main.c:118
+#: ../vector/v.surf.rst/main.c:586 ../vector/v.in.db/main.c:119
#: ../vector/v.to.rast/support.c:131 ../vector/v.to.rast/support.c:283
#: ../vector/v.to.rast/vect2rast.c:56 ../vector/v.drape/main.c:293
-#: ../vector/v.out.ogr/main.c:327 ../vector/v.lrs/v.lrs.create/main.c:286
+#: ../vector/v.out.ogr/main.c:330 ../vector/v.lrs/v.lrs.create/main.c:286
#: ../vector/v.lrs/v.lrs.create/main.c:294 ../vector/v.buffer/main.c:387
#: ../vector/v.extract/main.c:291 ../vector/v.to.3d/trans2.c:49
-#: ../vector/v.to.3d/trans3.c:50 ../vector/v.buffer2/main.c:292
+#: ../vector/v.to.3d/trans3.c:50 ../vector/v.buffer2/main.c:319
#: ../doc/vector/v.example/main.c:128 ../ps/ps.map/catval.c:54
#: ../ps/ps.map/catval.c:116 ../ps/ps.map/catval.c:182
#: ../display/d.vect/plot1.c:203 ../display/d.vect/area.c:60
@@ -9094,6 +6763,11 @@
"СоздаÑÑ ÑаÑÑÑовÑй Ñлой и векÑоÑнÑй ÑоÑеÑнÑй Ñлой, ÑодеÑжаÑий ÑлÑÑайно "
"ÑаÑположеннÑе ÑоÑки."
+#: ../raster/r.random/main.c:57 ../raster/r.out.bin/main.c:73
+#: ../raster/r.water.outlet/main.c:54 ../imagery/i.zc/main.c:69
+msgid "Name of input raster map"
+msgstr "Ðазвание вводного ÑаÑÑÑового ÑлоÑ"
#: ../raster/r.random/main.c:62 ../raster/r.median/main.c:58
msgid "Name of cover raster map"
msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¾Ð²ÐµÑлеÑ"
@@ -9114,33 +6788,47 @@
msgid "Generate vector points as 3D points"
msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑе ÑоÑки как 3D-ÑоÑки"
-#: ../raster/r.random/main.c:136
+#: ../raster/r.random/main.c:94 ../vector/v.in.ascii/in.c:161
+msgid "Do not build topology in points mode"
+msgstr "Ðе ÑÑÑоиÑÑ ÑÐ¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð² ÑоÑеÑном Ñежиме"
+#: ../raster/r.random/main.c:95 ../vector/v.in.ascii/in.c:84
+#: ../vector/v.in.ascii/in.c:91 ../vector/v.in.ascii/in.c:103
+#: ../vector/v.in.ascii/in.c:113 ../vector/v.in.ascii/in.c:123
+#: ../vector/v.in.ascii/in.c:133 ../vector/v.in.ascii/in.c:157
+#: ../vector/v.in.ascii/in.c:162 ../vector/v.in.ascii/in.c:168
+#: ../vector/v.out.ascii/out.c:67 ../vector/v.out.ascii/out.c:77
+#: ../vector/v.out.ascii/out.c:84 ../vector/v.out.ascii/out.c:97
+msgid "Points"
+msgstr "ТоÑки"
+#: ../raster/r.random/main.c:142
#, c-format
msgid "Note: one (or both) of %s and %s must be specified"
msgstr ""
"ÐÑимеÑание: Ð´Ð¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ ÑÐºÐ°Ð·Ð°Ð½Ñ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ %s или %s (или и Ñо, и дÑÑгое)"
-#: ../raster/r.random/main.c:154
+#: ../raster/r.random/main.c:160
#, c-format
msgid "<%s=%s> invalid percentage"
msgstr "<%s=%s> невеÑнÑй пÑоÑенÑ"
-#: ../raster/r.random/main.c:161
+#: ../raster/r.random/main.c:167
#, c-format
msgid "<%s=%s> invalid number of points"
msgstr "<%s=%s> невеÑное колиÑеÑÑво ÑоÑек"
-#: ../raster/r.random/main.c:174
+#: ../raster/r.random/main.c:180
#, c-format
msgid "There aren't [%ld] cells in the current region"
msgstr "ÐÐµÑ [%ld] ÑÑеек в ÑекÑÑем Ñегионе"
-#: ../raster/r.random/main.c:177
+#: ../raster/r.random/main.c:183
#, c-format
msgid "There aren't [%ld] non-NULL cells in the current region"
msgstr "ÐÐµÑ [%ld] не-NULL ÑÑеек в ÑекÑÑем Ñегионе"
-#: ../raster/r.random/main.c:182
+#: ../raster/r.random/main.c:188
msgid "There are no valid locations in the current region"
msgstr "ÐÐµÑ Ð¿Ð¾Ð´Ñ
одÑÑиÑ
@@ -9348,9 +7036,9 @@
msgstr "ÐеÑаÑаÑÑ Ð¿Ð¾Ð·Ð¸ÑÐ¸Ñ ÑолнÑа в конÑолÑном ÑÑиле"
#: ../raster/r.sunmask/main.c:260
-#, fuzzy, c-format
+#, c-format
msgid "Using map center coordinates: %f %f"
-msgstr "ÐÑполÑзование кооÑÐ´Ð¸Ð½Ð°Ñ ÑенÑÑа ÑлоÑ\n"
+msgstr "ÐÑполÑзование кооÑÐ´Ð¸Ð½Ð°Ñ ÑенÑÑа: %f %f"
#: ../raster/r.sunmask/main.c:267
msgid "Empty east coordinate specified!"
@@ -9483,25 +7171,25 @@
msgid "Computing quantiles"
msgstr "ÐÑÑиÑление кванÑилей"
-#: ../raster/r.quantile/main.c:244
+#: ../raster/r.quantile/main.c:255
msgid "Compute quantiles using two passes."
msgstr "ÐÑÑиÑлиÑÑ ÐºÐ²Ð°Ð½Ñили в два пÑоÑ
ода."
-#: ../raster/r.quantile/main.c:252
+#: ../raster/r.quantile/main.c:263
msgid "Number of quantiles"
msgstr "ÐолиÑеÑÑво кванÑилей"
-#: ../raster/r.quantile/main.c:260
+#: ../raster/r.quantile/main.c:271
msgid "List of percentiles"
msgstr "СпиÑок пÑоÑенÑилей"
-#: ../raster/r.quantile/main.c:266
+#: ../raster/r.quantile/main.c:277
msgid "Number of bins to use"
msgstr "ÐолиÑеÑÑво иÑполÑзÑемÑÑ
Ñазделов"
-#: ../raster/r.quantile/main.c:271
+#: ../raster/r.quantile/main.c:282
msgid "Generate recode rules based on quantile-defined intervals."
-msgstr ""
+msgstr "СоздаÑÑ Ð¿Ñавила пеÑекодиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð½Ð° оÑнове кванÑилÑнÑÑ
инÑеÑвалов."
#: ../raster/r.his/main.c:65
msgid ""
@@ -9749,208 +7437,207 @@
"Ñ Ð¿Ð¾Ð»ÑÑением нового ÑаÑÑÑового ÑÐ»Ð¾Ñ (возможно Ñ Ð´ÑÑгим ÑазÑеÑением) "
"иÑполÑзÑÑ ÑÐ¿Ð»Ð°Ð¹Ð½Ñ Ñо Ñглаживанием."
-#: ../raster/r.resamp.rst/main.c:173
+#: ../raster/r.resamp.rst/main.c:168
msgid "Desired east-west resolution"
msgstr "Ðжидаемое ÑазÑеÑение воÑÑок-запад"
-#: ../raster/r.resamp.rst/main.c:179
+#: ../raster/r.resamp.rst/main.c:174
msgid "Desired north-south resolution"
msgstr "Ðжидаемое ÑазÑеÑение ÑевеÑ-Ñг"
-#: ../raster/r.resamp.rst/main.c:186
+#: ../raster/r.resamp.rst/main.c:181
msgid "Output z-file (elevation) map"
msgstr "ÐÑÑ
одной Ñлой z (вÑÑоÑÑ)"
-#: ../raster/r.resamp.rst/main.c:193
+#: ../raster/r.resamp.rst/main.c:189
msgid "Output slope map (or fx)"
msgstr "ÐÑÑ
одной Ñлой кÑÑÑÐ¸Ð·Ð½Ñ Ñклонов (или fx)"
-#: ../raster/r.resamp.rst/main.c:201
+#: ../raster/r.resamp.rst/main.c:197
msgid "Output aspect map (or fy)"
msgstr "ÐÑÑ
одной Ñлой ÑкÑпозиÑии Ñклонов (или fy)"
-#: ../raster/r.resamp.rst/main.c:209
+#: ../raster/r.resamp.rst/main.c:205
msgid "Output profile curvature map (or fxx)"
msgstr "ÐÑÑ
одной Ñлой кÑÐ¸Ð²Ð¸Ð·Ð½Ñ Ð¿ÑоÑÐ¸Ð»Ñ (или fxx)"
-#: ../raster/r.resamp.rst/main.c:217
+#: ../raster/r.resamp.rst/main.c:213
msgid "Output tangential curvature map (or fyy)"
msgstr "ÐÑÑ
одной Ñлой ÑангенÑиалÑной кÑÐ¸Ð²Ð¸Ð·Ð½Ñ (или fyy)"
-#: ../raster/r.resamp.rst/main.c:225
+#: ../raster/r.resamp.rst/main.c:221
msgid "Output mean curvature map (or fxy)"
msgstr "ÐÑÑ
одной Ñлой ÑÑедней кÑÐ¸Ð²Ð¸Ð·Ð½Ñ (или fxy)"
-#: ../raster/r.resamp.rst/main.c:233
+#: ../raster/r.resamp.rst/main.c:229
msgid "Name of raster map containing smoothing"
msgstr "Ðазвание ÑаÑÑÑового ÑлоÑ, ÑодеÑжаÑего Ñглаживание"
-#: ../raster/r.resamp.rst/main.c:241
+#: ../raster/r.resamp.rst/main.c:237
msgid "Name of raster map to be used as mask"
msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð´Ð»Ñ Ð¸ÑполÑÐ·Ð¾Ð²Ð°Ð½Ð¸Ñ Ð² каÑеÑÑве маÑки"
-#: ../raster/r.resamp.rst/main.c:249
+#: ../raster/r.resamp.rst/main.c:245
msgid "Rows/columns overlap for segmentation"
msgstr "ÐеÑекÑÑÑие ÑÑÑок/ÑÑолбÑов Ð´Ð»Ñ ÑегменÑаÑии"
-#: ../raster/r.resamp.rst/main.c:257
+#: ../raster/r.resamp.rst/main.c:253
msgid "Multiplier for z-values"
msgstr "ÐножиÑÐµÐ»Ñ Ð´Ð»Ñ Ð·Ð½Ð°Ñений z"
-#: ../raster/r.resamp.rst/main.c:265
+#: ../raster/r.resamp.rst/main.c:261
msgid "Spline tension value"
msgstr "ÐÑивизна Ñплайна"
-#: ../raster/r.resamp.rst/main.c:272
+#: ../raster/r.resamp.rst/main.c:268
msgid "Anisotropy angle (in degrees)"
msgstr "Ð£Ð³Ð»Ð¾Ð²Ð°Ñ Ð°Ð½Ð¸Ð·Ð¾ÑÑÐ¾Ð¿Ð¸Ñ (в гÑадÑÑаÑ
-#: ../raster/r.resamp.rst/main.c:273 ../raster/r.resamp.rst/main.c:280
-#: ../vector/v.surf.rst/main.c:360 ../vector/v.surf.rst/main.c:367
+#: ../raster/r.resamp.rst/main.c:269 ../raster/r.resamp.rst/main.c:276
msgid "Anisotropy"
msgstr "ÐнизоÑÑопиÑ"
-#: ../raster/r.resamp.rst/main.c:279 ../vector/v.surf.rst/main.c:366
+#: ../raster/r.resamp.rst/main.c:275 ../vector/v.surf.rst/main.c:373
msgid "Anisotropy scaling factor"
msgstr "ÐнизоÑÑопнÑй ÑакÑÐ¾Ñ Ð¼Ð°ÑÑÑабиÑованиÑ"
-#: ../raster/r.resamp.rst/main.c:284
+#: ../raster/r.resamp.rst/main.c:280
msgid "Use dnorm independent tension"
msgstr "ÐÑполÑзоваÑÑ Ð½Ð°Ð¿ÑÑжение не завиÑÑÑее Ð¾Ñ dnorm"
-#: ../raster/r.resamp.rst/main.c:289 ../vector/v.surf.rst/main.c:199
+#: ../raster/r.resamp.rst/main.c:285 ../vector/v.surf.rst/main.c:200
msgid "Output partial derivatives instead of topographic parameters"
msgstr "ÐÑвод ÑаÑÑнÑÑ
пÑоизводнÑÑ
вмеÑÑо ÑопогÑаÑиÑеÑкиÑ
паÑамеÑÑов"
-#: ../raster/r.resamp.rst/main.c:296 ../general/g.setproj/main.c:107
+#: ../raster/r.resamp.rst/main.c:292 ../general/g.setproj/main.c:107
msgid "Retrieving and setting region failed"
msgstr "Ðе ÑдалоÑÑ Ð¿Ð¾Ð»ÑÑиÑÑ Ð¸ ÑÑÑановиÑÑ Ñегион"
-#: ../raster/r.resamp.rst/main.c:324
+#: ../raster/r.resamp.rst/main.c:320
msgid "Cannot read ew_res value"
msgstr "Ðевозможно пÑоÑиÑаÑÑ Ð·Ð½Ð°Ñение ew_res"
-#: ../raster/r.resamp.rst/main.c:327
+#: ../raster/r.resamp.rst/main.c:323
msgid "Cannot read ns_res value"
msgstr "Ðевозможно пÑоÑиÑаÑÑ Ð·Ð½Ð°Ñение ns_res"
-#: ../raster/r.resamp.rst/main.c:330
+#: ../raster/r.resamp.rst/main.c:326
msgid "Invalid value for tension"
msgstr "ÐепÑавилÑное знаÑение Ð´Ð»Ñ tension"
-#: ../raster/r.resamp.rst/main.c:333
+#: ../raster/r.resamp.rst/main.c:329
msgid "Invalid value for zmult"
msgstr "ÐепÑавилÑное знаÑение Ð´Ð»Ñ zmult"
-#: ../raster/r.resamp.rst/main.c:336
+#: ../raster/r.resamp.rst/main.c:332
msgid "Invalid value for overlap"
msgstr "ÐепÑавилÑное знаÑение Ð´Ð»Ñ overlap"
-#: ../raster/r.resamp.rst/main.c:340
+#: ../raster/r.resamp.rst/main.c:336
msgid "Invalid value for theta"
msgstr "ÐепÑавилÑное знаÑение Ð´Ð»Ñ theta"
-#: ../raster/r.resamp.rst/main.c:344
+#: ../raster/r.resamp.rst/main.c:340
msgid "Invalid value for scalex"
msgstr "ÐепÑавилÑное знаÑение Ð´Ð»Ñ scalex"
-#: ../raster/r.resamp.rst/main.c:346
+#: ../raster/r.resamp.rst/main.c:342
msgid "When using anisotropy both theta and scalex must be specified"
msgstr "ÐÑи иÑполÑзовании анизоÑÑопии Ð´Ð¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ ÑÐºÐ°Ð·Ð°Ð½Ñ Ð¸ theta, и scalex"
-#: ../raster/r.resamp.rst/main.c:369 ../vector/v.surf.rst/main.c:492
+#: ../raster/r.resamp.rst/main.c:365 ../vector/v.surf.rst/main.c:499
msgid "Not enough memory for az"
msgstr "Ðе Ñ
ваÑÐ°ÐµÑ Ð¿Ð°Ð¼ÑÑи Ð´Ð»Ñ az"
-#: ../raster/r.resamp.rst/main.c:374 ../vector/v.surf.rst/main.c:497
+#: ../raster/r.resamp.rst/main.c:370 ../vector/v.surf.rst/main.c:504
msgid "Not enough memory for adx"
msgstr "Ðе Ñ
ваÑÐ°ÐµÑ Ð¿Ð°Ð¼ÑÑи Ð´Ð»Ñ adx"
-#: ../raster/r.resamp.rst/main.c:378 ../vector/v.surf.rst/main.c:501
+#: ../raster/r.resamp.rst/main.c:374 ../vector/v.surf.rst/main.c:508
msgid "Not enough memory for ady"
msgstr "Ðе Ñ
ваÑÐ°ÐµÑ Ð¿Ð°Ð¼ÑÑи Ð´Ð»Ñ ady"
-#: ../raster/r.resamp.rst/main.c:383 ../vector/v.surf.rst/main.c:506
+#: ../raster/r.resamp.rst/main.c:379 ../vector/v.surf.rst/main.c:513
msgid "Not enough memory for adxx"
msgstr "Ðе Ñ
ваÑÐ°ÐµÑ Ð¿Ð°Ð¼ÑÑи Ð´Ð»Ñ adxx"
-#: ../raster/r.resamp.rst/main.c:387 ../vector/v.surf.rst/main.c:510
+#: ../raster/r.resamp.rst/main.c:383 ../vector/v.surf.rst/main.c:517
msgid "Not enough memory for adyy"
msgstr "Ðе Ñ
ваÑÐ°ÐµÑ Ð¿Ð°Ð¼ÑÑи Ð´Ð»Ñ adyy"
-#: ../raster/r.resamp.rst/main.c:391 ../vector/v.surf.rst/main.c:514
+#: ../raster/r.resamp.rst/main.c:387 ../vector/v.surf.rst/main.c:521
msgid "Not enough memory for adxy"
msgstr "Ðе Ñ
ваÑÐ°ÐµÑ Ð¿Ð°Ð¼ÑÑи Ð´Ð»Ñ adxy"
-#: ../raster/r.resamp.rst/main.c:411
+#: ../raster/r.resamp.rst/main.c:407
#, c-format
msgid "[%s]: Map is the wrong resolution"
msgstr "[%s]: ÐевеÑное ÑазÑеÑение ÑлоÑ"
-#: ../raster/r.resamp.rst/main.c:419
+#: ../raster/r.resamp.rst/main.c:415
msgid "Smoothing values can not be negative or NULL"
msgstr "СглаженнÑе знаÑÐµÐ½Ð¸Ñ Ð½Ðµ могÑÑ Ð±ÑÑÑ Ð¾ÑÑиÑаÑелÑнÑми или NULL"
-#: ../raster/r.resamp.rst/main.c:434
+#: ../raster/r.resamp.rst/main.c:430
msgid "Input map resolution differs from current region resolution!"
msgstr "РазÑеÑение иÑÑ
одного ÑÐ»Ð¾Ñ Ð¾ÑлиÑаеÑÑÑ Ð¾Ñ ÑазÑеÑÐµÐ½Ð¸Ñ ÑекÑÑего Ñегиона!"
-#: ../raster/r.resamp.rst/main.c:454
+#: ../raster/r.resamp.rst/main.c:450
msgid "Processing all selected output files will require"
msgstr "ÐбÑабоÑка вÑеÑ
вÑбÑаннÑÑ
вÑÑ
однÑÑ
Ñайлов поÑÑебÑеÑ"
-#: ../raster/r.resamp.rst/main.c:455
+#: ../raster/r.resamp.rst/main.c:451
#, c-format
msgid "%d bytes of disk space for temp files."
msgstr "%d Ð±Ð°Ð¹Ñ Ð½Ð° диÑке Ð´Ð»Ñ Ð²ÑеменнÑÑ
Ñайлов."
-#: ../raster/r.resamp.rst/main.c:480
+#: ../raster/r.resamp.rst/main.c:476
#, c-format
msgid "Cannot get row %d (error = %d)"
msgstr "Ðевозможно ÑÑение ÑÑÑоки %d (оÑибка = %d)"
-#: ../raster/r.resamp.rst/main.c:490
+#: ../raster/r.resamp.rst/main.c:486
msgid "Maximum value of a raster map is NULL."
msgstr "ÐакÑималÑное знаÑение ÑаÑÑÑового ÑÐ»Ð¾Ñ -- NULL."
-#: ../raster/r.resamp.rst/main.c:518
+#: ../raster/r.resamp.rst/main.c:514
msgid "Temporarily changing the region to desired resolution ..."
msgstr "ÐÑеменное пÑиведение Ñегиона к нÑÐ¶Ð½Ð¾Ð¼Ñ ÑазÑеÑениÑ..."
-#: ../raster/r.resamp.rst/main.c:524
+#: ../raster/r.resamp.rst/main.c:520
msgid "Changing back to the original region ..."
msgstr "ÐозвÑÐ°Ñ Ðº иÑÑ
Ð¾Ð´Ð½Ð¾Ð¼Ñ ÑегионÑ..."
-#: ../raster/r.resamp.rst/main.c:526
+#: ../raster/r.resamp.rst/main.c:522
msgid "Cannot set region to back to the initial region !!!"
msgstr "Ðевозможно ÑÑÑановиÑÑ Ñегион Ð´Ð»Ñ Ð²Ð¾Ð·Ð²ÑаÑа к наÑалÑÐ½Ð¾Ð¼Ñ ÑегионÑ!!!"
-#: ../raster/r.resamp.rst/main.c:530 ../raster/r.resample/main.c:137
-#: ../vector/v.surf.rst/main.c:594 ../vector/v.surf.rst/main.c:745
+#: ../raster/r.resamp.rst/main.c:526 ../raster/r.resample/main.c:137
+#: ../vector/v.surf.rst/main.c:601 ../vector/v.surf.rst/main.c:752
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:600
msgid "Percent complete: "
msgstr "ÐÑоÑенÑов завеÑÑено:"
-#: ../raster/r.resamp.rst/main.c:542
+#: ../raster/r.resamp.rst/main.c:538
#, c-format
msgid "dnorm in mainc after grid before out1= %f"
msgstr "dnorm в mainc поÑле гÑида пеÑед out1= %f"
-#: ../raster/r.resamp.rst/main.c:559
+#: ../raster/r.resamp.rst/main.c:555
#, c-format
msgid "dnorm in mainc after grid before out2= %f"
msgstr "dnorm в mainc поÑле гÑида пеÑед out2= %f"
-#: ../raster/r.resamp.rst/main.c:610 ../vector/v.surf.rst/main.c:610
+#: ../raster/r.resamp.rst/main.c:606 ../vector/v.surf.rst/main.c:617
msgid "Not enough memory for zero_array_cell"
msgstr "Ðе Ñ
ваÑÐ°ÐµÑ Ð¿Ð°Ð¼ÑÑи Ð´Ð»Ñ zero_array_cell"
-#: ../raster/r.resamp.rst/main.c:625 ../raster/r.resamp.rst/main.c:638
-#: ../raster/r.resamp.rst/main.c:651 ../raster/r.resamp.rst/main.c:665
-#: ../raster/r.resamp.rst/main.c:678 ../raster/r.resamp.rst/main.c:691
-#: ../vector/v.surf.rst/main.c:622 ../vector/v.surf.rst/main.c:631
-#: ../vector/v.surf.rst/main.c:640 ../vector/v.surf.rst/main.c:650
-#: ../vector/v.surf.rst/main.c:659 ../vector/v.surf.rst/main.c:668
+#: ../raster/r.resamp.rst/main.c:621 ../raster/r.resamp.rst/main.c:634
+#: ../raster/r.resamp.rst/main.c:647 ../raster/r.resamp.rst/main.c:661
+#: ../raster/r.resamp.rst/main.c:674 ../raster/r.resamp.rst/main.c:687
+#: ../vector/v.surf.rst/main.c:629 ../vector/v.surf.rst/main.c:638
+#: ../vector/v.surf.rst/main.c:647 ../vector/v.surf.rst/main.c:657
+#: ../vector/v.surf.rst/main.c:666 ../vector/v.surf.rst/main.c:675
msgid "Not enough disk space -- cannot write files"
msgstr "Ðевозможно ÑоздаÑÑ ÑайлÑ, недоÑÑаÑоÑно меÑÑа на диÑке"
@@ -9958,6 +7645,10 @@
msgid "Generates area statistics for raster map layers."
msgstr "ÐенеÑаÑÐ¸Ñ ÑÑаÑиÑÑики по плоÑади Ð´Ð»Ñ ÑаÑÑÑовÑÑ
Ñлоев."
+#: ../raster/r.stats/main.c:116
+msgid "Name for output file (if omitted or \"-\" output to stdout)"
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного Ñайла (еÑли не Ñказано или '-' вÑвод в stdout)"
#: ../raster/r.stats/main.c:144
msgid "One cell (range) per line"
msgstr "Ðдна ÑÑейка (знаÑение) на ÑÑÑокÑ"
@@ -10127,8 +7818,8 @@
msgid "Scale to apply to z data"
msgstr "ÐаÑÑÑаб пÑименÑемÑй Ð´Ð»Ñ Ð´Ð°Ð½Ð½ÑÑ
z"
-#: ../raster/r.in.xyz/main.c:235 ../raster/r.cost/main.c:199
-#: ../raster/r.walk/main.c:257
+#: ../raster/r.in.xyz/main.c:235 ../raster/r.cost/main.c:210
+#: ../raster/r.walk/main.c:268
msgid "Percent of map to keep in memory"
msgstr "ÐÑоÑÐµÐ½Ñ ÐºÐ°ÑÑÑ ÑоÑ
ÑанÑемÑй в памÑÑи"
@@ -10286,14 +7977,12 @@
#: ../raster/r.slope.aspect/main.c:244 ../raster/r.slope.aspect/main.c:254
#: ../raster/r.slope.aspect/main.c:264 ../vector/v.buffer/main.c:279
#: ../vector/v.buffer/main.c:287 ../vector/v.buffer/main.c:294
-#: ../vector/v.buffer/main.c:304 ../vector/v.buffer2/main.c:172
-#: ../vector/v.buffer2/main.c:180 ../vector/v.buffer2/main.c:188
-#: ../vector/v.buffer2/main.c:196 ../vector/v.buffer2/main.c:203
-#: ../display/d.legend/main.c:108 ../display/d.legend/main.c:117
-#: ../display/d.legend/main.c:125 ../display/d.legend/main.c:146
-#: ../display/d.legend/main.c:155 ../display/d.legend/main.c:165
-#: ../display/d.legend/main.c:170 ../display/d.legend/main.c:175
-#: ../display/d.legend/main.c:180 ../display/d.legend/main.c:185
+#: ../vector/v.buffer/main.c:304 ../display/d.legend/main.c:108
+#: ../display/d.legend/main.c:117 ../display/d.legend/main.c:125
+#: ../display/d.legend/main.c:146 ../display/d.legend/main.c:155
+#: ../display/d.legend/main.c:165 ../display/d.legend/main.c:170
+#: ../display/d.legend/main.c:175 ../display/d.legend/main.c:180
+#: ../display/d.legend/main.c:185
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:208
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:217
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:227
@@ -10472,11 +8161,40 @@
#: ../raster/r.colors/stats.c:79
msgid "Unable to use logarithmic scaling if range includes zero"
msgstr ""
+"Ðевозможно иÑполÑзоваÑÑ Ð»Ð¾Ð³Ð°ÑиÑмиÑеÑкое маÑÑÑабиÑование еÑли диапазон "
+"вклÑÑÐ°ÐµÑ Ð½Ð¾Ð»Ñ"
+#: ../raster/r.colors/main.c:165
+msgid "raster, color table"
+msgstr "ÑаÑÑÑ, ÑвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа"
#: ../raster/r.colors/main.c:167
msgid "Creates/modifies the color table associated with a raster map layer."
msgstr "СоздаÑÑ/измениÑÑ ÑвеÑовÑÑ ÑаблиÑÑ ÑвÑзаннÑÑ Ñ ÑаÑÑÑовÑм Ñлоем."
+#: ../raster/r.colors/main.c:181
+msgid "Type of color table"
+msgstr "Тип ÑвеÑовой ÑаблиÑÑ"
+#: ../raster/r.colors/main.c:183 ../raster/r.colors/main.c:197
+#: ../raster/r.colors/main.c:215 ../raster/r.colors/main.c:220
+#: ../raster/r.colors/main.c:225 ../raster/r.colors/main.c:230
+#: ../vector/v.label.sa/main.c:149 ../vector/v.label.sa/main.c:159
+#: ../vector/v.label.sa/main.c:166 ../vector/v.label.sa/main.c:176
+#: ../vector/v.label.sa/main.c:186 ../vector/v.label.sa/main.c:196
+#: ../vector/v.label.sa/main.c:203 ../vector/v.label/main.c:153
+#: ../vector/v.label/main.c:177 ../vector/v.label/main.c:190
+#: ../vector/v.label/main.c:196 ../vector/v.label/main.c:206
+#: ../display/d.vect/main.c:164 ../display/d.vect/main.c:174
+#: ../display/d.vect/main.c:181 ../display/d.vect/main.c:192
+#: ../display/d.vect/main.c:344 ../display/d.vect/main.c:350
+msgid "Colors"
+msgstr "ЦвеÑа"
+#: ../raster/r.colors/main.c:191
+msgid "Raster map name from which to copy color table"
+msgstr "ÐÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¸Ð· коÑоÑого бÑÐ´ÐµÑ ÑкопиÑована ÑвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа"
#: ../raster/r.colors/main.c:196
msgid "Path to rules file (\"-\" to read rules from stdin)"
msgstr "ÐÑÑÑ Ðº ÑÐ°Ð¹Ð»Ñ Ð¿Ñавил (\"-\" Ð´Ð»Ñ ÑÑÐµÐ½Ð¸Ñ Ð¿Ñавил из stdin)"
@@ -10493,14 +8211,17 @@
msgid "List available rules then exit"
msgstr "ÐÑвеÑÑи ÑпиÑок доÑÑÑпнÑÑ
пÑавил и вÑйÑи"
+#: ../raster/r.colors/main.c:214
+msgid "Invert colors"
+msgstr "ÐнвеÑÑиÑоваÑÑ ÑвеÑа"
#: ../raster/r.colors/main.c:219
msgid "Logarithmic scaling"
msgstr "ÐогаÑиÑмиÑеÑкое маÑÑÑабиÑование"
#: ../raster/r.colors/main.c:224
-#, fuzzy
msgid "Logarithmic-absolute scaling"
-msgstr "ÐогаÑиÑмиÑеÑкое маÑÑÑабиÑование"
+msgstr "ÐогаÑиÑмиÑеÑкое абÑолÑÑное маÑÑÑабиÑование"
#: ../raster/r.colors/main.c:229
msgid "Histogram equalization"
@@ -10511,9 +8232,8 @@
msgstr "ÐводиÑÑ Ð¿Ñавила инÑеÑакÑивно"
#: ../raster/r.colors/main.c:268
-#, fuzzy
msgid "No raster map specified"
-msgstr "Ðе Ñказан Ñлой даннÑÑ
+msgstr "Ðе Ñказан ÑаÑÑÑовÑй Ñлой"
#: ../raster/r.colors/main.c:271
msgid ""
@@ -10536,59 +8256,53 @@
msgstr "опÑии \"color\", \"rules\", and \"raster\" взаимоиÑклÑÑаемÑе"
#: ../raster/r.colors/main.c:287
-#, fuzzy
msgid "-g and -a flags are mutually exclusive"
-msgstr "-r и -e взаимоиÑклÑÑаÑÑиеÑÑ"
+msgstr "паÑамеÑÑÑ -r и -e взаимоиÑклÑÑаÑÑие"
#: ../raster/r.colors/main.c:297
-#, fuzzy, c-format
+#, c-format
msgid "Unable to remove color table of raster map <%s>"
-msgstr "Ðевозможно пÑоÑиÑаÑÑ ÑвеÑовой Ñайл Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
+msgstr "Ðевозможно ÑдалиÑÑ ÑвеÑовÑÑ ÑаблиÑÑ Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
#: ../raster/r.colors/main.c:299
-#, fuzzy, c-format
+#, c-format
msgid "Color table of raster map <%s> not found"
-msgstr "ÑаÑÑÑовÑй Ñлой albedo <%s> не найден"
+msgstr "Ðе найдена ÑвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
#: ../raster/r.colors/main.c:327
-#, fuzzy
msgid "Color table 'random' is not supported for floating point raster map"
msgstr ""
-"Ðевозможно ÑоздаÑÑ ÑлÑÑайнÑÑ ÑвеÑовÑÑ ÑаблиÑÑ Ð´Ð»Ñ ÑÐ»Ð¾Ñ Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой"
+"ЦвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа 'random' не поддеÑживаеÑÑÑ Ð´Ð»Ñ ÑаÑÑÑов Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей запÑÑой"
#: ../raster/r.colors/main.c:332
-#, fuzzy
msgid "Color table 'grey.eq' is not supported for floating point raster map"
msgstr ""
-"Ðевозможно ÑоздаÑÑ ÑвеÑовÑÑ ÑаблиÑÑ Ð² гÑадаÑиÑÑ
ÑеÑого Ð´Ð»Ñ ÑÐ»Ð¾Ñ Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей "
-"ÑоÑкой"
+"ЦвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа 'grey.eq' не поддеÑживаеÑÑÑ Ð´Ð»Ñ ÑаÑÑÑов Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей запÑÑой"
#: ../raster/r.colors/main.c:339
-#, fuzzy
msgid "Color table 'grey.log' is not supported for floating point raster map"
msgstr ""
-"ÑоÑкой"
+"ЦвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа 'grey.log' не поддеÑживаеÑÑÑ Ð´Ð»Ñ ÑаÑÑÑов Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей запÑÑой"
#: ../raster/r.colors/main.c:352
-#, fuzzy, c-format
+#, c-format
msgid "Unknown color request '%s'"
-msgstr "%s - неизвеÑÑнÑй запÑÐ¾Ñ ÑвеÑа"
+msgstr "ÐевеÑнÑй ÑÐ²ÐµÑ '%s'"
#: ../raster/r.colors/main.c:363
-#, fuzzy, c-format
+#, c-format
msgid "Unable to load rules file <%s>"
-msgstr "Ðевозможно загÑÑзиÑÑ Ñайл пÑавил %s"
+msgstr "Ðевозможно загÑÑзиÑÑ Ñайл пÑавил <%s>"
#: ../raster/r.colors/main.c:373 ../raster/r.grow.distance/main.c:316
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read color table for raster map <%s>"
-msgstr "Ðевозможно пÑоÑиÑаÑÑ ÑвеÑовой Ñайл Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s@%s>"
+msgstr "Ðевозможно пÑоÑиÑаÑÑ ÑаблиÑÑ ÑвеÑов Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
#: ../raster/r.colors/main.c:410
-#, fuzzy, c-format
+#, c-format
msgid "Color table for raster map <%s> set to '%s'"
-msgstr "ЦвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа Ð´Ð»Ñ <%s> ÑÑÑановлена в %s"
+msgstr "ЦвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа Ð´Ð»Ñ <%s> ÑÑÑановлена в '%s'"
#: ../raster/r.colors/rules.c:42
#, c-format
@@ -10702,6 +8416,10 @@
"ФилÑÑÑÑÐµÑ Ð¸ ÑÐ¾Ð·Ð´Ð°ÐµÑ Ñлой вÑÑÐ¾Ñ Ð±ÐµÐ· депÑеÑÑий, а Ñак же Ñлой напÑавлений "
"ÑÑока на оÑнове заданного Ñлой вÑÑоÑ."
+#: ../raster/r.fill.dir/main.c:91
+msgid "Name of existing raster map containing elevation surface"
+msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑего ÑаÑÑÑового ÑлоÑ, ÑодеÑжаÑего повеÑÑ
ноÑÑÑ Ð²ÑÑоÑ"
#: ../raster/r.fill.dir/main.c:98
msgid "Output elevation raster map after filling"
msgstr "ÐÑвеÑÑи ÑаÑÑÑовÑй Ñлой вÑÑÐ¾Ñ Ð¿Ð¾Ñле заполнениÑ"
@@ -10887,16 +8605,10 @@
msgid "Writing raster map <%s>"
msgstr "ÐапиÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
-#: ../raster/r.random.surface/save.c:100 ../raster/r.random.cells/indep.c:137
-#: ../raster/r.composite/main.c:199 ../imagery/i.smap/shapiro/write_img.c:12
-#, c-format
-msgid "Writing raster map <%s>..."
#: ../raster/r.random.surface/save.c:219 ../imagery/i.pca/support.c:27
-#, fuzzy, c-format
+#, c-format
msgid "Unable to write color table for raster map <%s>"
-msgstr " "
+msgstr "Ðевозможно запиÑаÑÑ ÑвеÑовой Ñайл Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
#: ../raster/r.random.surface/init.c:40
#, fuzzy
@@ -10909,8 +8621,9 @@
msgstr "ÐакÑималÑное допÑÑÑимое ÑаÑÑÑоÑние Ð¾Ñ ÑоÑки до линии"
#: ../raster/r.random.surface/init.c:67
+#, fuzzy
msgid "Distance decay exponent (value > 0.0)"
-msgstr ""
+msgstr "'layer' должен бÑÑÑ > 0"
#: ../raster/r.random.surface/init.c:76
msgid "Distance filter remains flat before beginning exponent"
@@ -10939,9 +8652,9 @@
msgstr "%s = %s -- должно бÑÑÑ Ð±Ð¾Ð»ÑÑе нÑлÑ"
#: ../raster/r.random.surface/init.c:173
-#, c-format
+#, fuzzy, c-format
msgid "Rastar map <%s> repeated, maps must be unique"
-msgstr ""
#: ../raster/r.random.surface/init.c:183
#, fuzzy
@@ -10964,9 +8677,9 @@
msgstr "ÐаÑÑавка [%d] менÑÑе Ñем минимÑм [%d]"
#: ../raster/r.random.surface/init.c:256
-#, c-format
+#, fuzzy, c-format
msgid "Distance value (%d): %lf must be >= 0.0"
-msgstr ""
#: ../raster/r.random.surface/init.c:285
#, fuzzy, c-format
@@ -11010,261 +8723,203 @@
msgstr "ЧÑение ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>..."
#: ../raster/r.cost/btree.c:58
-msgid "new_cell is NULL"
-msgstr "new_cell Ñавна NULL"
+#, c-format
+msgid "NULL value computed (row %d, col %d)"
+msgstr "NULL знаÑение ÑаÑÑиÑано (ÑÑд %d, колонка %d)"
-#: ../raster/r.cost/btree.c:145
+#: ../raster/r.cost/btree.c:146
#, c-format
-msgid "Can't find %d,%d:%f"
-msgstr "Ðевозможно найÑи %d,%d:%f"
+msgid "Unable to find row %d, col %d: %f"
+msgstr "Ðевозможно найÑи ÑÑд %d, ÐºÐ¾Ð»Ð¾Ð½ÐºÑ %d: %f"
-#: ../raster/r.cost/btree.c:183
+#: ../raster/r.cost/btree.c:185
msgid "Illegal delete request"
msgstr "ÐевеÑнÑй запÑÐ¾Ñ Ð½Ð° Ñдаление"
-#: ../raster/r.cost/btree.c:370
-msgid "Nothing to show"
-msgstr "ÐеÑего показаÑÑ"
-#: ../raster/r.cost/btree.c:401
-msgid "Bad Start Cell"
+#: ../raster/r.cost/btree.c:403
+msgid "Bad start cell"
msgstr "ÐевеÑÐ½Ð°Ñ Ð½Ð°ÑалÑÐ½Ð°Ñ ÑÑейка"
-#: ../raster/r.cost/btree.c:415
+#: ../raster/r.cost/btree.c:417
#, c-format
msgid "%s %f-%f lower cost higher or equal"
msgstr "%s %f-%f нижнÑÑ Ñен болÑÑе или Ñавна"
-#: ../raster/r.cost/btree.c:421
+#: ../raster/r.cost/btree.c:423
#, fuzzy, c-format
msgid "%s lower above pointer wrong"
msgstr "%s непÑавилÑнÑй ÑказаÑÐµÐ»Ñ Ð½Ð¸Ð¶Ðµ ÑвеÑÑ
Ñ"
-#: ../raster/r.cost/btree.c:428
+#: ../raster/r.cost/btree.c:430
#, c-format
msgid "%s %f-%f higher cost lower"
msgstr "%s %f-%f веÑÑ
нÑÑ Ñена ниже"
-#: ../raster/r.cost/btree.c:434
+#: ../raster/r.cost/btree.c:436
#, fuzzy, c-format
msgid "%s higher above pointer wrong"
msgstr "%s непÑавилÑнÑй ÑказаÑÐµÐ»Ñ Ð²ÑÑе ÑвеÑÑ
Ñ"
-#: ../raster/r.cost/main.c:124
+#: ../raster/r.cost/main.c:128
msgid "raster, cost surface, cumulative costs"
msgstr "ÑаÑÑÑ, повеÑÑ
ноÑÑÑ ÑÑоимоÑÑи, кÑмÑлÑÑÐ¸Ð²Ð½Ð°Ñ ÑÑоимоÑÑÑ"
-#: ../raster/r.cost/main.c:126
+#: ../raster/r.cost/main.c:130
msgid ""
-"Outputs a raster map layer showing the cumulative cost of moving between "
-"different geographic locations on an input raster map layer whose cell "
-"category values represent cost."
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
msgstr ""
"ÐÑвеÑÑи ÑаÑÑÑовÑй Ñлой показÑваÑÑий кÑмÑлÑÑивнÑÑ ÑÑоимоÑÑÑ Ð¿ÐµÑемеÑÐµÐ½Ð¸Ñ Ð¼ÐµÐ¶Ð´Ñ "
"ÑазнÑми меÑÑоположениÑми иÑÑ
одного ÑаÑÑÑового Ñлой, ÑÑи ÑÑейки имеÑÑ "
"знаÑение ÑÑоимоÑÑи."
-#: ../raster/r.cost/main.c:133
+#: ../raster/r.cost/main.c:137
msgid "Name of raster map containing grid cell cost information"
msgstr "Ðазвание ÑаÑÑÑового ÑÐ»Ð¾Ñ ÑодеÑжаÑего знаÑÐµÐ½Ð¸Ñ ÑÑоимоÑÑи"
-#: ../raster/r.cost/main.c:142 ../raster/r.walk/main.c:210
-msgid "Starting points vector map"
-msgstr "ÐаÑало ÑоÑеÑного векÑоÑного ÑлоÑ"
+#: ../raster/r.cost/main.c:147 ../raster/r.walk/main.c:214
+#, fuzzy
+msgid "Name of output raster map to contain movement directions"
+msgstr ""
+"ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ ÑодеÑжаÑего знаÑÐµÐ½Ð¸Ñ ÑаÑÑ
одов на пÑеодоление"
-#: ../raster/r.cost/main.c:149 ../raster/r.walk/main.c:217
-msgid "Stop points vector map"
-msgstr "ÐÐ¾Ð½ÐµÑ ÑоÑеÑного векÑоÑного ÑлоÑ"
+#: ../raster/r.cost/main.c:152
+msgid "Name of starting vector points map"
+msgstr "ÐÐ¼Ñ Ð½Ð°ÑалÑного ÑоÑеÑного векÑоÑного ÑлоÑ"
-#: ../raster/r.cost/main.c:156
-msgid "Starting points raster map"
+#: ../raster/r.cost/main.c:158
+msgid "Name of stop vector points map"
+msgstr "ÐÐ¼Ñ ÐºÐ¾Ð½ÐµÑного ÑоÑеÑного векÑоÑного ÑлоÑ"
-#: ../raster/r.cost/main.c:164 ../raster/r.walk/main.c:225
-msgid "The map E and N grid coordinates of a starting point (E,N)"
-msgstr "E и N кооÑдинаÑÑ Ð½Ð°ÑалÑной ÑоÑки (E,N)"
+#: ../raster/r.cost/main.c:159 ../raster/r.cost/main.c:183
+msgid "Stop"
+msgstr "СÑоп"
-#: ../raster/r.cost/main.c:172 ../raster/r.walk/main.c:233
-msgid "The map E and N grid coordinates of a stopping point (E,N)"
-msgstr "E и N кооÑдинаÑÑ ÐºÐ¾Ð½ÐµÑной ÑоÑки (E,N)"
+#: ../raster/r.cost/main.c:164
+msgid "Name of starting raster points map"
+msgstr "ÐÐ¼Ñ Ð½Ð°ÑалÑного ÑоÑеÑного ÑаÑÑÑового ÑлоÑ"
-#: ../raster/r.cost/main.c:181 ../raster/r.walk/main.c:241
-msgid "An optional maximum cumulative cost"
+#: ../raster/r.cost/main.c:173
+msgid "Map grid coordinates of a starting point (E,N)"
+msgstr "ÐооÑдинаÑÑ Ð½Ð°ÑалÑной ÑоÑки (E,N)"
+#: ../raster/r.cost/main.c:182
+msgid "Map grid coordinates of a stopping point (E,N)"
+msgstr "ÐооÑдинаÑÑ ÐºÐ¾Ð½ÐµÑной ÑоÑки (E,N)"
+#: ../raster/r.cost/main.c:192
+#, fuzzy
+msgid "Optional maximum cumulative cost"
msgstr "ÐакÑималÑÐ½Ð°Ñ ÑовокÑÐ¿Ð½Ð°Ñ ÑÑоимоÑÑÑ (опÑиÑ)"
-#: ../raster/r.cost/main.c:190 ../raster/r.walk/main.c:249
+#: ../raster/r.cost/main.c:201 ../raster/r.walk/main.c:260
msgid "Cost assigned to null cells. By default, null cells are excluded"
msgstr ""
"СÑоимоÑÑÑ Ð½Ð°Ð·Ð½Ð°ÑÐµÐ½Ð½Ð°Ñ null-ÑÑейкам. Ðо ÑмолÑаниÑ, null-ÑÑейки иÑклÑÑаÑÑÑÑ"
-#: ../raster/r.cost/main.c:204 ../raster/r.walk/main.c:299
+#: ../raster/r.cost/main.c:215 ../raster/r.walk/main.c:310
msgid "Use the 'Knight's move'; slower, but more accurate"
msgstr "ÐÑполÑзоваÑÑ 'Ход конем'; медленнее, но более ÑоÑно "
-#: ../raster/r.cost/main.c:208 ../raster/r.walk/main.c:303
-msgid "Keep null values in output map"
-msgstr "СоÑ
ÑанÑÑÑ null-знаÑÐµÐ½Ð¸Ñ Ð² вÑÑ
одном Ñлое"
+#: ../raster/r.cost/main.c:219
+msgid "Keep null values in output raster map"
+msgstr "СоÑ
одном ÑаÑÑÑовом Ñлое"
-#: ../raster/r.cost/main.c:212 ../raster/r.walk/main.c:307
+#: ../raster/r.cost/main.c:223 ../raster/r.walk/main.c:318
msgid "Start with values in raster map"
msgstr "ÐаÑинаÑÑ Ñо знаÑений ÑаÑÑÑового ÑлоÑ"
-#: ../raster/r.cost/main.c:217 ../raster/wildfire/r.ros/main.c:301
+#: ../raster/r.cost/main.c:229 ../raster/wildfire/r.ros/main.c:301
#: ../raster/wildfire/r.spreadpath/main.c:110 ../vector/v.kernel/main.c:176
#: ../display/d.vect/main.c:339
msgid "Run verbosely"
msgstr "ÐапÑÑÑиÑÑ Ñ Ð´ÐµÑалÑнÑм оÑÑеÑом"
-#: ../raster/r.cost/main.c:238 ../raster/r.water.outlet/main.c:84
-#: ../raster/r.walk/main.c:322 ../raster/wildfire/r.spread/main.c:338
+#: ../raster/r.cost/main.c:256 ../raster/r.water.outlet/main.c:84
+#: ../raster/r.walk/main.c:339 ../raster/wildfire/r.spread/main.c:338
msgid "Unable to read current window parameters"
msgstr "Ðевозможно пÑоÑеÑÑÑ Ð¿Ð°ÑамеÑÑÑ ÑекÑÑего окна "
-#: ../raster/r.cost/main.c:272
+#: ../raster/r.cost/main.c:290
msgid "Must specify exactly one of start_points, start_rast or coordinate"
msgstr ""
"ÐеобÑ
одимо ÑказаÑÑ Ð¾Ð´Ð¸Ð½ из паÑамеÑÑов start_points, start_rast или кооÑдинаÑÑ"
-#: ../raster/r.cost/main.c:277 ../raster/r.cost/main.c:532
-#: ../raster/r.cost/main.c:638
+#: ../raster/r.cost/main.c:295 ../raster/r.cost/main.c:596
+#: ../raster/r.cost/main.c:702
msgid "No start points"
msgstr "ÐÐµÑ Ð½Ð°ÑалÑнÑÑ
ÑоÑек"
-#: ../raster/r.cost/main.c:284 ../raster/r.walk/main.c:351
+#: ../raster/r.cost/main.c:302 ../raster/r.walk/main.c:368
#, c-format
msgid "Inappropriate maximum cost: %d"
msgstr "ÐепÑавилÑÐ½Ð°Ñ Ð¼Ð°ÐºÑималÑÐ½Ð°Ñ ÑÑоимоÑÑÑ: %d"
-#: ../raster/r.cost/main.c:288 ../raster/r.walk/main.c:355
+#: ../raster/r.cost/main.c:306 ../raster/r.walk/main.c:372
#, c-format
msgid "Inappropriate percent memory: %d"
msgstr "ÐепÑавилÑнÑй пÑоÑÐµÐ½Ñ Ð¿Ð°Ð¼ÑÑи: %d"
-#: ../raster/r.cost/main.c:292 ../raster/r.walk/main.c:393
-msgid "Null cells excluded from cost evaluation."
-msgstr "ЯÑейки Ñ Null-знаÑениÑми иÑклÑÑÐµÐ½Ñ Ð¸Ð· оÑенки ÑÑоимоÑÑи."
+#: ../raster/r.cost/main.c:324
+msgid "Assigning negative cost to null cell. Null cells excluded."
+msgstr "ÐазнаÑение оÑÑиÑаÑелÑнÑÑ
знаÑений null-ÑÑейкам. Null-ÑÑейки иÑклÑÑенÑ."
-#: ../raster/r.cost/main.c:296 ../raster/r.walk/main.c:397
-msgid "Input null cell will be retained into output map"
-msgstr "ÐÑÑ
однÑе ÑÑейки Ñ null-знаÑениÑми бÑдÑÑ ÑоÑ
ÑÐ°Ð½ÐµÐ½Ñ Ð² вÑÑ
одном Ñлое"
-#: ../raster/r.cost/main.c:306 ../raster/r.walk/main.c:495
-msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"ÐÑедÑпÑеждение: назнаÑение оÑÑиÑаÑелÑнÑÑ
знаÑений null-ÑÑейкам. Null-ÑÑейки "
-"иÑклÑÑенÑ."
-#: ../raster/r.cost/main.c:349
-msgid "Source map is: Integer cell type"
-msgstr "ÐÑÑ
однÑй Ñлой ÑелоÑиÑленного Ñипа"
-#: ../raster/r.cost/main.c:352
-msgid "Source map is: Floating point (float) cell type"
-msgstr "ÐÑÑ
однÑй Ñлой Ñипа Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой"
-#: ../raster/r.cost/main.c:355
-msgid "Source map is: Floating point (double) cell type"
-msgstr "ÐÑÑ
однÑй Ñлой Ñипа Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой (double)"
-#: ../raster/r.cost/main.c:358 ../raster/r.walk/main.c:584
-#: ../raster/r.walk/main.c:599 ../raster/r.walk/main.c:636
-#, c-format
-msgid " %d rows, %d cols"
-msgstr "%d ÑÑÑок, %d ÑÑолбÑов"
-#: ../raster/r.cost/main.c:372 ../raster/r.walk/main.c:654
+#: ../raster/r.cost/main.c:402 ../raster/r.walk/main.c:682
msgid "Creating some temporary files..."
msgstr "Создание вÑеменнÑÑ
Ñайлов... "
-#: ../raster/r.cost/main.c:393 ../raster/r.cost/main.c:605
-#, c-format
-msgid "Reading %s"
-msgstr "ЧÑение %s"
+#: ../raster/r.cost/main.c:499
+msgid "Initializing output..."
+msgstr "ÐниÑиализаÑÐ¸Ñ ÑезÑлÑÑаÑа..."
-#: ../raster/r.cost/main.c:457 ../raster/r.walk/main.c:812
-msgid "Initializing output "
+#: ../raster/r.cost/main.c:522 ../raster/r.walk/main.c:880
+#, fuzzy
+msgid "Initializing directional output "
msgstr "ÐниÑиализаÑÐ¸Ñ ÑезÑлÑÑаÑа"
-#: ../raster/r.cost/main.c:466 ../raster/r.walk/main.c:820
-msgid "Unable to allocate memory for segment fbuff == NULL"
-msgstr "Ðевозможно вÑделиÑÑ Ð¿Ð°Ð¼ÑÑÑ Ð´Ð»Ñ ÑегменÑа fbuff == NULL"
+#: ../raster/r.cost/main.c:613
+msgid "Failed to guess site file format\n"
+msgstr "Ðе ÑдалоÑÑ Ð¾Ð¿ÑеделиÑÑ ÑоÑÐ¼Ð°Ñ Ñайла ÑоÑек\n"
-#: ../raster/r.cost/main.c:593
-#, c-format
-msgid "can't open raster map [%s] needed for input coordinates"
-msgstr ""
-"Ðевозможно оÑкÑÑÑÑ ÑаÑÑÑовÑй Ñлой [%s] необÑ
одимÑй Ð´Ð»Ñ Ð¸ÑÑ
однÑÑ
кооÑдинаÑ"
-#: ../raster/r.cost/main.c:653 ../raster/r.walk/main.c:914
+#: ../raster/r.cost/main.c:717 ../raster/r.walk/main.c:982
msgid "Specified starting location outside database window"
msgstr "Ð£ÐºÐ°Ð·Ð°Ð½Ð½Ð°Ñ Ð½Ð°ÑалÑÐ½Ð°Ñ Ð¾Ð±Ð»Ð°ÑÑÑ Ð½Ð°Ñ
одиÑÑÑ Ð²Ð½Ðµ окна Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../raster/r.cost/main.c:669 ../raster/r.walk/main.c:931
-msgid "Finding cost path"
+#: ../raster/r.cost/main.c:733
+#, fuzzy
+msgid "Finding cost path..."
msgstr "ÐоиÑк ÑÑоимоÑÑного пÑÑи"
-#: ../raster/r.cost/main.c:894 ../raster/r.walk/main.c:1378
-msgid "End of map!"
-msgstr "ÐÐ¾Ð½ÐµÑ ÑлоÑ!"
+#: ../raster/r.cost/main.c:999
+msgid "No data"
+msgstr "ÐÐµÑ Ð´Ð°Ð½Ð½ÑÑ
-#: ../raster/r.cost/main.c:898 ../raster/r.walk/main.c:1382
+#: ../raster/r.cost/main.c:1003 ../raster/r.walk/main.c:1483
msgid "Error, ct == pres_cell"
msgstr "ÐÑибка, ct == pres_cell"
-#: ../raster/r.cost/main.c:910
-#, c-format
-msgid "Writing %s"
-msgstr "ÐапиÑÑ %s"
+#: ../raster/r.cost/main.c:1133 ../raster/r.walk/main.c:1621
+#, fuzzy, c-format
+msgid "Writing movement direction file %s..."
+msgstr "ÐапиÑÑ ÑÑанÑÑоÑмиÑованнÑÑ
даннÑÑ
в Ñайл..."
-#: ../raster/r.cost/main.c:913 ../raster/r.walk/main.c:1400
-msgid "Will copy input map null values into output map"
-msgstr "Null-знаÑÐµÐ½Ð¸Ñ Ð¸Ð· иÑÑ
одного ÑÐ»Ð¾Ñ Ð±ÑдÑÑ ÑкопиÑÐ¾Ð²Ð°Ð½Ñ Ð² вÑÑ
одной Ñлой"
-#: ../raster/r.cost/main.c:921 ../raster/r.walk/main.c:1407
-msgid ""
-"Integer cell type.\n"
-"Writing..."
-msgstr ""
-"ЦелоÑиÑленнÑй Ñип ÑÑеек.\n"
-"ÐапиÑÑ..."
-#: ../raster/r.cost/main.c:926 ../raster/r.cost/main.c:959
-#: ../raster/r.cost/main.c:992
-msgid "Error getting input null cells"
-msgstr "ÐÑибка пÑи полÑÑении null-ÑÑеек иÑÑ
одного ÑлоÑ"
-#: ../raster/r.cost/main.c:954 ../raster/r.walk/main.c:1442
-msgid ""
-"Float cell type.\n"
-"Writing..."
-msgstr ""
-"Тип ÑÑеек Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой.\n"
-"ÐапиÑÑ..."
-#: ../raster/r.cost/main.c:987 ../raster/r.walk/main.c:1477
-msgid ""
-"Double cell type.\n"
-"Writing..."
-msgstr ""
-"Тип ÑÑеек double.\n"
-"Writing..."
-#: ../raster/r.cost/main.c:1019 ../raster/r.walk/main.c:1513
-#, c-format
-msgid "Peak cost value: %f"
+#: ../raster/r.cost/main.c:1186
+#, fuzzy, c-format
+msgid "Peak cost value: %f."
msgstr "Ðиковое ÑÑоимоÑÑное знаÑение: %f"
-#: ../raster/r.cost/main.c:1062 ../raster/r.walk/main.c:1564
+#: ../raster/r.cost/main.c:1208 ../raster/r.walk/main.c:1706
#, c-format
msgid "Illegal x coordinate <%s>"
msgstr "ÐевеÑÐ½Ð°Ñ x кооÑдинаÑа <%s>"
-#: ../raster/r.cost/main.c:1064 ../raster/r.walk/main.c:1566
+#: ../raster/r.cost/main.c:1210 ../raster/r.walk/main.c:1708
#, c-format
msgid "Illegal y coordinate <%s>"
msgstr "ÐевеÑÐ½Ð°Ñ y кооÑдинаÑа <%s>"
-#: ../raster/r.cost/main.c:1068 ../raster/r.walk/main.c:1570
+#: ../raster/r.cost/main.c:1214 ../raster/r.walk/main.c:1712
#, c-format
msgid "Warning, ignoring point outside window: %.4f,%.4f"
msgstr "ÐÑедÑпÑеждение, ÑоÑка вне окна игноÑиÑÑеÑÑÑ: %.4f,%.4f"
@@ -11931,7 +9586,7 @@
msgid "Reading map"
msgstr "ЧÑение ÑлоÑ"
-#: ../raster/r.neighbors/main.c:108
+#: ../raster/r.neighbors/main.c:109
msgid ""
"Makes each cell category value a function of the category values assigned to "
"the cells around it, and stores new cell values in an output raster map "
@@ -11940,102 +9595,114 @@
"СделаÑÑ ÐºÐ°Ð¶Ð´Ð¾Ðµ знаÑение каÑегоÑии ÑÑейки ÑÑнкÑией знаÑений каÑегоÑий "
"окÑÑжаÑÑиÑ
ÑÑеек и ÑоÑ
ÑаниÑÑ Ð½Ð¾Ð²Ñе знаÑÐµÐ½Ð¸Ñ Ð² вÑÑ
одном ÑаÑÑÑовом Ñлое."
-#: ../raster/r.neighbors/main.c:131
+#: ../raster/r.neighbors/main.c:132
msgid "Neighborhood operation"
msgstr "ÐпеÑаÑÐ¸Ñ ÑоÑедÑÑва"
-#: ../raster/r.neighbors/main.c:132 ../raster/r.neighbors/main.c:140
-#: ../raster/r.neighbors/main.c:168
-#, fuzzy
+#: ../raster/r.neighbors/main.c:133 ../raster/r.neighbors/main.c:141
+#: ../raster/r.neighbors/main.c:175
msgid "Neighborhood"
-msgstr "Ð Ð°Ð·Ð¼ÐµÑ Ð¾Ð±Ð»Ð°ÑÑи ÑоÑедÑÑва"
+msgstr "ÐблаÑÑÑ ÑоÑедÑÑва"
-#: ../raster/r.neighbors/main.c:138
+#: ../raster/r.neighbors/main.c:139
msgid "Neighborhood size"
-#: ../raster/r.neighbors/main.c:147
+#: ../raster/r.neighbors/main.c:148
msgid "Title of the output raster map"
-#: ../raster/r.neighbors/main.c:154
+#: ../raster/r.neighbors/main.c:155
msgid "File containing weights"
msgstr "Файл, ÑодеÑжаÑий веÑа"
-#: ../raster/r.neighbors/main.c:158
+#: ../raster/r.neighbors/main.c:161
+#, fuzzy
+msgid "Sigma (in cells) for Gaussian filter"
+msgstr "ЧÑвÑÑвиÑелÑноÑÑÑ ÐаÑÑÑова ÑилÑÑÑа"
+#: ../raster/r.neighbors/main.c:165
msgid "Do not align output with the input"
msgstr "Ðе ÑовмеÑайÑе вÑÑ
однÑе даннÑе Ñ Ð¸ÑÑ
однÑми"
-#: ../raster/r.neighbors/main.c:167
+#: ../raster/r.neighbors/main.c:174
msgid "Use circular neighborhood"
msgstr "ÐÑполÑзоваÑÑ ÐºÑÑглÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ ÑоÑедÑÑва"
-#: ../raster/r.neighbors/main.c:175
+#: ../raster/r.neighbors/main.c:182
msgid "Neighborhood size must be positive"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ Ð¾Ð±Ð»Ð°ÑÑи ÑоÑедÑÑва должен бÑÑÑ Ð¿Ð¾Ð»Ð¾Ð¶Ð¸ÑелÑнÑм"
-#: ../raster/r.neighbors/main.c:177
+#: ../raster/r.neighbors/main.c:184
msgid "Neighborhood size must be odd"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ Ð¾Ð±Ð»Ð°ÑÑи ÑоÑедÑÑва должен бÑÑÑ Ð½ÐµÑеÑнÑм"
-#: ../raster/r.neighbors/main.c:181
+#: ../raster/r.neighbors/main.c:188
msgid "weight= and -c are mutually exclusive"
msgstr "weight= и -c взаимоиÑклÑÑаÑÑие"
-#: ../raster/r.neighbors/main.c:206 ../raster/r.series/main.c:198
+#: ../raster/r.neighbors/main.c:200
+#, fuzzy
+msgid "weight= and gauss= are mutually exclusive"
+msgstr "weight= и -c взаимоиÑклÑÑаÑÑие"
+#: ../raster/r.neighbors/main.c:215 ../raster/r.series/main.c:198
#: ../ps/ps.map/outl_io.c:72
#, c-format
msgid "Unable to open raster map <%s> in mapset <%s>"
msgstr "Ðевозможно оÑкÑÑÑÑ ÑаÑÑÑовÑй Ñлой <%s> в набоÑе <%s>"
-#: ../raster/r.neighbors/readweights.c:17
+#: ../raster/r.neighbors/main.c:254
+#, fuzzy, c-format
+msgid "Method %s not compatible with Gaussian filter"
+msgstr "оÑ
Ð²Ð°Ñ x-y ÐаÑÑÑова ÑилÑÑÑа"
+#: ../raster/r.neighbors/readweights.c:18
#, c-format
msgid "Unable to open weights file %s"
msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл веÑов %s"
-#: ../raster/r.neighbors/readweights.c:22
+#: ../raster/r.neighbors/readweights.c:23
#, c-format
msgid "Error reading weights file %s"
msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ Ñайла веÑов %s"
#: ../raster/r.clump/clump.c:98
-#, fuzzy, c-format
+#, c-format
msgid "Pass %d..."
-msgstr "ÐÑоÑ
од: %d\n"
+msgstr "ÐÑоÑ
од %d..."
#: ../raster/r.clump/clump.c:101
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read raster map row %d "
-msgstr "Ðевозможно пÑоÑеÑÑÑ ÑÑÑÐ¾ÐºÑ %d ÑаÑÑÑового ÑлоÑ"
+msgstr "Ðевозможно пÑоÑеÑÑÑ ÑÑÑÐ¾ÐºÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ %d "
#: ../raster/r.clump/clump.c:238 ../imagery/i.his.rgb/h2rmain.c:103
#: ../imagery/i.rgb.his/r2hmain.c:101
-#, fuzzy, c-format
+#, c-format
msgid "Failed writing raster map row %d"
-msgstr "ÐÑибка запиÑи ÑÑÑоки ÑаÑÑÑового ÑлоÑ"
+msgstr "ÐÑибка запиÑи ÑÑÑоки %d ÑаÑÑÑового ÑлоÑ"
#: ../raster/r.clump/main.c:49
-#, fuzzy
msgid "raster, statistics, reclass"
-msgstr "ÑаÑÑÑ, ÑÑаÑиÑÑика"
+msgstr "ÑаÑÑÑ, ÑÑаÑиÑÑика, пеÑеклаÑÑиÑикаÑиÑ"
#: ../raster/r.clump/main.c:51
-#, fuzzy
msgid ""
"Recategorizes data in a raster map by grouping cells that form physically "
"discrete areas into unique categories."
msgstr ""
-"ÐазнаÑиÑÑ Ð½Ð¾Ð²Ñе каÑегоÑии ÑÑейкам ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð·Ð° ÑÑÐµÑ Ð³ÑÑппиÑовки ÑÑеек "
-"обÑазÑÑÑиÑ
оÑделÑнÑе облаÑÑи и назнаÑÐµÐ½Ð¸Ñ Ð¸Ð¼ ÑникалÑнÑÑ
каÑегоÑий."
+"ÐазнаÑиÑÑ Ð½Ð¾Ð²Ñе ÑникалÑнÑе каÑегоÑии ÑÑейкам ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð·Ð° ÑÑÐµÑ "
+"гÑÑппиÑовки ÑÑеек обÑазÑÑÑиÑ
оÑделÑнÑе облаÑÑи."
#: ../raster/r.clump/main.c:63
msgid "Title, in quotes"
msgstr "Ðазвание в кавÑÑкаÑ
#: ../raster/r.clump/main.c:120
-#, fuzzy, c-format
+#, c-format
msgid "%d clumps."
-msgstr "%d clumps"
+msgstr "%d клаÑÑеÑов."
#: ../raster/r.what.color/main.c:89
msgid "Queries colors for a raster map layer."
@@ -12065,6 +9732,10 @@
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
msgstr "ÐмпоÑÑ ÑÐ»Ð¾Ñ GRIDATB.FOR (TOPMODEL) в ÑаÑÑÑовÑй Ñлой GRASS"
+#: ../raster/r.in.gridatb/main.c:53 ../imagery/i.ifft/ifftmain.c:83
+msgid "Name for output raster map"
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
#: ../raster/r.in.gridatb/main.c:67
#, c-format
msgid "File not found: %s"
@@ -12104,7 +9775,6 @@
"СгенеÑиÑоваÑÑ ÑÑейки Ñо ÑлÑÑайнÑми знаÑениÑми и пÑоÑÑÑанÑÑвенной завиÑимоÑÑÑÑ"
#: ../raster/r.to.vect/lines_io.c:76
-#, fuzzy
msgid "write_line: found half a loop!"
msgstr "write_line: найдена ÑеÑедина!"
@@ -12136,6 +9806,10 @@
msgid "Converts a raster map into a vector map layer."
msgstr "ÐонвеÑÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой в векÑоÑнÑй Ñлой."
+#: ../raster/r.to.vect/main.c:64 ../vector/v.to.db/parse.c:36
+msgid "Feature type"
+msgstr "Тип обÑекÑа"
#: ../raster/r.to.vect/main.c:68
msgid "Smooth corners of area features"
msgstr "СгладиÑÑ ÑÐ³Ð»Ñ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ð°"
@@ -12176,12 +9850,12 @@
"РаÑÑÑ Ð½Ðµ CELL, Ñлаг '-v' игноÑиÑÑеÑÑÑ, знаÑÐµÐ½Ð¸Ñ ÑаÑÑÑа бÑдÑÑ Ð·Ð°Ð¿Ð¸ÑÐ°Ð½Ñ Ð² "
"ÑаблиÑÑ.."
-#: ../raster/r.to.vect/main.c:192 ../vector/v.in.dxf/write_vect.c:207
+#: ../raster/r.to.vect/main.c:192 ../vector/v.in.dxf/write_vect.c:218
#: ../vector/lidar/lidarlib/raster.c:84 ../vector/lidar/lidarlib/raster.c:100
#: ../vector/lidar/lidarlib/raster.c:114 ../vector/lidar/lidarlib/raster.c:132
#: ../vector/lidar/lidarlib/raster.c:148 ../vector/lidar/lidarlib/raster.c:162
#: ../vector/lidar/lidarlib/raster.c:178 ../vector/lidar/lidarlib/raster.c:191
-#: ../vector/v.in.ascii/in.c:383 ../vector/v.in.sites/main.c:170
+#: ../vector/v.in.ascii/in.c:386 ../vector/v.in.sites/main.c:170
#: ../vector/v.mkgrid/main.c:244 ../vector/v.random/main.c:178
#: ../vector/v.lrs/v.lrs.create/main.c:325
#, c-format
@@ -12194,8 +9868,8 @@
msgstr "Ðевозможно ÑоздаÑÑ Ð¸Ð½Ð´ÐµÐºÑ"
#: ../raster/r.to.vect/main.c:201 ../raster/r.contour/main.c:206
-#: ../vector/v.in.dxf/write_vect.c:212 ../vector/v.distance/main.c:823
-#: ../vector/v.reclass/main.c:228 ../vector/v.in.ascii/in.c:392
+#: ../vector/v.in.dxf/write_vect.c:223 ../vector/v.distance/main.c:823
+#: ../vector/v.reclass/main.c:228 ../vector/v.in.ascii/in.c:395
#: ../vector/v.to.points/main.c:306 ../vector/v.sample/main.c:223
#: ../vector/v.in.ogr/main.c:773 ../vector/v.in.sites/main.c:179
#: ../vector/v.mkgrid/main.c:252 ../vector/v.random/main.c:189
@@ -12532,11 +10206,23 @@
msgid "Writing raster map, row %d"
msgstr "ÐапиÑÑ Ð½Ð¾Ð²Ð¾Ð³Ð¾ ÑаÑÑÑового ÑлоÑ, ÑÑд %d"
+#: ../raster/r.univar2/r.univar_main.c:40
+#: ../raster/r.univar2/r3.univar_main.c:39 ../vector/v.univar/main.c:92
+msgid "Percentile to calculate (requires extended statistics flag)"
+msgstr ""
+"ÐÑÑиÑлÑемÑй пÑоÑенÑÐ¸Ð»Ñ (ÑÑебÑÐµÑ ÑÑÑановки Ñлага ÑаÑÑиÑенной ÑÑаÑиÑÑики)"
#: ../raster/r.univar2/r.univar_main.c:45
#: ../raster/r.univar2/r3.univar_main.c:44 ../vector/v.univar/main.c:96
+#: ../vector/v.what/main.c:89
msgid "Print the stats in shell script style"
msgstr "ÐÑвеÑÑи ÑÑаÑиÑÑÐ¸ÐºÑ Ð² ÑÑиле shell"
+#: ../raster/r.univar2/r.univar_main.c:49
+#: ../raster/r.univar2/r3.univar_main.c:48 ../vector/v.univar/main.c:100
+msgid "Calculate extended statistics"
+msgstr "РаÑÑÑиÑаÑÑ Ð´Ð¾Ð¿Ð¾Ð»Ð½Ð¸ÑелÑнÑÑ ÑÑаÑиÑÑикÑ"
#: ../raster/r.univar2/r.univar_main.c:77
msgid ""
"Calculates univariate statistics from the non-null cells of a raster map."
@@ -12559,37 +10245,36 @@
"map."
msgstr "ÐÑÑиÑлиÑÑ Ð¾Ð´Ð½Ð¾Ð¼ÐµÑнÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð½Ðµ-null 3d ÑÑеек ÑÐ»Ð¾Ñ raster3d."
-#: ../raster/r.watershed/ram/init_vars.c:84
+#: ../raster/r.watershed/ram/init_vars.c:103
#, c-format
msgid "SECTION 1a (of %1d): Initiating Memory."
msgstr "СÐÐЦÐЯ 1a (из %1d): ÐниÑиализаÑÐ¸Ñ Ð¿Ð°Ð¼ÑÑи."
-#: ../raster/r.watershed/ram/init_vars.c:139
+#: ../raster/r.watershed/ram/init_vars.c:144
+#: ../raster/r.watershed/seg/init_vars.c:191
msgid "unable to open elevation map layer"
msgstr "невозможно оÑкÑÑÑÑ Ñлой вÑÑоÑ"
-#: ../raster/r.watershed/ram/init_vars.c:165
+#: ../raster/r.watershed/ram/init_vars.c:212
msgid "unable to open runoff map layer"
msgstr "невозможно оÑкÑÑÑÑ Ñлой ÑÑока"
-#: ../raster/r.watershed/ram/init_vars.c:187
+#: ../raster/r.watershed/ram/init_vars.c:251
+#: ../raster/r.watershed/seg/init_vars.c:278
msgid "unable to open depression map layer"
msgstr "невозможно оÑкÑÑÑÑ Ñлой депÑеÑÑий"
-#: ../raster/r.watershed/ram/init_vars.c:201
+#: ../raster/r.watershed/ram/init_vars.c:268
+#: ../raster/r.watershed/seg/init_vars.c:307
msgid "unable to open blocking map layer"
msgstr "невозможно оÑкÑÑÑÑ Ñлой пÑепÑÑÑÑвий"
-#: ../raster/r.watershed/ram/init_vars.c:215
+#: ../raster/r.watershed/ram/init_vars.c:285
msgid "unable to open rill map layer"
msgstr "невозможно оÑкÑÑÑÑ Ñлой rill"
-#: ../raster/r.watershed/ram/init_vars.c:224
-msgid "unable to open MASK"
-msgstr "невозможно оÑкÑÑÑÑ MASK"
-#: ../raster/r.watershed/ram/init_vars.c:261
-#: ../raster/r.watershed/seg/init_vars.c:258
+#: ../raster/r.watershed/ram/init_vars.c:313
+#: ../raster/r.watershed/seg/init_vars.c:356
#, c-format
msgid "SECTION 1b (of %1d): Determining Offmap Flow."
msgstr "СÐÐЦÐЯ 1b (из %1d): ÐпÑеделение поÑока вне ÑлоÑ."
@@ -12631,63 +10316,87 @@
"[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
"LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
-#: ../raster/r.watershed/ram/do_cum.c:12 ../raster/r.watershed/seg/do_cum.c:14
-msgid "SECTION 3: Accumulating Surface Flow."
+#: ../raster/r.watershed/ram/do_cum.c:14 ../raster/r.watershed/seg/do_cum.c:17
+#, fuzzy
+msgid "SECTION 3: Accumulating Surface Flow with SFD."
msgstr "СÐÐЦÐЯ 3: ÐккÑмÑлÑÑÐ¸Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑного ÑÑока."
-#: ../raster/r.watershed/ram/sg_factor.c:12
+#: ../raster/r.watershed/ram/do_cum.c:116
+#: ../raster/r.watershed/seg/do_cum.c:121
+#, fuzzy
+msgid "SECTION 3: Accumulating Surface Flow with MFD."
+msgstr "СÐÐЦÐЯ 3: ÐккÑмÑлÑÑÐ¸Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑного ÑÑока."
+#: ../raster/r.watershed/ram/do_cum.c:303
+#: ../raster/r.watershed/seg/do_cum.c:320
+#, c-format
+msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:360
+#: ../raster/r.watershed/seg/do_cum.c:380
+#, c-format
+msgid "MFD: A * path already processed when distributing flow: %d of %d cells"
+msgstr ""
+#: ../raster/r.watershed/ram/sg_factor.c:13
#: ../raster/r.watershed/seg/sg_factor.c:12
-msgid "SECTION 4: Length Slope determination."
+#, fuzzy
+msgid "SECTION 4: RUSLE LS and/or S factor determination."
msgstr "СÐÐЦÐЯ 4: ÐпÑеделение Ð´Ð»Ð¸Ð½Ñ Ñклона."
-#: ../raster/r.watershed/ram/main.c:36 ../raster/r.watershed/ram/main.c:52
-#: ../raster/r.watershed/seg/main.c:43 ../raster/r.watershed/seg/main.c:54
+#: ../raster/r.watershed/ram/main.c:79 ../raster/r.watershed/ram/main.c:95
+#: ../raster/r.watershed/seg/main.c:84 ../raster/r.watershed/seg/main.c:95
#, c-format
msgid "SECTION %d: Closing Maps."
msgstr "СÐÐЦÐЯ %d: ÐавеÑÑение Ñлоев."
-#: ../raster/r.watershed/ram/main.c:50 ../raster/r.watershed/seg/main.c:52
+#: ../raster/r.watershed/ram/main.c:93 ../raster/r.watershed/seg/main.c:93
#, c-format
msgid "SECTION %d: Watershed determination."
msgstr "СÐÐЦÐЯ %d: ÐпÑеделение водоÑбоÑа."
-#: ../raster/r.watershed/ram/close_maps.c:22
-#: ../raster/r.watershed/ram/close_maps.c:60
+#: ../raster/r.watershed/ram/close_maps.c:30
+#: ../raster/r.watershed/ram/close_maps.c:165
+#: ../raster/r.watershed/seg/close_maps.c:28
msgid "unable to open new accum map layer."
msgstr "невозможно оÑкÑÑÑÑ Ð½Ð¾Ð²Ñй Ñлой аккÑмÑлÑÑии"
-#: ../raster/r.watershed/ram/close_maps.c:32
-#: ../raster/r.watershed/ram/close_maps.c:49
-#: ../raster/r.watershed/ram/close_maps.c:81
-#: ../raster/r.watershed/ram/close_maps.c:106
-#: ../raster/r.watershed/ram/close_maps.c:126
-#: ../raster/r.watershed/ram/close_maps.c:146
+#: ../raster/r.watershed/ram/close_maps.c:66
+#: ../raster/r.watershed/ram/close_maps.c:153
+#: ../raster/r.watershed/ram/close_maps.c:186
+#: ../raster/r.watershed/ram/close_maps.c:211
+#: ../raster/r.watershed/ram/close_maps.c:231
+#: ../raster/r.watershed/ram/close_maps.c:251
+#: ../raster/r.watershed/seg/close_maps.c:44
msgid "Close failed."
msgstr "ÐÑибка закÑÑÑиÑ."
-#: ../raster/r.watershed/ram/close_maps.c:39
+#: ../raster/r.watershed/ram/close_maps.c:142
msgid "unable to open new aspect map layer."
msgstr "невозможно оÑкÑÑÑÑ Ð½Ð¾Ð²Ñй Ñлой ÑкÑпозиÑий."
-#: ../raster/r.watershed/ram/close_maps.c:96
-msgid "unable to open new L map layer."
+#: ../raster/r.watershed/ram/close_maps.c:201
+#, fuzzy
+msgid "unable to open new LS factor map layer."
msgstr "невозможно оÑкÑÑÑÑ Ð½Ð¾Ð²Ñй L-Ñлой."
-#: ../raster/r.watershed/ram/close_maps.c:114
+#: ../raster/r.watershed/ram/close_maps.c:219
msgid "unable to open new slope length map layer."
msgstr "невозможно оÑкÑÑÑÑ Ð½Ð¾Ð²Ñй Ñлой длин Ñклонов."
-#: ../raster/r.watershed/ram/close_maps.c:136
-msgid "unable to open new S map layer."
+#: ../raster/r.watershed/ram/close_maps.c:241
+#, fuzzy
+msgid "unable to open new S factor map layer."
msgstr "невозможно оÑкÑÑÑÑ Ð½Ð¾Ð²Ñй S-Ñлой."
-#: ../raster/r.watershed/ram/do_astar.c:18
-#: ../raster/r.watershed/seg/do_astar.c:21
+#: ../raster/r.watershed/ram/do_astar.c:16
+#: ../raster/r.watershed/seg/do_astar.c:20
msgid "SECTION 2: A * Search."
msgstr "СÐÐЦÐЯ 2: A * ÐоиÑк."
-#: ../raster/r.watershed/ram/do_astar.c:117
-#: ../raster/r.watershed/seg/do_astar.c:117
+#: ../raster/r.watershed/ram/do_astar.c:118
+#: ../raster/r.watershed/seg/do_astar.c:121
msgid "heapsize too large"
msgstr ""
@@ -13269,116 +10978,161 @@
"OK, %s должна бÑÑÑ Ð·Ð°Ð¿ÑÑена ÑледÑÑÑим обÑазом:\n"
"%s"
-#: ../raster/r.watershed/front/main.c:53
+#: ../raster/r.watershed/front/main.c:57
msgid "Watershed basin analysis program."
msgstr "ÐÑогÑамма анализа водоÑбоÑнÑÑ
баÑÑейнов."
-#: ../raster/r.watershed/front/main.c:57
+#: ../raster/r.watershed/front/main.c:61
msgid "Input map: elevation on which entire analysis is based"
msgstr "ÐÑÑ
однÑй Ñлой: вÑÑоÑÑ Ð½Ð° коÑоÑÑÑ
оÑнован веÑÑ Ð°Ð½Ð°Ð»Ð¸Ð·"
-#: ../raster/r.watershed/front/main.c:62
+#: ../raster/r.watershed/front/main.c:66
msgid "Input map: locations of real depressions"
msgstr "ÐÑÑ
однÑй Ñлой: меÑÑÐ¾Ð¿Ð¾Ð»Ð¾Ð¶ÐµÐ½Ð¸Ñ ÑеалÑнÑÑ
депÑеÑÑий"
-#: ../raster/r.watershed/front/main.c:70
+#: ../raster/r.watershed/front/main.c:67
+msgid "All non-NULL and non-zero cells are considered as real depressions"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:75
msgid "Input map: amount of overland flow per cell"
msgstr "ÐÑÑ
однÑй Ñлой: колиÑеÑÑво повеÑÑ
ноÑÑного ÑÑока на ÑÑейкÑ"
-#: ../raster/r.watershed/front/main.c:79
+#: ../raster/r.watershed/front/main.c:84
msgid "Input map or value: percent of disturbed land, for USLE"
msgstr "ÐÑÑ
однÑй Ñлой или знаÑение: пÑоÑÐµÐ½Ñ Ð½Ð°ÑÑÑенного покÑова, Ð´Ð»Ñ USLE"
-#: ../raster/r.watershed/front/main.c:88
+#: ../raster/r.watershed/front/main.c:93
msgid "Input map: terrain blocking overland surface flow, for USLE"
msgstr "ÐÑÑ
однÑй Ñлой: ÑоÑÐ¼Ñ ÑелÑеÑа блокиÑÑÑÑие повеÑÑ
ноÑÑнÑй ÑÑок, Ð´Ð»Ñ USLE"
-#: ../raster/r.watershed/front/main.c:97
+#: ../raster/r.watershed/front/main.c:95
+msgid "All non-NULL and non-zero cells are considered as blocking terrain"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:104
msgid "Input value: minimum size of exterior watershed basin"
msgstr "ÐÑÑ
одное знаÑение: минималÑнÑй ÑÐ°Ð·Ð¼ÐµÑ Ð²Ð½ÐµÑнего водоÑбоÑного баÑÑейна"
-#: ../raster/r.watershed/front/main.c:106
-msgid "Input value: maximum length of surface flow, for USLE"
+#: ../raster/r.watershed/front/main.c:112
+#, fuzzy
+msgid "Input value: maximum length of surface flow in map units, for USLE"
msgstr "ÐÑÑ
одное знаÑение: макÑималÑÐ½Ð°Ñ Ð´Ð»Ð¸Ð½Ð° повеÑÑ
ноÑÑного ÑÑока, Ð´Ð»Ñ USLE"
-#: ../raster/r.watershed/front/main.c:115
+#: ../raster/r.watershed/front/main.c:120
msgid "Output map: number of cells that drain through each cell"
msgstr "ÐÑÑ
одной Ñлой: колиÑеÑÑво ÑÑеек дÑениÑÑемÑÑ
ÑеÑез каждÑÑ ÑÑейкÑ"
-#: ../raster/r.watershed/front/main.c:123
+#: ../raster/r.watershed/front/main.c:128
msgid "Output map: drainage direction"
msgstr "ÐÑÑ
одной Ñлой: напÑавление ÑÑока"
-#: ../raster/r.watershed/front/main.c:132
+#: ../raster/r.watershed/front/main.c:137
msgid "Output map: unique label for each watershed basin"
msgstr "ÐÑÑ
одной Ñлой: ÑникалÑнÑе подпиÑи Ð´Ð»Ñ ÐºÐ°Ð¶Ð´Ð¾Ð³Ð¾ водоÑбоÑного баÑÑейна"
-#: ../raster/r.watershed/front/main.c:140
+#: ../raster/r.watershed/front/main.c:145
msgid "Output map: stream segments"
msgstr "ÐÑÑ
одной Ñлой: ÑегменÑÑ Ð¿Ð¾Ñока"
-#: ../raster/r.watershed/front/main.c:149
+#: ../raster/r.watershed/front/main.c:154
msgid "Output map: each half-basin is given a unique value"
msgstr "ÐÑÑ
одной Ñлой: ÐºÐ°Ð¶Ð´Ð¾Ð¼Ñ Ð¿Ð¾Ð»ÑбаÑÑÐµÐ¹Ð½Ñ Ð½Ð°Ð·Ð½Ð°Ñено ÑникалÑное знаÑение"
-#: ../raster/r.watershed/front/main.c:158
-msgid "Output map: useful for visual display of results"
+#: ../raster/r.watershed/front/main.c:163
+#, fuzzy
+msgid "Output map: useful for visual display of results. DEPRECATED."
msgstr "ÐÑÑ
одной Ñлой: визÑализиÑованнÑе ÑезÑлÑÑаÑÑ"
-#: ../raster/r.watershed/front/main.c:167
+#: ../raster/r.watershed/front/main.c:172
msgid "Output map: slope length and steepness (LS) factor for USLE"
msgstr "ÐÑÑ
одной Ñлой: длина Ñклона и кÑÑÑизна (LS) Ð´Ð»Ñ USLE"
-#: ../raster/r.watershed/front/main.c:175
+#: ../raster/r.watershed/front/main.c:180
msgid "Output map: slope steepness (S) factor for USLE"
msgstr "ÐÑÑ
одной Ñлой: кÑÑÑизна Ñклона (S) Ð´Ð»Ñ USLE"
-#: ../raster/r.watershed/front/main.c:186
+#: ../raster/r.watershed/front/main.c:191
+#, fuzzy
+msgid "Convergence factor for MFD (1-10)"
+msgstr "ÐоÑÑÑиÑÐ¸ÐµÐ½Ñ Ð¿ÑеобÑÐ°Ð·Ð¾Ð²Ð°Ð½Ð¸Ñ Ð´Ð»Ñ z-знаÑений"
+#: ../raster/r.watershed/front/main.c:193
+msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:200
msgid "Maximum memory to be used with -m flag (in MB)"
+msgstr "ÐакÑималÑное колиÑеÑÑво памÑÑи Ð´Ð»Ñ Ð¸ÑполÑÐ·Ð¾Ð²Ð°Ð½Ð¸Ñ Ñ Ñлагом -m (в MB)"
+#: ../raster/r.watershed/front/main.c:204
+msgid "enable MFD flow (default is SFD (D8))"
msgstr ""
-#: ../raster/r.watershed/front/main.c:191
+#: ../raster/r.watershed/front/main.c:206
+msgid "SFD: single flow direction, MFD: multiple flow direction"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:211
msgid "Allow only horizontal and vertical flow of water"
msgstr "РазÑеÑиÑÑ ÑолÑко гоÑизонÑалÑнÑй и веÑÑикалÑнÑй ÑÑок"
-#: ../raster/r.watershed/front/main.c:196
+#: ../raster/r.watershed/front/main.c:216
msgid "Enable disk swap memory option: Operation is slow"
msgstr ""
"ÐклÑÑиÑе опÑÐ¸Ñ Ñвопинга диÑковой памÑÑи: ÐпеÑаÑÐ¸Ñ Ð²ÑполнÑеÑÑÑ ÑлиÑком "
"медленно"
-#: ../raster/r.watershed/front/main.c:213
+#: ../raster/r.watershed/front/main.c:218
+msgid ""
+"Only needed if memory requirements exceed available RAM; see manual on how "
+"to calculate memory requirements"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:223
+msgid "Use positive flow accumulation even for likely underestimates"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:225
+msgid "See manual for a detailed description of flow accumulation output"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:242
msgid "Sorry, you must choose an output map."
msgstr "ÐÑ Ð´Ð¾Ð»Ð¶Ð½Ñ Ð²ÑбÑаÑÑ Ð²ÑÑ
одной Ñлой."
-#: ../raster/r.watershed/front/main.c:227
+#: ../raster/r.watershed/front/main.c:258
+#, fuzzy
msgid ""
"Sorry, if any of the following options are set:\n"
-" basin, stream, half.basin, slope, or lS\n"
+" basin, stream, half.basin, length.slope, or slope.steepness\n"
" you MUST provide a value for the basin threshold parameter."
msgstr ""
"ÐÑли одна из ÑледÑÑÑиÑ
опÑий ÑÑÑановлена:\n"
" паÑамеÑÑ Ð¿Ð¾Ñога баÑÑейна обÑзаÑелÑно должен бÑÑÑ Ð·Ð°Ð´Ð°Ð½."
-#: ../raster/r.watershed/front/main.c:360
+#: ../raster/r.watershed/front/main.c:401
#, c-format
msgid "Subprocess failed with exit code %d"
-msgstr ""
+msgstr "ÐодпÑоÑеÑÑ Ð·Ð°Ð²ÐµÑÑилÑÑ Ð½ÐµÑдаÑно Ñ ÐºÐ¾Ð´Ð¾Ð¼ %d"
-#: ../raster/r.watershed/seg/init_vars.c:95
+#: ../raster/r.watershed/seg/init_vars.c:114
#, c-format
msgid "SECTION 1 beginning: Initiating Variables. %d sections total."
msgstr "СÐÐЦÐЯ 1 наÑало: ÐниÑиализаÑÐ¸Ñ Ð¿ÐµÑеменнÑÑ
. вÑего %d ÑекÑий."
-#: ../raster/r.watershed/seg/init_vars.c:148
+#: ../raster/r.watershed/seg/init_vars.c:150
msgid ""
"Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
msgstr ""
+"ÐакÑималÑное колиÑеÑÑво иÑполÑзÑемой памÑÑи бÑло менÑÑе Ñем 3 MB, "
+"ÑÑÑановлено по ÑмолÑÐ°Ð½Ð¸Ñ = 300 MB."
-#: ../raster/r.watershed/seg/init_vars.c:226
-msgid "Unable to open MASK"
-msgstr "Ðевозможно оÑкÑÑÑÑ MASK"
+#: ../raster/r.watershed/seg/close_maps.c:52
+#, fuzzy
+msgid "unable to open flow accumulation map layer"
+msgstr "невозможно оÑкÑÑÑÑ Ð½Ð¾Ð²Ñй Ñлой аккÑмÑлÑÑии"
#: ../raster/r.in.poly/poly2rast.c:36
#, c-format
@@ -13391,9 +11145,8 @@
"СоздаÑÑ ÑаÑÑÑовÑй Ñлой из полигоналÑнÑй/линейнÑÑ
/ÑоÑеÑнÑÑ
Ñайлов ASCII."
#: ../raster/r.in.poly/main.c:35
-#, fuzzy
msgid "Name of input file; or \"-\" to read from stdin"
-msgstr "ÐÑÑÑ Ðº ÑÐ°Ð¹Ð»Ñ Ð¿Ñавил (\"-\" Ð´Ð»Ñ ÑÑÐµÐ½Ð¸Ñ Ð¿Ñавил из stdin)"
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного Ñайла; или \"-\" Ð´Ð»Ñ ÑÑÐµÐ½Ð¸Ñ Ð¿Ñавил из stdin"
#: ../raster/r.in.poly/main.c:50 ../vector/v.to.rast/main.c:85
msgid "Number of rows to hold in memory"
@@ -13477,9 +11230,9 @@
msgstr "ÐÐ¾Ð²Ð°Ñ ÑаблиÑа кванÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ñоздана Ð´Ð»Ñ %s"
#: ../raster/r.contour/cont.c:81
-#, fuzzy, c-format
+#, c-format
msgid "Writing vector contours (total levels %d)..."
-msgstr "ÐапиÑÑ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ <%s> ..."
+msgstr "ÐапиÑÑ Ð²ÐµÐºÑоÑнÑÑ
изолиний (вÑего ÑÑовней %d)..."
#: ../raster/r.contour/cont.c:211
#, c-format
@@ -13495,14 +11248,12 @@
msgstr "ЧиÑло гÑÐ°Ð½Ð¸Ñ Ð²Ð½Ðµ диапазона"
#: ../raster/r.contour/main.c:91
-#, fuzzy
msgid "raster, DEM, contours, vector"
-msgstr "Ðи ÑаÑÑÑовÑй, ни векÑоÑнÑй вÑвод"
+msgstr "ÑаÑÑÑ, ЦÐÐ , изолинии, векÑоÑ"
#: ../raster/r.contour/main.c:92
-#, fuzzy
msgid "Produces a vector map of specified contours from a raster map."
-msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой изолиний из ÑаÑÑÑового ÑлоÑ."
+msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой заданнÑÑ
#: ../raster/r.contour/main.c:104
msgid "List of contour levels"
@@ -13543,13 +11294,13 @@
#: ../vector/v.to.points/main.c:295 ../vector/v.in.ogr/main.c:762
#: ../vector/v.convert/att.c:80 ../vector/v.overlay/main.c:456
#: ../vector/v.net.path/path.c:109 ../vector/v.in.dwg/main.c:219
-#: ../vector/v.surf.rst/main.c:585
+#: ../vector/v.surf.rst/main.c:592
#, c-format
msgid "Unable to create table: '%s'"
msgstr "Ðевозможно ÑоздаÑÑ ÑаблиÑÑ: '%s'"
-#: ../raster/r.contour/main.c:201 ../vector/v.in.dxf/write_vect.c:214
-#: ../vector/v.reclass/main.c:223 ../vector/v.in.ascii/in.c:502
+#: ../raster/r.contour/main.c:201 ../vector/v.in.dxf/write_vect.c:225
+#: ../vector/v.reclass/main.c:223 ../vector/v.in.ascii/in.c:505
#: ../vector/v.to.points/main.c:300 ../vector/v.in.ogr/main.c:767
#: ../vector/v.in.sites/main.c:174 ../vector/v.convert/att.c:85
#: ../vector/v.in.dwg/main.c:223
@@ -13569,29 +11320,26 @@
msgstr "ЧÑение даннÑÑ
#: ../raster/r.contour/main.c:270
-#, fuzzy, c-format
+#, c-format
msgid "Range of data: min=%f, max=%f"
-msgstr "Ðиапазон даннÑÑ
: min = %f max = %f"
+msgstr "Ðиапазон даннÑÑ
: min = %f, max = %f"
#: ../raster/r.contour/main.c:272
-#, fuzzy
msgid "Range of data: empty"
: пÑÑÑо"
: пÑÑÑо"
#: ../raster/r.contour/main.c:299 ../raster/r.contour/main.c:303
-#, fuzzy
msgid "This step value is not allowed"
-msgstr "ÐÑо знаÑение Ñага недопÑÑÑимо."
+msgstr "ÐÑо знаÑение Ñага недопÑÑÑимо"
#: ../raster/r.contour/main.c:327
-#, fuzzy, c-format
+#, c-format
msgid "Range of levels: min = %f, max = %f"
-msgstr "Ðиапазон ÑÑовней: min = %f max = %f"
+msgstr "Ðиапазон ÑÑовней: min = %f, max = %f"
#: ../raster/r.contour/main.c:356
-#, fuzzy
msgid "Displacing data..."
-msgstr "Ðамена даннÑÑ
+msgstr "СмеÑение даннÑÑ
#: ../raster/r.cross/renumber.c:32
#, c-format
@@ -13733,17 +11481,17 @@
#: ../raster/r.series/main.c:157
msgid "Ignore values outside this range"
-msgstr ""
+msgstr "ÐгноÑиÑоваÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ð·Ð° ÑÑим диапазоном"
#: ../raster/r.series/main.c:209
msgid "output= and method= must have the same number of values"
-msgstr ""
+msgstr "output= и method= Ð´Ð¾Ð»Ð¶Ð½Ñ Ð¸Ð¼ÐµÑÑ Ð¾Ð´Ð¸Ð½Ð°ÐºÐ¾Ð²Ð¾Ðµ колиÑеÑÑво знаÑений"
#: ../raster/r.water.outlet/main.c:47
msgid "Watershed basin creation program."
msgstr "ÐÑогÑамма ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð²Ð¾Ð´Ð¾ÑбоÑнÑÑ
баÑÑейнов"
-#: ../raster/r.water.outlet/main.c:61 ../raster/r.walk/main.c:203
+#: ../raster/r.water.outlet/main.c:61 ../raster/r.walk/main.c:206
msgid "Name of raster map to contain results"
msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑаÑÑÑового ÑлоÑ"
@@ -13878,6 +11626,10 @@
msgid "Raster file(s) for View%d"
msgstr "РаÑÑÑ(Ñ) Ð´Ð»Ñ View%d"
+#: ../raster/r.out.mpeg/main.c:406
+msgid "Name for output file"
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного Ñайла"
#: ../raster/r.out.mpeg/main.c:416
msgid "Quality factor (1 = highest quality, lowest compression)"
msgstr "ÐаÑеÑÑво (1 = Ñамое вÑÑокое, низкое ÑжаÑие)"
@@ -13906,7 +11658,7 @@
msgid "Unable to create temporary files."
msgstr "Ðевозможно ÑоздаÑÑ Ð²ÑеменнÑй Ñайл."
-#: ../raster/r.walk/main.c:176
+#: ../raster/r.walk/main.c:179
msgid ""
"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
"between different geographic locations on an input elevation raster map "
@@ -13918,149 +11670,242 @@
"знаÑÐµÐ½Ð¸Ñ ÑÑеек коÑоÑого пÑедÑÑавлÑÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ð²ÑÑÐ¾Ñ ÐºÐ¾Ð¼Ð±Ð¸Ð½Ð¸ÑованнÑе Ñо "
"знаÑениÑми ÑаÑÑ
одов на пÑеодоление Ñ Ð´ÑÑгого ÑаÑÑÑового ÑлоÑ."
-#: ../raster/r.walk/main.c:188
+#: ../raster/r.walk/main.c:191
msgid "Name of elevation input raster map"
msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð²ÑÑоÑ"
-#: ../raster/r.walk/main.c:196
+#: ../raster/r.walk/main.c:199
msgid "Name of input raster map containing friction costs"
msgstr ""
"ÐÐ¼Ñ Ð¸ÑÑ
-#: ../raster/r.walk/main.c:266
+#: ../raster/r.walk/main.c:221
+msgid "Starting points vector map"
+msgstr "ÐаÑало ÑоÑеÑного векÑоÑного ÑлоÑ"
+#: ../raster/r.walk/main.c:228
+msgid "Stop points vector map"
+msgstr "ÐÐ¾Ð½ÐµÑ ÑоÑеÑного векÑоÑного ÑлоÑ"
+#: ../raster/r.walk/main.c:236
+msgid "The map E and N grid coordinates of a starting point (E,N)"
+msgstr "E и N кооÑдинаÑÑ Ð½Ð°ÑалÑной ÑоÑки (E,N)"
+#: ../raster/r.walk/main.c:244
+msgid "The map E and N grid coordinates of a stopping point (E,N)"
+msgstr "E и N кооÑдинаÑÑ ÐºÐ¾Ð½ÐµÑной ÑоÑки (E,N)"
+#: ../raster/r.walk/main.c:252
+msgid "An optional maximum cumulative cost"
+msgstr "ÐакÑималÑÐ½Ð°Ñ ÑовокÑÐ¿Ð½Ð°Ñ ÑÑоимоÑÑÑ (опÑиÑ)"
+#: ../raster/r.walk/main.c:277
msgid "Number of the segment to create (segment library)"
msgstr "ÐÐ¾Ð¼ÐµÑ Ñоздаваемого ÑегменÑа (библиоÑека ÑегменÑов)"
-#: ../raster/r.walk/main.c:276
+#: ../raster/r.walk/main.c:287
msgid "Coefficients for walking energy formula parameters a,b,c,d"
msgstr "ÐоÑÑÑиÑиенÑÑ Ð´Ð»Ñ Ð¿Ð°ÑамеÑÑов ÑоÑмÑÐ»Ñ ÑнеÑгии пеÑемеÑÐµÐ½Ð¸Ñ a,b,c,d"
-#: ../raster/r.walk/main.c:285
+#: ../raster/r.walk/main.c:296
msgid "Lambda coefficients for combining walking energy and friction cost"
msgstr ""
"ÐÑмбда коÑÑÑиÑиенÑÑ Ð´Ð»Ñ ÐºÐ¾Ð¼Ð±Ð¸Ð½Ð¸ÑÐ¾Ð²Ð°Ð½Ð¸Ñ ÑаÑÑ
одов на пÑеодоление и ÑнеÑгии "
"пеÑемеÑениÑ"
-#: ../raster/r.walk/main.c:294
+#: ../raster/r.walk/main.c:305
msgid "Slope factor determines travel energy cost per height step"
msgstr "ФакÑÐ¾Ñ Ñклона опÑеделÑÐµÑ ÑÐµÐ½Ñ ÑнеÑгии пеÑемеÑÐµÐ½Ð¸Ñ Ð½Ð° каждÑй Ñаг вÑÑоÑÑ"
-#: ../raster/r.walk/main.c:360
+#: ../raster/r.walk/main.c:314
+msgid "Keep null values in output map"
+msgstr "СоÑ
одном Ñлое"
+#: ../raster/r.walk/main.c:377
#, c-format
msgid "Missing required value: got %d instead of 4"
msgstr "ÐÑÑÑÑÑÑвÑÐµÑ Ð½ÐµÐ¾Ð±Ñ
одимое знаÑение: полÑÑено %d вмеÑÑо 4"
-#: ../raster/r.walk/main.c:364
+#: ../raster/r.walk/main.c:381
#, c-format
msgid "Walking costs are a=%lf b=%lf c=%lf d=%lf"
msgstr "Ð¦ÐµÐ½Ñ Ð¿ÐµÑемеÑÐµÐ½Ð¸Ñ a=%lf b=%lf c=%lf d=%lf"
-#: ../raster/r.walk/main.c:369 ../raster/r.walk/main.c:377
-#: ../raster/r.walk/main.c:384
+#: ../raster/r.walk/main.c:386 ../raster/r.walk/main.c:394
+#: ../raster/r.walk/main.c:401
#, c-format
msgid "Missing required value: %d"
одимое знаÑение: %d"
-#: ../raster/r.walk/main.c:372
+#: ../raster/r.walk/main.c:389
#, c-format
msgid "Lambda is %lf"
msgstr "ÐÑмбда %lf"
-#: ../raster/r.walk/main.c:380
+#: ../raster/r.walk/main.c:397
#, c-format
msgid "Slope_factor is %lf"
msgstr "Slope_factor %lf"
-#: ../raster/r.walk/main.c:387
+#: ../raster/r.walk/main.c:404
#, c-format
msgid "Nseg is %d"
msgstr "Nseg %d"
-#: ../raster/r.walk/main.c:409
+#: ../raster/r.walk/main.c:410
+msgid "Null cells excluded from cost evaluation."
+msgstr "ЯÑейки Ñ Null-знаÑениÑми иÑклÑÑÐµÐ½Ñ Ð¸Ð· оÑенки ÑÑоимоÑÑи."
+#: ../raster/r.walk/main.c:414
+msgid "Input null cell will be retained into output map"
+msgstr "ÐÑÑ
ÑÐ°Ð½ÐµÐ½Ñ Ð² вÑÑ
одном Ñлое"
+#: ../raster/r.walk/main.c:426
#, c-format
msgid "Unable to find starting vector <%s> "
msgstr "Ðевозможно найÑи наÑалÑнÑй векÑÐ¾Ñ <%s> "
-#: ../raster/r.walk/main.c:456
+#: ../raster/r.walk/main.c:473
#, c-format
msgid "Unable to find stop vector <%s>"
msgstr "Ðевозможно найÑи конеÑнÑй векÑÐ¾Ñ <%s>"
-#: ../raster/r.walk/main.c:556 ../raster/r.walk/main.c:558
+#: ../raster/r.walk/main.c:512
+msgid "Warning: assigning negative cost to null cell. Null cells excluded."
+msgstr ""
+"ÐÑедÑпÑеждение: назнаÑение оÑÑиÑаÑелÑнÑÑ
+"иÑклÑÑенÑ."
+#: ../raster/r.walk/main.c:584 ../raster/r.walk/main.c:586
#, c-format
msgid "Unable to read %s"
msgstr "Ðевозможно пÑоÑиÑаÑÑ %s"
-#: ../raster/r.walk/main.c:563
+#: ../raster/r.walk/main.c:591
msgid "Map with different projection"
msgstr "Слой Ñ Ð¾ÑлиÑной пÑоекÑией"
-#: ../raster/r.walk/main.c:575
+#: ../raster/r.walk/main.c:603
msgid "DTM_Source map is: Integer cell type"
msgstr "Тип ÑÐ»Ð¾Ñ DTM_Source: ÑелоÑиÑленнÑе ÑÑейки"
-#: ../raster/r.walk/main.c:578
+#: ../raster/r.walk/main.c:606
msgid "DTM_Source map is: Floating point (float) cell type"
msgstr "Тип ÑÐ»Ð¾Ñ DTM_Source: ÑÑейки Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой"
-#: ../raster/r.walk/main.c:581
+#: ../raster/r.walk/main.c:609
msgid "DTM_Source map is: Floating point (double) cell type"
msgstr "Тип ÑÐ»Ð¾Ñ DTM_Source: ÑÑейки Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой (double)"
-#: ../raster/r.walk/main.c:590
+#: ../raster/r.walk/main.c:612 ../raster/r.walk/main.c:627
+#: ../raster/r.walk/main.c:664
+#, c-format
+msgid " %d rows, %d cols"
+msgstr "%d ÑÑÑок, %d ÑÑолбÑов"
+#: ../raster/r.walk/main.c:618
msgid "COST_Source map is: Integer cell type"
msgstr "Тип ÑÐ»Ð¾Ñ COST_Source: ÑелоÑиÑленнÑе ÑÑейки"
-#: ../raster/r.walk/main.c:593
+#: ../raster/r.walk/main.c:621
msgid "COST_Source map is: Floating point (float) cell type"
msgstr "Тип ÑÐ»Ð¾Ñ COST_Source: ÑÑейки Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой"
-#: ../raster/r.walk/main.c:596
+#: ../raster/r.walk/main.c:624
msgid "COST_Source map is: Floating point (double) cell type"
msgstr "Тип ÑÐ»Ð¾Ñ COST_Source: ÑÑейки Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой (double)"
-#: ../raster/r.walk/main.c:627
+#: ../raster/r.walk/main.c:655
msgid "Output map is: Integer cell type"
msgstr "Тип вÑÑ
одного ÑлоÑ: ÑелоÑиÑленнÑе ÑÑейки"
-#: ../raster/r.walk/main.c:630
+#: ../raster/r.walk/main.c:658
msgid "Output map is: Floating point (float) cell type"
msgstr "Тип вÑÑ
одного ÑлоÑ: ÑÑейки Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой"
-#: ../raster/r.walk/main.c:633
+#: ../raster/r.walk/main.c:661
msgid "Output map is: Floating point (double) cell type"
msgstr "Тип вÑÑ
одного ÑлоÑ: ÑÑейки Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой (double)"
-#: ../raster/r.walk/main.c:638
+#: ../raster/r.walk/main.c:666
#, c-format
msgid " EW resolution %s (%lf)"
msgstr " EW ÑазÑеÑение %s (%lf)"
-#: ../raster/r.walk/main.c:640
+#: ../raster/r.walk/main.c:668
#, c-format
msgid " NS resolution %s (%lf)"
msgstr " NS ÑазÑеÑение %s (%lf)"
-#: ../raster/r.walk/main.c:849
+#: ../raster/r.walk/main.c:852
+msgid "Initializing output "
+msgstr "ÐниÑиализаÑÐ¸Ñ ÑезÑлÑÑаÑа"
+#: ../raster/r.walk/main.c:860 ../raster/r.walk/main.c:889
+msgid "Unable to allocate memory for segment fbuff == NULL"
+msgstr "Ðевозможно вÑделиÑÑ Ð¿Ð°Ð¼ÑÑÑ Ð´Ð»Ñ ÑегменÑа fbuff == NULL"
+#: ../raster/r.walk/main.c:917
#, c-format
msgid "Raster output map <%s> not found (no start_points given)"
msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой <%s> не найден (не Ð·Ð°Ð´Ð°Ð½Ñ start_points)"
-#: ../raster/r.walk/main.c:864
+#: ../raster/r.walk/main.c:932
#, c-format
msgid "Memory allocation error on reading start points from raster map %s"
msgstr "ÐÑибка вÑÐ´ÐµÐ»ÐµÐ½Ð¸Ñ Ð¿Ð°Ð¼ÑÑи на ÑÑение наÑалÑнÑÑ
ÑоÑек Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ %s"
-#: ../raster/r.walk/main.c:867
+#: ../raster/r.walk/main.c:935
#, c-format
msgid "Reading %s... "
msgstr "ЧÑение %s ..."
-#: ../raster/r.walk/main.c:1396
+#: ../raster/r.walk/main.c:999
+msgid "Finding cost path"
+msgstr "ÐоиÑк ÑÑоимоÑÑного пÑÑи"
+#: ../raster/r.walk/main.c:1479
+msgid "End of map!"
+msgstr "ÐÐ¾Ð½ÐµÑ ÑлоÑ!"
+#: ../raster/r.walk/main.c:1505
#, c-format
msgid "Writing output raster map %s... "
msgstr "ÐапиÑÑ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ %s... "
+#: ../raster/r.walk/main.c:1509
+msgid "Will copy input map null values into output map"
+msgstr "Null-знаÑÐµÐ½Ð¸Ñ Ð¸Ð· иÑÑ
одной Ñлой"
+#: ../raster/r.walk/main.c:1516
+msgid ""
+"Integer cell type.\n"
+"Writing..."
+msgstr ""
+"ЦелоÑиÑленнÑй Ñип ÑÑеек.\n"
+"ÐапиÑÑ..."
+#: ../raster/r.walk/main.c:1551
+msgid ""
+"Float cell type.\n"
+"Writing..."
+msgstr ""
+"Тип ÑÑеек Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой.\n"
+"ÐапиÑÑ..."
+#: ../raster/r.walk/main.c:1586
+msgid ""
+"Double cell type.\n"
+"Writing..."
+msgstr ""
+"Тип ÑÑеек double.\n"
+"Writing..."
+#: ../raster/r.walk/main.c:1637
+#, c-format
+msgid "Peak cost value: %f"
+msgstr "Ðиковое ÑÑоимоÑÑное знаÑение: %f"
#: ../raster/r.mapcalc/evaluate.c:91 ../raster/r.mapcalc/evaluate.c:206
#: ../raster/r.mapcalc/map3.c:348 ../raster/r.mapcalc/map.c:280
#, c-format
@@ -14220,63 +12065,66 @@
msgstr "Ðозникло пеÑеполнение во вÑÐµÐ¼Ñ Ð²ÑÑиÑлений"
#: ../raster/r.recode/read_rules.c:24
-#, fuzzy, c-format
+#, c-format
msgid "Data range of raster map <%s> is empty"
-msgstr "Ðевозможно пÑоÑиÑаÑÑ fp диапазон ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s> пÑÑÑ"
#: ../raster/r.recode/read_rules.c:31
-#, fuzzy, c-format
+#, c-format
msgid "Data range of raster map <%s> is %s to %s (entire map)"
Ð¾Ñ %s Ñ %s до %s (веÑÑ Ñлой)"
ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s> Ð¾Ñ %s до %s (веÑÑ Ñлой)"
#: ../raster/r.recode/read_rules.c:36
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read range of raster map <%s>"
+msgstr "Ðевозможно пÑоÑиÑаÑÑ Ð´Ð¸Ð°Ð¿Ð°Ð·Ð¾Ð½ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
#: ../raster/r.recode/read_rules.c:41
-#, fuzzy, c-format
+#, c-format
msgid "Integer data range of raster map <%s> is empty"
-msgstr "Ðиапазон ÑелоÑиÑленнÑÑ
даннÑÑ
%s пÑÑÑ"
+msgstr "Ðиапазон ÑелоÑиÑленнÑÑ
даннÑÑ
#: ../raster/r.recode/read_rules.c:44
-#, fuzzy, c-format
+#, c-format
msgid "Integer data range of raster mao <%s> is %d to %d"
даннÑÑ
Ð¾Ñ %s Ñ %d до %d"
даннÑÑ
ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s> Ð¾Ñ %d до %d"
#: ../raster/r.recode/read_rules.c:63
msgid "Enter the rule or 'help' for the format description"
msgstr "ÐведиÑе пÑавило или 'help' Ð´Ð»Ñ Ð¾Ð¿Ð¸ÑÐ°Ð½Ð¸Ñ ÑоÑмаÑа"
-#: ../raster/r.recode/read_rules.c:84
+#: ../raster/r.recode/read_rules.c:87
msgid "Enter a rule in one of these formats:"
msgstr "ÐведиÑе пÑавило в одном из ÑÑиÑ
ÑоÑмаÑов:"
-#: ../raster/r.recode/read_rules.c:85
+#: ../raster/r.recode/read_rules.c:89
msgid "old_low:old_high:new_low:new_high"
msgstr "old_low:old_high:new_low:new_high"
-#: ../raster/r.recode/read_rules.c:86
+#: ../raster/r.recode/read_rules.c:90
msgid "old_low:old_high:new_val (i.e. new_high == new_low)"
msgstr "old_low:old_high:new_val (Ñ.е. new_high == new_low)"
-#: ../raster/r.recode/read_rules.c:87
+#: ../raster/r.recode/read_rules.c:91
msgid "*:old_val:new_val (interval [inf, old_val])"
msgstr "*:old_val:new_val (инÑеÑвал [inf, old_val])"
-#: ../raster/r.recode/read_rules.c:88
+#: ../raster/r.recode/read_rules.c:92
msgid "old_val:*:new_val (interval [old_val, inf])"
msgstr "old_val:*:new_val (инÑеÑвал [old_val, inf])"
-#: ../raster/r.recode/read_rules.c:127
-#, fuzzy, c-format
+#: ../raster/r.recode/read_rules.c:94
+msgid "When finished type \"end\"."
+msgstr ""
+#: ../raster/r.recode/read_rules.c:134
+#, c-format
msgid "'%s' is not a valid rule"
-msgstr "ÐÑавило %s невеÑно"
+msgstr "'%s' - невеÑное пÑавило"
#: ../raster/r.recode/main.c:42
-#, fuzzy
msgid "raster, recode category"
-msgstr "ÑаÑÑÑ, пÑоекÑиÑ"
+msgstr "ÑаÑÑÑ, пеÑекодиÑоваÑÑ ÐºÐ°ÑегоÑии"
#: ../raster/r.recode/main.c:43
msgid "Recodes categorical raster maps."
@@ -14299,9 +12147,9 @@
msgstr "ÐÑÑ
одной Ñлой Ñипа double (DCELL)"
#: ../raster/r.recode/main.c:92
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open rules file <%s>"
-msgstr "Ðевозможно найÑи Ñайл пÑавил пеÑеклаÑÑиÑикаÑии <%s>"
+msgstr "Ðевозможно найÑи Ñайл пÑавил <%s>"
#: ../raster/r.recode/main.c:98
#, c-format
@@ -14317,7 +12165,6 @@
msgstr "ÑаÑÑÑ, обÑединение"
#: ../raster/r.composite/main.c:74
-#, fuzzy
msgid ""
"Combines red, green and blue raster maps into a single composite raster map."
msgstr ""
@@ -14329,9 +12176,8 @@
msgstr "ЧиÑло ÑÑовней иÑполÑзÑемÑÑ
Ð´Ð»Ñ ÐºÐ°Ð¶Ð´Ð¾Ð³Ð¾ компоненÑа"
#: ../raster/r.composite/main.c:101 ../raster/r.composite/main.c:119
-#, fuzzy
msgid "Levels"
-msgstr "ÐодпиÑи"
+msgstr "УÑовни"
#: ../raster/r.composite/main.c:116
#, c-format
@@ -14410,7 +12256,6 @@
msgstr "Тип поÑока подземнÑÑ
вод"
#: ../raster/r.gwflow/main.c:150
-#, fuzzy
msgid "The height of the river bed in [m]"
msgstr "ÐÑÑоÑа ÑÑÑла Ñеки в [м]"
@@ -14423,7 +12268,6 @@
msgstr "ÐоÑÑÑиÑÐ¸ÐµÐ½Ñ Ð¿ÑоÑÐµÐºÐ°Ð½Ð¸Ñ Ð»Ð¾Ð¶Ð° Ñеки в [1/Ñек]."
#: ../raster/r.gwflow/main.c:173
-#, fuzzy
msgid "The height of the drainage bed in [m]"
msgstr "ÐÑÑоÑа ложа дÑенажа в [м]"
@@ -14676,12 +12520,10 @@
msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð´Ð»Ñ Ð²ÑÑ
одной вÑемени ÑаÑпÑоÑÑÑÐ°Ð½ÐµÐ½Ð¸Ñ (мин)"
#: ../raster/wildfire/r.spread/main.c:222
-#, fuzzy
msgid "Name of raster map to contain X_BACK coordinates"
msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ ÑодеÑжаÑего X_BACK кооÑдинаÑÑ"
#: ../raster/wildfire/r.spread/main.c:230
-#, fuzzy
msgid "Name of raster map to contain Y_BACK coordinates"
msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ ÑодеÑжаÑего Y_BACK кооÑдинаÑÑ"
@@ -14877,41 +12719,35 @@
msgstr "ÐÑÑ
однÑе Ñлои Ð´Ð¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ Ð¾Ð´Ð¸Ð½Ð°ÐºÐ¾Ð²Ð¾Ð³Ð¾ Ñипа. CELL, FCELL или DCELL!"
#: ../raster/r.grow.distance/main.c:132
-#, fuzzy
msgid "Generates a raster map layer of distance to features in input layer."
-msgstr ""
-"СоздаÑÑ ÑаÑÑÑовÑй Ñлой Ñ Ð¿ÑоÑÑженнÑми зонами вÑÑаÑеннÑми вокÑÑг единиÑнÑÑ
-"ÑÑеек."
+msgstr "СоздаÑÑ ÑаÑÑÑовÑй Ñлой Ñ ÑаÑÑÑоÑниÑми до обÑекÑов в иÑÑ
одном Ñлое"
#: ../raster/r.grow.distance/main.c:139
-#, fuzzy
msgid "Name for distance output map"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑлоÑ"
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑÐ»Ð¾Ñ ÑаÑÑÑоÑний"
#: ../raster/r.grow.distance/main.c:144
-#, fuzzy
msgid "Name for value output map"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑÐ»Ð¾Ñ Ð·Ð½Ð°Ñений"
#: ../raster/r.grow.distance/main.c:162
-#, fuzzy
msgid "At least one of distance= and value= must be given"
-msgstr "Ðолжна бÑÑÑ Ñказана как минимÑм одна опÑÐ¸Ñ Ð¸Ð· %s "
+msgstr "ÐÐ¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ ÑÐºÐ°Ð·Ð°Ð½Ñ ÐºÐ°Ðº минимÑм одни distance= и value="
#: ../raster/r.grow.distance/main.c:182
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create distance map <%s>"
-msgstr "Ðевозможно ÑоздаÑÑ ÑаÑÑÑовÑй Ñлой <%s>"
+msgstr "Ðевозможно ÑоздаÑÑ Ñлой ÑаÑÑÑоÑний <%s>"
#: ../raster/r.grow.distance/main.c:188
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create value map <%s>"
+msgstr "Ðевозможно ÑоздаÑÑ Ñлой знаÑений <%s>"
#: ../raster/r.grow.distance/main.c:194
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create temporary file <%s>"
-msgstr "Ðевозможно ÑоздаÑÑ Ð²ÑеменнÑй Ñайл."
+msgstr "Ðевозможно ÑоздаÑÑ Ð²ÑеменнÑй Ñайл <%s>"
#: ../raster/r.external/main.c:172
msgid ""
@@ -15018,63 +12854,39 @@
msgid "Unable to set window"
msgstr "Ðевозможно ÑÑÑановиÑÑ Ð¾ÐºÐ½Ð¾"
-#: ../raster/r.sun2/main.c:227
-#, fuzzy
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in a local text file. Alternatively, "
-"a local time can be specified to compute solar incidence angle and/or "
-"irradiance raster maps. The shadowing effect of the topography is optionally "
-"incorporated."
-msgstr ""
-"ÐÑÑиÑление пÑÑмой (лÑÑами), ÑаÑÑеÑной и оÑÑаженной оÑвеÑенноÑÑи (ÑолнÑем) "
-"ÑаÑÑÑовÑÑ
Ñлоев Ð´Ð»Ñ Ð·Ð°Ð´Ð°Ð½Ð½ÑÑ
днÑ, ÑиÑоÑÑ, повеÑÑ
ноÑÑи и ÑоÑÑоÑÐ½Ð¸Ñ Ð°ÑмоÑÑеÑÑ. "
-"ÐаÑамеÑÑÑ ÑолнÑа (напÑ.: воÑÑ
од, закаÑ, наклон, оÑвеÑенноÑÑÑ Ð²ÐµÑÑ
ниÑ
Ñлоев "
-"аÑмоÑÑеÑÑ, пÑодолжиÑелÑноÑÑÑ ÑвеÑового днÑ) ÑоÑ
ÑанÑÑÑÑÑ Ð² Ñайле иÑÑоÑии "
-"каÑÑÑ. РкаÑеÑÑве алÑÑеÑнаÑивÑ, локалÑное вÑÐµÐ¼Ñ Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð¾Ð¿Ñеделено пÑи "
-"вÑÑиÑлении Ñгла Ð¿Ð°Ð´ÐµÐ½Ð¸Ñ ÑолнеÑнÑÑ
лÑÑей и/или оÑвеÑенноÑÑи ÑаÑÑÑовÑÑ
Ñлоев. "
-"ÐÑÑÐµÐºÑ Ð·Ð°ÑÐµÐ½ÐµÐ½Ð¸Ñ ÑопогÑаÑии подклÑÑаеÑÑÑ Ð¾Ð¿ÑионалÑно."
-#: ../raster/r.sun2/main.c:272
+#: ../raster/r.sun2/main.c:261
msgid "A single value of the orientation (aspect), 270 is south"
-msgstr ""
+msgstr "Ðдиное знаÑение ÑкÑпозиÑии (аÑпекÑа), 270 - Ñг"
-#: ../raster/r.sun2/main.c:288
-#, fuzzy
+#: ../raster/r.sun2/main.c:278
msgid "A single value of inclination (slope)"
-msgstr "Ðдиное знаÑение ÑиÑоÑÑ [деÑÑÑиÑнÑе доли гÑадÑÑа]"
+msgstr "Ðдиное знаÑение Ñклона [Ñклон]"
-#: ../raster/r.sun2/main.c:351
-#, fuzzy
+#: ../raster/r.sun2/main.c:346
msgid "Name of the longitude input raster map [decimal degrees]"
-msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ ÑиÑÐ¾Ñ [деÑÑÑиÑнÑе доли гÑадÑÑа]"
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ ÑиÑÐ¾Ñ [деÑÑÑиÑнÑе гÑадÑÑÑ]"
-#: ../raster/r.sun2/main.c:360
-#, fuzzy
+#: ../raster/r.sun2/main.c:355
msgid "Name of real-sky beam radiation coefficient input raster map [-]"
msgstr ""
"ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ ÐºÐ¾ÑÑÑиÑиенÑа ÑакÑиÑеÑкого небеÑного напÑавленного "
"излÑÑÐµÐ½Ð¸Ñ [-]"
-#: ../raster/r.sun2/main.c:369
-#, fuzzy
+#: ../raster/r.sun2/main.c:364
msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
msgstr ""
"ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ ÐºÐ¾ÑÑÑиÑиенÑа ÑакÑиÑеÑкого небеÑного ÑаÑÑеÑнного "
"излÑÑÐµÐ½Ð¸Ñ [-]"
-#: ../raster/r.sun2/main.c:377
-#, fuzzy
+#: ../raster/r.sun2/main.c:372
msgid "The horizon information input map prefix"
-msgstr "ÐнÑоÑмаÑÐ¸Ñ Ð¾ пÑоекÑии не бÑÐ´ÐµÑ Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½Ð°"
+msgstr "ÐÑеÑÐ¸ÐºÑ Ð¸Ñ
одного ÑÐ»Ð¾Ñ Ð¸Ð½ÑоÑмаÑии о гоÑизонÑе"
-#: ../raster/r.sun2/main.c:385 ../raster/r.horizon/main.c:243
+#: ../raster/r.sun2/main.c:380 ../raster/r.horizon/main.c:243
msgid "Angle step size for multidirectional horizon [degrees]"
-msgstr ""
+msgstr "Шаг Ñгла Ð´Ð»Ñ Ð¼ÑлÑÑинапÑавленного гоÑизонÑа [гÑадÑÑÑ]"
-#: ../raster/r.sun2/main.c:431
+#: ../raster/r.sun2/main.c:434
#, fuzzy
msgid ""
"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
@@ -15083,88 +12895,81 @@
"ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой пÑÑмой оÑвеÑенноÑÑи [W.m-2] (меÑод 1) или "
"иÑÑадиаÑии [Wh.m-2.day-1] (меÑод 2)"
-#: ../raster/r.sun2/main.c:481 ../raster/r.horizon/main.c:318
+#: ../raster/r.sun2/main.c:487 ../raster/r.horizon/main.c:318
msgid "Sampling distance step coefficient (0.5-1.5)"
-msgstr ""
+msgstr "ÐоÑÑÑиÑÐ¸ÐµÐ½Ñ ÑаÑÑÑоÑÐ½Ð¸Ñ Ñага ÑÑмплиÑÐ¾Ð²Ð°Ð½Ð¸Ñ (0.5-1.5)"
-#: ../raster/r.sun2/main.c:489
+#: ../raster/r.sun2/main.c:495
msgid "Read the input files in this number of chunks"
-msgstr ""
+msgstr "ÐÑоÑиÑаÑÑ Ð²Ñ
однÑе ÑÐ°Ð¹Ð»Ñ Ð² ÑÑо колиÑеÑÑво блоков"
-#: ../raster/r.sun2/main.c:496
+#: ../raster/r.sun2/main.c:502
msgid "Civil time zone value, if none, the time will be local solar time"
msgstr ""
+"ÐнаÑение вÑеменной зонÑ, еÑли не Ñказано, иÑполÑзÑеÑÑÑ Ð»Ð¾ÐºÐ°Ð»Ñное ÑолнеÑное "
+"вÑемÑ"
-#: ../raster/r.sun2/main.c:507
+#: ../raster/r.sun2/main.c:513
msgid "Use the low-memory version of the program"
-msgstr ""
+msgstr "ÐÑполÑзоваÑÑ Ð²ÐµÑÑÐ¸Ñ Ð¿ÑогÑÐ°Ð¼Ð¼Ñ Ð¸ÑполÑзÑÑÑÑÑ Ð¼ÐµÐ½ÑÑе памÑÑи"
-#: ../raster/r.sun2/main.c:539
+#: ../raster/r.sun2/main.c:560
msgid "You must give the longitude raster if you use civil time"
-msgstr ""
+msgstr "ÐеобÑ
одимо ÑказаÑÑ ÑаÑÑÑ Ð´Ð¾Ð»Ð³Ð¾Ñ ÐµÑли Ð²Ñ Ð¸ÑполÑзÑеÑе гÑажданÑкое вÑемÑ"
-#: ../raster/r.sun2/main.c:578
-#, fuzzy
+#: ../raster/r.sun2/main.c:599
msgid "Error reading time step size"
-msgstr " "
+msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ Ð²ÐµÐ»Ð¸ÑÐ¸Ð½Ñ Ñага вÑемени "
-#: ../raster/r.sun2/main.c:582
-#, fuzzy
+#: ../raster/r.sun2/main.c:603
msgid "Error reading horizon step size"
-msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ Ñайла кооÑдинаÑ"
+msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ Ð²ÐµÐ»Ð¸ÑÐ¸Ð½Ñ Ñага гоÑизонÑа"
-#: ../raster/r.sun2/main.c:586
-#, fuzzy
+#: ../raster/r.sun2/main.c:607
msgid "The horizon step size must be greater than 0."
-msgstr "%s = %s -- должно бÑÑÑ Ð±Ð¾Ð»ÑÑе нÑлÑ"
+msgstr "Шаг гоÑизонÑа должен бÑÑÑ Ð±Ð¾Ð»ÑÑе 0."
-#: ../raster/r.sun2/main.c:590
+#: ../raster/r.sun2/main.c:610
msgid ""
"If you use the horizon option you must also set the 'horizonstep' parameter."
msgstr ""
+"ÐÑли иÑполÑзÑеÑÑÑ Ð¾Ð¿ÑÐ¸Ñ horizon нÑжно обÑзаÑелÑно задаÑÑ Ð¿Ð°ÑамеÑÑ "
+"'horizonstep'."
-#: ../raster/r.sun2/main.c:597
-#, fuzzy
+#: ../raster/r.sun2/main.c:617
msgid "Time and insol_time are incompatible options"
msgstr "time и insol_time ÑвлÑÑÑÑÑ Ð½ÐµÑовмеÑÑимÑми опÑиÑми"
-#: ../raster/r.sun2/main.c:598
-#, fuzzy
+#: ../raster/r.sun2/main.c:618
msgid ""
"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
"time"
msgstr ""
-"ÐеÑод 1: ÑаÑÑÐµÑ Ñгла Ð¿Ð°Ð´ÐµÐ½Ð¸Ñ ÑолнеÑнÑÑ
лÑÑей и оÑвеÑенноÑÑи Ð´Ð»Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ð¾Ð³Ð¾ "
-"локалÑного вÑемени"
+"ÐеÑод 1: Угол Ð¿Ð°Ð´ÐµÐ½Ð¸Ñ ÑолнеÑнÑÑ
лÑÑей и иÑÑадиаÑии Ð´Ð»Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ð¾Ð³Ð¾ локалÑного "
+"вÑемени"
-#: ../raster/r.sun2/main.c:603
-#, fuzzy
-msgid "incidout requres time parameter to be set"
-msgstr "incidout ÑÑебÑÐµÑ ÑÑÑановленного паÑамеÑÑа вÑемени"
-#: ../raster/r.sun2/main.c:604
-#, fuzzy
-msgid "Mode 2: integrated daily irradiation"
-msgstr "ÐеÑод 2: обÑÐ°Ñ Ð´Ð½ÐµÐ²Ð½Ð°Ñ Ð¸ÑÑадиаÑÐ¸Ñ Ð´Ð»Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ð¾Ð³Ð¾ Ð´Ð½Ñ Ð³Ð¾Ð´Ð°"
-#: ../raster/r.sun2/main.c:657
+#: ../raster/r.sun2/main.c:679
msgid "If you use -s and no horizon rasters, numpartitions must be =1"
msgstr ""
+"ÐÑли иполÑзÑеÑÑÑ -s и не иÑполÑзÑÑÑÑÑ ÑаÑÑÑÑ Ð³Ð¾ÑизонÑов, numpartitions "
+"должен бÑÑÑ =1"
-#: ../raster/r.sun2/main.c:671
+#: ../raster/r.sun2/main.c:691
msgid ""
"If you want to save memory and to use shadows, you must use pre-calculated "
"horizons."
msgstr ""
+"ÐÐ»Ñ Ñкономии памÑÑи и иÑполÑÐ·Ð¾Ð²Ð°Ð½Ð¸Ñ Ñеней, нÑжно иÑполÑзоваÑÑ Ð³Ð¾ÑизонÑÑ "
+"ÑаÑÑиÑаннÑе заÑанее."
-#: ../raster/r.sun2/main.c:945
-#, fuzzy, c-format
+#: ../raster/r.sun2/main.c:951
+#, c-format
msgid "Horizon file no. %d <%s> not found"
-msgstr "СайÑ-Ñайл <%s> не найден"
+msgstr "Файл гоÑизонÑа Ð½Ð¾Ð¼ÐµÑ %d <%s> не найден"
#: ../raster/r.horizon/main.c:180
msgid "Horizon angle computation from a digital elevation model."
-msgstr ""
+msgstr "РаÑÑÐµÑ Ñгла гоÑизонÑа на оÑнове ÑиÑÑовой модели ÑелÑеÑа."
#: ../raster/r.horizon/main.c:182
msgid ""
@@ -15176,100 +12981,113 @@
"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
"output is the horizon height in radians."
msgstr ""
+"РаÑÑÐµÑ Ð²ÑÑоÑÑ Ñгла гоÑизонÑа на оÑнове ÑиÑÑовой модели ÑелÑеÑа. ÐодÑÐ»Ñ Ð¸Ð¼ÐµÐµÑ "
+"два Ñежима ÑабоÑÑ: 1. РаÑÑиÑÑÐ²Ð°ÐµÑ Ð²ÐµÑÑ Ð³Ð¾ÑÐ¸Ð·Ð¾Ð½Ñ Ð´Ð»Ñ ÑоÑки ÑÑи кооÑдинаÑÑ "
+"Ð·Ð°Ð´Ð°Ð½Ñ Ð¾Ð¿Ñией 'coord'. ÐÑÑоÑа гоÑизонÑа задаеÑÑÑ Ð² ÑадианаÑ
. 2. РаÑÑиÑаÑÑ "
+"Ð¾Ð´Ð½Ñ Ð¸Ð»Ð¸ болÑÑе ÑаÑÑÑовÑÑ
Ñлоев вÑÑоÑÑ Ð³Ð¾ÑизонÑа в одном напÑавлении. "
+"ÐÑÑ
однÑй Ñгол (в гÑадÑÑаÑ
) измеÑÑеÑÑÑ Ð¿ÑоÑив ÑаÑовой ÑÑÑелки где воÑÑок=0, "
+"ÑевеÑ=90 и Ñ.д. ÐÑÑ
одное знаÑение вÑÑоÑÑ Ð³Ð¾ÑизонÑа в ÑадианаÑ
#: ../raster/r.horizon/main.c:235
msgid "Direction in which you want to know the horizon height"
-msgstr ""
+msgstr "Ркаком напÑавлении нÑжно ÑаÑÑÑиÑаÑÑ Ð²ÑÑоÑÑ Ð³Ð¾ÑизонÑа"
#: ../raster/r.horizon/main.c:251
msgid ""
"For horizon rasters, read from the DEM an extra buffer around the present "
"region"
msgstr ""
+"ÐÐ»Ñ ÑаÑÑÑов гоÑизонÑов, ÑÑиÑаÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ñ Ð¦ÐРиз бÑÑеÑа вокÑÑг заданного "
+"Ñегиона"
#: ../raster/r.horizon/main.c:259
msgid ""
"For horizon rasters, read from the DEM an extra buffer eastward the present "
"region"
msgstr ""
+"ÐÐ»Ñ ÑаÑÑÑов гоÑизонÑов, ÑÑиÑаÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ñ Ð¦ÐРиз бÑÑеÑа на воÑÑок Ð¾Ñ "
+"заданного Ñегиона"
#: ../raster/r.horizon/main.c:267
msgid ""
"For horizon rasters, read from the DEM an extra buffer westward the present "
"region"
msgstr ""
+"ÐÐ»Ñ ÑаÑÑÑов гоÑизонÑов, ÑÑиÑаÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ñ Ð¦ÐРиз бÑÑеÑа на запад Ð¾Ñ "
#: ../raster/r.horizon/main.c:275
msgid ""
"For horizon rasters, read from the DEM an extra buffer northward the present "
"region"
msgstr ""
+"ÐÐ»Ñ ÑаÑÑÑов гоÑизонÑов, ÑÑиÑаÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ñ Ð¦ÐРиз бÑÑеÑа на ÑÐµÐ²ÐµÑ Ð¾Ñ "
#: ../raster/r.horizon/main.c:283
msgid ""
"For horizon rasters, read from the DEM an extra buffer southward the present "
"region"
msgstr ""
+"ÐÐ»Ñ ÑаÑÑÑов гоÑизонÑов, ÑÑиÑаÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ñ Ð¦ÐРиз бÑÑеÑа на Ñг Ð¾Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ð¾Ð³Ð¾ "
+"Ñегиона"
#: ../raster/r.horizon/main.c:291
msgid "The maximum distance to consider when finding the horizon height"
-msgstr ""
+msgstr "ÐакÑималÑное ÑаÑÑÑоÑние ÑÑиÑÑваемое пÑи поиÑке вÑÑоÑÑ Ð³Ð¾ÑизонÑа"
#: ../raster/r.horizon/main.c:300
-#, fuzzy
msgid "Prefix of the horizon raster output maps"
-msgstr "ÐÑеÑÐ¸ÐºÑ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (Ñлоев)"
+msgstr "ÐÑеÑÐ¸ÐºÑ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð³Ð¾ÑизонÑа"
#: ../raster/r.horizon/main.c:310
msgid "Coordinate for which you want to calculate the horizon"
-msgstr ""
+msgstr "ÐооÑдинаÑа Ð´Ð»Ñ ÐºÐ¾ÑоÑой нÑжно ÑаÑÑÑиÑаÑÑ Ð³Ð¾ÑизонÑ"
#: ../raster/r.horizon/main.c:325
-#, fuzzy
msgid "Write output in degrees (default is radians)"
однÑÑ
изобÑажений (по ÑмолÑÐ°Ð½Ð¸Ñ = NVIZ)"
+msgstr "ÐапиÑаÑÑ ÑезÑлÑÑÐ°Ñ Ð² гÑадÑÑаÑ
(по ÑмолÑÐ°Ð½Ð¸Ñ - ÑадианÑ)"
#: ../raster/r.horizon/main.c:362
msgid "You didn't specify a direction value or step size. Aborting."
-msgstr ""
+msgstr "Ðе задано знаÑение напÑÐ°Ð²Ð»ÐµÐ½Ð¸Ñ Ð¸Ð»Ð¸ Ñаг. ÐÑÑ
од..."
#: ../raster/r.horizon/main.c:368
msgid "You didn't specify a horizon raster name. Aborting."
-msgstr ""
+msgstr "Ðе задано Ð¸Ð¼Ñ ÑаÑÑÑа гоÑизонÑа. ÐÑÑ
од..."
#: ../raster/r.horizon/main.c:379
msgid "You didn't specify an angle step size. Aborting."
-msgstr ""
+msgstr "Ðе задан Ñаг Ñгла. ÐÑÑ
од"
#: ../raster/r.horizon/main.c:393
-#, fuzzy
msgid "Could not read bufferzone size. Aborting."
-msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñайл диапазона"
+msgstr "Ðевозможно пÑоÑиÑаÑÑ ÑÐ°Ð·Ð¼ÐµÑ Ð±ÑÑеÑной зонÑ. ÐÑÑ
од"
#: ../raster/r.horizon/main.c:399
msgid "Could not read east bufferzone size. Aborting."
-msgstr ""
+msgstr "Ðевозможно пÑоÑиÑаÑÑ Ð²Ð¾ÑÑоÑнÑй ÑÐ°Ð·Ð¼ÐµÑ Ð±ÑÑеÑной зонÑ. ÐÑÑ
од"
#: ../raster/r.horizon/main.c:405
msgid "Could not read west bufferzone size. Aborting."
-msgstr ""
+msgstr "Ðевозможно пÑоÑиÑаÑÑ Ð·Ð°Ð¿Ð°Ð´Ð½Ñй ÑÐ°Ð·Ð¼ÐµÑ Ð±ÑÑеÑной зонÑ. ÐÑÑ
од"
#: ../raster/r.horizon/main.c:412
msgid "Could not read south bufferzone size. Aborting."
-msgstr ""
+msgstr "Ðевозможно пÑоÑиÑаÑÑ ÑжнÑй ÑÐ°Ð·Ð¼ÐµÑ Ð±ÑÑеÑной зонÑ. ÐÑÑ
од"
#: ../raster/r.horizon/main.c:421
msgid "Could not read north bufferzone size. Aborting."
-msgstr ""
+msgstr "Ðевозможно пÑоÑиÑаÑÑ ÑевеÑнÑй ÑÐ°Ð·Ð¼ÐµÑ Ð±ÑÑеÑной зонÑ. ÐÑÑ
од"
#: ../raster/r.horizon/main.c:427
msgid "Could not read maximum distance. Aborting."
-msgstr ""
+msgstr "Ðевозможно пÑоÑиÑаÑÑ Ð¼Ð°ÐºÑималÑное ÑаÑÑÑоÑние. ÐÑÑ
од"
#: ../raster/r.horizon/main.c:1144
-#, fuzzy, c-format
+#, c-format
msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+msgstr "РаÑÑÐµÑ ÑÐ»Ð¾Ñ %01d из %01d (Ñгол %lf, ÑаÑÑÑовÑй Ñлой <%s>)"
#: ../vector/v.net.visibility/main.c:46
msgid "vector, path, visibility"
@@ -15292,11 +13110,11 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:180
#: ../vector/lidar/v.lidar.correction/main.c:151
#: ../vector/lidar/v.lidar.growing/main.c:127
-#: ../vector/lidar/v.lidar.growing/main.c:130 ../vector/v.out.ascii/out.c:145
+#: ../vector/lidar/v.lidar.growing/main.c:130 ../vector/v.out.ascii/out.c:146
#: ../vector/v.generalize/main.c:305 ../vector/v.net/main.c:164
-#: ../vector/v.support/main.c:135 ../vector/v.surf.rst/main.c:541
-#: ../vector/v.surf.rst/main.c:696 ../vector/v.surf.rst/main.c:785
-#: ../vector/v.to.3d/main.c:71 ../vector/v.buffer2/main.c:274
+#: ../vector/v.support/main.c:135 ../vector/v.surf.rst/main.c:548
+#: ../vector/v.surf.rst/main.c:703 ../vector/v.surf.rst/main.c:792
+#: ../vector/v.to.3d/main.c:71 ../vector/v.buffer2/main.c:301
#: ../doc/vector/v.example/main.c:85 ../display/d.what.vect/main.c:126
#, c-format
msgid "Unable to open vector map <%s>"
@@ -15311,6 +13129,11 @@
msgid "Lat-long projection"
msgstr "ÐÑоекÑÐ¸Ñ lat-long"
+#: ../vector/v.db.connect/main.c:50 ../vector/v.distance/main.c:115
+#: ../vector/v.db.select/main.c:52 ../vector/v.to.db/main.c:32
+msgid "vector, database, attribute table"
+msgstr "векÑоÑ, база даннÑÑ
, аÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
#: ../vector/v.db.connect/main.c:52
msgid "Prints/sets DB connection for a vector map to attribute table."
msgstr ""
@@ -15321,7 +13144,7 @@
msgid "Key column name"
msgstr "ÐÐ¼Ñ ÐºÐ»ÑÑевого полÑ"
-#: ../vector/v.db.connect/main.c:71 ../vector/v.in.db/main.c:85
+#: ../vector/v.db.connect/main.c:71 ../vector/v.in.db/main.c:87
msgid "Must refer to an integer column"
msgstr "Ðолжен ÑÑÑлаÑÑÑÑ Ð½Ð° ÑÑÐ¾Ð»Ð±ÐµÑ Ñ ÑелÑми ÑиÑлами"
@@ -15367,7 +13190,7 @@
msgid "Vector map <%s> is connected by:"
msgstr "ÐекÑоÑнÑй Ñлой <%s> пÑиÑоединен к:"
-#: ../vector/v.db.connect/main.c:157 ../display/d.what.vect/what.c:435
+#: ../vector/v.db.connect/main.c:157 ../display/d.what.vect/what.c:446
#: ../display/d.vect/main.c:495 ../display/d.thematic.area/main.c:227
#, c-format
msgid "Database connection not defined"
@@ -15384,7 +13207,7 @@
#: ../vector/v.db.connect/main.c:185 ../vector/v.edit/select.c:506
#: ../vector/lidar/v.surf.bspline/crosscorr.c:112
#: ../vector/v.distance/main.c:355 ../vector/v.distance/main.c:391
-#: ../vector/v.reclass/main.c:121 ../vector/v.out.ascii/b2a.c:37
+#: ../vector/v.reclass/main.c:121 ../vector/v.out.ascii/b2a.c:38
#: ../vector/v.db.select/main.c:136 ../vector/v.what.rast/main.c:126
#: ../vector/v.extrude/main.c:162 ../vector/v.sample/main.c:167
#: ../vector/v.generalize/misc.c:160 ../vector/v.info/main.c:200
@@ -15392,7 +13215,7 @@
#: ../vector/v.to.rast/support.c:126 ../vector/v.to.rast/support.c:277
#: ../vector/v.to.rast/vect2rast.c:51 ../vector/v.drape/main.c:271
#: ../vector/v.extract/main.c:278 ../vector/v.to.3d/trans2.c:44
-#: ../vector/v.to.3d/trans3.c:45 ../vector/v.buffer2/main.c:287
+#: ../vector/v.to.3d/trans3.c:45 ../vector/v.buffer2/main.c:314
#: ../doc/vector/v.example/main.c:103 ../display/d.vect/plot1.c:197
#: ../display/d.vect/area.c:54 ../display/d.vect.chart/plot.c:38
#: ../display/d.thematic.area/plot1.c:193
@@ -15411,12 +13234,12 @@
msgstr "ТаблиÑа <%s> не ÑÑÑеÑÑвÑÐµÑ Ð² базе даннÑÑ
<%s>"
#: ../vector/v.db.connect/main.c:261 ../vector/v.transform/trans_digit.c:93
-#: ../vector/v.in.db/main.c:137
+#: ../vector/v.in.db/main.c:138
#, c-format
msgid "Missing column <%s> in table <%s>"
msgstr "Ðоле <%s> оÑÑÑÑÑÑвÑÐµÑ Ð² ÑаблиÑе <%s>"
-#: ../vector/v.db.connect/main.c:267 ../vector/v.in.db/main.c:140
+#: ../vector/v.db.connect/main.c:267 ../vector/v.in.db/main.c:141
msgid "Data type of key column must be integer"
msgstr "Тип даннÑÑ
клÑÑевого Ð¿Ð¾Ð»Ñ Ð´Ð¾Ð»Ð¶ÐµÐ½ бÑÑÑ ÑелÑм ÑиÑлом"
@@ -15475,7 +13298,7 @@
msgid "Unable to get layer info for vector map"
msgstr "Ðевозможно полÑÑиÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ Ñлое Ð´Ð»Ñ Ð²ÐµÐºÑоÑной каÑÑÑ"
-#: ../vector/v.to.rast3/main.c:96 ../vector/lidar/v.surf.bspline/main.c:317
+#: ../vector/v.to.rast3/main.c:96 ../vector/lidar/v.surf.bspline/main.c:320
#: ../vector/v.univar/main.c:159 ../vector/v.class/main.c:126
#: ../vector/v.sample/main.c:185 ../vector/v.surf.idw/read_sites.c:52
#: ../vector/v.normal/main.c:154 ../vector/v.buffer/main.c:397
@@ -15486,10 +13309,10 @@
#: ../vector/v.to.rast3/main.c:100
#: ../vector/lidar/v.surf.bspline/crosscorr.c:131
-#: ../vector/lidar/v.surf.bspline/main.c:314 ../vector/v.univar/main.c:156
+#: ../vector/lidar/v.surf.bspline/main.c:317 ../vector/v.univar/main.c:156
#: ../vector/v.class/main.c:123 ../vector/v.what.rast/main.c:158
#: ../vector/v.sample/main.c:266 ../vector/v.surf.idw/read_sites.c:49
-#: ../vector/v.buffer/main.c:402 ../vector/v.buffer2/main.c:308
+#: ../vector/v.buffer/main.c:402 ../vector/v.buffer2/main.c:335
msgid "Column type not supported"
msgstr "Тип даннÑÑ
ÑÑолбÑа не поддеÑживаеÑÑÑ"
@@ -15497,8 +13320,8 @@
msgid "Unable to create output map"
msgstr "Ðевозможно ÑоздаÑÑ Ð²ÑÑ
одной Ñлой"
-#: ../vector/v.to.rast3/main.c:150 ../vector/v.to.rast/do_lines.c:49
-#: ../vector/v.to.rast/do_lines.c:57
+#: ../vector/v.to.rast3/main.c:150 ../vector/v.to.rast/do_lines.c:51
+#: ../vector/v.to.rast/do_lines.c:59
#, c-format
msgid "No record for line (cat = %d)"
msgstr "ÐÐµÑ Ð·Ð°Ð¿Ð¸Ñи Ð´Ð»Ñ Ð»Ð¸Ð½Ð¸Ð¸ (cat = %d)"
@@ -15507,6 +13330,17 @@
msgid "Unable to close new 3d raster map"
msgstr "Ðевозможно закÑÑÑÑ Ð½Ð¾Ð²Ñй 3d ÑаÑÑÑовÑй Ñлой"
+#: ../vector/v.external/main.c:58 ../vector/v.perturb/main.c:73
+#: ../vector/v.sample/main.c:86 ../vector/v.in.region/main.c:38
+#: ../vector/v.info/main.c:257 ../vector/v.patch/main.c:68
+#: ../vector/v.vol.rst/main.c:202 ../vector/v.mkgrid/main.c:63
+#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.voronoi/dt_main.c:46
+#: ../vector/v.voronoi/vo_main.c:119 ../vector/v.out.vtk/main.c:46
+#: ../vector/v.surf.rst/main.c:160 ../vector/v.buffer/main.c:254
+#: ../vector/v.delaunay2/main.c:62
+msgid "vector"
+msgstr "векÑоÑ"
#: ../vector/v.external/main.c:60
msgid "Creates a new vector as a read-only link to OGR layer."
msgstr "СоздаÑÑ Ð½Ð¾Ð²Ñй векÑÐ¾Ñ ÐºÐ°Ðº ÑÑÑÐ»ÐºÑ (ÑолÑко Ð´Ð»Ñ ÑÑениÑ) на Ñлой OGR."
@@ -15664,7 +13498,7 @@
msgid "Unable to get category list <%s>"
msgstr "Ðевозможно полÑÑиÑÑ ÑпиÑок каÑегоÑий <%s>"
-#: ../vector/v.edit/main.c:77 ../vector/v.in.ascii/in.c:201
+#: ../vector/v.edit/main.c:77 ../vector/v.in.ascii/in.c:204
#, c-format
msgid "Unable to open ASCII file <%s>"
msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл ASCII <%s>"
@@ -15686,13 +13520,13 @@
msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s> на ÑÑовне Ñопологии %d"
#: ../vector/v.edit/main.c:148
-#, fuzzy, c-format
+#, c-format
msgid ""
"Unable to open vector map <%s> as the background map. It is given as vector "
"map to be edited."
msgstr ""
-"Ðевозможно оÑкÑÑÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s> как Ñон каÑÑÑ. ÐекÑоÑнÑй Ñлой задан "
-"как ÑедакÑиÑÑемÑй."
+"Ðевозможно оÑкÑÑÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s> как ÑоновÑй. ÐекÑоÑнÑй Ñлой задан как "
+"ÑедакÑиÑÑемÑй."
#: ../vector/v.edit/main.c:163
#, c-format
@@ -15700,9 +13534,8 @@
msgstr "ФоновÑй векÑоÑнÑй Ñлой <%s> заÑегиÑÑÑиÑован"
#: ../vector/v.edit/main.c:203
-#, fuzzy
msgid "Selecting features..."
-msgstr "Ð¡Ð±Ð¾Ñ ÑÑаÑиÑÑики..."
+msgstr "ÐÑделение обÑекÑов..."
#: ../vector/v.edit/main.c:215
msgid "No features selected, nothing to edit"
@@ -15804,9 +13637,9 @@
msgstr "%d линий помеÑено"
#: ../vector/v.edit/main.c:387
-#, fuzzy, c-format
+#, c-format
msgid "%d features converted"
-msgstr "%d обÑекÑов пеÑемеÑено"
+msgstr "%d обÑекÑов конвеÑÑиÑовано"
#: ../vector/v.edit/main.c:390
msgid "No feature modified"
@@ -15830,20 +13663,21 @@
#: ../vector/v.in.ogr/main.c:130 ../vector/v.in.ogr/main.c:144
#: ../vector/v.in.ogr/main.c:166 ../vector/v.category/main.c:92
#: ../vector/v.category/main.c:97 ../vector/v.category/main.c:101
-#: ../vector/v.select/main.c:147 ../vector/v.select/main.c:152
-#: ../vector/v.select/main.c:161 ../vector/v.select/main.c:166
-#: ../vector/v.select/main.c:191 ../vector/v.extract/main.c:107
+#: ../vector/v.select/args.c:16 ../vector/v.select/args.c:21
+#: ../vector/v.select/args.c:30 ../vector/v.select/args.c:35
+#: ../vector/v.select/args.c:83 ../vector/v.surf.rst/main.c:210
+#: ../vector/v.surf.rst/main.c:213 ../vector/v.extract/main.c:107
#: ../vector/v.extract/main.c:117 ../vector/v.extract/main.c:123
#: ../vector/v.extract/main.c:127 ../vector/v.extract/main.c:130
#: ../vector/v.extract/main.c:138 ../vector/v.extract/main.c:148
+#: ../vector/v.buffer2/main.c:156 ../vector/v.buffer2/main.c:159
#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:150
#: ../display/d.vect/main.c:153 ../display/d.vect/main.c:156
#: ../display/d.vect/main.c:358 ../display/d.thematic.area/main.c:131
#: ../display/d.thematic.area/main.c:134 ../display/d.rast/main.c:67
#: ../display/d.rast/main.c:76 ../display/d.rast/main.c:93
-#, fuzzy
msgid "Selection"
-msgstr "РазÑеÑение"
+msgstr "ÐÑбоÑ"
#: ../vector/v.edit/args.c:54
msgid "Tool"
@@ -15920,7 +13754,6 @@
"'длинного'"
#: ../vector/v.edit/args.c:170
-#, fuzzy
msgid ""
"length;Select only lines or boundaries shorter/longer than threshold "
"distance;dangle;Select dangles shorter/longer than threshold distance"
@@ -15957,7 +13790,7 @@
msgid "Pair: value,step (e.g. 1100,10)"
msgstr "ÐаÑа: знаÑение,Ñаг (напÑÐ¸Ð¼ÐµÑ 1100,10)"
-#: ../vector/v.edit/args.c:201 ../vector/v.select/main.c:190
+#: ../vector/v.edit/args.c:201 ../vector/v.select/args.c:82
#: ../vector/v.extract/main.c:106
msgid "Reverse selection"
msgstr "ÐбÑаÑиÑÑ Ð²Ñделение"
@@ -16036,7 +13869,7 @@
msgid "Layer %d: %s"
msgstr "Слой %d: %s"
-#: ../vector/v.in.dxf/write_vect.c:219
+#: ../vector/v.in.dxf/write_vect.c:230
#, c-format
msgid "Unable to add database link for vector map <%s>"
msgstr "Ðевозможно добавиÑÑ ÑвÑÐ·Ñ Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
Ð´Ð»Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ <%s>"
@@ -16045,6 +13878,11 @@
msgid "end of file while looking for HEADER"
msgstr "ÐºÐ¾Ð½ÐµÑ Ñайла в пÑоÑеÑÑе поиÑка ÐÐÐÐÐÐÐÐÐ"
+#: ../vector/v.in.dxf/main.c:60 ../vector/v.in.ascii/in.c:48
+#: ../vector/v.in.ogr/main.c:101 ../vector/v.in.dwg/main.c:65
+msgid "vector, import"
+msgstr "векÑоÑ, импоÑÑ"
#: ../vector/v.in.dxf/main.c:62
msgid "Converts files in DXF format to GRASS vector map format."
msgstr "ÐонвеÑÑиÑование Ñайлов в ÑоÑмаÑе DXF в векÑоÑнÑе Ñлои GRASS."
@@ -16061,6 +13899,10 @@
msgid "Import polyface meshes as 3D wire frame"
msgstr "ÐмпоÑÑиÑоваÑÑ Ð¼Ð½Ð¾Ð³Ð¾Ð³ÑаннÑе меÑи как 3D каÑкаÑÑ"
+#: ../vector/v.in.dxf/main.c:82 ../vector/v.in.dwg/main.c:96
+msgid "List available layers and exit"
+msgstr "ÐоказаÑÑ Ð´Ð¾ÑÑÑпнÑе Ñлои и вÑйÑи"
#: ../vector/v.in.dxf/main.c:83 ../vector/v.in.dxf/main.c:89
#: ../vector/v.in.dxf/main.c:94 ../vector/v.in.dxf/main.c:108
msgid "DXF layers"
@@ -16165,14 +14007,12 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:86
#: ../vector/lidar/v.lidar.correction/main.c:90
#: ../vector/lidar/v.outlier/main.c:95
-#: ../vector/lidar/v.surf.bspline/main.c:110
msgid "Interpolation spline step value in east direction"
msgstr "ÐнаÑение Ñага инÑеÑполÑÑии Ñплайна в воÑÑоÑном напÑавлении"
#: ../vector/lidar/v.lidar.edgedetection/main.c:95
#: ../vector/lidar/v.lidar.correction/main.c:98
#: ../vector/lidar/v.outlier/main.c:103
-#: ../vector/lidar/v.surf.bspline/main.c:120
msgid "Interpolation spline step value in north direction"
msgstr "ÐнаÑение Ñага инÑеÑполÑÑии Ñплайна в ÑевеÑном напÑавлении"
@@ -16198,13 +14038,13 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:157
#: ../vector/lidar/v.outlier/main.c:126
-#: ../vector/lidar/v.surf.bspline/main.c:183
+#: ../vector/lidar/v.surf.bspline/main.c:186
msgid "Unable to read name of database"
msgstr "Ðевозможно полÑÑиÑÑ Ð¸Ð¼Ñ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
#: ../vector/lidar/v.lidar.edgedetection/main.c:160
#: ../vector/lidar/v.outlier/main.c:129
-#: ../vector/lidar/v.surf.bspline/main.c:186
+#: ../vector/lidar/v.surf.bspline/main.c:189
msgid "Unable to read name of driver"
msgstr "Ðевозможно опÑеделиÑÑ Ð¸Ð¼Ñ Ð´ÑайвеÑа"
@@ -16212,8 +14052,8 @@
#: ../vector/lidar/v.lidar.correction/main.c:176
#: ../vector/lidar/v.outlier/main.c:188
#: ../vector/lidar/v.lidar.growing/main.c:151
-#: ../vector/lidar/v.surf.bspline/main.c:201
-#: ../vector/lidar/v.surf.bspline/main.c:359
+#: ../vector/lidar/v.surf.bspline/main.c:204
+#: ../vector/lidar/v.surf.bspline/main.c:372
#, c-format
msgid "No database connection for driver <%s> is defined. Run db.connect."
msgstr ""
@@ -16259,7 +14099,6 @@
msgstr "ÐикÑбиÑеÑÐºÐ°Ñ Ð¸Ð½ÑеÑполÑÑиÑ"
#: ../vector/lidar/v.lidar.edgedetection/main.c:342
-#, fuzzy
msgid "Creating auxiliar table for archiving overlapping zones"
msgstr "Создание дополниÑелÑной ÑаблиÑÑ Ð´Ð»Ñ Ð½Ð°Ñ
Ð¾Ð¶Ð´ÐµÐ½Ð¸Ñ Ð·Ð¾Ð½ пеÑеÑеÑений"
@@ -16281,7 +14120,7 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:370
#: ../vector/lidar/v.lidar.correction/main.c:335
#: ../vector/lidar/v.outlier/main.c:345
-#: ../vector/lidar/v.surf.bspline/main.c:687
+#: ../vector/lidar/v.surf.bspline/main.c:714
msgid "Auxiliar table could not be dropped"
msgstr "ÐополниÑелÑÐ½Ð°Ñ ÑаблиÑа не Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ñдалена"
@@ -16352,6 +14191,13 @@
msgid "Correction and creation of terrain vector"
msgstr "Ðзменение и Ñоздание векÑоÑа ÑелÑеÑа"
+#: ../vector/lidar/v.outlier/main.c:66 ../vector/v.univar/main.c:64
+#: ../vector/v.class/main.c:45 ../vector/v.qcount/main.c:69
+#: ../vector/v.random/main.c:84 ../vector/v.kcv/main.c:76
+#: ../vector/v.normal/main.c:79
+msgid "vector, statistics"
+msgstr "векÑоÑ, ÑÑаÑиÑÑика"
#: ../vector/lidar/v.outlier/main.c:67
msgid "Removes outliers from vector point data."
msgstr "Удаление вÑбÑоÑов из даннÑÑ
векÑоÑнÑÑ
ÑоÑек."
@@ -16365,8 +14211,8 @@
msgstr "ÐÐ¼Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ Ð´Ð»Ñ Ð²Ð¸Ð·ÑализаÑии в QGIS"
#: ../vector/lidar/v.outlier/main.c:109
-#: ../vector/lidar/v.surf.bspline/main.c:138
-msgid "Tychonov regularization weight"
+#, fuzzy
+msgid "Tykhonov regularization weight"
msgstr "ÐÐµÑ ÑегÑлÑÑизаÑии ТиÑ
онова"
#: ../vector/lidar/v.outlier/main.c:116
@@ -16374,8 +14220,8 @@
msgstr "ÐÑаниÑнÑе знаÑÐµÐ½Ð¸Ñ Ð´Ð»Ñ Ð²ÑбÑоÑов"
#: ../vector/lidar/v.outlier/main.c:167
-#: ../vector/lidar/v.surf.bspline/main.c:228
-#: ../vector/lidar/v.surf.bspline/main.c:248
+#: ../vector/lidar/v.surf.bspline/main.c:231
+#: ../vector/lidar/v.surf.bspline/main.c:251
#, c-format
msgid "Unable to open vector map <%s> at the topological level"
msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s> на ÑÑовне Ñопологии"
@@ -16398,7 +14244,6 @@
msgstr "ÐÐ¼Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ Ð¿ÐµÑвого пÑлÑÑа"
#: ../vector/lidar/v.lidar.growing/main.c:96
-#, fuzzy
msgid "Threshold for cell object frequency in region growing"
msgstr "ÐоÑог Ð´Ð»Ñ ÑаÑÑоÑÑ Ð¾Ð±ÑекÑа ÑÑейки в вÑÑаÑивании Ñегиона"
@@ -16412,8 +14257,9 @@
msgstr "УÑÑановки Ñегионов и пÑÑмоÑголÑников"
#: ../vector/lidar/v.lidar.growing/main.c:176
-msgid "It was impossible to open table"
-msgstr "Ðевозможно оÑкÑÑÑÑ ÑаблиÑÑ "
+#, fuzzy, c-format
+msgid "Unable to create table <%s_edge_Interpolation>"
+msgstr "Ðевозможно ÑоздаÑÑ ÑаблиÑÑ: <%s>"
#: ../vector/lidar/v.lidar.growing/main.c:223
#, c-format
@@ -16430,25 +14276,23 @@
msgstr "...вÑÑ
одим в ÑиÑÑемÑ..."
#: ../vector/lidar/v.surf.bspline/crosscorr.c:75
-#, fuzzy, c-format
+#, c-format
msgid "%d are too many points. The cross validation would take too much time."
msgstr ""
-"CrossCorrelation: %d ÑлиÑком много ÑоÑек. ÐеÑекÑеÑÑÐ½Ð°Ñ Ð¿ÑовеÑка Ð·Ð°Ð¹Ð¼ÐµÑ "
-"ÑлиÑком много вÑемени."
+"%d ÑлиÑком много ÑоÑек. ÐеÑекÑеÑÑÐ½Ð°Ñ Ð¿ÑовеÑка Ð·Ð°Ð¹Ð¼ÐµÑ ÑлиÑком много вÑемени."
#: ../vector/lidar/v.surf.bspline/crosscorr.c:84
-#, fuzzy, c-format
+#, c-format
msgid "%d points read in region"
-msgstr "%lu ÑоÑек найдено в Ñегионе."
+msgstr "%d ÑоÑек найдено в Ñегионе."
#: ../vector/lidar/v.surf.bspline/crosscorr.c:88
-#, fuzzy
msgid ""
"Maybe, it takes too long. It will depend on how many points you are "
"considering."
msgstr ""
-"CrossCorrelation: Ðозможно, Ð·Ð°Ð½Ð¸Ð¼Ð°ÐµÑ ÑлиÑком много вÑемени. ÐÑо завиÑÐ¸Ñ Ð¾Ñ "
-"Ñого, ÑколÑко ÑоÑек ÐÑ ÑаÑÑмаÑÑиваеÑе."
+"Ðозможно, Ð·Ð°Ð½Ð¸Ð¼Ð°ÐµÑ ÑлиÑком много вÑемени. ÐÑо завиÑÐ¸Ñ Ð¾Ñ Ñого, ÑколÑко "
+"ÑаÑÑмаÑÑиваеÑÑÑ ÑоÑек."
#: ../vector/lidar/v.surf.bspline/crosscorr.c:117
#, c-format
@@ -16456,23 +14300,22 @@
msgstr "CrossCorrelation: дÑайвеÑ=%s ÐÐ=%s"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:134
-#, fuzzy, c-format
+#, c-format
msgid "No records selected from table <%s> "
msgstr "Ðе вÑбÑано запиÑей из ÑаблиÑÑ <%s>"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:149
-#, fuzzy, c-format
+#, c-format
msgid ""
"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
msgstr ""
-"CrossCorrelation: СлиÑком много Ñплайнов (%d x %d). ÐÑедлагаем измениÑÑ Ñаг "
-"Ñплайна \"sie=\" \"sin=\"."
+"СлиÑком много Ñплайнов (%d x %d). ÐÑедлагаем измениÑÑ Ñаг Ñплайна \"sie=\" "
+"\"sin=\"."
#: ../vector/lidar/v.surf.bspline/crosscorr.c:167
-#, fuzzy, c-format
+#, c-format
msgid "Begining cross validation with lambda_i=%.4f..."
-msgstr ""
-"CrossCorrelation: ÐеÑекÑеÑÑÐ½Ð°Ñ Ð¿ÑовеÑка наÑинаеÑÑÑ Ñ lambda_i=%.4f ...\n"
+msgstr "ÐаÑало пеÑекÑеÑÑной пÑовеÑки Ñ lambda_i=%.4f..."
#: ../vector/lidar/v.surf.bspline/crosscorr.c:217
#: ../vector/v.surf.idw/read_sites.c:86
@@ -16483,82 +14326,99 @@
#: ../vector/lidar/v.surf.bspline/crosscorr.c:287
#, c-format
msgid "Mean = %.5lf"
-msgstr ""
+msgstr "СÑеднее = %.5lf"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:288
-#, fuzzy, c-format
+#, c-format
msgid "Root Means Square (RMS) = %.5lf"
-msgstr "CrossCorrelation: СÑеднеквадÑаÑиÑеÑкое (RMS) = %.5lf\n"
+msgstr "СÑеднеквадÑаÑиÑеÑÐºÐ°Ñ Ð¾Ñибка (RMS) = %.5lf"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:304
-#, fuzzy
msgid ""
"Different number of splines and lambda_i values have been taken for the "
"cross correlation"
msgstr ""
-"CrossCorrelation: РазлиÑаеÑÑÑ ÐºÐ¾Ð»Ð¸ÑеÑÑво Ñплайнов и знаÑений lambda_i "
-"назнаÑеннÑÑ
на пеÑекÑеÑÑнÑÑ Ð¿ÑовеÑкÑ\n"
+"РазлиÑаеÑÑÑ ÐºÐ¾Ð»Ð¸ÑеÑÑво Ñплайнов и знаÑений lambda_i иÑполÑзÑемÑÑ
в "
+"пеÑекÑеÑÑной пÑовеÑке"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:306
-#, fuzzy, c-format
+#, c-format
msgid ""
"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
msgstr ""
-"CrossCorrelation: ÐинималÑное знаÑение Ð´Ð»Ñ ÑеÑÑа (rms=%lf) бÑло полÑÑено Ñ:\n"
+"ÐинималÑное знаÑение Ð´Ð»Ñ ÑеÑÑа (rms=%lf) бÑло полÑÑено Ñ: lambda_i = %.3f"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:314
-#, fuzzy
msgid "Results into a table:"
-msgstr "ТепеÑÑ, ÑезÑлÑÑаÑÑ Ð² ÑаблиÑÑ:\n"
+msgstr "РезÑлÑÑаÑÑ Ð² ÑаблиÑÑ:"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:315
-#, fuzzy
msgid " lambda | mean | rms |"
-msgstr " lambda | mean | rms |\n"
+msgstr " lambda | mean | rms |"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:317
-#, fuzzy, c-format
+#, c-format
msgid " %-10.5f| %-12.4f| %-12.4f|"
-msgstr " %-10.5f| %-12.4f| %-12.4f|\n"
+msgstr " %-10.5f| %-12.4f| %-12.4f|"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:325
-#, fuzzy
msgid "No point lies into the current region"
-msgstr "CrossCorrelation: Ðи одна ÑоÑка не наÑ
одиÑÑÑ Ð² ÑекÑÑем Ñегионе"
+msgstr "Ð ÑекÑÑем Ñегионе не найдено ни одной ÑоÑки "
-#: ../vector/lidar/v.surf.bspline/main.c:77 ../vector/v.surf.idw/main.c:84
+#: ../vector/lidar/v.surf.bspline/main.c:79 ../vector/v.surf.idw/main.c:84
msgid "vector, interpolation"
msgstr "векÑоÑ, инÑеÑполÑÑиÑ"
-#: ../vector/lidar/v.surf.bspline/main.c:79
+#: ../vector/lidar/v.surf.bspline/main.c:81
msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
msgstr ""
"ÐикÑбиÑеÑÐºÐ°Ñ Ð¸Ð»Ð¸ Ð±Ð¸Ð»Ð¸Ð½ÐµÐ¹Ð½Ð°Ñ Ð¸Ð½ÑеÑполÑÑÐ¸Ñ Ñплайна Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ ÑегÑлÑÑизаÑии "
"ТиÑ
онова."
-#: ../vector/lidar/v.surf.bspline/main.c:85
-msgid "Find best parameters using a cross validation method"
+#: ../vector/lidar/v.surf.bspline/main.c:87
+#, fuzzy
+msgid ""
+"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
+"cross validation method"
msgstr "ÐоиÑк лÑÑÑиÑ
паÑамеÑÑов поÑÑедÑÑвом меÑода пеÑекÑеÑÑной пÑовеÑки"
-#: ../vector/lidar/v.surf.bspline/main.c:94
+#: ../vector/lidar/v.surf.bspline/main.c:96
msgid "Name of input vector map of sparse points"
msgstr "Ðазвание иÑÑ
одного векÑоÑного ÑÐ»Ð¾Ñ ÑазÑеженнÑÑ
ÑоÑек"
-#: ../vector/lidar/v.surf.bspline/main.c:128
-msgid "Spline type of interpolation"
-msgstr "Сплайн инÑеÑполÑÑиÑ"
+#: ../vector/lidar/v.surf.bspline/main.c:112
+#, fuzzy
+msgid "Length of each spline step in the east-west direction"
+msgstr "ÐнаÑение Ñага инÑеÑполÑÑии Ñплайна в воÑÑоÑном напÑавлении"
-#: ../vector/lidar/v.surf.bspline/main.c:145 ../vector/v.surf.rst/main.c:206
+#: ../vector/lidar/v.surf.bspline/main.c:122
+#, fuzzy
+msgid "Length of each spline step in the north-south direction"
+msgstr "ÐнаÑение Ñага инÑеÑполÑÑии Ñплайна в ÑевеÑном напÑавлении"
+#: ../vector/lidar/v.surf.bspline/main.c:130
+#, fuzzy
+msgid "Spline interpolation algorithm"
+msgstr "ÐлгоÑиÑм генеÑализаÑии"
+#: ../vector/lidar/v.surf.bspline/main.c:140
+#, fuzzy
+msgid "Tykhonov regularization parameter (affects smoothing)"
+msgstr "ÐÐµÑ ÑегÑлÑÑизаÑии ТиÑ
онова"
+#: ../vector/lidar/v.surf.bspline/main.c:147 ../vector/v.surf.rst/main.c:207
+#, fuzzy
msgid "If set to 0, z coordinates are used. (3D vector only)"
msgstr ""
-"ÐÑли ÑÑÑановлено в 0, иÑполÑзÑÑÑÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ z (ÑолÑко 3D векÑоÑ)"
+"ÐÑли ÑÑÑановлено в 0, иÑполÑзÑеÑÑÑ ÑолÑко кооÑдинаÑа z (ÑолÑко ÑÑеÑ
меÑнÑй "
+"векÑоÑнÑй Ñлой)"
-#: ../vector/lidar/v.surf.bspline/main.c:155
+#: ../vector/lidar/v.surf.bspline/main.c:158
msgid "Attribute table column with values to interpolate (if layer>0)"
msgstr ""
"Ðоле аÑÑибÑÑивной ÑаблиÑÑ Ñ Ð¸Ð½ÑеÑполиÑÑемÑми знаÑениÑми (еÑли layer>0)"
-#: ../vector/lidar/v.surf.bspline/main.c:209
+#: ../vector/lidar/v.surf.bspline/main.c:212
#, c-format
msgid ""
"It was not possible to drop <%s> table. Nothing will be done. Try to drop it "
@@ -16567,28 +14427,29 @@
"Ðевозможно ÑдалиÑÑ <%s> ÑаблиÑÑ. ÐпеÑаÑÐ¸Ñ Ð½Ðµ бÑÐ´ÐµÑ Ð¿Ñоизведена. ÐопÑобÑйÑе "
"ÑдалиÑÑ Ð²ÑÑÑнÑÑ."
-#: ../vector/lidar/v.surf.bspline/main.c:217
+#: ../vector/lidar/v.surf.bspline/main.c:220
msgid "Choose either vector or raster output, not both"
msgstr "ÐÑбеÑиÑе либо векÑоÑнÑй, либо ÑаÑÑÑовÑй вÑвод, но не оба"
-#: ../vector/lidar/v.surf.bspline/main.c:220
+#: ../vector/lidar/v.surf.bspline/main.c:223
msgid "No raster nor vector output"
-#: ../vector/lidar/v.surf.bspline/main.c:234
-#, c-format
+#: ../vector/lidar/v.surf.bspline/main.c:237
+#, fuzzy, c-format
msgid ""
-"No vector map to interpolate. Interpolation will be done with <%s> vector map"
+"No vector map of sparse points to interpolate was specified. Interpolation "
+"will be done with <%s> vector map"
msgstr ""
"Ðе Ñказан векÑоÑнÑй Ñлой Ð´Ð»Ñ Ð¸Ð½ÑеÑполÑÑии. ÐнÑеÑполÑÑÐ¸Ñ Ð±ÑÐ´ÐµÑ Ð¿Ñоизведена Ñ <"
"%s> векÑоÑнÑм Ñлоем."
-#: ../vector/lidar/v.surf.bspline/main.c:240
-#, c-format
-msgid "<%s> vector map will be interpolated"
+#: ../vector/lidar/v.surf.bspline/main.c:243
+#, fuzzy, c-format
+msgid "Vector map <%s> of sparse points will be interpolated"
msgstr "<%s> векÑоÑнÑй Ñлой бÑÐ´ÐµÑ Ð¸Ð½ÑеÑполиÑован."
-#: ../vector/lidar/v.surf.bspline/main.c:256
+#: ../vector/lidar/v.surf.bspline/main.c:259
#, c-format
msgid ""
"Sorry, <%s> driver is not allowed for vector output in this module. Try with "
@@ -16597,24 +14458,24 @@
"ÐзвиниÑе, в ÑÑом модÑле дÑÐ°Ð¹Ð²ÐµÑ <%s> не Ð¼Ð¾Ð¶ÐµÑ Ð²ÑводиÑÑ Ð²ÐµÐºÑоÑ. ÐопÑобÑйÑе "
"ÑоÑ
ÑаниÑÑ Ð² ÑаÑÑÑовом ÑоÑмаÑе, или поÑобÑйÑе дÑÑгой дÑайвеÑ."
-#: ../vector/lidar/v.surf.bspline/main.c:298
+#: ../vector/lidar/v.surf.bspline/main.c:301
msgid "Cannot read field info"
msgstr "Ðевозможно пÑоÑиÑаÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ поле"
-#: ../vector/lidar/v.surf.bspline/main.c:319
+#: ../vector/lidar/v.surf.bspline/main.c:322
#, c-format
msgid "[%d] records selected from table"
msgstr "[%d] запиÑи вÑбÑÐ°Ð½Ñ Ð¸Ð· ÑаблиÑÑ"
-#: ../vector/lidar/v.surf.bspline/main.c:332
+#: ../vector/lidar/v.surf.bspline/main.c:335
msgid "Cross validation didn't finish correctly"
msgstr "ÐÑоÑÑ-пÑовеÑка завеÑÑилаÑÑ Ð½ÐµÑдаÑно"
-#: ../vector/lidar/v.surf.bspline/main.c:345
+#: ../vector/lidar/v.surf.bspline/main.c:348
msgid "Cross Validation was success!"
msgstr "ÐеÑекÑеÑÑÐ½Ð°Ñ Ð¿ÑовеÑка пÑоÑла ÑÑпеÑно!"
-#: ../vector/lidar/v.surf.bspline/main.c:378
+#: ../vector/lidar/v.surf.bspline/main.c:364
#, c-format
msgid ""
"Interpolation: The region resolution is too high: %d cells. Consider to "
@@ -16623,16 +14484,27 @@
"ÐнÑеÑполÑÑиÑ: ÑазÑеÑение ÑлиÑком велико: %d ÑÑеек. РекомендÑеÑÑÑ ÑменÑÑиÑÑ "
"ÑазÑеÑение."
-#: ../vector/lidar/v.surf.bspline/main.c:540
+#: ../vector/lidar/v.surf.bspline/main.c:385
+#, fuzzy
+msgid ""
+"Cannot allocate memory for auxiliar matrix.Consider changing region "
+"resolution"
+msgstr "Ðевозможно вÑделиÑÑ Ð¿Ð°Ð¼ÑÑÑ Ð´Ð»Ñ ÑÑÑоки"
+#: ../vector/lidar/v.surf.bspline/main.c:559
#, c-format
msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
msgstr "ÐнÑеÑполÑÑиÑ: (%d,%d): ÐÐµÑ Ð·Ð°Ð¿Ð¸Ñи Ð´Ð»Ñ ÑоÑки (cat = %d)"
-#: ../vector/lidar/v.surf.bspline/main.c:601
+#: ../vector/lidar/v.surf.bspline/main.c:620
#, c-format
msgid "Interpolation: Creating table: It was impossible to create table <%s>."
msgstr "ÐнÑеÑполÑÑиÑ: Создание ÑаблиÑÑ: Ðевозможно ÑоздаÑÑ ÑаблиÑÑ <%s>."
+#: ../vector/lidar/v.surf.bspline/main.c:693
+msgid "No data within this subzone. Consider changing the spline step."
+msgstr ""
#: ../vector/v.net.salesman/main.c:97 ../vector/v.net.iso/main.c:73
#: ../vector/v.net.path/main.c:41 ../vector/v.net/main.c:47
#: ../vector/v.net.alloc/main.c:61 ../vector/v.net.steiner/main.c:345
@@ -16705,46 +14577,38 @@
"ÑлоÑ."
#: ../vector/v.distance/main.c:121
-#, fuzzy
msgid "Name of existing vector map (from)"
-msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑего векÑоÑного ÑлоÑ"
+msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑего векÑоÑного ÑÐ»Ð¾Ñ (из)"
#: ../vector/v.distance/main.c:122 ../vector/v.distance/main.c:134
#: ../vector/v.distance/main.c:146
-#, fuzzy
msgid "From"
-msgstr "ÐÑÑ
однÑй Ñип"
+msgstr "Ðз"
#: ../vector/v.distance/main.c:126
-#, fuzzy
msgid "Name of existing vector map (to)"
+msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑего векÑоÑного ÑÐ»Ð¾Ñ (в)"
#: ../vector/v.distance/main.c:127 ../vector/v.distance/main.c:141
#: ../vector/v.distance/main.c:151 ../vector/v.distance/main.c:207
-#, fuzzy
msgid "To"
-msgstr "ÐнÑÑÑÑменÑÑ"
+msgstr "Ð"
#: ../vector/v.distance/main.c:133
-#, fuzzy
msgid "Feature type (from)"
-msgstr "Тип обÑекÑа"
+msgstr "Тип обÑекÑа (из)"
#: ../vector/v.distance/main.c:140
-#, fuzzy
msgid "Feature type (to)"
+msgstr "Тип обÑекÑа (в)"
#: ../vector/v.distance/main.c:145
-#, fuzzy
msgid "Layer number (from)"
-msgstr "ÐÐ¾Ð¼ÐµÑ ÑлоÑ"
+msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ (из)"
#: ../vector/v.distance/main.c:150
-#, fuzzy
msgid "Layer number (to)"
+msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ (в)"
#: ../vector/v.distance/main.c:156
msgid "Name for output vector map containing lines connecting nearest elements"
@@ -16792,7 +14656,7 @@
#: ../vector/v.distance/main.c:201
msgid "From_map"
-msgstr ""
+msgstr "ÐÑÑ
однÑй Ñлой"
#: ../vector/v.distance/main.c:206
msgid "Column name of nearest feature (used with upload=to_attr)"
@@ -16843,7 +14707,7 @@
"обновлен"
#: ../vector/v.distance/main.c:373 ../vector/v.distance/main.c:407
-#: ../vector/v.reclass/main.c:137 ../vector/v.out.ascii/b2a.c:222
+#: ../vector/v.reclass/main.c:137 ../vector/v.out.ascii/b2a.c:227
#: ../vector/v.to.3d/trans2.c:56 ../vector/v.to.3d/trans3.c:57
#, c-format
msgid "Column <%s> not found in table <%s>"
@@ -16854,7 +14718,6 @@
msgstr "Ðевозможно оÑкÑÑÑÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
по ÑмолÑаниÑ"
#: ../vector/v.distance/main.c:439
-#, fuzzy
msgid "Incompatible column types"
msgstr "ÐеÑовмеÑÑимÑе ÑÐ¸Ð¿Ñ ÑÑолбÑов"
@@ -16931,9 +14794,8 @@
msgstr "найдено %d оÑибок"
#: ../vector/v.reclass/main.c:63
-#, fuzzy
msgid "vector, reclass, attributes"
-msgstr "векÑоÑ, ÑаÑÑÑ, аÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
+msgstr "векÑоÑ, пеÑеклаÑÑиÑикаÑиÑ, аÑÑибÑÑÑ"
#: ../vector/v.reclass/main.c:65
msgid ""
@@ -16950,9 +14812,9 @@
"каÑегоÑии"
#: ../vector/v.reclass/main.c:83
-#, fuzzy
msgid "The source for the new key column must be type integer or string"
-msgstr "СÑÐ¾Ð»Ð±ÐµÑ Ð´Ð¾Ð»Ð¶Ð½ имеÑÑ ÑелоÑиÑленнÑй или ÑÑÑоковÑй Ñип"
+msgstr ""
+"ÐÑÑоÑник Ð´Ð»Ñ ÐºÐ»ÑÑевого ÑÑолбÑа должен имеÑÑ ÑелоÑиÑленнÑй или ÑÑÑоковÑй Ñип"
#: ../vector/v.reclass/main.c:88
msgid "Full path to the reclass rule file"
@@ -17030,9 +14892,9 @@
msgstr "Ðеполное пÑавило"
#: ../vector/v.reclass/main.c:428
-#, fuzzy, c-format
+#, c-format
msgid "%d features reclassed."
-msgstr "пеÑеклаÑÑиÑиÑиÑовано %d обÑекÑов"
+msgstr "пеÑеклаÑÑиÑиÑиÑовано %d обÑекÑов."
#: ../vector/v.in.ascii/head.c:22
#, c-format
@@ -17081,7 +14943,8 @@
msgstr "ÐаннÑе бÑдÑÑ Ð¿ÑоÑиÑÐ°Ð½Ñ Ð¸Ð· ввода или из Ñайла ASCII"
#: ../vector/v.in.ascii/in.c:67
-msgid "point;simple x,y[,z] list;standard;GRASS's vector ASCII format"
+#, fuzzy
+msgid "point;simple x,y[,z] list;standard;GRASS vector ASCII format"
msgstr ""
"ÑоÑка; пÑоÑÑой ÑпиÑок x,y[,z], ÑÑандаÑÑ, векÑоÑнÑй ÑоÑÐ¼Ð°Ñ GRASS Ð´Ð»Ñ ASCII "
"ÑекÑÑового Ñайла."
@@ -17090,124 +14953,121 @@
msgid "Input file format"
msgstr "ÐÑÑ
однÑй ÑоÑÐ¼Ð°Ñ Ñайла"
-#: ../vector/v.in.ascii/in.c:81
+#: ../vector/v.in.ascii/in.c:71 ../vector/v.in.ascii/in.c:74
+#: ../vector/v.in.ascii/in.c:152
+#, fuzzy
+msgid "Input format"
+msgstr "ÐÑÑ
+#: ../vector/v.in.ascii/in.c:83
msgid "Number of header lines to skip at top of input file (points mode)"
msgstr "ЧиÑло ÑÑÑок заголовка в иÑÑ
одном Ñайле (ÑоÑеÑнÑй Ñежим)"
-#: ../vector/v.in.ascii/in.c:88 ../vector/v.in.ascii/in.c:100
-#: ../vector/v.in.ascii/in.c:110 ../vector/v.in.ascii/in.c:120
-#: ../vector/v.in.ascii/in.c:132 ../vector/v.in.ascii/in.c:155
-msgid "Columns"
-msgstr "СÑолбÑÑ"
-#: ../vector/v.in.ascii/in.c:89
+#: ../vector/v.in.ascii/in.c:92
msgid "Column definition in SQL style (points mode)"
msgstr "ÐпÑеделение ÑÑолбÑа в ÑÑиле SQL (ÑоÑеÑнÑй Ñежим)"
-#: ../vector/v.in.ascii/in.c:90
+#: ../vector/v.in.ascii/in.c:93
msgid ""
"For example: 'x double precision, y double precision, cat int, name varchar"
"(10)'"
msgstr ""
"ÐапÑимеÑ: Ð´Ð²Ð¾Ð¹Ð½Ð°Ñ ÑоÑноÑÑÑ 'x, Ð´Ð²Ð¾Ð¹Ð½Ð°Ñ ÑоÑноÑÑÑ y, cat int, name varchar(10)'"
-#: ../vector/v.in.ascii/in.c:102
-msgid ""
-"Number of column used as x coordinate (first column is 1) for points mode"
+#: ../vector/v.in.ascii/in.c:105 ../vector/v.in.ascii/in.c:115
+msgid "First column is 1"
msgstr ""
-"ÐÐ¾Ð¼ÐµÑ ÑÑолбÑа, в коÑоÑой Ñ
ÑаниÑÑÑ ÐºÐ¾Ð¾ÑдинаÑа x (Ð½Ð¾Ð¼ÐµÑ Ð¿ÐµÑвого ÑÑолбÑа - 1), "
-"Ð´Ð»Ñ ÑоÑеÑного Ñежима"
-#: ../vector/v.in.ascii/in.c:112
-msgid ""
-"Number of column used as y coordinate (first column is 1) for points mode"
+#: ../vector/v.in.ascii/in.c:114
+#, fuzzy
+msgid "Number of column used as y coordinate (points mode)"
msgstr ""
ÑаниÑÑÑ ÐºÐ¾Ð¾ÑдинаÑа y (Ð½Ð¾Ð¼ÐµÑ Ð¿ÐµÑвого ÑÑолбÑа - 1), "
-#: ../vector/v.in.ascii/in.c:122
-msgid ""
-"Number of column used as z coordinate (first column is 1) for points mode"
+#: ../vector/v.in.ascii/in.c:124
+#, fuzzy
+msgid "Number of column used as z coordinate (points mode)"
msgstr ""
ÑаниÑÑÑ ÐºÐ¾Ð¾ÑдинаÑа z (Ð½Ð¾Ð¼ÐµÑ Ð¿ÐµÑвого ÑÑолбÑа - 1), "
-#: ../vector/v.in.ascii/in.c:124
-msgid "If 0, z coordinate is not used"
+#: ../vector/v.in.ascii/in.c:125
+#, fuzzy
+msgid "First column is 1. If 0, z coordinate is not used"
msgstr "ÐÑли 0, Ñо кооÑдинаÑа z не иÑполÑзÑеÑÑÑ"
-#: ../vector/v.in.ascii/in.c:134
-msgid "Number of column used as category (first column is 1) for points mode"
+#: ../vector/v.in.ascii/in.c:135
+#, fuzzy
+msgid "Number of column used as category (points mode)"
msgstr ""
"ÐÐ¾Ð¼ÐµÑ ÑÑолбÑа, в коÑоÑой ÑказÑваеÑÑÑ ÐºÐ°ÑегоÑÐ¸Ñ (Ð½Ð¾Ð¼ÐµÑ Ð¿ÐµÑвого ÑÑолбÑа - 1), "
-#: ../vector/v.in.ascii/in.c:136
+#: ../vector/v.in.ascii/in.c:137
+#, fuzzy
msgid ""
-"If 0, unique category is assigned to each row and written to new column 'cat'"
+"First column is 1. If 0, unique category is assigned to each row and written "
+"to new column 'cat'"
msgstr ""
"ÐÑли 0, Ñо ÐºÐ°Ð¶Ð´Ð°Ñ Ð·Ð°Ð¿Ð¸ÑÑ Ð² ÑаблиÑе полÑÑÐ¸Ñ ÑникалÑнÑÑ ÐºÐ°ÑегоÑиÑ, коÑоÑÐ°Ñ "
"бÑÐ´ÐµÑ Ð·Ð°Ð¿Ð¸Ñана в новом ÑÑолбÑе 'cat'"
-#: ../vector/v.in.ascii/in.c:140 ../vector/v.in.dwg/main.c:88
+#: ../vector/v.in.ascii/in.c:141 ../vector/v.in.dwg/main.c:88
msgid "Create 3D vector map"
msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑй 3D Ñлой"
-#: ../vector/v.in.ascii/in.c:145
-msgid "Create a new empty vector map and exit. Nothing is read from input"
+#: ../vector/v.in.ascii/in.c:146
+#, fuzzy
+msgid "Create a new empty vector map and exit. Nothing is read from input."
msgstr "СоздаÑÑ Ð¿ÑÑÑой векÑоÑнÑй Ñлой и вÑйÑи. Ðвод не иÑполÑзÑеÑÑÑ"
-#: ../vector/v.in.ascii/in.c:150
+#: ../vector/v.in.ascii/in.c:151
msgid "Don't expect a header when reading in standard format"
msgstr "ÐеожиданнÑй заголовок пÑи ÑÑении в ÑÑандаÑÑном ÑоÑмаÑе"
-#: ../vector/v.in.ascii/in.c:154
+#: ../vector/v.in.ascii/in.c:156
msgid "Do not create table in points mode"
msgstr "Ðе ÑоздаваÑÑ ÑаблиÑÑ Ð² ÑоÑеÑном Ñежиме"
-#: ../vector/v.in.ascii/in.c:159
-msgid "Do not build topology in points mode"
-msgstr "Ðе ÑÑÑоиÑÑ ÑÐ¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð² ÑоÑеÑном Ñежиме"
-#: ../vector/v.in.ascii/in.c:164
+#: ../vector/v.in.ascii/in.c:167
msgid "Only import points falling within current region (points mode)"
msgstr ""
"ÐмпоÑÑиÑоваÑÑ ÑолÑко Ñе ÑоÑки, коÑоÑÑе наÑ
одÑÑÑÑ Ð²Ð½ÑÑÑи ÑекÑÑего Ñегиона "
"(ÑоÑеÑнÑй Ñежим)"
-#: ../vector/v.in.ascii/in.c:178
+#: ../vector/v.in.ascii/in.c:181
msgid "Please specify reasonable number of lines to skip"
msgstr "ÐведиÑе колиÑеÑÑво ÑÑÑок, коÑоÑÑе бÑдÑÑ Ð¿ÑопÑÑенÑ"
-#: ../vector/v.in.ascii/in.c:181
+#: ../vector/v.in.ascii/in.c:184
msgid "Please specify z column"
msgstr "УкажиÑе ÑÑÐ¾Ð»Ð±ÐµÑ Ñ ÐºÐ¾Ð¾ÑдинаÑами z"
-#: ../vector/v.in.ascii/in.c:192
+#: ../vector/v.in.ascii/in.c:195
msgid "Please specify reasonable z column"
msgstr "УкажиÑе коÑÑекÑнÑй ÑÑÐ¾Ð»Ð±ÐµÑ Ñ ÐºÐ¾Ð¾ÑдинаÑами z"
-#: ../vector/v.in.ascii/in.c:197
-#, fuzzy
+#: ../vector/v.in.ascii/in.c:200
msgid "Column numbers must not be negative"
-msgstr "ТоÑноÑÑÑ Ð½Ðµ должна бÑÑÑ Ð¾ÑÑиÑаÑелÑной"
+msgstr "Column numbers must not be negative"
-#: ../vector/v.in.ascii/in.c:253
+#: ../vector/v.in.ascii/in.c:256
#, c-format
msgid "Maximum input row length: %d"
msgstr "ÐакÑималÑÐ½Ð°Ñ Ð´Ð»Ð¸Ð½Ð° ÑÑÑоки пÑи вводе: %d"
-#: ../vector/v.in.ascii/in.c:254
+#: ../vector/v.in.ascii/in.c:257
#, c-format
msgid "Maximum number of columns: %d"
msgstr "ÐакÑималÑное ÑиÑло ÑÑолбÑов: %d"
-#: ../vector/v.in.ascii/in.c:255
+#: ../vector/v.in.ascii/in.c:258
#, c-format
msgid "Minimum number of columns: %d"
msgstr "ÐинималÑное ÑиÑло ÑÑолбÑов: %d"
-#: ../vector/v.in.ascii/in.c:260
+#: ../vector/v.in.ascii/in.c:263
msgid ""
"x column number > minimum last column number\n"
"(incorrect field separator?)"
@@ -17215,7 +15075,7 @@
"ÐÐ¾Ð¼ÐµÑ ÑÑолбÑа Ñ ÐºÐ¾Ð¾ÑдинаÑами x > минималÑного номеÑа поÑледнего ÑÑолбÑа\n"
"(невеÑнÑй ÑазделиÑÐµÐ»Ñ Ð¿Ð¾Ð»ÐµÐ¹?)"
-#: ../vector/v.in.ascii/in.c:264
+#: ../vector/v.in.ascii/in.c:267
msgid ""
"y column number > minimum last column number\n"
@@ -17223,92 +15083,92 @@
"Ð½Ð¾Ð¼ÐµÑ ÑÑолбÑа y > минималÑного номеÑа поÑледнего ÑÑолбÑа\n"
-#: ../vector/v.in.ascii/in.c:268
+#: ../vector/v.in.ascii/in.c:271
msgid ""
"z column number > minimum last column number (incorrect field separator?)"
msgstr ""
"Ð½Ð¾Ð¼ÐµÑ ÑÑолбÑа Ñ ÐºÐ¾Ð¾ÑдинаÑами z > минималÑного номеÑа поÑледнего ÑÑолбÑа "
-#: ../vector/v.in.ascii/in.c:273
+#: ../vector/v.in.ascii/in.c:276
msgid ""
"cat column number > minimum last column number (incorrect field separator?)"
msgstr ""
"ÐÐ¾Ð¼ÐµÑ ÑÑолбÑа Ñ Ð·Ð½Ð°ÑениÑми каÑегоÑий > минималÑного номеÑа поÑледнего "
"ÑÑолбÑа (невеÑнÑй ÑазделиÑÐµÐ»Ñ Ð¿Ð¾Ð»ÐµÐ¹?)"
-#: ../vector/v.in.ascii/in.c:279
+#: ../vector/v.in.ascii/in.c:282
msgid "x column is not of number type"
msgstr "СÑÐ¾Ð»Ð±ÐµÑ Ñ ÐºÐ¾Ð¾ÑдинаÑой x Ð¸Ð¼ÐµÐµÑ Ð½Ðµ ÑиÑленнÑй ÑоÑмаÑ"
-#: ../vector/v.in.ascii/in.c:283
+#: ../vector/v.in.ascii/in.c:286
msgid "y column is not of number type"
msgstr "СÑÐ¾Ð»Ð±ÐµÑ Ñ ÐºÐ¾Ð¾ÑдинаÑой y Ð¸Ð¼ÐµÐµÑ Ð½Ðµ ÑиÑленнÑй ÑоÑмаÑ"
-#: ../vector/v.in.ascii/in.c:287
+#: ../vector/v.in.ascii/in.c:290
msgid "z column is not of number type"
msgstr "СÑÐ¾Ð»Ð±ÐµÑ Ñ ÐºÐ¾Ð¾ÑдинаÑой z Ð¸Ð¼ÐµÐµÑ Ð½Ðµ ÑиÑленнÑй ÑоÑмаÑ"
-#: ../vector/v.in.ascii/in.c:291
+#: ../vector/v.in.ascii/in.c:294
msgid "cat column is not of number type"
msgstr "СÑÐ¾Ð»Ð±ÐµÑ Ñ ÐºÐ°ÑегоÑиÑми Ð¸Ð¼ÐµÐµÑ Ð½Ðµ ÑиÑленнÑй ÑоÑмаÑ"
-#: ../vector/v.in.ascii/in.c:333
+#: ../vector/v.in.ascii/in.c:336
msgid "Category column is not of integer type"
msgstr "СÑÐ¾Ð»Ð±ÐµÑ Ñ ÐºÐ°ÑегоÑиÑми Ð¸Ð¼ÐµÐµÑ Ð½Ðµ ÑелоÑиÑленнÑй ÑоÑмаÑ"
-#: ../vector/v.in.ascii/in.c:414
+#: ../vector/v.in.ascii/in.c:417
#, c-format
msgid ""
"Number of columns defined (%d) does not match number of columns (%d) in input"
msgstr ""
"ЧиÑло заданнÑÑ
ÑÑолбÑов (%d) не ÑооÑвеÑÑÑвÑÐµÑ ÑиÑÐ»Ñ ÑÑолбÑов в иÑÑоÑнике (%d)"
-#: ../vector/v.in.ascii/in.c:442
+#: ../vector/v.in.ascii/in.c:445
#, c-format
msgid "Column number %d <%s> defined as double has only integer values"
msgstr ""
"СÑÐ¾Ð»Ð±ÐµÑ Ð½Ð¾Ð¼ÐµÑ %d <%s> опÑеделеннÑй как double Ð¸Ð¼ÐµÐµÑ ÑолÑко ÑелÑе знаÑениÑ."
-#: ../vector/v.in.ascii/in.c:447
+#: ../vector/v.in.ascii/in.c:450
#, c-format
msgid "Column number %d <%s> defined as string has only integer values"
msgstr ""
"СÑÐ¾Ð»Ð±ÐµÑ Ð½Ð¾Ð¼ÐµÑ %d <%s> опÑеделеннÑй как ÑÑÑоковÑй Ð¸Ð¼ÐµÐµÑ ÑолÑко ÑелÑе знаÑениÑ"
-#: ../vector/v.in.ascii/in.c:455
+#: ../vector/v.in.ascii/in.c:458
#, c-format
msgid "Column number %d <%s> defined as integer has double values"
msgstr ""
"СÑÐ¾Ð»Ð±ÐµÑ Ð½Ð¾Ð¼ÐµÑ %d <%s> опÑеделен как ÑелоÑиÑленнÑй, Ð¸Ð¼ÐµÐµÑ double знаÑениÑ"
-#: ../vector/v.in.ascii/in.c:460
+#: ../vector/v.in.ascii/in.c:463
#, c-format
msgid "Column number %d <%s> defined as string has double values"
msgstr ""
"СÑÐ¾Ð»Ð±ÐµÑ Ð½Ð¾Ð¼ÐµÑ %d <%s> опÑеделеннÑй как ÑÑÑоковÑй Ð¸Ð¼ÐµÐµÑ double знаÑениÑ"
-#: ../vector/v.in.ascii/in.c:468
+#: ../vector/v.in.ascii/in.c:471
#, c-format
msgid "Column number %d <%s> defined as integer has string values"
msgstr ""
"СÑÐ¾Ð»Ð±ÐµÑ Ð½Ð¾Ð¼ÐµÑ %d <%s> опÑеделеннÑй как ÑелоÑиÑленнÑй Ñип Ð¸Ð¼ÐµÐµÑ ÑÑÑоковÑе "
"знаÑениÑ"
-#: ../vector/v.in.ascii/in.c:474
+#: ../vector/v.in.ascii/in.c:477
#, c-format
msgid "Column number %d <%s> defined as double has string values"
msgstr ""
"СÑÐ¾Ð»Ð±ÐµÑ Ð½Ð¾Ð¼ÐµÑ %d <%s> опÑеделеннÑй как double Ð¸Ð¼ÐµÐµÑ ÑÑÑоковÑе знаÑениÑ"
-#: ../vector/v.in.ascii/in.c:480
+#: ../vector/v.in.ascii/in.c:483
#, c-format
msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
msgstr ""
"ЧиÑло знаков в ÑÑолбÑе %d <%s> (%d) менÑÑе Ñем макÑималÑное ÑиÑло знаков (%"
"d)"
-#: ../vector/v.in.ascii/in.c:520
+#: ../vector/v.in.ascii/in.c:523
msgid "Populating table..."
msgstr "Ðаполнение ÑаблиÑÑ..."
@@ -17375,7 +15235,7 @@
#: ../vector/v.to.points/main.c:213 ../vector/v.in.ogr/main.c:213
#: ../vector/v.overlay/main.c:120 ../vector/v.voronoi/vo_main.c:139
-#: ../vector/v.select/main.c:186
+#: ../vector/v.select/args.c:78
msgid "Do not create attribute table"
msgstr "Ðе ÑоздаваÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ"
@@ -17393,23 +15253,24 @@
msgid "%d points written to output vector map"
msgstr "%d ÑоÑек запиÑано в вÑÑ
одной векÑоÑнÑй Ñлой"
-#: ../vector/v.out.ascii/b2a.c:148
+#: ../vector/v.out.ascii/b2a.c:150
#, c-format
msgid "got type %d"
msgstr "полÑÑен Ñип %d"
-#: ../vector/v.out.ascii/b2a.c:187
+#: ../vector/v.out.ascii/b2a.c:192
#, c-format
msgid "Feature has more categories. Only first category (%d) is exported."
msgstr ""
+"ÐбÑÐµÐºÑ Ð¸Ð¼ÐµÐµÑ Ð±Ð¾Ð»ÑÑе каÑегоÑий. ÐÑÐ´ÐµÑ ÑкÑпоÑÑиÑована ÑолÑко пеÑÐ²Ð°Ñ (%d)."
-#: ../vector/v.out.ascii/b2a.c:197
-#, fuzzy, c-format
+#: ../vector/v.out.ascii/b2a.c:202
+#, c-format
msgid "Unable to select record from table <%s> (key %s, column %s)"
-msgstr "Ðевозможно вÑбÑаÑÑ Ð·Ð°Ð¿Ð¸Ñи из LRS ÑаблиÑÑ: %s"
+msgstr "Ðевозможно вÑбÑаÑÑ Ð·Ð°Ð¿Ð¸Ñи из ÑаблиÑÑ <%s> (клÑÑ %s, поле %s)"
-#: ../vector/v.out.ascii/b2a.c:224
-#, fuzzy, c-format
+#: ../vector/v.out.ascii/b2a.c:229
+#, c-format
msgid "Column <%s>: unsupported data type"
msgstr "Ðоле <%s>: невеÑнÑй Ñип даннÑÑ
@@ -17439,9 +15300,8 @@
msgstr "РазделиÑÐµÐ»Ñ Ð¿Ð¾Ð»ÐµÐ¹ (ÑоÑеÑнÑй Ñежим)"
#: ../vector/v.out.ascii/out.c:83
-#, fuzzy
msgid "Name of attribute column(s) to be exported (point mode)"
-msgstr "ÐÐ¼Ñ Ð°ÑÑибÑÑивного ÑÑолбÑа иÑполÑзÑемое Ð´Ð»Ñ Ð¿Ð¾Ð´Ð¿Ð¸Ñей"
+msgstr "ÐÐ¼Ñ ÑкÑпоÑÑиÑÑемого аÑÑибÑÑивного ÑÑолбÑа (Ñежим ÑоÑек)"
#: ../vector/v.out.ascii/out.c:91
msgid "Create old (version 4) ASCII file"
@@ -17453,32 +15313,31 @@
"ÐкÑпоÑÑиÑоваÑÑ ÑолÑко Ñе ÑоÑки, коÑоÑÑе наÑ
одÑÑÑÑ Ð²Ð½ÑÑÑи ÑекÑÑего 3D Ñегиона "
"(ÑоÑеÑнÑй Ñежим)"
-#: ../vector/v.out.ascii/out.c:110
+#: ../vector/v.out.ascii/out.c:111
#, c-format
msgid "Parameter '%s' ignored in standard mode"
-msgstr ""
+msgstr "ÐаÑамеÑÑ '%s' в ÑÑандаÑÑном Ñежиме игноÑиÑÑеÑÑÑ"
-#: ../vector/v.out.ascii/out.c:118
+#: ../vector/v.out.ascii/out.c:119
msgid "Format 'point' is not supported for old version"
msgstr "ФоÑÐ¼Ð°Ñ 'point' не поддеÑживаеÑÑÑ Ð´Ð»Ñ ÑÑаÑой веÑÑии"
-#: ../vector/v.out.ascii/out.c:122
+#: ../vector/v.out.ascii/out.c:123
msgid "'output' must be given for old version"
msgstr "'output' должен бÑÑÑ Ñказан Ð´Ð»Ñ ÑÑаÑой веÑÑии"
-#: ../vector/v.out.ascii/out.c:139 ../vector/v.out.vtk/main.c:186
-#, fuzzy
+#: ../vector/v.out.ascii/out.c:140 ../vector/v.out.vtk/main.c:186
msgid "Failed to interpret 'dp' parameter as an integer"
-msgstr "Ðевозможно иÑполÑзоваÑÑ Ð¿Ð°ÑамеÑÑ 'dp' как ÑелоÑиÑленнÑй"
+msgstr "Ðевозможно инÑеÑпÑеÑиÑоваÑÑ Ð¿Ð°ÑамеÑÑ 'dp' как ÑелоÑиÑленнÑй"
-#: ../vector/v.out.ascii/out.c:176
+#: ../vector/v.out.ascii/out.c:177
msgid "dig_att file already exist"
msgstr "Файл dig_att Ñже ÑÑÑеÑÑвÑеÑ"
-#: ../vector/v.out.ascii/out.c:179
-#, fuzzy, c-format
+#: ../vector/v.out.ascii/out.c:180
+#, c-format
msgid "Unable to open dig_att file <%s>"
-msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл dig_att <%s>\n"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл dig_att <%s>"
#: ../vector/v.build/main.c:34 ../vector/v.clean/main.c:43
msgid "vector, topology"
@@ -17801,7 +15660,7 @@
#: ../vector/v.label.sa/labels.c:178 ../vector/v.label/main.c:329
#: ../vector/v.buffer/main.c:454 ../vector/v.buffer/main.c:466
#: ../vector/v.buffer/main.c:531 ../vector/v.buffer/main.c:543
-#: ../vector/v.buffer2/main.c:359 ../vector/v.buffer2/main.c:425
+#: ../vector/v.buffer2/main.c:386 ../vector/v.buffer2/main.c:452
#, c-format
msgid "No record for category %d in table <%s>"
msgstr "ÐÐµÑ Ð½Ð¸ одной запиÑи Ð´Ð»Ñ ÐºÐ°ÑегоÑии %d в ÑаблиÑе <%s>"
@@ -17847,7 +15706,8 @@
"no;Ðе назнаÑаÑÑ Ð¿Ð¾Ð»Ð¸Ð»Ð¸Ð½Ð¸Ð¸ Ð½Ð¾Ð¼ÐµÑ ÐºÐ°ÑегоÑии;first;ÐазнаÑиÑÑ Ð¿Ð¾Ð»Ð¸Ð»Ð¸Ð½Ð¸Ð¸ Ð½Ð¾Ð¼ÐµÑ "
"каÑегоÑии пеÑвой линии;multi;ÐазнаÑиÑÑ Ð¿Ð¾Ð»Ð¸Ð»Ð¸Ð½Ð¸Ð¸ ÑоÑÑавной Ð½Ð¾Ð¼ÐµÑ ÐºÐ°ÑегоÑии"
-#: ../vector/v.build.polylines/main.c:128
+#: ../vector/v.build.polylines/main.c:128 ../vector/v.buffer2/main.c:210
+#: ../vector/v.buffer2/main.c:222
msgid "Unused"
msgstr "Ðе иÑполÑзÑеÑÑÑ"
@@ -17865,14 +15725,12 @@
#: ../vector/v.category/main.c:527 ../vector/v.clean/main.c:281
#: ../vector/v.kcv/main.c:161 ../vector/v.net/main.c:197
#: ../vector/v.type/main.c:234 ../vector/v.proj/main.c:278
-#, fuzzy
msgid "Failed to copy attribute table to output map"
-msgstr "Ðевозможно ÑкопиÑоваÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ Ð² векÑоÑнÑй Ñлой <%s>"
+msgstr "Ðевозможно ÑкопиÑоваÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ Ð² вÑÑ
одной Ñлой"
#: ../vector/v.net.iso/main.c:72
-#, fuzzy
msgid "Splits net by cost isolines."
-msgstr "РазделиÑÑ ÑеÑÑ Ð½Ð° полоÑÑ Ð¸Ð·Ð¾Ð»Ð¸Ð½Ð¸Ñми ÑÑоимоÑÑи"
+msgstr "РазделиÑÑ ÑеÑÑ Ð¸Ð·Ð¾Ð»Ð¸Ð½Ð¸Ñми ÑÑоимоÑÑи."
#: ../vector/v.net.iso/main.c:75
msgid ""
@@ -17925,9 +15783,9 @@
msgstr ""
#: ../vector/v.net.iso/main.c:164
-#, fuzzy, c-format
+#, c-format
msgid "Iso cost %d: %f"
-msgstr "MST ÑÑоимоÑÑи = %f"
+msgstr "Iso ÑÑоимоÑÑÑ %d: %f"
#: ../vector/v.net.iso/main.c:171
msgid "Not enough costs, everything reachable falls to first band"
@@ -17938,18 +15796,18 @@
msgstr ""
#: ../vector/v.net.iso/main.c:224
-#, fuzzy, c-format
+#, c-format
msgid "Number of centres: %d (nlayer %d)"
-msgstr "ÐолиÑеÑÑво ÑенÑÑов: [%d] (nlayer: [%d])"
+msgstr "ÐолиÑеÑÑво ÑенÑÑов: %d (nlayer: %d)"
#: ../vector/v.net.iso/main.c:227 ../vector/v.net.alloc/main.c:189
msgid "Not enough centres for selected nlayer. Nothing will be allocated."
msgstr "ÐедоÑÑаÑоÑно ÑенÑÑов Ð´Ð»Ñ Ð²ÑбÑанного ÑлоÑ. ÐиÑего не бÑÐ´ÐµÑ Ð½Ð°Ð·Ð½Ð°Ñено."
#: ../vector/v.net.iso/main.c:247
-#, fuzzy, c-format
+#, c-format
msgid "Calculating costs from centre %d..."
-msgstr "ÐÑÑиÑление ÑÑоимоÑÑей Ð¾Ñ ÑенÑÑов ..."
+msgstr "ÐÑÑиÑление ÑÑоимоÑÑей Ð¾Ñ ÑенÑÑа %d..."
#: ../vector/v.net.iso/main.c:508 ../vector/v.net.alloc/main.c:340
#: ../vector/v.net.alloc/main.c:351
@@ -18402,7 +16260,7 @@
msgid "Calculating centrality measures..."
msgstr "РаÑÑÐµÑ ÑенÑÑалÑнÑÑ
положений..."
-#: ../vector/v.generalize/misc.c:124 ../vector/v.select/main.c:477
+#: ../vector/v.generalize/misc.c:124 ../vector/v.select/main.c:478
#: ../vector/v.extract/main.c:427
msgid "Writing attributes..."
msgstr "ЧÑение аÑÑибÑÑов..."
@@ -18422,12 +16280,10 @@
msgstr "ÐÑбÑаÑÑ Ñип: Ð»Ð¸Ð½Ð¸Ñ Ð¸Ð»Ð¸ полигон"
#: ../vector/v.info/main.c:64
-#, fuzzy
msgid "vector, metadata, history"
-msgstr "векÑоÑ, меÑаданнÑе"
+msgstr "векÑоÑ, меÑаданнÑе, иÑÑоÑиÑ"
#: ../vector/v.info/main.c:66
-#, fuzzy
msgid "Outputs basic information about a user-specified vector map."
msgstr "ÐÑвеÑÑи оÑновнÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ векÑоÑном Ñлое, вÑбÑанном полÑзоваÑелем."
@@ -18449,9 +16305,9 @@
msgstr "ÐÑобÑазиÑÑ ÑипÑ/имена полей Ð´Ð»Ñ ÑвÑзи ÐÐ Ñо Ñлоем %d:"
#: ../vector/v.info/main.c:204 ../vector/v.convert/att.c:67
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open driver <%s>"
-msgstr " "
+msgstr "Ðевозможно оÑкÑÑÑÑ Ð´ÑÐ°Ð¹Ð²ÐµÑ <%s>"
#: ../vector/v.info/main.c:232
#, c-format
@@ -18786,7 +16642,7 @@
msgstr "Тип Ð¿Ð¾Ð»Ñ Ð½Ðµ поддеÑживаеÑÑÑ (%s)"
#: ../vector/v.in.ogr/main.c:755
-#, fuzzy, c-format
+#, c-format
msgid "Unable open database <%s> by driver <%s>"
msgstr "Ðевозможно оÑкÑÑÑÑ ÐÐ <%s> Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ Ð´ÑайвеÑа <%s>"
@@ -18843,8 +16699,8 @@
#: ../vector/v.in.ogr/main.c:985 ../vector/v.overlay/area_area.c:68
#: ../vector/v.voronoi/dt_main.c:142 ../vector/v.buffer/main.c:661
-#: ../vector/v.buffer/main.c:741 ../vector/v.buffer2/main.c:506
-#: ../vector/v.buffer2/main.c:577
+#: ../vector/v.buffer/main.c:741 ../vector/v.buffer2/main.c:533
+#: ../vector/v.buffer2/main.c:604
msgid "Cannot calculate area centroid"
msgstr "Ðевозможно ÑаÑÑÑиÑаÑÑ ÑенÑÑоид полигона"
@@ -18888,39 +16744,44 @@
"ÐÑÑ
однÑе даннÑе ÑодеÑÐ¶Ð°Ñ 3D-обÑекÑÑ. СозданнÑй векÑÐ¾Ñ Ð´Ð²ÑÑ
меÑнÑй, "
"иÑполÑзÑйÑе паÑамеÑÑ -z Ð´Ð»Ñ Ñого, ÑÑÐ¾Ð±Ñ Ð¸Ð¼Ð¿Ð¾ÑÑиÑоваÑÑ 3D-векÑоÑнÑй Ñлой"
-#: ../vector/v.in.ogr/geom.c:233
+#: ../vector/v.in.ogr/geom.c:192 ../vector/v.in.ogr/geom.c:205
+#: ../vector/v.in.ogr/geom.c:229 ../vector/v.in.ogr/geom.c:271
+msgid "Skipping empty geometry feature"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:245
#, c-format
msgid "Degenerate polygon ([%d] vertices)"
msgstr "УпÑоÑÑиÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½ ([%d] Ñзлов)"
-#: ../vector/v.in.ogr/geom.c:238
+#: ../vector/v.in.ogr/geom.c:250
#, c-format
msgid "Area size [%.1e], area not imported"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ð° [%.1e], полигон не импоÑÑиÑован"
-#: ../vector/v.in.ogr/geom.c:265
+#: ../vector/v.in.ogr/geom.c:282
#, c-format
msgid "Degenerate island ([%d] vertices)"
msgstr "УпÑоÑÑиÑÑ Ð¾ÑÑÑов ([%d] Ñзлов)"
-#: ../vector/v.in.ogr/geom.c:270
+#: ../vector/v.in.ogr/geom.c:287
#, c-format
msgid "Island size [%.1e], island not imported"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ Ð¾ÑÑÑова [%.1e], оÑÑÑов не импоÑÑиÑован"
-#: ../vector/v.in.ogr/geom.c:289
+#: ../vector/v.in.ogr/geom.c:308
msgid "Cannot calculate centroid"
msgstr "Ðевозможно ÑаÑÑÑиÑаÑÑ ÑенÑÑоид"
-#: ../vector/v.in.ogr/geom.c:320
+#: ../vector/v.in.ogr/geom.c:339
msgid "No centroid written for polygon with 0 vertices"
msgstr "Ðи одного ÑенÑÑоида не запиÑано Ð´Ð»Ñ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ð° Ñ 0 Ñзлами"
-#: ../vector/v.in.ogr/geom.c:341
+#: ../vector/v.in.ogr/geom.c:360
msgid "Cannot write part of geometry"
msgstr "Ðевозможно запиÑаÑÑ ÑаÑÑÑ Ð³ÐµÐ¾Ð¼ÐµÑÑии"
-#: ../vector/v.in.ogr/geom.c:347
+#: ../vector/v.in.ogr/geom.c:366
msgid "Unknown geometry type"
msgstr "ÐеизвеÑÑнÑй Ñип геомеÑÑии"
@@ -18968,9 +16829,8 @@
"Ñелое"
#: ../vector/v.in.sites/main.c:183
-#, fuzzy
msgid "Transferring sites to vector point map..."
-msgstr "ÐонвеÑÑиÑование ÑайÑов в векÑоÑнÑй ÑоÑеÑнÑй Ñлой..."
+msgstr "ÐонвеÑÑиÑование ÑайÑов в ÑоÑеÑнÑй векÑоÑнÑй Ñлой..."
#: ../vector/v.in.sites/main.c:255
#, c-format
@@ -19143,19 +17003,19 @@
меÑнÑй "
"векÑоÑнÑй Ñлой)"
-#: ../vector/v.surf.idw/main.c:117
+#: ../vector/v.surf.idw/main.c:118
msgid "Attribute table column with values to interpolate"
msgstr "Ðоле аÑÑибÑÑивной ÑаблиÑÑ Ñо знаÑениÑми Ð´Ð»Ñ Ð¸Ð½ÑеÑполÑÑии"
-#: ../vector/v.surf.idw/main.c:118
+#: ../vector/v.surf.idw/main.c:119
msgid "Required if layer > 0"
msgstr "ТÑебÑеÑÑÑ ÐµÑли Ñлой > 0"
-#: ../vector/v.surf.idw/main.c:122
+#: ../vector/v.surf.idw/main.c:123
msgid "Don't index points by raster cell"
msgstr "Ðе индекÑиÑоваÑÑ ÑоÑки ÑÑейкой ÑаÑÑÑа"
-#: ../vector/v.surf.idw/main.c:123
+#: ../vector/v.surf.idw/main.c:124
msgid ""
"Slower but uses less memory and includes points from outside region in the "
"interpolation"
@@ -19163,15 +17023,15 @@
"Ðедленнее, но иÑполÑзÑÐµÑ Ð¼ÐµÐ½ÑÑе памÑÑи и вклÑÑÐ°ÐµÑ Ð² Ð·Ð¾Ð½Ñ Ð¸Ð½ÑеÑполÑÑии ÑоÑки "
"вне Ñегиона"
-#: ../vector/v.surf.idw/main.c:141
+#: ../vector/v.surf.idw/main.c:142
msgid "No attribute column specified"
msgstr "ÐÑÑибÑÑивное поле не опÑеделено"
-#: ../vector/v.surf.idw/main.c:176
+#: ../vector/v.surf.idw/main.c:177
msgid "No data points found"
msgstr "Ðе найдено ни одной ÑоÑки Ñ Ð´Ð°Ð½Ð½Ñми"
-#: ../vector/v.surf.idw/main.c:261
+#: ../vector/v.surf.idw/main.c:262
#, c-format
msgid "Interpolating raster map <%s> (%d rows, %d cols)... "
msgstr "ÐнÑеÑполиÑование ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s> (%d ÑÑÑок, %d ÑÑолбÑов)... "
@@ -19208,11 +17068,11 @@
msgid "Name of the column containing w attribute to interpolate"
msgstr "ÐÐ¼Ñ Ð¿Ð¾Ð»Ñ, ÑодеÑжаÑего аÑÑибÑÑ w Ð´Ð»Ñ Ð¸Ð½ÑеÑполÑÑии"
-#: ../vector/v.vol.rst/main.c:260 ../vector/v.surf.rst/main.c:263
+#: ../vector/v.vol.rst/main.c:260 ../vector/v.surf.rst/main.c:299
msgid "Tension parameter"
msgstr "ÐаÑамеÑÑ Ð½Ð°ÑÑжениÑ"
-#: ../vector/v.vol.rst/main.c:268 ../vector/v.surf.rst/main.c:270
+#: ../vector/v.vol.rst/main.c:268 ../vector/v.surf.rst/main.c:306
msgid "Smoothing parameter"
msgstr "ÐаÑамеÑÑ ÑглаживаниÑ"
@@ -19220,13 +17080,11 @@
msgid "Name of the column with smoothing parameters"
msgstr "ÐÐ¼Ñ Ð¿Ð¾Ð»Ñ Ñ Ð¿Ð°ÑамеÑÑами ÑглаживаниÑ"
-#: ../vector/v.vol.rst/main.c:286 ../vector/v.surf.rst/main.c:330
+#: ../vector/v.vol.rst/main.c:286 ../vector/v.surf.rst/main.c:256
msgid "Output deviations vector point file"
msgstr "ÐÑÑ
одной векÑоÑнÑй ÑоÑеÑнÑй Ñайл оÑклонений"
#: ../vector/v.vol.rst/main.c:287 ../vector/v.vol.rst/main.c:295
-#: ../vector/v.surf.rst/main.c:331 ../vector/v.surf.rst/main.c:338
-#: ../vector/v.surf.rst/main.c:345 ../vector/v.surf.rst/main.c:352
msgid "Analysis"
msgstr "Ðнализ"
@@ -19234,101 +17092,102 @@
msgid "Output cross-validation vector map"
msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой кÑоÑÑ-пÑовеÑки"
-#: ../vector/v.vol.rst/main.c:302 ../vector/v.surf.rst/main.c:256
+#: ../vector/v.vol.rst/main.c:302 ../vector/v.surf.rst/main.c:283
msgid "Name of the raster map used as mask"
msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑлоÑ, иÑполÑзÑемого в каÑеÑÑве маÑки"
-#: ../vector/v.vol.rst/main.c:309 ../vector/v.surf.rst/main.c:286
+#: ../vector/v.vol.rst/main.c:309 ../vector/v.surf.rst/main.c:322
msgid "Maximum number of points in a segment"
msgstr "ÐакÑималÑное колиÑеÑÑво ÑоÑек в ÑегменÑе"
-#: ../vector/v.vol.rst/main.c:318 ../vector/v.surf.rst/main.c:295
+#: ../vector/v.vol.rst/main.c:318 ../vector/v.surf.rst/main.c:331
msgid "Minimum number of points for approximation in a segment (>segmax)"
msgstr "ÐинималÑное колиÑеÑÑво ÑоÑек Ð´Ð»Ñ Ð°Ð¿Ð¿ÑокÑимаÑии в ÑегменÑе (>segmax)"
-#: ../vector/v.vol.rst/main.c:327 ../vector/v.surf.rst/main.c:304
+#: ../vector/v.vol.rst/main.c:327
+#, fuzzy
+msgid "Maximum number of points for approximation in a segment (>npmin)"
+msgstr "ÐинималÑное колиÑеÑÑво ÑоÑек Ð´Ð»Ñ Ð°Ð¿Ð¿ÑокÑимаÑии в ÑегменÑе (>segmax)"
+#: ../vector/v.vol.rst/main.c:336 ../vector/v.surf.rst/main.c:340
msgid "Minimum distance between points (to remove almost identical points)"
msgstr ""
"ÐинималÑное ÑаÑÑÑоÑние Ð¼ÐµÐ¶Ð´Ñ ÑоÑками (ÑдалиÑÑ Ð¿Ð¾ÑÑи полноÑÑÑÑ Ð¸Ð´ÐµÐ½ÑиÑнÑе "
"ÑоÑки)"
-#: ../vector/v.vol.rst/main.c:336
+#: ../vector/v.vol.rst/main.c:345
msgid "Conversion factor for w-values used for interpolation"
msgstr ""
"ÐоÑÑÑиÑÐ¸ÐµÐ½Ñ Ð¿ÑеобÑÐ°Ð·Ð¾Ð²Ð°Ð½Ð¸Ñ Ð´Ð»Ñ w-знаÑений, иÑполÑзÑемÑй пÑи инÑеÑполÑÑии"
-#: ../vector/v.vol.rst/main.c:344
+#: ../vector/v.vol.rst/main.c:353
msgid "Conversion factor for z-values"
msgstr "ÐоÑÑÑиÑÐ¸ÐµÐ½Ñ Ð¿ÑеобÑÐ°Ð·Ð¾Ð²Ð°Ð½Ð¸Ñ Ð´Ð»Ñ z-знаÑений"
-#: ../vector/v.vol.rst/main.c:352
+#: ../vector/v.vol.rst/main.c:361
msgid "Output cross-section raster map"
msgstr "СоздаÑÑ ÑаÑÑÑовÑй Ñлой ÑеÑениÑ"
-#: ../vector/v.vol.rst/main.c:361
+#: ../vector/v.vol.rst/main.c:370
msgid "Output elevation g3d-file"
msgstr "ÐÑÑ
одной g3d-Ñайл вÑÑоÑ"
-#: ../vector/v.vol.rst/main.c:369
+#: ../vector/v.vol.rst/main.c:378
msgid "Output gradient magnitude g3d-file"
msgstr "ÐÑÑ
одной g3d-Ñайл магниÑÑдÑ"
-#: ../vector/v.vol.rst/main.c:379
-#, fuzzy
+#: ../vector/v.vol.rst/main.c:388
msgid "Output gradient horizontal angle g3d-file"
-msgstr "ÐÑÑ
одной Ñайл g3d гÑадиенÑов гоÑизонÑалÑного Ñгла"
+msgstr "ÐÑÑ
одной Ñайл гÑадиенÑа гоÑизонÑалÑного Ñгла g3d"
-#: ../vector/v.vol.rst/main.c:388
-#, fuzzy
+#: ../vector/v.vol.rst/main.c:397
msgid "Output gradient vertical angle g3d-file"
-msgstr "ÐÑÑ
одной Ñайл g3d гÑадиенÑов веÑÑикалÑного Ñгла"
+msgstr "ÐÑÑ
одной Ñайл гÑадиенÑа веÑÑикалÑного Ñгла g3d "
-#: ../vector/v.vol.rst/main.c:397
-#, fuzzy
+#: ../vector/v.vol.rst/main.c:406
msgid "Output change of gradient g3d-file"
-msgstr "ÐÑÑ
одной Ñайл g3d Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð³ÑадиенÑа"
+msgstr "ÐÑÑ
одной Ñайл Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð³ÑадиенÑа g3d "
-#: ../vector/v.vol.rst/main.c:406
+#: ../vector/v.vol.rst/main.c:415
msgid "Output gaussian curvature g3d-file"
msgstr "ÐÑÑ
одной g3d-Ñайл гаÑÑÑовой кÑивизнÑ"
-#: ../vector/v.vol.rst/main.c:415
+#: ../vector/v.vol.rst/main.c:424
msgid "Output mean curvature g3d-file"
msgstr "ÐÑÑ
одной g3d-Ñайл ÑÑедней кÑивизнÑ"
-#: ../vector/v.vol.rst/main.c:421
+#: ../vector/v.vol.rst/main.c:430
msgid "Perform a cross-validation procedure without volume interpolation"
msgstr ""
"ÐÑполниÑÑ Ð¿ÐµÑекÑеÑÑнÑÑ Ð¿ÑовеÑÐºÑ Ð±ÐµÐ· иÑполÑÐ·Ð¾Ð²Ð°Ð½Ð¸Ñ Ð¾Ð±Ñемной инÑеÑполÑÑии"
-#: ../vector/v.vol.rst/main.c:457
+#: ../vector/v.vol.rst/main.c:467
msgid "Smoothing must be a positive value"
msgstr "Сглаживание должно имеÑÑ Ð¿Ð¾Ð»Ð¾Ð¶Ð¸ÑелÑное знаÑение"
-#: ../vector/v.vol.rst/main.c:463
+#: ../vector/v.vol.rst/main.c:473
msgid "Both crossvalidation options (-c, cvdev) must be specified"
msgstr "ÐÐ¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ ÑÐºÐ°Ð·Ð°Ð½Ñ Ð¾Ð±Ðµ опÑии пеÑекÑеÑÑной пÑовеÑки (-c, cvdev)"
-#: ../vector/v.vol.rst/main.c:465
+#: ../vector/v.vol.rst/main.c:475
msgid "Both crossvalidation and deviations file specified"
msgstr "ÐпÑÐµÐ´ÐµÐ»ÐµÐ½Ñ Ð¿ÐµÑекÑеÑÑÐ½Ð°Ñ Ð¿ÑовеÑка и Ñайл оÑклонений"
-#: ../vector/v.vol.rst/main.c:548
+#: ../vector/v.vol.rst/main.c:557
msgid "Vector is not 3D"
msgstr "ÐекÑÐ¾Ñ Ð½Ðµ 3D"
-#: ../vector/v.vol.rst/main.c:584
+#: ../vector/v.vol.rst/main.c:596
#, c-format
msgid "Cannot create table: %s"
msgstr "Ðевозможно ÑоздаÑÑ ÑаблиÑÑ: %s "
-#: ../vector/v.vol.rst/main.c:600
+#: ../vector/v.vol.rst/main.c:612
#, c-format
msgid "Cannot open %s"
msgstr "Ðевозможно оÑкÑÑÑÑ %s"
#: ../vector/v.qcount/main.c:70
-#, fuzzy
msgid "Indices for quadrat counts of sites lists."
msgstr "ÐндекÑÑ Ð´Ð»Ñ ÐºÐ²Ð°Ð´ÑаÑов ÑÑеÑа ÑпиÑка ÑайÑов."
@@ -19360,7 +17219,7 @@
msgid "Counting sites in quadrats..."
msgstr "ÐодÑÑÐµÑ ÑайÑов в квадÑаÑаÑ
-#: ../vector/v.out.pov/main.c:207 ../vector/v.out.ogr/main.c:641
+#: ../vector/v.out.pov/main.c:207 ../vector/v.out.ogr/main.c:644
#, c-format
msgid "%d features written"
msgstr "Ðадано %d обÑекÑов"
@@ -19609,7 +17468,6 @@
msgstr "ÐижнÑÑ Ð»ÐµÐ²Ð°Ñ Ð²Ð¾ÑÑоÑÐ½Ð°Ñ Ð¸ ÑевеÑÐ½Ð°Ñ ÐºÐ¾Ð¾ÑдинаÑÑ ÑлоÑ"
#: ../vector/v.mkgrid/main.c:104
-#, fuzzy
msgid "Width and height of boxes in grid"
msgstr "ШиÑина и вÑÑоÑа пÑÑмоÑголÑников гÑида"
@@ -19619,7 +17477,7 @@
#: ../vector/v.mkgrid/main.c:116
msgid "Create grid of points instead of areas and centroids"
-msgstr ""
+msgstr "СоздаÑÑ ÑеÑÑ ÑоÑек вмеÑÑо полигонов и ÑенÑÑоидов"
#: ../vector/v.mkgrid/main.c:123
msgid "Quiet; No chatter"
@@ -19663,7 +17521,6 @@
msgstr "ÐÑполниÑÑ Ð´ÐµÐ¹ÑÑвие"
#: ../vector/v.category/main.c:84
-#, fuzzy
msgid ""
"add;add a new category;del;delete all categories of given layer;chlayer;"
"change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the "
@@ -19673,16 +17530,19 @@
msgstr ""
"add;добавиÑÑ Ð½Ð¾Ð²ÑÑ ÐºÐ°ÑегоÑиÑ;del;ÑдалиÑÑ ÐºÐ°ÑегоÑиÑ;chlayer;измениÑÑ Ð½Ð¾Ð¼ÐµÑ "
"ÑÐ»Ð¾Ñ (напÑимеÑ, Ñлой=3,1 менÑÐµÑ Ñлой 3 на Ñлой 1);sum;добавиÑÑ Ðº знаÑÐµÐ½Ð¸Ñ "
-"данной каÑегоÑи знаÑение, опÑеделенное опÑией каÑегоÑии;report;напеÑаÑаÑÑ "
+"данной каÑегоÑии знаÑение, опÑеделенное опÑией каÑегоÑии;report;напеÑаÑаÑÑ "
"оÑÑÐµÑ (ÑÑаÑиÑÑика), в ÑÑиле shell: Ñип ÑÐ»Ð¾Ñ Ð¸Ñоговое знаÑение минимÑм "
"макÑимÑм;print;пеÑаÑаÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий, болÑÑинÑÑво каÑегоÑий в одном и "
"Ñом же Ñлое ÑÐ°Ð·Ð´ÐµÐ»ÐµÐ½Ñ '/'"
#: ../vector/v.category/main.c:100
-#, fuzzy
msgid "Feature ids (by default all features are processed)"
-msgstr "Ðо ÑмолÑÐ°Ð½Ð¸Ñ Ð²Ñе обÑабаÑÑваÑÑÑÑ Ð²Ñе ids"
+msgstr "ID обÑекÑов (по ÑмолÑÐ°Ð½Ð¸Ñ Ð¾Ð±ÑабаÑÑваÑÑÑÑ Ð²Ñе)"
+#: ../vector/v.category/main.c:112
+msgid "Category increment"
+msgstr "Шаг номеÑа каÑегоÑии"
#: ../vector/v.category/main.c:116
msgid "Shell script style, currently only for report"
msgstr "СÑÐ¸Ð»Ñ ÑкÑипÑа shell, в наÑÑоÑÑее вÑÐµÐ¼Ñ ÑолÑко Ð´Ð»Ñ Ð¾ÑÑеÑа"
@@ -19703,6 +17563,8 @@
"Invalid category number (must be equal to or greater than 0). Normally "
"category number starts at 1."
msgstr ""
+"ÐепÑавилÑнÑй Ð½Ð¾Ð¼ÐµÑ ÐºÐ°ÑегоÑии (должен бÑÑÑ Ñавен или болÑÑе 0). ÐбÑÑно Ð½Ð¾Ð¼ÐµÑ "
+"каÑегоÑии наÑинаеÑÑÑ Ñ 1."
#: ../vector/v.category/main.c:162
#, c-format
@@ -19721,10 +17583,9 @@
msgid "Output vector wasn't entered"
msgstr "Ðе Ñказан вÑÑ
одной векÑоÑ"
-#: ../vector/v.category/main.c:229 ../vector/v.select/main.c:242
-#, fuzzy
+#: ../vector/v.category/main.c:229 ../vector/v.select/main.c:147
msgid "Processing features..."
-msgstr "ÐбÑабоÑка полигонов ainput..."
+msgstr "ÐбÑабоÑка обÑекÑов..."
#: ../vector/v.category/main.c:261 ../vector/v.delaunay2/main.c:154
msgid "Unable to calculate area centroid"
@@ -19744,47 +17605,42 @@
msgstr "Слой"
#: ../vector/v.category/main.c:451
-#, fuzzy, c-format
+#, c-format
msgid "type count min max\n"
-msgstr "Ðиапазон: минимÑм макÑимÑм\n"
+msgstr "Ñип ÑиÑло мин макÑ\n"
#: ../vector/v.category/main.c:452
-#, fuzzy
msgid "point"
-msgstr "ТоÑки"
+msgstr "ÑоÑка"
#: ../vector/v.category/main.c:456
-#, fuzzy
msgid "line"
-msgstr "Ðинии"
+msgstr "линиÑ"
#: ../vector/v.category/main.c:460
-#, fuzzy
msgid "boundary"
-msgstr "ÐÑаниÑÑ"
+msgstr "гÑаниÑа"
#: ../vector/v.category/main.c:464
msgid "centroid"
-msgstr ""
+msgstr "ÑенÑÑоид"
#: ../vector/v.category/main.c:468
-#, fuzzy
msgid "area"
-msgstr "ÐÑеÑваÑÑ"
+msgstr "полигон"
#: ../vector/v.category/main.c:472
msgid "all"
-msgstr ""
+msgstr "вÑе"
#: ../vector/v.category/main.c:525
-#, fuzzy
msgid "Copying attribute table(s)..."
-msgstr "УдалиÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ"
+msgstr "ÐопиÑоваÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ..."
#: ../vector/v.category/main.c:531
-#, fuzzy, c-format
+#, c-format
msgid "%d features modified."
-msgstr "%d обÑекÑов изменено"
+msgstr "%d обÑекÑов изменено."
#: ../vector/v.random/main.c:85
msgid "Randomly generate a 2D/3D vector points map."
@@ -19902,14 +17758,12 @@
msgstr "Endian иÑÑ
одного векÑоÑного ÑлоÑ"
#: ../vector/v.convert/att.c:36
-#, fuzzy
msgid "No category labels (dig_cats) found, no table created"
-msgstr "Ðе Ð½Ð°Ð¹Ð´ÐµÐ½Ñ Ð¿Ð¾Ð´Ð¿Ð¸Ñи каÑегоÑий (dig_cats), ÑаблиÑа не Ñоздана. \n"
+msgstr "Ðе Ð½Ð°Ð¹Ð´ÐµÐ½Ñ Ð¿Ð¾Ð´Ð¿Ð¸Ñи каÑегоÑий (dig_cats), ÑаблиÑа не Ñоздана"
#: ../vector/v.convert/att.c:41
-#, fuzzy
msgid "Unable to open dig_cats file"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл dig_cats"
#: ../vector/v.convert/read.c:41
msgid "Reading dig file..."
@@ -20051,7 +17905,7 @@
msgstr "ÐÑÑибÑÑ Ð½Ðµ найден"
#: ../vector/v.overlay/area_area.c:43 ../vector/v.buffer/main.c:625
-#: ../vector/v.buffer2/main.c:478
+#: ../vector/v.buffer2/main.c:505
msgid "Removing duplicates..."
msgstr "Удаление дÑбликаÑов..."
@@ -20060,7 +17914,7 @@
msgstr "ÐÑиÑÑка гÑÐ°Ð½Ð¸Ñ Ð² ÑзлаÑ
#: ../vector/v.overlay/area_area.c:55 ../vector/v.buffer/main.c:637
-#: ../vector/v.buffer2/main.c:490
+#: ../vector/v.buffer2/main.c:517
msgid "Attaching islands..."
msgstr "ÐазнаÑение оÑÑÑовов..."
@@ -20074,7 +17928,7 @@
msgstr "ÐапиÑÑ ÑенÑÑоидов..."
#: ../vector/v.overlay/area_area.c:264 ../vector/v.buffer/main.c:751
-#: ../vector/v.buffer2/main.c:599
+#: ../vector/v.buffer2/main.c:626
msgid "Attaching centroids..."
msgstr "ÐазнаÑаÑÑÑÑ ÑенÑÑоидÑ..."
@@ -20082,35 +17936,29 @@
msgid "Overlays two vector maps."
msgstr "ÐаложиÑÑ Ð´Ð²Ð° векÑоÑнÑÑ
ÑлоÑ."
-#: ../vector/v.overlay/main.c:59 ../vector/v.select/main.c:141
-#, fuzzy
+#: ../vector/v.overlay/main.c:59 ../vector/v.select/args.c:10
msgid "Name of input vector map (A)"
-msgstr "ÐÐ¼Ñ Ð¸ÑÑ
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного векÑоÑного ÑÐ»Ð¾Ñ (A)"
-#: ../vector/v.overlay/main.c:63 ../vector/v.select/main.c:145
-#, fuzzy
+#: ../vector/v.overlay/main.c:63 ../vector/v.select/args.c:14
msgid "Feature type (vector map A)"
-msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑй 3D Ñлой"
+msgstr "Тип обÑекÑов (векÑоÑнÑй Ñлой A)"
-#: ../vector/v.overlay/main.c:69 ../vector/v.select/main.c:150
-#, fuzzy
+#: ../vector/v.overlay/main.c:69 ../vector/v.select/args.c:19
msgid "Layer number (vector map A)"
-msgstr "векÑоÑ"
+msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ (векÑоÑнÑй Ñлой A)"
-#: ../vector/v.overlay/main.c:73 ../vector/v.select/main.c:155
-#, fuzzy
+#: ../vector/v.overlay/main.c:73 ../vector/v.select/args.c:24
msgid "Name of input vector map (B)"
-msgstr "ÐÐ¼Ñ Ð¸ÑÑ
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного векÑоÑного ÑÐ»Ð¾Ñ (B)"
-#: ../vector/v.overlay/main.c:77 ../vector/v.select/main.c:159
-#, fuzzy
+#: ../vector/v.overlay/main.c:77 ../vector/v.select/args.c:28
msgid "Feature type (vector map B)"
+msgstr "Тип обÑекÑов (векÑоÑнÑй Ñлой B)"
-#: ../vector/v.overlay/main.c:83 ../vector/v.select/main.c:164
-#, fuzzy
+#: ../vector/v.overlay/main.c:83 ../vector/v.select/args.c:33
msgid "Layer number (vector map B)"
-msgstr "векÑоÑ"
+msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ (векÑоÑнÑй Ñлой B)"
#: ../vector/v.overlay/main.c:95
msgid "Operator defines features written to output vector map"
@@ -20171,7 +18019,7 @@
msgstr "ÐеизвеÑÑнÑй Ñип ÑÑолбÑа '%s'"
#: ../vector/v.overlay/main.c:357 ../vector/v.out.svg/main.c:370
-#: ../vector/v.out.vtk/writeVTK.c:579 ../vector/v.out.ogr/main.c:700
+#: ../vector/v.out.vtk/writeVTK.c:579 ../vector/v.out.ogr/main.c:703
#: ../vector/v.lrs/v.lrs.label/main.c:347
msgid "Unable to fetch data from table"
msgstr "Ðевозможно вÑбÑаÑÑ Ð´Ð°Ð½Ð½Ñе из ÑаблиÑÑ"
@@ -20327,6 +18175,7 @@
msgid ""
"Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
msgstr ""
+"Ðевозможно загÑÑзиÑÑ Ð¿ÐµÑеÑекаÑÑиеÑÑ Ð²ÐµÑа. Ðоле %s в ÑаблиÑе <%s> не ÑиÑловое "
#: ../vector/v.label.sa/labels.c:281
#, c-format
@@ -20408,15 +18257,17 @@
"Numeric column to give precedence in case of overlapping labels. The label "
"with a smaller weight is hidden."
msgstr ""
+"ЧиÑловое поле ÑказÑваÑÑее пеÑвенÑÑво в ÑлÑÑае пеÑеÑекаÑÑиÑ
ÑÑ Ð¿Ð¾Ð´Ð¿Ð¸Ñей. "
+"СкÑÑваÑÑÑÑ Ð¿Ð¾Ð´Ð¿Ð¸Ñи Ñ Ð¼ÐµÐ½ÑÑим веÑом."
-#: ../vector/v.label.sa/font.c:55
+#: ../vector/v.label.sa/font.c:56
#, c-format
msgid "%s: Unable to read font definition file; use the default"
msgstr ""
"%s: Ðевозможно пÑоÑиÑаÑÑ Ñайл опиÑÐ°Ð½Ð¸Ñ ÑÑиÑÑа; иÑполÑзÑеÑÑÑ Ð¾Ð¿Ð¸Ñание по "
"ÑмолÑаниÑ"
-#: ../vector/v.label.sa/font.c:61
+#: ../vector/v.label.sa/font.c:62
#, c-format
msgid "%s: No font definition file"
msgstr "%s: ÐÑÑÑÑÑÑвÑÐµÑ Ñайл опиÑÐ°Ð½Ð¸Ñ ÑÑиÑÑа"
@@ -20683,9 +18534,8 @@
msgstr "Ðевозможно измениÑÑ ÑаблиÑÑ: %s"
#: ../vector/v.net/main.c:48
-#, fuzzy
msgid "Performs network maintenance."
-msgstr "ÐбÑлÑживание ÑеÑи."
+msgstr "ÐÑполниÑÑ Ð¾Ð±ÑлÑживание ÑеÑи."
#: ../vector/v.net/main.c:55
msgid "Name of input point vector map"
@@ -20727,7 +18577,6 @@
msgstr "ÐÐ»Ñ Ð¾Ð¿ÐµÑаÑии 'nodes'"
#: ../vector/v.net/main.c:120
-#, fuzzy
msgid "Unknown operation"
msgstr "ÐеизвеÑÑÐ½Ð°Ñ Ð¾Ð¿ÐµÑаÑиÑ"
@@ -20753,9 +18602,9 @@
#: ../vector/v.net/main.c:190
-#, fuzzy, c-format
+#, c-format
msgid "%d arcs added to network (nlayer %d)"
-msgstr "%d дÑг бÑло добавлено к ÑеÑи (nlayer: [%d])"
+msgstr "%d дÑг добавленÑÑ
к ÑеÑи (nlayer: %d)"
#: ../vector/v.net/nodes.c:85
#, c-format
@@ -20863,13 +18712,13 @@
"СмеÑение в единиÑаÑ
ÑлоÑ, положиÑелÑное Ð´Ð»Ñ Ð¿Ñавой ÑÑоÑонÑ, оÑÑиÑаÑелÑное - "
"Ð´Ð»Ñ Ð»ÐµÐ²Ð¾Ð¹"
-#: ../vector/v.what/what.c:90 ../vector/v.what/what.c:92
-#: ../display/d.what.vect/what.c:173 ../display/d.what.vect/what.c:175
+#: ../vector/v.what/what.c:105 ../vector/v.what/what.c:107
+#: ../display/d.what.vect/what.c:179 ../display/d.what.vect/what.c:181
#, c-format
msgid "Nothing Found.\n"
msgstr "ÐиÑего не найдено.\n"
-#: ../vector/v.what/what.c:135
+#: ../vector/v.what/what.c:157
#, c-format
msgid ""
"Id: %d\n"
@@ -20882,13 +18731,24 @@
"Слева: %d \n"
"СпÑава: %d \n"
-#: ../vector/v.what/what.c:139 ../vector/v.what/what.c:173
-#: ../display/d.what.vect/what.c:235
+#: ../vector/v.what/what.c:162 ../vector/v.what/what.c:217
+#: ../display/d.what.vect/what.c:241
#, c-format
msgid "Length: %f\n"
msgstr "Ðлина: %f\n"
-#: ../vector/v.what/what.c:155
+#: ../vector/v.what/what.c:180
+#, fuzzy, c-format
+msgid ""
+"Node[%d]=%d\n"
+"Number_lines=%d\n"
+"Coordinates=%.6f,%.6f,%.6f\n"
+msgstr ""
+"Узел[%d]: %d\n"
+"ЧиÑло линий: %d\n"
+"ÐооÑдинаÑÑ: %.6f, %.6f, %.6f\n"
+#: ../vector/v.what/what.c:185
#, c-format
msgid ""
"Node[%d]: %d\n"
@@ -20899,7 +18759,7 @@
"ЧиÑло линий: %d\n"
-#: ../vector/v.what/what.c:163
+#: ../vector/v.what/what.c:199
#, c-format
msgid ""
"Id: %5d\n"
@@ -20908,27 +18768,27 @@
"Id: %5d\n"
"Угол: %.8f\n"
-#: ../vector/v.what/what.c:170
+#: ../vector/v.what/what.c:214
#, c-format
msgid "Type: %s"
msgstr "Тип: %s"
-#: ../vector/v.what/what.c:171
+#: ../vector/v.what/what.c:215
#, c-format
msgid "Id: %d\n"
msgstr "Id: %d\n"
-#: ../vector/v.what/what.c:182 ../display/d.what.vect/what.c:289
+#: ../vector/v.what/what.c:231 ../display/d.what.vect/what.c:295
#, c-format
msgid "Point height: %f\n"
msgstr "ÐÑÑоÑа в ÑоÑкаÑ
: %f\n"
-#: ../vector/v.what/what.c:193 ../display/d.what.vect/what.c:307
+#: ../vector/v.what/what.c:248 ../display/d.what.vect/what.c:313
#, c-format
msgid "Line height: %f\n"
msgstr "ÐÑÑоÑа линии: %f\n"
-#: ../vector/v.what/what.c:197
+#: ../vector/v.what/what.c:259
#, c-format
msgid ""
"Line height min: %f\n"
@@ -20937,7 +18797,7 @@
"ÐинималÑÐ½Ð°Ñ Ð²ÑÑоÑа линии: %f\n"
"ÐакÑималÑÐ½Ð°Ñ Ð²ÑÑоÑа линии: %f\n"
-#: ../vector/v.what/what.c:206
+#: ../vector/v.what/what.c:273
#, c-format
msgid ""
"Type: Area\n"
@@ -20946,12 +18806,12 @@
"Тип: Ðолигон\n"
"ÐÑÑоÑа полигона: %f\n"
-#: ../vector/v.what/what.c:210
+#: ../vector/v.what/what.c:281
#, c-format
msgid "Type: Area\n"
msgstr "Тип: Ðолигон\n"
-#: ../vector/v.what/what.c:217
+#: ../vector/v.what/what.c:303
#, c-format
msgid ""
"Area: %d\n"
@@ -20960,17 +18820,17 @@
"Ðолигон: %d\n"
"ЧиÑло оÑÑÑовов: %d\n"
-#: ../vector/v.what/what.c:222
+#: ../vector/v.what/what.c:313
#, c-format
msgid "Isle[%d]: %d\n"
msgstr "ÐÑÑÑов[%d]: %d\n"
-#: ../vector/v.what/what.c:229
+#: ../vector/v.what/what.c:326
#, c-format
msgid "Island: %d In area: %d\n"
msgstr "ÐÑÑÑов: %d Рполигоне: %d\n"
-#: ../vector/v.what/what.c:234 ../vector/v.what/what.c:241
+#: ../vector/v.what/what.c:339 ../vector/v.what/what.c:346
#, c-format
msgid ""
"Sq Meters: %.3f\n"
@@ -20979,7 +18839,7 @@
"Ðв. меÑÑÑ: %.3f\n"
"ÐекÑаÑÑ: %.3f\n"
-#: ../vector/v.what/what.c:236 ../vector/v.what/what.c:244
+#: ../vector/v.what/what.c:341 ../vector/v.what/what.c:349
#, c-format
msgid ""
"Acres: %.3f\n"
@@ -20988,7 +18848,7 @@
"ÐкÑÑ: %.3f\n"
"Ðв. мили: %.4f\n"
-#: ../vector/v.what/what.c:262
+#: ../vector/v.what/what.c:372
#, c-format
msgid ""
"Layer: %d\n"
@@ -20997,7 +18857,7 @@
"Слой: %d\n"
"ÐаÑегоÑиÑ: %d\n"
-#: ../vector/v.what/what.c:269
+#: ../vector/v.what/what.c:386
#, c-format
msgid ""
"\n"
@@ -21036,16 +18896,17 @@
msgid "Print attribute information"
msgstr "ÐÑвод инÑоÑмаÑии об аÑÑибÑÑаÑ
-#: ../vector/v.what/main.c:155
+#: ../vector/v.what/main.c:159
#, c-format
msgid "You must build topology on vector map <%s>"
msgstr "ÐеобÑ
одимо ÑоздаÑÑ ÑÐ¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ <%s>"
-#: ../vector/v.what/main.c:158 ../display/d.what.vect/main.c:154
+#: ../vector/v.what/main.c:162 ../vector/v.select/main.c:141
+#: ../display/d.what.vect/main.c:154
msgid "Building spatial index..."
msgstr "ÐоÑÑÑоение пÑоÑÑÑанÑÑвенного индекÑа..."
-#: ../vector/v.what/main.c:174
+#: ../vector/v.what/main.c:178
#, c-format
msgid "Unknown input format, skipping: '%s'"
msgstr "ÐеизвеÑÑнÑй иÑÑ
однÑй ÑоÑмаÑ, пÑопÑÑено: '%s'"
@@ -21155,7 +19016,7 @@
msgid "Cannot select attributes for cat=%d"
msgstr "Ðевозможно вÑбÑаÑÑ Ð°ÑÑибÑÑÑ Ð´Ð»Ñ cat=%d"
-#: ../vector/v.to.db/update.c:27 ../vector/v.to.db/update.c:31
+#: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
#: ../vector/v.to.db/main.c:47 ../vector/v.to.db/query.c:83
#, c-format
msgid "Database connection not defined for layer %d. Use v.db.connect first."
@@ -21163,34 +19024,33 @@
"ÐÐ»Ñ ÑÐ»Ð¾Ñ %d не опÑеделено Ñоединение Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
. СнаÑала иÑполÑзÑйÑе v."
"db.connect."
-#: ../vector/v.to.db/update.c:74
+#: ../vector/v.to.db/update.c:82
msgid "Updating database..."
msgstr "Ðбновление Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../vector/v.to.db/update.c:106
-#, fuzzy, c-format
+#: ../vector/v.to.db/update.c:115
+#, c-format
msgid "More elements of category %d, nothing loaded to database"
-msgstr "Ðного ÑлеменÑов каÑегоÑии [%d], ниÑего не загÑÑжено в DB"
+msgstr "ÐолÑÑе ÑлеменÑов каÑегоÑии %d, в DB ниÑего не загÑÑжено"
-#: ../vector/v.to.db/update.c:204
-#, fuzzy, c-format
+#: ../vector/v.to.db/update.c:213
+#, c-format
msgid "Record (cat %d) already exists (not inserted)"
-msgstr "Cat [%d]: ÑÑÑока Ñже ÑÑÑеÑÑвÑÐµÑ (не вÑÑавлена)"
+msgstr "ÐапиÑÑ (каÑегоÑÐ¸Ñ %d) Ñже ÑÑÑеÑÑвÑÐµÑ (не вÑÑавлена)"
-#: ../vector/v.to.db/update.c:212 ../vector/v.to.3d/trans3.c:120
-#, fuzzy, c-format
+#: ../vector/v.to.db/update.c:221 ../vector/v.to.3d/trans3.c:120
+#, c-format
msgid "Record (cat %d) does not exist (not updated)"
-msgstr "Cat [%d]: ÑÑÑока не ÑÑÑеÑÑвÑÐµÑ (не обновлена)"
+msgstr "ÐапиÑÑ (каÑегоÑÐ¸Ñ %d) не ÑÑÑеÑÑвÑÐµÑ (не обновлена)"
#: ../vector/v.to.db/main.c:33
-#, fuzzy
msgid "Populates database values from vector features."
msgstr "ÐаполниÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
из векÑоÑнÑÑ
обÑекÑов."
#: ../vector/v.to.db/query.c:23 ../vector/v.to.db/lines.c:74
-#, fuzzy
+#: ../vector/v.to.rast/do_lines.c:35
msgid "Reading features..."
-msgstr "ЧÑение даннÑÑ
+msgstr "ЧÑение обÑекÑов..."
#: ../vector/v.to.db/query.c:93
msgid "Querying database... "
@@ -21218,22 +19078,18 @@
msgstr "Ðевозможно вÑбÑаÑÑ Ð·Ð°Ð¿Ð¸ÑÑ"
#: ../vector/v.to.db/parse.c:38
-#, fuzzy
msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr ""
-"Тип ÑлеменÑов (Ð´Ð»Ñ ÐºÐ¾Ð¾ÑÐ´Ð¸Ð½Ð°Ñ Ð¿ÑавилÑнÑе ÑоÑки/ÑенÑÑоидÑ, Ð´Ð»Ñ Ð´Ð»Ð¸Ð½Ñ "
-"пÑавилÑнÑе линии/гÑаниÑÑ)"
+msgstr "ÐÐ»Ñ ÐºÐ¾Ð¾ÑÐ´Ð¸Ð½Ð°Ñ Ð¿Ð¾Ð´Ñ
одÑÑ ÑоÑки/ÑенÑÑоидÑ, Ð´Ð»Ñ Ð´Ð»Ð¸Ð½Ñ - линии/гÑаниÑÑ"
#: ../vector/v.to.db/parse.c:42
-#, fuzzy
msgid "Layer number (write to)"
+msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ (Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи)"
#: ../vector/v.to.db/parse.c:46
msgid "Query layer number (read from)"
-msgstr ""
+msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ Ð²ÑбоÑки (Ð´Ð»Ñ ÑÑениÑ)"
-#: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:98
+#: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:99
msgid "Query"
msgstr "ÐапÑоÑ"
@@ -21241,92 +19097,99 @@
msgid "Value to upload"
msgstr "ÐнаÑение Ð´Ð»Ñ Ð·Ð°Ð³ÑÑзки"
-#: ../vector/v.to.db/parse.c:86
-msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-msgstr "mi(мили),f(ÑÑÑÑ),me(меÑÑÑ),k(киломеÑÑÑ),a(акÑÑ),h(гекÑаÑÑ)"
+#: ../vector/v.to.db/parse.c:87
+#, fuzzy
+msgid ""
+"mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
+msgstr ""
+"mi (мили), f (ÑÑÑÑ), me (меÑÑÑ), k (киломеÑÑÑ), a (акÑÑ), h (гекÑаÑÑ), p "
+"(пÑоÑенÑÑ)"
-#: ../vector/v.to.db/parse.c:92
+#: ../vector/v.to.db/parse.c:93
msgid "Name of attribute column used for 'query' option"
msgstr "ÐÐ»Ñ Ð¾Ð¿Ñии 'query' иÑполÑзÑеÑÑÑ Ð¸Ð¼Ñ ÑÑолбÑа аÑÑибÑÑов"
-#: ../vector/v.to.db/parse.c:93
+#: ../vector/v.to.db/parse.c:94
msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
msgstr "ÐапÑÐ¸Ð¼ÐµÑ 'cat', 'count(*)', 'sum(val)'"
-#: ../vector/v.to.db/parse.c:102
+#: ../vector/v.to.db/parse.c:103
msgid "Print only"
msgstr "ТолÑко Ð´Ð»Ñ Ð¿ÐµÑаÑи"
-#: ../vector/v.to.db/parse.c:107
-#, fuzzy
+#: ../vector/v.to.db/parse.c:108
msgid "Only print SQL statements"
-msgstr "ÐеÑаÑаÑÑ ÑолÑко запÑÐ¾Ñ sql"
+msgstr "ÐÑводиÑÑ ÑолÑко вÑÑÐ°Ð¶ÐµÐ½Ð¸Ñ SQL"
-#: ../vector/v.to.db/parse.c:113
+#: ../vector/v.to.db/parse.c:114
msgid "In print mode prints totals for options: length,area,count"
msgstr ""
"Ð Ñежиме пеÑаÑи вÑÐ²Ð¾Ð´Ð¸Ñ ÑÑммаÑнÑе знаÑÐµÐ½Ð¸Ñ Ð¾Ð¿Ñий: длина, облаÑÑÑ, колиÑеÑÑво"
-#: ../vector/v.to.db/parse.c:149
+#: ../vector/v.to.db/parse.c:150
msgid "This option requires one column"
msgstr "ÐÑа опÑÐ¸Ñ ÑÑебÑÐµÑ Ð¾Ð´Ð½Ð¾Ð³Ð¾ ÑÑолбÑа"
-#: ../vector/v.to.db/parse.c:154
+#: ../vector/v.to.db/parse.c:155
msgid "This option requires two columns"
msgstr "ÐÑа опÑÐ¸Ñ ÑÑебÑÐµÑ Ð´Ð²ÑÑ
ÑÑолбÑов"
-#: ../vector/v.to.db/parse.c:159
+#: ../vector/v.to.db/parse.c:160
msgid "This option requires at least two columns"
msgstr "ÐÑа опÑÐ¸Ñ ÑÑебÑÐµÑ ÐºÐ°Ðº минимÑм два ÑÑолбÑа"
-#: ../vector/v.to.db/parse.c:165
+#: ../vector/v.to.db/parse.c:166
msgid "Parameter 'qcolumn' must be specified for 'option=query'"
msgstr "ÐÐ»Ñ Ð¾Ð¿Ñии 'option=query' должен бÑÑÑ Ñказан паÑамеÑÑ 'qcolumn'"
-#: ../vector/v.to.db/parse.c:170
+#: ../vector/v.to.db/parse.c:171
msgid "The 'sides' option makes sense only for boundaries"
msgstr "ÐпÑÐ¸Ñ 'sides' пÑименима ÑолÑко к гÑаниÑам"
-#: ../vector/v.to.db/parse.c:173
+#: ../vector/v.to.db/parse.c:174
msgid "The 'sinuous' option makes sense only for lines"
msgstr "ÐпÑÐ¸Ñ 'sinuous' пÑименима ÑолÑко к линиÑм"
-#: ../vector/v.to.db/areas.c:28
+#: ../vector/v.to.db/parse.c:177
#, fuzzy
+msgid "The 'azimuth' option makes sense only for lines"
+msgstr "ÐпÑÐ¸Ñ 'sinuous' пÑименима ÑолÑко к линиÑм"
+#: ../vector/v.to.db/areas.c:28 ../vector/v.to.rast/do_areas.c:33
msgid "Reading areas..."
+msgstr "ЧÑение полигонов..."
-#: ../vector/v.to.db/report.c:181
-#, fuzzy, c-format
+#: ../vector/v.to.db/report.c:187
+#, c-format
msgid "%d categories read from vector map (layer %d)"
-msgstr "пÑоÑиÑано из ÑÐ»Ð¾Ñ %d каÑегоÑий"
+msgstr "пÑоÑиÑано из ÑÐ»Ð¾Ñ %d каÑегоÑий (Ñлой %d)"
-#: ../vector/v.to.db/report.c:185
-#, fuzzy, c-format
+#: ../vector/v.to.db/report.c:191
+#, c-format
msgid "%d records selected from table (layer %d)"
-msgstr "из ÑаблиÑÑ Ð²ÑбÑано %d ÑÑÑок "
+msgstr "из ÑаблиÑÑ Ð²ÑбÑано %d ÑÑÑок (Ñлой %d)"
-#: ../vector/v.to.db/report.c:188
-#, fuzzy, c-format
+#: ../vector/v.to.db/report.c:194
+#, c-format
msgid "%d categories read from vector map exist in selection from table"
msgstr "%d каÑегоÑий, пÑоÑиÑаннÑÑ
из ÑÐ»Ð¾Ñ ÑÑÑеÑÑвÑÑÑ Ð² вÑбоÑке из ÑаблиÑÑ"
-#: ../vector/v.to.db/report.c:191
-#, fuzzy, c-format
+#: ../vector/v.to.db/report.c:197
+#, c-format
msgid "%d categories read from vector map don't exist in selection from table"
из ÑÐ»Ð¾Ñ Ð½Ðµ ÑÑÑеÑÑвÑÑÑ Ð² вÑбоÑке из ÑаблиÑÑ"
-#: ../vector/v.to.db/report.c:193
-#, fuzzy, c-format
+#: ../vector/v.to.db/report.c:199
+#, c-format
msgid "%d records updated/inserted (layer %d)"
-msgstr "%d запиÑей обновлено/вÑÑавлено"
+msgstr "%d запиÑей обновлено/вÑÑавлено (Ñлой %d)"
-#: ../vector/v.to.db/report.c:196
-#, fuzzy, c-format
+#: ../vector/v.to.db/report.c:202
+#, c-format
msgid "%d update/insert errors (layer %d)"
-msgstr "%d оÑибок вÑÑавки/обновлениÑ"
+msgstr "%d оÑибок вÑÑавки/Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½Ð¸Ñ (Ñлой %d)"
-#: ../vector/v.to.db/report.c:199
+#: ../vector/v.to.db/report.c:205
#, c-format
msgid "%d categories with more points (coordinates not loaded)"
msgstr "%d каÑегоÑий Ñ Ð±Ð¾Ð»ÑÑим колиÑеÑÑвом ÑоÑек (кооÑдинаÑÑ Ð½Ðµ загÑÑженÑ)"
@@ -21336,7 +19199,7 @@
"No coordinates to generate the output! Maybe an empty vector type chosen?"
msgstr "ÐÐµÑ ÐºÐ¾Ð¾ÑÐ´Ð¸Ð½Ð°Ñ Ð´Ð»Ñ Ð²Ñвода! Ðозможно, Ñказан оÑÑÑÑÑÑвÑеÑий Ñип векÑоÑа."
-#: ../vector/v.out.vtk/writeVTK.c:575 ../vector/v.out.ogr/main.c:695
+#: ../vector/v.out.vtk/writeVTK.c:575 ../vector/v.out.ogr/main.c:698
#, c-format
msgid "Cannot select attributes for cat = %d"
@@ -21373,6 +19236,10 @@
msgid "Path to resulting VTK file"
msgstr "ÐÑÑÑ Ðº вÑÑ
Ð¾Ð´Ð½Ð¾Ð¼Ñ ÑÐ°Ð¹Ð»Ñ VTK"
+#: ../vector/v.out.vtk/main.c:83
+msgid "Layer number"
+msgstr "ÐÐ¾Ð¼ÐµÑ ÑлоÑ"
#: ../vector/v.out.vtk/main.c:93
msgid "Export numeric attribute table fields as VTK scalar variables"
msgstr ""
@@ -21384,9 +19251,8 @@
msgstr "ÐнаÑение dp должно бÑÑÑ Ð¾Ñ 0 до 8"
#: ../vector/v.out.vtk/main.c:197
-#, fuzzy
msgid "Failed to interpret 'layer' parameter as an integer"
-msgstr "Ðевозможно инÑеÑпÑеÑиÑоваÑÑ Ð¿Ð°ÑамеÑÑ 'layer' как Ñелое ÑиÑло"
+msgstr "Ðевозможно инÑеÑпÑеÑиÑоваÑÑ Ð¿Ð°ÑамеÑÑ 'layer' как ÑелоÑиÑленнÑй"
#: ../vector/v.support/main.c:40
msgid "vector, metadata"
@@ -21448,24 +19314,75 @@
msgid "Unable to open history file for vector map <%s>"
msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл иÑÑоÑии Ð´Ð»Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ <%s>"
-#: ../vector/v.select/main.c:136
+#: ../vector/v.select/main.c:52
#, fuzzy
-msgid "vector, query"
+msgid "vector, spatial query"
msgstr "векÑоÑ, запÑоÑ"
-#: ../vector/v.select/main.c:138
-#, fuzzy
+#: ../vector/v.select/main.c:54
msgid ""
"Selects features from vector map (A) by features from other vector map (B)."
-msgstr "ÐÑбÑаÑÑ Ð¾Ð±ÑекÑÑ Ð¸Ð· ainut по обÑекÑам из binput"
+msgstr ""
+"ÐÑбÑаÑÑ Ð¾Ð±ÑекÑÑ Ð¸Ð· векÑоÑного ÑÐ»Ð¾Ñ (A) по обÑекÑам из векÑоÑного ÑÐ»Ð¾Ñ (B)"
-#: ../vector/v.select/main.c:178
+#: ../vector/v.select/main.c:80
#, fuzzy
-msgid "Operator defines required relation between features"
-msgstr "ÐнаÑÐµÐ½Ð¸Ñ Ð¾Ð¿Ð¸ÑÑваÑÑие оÑноÑение Ð¼ÐµÐ¶Ð´Ñ Ð±Ð»Ð¸Ð¶Ð°Ð¹Ñими обÑекÑами"
+msgid "Unknown operator"
+msgstr "ÐеизвеÑÑÐ½Ð°Ñ Ð¾Ð¿ÐµÑаÑиÑ"
-#: ../vector/v.select/main.c:180
+#: ../vector/v.select/main.c:83
+#, c-format
+msgid "Enable GEOS operators (flag '%c') to use '%s'"
+msgstr ""
+#: ../vector/v.select/main.c:122
#, fuzzy
+msgid "Output from v.select"
+msgstr "ФоÑÐ¼Ð°Ñ Ð²Ñвода"
+#: ../vector/v.select/main.c:170
+#, fuzzy, c-format
+msgid "Unable to read line id %d from vector map <%s>"
+msgstr "Ðевозможно обÑабоÑаÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½ из векÑоÑного ÑÐ»Ð¾Ñ <%s>"
+#: ../vector/v.select/main.c:276
+msgid "Processing areas..."
+msgstr "ÐбÑабоÑка полигонов..."
+#: ../vector/v.select/main.c:299
+#, fuzzy, c-format
+msgid "Unable to read area id %d from vector map <%s>"
+#: ../vector/v.select/main.c:444
+msgid "Writing selected features..."
+msgstr "ÐапиÑÑ Ð²ÑбÑаннÑÑ
обÑекÑов..."
+#: ../vector/v.select/main.c:510
+#, c-format
+msgid "Layer %d - no table"
+msgstr "Слой %d - Ð½ÐµÑ ÑаблиÑÑ"
+#: ../vector/v.select/main.c:525
+#, c-format
+msgid "Layer %d - unable to copy table"
+msgstr "Слой %d - невозможно ÑкопиÑоваÑÑ ÑаблиÑÑ"
+#: ../vector/v.select/main.c:540
+#, fuzzy, c-format
+msgid "%d features without category skipped"
+msgstr "пÑопÑÑено %d обÑекÑов без каÑегоÑий"
+#: ../vector/v.select/main.c:543
+#, fuzzy, c-format
+msgid "%d features written to output."
+msgstr "%d обÑекÑов запиÑано в '%s'."
+#: ../vector/v.select/args.c:45
+msgid "Operator defines required relation between features"
+msgstr "ÐпеÑаÑÐ¾Ñ Ð¾Ð¿Ð¸ÑÑÐ²Ð°ÐµÑ Ð½ÐµÐ¾Ð±Ñ
одимÑе оÑноÑÐµÐ½Ð¸Ñ Ð¼ÐµÐ¶Ð´Ñ Ð¾Ð±ÑекÑами"
+#: ../vector/v.select/args.c:47
msgid ""
"A feature is written to output if the result of operation 'ainput operator "
"binput' is true. An input feature is considered to be true, if category of "
@@ -21475,30 +19392,30 @@
"operator binput' - иÑÑина. ÐÑÑ
однÑй обÑÐµÐºÑ ÑаÑÑмаÑÑиваеÑÑÑ ÐºÐ°Ðº иÑÑиннÑй, "
"еÑли Ñказана каÑегоÑÐ¸Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ð¾Ð³Ð¾ ÑлоÑ."
-#: ../vector/v.select/main.c:182
+#: ../vector/v.select/args.c:52
msgid "overlap;features partially or completely overlap"
+msgstr "пеÑекÑÑвание;обÑекÑÑ ÑаÑÑиÑно или полноÑÑÑÑ Ð¿ÐµÑекÑÑваÑÑÑÑ"
+#: ../vector/v.select/args.c:57
+msgid ""
+"equals;features are spatially equals (requires flag 'g');disjoint;features "
+"do not spatially intersect (requires flag 'g');intersects;features spatially "
+"intersect (requires flag 'g');touches;features spatially touches (requires "
+"flag 'g');crosses;features spatially crosses (requires flag 'g');within;"
+"feature A is completely inside feature B (requires flag 'g');contains;"
+"feature B is completely inside feature A (requires flag 'g');overlap;"
+"features spatilly overlap;relate;feature A is spatially related to feature B "
+"(requires 'relate' option and flag 'g');"
msgstr ""
-#: ../vector/v.select/main.c:322
-#, fuzzy
-msgid "Processing areas..."
+#: ../vector/v.select/args.c:73
+msgid "Intersection Matrix Pattern used for 'relate' operator"
+msgstr ""
-#: ../vector/v.select/main.c:443
-#, fuzzy
-msgid "Writing selected features..."
-msgstr "ÐмпоÑÑиÑование %d обÑекÑов ÑлоÑ..."
+#: ../vector/v.select/args.c:87
+msgid "Use GEOS operators"
+msgstr ""
-#: ../vector/v.select/main.c:509
-#, fuzzy, c-format
-msgid "Layer %d - no table"
-msgstr "Слой < %s > недоÑÑÑпен"
-#: ../vector/v.select/main.c:524
-#, fuzzy, c-format
-msgid "Layer %d - unable to copy table"
-msgstr "Ðевозможно ÑкопиÑоваÑÑ ÑаблиÑÑ"
#: ../vector/v.net.alloc/main.c:63
msgid "Allocate subnets for nearest centres (direction from centre)."
msgstr "ÐÑделиÑÑ Ð¿Ð¾Ð´ÑеÑи Ð´Ð»Ñ Ð±Ð»Ð¸Ð¶Ð°Ð¹ÑиÑ
ÑенÑÑов (напÑавление Ð¾Ñ ÑенÑÑа)."
@@ -21680,37 +19597,35 @@
msgstr "ÐеÑеÑное ÑиÑло Ñипов"
#: ../vector/v.in.dwg/main.c:66
-#, fuzzy
msgid "Converts DWG/DXF to GRASS vector map"
-msgstr "ÐонвеÑÑиÑоваÑÑ Ð²ÐµÐºÑоÑнÑе Ñлои OGR в векÑоÑнÑе Ñлои GRASS."
+msgstr "ÐонвеÑÑиÑоваÑÑ DWG/DXF в векÑоÑнÑй Ñлой GRASS"
#: ../vector/v.in.dwg/main.c:69
-#, fuzzy
msgid "Name of DWG or DXF file"
-msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного Ñайла DXF"
+msgstr "ÐÐ¼Ñ DWG или DXF Ñайла"
#: ../vector/v.in.dwg/main.c:92
msgid "Write circles as points (centre)"
-msgstr ""
+msgstr "ÐапиÑаÑÑ Ð¾ÐºÑÑжноÑÑи как ÑоÑки (ÑенÑÑ)"
#: ../vector/v.in.dwg/main.c:100
msgid "Use numeric type for attribute \"layer\""
-msgstr ""
+msgstr "ÐÑполÑзоваÑÑ ÑиÑленнÑй Ñип Ñ Ð°ÑÑибÑÑом \"layer\""
#: ../vector/v.in.dwg/main.c:120
#, c-format
msgid "Unable to initialize OpenDWG Toolkit, error: %d: %s."
-msgstr ""
+msgstr "Ðевозможно инниÑиализиÑоваÑÑ OpenDWG Toolkit, оÑибка: %d: %s."
#: ../vector/v.in.dwg/main.c:123
-#, fuzzy, c-format
+#, c-format
msgid "%s Cannot open %s"
-msgstr " "
+msgstr "%s Ðевозможно оÑкÑÑÑÑ %s"
#: ../vector/v.in.dwg/main.c:131
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open input file <%s>. Error %d: %s"
-msgstr "Ðевозможно оÑкÑÑÑÑ Ð¸ÑÑ
однÑй Ñайл <%s>"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ð¸ÑÑ
однÑй Ñайл <%s>. ÐÑибка %d: %s"
#: ../vector/v.in.dwg/main.c:266
#, c-format
@@ -21736,88 +19651,97 @@
msgid "Perform cross-validation procedure without raster approximation"
msgstr "ÐÑполнение пÑоÑедÑÑÑ ÐºÑоÑÑ-валидаÑии без ÑаÑÑÑовой аппÑокÑимаÑии"
-#: ../vector/v.surf.rst/main.c:193
+#: ../vector/v.surf.rst/main.c:194
msgid "Use scale dependent tension"
msgstr "ÐÑполÑзÑеÑÑÑ Ð·Ð°Ð²Ð¸ÑÑÑее Ð¾Ñ Ð¼Ð°ÑÑÑаба напÑÑжение Ñплайна"
-#: ../vector/v.surf.rst/main.c:214
-msgid ""
-"Name of the attribute column with values to be used for approximation (if "
-"layer>0)"
-msgstr "ÐÐ¼Ñ ÑÑолбÑа аÑÑибÑÑа Ñо знаÑениÑми Ð´Ð»Ñ Ð°Ð¿Ð¿ÑокÑимаÑии (еÑли Ñлой > 0)"
+#: ../vector/v.surf.rst/main.c:201 ../vector/v.surf.rst/main.c:219
+#: ../vector/v.surf.rst/main.c:225 ../vector/v.surf.rst/main.c:231
+#: ../vector/v.surf.rst/main.c:237 ../vector/v.surf.rst/main.c:243
+#: ../vector/v.surf.rst/main.c:249 ../vector/v.surf.rst/main.c:257
+#: ../vector/v.surf.rst/main.c:264 ../vector/v.surf.rst/main.c:271
+#: ../vector/v.surf.rst/main.c:278
+#, fuzzy
+msgid "Outputs"
+msgstr " "
-#: ../vector/v.surf.rst/main.c:221
+#: ../vector/v.surf.rst/main.c:218
msgid "Output surface raster map (elevation)"
msgstr "ÐÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ (вÑÑоÑа)"
-#: ../vector/v.surf.rst/main.c:226
+#: ../vector/v.surf.rst/main.c:224
msgid "Output slope raster map"
msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой кÑÑÑизнÑ"
-#: ../vector/v.surf.rst/main.c:232
+#: ../vector/v.surf.rst/main.c:230
msgid "Output aspect raster map"
msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой ÑкÑпозиÑий"
-#: ../vector/v.surf.rst/main.c:238
+#: ../vector/v.surf.rst/main.c:236
msgid "Output profile curvature raster map"
msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой кÑÐ¸Ð²Ð¸Ð·Ð½Ñ Ð¿ÑоÑилÑ"
-#: ../vector/v.surf.rst/main.c:244
+#: ../vector/v.surf.rst/main.c:242
msgid "Output tangential curvature raster map"
msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой повеÑÑ
ноÑÑной кÑивизнÑ"
-#: ../vector/v.surf.rst/main.c:250
+#: ../vector/v.surf.rst/main.c:248
msgid "Output mean curvature raster map"
msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой ÑÑедней кÑивизнÑ"
-#: ../vector/v.surf.rst/main.c:278
+#: ../vector/v.surf.rst/main.c:263
+msgid "Output cross-validation errors vector point file"
+msgstr "ÐÑÑ
одной ÑоÑеÑнÑй векÑоÑнÑй Ñайл оÑибок кÑоÑÑ-валидаÑии"
+#: ../vector/v.surf.rst/main.c:270
+msgid "Output vector map showing quadtree segmentation"
+msgstr "ÐÑÑ
одной векÑоÑнÑй Ñлой показÑваÑÑий ÑегменÑаÑÐ¸Ñ ÐºÐ²Ð°Ð´ÑаÑиÑного деÑева"
+#: ../vector/v.surf.rst/main.c:277
+msgid "Output vector map showing overlapping windows"
+msgstr "ÐÑÑ
одной векÑоÑнÑй Ñлой показÑваÑÑий пеÑекÑÑваÑÑиеÑÑ Ð¾ÐºÐ½Ð°"
+#: ../vector/v.surf.rst/main.c:291
+msgid ""
+"Name of the attribute column with values to be used for approximation (if "
+"layer>0)"
+msgstr "ÐÐ¼Ñ ÑÑолбÑа аÑÑибÑÑа Ñо знаÑениÑми Ð´Ð»Ñ Ð°Ð¿Ð¿ÑокÑимаÑии (еÑли Ñлой > 0)"
+#: ../vector/v.surf.rst/main.c:314
msgid "Name of the attribute column with smoothing parameters"
msgstr "ÐÐ¼Ñ ÑÑолбÑа аÑÑибÑÑов Ñ Ð¿Ð°ÑамеÑÑами ÑглаживаниÑ"
-#: ../vector/v.surf.rst/main.c:313
+#: ../vector/v.surf.rst/main.c:349
msgid ""
"Maximum distance between points on isoline (to insert additional points)"
msgstr ""
"ÐакÑималÑное ÑаÑÑÑоÑние Ð¼ÐµÐ¶Ð´Ñ ÑоÑками на изолинии (Ð´Ð»Ñ Ð´Ð¾Ð±Ð°Ð²Ð»ÐµÐ½Ð¸Ñ "
"дополниÑелÑнÑÑ
ÑоÑек)"
-#: ../vector/v.surf.rst/main.c:322
+#: ../vector/v.surf.rst/main.c:358
msgid "Conversion factor for values used for approximation"
msgstr "ФакÑÐ¾Ñ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð´Ð»Ñ Ð·Ð½Ð°Ñений, иÑполÑзÑемÑÑ
пÑи аппÑокÑимаÑии"
-#: ../vector/v.surf.rst/main.c:337
-msgid "Output cross-validation errors vector point file"
-msgstr "ÐÑÑ
-#: ../vector/v.surf.rst/main.c:344
-msgid "Output vector map showing quadtree segmentation"
-msgstr "ÐÑÑ
-#: ../vector/v.surf.rst/main.c:351
-msgid "Output vector map showing overlapping windows"
-msgstr "ÐÑÑ
-#: ../vector/v.surf.rst/main.c:359
+#: ../vector/v.surf.rst/main.c:366
msgid "Anisotropy angle (in degrees counterclockwise from East)"
msgstr "Угол анизоÑÑопноÑÑи (в гÑадÑÑаÑ
пÑоÑив ÑаÑовой ÑÑÑелки Ñ Ð²Ð¾ÑÑока)"
-#: ../vector/v.surf.rst/main.c:394 ../vector/v.surf.rst/main.c:399
-#: ../vector/v.surf.rst/main.c:404 ../vector/v.surf.rst/main.c:409
-#, fuzzy, c-format
+#: ../vector/v.surf.rst/main.c:401 ../vector/v.surf.rst/main.c:406
+#: ../vector/v.surf.rst/main.c:411 ../vector/v.surf.rst/main.c:416
+#, c-format
msgid "Output vector map name <%s> is not valid map name"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного векÑоÑного ÑÐ»Ð¾Ñ Ð½Ðµ бÑло Ñказано"
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного векÑоÑного ÑÐ»Ð¾Ñ <%s> невеÑно"
-#: ../vector/v.surf.rst/main.c:422
-#, fuzzy
+#: ../vector/v.surf.rst/main.c:429
msgid "You are not outputting any raster or vector maps"
-msgstr "Ðе вÑводиÑÑÑ Ð½Ð¸ ÑаÑÑÑовÑÑ
, ни векÑоÑнÑÑ
Ñлоев"
+msgstr "Ðе вÑводÑÑÑÑ Ð½Ð¸ ÑаÑÑÑовÑе, ни векÑоÑнÑе Ñлои"
-#: ../vector/v.surf.rst/main.c:426 ../vector/v.extract/main.c:274
+#: ../vector/v.surf.rst/main.c:433 ../vector/v.extract/main.c:274
#: ../display/d.vect/main.c:492
msgid "'layer' must be > 0 for 'where'."
msgstr "'layer' должен бÑÑÑ > 0 Ð´Ð»Ñ 'where'."
-#: ../vector/v.surf.rst/main.c:435
+#: ../vector/v.surf.rst/main.c:442
msgid ""
"Both cross-validation options (-c flag and cvdev vector output) must be "
"specified"
@@ -21825,7 +19749,7 @@
"ÐÐ¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ ÑÐºÐ°Ð·Ð°Ð½Ñ Ð¾Ð±Ðµ опÑии кÑоÑÑ-валидаÑии (Ñлаг -c и вÑÑ
одной векÑÐ¾Ñ "
"cvdev)"
-#: ../vector/v.surf.rst/main.c:438
+#: ../vector/v.surf.rst/main.c:445
msgid ""
"The cross-validation cannot be computed simultaneously with output raster or "
"devi file"
@@ -21833,36 +19757,36 @@
"ÐÑоÑÑ-валидаÑÐ¸Ñ Ð½Ðµ Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð²ÑÑиÑлена одновÑеменно Ñ Ð²ÑÑ
однÑм ÑаÑÑÑом или "
"Ñайлом оÑклонений"
-#: ../vector/v.surf.rst/main.c:456
+#: ../vector/v.surf.rst/main.c:463
msgid "Using anisotropy - both theta and scalex have to be specified"
msgstr "ÐÑполÑзÑеÑÑÑ Ð°Ð½Ð¸Ð·Ð¾ÑÑопноÑÑÑ - Ð´Ð¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ Ð¾Ð¿ÑÐµÐ´ÐµÐ»ÐµÐ½Ñ theta и scalex"
-#: ../vector/v.surf.rst/main.c:464
+#: ../vector/v.surf.rst/main.c:471
msgid "Both smatt and smooth options specified - using constant"
msgstr "Ð£ÐºÐ°Ð·Ð°Ð½Ñ Ð¾Ð±Ðµ опÑии smatt и smooth - иÑполÑзÑеÑÑÑ ÐºÐ¾Ð½ÑÑанÑа"
-#: ../vector/v.surf.rst/main.c:474
+#: ../vector/v.surf.rst/main.c:481
msgid "The computation will last too long - lower npmin is suggested"
msgstr ""
"ÐÑÑиÑление Ð·Ð°Ð¹Ð¼ÐµÑ Ð¼Ð½Ð¾Ð³Ð¾ вÑемени - ÑекомендÑеÑÑÑ ÑменÑÑиÑÑ Ð·Ð½Ð°Ñение npmin"
-#: ../vector/v.surf.rst/main.c:521
+#: ../vector/v.surf.rst/main.c:528
msgid "Cannot create quaddata"
msgstr "Ðевозможно ÑоздаÑÑ quaddata"
-#: ../vector/v.surf.rst/main.c:527
+#: ../vector/v.surf.rst/main.c:534
msgid "Cannot create quadfunc"
msgstr "Ðевозможно ÑоздаÑÑ quadfunc"
-#: ../vector/v.surf.rst/main.c:530
+#: ../vector/v.surf.rst/main.c:537
msgid "Cannot create tree"
msgstr "Ðевозможно ÑоздаÑÑ Ð´ÐµÑево"
-#: ../vector/v.surf.rst/main.c:534
+#: ../vector/v.surf.rst/main.c:541
msgid "Cannot create tree info"
msgstr "Ðевозможно ÑоздаÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ деÑеве"
-#: ../vector/v.surf.rst/main.c:727
+#: ../vector/v.surf.rst/main.c:734
#, c-format
msgid ""
"Processing all selected output files\n"
@@ -21871,14 +19795,18 @@
"ÐбÑабоÑка вÑеÑ
вÑбÑаннÑÑ
вÑÑ
однÑÑ
Ñайлов\n"
"поÑÑебÑÐµÑ %d Ð±Ð°Ð¹Ñ Ð´Ð¸Ñкового пÑоÑÑÑанÑÑва Ð´Ð»Ñ Ð²ÑеменнÑÑ
Ñайлов"
-#: ../vector/v.surf.rst/main.c:751
+#: ../vector/v.surf.rst/main.c:758
msgid "Interp_segmets failed"
msgstr "оÑибка Interp_segmets"
-#: ../vector/v.surf.rst/main.c:768
+#: ../vector/v.surf.rst/main.c:775
msgid "Cannot write raster maps -- try to increase resolution"
msgstr "Ðевозможно ÑоздаÑÑ ÑаÑÑÑовÑй Ñайл -- попÑобÑйÑе ÑвелиÑиÑÑ ÑазÑеÑение"
+#: ../vector/v.in.db/main.c:52
+msgid "vector, import, database, points"
+msgstr "векÑоÑ, импоÑÑ, база даннÑÑ
, ÑоÑки"
#: ../vector/v.in.db/main.c:54
msgid ""
"Creates new vector (points) map from database table containing coordinates."
@@ -21890,23 +19818,27 @@
msgid "Input table name"
msgstr "ÐведиÑе Ð¸Ð¼Ñ ÑаблиÑÑ"
-#: ../vector/v.in.db/main.c:70
+#: ../vector/v.in.db/main.c:63 ../vector/v.in.db/main.c:67
+msgid "Connection"
+msgstr "СвÑзÑ"
+#: ../vector/v.in.db/main.c:72
msgid "Name of column containing x coordinate"
msgstr "ÐÐ¼Ñ ÑÑолбÑа, ÑодеÑжаÑего кооÑдинаÑÑ x"
-#: ../vector/v.in.db/main.c:75
+#: ../vector/v.in.db/main.c:77
msgid "Name of column containing y coordinate"
msgstr "ÐÐ¼Ñ ÑÑолбÑа, ÑодеÑжаÑего кооÑдинаÑÑ y"
-#: ../vector/v.in.db/main.c:79
+#: ../vector/v.in.db/main.c:81
msgid "Name of column containing z coordinate"
msgstr "ÐÐ¼Ñ ÑÑолбÑа, ÑодеÑжаÑего кооÑдинаÑÑ z"
-#: ../vector/v.in.db/main.c:84
+#: ../vector/v.in.db/main.c:86
msgid "Name of column containing category number"
msgstr " ÐÐ¼Ñ Ð¿Ð¾Ð»Ñ Ñ Ð½Ð¾Ð¼ÐµÑом каÑегоÑии"
-#: ../vector/v.in.db/main.c:129
+#: ../vector/v.in.db/main.c:130
#, c-format
msgid ""
"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
@@ -21914,34 +19846,43 @@
"ÐÑÑ
одной векÑоÑнÑй Ñлой, ÑаблиÑа <%s> (дÑайвеÑ: <%s>, база даннÑÑ
: <%s>) Ñже "
"ÑÑÑеÑÑвÑеÑ"
-#: ../vector/v.in.db/main.c:162 ../display/d.vect/attr.c:112
+#: ../vector/v.in.db/main.c:163 ../display/d.vect/attr.c:112
#: ../display/d.vect.chart/plot.c:85
#, c-format
msgid "Unable to open select cursor: '%s'"
msgstr "Ðевозможно оÑкÑÑÑÑ ÐºÑÑÑÐ¾Ñ Ð²ÑбоÑа: '%s'"
-#: ../vector/v.in.db/main.c:174
+#: ../vector/v.in.db/main.c:173
+msgid "Writing features..."
+msgstr "ÐапиÑÑ Ð¾Ð±ÑекÑов..."
+#: ../vector/v.in.db/main.c:180
msgid "Key column must be integer"
msgstr "ÐлÑÑевой ÑÑÐ¾Ð»Ð±ÐµÑ Ð´Ð¾Ð»Ð¶ÐµÐ½ бÑÑÑ ÑелоÑиÑленнÑм"
-#: ../vector/v.in.db/main.c:182
+#: ../vector/v.in.db/main.c:188
msgid "x/y/z column must be integer or double"
msgstr "ÑÑÐ¾Ð»Ð±ÐµÑ x/y/z должен бÑÑÑ ÑелоÑиÑленнÑм или double"
-#: ../vector/v.in.db/main.c:203
-#, c-format
-msgid "%d points written to vector map"
-msgstr "%d ÑоÑек запиÑано в векÑоÑнÑй Ñлой"
+#: ../vector/v.in.db/main.c:212 ../vector/v.to.3d/main.c:96
+#: ../vector/v.to.3d/main.c:118
+msgid "Copying attributes..."
+msgstr "ÐопиÑование аÑÑибÑÑов..."
-#: ../vector/v.in.db/main.c:219 ../vector/v.extract/main.c:480
+#: ../vector/v.in.db/main.c:225 ../vector/v.extract/main.c:480
msgid "Unable to copy table"
-#: ../vector/v.to.rast/do_lines.c:63 ../vector/v.to.rast/do_areas.c:61
+#: ../vector/v.in.db/main.c:235
+#, c-format
+msgid "%d points written to vector map."
+msgstr "%d ÑоÑек запиÑано в векÑоÑнÑй Ñлой."
+#: ../vector/v.to.rast/do_lines.c:65 ../vector/v.to.rast/do_areas.c:63
msgid "Unable to use column specified"
msgstr "Ðевозможно иÑполÑзоваÑÑ Ñказанное поле"
-#: ../vector/v.to.rast/do_lines.c:122
+#: ../vector/v.to.rast/do_lines.c:124
#, c-format
msgid "%d lines with varying height were not written to raster"
msgstr "%d ÑÑÑок Ñазной Ð´Ð»Ð¸Ð½Ñ Ð½Ðµ бÑли запиÑÐ°Ð½Ñ Ð² ÑаÑÑÑ"
@@ -21951,7 +19892,7 @@
msgstr "векÑоÑ, ÑаÑÑÑ, конвеÑÑаÑиÑ"
#: ../vector/v.to.rast/main.c:39
-msgid "Converts a binary GRASS vector map layer into a GRASS raster map layer."
+msgid "Converts a binary GRASS vector map into a GRASS raster map ."
msgstr "ÐонвеÑÑиÑоваÑÑ Ð±Ð¸Ð½Ð°ÑнÑй векÑоÑнÑй Ñлой GRASS в ÑаÑÑÑовÑй Ñлой GRASS."
#: ../vector/v.to.rast/main.c:52
@@ -22057,24 +19998,28 @@
msgid "Unable to write categories for raster map <%s>"
msgstr "Ðевозможно запиÑаÑÑ ÐºÐ°ÑегоÑии Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
-#: ../vector/v.to.rast/do_areas.c:47 ../vector/v.to.rast/do_areas.c:55
+#: ../vector/v.to.rast/do_areas.c:49 ../vector/v.to.rast/do_areas.c:57
#, c-format
msgid "No record for area (cat = %d)"
msgstr "ÐÑÑÑÑÑÑвÑÐµÑ Ð·Ð°Ð¿Ð¸ÑÑ Ð´Ð»Ñ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ð° (cat = %d)"
-#: ../vector/v.to.rast/do_areas.c:76
+#: ../vector/v.to.rast/do_areas.c:78
#, c-format
msgid "Get area %d failed"
msgstr "Ðе ÑдалоÑÑ Ð¿Ð¾Ð»ÑÑиÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½ %d"
-#: ../vector/v.to.rast/do_areas.c:115
+#: ../vector/v.to.rast/do_areas.c:118
msgid "Area without centroid (may be OK for island)"
msgstr "Ðолигон без ÑенÑÑоида (возможно Ð´Ð»Ñ Ð¾ÑÑÑова)"
-#: ../vector/v.to.rast/do_areas.c:122
+#: ../vector/v.to.rast/do_areas.c:125
msgid "Area centroid without category"
msgstr "ЦенÑÑоид полигона без каÑегоÑии"
+#: ../vector/v.to.rast/vect2rast.c:39
+msgid "Loading data..."
+msgstr "ÐагÑÑзка даннÑÑ
#: ../vector/v.to.rast/vect2rast.c:44
#, c-format
msgid "Vector map <%s> is not 3D"
@@ -22115,20 +20060,24 @@
msgid "Problem processing lines from vector map <%s>, continuing..."
msgstr "ÐÑоблема обÑабоÑки линий векÑоÑного ÑÐ»Ð¾Ñ <%s>, пÑодолжаÑ..."
-#: ../vector/v.to.rast/vect2rast.c:182
+#: ../vector/v.to.rast/vect2rast.c:199
+msgid "Creating support files for raster map..."
+msgstr "Создание Ñайлов поддеÑжки Ð´Ð»Ñ ÑаÑÑÑового ÑлоÑ..."
+#: ../vector/v.to.rast/vect2rast.c:206
+msgid "Color can be updated from database only if use=attr"
+msgstr "Ð¦Ð²ÐµÑ Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½ из Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
ÑолÑко еÑли use=attr"
+#: ../vector/v.to.rast/vect2rast.c:224
#, c-format
msgid "Converted areas: %d of %d"
msgstr "ÐонвеÑÑиÑовано полигонов: %d из %d"
-#: ../vector/v.to.rast/vect2rast.c:183
+#: ../vector/v.to.rast/vect2rast.c:225
#, c-format
msgid "Converted points/lines: %d of %d"
msgstr "ÐонвеÑÑиÑовано ÑоÑек/линий: %d из %d"
-#: ../vector/v.to.rast/vect2rast.c:209
-msgid "Color can be updated from database only if use=attr"
-msgstr "Ð¦Ð²ÐµÑ Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½ из Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
#: ../vector/v.drape/main.c:166
msgid "vector, geometry, sampling"
msgstr "векÑоÑ, геомеÑÑиÑ, полÑÑение даннÑÑ
@@ -22152,18 +20101,18 @@
msgstr "ÐаÑÑÑабиÑоваÑÑ Ð¿Ð¾Ð»ÑÑеннÑе знаÑÐµÐ½Ð¸Ñ ÑаÑÑÑа"
#: ../vector/v.drape/main.c:206
-#, fuzzy
msgid "Layer is only used for WHERE SQL statement"
-msgstr "ÐÑполÑзоваÑÑ db.select Ð´Ð»Ñ SQL-опеÑаÑоÑа SELECT"
+msgstr "Слой иÑполÑзÑеÑÑÑ ÑолÑко в вÑÑажении WHERE SQL"
#: ../vector/v.drape/main.c:211
-#, fuzzy
msgid "Vector Z value for unknown height"
-msgstr "ÐÑÑоÑа векÑоÑной линии"
+msgstr "ÐнаÑение Z Ð´Ð»Ñ Ð²ÐµÐºÑÐ¾Ñ Ñ Ð½ÐµÐ¸Ð·Ð²ÐµÑÑной вÑÑоÑой"
#: ../vector/v.drape/main.c:213
msgid "Will set Z to this value, if value from raster map can not be read"
msgstr ""
+"Z бÑÐ´ÐµÑ ÑÑÑановлено ÑавнÑм ÑÑÐ¾Ð¼Ñ Ð·Ð½Ð°ÑениÑ, еÑли знаÑение не ÑÐ¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ "
+"пÑоÑиÑано из ÑаÑÑÑового ÑлоÑ"
#: ../vector/v.drape/main.c:220 ../vector/v.extract/main.c:204
msgid "Layer 0 not supported"
@@ -22171,16 +20120,17 @@
#: ../vector/v.drape/main.c:305
msgid "No features match Your query"
-msgstr ""
+msgstr "ÐапÑÐ¾Ñ Ð½Ðµ веÑнÑл ÑооÑвеÑÑÑвÑÑÑиÑ
обÑекÑов"
#: ../vector/v.drape/main.c:407 ../vector/v.drape/main.c:417
msgid "Due to error attribute data to new map are not transferred"
-msgstr ""
+msgstr "ÐÑÑибÑÑивнÑе даннÑе не пеÑенеÑÐµÐ½Ñ Ð² новÑй Ñлой из-за оÑибки"
#: ../vector/v.drape/main.c:425
msgid ""
"No features drapped. Check Your computational region and input raster map."
msgstr ""
+"ÐбÑекÑÑ Ð½Ðµ дÑаппиÑованÑ. ÐÑовеÑÑÑе ÑаÑÑеÑнÑй Ñегион и вÑ
одной ÑаÑÑÑовÑй Ñлой."
#: ../vector/v.out.ogr/main.c:88
msgid "Converts to one of the supported OGR vector formats."
@@ -22245,17 +20195,22 @@
msgid "The combination of types is not supported by all formats."
msgstr "ÐомбинаÑÐ¸Ñ Ñипов не поддеÑживаеÑÑÑ Ð½Ð¸ÐºÐ°ÐºÐ¸Ð¼Ð¸ ÑоÑмаÑами."
-#: ../vector/v.out.ogr/main.c:246
+#: ../vector/v.out.ogr/main.c:218
+msgid ""
+"The map contains islands. To preserve them in the output map, use the -c flag"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:249
#, c-format
msgid "OGR driver <%s> not found"
msgstr "ÐÑÐ°Ð¹Ð²ÐµÑ OGR <%s> не найден"
-#: ../vector/v.out.ogr/main.c:263
+#: ../vector/v.out.ogr/main.c:266
#, c-format
msgid "Unable to open OGR data source '%s'"
msgstr "Ðевозможно оÑкÑÑÑÑ Ð¸ÑÑоÑник даннÑÑ
OGR '%s'"
-#: ../vector/v.out.ogr/main.c:284 ../vector/v.out.ogr/main.c:291
+#: ../vector/v.out.ogr/main.c:287 ../vector/v.out.ogr/main.c:294
#, c-format
msgid ""
"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
@@ -22264,36 +20219,36 @@
"ÐекÑоÑнÑй Ñлой <%s> 3D. ÐÑполÑзÑйÑе опÑии ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ ÑпеÑиалÑно Ð´Ð»Ñ ÑоÑмаÑа "
"(паÑамеÑÑ 'lco') Ð´Ð»Ñ ÑкÑпоÑÑа в 3D а не 2D (по ÑмолÑаниÑ)"
-#: ../vector/v.out.ogr/main.c:303
+#: ../vector/v.out.ogr/main.c:306
msgid "Unable to create OGR layer"
msgstr "Ðевозможно ÑоздаÑÑ Ñлой OGR"
-#: ../vector/v.out.ogr/main.c:312
+#: ../vector/v.out.ogr/main.c:315
msgid "No attribute table found -> using only category numbers as attributes"
msgstr ""
"ÐÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа не найдена -> иÑполÑзÑÑÑÑÑ ÑолÑко номеÑа каÑегоÑий как "
"аÑÑибÑÑÑ"
-#: ../vector/v.out.ogr/main.c:374
+#: ../vector/v.out.ogr/main.c:377
#, c-format
msgid "Key column '%s' not found"
msgstr "ÐлÑÑевое поле '%s' не найдено"
-#: ../vector/v.out.ogr/main.c:386
+#: ../vector/v.out.ogr/main.c:389
#, c-format
msgid ""
"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
msgstr ""
"%d ÑоÑек найдено, но запÑоÑено Ð´Ð»Ñ ÑкÑпоÑÑа. ÐÑовеÑÑÑе паÑамеÑÑ 'type'."
-#: ../vector/v.out.ogr/main.c:391
+#: ../vector/v.out.ogr/main.c:394
#, c-format
msgid ""
"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
msgstr ""
"%d линий найдено, но не запÑоÑено Ð´Ð»Ñ ÑкÑпоÑÑа. ÐÑовеÑÑÑе паÑамеÑÑ 'type'."
-#: ../vector/v.out.ogr/main.c:397
+#: ../vector/v.out.ogr/main.c:400
#, c-format
msgid ""
"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
@@ -22301,7 +20256,7 @@
msgstr ""
"%d гÑÐ°Ð½Ð¸Ñ Ð½Ð°Ð¹Ð´ÐµÐ½Ð¾, но не запÑоÑено Ð´Ð»Ñ ÑкÑпоÑÑа. ÐÑовеÑÑÑе паÑамеÑÑ 'type'."
-#: ../vector/v.out.ogr/main.c:403
+#: ../vector/v.out.ogr/main.c:406
#, c-format
msgid ""
"%d centroid(s) found, but not requested to be exported. Verify 'type' "
@@ -22310,7 +20265,7 @@
"%d ÑенÑÑоидов найдено, но не запÑоÑено Ð´Ð»Ñ ÑкÑпоÑÑа. ÐÑовеÑÑÑе паÑамеÑÑ "
"'type'."
-#: ../vector/v.out.ogr/main.c:408
+#: ../vector/v.out.ogr/main.c:411
#, c-format
msgid ""
"%d areas found, but not requested to be exported. Verify 'type' parameter."
@@ -22318,40 +20273,40 @@
"%d полигонов найдено, но не запÑоÑено Ð´Ð»Ñ ÑкÑпоÑÑа. ÐÑовеÑÑÑе паÑамеÑÑ "
"'type'."
-#: ../vector/v.out.ogr/main.c:413
+#: ../vector/v.out.ogr/main.c:416
#, c-format
msgid ""
"%d faces found, but not requested to be exported. Verify 'type' parameter."
msgstr ""
"%d faces найдено, но не запÑоÑено Ð´Ð»Ñ ÑкÑпоÑÑа. ÐÑовеÑÑÑе паÑамеÑÑ 'type'."
-#: ../vector/v.out.ogr/main.c:421
+#: ../vector/v.out.ogr/main.c:424
#, c-format
msgid "Exporting %i points/lines..."
msgstr "ÐкÑпоÑÑ %i ÑоÑек/линий..."
-#: ../vector/v.out.ogr/main.c:499
+#: ../vector/v.out.ogr/main.c:502
#, c-format
msgid "Exporting %i areas (may take some time)..."
msgstr "ÐкÑпоÑÑ %i полигонов (Ð¼Ð¾Ð¶ÐµÑ Ð·Ð°Ð½ÑÑÑ Ð²ÑемÑ)..."
-#: ../vector/v.out.ogr/main.c:571
+#: ../vector/v.out.ogr/main.c:574
#, c-format
msgid "Exporting %i faces (may take some time) ..."
msgstr "ÐкÑпоÑÑ %i faces (Ð¼Ð¾Ð¶ÐµÑ Ð·Ð°Ð½ÑÑÑ Ð²ÑемÑ) ..."
-#: ../vector/v.out.ogr/main.c:643
-#, fuzzy, c-format
+#: ../vector/v.out.ogr/main.c:646
+#, c-format
msgid "%d features without category were written"
msgstr "запиÑано %d обÑекÑов без каÑегоÑий"
-#: ../vector/v.out.ogr/main.c:645
-#, fuzzy, c-format
+#: ../vector/v.out.ogr/main.c:648
+#, c-format
msgid "%d features without attributes were written"
msgstr "запиÑано %d обÑекÑов без аÑÑибÑÑов"
-#: ../vector/v.out.ogr/main.c:647
-#, fuzzy, c-format
+#: ../vector/v.out.ogr/main.c:650
+#, c-format
msgid "%d features found without category were skipped"
@@ -22382,7 +20337,6 @@
msgstr "ÐаÑегоÑии ÑоÑек ÑеÑминалÑнÑÑ
Ñзлов (Ñлой задаеÑÑÑ nlayer)"
#: ../vector/v.net.steiner/main.c:389
-#, fuzzy
msgid "Number of steiner points (-1 for all possible)"
msgstr "ЧиÑло ÑоÑек ÑÑайнеÑа (-1 Ð´Ð»Ñ Ð²ÑеÑ
возможнÑÑ
@@ -22531,7 +20485,6 @@
msgstr "Файл подпиÑей"
#: ../vector/v.lrs/v.lrs.label/main.c:155
-#, fuzzy
msgid "PM left, MP right, stationing left, stationing right offset"
msgstr "PM Ñлева, MP ÑпÑава, ÑÑанÑии Ñлева, ÑÑанÑии ÑпÑава ÑмеÑение"
@@ -22555,11 +20508,11 @@
#: ../vector/v.lrs/v.lrs.label/main.c:220
msgid "Line width of highlight color"
-msgstr ""
+msgstr "ШиÑина полоÑÑ ÑвеÑа подÑвеÑки"
#: ../vector/v.lrs/v.lrs.label/main.c:246
msgid "Opaque to vector"
-msgstr ""
+msgstr "ÐепÑозÑаÑноÑÑÑ Ð²ÐµÐºÑоÑа"
#: ../vector/v.lrs/v.lrs.label/main.c:247
msgid "Only relevant if background color is selected"
@@ -22942,11 +20895,11 @@
"СоздаÑÑ Ð±ÑÑÐµÑ Ð²Ð¾ÐºÑÑг обÑекÑов данного Ñипа (плоÑаднÑе обÑекÑÑ Ð´Ð¾Ð»Ð¶Ð½Ñ "
"ÑодеÑжаÑÑ ÑенÑÑоидÑ)."
-#: ../vector/v.buffer/main.c:271
+#: ../vector/v.buffer/main.c:271 ../vector/v.buffer2/main.c:221
msgid "Buffer distance in map units"
msgstr "РаÑÑÑоÑние бÑÑеÑизаÑии в единиÑаÑ
каÑÑÑ"
-#: ../vector/v.buffer/main.c:278 ../vector/v.buffer2/main.c:187
+#: ../vector/v.buffer/main.c:278
msgid "Attribute column to use for buffer distances"
msgstr "ÐÑÑибÑÑивное поле иÑполÑзÑемое Ð´Ð»Ñ ÑаÑÑÑоÑÐ½Ð¸Ñ Ð±ÑÑеÑизаÑии"
@@ -22954,7 +20907,7 @@
msgid "Scaling factor for attribute column values"
msgstr "ФакÑÐ¾Ñ Ð¼Ð°ÑÑÑабиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð´Ð»Ñ Ð·Ð½Ð°Ñений аÑÑибÑÑивного полÑ"
-#: ../vector/v.buffer/main.c:296 ../vector/v.buffer2/main.c:205
+#: ../vector/v.buffer/main.c:296 ../vector/v.buffer2/main.c:203
msgid ""
"Maximum distance between theoretical arc and polygon segments as multiple of "
"buffer"
@@ -22966,7 +20919,7 @@
msgid "Stop the process at a certain stage"
msgstr "ÐÑÑановиÑÑ Ð¿ÑоÑеÑÑ Ð² опÑеделеннÑй моменÑ"
-#: ../vector/v.buffer/main.c:319 ../vector/v.buffer2/main.c:229
+#: ../vector/v.buffer/main.c:319 ../vector/v.buffer2/main.c:247
msgid ""
"The bufcol option may contain bugs during the cleaning step. If you "
"encounter problems, use the debug option or clean manually with v.clean "
@@ -22977,8 +20930,8 @@
"step=0; v.extract -d type=area"
#: ../vector/v.buffer/main.c:335 ../vector/v.buffer/main.c:485
-#: ../vector/v.buffer/main.c:562 ../vector/v.buffer2/main.c:379
-#: ../vector/v.buffer2/main.c:445
+#: ../vector/v.buffer/main.c:562 ../vector/v.buffer2/main.c:406
+#: ../vector/v.buffer2/main.c:472
#, c-format
msgid "The tolerance in map units: %g"
msgstr "ÐоÑог в единиÑаÑ
ÑлоÑ: %g"
@@ -22993,7 +20946,7 @@
msgstr "ÐÑÑеÑизаÑÐ¸Ñ Ð»Ð¸Ð½Ð¸Ð¹..."
#: ../vector/v.buffer/main.c:473 ../vector/v.buffer/main.c:550
-#: ../vector/v.buffer2/main.c:365 ../vector/v.buffer2/main.c:431
+#: ../vector/v.buffer2/main.c:392 ../vector/v.buffer2/main.c:458
#, c-format
msgid "Attribute is of invalid size (%.3f) for category %d"
msgstr "ÐепÑавилÑнÑй ÑÐ°Ð·Ð¼ÐµÑ Ð°ÑÑибÑÑа (%.3f) Ð´Ð»Ñ ÐºÐ°ÑегоÑии %d"
@@ -23007,15 +20960,15 @@
msgid "Areas buffers... "
msgstr "ÐÑÑеÑизаÑÐ¸Ñ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ð¾Ð²..."
-#: ../vector/v.buffer/main.c:607 ../vector/v.buffer2/main.c:469
+#: ../vector/v.buffer/main.c:607 ../vector/v.buffer2/main.c:496
msgid "Building parts of topology..."
msgstr "ÐоÑÑÑоение ÑаÑÑей Ñопологии..."
-#: ../vector/v.buffer/main.c:619 ../vector/v.buffer2/main.c:472
+#: ../vector/v.buffer/main.c:619 ../vector/v.buffer2/main.c:499
msgid "Snapping boundaries..."
msgstr "ÐÑилипание гÑаниÑ..."
-#: ../vector/v.buffer/main.c:622 ../vector/v.buffer2/main.c:475
+#: ../vector/v.buffer/main.c:622 ../vector/v.buffer2/main.c:502
msgid "Breaking boundaries..."
msgstr "РазÑÑв гÑаниÑ..."
@@ -23082,9 +21035,8 @@
msgstr "ÐÑибка в pj_do_transform"
#: ../vector/v.extract/main.c:91
-#, fuzzy
msgid "vector, extract"
-msgstr "векÑоÑнÑй Ñлой, ÑкÑпоÑÑ"
+msgstr "векÑоÑ, ÑкÑпоÑÑ"
#: ../vector/v.extract/main.c:93
msgid ""
@@ -23103,15 +21055,14 @@
msgstr "Ðе копиÑоваÑÑ ÑаблиÑÑ (Ñм. Ñакже паÑамеÑÑ 'new')"
#: ../vector/v.extract/main.c:116
-#, fuzzy
msgid "Types to be extracted"
msgstr "ÐÑделÑемÑе ÑипÑ"
#: ../vector/v.extract/main.c:122
-#, fuzzy
msgid ""
"Layer number (if -1, all features in all layers of given type are extracted)"
-msgstr "ÐÑли -1, бÑдÑÑ Ð²ÑÐ´ÐµÐ»ÐµÐ½Ñ Ð²Ñе обÑекÑÑ Ð²Ð¾ вÑеÑ
ÑлоÑÑ
заданного Ñипа."
+msgstr ""
+"ÐÐ¾Ð¼ÐµÑ ÑлоÑ(еÑли -1, бÑдÑÑ Ð²ÑÐ´ÐµÐ»ÐµÐ½Ñ Ð²Ñе обÑекÑÑ Ð²Ð¾ вÑеÑ
ÑлоÑÑ
заданного Ñипа)"
#: ../vector/v.extract/main.c:136
msgid "Input text file with category numbers/number ranges to be extracted"
@@ -23124,11 +21075,11 @@
#: ../vector/v.extract/main.c:145
msgid "Number of random categories matching vector objects to extract"
-msgstr ""
+msgstr "ЧиÑло ÑлÑÑайнÑÑ
каÑегоÑий векÑоÑнÑÑ
обÑкÑов Ð´Ð»Ñ Ð¸Ð·Ð²Ð»ÐµÑениÑ"
#: ../vector/v.extract/main.c:147
msgid "Number must be smaller than unique cat count in layer"
-msgstr ""
+msgstr "ЧиÑло должно бÑÑÑ Ð¼ÐµÐ½ÑÑе Ñем ÑиÑло ÑникалÑнÑÑ
каÑегоÑий ÑлоÑ"
#: ../vector/v.extract/main.c:156
msgid "Enter -1 to keep original categories or the desired NEW category value"
@@ -23145,6 +21096,8 @@
"List, file, where and random options are exclusive. Please specify only one "
"of them"
msgstr ""
+"ÐпÑии List, file, where и random взаимоÑклÑÑаÑÑие. ÐÑполÑзÑйÑе ÑолÑко Ð¾Ð´Ð½Ñ "
+"из ниÑ
#: ../vector/v.extract/main.c:228
#, c-format
@@ -23176,11 +21129,12 @@
"This map has no categories attached. Use v.category to attach categories to "
"this vector map."
msgstr ""
+"У ÑÑого ÑÐ»Ð¾Ñ Ð½ÐµÑ ÐºÐ°ÑегоÑий. ÐÑполÑзÑйÑе v.category Ð´Ð»Ñ Ð½Ð°Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий "
+"ÑÑÐ¾Ð¼Ñ Ð²ÐµÐºÑоÑÐ½Ð¾Ð¼Ñ ÑлоÑ."
#: ../vector/v.extract/main.c:318
-#, fuzzy
msgid "Please specify random number larger than 0"
-msgstr "ÐведиÑе колиÑеÑÑво ÑÑÑок, коÑоÑÑе бÑдÑÑ Ð¿ÑопÑÑенÑ"
+msgstr "ÐадайÑе ÑлÑÑайное ÑиÑло болÑÑее Ñем 0"
#: ../vector/v.extract/main.c:322
#, c-format
@@ -23188,6 +21142,8 @@
"Random category count must be smaller than feature count. There are only %d "
"features of type(s): %s"
msgstr ""
+"ЧиÑло ÑлÑÑайнÑÑ
каÑегоÑий должно бÑÑÑ Ð¼ÐµÐ½ÑÑе ÑиÑла обÑекÑов. ЧиÑло обÑекÑов %"
+"d Ñипа (Ñипов): %s"
#: ../vector/v.extract/main.c:345
#, c-format
@@ -23195,11 +21151,12 @@
"Random category count is larger or equal to uniq \"%s\" feature category "
"count %d"
msgstr ""
+"ЧиÑло ÑлÑÑайнÑÑ
каÑегоÑий болÑÑе или Ñавно ÑиÑÐ»Ñ ÑникалÑнÑÑ
\"%s\" каÑегоÑий "
+"обÑекÑов %d"
#: ../vector/v.extract/main.c:382
-#, fuzzy
msgid "Extracting features..."
-msgstr "ÐолÑÑение полигонов..."
+msgstr "ÐкÑÑÑакÑÐ¸Ñ Ð¾Ð±ÑекÑов..."
#: ../vector/v.extract/main.c:497
msgid "Removing duplicate centroids..."
@@ -23209,221 +21166,229 @@
#: ../vector/v.delaunay2/memory.c:27 ../vector/v.delaunay2/memory.c:31
#: ../vector/v.delaunay2/memory.c:41 ../vector/v.delaunay2/memory.c:49
#: ../vector/v.delaunay2/memory.c:61 ../vector/v.delaunay2/memory.c:65
-#, fuzzy
msgid "Not enough memory."
-msgstr "Ðе Ñ
ваÑÐ°ÐµÑ Ð¿Ð°Ð¼ÑÑи Ð´Ð»Ñ az"
+msgstr "Ðе Ñ
ваÑÐ°ÐµÑ Ð¿Ð°Ð¼ÑÑи."
#: ../vector/v.delaunay2/main.c:160
-#, fuzzy
msgid "Unable to calculate area centroid z coordinate"
msgstr "Ðевозможно вÑÑиÑлиÑÑ z-кооÑдинаÑÑ ÑенÑÑоида полигона "
#: ../vector/v.delaunay2/memory.c:81
msgid "All allocated edges have been used."
-msgstr ""
+msgstr "ÐÑли иÑполÑÐ·Ð¾Ð²Ð°Ð½Ñ Ð²Ñе гÑани."
#: ../vector/v.to.3d/main.c:36
-#, fuzzy
msgid "vector, transformation, 3D"
-msgstr "векÑоÑ, ÑÑанÑÑоÑмаÑиÑ"
+msgstr "векÑоÑ, ÑÑанÑÑоÑмаÑиÑ, 3D"
#: ../vector/v.to.3d/main.c:38
msgid "Performs transformation of 2D vector features to 3D."
-msgstr ""
+msgstr "ТÑанÑÑоÑмаÑÐ¸Ñ 2D векÑоÑнÑÑ
обÑекÑов в 3D."
#: ../vector/v.to.3d/main.c:51
-#, fuzzy, c-format
+#, c-format
msgid "Either '%s' or '%s' parameter have to be used"
msgstr "Ðолжен бÑÑÑ ÑÑÑановлен один из ÑледÑÑÑиÑ
паÑамеÑÑов: '%s' или '%s'"
#: ../vector/v.to.3d/main.c:57
-#, fuzzy, c-format
+#, c-format
msgid "Parameters '%s' ignored"
-msgstr " "
+msgstr "ÐаÑамеÑÑÑ '%s' игноÑиÑованÑ"
#: ../vector/v.to.3d/main.c:62
-#, fuzzy
msgid "Attribute table required"
-msgstr "ÐÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа не найдена"
+msgstr "ÐеобÑ
одима аÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
#: ../vector/v.to.3d/main.c:75
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> is 2D"
-msgstr "ÐекÑоÑнÑй Ñлой <%s> не 3D"
+msgstr "ÐекÑоÑнÑй Ñлой <%s> 2D"
#: ../vector/v.to.3d/main.c:80
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> is 3D"
+msgstr "ÐекÑоÑнÑй Ñлой <%s> 3D"
-#: ../vector/v.to.3d/main.c:96 ../vector/v.to.3d/main.c:118
-#, fuzzy
-msgid "Copying attributes..."
-msgstr "ÐопиÑоваÑÑ Ð°ÑÑибÑÑÑ"
#: ../vector/v.to.3d/main.c:98 ../vector/v.to.3d/main.c:120
-#, fuzzy
msgid "Unable to copy attributes"
-msgstr "Ðевозможно вÑбÑаÑÑ Ð°ÑÑибÑÑÑ"
+msgstr "Ðевозможно коÑпиÑоваÑÑ Ð°ÑÑибÑÑÑ"
#: ../vector/v.to.3d/main.c:102
-#, fuzzy
msgid "Transforming features..."
-msgstr "ТÑанÑпониÑоваÑÑ eigen-маÑÑиÑÑ..."
+msgstr "ТÑанÑÑоÑмиÑование обÑекÑов..."
#: ../vector/v.to.3d/main.c:129
-#, fuzzy, c-format
+#, c-format
msgid "Vertical extent of vector map <%s>: B: %f T: %f"
-msgstr "векÑÐ¾Ñ "
+msgstr "ÐеÑÑикалÑнÑй оÑ
Ð²Ð°Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ <%s>: Ð: %f Ð: %f"
#: ../vector/v.to.3d/trans2.c:59 ../vector/v.to.3d/trans3.c:60
-#, fuzzy
msgid "Column must be numeric"
-msgstr "ÐÐ¼Ñ Ð¿Ð¾Ð»Ñ (Ñип должен бÑÑÑ ÑиÑловÑм)"
+msgstr "Тип Ð¿Ð¾Ð»Ñ Ð´Ð¾Ð»Ð¶ÐµÐ½ бÑÑÑ ÑиÑловÑм"
#: ../vector/v.to.3d/trans2.c:90
-#, fuzzy
msgid "Skipping feature without category"
-msgstr "ÐÑопÑÑк полигона %d без ÑенÑÑоида"
+msgstr "ÐÑопÑÑк обÑекÑа без каÑегоÑии"
#: ../vector/v.to.3d/trans2.c:105
-#, fuzzy, c-format
+#, c-format
msgid "Unable to get height for feature category %d"
-msgstr "Ðевозможно полÑÑиÑÑ Ð¾Ñ
Ð²Ð°Ñ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ð° %d"
+msgstr "Ðевозможно полÑÑиÑÑ Ð²ÑÑоÑÑ Ð´Ð»Ñ Ð¾Ð±ÑекÑа каÑегоÑии %d"
#: ../vector/v.to.3d/trans3.c:91
-#, fuzzy, c-format
+#, c-format
msgid "Feature id %d has no category - skipping"
-msgstr "ÐÐ¸Ð½Ð¸Ñ %d не Ð¸Ð¼ÐµÐµÑ ÐºÐ°ÑегоÑии"
+msgstr "ÐбÑÐµÐºÑ %d не Ð¸Ð¼ÐµÐµÑ ÐºÐ°ÑегоÑии - пÑопÑÑен"
#: ../vector/v.to.3d/trans3.c:94
#, c-format
msgid "Feature id %d has more categories. Using category %d."
-msgstr ""
+msgstr "ÐбÑÐµÐºÑ %d Ð¸Ð¼ÐµÐµÑ Ð±Ð¾Ð»ÑÑе каÑегоÑий. ÐÑполÑзÑеÑÑÑ ÐºÐ°ÑегоÑÐ¸Ñ %d."
#: ../vector/v.to.3d/args.c:11
-#, fuzzy
msgid "Reverse transformation; 3D vector features to 2D"
-msgstr "иÑполÑзоваÑÑ Ð¿Ñавила ÑÑанÑÑоÑмаÑии Ð´Ð»Ñ LANDSAT-4"
+msgstr "ÐбÑаÑÐ½Ð°Ñ ÑÑанÑÑоÑмаÑиÑ; векÑоÑнÑе 3D обÑекÑÑ Ð² 2D"
#: ../vector/v.to.3d/args.c:15
-#, fuzzy
msgid "Do not copy table"
+msgstr "Ðе копиÑоваÑÑ ÑаблиÑÑ"
#: ../vector/v.to.3d/args.c:30
-#, fuzzy
msgid "Fixed height for 3D vector features"
msgstr "ÐоÑÑоÑÐ½Ð½Ð°Ñ Ð²ÑÑоÑа Ð´Ð»Ñ 3D векÑоÑнÑÑ
обÑекÑов"
#: ../vector/v.to.3d/args.c:31 ../vector/v.to.3d/args.c:34
#: ../vector/v.to.3d/args.c:41
msgid "Height"
-msgstr ""
+msgstr "ÐÑÑоÑа"
#: ../vector/v.to.3d/args.c:37
-#, fuzzy
msgid "Name of attribute column used for height"
-msgstr "ÐÐ»Ñ Ð¾Ð¿Ñии 'query' иÑполÑзÑеÑÑÑ Ð¸Ð¼Ñ ÑÑолбÑа аÑÑибÑÑов"
+msgstr "ÐÐ¼Ñ ÑÑолбÑа аÑÑибÑÑов иÑполÑзÑемое Ð´Ð»Ñ Ð²ÑÑоÑÑ"
#: ../vector/v.to.3d/args.c:39
msgid "Can be used for reverse transformation, to store height of points"
msgstr ""
+"ÐÐ¾Ð¶ÐµÑ Ð±ÑÑÑ Ð¸ÑполÑзовано Ð´Ð»Ñ Ð¾Ð±ÑаÑной ÑÑанÑÑоÑмаÑии Ð´Ð»Ñ Ñ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ Ð²ÑÑÐ¾Ñ ÑоÑек"
#: ../vector/v.parallel2/main.c:45
-#, fuzzy
msgid "Creates parallel line to input vector lines."
-msgstr "СоздаÑÑ Ð¿Ð°ÑаллелÑнÑе линии Ð´Ð»Ñ Ð¸ÑÑ
однÑÑ
линий"
+msgstr "СоздаÑÑ Ð¿Ð°ÑаллелÑнÑе линии Ð´Ð»Ñ Ð¸ÑÑ
однÑÑ
линий."
#: ../vector/v.parallel2/main.c:57
-#, fuzzy
msgid "Offset along major axis in map units"
-msgstr "СмеÑение подпиÑи в напÑавлении x в единиÑаÑ
ÑлоÑ"
+msgstr "СмеÑение по болÑÑой полÑоÑи в единиÑаÑ
ÑлоÑ"
#: ../vector/v.parallel2/main.c:65
-#, fuzzy
msgid "Offset along minor axis in map units"
ÑлоÑ"
+msgstr "СмеÑение по малой полÑоÑи в единиÑаÑ
ÑлоÑ"
-#: ../vector/v.parallel2/main.c:73 ../vector/v.buffer2/main.c:179
+#: ../vector/v.parallel2/main.c:73 ../vector/v.buffer2/main.c:182
msgid "Angle of major axis in degrees"
-msgstr ""
+msgstr "Углов главной оÑи в гÑадÑÑаÑ
#: ../vector/v.parallel2/main.c:82
msgid "Side"
-msgstr ""
+msgstr "СÑоÑона"
#: ../vector/v.parallel2/main.c:84
msgid ""
"left;Parallel line is on the left;right;Parallel line is on the right;both;"
"Parallel lines on both sides"
msgstr ""
+"леваÑ;ÐаÑаллелÑÐ½Ð°Ñ Ð»Ð¸Ð½Ð¸Ñ Ñлева;пÑаваÑ;ÐаÑаллелÑÐ½Ð°Ñ Ð»Ð¸Ð½Ð¸Ñ ÑпÑава;обе;"
+"ÐаÑаллелÑнÑе линии по обе ÑÑоÑонÑ"
#: ../vector/v.parallel2/main.c:94
-#, fuzzy
msgid "Tolerance of arc polylines in map units"
-msgstr "ÐоÑог в единиÑаÑ
ÑлоÑ: %g"
+msgstr "ÐоÑог дÑг полилиний в единиÑаÑ
ÑлоÑ"
#: ../vector/v.parallel2/main.c:98
msgid "Make outside corners round"
-msgstr ""
+msgstr "ÐкÑÑглиÑÑ Ð²Ð½ÐµÑние ÑглÑ"
#: ../vector/v.parallel2/main.c:102
-#, fuzzy
msgid "Create buffer-like parallel lines"
однÑÑ
линий"
+msgstr "СоздаÑÑ Ð¿Ð°ÑаллелÑнÑе линии наподобие бÑÑеÑнÑÑ
зон"
#: ../vector/v.buffer2/main.c:146
-#, fuzzy
msgid "vector, buffer"
-msgstr "векÑоÑ, запÑоÑ"
+msgstr "векÑоÑ, бÑÑеÑ"
-#: ../vector/v.buffer2/main.c:164
-#, fuzzy
+#: ../vector/v.buffer2/main.c:166
msgid "Buffer distance along major axis in map units"
-msgstr "РаÑÑÑоÑние бÑÑеÑизаÑии в единиÑаÑ
каÑÑÑ"
+msgstr "РаÑÑÑоÑние бÑÑеÑизаÑии по болÑÑой полÑоÑи в единиÑаÑ
ÑлоÑ"
-#: ../vector/v.buffer2/main.c:171
+#: ../vector/v.buffer2/main.c:167 ../vector/v.buffer2/main.c:175
+#: ../vector/v.buffer2/main.c:188 ../vector/v.buffer2/main.c:204
#, fuzzy
+msgid "Distance"
+msgstr "ÐÑклÑÑиÑÑ"
+#: ../vector/v.buffer2/main.c:174
msgid "Buffer distance along minor axis in map units"
каÑÑÑ"
+msgstr "РаÑÑÑоÑние бÑÑеÑизаÑии по малой полÑоÑи в единиÑаÑ
ÑлоÑ"
-#: ../vector/v.buffer2/main.c:209
-msgid "Make outside corners straight"
+#: ../vector/v.buffer2/main.c:187
+#, fuzzy
+msgid "Name of column to use for buffer distances"
+msgstr "ÐÑÑибÑÑивное поле иÑполÑзÑемое Ð´Ð»Ñ ÑаÑÑÑоÑÐ½Ð¸Ñ Ð±ÑÑеÑизаÑии"
+#: ../vector/v.buffer2/main.c:212
+msgid "This does nothing. It is retained for backwards compatibility"
msgstr ""
-#: ../vector/v.buffer2/main.c:213
+#: ../vector/v.buffer2/main.c:219
+msgid ""
+"This is an alias to the distance option. It is retained for backwards "
+"compatibility"
+msgstr ""
+#: ../vector/v.buffer2/main.c:226
+msgid "Make outside corners straight"
+msgstr "ÐÑпÑÑмиÑÑ Ð²Ð½ÐµÑние ÑглÑ"
+#: ../vector/v.buffer2/main.c:230
msgid "Don't make caps at the ends of polylines"
msgstr ""
-#: ../vector/v.buffer2/main.c:225
+#: ../vector/v.buffer2/main.c:243
msgid "Select a buffer distance/minordistance/angle or column, but not both."
msgstr ""
-#: ../vector/v.buffer2/main.c:236
-#, fuzzy, c-format
+#: ../vector/v.buffer2/main.c:253
+msgid ""
+"The buffer option has been replaced by the distance option and will be "
+"removed in future."
+msgstr ""
+#: ../vector/v.buffer2/main.c:256
+#, fuzzy
+msgid "Use the distance option instead of the buffer option."
+msgstr "ÐÑполÑзоваÑÑ Ð´Ð»Ñ Ð¿Ð¾Ð²Ð¾ÑоÑа ÑÐ°Ð´Ð¸Ð°Ð½Ñ Ð²Ð¼ÐµÑÑо гÑадÑÑов"
+#: ../vector/v.buffer2/main.c:260
+#, c-format
msgid "The tolerance was reset to %g"
-msgstr "ÐоÑог бÑл ÑбÑоÑен в %g (ÐµÐ´Ð¸Ð½Ð¸Ñ ÑлоÑ)"
+msgstr "ÐоÑог бÑл ÑбÑоÑен в %g"
-#: ../vector/v.buffer2/main.c:257
-#, fuzzy, c-format
+#: ../vector/v.buffer2/main.c:284
+#, c-format
msgid "The tolerance in map units = %g"
ÑлоÑ: %g"
+msgstr "ÐоÑог в единиÑаÑ
ÑÐ»Ð¾Ñ = %g"
-#: ../vector/v.buffer2/main.c:302
-#, fuzzy, c-format
+#: ../vector/v.buffer2/main.c:329
+#, c-format
msgid "Unable to select data from table <%s>"
-msgstr "Ðевозможно вÑбÑаÑÑ Ð´Ð°Ð½Ð½Ñе из ÑаблиÑÑ"
+msgstr "Ðевозможно вÑбÑаÑÑ Ð´Ð°Ð½Ð½Ñе из ÑаблиÑÑ <%s>"
-#: ../vector/v.buffer2/main.c:342
-#, fuzzy
+#: ../vector/v.buffer2/main.c:369
msgid "Buffering lines..."
-msgstr "Разбиение линий..."
+msgstr "ÐÑÑеÑизаÑÐ¸Ñ Ð»Ð¸Ð½Ð¸Ð¹..."
-#: ../vector/v.buffer2/main.c:409
-#, fuzzy
+#: ../vector/v.buffer2/main.c:436
msgid "Buffering areas..."
-msgstr "ÐÑдавливание полигонов..."
+msgstr "ÐÑÑеÑизаÑÐ¸Ñ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ð¾Ð²..."
#: ../doc/raster/r.example/main.c:85
msgid "raster, keyword2, keyword3"
@@ -23451,17 +21416,17 @@
msgstr "Ðевозможно ÑÑÑановиÑÑ Ð·Ð°Ð´Ð°Ð½Ð½Ñй ÑÑÐ¾Ð²ÐµÐ½Ñ Ð¾ÑкÑÑÑÐ¸Ñ Ð²ÐµÐºÑоÑа"
#: ../doc/vector/v.example/main.c:167
-#, fuzzy, c-format
+#, c-format
msgid "Unable to get attribute data for cat %d"
msgstr "Ðевозможно полÑÑиÑÑ Ð°ÑÑибÑÑивнÑе даннÑе Ð´Ð»Ñ cat %d"
#: ../doc/vector/v.example/main.c:176
-#, fuzzy, c-format
+#, c-format
msgid "Error while retrieving database record for cat %d"
msgstr "ÐÑибка полÑÑÐµÐ½Ð¸Ñ Ð·Ð°Ð¿Ð¸Ñи из Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
Ð´Ð»Ñ cat %d"
#: ../doc/vector/v.example/main.c:209
-#, fuzzy, c-format
+#, c-format
msgid "Unable to copy attribute table to vector map <%s>"
msgstr "Ðевозможно ÑкопиÑоваÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ Ð² векÑоÑнÑй Ñлой <%s>"
@@ -23475,7 +21440,7 @@
msgid "Read error in vector map"
msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ Ð²ÐµÐºÑоÑного ÑлоÑ"
-#: ../ps/ps.map/ps_vlines.c:118 ../ps/ps.map/ps_vareas.c:100
+#: ../ps/ps.map/ps_vlines.c:118 ../ps/ps.map/ps_vareas.c:101
#: ../ps/ps.map/ps_vpoints.c:164 ../ps/ps.map/ps_vpoints.c:175
#: ../ps/ps.map/ps_vpoints.c:199 ../ps/ps.map/ps_vpoints.c:240
#: ../ps/ps.map/ps_vpoints.c:250
@@ -23483,7 +21448,7 @@
msgid "No record for category [%d]"
msgstr "ÐÐµÑ Ð·Ð°Ð¿Ð¸Ñей Ð´Ð»Ñ ÐºÐ°ÑегоÑии [%d]"
-#: ../ps/ps.map/ps_vlines.c:124 ../ps/ps.map/ps_vareas.c:106
+#: ../ps/ps.map/ps_vlines.c:124 ../ps/ps.map/ps_vareas.c:107
#: ../ps/ps.map/ps_vpoints.c:205
#, c-format
msgid "Invalid RGB color definition in column <%s> for category [%d]"
@@ -23526,10 +21491,11 @@
msgstr "Ðевозможно пÑоÑеÑÑÑ ÑвеÑа Ð´Ð»Ñ ÑвеÑового полÑ"
#: ../ps/ps.map/ps_clrtbl.c:47
+#, fuzzy
msgid ""
"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using CELL rasters. No colortable will be "
-"assigned to this output postscript file."
+"required for 'colortable' when using categorical legends; see the r.category "
+"help page. Colortable creation has been skipped."
msgstr ""
"Файл cats/ невеÑен. Файл cats/ Ñ ÐºÐ°ÑегоÑиÑми и подпиÑÑми необÑ
одим Ð´Ð»Ñ "
"'colortable' пÑи иÑполÑзовании ÑаÑÑÑов. ЦвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа не бÑÐ´ÐµÑ Ð½Ð°Ð·Ð½Ð°Ñена "
@@ -23796,14 +21762,12 @@
msgstr "ÐÑибка обÑабоÑки ввода в ÑÑÑоке %d"
#: ../imagery/i.ifft/orig_wind.c:27
-#, fuzzy
msgid "The real and imaginary original windows did not match"
-msgstr "ÐеÑеÑÑвенное и мнимое окна не Ñовпали."
+msgstr "ÐÑÑ
однÑе веÑеÑÑвенное и мнимое окна не Ñовпали"
#: ../imagery/i.ifft/ifftmain.c:68 ../imagery/i.fft/fftmain.c:74
-#, fuzzy
msgid "imagery, FFT"
-msgstr "изобÑажениÑ"
+msgstr "изобÑажениÑ, FFT"
#: ../imagery/i.ifft/ifftmain.c:70
msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
@@ -23811,46 +21775,40 @@
"ÐбÑаÑное бÑÑÑÑое пÑеобÑазование ФÑÑÑе (IFFT) Ð´Ð»Ñ Ð¾Ð±ÑабоÑки изобÑажений."
#: ../imagery/i.ifft/ifftmain.c:75
-#, fuzzy
msgid "Name of input raster map (image fft, real part)"
-msgstr "ÐÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (fft изобÑажение, веÑеÑÑÐ²ÐµÐ½Ð½Ð°Ñ ÑаÑÑÑ)"
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (fft изобÑажение, веÑеÑÑÐ²ÐµÐ½Ð½Ð°Ñ ÑаÑÑÑ)"
#: ../imagery/i.ifft/ifftmain.c:79
-#, fuzzy
msgid "Name of input raster map (image fft, imaginary part"
-msgstr "ÐÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (fft изобÑажение, Ð¼Ð½Ð¸Ð¼Ð°Ñ ÑаÑÑÑ"
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (fft изобÑажение, Ð¼Ð½Ð¸Ð¼Ð°Ñ ÑаÑÑÑ"
#: ../imagery/i.ifft/ifftmain.c:101
-#, fuzzy
msgid ""
"Unable to open real-image in the 'cell_misc' directory. Raster map probably "
"wasn't created by i.fft"
msgstr ""
-"Ðевозможно оÑкÑÑÑÑ Ð²ÐµÑеÑÑвенного изобÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð² каÑалоге cell_misc.\n"
-"ÐÑÑ
однÑй Ñлой не бÑÐ´ÐµÑ Ñоздан i.fft"
+"Ðевозможно оÑкÑÑÑÑ Ð²ÐµÑеÑÑвенное изобÑажение в каÑалоге cell_misc. Ðозможно "
+"ÑаÑÑÑовÑй Ñлой не бÑл Ñоздан i.fft"
#: ../imagery/i.ifft/ifftmain.c:111
-#, fuzzy
msgid ""
"Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
"probably wasn't created by i.fft"
msgstr ""
-"Ðевозможно оÑкÑÑÑÑ Ð¼Ð½Ð¸Ð¼Ð¾Ðµ изобÑажение в каÑалоге cell_misc.\n"
-"ÐÑÑ
+"Ðевозможно оÑкÑÑÑÑ Ð¼Ð½Ð¸Ð¼Ð¾Ðµ изобÑажение в каÑалоге cell_misc. Ðозможно "
#: ../imagery/i.ifft/ifftmain.c:134
-#, fuzzy, c-format
+#, c-format
msgid "Power 2 values: %d rows %d columns"
msgstr "ÐнаÑÐµÐ½Ð¸Ñ Ð²ÑоÑой ÑÑепени: %d ÑÑÑок %d ÑÑолбÑов"
#: ../imagery/i.ifft/ifftmain.c:144 ../imagery/i.gensigset/read_data.c:19
#: ../imagery/i.cluster/main.c:285
-#, fuzzy
msgid "Reading raster maps..."
-msgstr "ЧÑение ÑаÑÑÑового ÑлоÑ..."
+msgstr "ЧÑение ÑаÑÑÑовÑÑ
Ñлоев..."
#: ../imagery/i.ifft/ifftmain.c:151
-#, fuzzy
msgid "Masking raster maps..."
msgstr "ÐаÑкиÑование ÑаÑÑÑовÑÑ
Ñлоев..."
@@ -23863,9 +21821,8 @@
msgstr " РаÑÑÐµÑ Ð¾Ð±ÑаÑного FFT..."
#: ../imagery/i.ifft/ifftmain.c:225
-#, fuzzy
msgid "Writing data..."
-msgstr "ÐапиÑÑ Ð´Ð°Ð½Ð½ÑÑ
в Ñайл..."
+msgstr "ÐапиÑÑ Ð´Ð°Ð½Ð½ÑÑ
#: ../imagery/i.gensigset/parse.c:13 ../imagery/i.gensig/parse.c:14
msgid "Ground truth training map"
@@ -23873,14 +21830,12 @@
#: ../imagery/i.gensigset/parse.c:21 ../imagery/i.gensig/parse.c:22
#: ../imagery/i.cluster/main.c:97
-#, fuzzy
msgid "Name for output file containing result signatures"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного Ñайла, ÑодеÑжаÑего маÑÑиÑÑ Ð¾Ñибок и каппа"
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного Ñайла, ÑодеÑжаÑего ÑезÑлÑÑиÑÑÑÑие ÑÑалонÑ"
#: ../imagery/i.gensigset/parse.c:27
-#, fuzzy
msgid "Maximum number of sub-signatures in any class"
-msgstr "ÐинималÑное колиÑеÑÑво пикÑелей в клаÑÑе"
+msgstr "ÐакÑималÑное колиÑеÑÑво ÑÑб-ÑÑалонов в лÑбом клаÑÑе"
#: ../imagery/i.gensigset/parse.c:45 ../imagery/i.smap/shapiro/parse.c:58
#: ../imagery/i.gensig/parse.c:39 ../imagery/i.cluster/open_files.c:17
@@ -23896,151 +21851,142 @@
msgstr "ÐодгÑÑппа <%s> не найдена"
#: ../imagery/i.gensigset/parse.c:52
-#, fuzzy, c-format
+#, c-format
msgid "Illegal number of sub-signatures (%s)"
-msgstr "ÐепÑавилÑное колиÑеÑÑво ÑÑÑок <%s>"
+msgstr "ÐепÑавилÑное колиÑеÑÑво ÑÑб-ÑÑалонов %s"
#: ../imagery/i.gensigset/get_train.c:32 ../imagery/i.gensig/get_train.c:28
-#, fuzzy
msgid "Finding training classes..."
-msgstr "ÐоиÑк ÑÑениÑовоÑнÑÑ
клаÑÑов ..."
+msgstr "ÐоиÑк ÑÑениÑовоÑнÑÑ
клаÑÑов..."
#: ../imagery/i.gensigset/get_train.c:57 ../imagery/i.gensig/get_train.c:53
-#, fuzzy, c-format
+#, c-format
msgid "Training class %d only has one cell - this class will be ignored"
msgstr ""
-"ÐлаÑÑ Ð¿ÑовеÑки [%d] ÑодеÑÐ¶Ð¸Ñ ÑолÑко Ð¾Ð´Ð½Ñ ÑÑÐµÐ¹ÐºÑ - клаÑÑ Ð±ÑÐ´ÐµÑ Ð¸Ð³Ð½Ð¾ÑиÑован."
+"ÐлаÑÑ Ð¿ÑовеÑки %d ÑодеÑÐ¶Ð¸Ñ ÑолÑко Ð¾Ð´Ð½Ñ ÑÑÐµÐ¹ÐºÑ - клаÑÑ Ð±ÑÐ´ÐµÑ Ð¸Ð³Ð½Ð¾ÑиÑован"
#: ../imagery/i.gensigset/get_train.c:62 ../imagery/i.gensig/get_train.c:58
-#, fuzzy
msgid "Training map has no classes"
-msgstr "ÐÐµÑ ÐºÐ»Ð°ÑÑов в ÑÑениÑовоÑном Ñлое."
+msgstr "ÐÐµÑ ÐºÐ»Ð°ÑÑов в ÑÑениÑовоÑном Ñлое"
#: ../imagery/i.gensigset/get_train.c:78 ../imagery/i.gensig/get_train.c:73
-#, fuzzy
msgid "1 class found"
-msgstr "1 клаÑÑ."
+msgstr "найден 1 клаÑÑ"
#: ../imagery/i.gensigset/get_train.c:80 ../imagery/i.gensig/get_train.c:75
-#, fuzzy, c-format
+#, c-format
msgid "%d classes found"
-msgstr "найдено %d пеÑеÑений"
+msgstr "найдено %d клаÑÑов"
#: ../imagery/i.gensigset/openfiles.c:15
#: ../imagery/i.smap/shapiro/openfiles.c:15
#: ../imagery/i.smap/shapiro/read_sig.c:13 ../imagery/i.gensig/openfiles.c:16
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read REF file for subgroup <%s> in group <%s>"
-msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñайл REF Ð´Ð»Ñ Ð¿Ð¾Ð´Ð³ÑÑÐ¿Ð¿Ñ [%s] в гÑÑппе [%s]."
+msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñайл REF Ð´Ð»Ñ Ð¿Ð¾Ð´Ð³ÑÑÐ¿Ð¿Ñ <%s> в гÑÑппе <%s>."
#: ../imagery/i.gensigset/openfiles.c:19 ../imagery/i.gensig/openfiles.c:20
-#, fuzzy, c-format
+#, c-format
msgid "Subgroup <%s> in group <%s> contains no raster maps."
-msgstr "ÐодгÑÑппа [%s] в гÑÑппе [%s] не ÑодеÑÐ¶Ð¸Ñ Ñайлов."
+msgstr "ÐодгÑÑппа <%s> в гÑÑппе <%s> не ÑодеÑÐ¶Ð¸Ñ ÑаÑÑÑов."
#: ../imagery/i.gensigset/main.c:40 ../imagery/i.smap/shapiro/main.c:38
msgid "imagery, classification, supervised, SMAP"
-msgstr ""
+msgstr "изобÑажениÑ, клаÑÑиÑикаÑÐ¸Ñ Ñ Ð¾Ð±ÑÑением, SMAP"
#: ../imagery/i.gensigset/main.c:42
-#, fuzzy
msgid "Generates statistics for i.smap from raster map."
-msgstr "СоздаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð´Ð»Ñ i.maxlik из ÑаÑÑÑового ÑлоÑ."
+msgstr "РаÑÑиÑаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð´Ð»Ñ i.maxlik из ÑаÑÑÑового ÑлоÑ."
#: ../imagery/i.gensigset/main.c:52
-#, fuzzy, c-format
+#, c-format
msgid "Clustering class %d (%d pixels)..."
-msgstr "РаÑÑÐµÑ ÑÑедниÑ
клаÑÑа ..."
+msgstr "ÐлаÑÑеÑизаÑÐ¸Ñ ÐºÐ»Ð°ÑÑа %d (%d пикÑелей)..."
#: ../imagery/i.gensigset/main.c:55
-#, fuzzy, c-format
+#, c-format
msgid "Number of subclasses is %d"
-msgstr "ЧиÑло опÑеделÑемÑÑ
клаÑÑов"
+msgstr "ЧиÑло подклаÑÑов %d"
#: ../imagery/i.gensigset/subcluster.c:74
-#, fuzzy, c-format
+#, c-format
msgid "Not enough pixels in class %d"
-msgstr "ÐедоÑÑаÑоÑно Ñипов"
+msgstr "ÐедоÑÑаÑоÑно пикÑелей в клаÑÑе %d"
#: ../imagery/i.gensigset/subcluster.c:84
-#, fuzzy, c-format
+#, c-format
msgid "Too many subclasses for class index %d"
-msgstr "СлиÑком много ÑÑÑÐ°Ñ Ð´Ð»Ñ ÑаÑÑÑового ÑлоÑ"
+msgstr "СлиÑком много подклаÑÑов Ð´Ð»Ñ ÐºÐ»Ð°ÑÑа %d"
#: ../imagery/i.gensigset/subcluster.c:86
-#, fuzzy, c-format
+#, c-format
msgid "Number of subclasses set to %d"
клаÑÑов"
+msgstr "ЧиÑло подклаÑÑов Ñавно %d"
#: ../imagery/i.gensigset/subcluster.c:101
#, c-format
msgid "Combining subclasses (%d,%d)..."
-msgstr ""
+msgstr "ÐомбиниÑование подклаÑÑов (%d,%d)..."
#: ../imagery/i.gensigset/subcluster.c:311
#, c-format
msgid "Subsignature %d only contains %f pixels"
-msgstr ""
+msgstr "СÑбÑÑалон %d ÑодеÑÐ¶Ð¸Ñ ÑолÑко %f пикÑел"
#: ../imagery/i.gensigset/subcluster.c:546
msgid "Unreliable clustering. Try a smaller initial number of clusters"
msgstr ""
+"ÐÐµÐ½Ð°Ð´ÐµÐ¶Ð½Ð°Ñ ÐºÐ»Ð°ÑÑеÑизаÑиÑ. ÐопÑобÑйÑе менÑÑее иÑÑ
одного колиÑеÑÑво клаÑÑеÑов"
#: ../imagery/i.gensigset/subcluster.c:555
#, c-format
msgid "Removed a singular subsignature number %d (%d remain)"
-msgstr ""
+msgstr "СингÑлÑÑнÑй ÑÑбÑÑалон Ð½Ð¾Ð¼ÐµÑ %d (%d оÑÑалÑÑ) Ñдален"
#: ../imagery/i.gensigset/write_sig.c:13 ../imagery/i.gensig/write_sig.c:15
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create signature file <%s>"
-msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñайл ÑÑалонов [%s]"
+msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñайл ÑÑалонов <%s>"
#: ../imagery/i.gensigset/write_sig.c:16 ../imagery/i.gensig/write_sig.c:18
-#, fuzzy
msgid "Writing signatures..."
-msgstr "ÐапиÑÑ Ñайла ÑÑалонов [%s] ..."
+msgstr "ÐапиÑÑ Ñайла ÑÑалонов ..."
#: ../imagery/i.his.rgb/h2rmain.c:45 ../imagery/i.rgb.his/r2hmain.c:45
-#, fuzzy
msgid "imagery, color transformation, RGB, HIS"
-msgstr "обÑее, ÑÑанÑÑоÑмаÑиÑ, GCP"
+msgstr "изобÑажениÑ, ÑвеÑÐ¾Ð²Ð°Ñ ÑÑанÑÑоÑмаÑиÑ, RGB, HIS"
#: ../imagery/i.his.rgb/h2rmain.c:47
msgid ""
"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
"RGB (Red-Green-Blue) color space."
msgstr ""
+"ТÑанÑÑоÑмиÑоваÑÑ ÑаÑÑÑовÑе Ñлои из ÑвеÑового пÑоÑÑÑанÑÑва HIS (Ñон, ÑÑкоÑÑÑ, "
+"наÑÑÑенноÑÑÑ) в RGB (кÑаÑнÑй, зеленÑй и Ñиний)."
#: ../imagery/i.his.rgb/h2rmain.c:53
-#, fuzzy
msgid "Name of input raster map (hue)"
-msgstr " "
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (Ñон) "
#: ../imagery/i.his.rgb/h2rmain.c:57
-#, fuzzy
msgid "Name of input raster map (intensity)"
-msgstr " "
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (ÑÑкоÑÑÑ) "
#: ../imagery/i.his.rgb/h2rmain.c:61
-#, fuzzy
msgid "Name of input raster map (saturation)"
-msgstr " "
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (наÑÑÑенноÑÑÑ) "
#: ../imagery/i.his.rgb/h2rmain.c:65
-#, fuzzy
msgid "Name for output raster map (red)"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑаÑÑÑового ÑлоÑ"
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (кÑаÑнÑй)"
#: ../imagery/i.his.rgb/h2rmain.c:69
-#, fuzzy
msgid "Name for output raster map (green)"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (зеленÑй)"
#: ../imagery/i.his.rgb/h2rmain.c:73
-#, fuzzy
msgid "Name for output raster map (blue)"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (Ñиний)"
#: ../imagery/i.his.rgb/openfiles.c:23 ../imagery/i.his.rgb/openfiles.c:25
#: ../imagery/i.his.rgb/openfiles.c:27 ../imagery/i.rgb.his/openfiles.c:37
@@ -24162,73 +22108,65 @@
"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
"Intensity-Saturation) color space."
msgstr ""
+"ТÑанÑÑоÑмиÑоваÑÑ ÑаÑÑÑовÑе Ñлои из ÑвеÑового пÑоÑÑÑанÑÑва RGB (кÑаÑнÑй, "
+"зеленÑй и Ñиний) в HIS (Ñон, ÑÑкоÑÑÑ, наÑÑÑенноÑÑÑ)."
#: ../imagery/i.rgb.his/r2hmain.c:53
-#, fuzzy
msgid "Name of input raster map (red)"
-msgstr " "
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
#: ../imagery/i.rgb.his/r2hmain.c:57
-#, fuzzy
msgid "Name of input raster map (green)"
-msgstr " "
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (зеленÑй) "
#: ../imagery/i.rgb.his/r2hmain.c:61
-#, fuzzy
msgid "Name of input raster map (blue)"
-msgstr " "
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (Ñиний) "
#: ../imagery/i.rgb.his/r2hmain.c:65
-#, fuzzy
msgid "Name for output raster map (hue)"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (Ñон)"
#: ../imagery/i.rgb.his/r2hmain.c:69
-#, fuzzy
msgid "Name for output raster map (intensity)"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (ÑÑкоÑÑÑ)"
#: ../imagery/i.rgb.his/r2hmain.c:73
-#, fuzzy
msgid "Name for output raster map (saturation)"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (по ÑмолÑаниÑ: Ð¸Ð¼Ñ Ð¸ÑÑ
одного)"
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (наÑÑÑенноÑÑÑ)"
#: ../imagery/i.smap/bouman/segment.c:70
-#, fuzzy
msgid "Number of classes must be < 256"
-msgstr "ЧиÑло клаÑÑов должно бÑÑÑ < 256!"
+msgstr "ЧиÑло клаÑÑов должно бÑÑÑ < 256"
#: ../imagery/i.smap/bouman/segment.c:95
-#, fuzzy, c-format
+#, c-format
msgid "Processing rows %d-%d (of %d)..."
-msgstr "ÐбÑабоÑка ÑÑдов %d-%d (of %d), ÑÑолбÑов=%d-%d (of %d)"
+msgstr "ÐбÑабоÑка ÑÑдов %d-%d (из %d)..."
#: ../imagery/i.smap/bouman/model.c:38
-#, fuzzy, c-format
+#, c-format
msgid "Nonsymetric covariance for class %d subclass %d"
-msgstr ""
-"\n"
-"ÐеÑиммеÑÑиÑÐ½Ð°Ñ ÐºÐ¾Ð²Ð°ÑиаÑÐ¸Ñ Ð´Ð»Ñ ÐºÐ»Ð°ÑÑа [%d] подклаÑÑа [%d]."
+msgstr "ÐеÑиммеÑÑиÑÐ½Ð°Ñ ÐºÐ¾Ð²Ð°ÑиаÑÐ¸Ñ Ð´Ð»Ñ ÐºÐ»Ð°ÑÑа %d подклаÑÑа %d"
#: ../imagery/i.smap/bouman/model.c:48
-#, fuzzy, c-format
+#, c-format
msgid "Nonpositive eigenvalues for class %d subclass %d"
-msgstr "ÐеположиÑелÑнÑй eigen-знаÑÐµÐ½Ð¸Ñ Ð´Ð»Ñ ÐºÐ»Ð°ÑÑа [%d] подклаÑÑ [%d]."
+msgstr "ÐеположиÑелÑнÑе eigen-знаÑÐµÐ½Ð¸Ñ Ð´Ð»Ñ ÐºÐ»Ð°ÑÑа %d подклаÑÑ %d"
#: ../imagery/i.smap/bouman/interp.c:38
msgid "pyramid constructed."
msgstr "пиÑÐ°Ð¼Ð¸Ð´Ñ Ð¿Ð¾ÑÑÑоенÑ."
#: ../imagery/i.smap/bouman/interp.c:237
-#, fuzzy
msgid "Invalid parameter values"
-msgstr "interp: невеÑное знаÑение паÑамеÑÑа."
+msgstr "ÐевеÑнÑе знаÑÐµÐ½Ð¸Ñ Ð¿Ð°ÑамеÑÑа"
#: ../imagery/i.smap/shapiro/openfiles.c:19
#: ../imagery/i.smap/shapiro/read_sig.c:17
-#, fuzzy, c-format
+#, c-format
msgid "Subgroup <%s> in group <%s> contains no raster maps"
+msgstr "ÐодгÑÑппа <%s> в гÑÑппе <%s> не ÑодеÑÐ¶Ð¸Ñ ÑаÑÑÑовÑÑ
Ñлоев"
#: ../imagery/i.smap/shapiro/main.c:40
msgid ""
@@ -24239,13 +22177,12 @@
"maximum a posteriori (SMAP)."
#: ../imagery/i.smap/shapiro/parse.c:21 ../imagery/i.maxlik/main.c:79
-#, fuzzy
msgid "Name of file containing signatures"
-msgstr "Ðазвание Ñайла, ÑодеÑжаÑего SQL-опеÑаÑоÑÑ"
+msgstr "Ðазвание Ñайла, ÑодеÑжаÑего ÑÑалонÑ"
#: ../imagery/i.smap/shapiro/parse.c:22
msgid "Generated by i.gensigset"
-msgstr ""
+msgstr "Создано i.gensigset"
#: ../imagery/i.smap/shapiro/parse.c:31
msgid "Size of submatrix to process at one time"
@@ -24257,14 +22194,14 @@
#: ../imagery/i.smap/shapiro/read_sig.c:23
#: ../imagery/i.cluster/open_files.c:70 ../imagery/i.maxlik/open.c:54
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read signature file <%s>"
#: ../imagery/i.smap/shapiro/read_sig.c:27
-#, fuzzy, c-format
+#, c-format
msgid "Signature file <%s> is invalid"
-msgstr "ÐевеÑнÑй Ñайл ÑÑалонов [%s]."
+msgstr "ÐевеÑнÑй Ñайл ÑÑалонов <%s>"
#: ../imagery/i.vpoints/plot.c:61 ../imagery/i.vpoints/plot.c:143
#: ../display/d.graph/do_graph.c:415
@@ -24309,70 +22246,85 @@
msgstr "ÐÐ ÐÐУÐÐ ÐÐÐÐÐÐÐ: %s (ÑелкнÑÑÑ Ð¼ÑÑÑÑ Ð´Ð»Ñ Ð¿ÑодолжениÑ)"
#: ../imagery/i.pca/main.c:63
-#, fuzzy
msgid "imagery, image transformation, PCA"
+msgstr "изобÑажениÑ, ÑÑанÑÑоÑмаÑиÑ, PCA"
#: ../imagery/i.pca/main.c:64
msgid "Principal components analysis (pca) program for image processing."
msgstr "ÐÑогÑамма анализа главнÑÑ
ÐºÐ¾Ð¼Ð¿Ð¾Ð½ÐµÐ½Ñ (pca) Ð´Ð»Ñ Ð¾Ð±ÑабоÑки изобÑажений."
-#: ../imagery/i.pca/main.c:78
-msgid "Rescaling range output (For no rescaling use 0,0)"
+#: ../imagery/i.pca/main.c:69
+#, fuzzy
+msgid "Name of two or more input raster maps"
+msgstr "Ðазвание вводного ÑаÑÑÑового ÑлоÑ"
+#: ../imagery/i.pca/main.c:72
+#, fuzzy
+msgid "Base name for output raster maps"
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
+#: ../imagery/i.pca/main.c:74
+#, fuzzy
+msgid "A numerical suffix will be added for each component map"
+msgstr "ЧиÑло ÑÑовней иÑполÑзÑемÑÑ
Ð´Ð»Ñ ÐºÐ°Ð¶Ð´Ð¾Ð³Ð¾ компоненÑа"
+#: ../imagery/i.pca/main.c:83
+#, fuzzy
+msgid "Rescaling range for output maps (for no rescaling use 0,0)"
msgstr ""
"ÐаÑÑÑабиÑование вÑÑ
одного диапазона (ÑÑÐ¾Ð±Ñ Ð½Ðµ маÑÑÑабиÑоваÑÑ, иÑполÑзÑйÑе "
"0,0)"
-#: ../imagery/i.pca/main.c:87
+#: ../imagery/i.pca/main.c:93
msgid "Sorry, at least 2 input bands must be provided"
msgstr "ÐÐ¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ Ð·Ð°Ð´Ð°Ð½Ñ Ð¼Ð¸Ð½Ð¸Ð¼Ñм 2 иÑÑ
однÑÑ
канала"
-#: ../imagery/i.pca/main.c:130
-#, fuzzy
+#: ../imagery/i.pca/main.c:136
msgid "Calculating covariance matrix..."
-msgstr "РаÑÑÐµÑ Ð¼Ð°ÑÑиÑÑ ÐºÐ¾Ð²Ð°ÑиаÑии:"
+msgstr "РаÑÑÐµÑ Ð¼Ð°ÑÑиÑÑ ÐºÐ¾Ð²Ð°ÑиаÑии..."
-#: ../imagery/i.pca/main.c:206
-#, fuzzy
+#: ../imagery/i.pca/main.c:212
msgid "Scale range length should be > 0. Using default values: 0,255."
msgstr ""
-"Ðиапазон маÑÑÑаба должен бÑÑÑ > 0. ÐÑполÑзÑеÑÑÑ Ð·Ð½Ð°Ñение по ÑмолÑаниÑ: 0,255"
+"Ðиапазон маÑÑÑаба должен бÑÑÑ > 0. ÐÑполÑзÑеÑÑÑ Ð·Ð½Ð°Ñение по ÑмолÑаниÑ: 0,255."
-#: ../imagery/i.pca/main.c:243 ../imagery/i.pca/main.c:292
-#: ../imagery/i.pca/main.c:425
-#, fuzzy
+#: ../imagery/i.pca/main.c:249 ../imagery/i.pca/main.c:299
+#: ../imagery/i.pca/main.c:434
msgid "Unable allocate memory for row buffer"
msgstr "Ðевозможно вÑделиÑÑ Ð¿Ð°Ð¼ÑÑÑ Ð´Ð»Ñ Ð±ÑÑеÑа ÑÑÑок"
-#: ../imagery/i.pca/main.c:245
+#: ../imagery/i.pca/main.c:251
#, fuzzy, c-format
-msgid "Computing Means for band %d..."
-msgstr "РаÑÑÑиÑаÑÑ ÑÑедние Ð´Ð»Ñ ÐºÐ°Ð½Ð°Ð»Ð° %d:"
+msgid "Computing means for band %d..."
+msgstr "РаÑÑÑиÑаÑÑ ÑÑедние Ð´Ð»Ñ ÐºÐ°Ð½Ð°Ð»Ð° %d..."
-#: ../imagery/i.pca/main.c:294
-#, fuzzy, c-format
+#: ../imagery/i.pca/main.c:301
+#, c-format
msgid "Computing row %d of covariance matrix..."
-msgstr "ÐÑÑиÑлÑеÑÑÑ ÑÑÑока %d маÑÑиÑÑ ÐºÐ¾Ð²Ð°ÑиаÑии:"
+msgstr "ÐÑÑиÑлÑеÑÑÑ ÑÑÑока %d маÑÑиÑÑ ÐºÐ¾Ð²Ð°ÑиаÑии..."
-#: ../imagery/i.pca/main.c:310
-#, fuzzy
+#: ../imagery/i.pca/main.c:319
msgid "Unable to allocate memory for row buffer"
-#: ../imagery/i.pca/main.c:373
-#, fuzzy
+#: ../imagery/i.pca/main.c:381
msgid "Unable to allocate memory for raster row"
msgstr "Ðевозможно вÑделиÑÑ Ð¿Ð°Ð¼ÑÑÑ Ð´Ð»Ñ ÑÑÑоки ÑаÑÑÑа"
-#: ../imagery/i.pca/main.c:401
+#: ../imagery/i.pca/main.c:390
#, fuzzy, c-format
-msgid "Rescaling the data <%s> to range %d,%d..."
-msgstr "%s: ÐаÑÑÑабиÑование даннÑÑ
в диапазон [%d,%d]:"
+msgid "Transforming <%s>..."
-#: ../imagery/i.pca/support.c:43
-msgid "Eigen values:"
-msgstr "Eigen знаÑениÑ:"
+#: ../imagery/i.pca/main.c:409
+#, fuzzy, c-format
+msgid "Rescaling <%s> to range %d,%d..."
+msgstr "ÐаÑÑÑабиÑование даннÑÑ
<%s> в диапазон %d,%d..."
+#: ../imagery/i.pca/support.c:44
+msgid "Eigen values, (vectors), and [percent importance]:"
+msgstr ""
#: ../imagery/i.class/complete_reg.c:12
msgid "Too few points for region. Must have at least 3 points."
msgstr "СлиÑком мало ÑоÑек Ð´Ð»Ñ Ñегиона. Ðолжно бÑÑÑ Ð¼Ð¸Ð½Ð¸Ð¼Ñм 3."
@@ -24589,102 +22541,94 @@
msgstr "Ðкно ÑвелиÑÐµÐ½Ð¸Ñ Ð½Ðµ задано."
#: ../imagery/i.rectify/get_wind.c:46
-#, fuzzy, c-format
+#, c-format
msgid "Region N=%f S=%f E=%f W=%f"
-msgstr "ÐÑполÑзоваÑÑ Ñегион: С=%f Ю=%f, Ð=%f Ð=%f"
+msgstr "Регион С=%f Ю=%f Ð=%f Ð=%f"
#: ../imagery/i.rectify/get_wind.c:48
-#, fuzzy, c-format
+#, c-format
msgid "Resolution EW=%f NS=%f"
-msgstr ""
-"\n"
-"РазÑеÑение = %d; пеÑиод = %d"
+msgstr "РазÑеÑение ÐÐ=%f СЮ=%f"
#: ../imagery/i.rectify/cp.c:15
-#, fuzzy, c-format
+#, c-format
msgid "Control Point file for group <%s@%s> - "
-msgstr " "
+msgstr "Файл конÑÑолÑнÑÑ
ÑоÑек Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ <%s@%s> - "
#: ../imagery/i.rectify/cp.c:21
-#, fuzzy, c-format
+#, c-format
msgid "Not enough active control points for current order, %d are required."
-msgstr "ÐедоÑÑаÑоÑно ÑоÑек, ÑÑебÑеÑÑÑ %d"
+msgstr ""
+"ÐедоÑÑаÑоÑно акÑивнÑÑ
конÑÑолÑнÑÑ
ÑоÑек Ð´Ð»Ñ Ð²ÑбÑанного поÑÑдка, ÑÑебÑеÑÑÑ %d."
#: ../imagery/i.rectify/cp.c:25
-#, fuzzy
msgid "Poorly placed control points."
-msgstr "ÐонÑÑолÑнÑе ÑоÑки плоÑ
о ÑаÑÑÑавленÑ"
+msgstr "ÐлоÑ
о ÑаÑÑÑÐ°Ð²Ð»ÐµÐ½Ñ ÐºÐ¾Ð½ÑÑолÑнÑе ÑоÑки."
#: ../imagery/i.rectify/cp.c:26
-#, fuzzy
msgid " Can not generate the transformation equation."
-msgstr "векÑоÑ"
+msgstr " Ðевозможно полÑÑиÑÑ ÑÑавнение ÑÑанÑÑоÑмаÑии."
#: ../imagery/i.rectify/cp.c:29
msgid "Not enough memory to solve for transformation equation"
-msgstr ""
+msgstr "ÐедоÑÑаÑоÑно памÑÑи, ÑÑÐ¾Ð±Ñ ÑеÑиÑÑ ÑÑавнение ÑÑанÑÑоÑмаÑии"
#: ../imagery/i.rectify/cp.c:32
-#, fuzzy
msgid "Invalid order"
-msgstr "ÐевеÑнÑе кооÑдинаÑÑ"
+msgstr "ÐевеÑнÑй поÑÑдок"
#: ../imagery/i.rectify/rectify.c:94
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s@%s>: projection don't match current settings"
-msgstr "РаÑÑÑовÑй Ñлой <%s> не найден в ÑекÑÑем набоÑе"
+msgstr "РаÑÑÑовÑй Ñлой <%s@%s>: пÑоекÑÐ¸Ñ Ð½Ðµ ÑÐ¾Ð²Ð¿Ð°Ð´Ð°ÐµÑ Ñ ÑекÑÑими наÑÑÑойками"
#: ../imagery/i.rectify/rectify.c:100
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s@%s>: zone don't match current settings"
+msgstr "РаÑÑÑовÑй Ñлой <%s@%s>: зона не ÑÐ¾Ð²Ð¿Ð°Ð´Ð°ÐµÑ Ñ ÑекÑÑими наÑÑÑойками"
#: ../imagery/i.rectify/report.c:12
-#, fuzzy, c-format
+#, c-format
msgid "Rectify <%s@%s> (location <%s>)"
-msgstr "ЧÑение <%s> в <%s>"
+msgstr "ТÑанÑÑоÑмиÑоваÑÑ <%s@%s> (облаÑÑÑ <%s>)"
#: ../imagery/i.rectify/report.c:15
-#, fuzzy, c-format
+#, c-format
msgid "into <%s@%s> (location <%s>) ... %s"
-msgstr "ÐÐ°Ð±Ð¾Ñ <%s> в иÑÑ
одной облаÑÑи <%s> - %s"
+msgstr "в <%s@%s> (облаÑÑÑ <%s>) ... %s"
#: ../imagery/i.rectify/report.c:16
-#, fuzzy
msgid "complete"
-msgstr "Ðеполное пÑавило"
+msgstr "завеÑÑено"
-#, fuzzy
msgid "failed"
-msgstr "Ðвод пÑеÑван"
+msgstr "пÑеÑвано"
#: ../imagery/i.rectify/report.c:27
#, c-format
msgid "%d rows, %d cols (%ld cells) completed in"
-msgstr ""
+msgstr "%d ÑÑдов, %d колонок (%ld ÑÑеек) завеÑÑÐµÐ½Ñ Ð·Ð°"
#: ../imagery/i.rectify/report.c:34
#, c-format
msgid "%.1f cells per minute"
-msgstr ""
+msgstr "%.1f ÑÑеек в минÑÑÑ"
#: ../imagery/i.rectify/report.c:47
msgid "data compression required an additional"
-msgstr ""
+msgstr "необÑ
одима компÑеÑÑÐ¸Ñ Ð´Ð°Ð½Ð½ÑÑ
#: ../imagery/i.rectify/main.c:84
-#, fuzzy
msgid "imagery, rectify"
+msgstr "изобÑажениÑ, ÑÑанÑÑоÑмиÑоваÑÑ"
#: ../imagery/i.rectify/main.c:86
-#, fuzzy
msgid ""
"Rectifies an image by computing a coordinate transformation for each pixel "
"in the image based on the control points."
msgstr ""
-"РекÑиÑиÑиÑоваÑÑ Ð¸Ð·Ð¾Ð±Ñажение пÑÑем ÑÑанÑÑоÑмаÑии кооÑÐ´Ð¸Ð½Ð°Ñ Ð´Ð»Ñ ÐºÐ°Ð¶Ð´Ð¾Ð³Ð¾ "
+"ТÑанÑÑоÑмиÑованиÑÑ Ð¸Ð·Ð¾Ð±Ñажение пÑÑем ÑÑанÑÑоÑмаÑии кооÑÐ´Ð¸Ð½Ð°Ñ ÐºÐ°Ð¶Ð´Ð¾Ð³Ð¾ "
"пикÑела, иÑполÑзÑÑ ÐºÐ¾Ð½ÑÑолÑнÑе ÑоÑки"
#: ../imagery/i.rectify/main.c:100
@@ -24696,7 +22640,6 @@
msgstr "ÐоÑÑдок полинома ÑÑанÑÑоÑмаÑии (1-3)"
#: ../imagery/i.rectify/main.c:111
-#, fuzzy
msgid ""
"Use current region settings in target location (def.=calculate smallest area)"
msgstr ""
@@ -24723,83 +22666,81 @@
msgstr "ÐÑÑппа <%s> не ÑодеÑÐ¶Ð¸Ñ ÑаÑÑÑовÑÑ
Ñлоев; запÑÑÑиÑе i.group"
#: ../imagery/i.rectify/main.c:205
-#, fuzzy, c-format
+#, c-format
msgid "Using region: N=%f S=%f, E=%f W=%f"
#: ../imagery/i.rectify/main.c:219
-#, fuzzy, c-format
+#, c-format
msgid ""
"Input raster map <%s> does not exist in group <%s>.\n"
" Try:\n"
-msgstr "РаÑÑÑовÑй Ñлой <%s> не ÑÑÑеÑÑвÑÐµÑ Ð² подгÑÑппе <%s>"
+msgstr ""
+"ÐÑÑ
однÑй ÑаÑÑÑовÑй Ñлой <%s> не ÑÑÑеÑÑвÑÐµÑ Ð² гÑÑппе <%s>.\n"
+" Try:\n"
#: ../imagery/i.rectify/main.c:225
-#, fuzzy
msgid "Exit!"
-msgstr "СÑÑеÑÑвÑеÑ"
+msgstr "ÐÑÑ
од!"
#: ../imagery/i.rectify/exec.c:54
-#, fuzzy, c-format
+#, c-format
msgid "Rectified input raster map <%s> will be saved as <%s>"
-msgstr "Ðевозможно оÑкÑÑÑÑ ÑаÑÑÑовÑй Ñлой <%s> в набоÑе <%s>"
+msgstr "ТÑанÑÑоÑмиÑованнÑй ÑаÑÑÑ <%s> бÑÐ´ÐµÑ ÑоÑ
Ñанен как <%s>"
#: ../imagery/i.rectify/target.c:14
-#, fuzzy, c-format
+#, c-format
msgid "Target information for group <%s> missing"
-msgstr "ÐнÑоÑмаÑÐ¸Ñ Ð¾ диапазоне Ð´Ð»Ñ <%s> недоÑÑÑпна"
+msgstr "ÐÑÑÑÑÑÑвÑÐµÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ Ñели Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ <%s>"
#: ../imagery/i.rectify/target.c:20
-#, fuzzy, c-format
+#, c-format
msgid "Target location <%s> not found"
-msgstr " "
+msgstr "Ðе найдена ÑÐµÐ»ÐµÐ²Ð°Ñ Ð¾Ð±Ð»Ð°ÑÑÑ <%s>"
#: ../imagery/i.rectify/target.c:35
msgid "Please run i.target for group."
-msgstr ""
+msgstr "ÐапÑÑÑиÑе i.target Ð´Ð»Ñ Ð³ÑÑппÑ."
#: ../imagery/i.rectify/write.c:27
-#, fuzzy
msgid "Error while writing to temp file"
-msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ Ñайла иÑÑоÑии"
+msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ Ð²Ñеменного Ñайла"
#: ../imagery/i.rectify/write.c:54
-#, fuzzy, c-format
+#, c-format
msgid "Error writing row %d"
-msgstr "ÐÑибка запиÑи нÑлевой ÑÑÑоки [%d]."
+msgstr "ÐÑибка запиÑи ÑÑÑоки %d"
#: ../imagery/i.gensig/means.c:24
-#, fuzzy
msgid "Calculating class means..."
клаÑÑа ..."
+msgstr "РаÑÑÐµÑ ÑÑедниÑ
клаÑÑа..."
#: ../imagery/i.gensig/covariance.c:26
msgid "Calculating class covariance matrices..."
msgstr "РаÑÑÐµÑ Ð¼Ð°ÑÑÐ¸Ñ ÐºÐ¾Ð²Ð°ÑиаÑии клаÑÑов..."
#: ../imagery/i.gensig/check.c:21
-#, fuzzy, c-format
+#, c-format
msgid "Signature %d not invertible"
-msgstr "ÐÑалон[%d] нелÑÐ·Ñ Ð¸Ð½Ð²ÐµÑÑиÑоваÑÑ."
+msgstr "ÐÑалон %d нелÑÐ·Ñ Ð¸Ð½Ð²ÐµÑÑиÑоваÑÑ"
#: ../imagery/i.gensig/check.c:27
-#, fuzzy, c-format
+#, c-format
msgid "Signature %d unable to get eigen values"
-msgstr "ÐÑалон [%d] невозможно полÑÑиÑÑ eigen-знаÑениÑ."
+msgstr "ÐÑалон %d, невозможно полÑÑиÑÑ eigen-знаÑениÑ"
#: ../imagery/i.gensig/check.c:33
-#, fuzzy, c-format
+#, c-format
msgid "Signature %d not positive definite"
-msgstr "ÐÑалон [%d] не положиÑелÑнÑй опÑеделеннÑй."
+msgstr "ÐÑалон %d не положиÑелÑнÑй опÑеделеннÑй"
#: ../imagery/i.gensig/main.c:39
msgid "imagery, classification, supervised, MLC"
-msgstr ""
+msgstr "ÑаÑÑÑÑ, клаÑÑиÑикаÑÐ¸Ñ Ñ Ð¾Ð±ÑÑением, MLC"
#: ../imagery/i.gensig/main.c:41
-#, fuzzy
msgid "Generates statistics for i.maxlik from raster map."
#: ../imagery/i.points/main.c:98
msgid "Mark ground control points on image to be rectified."
@@ -24884,14 +22825,12 @@
msgstr "ÐÑÑÑÑое пÑеобÑазование ФÑÑÑе (FFT) Ð´Ð»Ñ Ð¾Ð±ÑабоÑки изобÑажений."
#: ../imagery/i.fft/fftmain.c:84
-#, fuzzy
msgid "Name for output real part arrays stored as raster map"
-msgstr "ÐÑвод веÑеÑÑвенной ÑаÑÑи маÑÑивов ÑоÑ
ÑаÑемой как ÑаÑÑÑовÑй Ñлой"
+msgstr "ÐÐ¼Ñ Ð²ÐµÑеÑÑвенной ÑаÑÑи маÑÑивов ÑоÑ
ÑаÑемÑÑ
как ÑаÑÑÑовÑй Ñлой"
#: ../imagery/i.fft/fftmain.c:88
-#, fuzzy
msgid "Name for output imaginary part arrays stored as raster map"
-msgstr "ÐÑвод мнимой ÑаÑÑи маÑÑивов ÑоÑ
ÑанÑемой как ÑаÑÑÑовÑй Ñлой"
+msgstr "ÐÐ¼Ñ Ð¼Ð½Ð¸Ð¼Ð¾Ð¹ ÑаÑÑи маÑÑивов ÑоÑ
ÑаÑемÑÑ
как ÑаÑÑÑовÑй Ñлой"
#: ../imagery/i.fft/fftmain.c:96
msgid "Range of values in output display files"
@@ -24904,12 +22843,11 @@
"ÐÑодолжение..."
#: ../imagery/i.fft/fftmain.c:129
-#, fuzzy
msgid "Range less than or equal to zero not allowed"
-msgstr "Ðиапазон менÑÑе или ÑавнÑй нÑÐ»Ñ Ð½ÐµÐ´Ð¾Ð¿ÑÑÑим."
+msgstr "Ðиапазон менÑÑе или ÑавнÑй нÑÐ»Ñ Ð½ÐµÐ´Ð¾Ð¿ÑÑÑим"
#: ../imagery/i.fft/fftmain.c:166
-#, fuzzy, c-format
+#, c-format
msgid "Reading the raster map <%s>..."
msgstr "ЧÑение ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>..."
@@ -24918,23 +22856,20 @@
msgstr "ÐапÑÑк FFT..."
#: ../imagery/i.fft/fftmain.c:225
-#, fuzzy
msgid "Writing transformed data..."
-msgstr "ÐапиÑÑ ÑÑанÑÑоÑмиÑованнÑÑ
даннÑÑ
в Ñайл..."
+msgstr "ÐапиÑÑ ÑÑанÑÑоÑмиÑованнÑÑ
даннÑÑ
#: ../imagery/i.fft/fftmain.c:231
-#, fuzzy
msgid "Writing viewable versions of transformed data..."
-msgstr "ÐапиÑÑ Ð¿ÑоÑмаÑÑиваемÑÑ
веÑÑий ÑÑанÑÑоÑмиÑованнÑÑ
даннÑÑ
в ÑайлÑ..."
+msgstr "ÐапиÑÑ Ð¿ÑоÑмаÑÑиваемÑÑ
даннÑÑ
#: ../imagery/i.fft/fftmain.c:274
msgid " "
msgstr ""
#: ../imagery/i.fft/save_fft.c:17 ../imagery/i.fft/save_fft.c:22
-#, fuzzy
msgid "Unable to open file in the 'cell_misc' directory"
-msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл в каÑалоге cell_misc."
+msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл в каÑалоге cell_misc"
#: ../imagery/i.find/main.c:63
#, c-format
@@ -25052,9 +22987,9 @@
"\n"
#: ../imagery/i.cluster/open_files.c:21 ../imagery/i.maxlik/open.c:19
-#, fuzzy, c-format
+#, c-format
msgid "Subgroup <%s> in group <%s> not found"
-msgstr "ÐодгÑÑппа <%s> не найдена"
+msgstr "ÐодгÑÑппа <%s> в гÑÑппе <%s> не найдена"
#: ../imagery/i.cluster/open_files.c:33
#, c-format
@@ -25062,34 +22997,32 @@
#: ../imagery/i.cluster/open_files.c:38
-#, fuzzy
msgid "No raster maps found"
-msgstr "Ðи одного ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð½Ðµ Ñдалено"
+msgstr "Ðе найдено ÑаÑÑÑовÑÑ
Ñлоев"
#: ../imagery/i.cluster/open_files.c:42
-#, fuzzy, c-format
+#, c-format
msgid "Subgroup <%s> doesn't have any raster maps"
-msgstr "ÐодгÑÑппа [%s] не ÑодеÑÐ¶Ð¸Ñ Ñайлов"
+msgstr "ÐодгÑÑппа <%s> не ÑодеÑÐ¶Ð¸Ñ ÑаÑÑÑовÑÑ
Ñлоев"
#: ../imagery/i.cluster/open_files.c:45
-#, fuzzy, c-format
+#, c-format
msgid "Subgroup <%s> only has 1 raster map"
-msgstr "ÐодгÑÑппа [%s] ÑодеÑÐ¶Ð¸Ñ ÑолÑко 1 Ñайл"
+msgstr "ÐодгÑÑппа <%s> ÑодеÑÐ¶Ð¸Ñ ÑолÑко 1 ÑаÑÑÑовÑй Ñлой"
#: ../imagery/i.cluster/open_files.c:46
-#, fuzzy
msgid "Subgroup must have at least 2 raster maps"
-msgstr "РподгÑÑппе должно бÑÑÑ Ð¼Ð¸Ð½Ð¸Ð¼Ñм 2 Ñайла Ð´Ð»Ñ Ð·Ð°Ð¿ÑÑка %s"
+msgstr "РподгÑÑппе должно бÑÑÑ Ð¼Ð¸Ð½Ð¸Ð¼Ñм 2 ÑаÑÑÑовÑÑ
ÑлоÑ"
#: ../imagery/i.cluster/open_files.c:64
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open seed signature file <%s>"
-msgstr "** Ðевозможно оÑкÑÑÑÑ Ñайл ÑÑалонов заÑÑавок <%s> **"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл ÑÑалонов-заÑÑавок <%s>"
#: ../imagery/i.cluster/open_files.c:74 ../imagery/i.maxlik/open.c:58
-#, fuzzy, c-format
+#, c-format
msgid "<%s> has too many signatures (limit is 255)"
-msgstr "** ÑлиÑком много ÑÑалонов в <%s> (макÑимÑм 255)"
+msgstr "<%s> ÑодеÑÐ¶Ð¸Ñ ÑлиÑком много ÑÑалонов (макÑимÑм 255)"
#: ../imagery/i.cluster/print6.c:11
#, c-format
@@ -25098,7 +23031,7 @@
#: ../imagery/i.cluster/main.c:80
msgid "imagery, classification, signatures"
-msgstr ""
+msgstr "изобÑажениÑ, клаÑÑиÑикаÑиÑ, ÑÑалонÑ"
#: ../imagery/i.cluster/main.c:82
msgid ""
@@ -25121,9 +23054,8 @@
msgstr "ÐÑÑ
одное ÑиÑло клаÑÑов"
#: ../imagery/i.cluster/main.c:112
-#, fuzzy
msgid "Name of file containing initial signatures"
-msgstr "Файл ÑодеÑжаÑий иÑÑ
однÑе ÑÑалонÑ"
+msgstr "Ðазвание Ñайла, ÑодеÑжаÑего иÑÑ
однÑе ÑÑалонÑ"
#: ../imagery/i.cluster/main.c:120
msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
@@ -25148,56 +23080,43 @@
#: ../imagery/i.cluster/main.c:159
-#, fuzzy
msgid "Name for output file containing final report"
-msgstr "ÐÑÑ
одной Ñайла оÑÑÑÑа"
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного Ñайла, ÑодеÑжаÑего оконÑаÑелÑнÑй оÑÑеÑ"
#: ../imagery/i.cluster/main.c:182
-#, fuzzy, c-format
+#, c-format
msgid "Illegal number of initial classes (%s)"
-msgstr ""
-"\n"
-"<%s> -- непÑавилÑное ÑиÑло наÑалÑнÑÑ
клаÑÑов"
+msgstr "ÐевеÑное ÑиÑло иÑÑ
однÑÑ
клаÑÑов (%s)"
#: ../imagery/i.cluster/main.c:193
-#, fuzzy, c-format
+#, c-format
msgid "Illegal value(s) of sample intervals (%s)"
-msgstr ""
-"\n"
-"<%s> -- непÑавилÑнÑе знаÑÐµÐ½Ð¸Ñ Ð¸Ð½ÑеÑвалов полÑÑÐµÐ½Ð¸Ñ Ð·Ð½Ð°Ñений"
+msgstr "ÐевеÑное ÑиÑло инÑеÑвалов ÑÑмплиÑÐ¾Ð²Ð°Ð½Ð¸Ñ (%s)"
#: ../imagery/i.cluster/main.c:207
-#, fuzzy, c-format
+#, c-format
msgid "Illegal value of iterations (%s>)"
-msgstr ""
-"\n"
-"<%s> -- непÑавилÑное ÑиÑло иÑеÑаÑий"
+msgstr "ÐевеÑное ÑиÑло иÑеÑаÑий (<%s>)"
#: ../imagery/i.cluster/main.c:213
-#, fuzzy, c-format
+#, c-format
msgid "Illegal value of convergence (%s)"
-msgstr ""
-"\n"
-"<%s> -- непÑавилÑное знаÑение ÑÑ
одимоÑÑи"
+msgstr "ÐевеÑное знаÑение ÑÑ
одимоÑÑи (%s)"
#: ../imagery/i.cluster/main.c:218
-#, fuzzy, c-format
+#, c-format
msgid "Illegal value of separation (%s)"
-msgstr ""
-"\n"
-"<%s> -- непÑавилÑное знаÑение ÑазделениÑ"
+msgstr "ÐевеÑное знаÑение ÑÐ°Ð·Ð´ÐµÐ»ÐµÐ½Ð¸Ñ (%s)"
#: ../imagery/i.cluster/main.c:223
-#, fuzzy, c-format
+#, c-format
msgid "Illegal value of min_size (%s)"
-msgstr ""
-"\n"
-"<%s> -- непÑавилÑное знаÑение min_size"
+msgstr "ÐедопÑÑÑимое знаÑение min_size (%s)"
#: ../imagery/i.cluster/main.c:234
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create report file <%s>"
-msgstr "Ðевозможно ÑоздаÑÑ Ñайл <%s>"
+msgstr "Ðевозможно ÑоздаÑÑ Ñайл оÑÑеÑа <%s>"
#: ../imagery/i.cluster/main.c:242
#, c-format
@@ -25314,9 +23233,8 @@
msgstr " ÐнÑеÑвал полÑÑÐµÐ½Ð¸Ñ Ð·Ð½Ð°Ñений по ÑÑолбÑам: %d\n"
#: ../imagery/i.cluster/main.c:297
-#, fuzzy
msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr "ÐÐµÑ Ð¿Ð°Ð¼ÑÑи. ÐапÑÑÑиÑе опÑÑÑ Ð¸ вÑбеÑиÑе менÑÑий ÑÐ°Ð·Ð¼ÐµÑ Ð²ÑбоÑки"
+msgstr "ÐÐµÑ Ð¿Ð°Ð¼ÑÑи. ÐапÑÑÑиÑе опÑÑÑ Ð¸ вÑбеÑиÑе менÑÑий ÑÐ°Ð·Ð¼ÐµÑ Ð²ÑбоÑки."
#: ../imagery/i.cluster/main.c:303
#, c-format
@@ -25324,19 +23242,17 @@
msgstr "Ð Ð°Ð·Ð¼ÐµÑ Ð²ÑбоÑки: %d ÑоÑек\n"
#: ../imagery/i.cluster/main.c:306
-#, fuzzy
msgid ""
"Not enough sample points. Please run again and choose a larger sample size."
msgstr ""
"ÐедоÑÑаÑоÑно ÑоÑек в вÑбоÑке. ÐапÑÑÑиÑе опÑÑÑ Ð¸ вÑбеÑиÑе болÑÑий ÑÐ°Ð·Ð¼ÐµÑ "
-"вÑбоÑки"
+"вÑбоÑки."
#: ../imagery/i.cluster/main.c:310
-#, fuzzy
msgid ""
"Not enough non-zero sample data points. Check your current region (and mask)."
msgstr ""
-"ÐедоÑÑаÑоÑно не-нÑлевÑÑ
ÑоÑек вÑбоÑки. ÐÑовеÑÑÑе ÑекÑÑий Ñегион (и маÑкÑ)"
+"ÐедоÑÑаÑоÑно не-нÑлевÑÑ
ÑоÑек вÑбоÑки. ÐÑовеÑÑÑе ÑекÑÑий Ñегион (и маÑкÑ)."
#: ../imagery/i.cluster/main.c:323
#, c-format
@@ -25353,9 +23269,9 @@
msgstr "%d клаÑÑов (ÑÑ
одимоÑÑÑ=%.1f%%)\n"
#: ../imagery/i.cluster/main.c:335
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr "Ðевозможно запиÑаÑÑ Ñайл ÑÑалонов <%s> Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ <%s>, подгÑÑÐ¿Ð¿Ñ <%s>"
+msgstr "Ðевозможно ÑоздаÑÑ Ñайл ÑÑалонов <%s> Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ <%s>, подгÑÑÐ¿Ð¿Ñ <%s>"
#: ../imagery/i.cluster/main.c:340
#, c-format
@@ -25400,79 +23316,77 @@
#: ../imagery/i.ortho.photo/photo.rectify/main.c:49
#: ../imagery/i.ortho.photo/photo.target/main.c:46
msgid "imagery, orthorectify"
-msgstr ""
+msgstr "изобÑажениÑ, оÑÑоÑекÑиÑикаÑиÑ"
#: ../imagery/i.ortho.photo/photo.2target/main.c:54
msgid "Creates control points on an image to be ortho-rectified."
msgstr "СоздаÑÑ ÐºÐ¾Ð½ÑÑолÑнÑе ÑоÑки Ð´Ð»Ñ Ð¾ÑÑо-ÑÑанÑÑоÑмиÑÑемого изобÑажениÑ."
#: ../imagery/i.ortho.photo/photo.2target/main.c:66
-#, fuzzy
msgid "Name of image to be rectified which will be initially drawn on screen"
-msgstr "ÐÐ¼Ñ ÑÑанÑÑоÑмиÑÑемого изобÑажениÑ, показÑваемого на ÑкÑане."
+msgstr "ÐÐ¼Ñ ÑÑанÑÑоÑмиÑÑемого изобÑажениÑ, изнаÑалÑно показÑваемого на ÑкÑане"
#: ../imagery/i.ortho.photo/photo.2target/main.c:72
-#, fuzzy
msgid ""
"Name of a map from target mapset which will be initially drawn on screen"
-msgstr "ÐÐ¼Ñ ÑÐ»Ð¾Ñ Ð¸Ð· Ñелевого набоÑа, показÑваемого на ÑкÑане."
+msgstr "ÐÐ¼Ñ ÑÐ»Ð¾Ñ Ð¸Ð· Ñелевого набоÑа, изнаÑалÑно показÑваемого на ÑкÑане"
#: ../imagery/i.ortho.photo/photo.2target/main.c:102
#: ../imagery/i.ortho.photo/photo.init/main.c:64
#: ../imagery/i.ortho.photo/photo.rectify/main.c:72
-#, fuzzy, c-format
+#, c-format
msgid "Group [%s] not found"
-msgstr "ÐÑÑппа [%s] не найдена."
+msgstr "ÐÑÑппа [%s] не найдена"
#: ../imagery/i.ortho.photo/photo.2target/main.c:114
#: ../imagery/i.ortho.photo/photo.2image/main.c:98
#: ../imagery/i.ortho.photo/photo.rectify/main.c:107
#, c-format
msgid "No camera reference file selected for group [%s]"
-msgstr ""
+msgstr "Ðе вÑбÑан Ñайл камеÑÑ Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s]"
#: ../imagery/i.ortho.photo/photo.2target/main.c:118
#: ../imagery/i.ortho.photo/photo.2image/main.c:102
#: ../imagery/i.ortho.photo/photo.rectify/main.c:111
-#, fuzzy, c-format
+#, c-format
msgid "Bad format in camera file for group [%s]"
-msgstr " "
+msgstr "ÐепÑавилÑнÑй ÑоÑÐ¼Ð°Ñ Ñайла камеÑÑ Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s]"
#: ../imagery/i.ortho.photo/photo.2target/main.c:125
#, c-format
msgid "No initial camera exposure station for group [%s]"
-msgstr ""
+msgstr "Ñайла наÑалÑной ÑкÑпозиÑии ÑÑанÑии Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s] "
#: ../imagery/i.ortho.photo/photo.2target/main.c:129
#, c-format
msgid "Bad format in initial camera exposure station for group [%s]"
-msgstr ""
+msgstr "ÐепÑавилÑнÑй ÑоÑÐ¼Ð°Ñ Ð½Ð°ÑалÑной ÑкÑпозиÑии ÑÑанÑии Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s] "
#: ../imagery/i.ortho.photo/photo.2target/main.c:143
-#, fuzzy, c-format
+#, c-format
msgid "No photo points for group [%s]"
-msgstr "Ðе найдено ни одной ÑоÑки Ñ Ð´Ð°Ð½Ð½Ñми"
+msgstr "ÐÐµÑ ÑоÑоÑоÑек Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s] "
#: ../imagery/i.ortho.photo/photo.2target/main.c:145
-#, fuzzy, c-format
+#, c-format
msgid "Poorly placed photo points for group [%s]"
о ÑаÑÑÑавленÑ"
+msgstr "ÐлоÑ
о ÑаÑÑÑÐ°Ð²Ð»ÐµÐ½Ñ ÑоÑоÑоÑки Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s] "
#: ../imagery/i.ortho.photo/photo.2target/main.c:167
-#, fuzzy
msgid "Computing equations ..."
-msgstr "ÐÑÑиÑление кванÑилей"
+msgstr "ÐÑÑиÑление ÑÑавнений ..."
#: ../imagery/i.ortho.photo/photo.2target/main.c:202
#: ../imagery/i.ortho.photo/photo.2target/main.c:233
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read raster header of <%s>"
-msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл заголовка <%s>"
+msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñайл заголовка <%s>"
#: ../imagery/i.ortho.photo/photo.camera/main.c:56
msgid ""
"Interactively select and modify the imagery group camera reference file."
msgstr ""
+"ÐнÑеÑакÑивно вÑбÑаÑÑ Ð¸Ð»Ð¸ измениÑÑ Ñайл камеÑÑ Ñелевой гÑÑÐ¿Ð¿Ñ Ð¸Ð·Ð¾Ð±Ñажений."
#: ../imagery/i.ortho.photo/photo.camera/main.c:60
#: ../imagery/i.ortho.photo/photo.elev/main.c:68
@@ -25485,132 +23399,125 @@
msgstr "ÐÐ¼Ñ Ð³ÑÑÐ¿Ð¿Ñ Ð¸Ð·Ð¾Ð±Ñажений Ð´Ð»Ñ Ð¾ÑÑо-ÑÑанÑÑоÑмаÑии"
#: ../imagery/i.ortho.photo/photo.camera/main.c:67
-#, fuzzy
msgid "Name of camera reference file to use"
-msgstr "ÐÐ¼Ñ ÑаблиÑÑ Ð»Ð¸Ð½ÐµÐ¹Ð½Ð¾Ð¹ ÑиÑÑемÑ"
+msgstr "ÐÐ¼Ñ Ð¸ÑполÑзÑемого Ñайла камеÑÑ"
#: ../imagery/i.ortho.photo/photo.camera/main.c:83
msgid "Enter a camera reference file to be used with this imagery group"
-msgstr ""
+msgstr "УказаÑÑ Ñайл камеÑÑ Ð¸ÑполÑзÑемÑй Ñ ÑÑой Ñелевой гÑÑппой изобÑажений"
#: ../imagery/i.ortho.photo/photo.camera/main.c:100
-#, fuzzy, c-format
+#, c-format
msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
-msgstr " "
+msgstr ""
+"ÐÑÑппа [%s] в облаÑÑи [%s] набоÑе [%s] ÑепеÑÑ ÑодеÑÐ¶Ð¸Ñ Ñайл камеÑÑ [%s]"
#: ../imagery/i.ortho.photo/photo.elev/main.c:64
msgid "Interactively select or modify the target elevation model."
-msgstr ""
+msgstr "ÐнÑеÑакÑивно вÑбÑаÑÑ Ð¸Ð»Ð¸ измениÑÑ ÑелевÑÑ Ð¼Ð¾Ð´ÐµÐ»Ñ ÑелÑеÑа."
#: ../imagery/i.ortho.photo/photo.elev/main.c:91
#, c-format
msgid "Target information for group [%s] missing\n"
-msgstr ""
+msgstr "Ð¦ÐµÐ»ÐµÐ²Ð°Ñ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s] оÑÑÑÑÑÑвÑеÑ\n"
#: ../imagery/i.ortho.photo/photo.elev/main.c:98
-#, fuzzy, c-format
+#, c-format
msgid "Target location [%s] not found\n"
-msgstr " "
+msgstr "Ð¦ÐµÐ»ÐµÐ²Ð°Ñ Ð¾Ð±Ð»Ð°ÑÑÑ [%s] не найдена\n"
#: ../imagery/i.ortho.photo/photo.elev/main.c:127
-#, fuzzy, c-format
+#, c-format
msgid "Mapset [%s] in target location [%s] - "
-msgstr "ÐÐ°Ð±Ð¾Ñ Ñлоев <%s> в Ñелевой облаÑÑи <%s> - "
+msgstr "ÐÐ°Ð±Ð¾Ñ [%s] в ÑекÑÑей облаÑÑи [%s] - "
#: ../imagery/i.ortho.photo/photo.elev/main.c:128
-#, fuzzy
msgid "permission denied\n"
-msgstr "недоÑÑаÑоÑнÑе пÑава доÑÑÑпа"
+msgstr "доÑÑÑп запÑеÑен\n"
-#, fuzzy
msgid "not found\n"
-msgstr "%s не найден"
+msgstr "не найден\n"
#: ../imagery/i.ortho.photo/photo.elev/main.c:131
msgid "Please select a target for group"
-msgstr ""
+msgstr "УкажиÑе ÑÐµÐ»Ñ Ð´Ð»Ñ Ð³ÑÑппÑ"
#: ../imagery/i.ortho.photo/menu/menu.c:44
msgid "Menu driver for the photo imagery programs."
msgstr "ÐÑÐ°Ð¹Ð²ÐµÑ Ð¼ÐµÐ½Ñ Ð´Ð»Ñ Ð¿ÑогÑамм ÑоÑовизÑализаÑии."
#: ../imagery/i.ortho.photo/menu/menu.c:62
-#, fuzzy, c-format
+#, c-format
msgid "Pre-selected group <%s> not found"
-msgstr ""
-"\n"
-" гÑÑппа <%s> не найдена"
+msgstr "ÐÑбÑÐ°Ð½Ð½Ð°Ñ Ð³ÑÑппа <%s> не найдена"
#: ../imagery/i.ortho.photo/menu/menu.c:68
-#, fuzzy
msgid "Enter imagery group for ortho-rectification"
#: ../imagery/i.ortho.photo/menu/menu.c:74
-#, fuzzy, c-format
+#, c-format
msgid "Group [%s] contains no files"
+msgstr "ÐÑÑппа [%s] не ÑодеÑÐ¶Ð¸Ñ Ñайлов."
#: ../imagery/i.ortho.photo/photo.init/main.c:46
msgid ""
"Interactively creates or modifies entries in a camera initial exposure "
"station file for imagery group referenced by a sub-block."
msgstr ""
+"ÐнÑеÑакÑивно ÑоздаваÑÑ Ð¸Ð»Ð¸ изменÑÑÑ Ð·Ð°Ð¿Ð¸Ñи в Ñайле наÑалÑной ÑкÑпозиÑии "
+"камеÑÑ Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ Ð¸Ð·Ð¾Ð±Ñажений ÑÑбблока"
#: ../imagery/i.ortho.photo/photo.2image/main.c:56
msgid "Interactively mark fiducial or reseau points on an image."
msgstr ""
#: ../imagery/i.ortho.photo/photo.2image/main.c:86
-#, fuzzy, c-format
+#, c-format
msgid "Image Group [%s] not found"
+msgstr "ÐÑÑппа изобÑажений [%s] не найдена"
#: ../imagery/i.ortho.photo/photo.rectify/ask_files.c:36
msgid "Please select the file(s) you wish to rectify by naming an output file"
-msgstr ""
+msgstr "УкажиÑе Ñайл(Ñ), коÑоÑÑе надо ÑÑанÑÑоÑмиÑоваÑÑ Ð½Ð°Ð·Ð²Ð°Ð² вÑÑ
одной Ñайл"
#: ../imagery/i.ortho.photo/photo.rectify/ps_cp.c:53
-#, fuzzy
msgid "Poorly placed psuedo control points. "
о ÑаÑÑÑавленÑ"
+msgstr "ÐлоÑ
о ÑаÑÑÑÐ°Ð²Ð»ÐµÐ½Ñ Ð¿Ñевдо конÑÑолÑнÑе ÑоÑки."
#: ../imagery/i.ortho.photo/photo.rectify/ps_cp.c:54
-#, fuzzy
msgid "Cannot generate the transformation equation."
-msgstr "векÑоÑ"
+msgstr "Ðевозможно ÑгенеÑиÑоваÑÑ ÑÑавнение ÑÑанÑÑоÑмаÑии."
#: ../imagery/i.ortho.photo/photo.rectify/ps_cp.c:58
-#, fuzzy
msgid "No active psuedo control points"
-msgstr "ÐÐµÑ Ð°ÐºÑивнÑÑ
конÑÑолÑнÑÑ
ÑоÑек"
+msgstr "ÐÐµÑ Ð°ÐºÑивнÑÑ
пÑевдо конÑÑолÑнÑÑ
ÑоÑек"
#: ../imagery/i.ortho.photo/photo.rectify/rectify.c:245
-#, fuzzy, c-format
+#, c-format
msgid "%s@%s: projection doesn't match current settings"
-msgstr "ÐÑйÑи без Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð½Ð°ÑÑÑоек"
+msgstr "%s@%s: пÑоекÑÐ¸Ñ Ð½Ðµ ÑооÑвеÑÑÑвÑÐµÑ ÑекÑÑим наÑÑÑойкам"
#: ../imagery/i.ortho.photo/photo.rectify/rectify.c:251
-#, fuzzy, c-format
+#, c-format
msgid "%s@%s: zone doesn't match current settings"
+msgstr "%s@%s: зона не ÑооÑвеÑÑÑвÑÐµÑ ÑекÑÑим наÑÑÑойкам"
#: ../imagery/i.ortho.photo/photo.rectify/main.c:51
#: ../imagery/i.ortho.photo/photo.target/main.c:48
-#, fuzzy
msgid "Interactively select or modify the imagery group target."
-msgstr "ÐнÑеÑакÑивно вÑбÑаÑÑ Ð¼Ð°ÑÑÑÑÑ"
+msgstr "ÐнÑеÑакÑивно вÑбÑаÑÑ Ð¸Ð»Ð¸ измениÑÑ ÑелевÑÑ Ð³ÑÑÐ¿Ð¿Ñ Ð¸Ð·Ð¾Ð±Ñажений."
#: ../imagery/i.ortho.photo/photo.rectify/main.c:78
-#, fuzzy
msgid "No files in this group!"
-msgstr " ."
+msgstr "Ð ÑÑой гÑÑппе Ð½ÐµÑ Ñайлов!"
#: ../imagery/i.ortho.photo/photo.rectify/main.c:117
#, c-format
msgid "Bad format in initial exposusre station file for group [%s]"
msgstr ""
+"ÐепÑавилÑнÑй ÑоÑÐ¼Ð°Ñ Ñайла наÑалÑной ÑкÑпозиÑии ÑÑанÑии Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ [%s] "
#: ../imagery/i.ortho.photo/photo.rectify/write.c:34
#, c-format
@@ -25636,37 +23543,36 @@
"запиÑÑ."
#: ../imagery/i.ortho.photo/photo.target/main.c:66
-#, fuzzy, c-format
+#, c-format
msgid "Group [%s] targeted for location [%s], mapset [%s]"
-msgstr "ÐÑÑппа <%s> наÑелена на облаÑÑÑ [%s], Ð½Ð°Ð±Ð¾Ñ [%s]"
+msgstr "ÐÑÑппа [%s] наÑелена на облаÑÑÑ [%s], Ð½Ð°Ð±Ð¾Ñ [%s]"
#: ../imagery/i.maxlik/open.c:26
-#, fuzzy, c-format
+#, c-format
msgid ""
"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
"have at least 2 raster maps."
msgstr ""
-"ÐодгÑÑппа [%s] гÑÑÐ¿Ð¿Ñ [%s] не ÑодеÑÐ¶Ð¸Ñ ÑайлÑ.\n"
-"ÐодгÑÑппа должна ÑодеÑжаÑÑ Ð¼Ð¸Ð½Ð¸Ð¼Ñм 2 Ñайла."
+"ÐодгÑÑппа <%s> гÑÑÐ¿Ð¿Ñ <%s> не ÑодеÑÐ¶Ð¸Ñ ÑайлÑ. ÐодгÑÑппа должна ÑодеÑжаÑÑ "
+"минимÑм 2 ÑаÑÑÑовÑÑ
ÑлоÑ."
#: ../imagery/i.maxlik/open.c:29
-#, fuzzy, c-format
+#, c-format
msgid ""
"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
"least 2 raster maps."
msgstr ""
-"ÐодгÑÑппа [%s] гÑÑÐ¿Ð¿Ñ [%s] ÑодеÑÐ¶Ð¸Ñ 1 Ñайл.\n"
+"ÐодгÑÑппа <%s> гÑÑÐ¿Ð¿Ñ <%s> ÑодеÑÐ¶Ð¸Ñ 1 ÑаÑÑÑовÑй Ñлой. ÐодгÑÑппа должна "
+"ÑодеÑжаÑÑ Ð¼Ð¸Ð½Ð¸Ð¼Ñм 2 ÑаÑÑÑовÑÑ
ÑлоÑ."
#: ../imagery/i.maxlik/open.c:48
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open signature file <%s>"
-msgstr "Ðевозможно оÑкÑÑÑÑ ÑайÑ-Ñайл <%s@%s>"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл ÑÑалонов <%s>"
#: ../imagery/i.maxlik/main.c:63
-#, fuzzy
msgid "imagery, classification, MLC"
-msgstr "ÐлаÑÑиÑикаÑÐ¸Ñ ÑоÑек"
+msgstr "изобÑажениÑ, клаÑÑиÑикаÑиÑ, MLC"
#: ../imagery/i.maxlik/main.c:65
msgid "Classifies the cell spectral reflectances in imagery data."
@@ -25681,31 +23587,26 @@
"cluster, i.class, или i.gensig."
#: ../imagery/i.maxlik/main.c:80
-#, fuzzy
msgid "Generated by either i.cluster, i.class, or i.gensig"
-msgstr ""
-"ÐлаÑÑиÑикаÑÐ¸Ñ Ð¾Ñнована на инÑоÑмаÑии ÑпекÑÑалÑнÑÑ
ÑÑалонов, генеÑиÑÑемой i."
-"cluster, i.class, или i.gensig."
+msgstr "Создано Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ i.cluster, i.class, или i.gensig"
#: ../imagery/i.maxlik/main.c:85
-#, fuzzy
msgid "Name for raster map holding classification results"
msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑлоÑ, ÑодеÑжаÑего ÑезÑлÑÑÐ°Ñ ÐºÐ»Ð°ÑÑиÑикаÑии"
#: ../imagery/i.maxlik/main.c:91
-#, fuzzy
msgid "Name for raster map holding reject threshold results"
msgstr "РаÑÑÑовÑй Ñлой Ð´Ð»Ñ ÑезÑлÑÑаÑов оÑбÑакованнÑÑ
по поÑогÑ"
#: ../imagery/i.maxlik/invert.c:28
-#, fuzzy, c-format
+#, c-format
msgid "Signature %d is not valid (ill-conditioned) - ignored"
-msgstr "ÑÑалон %d не веÑен (непÑавилÑно задан) - игноÑиÑÑеÑÑÑ."
+msgstr "ÐÑалон %d не веÑен (непÑавилÑно задан) - игноÑиÑÑеÑÑÑ"
#: ../imagery/i.maxlik/invert.c:31
-#, fuzzy, c-format
+#, c-format
msgid "Signature %d is not valid (singular) - ignored"
-msgstr "ÑÑалон %d не веÑен (ÑингÑлÑÑен) - игноÑиÑÑеÑÑÑ."
+msgstr "ÐÑалон %d не веÑен (ÑингÑлÑÑен) - игноÑиÑÑеÑÑÑ"
#: ../imagery/i.cca/transform.c:18
msgid "Unable to allocate cell buffers."
@@ -25871,6 +23772,27 @@
msgid "Unable to map image file"
msgstr "Ðевозможно наложиÑÑ Ñайл изобÑажениÑ"
+#: ../visualization/ximgview/main.c:270 ../display/d.histogram/main.c:71
+#: ../display/d.mapgraph/main.c:48 ../display/d.erase/main.c:32
+#: ../display/d.profile/main.c:61 ../display/d.measure/main.c:49
+#: ../display/d.colors/main.c:50 ../display/d.what.vect/main.c:54
+#: ../display/d.font/main.c:46 ../display/d.rast.num/number.c:84
+#: ../display/d.linegraph/linegraph.c:113 ../display/d.colorlist/main.c:35
+#: ../display/d.what.rast/main.c:52 ../display/d.title/main.c:45
+#: ../display/d.geodesic/main.c:45 ../display/d.text/main.c:66
+#: ../display/d.font.freetype/main.c:59 ../display/d.info/main.c:34
+#: ../display/d.save/main.c:79 ../display/d.rast.arrow/arrow.c:110
+#: ../display/d.menu/main.c:66 ../display/d.thematic.area/main.c:78
+#: ../display/d.text.freetype/main.c:138 ../display/d.extract/main.c:50
+#: ../display/d.rgb/main.c:55 ../display/d.where/main.c:42
+#: ../display/d.paint.labels/main.c:46 ../display/d.text.new/main.c:139
+#: ../display/d.ask/main.c:36 ../display/d.his/main.c:65
+#: ../display/d.zoom/main.c:57 ../display/d.rhumbline/main.c:45
+#: ../display/d.nviz/main.c:68 ../display/d.mon/cmd/main.c:48
+#: ../display/d.frame/frame.c:60
+msgid "display"
+msgstr "показаÑÑ/диÑплей"
#: ../visualization/ximgview/main.c:271
msgid "View BMP images from the PNG driver."
msgstr "ÐÑоÑмоÑÑ Ð¸Ð·Ð¾Ð±Ñажений BMP Ñ Ð´ÑайвеÑом PNG."
@@ -25943,41 +23865,44 @@
msgid "Quickstart - Do not load any data"
msgstr "ÐÑÑÑÑое наÑало - не загÑÑжаÑÑ Ð´Ð°Ð½Ð½Ñе"
-#: ../visualization/nviz/src/nviz_init.c:104
-msgid "Script kill option"
-msgstr "ÐпÑÐ¸Ñ kill ÑкÑипÑа"
+#: ../visualization/nviz/src/nviz_init.c:105
+msgid "Exit after completing script launched from the command line"
+msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:108
-msgid "Start in Demo mode"
-msgstr "ÐапÑÑÑиÑÑ Ð² Ðемо Ñежиме"
+#: ../visualization/nviz/src/nviz_init.c:110
+msgid "Start in Demo mode (skip the \"please wait\" message)"
+msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:112
-msgid "Output more comments (default=quiet)"
-msgstr "ÐÑводиÑÑ Ð±Ð¾Ð»ÑÑе комменÑаÑиев (по ÑмолÑаниÑ=quiet)"
+#: ../visualization/nviz/src/nviz_init.c:114
+#, fuzzy
+msgid "Verbose module output"
+msgstr "Режим ÑаÑÑиÑенной инÑоÑмаÑии"
-#: ../visualization/nviz/src/nviz_init.c:118
+#: ../visualization/nviz/src/nviz_init.c:120
msgid "Set alternative panel path"
msgstr "ÐадаÑÑ Ð°Ð»ÑÑеÑнаÑивнÑй пÑÑÑ Ð¿Ð°Ð½ÐµÐ»Ð¸"
-#: ../visualization/nviz/src/nviz_init.c:124
+#: ../visualization/nviz/src/nviz_init.c:126
msgid "Execute script file at startup"
msgstr "ÐапÑÑÑиÑÑ ÑкÑÐ¸Ð¿Ñ Ð¿Ñи ÑÑаÑÑе"
-#: ../visualization/nviz/src/nviz_init.c:130
-#, fuzzy
+#: ../visualization/nviz/src/nviz_init.c:132
msgid "Load previously saved state file"
-msgstr "ÐагÑÑзиÑÑ Ð¿ÑедваÑиÑелÑно ÑоÑ
ÑаненнÑй Ñайл ÑÑаÑиÑÑики"
+msgstr "ÐагÑÑзиÑÑ Ð¿ÑедваÑиÑелÑно ÑоÑ
ÑаненнÑй Ñайл ÑоÑÑоÑниÑ"
-#: ../visualization/nviz/src/nviz_init.c:279
+#: ../visualization/nviz/src/nviz_init.c:286
msgid "Number of elevation files does not match number of colors files"
msgstr "ÐолиÑеÑÑво Ñайлов вÑÑÐ¾Ñ Ð½Ðµ ÑооÑвеÑÑÑвÑÐµÑ ÑиÑÐ»Ñ ÑвеÑовÑÑ
Ñайлов"
-#: ../visualization/nviz/src/nviz_init.c:290
+#: ../visualization/nviz/src/nviz_init.c:297
msgid "Loading data failed"
msgstr "Ðе ÑдалоÑÑ Ð·Ð°Ð³ÑÑзиÑÑ Ð´Ð°Ð½Ð½Ñе"
+#: ../visualization/nviz/src/nviz_init.c:405
+msgid "Entering script mode ..."
+msgstr ""
#: ../visualization/nviz2/cmd/vector.c:181
-#, fuzzy
msgid "Unknown icon marker"
msgstr "ÐеизвеÑÑÐ½Ð°Ñ Ð¸ÐºÐ¾Ð½ÐºÐ° маÑкеÑа"
@@ -26060,6 +23985,10 @@
msgid "Image"
msgstr "ÐзобÑажение"
+#: ../visualization/nviz2/cmd/args.c:87
+msgid "Graphics file format"
+msgstr "ФоÑÐ¼Ð°Ñ Ð³ÑаÑиÑеÑкого Ñайла"
#: ../visualization/nviz2/cmd/args.c:97
msgid "Width and height of output image"
msgstr "ШиÑина и вÑÑоÑа вÑÑ
одного изобÑажениÑ"
@@ -26306,6 +24235,14 @@
msgid "Cannot use current window"
msgstr "Ðевозможно иÑполÑзоваÑÑ ÑекÑÑее окно"
+#: ../display/d.rast.edit/main.c:59 ../display/d.rast/main.c:51
+msgid "display, raster"
+msgstr "показ, ÑаÑÑÑ"
+#: ../display/d.rast.edit/main.c:61
+msgid "Interactively edit cell values in a raster map."
+msgstr "ÐнÑеÑакÑивное ÑедакÑиÑование знаÑений ÑÑеек ÑаÑÑÑового ÑлоÑ"
#: ../display/d.histogram/main.c:73
msgid ""
"Displays a histogram in the form of a pie or bar chart for a user-specified "
@@ -26527,67 +24464,67 @@
msgid "warning: %s - vector map not found\n"
msgstr "пÑедÑпÑеждение: %s - векÑÐ¾Ñ Ð½Ðµ найден\n"
-#: ../display/d.what.vect/what.c:231
+#: ../display/d.what.vect/what.c:237
#, c-format
msgid "Line: %d Type: %s Left: %d Right: %d "
msgstr "СÑÑока: %d Тип: %s Ðево: %d ÐÑаво: %d "
-#: ../display/d.what.vect/what.c:251
+#: ../display/d.what.vect/what.c:257
#, c-format
msgid " Node[%d]: %d Number of lines: %d Coordinates: %.6f, %.6f, %.6f\n"
msgstr " Узел[%d]: %d ЧиÑло линий: %d ÐооÑдинаÑÑ: %.6f, %.6f, %.6f\n"
-#: ../display/d.what.vect/what.c:260
+#: ../display/d.what.vect/what.c:266
#, c-format
msgid " Line: %5d Angle: %.8f\n"
msgstr " ÐиниÑ: %5d Угол: %.8f\n"
-#: ../display/d.what.vect/what.c:269
+#: ../display/d.what.vect/what.c:275
#, c-format
msgid "length %f\n"
msgstr "длина %f\n"
-#: ../display/d.what.vect/what.c:316
+#: ../display/d.what.vect/what.c:322
#, c-format
msgid "Line height min: %f max: %f\n"
msgstr "ÐÑÑоÑа лини мин: %f макÑ: %f\n"
-#: ../display/d.what.vect/what.c:337
+#: ../display/d.what.vect/what.c:343
#, c-format
msgid "Area height: %f\n"
msgstr "ÐÑÑоÑа полигона: %f\n"
-#: ../display/d.what.vect/what.c:346
+#: ../display/d.what.vect/what.c:352
#, c-format
msgid "Area\n"
msgstr "Ðолигон\n"
-#: ../display/d.what.vect/what.c:361
+#: ../display/d.what.vect/what.c:374
#, c-format
msgid "Area: %d Number of isles: %d\n"
msgstr "Ðолигон: %d ЧиÑло оÑÑÑовов: %d\n"
-#: ../display/d.what.vect/what.c:366
+#: ../display/d.what.vect/what.c:379
#, c-format
msgid " Isle[%d]: %d\n"
msgstr " ÐÑÑÑов[%d]: %d\n"
-#: ../display/d.what.vect/what.c:373
+#: ../display/d.what.vect/what.c:386
#, c-format
msgid "Island: %d In area: %d\n"
msgstr "ÐÑÑÑов: %d Рполигоне: %d\n"
-#: ../display/d.what.vect/what.c:380 ../display/d.what.vect/what.c:389
+#: ../display/d.what.vect/what.c:393 ../display/d.what.vect/what.c:401
#, c-format
msgid "Size - Sq Meters: %.3f\t\tHectares: %.3f\n"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ - кв. меÑÑÑ: %.3f\t\tÐекÑаÑÑ: %.3f\n"
-#: ../display/d.what.vect/what.c:384 ../display/d.what.vect/what.c:393
+#: ../display/d.what.vect/what.c:397 ../display/d.what.vect/what.c:405
#, c-format
msgid " Acres: %.3f\t\tSq Miles: %.4f\n"
msgstr " ÐкÑÑ: %.3f\t\tÐв. мили: %.4f\n"
-#: ../display/d.what.vect/what.c:422
+#: ../display/d.what.vect/what.c:433
#, c-format
msgid ""
"Layer: %d\n"
@@ -26596,7 +24533,7 @@
"Слой: %d\n"
"ÐаÑегоÑиÑ: %d\n"
-#: ../display/d.what.vect/what.c:447
+#: ../display/d.what.vect/what.c:458
#, c-format
msgid ""
"driver: %s\n"
@@ -26609,7 +24546,7 @@
"ÑаблиÑа: %s\n"
"клÑÑевой ÑÑолбеÑ: %s\n"
-#: ../display/d.what.vect/what.c:512
+#: ../display/d.what.vect/what.c:523
#, c-format
msgid ""
"\n"
@@ -26620,22 +24557,22 @@
"ЩелкниÑе мÑÑÑÑ Ð² нÑжном меÑÑоположении\n"
"\n"
-#: ../display/d.what.vect/what.c:517
+#: ../display/d.what.vect/what.c:528
#, c-format
msgid "Buttons\n"
msgstr "Ðнопки\n"
-#: ../display/d.what.vect/what.c:518
+#: ../display/d.what.vect/what.c:529
#, c-format
msgid " Left: what's here\n"
msgstr " ÐеваÑ: ÑÑо здеÑÑ\n"
-#: ../display/d.what.vect/what.c:520
+#: ../display/d.what.vect/what.c:531
#, c-format
msgid " Middle: toggle flash color\n"
msgstr " СÑеднÑÑ: пеÑеклÑÑиÑÑ ÑÐ²ÐµÑ Ð¼Ð¸Ð³Ð°Ð½Ð¸Ñ\n"
-#: ../display/d.what.vect/what.c:525
+#: ../display/d.what.vect/what.c:536
#, c-format
msgid " Right: quit\n"
msgstr " ÐÑаваÑ: вÑйÑи\n"
@@ -26955,6 +24892,8 @@
"Displays a geodesic line, tracing the shortest distance between two "
"geographic points along a great circle, in a longitude/latitude data set."
msgstr ""
+"ÐоказаÑÑ Ð³ÐµÐ¾Ð´ÐµÐ·Ð¸ÑеÑкÑÑ Ð»Ð¸Ð½Ð¸Ñ, показÑваÑÑÑÑ ÐºÑаÑÑайÑее ÑаÑÑÑоÑние Ð¼ÐµÐ¶Ð´Ñ Ð´Ð²ÑÐ¼Ñ "
+"геогÑаÑиÑеÑкими ÑоÑками на линии болÑÑого кÑÑга, в набоÑе ÑиÑоÑа/долгоÑа."
#: ../display/d.geodesic/main.c:56 ../display/d.rhumbline/main.c:55
#: ../display/d.path/main.c:66
@@ -26967,14 +24906,13 @@
msgstr "Ð¦Ð²ÐµÑ Ð»Ð¸Ð½Ð¸Ð¸"
#: ../display/d.geodesic/main.c:70
-#, fuzzy
msgid "Text color or \"none\""
-msgstr "Ð¦Ð²ÐµÑ ÑекÑÑа"
+msgstr "Ð¦Ð²ÐµÑ ÑекÑÑа или \"none\""
#: ../display/d.geodesic/main.c:78 ../display/d.rhumbline/main.c:79
-#, fuzzy, c-format
+#, c-format
msgid "Location is not %s"
-msgstr "ÐблаÑÑÑ: %s\n"
+msgstr "ÐблаÑÑÑ Ð½Ðµ %s"
#: ../display/d.geodesic/main.c:83 ../display/d.rhumbline/main.c:85
#: ../display/d.path/main.c:143
@@ -26985,9 +24923,9 @@
#: ../display/d.geodesic/main.c:95 ../display/d.geodesic/main.c:99
#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:93
#: ../display/d.rhumbline/main.c:98 ../display/d.rhumbline/main.c:102
-#, fuzzy, c-format
+#, c-format
msgid "%s - illegal longitude"
-msgstr " "
+msgstr "%s - недопÑÑÑÐ¸Ð¼Ð°Ñ Ð´Ð¾Ð»Ð³Ð¾Ñа"
#: ../display/d.text/main.c:68 ../display/d.text.new/main.c:141
msgid ""
@@ -27074,11 +25012,8 @@
msgstr "ÐоказаÑÑ Ð¿ÑÑмоÑголÑник ÑекÑÑего Ñегиона"
#: ../display/d.info/main.c:58
-#, fuzzy
msgid "Display geographic coordinates and resolution of entire screen"
-msgstr ""
-"ÐоказаÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ Ð¸ ÑазÑеÑение пÑÑмоÑголÑника ÑкÑана (запад, воÑÑок, "
-"ÑевеÑ, Ñг, ÑазÑеÑение воÑÑок-запад, ÑазÑеÑение ÑевеÑ-Ñг)"
+msgstr "ÐоказаÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ Ð¸ ÑазÑеÑение вÑего ÑкÑана"
#: ../display/d.info/main.c:62
msgid "Display number of colors"
@@ -27097,6 +25032,10 @@
msgstr ""
"ÐоказаÑÑ Ð»ÐµÐ³ÐµÐ½Ð´Ñ Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð² акÑивном ÑÑейме гÑаÑиÑеÑкого мониÑоÑа."
+#: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:90
+msgid "Name of raster map"
+msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑлоÑ"
#: ../display/d.legend/main.c:99
msgid "Sets the legend's text color"
msgstr "УÑÑановиÑÑ ÑÐ²ÐµÑ ÑекÑÑа легендÑ"
@@ -27145,6 +25084,10 @@
msgid "Draw smooth gradient"
msgstr "ÐÑÑиÑоваÑÑ Ð³Ð»Ð°Ð´ÐºÐ¸Ð¹ гÑадиенÑ"
+#: ../display/d.legend/main.c:184
+msgid "Flip legend"
+msgstr "ÐеÑевеÑнÑÑÑ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
#: ../display/d.legend/main.c:205 ../display/d.menu/main.c:113
#: ../display/d.menu/main.c:119 ../display/d.menu/main.c:125
#, c-format
@@ -27241,7 +25184,7 @@
msgstr "ÐониÑÐ¾Ñ Ð½Ðµ вÑбÑан"
#: ../display/d.save/main.c:481 ../display/d.save/main.c:516
-#, fuzzy, c-format
+#, c-format
msgid "Unknown item type in pad: %s"
msgstr "ÐеизвеÑÑнÑй Ñип ÑлеменÑа в pad: %s"
@@ -27293,9 +25236,8 @@
msgstr "Ðевозможно пÑоÑиÑаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
#: ../display/d.vect/plot1.c:211 ../display/d.thematic.area/plot1.c:207
-#, fuzzy
msgid "Color definition column not specified"
-msgstr "Ðе Ñказан ÑÑÐ¾Ð»Ð±ÐµÑ Ð¾Ð¿ÑеделиÑÐµÐ»Ñ ÑвеÑа."
+msgstr "Ðе Ñказан ÑÑÐ¾Ð»Ð±ÐµÑ Ð¾Ð¿ÑÐµÐ´ÐµÐ»ÐµÐ½Ð¸Ñ ÑвеÑа"
#: ../display/d.vect/plot1.c:221 ../display/d.vect/area.c:79
#: ../display/d.thematic.area/plot1.c:217
@@ -27328,18 +25270,18 @@
msgstr "СÑÐ¾Ð»Ð±ÐµÑ Ñ ÑиÑиной линии (%s) не ÑиÑловаÑ."
#: ../display/d.vect/plot1.c:386
-#, fuzzy, c-format
+#, c-format
msgid ""
"Error in color definition column '%s', feature id %d with cat %d: "
"colorstring '%s'"
msgstr ""
-"ÐÑибка в ÑÑолбÑе опÑеделиÑÐµÐ»Ñ ÑвеÑа (%s), ÑÐ»ÐµÐ¼ÐµÐ½Ñ %d Ñ ÐºÐ°ÑегоÑией %d: ÑÑÑока "
-"ÑвеÑа [%s]"
+"ÐÑибка в ÑÑолбÑе опÑÐµÐ´ÐµÐ»ÐµÐ½Ð¸Ñ ÑвеÑа '%s', ÑÐ»ÐµÐ¼ÐµÐ½Ñ %d Ñ ÐºÐ°ÑегоÑией %d: ÑÑÑока "
+"ÑвеÑа '%s'"
#: ../display/d.vect/plot1.c:394
-#, fuzzy, c-format
+#, c-format
msgid "Error in color definition column '%s', feature id %d with cat %d"
-msgstr "ÐÑибка в ÑÑолбÑе опÑеделиÑÐµÐ»Ñ ÑвеÑа (%s), ÑÐ»ÐµÐ¼ÐµÐ½Ñ %d Ñ ÐºÐ°ÑегоÑией %d"
+msgstr "ÐÑибка в ÑÑолбÑе опÑÐµÐ´ÐµÐ»ÐµÐ½Ð¸Ñ ÑвеÑа '%s', обÑÐµÐºÑ %d Ñ ÐºÐ°ÑегоÑией %d"
#: ../display/d.vect/plot1.c:463 ../display/d.vect/area.c:345
#: ../display/d.thematic.area/plot1.c:441
@@ -27351,9 +25293,9 @@
"[%d]"
#: ../display/d.vect/plot1.c:528
-#, fuzzy, c-format
+#, c-format
msgid "Error in color definition column '%s': %d features affected"
-msgstr "ÐÑибка в ÑÑолбÑе опÑеделиÑÐµÐ»Ñ ÑвеÑа (%s) Ñ ÐºÐ°ÑегоÑией %d"
+msgstr "ÐÑибка в ÑÑолбÑе опÑÐµÐ´ÐµÐ»ÐµÐ½Ð¸Ñ ÑвеÑа '%s': заÑÑонÑÑо %d обÑекÑов"
#: ../display/d.vect/topo.c:39 ../display/d.thematic.area/plot1.c:291
#, c-format
@@ -27377,9 +25319,8 @@
msgstr "ÐоказаÑÑ"
#: ../display/d.vect/main.c:148
-#, fuzzy
msgid "Layer number (if -1, all layers are displayed)"
-msgstr "ÐÐ¾Ð¼ÐµÑ ÑлоÑ. ÐÑли -1, показÑваÑÑÑÑ Ð²Ñе Ñлои."
+msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ (ÐÑли -1, показÑваÑÑÑÑ Ð²Ñе Ñлои)"
#: ../display/d.vect/main.c:167 ../display/d.vect/main.c:177
#: ../display/d.vect/main.c:264 ../display/d.vect/main.c:274
@@ -27437,9 +25378,8 @@
msgstr "ÐодпиÑи"
#: ../display/d.vect/main.c:239
-#, fuzzy
msgid "Layer number for labels (default: the given layer number)"
-msgstr "Слой Ð´Ð»Ñ Ð¿Ð¾Ð´Ð¿Ð¸Ñей (по ÑмолÑаниÑ: заданнÑй Ð½Ð¾Ð¼ÐµÑ ÑлоÑ)"
+msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ Ð´Ð»Ñ Ð¿Ð¾Ð´Ð¿Ð¸Ñей (по ÑмолÑаниÑ: заданнÑй Ð½Ð¾Ð¼ÐµÑ ÑлоÑ)"
#: ../display/d.vect/main.c:245
msgid "Name of column to be displayed"
@@ -27552,12 +25492,11 @@
msgstr "ÐеизвеÑÑнÑй ÑвеÑ: [%s]"
#: ../display/d.vect/main.c:466
-#, fuzzy, c-format
+#, c-format
msgid "Unknown color: '%s'"
-msgstr "ÐеизвеÑÑнÑй ÑвеÑ: [%s]"
+msgstr "ÐеизвеÑÑнÑй ÑвеÑ: '%s'"
#: ../display/d.vect/main.c:472
-#, fuzzy
msgid "Unable to read symbol, unable todisplay points"
msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñимвол, невозможно показаÑÑ ÑоÑки"
@@ -27580,17 +25519,14 @@
msgstr "ÐÑ
Ð²Ð°Ñ ÑÐ»Ð¾Ñ Ð²Ð½Ðµ ÑекÑÑего Ñегиона, ниÑего не показÑваеÑÑÑ."
#: ../display/d.vect/main.c:679
-#, fuzzy
msgid "Unable to display areas, topology not available"
msgstr "Ðевозможно показаÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ñ, недоÑÑÑпна ÑопологиÑ"
#: ../display/d.vect/main.c:684
-#, fuzzy
msgid "Unable to display lines by id, topology not available"
msgstr "Ðевозможно показаÑÑ Ð»Ð¸Ð½Ð¸Ð¸ по id, недоÑÑÑпна ÑопологиÑ"
#: ../display/d.vect/main.c:726
-#, fuzzy
msgid "Unable to display topology, not available"
msgstr "Ðевозможно показаÑÑ ÑопологиÑ, не доÑÑÑпна"
@@ -27782,13 +25718,11 @@
msgstr "ÐÑибка в поле опÑеделиÑÐµÐ»Ñ ÑвеÑа (%s), ÑÐ»ÐµÐ¼ÐµÐ½Ñ %d Ñ ÐºÐ°ÑегоÑией %d"
#: ../display/d.thematic.area/main.c:80
-#, fuzzy
msgid ""
"Displays a thematic vector area map in the active frame on the graphics "
"monitor."
msgstr ""
-"ÐоказÑÐ²Ð°ÐµÑ ÑемаÑиÑеÑкий векÑоÑнÑй Ñлой в акÑивном ÑÑейме гÑаÑиÑеÑкого "
-"мониÑоÑа."
+"ÐоказаÑÑ ÑемаÑиÑеÑкий векÑоÑнÑй Ñлой в акÑивном ÑÑейме гÑаÑиÑеÑкого мониÑоÑа."
#: ../display/d.thematic.area/main.c:90
msgid "Data to be classified: column name or expression"
@@ -27981,9 +25915,8 @@
msgstr "ÐевеÑнÑй ÑÑиÑÑ: %s"
#: ../display/d.text.freetype/main.c:331 ../display/d.text.freetype/main.c:458
-#, fuzzy
msgid "Unable to create face"
-msgstr "Ðевозможно ÑоздаÑÑ face"
+msgstr "Ðевозможно ÑоздаÑÑ Ð³ÑанÑ"
#: ../display/d.text.freetype/main.c:334 ../display/d.text.freetype/main.c:461
#: ../display/d.text.freetype/main.c:478
@@ -28315,25 +26248,26 @@
"Prompts the user to select a GRASS data base file from among files displayed "
"in a menu on the graphics monitor."
msgstr ""
+"ÐÑоÑиÑÑ Ð¿Ð¾Ð»ÑзоваÑÐµÐ»Ñ Ð²ÑбÑаÑÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
GRASS из Ñайлов показаннÑÑ
в Ð¼ÐµÐ½Ñ "
+"гÑаÑиÑеÑкого мониÑоÑа."
#: ../display/d.ask/main.c:46
msgid "Database element, one word description"
-msgstr ""
+msgstr "ÐÐ»ÐµÐ¼ÐµÐ½Ñ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
, опиÑание из одного Ñлова"
#: ../display/d.ask/main.c:52
-#, fuzzy
msgid "Short user prompt message"
-msgstr "ÐÑвеÑÑи ÑообÑение об авÑоÑÑкиÑ
пÑаваÑ
+msgstr "ÐоÑоÑÐºÐ°Ñ Ð¿Ð¾Ð»ÑзоваÑелÑÑÐºÐ°Ñ Ð¿Ð¾Ð´Ñказка"
#: ../display/d.ask/main.c:85
#, c-format
msgid "** no %s files found **\n"
-msgstr ""
+msgstr "** Ñайлов %s не найдено **\n"
#: ../display/d.ask/main.c:86
#, c-format
msgid "Click here to CONTINUE\n"
-msgstr ""
+msgstr "ЩелкниÑе Ð´Ð»Ñ Ð¿ÑодолжениÑ\n"
#: ../display/d.his/main.c:67
msgid ""
@@ -28388,6 +26322,10 @@
"ÐозволÑÐµÑ Ð¸Ð½ÑеÑакÑивно измениÑÑ ÑекÑÑие наÑÑÑойки геогÑаÑиÑеÑкого Ñегиона Ñ "
"помоÑÑÑ Ð¼ÑÑи."
+#: ../display/d.zoom/main.c:100
+msgid "Name of vector map"
+msgstr "ÐÐ¼Ñ Ð²ÐµÐºÑоÑного ÑлоÑ"
#: ../display/d.zoom/main.c:108
msgid "Magnification: >1.0 zooms in, <1.0 zooms out"
msgstr "ÐаÑÑÑабиÑование: >1.0 ÑвелиÑиÑÑ, <1.0 ÑменÑÑиÑÑ"
@@ -28434,7 +26372,6 @@
msgstr "%d ÑаÑÑÑ%s, %d векÑоÑ%s\n"
#: ../display/d.zoom/main.c:307
-#, fuzzy
msgid "No previous zoom available"
msgstr "ÐÐµÑ Ð¿ÑедÑдÑÑиÑ
маÑÑÑабов"
@@ -28532,6 +26469,11 @@
msgid "Grid color"
msgstr "Ð¦Ð²ÐµÑ ÑеÑки"
+#: ../display/d.grid/main.c:76 ../display/d.grid/main.c:81
+#: ../display/d.grid/main.c:87
+msgid "Color"
+msgstr "ЦвеÑ"
#: ../display/d.grid/main.c:95
msgid "Font size for gridline coordinate labels"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ ÑÑиÑÑа Ð´Ð»Ñ Ð¿Ð¾Ð´Ð¿Ð¸Ñей кооÑÐ´Ð¸Ð½Ð°Ñ Ð»Ð¸Ð½Ð¸Ð¹ ÑеÑки"
@@ -28582,7 +26524,6 @@
msgstr "ÐпÑÐ¸Ñ Geo-Grid недоÑÑÑпна Ð´Ð»Ñ Ð¿ÑоекÑии XY"
#: ../display/d.grid/main.c:154
-#, fuzzy
msgid "Choose a single mark style"
msgstr "ÐÑбÑаÑÑ ÐµÐ´Ð¸Ð½Ñй ÑÑÐ¸Ð»Ñ Ð¼ÐµÑок"
@@ -28597,13 +26538,12 @@
msgstr "ÐевеÑнÑй ÑÐ°Ð·Ð¼ÐµÑ ÑеÑки <%s>"
#: ../display/d.rhumbline/main.c:47
-#, fuzzy
msgid ""
"Displays the rhumbline joining two user-specified points, in the active "
"frame on the user's graphics monitor."
msgstr ""
-"мониÑоÑа."
+"ÐоказаÑÑ Ð»Ð¸Ð½Ð¸Ñ ÑÑмба ÑоединÑÑÑÑÑ Ð´Ð²Ðµ заданнÑе ÑоÑки, в акÑивном ÑÑейме окна "
+"гÑаÑики полÑзоваÑелÑ."
#: ../display/d.nviz/main.c:69
msgid "Creates fly-through script to run in NVIZ."
@@ -28622,9 +26562,8 @@
msgstr "ÐооÑдинаÑÑ Ð¼Ð°ÑÑÑÑÑа (воÑÑок,ÑевеÑ)"
#: ../display/d.nviz/main.c:94
-#, fuzzy
msgid "Camera layback distance (in map units)"
-msgstr "ÐакÑималÑное ÑаÑÑÑоÑние Ð¼ÐµÐ¶Ð´Ñ ÑоÑками в единиÑаÑ
каÑÑÑ"
+msgstr ""
#: ../display/d.nviz/main.c:100
msgid "Camera height above terrain"
@@ -28696,6 +26635,10 @@
"ТоÑка пÑопÑÑен, Ñак как наÑ
одиÑÑÑ Ð²Ð½Ðµ Ñегиона. Ðозможно ÑаÑÑÑоÑние до камеÑÑ "
"оÑноÑÐ¸Ñ ÑоÑÐºÑ Ð·Ð° кÑай?"
+#: ../display/d.colortable/main.c:66 ../display/d.extend/main.c:31
+msgid "display, setup"
+msgstr "показ, наÑÑÑойка"
#: ../display/d.colortable/main.c:68
msgid "Displays the color table associated with a raster map layer."
msgstr "ÐÑобÑажаеÑÑÑ ÑаблиÑа ÑвеÑов, аÑÑоÑииÑÐ¾Ð²Ð°Ð½Ð½Ð°Ñ Ñ ÑаÑÑÑовÑм Ñлоем."
@@ -29131,14 +27074,13 @@
#: ../general/g.gisenv/main.c:66
msgid "Use shell syntax (for \"eval\")"
-msgstr ""
+msgstr "ÐÑполÑзÑйÑе ÑинÑакÑÐ¸Ñ Ð¾Ð±Ð¾Ð»Ð¾Ñки (Ð´Ð»Ñ \"eval\")"
#: ../general/g.gisenv/main.c:70
msgid "Don't use shell syntax"
-msgstr ""
+msgstr "Ðе иÑполÑзÑйÑе ÑинÑакÑÐ¸Ñ Ð¾Ð±Ð¾Ð»Ð¾Ñки"
#: ../general/g.gisenv/main.c:76
-#, fuzzy
msgid "-s and -n are mutually exclusive"
msgstr "-r и -e взаимоиÑклÑÑаÑÑиеÑÑ"
@@ -29159,9 +27101,8 @@
msgstr "Ðолжен бÑÑÑ Ð¾ÑкÑÑÑ Ð´Ð¾ÑÑÑп к набоÑÑ PERMANENT, ниÑего не изменено"
#: ../general/g.access/main.c:67
-#, fuzzy
msgid "Unable to determine mapset permissions"
-msgstr "Ðевозможно опÑеделиÑÑ Ð¿Ñава доÑÑÑпа к набоÑÑ Ñлоев"
+msgstr "Ðевозможно опÑеделиÑÑ Ð¿Ñава доÑÑÑпа к набоÑÑ"
#: ../general/manage/cmd/rename.c:40 ../general/manage/cmd/copy.c:39
#: ../general/manage/cmd/list.c:41 ../general/manage/cmd/remove.c:99
@@ -29189,12 +27130,12 @@
msgid "<%s> already exists in mapset <%s>"
msgstr "<%s> Ñже ÑÑÑеÑÑвÑÐµÑ Ð² набоÑе Ñлоев <%s>"
-#: ../general/manage/cmd/rename.c:88
-#, c-format
-msgid "%s=%s,%s: files are the same, no rename required"
+#: ../general/manage/cmd/rename.c:89
+#, fuzzy, c-format
+msgid "%s=%s,%s: files could be the same, no rename possible"
msgstr "%s=%s,%s: ÑÐ°Ð¹Ð»Ñ ÑовпадаÑÑ - пеÑеименование не ÑÑебÑеÑÑÑ"
-#: ../general/manage/cmd/rename.c:98
+#: ../general/manage/cmd/rename.c:99
msgid "Renaming reclass maps"
msgstr "ÐеÑеименование Ñлоев пеÑеклаÑÑиÑикаÑии"
@@ -29348,11 +27289,9 @@
msgstr "ÐÑÑоÑа изобÑажениÑ"
#: ../general/g.dirseps/main.c:35
-#, fuzzy
msgid "Internal GRASS utility for converting directory separator characters."
msgstr ""
-"ÐнÑÑÑенний инÑÑÑÑÐ¼ÐµÐ½Ñ GRASS Ð´Ð»Ñ ÐºÐ¾Ð½Ð²ÐµÑÑиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ñимволов Ñазделение "
-"каÑалогов."
+"ÐнÑÑÑенний инÑÑÑÑÐ¼ÐµÐ½Ñ GRASS Ð´Ð»Ñ ÐºÐ¾Ð½Ð²ÐµÑÑиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ñимволов ÑÐ°Ð·Ð´ÐµÐ»ÐµÐ½Ð¸Ñ ÐºÐ°Ñалога."
#: ../general/g.proj/input.c:82
msgid "Error reading WKT projection description"
@@ -29613,11 +27552,11 @@
msgid "Display summary information"
msgstr "ÐÑобÑазиÑÑ ÑводнÑÑ Ð¸Ð½ÑоÑмаÑиÑ"
-#: ../general/g.mapsets/main_cmd.c:52 ../general/g.mapset/main.c:48
+#: ../general/g.mapsets/main.c:59 ../general/g.mapset/main.c:48
msgid "general, settings"
msgstr "обÑее, наÑÑÑойки"
-#: ../general/g.mapsets/main_cmd.c:54
+#: ../general/g.mapsets/main.c:61
msgid ""
"Modifies the user's current mapset search path, affecting the user's access "
"to data existing under the other GRASS mapsets in the current location."
@@ -29625,70 +27564,88 @@
"ÐзмениÑÑ Ð¿ÑÑÑ Ð¿Ð¾Ð¸Ñка ÑекÑÑего набоÑа, заÑÑагиваÑÑий доÑÑÑп полÑзоваÑÐµÐ»Ñ Ðº "
"даннÑм из дÑÑгиÑ
набоÑов GRASS в ÑекÑÑей облаÑÑи."
-#: ../general/g.mapsets/main_cmd.c:63
+#: ../general/g.mapsets/main.c:70
msgid "Name(s) of existing mapset(s)"
msgstr "ÐÐ¼Ñ (имена) ÑÑÑеÑÑвÑÑÑего набоÑа (набоÑов)"
-#: ../general/g.mapsets/main_cmd.c:71
+#: ../general/g.mapsets/main.c:78
msgid "Name(s) of existing mapset(s) to add to search list"
msgstr "ÐÐ¼Ñ (имена) ÑÑÑеÑÑвÑÑÑего набоÑа Ð´Ð»Ñ Ð´Ð¾Ð±Ð°Ð²Ð»ÐµÐ½Ð¸Ñ Ð² ÑпиÑок поиÑка"
-#: ../general/g.mapsets/main_cmd.c:79
+#: ../general/g.mapsets/main.c:86
msgid "Name(s) of existing mapset(s) to remove from search list"
msgstr "ÐÐ¼Ñ (имена) ÑÑÑеÑÑвÑÑÑего набоÑа Ð´Ð»Ñ ÑÐ´Ð°Ð»ÐµÐ½Ð¸Ñ Ð¸Ð· ÑпиÑка поиÑка"
-#: ../general/g.mapsets/main_cmd.c:83
+#: ../general/g.mapsets/main.c:93
msgid "List all available mapsets"
msgstr "ÐÑвеÑÑи ÑпиÑок вÑеÑ
доÑÑÑпнÑÑ
набоÑов "
-#: ../general/g.mapsets/main_cmd.c:87
+#: ../general/g.mapsets/main.c:97
msgid "Print current mapset search path"
msgstr "ÐÑвеÑÑи пÑÑÑ Ð¿Ð¾Ð¸Ñка ÑекÑÑего набоÑа"
-#: ../general/g.mapsets/main_cmd.c:91
+#: ../general/g.mapsets/main.c:101
msgid "Show mapset selection dialog"
msgstr "ÐоказаÑÑ Ð´Ð¸Ð°Ð»Ð¾Ð³ вÑбоÑа набоÑа "
-#: ../general/g.mapsets/main_cmd.c:115 ../general/g.mapsets/main_cmd.c:140
+#: ../general/g.mapsets/main.c:126 ../general/g.mapsets/main.c:155
#, c-format
msgid "Mapset <%s> not found"
msgstr "ÐÐ°Ð±Ð¾Ñ <%s> не найден"
-#: ../general/g.mapsets/main_cmd.c:142
+#: ../general/g.mapsets/main.c:157
#, c-format
msgid "Mapset <%s> added to search path"
msgstr "ÐÐ°Ð±Ð¾Ñ <%s> добавлен в пÑÑÑ Ð¿Ð¾Ð¸Ñка"
-#: ../general/g.mapsets/main_cmd.c:166
+#: ../general/g.mapsets/main.c:183
#, c-format
msgid "Mapset <%s> removed from search path"
msgstr "ÐÐ°Ð±Ð¾Ñ <%s> Ñдален из пÑÑи поиÑка"
-#: ../general/g.mapsets/main_cmd.c:188
+#: ../general/g.mapsets/main.c:216
msgid "Cannot open SEARCH_PATH for write"
msgstr "Ðевозможно оÑкÑÑÑÑ SEARCH_PATH Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи"
+#: ../general/g.mapsets/dsply_path.c:19
+#, fuzzy, c-format
+msgid "Your mapset search list:\n"
+msgstr "ÐÑвеÑÑи пÑÑÑ Ð¿Ð¾Ð¸Ñка ÑекÑÑего набоÑа"
+#: ../general/g.mapsets/dsply_path.c:29
+#, fuzzy, c-format
+msgid "<%s> not found in mapset list"
+msgstr "СÑÐ¾Ð»Ð±ÐµÑ <%s> не найден в ÑаблиÑе <%s>"
+#: ../general/g.mapsets/dsply_maps.c:23
+#, fuzzy, c-format
+msgid "Available mapsets:"
+msgstr "СпиÑок доÑÑÑпнÑÑ
набоÑов"
+#: ../general/g.mapsets/dsply_maps.c:33
+#, fuzzy, c-format
+msgid "** no mapsets **\n"
#: ../general/g.findfile/main.c:37
msgid "Searches for GRASS data base files and sets variables for the shell."
-msgstr ""
+msgstr "ÐоиÑк Ñайлов баз даннÑÑ
GRASS и ÑÑÑановка пеÑеменнÑÑ
ÑÑедÑ."
#: ../general/g.findfile/main.c:48 ../general/g.filename/main.c:48
msgid "Name of an element"
msgstr "ÐÐ¼Ñ ÑлеменÑа"
#: ../general/g.findfile/main.c:54
-#, fuzzy
msgid "Name of an existing map"
-msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑего ÑаÑÑÑового ÑлоÑ"
+msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑего ÑлоÑ"
#: ../general/g.findfile/main.c:60
-#, fuzzy
msgid "Name of a mapset"
-msgstr "ÐÐ¼Ñ Ñелевого набоÑа"
+msgstr "ÐÐ¼Ñ Ð½Ð°Ð±Ð¾Ñа"
#: ../general/g.findfile/main.c:65
msgid "Don't add quotes"
-msgstr ""
+msgstr "Ðе добавлÑÑÑ ÐºÐ°Ð²ÑÑки"
#: ../general/g.findfile/main.c:79
#, c-format
@@ -29748,13 +27705,15 @@
#: ../general/g.region/main.c:114
msgid "Print the convergence angle (degrees CCW)"
-msgstr ""
+msgstr "ÐÑвеÑÑи Ñгол ÑÑ
одимоÑÑи (гÑадÑÑом пÑоÑив ÑаÑовой ÑÑÑелки)"
#: ../general/g.region/main.c:116
msgid ""
"The difference between the projection's grid north and true north, measured "
"at the center coordinates of the current region."
msgstr ""
+"РазниÑа Ð¼ÐµÐ¶Ð´Ñ ÑевеÑом пÑоекÑии и иÑÑиннÑм ÑевеÑом, измеÑÐµÐ½Ð½Ð°Ñ Ð² ÑенÑÑе "
+"кооÑÐ´Ð¸Ð½Ð°Ñ ÑекÑÑего Ñегиона."
#: ../general/g.region/main.c:122
msgid "Print also 3D settings"
@@ -29764,6 +27723,10 @@
msgid "Print the maximum bounding box in lat/long on WGS84"
msgstr "ÐÑвеÑÑи макÑималÑнÑй оÑ
Ð²Ð°Ñ Ð² lat/long WGS84"
+#: ../general/g.region/main.c:133
+msgid "Print in shell script style"
+msgstr "ÐÑвеÑÑи ÑÑаÑиÑÑÐ¸ÐºÑ Ð² ÑÑиле shell"
#: ../general/g.region/main.c:139
msgid ""
"Align region to resolution (default = align to bounds, works only for 2D "
@@ -29958,7 +27921,6 @@
msgstr "ÐеÑаÑаÑÑ ÑообÑение как оÑладоÑнÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ GRASS"
#: ../general/g.message/main.c:56
-#, fuzzy
msgid "Print message in all but full quiet mode"
msgstr "ÐÑвеÑÑи ÑообÑение в лÑбом, но не полноÑÑÑÑ ÑиÑ
ом Ñежиме"
@@ -29995,27 +27957,38 @@
msgstr "ÐнаÑение по ÑмолÑаниÑ: GRASS_GUI еÑли ÑÑÑановлен, инаÑе - tcltk"
#: ../general/g.gui/main.c:45
+#, fuzzy
msgid ""
"tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - "
-"Display Manager (d.m);wxpython;wxPython based next generation GUI"
+"Display Manager (d.m);wxpython;wxPython based next generation GUI;text;"
+"command line interface only"
msgstr ""
"tcltk;GUI оÑнованнÑй на Tcl/Tk - ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ GIS (gis.m);oldtcltk;СÑаÑÑй GUI "
"оÑнованнÑй на Tcl/Tk - ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ Ð´Ð¸Ñплеев (d.m);wxpython;GUI нового Ð¿Ð¾ÐºÐ¾Ð»ÐµÐ½Ð¸Ñ "
"оÑнованнÑй на wxPython "
-#: ../general/g.gui/main.c:53
+#: ../general/g.gui/main.c:54
msgid "Name of workspace file"
msgstr "ÐÐ¼Ñ Ñайла пÑоекÑа"
-#: ../general/g.gui/main.c:57
+#: ../general/g.gui/main.c:58
msgid "Update default GUI setting"
msgstr "СÑандаÑÑнÑе ÑÑÑановки гÑаÑиÑеÑкого инÑеÑÑейÑа обновленÑ"
-#: ../general/g.gui/main.c:75
+#: ../general/g.gui/main.c:63
+#, fuzzy
+msgid "Do not launch GUI after updating the default GUI setting"
+msgstr "СÑандаÑÑнÑе ÑÑÑановки гÑаÑиÑеÑкого инÑеÑÑейÑа обновленÑ"
+#: ../general/g.gui/main.c:89
#, c-format
msgid "<%s> is now the default GUI"
msgstr "<%s> ÑепеÑÑ ÑÑандаÑÑнÑй GUI"
+#: ../general/g.gui/main.c:106
+msgid "The old d.m GUI is not available for WinGRASS"
+msgstr ""
#: ../general/g.version/main.c:35
msgid "Displays version and copyright information."
msgstr "ÐоказаÑÑ Ð²ÐµÑÑÐ¸Ñ Ð¸ инÑоÑмаÑÐ¸Ñ Ð¾Ð± авÑоÑÑкиÑ
пÑаваÑ
@@ -30028,6 +28001,10 @@
msgid "Print the GRASS build information"
msgstr "ÐÑвеÑÑи инÑоÑмаÑÐ¸Ñ Ð¾ ÑбоÑке GRASS"
+#: ../general/g.version/main.c:48
+msgid "Print the GIS library revision number and time"
+msgstr ""
#: ../general/g.setproj/main.c:78
msgid "general, projection"
msgstr "обÑее, пÑоекÑиÑ"
@@ -30139,7 +28116,6 @@
msgstr "ÐнÑоÑмаÑÐ¸Ñ Ð¾ зоне UTM не бÑла обновлена"
#: ../general/g.setproj/main.c:455
-#, fuzzy
msgid ""
"But if you change zone, all the existing data will be interpreted by "
"projection software. GRASS will not automatically re-project or even change "
@@ -30163,9 +28139,9 @@
msgstr "ÐведиÑе множеÑÑвеннÑÑ ÑоÑÐ¼Ñ Ð´Ð»Ñ ÐµÐ´Ð¸Ð½Ð¸Ñ [меÑÑÑ]:"
#: ../general/g.setproj/main.c:602
-#, fuzzy, c-format
+#, c-format
msgid "Enter singular for unit: "
-msgstr "ÐведиÑе 'list' Ð´Ð»Ñ Ð²Ñвода ÑпиÑка ÑллипÑоидов\n"
+msgstr "ÐведиÑе единиÑÑ Ð¸Ð·Ð¼ÐµÑÐµÐ½Ð¸Ñ Ð² единÑÑвенном ÑиÑле:"
#: ../general/g.setproj/main.c:610
#, c-format
@@ -30281,7 +28257,6 @@
msgstr "ÐÐ°Ð±Ð¾Ñ Ð½Ðµ ÑÑÑеÑÑвÑеÑ. ÐÑполÑзÑйÑе паÑамеÑÑ -c ÑÑÐ¾Ð±Ñ ÐµÐ³Ð¾ ÑоздаÑÑ."
#: ../general/g.mapset/main.c:158
-#, fuzzy
msgid "Unable to read GIS_LOCK environment variable"
msgstr "Ðевозможно пÑоÑеÑÑÑ Ð¿ÐµÑеменнÑÑ Ð¾ÐºÑÑÐ¶ÐµÐ½Ð¸Ñ GIS_LOCK"
@@ -30361,6 +28336,10 @@
msgstr ""
"ÐÑполÑзоваÑÑ ÑаÑÑиÑеннÑе ÑегÑлÑÑнÑе вÑÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð²Ð¼ÐµÑÑо гÑÑпповÑÑ
Ñимволов"
+#: ../general/g.mremove/main.c:76
+msgid "Force removal (required for actual deletion of files)"
+msgstr "Силовое Ñдаление (необÑ
одимо Ð´Ð»Ñ ÑеалÑного ÑÐ´Ð°Ð»ÐµÐ½Ð¸Ñ Ñайлов)"
#: ../general/g.mremove/main.c:80
msgid "Remove base maps"
msgstr "УдалиÑÑ Ð±Ð°Ð·Ð¾Ð²Ñе Ñлои"
@@ -30371,7 +28350,7 @@
#: ../general/g.mremove/main.c:107
msgid "The following files would be deleted:"
-msgstr ""
+msgstr "СледÑÑÑие ÑÑÑоки бÑдÑÑ ÑдаленÑ:"
#: ../general/g.mremove/main.c:130 ../general/g.mlist/main.c:164
#: ../general/g.mlist/main.c:175
@@ -30381,7 +28360,7 @@
#: ../general/g.mremove/main.c:158
msgid "You must use the force flag to actually remove them. Exiting."
-msgstr ""
+msgstr "ÐÑполÑзÑйÑе Ñлаг force ÑÑÐ¾Ð±Ñ ÑдалиÑÑ Ð¸Ñ
. ÐÑÑ
од."
#: ../general/g.mremove/read_list.c:144 ../general/g.mlist/read_list.c:144
#, c-format
@@ -30399,9 +28378,8 @@
msgstr "Шаблон поиÑка Ñлоев (по ÑмолÑаниÑ: вÑе)"
#: ../general/g.mlist/main.c:104
-#, fuzzy
msgid "Map name exclusion pattern (default: none)"
-msgstr "Шаблон поиÑка Ñлоев (по ÑмолÑаниÑ: вÑе)"
+msgstr "Шаблон иÑклÑÑÐµÐ½Ð¸Ñ Ñлоев (по ÑмолÑаниÑ: неÑ)"
#: ../general/g.mlist/main.c:113
msgid "One-character output separator, newline, comma, space, or tab"
@@ -30420,15 +28398,405 @@
msgid "Pretty printing in human readable format"
msgstr "ÐÑаÑивÑй вÑвод в ÑиÑабелÑном ÑоÑмаÑе"
+#~ msgid "Eigen values:"
+#~ msgstr "Eigen знаÑениÑ:"
+#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
+#~ msgstr "mi(мили),f(ÑÑÑÑ),me(меÑÑÑ),k(киломеÑÑÑ),a(акÑÑ),h(гекÑаÑÑ)"
+#~ msgid "Field value. If set to 0, z coordinates are used. (3D vector only)"
+#~ msgstr ""
+#~ "ÐнаÑение полÑ. ÐÑли ÑÑÑановлено в 0, иÑполÑзÑÑÑÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ z (ÑолÑко 3D "
+#~ "векÑоÑ)"
+#~ msgid "Columns"
+#~ msgstr "СÑолбÑÑ"
+#~ msgid ""
+#~ "Number of column used as x coordinate (first column is 1) for points mode"
+#~ msgstr ""
+#~ "ÐÐ¾Ð¼ÐµÑ ÑÑолбÑа, в коÑоÑой Ñ
ÑаниÑÑÑ ÐºÐ¾Ð¾ÑдинаÑа x (Ð½Ð¾Ð¼ÐµÑ Ð¿ÐµÑвого ÑÑолбÑа - "
+#~ "1), Ð´Ð»Ñ ÑоÑеÑного Ñежима"
+#~ msgid "It was impossible to open table"
+#~ msgstr "Ðевозможно оÑкÑÑÑÑ ÑаблиÑÑ "
+#~ msgid "Spline type of interpolation"
+#~ msgstr "Сплайн инÑеÑполÑÑиÑ"
+#~ msgid "Use db.select for SELECT SQL statements"
+#~ msgstr "ÐÑполÑзоваÑÑ db.select Ð´Ð»Ñ SQL-опеÑаÑоÑа SELECT"
+#~ msgid "Unable to open MASK"
+#~ msgstr "Ðевозможно оÑкÑÑÑÑ MASK"
+#~ msgid "unable to open MASK"
+#~ msgstr "невозможно оÑкÑÑÑÑ MASK"
+#~ msgid "Starting map [%s]"
+#~ msgstr "ÐаÑало ÑÐ»Ð¾Ñ [%s]"
+#~ msgid "Starting filter #%d, distance: %.*lf, exponent: %.*lf, flat: %.*lf"
+#~ msgstr ""
+#~ "ÐаÑалÑнÑй ÑилÑÑÑ #%d, ÑаÑÑÑоÑние: %.*lf, ÑкÑпоненÑа: %.*lf, плоÑкоÑÑÑ: %."
+#~ "*lf"
+#~ msgid "Percent done:"
+#~ msgstr "ÐÑоÑенÑов завеÑÑено:"
+#~ msgid ""
+#~ "%s: saving [%s] raster map layer.\n"
+#~ "Percent complete:"
+#~ msgstr ""
+#~ "%s: ÑоÑ
Ñанение [%s] ÑаÑÑÑового ÑлоÑ.\n"
+#~ "ÐÑогÑеÑÑ (пÑоÑенÑов):"
+#~ msgid ""
+#~ "Computes direct (beam), diffuse and reflected solar irradiation raster "
+#~ "maps for given day, latitude, surface and atmospheric conditions. Solar "
+#~ "parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+#~ "irradiance, daylight length) are saved in a local text file. "
+#~ "Alternatively, a local time can be specified to compute solar incidence "
+#~ "angle and/or irradiance raster maps. The shadowing effect of the "
+#~ "topography is optionally incorporated."
+#~ msgstr ""
+#~ "ÐÑÑиÑление пÑÑмой (лÑÑами), ÑаÑÑеÑной и оÑÑаженной оÑвеÑенноÑÑи (ÑолнÑем) "
+#~ "ÑаÑÑÑовÑÑ
Ñлоев Ð´Ð»Ñ Ð·Ð°Ð´Ð°Ð½Ð½ÑÑ
днÑ, ÑиÑоÑÑ, повеÑÑ
ноÑÑи и ÑоÑÑоÑÐ½Ð¸Ñ "
+#~ "аÑмоÑÑеÑÑ. ÐаÑамеÑÑÑ ÑолнÑа (напÑ.: воÑÑ
од, закаÑ, наклон, оÑвеÑенноÑÑÑ "
+#~ "веÑÑ
ниÑ
Ñлоев аÑмоÑÑеÑÑ, пÑодолжиÑелÑноÑÑÑ ÑвеÑового днÑ) ÑоÑ
ÑанÑÑÑÑÑ Ð² "
+#~ "Ñайле иÑÑоÑии каÑÑÑ. РкаÑеÑÑве алÑÑеÑнаÑивÑ, локалÑное вÑÐµÐ¼Ñ Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ "
+#~ "опÑеделено пÑи вÑÑиÑлении Ñгла Ð¿Ð°Ð´ÐµÐ½Ð¸Ñ ÑолнеÑнÑÑ
лÑÑей и/или оÑвеÑенноÑÑи "
+#~ "ÑаÑÑÑовÑÑ
Ñлоев. ÐÑÑÐµÐºÑ Ð·Ð°ÑÐµÐ½ÐµÐ½Ð¸Ñ ÑопогÑаÑии подклÑÑаеÑÑÑ Ð¾Ð¿ÑионалÑно."
+#~ msgid "incidout requres time parameter to be set"
+#~ msgstr "incidout ÑÑебÑÐµÑ ÑÑÑановленного паÑамеÑÑа вÑемени"
+#~ msgid "Mode 2: integrated daily irradiation"
+#~ msgstr "ÐеÑод 2: обÑÐ°Ñ Ð´Ð½ÐµÐ²Ð½Ð°Ñ Ð¸ÑÑадиаÑиÑ"
+#~ msgid "Script kill option"
+#~ msgstr "ÐпÑÐ¸Ñ kill ÑкÑипÑа"
+#~ msgid "Start in Demo mode"
+#~ msgstr "ÐапÑÑÑиÑÑ Ð² Ðемо Ñежиме"
+#~ msgid "Output more comments (default=quiet)"
+#~ msgstr "ÐÑводиÑÑ Ð±Ð¾Ð»ÑÑе комменÑаÑиев (по ÑмолÑаниÑ=quiet)"
+#~ msgid "Display manager for GRASS"
+#~ msgstr "ÐоказаÑÑ Ð¼ÐµÐ½ÐµÐ´Ð¶ÐµÑ GRASS"
+#~ msgid "Name of .dmrc settings file"
+#~ msgstr "Ðазвание .dmrc Ñайла наÑÑÑоек"
+#~ msgid "GIS manager for GRASS"
+#~ msgstr "GIS Ð¼ÐµÐ½ÐµÐ´Ð¶ÐµÑ Ð´Ð»Ñ GRASS"
+#~ msgid "Name of GIS manager settings file (.grc)"
+#~ msgstr "Ðазвание Ñайла наÑÑÑоек GIS менеджеÑа (.grc)"
+#~ msgid "Configuration editor for r.li.'index'"
+#~ msgstr "РедакÑÐ¾Ñ ÐºÐ¾Ð½ÑигÑÑаÑии Ð´Ð»Ñ r.li.'index'"
+#~ msgid "raster, landscape structure analysis"
+#~ msgstr "ÑаÑÑÑ, ÑÑÑÑкÑÑÑнÑй анализ ландÑаÑÑа"
+#~ msgid "Prints a graph of the correlation between data layers (in pairs)."
+#~ msgstr "ÐÑобÑажаÑÑ Ð³ÑаÑик коÑÑелÑÑии Ð¼ÐµÐ¶Ð´Ñ ÑлоÑми даннÑÑ
(паÑами)."
+#~ msgid "display, diagram"
+#~ msgstr "показ, диагÑамма"
+#~ msgid "raster input map"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой"
+#~ msgid "Selects/starts specified monitor at specified size"
+#~ msgstr "ÐÑбÑаÑÑ/задаÑÑ Ð¼Ð¾Ð½Ð¸ÑÐ¾Ñ Ñ Ð¾Ð¿ÑеделеннÑми ÑазмеÑами"
+#~ msgid "Display monitor to start"
+#~ msgstr "ÐÑобÑажаÑÑ Ð¼Ð¾Ð½Ð¸ÑÐ¾Ñ Ð¿Ñи запÑÑке"
+#~ msgid "Width in pixels of new display monitor"
+#~ msgstr "ШиÑина в пикÑелÑÑ
Ð´Ð»Ñ Ð½Ð¾Ð²Ð¾Ð³Ð¾ мониÑоÑа"
+#~ msgid "Height in pixels of new display monitor"
+#~ msgstr "ÐÑÑоÑа в пикÑелÑÑ
+#~ msgid "Moves displayed maps to another monitor"
+#~ msgstr "ÐеÑемеÑÑиÑÑ Ð¿ÑоÑмаÑÑиваемÑе Ñлои на дÑÑгой мониÑоÑ"
+#~ msgid "clear target monitor before moving"
+#~ msgstr "оÑиÑÑиÑÑ Ñелевой мониÑÐ¾Ñ Ð¿ÐµÑед пеÑемеÑением"
+#~ msgid "stay with source monitor"
+#~ msgstr "оÑÑаваÑÑÑÑ Ð½Ð° иÑÑ
одном мониÑоÑе"
+#~ msgid "kill source monitor after moving"
+#~ msgstr "ÑдалиÑÑ Ð¸ÑÑ
однÑй мониÑÐ¾Ñ Ð¿Ð¾Ñле пеÑемеÑениÑ"
+#~ msgid "Target monitor"
+#~ msgstr "Целевой мониÑоÑ"
+#~ msgid "Source monitor"
+#~ msgstr "ÐÑÑ
однÑй мониÑоÑ"
+#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
+#~ msgstr ""
+#~ "ÐкÑпоÑÑиÑоваÑÑ Ð´Ð¸Ñплей мониÑоÑа в Ñоновое изобÑажение ÑовмеÑÑимое Ñ "
+#~ "GpsDrive"
+#~ msgid "display, export, GPS"
+#~ msgstr "диÑплей, ÑкÑпоÑÑ, GPS"
+#, fuzzy
+#~ msgid "name for new map image (lives in ~/.gpsdrive)"
+#~ msgstr "Ð¸Ð¼Ñ Ð½Ð¾Ð²Ð¾Ð³Ð¾ обÑаза ÑÐ»Ð¾Ñ (наÑ
одиÑÑÑ Ð² ~/.gpsdrive)"
+#~ msgid "Make JPEG instead of PNG image"
+#~ msgstr "СоздаÑÑ JPEG на оÑнове PNG"
+#~ msgid "Saves active display monitor to PNG file in home directory"
+#~ msgstr "СоÑ
ÑаниÑÑ ÑодеÑжимое мониÑоÑа в Ñайл PNG в домаÑней папке"
+#~ msgid "display, export"
+#~ msgstr "диÑплей, ÑкÑпоÑÑ"
+#~ msgid "Name of PNG file"
+#~ msgstr "Ðазвание Ñайла PNG"
+#~ msgid "Resolution of output file (single=1, double=2, quad=4)"
+#~ msgstr ""
+#~ "РазÑеÑение Ð´Ð»Ñ Ð²ÑÑ
одного Ñайла (один к одномÑ=1, двойной=2, "
+#~ "ÑеÑÑÑеÑ
кÑаÑнÑй=4)"
+#~ msgid "Saves the contents of the active display monitor to a graphics file."
+#~ msgstr "СоÑ
Ñанение ÑодеÑÐ¶Ð°Ð½Ð¸Ñ Ð°ÐºÑивного мониÑоÑа в гÑаÑиÑеÑкий Ñайл."
+#~ msgid "Name for output file (do NOT add extension)"
+#~ msgstr "Ðазвание Ð´Ð»Ñ Ñайла вÑвода (ÐÐ ÑказÑваÑÑ ÑаÑÑиÑение)"
+#~ msgid "Dimensions of output file versus current window size"
+#~ msgstr "Ð Ð°Ð·Ð¼ÐµÑ Ð²ÑÑ
одного Ñайла оÑноÑиÑелÑно ÑекÑÑего ÑазмеÑа окна"
+#~ msgid "(same=1, double size=2, quadruple size=4)"
+#~ msgstr "(один к одномÑ=1, двойной ÑазмеÑ=2, ÑеÑÑÑеÑ
кÑаÑнÑй ÑазмеÑ=4)"
+#~ msgid "Images"
+#~ msgstr "ÐзобÑажениÑ"
+#~ msgid "Width and height of output image (overrides resolution setting)"
+#~ msgstr ""
+#~ "ШиÑина и вÑÑоÑа вÑÑ
одного изобÑÐ°Ð¶ÐµÐ½Ð¸Ñ (оÑменÑÑÑ Ð½Ð°ÑÑÑойки ÑазÑеÑениÑ)"
+#~ msgid "Compression for PNG files"
+#~ msgstr "СжаÑие Ð´Ð»Ñ PNG Ñайла"
+#~ msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
+#~ msgstr ""
+#~ "(0=неÑ, 1=бÑÑÑÑо, 9=наиболÑÑее; без поÑеÑÑ, ÑолÑко вÑÐµÐ¼Ñ vs. ÑÐ°Ð·Ð¼ÐµÑ Ñайла)"
+#~ msgid "File size/quality for JPEG files"
+#~ msgstr "РазмеÑ/каÑеÑÑво Ñайла JPEG"
+#~ msgid "(10=smallest/worst, 100=largest/best)"
+#~ msgstr "(10=незнаÑиÑелÑно/плоÑ
о, 100=знаÑиÑелÑно/Ñ
оÑоÑо)"
+#~ msgid "Paper size for PostScript output"
+#~ msgstr "Размег бÑмаги Ð´Ð»Ñ Ð²Ñвода PostScript"
+#~ msgid "PostScript"
+#~ msgstr "PostScript"
+#~ msgid "PostScript level (only limits functionality!)"
+#~ msgstr "УÑÐ¾Ð²ÐµÐ½Ñ PostScript (огÑаниÑÐµÐ½Ð½Ð°Ñ ÑÑнкÑионалÑноÑÑÑ!)"
+#~ msgid "Set background color to black (white default)"
+#~ msgstr "СделаÑÑ Ñон ÑеÑнÑм (по ÑмолÑÐ°Ð½Ð¸Ñ - белÑй)"
+#~ msgid "Set transparent background"
+#~ msgstr "СделаÑÑ Ñон пÑозÑаÑнÑм"
+#~ msgid "Use the Cario driver to render images"
+#~ msgstr "ÐÑполÑзоваÑÑ Ð´ÑÐ°Ð¹Ð²ÐµÑ Cario Ð´Ð»Ñ ÑендеÑинга изобÑажений"
+#~ msgid "Set paper orientation to landscape (for PostScript output)"
+#~ msgstr "ÐлÑÐ±Ð¾Ð¼Ð½Ð°Ñ Ð¾ÑиенÑаÑÐ¸Ñ Ð±Ñмаги (Ð´Ð»Ñ Ð²Ñвода PostScript)"
+#~ msgid "Draws polar diagram of angle map such as aspect or flow directions"
+#~ msgstr ""
+#~ "СоздаÑÑ Ð¿Ð¾Ð»ÑÑнÑÑ Ð´Ð¸Ð°Ð³ÑÐ°Ð¼Ð¼Ñ ÑÐ»Ð¾Ñ Ñглов, Ñакого как ÑÐºÐ»Ð¾Ð½Ñ Ð¸Ð»Ð¸ напÑÐ°Ð²Ð»ÐµÐ½Ð¸Ñ "
+#~ "поÑока"
+#~ msgid "Name of raster angle map"
+#~ msgstr "Ðазвание ÑаÑÑÑового ÑÐ»Ð¾Ñ Ñглов"
+#~ msgid "Pixel value to be interpreted as undefined (different from NULL)"
+#~ msgstr ""
+#~ "ÐнаÑение пикÑÐµÐ»Ñ Ð±Ñло инÑеÑпÑеÑиÑовано как неопÑеделенное (оÑлиÑное Ð¾Ñ "
+#~ "NULL)"
+#~ msgid "Name of optional EPS output file"
+#~ msgstr "Ðазвание дополниÑелÑного EPS Ñайла вÑвода"
+#~ msgid "Plot using Xgraph"
+#~ msgstr "ÐеÑаÑÑ Ñ Ð¸ÑполÑзованием Xgraph"
+#~ msgid "Name of aspect raster map"
+#~ msgstr "Ðазвание Ð²Ð´Ð¾Ð»Ñ ÑÑоÑÐ¾Ð½Ñ ÑаÑÑÑового ÑлоÑ"
+#~ msgid "Width of display canvas"
+#~ msgstr "ШиÑина полей диÑплеÑ"
+#~ msgid "Height of display canvas"
+#~ msgstr "ÐÑÑоÑа полей диÑплеÑ"
+#~ msgid "Minimum size of each cell"
+#~ msgstr "ÐинималÑнÑй ÑÐ°Ð·Ð¼ÐµÑ ÐºÐ°Ð¶Ð´Ð¾Ð¹ ÑÑейки"
+#~ msgid "Maximum number of rows to load"
+#~ msgstr "ÐакÑималÑное колиÑеÑÑво загÑÑжаемÑÑ
ÑÑÑок"
+#~ msgid "Maximum number of columns to load"
ÑÑолбÑов "
+#~ msgid "Displays a raster map and its legend on a graphics window"
+#~ msgstr "ÐоказаÑÑ ÑаÑÑÑовÑй Ñлой и его Ð»ÐµÐ³ÐµÐ½Ð´Ñ Ð² окне гÑаÑики"
+#~ msgid "Omit entries with missing label"
+#~ msgstr "ÐÑопÑÑÑиÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ñ Ð¾ÑÑÑÑÑÑвÑÑÑей подпиÑÑÑ"
+#~ msgid "Number of lines to appear in the legend"
+#~ msgstr "ЧиÑло линий в легенде"
+#~ msgid "Name of raster map to generate legend from"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¸ÑполÑзÑемого Ð´Ð»Ñ ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
+#~ msgid "Redraws the current display frame in the GRASS monitor"
+#~ msgstr "ÐеÑеÑиÑоваÑÑ ÑекÑÑей ÑÑейм диÑÐ¿Ð»ÐµÑ Ð² GRASS мониÑоÑе"
+#~ msgid "Redraw all frames"
+#~ msgstr "ÐеÑеÑиÑоваÑÑ Ð²Ñе ÑÑеймÑ"
+#~ msgid "Do not preserve individual regions when redrawing all frames"
+#~ msgstr "Ðе ÑоÑ
ÑанÑÑÑ Ð¸Ð½Ð´Ð¸Ð²Ð¸Ð´ÑалÑнÑе ÑегионÑ, пÑи пеÑеÑиÑовке вÑеÑ
ÑÑеймов"
+#~ msgid "Resizes active display monitor"
+#~ msgstr "ÐзмениÑÑ ÑÐ°Ð·Ð¼ÐµÑ Ð°ÐºÑивного мониÑоÑа"
+#~ msgid "New width for window"
+#~ msgstr "ÐÐ¾Ð²Ð°Ñ ÑиÑина Ð´Ð»Ñ Ð¾ÐºÐ½Ð°"
+#~ msgid "New height for window"
+#~ msgstr "ÐÐ¾Ð²Ð°Ñ Ð²ÑÑоÑа Ð´Ð»Ñ Ð¾ÐºÐ½Ð°"
+#~ msgid "Drapes a color raster over a shaded relief map using d.his"
+#~ msgstr ""
+#~ "ÐÑапиÑоваÑÑ ÑвеÑной ÑаÑÑÑ Ð¿Ð¾Ð²ÐµÑÑ
ÑÐ»Ð¾Ñ Ñеневой оÑмÑвки ÑелÑеÑа иÑполÑзÑÑ d."
+#~ "his"
+#~ msgid "Name of shaded relief or aspect map"
+#~ msgstr "ÐÐ¼Ñ ÑÐ»Ð¾Ñ Ñеневого ÑелÑеÑа или ÑкÑпозиÑий "
+#~ msgid "Name of raster to drape over relief map"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑа дÑапиÑÑемого по ÑелÑеÑÑ "
+#~ msgid "Percent to brighten"
+#~ msgstr "ÐÑоÑÐµÐ½Ñ ÑвелиÑÐµÐ½Ð¸Ñ ÑÑкоÑÑи"
+#~ msgid "Slide show of GRASS raster/vector maps."
+#~ msgstr "СлайдÑÐ¾Ñ ÑаÑÑÑовÑÑ
/векÑоÑнÑÑ
Ñлоев GRASS"
+#~ msgid "display, slideshow"
+#~ msgstr "показаÑÑ, ÑлайдÑоÑ"
+#~ msgid "Show vector maps rather than raster maps"
+#~ msgstr "ÐоказаÑÑ Ð²ÐµÐºÑоÑнÑе Ñлои вмеÑÑо ÑаÑÑÑовÑÑ
+#~ msgid "Map prefix. Specify character(s) to view selected maps only"
+#~ msgstr "ÐÑеÑÐ¸ÐºÑ ÑлоÑ. УкажиÑе Ñимвол(Ñ) Ð´Ð»Ñ Ð¿ÑоÑмоÑÑа вÑбÑаннÑÑ
Ñлоев"
+#, fuzzy
+#~ msgid "Map number show across the monitor"
+#~ msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ Ð¿Ð¾ÐºÐ°Ð·ÑваемÑй попеÑек мониÑоÑа"
+#, fuzzy
+#~ msgid "Map number show down the monitor"
+#~ msgstr "ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ Ð¿Ð¾ÐºÐ°Ð·ÑваемÑй ÑвеÑÑ
Ñ Ð²Ð½Ð¸Ð· мониÑоÑа"
+#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
+#~ msgstr "ÐÑполÑзÑемÑе набоÑÑ. УкажиÑе неÑколÑко набоÑов ÑеÑез запÑÑÑÑ "
+#~ msgid "Number of seconds to pause between slides"
+#~ msgstr "ÐÑÐµÐ¼Ñ Ð² ÑекÑндаÑ
Ð´Ð»Ñ Ð¿Ð°ÑÐ·Ñ Ð¼ÐµÐ¶Ð´Ñ Ñлайдами"
+#~ msgid ""
+#~ "Divides active display into two frames & displays maps/executes commands "
+#~ "in each frame."
+#~ msgstr ""
+#~ "РазделиÑÑ Ð°ÐºÑивнÑй диÑплей на два ÑÑейма и показаÑÑ Ñлои/вÑполниÑÑ "
+#~ "ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ Ð² каждом ÑÑейме "
+#~ msgid "Enter raster map to display in 1st frame"
+#~ msgstr "ÐведиÑе ÑаÑÑÑовÑй Ñлой Ð´Ð»Ñ Ð¿Ð¾ÐºÐ°Ð·Ð° в пеÑвом ÑÑейме"
+#~ msgid "Enter command to execute in 1st frame"
+#~ msgstr "ÐведиÑе ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ Ð´Ð»Ñ Ð¸ÑÐ¿Ð¾Ð»Ð½ÐµÐ½Ð¸Ñ Ð² 1-м ÑÑейме"
+#~ msgid "Enter raster map to display in 2nd frame"
+#~ msgstr "ÐведиÑе ÑаÑÑÑовÑй Ñлой Ð´Ð»Ñ Ð¿Ð¾ÐºÐ°Ð·Ð° в вÑоÑом ÑÑейме"
+#~ msgid "Enter command to execute in 2nd frame"
+#~ msgstr "ÐведиÑе ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ Ð´Ð»Ñ Ð¸ÑÐ¿Ð¾Ð»Ð½ÐµÐ½Ð¸Ñ Ð²Ð¾ 2-м ÑÑейме"
+#~ msgid "How to split display"
+#~ msgstr "Ðак ÑазделиÑÑ Ð´Ð¸Ñплей "
+#, fuzzy
+#~ msgid "Displays thematic vector map"
+#~ msgstr "ÐÑобÑазиÑÑ ÑемаÑиÑеÑкий векÑоÑнÑй Ñлой"
+#, fuzzy
+#~ msgid "display, legend"
+#~ msgstr "ÐеÑевеÑнÑÑÑ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
+#~ msgid "Files"
+#~ msgstr "ФайлÑ"
#~ msgid "Vector map to display thematically"
#~ msgstr "ÐекÑоÑнÑй Ñлой Ð´Ð»Ñ ÑемаÑиÑеÑкой каÑÑÑ"
+#, fuzzy
+#~ msgid "Theme_prefs"
+#~ msgstr "Theme_prefs"
#~ msgid "Vector map type"
#~ msgstr "Тип векÑоÑного ÑлоÑ"
+#, fuzzy
+#~ msgid "Attribute column to use for thematic display (must be numeric)"
+#~ msgstr ""
+#~ "Ðоле, иÑполÑзÑемое Ð´Ð»Ñ ÑемаÑиÑеÑкого оÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ (должно бÑÑÑ ÑиÑловÑм)"
+#~ msgid "Type of thematic display"
+#~ msgstr "Тип ÑемаÑиÑеÑкой каÑÑÑ"
+#~ msgid "Thematic divisions of data for display"
+#~ msgstr "ТемаÑиÑеÑкое Ñазделение даннÑÑ
Ð´Ð»Ñ Ð¾ÑобÑажениÑ"
+#, fuzzy
+#~ msgid ""
+#~ "Break points for custom breaks option. Separate values by spaces. (0 10 "
+#~ "20 30 ...)"
+#~ msgstr ""
+#~ "ТоÑки ÑазÑÑва Ð´Ð»Ñ Ð¾Ð¿Ñии вÑбоÑа ÑазÑÑвов. РазделиÑе знаÑÐµÐ½Ð¸Ñ Ð¿Ñобелами ( 0 "
+#~ "10 20 30 ...)"
#~ msgid "Layer to use for thematic display"
#~ msgstr "Слои Ð´Ð»Ñ ÑемаÑиÑеÑкого оÑобÑажениÑ"
+#~ msgid "Vector point icon for point data"
+#~ msgstr "ÐекÑоÑнÑй ÑоÑеÑнÑй знаÑок Ð´Ð»Ñ ÑоÑеÑнÑÑ
даннÑÑ
#~ msgid ""
#~ "Icon size for point data (minimum icon size/line width for graduated "
#~ "points/lines)"
@@ -30436,13 +28804,166 @@
#~ "Ð Ð°Ð·Ð¼ÐµÑ Ð·Ð½Ð°Ñка Ð´Ð»Ñ ÑоÑеÑнÑÑ
даннÑÑ
(минималÑнÑй ÑÐ°Ð·Ð¼ÐµÑ Ð¸ÐºÐ¾Ð½ÐºÐ¸/ÑиÑина линии "
#~ "Ð´Ð»Ñ Ð³ÑадÑиÑованнÑÑ
ÑоÑек/линий)"
+#~ msgid "Maximum icon size/line width for graduated points and lines"
+#~ msgstr ""
+#~ "ÐакÑималÑнÑй ÑÐ°Ð·Ð¼ÐµÑ Ð¸ÐºÐ¾Ð½ÐºÐ¸/ÑиÑина линии Ð´Ð»Ñ ÐºÐ°Ð»Ð¸Ð±ÑованнÑÑ
ÑоÑек и линий"
+#~ msgid "Number of classes for interval theme (integer)"
+#~ msgstr "ЧиÑло клаÑÑов Ð´Ð»Ñ Ð¸Ð½ÑеÑвалÑного ÑÐ»Ð¾Ñ (Ñелое)"
+#, fuzzy
#~ msgid ""
+#~ "Color scheme for graduated color mapping (select 'single_color' for "
+#~ "graduated point/line display)"
+#~ msgstr ""
+#~ "ЦвеÑÐ¾Ð²Ð°Ñ ÑÑ
ема Ð´Ð»Ñ Ð³ÑадÑиÑованного ÑвеÑового оÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ (вÑбеÑиÑе "
+#~ "''single_color' Ð´Ð»Ñ Ð¾ÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð³ÑадÑиÑованнÑÑ
ÑоÑек/линий)"
+#, fuzzy
+#~ msgid ""
+#~ "Color for graduated points map (grass named color or R:G:B triplet). Set "
+#~ "color scheme to single color."
+#~ msgstr ""
+#~ "Ð¦Ð²ÐµÑ Ð´Ð»Ñ Ð³ÑадÑиÑованного ÑÐ»Ð¾Ñ Ð»Ð¸Ð½Ð¸Ð¹ или конÑÑÑов ÑоÑек/плоÑаднÑÑ
обÑекÑов "
+#~ "(ÑвеÑа grass или ÑÑÐ¸Ð¿Ð»ÐµÑ R:G:B). ÐÑбеÑиÑе ÑвеÑовÑÑ ÑÑ
ÐµÐ¼Ñ Ð´Ð»Ñ Ð¾Ð´Ð½Ð¾Ð³Ð¾ ÑвеÑа."
+#~ msgid ""
#~ "Color for graduated lines or point/area outlines (grass named color or R:"
#~ "G:B triplet). Set color scheme to single color."
#~ msgstr ""
обÑекÑов "
+#, fuzzy
+#~ msgid ""
+#~ "Beginning color for custom color gradient. Must be expressed as R:G:B "
+#~ "triplet."
+#~ msgstr ""
+#~ "ÐаÑалÑнÑй ÑÐ²ÐµÑ Ð´Ð»Ñ Ð¿Ð¾Ð»ÑзоваÑелÑÑкого ÑвеÑового гÑадиенÑа. Ðолжен бÑÑÑ "
+#~ "задан как ÑÑÐ¸Ð¿Ð»ÐµÑ R:G:B."
+#, fuzzy
+#~ msgid ""
+#~ "Ending color for custom color gradient. Must be expressed as R:G:B triplet"
+#~ msgstr ""
+#~ "ÐонеÑнÑй ÑÐ²ÐµÑ Ð´Ð»Ñ Ð¿Ð¾Ð»ÑзоваÑелÑÑкого ÑвеÑового гÑадиенÑа. Ðолжен бÑÑÑ "
+#~ "задан как ÑÑÐ¸Ð¿Ð»ÐµÑ R:G:B"
+#~ msgid "Misc"
+#~ msgstr "Разное"
+#~ msgid "Select x11 display monitor for legend"
+#~ msgstr "ÐÑбеÑиÑе Ñ
11 мониÑÐ¾Ñ Ð´Ð»Ñ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
+#~ msgid "Save thematic map commands to group file for GIS Manager"
+#~ msgstr ""
+#~ "СоÑ
ÑаниÑÑ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ ÑемаÑиÑеÑкиÑ
Ñлоев в гÑÑпповой Ñайл Ð´Ð»Ñ Ð¼ÐµÐ½ÐµÐ´Ð¶ÐµÑа ÐÐС"
+#~ msgid "WHERE conditions of SQL statement without 'where' keyword"
+#~ msgstr "WHERE ÑÑÐ»Ð¾Ð²Ð¸Ñ SQL ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ Ð½Ðµ имеÑÑ ÐºÐ»ÑÑевого Ñлова 'where'"
+#, fuzzy
+#~ msgid ""
+#~ "Root for the name of psmap instruction files to be in current directory "
+#~ "(if not set, no psmap instruction files will be created)"
+#~ msgstr ""
+#~ "ÐоÑÐµÐ½Ñ Ð¸Ð¼ÐµÐ½Ð¸ Ñайлов инÑÑÑÑкÑии psmap в ÑекÑÑей папке (еÑли не "
+#~ "ÑÑÑановлено, ÑÐ°Ð¹Ð»Ñ Ð¸Ð½ÑÑÑÑкÑии psmap не бÑдÑÑ ÑозданÑ) "
+#~ msgid "Name of group file where thematic map commands will be saved"
+#~ msgstr ""
+#~ "ÐÐ¼Ñ Ð³ÑÑÐ¿Ð¿Ñ Ñайлов, кÑда бÑдÑÑ Ð·Ð°Ð¿Ð¸ÑÐ°Ð½Ñ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ Ð´Ð»Ñ ÑемаÑиÑеÑкиÑ
Ñлоев"
+#~ msgid "Create graphic legend in x11 display monitor"
+#~ msgstr "СоздаÑÑ Ð³ÑаÑиÑеÑкÑÑ Ð»ÐµÐ³ÐµÐ½Ð´Ñ Ð² x11 мониÑоÑе"
+#~ msgid "Only draw fills (no outlines) for areas and points"
+#~ msgstr "ÐÑÑиÑоваÑÑ ÑолÑко заливки без гÑÐ°Ð½Ð¸Ñ Ð´Ð»Ñ Ð¿Ð»Ð¾ÑаднÑÑ
ÑÑаÑÑков и ÑоÑек"
+#~ msgid "Update color values to GRASSRGB column in attribute table"
+#~ msgstr "ÐбновиÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÑвеÑов в ÑÑолбÑе GRASSRGB аÑÑибÑÑивной ÑаблиÑÑ"
+#~ msgid "Output legend for GIS Manager (for scripting use only)"
+#~ msgstr "РезÑлÑÑиÑÑÑÑÐ°Ñ Ð»ÐµÐ³ÐµÐ½Ð´Ð° Ð´Ð»Ñ Ð¼ÐµÐ½ÐµÐ´Ð¶ÐµÑа ÐÐС (ÑолÑко Ð´Ð»Ñ ÑкÑипÑов)"
+#~ msgid "Use math notation brackets in legend"
+#~ msgstr "ÐÑполÑзоваÑÑ Ð¼Ð°ÑемаÑиÑеÑкое обознаÑение Ñкобок в легенде "
+#~ msgid "Drops a column from selected attribute table"
+#~ msgstr "УдалиÑÑ ÑÑÐ¾Ð»Ð±ÐµÑ Ð¸Ð· вÑбÑанной ÑаблиÑÑ Ð°ÑÑибÑÑов"
+#~ msgid "Table from which to drop attribute column"
+#~ msgstr "ТаблиÑа из коÑоÑой ÑдалиÑÑ ÑÑолбеÑ"
+#~ msgid "Name of the column"
+#~ msgstr "ÐÐ¼Ñ ÑÑолбÑа"
+#~ msgid "Drops an attribute table."
+#~ msgstr "УдалиÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ"
+#~ msgid "Table to drop"
+#~ msgstr "УдалÑÐµÐ¼Ð°Ñ ÑаблиÑа"
+#~ msgid "Imports attribute tables in various formats."
+#~ msgstr "ÐмпоÑÑ Ð°ÑÑибÑÑивнÑÑ
ÑÐ°Ð±Ð»Ð¸Ñ Ð² ÑазлиÑнÑÑ
ÑоÑмаÑаÑ
+#~ msgid "Table file to be imported or DB connection string"
+#~ msgstr "Файл ÑаблиÑÑ Ð´Ð»Ñ Ð¸Ð¼Ð¿Ð¾ÑÑа или ÑÑÑока ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ñ ÐÐ"
+#~ msgid "Table name of SQL DB table"
+#~ msgstr "Ðазвание ÑаблиÑÑ SQL DB"
+#~ msgid "Name for output table"
+#~ msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного Ñайла"
+#~ msgid "Name for auto-generated unique key column"
+#~ msgstr "ÐÐ¼Ñ Ð°Ð²ÑомаÑиÑеÑки Ñоздаваемого ÑÑолбÑа ÑникалÑного клÑÑа"
+#~ msgid "Exports attribute tables into various formats."
ÑоÑмаÑаÑ
+#~ msgid "GRASS table name"
+#~ msgstr "ÐÐ¼Ñ ÑаблиÑÑ GRASS"
+#~ msgid "Table file to be exported or DB connection string"
+#~ msgstr "Файл ÑаблиÑÑ Ð´Ð»Ñ ÑкÑпоÑÑа или ÑÑÑока ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ñ ÐÐ"
+#~ msgid "Table format"
+#~ msgstr "ФоÑÐ¼Ð°Ñ ÑаблиÑÑ"
+#~ msgid "Test database driver, database must exist and set by db.connect."
+#~ msgstr ""
+#~ "ÐÑовеÑиÑÑ Ð´ÑÐ°Ð¹Ð²ÐµÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
, база даннÑÑ
должна ÑÑÑеÑÑвоваÑÑ Ð¸ "
+#~ "ÑÑÑановлена db.connect."
+#~ msgid "Test name"
+#~ msgstr "ÐÐ¼Ñ ÑеÑÑа"
+#~ msgid "Display the HTML man pages of GRASS"
+#~ msgstr "ÐоказаÑÑ HTML ÑÑÑаниÑÑ ÑÑководÑÑва GRASS"
+#~ msgid "general, manual, help"
+#~ msgstr "обÑее, ÑÑководÑÑво, помоÑÑ"
+#~ msgid "Display index"
+#~ msgstr "ÐоказаÑÑ Ð¸Ð½Ð´ÐµÐºÑ"
+#~ msgid "Display as MAN text page instead of HTML page in browser"
+#~ msgstr "ÐоказаÑÑ ÑÑÑаниÑÑ ÐºÐ°Ðº ÑекÑÑ, вмеÑÑо HTML в бÑаÑзеÑе"
+#~ msgid "Manual entry to be displayed"
+#~ msgstr "Ð ÑÑной ввод Ð´Ð»Ñ Ð¿Ð¾ÐºÐ°Ð·Ð°"
+#~ msgid ""
+#~ "Brovey transform to merge multispectral and high-res panchromatic channels"
+#~ msgstr ""
+#~ "ТÑанÑÑоÑмаÑÐ¸Ñ Ð±ÑÑви Ð´Ð»Ñ ÑлиÑÐ½Ð¸Ñ Ð¼ÑлÑÑиÑпекÑÑалÑнÑÑ
каналов и "
+#~ "панÑ
ÑомаÑиÑеÑкиÑ
каналов вÑÑокого ÑазÑеÑениÑ"
+#, fuzzy
+#~ msgid "raster, imagery, fusion"
+#~ msgstr "ÑаÑÑÑ, изобÑажениÑ, импоÑÑ"
#~ msgid "sensor: LANDSAT"
#~ msgstr "ÑенÑоÑ: LANDSAT"
@@ -30452,9 +28973,1048 @@
#~ msgid "sensor: SPOT"
#~ msgstr "ÑенÑоÑ: SPOT"
+#, fuzzy
+#~ msgid "raster input map (green: tm2 | qbird_green | spot1)"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (green: tm2 | qbird_green | spot1)"
+#, fuzzy
+#~ msgid "raster input map (NIR: tm4 | qbird_nir | spot2)"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (NIR: tm4 | qbird_nir | spot2)"
+#, fuzzy
+#~ msgid "raster input map (MIR; tm5 | qbird_red | spot3)"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (MIR; tm5 | qbird_red | spot3)"
+#, fuzzy
+#~ msgid "raster input map (etmpan | qbird_pan | spotpan)"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (etmpan | qbird_pan | spotpan)"
+#, fuzzy
+#~ msgid "raster output map prefix (e.g. 'brov')"
+#~ msgstr "пÑеÑÐ¸ÐºÑ Ð²ÑÑ
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (напÑÐ¸Ð¼ÐµÑ 'brov')"
+#~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
+#~ msgstr ""
+#~ "ÐозаиÑиÑоваÑÑ Ð´Ð¾ 4 изобÑажений и ÑаÑÑиÑиÑÑ ÑвеÑовÑÑ ÑаблиÑÑ; ÑоздаÑÑ Ñлой "
+#~ "*.mosaic"
+#~ msgid "raster, imagery, mosaicking"
+#~ msgstr "ÑаÑÑÑ, изобÑажениÑ, мозаиÑиÑование"
+#~ msgid "1st map for mosaic (top of image stack)."
+#~ msgstr "пеÑвÑй Ñлой Ð´Ð»Ñ Ð¼Ð¾Ð·Ð°Ð¸ÐºÐ¸ (веÑÑ
ÑÑÑка изобÑажений)."
+#~ msgid "2nd map for mosaic."
+#~ msgstr "ÐÑоÑой Ñлой Ð´Ð»Ñ Ð¼Ð¾Ð·Ð°Ð¸ÐºÐ¸"
+#~ msgid "3rd map for mosaic."
+#~ msgstr "ТÑеÑий Ñлой Ð´Ð»Ñ Ð¼Ð¾Ð·Ð°Ð¸ÐºÐ¸"
+#~ msgid "4th map for mosaic."
+#~ msgstr "ЧеÑвеÑÑÑй Ñлой Ð´Ð»Ñ Ð¼Ð¾Ð·Ð°Ð¸ÐºÐ¸"
+#~ msgid "Import of SPOT VGT NDVI file into a raster map"
+#~ msgstr "ÐмпоÑÑ Ñайла SPOT VGT NDVI в ÑаÑÑÑовÑй Ñлой"
+#~ msgid "raster, imagery, import"
+#~ msgid "also import quality map (SM status map layer) and filter NDVI map"
+#~ msgstr ""
+#~ "Ñакже импоÑÑиÑоваÑÑ Ñлой каÑеÑÑва (Ñлой ÑÑаÑÑÑа SM) и Ñлой "
+#~ "оÑÑилÑÑÑованного NDVI"
+#~ msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
+#~ msgstr "ÑÑÑеÑÑвÑÑÑий Ñайл SPOT VGT NDVI HDF (0001_NDV.HDF)"
+#, fuzzy
+#~ msgid "Auto-balancing of colors for LANDSAT images"
+#~ msgstr "ÐвÑомаÑиÑеÑÐºÐ°Ñ Ð±Ð°Ð»Ð°Ð½ÑиÑовка ÑвеÑов Ð´Ð»Ñ Ð¸Ð·Ð¾Ð±ÑÐ°Ð¶ÐµÐ½Ð¸Ñ LANDSAT"
+#~ msgid "raster, imagery, colors"
+#~ msgstr "ÑаÑÑÑ, изобÑажениÑ, ÑвеÑа"
+#~ msgid "LANDSAT red channel"
+#~ msgstr "кÑаÑнÑй канал LANDSAT"
+#~ msgid "LANDSAT green channel"
+#~ msgstr "зеленÑй канал LANDSAT"
+#~ msgid "LANDSAT blue channel"
+#~ msgstr "Ñиний канал LANDSAT"
+#~ msgid "Cropping intensity (upper brightness level)"
+#~ msgstr "ÐбÑезка инÑенÑивноÑÑи (веÑÑ
ний ÑÑÐ¾Ð²ÐµÐ½Ñ ÑÑкоÑÑи)"
+#~ msgid "Extend colors to full range of data on each channel"
+#~ msgstr "РаÑÑиÑиÑÑ ÑвеÑа до полного диапазона даннÑÑ
по ÐºÐ°Ð¶Ð´Ð¾Ð¼Ñ ÐºÐ°Ð½Ð°Ð»Ñ"
+#~ msgid "Preserve relative colors, adjust brightness only"
+#~ msgstr "СоÑ
ÑаниÑÑ Ð¾ÑноÑиÑелÑнÑе ÑвеÑа, подÑÑÑоиÑÑ ÑолÑко ÑÑкоÑÑÑ"
+#~ msgid "Reset to standard color range"
+#~ msgstr "СбÑоÑиÑÑ Ð² ÑÑандаÑÑнÑй ÑвеÑовой диапазон"
+#~ msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
+#~ msgstr ""
+#~ "РаÑÑÑиÑаÑÑ ÑаблиÑÑ Optimum-Index-Factor Ð´Ð»Ñ ÐºÐ°Ð½Ð°Ð»Ð¾Ð² LANDSAT TM 1-5 и 7"
+#~ msgid "raster, imagery, statistics"
+#~ msgstr "ÑаÑÑÑ, изобÑажениÑ, ÑÑаÑиÑÑика"
+#~ msgid "LANDSAT TM band 1."
+#~ msgstr "LANDSAT TM канал 1."
+#~ msgid "LANDSAT TM band 2."
+#~ msgstr "LANDSAT TM канал 2."
+#~ msgid "LANDSAT TM band 3."
+#~ msgstr "LANDSAT TM канал 3."
+#~ msgid "LANDSAT TM band 4."
+#~ msgstr "LANDSAT TM канал 4."
+#~ msgid "LANDSAT TM band 5."
+#~ msgstr "LANDSAT TM канал 5."
+#~ msgid "LANDSAT TM band 7."
+#~ msgstr "LANDSAT TM канал 7."
+#, fuzzy
+#~ msgid ""
+#~ "displays spectral response at user specified locations in group or images"
+#~ msgstr ""
+#~ "ÐоказаÑÑ ÑпекÑÑалÑное оÑÑажение Ð´Ð»Ñ Ð³ÑÑпп или изобÑажений, опÑеделеннÑÑ
+#~ "полÑзоваÑелем"
+#~ msgid "imagery, raster, multispectral"
+#~ msgstr "изобÑажениÑ, ÑаÑÑÑ, мÑлÑÑиÑпекÑÑалÑнÑе"
+#, fuzzy
+#~ msgid "group input"
+#~ msgstr "иÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð³ÑÑппа"
+#, fuzzy
+#~ msgid "raster input maps"
+#~ msgstr "иÑÑ
+#, fuzzy
+#~ msgid "write output to PNG image"
+#~ msgstr "запиÑаÑÑ ÑезÑлÑÑÐ°Ñ Ð² изобÑажение PNG"
+#~ msgid "Use image list and not group"
+#~ msgstr "ÐÑполÑзоваÑÑ ÑпиÑок изобÑажений, но не гÑÑппÑ"
+#~ msgid "Select multiple points"
+#~ msgstr "ÐÑÐ±Ð¾Ñ Ð½ÐµÑколÑкиÑ
ÑоÑек"
+#, fuzzy
+#~ msgid "label with coordinates instead of numbering"
+#~ msgstr "подпиÑаÑÑ ÐºÐ¾Ð¾ÑдинаÑами вмеÑÑо ÑиÑел"
+#~ msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
+#~ msgstr "ТÑанÑÑоÑмаÑÐ¸Ñ Tasseled Cap (Kauth Thomas) Ð´Ð»Ñ Ð´Ð°Ð½Ð½ÑÑ
LANDSAT-TM"
+#~ msgid "raster, imagery"
+#~ msgstr "ÑаÑÑÑ, изобÑажениÑ"
+#~ msgid "use transformation rules for LANDSAT-4"
+#~ msgstr "иÑполÑзоваÑÑ Ð¿Ñавила ÑÑанÑÑоÑмаÑии Ð´Ð»Ñ LANDSAT-4"
+#~ msgid "use transformation rules for LANDSAT-5"
+#~ msgstr "иÑполÑзоваÑÑ Ð¿Ñавила ÑÑанÑÑоÑмаÑии Ð´Ð»Ñ LANDSAT-5"
+#~ msgid "use transformation rules for LANDSAT-7"
+#~ msgstr "иÑполÑзоваÑÑ Ð¿Ñавила ÑÑанÑÑоÑмаÑии Ð´Ð»Ñ LANDSAT-7"
+#~ msgid "raster input map (LANDSAT channel 1)"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (1 канал LANDSAT)"
+#~ msgid "raster input map (LANDSAT channel 2)"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (2 канал LANDSAT)"
+#~ msgid "raster input map (LANDSAT channel 3)"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (3 канал LANDSAT)"
+#~ msgid "raster input map (LANDSAT channel 4)"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (4 канал LANDSAT)"
+#~ msgid "raster input map (LANDSAT channel 5)"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (5 канал LANDSAT)"
+#~ msgid "raster input map (LANDSAT channel 7)"
+#~ msgstr "иÑÑ
однÑй ÑаÑÑÑовÑй Ñлой (7 канал LANDSAT)"
+#~ msgid "raster output TC maps prefix"
однÑÑ
ÑаÑÑÑовÑÑ
Ñлоев TC"
+#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+#~ msgstr ""
+#~ "ÐонвеÑÑиÑоваÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ Ð¸Ð· одной пÑоекÑии в дÑÑгÑÑ (иÑполÑзÑÐµÑ cs2cs)."
+#~ msgid "miscellaneous, projection"
+#~ msgstr "Ñазное, пÑоекÑиÑ"
+#~ msgid "Input coordinate file (omit to read from stdin)"
+#~ msgstr "ÐÑÑ
однÑй Ñайл кооÑÐ´Ð¸Ð½Ð°Ñ (не ÑказÑвайÑе Ð´Ð»Ñ ÑÑÐµÐ½Ð¸Ñ Ð¸Ð· stdin)"
+#~ msgid "Output coordinate file (omit to send to stdout)"
+#~ msgstr "ÐÑÑ
одной Ñайл кооÑÐ´Ð¸Ð½Ð°Ñ (пÑопÑÑÑиÑÑ Ð²Ñвод в stdout)"
+#~ msgid "Field separator"
+#~ msgstr "РазделиÑÐµÐ»Ñ Ð¿Ð¾Ð»ÐµÐ¹"
+#~ msgid "Input projection parameters (PROJ.4 style)"
+#~ msgstr "ÐÑÑ
однÑе паÑамеÑÑÑ Ð¿ÑоекÑии (ÑÑÐ¸Ð»Ñ PROJ.4)"
+#~ msgid "Output projection parameters (PROJ.4 style)"
+#~ msgstr "ÐÑÑ
+#~ msgid "Use LL WGS84 as input and current location as output projection"
+#~ msgstr ""
+#~ "ÐÑполÑзоваÑÑ LL WGS84 как иÑÑ
однÑÑ Ð¸ ÑекÑÑÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ ÐºÐ°Ðº вÑÑ
однÑÑ Ð¿ÑоекÑии"
+#~ msgid "Use current location as input and LL WGS84 as output projection"
+#~ msgstr ""
+#~ "ÐÑполÑзоваÑÑ ÑекÑÑÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ ÐºÐ°Ðº иÑÑ
однÑÑ Ð¸ LL WGS84 как вÑÑ
однÑÑ "
+#~ "пÑоекÑии"
+#~ msgid ""
+#~ "Output long/lat in decimal degrees or other projections with many decimal "
+#~ "places"
+#~ msgstr ""
+#~ "ÐÑÑ
однÑе знаÑÐµÐ½Ð¸Ñ long/lat в деÑÑÑиÑнÑÑ
гÑадÑÑаÑ
или дÑÑгой пÑоекÑии в "
+#~ "ÑоÑмаÑе Ñ Ð¼Ð½Ð¾Ð³Ð¸Ð¼Ð¸ ÑиÑлами поÑле запÑÑой"
+#~ msgid "Verbose mode (print projection parameters and filenames to stderr)"
+#~ msgstr ""
+#~ "РаÑÑиÑеннÑй Ñежим (вÑводиÑÑ Ð¿Ð°ÑамеÑÑÑ Ð¿ÑоекÑии и имена Ñайлов в stderr)"
+#~ msgid "Blends color components of two raster maps by a given ratio."
+#~ msgstr ""
+#~ "СмеÑаÑÑ ÑвеÑовÑе компоненÑÑ Ð´Ð²ÑÑ
ÑаÑÑÑовÑÑ
Ñлоев иÑполÑзÑÑ Ð·Ð°Ð´Ð°Ð½Ð½Ð¾Ðµ "
+#~ "ÑооÑноÑение."
+#~ msgid "Name of first raster map for blending"
+#~ msgstr "ÐÐ¼Ñ Ð¿ÐµÑвого ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð´Ð»Ñ ÑмеÑиваниÑ"
+#~ msgid "Name of second raster map for blending"
+#~ msgstr "ÐÐ¼Ñ Ð²ÑоÑого ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð´Ð»Ñ ÑмеÑиваниÑ"
+#~ msgid "Base name for red, green and blue output maps containing the blend"
+#~ msgstr ""
+#~ "Ðазовое Ð¸Ð¼Ñ Ð´Ð»Ñ Ñлоев ÑодеÑжаÑиÑ
кÑаÑнÑй, зеленÑй и Ñиний Ð´Ð»Ñ ÑмеÑиваниÑ"
+#~ msgid "Percentage weight of first map for color blending"
+#~ msgstr "ÐÑоÑенÑнÑй Ð²ÐµÑ Ð¿ÐµÑвого ÑÐ»Ð¾Ñ Ð´Ð»Ñ ÑвеÑового ÑмеÑиваниÑ"
+#~ msgid ""
+#~ "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+#~ msgstr ""
+#~ "ÐаполниÑÑ no-data знаÑÐµÐ½Ð¸Ñ ÑаÑÑÑовÑÑ
Ñлоев, иÑполÑзÑÑ Ñплайн-инÑеÑполÑÑÐ¸Ñ "
+#~ "v.surf.rst"
+#~ msgid "raster, elevation, interpolation"
+#~ msgstr "ÑаÑÑÑ, вÑÑоÑа, инÑеÑполÑÑиÑ"
+#~ msgid "Raster map in which to fill nulls"
+#~ msgstr "РаÑÑÑовÑй Ñлой Ð´Ð»Ñ Ð·Ð°Ð¿Ð¾Ð»Ð½ÐµÐ½Ð¸Ñ Ð½Ñлей"
+#~ msgid ""
+#~ "Output raster map with nulls filled by interpolation from surrounding "
+#~ "values"
+#~ msgstr ""
+#~ "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой Ñ Ð½ÑлÑми заполненнÑми инÑеÑполÑÑией окÑÑжаÑÑиÑ
+#~ "знаÑений"
+#~ msgid "Spline tension parameter"
+#~ msgstr "паÑамеÑÑ tenstion Ñплайн-инÑеÑполÑÑии"
+#~ msgid "Spline smoothing parameter"
+#~ msgstr "ÐаÑамеÑÑ ÑÐ³Ð»Ð°Ð¶Ð¸Ð²Ð°Ð½Ð¸Ñ Ñплайна"
+#~ msgid ""
+#~ "Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+#~ "using gdalwarp."
+#~ msgstr ""
+#~ "ÐÑивÑзаÑÑ, ÑÑанÑÑоÑмиÑоваÑÑ Ð¸ импоÑÑиÑоваÑÑ ÑÑÐµÐ¼ÐºÑ Terra-ASTER и "
+#~ "оÑноÑиÑелÑнÑе ЦÐРиÑполÑзÑÑ gdalwarp."
+#~ msgid "Input ASTER image to be georeferenced & rectified"
+#~ msgstr "ÐÑÑ
одное изобÑажение ASTER Ð´Ð»Ñ Ð¿ÑивÑзки и ÑÑанÑÑоÑмаÑии"
+#~ msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
+#~ msgstr "Тип даннÑÑ
ASTER (Level 1A, Level 1B, или оÑноÑиÑелÑнÑй DEM)"
+#~ msgid ""
+#~ "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
+#~ "single band"
+#~ msgstr ""
+#~ "канал L1A или L1B Ð´Ð»Ñ Ð¿ÐµÑевода (1, 2, 3n, 3b, 4-14). Ðожно пеÑевеÑÑи "
+#~ "ÑолÑко один канал"
+#~ msgid "Import SRTM HGT files into GRASS"
+#~ msgstr "ÐмпоÑÑ Ñайлов SRTM HGT в GRASS"
+#~ msgid "SRTM input tile (file without .hgt.zip extension)"
+#~ msgstr "иÑÑ
однÑй ÑÑÐ°Ð³Ð¼ÐµÐ½Ñ SRTM (Ñайл без ÑаÑÑиÑÐµÐ½Ð¸Ñ .hgt.zip)"
+#~ msgid "Output raster map (default: input tile)"
одного ÑаÑÑÑового ÑÐ»Ð¾Ñ (по ÑмолÑаниÑ: Ð¸Ð¼Ñ Ð¸ÑÑ
одного)"
+#~ msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
+#~ msgstr "ÐÑÑ
однÑе даннÑе 1-arcsec (по ÑмолÑаниÑ: 3-arcsec)"
+#~ msgid "Downloads and imports data from WMS servers."
+#~ msgstr "ÐагÑÑзиÑÑ Ð¸ импоÑÑиÑоваÑÑ Ð´Ð°Ð½Ð½Ñе Ñ ÑеÑвеÑов WMS."
+#~ msgid "wms"
+#~ msgstr "wms"
+#~ msgid "Request"
+#~ msgstr "ÐапÑоÑ"
+#~ msgid "Skip to downloading (to resume downloads faster)"
+#~ msgstr "ÐÑопÑÑÑиÑÑ Ð¸ наÑаÑÑ Ð·Ð°Ð³ÑÑÐ·ÐºÑ (Ð´Ð»Ñ Ð±ÑÑÑÑого пÑÐ¾Ð´Ð¾Ð»Ð¶ÐµÐ½Ð¸Ñ Ð·Ð°Ð³ÑÑзки)"
+#~ msgid "Download"
+#~ msgstr "СкаÑаÑÑ"
+#~ msgid "Don't request transparent data"
+#~ msgstr "Ðе запÑаÑиваÑÑ Ð¿ÑозÑаÑнÑе даннÑе"
+#~ msgid "Clean existing data out of download directory"
+#~ msgstr "ÐÑиÑÑиÑÑ ÑÑÑеÑÑвÑÑÑие даннÑе из папки загÑÑзки"
+#~ msgid "Import"
+#~ msgstr "ÐмпоÑÑ"
+#~ msgid "Don't reproject the data, just patch it"
+#~ msgstr "Ðе пеÑепÑоекÑиÑоваÑÑ Ð´Ð°Ð½Ð½Ñе, ÑолÑко залаÑаÑÑ"
+#~ msgid "Use GET method instead of POST data method"
+#~ msgstr "ÐÑполÑзоваÑÑ Ð¼ÐµÑод GET вмеÑÑо меÑода POST"
+#~ msgid "This may be needed to connect to servers which lack POST capability"
+#~ msgstr ""
+#~ "Ðозможно ÑÑо понадобиÑÑÑ Ð´Ð»Ñ ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ñ ÑеÑвеÑами без возможноÑÑи POST"
+#~ msgid "Mapserver to request data from"
+#~ msgstr "ÐаÑÑогÑаÑиÑеÑкий ÑеÑÐ²ÐµÑ Ð´Ð»Ñ Ð·Ð°Ð¿ÑоÑа даннÑÑ
+#~ msgid "Layers to request from map server"
+#~ msgstr "Слои, запÑаÑиваемÑе Ñ ÐºÐ°ÑÑогÑаÑиÑеÑкого ÑеÑвеÑа"
+#~ msgid "Styles to request from map server"
+#~ msgstr "СÑили, запÑаÑиваемÑе Ñ ÐºÐ°ÑÑогÑаÑиÑеÑкого ÑеÑвеÑа"
+#~ msgid "Source projection to request from server"
+#~ msgstr "ÐÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð¿ÑоекÑиÑ, запÑаÑÐ¸Ð²Ð°ÐµÐ¼Ð°Ñ Ñ ÑеÑвеÑа"
+#~ msgid "Image format requested from the server"
+#~ msgstr "ФоÑÐ¼Ð°Ñ Ð¸Ð·Ð¾Ð±ÑажениÑ, запÑаÑиваемÑй Ñ ÑеÑвеÑа"
+#~ msgid "Addition query options for server"
+#~ msgstr "ÐополниÑелÑнÑе опÑии запÑоÑа к ÑеÑвеÑÑ"
+#~ msgid "Maximum columns to request at a time"
+#~ msgstr "ÐакÑималÑное колиÑеÑÑво ÑÑолбÑов запÑаÑиваемое единовÑеменно"
+#~ msgid "Maximum rows to request at a time"
+#~ msgstr "ÐинималÑное колиÑеÑÑво ÑÑолбÑов запÑаÑиваемое единовÑеменно"
+#~ msgid "Additional options for r.tileset"
+#~ msgstr "ÐополниÑелÑнÑе опÑии Ð´Ð»Ñ r.tileset"
+#~ msgid "Named region to request data for. Current region used if omitted"
+#~ msgstr ""
+#~ "Регион Ñ Ð½Ð°Ð·Ð²Ð°Ð½Ð¸ÐµÐ¼ Ð´Ð»Ñ ÐºÐ¾ÑоÑого запÑоÑиÑÑ Ð´Ð°Ð½Ð½Ñе. ÐÑли не Ñказан, "
+#~ "иÑполÑзÑеÑÑÑ ÑекÑÑий Ñегион"
+#~ msgid "Folder to save downloaded data to"
+#~ msgstr "ÐаÑалог Ð´Ð»Ñ ÑоÑ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ Ð·Ð°Ð³ÑÑженнÑÑ
даннÑÑ
+#~ msgid "Additional options for wget"
+#~ msgstr "ÐополниÑелÑнÑе опÑии Ð´Ð»Ñ wget"
+#~ msgid "Additional options for curl"
+#~ msgstr "ÐополниÑелÑнÑе опÑии Ð´Ð»Ñ curl"
+#~ msgid "Reprojection method to use"
+#~ msgstr "ÐÑполÑзÑемÑй меÑод пеÑепÑоеÑиÑованиÑ"
+#~ msgid "Filename to save capabilities XML file to"
+#~ msgstr "ÐÐ¼Ñ Ñайла Ð´Ð»Ñ ÑоÑ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ Ñайла возможноÑÑей XML"
+#~ msgid "Requires list available layers flag"
+#~ msgstr "ТÑебÑеÑÑÑ Ñлаг вÑвеÑÑи ÑпиÑок доÑÑÑпнÑÑ
Ñлоев"
+#~ msgid "Verbosity level"
+#~ msgstr "УÑÐ¾Ð²ÐµÐ½Ñ Ð²Ñвода инÑоÑмаÑии"
+#~ msgid "Calculate new raster map from a r.mapcalc expression."
+#~ msgstr "РаÑÑÑиÑаÑÑ Ð½Ð¾Ð²Ñй ÑаÑÑÑовÑй Ñлой иÑполÑзÑÑ Ð²ÑÑажение r.mapcalc."
+#~ msgid "A"
+#~ msgstr "A"
+#~ msgid "B"
+#~ msgstr "B"
+#~ msgid "C"
+#~ msgstr "C"
+#~ msgid "D"
+#~ msgstr "D"
+#~ msgid "E"
+#~ msgstr "E"
+#~ msgid "F"
+#~ msgstr "F"
+#~ msgid "Formula (e.g. A-B or A*C+B)"
+#~ msgstr "ФоÑмÑла (напÑÐ¸Ð¼ÐµÑ A-B или A*C+B)"
+#~ msgid "Show help"
+#~ msgstr "ÐоказаÑÑ Ð¿Ð¾Ð¼Ð¾ÑÑ"
+#~ msgid "Expert mode (enter a set of r.mapcalc expressions)"
+#~ msgstr "ÐкÑпеÑÑнÑй Ñежим (ввеÑÑи Ð½Ð°Ð±Ð¾Ñ Ð²ÑÑажений r.mapcalc)"
+#~ msgid "Do not overwrite existing map"
+#~ msgstr "Ðе пеÑезапиÑÑваÑÑ ÑÑÑеÑÑвÑÑÑие Ñлои "
+#~ msgid "Create a MASK for limiting raster operation"
+#~ msgstr "СоздаÑÑ MASK Ð´Ð»Ñ Ð¾Ð³ÑаниÑÐµÐ½Ð¸Ñ ÑаÑÑÑовÑÑ
опеÑаÑий"
+#~ msgid "raster, mask"
+#~ msgstr "ÑаÑÑÑ, маÑка"
+#~ msgid "Raster map to use as MASK"
+#~ msgstr "РаÑÑÑовÑй Ñлой, иÑполÑзÑемÑй в каÑеÑÑве MASK"
+#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
+#~ msgstr "ÐнаÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий Ð´Ð»Ñ MASK (ÑоÑмаÑ: 1 2 3 до 7 *)"
+#~ msgid "Create inverse MASK from specified 'maskcats' list"
+#~ msgstr "СоздаÑÑ Ð¸Ð½Ð²ÐµÑÑиÑованнÑÑ MASK из заданного ÑпиÑка 'maskcats'"
+#~ msgid "Overwrite existing MASK"
+#~ msgstr "ÐеÑезапиÑаÑÑ ÑÑÑеÑÑвÑÑÑÑÑ MASK"
+#~ msgid "Remove existing MASK (overrides other options)"
+#~ msgstr "УдалиÑÑ ÑÑÑеÑÑвÑÑÑÑÑ MASK (заменÑÐµÑ Ð´ÑÑгие опÑии)"
+#~ msgid "Exports GRASS raster into GDAL supported formats."
+#~ msgstr "ÐкÑпоÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ GRASS в ÑоÑмаÑÑ Ð¿Ð¾Ð´Ð´ÐµÑживаемÑе GDAL."
+#~ msgid "Region sensitive output"
+#~ msgstr "ÐÑвод завиÑÑÑий Ð¾Ñ Ñегиона"
+#~ msgid ""
+#~ "Creation option to the output format driver. Multiple options may be "
+#~ "listed"
+#~ msgstr ""
+#~ "ÐпÑии ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð´Ð»Ñ Ð´ÑайвеÑа вÑÑ
одного ÑоÑмаÑа. Ðозможно неÑколÑко опÑий"
+#~ msgid "Metadata key passed on the output dataset if possible"
+#~ msgstr "ÐеÑаданнÑе пеÑедаваемÑе еÑли возможно вÑÑ
Ð¾Ð´Ð½Ð¾Ð¼Ñ Ð½Ð°Ð±Ð¾ÑÑ Ð´Ð°Ð½Ð½ÑÑ
+#~ msgid ""
+#~ "Export a raster map to a text file as x,y,z values based on cell centers."
+#~ msgstr ""
+#~ "ÐкÑпоÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð² ÑекÑÑовÑй Ñайл как знаÑÐµÐ½Ð¸Ñ x,y,z ÑенÑÑов ÑÑеек."
+#~ msgid ""
+#~ "Creates raster plane map given dip (inclination), aspect (azimuth) and "
+#~ "one point."
+#~ msgstr ""
+#~ "СоздаÑÑ ÑаÑÑÑовÑй Ñлой Ð·Ð½Ð°Ñ Ð¿Ð°Ð´ÐµÐ½Ð¸Ðµ (наклонение), ÑкÑпозиÑÐ¸Ñ (азимÑÑ) и "
+#~ "Ð¾Ð´Ð½Ñ ÑоÑкÑ."
+#~ msgid "raster, elevation"
+#~ msgstr "ÑаÑÑÑ, вÑÑоÑа"
+#~ msgid "Name of raster plane to be created"
+#~ msgstr "ÐÐ¼Ñ Ñоздаваемой ÑаÑÑÑовой плоÑкоÑÑи"
+#~ msgid "Dip of plane. Value must be between -90 and 90 degrees"
+#~ msgstr "ÐзимÑÑ Ð¿Ð»Ð¾ÑкоÑÑи. ÐнаÑение должно бÑÑÑ Ð¼ÐµÐ¶Ð´Ñ -90 и 90 гÑадÑÑами"
+#~ msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
+#~ msgstr "ÐзимÑÑ Ð¿Ð»Ð¾ÑкоÑÑи. ÐнаÑение должно бÑÑÑ Ð¼ÐµÐ¶Ð´Ñ 0 и 360 гÑадÑÑами"
+#~ msgid "Easting coordinate of a point on the plane"
+#~ msgstr "ÐоÑÑоÑÐ½Ð°Ñ ÐºÐ¾Ð¾ÑдинаÑа ÑоÑки на плоÑкоÑÑи "
+#~ msgid "Northing coordinate of a point on the plane"
+#~ msgstr "СевеÑÐ½Ð°Ñ ÐºÐ¾Ð¾ÑдинаÑа ÑоÑки на плоÑкоÑÑи "
+#~ msgid "Elevation coordinate of a point on the plane"
+#~ msgstr "ÐÑÑоÑÐ½Ð°Ñ ÐºÐ¾Ð¾ÑдинаÑа ÑоÑки на плоÑкоÑÑи "
+#~ msgid "Type of the raster map to be created"
+#~ msgstr "Тип Ñоздаваемого ÑаÑÑÑового ÑлоÑ"
+#, fuzzy
+#~ msgid ""
+#~ "Reclasses a raster map greater or less than user specified area size (in "
+#~ "hectares)"
+#~ msgstr ""
+#~ "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой болÑÑе или менÑÑе Ñем плоÑÐ°Ð´Ñ "
+#~ "Ð·Ð°Ð´Ð°Ð½Ð½Ð°Ñ Ð¿Ð¾Ð»ÑзоваÑелем (в гекÑаÑаÑ
+#~ msgid "raster, statistics, aggregation"
+#~ msgstr "ÑаÑÑÑ, ÑÑаÑиÑÑика, аггÑегаÑиÑ"
+#, fuzzy
+#~ msgid "lesser val option that sets the <= area size limit [hectares]"
+#~ msgstr ""
+#~ "менÑÑее знаÑение опÑии, коÑоÑÐ°Ñ ÑÑÑÐ°Ð½Ð°Ð²Ð»Ð¸Ð²Ð°ÐµÑ <= Ð»Ð¸Ð¼Ð¸Ñ Ð¿Ð»Ð¾Ñади полигона "
+#~ "[гекÑаÑÑ]"
+#, fuzzy
+#~ msgid "greater val option that sets the >= area size limit [hectares]"
+#~ msgstr ""
+#~ "болÑÑее знаÑение опÑии, коÑоÑÐ°Ñ ÑÑÑÐ°Ð½Ð°Ð²Ð»Ð¸Ð²Ð°ÐµÑ >= Ð»Ð¸Ð¼Ð¸Ñ Ð¿Ð»Ð¾Ñади полигона "
+#~ "[гекÑаÑÑ]"
#~ msgid "reclass raster output map"
#~ msgstr "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ Ð²ÑÑ
одной Ñлой"
+#~ msgid "Calculates linear regression from two raster maps: y = a + b*x"
+#~ msgstr "РаÑÑÑиÑаÑÑ Ð»Ð¸Ð½ÐµÐ¹Ð½ÑÑ ÑегÑеÑÑÐ¸Ñ Ð´Ð»Ñ Ð´Ð²ÑÑ
ÑаÑÑÑовÑÑ
Ñлоев: y = a + b*x"
+#~ msgid "Slower but accurate (applies to FP maps only)"
+#~ msgstr "Ðедленнее, но ÑоÑнее (пÑименимо ÑолÑко Ð´Ð»Ñ FP Ñлоев)"
+#~ msgid "Map for x coefficient"
+#~ msgstr "Слой Ð´Ð»Ñ ÐºÐ¾ÑÑÑиÑиенÑа x"
+#~ msgid "Map for y coefficient"
+#~ msgstr "Слой Ð´Ð»Ñ ÐºÐ¾ÑÑÑиÑиенÑа y"
+#~ msgid ""
+#~ "ASCII file for storing regression coefficients (output to screen if file "
+#~ "not specified)."
+#~ msgstr ""
+#~ "Ñайл ASCII Ð´Ð»Ñ ÑоÑ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ ÐºÐ¾ÑÑÑиÑиенÑов ÑегÑеÑÑии (вÑвод на ÑкÑан, еÑли "
+#~ "Ñайл не задан)."
+#~ msgid "Creates shaded relief map from an elevation map (DEM)."
+#~ msgstr "СоздаÑÑ Ñлой Ñеневого ÑелÑеÑа из ÑÐ»Ð¾Ñ ÑелÑеÑа (DEM)."
+#~ msgid "Output shaded relief map name"
+#~ msgstr "ÐÑвеÑÑи Ð¸Ð¼Ñ ÑÐ»Ð¾Ñ Ñеневой оÑмÑвки ÑелÑеÑа"
+#~ msgid "Altitude of the sun in degrees above the horizon"
+#~ msgstr "ÐÑÑоÑа ÑолнÑа над гоÑизонÑом в гÑадÑÑаÑ
+#~ msgid "Azimuth of the sun in degrees to the east of north"
+#~ msgstr "ÐзимÑÑ ÑолнÑа в гÑадÑÑаÑ
к воÑÑÐ¾ÐºÑ Ð¾Ñ ÑевеÑа"
+#~ msgid "Factor for exaggerating relief"
+#~ msgstr "ФакÑÐ¾Ñ Ð¼Ð°ÑÑÑабиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð´Ð»Ñ Ð²ÑÑоÑ"
+#~ msgid "Scale factor for converting horizontal units to elevation units"
+#~ msgstr ""
+#~ "ФакÑÐ¾Ñ Ð¼Ð°ÑÑÑабиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð´Ð»Ñ ÐºÐ¾Ð½Ð²ÐµÑÑаÑии гоÑизонÑалÑнÑÑ
ÐµÐ´Ð¸Ð½Ð¸Ñ Ð² вÑÑоÑнÑе "
+#~ msgid ""
+#~ "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+#~ msgstr ""
+#~ "ÐадаÑÑ ÑакÑÐ¾Ñ Ð¼Ð°ÑÑÑабиÑÐ¾Ð²Ð°Ð½Ð¸Ñ (ÑолÑко Ð´Ð»Ñ ÑоÑек в lat./long., еÑли пÑÑÑо: "
+#~ "scale=1)"
+#~ msgid ""
+#~ "Produces tilings of the source projection for use in the destination "
+#~ "region and projection."
+#~ msgstr ""
+#~ "СоздаÑÑ ÑÐ°Ð¹Ð»Ñ Ð² иÑÑ
одной пÑоекÑии Ð´Ð»Ñ Ð¸ÑполÑÐ·Ð¾Ð²Ð°Ð½Ð¸Ñ Ñ Ð²ÑÑ
однÑм Ñегионом и "
+#~ "пÑоекÑией."
+#~ msgid "raster, tiling"
+#~ msgstr "ÑаÑÑÑ, плиÑки"
+#~ msgid "Produces shell script output"
+#~ msgstr "ÐÑвеÑÑи ÑÑаÑиÑÑÐ¸ÐºÑ Ð² ÑÑиле shell"
+#~ msgid "Produces web map server query string output"
+#~ msgstr "СоздаÑÑ ÑÑÑÐ¾ÐºÑ Ð·Ð°Ð¿ÑоÑа вÑвода к каÑÑогÑаÑиÑеÑÐºÐ¾Ð¼Ñ Ð²ÐµÐ± ÑеÑвеÑÑ"
+#~ msgid ""
+#~ "Name of region to use instead of current region for bounds and resolution"
+#~ msgstr ""
+#~ "Ðазвание Ñегиона Ð´Ð»Ñ Ð¸ÑполÑÐ·Ð¾Ð²Ð°Ð½Ð¸Ñ Ð²Ð¼ÐµÑÑо ÑекÑÑего Ð´Ð»Ñ Ð³ÑÐ°Ð½Ð¸Ñ Ð¸ ÑазÑеÑениÑ"
+#~ msgid "Source projection"
+#~ msgstr "ÐÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð¿ÑоекÑиÑ"
+#~ msgid "Conversion factor from units to meters in source projection"
+#~ msgstr "ÐоÑÑÑиÑÐ¸ÐµÐ½Ñ Ð¿ÐµÑеÑÑеÑа из ÐµÐ´Ð¸Ð½Ð¸Ñ Ð² меÑÑÑ Ð² иÑÑ
одной пÑоекÑии"
+#~ msgid "Destination projection, defaults to this location's projection"
+#~ msgstr "ÐонеÑÐ½Ð°Ñ Ð¿ÑоекÑиÑ, по ÑмолÑÐ°Ð½Ð¸Ñ Ð¿ÑоекÑÐ¸Ñ Ð¾Ð±Ð»Ð°ÑÑи "
+#~ msgid "Maximum number of columns for a tile in the source projection"
+#~ msgstr "ÐакÑималÑное ÑиÑло ÑÑолбÑов Ð´Ð»Ñ ÑÑагменÑа в иÑÑ
одной пÑоекÑии"
+#~ msgid "Maximum number of rows for a tile in the source projection"
+#~ msgstr "ÐакÑималÑное ÑиÑло ÑÑдов Ð´Ð»Ñ ÑÑагменÑа в иÑÑ
одной пÑоекÑии"
+#, fuzzy
+#~ msgid "Number of cells tiles should overlap in each direction"
+#~ msgstr "ЧиÑло ÑÑеек должно пеÑеÑекаÑÑÑÑ Ð²Ð¾ вÑеÑ
напÑавлениÑÑ
+#~ msgid "calculates univariate statistics from a GRASS raster map"
+#~ msgstr "РаÑÑÑиÑаÑÑ Ð¾Ð´Ð½Ð¾Ð¼ÐµÑнÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ GRASS"
+#~ msgid "extended statistics (quartiles and percentile)"
+#~ msgstr "ÑаÑÑиÑÐµÐ½Ð½Ð°Ñ ÑÑаÑиÑÑика (кваÑÑили и пеÑÑенÑили)"
+#~ msgid "Percentile to calculate (requires -e flag)"
+#~ msgstr "ÐÑÑиÑлÑемÑй пÑоÑенÑÐ¸Ð»Ñ (ÑÑебÑÐµÑ Ð¿Ð°ÑамеÑÑа -e)"
+#~ msgid "Calculates new grid3D volume from r3.mapcalc expression."
+#~ msgstr "РаÑÑÑиÑаÑÑ Ð½Ð¾Ð²Ñй grid3D обÑем Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ Ð²ÑÑÐ°Ð¶ÐµÐ½Ð¸Ñ r3.mapcalc"
+#~ msgid "A (grid3D file)"
+#~ msgstr "A (Ñайл grid3D)"
+#~ msgid "B (grid3D file)"
+#~ msgstr "B (Ñайл grid3D)"
+#~ msgid "C (grid3D file)"
+#~ msgstr "C (Ñайл grid3D)"
+#~ msgid "D (grid3D file)"
+#~ msgstr "D (Ñайл grid3D)"
+#~ msgid "E (grid3D file)"
+#~ msgstr "E (Ñайл grid3D)"
+#~ msgid "F (grid3D file)"
+#~ msgstr "F (Ñайл grid3D)"
+#~ msgid "Name for output grid3D volume"
одного обÑема grid3D"
+#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
+#~ msgstr "ÐкÑпеÑÑнÑй Ñежим (введиÑе Ð½Ð°Ð±Ð¾Ñ Ð²ÑÑажений r3.mapcalc)"
+#~ msgid "Rebuilds topology on all vector maps in the current mapset."
+#~ msgstr "ÐеÑеÑÑÑоиÑÑ ÑÐ¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð´Ð»Ñ Ð²ÑеÑ
векÑоÑнÑÑ
Ñлоев ÑекÑÑего набоÑа."
+#~ msgid "Adds missing centroids to closed boundaries."
+#~ msgstr "ÐобавиÑÑ Ð¿ÑопÑÑеннÑе ÑенÑÑÐ¾Ð¸Ð´Ñ Ðº замкнÑÑÑм гÑаниÑам."
+#~ msgid "vector, centroid, area"
+#~ msgstr "векÑоÑ, ÑенÑÑоид, полигон"
+#~ msgid "Name of input vector map"
+#~ msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного векÑоÑного ÑлоÑ"
+#~ msgid "Name for output vector map"
+#~ msgid "Action to be taken"
+#~ msgstr "ÐÑполниÑÑ Ð´ÐµÐ¹ÑÑвие"
+#~ msgid "Category number starting value"
+#~ msgstr "ÐаÑалÑнÑй Ð½Ð¾Ð¼ÐµÑ ÐºÐ°ÑегоÑии"
+#~ msgid ""
+#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+#~ "format"
+#~ msgstr ""
+#~ "ÐонвеÑÑиÑоваÑÑ Ð²Ñе ÑÑаÑÑе Ñлои GRASS < Ver5.7 в ÑекÑÑем набоÑе в ÑекÑÑий "
+#~ "ÑоÑмаÑ"
+#~ msgid "run non-interactively"
+#~ msgstr "запÑÑÑиÑÑ Ð±ÐµÐ· инÑеÑакÑивноÑÑи"
+#~ msgid ""
+#~ "Adds one or more columns to the attribute table connected to a given "
+#~ "vector map."
+#~ msgstr ""
+#~ "ÐобавиÑÑ Ð¾Ð´Ð½Ð¾ или более полей к аÑÑибÑÑивной ÑаблиÑе, ÑвÑзанной Ñ "
+#~ "заданнÑм векÑоÑнÑм Ñлоем."
+#~ msgid "Vector map for which to edit attribute table"
+#~ msgstr "ÐекÑоÑнÑй Ñлой Ð´Ð»Ñ ÐºÐ¾ÑоÑого ÑедакÑиÑоваÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ"
+#~ msgid "Layer where to add column"
+#~ msgstr "Слой к коÑоÑÐ¾Ð¼Ñ Ð´Ð¾Ð±Ð°Ð²Ð¸ÑÑ ÑÑолбеÑ"
+#~ msgid ""
+#~ "Name and type of the new column(s) (types depend on database backend, but "
+#~ "all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
+#~ msgstr ""
+#~ "ÐÐ¼Ñ Ð¸ Ñип нового Ð¿Ð¾Ð»Ñ (полей) (ÑÐ¸Ð¿Ñ Ð·Ð°Ð²Ð¸ÑÑÑ Ð¾Ñ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
, но вÑе "
+#~ "поддеÑживаÑÑ VARCHAR(), INT, DOUBLE and DATE)"
+#~ msgid ""
+#~ "Creates and adds a new attribute table to a given layer of an existing "
+#~ "vector map."
+#~ msgstr ""
+#~ "СоздаÑÑ Ð¸ добавиÑÑ Ð½Ð¾Ð²ÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ Ð² даннÑй Ñлой ÑÑÑеÑÑвÑÑÑего "
+#~ "векÑоÑного ÑлоÑ."
+#~ msgid "Vector map for which to add new attribute table"
+#~ msgstr "ÐекÑоÑнÑй Ñлой, коÑоÑÐ¾Ð¼Ñ Ð´Ð¾Ð±Ð°Ð²Ð»ÑеÑÑÑ Ð½Ð¾Ð²Ð°Ñ Ð°ÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
+#~ msgid "Name of new attribute table (default: vector map name)"
+#~ msgstr "ÐÐ¼Ñ Ð½Ð¾Ð²Ð¾Ð¹ аÑÑибÑÑивной ÑаблиÑÑ (по ÑмолÑаниÑ: Ð¸Ð¼Ñ Ð²ÐµÐºÑоÑного ÑлоÑ)"
+#~ msgid "Layer where to add new attribute table"
+#~ msgstr "Слой коÑоÑÐ¾Ð¼Ñ Ð´Ð¾Ð±Ð°Ð²Ð»ÑеÑÑÑ Ð½Ð¾Ð²Ð°Ñ Ð°ÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
+#~ msgid "Allows to join a table to a vector map table."
+#~ msgstr "ÐÑиÑоединиÑÑ ÑаблиÑÑ Ð²ÐµÐºÑоÑÐ½Ð¾Ð¼Ñ ÑлоÑ."
+#~ msgid "Vector map to which to join other table"
+#~ msgstr "ÐекÑоÑнÑй Ñлой к коÑоÑÐ¾Ð¼Ñ Ð¿ÑиÑоединиÑÑ Ð´ÑÑгÑÑ ÑаблиÑÑ"
+#, fuzzy
+#~ msgid "Layer where to join"
+#~ msgstr "Слой к коÑоÑÐ¾Ð¼Ñ Ð´Ð¾Ð±Ð°Ð²Ð¸ÑÑ Ñоединение"
+#~ msgid "Join column in map table"
+#~ msgstr "Ðоле ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ð² ÑаблиÑе ÑлоÑ"
+#~ msgid "Other table name"
+#~ msgstr "ÐÐ¼Ñ Ð´ÑÑгой ÑаблиÑÑ"
+#~ msgid "Join column in other table"
+#~ msgstr "Ðоле ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ð² дÑÑгой ÑаблиÑе"
+#~ msgid ""
+#~ "Drops a column from the attribute table connected to a given vector map."
+#~ msgstr ""
+#~ "УдалиÑÑ Ð¿Ð¾Ð»Ðµ в аÑÑибÑÑивной ÑаблиÑе, ÑвÑзанной Ñ Ð´Ð°Ð½Ð½Ñм векÑоÑнÑм Ñлоем."
+#~ msgid "Vector map for which to drop attribute column"
+#~ msgstr "ÐекÑоÑнÑй Ñлой из ÑаблиÑÑ ÐºÐ¾ÑоÑого ÑдалÑеÑÑÑ Ð¿Ð¾Ð»Ðµ"
+#~ msgid "Layer where to drop column"
+#~ msgstr "Слой Ñ ÐºÐ¾ÑоÑого ÑдалиÑÑ ÑÑолбеÑ"
+#~ msgid "Removes existing attribute table of a vector map."
+#~ msgstr "УдалиÑÑ ÑÑÑеÑÑвÑÑÑÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ Ð¸Ð· векÑоÑного ÑлоÑ."
+#~ msgid "Force removal (required for actual deletion of table)"
+#~ msgstr "Силовое Ñдаление (ÑÑебÑеÑÑÑ Ð´Ð»Ñ ÑизиÑеÑкого ÑÐ´Ð°Ð»ÐµÐ½Ð¸Ñ ÑаблиÑÑ)"
+#~ msgid "Vector map from which to remove attribute table"
+#~ msgstr "ÐекÑоÑнÑй Ñлой из коÑоÑого ÑдалÑеÑÑÑ ÑаблиÑа аÑÑибÑÑов"
+#~ msgid "Name of existing attribute table (default: vector map name)"
+#~ msgstr ""
+#~ "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑей ÑаблиÑÑ Ð°ÑÑибÑÑов (по ÑмолÑаниÑ: Ð¸Ð¼Ñ Ð²ÐµÐºÑоÑного ÑлоÑ)"
+#~ msgid "Layer from which to drop linked attribute table"
+#~ msgstr "Слой из коÑоÑого ÑдалÑеÑÑÑ ÑвÑÐ·Ð°Ð½Ð½Ð°Ñ Ð°ÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
+#~ msgid ""
+#~ "Renames a column in the attribute table connected to a given vector map."
+#~ msgstr ""
+#~ "ÐеÑеименоваÑÑ Ð¿Ð¾Ð»Ðµ в аÑÑибÑÑивной ÑаблиÑе, ÑвÑзанной Ñ Ð´Ð°Ð½Ð½Ñм векÑоÑнÑм "
+#~ "Ñлоем."
+#~ msgid "Vector map for which to rename attribute column"
+#~ msgstr "Ðоле аÑÑибÑÑов векÑоÑного ÑÐ»Ð¾Ñ Ð¸ÑполÑзÑемое Ð´Ð»Ñ Ð¿ÐµÑеименованиÑ"
+#~ msgid "Layer where to rename column"
+#~ msgstr "Слой в коÑоÑом пеÑеименовÑваеÑÑÑ Ð¿Ð¾Ð»Ðµ"
+#~ msgid "Old and new name of the column (old,new)"
+#~ msgstr "СÑаÑое и новое Ð¸Ð¼Ñ ÑÑолбÑа (ÑÑаÑое,новое)"
+#~ msgid "Reconnects vectors to a new database."
+#~ msgstr "ÐеÑеÑоединиÑÑ Ð²ÐµÐºÑоÑа Ñ Ð½Ð¾Ð²Ð¾Ð¹ базой даннÑÑ
+#, fuzzy
+#~ msgid ""
+#~ "Name of old database. The database must be in form printed by v.db."
+#~ "connect -g, i.e. with substituted variables"
+#~ msgstr ""
+#~ "ÐÐ¼Ñ ÑÑаÑой Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
. Ðаза даннÑÑ
должна бÑÑÑ Ñказана в ÑоÑме "
+#~ "задаваемой v.db.connect -g, Ñо еÑÑÑ Ñ Ð¿Ð¾Ð´Ð¼ÐµÐ½ÐµÐ½Ð½Ñми пеÑеменнÑми."
+#~ msgid "Name of new database"
+#~ msgstr "ÐÐ¼Ñ Ð½Ð¾Ð²Ð¾Ð¹ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
+#~ msgid "Old schema"
+#~ msgstr "СÑаÑÐ°Ñ ÑÑ
ема"
+#~ msgid "New schema"
+#~ msgstr "ÐÐ¾Ð²Ð°Ñ ÑÑ
ема"
+#~ msgid ""
+#~ "Calculates univariate statistics on selected table column for a GRASS "
+#~ "vector map."
+#~ msgstr ""
+#~ "РаÑÑÑиÑаÑÑ Ð¾Ð´Ð½Ð¾Ð¼ÐµÑнÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð¿Ð¾ вÑбÑÐ°Ð½Ð½Ð¾Ð¼Ñ Ð¿Ð¾Ð»Ñ ÑаблиÑÑ Ð´Ð»Ñ "
+#~ "векÑоÑного ÑÐ»Ð¾Ñ GRASS."
+#~ msgid "Extended statistics (quartiles and 90th percentile)"
+#~ msgstr "РаÑÑиÑÐµÐ½Ð½Ð°Ñ ÑÑаÑиÑÑика (кваÑÑили и 90 пеÑÑенÑилÑ)"
+#~ msgid "Name of data table"
+#~ msgstr "ÐÐ¼Ñ ÑаблиÑÑ"
+#~ msgid "Column on which to calculate statistics (must be numeric)"
+#~ msgstr "СÑÐ¾Ð»Ð±ÐµÑ Ð´Ð»Ñ ÐºÐ¾ÑоÑого ÑаÑÑÑиÑаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ (должен бÑÑÑ ÑиÑловой)"
+#~ msgid "Database/directory for table"
+#~ msgstr "Ðаза даннÑÑ
/каÑалог Ð´Ð»Ñ ÑаблиÑÑ"
+#~ msgid "Database driver"
+#~ msgstr "ÐÑÐ°Ð¹Ð²ÐµÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
+#~ msgid ""
+#~ "Allows to update a column in the attribute table connected to a vector "
+#~ "map."
+#~ msgstr "ÐбновиÑÑ Ð¿Ð¾Ð»Ðµ в аÑÑибÑÑивной ÑаблиÑе, ÑвÑзанной Ñ Ð²ÐµÐºÑоÑнÑм Ñлоем."
+#~ msgid "Vector map to edit the attribute table for"
+#~ msgstr "ÐекÑоÑнÑй Ñлой Ð´Ð»Ñ ÑедакÑиÑÐ¾Ð²Ð°Ð½Ð¸Ñ ÑаблиÑÑ"
+#~ msgid "Layer to which the table to be changed is connected"
+#~ msgstr "Слой Ñ ÐºÐ¾ÑоÑÑм Ñоединена изменÑÐµÐ¼Ð°Ñ ÑаблиÑа"
+#~ msgid "Column to update"
+#~ msgstr "ÐбновлÑемÑй ÑÑолбеÑ"
+#~ msgid ""
+#~ "Value to update the column with (varchar values have to be in single "
+#~ "quotes, e.g. 'grass')"
+#~ msgstr ""
+#~ "ÐнаÑение иÑполÑзÑемое Ð´Ð»Ñ Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½Ð¸Ñ ÑÑолбÑа (знаÑÐµÐ½Ð¸Ñ varchar Ð´Ð¾Ð»Ð¶Ð½Ñ "
+#~ "бÑÑÑ Ð² одиноÑнÑÑ
кавÑÑкаÑ
, напÑÐ¸Ð¼ÐµÑ 'grass')"
+#~ msgid "Column to query"
+#~ msgstr "ÐапÑаÑиваемÑй ÑÑолбеÑ"
+#~ msgid ""
+#~ "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
+#~ "col2>1)"
+#~ msgstr ""
+#~ "ÐбновлÑемое ÑÑловие WHERE, без клÑÑевого Ñлова 'where' (напÑÐ¸Ð¼ÐµÑ cat=1 "
+#~ "или col1/col2>1)"
+#~ msgid ""
+#~ "Dissolves boundaries between adjacent areas sharing a common category "
+#~ "number or attribute."
+#~ msgstr ""
+#~ "РаÑÑвоÑиÑÑ Ð³ÑаниÑÑ Ð¼ÐµÐ¶Ð´Ñ Ð¿ÑилегаÑÑими полигонами имеÑÑими одинаковое "
+#~ "знаÑение каÑегоÑии или аÑÑибÑÑа."
+#~ msgid "vector, area, dissolve"
+#~ msgstr "векÑоÑ, полигон, ÑаÑÑвоÑиÑÑ"
+#, fuzzy
+#~ msgid "Layer number. If -1, all layers are extracted"
+#~ msgstr "ÐÐ¾Ð¼ÐµÑ ÑлоÑ. ÐÑли -1, полÑÑаÑÑÑÑ Ð²Ñе Ñлои"
+#~ msgid "Name of column used to dissolve common boundaries"
+#~ msgstr "ÐÐ¼Ñ Ð¿Ð¾Ð»Ñ Ð¸ÑполÑзÑемого Ð´Ð»Ñ ÑаÑÑвоÑÐµÐ½Ð¸Ñ Ð¾Ð±ÑиÑ
гÑÐ°Ð½Ð¸Ñ "
+#~ msgid "Import E00 file into a vector map."
+#~ msgstr "ÐмпоÑÑ Ñайла E00 в векÑоÑнÑй Ñлой."
+#~ msgid "E00 file"
+#~ msgstr "Ñайл E00"
+#~ msgid "Input type point, line or area"
+#~ msgstr "ÐÑÑ
однÑй Ñип ÑоÑка, линий или полигон"
+#~ msgid ""
+#~ "Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
+#~ "vector map."
+#~ msgstr ""
+#~ "ÐагÑÑзиÑÑ ÑоÑки, маÑÑÑÑÑÑ Ð¸ ÑÑÑки из пÑиемника Garmin GPS в векÑоÑнÑй "
+#~ "Ñлой."
+#~ msgid "vector, import, GPS"
+#~ msgstr "векÑоÑ, импоÑÑ, GPS"
+#~ msgid "Download Waypoints from GPS"
+#~ msgstr "ÐагÑÑзиÑÑ ÑоÑки Ñ GPS"
+#~ msgid "Download Routes from GPS"
+#~ msgstr "ÐагÑÑзиÑÑ Ð¼Ð°ÑÑÑÑÑÑ Ñ GPS"
+#~ msgid "Download Track from GPS"
+#~ msgstr "ÐагÑÑзиÑÑ ÑÑÑк из GPS"
+#~ msgid "Force import of track or route data as points"
+#~ msgstr "ÐмпоÑÑиÑоваÑÑ ÑÑÑки и маÑÑÑÑÑÑ ÐºÐ°Ðº ÑоÑки"
+#~ msgid "Use gardump instead of gpstrans as the download program"
+#~ msgstr "ÐÑполÑзоваÑÑ Ð´Ð»Ñ Ð·Ð°Ð³ÑÑзки gardump вмеÑÑо gpstrans"
+#~ msgid "Import track in 3D (gardump only)"
+#~ msgstr "ÐмпоÑÑиÑоваÑÑ ÑÑÑк в 3D (ÑолÑко Ð´Ð»Ñ gardump)"
+#~ msgid "Do not attempt projection transform from WGS84"
+#~ msgstr "Ðе пÑÑаÑÑÑÑ Ð¿ÐµÑепÑоекÑиÑоваÑÑ Ð¸Ð· WGS84"
+#~ msgid "Name for output vector map (omit for display to stdout)"
одного векÑоÑного ÑÐ»Ð¾Ñ (не задаваÑÑ Ð´Ð»Ñ Ð²Ñвода в stdout)"
+#~ msgid "Port Garmin receiver is connected to"
+#~ msgstr "ÐоÑÑ Ðº коÑоÑÐ¾Ð¼Ñ Ð¿ÑиÑоединен Garmin "
+#~ msgid "Imports geonames.org country files into a GRASS vector points map."
+#~ msgstr "ÐмпоÑÑ Ñайлов ÑÑÑан geonames.org в ÑоÑеÑнÑй векÑоÑнÑй Ñлой GRASS."
+#~ msgid "vector, import, gazetteer"
+#~ msgstr "векÑоÑ, импоÑÑ, каÑалог"
+#~ msgid "Uncompressed geonames file from (with .txt extension)"
+#~ msgstr "ÐеÑжаÑÑй Ñайл geonames из (Ñ ÑаÑÑиÑением .txt)"
+#~ msgid ""
+#~ "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS "
+#~ "vector points map."
+#~ msgstr ""
+#~ "ÐмпоÑÑ Ñайлов ÑÑÑан US-NGA GEOnet Names Server (GNS) в ÑоÑеÑнÑй векÑоÑнÑй "
+#~ "Ñлой GRASS."
+#~ msgid "Uncompressed GNS file from NGA (with .txt extension)"
+#~ msgstr "ÐеÑжаÑÑй Ñайл GNS из NGA (Ñ ÑаÑÑиÑением .txt)"
+#~ msgid ""
+#~ "Import waypoints, routes, and tracks from a GPS receiver or GPS download "
+#~ "file into a vector map."
+#~ msgstr ""
+#~ "ÐмпоÑÑиÑоваÑÑ Ð¿ÑÑевÑе ÑоÑки, маÑÑÑÑÑÑ, и ÑÑеки из GPS или Ñайла "
+#~ "ÑкаÑанного из GPS в векÑоÑнÑй Ñлой."
+#~ msgid "Import waypoints"
+#~ msgstr "ÐмпоÑÑ Ð¿ÑÑевÑÑ
ÑоÑек"
+#~ msgid "Import routes"
+#~ msgstr "ÐмпоÑÑиÑоваÑÑ Ð¼Ð°ÑÑÑÑÑÑ"
+#~ msgid "Import track"
+#~ msgstr "ÐмпоÑÑ ÑÑÑка"
+#~ msgid "Force vertices of track or route data as points"
+#~ msgstr "ÐеÑÑÐ¸Ð½Ñ ÑÑÑка или маÑÑÑÑÑа как ÑоÑки"
+#~ msgid "Device or file used to import data"
+#~ msgstr "УÑÑÑойÑÑво или Ñайл иÑполÑзÑемÑй Ð´Ð»Ñ Ð¸Ð¼Ð¿Ð¾ÑÑа даннÑÑ
+#~ msgid "Format of GPS input data (use gpsbabel supported formats)"
+#~ msgstr ""
+#~ "ФоÑÐ¼Ð°Ñ Ð¸ÑÑ
однÑÑ
даннÑÑ
GPS (иÑполÑзоваÑÑ ÑоÑмаÑÑ Ð¿Ð¾Ð´Ð´ÐµÑживаемÑе gpsbabel)"
+#~ msgid ""
+#~ "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is "
+#~ "assumed"
+#~ msgstr ""
+#~ "ÐÑоекÑÐ¸Ñ Ð¸ÑÑ
однÑÑ
даннÑÑ
(в ÑÑиле PROJ.4), еÑли не задана, "
+#~ "подÑазÑмеваеÑÑÑ Lat/Lon WGS84"
+#~ msgid "Import Mapgen or Matlab vector maps into GRASS."
+#~ msgstr "ÐмпоÑÑ Ð² GRASS векÑоÑнÑÑ
Ñлоев ÑоÑмаÑа Mapgen или Matlab."
+#~ msgid "Input map is in Matlab format"
+#~ msgstr "ÐÑÑ
однÑй Ñлой в ÑоÑмаÑе Matlab"
+#~ msgid "Create a 3D vector points map from 3 column Matlab data"
+#~ msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑй 3D ÑоÑеÑнÑй Ñлой из 3 ÑÑолбÑов даннÑÑ
Matlab"
+#~ msgid "Name of input file in Mapgen/Matlab format"
+#~ msgstr " ÐÐ¼Ñ Ð¸ÑÑ
одного Ñайла в ÑоÑмаÑе Mapgen/Matlab"
+#~ msgid ""
+#~ "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector "
+#~ "maps."
+#~ msgstr ""
+#~ "ÐонвеÑÑиÑоваÑÑ Ð²Ñе ÑÑаÑÑе Ñлои ÑайÑов GRASS < Ver5.7 в ÑекÑÑем набоÑе в "
+#~ "векÑоÑнÑе Ñлои."
+#~ msgid "sites, vector, import"
+#~ msgstr "ÑайÑÑ, векÑоÑ, импоÑÑ"
+#~ msgid "Run non-interactively"
+#~ msgstr "ÐÑполниÑÑ Ð±ÐµÐ· инÑеÑакÑивноÑÑи"
+#~ msgid "import GetFeature from WFS"
+#~ msgstr "импоÑÑиÑоваÑÑ GetFeature из WFS"
+#~ msgid "GetFeature URL starting with http"
+#~ msgstr "GetFeature URL наÑинаÑÑийÑÑ Ñ http"
+#~ msgid "Vector output map"
+#~ msgstr "ÐÑÑ
одной векÑоÑнÑй Ñлой"
+#~ msgid ""
+#~ "Calculates univariate statistics from a GRASS raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "ÐÑÑиÑление одномеÑной ÑÑаÑиÑÑики по ÑаÑÑÑÐ¾Ð²Ð¾Ð¼Ñ ÑÐ»Ð¾Ñ GRASS, иÑполÑзÑÑ "
+#~ "векÑоÑнÑе полигонÑ. ÐагÑÑзка ÑÑаÑиÑÑики в новÑй ÑÑÐ¾Ð»Ð±ÐµÑ Ð°ÑÑибÑÑов."
+#~ msgid "vector, raster, statistics"
+#~ msgstr "векÑоÑ, ÑаÑÑÑ, ÑÑаÑиÑÑика"
+#~ msgid "Continue if upload column(s) already exist"
+#~ msgstr "ÐÑодолжиÑÑ, еÑли загÑÑжаемÑй ÑÑÐ¾Ð»Ð±ÐµÑ (ÑÑолбÑÑ) Ñже ÑÑÑеÑÑвÑÑÑ"
+#~ msgid "Name of vector polygon map"
+#~ msgstr "ÐÐ¼Ñ Ð²ÐµÐºÑоÑного полигоналÑного ÑлоÑ"
+#~ msgid "Name of raster map to calculate statistics from"
+#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð´Ð»Ñ Ð²ÑÑиÑÐ»ÐµÐ½Ð¸Ñ ÑÑаÑиÑÑики"
+#~ msgid "Column prefix for new attribute columns"
+#~ msgstr "ÐÑеÑÐ¸ÐºÑ Ð´Ð»Ñ Ð½Ð¾Ð²Ð¾Ð³Ð¾ ÑÑолбÑа аÑÑибÑÑов"
+#~ msgid "Reports geometry statistics for vectors."
+#~ msgstr "ÐÑÑÐµÑ Ð³ÐµÐ¾Ð¼ÐµÑÑиÑеÑкой ÑÑаÑиÑÑики Ð´Ð»Ñ Ð²ÐµÐºÑоÑов."
+#~ msgid "vector, report, statistics"
+#~ msgstr "векÑоÑ, оÑÑеÑ, ÑÑаÑиÑÑика"
+#~ msgid "Reverse sort the result"
+#~ msgstr "ÐбÑаÑÐ½Ð°Ñ ÑоÑÑиÑовка ÑезÑлÑÑаÑа"
+#~ msgid "Sort the result"
+#~ msgstr "СоÑÑиÑовка ÑезÑлÑÑаÑа"
+#~ msgid "Value to calculate"
+#~ msgstr "ÐÑÑиÑлÑемое знаÑение"
+#~ msgid "Uploads vector values at positions of vector points to the table."
+#~ msgstr "ÐагÑÑзка знаÑений векÑоÑа в позиÑиÑÑ
векÑоÑнÑÑ
ÑоÑек в ÑаблиÑÑ."
+#~ msgid "Points vector map to modify"
+#~ msgstr "ÐзменÑемÑй ÑоÑеÑнÑй векÑоÑнÑй ÑлоÑ"
+#~ msgid "Layer in the vector to be modified"
+#~ msgstr "ÐзменÑемÑй Ñлой векÑоÑа"
+#~ msgid "Column to be updated with the query result"
+#~ msgstr "СÑолбеÑ, коÑоÑÑй бÑÐ´ÐµÑ Ð¾Ð±Ð½Ð¾Ð²Ð»ÐµÐ½ по ÑезÑлÑÑаÑÑ Ð·Ð°Ð¿ÑоÑа"
+#~ msgid "Vector map to be queried"
+#~ msgstr "ÐапÑаÑиваемÑй векÑоÑнÑй Ñлой"
+#, fuzzy
+#~ msgid "Layer of the query vector containing data"
+#~ msgstr "Слой векÑоÑа запÑоÑа ÑодеÑжаÑего даннÑе"
+#~ msgid "Column to be queried"
+#~ msgid "Maximum query distance in map units"
+#~ msgstr "ÐакÑималÑное ÑаÑÑÑоÑние запÑоÑа в единиÑаÑ
ÑÐ»Ð¾Ñ "
#~ msgid "Name of fractal surface raster layer"
#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ ÑÑакÑалÑной повеÑÑ
ноÑÑи "
@@ -30464,6 +30024,9 @@
#~ msgid "ERROR: Problem opening output file."
#~ msgstr "ÐШÐÐÐÐ: Ðевозможно оÑкÑÑÑÑ Ð²ÑÑ
одной Ñайл."
+#~ msgid "Output drain raster map"
+#~ msgstr "ÐÑÑ
одной ÑаÑÑÑовÑй Ñлой водоÑÑока"
#~ msgid "Creates explicitly the NULL-value bitmap file."
#~ msgstr "СоздаÑÑ ÑаÑÑÑовÑй биÑмÑп Ñайл Ñ NULL-знаÑениÑми."
@@ -30520,29 +30083,61 @@
#~ msgid "%s - color table not found"
#~ msgstr "%s - ÑвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа не найдена"
-#~ msgid "Can't make logarithmic color table for floating point map"
+#, fuzzy
+#~ msgid "Can't make random color table for floating point map"
#~ msgstr ""
#~ "Ðевозможно ÑоздаÑÑ Ð»Ð¾Ð³Ð°ÑиÑмиÑеÑкÑÑ ÑвеÑовÑÑ ÑаблиÑÑ Ð´Ð»Ñ ÑÐ»Ð¾Ñ Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей "
#~ "ÑоÑкой"
-#~ msgid ""
-#~ "%s: saving [%s] raster map layer.\n"
-#~ "Percent complete:"
+#, fuzzy
+#~ msgid "Can't make grey.eq color table for floating point map"
#~ msgstr ""
-#~ "%s: ÑоÑ
-#~ "ÐÑогÑеÑÑ (пÑоÑенÑов):"
+#~ "Ðевозможно ÑоздаÑÑ Ð»Ð¾Ð³Ð°ÑиÑмиÑеÑкÑÑ ÑвеÑовÑÑ ÑаблиÑÑ Ð´Ð»Ñ ÑÐ»Ð¾Ñ Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей "
+#~ "ÑоÑкой"
-#~ msgid "Starting map [%s]"
-#~ msgstr "ÐаÑало ÑÐ»Ð¾Ñ [%s]"
+#~ msgid "Can't make logarithmic color table for floating point map"
+#~ msgstr ""
+#~ "ÑоÑкой"
-#~ msgid "Starting filter #%d, distance: %.*lf, exponent: %.*lf, flat: %.*lf"
+#, fuzzy
+#~ msgid "%s - unknown color request"
+#~ msgstr " "
+#~ msgid "new_cell is NULL"
+#~ msgstr "new_cell Ñавна NULL"
+#~ msgid "Can't find %d,%d:%f"
+#~ msgstr "Ðевозможно найÑи %d,%d:%f"
+#~ msgid "Nothing to show"
+#~ msgstr "ÐеÑего показаÑÑ"
+#~ msgid "Starting points raster map"
+#~ msgstr "ÐаÑало ÑоÑеÑного ÑаÑÑÑового ÑлоÑ"
+#~ msgid "Source map is: Integer cell type"
+#~ msgstr "ÐÑÑ
однÑй Ñлой ÑелоÑиÑленного Ñипа"
+#~ msgid "Source map is: Floating point (float) cell type"
+#~ msgstr "ÐÑÑ
однÑй Ñлой Ñипа Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой"
+#~ msgid "Source map is: Floating point (double) cell type"
+#~ msgstr "ÐÑÑ
однÑй Ñлой Ñипа Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой (double)"
+#~ msgid "Reading %s"
+#~ msgstr "ЧÑение %s"
+#~ msgid "can't open raster map [%s] needed for input coordinates"
#~ msgstr ""
-#~ "ÐаÑалÑнÑй ÑилÑÑÑ #%d, ÑаÑÑÑоÑние: %.*lf, ÑкÑпоненÑа: %.*lf, плоÑкоÑÑÑ: %."
-#~ "*lf"
+#~ "Ðевозможно оÑкÑÑÑÑ ÑаÑÑÑовÑй Ñлой [%s] необÑ
одимÑй Ð´Ð»Ñ Ð¸ÑÑ
однÑÑ
кооÑдинаÑ"
-#~ msgid "Percent done:"
-#~ msgstr "ÐÑоÑенÑов завеÑÑено:"
+#~ msgid "Writing %s"
+#~ msgstr "ÐапиÑÑ %s"
+#~ msgid "Error getting input null cells"
+#~ msgstr "ÐÑибка пÑи полÑÑении null-ÑÑеек иÑÑ
одного ÑлоÑ"
#~ msgid "CLUMP PASS %d ... "
#~ msgstr "CLUMP PASS %d ... "
@@ -30564,6 +30159,10 @@
#~ msgid "Total levels: %4d"
#~ msgstr "ÐÑего Ñлоев: %4d"
+#, fuzzy
+#~ msgid "Could not read range file"
+#~ msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñайл диапазона"
#~ msgid "Reading data: "
#~ msgstr "ЧÑение даннÑÑ
@@ -30573,6 +30172,10 @@
#~ msgid "Data range is empty"
#~ msgstr "Ðиапазон даннÑÑ
пÑÑÑ"
+#, fuzzy
+#~ msgid "Integer data range of %s is empty"
+#~ msgstr "Ðиапазон ÑелоÑиÑленнÑÑ
даннÑÑ
%s пÑÑÑ"
#~ msgid "Name of raster map layer to be used for <%s>"
#~ msgstr "Ðазвание ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¸ÑполÑзÑемого Ð´Ð»Ñ <%s>."
@@ -30625,6 +30228,10 @@
#~ "\n"
#~ "ÐÑе ÑезÑлÑÑаÑÑ Ð¿Ð¾Ð»ÑÑенÑ.\n"
+#, fuzzy
+#~ msgid "From type"
+#~ msgstr "ÐонеÑнÑй Ñип"
#~ msgid "To type"
@@ -30637,6 +30244,10 @@
#~ msgid "vector, attribute table"
#~ msgstr "векÑоÑ, аÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑаблиÑа"
+#, fuzzy
+#~ msgid "The column must be type integer or string"
+#~ msgstr "СÑÐ¾Ð»Ð±ÐµÑ Ð´Ð¾Ð»Ð¶ÐµÐ½ имеÑÑ ÑелоÑиÑленнÑй или ÑÑÑоковÑй Ñип"
#~ msgid "Select type"
#~ msgstr "ÐÑбеÑиÑе Ñип"
@@ -30691,6 +30302,10 @@
#~ msgid "%d categories read from map"
#~ msgstr "Ðз ÑÐ»Ð¾Ñ Ð¿ÑоÑиÑано %d каÑегоÑий"
+#, fuzzy
+#~ msgid "%d update/insert errors"
+#~ msgstr "найдено %d оÑибок"
#~ msgid ""
#~ "Operator defines required relation between features. A feature is written "
#~ "to output if the result of operation 'ainput operator binput' is true. An "
@@ -30707,6 +30322,10 @@
#~ msgid "Processing ainput lines ..."
#~ msgstr "ÐбÑабоÑка линий ainput..."
+#, fuzzy
+#~ msgid "Processing ainput areas ..."
+#~ msgstr "ÐбÑабоÑка линий ainput..."
#~ msgid "Writing attributes ..."
#~ msgstr "ÐапиÑÑ Ð°ÑÑибÑÑов..."
@@ -30812,6 +30431,10 @@
#~ msgid "get_img: out of memory."
#~ msgstr "get_img: Ð½ÐµÑ Ð¿Ð°Ð¼ÑÑи."
+#, fuzzy
+#~ msgid "Subgroup [%s] in group [%s] contains no files."
+#~ msgstr "ÐодгÑÑппа [%s] в гÑÑппе [%s] не ÑодеÑÐ¶Ð¸Ñ Ñайлов."
#~ msgid "Writing [%s] ..."
#~ msgstr "ÐапиÑÑ [%s] ..."
@@ -30830,6 +30453,10 @@
#~ msgid "Ordering eigenvalues in descending order..."
#~ msgstr "СоÑÑиÑовка eigen-знаÑений по-ÑбÑваниÑ..."
+#, fuzzy
+#~ msgid "Transposing eigen matrix..."
+#~ msgstr "ТÑанÑпониÑоваÑÑ eigen-маÑÑиÑÑ..."
#~ msgid "Cannot write color table of raster map <%s>"
#~ msgstr "Ðевозможно запиÑаÑÑ ÑвеÑовÑÑ ÑаблиÑÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
@@ -30848,6 +30475,10 @@
#~ msgid "Resultant signature file"
#~ msgstr "ÐÑÑ
одной Ñайл ÑигнаÑÑÑ"
+#, fuzzy
+#~ msgid "1 class."
+#~ msgstr "%d клаÑÑов."
#~ msgid "%d classes."
@@ -30874,13 +30505,31 @@
#~ msgid "FFT completed..."
#~ msgstr "FFT завеÑÑен..."
+#, fuzzy
+#~ msgid ""
+#~ "\n"
+#~ " group <%s> not found"
+#~ msgstr "ÐÑÑппа <%s> не найдена"
#~ msgid "subgroup <%s> not found"
#~ msgstr "подгÑÑппа <%s> не найдена"
+#, fuzzy
+#~ msgid "Subgroup [%s] doesn't have any files"
+#~ msgstr " ."
+#, fuzzy
+#~ msgid "The subgroup must have at least 2 files to run %s"
+#~ msgstr " ."
#~ msgid "Unable to proceed"
#~ msgstr "Ðевозможно пÑодолжиÑÑ"
#, fuzzy
+#~ msgid "Can't open seed signature file <%s>"
+#~ msgstr "** Ðевозможно оÑкÑÑÑÑ Ñайл ÑÑалонов заÑÑавок <%s> **"
+#, fuzzy
#~ msgid "Can't read signature file <%s>"
#~ msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñайл ÑÑалонов [%s]."
@@ -30890,6 +30539,22 @@
#~ msgid "Subgroup name in the above group"
#~ msgstr "ÐÐ¼Ñ Ð¿Ð¾Ð´Ð³ÑÑÐ¿Ð¿Ñ Ð² гÑÑппе"
+#, fuzzy
+#~ msgid "File containing initial signatures"
+#~ msgstr "Файл ÑодеÑжаÑий иÑÑ
однÑе ÑÑалонÑ"
+#, fuzzy
+#~ msgid "Output file to contain final report"
+#~ msgstr "ÐÑÑ
одной Ñайла оÑÑÑÑа"
+#, fuzzy
+#~ msgid ""
+#~ "\n"
+#~ "<%s> -- illegal value of min_size"
+#~ msgstr ""
+#~ "\n"
+#~ "<%s> -- непÑавилÑное знаÑение min_size"
#~ msgid "Can't creat reportfile: "
#~ msgstr "Ðевозможно ÑоздаÑÑ Ñайл оÑÑеÑа:"
@@ -31032,6 +30697,9 @@
#~ "values;terrain;global elevation color table covering -11000 to +8850m;"
#~ "wave;color wave;"
+#~ msgid "Path to rules file"
+#~ msgstr "ÐÑÑÑ Ðº Ñайлам пÑавил"
#~ msgid "Do not print polyline info"
#~ msgstr "Ðе вÑводиÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ полилинии"
@@ -31143,6 +30811,10 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "Name of input raster map(s)"
+#~ msgstr "Ðазвание вводного ÑаÑÑÑового ÑлоÑ"
+#, fuzzy
#~ msgid "Output file extension (inputfile(s) + extension)"
#~ msgstr " "
@@ -31165,10 +30837,6 @@
#~ msgstr "ÐÐ¼Ñ ÑаÑÑÑового Ñайла-маÑки"
#, fuzzy
-#~ msgid "Output"
-#~ msgstr " "
-#, fuzzy
#~ msgid ""
#~ "Not enough data columns. Incorrect delimiter or column number?\n"
#~ "[%s]"
@@ -31209,6 +30877,10 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "Adding files to group [%s]"
+#~ msgstr " "
+#, fuzzy
#~ msgid "Adding files to subgroup [%s]"
#~ msgstr " "
@@ -31221,6 +30893,10 @@
#~ msgstr " ."
#, fuzzy
+#~ msgid "Found file <%s@%s> in subgroup."
+#~ msgstr " ."
+#, fuzzy
#~ msgid "Unable to open file: <%s>"
#~ msgstr " ."
@@ -31367,6 +31043,10 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "region <%s> not found"
+#~ msgstr "Регион <%s> не найден"
+#, fuzzy
#~ msgid "can't read region <%s> in <%s>"
#~ msgstr " "
@@ -31379,6 +31059,10 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "can't open vector map <%s> in <%s>"
+#~ msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s> в <%s>"
+#, fuzzy
#~ msgid "invalid region: %s"
#~ msgstr " "
@@ -31431,6 +31115,10 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "elevation file [%s] not found"
+#~ msgstr " "
+#, fuzzy
#~ msgid "min computed aspect %.4f max computed aspect %.4f"
#~ msgstr "ÐкÑпозиÑÐ¸Ñ ÐкÑпозиÑиÑ"
@@ -31765,6 +31453,10 @@
#~ msgstr "векÑоÑ"
#, fuzzy
+#~ msgid "Parameter <%s> not set"
+#~ msgstr "Ðе Ñказан обÑзаÑелÑнÑй паÑамеÑÑ <%s>"
+#, fuzzy
#~ msgid "Input map containing lines"
#~ msgstr "векÑоÑ"
@@ -31773,6 +31465,10 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "Cannot get layer information for vector map"
+#~ msgstr "векÑоÑ"
+#, fuzzy
#~ msgid "<%s> cellfile not found"
#~ msgstr " "
@@ -31857,6 +31553,10 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "Cannot open file for <%s>"
+#~ msgstr " "
+#, fuzzy
#~ msgid "%s: Unable to find raster map <%s>"
#~ msgstr " "
@@ -31938,6 +31638,10 @@
#~ msgstr " ."
#, fuzzy
+#~ msgid "[%s] is an illegal name"
+#~ msgstr " "
+#, fuzzy
#~ msgid "Could not open <%s>"
#~ msgstr " "
@@ -32010,6 +31714,10 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "Error reading map %s"
+#~ msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
+#, fuzzy
#~ msgid "<%s> is not a valid GRASS map name"
#~ msgstr " "
@@ -32054,6 +31762,10 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
+#~ msgstr "Ðе найден ÑаÑÑÑовÑй Ñлой <%s> в облаÑÑи <%s> в набоÑе <%s>"
+#, fuzzy
#~ msgid "Error writing output map"
#~ msgstr " "
@@ -32086,6 +31798,10 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "%s in %s -can't open raster map"
+#~ msgstr " "
+#, fuzzy
#~ msgid "%s - can't create raster map"
#~ msgstr " "
@@ -32256,6 +31972,10 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "name for new vector map"
+#~ msgstr "векÑоÑ"
+#, fuzzy
#~ msgid "name for new vector map (omit for display to stdout)"
#~ msgstr "векÑоÑ"
@@ -32492,6 +32212,10 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "Unable to write color table to raster [%s]"
+#~ msgstr " "
+#, fuzzy
#~ msgid "Cannot find map %s"
#~ msgstr " "
@@ -32951,3 +32675,127 @@
#~ msgid ""
#~ "Vect runs out of region and re-enters - this case is not yet implemented!"
#~ msgstr " !"
+#, fuzzy
+#~ msgid "Name of raster map to print in legend"
+#, fuzzy
+#~ msgid "Split the display into subframes."
+#, fuzzy
+#~ msgid "Number of subframes"
+#~ msgstr "ЧиÑло ÑÑеймов"
+#, fuzzy
+#~ msgid "display, vector, thematic, legend"
+#~ msgstr "диÑплей, легенда "
+#, fuzzy
+#~ msgid "Break points for custom breaks option"
+#~ msgstr ""
+#~ "10 20 30 ...)"
+#, fuzzy
+#~ msgid "Icon size for point data"
даннÑÑ
+#, fuzzy
+#~ msgid "Minimum icon size/line width for graduated points/lines)"
+#~ msgstr ""
ÑоÑек и линий"
+#, fuzzy
+#~ msgid "Color for graduated points map"
+#~ msgstr "Ð¦Ð²ÐµÑ Ð´Ð»Ñ Ð´Ð°Ð½Ð½ÑÑ
Y"
+#, fuzzy
+#~ msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
+#~ msgstr ""
+#~ "Ð¦Ð²ÐµÑ Ð´Ð»Ñ Ð³ÑадÑиÑованного ÑÐ»Ð¾Ñ ÑоÑек (ÑÐ²ÐµÑ grass или ÑÑÐ¸Ð¿Ð»ÐµÑ R:G:B). "
+#~ "ÐÑбеÑиÑе ÑвеÑовÑÑ ÑÑ
+#, fuzzy
+#~ msgid ""
+#~ "GRASS named color or R:G:B triplet. Set color scheme to single color."
+#~ msgstr ""
+#, fuzzy
+#~ msgid "Must be expressed as R:G:B triplet"
+#~ msgstr ""
+#, fuzzy
+#~ msgid "imagery, fusion, Brovey"
+#~ msgstr "ÑаÑÑÑ, изобÑажениÑ, ÑлиÑние"
+#, fuzzy
+#~ msgid "LANDSAT sensor"
+#, fuzzy
+#~ msgid "Raster input maps"
+#~ msgstr "иÑÑ
однÑе ÑаÑÑÑовÑе Ñлои"
+#, fuzzy
+#~ msgid "Color using standard deviation bands"
+#~ msgstr ""
+#~ "ÑÑедние и ÑÑандаÑÑнÑе оÑÐºÐ»Ð¾Ð½ÐµÐ½Ð¸Ñ Ð´Ð»Ñ %d band%s\n"
+#~ "\n"
+#, fuzzy
+#~ msgid "vector, color table"
+#~ msgstr "ÑаÑÑÑ, ÑвеÑÐ¾Ð²Ð°Ñ ÑаблиÑа"
+#, fuzzy
+#~ msgid "Name of column containg numeric data"
+#~ msgstr "ÐÐ¼Ñ ÑÑолбÑа, ÑодеÑжаÑего кооÑдинаÑÑ x"
+#, fuzzy
+#~ msgid "Layer number of data column"
+#, fuzzy
+#~ msgid "Name of color column to populate"
+#~ msgstr "ÐÐ¼Ñ Ð¿Ð¾ÐºÐ°Ð·Ñваемого полÑ"
+#, fuzzy
+#~ msgid "Manually set range (min,max)"
+#~ msgstr "ЦелоÑиÑленнÑй диапазон: минимÑм, макÑимÑм"
+#, fuzzy
+#~ msgid "Name of old database"
+#, fuzzy
+#~ msgid "vector, export, GPS"
+#, fuzzy
+#~ msgid "Export as waypoints"
ÑоÑек"
+#, fuzzy
+#~ msgid "Export as routes"
+#, fuzzy
+#~ msgid "Export as tracks"
+#, fuzzy
+#~ msgid "Feature type(s)"
+#~ msgstr "Тип обÑекÑа"
+#, fuzzy
+#~ msgid "Name for output file or GPS device"
одного Ñайла"
+#, fuzzy
+#~ msgid "GpsBabel supported output format"
+#~ msgstr "ÐеÑеÑиÑлиÑÑ Ð¿Ð¾Ð´Ð´ÐµÑживаемÑе вÑÑ
однÑе ÑоÑмаÑÑ"
Modified: grass/branches/develbranch_6/locale/po/grasstcl_es.po
--- grass/branches/develbranch_6/locale/po/grasstcl_es.po 2009-05-22 15:36:57 UTC (rev 37374)
+++ grass/branches/develbranch_6/locale/po/grasstcl_es.po 2009-05-22 15:53:49 UTC (rev 37375)
@@ -11,7 +11,7 @@
msgstr ""
"Project-Id-Version: grasstcl_es\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2009-01-29 21:41+0100\n"
+"POT-Creation-Date: 2009-05-22 17:09+0200\n"
"PO-Revision-Date: 2008-08-04 11:00+0200\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -42,7 +42,7 @@
msgstr "Configuración ya abierta"
#: ../vector/v.digit/settings.tcl:174 ../lib/init/epsg_option.tcl:311
-#: ../lib/init/file_option.tcl:263 ../gui/tcltk/gis.m/gm.tcl:455
+#: ../lib/init/file_option.tcl:264 ../gui/tcltk/gis.m/gm.tcl:455
#: ../gui/tcltk/gis.m/animate.tcl:536 ../gui/tcltk/gis.m/dnviz.tcl:228
#: ../gui/tcltk/gis.m/rules.tcl:170
msgid "OK"
@@ -286,17 +286,17 @@
msgstr "Ok"
#: ../lib/gtcltk/select.tcl:210 ../lib/init/epsg_option.tcl:167
-#: ../lib/init/epsg_option.tcl:314 ../lib/init/file_option.tcl:114
-#: ../lib/init/file_option.tcl:266 ../gui/tcltk/gis.m/gm.tcl:458
+#: ../lib/init/epsg_option.tcl:314 ../lib/init/file_option.tcl:115
+#: ../lib/init/file_option.tcl:267 ../gui/tcltk/gis.m/gm.tcl:458
#: ../gui/tcltk/gis.m/animate.tcl:538 ../gui/tcltk/gis.m/dnviz.tcl:230
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:859 ../gui/tcltk/gis.m/georect.tcl:703
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:901 ../gui/tcltk/gis.m/georect.tcl:703
#: ../gui/tcltk/gis.m/rules.tcl:172
msgid "Cancel"
msgstr "Cancelar"
#: ../lib/gis/gui.tcl:11 ../lib/gis/gui.tcl:15 ../lib/gis/gui.tcl:19
-#: ../lib/gis/gui.tcl:310 ../gui/tcltk/gis.m/runandoutput.tcl:270
-#: ../gui/tcltk/gis.m/runandoutput.tcl:276
+#: ../lib/gis/gui.tcl:310 ../gui/tcltk/gis.m/runandoutput.tcl:277
+#: ../gui/tcltk/gis.m/runandoutput.tcl:283
#: ../gui/tcltk/gis.m/grassabout.tcl:94 ../gui/tcltk/gis.m/gmlib.tcl:141
msgid "Error"
msgstr "Error"
@@ -310,7 +310,7 @@
msgstr "Cargar archivo"
#: ../lib/gis/gui.tcl:295 ../lib/gis/gui.tcl:485
-#: ../gui/tcltk/gis.m/gmmenu.tcl:335
+#: ../gui/tcltk/gis.m/gmmenu.tcl:336
msgid "Output"
msgstr "Salida"
@@ -328,7 +328,7 @@
msgstr "Copiar"
#: ../lib/gis/gui.tcl:508 ../gui/tcltk/gis.m/runandoutput.tcl:44
-#: ../gui/tcltk/gis.m/runandoutput.tcl:116
+#: ../gui/tcltk/gis.m/runandoutput.tcl:118
msgid "Run"
msgstr "Ejecutar"
@@ -347,7 +347,7 @@
#: ../gui/tcltk/gis.m/legend.tcl:219 ../gui/tcltk/gis.m/legend.tcl:222
#: ../gui/tcltk/gis.m/raster.tcl:192 ../gui/tcltk/gis.m/raster.tcl:196
#: ../gui/tcltk/gis.m/chart.tcl:184 ../gui/tcltk/gis.m/chart.tcl:188
-#: ../gui/tcltk/gis.m/vector.tcl:330 ../gui/tcltk/gis.m/vector.tcl:334
+#: ../gui/tcltk/gis.m/vector.tcl:327 ../gui/tcltk/gis.m/vector.tcl:331
#: ../gui/tcltk/gis.m/barscale.tcl:180 ../gui/tcltk/gis.m/barscale.tcl:184
#: ../gui/tcltk/gis.m/rgbhis.tcl:156 ../gui/tcltk/gis.m/rgbhis.tcl:165
#: ../gui/tcltk/gis.m/dtext.tcl:177 ../gui/tcltk/gis.m/dtext.tcl:181
@@ -414,7 +414,7 @@
msgid "Define location using EPSG projection codes"
msgstr "Definir localización usando códigos de proyección EPSG"
-#: ../lib/init/epsg_option.tcl:122 ../lib/init/file_option.tcl:92
+#: ../lib/init/epsg_option.tcl:122 ../lib/init/file_option.tcl:93
msgid "Name of new location"
msgstr "Nombre de la nueva localización"
@@ -427,7 +427,7 @@
msgstr "Ruta al archivo de códigos EPSG"
#: ../lib/init/epsg_option.tcl:135 ../lib/init/epsg_option.tcl:148
-#: ../lib/init/gis_set.tcl:243 ../lib/init/file_option.tcl:105
+#: ../lib/init/gis_set.tcl:243 ../lib/init/file_option.tcl:106
msgid "Browse..."
msgstr "Explorar..."
@@ -455,7 +455,7 @@
msgid "WARNING: The epsg-codes file was not found!"
msgstr "AVISO: ¡El archivo de códigos EPSG no se encontró!"
-#: ../lib/init/epsg_option.tcl:164 ../lib/init/file_option.tcl:111
+#: ../lib/init/epsg_option.tcl:164 ../lib/init/file_option.tcl:112
msgid "Define location"
msgstr "Definir la localización"
@@ -478,12 +478,12 @@
msgstr "AVISO: la localización '%s' ya existe: por favor, pruebe otro nombre."
#: ../lib/init/epsg_option.tcl:236 ../lib/init/epsg_option.tcl:263
-#: ../lib/init/file_option.tcl:185 ../lib/init/file_option.tcl:212
+#: ../lib/init/file_option.tcl:186 ../lib/init/file_option.tcl:213
msgid "Error creating location!"
msgstr "¡Error al crear localización!"
#: ../lib/init/epsg_option.tcl:237 ../lib/init/epsg_option.tcl:264
-#: ../lib/init/file_option.tcl:186 ../lib/init/file_option.tcl:213
+#: ../lib/init/file_option.tcl:187 ../lib/init/file_option.tcl:214
#, tcl-format
msgid ""
"g.proj returned the following message:\n"
@@ -493,12 +493,12 @@
"%s"
#: ../lib/init/epsg_option.tcl:244 ../lib/init/epsg_option.tcl:268
-#: ../lib/init/file_option.tcl:193 ../lib/init/file_option.tcl:217
+#: ../lib/init/file_option.tcl:194 ../lib/init/file_option.tcl:218
msgid "Informational output from g.proj"
msgstr "Salida informativa de g.proj"
#: ../lib/init/epsg_option.tcl:245 ../lib/init/epsg_option.tcl:269
-#: ../lib/init/file_option.tcl:194 ../lib/init/file_option.tcl:218
+#: ../lib/init/file_option.tcl:195 ../lib/init/file_option.tcl:219
#, tcl-format
msgid ""
"g.proj returned the following informational message:\n"
@@ -507,11 +507,11 @@
"g.proj devolvió el siguiente mensaje informativo:\n"
"%s"
-#: ../lib/init/epsg_option.tcl:288 ../lib/init/file_option.tcl:240
+#: ../lib/init/epsg_option.tcl:288 ../lib/init/file_option.tcl:241
msgid "Select datum transformation parameters:"
msgstr "Seleccionar parámetros de transformación del datum:"
-#: ../lib/init/epsg_option.tcl:292 ../lib/init/file_option.tcl:244
+#: ../lib/init/epsg_option.tcl:292 ../lib/init/file_option.tcl:245
msgid ""
"Continue without specifying parameters - if used when creating a location, "
"other GRASS modules will use the \"default\" (likely non-optimum) parameters "
@@ -570,9 +570,9 @@
"Mensaje de error: %s"
#: ../lib/init/gis_set.tcl:128 ../lib/init/gis_set.tcl:379
-#: ../lib/init/gis_set.tcl:485 ../lib/init/gis_set.tcl:606
-#: ../lib/init/gis_set.tcl:627 ../lib/init/gis_set.tcl:645
-#: ../lib/init/gis_set.tcl:673
+#: ../lib/init/gis_set.tcl:485 ../lib/init/gis_set.tcl:617
+#: ../lib/init/gis_set.tcl:638 ../lib/init/gis_set.tcl:656
+#: ../lib/init/gis_set.tcl:684
msgid "WARNING: invalid location"
msgstr "AVISO: localización no válida"
@@ -700,7 +700,7 @@
"AVISO: la localización seleccionada <%s> no es válida. \n"
"Intentar de nuevo con una localización válida."
-#: ../lib/init/gis_set.tcl:491 ../lib/init/gis_set.tcl:651
+#: ../lib/init/gis_set.tcl:491 ../lib/init/gis_set.tcl:662
msgid "WARNING: invalid mapset"
msgstr "AVISO: directorio de mapas no válido"
@@ -718,17 +718,33 @@
msgstr "Salir"
#: ../lib/init/gis_set.tcl:559
+msgid "Starting GRASS for the first time"
+msgstr ""
+#: ../lib/init/gis_set.tcl:560
+msgid ""
+"GRASS needs a directory in which to store its data. Create one now if you "
+"have not already done so. A popular choice is \"grassdata\", located in "
+"your home directory."
+msgstr ""
+#: ../lib/init/gis_set.tcl:565
+#, fuzzy
+msgid "Select GIS data directory"
+msgstr "Nuevo directorio de datos GIS"
+#: ../lib/init/gis_set.tcl:570
msgid "WARNING: Invalid Database"
msgstr "AVISO: La base de datos no es válida"
-#: ../lib/init/gis_set.tcl:560
+#: ../lib/init/gis_set.tcl:571
msgid "WARNING: Invalid database. Finding first valid directory in parent tree"
msgstr ""
"AVISO: La base de datos no es válida. Buscando el primer directorio válido "
"en directorios superiores"
-#: ../lib/init/gis_set.tcl:607 ../lib/init/gis_set.tcl:628
-#: ../lib/init/gis_set.tcl:646 ../lib/init/gis_set.tcl:674
+#: ../lib/init/gis_set.tcl:618 ../lib/init/gis_set.tcl:639
+#: ../lib/init/gis_set.tcl:657 ../lib/init/gis_set.tcl:685
#, tcl-format
msgid ""
"Warning: selected location <%%s> is not valid. \n"
@@ -737,16 +753,16 @@
"AVISO: la localización seleccionada <%%s> no es válida. \n"
-#: ../lib/init/gis_set.tcl:652
+#: ../lib/init/gis_set.tcl:663
#, tcl-format
msgid "Warning: <%%s> is not a valid mapset"
msgstr "AVISO: <%%s> no es un directorio de mapas válido"
-#: ../lib/init/gis_set.tcl:746
+#: ../lib/init/gis_set.tcl:757
msgid "WARNING: change directory failed"
msgstr "AVISO: falló el cambio de directorio"
-#: ../lib/init/gis_set.tcl:747
+#: ../lib/init/gis_set.tcl:758
#, tcl-format
msgid ""
"Warning: could not change directory to <%s>.\n"
@@ -755,34 +771,34 @@
"Aviso: no se pudo cambiar el directorio a <%s>.\n"
"Compruebe los permisos del directorio."
-#: ../lib/init/file_option.tcl:72
+#: ../lib/init/file_option.tcl:73
msgid "Define location using projection information in georeferenced file"
msgstr ""
"Definir localización usando la proyección contenida en archivo "
"georreferenciado"
-#: ../lib/init/file_option.tcl:95
+#: ../lib/init/file_option.tcl:96
msgid "Enter name of location to be created"
msgstr "Introducir nombre de la nueva localización"
-#: ../lib/init/file_option.tcl:99
+#: ../lib/init/file_option.tcl:100
msgid "Path to georeferenced file"
msgstr "Ruta de archivo georreferenciado"
-#: ../lib/init/file_option.tcl:102
+#: ../lib/init/file_option.tcl:103
msgid "Path to georeferenced file (format must be readable by GDAL/OGR)"
msgstr ""
"Ruta a archivo georreferenciado (el formato debe ser legible por GDAL/OGR)"
-#: ../lib/init/file_option.tcl:106
+#: ../lib/init/file_option.tcl:107
msgid "Browse to locate georeferenced file"
msgstr "Buscar archivo georreferenciado"
-#: ../lib/init/file_option.tcl:131 ../lib/init/file_option.tcl:134
+#: ../lib/init/file_option.tcl:132 ../lib/init/file_option.tcl:135
msgid "Choose georeferenced file"
msgstr "Elegir archivo georreferenciado"
-#: ../lib/init/file_option.tcl:152
+#: ../lib/init/file_option.tcl:153
msgid ""
"WARNING: Please supply a\n"
"valid georeferenced file"
@@ -792,16 +808,16 @@
#: ../gui/tcltk/gis.m/thematic.tcl:107 ../gui/tcltk/gis.m/thematic.tcl:607
#: ../gui/tcltk/gis.m/thematic.tcl:680 ../gui/tcltk/gis.m/labels.tcl:78
#: ../gui/tcltk/gis.m/labels.tcl:279 ../gui/tcltk/gis.m/rastnums.tcl:79
-#: ../gui/tcltk/gis.m/rastnums.tcl:360 ../gui/tcltk/gis.m/frames.tcl:78
+#: ../gui/tcltk/gis.m/rastnums.tcl:369 ../gui/tcltk/gis.m/frames.tcl:78
#: ../gui/tcltk/gis.m/frames.tcl:275 ../gui/tcltk/gis.m/animate.tcl:91
#: ../gui/tcltk/gis.m/mapprint.tcl:194 ../gui/tcltk/gis.m/mapprint.tcl:201
#: ../gui/tcltk/gis.m/gridline.tcl:99 ../gui/tcltk/gis.m/gridline.tcl:406
#: ../gui/tcltk/gis.m/legend.tcl:95 ../gui/tcltk/gis.m/legend.tcl:506
#: ../gui/tcltk/gis.m/raster.tcl:86 ../gui/tcltk/gis.m/raster.tcl:463
#: ../gui/tcltk/gis.m/chart.tcl:89 ../gui/tcltk/gis.m/chart.tcl:441
-#: ../gui/tcltk/gis.m/vector.tcl:194 ../gui/tcltk/gis.m/vector.tcl:819
+#: ../gui/tcltk/gis.m/vector.tcl:191 ../gui/tcltk/gis.m/vector.tcl:816
#: ../gui/tcltk/gis.m/cmd.tcl:75 ../gui/tcltk/gis.m/cmd.tcl:206
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:212 ../gui/tcltk/gis.m/mapcanvas.tcl:222
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:224 ../gui/tcltk/gis.m/mapcanvas.tcl:234
#: ../gui/tcltk/gis.m/barscale.tcl:91 ../gui/tcltk/gis.m/barscale.tcl:401
#: ../gui/tcltk/gis.m/rgbhis.tcl:83 ../gui/tcltk/gis.m/rgbhis.tcl:362
#: ../gui/tcltk/gis.m/dtext.tcl:92 ../gui/tcltk/gis.m/dtext.tcl:401
@@ -838,7 +854,7 @@
#: ../gui/tcltk/gis.m/labels.tcl:118 ../gui/tcltk/gis.m/rastnums.tcl:146
#: ../gui/tcltk/gis.m/gridline.tcl:147 ../gui/tcltk/gis.m/legend.tcl:200
#: ../gui/tcltk/gis.m/raster.tcl:168 ../gui/tcltk/gis.m/chart.tcl:166
-#: ../gui/tcltk/gis.m/vector.tcl:306 ../gui/tcltk/gis.m/cmd.tcl:105
+#: ../gui/tcltk/gis.m/vector.tcl:303 ../gui/tcltk/gis.m/cmd.tcl:105
#: ../gui/tcltk/gis.m/barscale.tcl:160 ../gui/tcltk/gis.m/rgbhis.tcl:143
#: ../gui/tcltk/gis.m/dtext.tcl:166 ../gui/tcltk/gis.m/histogram.tcl:145
msgid "Opaque "
@@ -886,7 +902,7 @@
msgid " scale factor for computing arrow length"
msgstr "Factor de escala para calcular la longitud del norte. "
-#: ../gui/tcltk/gis.m/thematic.tcl:129 ../gui/tcltk/gis.m/vector.tcl:220
+#: ../gui/tcltk/gis.m/thematic.tcl:129 ../gui/tcltk/gis.m/vector.tcl:217
#: ../gui/tcltk/d.m/menu.tcl:94 ../gui/tcltk/d.m/menu.tcl:134
msgid "Vector map"
msgstr "Mapa vectorial"
@@ -907,7 +923,7 @@
msgid "Select font"
msgstr "Seleccionar fuente"
-#: ../gui/tcltk/gis.m/thematic.tcl:194 ../gui/tcltk/gis.m/vector.tcl:281
+#: ../gui/tcltk/gis.m/thematic.tcl:194 ../gui/tcltk/gis.m/vector.tcl:278
msgid "Vector point symbol"
msgstr "SÃmbolo de punto vectorial"
@@ -921,7 +937,7 @@
msgid " or by graduated sizes (points and lines)"
msgstr " o por tamaños graduados (puntos y lÃneas)"
-#: ../gui/tcltk/gis.m/thematic.tcl:233 ../gui/tcltk/gis.m/vector.tcl:316
+#: ../gui/tcltk/gis.m/thematic.tcl:233 ../gui/tcltk/gis.m/vector.tcl:313
#: ../gui/tcltk/d.m/thematic.tcl:116
msgid "Vector map:"
msgstr "Mapa vectorial:"
@@ -948,13 +964,13 @@
msgstr "mostrar columnas de atributos"
#: ../gui/tcltk/gis.m/thematic.tcl:269 ../gui/tcltk/gis.m/chart.tcl:213
-#: ../gui/tcltk/gis.m/vector.tcl:484 ../gui/tcltk/d.m/thematic.tcl:151
+#: ../gui/tcltk/gis.m/vector.tcl:481 ../gui/tcltk/d.m/thematic.tcl:151
#: ../gui/tcltk/d.m/chart.tcl:121 ../gui/tcltk/d.m/vector.tcl:349
msgid "columns"
msgstr "columnas"
#: ../gui/tcltk/gis.m/thematic.tcl:273 ../gui/tcltk/gis.m/chart.tcl:217
-#: ../gui/tcltk/gis.m/vector.tcl:488 ../gui/tcltk/d.m/thematic.tcl:155
+#: ../gui/tcltk/gis.m/vector.tcl:485 ../gui/tcltk/d.m/thematic.tcl:155
#: ../gui/tcltk/d.m/chart.tcl:125 ../gui/tcltk/d.m/vector.tcl:353
msgid "Show columns"
msgstr "mostrar columnas"
@@ -964,13 +980,13 @@
msgstr "mostrar datos"
#: ../gui/tcltk/gis.m/thematic.tcl:275 ../gui/tcltk/gis.m/chart.tcl:219
-#: ../gui/tcltk/gis.m/vector.tcl:490 ../gui/tcltk/d.m/thematic.tcl:157
+#: ../gui/tcltk/gis.m/vector.tcl:487 ../gui/tcltk/d.m/thematic.tcl:157
#: ../gui/tcltk/d.m/vector.tcl:355
msgid "data"
msgstr "datos"
#: ../gui/tcltk/gis.m/thematic.tcl:279 ../gui/tcltk/gis.m/chart.tcl:223
-#: ../gui/tcltk/gis.m/vector.tcl:494 ../gui/tcltk/d.m/thematic.tcl:161
+#: ../gui/tcltk/gis.m/vector.tcl:491 ../gui/tcltk/d.m/thematic.tcl:161
#: ../gui/tcltk/d.m/vector.tcl:359
msgid "Show data"
msgstr "Mostrar datos"
@@ -1143,7 +1159,7 @@
msgid "r.univar error"
msgstr "error de r.univar"
-#: ../gui/tcltk/gis.m/profile.tcl:415 ../gui/tcltk/gis.m/mapcanvas.tcl:435
+#: ../gui/tcltk/gis.m/profile.tcl:415 ../gui/tcltk/gis.m/mapcanvas.tcl:449
msgid "g.proj or projection error"
msgstr "error de g.prog o de proyección"
@@ -1179,7 +1195,12 @@
msgid "Zero elevation range"
msgstr "Rango de elevación cero"
-#: ../gui/tcltk/gis.m/profile.tcl:534 ../gui/tcltk/gis.m/profile.tcl:619
+#: ../gui/tcltk/gis.m/profile.tcl:542
+#, fuzzy
+msgid "Error reading region values"
+msgstr "Error al establecer la región"
+#: ../gui/tcltk/gis.m/profile.tcl:566 ../gui/tcltk/gis.m/profile.tcl:651
msgid "r.profile error"
msgstr "error de r.profile"
@@ -1270,42 +1291,38 @@
msgid "GRASS%s GIS Manager - %s %s"
msgstr "Administrador GIS - %s %s de GRASS%s"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:119
+#: ../gui/tcltk/gis.m/runandoutput.tcl:121
msgid "Run (background)"
msgstr "Ejecutar (segundo plano)"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:122
+#: ../gui/tcltk/gis.m/runandoutput.tcl:124
msgid "Run (GUI)"
msgstr "Ejecutar (GUI)"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:125
-msgid "Run (in Xterm)"
-msgstr "Ejecutar (en Xterm)"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:129
+#: ../gui/tcltk/gis.m/runandoutput.tcl:136
#, fuzzy
msgid " Save "
msgstr "Guardar"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:131
+#: ../gui/tcltk/gis.m/runandoutput.tcl:138
#, fuzzy
msgid " Clear "
msgstr "Limpiar"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:152
+#: ../gui/tcltk/gis.m/runandoutput.tcl:159
msgid "Output - GIS.m"
msgstr "Salida - GIS.m"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:254
+#: ../gui/tcltk/gis.m/runandoutput.tcl:261
#, fuzzy
msgid "X Windows not available"
msgstr "GhostScript no disponible"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:255
+#: ../gui/tcltk/gis.m/runandoutput.tcl:262
msgid "Functions that require X Windows are not available in Windows"
msgstr ""
-#: ../gui/tcltk/gis.m/runandoutput.tcl:277
+#: ../gui/tcltk/gis.m/runandoutput.tcl:284
msgid "This module requires X11 support, but no xmons were found"
msgstr ""
"Este módulo requiere soporte para X11, pero no se encontró ningún monitor X "
@@ -1376,8 +1393,8 @@
"Establecer la extensión de la región computacional para ajustar a la "
"visualización"
-#: ../gui/tcltk/gis.m/maptool.tcl:229 ../gui/tcltk/gis.m/gmmenu.tcl:626
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1865 ../gui/tcltk/d.m/menu.tcl:559
+#: ../gui/tcltk/gis.m/maptool.tcl:229 ../gui/tcltk/gis.m/gmmenu.tcl:631
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1928 ../gui/tcltk/d.m/menu.tcl:560
msgid "Query"
msgstr "Consultas"
@@ -1413,7 +1430,7 @@
msgid "(* requires gdal)"
msgstr "(* requiere gdal)"
-#: ../gui/tcltk/gis.m/maptool.tcl:327
+#: ../gui/tcltk/gis.m/maptool.tcl:327 ../gui/tcltk/gis.m/rastnums.tcl:282
msgid "Constrain map to region geometry"
msgstr "Restringir mapa a la geometrÃa de la región"
@@ -1482,7 +1499,7 @@
msgid "use raster colors for cell values"
msgstr "usar colores de ráster para valores de celda"
-#: ../gui/tcltk/gis.m/rastnums.tcl:273
+#: ../gui/tcltk/gis.m/rastnums.tcl:274
msgid ""
"Cell values can only be displayed\n"
"for regions of < 10,000 cells"
@@ -1490,6 +1507,24 @@
"Los valores de celda sólo se pueden mostrar\n"
"para regiones de menos de 10.000 celdas"
+#: ../gui/tcltk/gis.m/rastnums.tcl:279
+#, fuzzy
+msgid "Constrain map to region geometry?"
+msgstr "Restringir mapa a la geometrÃa de la región"
+#: ../gui/tcltk/gis.m/rastnums.tcl:280
+msgid ""
+"Cell values can only be displayed for \n"
+"regions of < 10,000 cells. Map in explore mode may contain more than 10,000 "
+"cells.\n"
+"\n"
+" It's suggested to constrain map to region geometry to display cell values."
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:282
+msgid "Leave in explore mode"
+msgstr ""
#: ../gui/tcltk/gis.m/frames.tcl:105
msgid "Divide map display into frames for displaying multiple maps"
msgstr ""
@@ -1792,7 +1827,7 @@
msgid "Open..."
msgstr "Abrir..."
-#: ../gui/tcltk/gis.m/gmmenu.tcl:88 ../gui/tcltk/gis.m/mapcanvas.tcl:863
+#: ../gui/tcltk/gis.m/gmmenu.tcl:88 ../gui/tcltk/gis.m/mapcanvas.tcl:905
#: ../gui/tcltk/d.m/menu.tcl:174
msgid "Save"
msgstr "Guardar"
@@ -2113,1154 +2148,1159 @@
msgstr "Cambiar configuración"
#: ../gui/tcltk/gis.m/gmmenu.tcl:217 ../gui/tcltk/d.m/menu.tcl:200
+msgid "Change default GUI"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:218 ../gui/tcltk/d.m/menu.tcl:201
msgid "Show current GRASS version"
msgstr "Mostrar versión de GRASS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:219 ../gui/tcltk/gis.m/gmmenu.tcl:220
-#: ../gui/tcltk/d.m/menu.tcl:202
+#: ../gui/tcltk/gis.m/gmmenu.tcl:220 ../gui/tcltk/gis.m/gmmenu.tcl:221
+#: ../gui/tcltk/d.m/menu.tcl:203
msgid "Manage projections"
msgstr "Administrar proyecciones"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:221
+#: ../gui/tcltk/gis.m/gmmenu.tcl:222
msgid "Projection for current location"
msgstr "Proyección para la localización actual"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:223
+#: ../gui/tcltk/gis.m/gmmenu.tcl:224
msgid "Convert coordinates"
msgstr "Convertir coordenadas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:225
+#: ../gui/tcltk/gis.m/gmmenu.tcl:226
msgid "Display font"
msgstr "Visualizar fuentes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:227 ../gui/tcltk/d.m/menu.tcl:220
+#: ../gui/tcltk/gis.m/gmmenu.tcl:228 ../gui/tcltk/d.m/menu.tcl:221
msgid "&Raster"
msgstr "&Ráster"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:228 ../gui/tcltk/gis.m/gmmenu.tcl:429
-#: ../gui/tcltk/d.m/menu.tcl:221 ../gui/tcltk/d.m/menu.tcl:380
+#: ../gui/tcltk/gis.m/gmmenu.tcl:229 ../gui/tcltk/gis.m/gmmenu.tcl:430
+#: ../gui/tcltk/d.m/menu.tcl:222 ../gui/tcltk/d.m/menu.tcl:381
msgid "Develop map"
msgstr "Crear mapa"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:229 ../gui/tcltk/d.m/menu.tcl:222
+#: ../gui/tcltk/gis.m/gmmenu.tcl:230 ../gui/tcltk/d.m/menu.tcl:223
msgid "Digitize raster"
msgstr "Digitalizar ráster"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:235
+#: ../gui/tcltk/gis.m/gmmenu.tcl:236
msgid "Compress/decompress"
msgstr "Comprimir/descomprimir"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:237
+#: ../gui/tcltk/gis.m/gmmenu.tcl:238
msgid "Boundaries"
msgstr "Contornos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:238
+#: ../gui/tcltk/gis.m/gmmenu.tcl:239
msgid "Null values"
msgstr "Valores nulos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:239
+#: ../gui/tcltk/gis.m/gmmenu.tcl:240
msgid "Quantization"
msgstr "Quantización"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:240
+#: ../gui/tcltk/gis.m/gmmenu.tcl:241
msgid "Timestamps"
msgstr "Marcas de tiempo"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:242 ../gui/tcltk/d.m/menu.tcl:233
+#: ../gui/tcltk/gis.m/gmmenu.tcl:243 ../gui/tcltk/d.m/menu.tcl:234
msgid "Resample using aggregate statistics"
msgstr "Volver a muestrear utilizando estadÃstica de conjuntos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:243
+#: ../gui/tcltk/gis.m/gmmenu.tcl:244
msgid "Resample using multiple methods"
msgstr "Volver a muestrear utilizando varios métodos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:244
+#: ../gui/tcltk/gis.m/gmmenu.tcl:245
msgid "Resample using nearest neighbor"
msgstr "Volver a muestrear utilizando el vecino más próximo"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:245
+#: ../gui/tcltk/gis.m/gmmenu.tcl:246
msgid "Resample using spline tension"
msgstr "Volver a muestrear usando tensión spline"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:247
+#: ../gui/tcltk/gis.m/gmmenu.tcl:248
msgid "Support file maintenance"
msgstr "Soportar mantenimiento de archivos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:248
+#: ../gui/tcltk/gis.m/gmmenu.tcl:249
msgid "Update map statistics"
msgstr "Actualizar estadÃsticas de mapa"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:250
+#: ../gui/tcltk/gis.m/gmmenu.tcl:251
msgid "Reproject"
msgstr "Reproyectar"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:251
+#: ../gui/tcltk/gis.m/gmmenu.tcl:252
msgid "Tiling"
msgstr "Teselado"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:253 ../gui/tcltk/d.m/menu.tcl:242
+#: ../gui/tcltk/gis.m/gmmenu.tcl:254 ../gui/tcltk/d.m/menu.tcl:243
msgid "Manage map colors"
msgstr "Administrar colores de mapas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:254
+#: ../gui/tcltk/gis.m/gmmenu.tcl:255
msgid "Color tables"
msgstr "Tablas de color"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:255
+#: ../gui/tcltk/gis.m/gmmenu.tcl:256
#, fuzzy
msgid "Color tables (stddev)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:256
+#: ../gui/tcltk/gis.m/gmmenu.tcl:257
msgid "Color rules"
msgstr "Reglas de color"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:258
+#: ../gui/tcltk/gis.m/gmmenu.tcl:259
msgid "Blend"
msgstr "Mezclar"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:259
+#: ../gui/tcltk/gis.m/gmmenu.tcl:260
msgid "Create RGB"
msgstr "Crear RGB"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:260 ../gui/tcltk/gis.m/gmmenu.tcl:549
+#: ../gui/tcltk/gis.m/gmmenu.tcl:261 ../gui/tcltk/gis.m/gmmenu.tcl:550
msgid "HIS to RGB"
msgstr "HIS a RGB"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:263 ../gui/tcltk/d.m/menu.tcl:252
-#: ../gui/tcltk/d.m/menu.tcl:408
+#: ../gui/tcltk/gis.m/gmmenu.tcl:264 ../gui/tcltk/d.m/menu.tcl:253
+#: ../gui/tcltk/d.m/menu.tcl:409
msgid "Query by coordinate(s)"
msgstr "Búsqueda por coordenada(s)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:265
+#: ../gui/tcltk/gis.m/gmmenu.tcl:266
msgid "Buffers"
msgstr "Buffers"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:266
+#: ../gui/tcltk/gis.m/gmmenu.tcl:267
msgid "Closest points"
msgstr "Puntos más cercanos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:267
+#: ../gui/tcltk/gis.m/gmmenu.tcl:268
msgid "MASK"
msgstr "MÃSCARA"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:268 ../gui/tcltk/d.m/menu.tcl:257
+#: ../gui/tcltk/gis.m/gmmenu.tcl:269 ../gui/tcltk/d.m/menu.tcl:258
msgid "Map calculator"
msgstr "Calculadora de mapas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:269 ../gui/tcltk/d.m/menu.tcl:258
-#: ../gui/tcltk/d.m/menu.tcl:418
+#: ../gui/tcltk/gis.m/gmmenu.tcl:270 ../gui/tcltk/d.m/menu.tcl:259
+#: ../gui/tcltk/d.m/menu.tcl:419
msgid "Neighborhood analysis"
msgstr "Análisis del vecino más próximo"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:270
+#: ../gui/tcltk/gis.m/gmmenu.tcl:271
msgid "Moving window"
msgstr "Moviendo la ventana"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:271
+#: ../gui/tcltk/gis.m/gmmenu.tcl:272
msgid "Neighborhood points"
msgstr "Puntos de vecindario"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:273 ../gui/tcltk/gis.m/gmmenu.tcl:493
-#: ../gui/tcltk/d.m/menu.tcl:262 ../gui/tcltk/d.m/menu.tcl:432
+#: ../gui/tcltk/gis.m/gmmenu.tcl:274 ../gui/tcltk/gis.m/gmmenu.tcl:494
+#: ../gui/tcltk/d.m/menu.tcl:263 ../gui/tcltk/d.m/menu.tcl:433
msgid "Overlay maps"
msgstr "Superponer mapas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:274 ../gui/tcltk/d.m/menu.tcl:263
+#: ../gui/tcltk/gis.m/gmmenu.tcl:275 ../gui/tcltk/d.m/menu.tcl:264
msgid "Cross product"
msgstr "Cruzar productos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:275
+#: ../gui/tcltk/gis.m/gmmenu.tcl:276
msgid "Map series"
msgstr "Series de mapas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:276 ../gui/tcltk/d.m/menu.tcl:265
+#: ../gui/tcltk/gis.m/gmmenu.tcl:277 ../gui/tcltk/d.m/menu.tcl:266
msgid "Patch maps"
msgstr "'Coser' mapas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:278
+#: ../gui/tcltk/gis.m/gmmenu.tcl:279
msgid "Statistical overlay"
msgstr "Superposición estadÃstica"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:280 ../gui/tcltk/d.m/menu.tcl:269
+#: ../gui/tcltk/gis.m/gmmenu.tcl:281 ../gui/tcltk/d.m/menu.tcl:270
msgid "Solar radiance and shadows"
msgstr "Radiación solar y sombras"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:281
+#: ../gui/tcltk/gis.m/gmmenu.tcl:282
msgid "Solar irradiance irradiation"
msgstr "Irradiación solar e irradiación"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:282
+#: ../gui/tcltk/gis.m/gmmenu.tcl:283
msgid "Shadows map"
msgstr "Mapa de sombras"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:284 ../gui/tcltk/d.m/menu.tcl:273
+#: ../gui/tcltk/gis.m/gmmenu.tcl:285 ../gui/tcltk/d.m/menu.tcl:274
msgid "Terrain analysis"
msgstr "Análisis del terreno"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:285
+#: ../gui/tcltk/gis.m/gmmenu.tcl:286
msgid "Cumulative movement costs"
msgstr "Costes acumulados de movimientos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:286 ../gui/tcltk/d.m/menu.tcl:275
+#: ../gui/tcltk/gis.m/gmmenu.tcl:287 ../gui/tcltk/d.m/menu.tcl:276
msgid "Cost surface"
msgstr "Superficies de coste"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:287 ../gui/tcltk/d.m/menu.tcl:276
+#: ../gui/tcltk/gis.m/gmmenu.tcl:288 ../gui/tcltk/d.m/menu.tcl:277
msgid "Least cost route or flow"
msgstr "Ruta de costes mÃnimos o corriente"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:289
+#: ../gui/tcltk/gis.m/gmmenu.tcl:290
msgid "Shaded relief"
msgstr "Relieve sombreado"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:291 ../gui/tcltk/d.m/menu.tcl:279
+#: ../gui/tcltk/gis.m/gmmenu.tcl:292 ../gui/tcltk/d.m/menu.tcl:280
msgid "Slope and aspect"
msgstr "Pendiente y orientación"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:292 ../gui/tcltk/d.m/menu.tcl:280
+#: ../gui/tcltk/gis.m/gmmenu.tcl:293 ../gui/tcltk/d.m/menu.tcl:281
msgid "Terrain parameters"
msgstr "Parámetros del terreno"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:293 ../gui/tcltk/d.m/menu.tcl:281
+#: ../gui/tcltk/gis.m/gmmenu.tcl:294 ../gui/tcltk/d.m/menu.tcl:282
msgid "Textural features"
msgstr "Entidades de textura"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:295
+#: ../gui/tcltk/gis.m/gmmenu.tcl:296
msgid "Visibility"
msgstr "Visibilidad"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:296 ../gui/tcltk/d.m/menu.tcl:283
+#: ../gui/tcltk/gis.m/gmmenu.tcl:297 ../gui/tcltk/d.m/menu.tcl:284
#, fuzzy
msgid "Distance to features"
msgstr "Editar elementos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:298
+#: ../gui/tcltk/gis.m/gmmenu.tcl:299
msgid "Horizon"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:300 ../gui/tcltk/d.m/menu.tcl:285
+#: ../gui/tcltk/gis.m/gmmenu.tcl:301 ../gui/tcltk/d.m/menu.tcl:286
msgid "Transform features"
msgstr "Transformar entidades"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:301
+#: ../gui/tcltk/gis.m/gmmenu.tcl:302
msgid "Clump"
msgstr "Agrupar"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:302
+#: ../gui/tcltk/gis.m/gmmenu.tcl:303
msgid "Grow"
msgstr "Incrementar"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:303
+#: ../gui/tcltk/gis.m/gmmenu.tcl:304
msgid "Thin"
msgstr "Adelgazar"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:306 ../gui/tcltk/d.m/menu.tcl:291
+#: ../gui/tcltk/gis.m/gmmenu.tcl:307 ../gui/tcltk/d.m/menu.tcl:292
msgid "Hydrologic modeling"
msgstr "Modelo hidrológico"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:307
+#: ../gui/tcltk/gis.m/gmmenu.tcl:308
msgid "Carve stream channels"
msgstr "Canales de corrientes de excavación"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:308
+#: ../gui/tcltk/gis.m/gmmenu.tcl:309
msgid "Fill lake"
msgstr "Rellenar lago"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:310
+#: ../gui/tcltk/gis.m/gmmenu.tcl:311
msgid "Depressionless map and flowlines"
msgstr "Mapa sin depresiones y lÃneas de flujos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:311
+#: ../gui/tcltk/gis.m/gmmenu.tcl:312
msgid "Flow accumulation"
msgstr "Acumulación de flujos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:312
+#: ../gui/tcltk/gis.m/gmmenu.tcl:313
msgid "Flow lines"
msgstr "LÃneas de flujo"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:314 ../gui/tcltk/gis.m/gmmenu.tcl:596
+#: ../gui/tcltk/gis.m/gmmenu.tcl:315 ../gui/tcltk/gis.m/gmmenu.tcl:601
msgid "Groundwater flow model"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:316 ../gui/tcltk/d.m/menu.tcl:297
+#: ../gui/tcltk/gis.m/gmmenu.tcl:317 ../gui/tcltk/d.m/menu.tcl:298
msgid "SIMWE overland flow modeling"
msgstr "SIMWE modelado de flujos sobre tierra"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:317
+#: ../gui/tcltk/gis.m/gmmenu.tcl:318
msgid "SIMWE sediment flux modeling"
msgstr "Modelos de flujo de sedimentos SIMWE"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:319 ../gui/tcltk/d.m/menu.tcl:299
+#: ../gui/tcltk/gis.m/gmmenu.tcl:320 ../gui/tcltk/d.m/menu.tcl:300
msgid "Topographic index map"
msgstr "Mapa de Ãndice topográfico"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:320 ../gui/tcltk/d.m/menu.tcl:300
+#: ../gui/tcltk/gis.m/gmmenu.tcl:321 ../gui/tcltk/d.m/menu.tcl:301
msgid "TOPMODEL simulation"
msgstr "Simulación TOPMODEL"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:322 ../gui/tcltk/d.m/menu.tcl:301
+#: ../gui/tcltk/gis.m/gmmenu.tcl:323 ../gui/tcltk/d.m/menu.tcl:302
msgid "Watershed subbasins"
msgstr "Delimitación de sub-cuencas hidrográficas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:323 ../gui/tcltk/d.m/menu.tcl:302
+#: ../gui/tcltk/gis.m/gmmenu.tcl:324 ../gui/tcltk/d.m/menu.tcl:303
msgid "Watershed analysis"
msgstr "Análisis de cuencas hidrográficas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:324 ../gui/tcltk/d.m/menu.tcl:303
+#: ../gui/tcltk/gis.m/gmmenu.tcl:325 ../gui/tcltk/d.m/menu.tcl:304
msgid "Watershed basin creation"
msgstr "Creación de cuencas hidrográficas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:326 ../gui/tcltk/d.m/menu.tcl:305
+#: ../gui/tcltk/gis.m/gmmenu.tcl:327 ../gui/tcltk/d.m/menu.tcl:306
msgid "Landscape structure modeling"
msgstr "Modelado de la estructura del paisaje"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:327
+#: ../gui/tcltk/gis.m/gmmenu.tcl:328
msgid "Set up"
msgstr "Configuración"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:333
+#: ../gui/tcltk/gis.m/gmmenu.tcl:334
msgid "Analyze landscape"
msgstr "Analizar paisaje"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:334
+#: ../gui/tcltk/gis.m/gmmenu.tcl:335
msgid "Analyze patches"
msgstr "Analizar parcelas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:337
+#: ../gui/tcltk/gis.m/gmmenu.tcl:338
msgid "Landscape patch analysis"
msgstr "Analizar parcelas del paisaje"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:338 ../gui/tcltk/d.m/menu.tcl:306
+#: ../gui/tcltk/gis.m/gmmenu.tcl:339 ../gui/tcltk/d.m/menu.tcl:307
msgid "Set up sampling and analysis framework"
msgstr "Ajustar el muestreo y analizar un entorno de trabajo"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:340
+#: ../gui/tcltk/gis.m/gmmenu.tcl:341
msgid "Edge density"
msgstr "Densidad de borde"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:341
+#: ../gui/tcltk/gis.m/gmmenu.tcl:342
#, fuzzy
msgid "Contrast weighted edge density"
msgstr "Calcular Ãndice de densidad de borde"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:343
+#: ../gui/tcltk/gis.m/gmmenu.tcl:344
msgid "Patch size mean"
msgstr "Tamaño medio de parcela"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:344
+#: ../gui/tcltk/gis.m/gmmenu.tcl:345
msgid "Patch area range"
msgstr "Rango de superficie de parcela"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:345
+#: ../gui/tcltk/gis.m/gmmenu.tcl:346
msgid "Patch area Std Dev"
msgstr "Desviación estándar de superficie de parcela"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:346
+#: ../gui/tcltk/gis.m/gmmenu.tcl:347
msgid "Patch area Coeff Var"
msgstr "Coeficiente de varianza de superficie de parcela"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:347
+#: ../gui/tcltk/gis.m/gmmenu.tcl:348
msgid "Patch density"
msgstr "Densidad de parcela"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:348
+#: ../gui/tcltk/gis.m/gmmenu.tcl:349
msgid "Patch number"
msgstr "Número de parcelas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:350
+#: ../gui/tcltk/gis.m/gmmenu.tcl:351
msgid "Dominance's diversity"
msgstr "Diversidad de dominancia"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:351
+#: ../gui/tcltk/gis.m/gmmenu.tcl:352
msgid "Shannon's diversity"
msgstr "Diversidad de Shannon"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:352
+#: ../gui/tcltk/gis.m/gmmenu.tcl:353
msgid "Simpson's diversity"
msgstr "Diversidad de Simpson"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:354
+#: ../gui/tcltk/gis.m/gmmenu.tcl:355
msgid "Ricness"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:355
+#: ../gui/tcltk/gis.m/gmmenu.tcl:356
msgid "Shape index"
msgstr "Ãndice de formas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:357 ../gui/tcltk/d.m/menu.tcl:312
+#: ../gui/tcltk/gis.m/gmmenu.tcl:358 ../gui/tcltk/d.m/menu.tcl:313
msgid "Wildfire modeling"
msgstr "Modelado de incendios"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:358
+#: ../gui/tcltk/gis.m/gmmenu.tcl:359
msgid "Rate of spread"
msgstr "Relación de propagación"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:359
+#: ../gui/tcltk/gis.m/gmmenu.tcl:360
msgid "Least-cost spread paths"
msgstr "Rutas de propagación de menor coste"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:360
+#: ../gui/tcltk/gis.m/gmmenu.tcl:361
msgid "Anisotropic spread simulation"
msgstr "Simulación de propagación anisotrópica"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:363 ../gui/tcltk/d.m/menu.tcl:318
+#: ../gui/tcltk/gis.m/gmmenu.tcl:364 ../gui/tcltk/d.m/menu.tcl:319
msgid "Change category values and labels"
msgstr "Cambiar valores de categorÃas y etiquetas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:364
+#: ../gui/tcltk/gis.m/gmmenu.tcl:365
msgid "Interactively edit category values"
msgstr "Editar valores de categorÃa de forma interactiva"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:366
+#: ../gui/tcltk/gis.m/gmmenu.tcl:367
msgid "Reclassify by size"
msgstr "Reclasificar por tamaño"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:367
+#: ../gui/tcltk/gis.m/gmmenu.tcl:368
msgid "Reclassify interactively"
msgstr "Reclasificar de forma interactiva"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:368 ../gui/tcltk/gis.m/gmmenu.tcl:501
+#: ../gui/tcltk/gis.m/gmmenu.tcl:369 ../gui/tcltk/gis.m/gmmenu.tcl:502
msgid "Reclassify using rules file"
msgstr "Reclasificar usando archivo de reglas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:370
+#: ../gui/tcltk/gis.m/gmmenu.tcl:371
msgid "Recode interactively"
msgstr "Recodificar de forma interactiva"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:371
+#: ../gui/tcltk/gis.m/gmmenu.tcl:372
msgid "Recode using rules file"
msgstr "Volver a codificar usando archivo de reglas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:373
+#: ../gui/tcltk/gis.m/gmmenu.tcl:374
msgid "Rescale"
msgstr "Rescalar"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:374
+#: ../gui/tcltk/gis.m/gmmenu.tcl:375
msgid "Rescale with histogram"
msgstr "Rescalar con histograma"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:377
+#: ../gui/tcltk/gis.m/gmmenu.tcl:378
msgid "Concentric circles"
msgstr "CÃrculos concéntricos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:378 ../gui/tcltk/d.m/menu.tcl:335
+#: ../gui/tcltk/gis.m/gmmenu.tcl:379 ../gui/tcltk/d.m/menu.tcl:336
msgid "Generate random cells"
msgstr "Generar celdas aleatorias"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:379
+#: ../gui/tcltk/gis.m/gmmenu.tcl:380
msgid "Random cells"
msgstr "Celdas aleatorias"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:380
+#: ../gui/tcltk/gis.m/gmmenu.tcl:381
msgid "Random cells and vector points"
msgstr "Celdas aleatorias y puntos vectoriales"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:382 ../gui/tcltk/d.m/menu.tcl:338
+#: ../gui/tcltk/gis.m/gmmenu.tcl:383 ../gui/tcltk/d.m/menu.tcl:339
msgid "Generate surfaces"
msgstr "Generar superficies"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:383
+#: ../gui/tcltk/gis.m/gmmenu.tcl:384
msgid "Fractal surface"
msgstr "Superficie fractal"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:385
+#: ../gui/tcltk/gis.m/gmmenu.tcl:386
msgid "Gausian kernal density surface"
msgstr "Superficie de densidad kernal gausiana"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:386
+#: ../gui/tcltk/gis.m/gmmenu.tcl:387
msgid "Gaussian deviates surface"
msgstr "Superficie gaussiana derivada"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:388
+#: ../gui/tcltk/gis.m/gmmenu.tcl:389
msgid "Plane"
msgstr "Plano"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:390
+#: ../gui/tcltk/gis.m/gmmenu.tcl:391
msgid "Random deviates surface"
msgstr "Superficie derivada aleatoria"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:391
+#: ../gui/tcltk/gis.m/gmmenu.tcl:392
msgid "Random surface with spatial dependence"
msgstr "Superficie aleatoria con dependencia espacial"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:393
+#: ../gui/tcltk/gis.m/gmmenu.tcl:394
msgid "Contour lines"
msgstr "LÃneas de contornos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:394 ../gui/tcltk/d.m/menu.tcl:347
+#: ../gui/tcltk/gis.m/gmmenu.tcl:395 ../gui/tcltk/d.m/menu.tcl:348
msgid "Interpolate surfaces"
msgstr "Interpolar superficies"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:395
+#: ../gui/tcltk/gis.m/gmmenu.tcl:396
msgid "Bilinear from raster points"
msgstr "Bilineal a partir de puntos ráster"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:396
+#: ../gui/tcltk/gis.m/gmmenu.tcl:397
msgid "Bilinear and bicubic from vector points"
msgstr "Bilineal y bicúbica a partir de puntos vectoriales"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:398
+#: ../gui/tcltk/gis.m/gmmenu.tcl:399
msgid "IDW from raster points"
msgstr "IDW a partir de puntos ráster"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:399
+#: ../gui/tcltk/gis.m/gmmenu.tcl:400
msgid "IDW from vector points"
msgstr "IDW a partir de puntos vectoriales"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:401
+#: ../gui/tcltk/gis.m/gmmenu.tcl:402
msgid "Raster contours"
msgstr "Contornos ráster"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:402
+#: ../gui/tcltk/gis.m/gmmenu.tcl:403
msgid "Regularized spline tension"
msgstr "Tensión spline regularizada"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:404
+#: ../gui/tcltk/gis.m/gmmenu.tcl:405
msgid "Fill NULL cells"
msgstr "Rellenas celdas NULAS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:407 ../gui/tcltk/gis.m/gmmenu.tcl:528
-#: ../gui/tcltk/gis.m/gmmenu.tcl:582 ../gui/tcltk/d.m/menu.tcl:358
-#: ../gui/tcltk/d.m/menu.tcl:464 ../gui/tcltk/d.m/menu.tcl:520
+#: ../gui/tcltk/gis.m/gmmenu.tcl:408 ../gui/tcltk/gis.m/gmmenu.tcl:529
+#: ../gui/tcltk/gis.m/gmmenu.tcl:587 ../gui/tcltk/d.m/menu.tcl:359
+#: ../gui/tcltk/d.m/menu.tcl:465 ../gui/tcltk/d.m/menu.tcl:521
msgid "Reports and statistics"
msgstr "Informes y estadÃsticas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:408 ../gui/tcltk/d.m/menu.tcl:359
-#: ../gui/tcltk/d.m/menu.tcl:521
+#: ../gui/tcltk/gis.m/gmmenu.tcl:409 ../gui/tcltk/d.m/menu.tcl:360
+#: ../gui/tcltk/d.m/menu.tcl:522
msgid "Report basic file information"
msgstr "Informe básico del contenido del archivo"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:409
+#: ../gui/tcltk/gis.m/gmmenu.tcl:410
msgid "Manage category information"
msgstr "Administrar información de categorÃa"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:411 ../gui/tcltk/d.m/menu.tcl:362
+#: ../gui/tcltk/gis.m/gmmenu.tcl:412 ../gui/tcltk/d.m/menu.tcl:363
msgid "General statistics"
msgstr "EstadÃsticas generales"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:412
+#: ../gui/tcltk/gis.m/gmmenu.tcl:413
msgid "Quantiles for large data sets"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:413
+#: ../gui/tcltk/gis.m/gmmenu.tcl:414
msgid "Range of category values"
msgstr "Rango de valores de categorÃa"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:414
+#: ../gui/tcltk/gis.m/gmmenu.tcl:415
msgid "Sum cell category values"
msgstr "Sumar valores de categorÃa de celdas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:415 ../gui/tcltk/d.m/menu.tcl:365
+#: ../gui/tcltk/gis.m/gmmenu.tcl:416 ../gui/tcltk/d.m/menu.tcl:366
msgid "Sum area by map and category"
msgstr "Sumar área por mapa y categorÃa"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:416
+#: ../gui/tcltk/gis.m/gmmenu.tcl:417
msgid "Statistics for clumped cells (works with r.clump)"
msgstr "EstadÃsticas de celdas reunidas (funciona con r.clump)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:417 ../gui/tcltk/d.m/menu.tcl:367
+#: ../gui/tcltk/gis.m/gmmenu.tcl:418 ../gui/tcltk/d.m/menu.tcl:368
msgid "Total surface area corrected for topography"
msgstr "Ãrea de la superficie total corregida por topografÃa"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:418 ../gui/tcltk/d.m/menu.tcl:368
-#: ../gui/tcltk/d.m/menu.tcl:468
+#: ../gui/tcltk/gis.m/gmmenu.tcl:419 ../gui/tcltk/d.m/menu.tcl:369
+#: ../gui/tcltk/d.m/menu.tcl:469
msgid "Univariate statistics"
msgstr "EstadÃstica univariada"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:420
+#: ../gui/tcltk/gis.m/gmmenu.tcl:421
msgid "Sample transects"
msgstr "Muestrear transectos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:421
+#: ../gui/tcltk/gis.m/gmmenu.tcl:422
msgid "Sample transects (bearing/distance)"
msgstr "Muestrear transectos (rumbo/distancia)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:423 ../gui/tcltk/d.m/menu.tcl:374
+#: ../gui/tcltk/gis.m/gmmenu.tcl:424 ../gui/tcltk/d.m/menu.tcl:375
msgid "Covariance/correlation"
msgstr "Covarianza/correlación"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:424
+#: ../gui/tcltk/gis.m/gmmenu.tcl:425
msgid "Linear regression"
msgstr "Regresión lineal"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:425
+#: ../gui/tcltk/gis.m/gmmenu.tcl:426
msgid "Mutual category occurences"
msgstr "Ocurrencias de categorÃas mutuas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:428 ../gui/tcltk/d.m/menu.tcl:379
+#: ../gui/tcltk/gis.m/gmmenu.tcl:429 ../gui/tcltk/d.m/menu.tcl:380
msgid "&Vector"
msgstr "&Vectorial"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:430 ../gui/tcltk/d.m/menu.tcl:381
+#: ../gui/tcltk/gis.m/gmmenu.tcl:431 ../gui/tcltk/d.m/menu.tcl:382
msgid "Digitize"
msgstr "Digitalizar"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:431
+#: ../gui/tcltk/gis.m/gmmenu.tcl:432
msgid "Edit features"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:433 ../gui/tcltk/d.m/menu.tcl:383
+#: ../gui/tcltk/gis.m/gmmenu.tcl:434 ../gui/tcltk/d.m/menu.tcl:384
#, fuzzy
msgid "Create/rebuild topology"
msgstr "Crear/reconstruir topologÃa: "
-#: ../gui/tcltk/gis.m/gmmenu.tcl:434
+#: ../gui/tcltk/gis.m/gmmenu.tcl:435
msgid "Clean vector"
msgstr "Limpiar vectorial"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:435
+#: ../gui/tcltk/gis.m/gmmenu.tcl:436
msgid "Smooth or simplify"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:437
+#: ../gui/tcltk/gis.m/gmmenu.tcl:438
msgid "Convert object types"
msgstr "Convertir tipos objetos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:439
+#: ../gui/tcltk/gis.m/gmmenu.tcl:440
msgid "Add centroids"
msgstr "Añadir centroides"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:441
+#: ../gui/tcltk/gis.m/gmmenu.tcl:442
msgid "Build polylines"
msgstr "Construir polilÃneas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:442
+#: ../gui/tcltk/gis.m/gmmenu.tcl:443
msgid "Split polylines"
msgstr "Dividir polilÃneas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:443
+#: ../gui/tcltk/gis.m/gmmenu.tcl:444
msgid "Parallel lines"
msgstr "LÃneas parelelas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:445
+#: ../gui/tcltk/gis.m/gmmenu.tcl:446
msgid "Dissolve boundaries"
msgstr "Disolver contornos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:447
+#: ../gui/tcltk/gis.m/gmmenu.tcl:448
msgid "Create 3D vector over raster"
msgstr "Crear vectorial 3D sobre ráster"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:448
+#: ../gui/tcltk/gis.m/gmmenu.tcl:449
msgid "Extrude 3D vector"
msgstr "Extrudir vectorial 3D"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:450
+#: ../gui/tcltk/gis.m/gmmenu.tcl:451
msgid "Link to OGR"
msgstr "Enlazar a OGR"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:452
+#: ../gui/tcltk/gis.m/gmmenu.tcl:453
msgid "Create labels"
msgstr "Crear etiquetas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:453
+#: ../gui/tcltk/gis.m/gmmenu.tcl:454
#, fuzzy
msgid "Assign colors"
msgstr "color de lÃnea"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:455
+#: ../gui/tcltk/gis.m/gmmenu.tcl:456
msgid "Reposition vector"
msgstr "Reposicionar vectorial"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:456
+#: ../gui/tcltk/gis.m/gmmenu.tcl:457
msgid "Reproject vector"
msgstr "Reproyectar vectorial"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:458
+#: ../gui/tcltk/gis.m/gmmenu.tcl:459
msgid "Metadata support"
msgstr "Soporte de metadatos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:462
+#: ../gui/tcltk/gis.m/gmmenu.tcl:463
msgid "Query with attributes"
msgstr "Consultar con atributos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:463
+#: ../gui/tcltk/gis.m/gmmenu.tcl:464
msgid "Query with coordinate(s)"
msgstr "Consultar con coordenada(s)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:464
+#: ../gui/tcltk/gis.m/gmmenu.tcl:465
msgid "Query with another map"
msgstr "Consultar con otro mapa"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:466
+#: ../gui/tcltk/gis.m/gmmenu.tcl:467
msgid "Buffer vectors"
msgstr "Crear áreas de influencia de vectoriales"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:467
+#: ../gui/tcltk/gis.m/gmmenu.tcl:468
msgid "Lidar analysis"
msgstr "Análisis lidar"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:468
+#: ../gui/tcltk/gis.m/gmmenu.tcl:469
msgid "Detect edges"
msgstr "Detectar bordes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:469
+#: ../gui/tcltk/gis.m/gmmenu.tcl:470
msgid "Detect interiors"
msgstr "Detectar interiores"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:470
+#: ../gui/tcltk/gis.m/gmmenu.tcl:471
msgid "Correct and reclassify objects"
msgstr "Corregir y reclasificar objetos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:472
+#: ../gui/tcltk/gis.m/gmmenu.tcl:473
msgid "Linear referencing"
msgstr "Referencia lineal"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:473
+#: ../gui/tcltk/gis.m/gmmenu.tcl:474
msgid "Create LRS"
msgstr "Crear LRS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:474
+#: ../gui/tcltk/gis.m/gmmenu.tcl:475
msgid "Create stationing"
msgstr "Crear estacionamiento"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:475
+#: ../gui/tcltk/gis.m/gmmenu.tcl:476
msgid "Create points/segments"
msgstr "Crear puntos/segmentos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:476
+#: ../gui/tcltk/gis.m/gmmenu.tcl:477
msgid "Find ID and offset"
msgstr "Encontrar ID y ordendas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:478
+#: ../gui/tcltk/gis.m/gmmenu.tcl:479
msgid "Nearest features"
msgstr "Elementos más próximos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:479 ../gui/tcltk/d.m/menu.tcl:423
+#: ../gui/tcltk/gis.m/gmmenu.tcl:480 ../gui/tcltk/d.m/menu.tcl:424
msgid "Network analysis"
msgstr "Análisis de redes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:480 ../gui/tcltk/d.m/menu.tcl:424
+#: ../gui/tcltk/gis.m/gmmenu.tcl:481 ../gui/tcltk/d.m/menu.tcl:425
msgid "Allocate subnets"
msgstr "Asignar subredes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:481 ../gui/tcltk/d.m/menu.tcl:425
+#: ../gui/tcltk/gis.m/gmmenu.tcl:482 ../gui/tcltk/d.m/menu.tcl:426
msgid "Network maintenance"
msgstr "Mantenimiento de redes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:482
+#: ../gui/tcltk/gis.m/gmmenu.tcl:483
msgid "Visibility network"
msgstr "Red de visibilidad"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:483 ../gui/tcltk/d.m/menu.tcl:426
+#: ../gui/tcltk/gis.m/gmmenu.tcl:484 ../gui/tcltk/d.m/menu.tcl:427
msgid "Shortest route"
msgstr "Ruta más corta"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:484
+#: ../gui/tcltk/gis.m/gmmenu.tcl:485
msgid "Display shortest route"
msgstr "Mostrar la ruta más corta"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:489
+#: ../gui/tcltk/gis.m/gmmenu.tcl:490
msgid "Split net"
msgstr "Dividir red"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:490 ../gui/tcltk/d.m/menu.tcl:429
+#: ../gui/tcltk/gis.m/gmmenu.tcl:491 ../gui/tcltk/d.m/menu.tcl:430
msgid "Steiner tree"
msgstr "Ãrbol de Steiner"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:491 ../gui/tcltk/d.m/menu.tcl:430
+#: ../gui/tcltk/gis.m/gmmenu.tcl:492 ../gui/tcltk/d.m/menu.tcl:431
msgid "Traveling salesman analysis"
msgstr "Análisis del representante de comercio"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:494
+#: ../gui/tcltk/gis.m/gmmenu.tcl:495
msgid "Overlay"
msgstr "Superponer"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:495
+#: ../gui/tcltk/gis.m/gmmenu.tcl:496
msgid "Patch (combine)"
msgstr "Parchear (combinar)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:498 ../gui/tcltk/d.m/menu.tcl:439
+#: ../gui/tcltk/gis.m/gmmenu.tcl:499 ../gui/tcltk/d.m/menu.tcl:440
msgid "Change attributes"
msgstr "Cambiar atributos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:499
+#: ../gui/tcltk/gis.m/gmmenu.tcl:500
msgid "Manage or report categories"
msgstr "Gestionar o informar de categorÃas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:500
+#: ../gui/tcltk/gis.m/gmmenu.tcl:501
msgid "Reclassify objects interactively"
msgstr "Reclasificar objetos de forma interactiva"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:504
+#: ../gui/tcltk/gis.m/gmmenu.tcl:505
msgid "Generate area for current region"
msgstr "Generar área para la región actual"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:505 ../gui/tcltk/d.m/menu.tcl:450
+#: ../gui/tcltk/gis.m/gmmenu.tcl:506 ../gui/tcltk/d.m/menu.tcl:451
msgid "Generate areas from points"
msgstr "Generar áreas a partir de puntos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:506
+#: ../gui/tcltk/gis.m/gmmenu.tcl:507
msgid "Convex hull"
msgstr "Casco convexo"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:507
+#: ../gui/tcltk/gis.m/gmmenu.tcl:508
msgid "Delaunay triangles"
msgstr "Triángulos de Delaunay"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:508
+#: ../gui/tcltk/gis.m/gmmenu.tcl:509
msgid "Voronoi diagram/Thiessen polygons"
msgstr "Diagrama de Voronoi/polÃgonos de Thiessen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:510
+#: ../gui/tcltk/gis.m/gmmenu.tcl:511
msgid "Generate grid"
msgstr "Generar cuadrÃcula"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:511 ../gui/tcltk/d.m/menu.tcl:445
+#: ../gui/tcltk/gis.m/gmmenu.tcl:512 ../gui/tcltk/d.m/menu.tcl:446
msgid "Generate points"
msgstr "Generar puntos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:512
+#: ../gui/tcltk/gis.m/gmmenu.tcl:513
msgid "Generate points from database"
msgstr "Generar puntos a partir de una base de datos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:513
+#: ../gui/tcltk/gis.m/gmmenu.tcl:514
msgid "Generate points along lines"
msgstr "Generar puntos a lo largo de lÃneas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:514 ../gui/tcltk/d.m/menu.tcl:447
+#: ../gui/tcltk/gis.m/gmmenu.tcl:515 ../gui/tcltk/d.m/menu.tcl:448
msgid "Generate random points"
msgstr "Generar puntos aleatorios"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:515
+#: ../gui/tcltk/gis.m/gmmenu.tcl:516
msgid "Perturb points"
msgstr "Perturbar puntos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:518
+#: ../gui/tcltk/gis.m/gmmenu.tcl:519
msgid "Remove outliers in point sets"
msgstr "Eliminar outliers de conjunto de puntos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:519
+#: ../gui/tcltk/gis.m/gmmenu.tcl:520
msgid "Test/training sets"
msgstr "Conjuntos de texto/entrenamiento"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:521
+#: ../gui/tcltk/gis.m/gmmenu.tcl:522
msgid "Update area attributes from raster"
msgstr "Actualizar atributos de área a partir de ráster"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:522
+#: ../gui/tcltk/gis.m/gmmenu.tcl:523
msgid "Update point attributes from areas"
msgstr "Actualizar atributos de puntos a partir de áreas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:523
+#: ../gui/tcltk/gis.m/gmmenu.tcl:524
msgid "Update point attributes from raster"
msgstr "Actualizar atributos de puntos a partir de ráster"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:524 ../gui/tcltk/d.m/menu.tcl:457
+#: ../gui/tcltk/gis.m/gmmenu.tcl:525 ../gui/tcltk/d.m/menu.tcl:458
msgid "Sample raster map at point locations"
msgstr "Muestrear mapa ráster en localizaciones de puntos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:525 ../gui/tcltk/d.m/menu.tcl:458
+#: ../gui/tcltk/gis.m/gmmenu.tcl:526 ../gui/tcltk/d.m/menu.tcl:459
msgid "Sample raster neighborhood around points"
msgstr "Muestrear 'vecindario' ráster alrededor de puntos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:529 ../gui/tcltk/gis.m/gmmenu.tcl:599
-#: ../gui/tcltk/d.m/menu.tcl:465
+#: ../gui/tcltk/gis.m/gmmenu.tcl:530 ../gui/tcltk/gis.m/gmmenu.tcl:604
+#: ../gui/tcltk/d.m/menu.tcl:466
msgid "Basic information"
msgstr "Información básica"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:531
+#: ../gui/tcltk/gis.m/gmmenu.tcl:532
msgid "Report topology by category"
msgstr "Informar topologÃa por categorÃa"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:532
+#: ../gui/tcltk/gis.m/gmmenu.tcl:533
msgid "Upload or report topology"
msgstr "Cargar o informar topologÃa"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:534
+#: ../gui/tcltk/gis.m/gmmenu.tcl:535
msgid "Univariate attribute statistics"
msgstr "EstadÃsticas de atributos univariante"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:536
+#: ../gui/tcltk/gis.m/gmmenu.tcl:537
msgid "Quadrat indices"
msgstr "Ãndices cuadráticos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:537
+#: ../gui/tcltk/gis.m/gmmenu.tcl:538
msgid "Test normality"
msgstr "Probar normalidad"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:540 ../gui/tcltk/d.m/menu.tcl:475
+#: ../gui/tcltk/gis.m/gmmenu.tcl:541 ../gui/tcltk/d.m/menu.tcl:476
msgid "&Imagery"
msgstr "&Imágenes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:541 ../gui/tcltk/d.m/menu.tcl:476
+#: ../gui/tcltk/gis.m/gmmenu.tcl:542 ../gui/tcltk/d.m/menu.tcl:477
msgid "Develop images and groups"
msgstr "Crear imágenes y grupos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:542
+#: ../gui/tcltk/gis.m/gmmenu.tcl:543
msgid "Create/edit group"
msgstr "Crear/editar grupo"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:543
+#: ../gui/tcltk/gis.m/gmmenu.tcl:544
msgid "Target group"
msgstr "Grupo objetivo"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:545
+#: ../gui/tcltk/gis.m/gmmenu.tcl:546
msgid "Mosaic images"
msgstr "Hacer mosaico de imágenes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:547 ../gui/tcltk/d.m/menu.tcl:482
+#: ../gui/tcltk/gis.m/gmmenu.tcl:548 ../gui/tcltk/d.m/menu.tcl:483
msgid "Manage image colors"
msgstr "Administrar colores de imágenes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:548
+#: ../gui/tcltk/gis.m/gmmenu.tcl:549
msgid "Color balance for RGB"
msgstr "Equilibrio de color para RGB"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:550
+#: ../gui/tcltk/gis.m/gmmenu.tcl:551
msgid "RGB to HIS"
msgstr "RGB a HIS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:552 ../gui/tcltk/d.m/menu.tcl:493
+#: ../gui/tcltk/gis.m/gmmenu.tcl:553 ../gui/tcltk/d.m/menu.tcl:494
msgid "Ortho photo rectification"
msgstr "Rectificación de ortofotos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:558
+#: ../gui/tcltk/gis.m/gmmenu.tcl:559
msgid "Brovey sharpening"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:559 ../gui/tcltk/d.m/menu.tcl:497
+#: ../gui/tcltk/gis.m/gmmenu.tcl:560 ../gui/tcltk/d.m/menu.tcl:498
msgid "Classify image"
msgstr "Clasificar imagen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:560 ../gui/tcltk/d.m/menu.tcl:498
+#: ../gui/tcltk/gis.m/gmmenu.tcl:561 ../gui/tcltk/d.m/menu.tcl:499
msgid "Clustering input for unsupervised classification"
msgstr "Entrada de agrupaciones para clasificación no supervisada"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:562 ../gui/tcltk/d.m/menu.tcl:500
-msgid "Maximum likelyhood classification (MLC)"
+#: ../gui/tcltk/gis.m/gmmenu.tcl:563 ../gui/tcltk/d.m/menu.tcl:501
+#, fuzzy
+msgid "Maximum likelihood classification (MLC)"
msgstr "Clasificación por probabilidad máxima (MLC)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:563 ../gui/tcltk/d.m/menu.tcl:501
+#: ../gui/tcltk/gis.m/gmmenu.tcl:564 ../gui/tcltk/d.m/menu.tcl:502
msgid "Sequential maximum a posteriory classification (SMAP)"
msgstr "Clasificación secuencial máxima a posteriori (SMAP)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:565 ../gui/tcltk/d.m/menu.tcl:503
+#: ../gui/tcltk/gis.m/gmmenu.tcl:566 ../gui/tcltk/d.m/menu.tcl:504
msgid "Interactive input for supervised classification"
msgstr "Clasificación supervisada de entrada interactiva"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:566
+#: ../gui/tcltk/gis.m/gmmenu.tcl:571
msgid "Input for supervised MLC"
msgstr "Entrada para MLC supervisado"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:567
+#: ../gui/tcltk/gis.m/gmmenu.tcl:572
msgid "Input for supervised SMAP"
msgstr "Entrada para SMAP supervisado"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:569 ../gui/tcltk/d.m/menu.tcl:507
+#: ../gui/tcltk/gis.m/gmmenu.tcl:574 ../gui/tcltk/d.m/menu.tcl:508
msgid "Filter image"
msgstr "Filtro de imagen "
-#: ../gui/tcltk/gis.m/gmmenu.tcl:570
+#: ../gui/tcltk/gis.m/gmmenu.tcl:575
msgid "Edge detection"
msgstr "Detección de bordes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:571
+#: ../gui/tcltk/gis.m/gmmenu.tcl:576
#, fuzzy
msgid "Matrix/convolving filter"
msgstr "Filtro de matriz/"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:573 ../gui/tcltk/d.m/menu.tcl:511
+#: ../gui/tcltk/gis.m/gmmenu.tcl:578 ../gui/tcltk/d.m/menu.tcl:512
msgid "Spectral response"
msgstr "Respuesta espectral"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:574 ../gui/tcltk/d.m/menu.tcl:512
+#: ../gui/tcltk/gis.m/gmmenu.tcl:579 ../gui/tcltk/d.m/menu.tcl:513
msgid "Tassled cap vegetation index"
msgstr "Ãndice de vegetación 'Tassled cap'"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:575 ../gui/tcltk/d.m/menu.tcl:513
+#: ../gui/tcltk/gis.m/gmmenu.tcl:580 ../gui/tcltk/d.m/menu.tcl:514
msgid "Transform image"
msgstr "Transformar imagen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:576
+#: ../gui/tcltk/gis.m/gmmenu.tcl:581
msgid "Canonical correlation"
msgstr "Correlación canónica"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:577
+#: ../gui/tcltk/gis.m/gmmenu.tcl:582
msgid "Principal components"
msgstr "Componentes principales"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:578
+#: ../gui/tcltk/gis.m/gmmenu.tcl:583
msgid "Fast Fourier"
msgstr "Fast Fourier"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:579
+#: ../gui/tcltk/gis.m/gmmenu.tcl:584
msgid "Inverse Fast Fourier"
msgstr "Fast Fourier inversa"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:583
+#: ../gui/tcltk/gis.m/gmmenu.tcl:588
msgid "Bit pattern comparison"
msgstr "Comparación de patrón de bit"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:584
+#: ../gui/tcltk/gis.m/gmmenu.tcl:589
msgid "Kappa analysis"
msgstr "Análisis kappa"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:585
+#: ../gui/tcltk/gis.m/gmmenu.tcl:590
msgid "OIF for LandSat TM"
msgstr "OIF para LandSat TM"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:588
+#: ../gui/tcltk/gis.m/gmmenu.tcl:593
msgid "&Volumes"
msgstr "&Volúmenes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:589 ../gui/tcltk/d.m/menu.tcl:530
+#: ../gui/tcltk/gis.m/gmmenu.tcl:594 ../gui/tcltk/d.m/menu.tcl:531
msgid "Develop grid3D volumes"
msgstr "Crear volúmenes grid3D "
-#: ../gui/tcltk/gis.m/gmmenu.tcl:590 ../gui/tcltk/d.m/menu.tcl:531
+#: ../gui/tcltk/gis.m/gmmenu.tcl:595 ../gui/tcltk/d.m/menu.tcl:532
msgid "Manage nulls for grid3D volume"
msgstr "Administrar valores nulos en volúmenes grid3D"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:591 ../gui/tcltk/d.m/menu.tcl:532
+#: ../gui/tcltk/gis.m/gmmenu.tcl:596 ../gui/tcltk/d.m/menu.tcl:533
msgid "Manage timestamp for grid3D volume"
msgstr "Administrar hora en volúmenes grid3D"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:593
+#: ../gui/tcltk/gis.m/gmmenu.tcl:598
msgid "3D MASK"
msgstr "MÃSCARA 3D"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:594
+#: ../gui/tcltk/gis.m/gmmenu.tcl:599
msgid "3D Map calculator"
msgstr "Calculadora de mapas 3D"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:595
+#: ../gui/tcltk/gis.m/gmmenu.tcl:600
msgid "Cross section from volume"
msgstr "Sección transversal a partir de volumen"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:597
+#: ../gui/tcltk/gis.m/gmmenu.tcl:602
msgid "Interpolate volume from vector points"
msgstr "Interpolar volúmenes a partir de puntos vectoriales"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:598 ../gui/tcltk/d.m/menu.tcl:538
+#: ../gui/tcltk/gis.m/gmmenu.tcl:603 ../gui/tcltk/d.m/menu.tcl:539
msgid "Report and Statistics"
msgstr "Informes y estadÃstica"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:602 ../gui/tcltk/d.m/menu.tcl:542
+#: ../gui/tcltk/gis.m/gmmenu.tcl:607 ../gui/tcltk/d.m/menu.tcl:543
msgid "&Databases"
msgstr "&Bases de datos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:603 ../gui/tcltk/d.m/menu.tcl:552
+#: ../gui/tcltk/gis.m/gmmenu.tcl:608 ../gui/tcltk/d.m/menu.tcl:553
msgid "Database information"
msgstr "Información sobre la base de datos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:604 ../gui/tcltk/d.m/menu.tcl:553
+#: ../gui/tcltk/gis.m/gmmenu.tcl:609 ../gui/tcltk/d.m/menu.tcl:554
msgid "Describe table"
msgstr "Describir tabla"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:605 ../gui/tcltk/d.m/menu.tcl:554
+#: ../gui/tcltk/gis.m/gmmenu.tcl:610 ../gui/tcltk/d.m/menu.tcl:555
msgid "List columns"
msgstr "Listar columnas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:606 ../gui/tcltk/d.m/menu.tcl:555
+#: ../gui/tcltk/gis.m/gmmenu.tcl:611 ../gui/tcltk/d.m/menu.tcl:556
msgid "List drivers"
msgstr "Listar controladores"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:607 ../gui/tcltk/d.m/menu.tcl:556
+#: ../gui/tcltk/gis.m/gmmenu.tcl:612 ../gui/tcltk/d.m/menu.tcl:557
msgid "List tables"
msgstr "Listar tablas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:610 ../gui/tcltk/d.m/menu.tcl:543
+#: ../gui/tcltk/gis.m/gmmenu.tcl:615 ../gui/tcltk/d.m/menu.tcl:544
msgid "Manage database"
msgstr "Administrar base de datos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:611 ../gui/tcltk/d.m/menu.tcl:544
+#: ../gui/tcltk/gis.m/gmmenu.tcl:616 ../gui/tcltk/d.m/menu.tcl:545
msgid "Connect to database"
msgstr "Conectar a la base de datos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:612 ../gui/tcltk/d.m/menu.tcl:545
+#: ../gui/tcltk/gis.m/gmmenu.tcl:617 ../gui/tcltk/d.m/menu.tcl:546
msgid "Login to database"
msgstr "Ingresar en base de datos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:614 ../gui/tcltk/d.m/menu.tcl:547
+#: ../gui/tcltk/gis.m/gmmenu.tcl:619 ../gui/tcltk/d.m/menu.tcl:548
msgid "Copy table"
msgstr "Copiar tabla"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:615
+#: ../gui/tcltk/gis.m/gmmenu.tcl:620
msgid "New table"
msgstr "Nueva tabla"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:616
+#: ../gui/tcltk/gis.m/gmmenu.tcl:621
msgid "Remove table"
msgstr "Eliminar tabla"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:618
+#: ../gui/tcltk/gis.m/gmmenu.tcl:623
msgid "Add columns"
msgstr "Añadir columnas"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:619
+#: ../gui/tcltk/gis.m/gmmenu.tcl:624
msgid "Change values"
msgstr "Cambiar valores"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:620
+#: ../gui/tcltk/gis.m/gmmenu.tcl:625
msgid "Drop column"
msgstr "Quitar columna"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:621
+#: ../gui/tcltk/gis.m/gmmenu.tcl:626
msgid "Rename a column"
msgstr "Cambiar nombre de una columna"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:623 ../gui/tcltk/d.m/menu.tcl:550
+#: ../gui/tcltk/gis.m/gmmenu.tcl:628 ../gui/tcltk/d.m/menu.tcl:551
msgid "Test database"
msgstr "Probar base de datos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:627
+#: ../gui/tcltk/gis.m/gmmenu.tcl:632
msgid "Query any table"
msgstr "Consultar cualquier tabla"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:628
+#: ../gui/tcltk/gis.m/gmmenu.tcl:633
msgid "Query vector attribute table"
msgstr "Consultar tabla de atributos de un vectorial"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:629
+#: ../gui/tcltk/gis.m/gmmenu.tcl:634
msgid "SQL statement"
msgstr "Sentencia SQL"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:631 ../gui/tcltk/d.m/menu.tcl:401
+#: ../gui/tcltk/gis.m/gmmenu.tcl:636 ../gui/tcltk/d.m/menu.tcl:402
msgid "Vector<->database connections"
msgstr "Conexión vectorial <-> base de datos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:632
+#: ../gui/tcltk/gis.m/gmmenu.tcl:637
msgid "Reconnect vector to database"
msgstr "Volver a conectar vectorial a base de datos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:633
+#: ../gui/tcltk/gis.m/gmmenu.tcl:638
msgid "Set vector - database connection"
msgstr "Configurar conexión vectorial - base de datos"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:636 ../gui/tcltk/d.m/menu.tcl:564
+#: ../gui/tcltk/gis.m/gmmenu.tcl:641 ../gui/tcltk/d.m/menu.tcl:565
msgid "&Help"
msgstr "&Ayuda"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:637 ../gui/tcltk/d.m/menu.tcl:565
+#: ../gui/tcltk/gis.m/gmmenu.tcl:642 ../gui/tcltk/d.m/menu.tcl:566
msgid "GRASS help"
msgstr "Manual de usuario"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:638 ../gui/tcltk/d.m/menu.tcl:566
+#: ../gui/tcltk/gis.m/gmmenu.tcl:643 ../gui/tcltk/d.m/menu.tcl:567
msgid "GIS Manager &help"
msgstr "&Ayuda del Administrador GIS"
msgid "GIS Manager help"
msgstr "Ayuda del Administrador GIS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:639 ../gui/tcltk/d.m/menu.tcl:567
+#: ../gui/tcltk/gis.m/gmmenu.tcl:644 ../gui/tcltk/d.m/menu.tcl:568
msgid "About &GRASS"
msgstr "Acerca de &GRASS"
msgid "About GRASS"
msgstr "Acerca de GRASS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:640 ../gui/tcltk/d.m/menu.tcl:568
+#: ../gui/tcltk/gis.m/gmmenu.tcl:645 ../gui/tcltk/d.m/menu.tcl:569
msgid "About &System"
msgstr "Acerca del &sistema"
msgid "About System"
msgstr "Acerca del sistema"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:648 ../gui/tcltk/d.m/menu.tcl:576
+#: ../gui/tcltk/gis.m/gmmenu.tcl:653 ../gui/tcltk/d.m/menu.tcl:577
msgid "&Xtns"
msgstr "E&xtensiones"
@@ -3945,199 +3985,200 @@
msgid "\tchart outline color:"
msgstr "\tcolor de borde del gráfico:"
-#: ../gui/tcltk/gis.m/vector.tcl:229
+#: ../gui/tcltk/gis.m/vector.tcl:226
msgid "Vector output map"
msgstr "Mapa vectorial de salida"
-#: ../gui/tcltk/gis.m/vector.tcl:299
+#: ../gui/tcltk/gis.m/vector.tcl:296
msgid "Display vector maps"
msgstr "Visualizar mapas vectoriales"
-#: ../gui/tcltk/gis.m/vector.tcl:310
+#: ../gui/tcltk/gis.m/vector.tcl:307
msgid "Transparent"
msgstr "Transparente"
-#: ../gui/tcltk/gis.m/vector.tcl:319
+#: ../gui/tcltk/gis.m/vector.tcl:316
msgid "vector map to display"
msgstr "vectorial a visualizar"
-#: ../gui/tcltk/gis.m/vector.tcl:324 ../gui/tcltk/gis.m/vector.tcl:328
+#: ../gui/tcltk/gis.m/vector.tcl:321 ../gui/tcltk/gis.m/vector.tcl:325
msgid "Vector Info"
msgstr "Información del vectorial"
-#: ../gui/tcltk/gis.m/vector.tcl:340
+#: ../gui/tcltk/gis.m/vector.tcl:337
msgid "Display: "
msgstr "Visualizar: "
-#: ../gui/tcltk/gis.m/vector.tcl:341
+#: ../gui/tcltk/gis.m/vector.tcl:338
msgid "Shapes "
msgstr "Formas "
-#: ../gui/tcltk/gis.m/vector.tcl:343
+#: ../gui/tcltk/gis.m/vector.tcl:340
msgid "Categories "
msgstr "CategorÃas "
-#: ../gui/tcltk/gis.m/vector.tcl:345
+#: ../gui/tcltk/gis.m/vector.tcl:342
msgid "Topology "
msgstr "TopologÃa "
-#: ../gui/tcltk/gis.m/vector.tcl:347
+#: ../gui/tcltk/gis.m/vector.tcl:344
msgid "Line directions "
msgstr "Direcciones de lÃnea "
-#: ../gui/tcltk/gis.m/vector.tcl:355
+#: ../gui/tcltk/gis.m/vector.tcl:352
msgid "Points "
msgstr "Puntos "
-#: ../gui/tcltk/gis.m/vector.tcl:357
+#: ../gui/tcltk/gis.m/vector.tcl:354
msgid "Lines "
msgstr "LÃneas "
-#: ../gui/tcltk/gis.m/vector.tcl:359
+#: ../gui/tcltk/gis.m/vector.tcl:356
msgid "Boundaries "
msgstr "Contornos "
-#: ../gui/tcltk/gis.m/vector.tcl:361
+#: ../gui/tcltk/gis.m/vector.tcl:358
msgid "Areas "
msgstr "Ãreas "
-#: ../gui/tcltk/gis.m/vector.tcl:363
+#: ../gui/tcltk/gis.m/vector.tcl:360
msgid "Centroids "
msgstr "Centroides "
-#: ../gui/tcltk/gis.m/vector.tcl:365
+#: ../gui/tcltk/gis.m/vector.tcl:362
msgid "Faces "
msgstr "Caras "
-#: ../gui/tcltk/gis.m/vector.tcl:372
+#: ../gui/tcltk/gis.m/vector.tcl:369
msgid "Point symbols:"
msgstr "SÃmbolos de puntos:"
-#: ../gui/tcltk/gis.m/vector.tcl:373
+#: ../gui/tcltk/gis.m/vector.tcl:370
msgid "Icon"
msgstr "Icono"
-#: ../gui/tcltk/gis.m/vector.tcl:377
+#: ../gui/tcltk/gis.m/vector.tcl:374
msgid " Size"
msgstr " Tamaño"
-#: ../gui/tcltk/gis.m/vector.tcl:379
+#: ../gui/tcltk/gis.m/vector.tcl:376
msgid "Icon size"
msgstr "Tamaño de icono"
-#: ../gui/tcltk/gis.m/vector.tcl:385 ../gui/tcltk/d.m/vector.tcl:259
+#: ../gui/tcltk/gis.m/vector.tcl:382 ../gui/tcltk/d.m/vector.tcl:259
msgid "Draw lines:"
msgstr "Dibujar lÃneas:"
-#: ../gui/tcltk/gis.m/vector.tcl:388 ../gui/tcltk/gis.m/vector.tcl:404
+#: ../gui/tcltk/gis.m/vector.tcl:385 ../gui/tcltk/gis.m/vector.tcl:401
msgid "Color"
msgstr "Color"
-#: ../gui/tcltk/gis.m/vector.tcl:391
+#: ../gui/tcltk/gis.m/vector.tcl:388
msgid " Width"
msgstr " Anchura"
-#: ../gui/tcltk/gis.m/vector.tcl:393
+#: ../gui/tcltk/gis.m/vector.tcl:390
msgid "Line width"
msgstr "Anchura de lÃnea"
-#: ../gui/tcltk/gis.m/vector.tcl:395
+#: ../gui/tcltk/gis.m/vector.tcl:392
msgid "(pixels) "
msgstr "(pÃxeles) "
-#: ../gui/tcltk/gis.m/vector.tcl:401 ../gui/tcltk/d.m/vector.tcl:275
+#: ../gui/tcltk/gis.m/vector.tcl:398 ../gui/tcltk/d.m/vector.tcl:275
msgid "Fill areas:"
msgstr "Rellenar áreas:"
-#: ../gui/tcltk/gis.m/vector.tcl:408
+#: ../gui/tcltk/gis.m/vector.tcl:405
msgid "Random colors "
msgstr "Colores aleatorios "
-#: ../gui/tcltk/gis.m/vector.tcl:410 ../gui/tcltk/d.m/vector.tcl:284
+#: ../gui/tcltk/gis.m/vector.tcl:407 ../gui/tcltk/d.m/vector.tcl:284
msgid "GRASSRGB column colors"
msgstr "columna de colores 'GRASSRGB'"
-#: ../gui/tcltk/gis.m/vector.tcl:417 ../gui/tcltk/d.m/vector.tcl:291
+#: ../gui/tcltk/gis.m/vector.tcl:414 ../gui/tcltk/d.m/vector.tcl:291
msgid "Label vectors:"
msgstr "Etiquetar vectoriales:"
-#: ../gui/tcltk/gis.m/vector.tcl:418 ../gui/tcltk/d.m/vector.tcl:292
+#: ../gui/tcltk/gis.m/vector.tcl:415 ../gui/tcltk/d.m/vector.tcl:292
msgid "label"
msgstr "Etiqueta"
-#: ../gui/tcltk/gis.m/vector.tcl:420
+#: ../gui/tcltk/gis.m/vector.tcl:417
msgid " Text color"
msgstr " Color de texto"
-#: ../gui/tcltk/gis.m/vector.tcl:423
+#: ../gui/tcltk/gis.m/vector.tcl:420
msgid " Text size"
msgstr " Tamaño de texto"
-#: ../gui/tcltk/gis.m/vector.tcl:425 ../gui/tcltk/d.m/vector.tcl:299
+#: ../gui/tcltk/gis.m/vector.tcl:422 ../gui/tcltk/d.m/vector.tcl:299
msgid "text size"
msgstr "tamaño del texto"
-#: ../gui/tcltk/gis.m/vector.tcl:433
+#: ../gui/tcltk/gis.m/vector.tcl:430
msgid "Label part to align with vector point"
msgstr "Parte de la etiqueta para alinear con punto vectorial"
-#: ../gui/tcltk/gis.m/vector.tcl:437
+#: ../gui/tcltk/gis.m/vector.tcl:434
msgid " Justification"
msgstr " Justificación"
-#: ../gui/tcltk/gis.m/vector.tcl:446
+#: ../gui/tcltk/gis.m/vector.tcl:443
msgid " Layer for labels"
msgstr " Capa para etiquetas"
-#: ../gui/tcltk/gis.m/vector.tcl:448
-msgid " Attribute col for labels"
+#: ../gui/tcltk/gis.m/vector.tcl:445
+#, fuzzy
+msgid " Attribute column for labels"
msgstr " Columna de atributos para las etiquetas"
-#: ../gui/tcltk/gis.m/vector.tcl:455
+#: ../gui/tcltk/gis.m/vector.tcl:452
msgid "Query vectors for display: "
msgstr "Consultar vectoriales para visualizar: "
-#: ../gui/tcltk/gis.m/vector.tcl:456 ../gui/tcltk/d.m/vector.tcl:327
+#: ../gui/tcltk/gis.m/vector.tcl:453 ../gui/tcltk/d.m/vector.tcl:327
msgid "layer for query"
msgstr "capa para consulta"
-#: ../gui/tcltk/gis.m/vector.tcl:464
+#: ../gui/tcltk/gis.m/vector.tcl:461
msgid "Query cat values"
msgstr "Valores de las categorÃas para la consulta"
-#: ../gui/tcltk/gis.m/vector.tcl:475
+#: ../gui/tcltk/gis.m/vector.tcl:472
msgid "Use SQL query"
msgstr "Usar consulta SQL"
-#: ../gui/tcltk/gis.m/vector.tcl:483
+#: ../gui/tcltk/gis.m/vector.tcl:480
msgid " Show attribute columns"
msgstr " Mostrar columnas de atributos"
-#: ../gui/tcltk/gis.m/vector.tcl:489
+#: ../gui/tcltk/gis.m/vector.tcl:486
msgid " Show attribute data"
msgstr " Mostrar atributos"
-#: ../gui/tcltk/gis.m/vector.tcl:501
+#: ../gui/tcltk/gis.m/vector.tcl:498
msgid "Save displayed objects to new vector file "
msgstr "Guardar objetos visualizados en nuevo vectorial "
-#: ../gui/tcltk/gis.m/vector.tcl:503
+#: ../gui/tcltk/gis.m/vector.tcl:500
msgid "Overwrite existing"
msgstr "Sobrescribir existente"
-#: ../gui/tcltk/gis.m/vector.tcl:510
+#: ../gui/tcltk/gis.m/vector.tcl:507
msgid " New vector"
msgstr " Nuevo vectorial"
-#: ../gui/tcltk/gis.m/vector.tcl:514
+#: ../gui/tcltk/gis.m/vector.tcl:511
msgid "Select existing vector for saving queried objects"
msgstr "Seleccionar vectorial existente para guardar objetos consultados"
-#: ../gui/tcltk/gis.m/vector.tcl:522 ../gui/tcltk/d.m/vector.tcl:376
+#: ../gui/tcltk/gis.m/vector.tcl:519 ../gui/tcltk/d.m/vector.tcl:376
msgid "Display when avg. region dimension is"
msgstr "Visualizar cuando la dimensión media de la región sea"
-#: ../gui/tcltk/gis.m/vector.tcl:525
+#: ../gui/tcltk/gis.m/vector.tcl:522
msgid " or <"
msgstr " o <"
@@ -4145,40 +4186,50 @@
msgid "Command:"
msgstr "Comando:"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:526
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:546
msgid "Maximum zoom-in reached"
msgstr "Máximo aumento de zum alcanzado"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:596 ../gui/tcltk/gis.m/mapcanvas.tcl:1225
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:609 ../gui/tcltk/gis.m/mapcanvas.tcl:618
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1098 ../gui/tcltk/gis.m/mapcanvas.tcl:1105
+msgid "Cannot explore beyond the poles: switching into constrained mode"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:610 ../gui/tcltk/gis.m/mapcanvas.tcl:619
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1099 ../gui/tcltk/gis.m/mapcanvas.tcl:1106
+msgid "Switching to constrained mode"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:638 ../gui/tcltk/gis.m/mapcanvas.tcl:1288
#: ../gui/tcltk/gis.m/georect.tcl:1587
msgid "Error setting region"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:605
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:647
msgid "please wait..."
msgstr "por favor espere..."
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:764 ../gui/tcltk/gis.m/mapcanvas.tcl:1819
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:806 ../gui/tcltk/gis.m/mapcanvas.tcl:1882
msgid "You have to select map layer first"
msgstr "Tiene que seleccionar la capa del mapa primero"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:765 ../gui/tcltk/gis.m/mapcanvas.tcl:1820
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:807 ../gui/tcltk/gis.m/mapcanvas.tcl:1883
msgid "No map layer selected"
msgstr "Ninguna capa de mapa seleccionada"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:837
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:879
msgid "Save Region"
msgstr "Guardar región"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:840
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:882
msgid "Save current display geometry to named region"
msgstr "Guardar las lÃmites de la visualización actual para la región indicada"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:846
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:888
msgid "Enter region name"
msgstr "Introducir nombre de región"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:881
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:923
#, tcl-format
msgid ""
"Region file %s already exists. \n"
@@ -4187,52 +4238,52 @@
"El archivo de región %s ya existe. \n"
"¿Quiere sobrescribirlo?"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1068
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1131
#, tcl-format
msgid "Display: rows=%d cols=%d N-S res=%g E-W res=%g"
msgstr "Mostrar: filas=%d columnas=%d resolución N-S=%g resolución E-W=%g"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1140
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1203
msgid "Error setting region (Problem with g.region?)"
msgstr "Error al establecer la región (¿Problema con g.region?)"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1188 ../gui/tcltk/gis.m/mapcanvas.tcl:1193
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1251 ../gui/tcltk/gis.m/mapcanvas.tcl:1256
msgid "Error reading current resolution with g.region"
msgstr "Error al leer la resolución actual con g.region"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1250 ../gui/tcltk/gis.m/georect.tcl:2029
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1313 ../gui/tcltk/gis.m/georect.tcl:2029
msgid "Drag or click mouse to zoom"
msgstr "Arrastrar o clic de ratón para hacer zum"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1252 ../gui/tcltk/gis.m/georect.tcl:2031
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1315 ../gui/tcltk/gis.m/georect.tcl:2031
msgid "Drag or click mouse to unzoom"
msgstr "Arrastrar o clic de ratón para deshacer zum"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1487 ../gui/tcltk/gis.m/georect.tcl:2229
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1550 ../gui/tcltk/gis.m/georect.tcl:2229
msgid "Drag with mouse to pan"
msgstr "Arrastrar con el ratón para panorámica"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1614
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1677
msgid "Measurement"
msgstr "Medida"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1633
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1696
msgid "Draw measure line with mouse"
msgstr "Dibujar lÃnea de medida con el ratón"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1790
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1853
msgid "Click to query feature"
msgstr "Hacer clic para consultar elemento"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1858
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1921
msgid "This layer type does not support queries"
msgstr "Este tipo de capa no soporta consultas"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1859
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1922
msgid "Query not supported"
msgstr "Consulta no soportada"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1866
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1929
msgid "You must select a map to query\n"
msgstr "Se debe seleccionar un mapa a consultar\n"
@@ -5279,691 +5330,691 @@
msgid "Set GRASS environment settings"
msgstr "Entorno de trabajo de GRASS"
-#: ../gui/tcltk/d.m/menu.tcl:203
+#: ../gui/tcltk/d.m/menu.tcl:204
#, fuzzy
msgid "Create/edit projection information for current location"
-#: ../gui/tcltk/d.m/menu.tcl:204
+#: ../gui/tcltk/d.m/menu.tcl:205
#, fuzzy
msgid "Show projection information and create projection files"
msgstr ""
"Definir localización usando la proyección contenida en archivo "
"georreferenciado"
-#: ../gui/tcltk/d.m/menu.tcl:206
+#: ../gui/tcltk/d.m/menu.tcl:207
msgid "Convert coordinates from one projection to another"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:208
+#: ../gui/tcltk/d.m/menu.tcl:209
#, fuzzy
msgid "Text"
msgstr "Test"
-#: ../gui/tcltk/d.m/menu.tcl:209
+#: ../gui/tcltk/d.m/menu.tcl:210
#, fuzzy
msgid "Select default text font"
msgstr "Seleccionar fuente de etiqueta"
-#: ../gui/tcltk/d.m/menu.tcl:210
+#: ../gui/tcltk/d.m/menu.tcl:211
#, fuzzy
msgid "Select default freetype text font"
msgstr "seleccionar fuente para texto"
-#: ../gui/tcltk/d.m/menu.tcl:212
+#: ../gui/tcltk/d.m/menu.tcl:213
#, fuzzy
msgid "X-monitor displays"
msgstr "LÃneas a visualizar"
-#: ../gui/tcltk/d.m/menu.tcl:213
+#: ../gui/tcltk/d.m/menu.tcl:214
#, fuzzy
msgid "Configure xmonitor displays"
-#: ../gui/tcltk/d.m/menu.tcl:214
+#: ../gui/tcltk/d.m/menu.tcl:215
msgid "Configure frames for xmonitors"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:215
+#: ../gui/tcltk/d.m/menu.tcl:216
msgid "Start/restart xmonitor at specified window size"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:216
+#: ../gui/tcltk/d.m/menu.tcl:217
msgid "Set active xmonitor to specified size"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:217
+#: ../gui/tcltk/d.m/menu.tcl:218
msgid "Display information about active xmonitor"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:224
+#: ../gui/tcltk/d.m/menu.tcl:225
#, fuzzy
msgid "Compress/decompress raster file"
-#: ../gui/tcltk/d.m/menu.tcl:225
+#: ../gui/tcltk/d.m/menu.tcl:226
#, fuzzy
msgid "Manage boundary definitions"
-#: ../gui/tcltk/d.m/menu.tcl:226
+#: ../gui/tcltk/d.m/menu.tcl:227
#, fuzzy
msgid "Manage null values"
msgstr "incluir valores nulos"
-#: ../gui/tcltk/d.m/menu.tcl:227
+#: ../gui/tcltk/d.m/menu.tcl:228
#, fuzzy
msgid "Manage timestamps for files"
-#: ../gui/tcltk/d.m/menu.tcl:228
+#: ../gui/tcltk/d.m/menu.tcl:229
msgid "Quantization for floating-point maps"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:230
+#: ../gui/tcltk/d.m/menu.tcl:231
#, fuzzy
msgid "Resample (change resolution)"
-#: ../gui/tcltk/d.m/menu.tcl:231
+#: ../gui/tcltk/d.m/menu.tcl:232
#, fuzzy
msgid "Resample using nearest neighbor method"
-#: ../gui/tcltk/d.m/menu.tcl:232
+#: ../gui/tcltk/d.m/menu.tcl:233
#, fuzzy
msgid "Resample using various interpolation methods"
-#: ../gui/tcltk/d.m/menu.tcl:234
+#: ../gui/tcltk/d.m/menu.tcl:235
#, fuzzy
msgid "Resample using regularized spline with tension method"
-#: ../gui/tcltk/d.m/menu.tcl:237
+#: ../gui/tcltk/d.m/menu.tcl:238
#, fuzzy
msgid "Support file creation and maintenance"
-#: ../gui/tcltk/d.m/menu.tcl:239
+#: ../gui/tcltk/d.m/menu.tcl:240
#, fuzzy
msgid "Reproject raster from other location"
-#: ../gui/tcltk/d.m/menu.tcl:240
+#: ../gui/tcltk/d.m/menu.tcl:241
#, fuzzy
msgid "Generate tiling for other projection"
-#: ../gui/tcltk/d.m/menu.tcl:243
+#: ../gui/tcltk/d.m/menu.tcl:244
msgid "Set colors to predefined color tables"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:244
+#: ../gui/tcltk/d.m/menu.tcl:245
msgid "Set colors based on standard deviations"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:245
+#: ../gui/tcltk/d.m/menu.tcl:246
msgid "Set colors using color rules"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:247
+#: ../gui/tcltk/d.m/menu.tcl:248
msgid "Blend 2 color maps to produce 3 RGB files"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:248
+#: ../gui/tcltk/d.m/menu.tcl:249
msgid "Create color image from RGB files"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:249
+#: ../gui/tcltk/d.m/menu.tcl:250
msgid ""
"Create 3 RGB (red, green, blue) maps from 3 HIS (hue, intensity, saturation) "
"maps"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:254
+#: ../gui/tcltk/d.m/menu.tcl:255
#, fuzzy
msgid "Create raster buffers"
-#: ../gui/tcltk/d.m/menu.tcl:255
+#: ../gui/tcltk/d.m/menu.tcl:256
#, fuzzy
msgid "Create raster MASK"
msgstr "Crear perfil de mapa ráster"
-#: ../gui/tcltk/d.m/menu.tcl:256
+#: ../gui/tcltk/d.m/menu.tcl:257
msgid "Locate closest points between areas in 2 raster maps"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:259
+#: ../gui/tcltk/d.m/menu.tcl:260
msgid "Moving window analysis of raster cells"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:260
+#: ../gui/tcltk/d.m/menu.tcl:261
msgid "Analyze vector points in neighborhood of raster cells"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:264
+#: ../gui/tcltk/d.m/menu.tcl:265
msgid "Function of map series (time series)"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:267
+#: ../gui/tcltk/d.m/menu.tcl:268
msgid "Statistical calculations for cover map over base map"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:270
+#: ../gui/tcltk/d.m/menu.tcl:271
#, fuzzy
msgid "Solar irradiance and daily irradiation"
-#: ../gui/tcltk/d.m/menu.tcl:271
+#: ../gui/tcltk/d.m/menu.tcl:272
msgid "Shadows map for sun position or date/time"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:274
+#: ../gui/tcltk/d.m/menu.tcl:275
#, fuzzy
msgid "Calculate cumulative movement costs between locales"
-#: ../gui/tcltk/d.m/menu.tcl:277
+#: ../gui/tcltk/d.m/menu.tcl:278
#, fuzzy
msgid "Profile analysis"
-#: ../gui/tcltk/d.m/menu.tcl:278
+#: ../gui/tcltk/d.m/menu.tcl:279
#, fuzzy
msgid "Shaded relief map"
-#: ../gui/tcltk/d.m/menu.tcl:282
+#: ../gui/tcltk/d.m/menu.tcl:283
#, fuzzy
msgid "Visibility/line of sight"
-#: ../gui/tcltk/d.m/menu.tcl:286
+#: ../gui/tcltk/d.m/menu.tcl:287
msgid "Clump small areas (statistics calculated by r.volume)"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:287
+#: ../gui/tcltk/d.m/menu.tcl:288
#, fuzzy
msgid "Grow areas"
msgstr "áreas"
-#: ../gui/tcltk/d.m/menu.tcl:288
+#: ../gui/tcltk/d.m/menu.tcl:289
#, fuzzy
msgid "Thin linear features"
-#: ../gui/tcltk/d.m/menu.tcl:292
+#: ../gui/tcltk/d.m/menu.tcl:293
msgid "Carve stream channels into elevation map using vector streams map"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:293
+#: ../gui/tcltk/d.m/menu.tcl:294
#, fuzzy
msgid "Depressionless elevation map and flowline map"
-#: ../gui/tcltk/d.m/menu.tcl:294
+#: ../gui/tcltk/d.m/menu.tcl:295
msgid "Fill lake from seed point to specified level"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:295
+#: ../gui/tcltk/d.m/menu.tcl:296
#, fuzzy
msgid "Flow accumulation for massive grids"
-#: ../gui/tcltk/d.m/menu.tcl:296
+#: ../gui/tcltk/d.m/menu.tcl:297
#, fuzzy
msgid "Generate flow lines for raster map"
-#: ../gui/tcltk/d.m/menu.tcl:298
+#: ../gui/tcltk/d.m/menu.tcl:299
msgid "SIMWE sediment erosion, transport, & deposition modeling"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:308
+#: ../gui/tcltk/d.m/menu.tcl:309
#, fuzzy
msgid "Analyze landscape characteristics"
-#: ../gui/tcltk/d.m/menu.tcl:309
+#: ../gui/tcltk/d.m/menu.tcl:310
#, fuzzy
msgid "Analyze landscape patch characteristics"
-#: ../gui/tcltk/d.m/menu.tcl:310
+#: ../gui/tcltk/d.m/menu.tcl:311
#, fuzzy
msgid "Output landscape patch information"
-#: ../gui/tcltk/d.m/menu.tcl:313
+#: ../gui/tcltk/d.m/menu.tcl:314
msgid "Generate rate of spread (ROS) maps"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:314
+#: ../gui/tcltk/d.m/menu.tcl:315
#, fuzzy
msgid "Generate least-cost spread paths"
-#: ../gui/tcltk/d.m/menu.tcl:315
+#: ../gui/tcltk/d.m/menu.tcl:316
#, fuzzy
msgid "Simulate anisotropic spread phenomena"
-#: ../gui/tcltk/d.m/menu.tcl:319
+#: ../gui/tcltk/d.m/menu.tcl:320
msgid "Edit category values of individual cells for displayed raster map"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:322
+#: ../gui/tcltk/d.m/menu.tcl:323
msgid "Reclassify categories for areas of specified sizes"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:323
+#: ../gui/tcltk/d.m/menu.tcl:324
#, fuzzy
msgid "Reclassify categories using rules"
-#: ../gui/tcltk/d.m/menu.tcl:324
+#: ../gui/tcltk/d.m/menu.tcl:325
#, fuzzy
msgid "Reclassify categories using rules file"
-#: ../gui/tcltk/d.m/menu.tcl:326
+#: ../gui/tcltk/d.m/menu.tcl:327
msgid "Recode categories using rules (create new map)"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:327
+#: ../gui/tcltk/d.m/menu.tcl:328
#, fuzzy
msgid "Recode categories using rules file (create new map)"
-#: ../gui/tcltk/d.m/menu.tcl:329
+#: ../gui/tcltk/d.m/menu.tcl:330
#, fuzzy
msgid "Rescale categories (create new map)"
msgstr " intervalo entre categorÃas (mapas enteros)"
-#: ../gui/tcltk/d.m/menu.tcl:330
+#: ../gui/tcltk/d.m/menu.tcl:331
msgid "Rescale categories with equalized histogram (create new map)"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:333
+#: ../gui/tcltk/d.m/menu.tcl:334
#, fuzzy
msgid "Generate concentric circles around points"
-#: ../gui/tcltk/d.m/menu.tcl:334
+#: ../gui/tcltk/d.m/menu.tcl:335
#, fuzzy
msgid "Generate random raster cells"
-#: ../gui/tcltk/d.m/menu.tcl:336
+#: ../gui/tcltk/d.m/menu.tcl:337
#, fuzzy
msgid "Generate random cells and vector points from raster map"
-#: ../gui/tcltk/d.m/menu.tcl:339
+#: ../gui/tcltk/d.m/menu.tcl:340
msgid "Generate density surface using moving Gausian kernal"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:340
+#: ../gui/tcltk/d.m/menu.tcl:341
#, fuzzy
msgid "Generate fractal surface"
-#: ../gui/tcltk/d.m/menu.tcl:341
+#: ../gui/tcltk/d.m/menu.tcl:342
#, fuzzy
msgid "Generate gaussian deviates surface"
-#: ../gui/tcltk/d.m/menu.tcl:342
+#: ../gui/tcltk/d.m/menu.tcl:343
#, fuzzy
msgid "Generate plane"
-#: ../gui/tcltk/d.m/menu.tcl:343
+#: ../gui/tcltk/d.m/menu.tcl:344
#, fuzzy
msgid "Generate random deviates surface"
-#: ../gui/tcltk/d.m/menu.tcl:344
+#: ../gui/tcltk/d.m/menu.tcl:345
#, fuzzy
msgid "Generate random surface with spatial dependence"
-#: ../gui/tcltk/d.m/menu.tcl:346
+#: ../gui/tcltk/d.m/menu.tcl:347
#, fuzzy
msgid "Generate vector contour lines"
-#: ../gui/tcltk/d.m/menu.tcl:348
+#: ../gui/tcltk/d.m/menu.tcl:349
#, fuzzy
msgid "Bilinear interpolation from raster points"
-#: ../gui/tcltk/d.m/menu.tcl:349
+#: ../gui/tcltk/d.m/menu.tcl:350
msgid "Inverse distance weighted interpolation from raster points"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:350
+#: ../gui/tcltk/d.m/menu.tcl:351
#, fuzzy
msgid "Interpolation from raster contours"
-#: ../gui/tcltk/d.m/menu.tcl:352
+#: ../gui/tcltk/d.m/menu.tcl:353
#, fuzzy
msgid "Inverse distance weighted interpolation from vector points"
-#: ../gui/tcltk/d.m/menu.tcl:353
+#: ../gui/tcltk/d.m/menu.tcl:354
msgid "Regularized spline tension interpolation from vector points or contours"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:355
+#: ../gui/tcltk/d.m/menu.tcl:356
msgid "Fill NULL cells by interpolation using regularized spline tension"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:360
+#: ../gui/tcltk/d.m/menu.tcl:361
#, fuzzy
msgid "Manage category labels and values"
-#: ../gui/tcltk/d.m/menu.tcl:363
+#: ../gui/tcltk/d.m/menu.tcl:364
#, fuzzy
msgid "Range of all category values"
-#: ../gui/tcltk/d.m/menu.tcl:364
+#: ../gui/tcltk/d.m/menu.tcl:365
#, fuzzy
msgid "Sum all cell category values"
-#: ../gui/tcltk/d.m/menu.tcl:366
+#: ../gui/tcltk/d.m/menu.tcl:367
#, fuzzy
msgid "Summary statistics for clumped cells (works with r.clump)"
-#: ../gui/tcltk/d.m/menu.tcl:369
+#: ../gui/tcltk/d.m/menu.tcl:370
#, fuzzy
msgid "Univariate statistics (script version)"
-#: ../gui/tcltk/d.m/menu.tcl:371
+#: ../gui/tcltk/d.m/menu.tcl:372
#, fuzzy
msgid "Sample values along transects"
-#: ../gui/tcltk/d.m/menu.tcl:372
+#: ../gui/tcltk/d.m/menu.tcl:373
#, fuzzy
msgid "Sample values along transects (use azimuth, distance)"
-#: ../gui/tcltk/d.m/menu.tcl:375
+#: ../gui/tcltk/d.m/menu.tcl:376
#, fuzzy
msgid "Linear regression between 2 maps"
-#: ../gui/tcltk/d.m/menu.tcl:376
+#: ../gui/tcltk/d.m/menu.tcl:377
#, fuzzy
msgid "Mutual category occurences (coincidence)"
-#: ../gui/tcltk/d.m/menu.tcl:384
+#: ../gui/tcltk/d.m/menu.tcl:385
#, fuzzy
msgid "Clean vector files"
-#: ../gui/tcltk/d.m/menu.tcl:385
+#: ../gui/tcltk/d.m/menu.tcl:386
#, fuzzy
msgid "Add missing centroids"
-#: ../gui/tcltk/d.m/menu.tcl:387
+#: ../gui/tcltk/d.m/menu.tcl:388
msgid "Build polylines from adjacent segments"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:388
+#: ../gui/tcltk/d.m/menu.tcl:389
#, fuzzy
msgid "Split polylines into segments"
-#: ../gui/tcltk/d.m/menu.tcl:389
+#: ../gui/tcltk/d.m/menu.tcl:390
#, fuzzy
msgid "Create lines parallel to existing lines"
-#: ../gui/tcltk/d.m/menu.tcl:390
+#: ../gui/tcltk/d.m/menu.tcl:391
#, fuzzy
msgid "Dissolve common boundaries"
-#: ../gui/tcltk/d.m/menu.tcl:392
+#: ../gui/tcltk/d.m/menu.tcl:393
#, fuzzy
msgid "Convert vector feature types"
-#: ../gui/tcltk/d.m/menu.tcl:393
+#: ../gui/tcltk/d.m/menu.tcl:394
#, fuzzy
msgid "Convert 2D vector to 3D by sampling raster"
-#: ../gui/tcltk/d.m/menu.tcl:394
+#: ../gui/tcltk/d.m/menu.tcl:395
#, fuzzy
msgid "Extrude 2D vector into 3D vector"
-#: ../gui/tcltk/d.m/menu.tcl:396
+#: ../gui/tcltk/d.m/menu.tcl:397
#, fuzzy
msgid "Create text label file for vector features"
msgstr ""
"Crear etiquetas PostScript para objetos vectoriales a partir de archivo v."
"labels"
-#: ../gui/tcltk/d.m/menu.tcl:397
+#: ../gui/tcltk/d.m/menu.tcl:398
msgid "Assign colors from a numeric attribute column"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:399
+#: ../gui/tcltk/d.m/menu.tcl:400
#, fuzzy
msgid "Reproject vector from other location"
msgstr "Proyección para la localización actual"
-#: ../gui/tcltk/d.m/menu.tcl:402
+#: ../gui/tcltk/d.m/menu.tcl:403
msgid "Create new vector as link to external OGR layer"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:403
+#: ../gui/tcltk/d.m/menu.tcl:404
msgid "Set database connection for vector attributes"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:405
+#: ../gui/tcltk/d.m/menu.tcl:406
#, fuzzy
msgid "Rectify and georeference vector map"
msgstr "Georreferenciar vectorial"
-#: ../gui/tcltk/d.m/menu.tcl:407
+#: ../gui/tcltk/d.m/menu.tcl:408
#, fuzzy
msgid "Query by attributes"
-#: ../gui/tcltk/d.m/menu.tcl:409
+#: ../gui/tcltk/d.m/menu.tcl:410
#, fuzzy
msgid "Query by map features"
-#: ../gui/tcltk/d.m/menu.tcl:411
+#: ../gui/tcltk/d.m/menu.tcl:412
#, fuzzy
msgid "Create vector buffers"
-#: ../gui/tcltk/d.m/menu.tcl:412
+#: ../gui/tcltk/d.m/menu.tcl:413
#, fuzzy
msgid "Linear referencing for vectors"
-#: ../gui/tcltk/d.m/menu.tcl:413
+#: ../gui/tcltk/d.m/menu.tcl:414
msgid "Create linear reference system"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:414
+#: ../gui/tcltk/d.m/menu.tcl:415
msgid "Create stationing from imput lines, and linear reference system"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:415
+#: ../gui/tcltk/d.m/menu.tcl:416
msgid ""
"Create points/segments from input lines, linear reference system and "
"positions read from stdin"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:416
+#: ../gui/tcltk/d.m/menu.tcl:417
msgid ""
"Find line id and real km+offset for given points in vector map using linear "
"reference system"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:419
+#: ../gui/tcltk/d.m/menu.tcl:420
msgid "Locate nearest features to points or centroids"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:420
+#: ../gui/tcltk/d.m/menu.tcl:421
msgid "Generate Thiessen polygons around points (Voronoi diagram)"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:421
+#: ../gui/tcltk/d.m/menu.tcl:422
msgid "Connect points to create Delaunay triangles"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:427
+#: ../gui/tcltk/d.m/menu.tcl:428
msgid "Shortest route (visualization only)"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:428
+#: ../gui/tcltk/d.m/menu.tcl:429
msgid "Split net to bands between cost isolines"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:433
+#: ../gui/tcltk/d.m/menu.tcl:434
#, fuzzy
msgid "Overlay/combine 2 vector maps"
-#: ../gui/tcltk/d.m/menu.tcl:434
+#: ../gui/tcltk/d.m/menu.tcl:435
#, fuzzy
msgid "Patch multiple maps (combine)"
-#: ../gui/tcltk/d.m/menu.tcl:436
+#: ../gui/tcltk/d.m/menu.tcl:437
#, fuzzy
msgid "Generate area feature for extent of current region"
-#: ../gui/tcltk/d.m/menu.tcl:437
+#: ../gui/tcltk/d.m/menu.tcl:438
#, fuzzy
msgid "Generate rectangular vector grid"
msgstr "Crear/reemplazar grupo de vectoriales"
-#: ../gui/tcltk/d.m/menu.tcl:440
+#: ../gui/tcltk/d.m/menu.tcl:441
#, fuzzy
msgid "Attach, delete, or report categories"
-#: ../gui/tcltk/d.m/menu.tcl:441
+#: ../gui/tcltk/d.m/menu.tcl:442
#, fuzzy
msgid "Reclassify features using rules file"
-#: ../gui/tcltk/d.m/menu.tcl:444
+#: ../gui/tcltk/d.m/menu.tcl:445
#, fuzzy
msgid "Work with vector points"
-#: ../gui/tcltk/d.m/menu.tcl:446
+#: ../gui/tcltk/d.m/menu.tcl:447
#, fuzzy
msgid "Generate points from database with x/y coordinates"
-#: ../gui/tcltk/d.m/menu.tcl:448
+#: ../gui/tcltk/d.m/menu.tcl:449
#, fuzzy
msgid "Random location perturbations of points"
-#: ../gui/tcltk/d.m/menu.tcl:451
+#: ../gui/tcltk/d.m/menu.tcl:452
#, fuzzy
msgid "Generate convex hull for point set"
-#: ../gui/tcltk/d.m/menu.tcl:452
+#: ../gui/tcltk/d.m/menu.tcl:453
#, fuzzy
msgid "Generate Delaunay triangles for point set"
-#: ../gui/tcltk/d.m/menu.tcl:453
+#: ../gui/tcltk/d.m/menu.tcl:454
#, fuzzy
msgid "Generate Voronoi diagram/Thiessen polygons for point set"
-#: ../gui/tcltk/d.m/menu.tcl:455
+#: ../gui/tcltk/d.m/menu.tcl:456
#, fuzzy
msgid "Sample raster maps"
msgstr "Animar mapas ráster"
-#: ../gui/tcltk/d.m/menu.tcl:456
+#: ../gui/tcltk/d.m/menu.tcl:457
msgid "Calculate statistics for raster map overlain by vector map"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:460
+#: ../gui/tcltk/d.m/menu.tcl:461
msgid "Partition points into test/training sets for k-fold cross validatation"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:461
+#: ../gui/tcltk/d.m/menu.tcl:462
msgid "Transfer attribute data from queried vector map to points"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:466
+#: ../gui/tcltk/d.m/menu.tcl:467
msgid "Load vector attributes to database or create reports"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:467
+#: ../gui/tcltk/d.m/menu.tcl:468
#, fuzzy
msgid "Report areas for vector attribute categories"
-#: ../gui/tcltk/d.m/menu.tcl:470
+#: ../gui/tcltk/d.m/menu.tcl:471
msgid "Test normality of point distribution"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:471
+#: ../gui/tcltk/d.m/menu.tcl:472
msgid "Calculate stats for raster map underlying vector objects"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:472
+#: ../gui/tcltk/d.m/menu.tcl:473
msgid "Indices of point counts in quadrats"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:477
+#: ../gui/tcltk/d.m/menu.tcl:478
#, fuzzy
msgid "Create/edit imagery group"
-#: ../gui/tcltk/d.m/menu.tcl:478
+#: ../gui/tcltk/d.m/menu.tcl:479
#, fuzzy
msgid "Target imagery group"
-#: ../gui/tcltk/d.m/menu.tcl:480
+#: ../gui/tcltk/d.m/menu.tcl:481
#, fuzzy
msgid "Mosaic up to 4 adjacent images"
-#: ../gui/tcltk/d.m/menu.tcl:483
+#: ../gui/tcltk/d.m/menu.tcl:484
msgid ""
"Color balance and enhance color tables of multiband imagery for rgb display"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:484
+#: ../gui/tcltk/d.m/menu.tcl:485
msgid ""
"Transform HIS (Hue/Intensity/Saturation) color image to RGB (Red/Green/Blue)"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:485
+#: ../gui/tcltk/d.m/menu.tcl:486
#, fuzzy
msgid ""
"Transform RGB (Red/Green/Blue) color image to HIS (Hue/Intensity/Saturation)"
@@ -5971,127 +6022,127 @@
"Mostrar 3 mapas ráster como canales Rojo/Verde/Azul o de Tonalidad/"
"Intensidad/Saturación"
-#: ../gui/tcltk/d.m/menu.tcl:487
+#: ../gui/tcltk/d.m/menu.tcl:488
msgid "Rectify and georeference image group"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:488
+#: ../gui/tcltk/d.m/menu.tcl:489
msgid "Set ground control points (GCP's) from raster map or keyboard entry"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:490
+#: ../gui/tcltk/d.m/menu.tcl:491
msgid "Set ground control points (GCP's) from vector map or keyboard entry"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:492
+#: ../gui/tcltk/d.m/menu.tcl:493
msgid "Affine and Polynomial rectification (rubber sheet)"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:496
+#: ../gui/tcltk/d.m/menu.tcl:497
msgid "Brovey transformation and pan sharpening"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:504
+#: ../gui/tcltk/d.m/menu.tcl:505
#, fuzzy
msgid "Non-interactive input for supervised classification (MLC)"
-#: ../gui/tcltk/d.m/menu.tcl:505
+#: ../gui/tcltk/d.m/menu.tcl:506
#, fuzzy
msgid "Non-interactive input for supervised classification (SMAP)"
-#: ../gui/tcltk/d.m/menu.tcl:508
+#: ../gui/tcltk/d.m/menu.tcl:509
#, fuzzy
msgid "Zero edge crossing detection"
-#: ../gui/tcltk/d.m/menu.tcl:509
+#: ../gui/tcltk/d.m/menu.tcl:510
#, fuzzy
msgid "User defined matrix/convolving filter"
-#: ../gui/tcltk/d.m/menu.tcl:514
+#: ../gui/tcltk/d.m/menu.tcl:515
#, fuzzy
msgid "Canonical component"
-#: ../gui/tcltk/d.m/menu.tcl:515
+#: ../gui/tcltk/d.m/menu.tcl:516
#, fuzzy
msgid "Principal component"
-#: ../gui/tcltk/d.m/menu.tcl:516
+#: ../gui/tcltk/d.m/menu.tcl:517
#, fuzzy
msgid "Fast Fourier Transform"
-#: ../gui/tcltk/d.m/menu.tcl:517
+#: ../gui/tcltk/d.m/menu.tcl:518
#, fuzzy
msgid "Inverse Fast Fourier Transform"
-#: ../gui/tcltk/d.m/menu.tcl:522
+#: ../gui/tcltk/d.m/menu.tcl:523
#, fuzzy
msgid "Range of image values"
-#: ../gui/tcltk/d.m/menu.tcl:524
+#: ../gui/tcltk/d.m/menu.tcl:525
#, fuzzy
msgid "Bit pattern comparison for ID of low quality pixels"
-#: ../gui/tcltk/d.m/menu.tcl:525
+#: ../gui/tcltk/d.m/menu.tcl:526
msgid "Kappa classification accuracy assessment"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:526
+#: ../gui/tcltk/d.m/menu.tcl:527
#, fuzzy
msgid "Optimum index factor for LandSat TM"
-#: ../gui/tcltk/d.m/menu.tcl:529
+#: ../gui/tcltk/d.m/menu.tcl:530
msgid "&Grid3D"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:534
+#: ../gui/tcltk/d.m/menu.tcl:535
msgid "Create 3D mask for grid3D operations"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:535
+#: ../gui/tcltk/d.m/menu.tcl:536
#, fuzzy
msgid "Create 2D raster cross section from grid3d volume"
-#: ../gui/tcltk/d.m/menu.tcl:536
+#: ../gui/tcltk/d.m/menu.tcl:537
msgid "Map calculator for grid3D operations"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:537
+#: ../gui/tcltk/d.m/menu.tcl:538
#, fuzzy
msgid "Interpolate volume from vector points using splines"
-#: ../gui/tcltk/d.m/menu.tcl:539
+#: ../gui/tcltk/d.m/menu.tcl:540
#, fuzzy
msgid "Display information about grid3D volume"
msgstr "Importar volúmenes grid3D"
-#: ../gui/tcltk/d.m/menu.tcl:548
+#: ../gui/tcltk/d.m/menu.tcl:549
#, fuzzy
msgid "Add columns to table"
-#: ../gui/tcltk/d.m/menu.tcl:549
+#: ../gui/tcltk/d.m/menu.tcl:550
#, fuzzy
msgid "Change values in a column"
-#: ../gui/tcltk/d.m/menu.tcl:560
+#: ../gui/tcltk/d.m/menu.tcl:561
msgid "Query data (SQL select)"
msgstr ""
-#: ../gui/tcltk/d.m/menu.tcl:561
+#: ../gui/tcltk/d.m/menu.tcl:562
#, fuzzy
msgid "Execute SQL statement"
@@ -6438,6 +6489,9 @@
msgid "Test"
msgstr "Test"
+#~ msgid "Run (in Xterm)"
+#~ msgstr "Ejecutar (en Xterm)"
#~ msgid "Zoom to..."
#~ msgstr "Zum a..."
Modified: grass/branches/develbranch_6/locale/po/grasstcl_ru.po
--- grass/branches/develbranch_6/locale/po/grasstcl_ru.po 2009-05-22 15:36:57 UTC (rev 37374)
+++ grass/branches/develbranch_6/locale/po/grasstcl_ru.po 2009-05-22 15:53:49 UTC (rev 37375)
@@ -6,12 +6,12 @@
msgstr ""
"Project-Id-Version: grasstcl_ru\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2009-01-09 17:00+0100\n"
-"PO-Revision-Date: 2008-10-09 22:55-0600\n"
+"POT-Creation-Date: 2009-05-22 17:09+0200\n"
+"PO-Revision-Date: 2009-01-28 23:05-0600\n"
"Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
"Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=utf-8\n"
+"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"X-Generator: KBabel 1.9.1\n"
@@ -36,7 +36,7 @@
msgstr "ÐаÑÑÑойки Ñже оÑкÑÑÑÑ"
#: ../vector/v.digit/settings.tcl:174 ../lib/init/epsg_option.tcl:311
-#: ../lib/init/file_option.tcl:263 ../gui/tcltk/gis.m/gm.tcl:455
+#: ../lib/init/file_option.tcl:264 ../gui/tcltk/gis.m/gm.tcl:455
#: ../gui/tcltk/gis.m/animate.tcl:536 ../gui/tcltk/gis.m/dnviz.tcl:228
#: ../gui/tcltk/gis.m/rules.tcl:170
msgid "OK"
@@ -271,26 +271,26 @@
msgid "Add new"
msgstr "ÐобавиÑÑ Ð½Ð¾Ð²Ñй"
-#: ../lib/gtcltk/select.tcl:103
+#: ../lib/gtcltk/select.tcl:107
msgid "Select item"
msgstr "ÐÑбÑаÑÑ Ð¾Ð±ÑекÑ"
-#: ../lib/gtcltk/select.tcl:208
+#: ../lib/gtcltk/select.tcl:209
msgid "Ok"
msgstr "Ðк"
-#: ../lib/gtcltk/select.tcl:209 ../lib/init/epsg_option.tcl:167
-#: ../lib/init/epsg_option.tcl:314 ../lib/init/file_option.tcl:114
-#: ../lib/init/file_option.tcl:266 ../gui/tcltk/gis.m/gm.tcl:458
+#: ../lib/gtcltk/select.tcl:210 ../lib/init/epsg_option.tcl:167
+#: ../lib/init/epsg_option.tcl:314 ../lib/init/file_option.tcl:115
+#: ../lib/init/file_option.tcl:267 ../gui/tcltk/gis.m/gm.tcl:458
#: ../gui/tcltk/gis.m/animate.tcl:538 ../gui/tcltk/gis.m/dnviz.tcl:230
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:859 ../gui/tcltk/gis.m/georect.tcl:703
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:901 ../gui/tcltk/gis.m/georect.tcl:703
#: ../gui/tcltk/gis.m/rules.tcl:172
msgid "Cancel"
msgstr "ÐÑмена"
#: ../lib/gis/gui.tcl:11 ../lib/gis/gui.tcl:15 ../lib/gis/gui.tcl:19
-#: ../lib/gis/gui.tcl:310 ../gui/tcltk/gis.m/runandoutput.tcl:270
-#: ../gui/tcltk/gis.m/runandoutput.tcl:276
+#: ../lib/gis/gui.tcl:310 ../gui/tcltk/gis.m/runandoutput.tcl:277
+#: ../gui/tcltk/gis.m/runandoutput.tcl:283
#: ../gui/tcltk/gis.m/grassabout.tcl:94 ../gui/tcltk/gis.m/gmlib.tcl:141
msgid "Error"
msgstr "ÐÑибка"
@@ -304,7 +304,7 @@
msgstr "ÐагÑÑзиÑÑ Ð¤Ð°Ð¹Ð»"
#: ../lib/gis/gui.tcl:295 ../lib/gis/gui.tcl:485
-#: ../gui/tcltk/gis.m/gmmenu.tcl:335
+#: ../gui/tcltk/gis.m/gmmenu.tcl:336
msgid "Output"
msgstr "ÐÑвод"
@@ -322,7 +322,7 @@
msgstr "ÐопиÑоваÑÑ"
#: ../lib/gis/gui.tcl:508 ../gui/tcltk/gis.m/runandoutput.tcl:44
-#: ../gui/tcltk/gis.m/runandoutput.tcl:116
+#: ../gui/tcltk/gis.m/runandoutput.tcl:118
msgid "Run"
msgstr "ÐапÑÑÑиÑÑ"
@@ -341,7 +341,7 @@
#: ../gui/tcltk/gis.m/legend.tcl:219 ../gui/tcltk/gis.m/legend.tcl:222
#: ../gui/tcltk/gis.m/raster.tcl:192 ../gui/tcltk/gis.m/raster.tcl:196
#: ../gui/tcltk/gis.m/chart.tcl:184 ../gui/tcltk/gis.m/chart.tcl:188
-#: ../gui/tcltk/gis.m/vector.tcl:330 ../gui/tcltk/gis.m/vector.tcl:334
+#: ../gui/tcltk/gis.m/vector.tcl:327 ../gui/tcltk/gis.m/vector.tcl:331
#: ../gui/tcltk/gis.m/barscale.tcl:180 ../gui/tcltk/gis.m/barscale.tcl:184
#: ../gui/tcltk/gis.m/rgbhis.tcl:156 ../gui/tcltk/gis.m/rgbhis.tcl:165
#: ../gui/tcltk/gis.m/dtext.tcl:177 ../gui/tcltk/gis.m/dtext.tcl:181
@@ -408,7 +408,7 @@
msgid "Define location using EPSG projection codes"
msgstr "ÐпÑеделиÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ Ð¸ÑполÑзÑÑ ÐºÐ¾Ð´Ñ Ð¿ÑоекÑии EPSG"
-#: ../lib/init/epsg_option.tcl:122 ../lib/init/file_option.tcl:92
+#: ../lib/init/epsg_option.tcl:122 ../lib/init/file_option.tcl:93
msgid "Name of new location"
msgstr "ÐÐ¼Ñ Ð½Ð¾Ð²Ð¾Ð¹ облаÑÑи"
@@ -421,7 +421,7 @@
msgstr "ÐÑÑÑ Ðº ÑÐ°Ð¹Ð»Ñ EPSG-кодов"
#: ../lib/init/epsg_option.tcl:135 ../lib/init/epsg_option.tcl:148
-#: ../lib/init/gis_set.tcl:243 ../lib/init/file_option.tcl:105
+#: ../lib/init/gis_set.tcl:243 ../lib/init/file_option.tcl:106
msgid "Browse..."
msgstr "ÐÑбÑаÑÑ..."
@@ -449,7 +449,7 @@
msgid "WARNING: The epsg-codes file was not found!"
msgstr "ÐÐ ÐÐУÐÐ ÐÐÐÐÐÐÐ: Ñайл кодов epsg не найден!"
-#: ../lib/init/epsg_option.tcl:164 ../lib/init/file_option.tcl:111
+#: ../lib/init/epsg_option.tcl:164 ../lib/init/file_option.tcl:112
msgid "Define location"
msgstr "ÐпÑеделиÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ"
@@ -472,12 +472,12 @@
msgstr "ÐÐ ÐÐУÐÐ ÐÐÐÐÐÐÐ: ÐблаÑÑÑ '%s' Ñже ÑÑÑеÑÑвÑеÑ: иÑполÑзÑйÑе дÑÑгое имÑ."
#: ../lib/init/epsg_option.tcl:236 ../lib/init/epsg_option.tcl:263
-#: ../lib/init/file_option.tcl:185 ../lib/init/file_option.tcl:212
+#: ../lib/init/file_option.tcl:186 ../lib/init/file_option.tcl:213
msgid "Error creating location!"
msgstr "ÐÑибка ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð¾Ð±Ð»Ð°ÑÑи!"
#: ../lib/init/epsg_option.tcl:237 ../lib/init/epsg_option.tcl:264
-#: ../lib/init/file_option.tcl:186 ../lib/init/file_option.tcl:213
+#: ../lib/init/file_option.tcl:187 ../lib/init/file_option.tcl:214
#, tcl-format
msgid ""
"g.proj returned the following message:\n"
@@ -487,12 +487,12 @@
"%s"
#: ../lib/init/epsg_option.tcl:244 ../lib/init/epsg_option.tcl:268
-#: ../lib/init/file_option.tcl:193 ../lib/init/file_option.tcl:217
+#: ../lib/init/file_option.tcl:194 ../lib/init/file_option.tcl:218
msgid "Informational output from g.proj"
msgstr "ÐÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð¸Ð½ÑоÑмаÑÐ¸Ñ r.stats"
#: ../lib/init/epsg_option.tcl:245 ../lib/init/epsg_option.tcl:269
-#: ../lib/init/file_option.tcl:194 ../lib/init/file_option.tcl:218
+#: ../lib/init/file_option.tcl:195 ../lib/init/file_option.tcl:219
#, tcl-format
msgid ""
"g.proj returned the following informational message:\n"
@@ -501,11 +501,11 @@
"g.proj веÑнÑл ÑледÑÑÑее инÑоÑмаÑионное ÑообÑение:\n"
"%s"
-#: ../lib/init/epsg_option.tcl:288 ../lib/init/file_option.tcl:240
+#: ../lib/init/epsg_option.tcl:288 ../lib/init/file_option.tcl:241
msgid "Select datum transformation parameters:"
msgstr "ÐÑбеÑиÑе паÑамеÑÑÑ ÑÑанÑÑоÑмаÑии даÑÑма:"
-#: ../lib/init/epsg_option.tcl:292 ../lib/init/file_option.tcl:244
+#: ../lib/init/epsg_option.tcl:292 ../lib/init/file_option.tcl:245
msgid ""
"Continue without specifying parameters - if used when creating a location, "
"other GRASS modules will use the \"default\" (likely non-optimum) parameters "
@@ -564,9 +564,9 @@
"СообÑение об оÑибке: %s"
#: ../lib/init/gis_set.tcl:128 ../lib/init/gis_set.tcl:379
-#: ../lib/init/gis_set.tcl:485 ../lib/init/gis_set.tcl:606
-#: ../lib/init/gis_set.tcl:627 ../lib/init/gis_set.tcl:645
-#: ../lib/init/gis_set.tcl:673
+#: ../lib/init/gis_set.tcl:485 ../lib/init/gis_set.tcl:617
+#: ../lib/init/gis_set.tcl:638 ../lib/init/gis_set.tcl:656
+#: ../lib/init/gis_set.tcl:684
msgid "WARNING: invalid location"
msgstr "ÐÐ ÐÐУÐÐ ÐÐÐÐÐÐÐ: невеÑÐ½Ð°Ñ Ð¾Ð±Ð»Ð°ÑÑÑ"
@@ -695,7 +695,7 @@
"ÐÑедÑпÑеждение: вÑбÑÐ°Ð½Ð½Ð°Ñ Ð¾Ð±Ð»Ð°ÑÑÑ <%s> непÑавилÑнаÑ. \n"
" ÐÑбеÑиÑе пÑавилÑнÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ Ð¸ попÑобÑйÑе еÑе Ñаз."
-#: ../lib/init/gis_set.tcl:491 ../lib/init/gis_set.tcl:651
+#: ../lib/init/gis_set.tcl:491 ../lib/init/gis_set.tcl:662
msgid "WARNING: invalid mapset"
msgstr "ÐÐ ÐÐУÐÐ ÐÐÐÐÐÐÐ: невеÑнÑй набоÑ"
@@ -713,17 +713,33 @@
msgstr "ÐÑÑ
од"
#: ../lib/init/gis_set.tcl:559
+msgid "Starting GRASS for the first time"
+msgstr ""
+#: ../lib/init/gis_set.tcl:560
+msgid ""
+"GRASS needs a directory in which to store its data. Create one now if you "
+"have not already done so. A popular choice is \"grassdata\", located in "
+"your home directory."
+msgstr ""
+#: ../lib/init/gis_set.tcl:565
+#, fuzzy
+msgid "Select GIS data directory"
+msgstr "ÐовÑй каÑалог ÐÐС даннÑÑ
+#: ../lib/init/gis_set.tcl:570
msgid "WARNING: Invalid Database"
msgstr "ÐÐ ÐÐУÐÐ ÐÐÐÐÐÐÐ: невеÑÐ½Ð°Ñ Ð±Ð°Ð·Ð° даннÑÑ
-#: ../lib/init/gis_set.tcl:560
+#: ../lib/init/gis_set.tcl:571
msgid "WARNING: Invalid database. Finding first valid directory in parent tree"
msgstr ""
"ÐÑедÑпÑеждение: ÐепÑавилÑÐ½Ð°Ñ Ð±Ð°Ð·Ð° даннÑÑ
. ÐоиÑк пеÑвой пÑавилÑной папки в "
"коÑневой"
-#: ../lib/init/gis_set.tcl:607 ../lib/init/gis_set.tcl:628
-#: ../lib/init/gis_set.tcl:646 ../lib/init/gis_set.tcl:674
+#: ../lib/init/gis_set.tcl:618 ../lib/init/gis_set.tcl:639
+#: ../lib/init/gis_set.tcl:657 ../lib/init/gis_set.tcl:685
#, tcl-format
msgid ""
"Warning: selected location <%%s> is not valid. \n"
@@ -732,16 +748,16 @@
"ÐÑедÑпÑеждение: вÑбÑÐ°Ð½Ð½Ð°Ñ Ð¾Ð±Ð»Ð°ÑÑÑ <%%s> непÑавилÑнаÑ. \n"
-#: ../lib/init/gis_set.tcl:652
+#: ../lib/init/gis_set.tcl:663
#, tcl-format
msgid "Warning: <%%s> is not a valid mapset"
msgstr "ÐÑедÑпÑеждение: <%%s> - невеÑнÑй набоÑ"
-#: ../lib/init/gis_set.tcl:746
+#: ../lib/init/gis_set.tcl:757
msgid "WARNING: change directory failed"
msgstr "ÐÐ ÐÐУÐÐ ÐÐÐÐÐÐÐ: невозможно измениÑÑ Ð¿Ð°Ð¿ÐºÑ"
-#: ../lib/init/gis_set.tcl:747
+#: ../lib/init/gis_set.tcl:758
#, tcl-format
msgid ""
"Warning: could not change directory to <%s>.\n"
@@ -750,31 +766,31 @@
"ÐÑедÑпÑеждение: невозможно измениÑÑ Ð¿Ð°Ð¿ÐºÑ <%s>.\n"
"ÐÑовеÑÑÑе пÑавила доÑÑÑпа к папке."
-#: ../lib/init/file_option.tcl:72
+#: ../lib/init/file_option.tcl:73
msgid "Define location using projection information in georeferenced file"
msgstr "ÐпÑеделиÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ Ð¸ÑполÑзÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¸Ð· Ñайла пÑивÑзки"
-#: ../lib/init/file_option.tcl:95
+#: ../lib/init/file_option.tcl:96
msgid "Enter name of location to be created"
msgstr "ÐведиÑе Ð¸Ð¼Ñ Ð´Ð»Ñ Ñоздаваемой облаÑÑи"
-#: ../lib/init/file_option.tcl:99
+#: ../lib/init/file_option.tcl:100
msgid "Path to georeferenced file"
msgstr "ÐÑÑÑ Ðº пÑивÑÐ·Ð°Ð½Ð½Ð¾Ð¼Ñ ÑайлÑ"
-#: ../lib/init/file_option.tcl:102
+#: ../lib/init/file_option.tcl:103
msgid "Path to georeferenced file (format must be readable by GDAL/OGR)"
msgstr "ÐÑÑÑ Ðº ÑÐ°Ð¹Ð»Ñ Ð¿ÑивÑзки (ÑоÑÐ¼Ð°Ñ Ð´Ð¾Ð»Ð¶ÐµÐ½ бÑÑÑ ÑиÑаемÑм GDAL/OGR)"
-#: ../lib/init/file_option.tcl:106
+#: ../lib/init/file_option.tcl:107
msgid "Browse to locate georeferenced file"
msgstr "УказаÑÑ Ñайл пÑивÑзки"
-#: ../lib/init/file_option.tcl:131 ../lib/init/file_option.tcl:134
+#: ../lib/init/file_option.tcl:132 ../lib/init/file_option.tcl:135
msgid "Choose georeferenced file"
msgstr "ÐÑбеÑиÑе пÑивÑзаннÑй Ñайл"
-#: ../lib/init/file_option.tcl:152
+#: ../lib/init/file_option.tcl:153
msgid ""
"WARNING: Please supply a\n"
"valid georeferenced file"
@@ -786,16 +802,16 @@
#: ../gui/tcltk/gis.m/thematic.tcl:107 ../gui/tcltk/gis.m/thematic.tcl:607
#: ../gui/tcltk/gis.m/thematic.tcl:680 ../gui/tcltk/gis.m/labels.tcl:78
#: ../gui/tcltk/gis.m/labels.tcl:279 ../gui/tcltk/gis.m/rastnums.tcl:79
-#: ../gui/tcltk/gis.m/rastnums.tcl:360 ../gui/tcltk/gis.m/frames.tcl:78
+#: ../gui/tcltk/gis.m/rastnums.tcl:369 ../gui/tcltk/gis.m/frames.tcl:78
#: ../gui/tcltk/gis.m/frames.tcl:275 ../gui/tcltk/gis.m/animate.tcl:91
#: ../gui/tcltk/gis.m/mapprint.tcl:194 ../gui/tcltk/gis.m/mapprint.tcl:201
#: ../gui/tcltk/gis.m/gridline.tcl:99 ../gui/tcltk/gis.m/gridline.tcl:406
#: ../gui/tcltk/gis.m/legend.tcl:95 ../gui/tcltk/gis.m/legend.tcl:506
#: ../gui/tcltk/gis.m/raster.tcl:86 ../gui/tcltk/gis.m/raster.tcl:463
#: ../gui/tcltk/gis.m/chart.tcl:89 ../gui/tcltk/gis.m/chart.tcl:441
-#: ../gui/tcltk/gis.m/vector.tcl:194 ../gui/tcltk/gis.m/vector.tcl:819
+#: ../gui/tcltk/gis.m/vector.tcl:191 ../gui/tcltk/gis.m/vector.tcl:816
#: ../gui/tcltk/gis.m/cmd.tcl:75 ../gui/tcltk/gis.m/cmd.tcl:206
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:212 ../gui/tcltk/gis.m/mapcanvas.tcl:222
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:224 ../gui/tcltk/gis.m/mapcanvas.tcl:234
#: ../gui/tcltk/gis.m/barscale.tcl:91 ../gui/tcltk/gis.m/barscale.tcl:401
#: ../gui/tcltk/gis.m/rgbhis.tcl:83 ../gui/tcltk/gis.m/rgbhis.tcl:362
#: ../gui/tcltk/gis.m/dtext.tcl:92 ../gui/tcltk/gis.m/dtext.tcl:401
@@ -830,7 +846,7 @@
#: ../gui/tcltk/gis.m/labels.tcl:118 ../gui/tcltk/gis.m/rastnums.tcl:146
#: ../gui/tcltk/gis.m/gridline.tcl:147 ../gui/tcltk/gis.m/legend.tcl:200
#: ../gui/tcltk/gis.m/raster.tcl:168 ../gui/tcltk/gis.m/chart.tcl:166
-#: ../gui/tcltk/gis.m/vector.tcl:306 ../gui/tcltk/gis.m/cmd.tcl:105
+#: ../gui/tcltk/gis.m/vector.tcl:303 ../gui/tcltk/gis.m/cmd.tcl:105
#: ../gui/tcltk/gis.m/barscale.tcl:160 ../gui/tcltk/gis.m/rgbhis.tcl:143
#: ../gui/tcltk/gis.m/dtext.tcl:166 ../gui/tcltk/gis.m/histogram.tcl:145
msgid "Opaque "
@@ -878,7 +894,7 @@
msgid " scale factor for computing arrow length"
msgstr " коÑÑÑиÑÐ¸ÐµÐ½Ñ Ð¼Ð°ÑÑÑабиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð´Ð»Ñ Ð²ÑÑиÑÐ»ÐµÐ½Ð¸Ñ Ð´Ð»Ð¸Ð½ ÑÑÑелок"
-#: ../gui/tcltk/gis.m/thematic.tcl:129 ../gui/tcltk/gis.m/vector.tcl:220
+#: ../gui/tcltk/gis.m/thematic.tcl:129 ../gui/tcltk/gis.m/vector.tcl:217
#: ../gui/tcltk/d.m/menu.tcl:94 ../gui/tcltk/d.m/menu.tcl:134
msgid "Vector map"
msgstr "ÐекÑоÑнÑй Ñлой"
@@ -899,7 +915,7 @@
msgid "Select font"
msgstr "ÐÑбеÑиÑе ÑÑиÑÑ"
-#: ../gui/tcltk/gis.m/thematic.tcl:194 ../gui/tcltk/gis.m/vector.tcl:281
+#: ../gui/tcltk/gis.m/thematic.tcl:194 ../gui/tcltk/gis.m/vector.tcl:278
msgid "Vector point symbol"
msgstr "ÐекÑоÑнÑй ÑоÑеÑнÑй Ñимвол"
@@ -913,7 +929,7 @@
msgid " or by graduated sizes (points and lines)"
msgstr " или гÑадÑиÑованнÑе ÑазмеÑÑ (ÑоÑки и линии)"
-#: ../gui/tcltk/gis.m/thematic.tcl:233 ../gui/tcltk/gis.m/vector.tcl:316
+#: ../gui/tcltk/gis.m/thematic.tcl:233 ../gui/tcltk/gis.m/vector.tcl:313
#: ../gui/tcltk/d.m/thematic.tcl:116
msgid "Vector map:"
msgstr "ÐекÑоÑнÑй Ñлой:"
@@ -940,13 +956,13 @@
msgstr " показаÑÑ Ð¿Ð¾Ð»Ñ Ð°ÑÑибÑÑов"
#: ../gui/tcltk/gis.m/thematic.tcl:269 ../gui/tcltk/gis.m/chart.tcl:213
-#: ../gui/tcltk/gis.m/vector.tcl:484 ../gui/tcltk/d.m/thematic.tcl:151
+#: ../gui/tcltk/gis.m/vector.tcl:481 ../gui/tcltk/d.m/thematic.tcl:151
#: ../gui/tcltk/d.m/chart.tcl:121 ../gui/tcltk/d.m/vector.tcl:349
msgid "columns"
msgstr "ÑÑолбÑÑ"
#: ../gui/tcltk/gis.m/thematic.tcl:273 ../gui/tcltk/gis.m/chart.tcl:217
-#: ../gui/tcltk/gis.m/vector.tcl:488 ../gui/tcltk/d.m/thematic.tcl:155
+#: ../gui/tcltk/gis.m/vector.tcl:485 ../gui/tcltk/d.m/thematic.tcl:155
#: ../gui/tcltk/d.m/chart.tcl:125 ../gui/tcltk/d.m/vector.tcl:353
msgid "Show columns"
msgstr "ÐоказаÑÑ ÑÑолбеÑ"
@@ -956,13 +972,13 @@
msgstr " показаÑÑ Ð´Ð°Ð½Ð½Ñе"
#: ../gui/tcltk/gis.m/thematic.tcl:275 ../gui/tcltk/gis.m/chart.tcl:219
-#: ../gui/tcltk/gis.m/vector.tcl:490 ../gui/tcltk/d.m/thematic.tcl:157
+#: ../gui/tcltk/gis.m/vector.tcl:487 ../gui/tcltk/d.m/thematic.tcl:157
#: ../gui/tcltk/d.m/vector.tcl:355
msgid "data"
msgstr "даннÑе"
#: ../gui/tcltk/gis.m/thematic.tcl:279 ../gui/tcltk/gis.m/chart.tcl:223
-#: ../gui/tcltk/gis.m/vector.tcl:494 ../gui/tcltk/d.m/thematic.tcl:161
+#: ../gui/tcltk/gis.m/vector.tcl:491 ../gui/tcltk/d.m/thematic.tcl:161
#: ../gui/tcltk/d.m/vector.tcl:359
msgid "Show data"
msgstr "ÐоказаÑÑ Ð´Ð°Ð½Ð½Ñе"
@@ -974,7 +990,7 @@
#: ../gui/tcltk/gis.m/thematic.tcl:288 ../gui/tcltk/d.m/thematic.tcl:171
#, fuzzy
msgid " map by"
-msgstr " Ñлой "
+msgstr "Ñлой "
#: ../gui/tcltk/gis.m/thematic.tcl:297
msgid " number of intervals to map (interval themes):"
@@ -1099,14 +1115,12 @@
msgstr "СоÑ
ÑаниÑÑ Ð»ÐµÐ³ÐµÐ½Ð´Ñ Ð² Ñайл EPS"
#: ../gui/tcltk/gis.m/profile.tcl:54
-#, fuzzy
msgid "Raster map for profile"
-msgstr "РаÑÑÑовÑй Ñлой Ð´Ð»Ñ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
+msgstr "РаÑÑÑовÑй Ñлой Ð´Ð»Ñ Ð¿ÑоÑилÑ"
#: ../gui/tcltk/gis.m/profile.tcl:77
-#, fuzzy
msgid "Profile Window"
-msgstr "ÐÑоÑилÑнÑй анализ"
+msgstr "Ðкно пÑоÑилÑ"
#: ../gui/tcltk/gis.m/profile.tcl:110
msgid ""
@@ -1136,7 +1150,7 @@
msgid "r.univar error"
msgstr "r.univar оÑибка"
-#: ../gui/tcltk/gis.m/profile.tcl:415 ../gui/tcltk/gis.m/mapcanvas.tcl:435
+#: ../gui/tcltk/gis.m/profile.tcl:415 ../gui/tcltk/gis.m/mapcanvas.tcl:449
msgid "g.proj or projection error"
msgstr "g.proj или оÑибка пÑоекÑии"
@@ -1172,7 +1186,12 @@
msgid "Zero elevation range"
msgstr "Ðиапазон нÑлевÑÑ
вÑÑоÑ"
-#: ../gui/tcltk/gis.m/profile.tcl:534 ../gui/tcltk/gis.m/profile.tcl:619
+#: ../gui/tcltk/gis.m/profile.tcl:542
+#, fuzzy
+msgid "Error reading region values"
+msgstr "ÐÑибка ÑÑÑановки Ñегиона"
+#: ../gui/tcltk/gis.m/profile.tcl:566 ../gui/tcltk/gis.m/profile.tcl:651
msgid "r.profile error"
msgstr "r.profile оÑибка"
@@ -1263,41 +1282,35 @@
msgid "GRASS%s GIS Manager - %s %s"
msgstr "GIS Ð¼ÐµÐ½ÐµÐ´Ð¶ÐµÑ GRASS%s - %s %s"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:119
+#: ../gui/tcltk/gis.m/runandoutput.tcl:121
msgid "Run (background)"
msgstr "ÐапÑÑÑиÑÑ (в Ñоне)"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:122
+#: ../gui/tcltk/gis.m/runandoutput.tcl:124
msgid "Run (GUI)"
msgstr "ÐапÑÑÑиÑÑ (GUI)"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:125
-msgid "Run (in Xterm)"
-msgstr "ÐапÑÑÑиÑÑ (в Xterm)"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:129
-#, fuzzy
+#: ../gui/tcltk/gis.m/runandoutput.tcl:136
msgid " Save "
-msgstr "СоÑ
ÑаниÑÑ"
+msgstr " СоÑ
ÑаниÑÑ"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:131
-#, fuzzy
+#: ../gui/tcltk/gis.m/runandoutput.tcl:138
msgid " Clear "
-msgstr "ÐÑиÑÑиÑÑ"
+msgstr " ÐÑиÑÑиÑÑ"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:152
+#: ../gui/tcltk/gis.m/runandoutput.tcl:159
msgid "Output - GIS.m"
msgstr "ÐÑвод - GIS.m"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:254
+#: ../gui/tcltk/gis.m/runandoutput.tcl:261
msgid "X Windows not available"
msgstr "X Windows недоÑÑÑпнÑ"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:255
+#: ../gui/tcltk/gis.m/runandoutput.tcl:262
msgid "Functions that require X Windows are not available in Windows"
msgstr "ФÑнкÑии, коÑоÑÑе ÑÑебÑÑÑ X Windows недоÑÑÑÐ¿Ð½Ñ Ð² Windows"
-#: ../gui/tcltk/gis.m/runandoutput.tcl:277
+#: ../gui/tcltk/gis.m/runandoutput.tcl:284
msgid "This module requires X11 support, but no xmons were found"
msgstr "ÐÑÐ¾Ð¼Ñ Ð¼Ð¾Ð´ÑÐ»Ñ Ð½Ñжна поддеÑжка X11, но xmons не найденÑ"
@@ -1364,8 +1377,8 @@
msgid "Set computational region extents to match display"
msgstr "УÑÑановиÑÑ Ð¾Ñ
Ð²Ð°Ñ ÑаÑÑеÑного Ñегиона ÑооÑвеÑÑÑвÑÑÑий диÑплеÑ"
-#: ../gui/tcltk/gis.m/maptool.tcl:229 ../gui/tcltk/gis.m/gmmenu.tcl:626
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1865 ../gui/tcltk/d.m/menu.tcl:559
+#: ../gui/tcltk/gis.m/maptool.tcl:229 ../gui/tcltk/gis.m/gmmenu.tcl:631
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1928 ../gui/tcltk/d.m/menu.tcl:560
msgid "Query"
msgstr "ÐапÑоÑ"
@@ -1401,7 +1414,7 @@
msgid "(* requires gdal)"
msgstr "(* ÑÑебÑÐµÑ gdal)"
-#: ../gui/tcltk/gis.m/maptool.tcl:327
+#: ../gui/tcltk/gis.m/maptool.tcl:327 ../gui/tcltk/gis.m/rastnums.tcl:282
msgid "Constrain map to region geometry"
msgstr "ÐгÑаниÑиÑÑ Ñлой геомеÑÑией Ñегиона"
@@ -1470,7 +1483,7 @@
msgid "use raster colors for cell values"
msgstr "иÑполÑзоваÑÑ ÑвеÑа ÑаÑÑÑа Ð´Ð»Ñ Ð·Ð½Ð°Ñений ÑÑейки"
-#: ../gui/tcltk/gis.m/rastnums.tcl:273
+#: ../gui/tcltk/gis.m/rastnums.tcl:274
msgid ""
"Cell values can only be displayed\n"
"for regions of < 10,000 cells"
@@ -1478,6 +1491,24 @@
"ÐнаÑÐµÐ½Ð¸Ñ ÑÑеек могÑÑ Ð±ÑÑÑ Ð¾ÑобÑÐ°Ð¶ÐµÐ½Ñ Ð´Ð»Ñ\n"
"Ñегионов Ñ ÐºÐ¾Ð»Ð¸ÑеÑÑво ÑÑеек < 10,000"
+#: ../gui/tcltk/gis.m/rastnums.tcl:279
+#, fuzzy
+msgid "Constrain map to region geometry?"
+msgstr "ÐгÑаниÑиÑÑ Ñлой геомеÑÑией Ñегиона"
+#: ../gui/tcltk/gis.m/rastnums.tcl:280
+msgid ""
+"Cell values can only be displayed for \n"
+"regions of < 10,000 cells. Map in explore mode may contain more than 10,000 "
+"cells.\n"
+"\n"
+" It's suggested to constrain map to region geometry to display cell values."
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:282
+msgid "Leave in explore mode"
+msgstr ""
#: ../gui/tcltk/gis.m/frames.tcl:105
msgid "Divide map display into frames for displaying multiple maps"
msgstr "РазделиÑÑ Ð´Ð¸Ñплей на ÑÑÐµÐ¹Ð¼Ñ Ð´Ð»Ñ Ð¿Ð¾ÐºÐ°Ð·Ð° неÑколÑкиÑ
каÑÑ"
@@ -1499,11 +1530,11 @@
msgstr "ÐÐ¼Ñ ÑÑейма (опÑиÑ):"
#: ../gui/tcltk/gis.m/frames.tcl:135
-#, fuzzy, tcl-format
+#, tcl-format
msgid "Set frame borders at 0-100% from lower left corner of display "
msgstr ""
-"УÑÑановиÑÑ Ð³ÑаниÑÑ ÑÑеймов ÑавнÑми 0-100% наÑÐ¸Ð½Ð°Ñ Ñ Ð½Ð¸Ð¶Ð½ÐµÐ³Ð¾ левого Ñгла "
-"диÑÐ¿Ð»ÐµÑ "
+"УÑÑановиÑÑ Ð³ÑаниÑÑ ÑÑеймов ÑавнÑми 0-100 пÑоÑенÑов наÑÐ¸Ð½Ð°Ñ Ñ Ð½Ð¸Ð¶Ð½ÐµÐ³Ð¾ левого "
+"Ñгла диÑплеÑ"
#: ../gui/tcltk/gis.m/frames.tcl:141
msgid " set borders (bottom,top,left,right): "
@@ -1777,7 +1808,7 @@
msgid "Open..."
msgstr "ÐÑкÑÑÑÑ..."
-#: ../gui/tcltk/gis.m/gmmenu.tcl:88 ../gui/tcltk/gis.m/mapcanvas.tcl:863
+#: ../gui/tcltk/gis.m/gmmenu.tcl:88 ../gui/tcltk/gis.m/mapcanvas.tcl:905
#: ../gui/tcltk/d.m/menu.tcl:174
msgid "Save"
msgstr "СоÑ
ÑаниÑÑ"
@@ -1796,9 +1827,8 @@
msgstr "ФоÑмаÑÑ Ð¸Ð¼Ð¿Ð¾ÑÑа иÑполÑзÑÑÑие GDAL"
#: ../gui/tcltk/gis.m/gmmenu.tcl:95
-#, fuzzy
msgid "Multiple formats using GDAL (link into instead of import)"
-msgstr "ФоÑмаÑÑ Ð¸Ð¼Ð¿Ð¾ÑÑа иÑполÑзÑÑÑие GDAL"
+msgstr "ФоÑмаÑÑ Ð¸Ð¼Ð¿Ð¾ÑÑа иÑполÑзÑÑÑие GDAL (ÑвÑзÑвание вмеÑÑо импоÑÑа)"
#: ../gui/tcltk/gis.m/gmmenu.tcl:97
msgid "Aggregate ASCII xyz"
@@ -1877,9 +1907,8 @@
msgstr "GPSBabel GPS"
#: ../gui/tcltk/gis.m/gmmenu.tcl:121
-#, fuzzy
msgid "Geonames"
-msgstr "ÐеÑеименоваÑÑ"
+msgstr "Geonames"
#: ../gui/tcltk/gis.m/gmmenu.tcl:122
msgid "GEOnet"
@@ -1902,9 +1931,8 @@
msgstr "Vis5D"
#: ../gui/tcltk/gis.m/gmmenu.tcl:129
-#, fuzzy
msgid "Import data table"
-msgstr "ÐмпоÑÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой"
+msgstr "ÐмпоÑÑиÑоваÑÑ ÑаблиÑÑ Ð´Ð°Ð½Ð½ÑÑ
#: ../gui/tcltk/gis.m/gmmenu.tcl:131
msgid "Export raster map"
@@ -1956,9 +1984,8 @@
msgstr "ÐкÑпоÑÑиÑоваÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
#: ../gui/tcltk/gis.m/gmmenu.tcl:157 ../gui/tcltk/d.m/menu.tcl:139
-#, fuzzy
msgid "Multiple GPS formats using GPSBabel"
-msgstr "ФоÑмаÑÑ Ð¸Ð¼Ð¿Ð¾ÑÑа иÑполÑзÑÑÑие OGR"
+msgstr "ФоÑмаÑÑ Ð¸Ð¼Ð¿Ð¾ÑÑа GPS иÑполÑзÑÑÑие GPSBabel"
#: ../gui/tcltk/gis.m/gmmenu.tcl:159 ../gui/tcltk/d.m/menu.tcl:141
msgid "SVG"
@@ -1969,9 +1996,8 @@
msgstr "ÐкÑпоÑÑ Ð¾Ð±ÑемнÑй 3D гÑид"
#: ../gui/tcltk/gis.m/gmmenu.tcl:167
-#, fuzzy
msgid "Export data table"
-msgstr "ÐкÑпоÑÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой"
+msgstr "ÐкÑпоÑÑиÑоваÑÑ ÑаблиÑÑ Ð´Ð°Ð½Ð½ÑÑ
#: ../gui/tcltk/gis.m/gmmenu.tcl:169 ../gui/tcltk/d.m/menu.tcl:151
msgid "Manage maps and volumes"
@@ -2098,1151 +2124,1153 @@
msgstr "ÐзмениÑÑ Ð½Ð°ÑÑÑойки"
#: ../gui/tcltk/gis.m/gmmenu.tcl:217 ../gui/tcltk/d.m/menu.tcl:200
+msgid "Change default GUI"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:218 ../gui/tcltk/d.m/menu.tcl:201
msgid "Show current GRASS version"
msgstr "ÐоказаÑÑ ÑекÑÑÑÑ Ð²ÐµÑÑÐ¸Ñ GRASS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:219 ../gui/tcltk/gis.m/gmmenu.tcl:220
-#: ../gui/tcltk/d.m/menu.tcl:202
+#: ../gui/tcltk/gis.m/gmmenu.tcl:220 ../gui/tcltk/gis.m/gmmenu.tcl:221
+#: ../gui/tcltk/d.m/menu.tcl:203
msgid "Manage projections"
msgstr "УпÑавление пÑоекÑиÑми"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:221
+#: ../gui/tcltk/gis.m/gmmenu.tcl:222
msgid "Projection for current location"
msgstr "ÐÑоекÑÐ¸Ñ Ð´Ð»Ñ ÑекÑÑей облаÑÑи"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:223
+#: ../gui/tcltk/gis.m/gmmenu.tcl:224
msgid "Convert coordinates"
msgstr "ÐÑеобÑазоваÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:225
+#: ../gui/tcltk/gis.m/gmmenu.tcl:226
msgid "Display font"
msgstr "ÐÑобÑазиÑÑ ÑÑиÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:227 ../gui/tcltk/d.m/menu.tcl:220
+#: ../gui/tcltk/gis.m/gmmenu.tcl:228 ../gui/tcltk/d.m/menu.tcl:221
msgid "&Raster"
msgstr "&РаÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:228 ../gui/tcltk/gis.m/gmmenu.tcl:429
-#: ../gui/tcltk/d.m/menu.tcl:221 ../gui/tcltk/d.m/menu.tcl:380
+#: ../gui/tcltk/gis.m/gmmenu.tcl:229 ../gui/tcltk/gis.m/gmmenu.tcl:430
+#: ../gui/tcltk/d.m/menu.tcl:222 ../gui/tcltk/d.m/menu.tcl:381
msgid "Develop map"
msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:229 ../gui/tcltk/d.m/menu.tcl:222
+#: ../gui/tcltk/gis.m/gmmenu.tcl:230 ../gui/tcltk/d.m/menu.tcl:223
msgid "Digitize raster"
msgstr "ÐÑиÑÑоваÑÑ ÑаÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:235
+#: ../gui/tcltk/gis.m/gmmenu.tcl:236
msgid "Compress/decompress"
msgstr "СжаÑÑ/ÑаÑпаковаÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:237
+#: ../gui/tcltk/gis.m/gmmenu.tcl:238
msgid "Boundaries"
msgstr "ÐÑаниÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:238
+#: ../gui/tcltk/gis.m/gmmenu.tcl:239
msgid "Null values"
msgstr "УпÑавление NULL-знаÑениÑми"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:239
+#: ../gui/tcltk/gis.m/gmmenu.tcl:240
msgid "Quantization"
msgstr "ÐванÑование"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:240
+#: ../gui/tcltk/gis.m/gmmenu.tcl:241
msgid "Timestamps"
msgstr "ÐÑеменнÑе меÑки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:242 ../gui/tcltk/d.m/menu.tcl:233
+#: ../gui/tcltk/gis.m/gmmenu.tcl:243 ../gui/tcltk/d.m/menu.tcl:234
msgid "Resample using aggregate statistics"
msgstr "ÐеÑеÑÑÐµÑ Ñ Ð¸ÑполÑзованием ÑÑаÑиÑÑики агÑегаÑии"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:243
+#: ../gui/tcltk/gis.m/gmmenu.tcl:244
msgid "Resample using multiple methods"
msgstr "ÐеÑеÑÑÐµÑ Ð¸ÑполÑзÑÑ ÑазлиÑнÑе меÑодÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:244
+#: ../gui/tcltk/gis.m/gmmenu.tcl:245
msgid "Resample using nearest neighbor"
msgstr "ÐеÑеÑÑÐµÑ Ð¸ÑполÑзÑÑ Ð¼ÐµÑод ближайÑего ÑоÑеда"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:245
+#: ../gui/tcltk/gis.m/gmmenu.tcl:246
msgid "Resample using spline tension"
msgstr "ÐеÑеÑÑÐµÑ Ñ Ð¸ÑполÑзованием Ñплайнов"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:247
+#: ../gui/tcltk/gis.m/gmmenu.tcl:248
msgid "Support file maintenance"
msgstr "Ðбновление Ñайла поддеÑжки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:248
+#: ../gui/tcltk/gis.m/gmmenu.tcl:249
msgid "Update map statistics"
msgstr "ÐбновиÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ ÑлоÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:250
+#: ../gui/tcltk/gis.m/gmmenu.tcl:251
msgid "Reproject"
msgstr "ÐеÑепÑоекÑиÑоваÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:251
+#: ../gui/tcltk/gis.m/gmmenu.tcl:252
msgid "Tiling"
msgstr "Тайлинг"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:253 ../gui/tcltk/d.m/menu.tcl:242
+#: ../gui/tcltk/gis.m/gmmenu.tcl:254 ../gui/tcltk/d.m/menu.tcl:243
msgid "Manage map colors"
msgstr "УпÑавление ÑвеÑами ÑлоÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:254
+#: ../gui/tcltk/gis.m/gmmenu.tcl:255
msgid "Color tables"
msgstr "ЦвеÑовÑе ÑаблиÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:255
-#, fuzzy
+#: ../gui/tcltk/gis.m/gmmenu.tcl:256
msgid "Color tables (stddev)"
-msgstr "ЦвеÑовÑе ÑаблиÑÑ"
+msgstr "ЦвеÑовÑе ÑаблиÑÑ (ÑÑд.оÑкл)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:256
+#: ../gui/tcltk/gis.m/gmmenu.tcl:257
msgid "Color rules"
msgstr "ЦвеÑовÑе пÑавила"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:258
+#: ../gui/tcltk/gis.m/gmmenu.tcl:259
msgid "Blend"
msgstr "СмеÑаÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:259
+#: ../gui/tcltk/gis.m/gmmenu.tcl:260
msgid "Create RGB"
msgstr "СоздаÑÑ RGB"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:260 ../gui/tcltk/gis.m/gmmenu.tcl:549
+#: ../gui/tcltk/gis.m/gmmenu.tcl:261 ../gui/tcltk/gis.m/gmmenu.tcl:550
msgid "HIS to RGB"
msgstr "HIS в RGB"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:263 ../gui/tcltk/d.m/menu.tcl:252
-#: ../gui/tcltk/d.m/menu.tcl:408
+#: ../gui/tcltk/gis.m/gmmenu.tcl:264 ../gui/tcltk/d.m/menu.tcl:253
+#: ../gui/tcltk/d.m/menu.tcl:409
msgid "Query by coordinate(s)"
msgstr " ÐапÑÐ¾Ñ Ð¿Ð¾ кооÑдинаÑе(ам)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:265
+#: ../gui/tcltk/gis.m/gmmenu.tcl:266
msgid "Buffers"
msgstr "ÐÑÑеÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:266
+#: ../gui/tcltk/gis.m/gmmenu.tcl:267
msgid "Closest points"
msgstr "ÐлижайÑие ÑоÑки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:267
+#: ../gui/tcltk/gis.m/gmmenu.tcl:268
msgid "MASK"
msgstr "MASK"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:268 ../gui/tcltk/d.m/menu.tcl:257
+#: ../gui/tcltk/gis.m/gmmenu.tcl:269 ../gui/tcltk/d.m/menu.tcl:258
msgid "Map calculator"
msgstr "ÐалÑкÑлÑÑÐ¾Ñ Ñлоев"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:269 ../gui/tcltk/d.m/menu.tcl:258
-#: ../gui/tcltk/d.m/menu.tcl:418
+#: ../gui/tcltk/gis.m/gmmenu.tcl:270 ../gui/tcltk/d.m/menu.tcl:259
+#: ../gui/tcltk/d.m/menu.tcl:419
msgid "Neighborhood analysis"
msgstr "Ðнализ ÑоÑедÑÑва"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:270
+#: ../gui/tcltk/gis.m/gmmenu.tcl:271
msgid "Moving window"
msgstr "ÐлаваÑÑее окно"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:271
+#: ../gui/tcltk/gis.m/gmmenu.tcl:272
msgid "Neighborhood points"
msgstr "СоÑедние ÑоÑки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:273 ../gui/tcltk/gis.m/gmmenu.tcl:493
-#: ../gui/tcltk/d.m/menu.tcl:262 ../gui/tcltk/d.m/menu.tcl:432
+#: ../gui/tcltk/gis.m/gmmenu.tcl:274 ../gui/tcltk/gis.m/gmmenu.tcl:494
+#: ../gui/tcltk/d.m/menu.tcl:263 ../gui/tcltk/d.m/menu.tcl:433
msgid "Overlay maps"
msgstr "ÐаложиÑÑ Ñлои"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:274 ../gui/tcltk/d.m/menu.tcl:263
+#: ../gui/tcltk/gis.m/gmmenu.tcl:275 ../gui/tcltk/d.m/menu.tcl:264
msgid "Cross product"
msgstr "ÐÑоÑÑ-пÑодÑкÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:275
+#: ../gui/tcltk/gis.m/gmmenu.tcl:276
msgid "Map series"
msgstr "СеÑии ÑаÑÑÑов"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:276 ../gui/tcltk/d.m/menu.tcl:265
+#: ../gui/tcltk/gis.m/gmmenu.tcl:277 ../gui/tcltk/d.m/menu.tcl:266
msgid "Patch maps"
msgstr "ÐалаÑаÑÑ Ñлои"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:278
+#: ../gui/tcltk/gis.m/gmmenu.tcl:279
msgid "Statistical overlay"
msgstr "СÑаÑиÑÑиÑеÑкое наложение"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:280 ../gui/tcltk/d.m/menu.tcl:269
+#: ../gui/tcltk/gis.m/gmmenu.tcl:281 ../gui/tcltk/d.m/menu.tcl:270
msgid "Solar radiance and shadows"
msgstr "СолнеÑÐ½Ð°Ñ Ð¾ÑвеÑенноÑÑÑ Ð¸ Ñени"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:281
+#: ../gui/tcltk/gis.m/gmmenu.tcl:282
msgid "Solar irradiance irradiation"
msgstr "СолнеÑÐ½Ð°Ñ Ð¾ÑвеÑенноÑÑÑ Ð¸ иÑÑадиаÑиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:282
+#: ../gui/tcltk/gis.m/gmmenu.tcl:283
msgid "Shadows map"
msgstr "Слой Ñеней"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:284 ../gui/tcltk/d.m/menu.tcl:273
+#: ../gui/tcltk/gis.m/gmmenu.tcl:285 ../gui/tcltk/d.m/menu.tcl:274
msgid "Terrain analysis"
msgstr "Ðнализ ÑелÑеÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:285
+#: ../gui/tcltk/gis.m/gmmenu.tcl:286
msgid "Cumulative movement costs"
msgstr "СÑммаÑÐ½Ð°Ñ ÑÑоимоÑÑÑ Ð¿ÐµÑемеÑениÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:286 ../gui/tcltk/d.m/menu.tcl:275
+#: ../gui/tcltk/gis.m/gmmenu.tcl:287 ../gui/tcltk/d.m/menu.tcl:276
msgid "Cost surface"
msgstr "СÑоимоÑÑÐ½Ð°Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:287 ../gui/tcltk/d.m/menu.tcl:276
+#: ../gui/tcltk/gis.m/gmmenu.tcl:288 ../gui/tcltk/d.m/menu.tcl:277
msgid "Least cost route or flow"
msgstr "ÐÑÑÑ Ð¸Ð»Ð¸ поÑок наименÑÑей ÑÑоимоÑÑи "
-#: ../gui/tcltk/gis.m/gmmenu.tcl:289
+#: ../gui/tcltk/gis.m/gmmenu.tcl:290
msgid "Shaded relief"
msgstr "Теневой ÑелÑеÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:291 ../gui/tcltk/d.m/menu.tcl:279
+#: ../gui/tcltk/gis.m/gmmenu.tcl:292 ../gui/tcltk/d.m/menu.tcl:280
msgid "Slope and aspect"
msgstr "ÐÑÑÑизна и ÑкÑпозиÑиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:292 ../gui/tcltk/d.m/menu.tcl:280
+#: ../gui/tcltk/gis.m/gmmenu.tcl:293 ../gui/tcltk/d.m/menu.tcl:281
msgid "Terrain parameters"
msgstr "ÐаÑамеÑÑÑ ÑелÑеÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:293 ../gui/tcltk/d.m/menu.tcl:281
+#: ../gui/tcltk/gis.m/gmmenu.tcl:294 ../gui/tcltk/d.m/menu.tcl:282
msgid "Textural features"
msgstr "ТекÑÑÑÑнÑе пÑизнаки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:295
+#: ../gui/tcltk/gis.m/gmmenu.tcl:296
msgid "Visibility"
msgstr "ÐидимоÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:296 ../gui/tcltk/d.m/menu.tcl:283
-#, fuzzy
+#: ../gui/tcltk/gis.m/gmmenu.tcl:297 ../gui/tcltk/d.m/menu.tcl:284
msgid "Distance to features"
-msgstr "РедакÑиÑоваÑÑ Ð¾Ð±ÑекÑÑ"
+msgstr "РаÑÑÑоÑние до обÑекÑов"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:298
+#: ../gui/tcltk/gis.m/gmmenu.tcl:299
msgid "Horizon"
-msgstr ""
+msgstr "ÐоÑизонÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:300 ../gui/tcltk/d.m/menu.tcl:285
+#: ../gui/tcltk/gis.m/gmmenu.tcl:301 ../gui/tcltk/d.m/menu.tcl:286
msgid "Transform features"
msgstr "ТÑанÑÑоÑмиÑоваÑÑ Ð¾Ð±ÑекÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:301
+#: ../gui/tcltk/gis.m/gmmenu.tcl:302
msgid "Clump"
msgstr "ÐлаÑÑеÑизаÑиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:302
+#: ../gui/tcltk/gis.m/gmmenu.tcl:303
msgid "Grow"
msgstr "ÐÑÑаÑÑиÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:303
+#: ../gui/tcltk/gis.m/gmmenu.tcl:304
msgid "Thin"
msgstr "ÐÑоÑедиÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:306 ../gui/tcltk/d.m/menu.tcl:291
+#: ../gui/tcltk/gis.m/gmmenu.tcl:307 ../gui/tcltk/d.m/menu.tcl:292
msgid "Hydrologic modeling"
msgstr "ÐидÑологиÑеÑкое моделиÑование"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:307
+#: ../gui/tcltk/gis.m/gmmenu.tcl:308
msgid "Carve stream channels"
msgstr "ÐÑоÑезаÑÑ ÐºÐ°Ð½Ð°Ð»Ñ Ð¿Ð¾Ñоков"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:308
+#: ../gui/tcltk/gis.m/gmmenu.tcl:309
msgid "Fill lake"
msgstr "ÐаполниÑÑ Ð¾Ð·ÐµÑо"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:310
+#: ../gui/tcltk/gis.m/gmmenu.tcl:311
msgid "Depressionless map and flowlines"
msgstr "Слой без депÑеÑÑий и водоÑоки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:311
+#: ../gui/tcltk/gis.m/gmmenu.tcl:312
msgid "Flow accumulation"
msgstr "ÐккÑмÑлÑÑÐ¸Ñ ÑÑока"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:312
+#: ../gui/tcltk/gis.m/gmmenu.tcl:313
msgid "Flow lines"
msgstr "ÐодоÑоки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:314 ../gui/tcltk/gis.m/gmmenu.tcl:596
+#: ../gui/tcltk/gis.m/gmmenu.tcl:315 ../gui/tcltk/gis.m/gmmenu.tcl:601
msgid "Groundwater flow model"
msgstr "ÐÐ¾Ð´ÐµÐ»Ñ Ð¿Ð¾Ñока гÑÑнÑовÑÑ
вод"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:316 ../gui/tcltk/d.m/menu.tcl:297
+#: ../gui/tcltk/gis.m/gmmenu.tcl:317 ../gui/tcltk/d.m/menu.tcl:298
msgid "SIMWE overland flow modeling"
msgstr "ÐоделиÑование повеÑÑ
ноÑÑного ÑÑока SIMWE"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:317
+#: ../gui/tcltk/gis.m/gmmenu.tcl:318
msgid "SIMWE sediment flux modeling"
msgstr "SIMWE-моделиÑование наноÑнÑÑ
поÑоков"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:319 ../gui/tcltk/d.m/menu.tcl:299
+#: ../gui/tcltk/gis.m/gmmenu.tcl:320 ../gui/tcltk/d.m/menu.tcl:300
msgid "Topographic index map"
msgstr "Слой индекÑа ÑелÑеÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:320 ../gui/tcltk/d.m/menu.tcl:300
+#: ../gui/tcltk/gis.m/gmmenu.tcl:321 ../gui/tcltk/d.m/menu.tcl:301
msgid "TOPMODEL simulation"
msgstr "СимÑлÑÑÐ¸Ñ TOPMODEL"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:322 ../gui/tcltk/d.m/menu.tcl:301
+#: ../gui/tcltk/gis.m/gmmenu.tcl:323 ../gui/tcltk/d.m/menu.tcl:302
msgid "Watershed subbasins"
msgstr "ÐодоÑбоÑнÑе ÑÑббаÑÑейнÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:323 ../gui/tcltk/d.m/menu.tcl:302
+#: ../gui/tcltk/gis.m/gmmenu.tcl:324 ../gui/tcltk/d.m/menu.tcl:303
msgid "Watershed analysis"
msgstr "Ðнализ водоÑбоÑов"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:324 ../gui/tcltk/d.m/menu.tcl:303
+#: ../gui/tcltk/gis.m/gmmenu.tcl:325 ../gui/tcltk/d.m/menu.tcl:304
msgid "Watershed basin creation"
msgstr "Создание водоÑбоÑного баÑÑейна"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:326 ../gui/tcltk/d.m/menu.tcl:305
+#: ../gui/tcltk/gis.m/gmmenu.tcl:327 ../gui/tcltk/d.m/menu.tcl:306
msgid "Landscape structure modeling"
msgstr "СÑÑÑкÑÑÑное моделиÑование ландÑаÑÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:327
+#: ../gui/tcltk/gis.m/gmmenu.tcl:328
msgid "Set up"
msgstr "УÑÑановиÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:333
+#: ../gui/tcltk/gis.m/gmmenu.tcl:334
msgid "Analyze landscape"
msgstr "ÐнализиÑоваÑÑ Ð»Ð°Ð½Ð´ÑаÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:334
+#: ../gui/tcltk/gis.m/gmmenu.tcl:335
msgid "Analyze patches"
msgstr "ÐнализиÑоваÑÑ ÑÑаÑÑки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:337
+#: ../gui/tcltk/gis.m/gmmenu.tcl:338
msgid "Landscape patch analysis"
msgstr "Ðнализ ÑÑаÑÑков ландÑаÑÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:338 ../gui/tcltk/d.m/menu.tcl:306
+#: ../gui/tcltk/gis.m/gmmenu.tcl:339 ../gui/tcltk/d.m/menu.tcl:307
msgid "Set up sampling and analysis framework"
msgstr "ÐадаÑÑ ÑÑ
ÐµÐ¼Ñ Ð°Ð½Ð°Ð»Ð¸Ð·Ð° и ÑÑмплинга"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:340
+#: ../gui/tcltk/gis.m/gmmenu.tcl:341
msgid "Edge density"
msgstr "ÐлоÑноÑÑÑ Ð³ÑаниÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:341
+#: ../gui/tcltk/gis.m/gmmenu.tcl:342
msgid "Contrast weighted edge density"
msgstr "ÐлоÑноÑÑÑ Ð³ÑÐ°Ð½Ð¸Ñ Ð²Ð·Ð²ÐµÑÐµÐ½Ð½Ð°Ñ Ð¿Ð¾ конÑÑаÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:343
+#: ../gui/tcltk/gis.m/gmmenu.tcl:344
msgid "Patch size mean"
msgstr "СÑеднÑÑ Ð¿Ð»Ð¾ÑÐ°Ð´Ñ ÑÑаÑÑка"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:344
+#: ../gui/tcltk/gis.m/gmmenu.tcl:345
msgid "Patch area range"
msgstr "Ðиапазон плоÑадей ÑÑаÑÑков"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:345
+#: ../gui/tcltk/gis.m/gmmenu.tcl:346
msgid "Patch area Std Dev"
msgstr "СÑандаÑÑное оÑклонение плоÑади ÑÑаÑÑков"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:346
+#: ../gui/tcltk/gis.m/gmmenu.tcl:347
msgid "Patch area Coeff Var"
msgstr "ÐоÑÑÑиÑÐ¸ÐµÐ½Ñ Ð²Ð°ÑиаÑии плоÑади ÑÑаÑÑка"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:347
+#: ../gui/tcltk/gis.m/gmmenu.tcl:348
msgid "Patch density"
msgstr "ÐлоÑноÑÑÑ ÑÑаÑÑков"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:348
+#: ../gui/tcltk/gis.m/gmmenu.tcl:349
msgid "Patch number"
msgstr "ÐолиÑеÑÑво ÑÑаÑÑков"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:350
+#: ../gui/tcltk/gis.m/gmmenu.tcl:351
msgid "Dominance's diversity"
msgstr "ÐоминанÑное ÑазнообÑазие"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:351
+#: ../gui/tcltk/gis.m/gmmenu.tcl:352
msgid "Shannon's diversity"
msgstr "РазнообÑазие Шеннона"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:352
+#: ../gui/tcltk/gis.m/gmmenu.tcl:353
msgid "Simpson's diversity"
msgstr "РазнообÑазие СимпÑона"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:354
+#: ../gui/tcltk/gis.m/gmmenu.tcl:355
msgid "Ricness"
msgstr "ÐогаÑÑÑво"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:355
+#: ../gui/tcltk/gis.m/gmmenu.tcl:356
msgid "Shape index"
msgstr "ÐÐ½Ð´ÐµÐºÑ ÑоÑмÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:357 ../gui/tcltk/d.m/menu.tcl:312
+#: ../gui/tcltk/gis.m/gmmenu.tcl:358 ../gui/tcltk/d.m/menu.tcl:313
msgid "Wildfire modeling"
msgstr "ÐоделиÑование пожаÑов"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:358
+#: ../gui/tcltk/gis.m/gmmenu.tcl:359
msgid "Rate of spread"
msgstr "СкоÑоÑÑÑ ÑаÑпÑоÑÑÑанениÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:359
+#: ../gui/tcltk/gis.m/gmmenu.tcl:360
msgid "Least-cost spread paths"
msgstr "ТÑаекÑоÑии минималÑной ÑÑоимоÑÑи ÑаÑпÑоÑÑÑанениÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:360
+#: ../gui/tcltk/gis.m/gmmenu.tcl:361
msgid "Anisotropic spread simulation"
msgstr "ÐоделиÑование анизоÑÑопного ÑаÑпÑоÑÑÑанениÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:363 ../gui/tcltk/d.m/menu.tcl:318
+#: ../gui/tcltk/gis.m/gmmenu.tcl:364 ../gui/tcltk/d.m/menu.tcl:319
msgid "Change category values and labels"
msgstr "ÐзмениÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий и подпиÑи"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:364
+#: ../gui/tcltk/gis.m/gmmenu.tcl:365
msgid "Interactively edit category values"
msgstr "ÐнÑеÑакÑивное ÑедакÑиÑование знаÑений каÑегоÑий"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:366
+#: ../gui/tcltk/gis.m/gmmenu.tcl:367
msgid "Reclassify by size"
msgstr "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ Ð¿Ð¾ ÑазмеÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:367
+#: ../gui/tcltk/gis.m/gmmenu.tcl:368
msgid "Reclassify interactively"
msgstr "ÐнÑеÑакÑÐ¸Ð²Ð½Ð°Ñ Ð¿ÐµÑеклаÑÑиÑикаÑиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:368 ../gui/tcltk/gis.m/gmmenu.tcl:501
+#: ../gui/tcltk/gis.m/gmmenu.tcl:369 ../gui/tcltk/gis.m/gmmenu.tcl:502
msgid "Reclassify using rules file"
msgstr "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ, иÑполÑзÑÑ Ñайл пÑавил"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:370
+#: ../gui/tcltk/gis.m/gmmenu.tcl:371
msgid "Recode interactively"
msgstr "ÐнÑеÑакÑÐ¸Ð²Ð½Ð°Ñ Ð¿ÐµÑекодиÑовка"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:371
+#: ../gui/tcltk/gis.m/gmmenu.tcl:372
msgid "Recode using rules file"
msgstr "ÐеÑекодиÑоваÑÑ, иÑполÑзÑÑ Ñайл пÑавил"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:373
+#: ../gui/tcltk/gis.m/gmmenu.tcl:374
msgid "Rescale"
msgstr "ÐзмениÑÑ Ð¼Ð°ÑÑÑаб"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:374
+#: ../gui/tcltk/gis.m/gmmenu.tcl:375
msgid "Rescale with histogram"
msgstr "ÐзмениÑÑ Ð¼Ð°ÑÑÑаб Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ Ð³Ð¸ÑÑогÑаммÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:377
+#: ../gui/tcltk/gis.m/gmmenu.tcl:378
msgid "Concentric circles"
msgstr "ÐонÑенÑÑиÑеÑкие окÑÑжноÑÑи"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:378 ../gui/tcltk/d.m/menu.tcl:335
+#: ../gui/tcltk/gis.m/gmmenu.tcl:379 ../gui/tcltk/d.m/menu.tcl:336
msgid "Generate random cells"
msgstr "ÐенеÑиÑоваÑÑ ÑлÑÑайнÑе ÑÑейки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:379
+#: ../gui/tcltk/gis.m/gmmenu.tcl:380
msgid "Random cells"
msgstr "СлÑÑайнÑе ÑÑейки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:380
+#: ../gui/tcltk/gis.m/gmmenu.tcl:381
msgid "Random cells and vector points"
msgstr "СлÑÑайнÑе ÑÑейки и векÑоÑнÑе ÑоÑки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:382 ../gui/tcltk/d.m/menu.tcl:338
+#: ../gui/tcltk/gis.m/gmmenu.tcl:383 ../gui/tcltk/d.m/menu.tcl:339
msgid "Generate surfaces"
msgstr "ÐенеÑиÑоваÑÑ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑи"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:383
+#: ../gui/tcltk/gis.m/gmmenu.tcl:384
msgid "Fractal surface"
msgstr "ФÑакÑалÑÐ½Ð°Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:385
+#: ../gui/tcltk/gis.m/gmmenu.tcl:386
msgid "Gausian kernal density surface"
msgstr "ÐовеÑÑ
ноÑÑÑ Ð¿Ð»Ð¾ÑноÑÑи ÑÑнкÑии гаÑÑÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:386
+#: ../gui/tcltk/gis.m/gmmenu.tcl:387
msgid "Gaussian deviates surface"
msgstr "ÐовеÑÑ
ноÑÑÑ ÑлÑÑайнÑÑ
оÑклонений"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:388
+#: ../gui/tcltk/gis.m/gmmenu.tcl:389
msgid "Plane"
msgstr "ÐлоÑкоÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:390
+#: ../gui/tcltk/gis.m/gmmenu.tcl:391
msgid "Random deviates surface"
msgstr "ÐовеÑÑ
ноÑÑÑ ÑлÑÑайнÑÑ
оÑклонений"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:391
+#: ../gui/tcltk/gis.m/gmmenu.tcl:392
msgid "Random surface with spatial dependence"
msgstr "СлÑÑÐ°Ð¹Ð½Ð°Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ Ñ Ð¿ÑоÑÑÑанÑÑвенной завиÑимоÑÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:393
+#: ../gui/tcltk/gis.m/gmmenu.tcl:394
msgid "Contour lines"
msgstr "Ðзолинии"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:394 ../gui/tcltk/d.m/menu.tcl:347
+#: ../gui/tcltk/gis.m/gmmenu.tcl:395 ../gui/tcltk/d.m/menu.tcl:348
msgid "Interpolate surfaces"
msgstr "ÐнÑеÑполиÑоваÑÑ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑи"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:395
+#: ../gui/tcltk/gis.m/gmmenu.tcl:396
msgid "Bilinear from raster points"
msgstr "ÐÐ¸Ð»Ð¸Ð½ÐµÐ¹Ð½Ð°Ñ Ð¸Ð½ÑеÑполÑÑÐ¸Ñ ÑаÑÑÑовÑÑ
ÑоÑек"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:396
+#: ../gui/tcltk/gis.m/gmmenu.tcl:397
msgid "Bilinear and bicubic from vector points"
msgstr "ÐÐ¸Ð»Ð¸Ð½ÐµÐ¹Ð½Ð°Ñ Ð¸ бикÑбиÑеÑÐºÐ°Ñ Ð¸Ð½ÑеÑполÑÑÐ¸Ñ Ð²ÐµÐºÑоÑнÑÑ
ÑоÑек"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:398
+#: ../gui/tcltk/gis.m/gmmenu.tcl:399
msgid "IDW from raster points"
msgstr "IDW из ÑаÑÑÑовÑÑ
ÑоÑек"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:399
+#: ../gui/tcltk/gis.m/gmmenu.tcl:400
msgid "IDW from vector points"
msgstr "IDW из векÑоÑнÑÑ
ÑоÑек"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:401
+#: ../gui/tcltk/gis.m/gmmenu.tcl:402
msgid "Raster contours"
msgstr "РаÑÑÑовÑе изолинии"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:402
+#: ../gui/tcltk/gis.m/gmmenu.tcl:403
msgid "Regularized spline tension"
msgstr "Сплайн-инÑеÑполÑÑÐ¸Ñ (Regularized spline tension)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:404
+#: ../gui/tcltk/gis.m/gmmenu.tcl:405
msgid "Fill NULL cells"
msgstr "ÐаполниÑÑ NULL-ÑÑейки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:407 ../gui/tcltk/gis.m/gmmenu.tcl:528
-#: ../gui/tcltk/gis.m/gmmenu.tcl:582 ../gui/tcltk/d.m/menu.tcl:358
-#: ../gui/tcltk/d.m/menu.tcl:464 ../gui/tcltk/d.m/menu.tcl:520
+#: ../gui/tcltk/gis.m/gmmenu.tcl:408 ../gui/tcltk/gis.m/gmmenu.tcl:529
+#: ../gui/tcltk/gis.m/gmmenu.tcl:587 ../gui/tcltk/d.m/menu.tcl:359
+#: ../gui/tcltk/d.m/menu.tcl:465 ../gui/tcltk/d.m/menu.tcl:521
msgid "Reports and statistics"
msgstr "ÐÑÑеÑÑ Ð¸ ÑÑаÑиÑÑика"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:408 ../gui/tcltk/d.m/menu.tcl:359
-#: ../gui/tcltk/d.m/menu.tcl:521
+#: ../gui/tcltk/gis.m/gmmenu.tcl:409 ../gui/tcltk/d.m/menu.tcl:360
+#: ../gui/tcltk/d.m/menu.tcl:522
msgid "Report basic file information"
msgstr "ÐÑвеÑÑи оÑновнÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ Ñайле"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:409
+#: ../gui/tcltk/gis.m/gmmenu.tcl:410
msgid "Manage category information"
msgstr "УпÑавление инÑоÑмаÑией о каÑегоÑиÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:411 ../gui/tcltk/d.m/menu.tcl:362
+#: ../gui/tcltk/gis.m/gmmenu.tcl:412 ../gui/tcltk/d.m/menu.tcl:363
msgid "General statistics"
msgstr "ÐбÑÐ°Ñ ÑÑаÑиÑÑика"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:412
+#: ../gui/tcltk/gis.m/gmmenu.tcl:413
msgid "Quantiles for large data sets"
-msgstr ""
+msgstr "ÐванÑили Ð´Ð»Ñ Ð±Ð¾Ð»ÑÑиÑ
набоÑов даннÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:413
+#: ../gui/tcltk/gis.m/gmmenu.tcl:414
msgid "Range of category values"
msgstr "РазбÑÐ¾Ñ Ð·Ð½Ð°Ñений каÑегоÑий"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:414
+#: ../gui/tcltk/gis.m/gmmenu.tcl:415
msgid "Sum cell category values"
msgstr "СÑммиÑоваÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий ÑÑеек"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:415 ../gui/tcltk/d.m/menu.tcl:365
+#: ../gui/tcltk/gis.m/gmmenu.tcl:416 ../gui/tcltk/d.m/menu.tcl:366
msgid "Sum area by map and category"
msgstr "СÑммиÑоваÑÑ Ð¿Ð»Ð¾ÑÐ°Ð´Ñ Ð¿Ð¾ ÑÐ»Ð¾Ñ Ð¸ по каÑегоÑиÑм"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:416
+#: ../gui/tcltk/gis.m/gmmenu.tcl:417
msgid "Statistics for clumped cells (works with r.clump)"
msgstr "СÑаÑиÑÑика Ð´Ð»Ñ ÐºÐ»Ð°ÑÑеÑов ÑÑеек (ÑабоÑÐ°ÐµÑ Ñ r.clump)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:417 ../gui/tcltk/d.m/menu.tcl:367
+#: ../gui/tcltk/gis.m/gmmenu.tcl:418 ../gui/tcltk/d.m/menu.tcl:368
msgid "Total surface area corrected for topography"
msgstr "ÐбÑÐ°Ñ Ð¿Ð»Ð¾ÑÐ°Ð´Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑи ÑкоÑÑекÑиÑÐ¾Ð²Ð°Ð½Ð½Ð°Ñ Ñ ÑÑеÑом ÑелÑеÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:418 ../gui/tcltk/d.m/menu.tcl:368
-#: ../gui/tcltk/d.m/menu.tcl:468
+#: ../gui/tcltk/gis.m/gmmenu.tcl:419 ../gui/tcltk/d.m/menu.tcl:369
+#: ../gui/tcltk/d.m/menu.tcl:469
msgid "Univariate statistics"
msgstr "ÐдномеÑÐ½Ð°Ñ ÑÑаÑиÑÑика "
-#: ../gui/tcltk/gis.m/gmmenu.tcl:420
+#: ../gui/tcltk/gis.m/gmmenu.tcl:421
msgid "Sample transects"
msgstr "ТÑанÑекÑÑ ÑÑплиÑованиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:421
+#: ../gui/tcltk/gis.m/gmmenu.tcl:422
msgid "Sample transects (bearing/distance)"
msgstr "ÐÑбоÑка по ÑÑанÑекÑам (напÑавление/ÑаÑÑÑоÑние)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:423 ../gui/tcltk/d.m/menu.tcl:374
+#: ../gui/tcltk/gis.m/gmmenu.tcl:424 ../gui/tcltk/d.m/menu.tcl:375
msgid "Covariance/correlation"
msgstr "ÐоваÑиаÑиÑ/коÑÑелÑÑиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:424
+#: ../gui/tcltk/gis.m/gmmenu.tcl:425
msgid "Linear regression"
msgstr "ÐÐ¸Ð½ÐµÐ¹Ð½Ð°Ñ ÑегÑеÑÑиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:425
+#: ../gui/tcltk/gis.m/gmmenu.tcl:426
msgid "Mutual category occurences"
msgstr "Совпадение обÑиÑ
каÑегоÑий"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:428 ../gui/tcltk/d.m/menu.tcl:379
+#: ../gui/tcltk/gis.m/gmmenu.tcl:429 ../gui/tcltk/d.m/menu.tcl:380
msgid "&Vector"
msgstr "&ÐекÑоÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:430 ../gui/tcltk/d.m/menu.tcl:381
+#: ../gui/tcltk/gis.m/gmmenu.tcl:431 ../gui/tcltk/d.m/menu.tcl:382
msgid "Digitize"
msgstr "ÐекÑоÑизоваÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:431
+#: ../gui/tcltk/gis.m/gmmenu.tcl:432
msgid "Edit features"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:433 ../gui/tcltk/d.m/menu.tcl:383
+#: ../gui/tcltk/gis.m/gmmenu.tcl:434 ../gui/tcltk/d.m/menu.tcl:384
msgid "Create/rebuild topology"
msgstr "СоздаÑÑ/пеÑеÑÑÑоиÑÑ ÑопологиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:434
+#: ../gui/tcltk/gis.m/gmmenu.tcl:435
msgid "Clean vector"
msgstr "ÐÑиÑÑиÑÑ Ð²ÐµÐºÑоÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:435
+#: ../gui/tcltk/gis.m/gmmenu.tcl:436
msgid "Smooth or simplify"
-msgstr ""
+msgstr "СгладиÑÑ Ð¸Ð»Ð¸ ÑпÑоÑÑиÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:437
+#: ../gui/tcltk/gis.m/gmmenu.tcl:438
msgid "Convert object types"
msgstr "ÐонвеÑÑиÑоваÑÑ ÑÐ¸Ð¿Ñ Ð¾Ð±ÑекÑов"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:439
+#: ../gui/tcltk/gis.m/gmmenu.tcl:440
msgid "Add centroids"
msgstr "ÐобавиÑÑ ÑенÑÑоидÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:441
+#: ../gui/tcltk/gis.m/gmmenu.tcl:442
msgid "Build polylines"
msgstr "ÐоÑÑÑоиÑÑ Ð¿Ð¾Ð»Ð¸Ð»Ð¸Ð½Ð¸Ð¸"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:442
+#: ../gui/tcltk/gis.m/gmmenu.tcl:443
msgid "Split polylines"
msgstr "РазделиÑÑ Ð¿Ð¾Ð»Ð¸Ð½Ð¸Ð¸"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:443
+#: ../gui/tcltk/gis.m/gmmenu.tcl:444
msgid "Parallel lines"
msgstr "ÐаÑаллелÑнÑе линии"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:445
+#: ../gui/tcltk/gis.m/gmmenu.tcl:446
msgid "Dissolve boundaries"
msgstr "УдалиÑÑ Ð³ÑаниÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:447
+#: ../gui/tcltk/gis.m/gmmenu.tcl:448
msgid "Create 3D vector over raster"
msgstr "СоздаÑÑ 3D векÑÐ¾Ñ Ð¿Ð¾ ÑаÑÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:448
+#: ../gui/tcltk/gis.m/gmmenu.tcl:449
msgid "Extrude 3D vector"
msgstr "ÐÑдвинÑÑÑ ÑÑеÑ
меÑнÑй векÑоÑнÑй Ñлой"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:450
+#: ../gui/tcltk/gis.m/gmmenu.tcl:451
msgid "Link to OGR"
msgstr "СвÑзаÑÑ Ñ OGR"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:452
+#: ../gui/tcltk/gis.m/gmmenu.tcl:453
msgid "Create labels"
msgstr "СоздаÑÑ Ð¿Ð¾Ð´Ð¿Ð¸Ñи"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:453
-#, fuzzy
+#: ../gui/tcltk/gis.m/gmmenu.tcl:454
msgid "Assign colors"
-msgstr "ÑÐ²ÐµÑ Ð»Ð¸Ð½Ð¸Ð¸"
+msgstr "ÐазнаÑиÑÑ ÑвеÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:455
+#: ../gui/tcltk/gis.m/gmmenu.tcl:456
msgid "Reposition vector"
msgstr "ÐеизвеÑÑнÑй Ñип векÑоÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:456
+#: ../gui/tcltk/gis.m/gmmenu.tcl:457
msgid "Reproject vector"
msgstr "ÐеÑепÑоекÑиÑоваÑÑ Ð²ÐµÐºÑоÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:458
+#: ../gui/tcltk/gis.m/gmmenu.tcl:459
msgid "Metadata support"
msgstr "ÐоддеÑжка меÑаданнÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:462
+#: ../gui/tcltk/gis.m/gmmenu.tcl:463
msgid "Query with attributes"
msgstr "ÐапÑÐ¾Ñ Ð¿Ð¾ аÑÑибÑÑами"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:463
+#: ../gui/tcltk/gis.m/gmmenu.tcl:464
msgid "Query with coordinate(s)"
msgstr " ÐапÑÐ¾Ñ Ð¿Ð¾ кооÑдинаÑам"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:464
+#: ../gui/tcltk/gis.m/gmmenu.tcl:465
msgid "Query with another map"
msgstr "ÐапÑÐ¾Ñ Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ Ð´ÑÑгого ÑлоÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:466
+#: ../gui/tcltk/gis.m/gmmenu.tcl:467
msgid "Buffer vectors"
msgstr "ÐÑÑеÑизоваÑÑ Ð²ÐµÐºÑоÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:467
+#: ../gui/tcltk/gis.m/gmmenu.tcl:468
msgid "Lidar analysis"
msgstr "Ðнализ даннÑÑ
LIDAR"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:468
+#: ../gui/tcltk/gis.m/gmmenu.tcl:469
msgid "Detect edges"
msgstr "ÐпÑеделиÑÑ Ð³ÑаниÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:469
+#: ../gui/tcltk/gis.m/gmmenu.tcl:470
msgid "Detect interiors"
msgstr "ÐпÑеделиÑÑ Ð²Ð½ÑÑÑенноÑÑи"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:470
+#: ../gui/tcltk/gis.m/gmmenu.tcl:471
msgid "Correct and reclassify objects"
msgstr "ÐÑпÑавиÑÑ Ð¸ пеÑеклаÑÑиÑиÑиÑоваÑÑ Ð¾Ð±ÑекÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:472
+#: ../gui/tcltk/gis.m/gmmenu.tcl:473
msgid "Linear referencing"
msgstr "ÐÐ¸Ð½ÐµÐ¹Ð½Ð°Ñ Ð¿ÑивÑзка"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:473
+#: ../gui/tcltk/gis.m/gmmenu.tcl:474
msgid "Create LRS"
msgstr "СоздаÑÑ LRS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:474
+#: ../gui/tcltk/gis.m/gmmenu.tcl:475
msgid "Create stationing"
msgstr "СоздаÑÑ ÑÑанÑии"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:475
+#: ../gui/tcltk/gis.m/gmmenu.tcl:476
msgid "Create points/segments"
msgstr "СоздаÑÑ ÑоÑки/ÑегменÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:476
+#: ../gui/tcltk/gis.m/gmmenu.tcl:477
msgid "Find ID and offset"
msgstr "ÐайÑи ID и ÑмеÑÑиÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:478
+#: ../gui/tcltk/gis.m/gmmenu.tcl:479
msgid "Nearest features"
msgstr "ÐлижайÑие обÑекÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:479 ../gui/tcltk/d.m/menu.tcl:423
+#: ../gui/tcltk/gis.m/gmmenu.tcl:480 ../gui/tcltk/d.m/menu.tcl:424
msgid "Network analysis"
msgstr "СеÑевой анализ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:480 ../gui/tcltk/d.m/menu.tcl:424
+#: ../gui/tcltk/gis.m/gmmenu.tcl:481 ../gui/tcltk/d.m/menu.tcl:425
msgid "Allocate subnets"
msgstr "ÐайÑи подÑеÑи"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:481 ../gui/tcltk/d.m/menu.tcl:425
+#: ../gui/tcltk/gis.m/gmmenu.tcl:482 ../gui/tcltk/d.m/menu.tcl:426
msgid "Network maintenance"
msgstr "ÐбÑлÑживание ÑеÑи"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:482
+#: ../gui/tcltk/gis.m/gmmenu.tcl:483
msgid "Visibility network"
msgstr "СеÑÑ Ð²Ð¸Ð´Ð¸Ð¼Ð¾ÑÑи"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:483 ../gui/tcltk/d.m/menu.tcl:426
+#: ../gui/tcltk/gis.m/gmmenu.tcl:484 ../gui/tcltk/d.m/menu.tcl:427
msgid "Shortest route"
msgstr "ÐÑаÑÑайÑий пÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:484
+#: ../gui/tcltk/gis.m/gmmenu.tcl:485
msgid "Display shortest route"
msgstr "ÐоказаÑÑ ÐºÑаÑÑайÑий пÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:489
+#: ../gui/tcltk/gis.m/gmmenu.tcl:490
msgid "Split net"
msgstr "РазделиÑÑ ÑеÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:490 ../gui/tcltk/d.m/menu.tcl:429
+#: ../gui/tcltk/gis.m/gmmenu.tcl:491 ../gui/tcltk/d.m/menu.tcl:430
msgid "Steiner tree"
msgstr "ÐеÑево ШÑейнеÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:491 ../gui/tcltk/d.m/menu.tcl:430
+#: ../gui/tcltk/gis.m/gmmenu.tcl:492 ../gui/tcltk/d.m/menu.tcl:431
msgid "Traveling salesman analysis"
msgstr "Ðнализ коммивоÑжеÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:494
+#: ../gui/tcltk/gis.m/gmmenu.tcl:495
msgid "Overlay"
msgstr "ÐвеÑлей"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:495
+#: ../gui/tcltk/gis.m/gmmenu.tcl:496
msgid "Patch (combine)"
msgstr "ÐалаÑаÑÑ (комбиниÑование)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:498 ../gui/tcltk/d.m/menu.tcl:439
+#: ../gui/tcltk/gis.m/gmmenu.tcl:499 ../gui/tcltk/d.m/menu.tcl:440
msgid "Change attributes"
msgstr "ÐзмениÑÑ Ð°ÑÑибÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:499
+#: ../gui/tcltk/gis.m/gmmenu.tcl:500
msgid "Manage or report categories"
msgstr "УпÑавлÑÑÑ Ð¸Ð»Ð¸ вÑвеÑÑи каÑегоÑии"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:500
+#: ../gui/tcltk/gis.m/gmmenu.tcl:501
msgid "Reclassify objects interactively"
msgstr "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ Ð¾Ð±ÑекÑÑ Ð² инÑеÑакÑивном Ñежиме"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:504
+#: ../gui/tcltk/gis.m/gmmenu.tcl:505
msgid "Generate area for current region"
msgstr "СоздаÑÑ Ð¿Ð»Ð¾ÑÐ°Ð´Ñ Ð´Ð»Ñ ÑекÑÑего Ñегиона"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:505 ../gui/tcltk/d.m/menu.tcl:450
+#: ../gui/tcltk/gis.m/gmmenu.tcl:506 ../gui/tcltk/d.m/menu.tcl:451
msgid "Generate areas from points"
msgstr "СоздаÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ñ Ð¸Ð· ÑоÑек"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:506
+#: ../gui/tcltk/gis.m/gmmenu.tcl:507
msgid "Convex hull"
msgstr "ÐонвекÑнÑй полигон"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:507
+#: ../gui/tcltk/gis.m/gmmenu.tcl:508
msgid "Delaunay triangles"
msgstr "ТÑиангÑлÑÑÐ¸Ñ Ðелоне"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:508
+#: ../gui/tcltk/gis.m/gmmenu.tcl:509
msgid "Voronoi diagram/Thiessen polygons"
msgstr "ÐиагÑамма ÐоÑоного/ÐÐ¾Ð»Ð¸Ð³Ð¾Ð½Ñ Ð¢Ð¸ÑÑена"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:510
+#: ../gui/tcltk/gis.m/gmmenu.tcl:511
msgid "Generate grid"
msgstr "СоздаÑÑ ÑеÑкÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:511 ../gui/tcltk/d.m/menu.tcl:445
+#: ../gui/tcltk/gis.m/gmmenu.tcl:512 ../gui/tcltk/d.m/menu.tcl:446
msgid "Generate points"
msgstr "СоздаÑÑ ÑоÑки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:512
+#: ../gui/tcltk/gis.m/gmmenu.tcl:513
msgid "Generate points from database"
msgstr "СоздаÑÑ ÑоÑки из Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:513
+#: ../gui/tcltk/gis.m/gmmenu.tcl:514
msgid "Generate points along lines"
msgstr "СоздаÑÑ ÑоÑки Ð²Ð´Ð¾Ð»Ñ Ð»Ð¸Ð½Ð¸Ð¹"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:514 ../gui/tcltk/d.m/menu.tcl:447
+#: ../gui/tcltk/gis.m/gmmenu.tcl:515 ../gui/tcltk/d.m/menu.tcl:448
msgid "Generate random points"
msgstr "СоздаÑÑ ÑлÑÑайнÑе ÑоÑки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:515
+#: ../gui/tcltk/gis.m/gmmenu.tcl:516
msgid "Perturb points"
msgstr "СмеÑÑиÑÑ ÑоÑки"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:518
+#: ../gui/tcltk/gis.m/gmmenu.tcl:519
msgid "Remove outliers in point sets"
msgstr "УдалиÑÑ Ð¾Ð±Ð¾ÑобленнÑе ÑоÑки из набоÑа ÑоÑек"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:519
+#: ../gui/tcltk/gis.m/gmmenu.tcl:520
msgid "Test/training sets"
msgstr "ÐÑовеÑоÑнÑе/ÑÑениÑовоÑнÑе набоÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:521
+#: ../gui/tcltk/gis.m/gmmenu.tcl:522
msgid "Update area attributes from raster"
msgstr "ÐбновиÑÑ Ð°ÑÑибÑÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ð° из ÑаÑÑÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:522
+#: ../gui/tcltk/gis.m/gmmenu.tcl:523
msgid "Update point attributes from areas"
msgstr "ÐбновиÑÑ Ð°ÑÑибÑÑÑ ÑоÑек иÑполÑзÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ñ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:523
+#: ../gui/tcltk/gis.m/gmmenu.tcl:524
msgid "Update point attributes from raster"
msgstr "ÐбновиÑÑ Ð°ÑÑибÑÑÑ ÑоÑки иÑполÑзÑÑ ÑаÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:524 ../gui/tcltk/d.m/menu.tcl:457
+#: ../gui/tcltk/gis.m/gmmenu.tcl:525 ../gui/tcltk/d.m/menu.tcl:458
msgid "Sample raster map at point locations"
msgstr "ÐолÑÑиÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð² ÑоÑкаÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:525 ../gui/tcltk/d.m/menu.tcl:458
+#: ../gui/tcltk/gis.m/gmmenu.tcl:526 ../gui/tcltk/d.m/menu.tcl:459
msgid "Sample raster neighborhood around points"
msgstr "ÐолÑÑаÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÑаÑÑÑа в окÑеÑÑноÑÑÑÑ
ÑоÑек"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:529 ../gui/tcltk/gis.m/gmmenu.tcl:599
-#: ../gui/tcltk/d.m/menu.tcl:465
+#: ../gui/tcltk/gis.m/gmmenu.tcl:530 ../gui/tcltk/gis.m/gmmenu.tcl:604
+#: ../gui/tcltk/d.m/menu.tcl:466
msgid "Basic information"
msgstr "ÐÑÐ½Ð¾Ð²Ð½Ð°Ñ Ð¸Ð½ÑоÑмаÑиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:531
+#: ../gui/tcltk/gis.m/gmmenu.tcl:532
msgid "Report topology by category"
msgstr "ÐоказаÑÑ ÑÐ¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð¿Ð¾ каÑегоÑии"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:532
+#: ../gui/tcltk/gis.m/gmmenu.tcl:533
msgid "Upload or report topology"
msgstr "ÐагÑÑзиÑÑ Ð¸Ð»Ð¸ показаÑÑ ÑопологиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:534
+#: ../gui/tcltk/gis.m/gmmenu.tcl:535
msgid "Univariate attribute statistics"
msgstr "ÐдномеÑÐ½Ð°Ñ Ð°ÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑÑаÑиÑÑика"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:536
+#: ../gui/tcltk/gis.m/gmmenu.tcl:537
msgid "Quadrat indices"
msgstr "ÐвадÑаÑиÑеÑкие индекÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:537
+#: ../gui/tcltk/gis.m/gmmenu.tcl:538
msgid "Test normality"
msgstr "ТеÑÑ Ð½Ð¾ÑмалÑноÑÑи"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:540 ../gui/tcltk/d.m/menu.tcl:475
+#: ../gui/tcltk/gis.m/gmmenu.tcl:541 ../gui/tcltk/d.m/menu.tcl:476
msgid "&Imagery"
msgstr "&ÐзобÑажениÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:541 ../gui/tcltk/d.m/menu.tcl:476
+#: ../gui/tcltk/gis.m/gmmenu.tcl:542 ../gui/tcltk/d.m/menu.tcl:477
msgid "Develop images and groups"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:542
+#: ../gui/tcltk/gis.m/gmmenu.tcl:543
msgid "Create/edit group"
msgstr "СоздаÑÑ/ÑедакÑиÑоваÑÑ Ð³ÑÑппÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:543
+#: ../gui/tcltk/gis.m/gmmenu.tcl:544
msgid "Target group"
msgstr "Ð¦ÐµÐ»ÐµÐ²Ð°Ñ Ð³ÑÑппа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:545
+#: ../gui/tcltk/gis.m/gmmenu.tcl:546
msgid "Mosaic images"
msgstr "ÐозаиÑиÑоваÑÑ Ð¸Ð·Ð¾Ð±ÑажениÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:547 ../gui/tcltk/d.m/menu.tcl:482
+#: ../gui/tcltk/gis.m/gmmenu.tcl:548 ../gui/tcltk/d.m/menu.tcl:483
msgid "Manage image colors"
msgstr "УпÑавление ÑвеÑами изобÑажениÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:548
+#: ../gui/tcltk/gis.m/gmmenu.tcl:549
msgid "Color balance for RGB"
msgstr "ЦвеÑовой Ð±Ð°Ð»Ð°Ð½Ñ RGB"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:550
+#: ../gui/tcltk/gis.m/gmmenu.tcl:551
msgid "RGB to HIS"
msgstr "RGB в HIS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:552 ../gui/tcltk/d.m/menu.tcl:493
+#: ../gui/tcltk/gis.m/gmmenu.tcl:553 ../gui/tcltk/d.m/menu.tcl:494
msgid "Ortho photo rectification"
msgstr "ÐÑÑоÑоÑоÑÑанÑÑоÑмаÑиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:558
+#: ../gui/tcltk/gis.m/gmmenu.tcl:559
msgid "Brovey sharpening"
msgstr "ÑвелиÑение ÑезкоÑÑи по ÐÑÑви"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:559 ../gui/tcltk/d.m/menu.tcl:497
+#: ../gui/tcltk/gis.m/gmmenu.tcl:560 ../gui/tcltk/d.m/menu.tcl:498
msgid "Classify image"
msgstr "ÐлаÑÑиÑиÑиÑоваÑÑ Ð¸Ð·Ð¾Ð±Ñажение"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:560 ../gui/tcltk/d.m/menu.tcl:498
+#: ../gui/tcltk/gis.m/gmmenu.tcl:561 ../gui/tcltk/d.m/menu.tcl:499
msgid "Clustering input for unsupervised classification"
msgstr "ÐлаÑÑеÑизаÑÐ¸Ñ Ð¸ÑÑ
однÑÑ
даннÑÑ
Ð´Ð»Ñ ÐºÐ»Ð°ÑÑиÑикаÑии без обÑÑениÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:562 ../gui/tcltk/d.m/menu.tcl:500
-msgid "Maximum likelyhood classification (MLC)"
+#: ../gui/tcltk/gis.m/gmmenu.tcl:563 ../gui/tcltk/d.m/menu.tcl:501
+#, fuzzy
+msgid "Maximum likelihood classification (MLC)"
msgstr "ÐлаÑÑиÑикаÑÐ¸Ñ Ð¼Ð°ÐºÑималÑного Ð¿Ð¾Ð´Ð¾Ð±Ð¸Ñ (MLC)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:563 ../gui/tcltk/d.m/menu.tcl:501
+#: ../gui/tcltk/gis.m/gmmenu.tcl:564 ../gui/tcltk/d.m/menu.tcl:502
msgid "Sequential maximum a posteriory classification (SMAP)"
msgstr "Sequential maximum a posteriory classification (SMAP)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:565 ../gui/tcltk/d.m/menu.tcl:503
+#: ../gui/tcltk/gis.m/gmmenu.tcl:566 ../gui/tcltk/d.m/menu.tcl:504
msgid "Interactive input for supervised classification"
msgstr "ÐнÑеÑакÑивнÑй ввод Ð´Ð»Ñ ÐºÐ»Ð°ÑÑиÑикаÑии Ñ Ð¾Ð±ÑÑением"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:566
+#: ../gui/tcltk/gis.m/gmmenu.tcl:571
msgid "Input for supervised MLC"
msgstr "ÐÑÑ
однÑе даннÑе Ð´Ð»Ñ MLC Ñ Ð¾Ð±ÑÑением"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:567
+#: ../gui/tcltk/gis.m/gmmenu.tcl:572
msgid "Input for supervised SMAP"
msgstr "ÐÑ
однÑе даннÑе Ð´Ð»Ñ SMAP Ñ Ð¾Ð±ÑÑением"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:569 ../gui/tcltk/d.m/menu.tcl:507
+#: ../gui/tcltk/gis.m/gmmenu.tcl:574 ../gui/tcltk/d.m/menu.tcl:508
msgid "Filter image"
msgstr "ФилÑÑÑоваÑÑ Ð¸Ð·Ð¾Ð±Ñажение"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:570
+#: ../gui/tcltk/gis.m/gmmenu.tcl:575
msgid "Edge detection"
msgstr "ÐпÑеделение гÑаниÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:571
+#: ../gui/tcltk/gis.m/gmmenu.tcl:576
msgid "Matrix/convolving filter"
msgstr "ÐаÑÑиÑнÑй/ÑвеÑнÑÑÑй ÑилÑÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:573 ../gui/tcltk/d.m/menu.tcl:511
+#: ../gui/tcltk/gis.m/gmmenu.tcl:578 ../gui/tcltk/d.m/menu.tcl:512
msgid "Spectral response"
msgstr "СпекÑÑалÑнÑй оÑклик"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:574 ../gui/tcltk/d.m/menu.tcl:512
+#: ../gui/tcltk/gis.m/gmmenu.tcl:579 ../gui/tcltk/d.m/menu.tcl:513
msgid "Tassled cap vegetation index"
msgstr "ÐÐ½Ð´ÐµÐºÑ Ð²ÐµÐ³ÐµÑаÑии Tasseled cap"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:575 ../gui/tcltk/d.m/menu.tcl:513
+#: ../gui/tcltk/gis.m/gmmenu.tcl:580 ../gui/tcltk/d.m/menu.tcl:514
msgid "Transform image"
msgstr "ТÑанÑÑоÑмиÑоваÑÑ Ð¸Ð·Ð¾Ð±Ñажение"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:576
+#: ../gui/tcltk/gis.m/gmmenu.tcl:581
msgid "Canonical correlation"
msgstr "ÐанониÑеÑÐºÐ°Ñ ÐºÐ¾ÑÑелÑÑиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:577
+#: ../gui/tcltk/gis.m/gmmenu.tcl:582
msgid "Principal components"
msgstr "ÐлавнÑе компоненÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:578
+#: ../gui/tcltk/gis.m/gmmenu.tcl:583
msgid "Fast Fourier"
msgstr "ÐÑÑÑÑое пÑеобÑазование ФÑÑÑе"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:579
+#: ../gui/tcltk/gis.m/gmmenu.tcl:584
msgid "Inverse Fast Fourier"
msgstr "ÐбÑаÑное бÑÑÑÑое пÑеобÑазование ФÑÑÑе"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:583
+#: ../gui/tcltk/gis.m/gmmenu.tcl:588
msgid "Bit pattern comparison"
msgstr "ÐиÑовое ÑÑавнение Ñаблонов"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:584
+#: ../gui/tcltk/gis.m/gmmenu.tcl:589
msgid "Kappa analysis"
msgstr "Ðаппа анализ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:585
+#: ../gui/tcltk/gis.m/gmmenu.tcl:590
msgid "OIF for LandSat TM"
msgstr "OIF Ð´Ð»Ñ LandSat TM"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:588
+#: ../gui/tcltk/gis.m/gmmenu.tcl:593
msgid "&Volumes"
msgstr "&ÐбÑемÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:589 ../gui/tcltk/d.m/menu.tcl:530
+#: ../gui/tcltk/gis.m/gmmenu.tcl:594 ../gui/tcltk/d.m/menu.tcl:531
msgid "Develop grid3D volumes"
msgstr "СоздаÑÑ Ð¾Ð±ÑÐµÐ¼Ñ grid3D "
-#: ../gui/tcltk/gis.m/gmmenu.tcl:590 ../gui/tcltk/d.m/menu.tcl:531
+#: ../gui/tcltk/gis.m/gmmenu.tcl:595 ../gui/tcltk/d.m/menu.tcl:532
msgid "Manage nulls for grid3D volume"
msgstr "УпÑавление нÑлÑми Ð´Ð»Ñ Ð¾Ð±ÑемнÑÑ
даннÑÑ
grid3D"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:591 ../gui/tcltk/d.m/menu.tcl:532
+#: ../gui/tcltk/gis.m/gmmenu.tcl:596 ../gui/tcltk/d.m/menu.tcl:533
msgid "Manage timestamp for grid3D volume"
msgstr "УпÑавление вÑеменнÑми меÑками Ð´Ð»Ñ Ð¾Ð±ÑемнÑÑ
даннÑÑ
grid3D"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:593
+#: ../gui/tcltk/gis.m/gmmenu.tcl:598
msgid "3D MASK"
msgstr "3D MASK"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:594
+#: ../gui/tcltk/gis.m/gmmenu.tcl:599
msgid "3D Map calculator"
msgstr "3D ÑаÑÑÑовÑй калÑкÑлÑÑоÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:595
+#: ../gui/tcltk/gis.m/gmmenu.tcl:600
msgid "Cross section from volume"
msgstr "СеÑение обÑема"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:597
+#: ../gui/tcltk/gis.m/gmmenu.tcl:602
msgid "Interpolate volume from vector points"
msgstr "ÐнÑеÑполиÑоваÑÑ Ð¾Ð±Ñем по векÑоÑнÑм ÑоÑкам"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:598 ../gui/tcltk/d.m/menu.tcl:538
+#: ../gui/tcltk/gis.m/gmmenu.tcl:603 ../gui/tcltk/d.m/menu.tcl:539
msgid "Report and Statistics"
msgstr "ÐÑÑÐµÑ Ð¸ ÑÑаÑиÑÑика"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:602 ../gui/tcltk/d.m/menu.tcl:542
+#: ../gui/tcltk/gis.m/gmmenu.tcl:607 ../gui/tcltk/d.m/menu.tcl:543
msgid "&Databases"
msgstr "&ÐÐ°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:603 ../gui/tcltk/d.m/menu.tcl:552
+#: ../gui/tcltk/gis.m/gmmenu.tcl:608 ../gui/tcltk/d.m/menu.tcl:553
msgid "Database information"
msgstr "ÐнÑоÑмаÑÐ¸Ñ Ð¾ базе даннÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:604 ../gui/tcltk/d.m/menu.tcl:553
+#: ../gui/tcltk/gis.m/gmmenu.tcl:609 ../gui/tcltk/d.m/menu.tcl:554
msgid "Describe table"
msgstr "ÐпиÑаÑÑ ÑаблиÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:605 ../gui/tcltk/d.m/menu.tcl:554
+#: ../gui/tcltk/gis.m/gmmenu.tcl:610 ../gui/tcltk/d.m/menu.tcl:555
msgid "List columns"
msgstr "СпиÑок ÑÑолбÑов"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:606 ../gui/tcltk/d.m/menu.tcl:555
+#: ../gui/tcltk/gis.m/gmmenu.tcl:611 ../gui/tcltk/d.m/menu.tcl:556
msgid "List drivers"
msgstr "СпиÑок дÑайвеÑов"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:607 ../gui/tcltk/d.m/menu.tcl:556
+#: ../gui/tcltk/gis.m/gmmenu.tcl:612 ../gui/tcltk/d.m/menu.tcl:557
msgid "List tables"
msgstr "СпиÑок ÑаблиÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:610 ../gui/tcltk/d.m/menu.tcl:543
+#: ../gui/tcltk/gis.m/gmmenu.tcl:615 ../gui/tcltk/d.m/menu.tcl:544
msgid "Manage database"
msgstr "УпÑавлÑÑÑ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:611 ../gui/tcltk/d.m/menu.tcl:544
+#: ../gui/tcltk/gis.m/gmmenu.tcl:616 ../gui/tcltk/d.m/menu.tcl:545
msgid "Connect to database"
msgstr "СоединиÑÑÑÑ Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:612 ../gui/tcltk/d.m/menu.tcl:545
+#: ../gui/tcltk/gis.m/gmmenu.tcl:617 ../gui/tcltk/d.m/menu.tcl:546
msgid "Login to database"
msgstr "ÐойÑи в Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:614 ../gui/tcltk/d.m/menu.tcl:547
+#: ../gui/tcltk/gis.m/gmmenu.tcl:619 ../gui/tcltk/d.m/menu.tcl:548
msgid "Copy table"
msgstr "ÐопиÑоваÑÑ ÑаблиÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:615
+#: ../gui/tcltk/gis.m/gmmenu.tcl:620
msgid "New table"
msgstr "ÐÐ¾Ð²Ð°Ñ ÑаблиÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:616
+#: ../gui/tcltk/gis.m/gmmenu.tcl:621
msgid "Remove table"
msgstr "УдалиÑÑ ÑаблиÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:618
+#: ../gui/tcltk/gis.m/gmmenu.tcl:623
msgid "Add columns"
msgstr "ÐобавиÑÑ ÑÑолбÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:619
+#: ../gui/tcltk/gis.m/gmmenu.tcl:624
msgid "Change values"
msgstr "ÐзмениÑÑ Ð·Ð½Ð°ÑениÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:620
+#: ../gui/tcltk/gis.m/gmmenu.tcl:625
msgid "Drop column"
msgstr "УдалиÑÑполе"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:621
+#: ../gui/tcltk/gis.m/gmmenu.tcl:626
msgid "Rename a column"
msgstr "ÐеÑеименоваÑÑ ÑÑолбеÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:623 ../gui/tcltk/d.m/menu.tcl:550
+#: ../gui/tcltk/gis.m/gmmenu.tcl:628 ../gui/tcltk/d.m/menu.tcl:551
msgid "Test database"
msgstr "ТеÑÑиÑоваÑÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:627
+#: ../gui/tcltk/gis.m/gmmenu.tcl:632
msgid "Query any table"
msgstr "ÐапÑÐ¾Ñ Ðº лÑбой ÑаблиÑе"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:628
+#: ../gui/tcltk/gis.m/gmmenu.tcl:633
msgid "Query vector attribute table"
msgstr "ÐапÑÐ¾Ñ Ðº аÑÑибÑÑивнÑм даннÑм векÑоÑа"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:629
+#: ../gui/tcltk/gis.m/gmmenu.tcl:634
msgid "SQL statement"
msgstr "SQL вÑÑажение"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:631 ../gui/tcltk/d.m/menu.tcl:401
+#: ../gui/tcltk/gis.m/gmmenu.tcl:636 ../gui/tcltk/d.m/menu.tcl:402
msgid "Vector<->database connections"
msgstr "ÐекÑÐ¾Ñ <-> ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ñ Ð±Ð°Ð·Ð°Ð¼Ð¸ даннÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:632
+#: ../gui/tcltk/gis.m/gmmenu.tcl:637
msgid "Reconnect vector to database"
msgstr "СвÑзаÑÑ Ð·Ð°Ð½Ð¾Ð²Ð¾ векÑоÑнÑй и Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:633
+#: ../gui/tcltk/gis.m/gmmenu.tcl:638
msgid "Set vector - database connection"
msgstr "УÑÑановиÑÑ ÑвÑÐ·Ñ Ð²ÐµÐºÑоÑнÑй Ñлой - база даннÑÑ
-#: ../gui/tcltk/gis.m/gmmenu.tcl:636 ../gui/tcltk/d.m/menu.tcl:564
+#: ../gui/tcltk/gis.m/gmmenu.tcl:641 ../gui/tcltk/d.m/menu.tcl:565
msgid "&Help"
msgstr "&ÐомоÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:637 ../gui/tcltk/d.m/menu.tcl:565
+#: ../gui/tcltk/gis.m/gmmenu.tcl:642 ../gui/tcltk/d.m/menu.tcl:566
msgid "GRASS help"
msgstr "GRASS помоÑÑ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:638 ../gui/tcltk/d.m/menu.tcl:566
+#: ../gui/tcltk/gis.m/gmmenu.tcl:643 ../gui/tcltk/d.m/menu.tcl:567
msgid "GIS Manager &help"
msgstr "ÐомоÑÑ Ð´Ð»Ñ ÐÐС ÐенеджеÑа"
msgid "GIS Manager help"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:639 ../gui/tcltk/d.m/menu.tcl:567
+#: ../gui/tcltk/gis.m/gmmenu.tcl:644 ../gui/tcltk/d.m/menu.tcl:568
msgid "About &GRASS"
msgstr "Ð &GRASS"
msgid "About GRASS"
msgstr "Ð GRASS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:640 ../gui/tcltk/d.m/menu.tcl:568
+#: ../gui/tcltk/gis.m/gmmenu.tcl:645 ../gui/tcltk/d.m/menu.tcl:569
msgid "About &System"
msgstr "Ð &СиÑÑеме"
msgid "About System"
msgstr "РСиÑÑеме"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:648 ../gui/tcltk/d.m/menu.tcl:576
+#: ../gui/tcltk/gis.m/gmmenu.tcl:653 ../gui/tcltk/d.m/menu.tcl:577
msgid "&Xtns"
msgstr "&Xtns"
@@ -3575,14 +3603,15 @@
msgstr "РаÑÑÑовÑй Ñлой:"
#: ../gui/tcltk/gis.m/legend.tcl:229
+#, tcl-format
msgid "Legend placement and size as 0-100% of display"
-msgstr "РаÑположение Ð»ÐµÐ³ÐµÐ½Ð´Ñ Ð¸ ÑÐ°Ð·Ð¼ÐµÑ ÐºÐ°Ðº 0-100% диÑплеÑ"
+msgstr "РаÑположение Ð»ÐµÐ³ÐµÐ½Ð´Ñ Ð¸ ÑÐ°Ð·Ð¼ÐµÑ ÐºÐ°Ðº 0-100 пÑоÑенÑов диÑплеÑ"
#: ../gui/tcltk/gis.m/legend.tcl:235
+#, tcl-format
msgid " x,y of lower left corner (in % from display top left)"
-msgstr " x,y нижнего левого Ñгла (в % Ð¾Ñ Ð²ÐµÑÑ
него левого Ñгла диÑплеÑ)"
+msgstr ""
+" x,y нижнего левого Ñгла (в пÑоÑенÑаÑ
Ð¾Ñ Ð²ÐµÑÑ
#: ../gui/tcltk/gis.m/legend.tcl:238 ../gui/tcltk/gis.m/barscale.tcl:191
#: ../gui/tcltk/gis.m/maptext.tcl:150 ../gui/tcltk/gis.m/dtext.tcl:197
@@ -3594,18 +3623,18 @@
msgstr " вÑÑоÑа легендÑ"
#: ../gui/tcltk/gis.m/legend.tcl:248
+#, tcl-format
msgid "Legend height (% of display)"
-msgstr "ÐÑÑоÑа Ð»ÐµÐ³ÐµÐ½Ð´Ñ (% диÑплеÑ)"
+msgstr "ÐÑÑоÑа Ð»ÐµÐ³ÐµÐ½Ð´Ñ (в пÑоÑенÑаÑ
диÑплеÑ)"
#: ../gui/tcltk/gis.m/legend.tcl:249
msgid "% width"
msgstr "% ÑиÑина"
#: ../gui/tcltk/gis.m/legend.tcl:251
+#, tcl-format
msgid "Legend width (% of display)"
-msgstr "ШиÑина Ð»ÐµÐ³ÐµÐ½Ð´Ñ (% диÑплеÑ)"
+msgstr "ШиÑина Ð»ÐµÐ³ÐµÐ½Ð´Ñ (в пÑоÑенÑаÑ
диÑплеÑ)"
#: ../gui/tcltk/gis.m/legend.tcl:258
msgid "Legend appearance: text color"
@@ -3923,200 +3952,201 @@
msgid "\tchart outline color:"
msgstr "\tÑÐ²ÐµÑ Ð¾Ð±Ð²Ð¾Ð´ÐºÐ¸ диагÑаммÑ:"
-#: ../gui/tcltk/gis.m/vector.tcl:229
+#: ../gui/tcltk/gis.m/vector.tcl:226
msgid "Vector output map"
msgstr "ÐÑÑ
одной векÑоÑнÑй Ñлой"
-#: ../gui/tcltk/gis.m/vector.tcl:299
+#: ../gui/tcltk/gis.m/vector.tcl:296
msgid "Display vector maps"
msgstr "ÐоказаÑÑ Ð²ÐµÐºÑоÑнÑе Ñлои"
-#: ../gui/tcltk/gis.m/vector.tcl:310
+#: ../gui/tcltk/gis.m/vector.tcl:307
msgid "Transparent"
msgstr "ÐÑозÑаÑнÑй"
-#: ../gui/tcltk/gis.m/vector.tcl:319
+#: ../gui/tcltk/gis.m/vector.tcl:316
msgid "vector map to display"
msgstr "показÑваемÑй векÑоÑнÑй Ñлой"
-#: ../gui/tcltk/gis.m/vector.tcl:324 ../gui/tcltk/gis.m/vector.tcl:328
+#: ../gui/tcltk/gis.m/vector.tcl:321 ../gui/tcltk/gis.m/vector.tcl:325
msgid "Vector Info"
msgstr "ÐнÑоÑмаÑÐ¸Ñ Ð¾ векÑоÑе"
-#: ../gui/tcltk/gis.m/vector.tcl:340
+#: ../gui/tcltk/gis.m/vector.tcl:337
#, fuzzy
msgid "Display: "
msgstr "ÐоказаÑÑ:"
-#: ../gui/tcltk/gis.m/vector.tcl:341
+#: ../gui/tcltk/gis.m/vector.tcl:338
msgid "Shapes "
msgstr "ÐбÑекÑÑ"
-#: ../gui/tcltk/gis.m/vector.tcl:343
+#: ../gui/tcltk/gis.m/vector.tcl:340
msgid "Categories "
msgstr "ÐаÑегоÑии"
-#: ../gui/tcltk/gis.m/vector.tcl:345
+#: ../gui/tcltk/gis.m/vector.tcl:342
msgid "Topology "
msgstr "ТопологиÑ"
-#: ../gui/tcltk/gis.m/vector.tcl:347
+#: ../gui/tcltk/gis.m/vector.tcl:344
msgid "Line directions "
msgstr "ÐапÑÐ°Ð²Ð»ÐµÐ½Ð¸Ñ Ð»Ð¸Ð½Ð¸Ð¹"
-#: ../gui/tcltk/gis.m/vector.tcl:355
+#: ../gui/tcltk/gis.m/vector.tcl:352
msgid "Points "
msgstr "ТоÑки"
-#: ../gui/tcltk/gis.m/vector.tcl:357
+#: ../gui/tcltk/gis.m/vector.tcl:354
msgid "Lines "
msgstr "Ðинии"
-#: ../gui/tcltk/gis.m/vector.tcl:359
+#: ../gui/tcltk/gis.m/vector.tcl:356
msgid "Boundaries "
msgstr "ÐÑаниÑÑ"
-#: ../gui/tcltk/gis.m/vector.tcl:361
+#: ../gui/tcltk/gis.m/vector.tcl:358
msgid "Areas "
msgstr "ÐлоÑади"
-#: ../gui/tcltk/gis.m/vector.tcl:363
+#: ../gui/tcltk/gis.m/vector.tcl:360
msgid "Centroids "
msgstr "ЦенÑÑоидÑ"
-#: ../gui/tcltk/gis.m/vector.tcl:365
+#: ../gui/tcltk/gis.m/vector.tcl:362
msgid "Faces "
msgstr "ÐÑани"
-#: ../gui/tcltk/gis.m/vector.tcl:372
+#: ../gui/tcltk/gis.m/vector.tcl:369
msgid "Point symbols:"
msgstr "ТоÑеÑнÑе ÑимволÑ:"
-#: ../gui/tcltk/gis.m/vector.tcl:373
+#: ../gui/tcltk/gis.m/vector.tcl:370
msgid "Icon"
msgstr "Ðконка"
-#: ../gui/tcltk/gis.m/vector.tcl:377
+#: ../gui/tcltk/gis.m/vector.tcl:374
msgid " Size"
msgstr " РазмеÑ"
-#: ../gui/tcltk/gis.m/vector.tcl:379
+#: ../gui/tcltk/gis.m/vector.tcl:376
msgid "Icon size"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ Ð¸ÐºÐ¾Ð½ÐºÐ¸"
-#: ../gui/tcltk/gis.m/vector.tcl:385 ../gui/tcltk/d.m/vector.tcl:259
+#: ../gui/tcltk/gis.m/vector.tcl:382 ../gui/tcltk/d.m/vector.tcl:259
msgid "Draw lines:"
msgstr "ÐаÑиÑоваÑÑ Ð»Ð¸Ð½Ð¸Ð¸:"
-#: ../gui/tcltk/gis.m/vector.tcl:388 ../gui/tcltk/gis.m/vector.tcl:404
+#: ../gui/tcltk/gis.m/vector.tcl:385 ../gui/tcltk/gis.m/vector.tcl:401
msgid "Color"
msgstr "ЦвеÑ"
-#: ../gui/tcltk/gis.m/vector.tcl:391
+#: ../gui/tcltk/gis.m/vector.tcl:388
msgid " Width"
msgstr " ШиÑина"
-#: ../gui/tcltk/gis.m/vector.tcl:393
+#: ../gui/tcltk/gis.m/vector.tcl:390
msgid "Line width"
msgstr "ШиÑина линии"
-#: ../gui/tcltk/gis.m/vector.tcl:395
+#: ../gui/tcltk/gis.m/vector.tcl:392
msgid "(pixels) "
msgstr "(пикÑелей) "
-#: ../gui/tcltk/gis.m/vector.tcl:401 ../gui/tcltk/d.m/vector.tcl:275
+#: ../gui/tcltk/gis.m/vector.tcl:398 ../gui/tcltk/d.m/vector.tcl:275
msgid "Fill areas:"
msgstr "ÐалиÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ñ:"
-#: ../gui/tcltk/gis.m/vector.tcl:408
+#: ../gui/tcltk/gis.m/vector.tcl:405
msgid "Random colors "
msgstr "СлÑÑайнÑе ÑвеÑа"
-#: ../gui/tcltk/gis.m/vector.tcl:410 ../gui/tcltk/d.m/vector.tcl:284
+#: ../gui/tcltk/gis.m/vector.tcl:407 ../gui/tcltk/d.m/vector.tcl:284
msgid "GRASSRGB column colors"
msgstr "GRASSRGB ÑÑолбÑÑ ÑвеÑов"
-#: ../gui/tcltk/gis.m/vector.tcl:417 ../gui/tcltk/d.m/vector.tcl:291
+#: ../gui/tcltk/gis.m/vector.tcl:414 ../gui/tcltk/d.m/vector.tcl:291
msgid "Label vectors:"
msgstr "ÐодпиÑаÑÑ Ð²ÐµÐºÑоÑа:"
-#: ../gui/tcltk/gis.m/vector.tcl:418 ../gui/tcltk/d.m/vector.tcl:292
+#: ../gui/tcltk/gis.m/vector.tcl:415 ../gui/tcltk/d.m/vector.tcl:292
msgid "label"
msgstr "подпиÑÑ"
-#: ../gui/tcltk/gis.m/vector.tcl:420
+#: ../gui/tcltk/gis.m/vector.tcl:417
msgid " Text color"
msgstr " Ð¦Ð²ÐµÑ ÑекÑÑа"
-#: ../gui/tcltk/gis.m/vector.tcl:423
+#: ../gui/tcltk/gis.m/vector.tcl:420
msgid " Text size"
msgstr " Ð Ð°Ð·Ð¼ÐµÑ ÑекÑÑа"
-#: ../gui/tcltk/gis.m/vector.tcl:425 ../gui/tcltk/d.m/vector.tcl:299
+#: ../gui/tcltk/gis.m/vector.tcl:422 ../gui/tcltk/d.m/vector.tcl:299
msgid "text size"
msgstr "text size"
-#: ../gui/tcltk/gis.m/vector.tcl:433
+#: ../gui/tcltk/gis.m/vector.tcl:430
msgid "Label part to align with vector point"
msgstr "ЧаÑÑÑ Ð¿Ð¾Ð´Ð¿Ð¸Ñи вÑÑÐ°Ð²Ð½Ð¸Ð²Ð°ÐµÐ¼Ð°Ñ Ñ Ð²ÐµÐºÑоÑной ÑоÑкой"
-#: ../gui/tcltk/gis.m/vector.tcl:437
+#: ../gui/tcltk/gis.m/vector.tcl:434
msgid " Justification"
msgstr " ÐÑÑавнивание"
-#: ../gui/tcltk/gis.m/vector.tcl:446
+#: ../gui/tcltk/gis.m/vector.tcl:443
msgid " Layer for labels"
msgstr " Слой Ð´Ð»Ñ Ð¿Ð¾Ð´Ð¿Ð¸Ñей"
-#: ../gui/tcltk/gis.m/vector.tcl:448
-msgid " Attribute col for labels"
+#: ../gui/tcltk/gis.m/vector.tcl:445
+#, fuzzy
+msgid " Attribute column for labels"
msgstr " Ðоле аÑÑибÑÑов Ð´Ð»Ñ Ð¿Ð¾Ð´Ð¿Ð¸Ñей"
-#: ../gui/tcltk/gis.m/vector.tcl:455
+#: ../gui/tcltk/gis.m/vector.tcl:452
msgid "Query vectors for display: "
msgstr "ÐапÑоÑиÑÑ Ð²ÐµÐºÑоÑа Ð´Ð»Ñ Ð¿Ð¾ÐºÐ°Ð·Ð°:"
-#: ../gui/tcltk/gis.m/vector.tcl:456 ../gui/tcltk/d.m/vector.tcl:327
+#: ../gui/tcltk/gis.m/vector.tcl:453 ../gui/tcltk/d.m/vector.tcl:327
msgid "layer for query"
msgstr "Ñлой Ð´Ð»Ñ Ð·Ð°Ð¿ÑоÑа"
-#: ../gui/tcltk/gis.m/vector.tcl:464
+#: ../gui/tcltk/gis.m/vector.tcl:461
msgid "Query cat values"
msgstr "ÐапÑÐ¾Ñ Ð·Ð½Ð°Ñений каÑегоÑий"
-#: ../gui/tcltk/gis.m/vector.tcl:475
+#: ../gui/tcltk/gis.m/vector.tcl:472
msgid "Use SQL query"
msgstr "ÐÑполÑзоваÑÑ Ð·Ð°Ð¿ÑÐ¾Ñ SQL"
-#: ../gui/tcltk/gis.m/vector.tcl:483
+#: ../gui/tcltk/gis.m/vector.tcl:480
msgid " Show attribute columns"
msgstr " ÐоказаÑÑ Ð¿Ð¾Ð»Ñ Ð°ÑÑибÑÑов"
-#: ../gui/tcltk/gis.m/vector.tcl:489
+#: ../gui/tcltk/gis.m/vector.tcl:486
msgid " Show attribute data"
msgstr " ÐоказаÑÑ Ð°ÑÑибÑÑивнÑе даннÑе"
-#: ../gui/tcltk/gis.m/vector.tcl:501
+#: ../gui/tcltk/gis.m/vector.tcl:498
msgid "Save displayed objects to new vector file "
msgstr "СоÑ
ÑаниÑÑ Ð¿Ð¾ÐºÐ°Ð·Ð°Ð½Ð½Ñе обÑекÑÑ Ð² новÑй векÑоÑнÑй Ñайл"
-#: ../gui/tcltk/gis.m/vector.tcl:503
+#: ../gui/tcltk/gis.m/vector.tcl:500
msgid "Overwrite existing"
msgstr "ÐеÑезапиÑаÑÑ ÑÑÑеÑÑвÑÑÑий"
-#: ../gui/tcltk/gis.m/vector.tcl:510
+#: ../gui/tcltk/gis.m/vector.tcl:507
msgid " New vector"
msgstr " ÐовÑй векÑоÑ"
-#: ../gui/tcltk/gis.m/vector.tcl:514
+#: ../gui/tcltk/gis.m/vector.tcl:511
msgid "Select existing vector for saving queried objects"
msgstr "ÐÑбÑаÑÑ ÑÑÑеÑÑвÑÑÑий векÑÐ¾Ñ Ð´Ð»Ñ ÑоÑ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ Ð²ÑбоÑки обÑекÑов"
-#: ../gui/tcltk/gis.m/vector.tcl:522 ../gui/tcltk/d.m/vector.tcl:376
+#: ../gui/tcltk/gis.m/vector.tcl:519 ../gui/tcltk/d.m/vector.tcl:376
msgid "Display when avg. region dimension is"
msgstr "ÐоказаÑÑ ÐºÐ¾Ð³Ð´Ð° ÑÑедние ÑазмеÑÑ Ñегиона"
-#: ../gui/tcltk/gis.m/vector.tcl:525
+#: ../gui/tcltk/gis.m/vector.tcl:522
msgid " or <"
msgstr "или <"
@@ -4124,40 +4154,50 @@
msgid "Command:"
msgstr "Ðоманда:"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:526
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:546
msgid "Maximum zoom-in reached"
msgstr "ÐоÑÑигнÑÑо макÑималÑное ÑвелиÑение"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:596 ../gui/tcltk/gis.m/mapcanvas.tcl:1225
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:609 ../gui/tcltk/gis.m/mapcanvas.tcl:618
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1098 ../gui/tcltk/gis.m/mapcanvas.tcl:1105
+msgid "Cannot explore beyond the poles: switching into constrained mode"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:610 ../gui/tcltk/gis.m/mapcanvas.tcl:619
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1099 ../gui/tcltk/gis.m/mapcanvas.tcl:1106
+msgid "Switching to constrained mode"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:638 ../gui/tcltk/gis.m/mapcanvas.tcl:1288
#: ../gui/tcltk/gis.m/georect.tcl:1587
msgid "Error setting region"
msgstr "ÐÑибка ÑÑÑановки Ñегиона"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:605
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:647
msgid "please wait..."
msgstr "пожалÑйÑÑа, подождиÑе..."
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:764 ../gui/tcltk/gis.m/mapcanvas.tcl:1819
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:806 ../gui/tcltk/gis.m/mapcanvas.tcl:1882
msgid "You have to select map layer first"
msgstr "ÐÑжно ÑнаÑала вÑбÑаÑÑ Ñлой"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:765 ../gui/tcltk/gis.m/mapcanvas.tcl:1820
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:807 ../gui/tcltk/gis.m/mapcanvas.tcl:1883
msgid "No map layer selected"
msgstr "Ðе вÑбÑан Ñлой"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:837
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:879
msgid "Save Region"
msgstr "СоÑ
ÑаниÑÑ Ñегион"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:840
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:882
msgid "Save current display geometry to named region"
msgstr "СоÑ
ÑаниÑÑ ÑекÑÑÑÑ Ð³ÐµÐ¾Ð¼ÐµÑÑÐ¸Ñ Ð´Ð¸ÑÐ¿Ð»ÐµÑ Ð² Ñегион Ñ Ð½Ð°Ð·Ð²Ð°Ð½Ð¸ÐµÐ¼"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:846
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:888
msgid "Enter region name"
msgstr "ÐведиÑе Ð¸Ð¼Ñ Ñегиона"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:881
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:923
#, tcl-format
msgid ""
"Region file %s already exists. \n"
@@ -4166,52 +4206,52 @@
"Файл Ñегиона %s Ñже ÑÑÑеÑÑвÑеÑ.\n"
"ÐеÑезапиÑаÑÑ?"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1068
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1131
#, tcl-format
msgid "Display: rows=%d cols=%d N-S res=%g E-W res=%g"
msgstr "ÐиÑплей: ÑÑдÑ=%d ÑолбÑÑ=%d ÑазÑеÑение С-Ю=%g ÑазÑеÑение Ð-Ð=%g"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1140
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1203
msgid "Error setting region (Problem with g.region?)"
msgstr "ÐÑибка ÑÑÑановки Ñегиона (пÑоблема Ñ g.region?)"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1188 ../gui/tcltk/gis.m/mapcanvas.tcl:1193
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1251 ../gui/tcltk/gis.m/mapcanvas.tcl:1256
msgid "Error reading current resolution with g.region"
msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑекÑÑего ÑазÑеÑÐµÐ½Ð¸Ñ Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ g.region"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1250 ../gui/tcltk/gis.m/georect.tcl:2029
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1313 ../gui/tcltk/gis.m/georect.tcl:2029
msgid "Drag or click mouse to zoom"
msgstr "ÐаÑÑÑабиÑование ÑелÑком мÑÑи или пеÑеÑаÑкиванием"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1252 ../gui/tcltk/gis.m/georect.tcl:2031
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1315 ../gui/tcltk/gis.m/georect.tcl:2031
msgid "Drag or click mouse to unzoom"
msgstr "УменÑÑиÑе каÑÑÑ ÑелÑком мÑÑи или пеÑеÑаÑкиванием"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1487 ../gui/tcltk/gis.m/georect.tcl:2229
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1550 ../gui/tcltk/gis.m/georect.tcl:2229
msgid "Drag with mouse to pan"
msgstr "ÐеÑеÑаÑиÑе мÑÑÑÑ, ÑÑÐ¾Ð±Ñ ÑдвинÑÑÑ"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1614
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1677
msgid "Measurement"
msgstr "Ðзменение"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1633
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1696
msgid "Draw measure line with mouse"
msgstr "ÐÑполÑзоваÑÑ Ð¼ÑÑÑ Ð´Ð»Ñ Ð¿ÑÐ¾Ð²ÐµÐ´ÐµÐ½Ð¸Ñ Ð»Ð¸Ð½Ð¸Ð¸ измеÑениÑ"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1790
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1853
msgid "Click to query feature"
msgstr "ЩелкниÑе ÑÑÐ¾Ð±Ñ Ð·Ð°Ð¿ÑоÑиÑÑ Ð¾Ð±ÑекÑ"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1858
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1921
msgid "This layer type does not support queries"
msgstr "ÐÑÐ¾Ñ Ñлой не поддеÑÐ¶Ð¸Ð²Ð°ÐµÑ Ð·Ð°Ð¿ÑоÑÑ"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1859
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1922
msgid "Query not supported"
msgstr "ÐапÑÐ¾Ñ Ð½Ðµ поддеÑживаеÑÑÑ"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1866
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1929
msgid "You must select a map to query\n"
msgstr "ÐÑжно вÑбÑаÑÑ ÑлоÑ, ÑÑÐ¾Ð±Ñ ÑделаÑÑ Ð·Ð°Ð¿ÑоÑ\n"
@@ -4220,9 +4260,10 @@
msgstr "ÐоказаÑÑ Ð¼Ð°ÑÑÑаб и ÑÑÑÐµÐ»ÐºÑ Ð½Ð° ÑевеÑ"
#: ../gui/tcltk/gis.m/barscale.tcl:170
-#, fuzzy, tcl-format
+#, tcl-format
msgid "Scale placement: 0-100% from top left of display"
-msgstr "РаÑположение маÑÑÑаба: 0-100% Ð¾Ñ Ð»ÐµÐ²Ð¾Ð³Ð¾ веÑÑ
него Ñгла диÑплеÑ"
+msgstr ""
+"РаÑположение маÑÑÑаба: 0-100 пÑоÑенÑов Ð¾Ñ Ð»ÐµÐ²Ð¾Ð³Ð¾ веÑÑ
него Ñгла диÑÐ¿Ð»ÐµÑ "
#: ../gui/tcltk/gis.m/barscale.tcl:176
msgid "\t enter x,y of scale/arrow upper left corner"
@@ -4540,7 +4581,8 @@
msgstr "2-ой поÑÑдок"
#: ../gui/tcltk/gis.m/georect.tcl:1020
-msgid "polynomial transformation (rasters only). Requires 7+ GCPs."
+#, fuzzy
+msgid "polynomial transformation (rasters only). Requires 6+ GCPs."
msgstr "полиномиалÑÐ½Ð°Ñ ÑÑанÑÑоÑмаÑÐ¸Ñ (ÑолÑко ÑаÑÑÑÑ). ТÑебÑÐµÑ 7+ GCP."
#: ../gui/tcltk/gis.m/georect.tcl:1024
@@ -4939,9 +4981,8 @@
msgstr "Garmin GPS ТоÑки/ÐаÑÑÑÑÑÑ/ТÑÑки"
#: ../gui/tcltk/d.m/menu.tcl:103
-#, fuzzy
msgid "GPS Waypoints/Routes/Tracks from many formats using GPSBabel"
-msgstr "GPS ТоÑки/ÐаÑÑÑÑÑÑ/ТÑÑки иÑполÑзÑÑ GPSBabel"
+msgstr "GPS ТоÑки/ÐаÑÑÑÑÑÑ/ТÑÑки из ÑазнÑÑ
ÑоÑмаÑов иÑполÑзÑÑ GPSBabel"
#: ../gui/tcltk/d.m/menu.tcl:104
msgid "GEOnet Name server country files (US-NGA GNS)"
@@ -5168,123 +5209,123 @@
msgid "Set GRASS environment settings"
msgstr "УÑÑановиÑÑ Ð½Ð°ÑÑÑойки ÑÑÐµÐ´Ñ GRASS"
-#: ../gui/tcltk/d.m/menu.tcl:203
+#: ../gui/tcltk/d.m/menu.tcl:204
msgid "Create/edit projection information for current location"
msgstr "СоздаÑÑ/ÑедакÑиÑоваÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ пÑоекÑии Ð´Ð»Ñ ÑекÑÑей облаÑÑи"
-#: ../gui/tcltk/d.m/menu.tcl:204
+#: ../gui/tcltk/d.m/menu.tcl:205
msgid "Show projection information and create projection files"
msgstr "ÐоказаÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ пÑоекÑии и ÑоздаÑÑ ÑÐ°Ð¹Ð»Ñ Ð¿ÑоекÑии"
-#: ../gui/tcltk/d.m/menu.tcl:206
+#: ../gui/tcltk/d.m/menu.tcl:207
msgid "Convert coordinates from one projection to another"
msgstr "ÐонвеÑÑиÑоваÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ Ð¸Ð· одной пÑоекÑии дÑÑгÑÑ"
-#: ../gui/tcltk/d.m/menu.tcl:208
+#: ../gui/tcltk/d.m/menu.tcl:209
msgid "Text"
msgstr "ТекÑÑ"
-#: ../gui/tcltk/d.m/menu.tcl:209
+#: ../gui/tcltk/d.m/menu.tcl:210
msgid "Select default text font"
msgstr "ÐÑÐ±Ð¾Ñ ÑÑиÑÑа по ÑмолÑаниÑ"
-#: ../gui/tcltk/d.m/menu.tcl:210
+#: ../gui/tcltk/d.m/menu.tcl:211
msgid "Select default freetype text font"
msgstr "ÐÑбÑаÑÑ freetype-ÑÑиÑÑ Ð¿Ð¾ ÑмолÑаниÑ"
-#: ../gui/tcltk/d.m/menu.tcl:212
+#: ../gui/tcltk/d.m/menu.tcl:213
msgid "X-monitor displays"
msgstr "диÑплеи X-monitor"
-#: ../gui/tcltk/d.m/menu.tcl:213
+#: ../gui/tcltk/d.m/menu.tcl:214
msgid "Configure xmonitor displays"
msgstr "ÐонÑигÑÑиÑоваÑÑ Ð´Ð¸Ñплеи xmonitor"
-#: ../gui/tcltk/d.m/menu.tcl:214
+#: ../gui/tcltk/d.m/menu.tcl:215
msgid "Configure frames for xmonitors"
msgstr "ÐонÑигÑÑиÑоваÑÑ Ñамки Ð´Ð»Ñ xmonitors"
-#: ../gui/tcltk/d.m/menu.tcl:215
+#: ../gui/tcltk/d.m/menu.tcl:216
msgid "Start/restart xmonitor at specified window size"
msgstr "ÐаÑаÑÑ/пеÑезапÑÑÑиÑÑ xmonitor заданного ÑазмеÑа"
-#: ../gui/tcltk/d.m/menu.tcl:216
+#: ../gui/tcltk/d.m/menu.tcl:217
msgid "Set active xmonitor to specified size"
msgstr "УÑÑановиÑÑ Ð°ÐºÑÐ¸Ð²Ð½Ð¾Ð¼Ñ xmonitor заданнÑй ÑазмеÑ"
-#: ../gui/tcltk/d.m/menu.tcl:217
+#: ../gui/tcltk/d.m/menu.tcl:218
msgid "Display information about active xmonitor"
msgstr "ÐоказаÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾Ð± акÑивном xmonitor"
-#: ../gui/tcltk/d.m/menu.tcl:224
+#: ../gui/tcltk/d.m/menu.tcl:225
msgid "Compress/decompress raster file"
msgstr "СжаÑÑ/ÑаÑпаковаÑÑ ÑаÑÑÑовÑй Ñайл"
-#: ../gui/tcltk/d.m/menu.tcl:225
+#: ../gui/tcltk/d.m/menu.tcl:226
msgid "Manage boundary definitions"
msgstr "УпÑавлÑÑÑ Ð¾Ð¿ÑеделениÑми гÑаниÑ"
-#: ../gui/tcltk/d.m/menu.tcl:226
+#: ../gui/tcltk/d.m/menu.tcl:227
msgid "Manage null values"
msgstr "УпÑавление NULL-знаÑениÑми"
-#: ../gui/tcltk/d.m/menu.tcl:227
+#: ../gui/tcltk/d.m/menu.tcl:228
msgid "Manage timestamps for files"
msgstr "УпÑавление вÑеменнÑми меÑками Ñайлов"
-#: ../gui/tcltk/d.m/menu.tcl:228
+#: ../gui/tcltk/d.m/menu.tcl:229
msgid "Quantization for floating-point maps"
msgstr "ÐванÑование Ð´Ð»Ñ Ñлоев Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей запÑÑой."
-#: ../gui/tcltk/d.m/menu.tcl:230
+#: ../gui/tcltk/d.m/menu.tcl:231
msgid "Resample (change resolution)"
msgstr "ÐеÑеÑÑÐµÑ (измениÑÑ ÑазÑеÑение)"
-#: ../gui/tcltk/d.m/menu.tcl:231
+#: ../gui/tcltk/d.m/menu.tcl:232
msgid "Resample using nearest neighbor method"
msgstr "ÐеÑеÑÑиÑаÑÑ Ð¸ÑполÑзÑÑ Ð¼ÐµÑод ближайÑего ÑоÑеда"
-#: ../gui/tcltk/d.m/menu.tcl:232
+#: ../gui/tcltk/d.m/menu.tcl:233
msgid "Resample using various interpolation methods"
msgstr "ÐеÑеÑÑиÑаÑÑ Ð¸ÑполÑзÑÑ ÑазлиÑнÑе меÑÐ¾Ð´Ñ Ð¸Ð½ÑеÑполÑÑии"
-#: ../gui/tcltk/d.m/menu.tcl:234
+#: ../gui/tcltk/d.m/menu.tcl:235
msgid "Resample using regularized spline with tension method"
msgstr "ÐеÑеÑÑиÑаÑÑ Ð¸ÑполÑзÑÑ ÑÐ¿Ð»Ð°Ð¹Ð½Ñ (RST)"
-#: ../gui/tcltk/d.m/menu.tcl:237
+#: ../gui/tcltk/d.m/menu.tcl:238
msgid "Support file creation and maintenance"
msgstr "Создание и обновление Ñайла поддеÑжки"
-#: ../gui/tcltk/d.m/menu.tcl:239
+#: ../gui/tcltk/d.m/menu.tcl:240
msgid "Reproject raster from other location"
msgstr "ÐеÑепÑоекÑиÑоваÑÑ ÑаÑÑÑ Ð¸Ð· дÑÑгой облаÑÑи"
-#: ../gui/tcltk/d.m/menu.tcl:240
+#: ../gui/tcltk/d.m/menu.tcl:241
msgid "Generate tiling for other projection"
msgstr "СоздаÑÑ Ñайлинг Ð´Ð»Ñ Ð´ÑÑгой пÑоекÑии"
-#: ../gui/tcltk/d.m/menu.tcl:243
+#: ../gui/tcltk/d.m/menu.tcl:244
msgid "Set colors to predefined color tables"
msgstr "УÑÑановиÑÑ ÑвеÑа в заданнÑе ÑвеÑовÑе ÑаблиÑÑ"
-#: ../gui/tcltk/d.m/menu.tcl:244
+#: ../gui/tcltk/d.m/menu.tcl:245
msgid "Set colors based on standard deviations"
-msgstr ""
+msgstr "УÑÑановиÑÑ ÑвеÑа по ÑÑандаÑÑнÑм оÑклонениÑм"
-#: ../gui/tcltk/d.m/menu.tcl:245
+#: ../gui/tcltk/d.m/menu.tcl:246
msgid "Set colors using color rules"
msgstr "УÑÑановиÑÑ ÑвеÑа Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ ÑвеÑовÑÑ
пÑавил"
-#: ../gui/tcltk/d.m/menu.tcl:247
+#: ../gui/tcltk/d.m/menu.tcl:248
msgid "Blend 2 color maps to produce 3 RGB files"
msgstr "СмеÑаÑÑ 2 ÑвеÑовÑÑ
ÑÐ»Ð¾Ñ ÑÑÐ¾Ð±Ñ Ð¿Ð¾Ð»ÑÑиÑÑ 3 Ñайла RGB"
-#: ../gui/tcltk/d.m/menu.tcl:248
+#: ../gui/tcltk/d.m/menu.tcl:249
msgid "Create color image from RGB files"
msgstr "СоздаÑÑ ÑвеÑное изобÑажение из Ñайлов RGB"
-#: ../gui/tcltk/d.m/menu.tcl:249
+#: ../gui/tcltk/d.m/menu.tcl:250
msgid ""
"Create 3 RGB (red, green, blue) maps from 3 HIS (hue, intensity, saturation) "
"maps"
@@ -5292,339 +5333,339 @@
"СоздаÑÑ 3 ÑÐ»Ð¾Ñ RGB (кÑаÑнÑй, зеленÑй, Ñиний) из 3 Ñлоев HIS (Ñон, ÑÑкоÑÑÑ, "
"наÑÑÑенноÑÑÑ)"
-#: ../gui/tcltk/d.m/menu.tcl:254
+#: ../gui/tcltk/d.m/menu.tcl:255
msgid "Create raster buffers"
msgstr "СоздаÑÑ ÑаÑÑÑовÑе бÑÑеÑа"
-#: ../gui/tcltk/d.m/menu.tcl:255
+#: ../gui/tcltk/d.m/menu.tcl:256
msgid "Create raster MASK"
msgstr "СоздаÑÑ ÑаÑÑÑ MASK"
-#: ../gui/tcltk/d.m/menu.tcl:256
+#: ../gui/tcltk/d.m/menu.tcl:257
msgid "Locate closest points between areas in 2 raster maps"
msgstr "ÐайÑи ближайÑие ÑоÑки Ð¼ÐµÐ¶Ð´Ñ Ð¾Ð±ÑекÑами двÑÑ
ÑаÑÑÑовÑÑ
Ñлоев"
-#: ../gui/tcltk/d.m/menu.tcl:259
+#: ../gui/tcltk/d.m/menu.tcl:260
msgid "Moving window analysis of raster cells"
msgstr "Ðнализ ÑаÑÑÑовÑÑ
ÑÑеек плаваÑÑим окном"
-#: ../gui/tcltk/d.m/menu.tcl:260
+#: ../gui/tcltk/d.m/menu.tcl:261
msgid "Analyze vector points in neighborhood of raster cells"
msgstr "Ðнализ векÑоÑнÑÑ
ÑоÑек в ÑоÑедÑÑве Ñ ÑÑейками ÑаÑÑÑа"
-#: ../gui/tcltk/d.m/menu.tcl:264
+#: ../gui/tcltk/d.m/menu.tcl:265
msgid "Function of map series (time series)"
msgstr "ФÑнкÑÐ¸Ñ ÑеÑий Ñлоев (вÑеменнÑе ÑеÑии)"
-#: ../gui/tcltk/d.m/menu.tcl:267
+#: ../gui/tcltk/d.m/menu.tcl:268
msgid "Statistical calculations for cover map over base map"
msgstr "СÑаÑиÑÑиÑеÑкий ÑаÑÑÐµÑ Ð´Ð»Ñ ÑÐ»Ð¾Ñ Ð¾Ð²ÐµÑÐ»ÐµÑ Ð±Ð°Ð·Ð¾Ð²Ð¾Ð³Ð¾ ÑлоÑ"
-#: ../gui/tcltk/d.m/menu.tcl:270
+#: ../gui/tcltk/d.m/menu.tcl:271
msgid "Solar irradiance and daily irradiation"
msgstr "СолнеÑÐ½Ð°Ñ Ð¾ÑвеÑенноÑÑÑ Ð¸ Ð´Ð½ÐµÐ²Ð½Ð°Ñ Ð¸ÑÑадиаÑиÑ"
-#: ../gui/tcltk/d.m/menu.tcl:271
+#: ../gui/tcltk/d.m/menu.tcl:272
msgid "Shadows map for sun position or date/time"
msgstr "Слой Ñеней Ð´Ð»Ñ Ð¿Ð¾Ð·Ð¸Ñии ÑолнÑа или даÑа/вÑемÑ"
-#: ../gui/tcltk/d.m/menu.tcl:274
+#: ../gui/tcltk/d.m/menu.tcl:275
msgid "Calculate cumulative movement costs between locales"
msgstr ""
"РаÑÑÑиÑаÑÑ ÐºÑмÑлÑÑивнÑÑ ÑÑоимоÑÑÑ Ð¿ÐµÑемеÑÐµÐ½Ð¸Ñ Ð¼ÐµÐ¶Ð´Ñ Ð´Ð²ÑÐ¼Ñ Ð¼ÐµÑÑоположениÑми"
-#: ../gui/tcltk/d.m/menu.tcl:277
+#: ../gui/tcltk/d.m/menu.tcl:278
msgid "Profile analysis"
msgstr "ÐÑоÑилÑнÑй анализ"
-#: ../gui/tcltk/d.m/menu.tcl:278
+#: ../gui/tcltk/d.m/menu.tcl:279
msgid "Shaded relief map"
msgstr "Слой Ñеневой оÑмÑвки ÑелÑеÑа"
-#: ../gui/tcltk/d.m/menu.tcl:282
+#: ../gui/tcltk/d.m/menu.tcl:283
msgid "Visibility/line of sight"
msgstr "ÐидимоÑÑÑ/Ð»Ð¸Ð½Ð¸Ñ Ð²Ð¸Ð´Ð¸Ð¼Ð¾ÑÑи"
-#: ../gui/tcltk/d.m/menu.tcl:286
+#: ../gui/tcltk/d.m/menu.tcl:287
msgid "Clump small areas (statistics calculated by r.volume)"
msgstr "ÐлаÑÑеÑизоваÑÑ Ð¼Ð°Ð»ÐµÐ½Ñкие ÑеÑÑиÑоÑии (ÑÑаÑиÑÑика вÑÑиÑлÑеÑÑÑ r.volume)"
-#: ../gui/tcltk/d.m/menu.tcl:287
+#: ../gui/tcltk/d.m/menu.tcl:288
msgid "Grow areas"
msgstr "ÐÑÑаÑÑиÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ñ"
-#: ../gui/tcltk/d.m/menu.tcl:288
+#: ../gui/tcltk/d.m/menu.tcl:289
msgid "Thin linear features"
msgstr "ÐÑоÑедиÑÑ Ð»Ð¸Ð½ÐµÐ¹Ð½Ñе обÑекÑÑ"
-#: ../gui/tcltk/d.m/menu.tcl:292
+#: ../gui/tcltk/d.m/menu.tcl:293
msgid "Carve stream channels into elevation map using vector streams map"
msgstr "ÐÑоÑезаÑÑ Ð²Ð¾Ð´Ð¾Ñоки в Ñлое вÑÑÐ¾Ñ Ð¸ÑполÑзÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой водоÑоков"
-#: ../gui/tcltk/d.m/menu.tcl:293
+#: ../gui/tcltk/d.m/menu.tcl:294
msgid "Depressionless elevation map and flowline map"
msgstr "Слой вÑÑÐ¾Ñ Ð±ÐµÐ· депÑеÑÑий и Ñлой ÑÑока"
-#: ../gui/tcltk/d.m/menu.tcl:294
+#: ../gui/tcltk/d.m/menu.tcl:295
msgid "Fill lake from seed point to specified level"
msgstr "ÐаполниÑÑ Ð¾Ð·ÐµÑо из заÑÑавки на заданнÑй ÑÑовенÑ"
-#: ../gui/tcltk/d.m/menu.tcl:295
+#: ../gui/tcltk/d.m/menu.tcl:296
msgid "Flow accumulation for massive grids"
msgstr "ÐÑÑиÑление ÑÑока Ð´Ð»Ñ Ð±Ð¾Ð»ÑÑиÑ
гÑидов"
-#: ../gui/tcltk/d.m/menu.tcl:296
+#: ../gui/tcltk/d.m/menu.tcl:297
msgid "Generate flow lines for raster map"
msgstr "СоздаÑÑ Ð»Ð¸Ð½Ð¸Ð¸ ÑÑока Ð´Ð»Ñ ÑаÑÑÑового ÑлоÑ"
-#: ../gui/tcltk/d.m/menu.tcl:298
+#: ../gui/tcltk/d.m/menu.tcl:299
msgid "SIMWE sediment erosion, transport, & deposition modeling"
msgstr "моделиÑование ÑÑозии, пеÑеноÑа и оÑÐ»Ð¾Ð¶ÐµÐ½Ð¸Ñ Ð½Ð°Ð½Ð¾Ñов SIMWE"
-#: ../gui/tcltk/d.m/menu.tcl:308
+#: ../gui/tcltk/d.m/menu.tcl:309
msgid "Analyze landscape characteristics"
msgstr "Ðнализ Ñ
аÑакÑеÑиÑÑик ландÑаÑÑа"
-#: ../gui/tcltk/d.m/menu.tcl:309
+#: ../gui/tcltk/d.m/menu.tcl:310
msgid "Analyze landscape patch characteristics"
аÑакÑеÑиÑÑики ÑÑаÑÑка ландÑаÑÑа"
-#: ../gui/tcltk/d.m/menu.tcl:310
+#: ../gui/tcltk/d.m/menu.tcl:311
msgid "Output landscape patch information"
msgstr "ÐÑвеÑÑи инÑоÑмаÑÐ¸Ñ Ð¾Ð± ÑÑаÑÑке ландÑаÑÑа"
-#: ../gui/tcltk/d.m/menu.tcl:313
+#: ../gui/tcltk/d.m/menu.tcl:314
msgid "Generate rate of spread (ROS) maps"
msgstr "СоздаÑÑ Ñлои ÑкоÑоÑÑи ÑаÑпÑоÑÑÑÐ°Ð½ÐµÐ½Ð¸Ñ (ROS)"
-#: ../gui/tcltk/d.m/menu.tcl:314
+#: ../gui/tcltk/d.m/menu.tcl:315
msgid "Generate least-cost spread paths"
msgstr "СоздаÑÑ Ð¼Ð°ÑÑÑÑÑÑ Ð½Ð°Ð¸Ð¼ÐµÐ½ÑÑей ÑÑоимоÑÑи ÑаÑпÑоÑÑÑанениÑ"
-#: ../gui/tcltk/d.m/menu.tcl:315
+#: ../gui/tcltk/d.m/menu.tcl:316
msgid "Simulate anisotropic spread phenomena"
msgstr "СимÑлиÑоваÑÑ Ñеномен анизоÑÑопного ÑаÑпÑоÑÑÑанениÑ"
-#: ../gui/tcltk/d.m/menu.tcl:319
+#: ../gui/tcltk/d.m/menu.tcl:320
msgid "Edit category values of individual cells for displayed raster map"
msgstr ""
"РедакÑиÑоваÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий индивидÑалÑнÑÑ
ÑÑеек Ð´Ð»Ñ Ð¿Ð¾ÐºÐ°Ð·Ñваемого "
"ÑаÑÑÑового ÑлоÑ"
-#: ../gui/tcltk/d.m/menu.tcl:322
+#: ../gui/tcltk/d.m/menu.tcl:323
msgid "Reclassify categories for areas of specified sizes"
msgstr "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ ÐºÐ°ÑегоÑии Ð´Ð»Ñ Ð¿Ð»Ð¾Ñадей Ñказанного ÑазмеÑа"
-#: ../gui/tcltk/d.m/menu.tcl:323
+#: ../gui/tcltk/d.m/menu.tcl:324
msgid "Reclassify categories using rules"
msgstr "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ, иÑполÑзÑÑ Ð¿Ñавила"
-#: ../gui/tcltk/d.m/menu.tcl:324
+#: ../gui/tcltk/d.m/menu.tcl:325
msgid "Reclassify categories using rules file"
msgstr "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ ÐºÐ°ÑегоÑии, иÑполÑзÑÑ Ñайл пÑавил"
-#: ../gui/tcltk/d.m/menu.tcl:326
+#: ../gui/tcltk/d.m/menu.tcl:327
msgid "Recode categories using rules (create new map)"
msgstr "ÐеÑекодиÑоваÑÑ ÐºÐ°ÑегоÑии иÑполÑзÑÑ Ð¿Ñавила (ÑоздаÑÑ Ð½Ð¾Ð²Ñй Ñлой)"
-#: ../gui/tcltk/d.m/menu.tcl:327
+#: ../gui/tcltk/d.m/menu.tcl:328
msgid "Recode categories using rules file (create new map)"
msgstr "ÐеÑекодиÑоваÑÑ ÐºÐ°ÑегоÑии, иÑполÑзÑÑ Ñайл пÑавил (ÑоздаÑÑ Ð½Ð¾Ð²Ñй Ñлой)"
-#: ../gui/tcltk/d.m/menu.tcl:329
+#: ../gui/tcltk/d.m/menu.tcl:330
msgid "Rescale categories (create new map)"
msgstr "ÐаÑÑÑабиÑоваÑÑ ÐºÐ°ÑегоÑии (ÑоздаÑÑ Ð½Ð¾Ð²Ñй Ñлой)"
-#: ../gui/tcltk/d.m/menu.tcl:330
+#: ../gui/tcltk/d.m/menu.tcl:331
msgid "Rescale categories with equalized histogram (create new map)"
msgstr ""
"ÐаÑÑÑабиÑоваÑÑ ÐºÐ°ÑегоÑии Ñ ÑквализаÑией гиÑÑогÑÐ°Ð¼Ð¼Ñ (ÑоздаÑÑ Ð½Ð¾Ð²Ñй Ñлой)"
-#: ../gui/tcltk/d.m/menu.tcl:333
+#: ../gui/tcltk/d.m/menu.tcl:334
msgid "Generate concentric circles around points"
msgstr "СоздаÑÑ ÐºÐ¾Ð½ÑенÑÑиÑеÑкие окÑÑжноÑÑи вокÑÑг ÑоÑек"
-#: ../gui/tcltk/d.m/menu.tcl:334
+#: ../gui/tcltk/d.m/menu.tcl:335
msgid "Generate random raster cells"
msgstr "СоздаÑÑ ÑлÑÑайнÑе ÑаÑÑÑовÑе ÑÑейки"
-#: ../gui/tcltk/d.m/menu.tcl:336
+#: ../gui/tcltk/d.m/menu.tcl:337
msgid "Generate random cells and vector points from raster map"
msgstr "СоздаÑÑ ÑлÑÑайнÑе ÑÑейки и векÑоÑнÑе ÑоÑки из ÑаÑÑÑового ÑлоÑ"
-#: ../gui/tcltk/d.m/menu.tcl:339
+#: ../gui/tcltk/d.m/menu.tcl:340
msgid "Generate density surface using moving Gausian kernal"
msgstr "СоздаÑÑ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ Ð¿Ð»Ð¾ÑноÑÑи иÑполÑзÑÑ Ð¿Ð»Ð°Ð²Ð°ÑÑее ÐаÑÑÑово ÑдÑо"
-#: ../gui/tcltk/d.m/menu.tcl:340
+#: ../gui/tcltk/d.m/menu.tcl:341
msgid "Generate fractal surface"
msgstr "СоздаÑÑ ÑÑакÑалÑнÑÑ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ"
-#: ../gui/tcltk/d.m/menu.tcl:341
+#: ../gui/tcltk/d.m/menu.tcl:342
msgid "Generate gaussian deviates surface"
ноÑÑÑ Ð³Ð°ÑÑÑовÑÑ
оÑклонений"
-#: ../gui/tcltk/d.m/menu.tcl:342
+#: ../gui/tcltk/d.m/menu.tcl:343
msgid "Generate plane"
msgstr "СоздаÑÑ Ð¿Ð»Ð¾ÑкоÑÑÑ"
-#: ../gui/tcltk/d.m/menu.tcl:343
+#: ../gui/tcltk/d.m/menu.tcl:344
msgid "Generate random deviates surface"
ноÑÑÑ ÑлÑÑайнÑÑ
оÑклонений"
-#: ../gui/tcltk/d.m/menu.tcl:344
+#: ../gui/tcltk/d.m/menu.tcl:345
msgid "Generate random surface with spatial dependence"
msgstr "СоздаÑÑ ÑлÑÑайнÑÑ Ð¿Ð¾Ð²ÐµÑÑ
-#: ../gui/tcltk/d.m/menu.tcl:346
+#: ../gui/tcltk/d.m/menu.tcl:347
msgid "Generate vector contour lines"
msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑе изолинии"
-#: ../gui/tcltk/d.m/menu.tcl:348
+#: ../gui/tcltk/d.m/menu.tcl:349
msgid "Bilinear interpolation from raster points"
ÑоÑек"
-#: ../gui/tcltk/d.m/menu.tcl:349
+#: ../gui/tcltk/d.m/menu.tcl:350
msgid "Inverse distance weighted interpolation from raster points"
msgstr "ÐнÑеÑполÑÑÐ¸Ñ Inverse distance weighted из ÑаÑÑÑовÑÑ
ÑоÑек"
-#: ../gui/tcltk/d.m/menu.tcl:350
+#: ../gui/tcltk/d.m/menu.tcl:351
msgid "Interpolation from raster contours"
msgstr "ÐнÑеÑполÑÑÐ¸Ñ ÑаÑÑÑовÑÑ
изолиний"
-#: ../gui/tcltk/d.m/menu.tcl:352
+#: ../gui/tcltk/d.m/menu.tcl:353
msgid "Inverse distance weighted interpolation from vector points"
msgstr "ÐнÑеÑполÑÑÐ¸Ñ Inverse distance weighted из векÑоÑнÑÑ
ÑоÑек"
-#: ../gui/tcltk/d.m/menu.tcl:353
+#: ../gui/tcltk/d.m/menu.tcl:354
msgid "Regularized spline tension interpolation from vector points or contours"
msgstr "Сплайн-инÑеÑполÑÑÐ¸Ñ Ð¸Ð· векÑоÑнÑÑ
ÑоÑек или изолиний"
-#: ../gui/tcltk/d.m/menu.tcl:355
+#: ../gui/tcltk/d.m/menu.tcl:356
msgid "Fill NULL cells by interpolation using regularized spline tension"
msgstr "ÐаполниÑÑ NULL-ÑÑейки иÑполÑзÑÑ Ñплайн-инÑеÑполÑÑиÑ"
-#: ../gui/tcltk/d.m/menu.tcl:360
+#: ../gui/tcltk/d.m/menu.tcl:361
msgid "Manage category labels and values"
msgstr "УпÑавлÑÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ð¸ подпиÑи каÑегоÑий"
-#: ../gui/tcltk/d.m/menu.tcl:363
+#: ../gui/tcltk/d.m/menu.tcl:364
msgid "Range of all category values"
msgstr "Ðиапазон вÑеÑ
знаÑений каÑегоÑии"
-#: ../gui/tcltk/d.m/menu.tcl:364
+#: ../gui/tcltk/d.m/menu.tcl:365
msgid "Sum all cell category values"
msgstr "СÑмма вÑеÑ
знаÑений каÑегоÑий ÑÑеек"
-#: ../gui/tcltk/d.m/menu.tcl:366
+#: ../gui/tcltk/d.m/menu.tcl:367
msgid "Summary statistics for clumped cells (works with r.clump)"
msgstr "ÐбзоÑÐ½Ð°Ñ ÑÑаÑиÑÑика Ð´Ð»Ñ ÐºÐ»Ð°ÑÑеÑизованÑÑ
-#: ../gui/tcltk/d.m/menu.tcl:369
+#: ../gui/tcltk/d.m/menu.tcl:370
msgid "Univariate statistics (script version)"
msgstr "ÐдномеÑÐ½Ð°Ñ ÑÑаÑиÑÑика (ÑкÑипÑ)"
-#: ../gui/tcltk/d.m/menu.tcl:371
+#: ../gui/tcltk/d.m/menu.tcl:372
msgid "Sample values along transects"
msgstr "Ð¡Ð±Ð¾Ñ Ð·Ð½Ð°Ñений Ð²Ð´Ð¾Ð»Ñ ÑÑанÑекÑ"
-#: ../gui/tcltk/d.m/menu.tcl:372
+#: ../gui/tcltk/d.m/menu.tcl:373
msgid "Sample values along transects (use azimuth, distance)"
msgstr "ÐÑоизвеÑÑи вÑбоÑÐºÑ Ð²Ð´Ð¾Ð»Ñ ÑÑанÑекÑÑ (иÑполÑзоваÑÑ Ð°Ð·Ð¸Ð¼ÑÑ, ÑаÑÑÑоÑние)"
-#: ../gui/tcltk/d.m/menu.tcl:375
+#: ../gui/tcltk/d.m/menu.tcl:376
msgid "Linear regression between 2 maps"
msgstr "ÐÐ¸Ð½ÐµÐ¹Ð½Ð°Ñ ÑегÑеÑÑÐ¸Ñ Ð¼ÐµÐ¶Ð´Ñ Ð´Ð²ÑÐ¼Ñ ÑлоÑми"
-#: ../gui/tcltk/d.m/menu.tcl:376
+#: ../gui/tcltk/d.m/menu.tcl:377
msgid "Mutual category occurences (coincidence)"
msgstr "СовмеÑÑное поÑвление каÑегоÑий (Ñовпадение)"
-#: ../gui/tcltk/d.m/menu.tcl:384
+#: ../gui/tcltk/d.m/menu.tcl:385
msgid "Clean vector files"
msgstr "ÐÑиÑÑиÑÑ Ð²ÐµÐºÑоÑнÑе ÑайлÑ"
-#: ../gui/tcltk/d.m/menu.tcl:385
+#: ../gui/tcltk/d.m/menu.tcl:386
msgid "Add missing centroids"
msgstr "ÐобавиÑÑ Ð½ÐµÐ´Ð¾ÑÑаÑÑие ÑенÑÑоидÑ"
-#: ../gui/tcltk/d.m/menu.tcl:387
+#: ../gui/tcltk/d.m/menu.tcl:388
msgid "Build polylines from adjacent segments"
msgstr "ÐоÑÑÑоиÑÑ Ð¿Ð¾Ð»Ð¸Ð»Ð¸Ð½Ð¸Ð¸ из пÑимÑкаÑÑиÑ
ÑегменÑов"
-#: ../gui/tcltk/d.m/menu.tcl:388
+#: ../gui/tcltk/d.m/menu.tcl:389
msgid "Split polylines into segments"
msgstr "РазделиÑÑ Ð¿Ð¾Ð»Ð¸Ð»Ð¸Ð½Ð¸Ð¸ на ÑегменÑÑ"
-#: ../gui/tcltk/d.m/menu.tcl:389
+#: ../gui/tcltk/d.m/menu.tcl:390
msgid "Create lines parallel to existing lines"
msgstr "СоздаÑÑ Ð»Ð¸Ð½Ð¸Ð¸ паÑаллелÑнÑе ÑÑÑеÑÑвÑÑÑим"
-#: ../gui/tcltk/d.m/menu.tcl:390
+#: ../gui/tcltk/d.m/menu.tcl:391
msgid "Dissolve common boundaries"
msgstr "УдалиÑÑ Ð¾Ð±Ñие гÑаниÑÑ"
-#: ../gui/tcltk/d.m/menu.tcl:392
+#: ../gui/tcltk/d.m/menu.tcl:393
msgid "Convert vector feature types"
msgstr "ÐонвеÑÑиÑоваÑÑ ÑÐ¸Ð¿Ñ Ð²ÐµÐºÑоÑнÑÑ
обÑекÑов"
-#: ../gui/tcltk/d.m/menu.tcl:393
+#: ../gui/tcltk/d.m/menu.tcl:394
msgid "Convert 2D vector to 3D by sampling raster"
msgstr "ÐонвеÑÑиÑоваÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой 2D в 3D, полÑÑÐ°Ñ Ð´Ð°Ð½Ð½Ñе Ñ ÑаÑÑÑа"
-#: ../gui/tcltk/d.m/menu.tcl:394
+#: ../gui/tcltk/d.m/menu.tcl:395
msgid "Extrude 2D vector into 3D vector"
msgstr "ÐÑдавиÑÑ 2D векÑÐ¾Ñ Ð² 3D векÑоÑ"
-#: ../gui/tcltk/d.m/menu.tcl:396
+#: ../gui/tcltk/d.m/menu.tcl:397
msgid "Create text label file for vector features"
msgstr "СоздаÑÑ ÑекÑÑовÑе подпиÑи Ð´Ð»Ñ Ð²ÐµÐºÑоÑнÑÑ
обÑекÑов"
-#: ../gui/tcltk/d.m/menu.tcl:397
+#: ../gui/tcltk/d.m/menu.tcl:398
msgid "Assign colors from a numeric attribute column"
-msgstr ""
+msgstr "УÑÑановиÑÑ ÑвеÑа по ÑиÑÐ»Ð¾Ð²Ð¾Ð¼Ñ Ð¿Ð¾Ð»Ñ"
-#: ../gui/tcltk/d.m/menu.tcl:399
+#: ../gui/tcltk/d.m/menu.tcl:400
msgid "Reproject vector from other location"
msgstr "ÐеÑепÑоекÑиÑоваÑÑ Ð²ÐµÐºÑÐ¾Ñ Ð¸Ð· дÑÑгой облаÑÑи"
-#: ../gui/tcltk/d.m/menu.tcl:402
+#: ../gui/tcltk/d.m/menu.tcl:403
msgid "Create new vector as link to external OGR layer"
msgstr "СоздаÑÑ Ð½Ð¾Ð²Ñй векÑÐ¾Ñ ÐºÐ°Ðº ÑÑÑÐ»ÐºÑ Ðº внеÑÐ½ÐµÐ¼Ñ ÑÐ»Ð¾Ñ OGR"
-#: ../gui/tcltk/d.m/menu.tcl:403
+#: ../gui/tcltk/d.m/menu.tcl:404
msgid "Set database connection for vector attributes"
msgstr "ÐадаÑÑ Ñоединение Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
Ð´Ð»Ñ Ð°ÑÑибÑÑов векÑоÑа"
-#: ../gui/tcltk/d.m/menu.tcl:405
+#: ../gui/tcltk/d.m/menu.tcl:406
msgid "Rectify and georeference vector map"
msgstr "ТÑанÑÑоÑмиÑоваÑÑ Ð¸ пÑивÑзаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
-#: ../gui/tcltk/d.m/menu.tcl:407
+#: ../gui/tcltk/d.m/menu.tcl:408
msgid "Query by attributes"
msgstr "ÐапÑÐ¾Ñ Ð¿Ð¾ аÑÑибÑÑам"
-#: ../gui/tcltk/d.m/menu.tcl:409
+#: ../gui/tcltk/d.m/menu.tcl:410
msgid "Query by map features"
msgstr "ÐапÑÐ¾Ñ Ð¿Ð¾ обÑекÑам ÑлоÑ"
-#: ../gui/tcltk/d.m/menu.tcl:411
+#: ../gui/tcltk/d.m/menu.tcl:412
msgid "Create vector buffers"
msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑе бÑÑеÑнÑе зонÑ"
-#: ../gui/tcltk/d.m/menu.tcl:412
+#: ../gui/tcltk/d.m/menu.tcl:413
msgid "Linear referencing for vectors"
msgstr "ÐÐ¸Ð½ÐµÐ¹Ð½Ð°Ñ Ð¿ÑивÑзка Ð´Ð»Ñ Ð²ÐµÐºÑоÑов"
-#: ../gui/tcltk/d.m/menu.tcl:413
+#: ../gui/tcltk/d.m/menu.tcl:414
msgid "Create linear reference system"
msgstr "СоздаÑÑ Ð»Ð¸Ð½ÐµÐ¹Ð½ÑÑ ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑдинаÑ"
-#: ../gui/tcltk/d.m/menu.tcl:414
+#: ../gui/tcltk/d.m/menu.tcl:415
msgid "Create stationing from imput lines, and linear reference system"
msgstr "СоздаÑÑ ÑÑанÑии из иÑÑ
однÑÑ
линий и линейнÑÑ ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑдинаÑ"
-#: ../gui/tcltk/d.m/menu.tcl:415
+#: ../gui/tcltk/d.m/menu.tcl:416
msgid ""
"Create points/segments from input lines, linear reference system and "
"positions read from stdin"
@@ -5632,7 +5673,7 @@
"СоздаÑÑ ÑоÑки/ÑегменÑÑ Ð¸Ð· иÑÑ
однÑÑ
линий, ÑиÑÑÐµÐ¼Ñ Ð»Ð¸Ð½ÐµÐ¹Ð½ÑÑ
кооÑÐ´Ð¸Ð½Ð°Ñ Ð¸ "
"ÑоÑек, ÑÑиÑÑваемÑÑ
из stdin"
-#: ../gui/tcltk/d.m/menu.tcl:416
+#: ../gui/tcltk/d.m/menu.tcl:417
msgid ""
"Find line id and real km+offset for given points in vector map using linear "
"reference system"
@@ -5640,250 +5681,250 @@
"ÐайÑи ID линии и ÑеалÑнÑй киломеÑÑаж+Ñдвиг Ð´Ð»Ñ Ð·Ð°Ð´Ð°Ð½Ð½ÑÑ
ÑоÑек векÑоÑного "
"ÑÐ»Ð¾Ñ Ð¸ÑполÑзÑÑ ÑиÑÑÐµÐ¼Ñ Ð»Ð¸Ð½ÐµÐ¹Ð½ÑÑ
кооÑдинаÑ"
-#: ../gui/tcltk/d.m/menu.tcl:419
+#: ../gui/tcltk/d.m/menu.tcl:420
msgid "Locate nearest features to points or centroids"
msgstr "ÐайÑи ближайÑие к ÑоÑкам или ÑенÑÑоидам обÑекÑÑ "
-#: ../gui/tcltk/d.m/menu.tcl:420
+#: ../gui/tcltk/d.m/menu.tcl:421
msgid "Generate Thiessen polygons around points (Voronoi diagram)"
msgstr "СоздаÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ñ Ð¢Ð¸ÑÑена вокÑÑг ÑоÑек (диагÑамма ÐоÑоного)"
-#: ../gui/tcltk/d.m/menu.tcl:421
+#: ../gui/tcltk/d.m/menu.tcl:422
msgid "Connect points to create Delaunay triangles"
msgstr "СоединиÑÑ ÑоÑки Ð´Ð»Ñ ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ ÑÑиангÑлÑÑии Ðелоне"
-#: ../gui/tcltk/d.m/menu.tcl:427
+#: ../gui/tcltk/d.m/menu.tcl:428
msgid "Shortest route (visualization only)"
msgstr "ÐÑаÑÑайÑий пÑÑÑ (ÑолÑко оÑобÑажение)"
-#: ../gui/tcltk/d.m/menu.tcl:428
+#: ../gui/tcltk/d.m/menu.tcl:429
msgid "Split net to bands between cost isolines"
msgstr "РазделиÑÑ ÑеÑÑ Ð½Ð° полоÑÑ Ð¼ÐµÐ¶Ð´Ñ Ð¸Ð·Ð¾Ð»Ð¸Ð½Ð¸Ñми ÑÑоимоÑÑи"
-#: ../gui/tcltk/d.m/menu.tcl:433
+#: ../gui/tcltk/d.m/menu.tcl:434
msgid "Overlay/combine 2 vector maps"
msgstr "ÐаложиÑÑ/комбиниÑоваÑÑ Ð´Ð²Ð° векÑоÑнÑÑ
ÑлоÑ"
-#: ../gui/tcltk/d.m/menu.tcl:434
+#: ../gui/tcltk/d.m/menu.tcl:435
msgid "Patch multiple maps (combine)"
msgstr "СовмеÑÑиÑÑ Ð½ÐµÑколÑко Ñлоев (комбиниÑование)"
-#: ../gui/tcltk/d.m/menu.tcl:436
+#: ../gui/tcltk/d.m/menu.tcl:437
msgid "Generate area feature for extent of current region"
msgstr "СоздаÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½ Ñ Ð¾Ñ
ваÑом ÑекÑÑего Ñегиона"
-#: ../gui/tcltk/d.m/menu.tcl:437
+#: ../gui/tcltk/d.m/menu.tcl:438
msgid "Generate rectangular vector grid"
msgstr "СоздаÑÑ Ð¿ÑÑмоÑголÑнÑÑ Ð²ÐµÐºÑоÑнÑÑ ÑеÑкÑ"
-#: ../gui/tcltk/d.m/menu.tcl:440
+#: ../gui/tcltk/d.m/menu.tcl:441
msgid "Attach, delete, or report categories"
msgstr "ÐÑиÑоединиÑÑ, ÑдалиÑÑ Ð¸Ð»Ð¸ показаÑÑ ÐºÐ°ÑегоÑии"
-#: ../gui/tcltk/d.m/menu.tcl:441
+#: ../gui/tcltk/d.m/menu.tcl:442
msgid "Reclassify features using rules file"
msgstr "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ Ð¾Ð±ÑекÑÑ, иÑполÑзÑÑ Ñайл пÑавил"
-#: ../gui/tcltk/d.m/menu.tcl:444
+#: ../gui/tcltk/d.m/menu.tcl:445
msgid "Work with vector points"
msgstr "РабоÑаÑÑ Ñ ÑоÑками векÑоÑа"
-#: ../gui/tcltk/d.m/menu.tcl:446
+#: ../gui/tcltk/d.m/menu.tcl:447
msgid "Generate points from database with x/y coordinates"
Ñ ÐºÐ¾Ð¾ÑдинаÑами x/y"
-#: ../gui/tcltk/d.m/menu.tcl:448
+#: ../gui/tcltk/d.m/menu.tcl:449
msgid "Random location perturbations of points"
msgstr "СлÑÑайное ÑмеÑение меÑÑÐ¾Ð¿Ð¾Ð»Ð¾Ð¶ÐµÐ½Ð¸Ñ ÑоÑек"
-#: ../gui/tcltk/d.m/menu.tcl:451
+#: ../gui/tcltk/d.m/menu.tcl:452
msgid "Generate convex hull for point set"
msgstr "СоздаÑÑ ÐºÐ¾Ð½Ð²ÐµÐºÑнÑй полигон Ð´Ð»Ñ Ð½Ð°Ð±Ð¾Ñа ÑоÑек"
-#: ../gui/tcltk/d.m/menu.tcl:452
+#: ../gui/tcltk/d.m/menu.tcl:453
msgid "Generate Delaunay triangles for point set"
msgstr "СоздаÑÑ ÑÑиангÑлÑÑÐ¸Ñ Ðелоне Ð´Ð»Ñ Ð½Ð°Ð±Ð¾Ñа ÑоÑек"
-#: ../gui/tcltk/d.m/menu.tcl:453
+#: ../gui/tcltk/d.m/menu.tcl:454
msgid "Generate Voronoi diagram/Thiessen polygons for point set"
msgstr "СоздаÑÑ Ð´Ð¸Ð°Ð³ÑÐ°Ð¼Ð¼Ñ ÐоÑоного/Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ñ Ð¢Ð¸ÑÑена Ð´Ð»Ñ ÑоÑеÑного набоÑа"
-#: ../gui/tcltk/d.m/menu.tcl:455
+#: ../gui/tcltk/d.m/menu.tcl:456
msgid "Sample raster maps"
msgstr "ÐолÑÑиÑÑ Ð´Ð°Ð½Ð½Ñе Ñ ÑаÑÑÑовÑÑ
Ñлоев"
-#: ../gui/tcltk/d.m/menu.tcl:456
+#: ../gui/tcltk/d.m/menu.tcl:457
msgid "Calculate statistics for raster map overlain by vector map"
msgstr ""
"РаÑÑÑиÑаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð½Ð° коÑоÑÑй наложен векÑоÑнÑй Ñлой"
-#: ../gui/tcltk/d.m/menu.tcl:460
+#: ../gui/tcltk/d.m/menu.tcl:461
msgid "Partition points into test/training sets for k-fold cross validatation"
msgstr "РазделиÑÑ ÑоÑки на ÑеÑÑовÑе/ÑÑениÑовоÑнÑе Ð´Ð»Ñ k-fold кÑоÑÑ-валидаÑии"
-#: ../gui/tcltk/d.m/menu.tcl:461
+#: ../gui/tcltk/d.m/menu.tcl:462
msgid "Transfer attribute data from queried vector map to points"
msgstr ""
"ÐеÑенеÑÑи на ÑоÑки аÑÑибÑÑивнÑе даннÑе из запÑаÑиваемого векÑоÑного ÑлоÑ"
-#: ../gui/tcltk/d.m/menu.tcl:466
+#: ../gui/tcltk/d.m/menu.tcl:467
msgid "Load vector attributes to database or create reports"
msgstr "ÐагÑÑзиÑÑ Ð°ÑÑибÑÑÑ Ð²ÐµÐºÑоÑа в Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
или ÑоздаÑÑ Ð¾ÑÑеÑ"
-#: ../gui/tcltk/d.m/menu.tcl:467
+#: ../gui/tcltk/d.m/menu.tcl:468
msgid "Report areas for vector attribute categories"
msgstr "ÐÑвеÑÑи Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ñ Ð´Ð»Ñ ÐºÐ°ÑегоÑий аÑÑибÑÑов векÑоÑа"
-#: ../gui/tcltk/d.m/menu.tcl:470
+#: ../gui/tcltk/d.m/menu.tcl:471
msgid "Test normality of point distribution"
msgstr "ÐÑовеÑиÑÑ Ð½Ð¾ÑмалÑноÑÑÑ ÑаÑпÑÐµÐ´ÐµÐ»ÐµÐ½Ð¸Ñ ÑоÑек"
-#: ../gui/tcltk/d.m/menu.tcl:471
+#: ../gui/tcltk/d.m/menu.tcl:472
msgid "Calculate stats for raster map underlying vector objects"
msgstr "РаÑÑÑиÑаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð´Ð»Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¿Ð¾Ð´ векÑоÑнÑми обÑекÑами"
-#: ../gui/tcltk/d.m/menu.tcl:472
+#: ../gui/tcltk/d.m/menu.tcl:473
msgid "Indices of point counts in quadrats"
msgstr "ÐндекÑÑ ÑоÑеÑнÑÑ
ÑÑеÑов по квадÑаÑам"
-#: ../gui/tcltk/d.m/menu.tcl:477
+#: ../gui/tcltk/d.m/menu.tcl:478
msgid "Create/edit imagery group"
msgstr "СоздаÑÑ/ÑедакÑиÑоваÑÑ Ð³ÑÑÐ¿Ð¿Ñ Ð¸Ð·Ð¾Ð±Ñажений"
-#: ../gui/tcltk/d.m/menu.tcl:478
+#: ../gui/tcltk/d.m/menu.tcl:479
msgid "Target imagery group"
msgstr "Ð¦ÐµÐ»ÐµÐ²Ð°Ñ Ð³ÑÑппа изобÑажений"
-#: ../gui/tcltk/d.m/menu.tcl:480
+#: ../gui/tcltk/d.m/menu.tcl:481
msgid "Mosaic up to 4 adjacent images"
msgstr "ÐозаиÑиÑоваÑÑ Ð´Ð¾ 4 ÑоÑедниÑ
изобÑажений"
-#: ../gui/tcltk/d.m/menu.tcl:483
+#: ../gui/tcltk/d.m/menu.tcl:484
msgid ""
"Color balance and enhance color tables of multiband imagery for rgb display"
msgstr ""
"ЦвеÑÐ¾Ð²Ð°Ñ Ð±Ð°Ð»Ð°Ð½ÑиÑовка и ÑлÑÑÑение ÑвеÑовÑÑ
ÑÐ°Ð±Ð»Ð¸Ñ Ð´Ð»Ñ Ð¼Ð½Ð¾Ð³Ð¾ÐºÐ°Ð½Ð°Ð»ÑнÑÑ
"изобÑажений Ð´Ð»Ñ Ð¿Ð¾ÐºÐ°Ð·Ð° RGB"
-#: ../gui/tcltk/d.m/menu.tcl:484
+#: ../gui/tcltk/d.m/menu.tcl:485
msgid ""
"Transform HIS (Hue/Intensity/Saturation) color image to RGB (Red/Green/Blue)"
msgstr ""
"ТÑанÑÑоÑмиÑоваÑÑ ÑвеÑное изобÑажение HIS (Тон/ЯÑкоÑÑÑ/ÐаÑÑÑенноÑÑÑ) в RGB "
"(ÐÑаÑнÑй/ÐеленÑй/Синий)"
-#: ../gui/tcltk/d.m/menu.tcl:485
+#: ../gui/tcltk/d.m/menu.tcl:486
msgid ""
"Transform RGB (Red/Green/Blue) color image to HIS (Hue/Intensity/Saturation)"
msgstr ""
"ТÑанÑÑоÑмиÑоваÑÑ ÑвеÑное изобÑажение RGB (ÐÑаÑнÑй/ÐеленÑй/Синий) в HIS (Тон/"
"ЯÑкоÑÑÑ/ÐаÑÑÑенноÑÑÑ)"
-#: ../gui/tcltk/d.m/menu.tcl:487
+#: ../gui/tcltk/d.m/menu.tcl:488
msgid "Rectify and georeference image group"
msgstr "ТÑанÑÑоÑмиÑоваÑÑ Ð¸ пÑивÑзаÑÑ Ð³ÑÑÐ¿Ð¿Ñ Ð¸Ð·Ð¾Ð±Ñажений"
-#: ../gui/tcltk/d.m/menu.tcl:488
+#: ../gui/tcltk/d.m/menu.tcl:489
msgid "Set ground control points (GCP's) from raster map or keyboard entry"
msgstr "ÐвеÑÑи опоÑнÑе ÑоÑки (GCP) Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¸Ð»Ð¸ ввод Ñ ÐºÐ»Ð°Ð²Ð¸Ð°ÑÑÑÑ"
-#: ../gui/tcltk/d.m/menu.tcl:490
+#: ../gui/tcltk/d.m/menu.tcl:491
msgid "Set ground control points (GCP's) from vector map or keyboard entry"
msgstr "ÐвеÑÑи опоÑнÑе ÑоÑки (GCP) Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ Ð¸Ð»Ð¸ ввод Ñ ÐºÐ»Ð°Ð²Ð¸Ð°ÑÑÑÑ"
-#: ../gui/tcltk/d.m/menu.tcl:492
+#: ../gui/tcltk/d.m/menu.tcl:493
msgid "Affine and Polynomial rectification (rubber sheet)"
msgstr "ÐÑÑÐ¸Ð½Ð½Ð°Ñ Ð¸Ð»Ð¸ полиномиалÑÐ½Ð°Ñ ÑÑанÑÑоÑмаÑÐ¸Ñ (меÑод Ñезинового лиÑÑа)"
-#: ../gui/tcltk/d.m/menu.tcl:496
+#: ../gui/tcltk/d.m/menu.tcl:497
msgid "Brovey transformation and pan sharpening"
msgstr "ТÑанÑÑоÑмаÑÐ¸Ñ Ð¿Ð¾ Brovey и ÑвелиÑение ÑезкоÑÑи"
-#: ../gui/tcltk/d.m/menu.tcl:504
+#: ../gui/tcltk/d.m/menu.tcl:505
msgid "Non-interactive input for supervised classification (MLC)"
msgstr "ÐеинÑеÑакÑивнÑй ввод Ð´Ð»Ñ ÐºÐ»Ð°ÑÑиÑикаÑии Ñ Ð¾Ð±ÑÑением (MLC)"
-#: ../gui/tcltk/d.m/menu.tcl:505
+#: ../gui/tcltk/d.m/menu.tcl:506
msgid "Non-interactive input for supervised classification (SMAP)"
msgstr "ÐеинÑеÑакÑивнÑй ввод Ð´Ð»Ñ ÐºÐ»Ð°ÑÑиÑикаÑии Ñ Ð¾Ð±ÑÑением (SMAP)"
-#: ../gui/tcltk/d.m/menu.tcl:508
+#: ../gui/tcltk/d.m/menu.tcl:509
msgid "Zero edge crossing detection"
msgstr "ÐпÑеделение пеÑеÑеÑÐµÐ½Ð¸Ñ Ð½Ñлевой гÑаниÑÑ"
-#: ../gui/tcltk/d.m/menu.tcl:509
+#: ../gui/tcltk/d.m/menu.tcl:510
msgid "User defined matrix/convolving filter"
msgstr "ÐолÑзоваÑелÑÑкий маÑÑиÑнÑй ÑилÑÑÑ Ð¸Ð»Ð¸ ÑилÑÑÑ ÑвеÑÑки"
-#: ../gui/tcltk/d.m/menu.tcl:514
+#: ../gui/tcltk/d.m/menu.tcl:515
msgid "Canonical component"
msgstr "ÐанониÑеÑÐºÐ°Ñ ÐºÐ¾Ð¼Ð¿Ð¾Ð½ÐµÐ½Ñа"
-#: ../gui/tcltk/d.m/menu.tcl:515
+#: ../gui/tcltk/d.m/menu.tcl:516
msgid "Principal component"
msgstr "ÐÐ»Ð°Ð²Ð½Ð°Ñ ÐºÐ¾Ð¼Ð¿Ð¾Ð½ÐµÐ½Ñа"
-#: ../gui/tcltk/d.m/menu.tcl:516
+#: ../gui/tcltk/d.m/menu.tcl:517
msgid "Fast Fourier Transform"
-#: ../gui/tcltk/d.m/menu.tcl:517
+#: ../gui/tcltk/d.m/menu.tcl:518
msgid "Inverse Fast Fourier Transform"
-#: ../gui/tcltk/d.m/menu.tcl:522
+#: ../gui/tcltk/d.m/menu.tcl:523
msgid "Range of image values"
msgstr "Ðиапазон знаÑений изобÑажениÑ"
-#: ../gui/tcltk/d.m/menu.tcl:524
+#: ../gui/tcltk/d.m/menu.tcl:525
msgid "Bit pattern comparison for ID of low quality pixels"
msgstr "СÑавнение bit pattern Ð´Ð»Ñ Ð¾Ð¿ÑÐµÐ´ÐµÐ»ÐµÐ½Ð¸Ñ Ð¿Ð¸ÐºÑелей низкого каÑеÑÑва"
-#: ../gui/tcltk/d.m/menu.tcl:525
+#: ../gui/tcltk/d.m/menu.tcl:526
msgid "Kappa classification accuracy assessment"
msgstr "ÐÑенка каÑеÑÑва клаÑÑиÑикаÑии Kappa"
-#: ../gui/tcltk/d.m/menu.tcl:526
+#: ../gui/tcltk/d.m/menu.tcl:527
msgid "Optimum index factor for LandSat TM"
msgstr "Optimum index factor Ð´Ð»Ñ LandSat TM"
-#: ../gui/tcltk/d.m/menu.tcl:529
+#: ../gui/tcltk/d.m/menu.tcl:530
msgid "&Grid3D"
msgstr "&Grid3D"
-#: ../gui/tcltk/d.m/menu.tcl:534
+#: ../gui/tcltk/d.m/menu.tcl:535
msgid "Create 3D mask for grid3D operations"
msgstr "СоздаÑÑ 3D маÑÐºÑ Ð´Ð»Ñ Ð¾Ð¿ÐµÑаÑий grid3D "
-#: ../gui/tcltk/d.m/menu.tcl:535
+#: ../gui/tcltk/d.m/menu.tcl:536
msgid "Create 2D raster cross section from grid3d volume"
msgstr "СоздаÑÑ 2D ÑаÑÑÑовое ÑеÑение из обÑема grid3d"
-#: ../gui/tcltk/d.m/menu.tcl:536
+#: ../gui/tcltk/d.m/menu.tcl:537
msgid "Map calculator for grid3D operations"
msgstr "ÐалÑкÑлÑÑÐ¾Ñ Ð´Ð»Ñ Ð¾Ð¿ÐµÑаÑий Ñ grid3D"
-#: ../gui/tcltk/d.m/menu.tcl:537
+#: ../gui/tcltk/d.m/menu.tcl:538
msgid "Interpolate volume from vector points using splines"
msgstr "ÐнÑеÑполиÑоваÑÑ Ð¾Ð±Ñем из векÑоÑнÑÑ
ÑоÑек иÑполÑзÑÑ ÑплайнÑ"
-#: ../gui/tcltk/d.m/menu.tcl:539
+#: ../gui/tcltk/d.m/menu.tcl:540
msgid "Display information about grid3D volume"
msgstr "ÐоказаÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ обÑеме grid3D"
-#: ../gui/tcltk/d.m/menu.tcl:548
+#: ../gui/tcltk/d.m/menu.tcl:549
msgid "Add columns to table"
msgstr "ÐобавиÑÑ ÑÑолбÑÑ Ð² ÑаблиÑÑ"
-#: ../gui/tcltk/d.m/menu.tcl:549
+#: ../gui/tcltk/d.m/menu.tcl:550
msgid "Change values in a column"
msgstr "ÐзмениÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ð² ÑÑолбÑе"
-#: ../gui/tcltk/d.m/menu.tcl:560
+#: ../gui/tcltk/d.m/menu.tcl:561
msgid "Query data (SQL select)"
msgstr "ÐапÑÐ¾Ñ Ð´Ð°Ð½Ð½ÑÑ
(SQL вÑбоÑ)"
-#: ../gui/tcltk/d.m/menu.tcl:561
+#: ../gui/tcltk/d.m/menu.tcl:562
msgid "Execute SQL statement"
msgstr "ÐÑполниÑÑ SQL вÑÑажение"
@@ -5913,13 +5954,13 @@
msgstr " вÑÑовнÑÑÑ ÑекÑÑ Ñ ÑоÑкой"
#: ../gui/tcltk/d.m/fttext.tcl:120
+#, tcl-format
msgid ""
" (for coordinates, % is from bottom left of display, pixels from top "
"left)"
msgstr ""
-" (Ð´Ð»Ñ ÐºÐ¾Ð¾ÑдинаÑ, % наÑÐ¸Ð½Ð°Ñ Ñ Ð½Ð¸Ð¶Ð½ÐµÐ³Ð¾ левого Ñгла, пикÑели Ñ Ð²ÐµÑÑ
него "
-"левого)"
+" (Ð´Ð»Ñ ÐºÐ¾Ð¾ÑдинаÑ, пÑоÑенÑов наÑÐ¸Ð½Ð°Ñ Ñ Ð½Ð¸Ð¶Ð½ÐµÐ³Ð¾ левого Ñгла, пикÑели Ñ "
+"веÑÑ
него левого)"
#: ../gui/tcltk/d.m/fttext.tcl:126
msgid " text rotation (degrees counterclockwise)"
@@ -6179,6 +6220,9 @@
msgid "Test"
msgstr "ТеÑÑ"
+#~ msgid "Run (in Xterm)"
+#~ msgstr "ÐапÑÑÑиÑÑ (в Xterm)"
#~ msgid "Zoom to..."
#~ msgstr "ÐаÑÑÑабиÑоваÑÑ Ð´Ð¾..."
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_es.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_es.po 2009-05-22 15:36:57 UTC (rev 37374)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_es.po 2009-05-22 15:53:49 UTC (rev 37375)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_es\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2009-01-29 21:41+0100\n"
+"POT-Creation-Date: 2009-05-22 17:09+0200\n"
"PO-Revision-Date: 2008-08-08 16:34+0200\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -109,7 +109,7 @@
msgstr "Guardar visualización en archivo PNG"
#: ../gui/wxpython/icons/icon.py:176
-#: ../gui/wxpython/gui_modules/mapdisp.py:1009
+#: ../gui/wxpython/gui_modules/mapdisp.py:1020
msgid "Print display"
msgstr "Imprimir visualización"
@@ -214,7 +214,7 @@
msgstr "Añadir etiquetas"
#: ../gui/wxpython/icons/icon.py:228
-#: ../gui/wxpython/gui_modules/mapdisp.py:1604
+#: ../gui/wxpython/gui_modules/mapdisp.py:1627
msgid "Add text layer"
msgstr "Añadir capa de texto"
@@ -260,7 +260,7 @@
msgstr "Izquierda: seleccionar; Centro: deseleccionar; Derecha: confirmar"
#: ../gui/wxpython/icons/icon.py:248
-#: ../gui/wxpython/gui_modules/toolbars.py:736
+#: ../gui/wxpython/gui_modules/toolbars.py:738
msgid "Copy categories"
msgstr "Copiar categorÃas"
@@ -298,7 +298,7 @@
#: ../gui/wxpython/icons/icon.py:272 ../gui/wxpython/icons/icon.py:332
#: ../gui/wxpython/icons/icon.py:336
-#: ../gui/wxpython/gui_modules/nviz_tools.py:949
+#: ../gui/wxpython/gui_modules/nviz_tools.py:950
msgid "Settings"
msgstr "Configuración"
@@ -366,7 +366,7 @@
msgstr "Seleccionar color"
#: ../gui/wxpython/icons/icon.py:306
-#: ../gui/wxpython/gui_modules/gdialogs.py:299
+#: ../gui/wxpython/gui_modules/gdialogs.py:301
msgid "Set options"
msgstr "Establecer opciones"
@@ -383,8 +383,8 @@
msgstr "Definir GCP (Puntos de Control sobre el Terreno)"
#: ../gui/wxpython/icons/icon.py:314
-#: ../gui/wxpython/gui_modules/georect.py:141
-#: ../gui/wxpython/gui_modules/georect.py:147
+#: ../gui/wxpython/gui_modules/georect.py:148
+#: ../gui/wxpython/gui_modules/georect.py:154
#: ../gui/wxpython/menustrings.py:164
msgid "Georectify"
msgstr "Georrectificar"
@@ -429,603 +429,636 @@
msgid "Show Nviz settings dialog"
msgstr "Mostrar diálogo de configuración de NVIZ"
-#: ../gui/wxpython/gui_modules/location_wizard.py:131
+#: ../gui/wxpython/gui_modules/location_wizard.py:139
msgid "Define GRASS Database and Location Name"
msgstr "Definir base de datos de GRASS y nombre de localización"
-#: ../gui/wxpython/gui_modules/location_wizard.py:137
-#: ../gui/wxpython/gui_modules/location_wizard.py:1076
-#: ../gui/wxpython/gui_modules/location_wizard.py:1154
-#: ../gui/wxpython/gui_modules/location_wizard.py:1246
-#: ../gui/wxpython/gui_modules/menuform.py:1295
-#: ../gui/wxpython/gui_modules/gdialogs.py:814
-#: ../gui/wxpython/gui_modules/gdialogs.py:824 ../gui/wxpython/gis_set.py:124
+#: ../gui/wxpython/gui_modules/location_wizard.py:145
+#: ../gui/wxpython/gui_modules/location_wizard.py:1088
+#: ../gui/wxpython/gui_modules/location_wizard.py:1166
+#: ../gui/wxpython/gui_modules/location_wizard.py:1261
+#: ../gui/wxpython/gui_modules/menuform.py:1457
+#: ../gui/wxpython/gui_modules/gdialogs.py:856
+#: ../gui/wxpython/gui_modules/gdialogs.py:865 ../gui/wxpython/gis_set.py:121
msgid "Browse"
msgstr "Explorar"
-#: ../gui/wxpython/gui_modules/location_wizard.py:145
-#: ../gui/wxpython/gis_set.py:100
+#: ../gui/wxpython/gui_modules/location_wizard.py:153
+#: ../gui/wxpython/gis_set.py:97
msgid "GIS Data Directory:"
msgstr "Directorio de datos de SIG:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:161
+#: ../gui/wxpython/gui_modules/location_wizard.py:169
msgid "Project Location"
msgstr "Localización del proyecto"
-#: ../gui/wxpython/gui_modules/location_wizard.py:199
+#: ../gui/wxpython/gui_modules/location_wizard.py:207
msgid "Choose GRASS data directory:"
msgstr "Seleccionar directorio de datos de GRASS:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:210
-#: ../gui/wxpython/gui_modules/location_wizard.py:1839
+#: ../gui/wxpython/gui_modules/location_wizard.py:218
+#: ../gui/wxpython/gui_modules/location_wizard.py:1863
msgid "Location already exists in GRASS Database."
msgstr "La localización ya existe en la base de datos de GRASS."
-#: ../gui/wxpython/gui_modules/location_wizard.py:213
+#: ../gui/wxpython/gui_modules/location_wizard.py:221
msgid "Unable to create location"
msgstr "No se puede crear la localización"
-#: ../gui/wxpython/gui_modules/location_wizard.py:217
-#: ../gui/wxpython/gui_modules/location_wizard.py:540
-#: ../gui/wxpython/gui_modules/location_wizard.py:1420
-#: ../gui/wxpython/gui_modules/location_wizard.py:1840
-#: ../gui/wxpython/gui_modules/location_wizard.py:1916
-#: ../gui/wxpython/gui_modules/location_wizard.py:2023
-#: ../gui/wxpython/gui_modules/location_wizard.py:2058
-#: ../gui/wxpython/gui_modules/location_wizard.py:2230
-#: ../gui/wxpython/gui_modules/location_wizard.py:2247
-#: ../gui/wxpython/gui_modules/location_wizard.py:2554
-#: ../gui/wxpython/gui_modules/georect.py:902
-#: ../gui/wxpython/gui_modules/georect.py:939
-#: ../gui/wxpython/gui_modules/gdialogs.py:144
-#: ../gui/wxpython/gui_modules/mapdisp.py:357
-#: ../gui/wxpython/gui_modules/workspace.py:617
-#: ../gui/wxpython/gui_modules/preferences.py:1546
-#: ../gui/wxpython/gui_modules/dbm.py:187
-#: ../gui/wxpython/gui_modules/dbm.py:275
-#: ../gui/wxpython/gui_modules/dbm.py:1246
-#: ../gui/wxpython/gui_modules/dbm.py:1350
-#: ../gui/wxpython/gui_modules/dbm.py:1434
-#: ../gui/wxpython/gui_modules/dbm.py:1446
-#: ../gui/wxpython/gui_modules/dbm.py:1460
-#: ../gui/wxpython/gui_modules/dbm.py:1553
-#: ../gui/wxpython/gui_modules/dbm.py:1575
-#: ../gui/wxpython/gui_modules/dbm.py:1729
-#: ../gui/wxpython/gui_modules/dbm.py:1740
-#: ../gui/wxpython/gui_modules/dbm.py:1752
-#: ../gui/wxpython/gui_modules/dbm.py:2568
-#: ../gui/wxpython/gui_modules/dbm.py:2666
-#: ../gui/wxpython/gui_modules/dbm.py:2673
-#: ../gui/wxpython/gui_modules/dbm.py:2712
+#: ../gui/wxpython/gui_modules/location_wizard.py:225
+#: ../gui/wxpython/gui_modules/location_wizard.py:547
+#: ../gui/wxpython/gui_modules/location_wizard.py:1864
+#: ../gui/wxpython/gui_modules/location_wizard.py:1962
+#: ../gui/wxpython/gui_modules/location_wizard.py:2064
+#: ../gui/wxpython/gui_modules/location_wizard.py:2096
+#: ../gui/wxpython/gui_modules/location_wizard.py:2259
+#: ../gui/wxpython/gui_modules/location_wizard.py:2276
+#: ../gui/wxpython/gui_modules/location_wizard.py:2583
+#: ../gui/wxpython/gui_modules/georect.py:945
+#: ../gui/wxpython/gui_modules/georect.py:982
+#: ../gui/wxpython/gui_modules/gdialogs.py:143
+#: ../gui/wxpython/gui_modules/mapdisp.py:309
+#: ../gui/wxpython/gui_modules/mapdisp.py:367
+#: ../gui/wxpython/gui_modules/workspace.py:631
+#: ../gui/wxpython/gui_modules/preferences.py:1579
+#: ../gui/wxpython/gui_modules/dbm.py:179
+#: ../gui/wxpython/gui_modules/dbm.py:280
+#: ../gui/wxpython/gui_modules/dbm.py:1277
+#: ../gui/wxpython/gui_modules/dbm.py:1386
+#: ../gui/wxpython/gui_modules/dbm.py:1472
+#: ../gui/wxpython/gui_modules/dbm.py:1484
+#: ../gui/wxpython/gui_modules/dbm.py:1499
+#: ../gui/wxpython/gui_modules/dbm.py:1594
+#: ../gui/wxpython/gui_modules/dbm.py:1616
+#: ../gui/wxpython/gui_modules/dbm.py:1771
+#: ../gui/wxpython/gui_modules/dbm.py:1782
+#: ../gui/wxpython/gui_modules/dbm.py:1794
+#: ../gui/wxpython/gui_modules/dbm.py:2574
+#: ../gui/wxpython/gui_modules/dbm.py:2672
+#: ../gui/wxpython/gui_modules/dbm.py:2679
+#: ../gui/wxpython/gui_modules/dbm.py:2718
#: ../gui/wxpython/gui_modules/gcmd.py:66
#: ../gui/wxpython/gui_modules/gcmd.py:92
-#: ../gui/wxpython/gui_modules/render.py:465
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:411
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:443
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1232
-#: ../gui/wxpython/gui_modules/vdigit.py:1899
-#: ../gui/wxpython/gui_modules/vdigit.py:2078
-#: ../gui/wxpython/gui_modules/vdigit.py:2102
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1851
-#: ../gui/wxpython/gis_set.py:675 ../gui/wxpython/wxgui.py:780
-#: ../gui/wxpython/wxgui.py:912 ../gui/wxpython/wxgui.py:921
+#: ../gui/wxpython/gui_modules/render.py:477
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:442
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:474
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:511
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1288
+#: ../gui/wxpython/gui_modules/vdigit.py:1948
+#: ../gui/wxpython/gui_modules/vdigit.py:2127
+#: ../gui/wxpython/gui_modules/vdigit.py:2151
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1893
+#: ../gui/wxpython/gis_set.py:687 ../gui/wxpython/wxgui.py:799
+#: ../gui/wxpython/wxgui.py:931 ../gui/wxpython/wxgui.py:940
msgid "Error"
msgstr "Error"
-#: ../gui/wxpython/gui_modules/location_wizard.py:239
+#: ../gui/wxpython/gui_modules/location_wizard.py:247
msgid "Choose method for creating a new location"
msgstr "Seleccione el método para crear una nueva localización"
-#: ../gui/wxpython/gui_modules/location_wizard.py:246
+#: ../gui/wxpython/gui_modules/location_wizard.py:254
msgid "Select coordinate system"
msgstr "Seleccione el sistema de coordenadas"
-#: ../gui/wxpython/gui_modules/location_wizard.py:249
+#: ../gui/wxpython/gui_modules/location_wizard.py:257
msgid "Select EPSG code of coordinate system"
msgstr "Seleccionar código EPSG del sistema de coordenadas"
-#: ../gui/wxpython/gui_modules/location_wizard.py:251
+#: ../gui/wxpython/gui_modules/location_wizard.py:259
msgid "Use coordinate system of selected georeferenced file"
msgstr "Usar sistema de coordenadas del archivo georreferenciado seleccionado"
-#: ../gui/wxpython/gui_modules/location_wizard.py:254
+#: ../gui/wxpython/gui_modules/location_wizard.py:262
msgid "Use coordinate system of selected WKT or PRJ file"
msgstr "Usar sistema de coordenadas del archivo WKT o PRJ seleccionado"
-#: ../gui/wxpython/gui_modules/location_wizard.py:257
+#: ../gui/wxpython/gui_modules/location_wizard.py:265
msgid "Create custom PROJ.4 parameters string for coordinate system"
msgstr ""
"Crear cadena de parámetros PROJ.4 personalizada para el sistema de "
"coordenadas"
-#: ../gui/wxpython/gui_modules/location_wizard.py:260
+#: ../gui/wxpython/gui_modules/location_wizard.py:268
#, fuzzy
msgid "Use arbitrary non-earth coordinate system (XY)"
msgstr "Usar"
-#: ../gui/wxpython/gui_modules/location_wizard.py:332
+#: ../gui/wxpython/gui_modules/location_wizard.py:341
msgid "Choose projection"
msgstr "Seleccionar proyección"
-#: ../gui/wxpython/gui_modules/location_wizard.py:347
-#: ../gui/wxpython/gui_modules/location_wizard.py:771
-#: ../gui/wxpython/gui_modules/location_wizard.py:779
-#: ../gui/wxpython/gui_modules/location_wizard.py:964
-#: ../gui/wxpython/gui_modules/location_wizard.py:1254
+#: ../gui/wxpython/gui_modules/location_wizard.py:356
+#: ../gui/wxpython/gui_modules/location_wizard.py:783
+#: ../gui/wxpython/gui_modules/location_wizard.py:791
+#: ../gui/wxpython/gui_modules/location_wizard.py:976
+#: ../gui/wxpython/gui_modules/location_wizard.py:1269
msgid "Code"
msgstr "Código"
msgid "Description"
msgstr "Descripción"
-#: ../gui/wxpython/gui_modules/location_wizard.py:350
+#: ../gui/wxpython/gui_modules/location_wizard.py:359
msgid "Projection code:"
msgstr "Código de la proyección:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:358
-#: ../gui/wxpython/gui_modules/location_wizard.py:793
-#: ../gui/wxpython/gui_modules/location_wizard.py:976
-#: ../gui/wxpython/gui_modules/location_wizard.py:1237
+#: ../gui/wxpython/gui_modules/location_wizard.py:367
+#: ../gui/wxpython/gui_modules/location_wizard.py:805
+#: ../gui/wxpython/gui_modules/location_wizard.py:988
msgid "Search in description:"
msgstr "Buscar en la descripción:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:539
+#: ../gui/wxpython/gui_modules/location_wizard.py:546
#, python-format
msgid "Unable to read list: %s"
msgstr "No se puede leer la lista: %s"
-#: ../gui/wxpython/gui_modules/location_wizard.py:639
-#: ../gui/wxpython/gui_modules/location_wizard.py:1431
+#: ../gui/wxpython/gui_modules/location_wizard.py:651
+#: ../gui/wxpython/gui_modules/location_wizard.py:1455
msgid "Choose method of specifying georeferencing parameters"
msgstr ""
"Seleccionar método para especificar los parámetros de georreferenciación"
-#: ../gui/wxpython/gui_modules/location_wizard.py:647
+#: ../gui/wxpython/gui_modules/location_wizard.py:659
msgid "Select datum with associated ellipsoid"
msgstr "Seleccionar datum con elipsoide asociado"
-#: ../gui/wxpython/gui_modules/location_wizard.py:650
+#: ../gui/wxpython/gui_modules/location_wizard.py:662
msgid "Select ellipsoid"
msgstr "Seleccionar elipsoide"
-#: ../gui/wxpython/gui_modules/location_wizard.py:651
+#: ../gui/wxpython/gui_modules/location_wizard.py:663
msgid "Set zone for UTM projection:"
msgstr "Establecer zona para proyección UTM:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:653
+#: ../gui/wxpython/gui_modules/location_wizard.py:665
msgid "Zone:"
msgstr "Zona:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:656
+#: ../gui/wxpython/gui_modules/location_wizard.py:668
msgid "Hemisphere for zone:"
msgstr "Hemisferio para la zona:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:744
+#: ../gui/wxpython/gui_modules/location_wizard.py:756
msgid "Specify geodetic datum"
msgstr "Especificar datum geodésico"
msgid "Ellipsoid"
msgstr "Elipsoide"
msgid "Datum"
msgstr "Datum"
-#: ../gui/wxpython/gui_modules/location_wizard.py:784
+#: ../gui/wxpython/gui_modules/location_wizard.py:796
msgid "Datum code:"
msgstr "Código del datum:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:808
+#: ../gui/wxpython/gui_modules/location_wizard.py:820
msgid "Transformation parameters:"
msgstr "Parámetros de transformación:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:941
+#: ../gui/wxpython/gui_modules/location_wizard.py:953
msgid "Specify ellipsoid"
msgstr "Especificar elipsoide"
-#: ../gui/wxpython/gui_modules/location_wizard.py:968
+#: ../gui/wxpython/gui_modules/location_wizard.py:980
msgid "Ellipsoid code:"
msgstr "Código del elipsoide:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1069
-#: ../gui/wxpython/gui_modules/location_wizard.py:1128
+#: ../gui/wxpython/gui_modules/location_wizard.py:1081
+#: ../gui/wxpython/gui_modules/location_wizard.py:1140
msgid "Select georeferenced file"
msgstr "Seleccionar archivo georreferenciado"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1074
+#: ../gui/wxpython/gui_modules/location_wizard.py:1086
msgid "Georeferenced file:"
msgstr "Archivo georreferenciado:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1147
-#: ../gui/wxpython/gui_modules/location_wizard.py:1206
+#: ../gui/wxpython/gui_modules/location_wizard.py:1159
+#: ../gui/wxpython/gui_modules/location_wizard.py:1218
msgid "Select WKT file"
msgstr "Seleccionar archivo WKT"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1152
+#: ../gui/wxpython/gui_modules/location_wizard.py:1164
msgid "WKT file:"
msgstr "Archivo WKT:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1225
+#: ../gui/wxpython/gui_modules/location_wizard.py:1237
msgid "Choose EPSG Code"
msgstr "Seleccionar código EPSG"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1233
+#: ../gui/wxpython/gui_modules/location_wizard.py:1245
msgid "Path to the EPSG-codes file:"
msgstr "Ruta al archivo de códigos EPSG:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1235
+#: ../gui/wxpython/gui_modules/location_wizard.py:1247
msgid "EPSG code:"
msgstr "Código EPSG:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1247
-msgid "Browse EPSG Codes"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1249
+msgid "Search in"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1252
+#, fuzzy
+msgid "codes"
+msgstr "Código"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1253
+#, fuzzy
+msgid "description"
+msgstr "Descripción"
+#, fuzzy
+msgid "parameters"
+msgstr "Parámetros"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1262
+#, fuzzy
+msgid "Reload EPSG Codes"
msgstr "Explorar códigos EPSG"
msgid "Parameters"
msgstr "Parámetros"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1368
+#: ../gui/wxpython/gui_modules/location_wizard.py:1390
msgid "Choose EPSG codes file"
msgstr "Seleccionar archivo de códigos EPSG"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1419
-#, python-format
-msgid "Unable to read EPGS codes: %s"
-msgstr "No se pueden leer los códigos EPSG: %s"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1439
+#: ../gui/wxpython/gui_modules/location_wizard.py:1463
msgid "Enter PROJ.4 parameters string:"
msgstr "Introducir cadena de parámetros PROJ.4:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1490
+#: ../gui/wxpython/gui_modules/location_wizard.py:1514
msgid "Summary"
msgstr "Resumen"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1512
+#: ../gui/wxpython/gui_modules/location_wizard.py:1536
msgid "GRASS Database:"
msgstr "Base de datos de GRASS:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1518
+#: ../gui/wxpython/gui_modules/location_wizard.py:1542
msgid "Location Name:"
msgstr "Nombre de la localización:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1524
+#: ../gui/wxpython/gui_modules/location_wizard.py:1548
msgid "Projection:"
msgstr "Proyección:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1563
+#: ../gui/wxpython/gui_modules/location_wizard.py:1587
msgid "PROJ.4 definition:"
msgstr "Definición PROJ.4:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1608
+#: ../gui/wxpython/gui_modules/location_wizard.py:1632
#, python-format
msgid "Do you want to create GRASS location <%s>?"
msgstr "¿Quiere crear la localización de GRASS <%s>?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1609
+#: ../gui/wxpython/gui_modules/location_wizard.py:1633
msgid "Create new location?"
msgstr "¿Crear nueva localización?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1645
+#: ../gui/wxpython/gui_modules/location_wizard.py:1669
msgid "Define new GRASS Location"
msgstr "Definir nueva localización de GRASS"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1723
+#: ../gui/wxpython/gui_modules/location_wizard.py:1747
msgid "Do you want to set the default region extents and resolution now?"
msgstr ""
"¿Quiere establecer la extensión y resolución de la región predeterminada "
"ahora?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1725
+#: ../gui/wxpython/gui_modules/location_wizard.py:1749
#, python-format
msgid "Location <%s> created"
msgstr "Localización <%s> creada"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1739
+#: ../gui/wxpython/gui_modules/location_wizard.py:1763
#, python-format
msgid "Unable to create new location. Location <%s> not created."
msgstr "No se puede crear la nueva localización. Localización <%s> no creada."
-#: ../gui/wxpython/gui_modules/location_wizard.py:1741
-#: ../gui/wxpython/gui_modules/location_wizard.py:1749
-#: ../gui/wxpython/gis_set.py:128
+#: ../gui/wxpython/gui_modules/location_wizard.py:1765
+#: ../gui/wxpython/gui_modules/location_wizard.py:1773
+#: ../gui/wxpython/gis_set.py:125
msgid "Location wizard"
msgstr "Asistente de localizaciones"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1747
+#: ../gui/wxpython/gui_modules/location_wizard.py:1771
msgid "Location wizard canceled. Location not created."
msgstr ""
"Se ha cancelado el asistente de localizaciones. La localización no se ha "
"creado."
-#: ../gui/wxpython/gui_modules/location_wizard.py:1837
-#: ../gui/wxpython/gui_modules/location_wizard.py:1915
-#: ../gui/wxpython/gui_modules/location_wizard.py:2022
-#: ../gui/wxpython/gui_modules/location_wizard.py:2095
-#: ../gui/wxpython/gui_modules/location_wizard.py:2125
+#: ../gui/wxpython/gui_modules/location_wizard.py:1861
+#: ../gui/wxpython/gui_modules/location_wizard.py:1961
+#: ../gui/wxpython/gui_modules/location_wizard.py:2063
+#: ../gui/wxpython/gui_modules/location_wizard.py:2131
+#: ../gui/wxpython/gui_modules/location_wizard.py:2159
msgid "Unable to create new location"
msgstr "No se puede crear la nueva localización"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1884
+#, python-format
+msgid ""
+"Location <%(loc)s> will be created in GIS data directory <%(dir)s>.You will "
+"need to change the default GIS data directory in the GRASS startup screen."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1889
+#, fuzzy
+msgid "New GIS data directory"
+msgstr "Directorio de datos de SIG:"
msgid "EPSG code missing."
msgstr "Falta el código EPSG."
-#: ../gui/wxpython/gui_modules/location_wizard.py:2057
+#: ../gui/wxpython/gui_modules/location_wizard.py:2095
msgid "Datum transform is required."
msgstr "Se requiere una transformación del datum."
-#: ../gui/wxpython/gui_modules/location_wizard.py:2096
-#: ../gui/wxpython/gui_modules/location_wizard.py:2126
+#: ../gui/wxpython/gui_modules/location_wizard.py:2132
+#: ../gui/wxpython/gui_modules/location_wizard.py:2160
msgid "file not found"
msgstr "no se ha encontrado el archivo"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2152
+#: ../gui/wxpython/gui_modules/location_wizard.py:2181
msgid "Set default region extent and resolution"
msgstr "Establecer la extensión y resolución de la región predeterminada"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2196
+#: ../gui/wxpython/gui_modules/location_wizard.py:2228
msgid "&Set region"
msgstr "E&stablecer región"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2229
+#: ../gui/wxpython/gui_modules/location_wizard.py:2258
msgid "Invalid location selected."
msgstr "Seleccionada una localizacióŠno válida."
-#: ../gui/wxpython/gui_modules/location_wizard.py:2246
+#: ../gui/wxpython/gui_modules/location_wizard.py:2275
msgid "Invalid region"
msgstr "Región no válida"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2276
+#: ../gui/wxpython/gui_modules/location_wizard.py:2305
msgid "Click here to show 3D settings"
msgstr "Pulse aquà para mostrar configuración 3D"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2277
+#: ../gui/wxpython/gui_modules/location_wizard.py:2306
msgid "Click here to hide 3D settings"
msgstr "Pulse aquà para ocultar configuración 3D"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2300
-#: ../gui/wxpython/gui_modules/location_wizard.py:2581
+#: ../gui/wxpython/gui_modules/location_wizard.py:2329
+#: ../gui/wxpython/gui_modules/location_wizard.py:2610
#, python-format
msgid "Rows: %d"
msgstr "Filas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2301
-#: ../gui/wxpython/gui_modules/location_wizard.py:2582
+#: ../gui/wxpython/gui_modules/location_wizard.py:2330
+#: ../gui/wxpython/gui_modules/location_wizard.py:2611
#, python-format
msgid "Cols: %d"
msgstr "Columnas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2302
-#: ../gui/wxpython/gui_modules/location_wizard.py:2583
+#: ../gui/wxpython/gui_modules/location_wizard.py:2331
+#: ../gui/wxpython/gui_modules/location_wizard.py:2612
#, python-format
msgid "Cells: %d"
msgstr "Celdas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2343
-#: ../gui/wxpython/gui_modules/location_wizard.py:2585
+#: ../gui/wxpython/gui_modules/location_wizard.py:2372
+#: ../gui/wxpython/gui_modules/location_wizard.py:2614
#, python-format
msgid "Depth: %d"
msgstr "Profundida: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2344
-#: ../gui/wxpython/gui_modules/location_wizard.py:2586
+#: ../gui/wxpython/gui_modules/location_wizard.py:2373
+#: ../gui/wxpython/gui_modules/location_wizard.py:2615
#, python-format
msgid "3D Cells: %d"
msgstr "Celdas 3D: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2347
+#: ../gui/wxpython/gui_modules/location_wizard.py:2376
msgid "Top"
msgstr "Superior"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2355
+#: ../gui/wxpython/gui_modules/location_wizard.py:2384
msgid "Bottom"
msgstr "Inferior"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2363
+#: ../gui/wxpython/gui_modules/location_wizard.py:2392
msgid "T-B resolution"
msgstr "Resolución Sup-Inf"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2426
+#: ../gui/wxpython/gui_modules/location_wizard.py:2455
msgid "North"
msgstr "Norte"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2434
+#: ../gui/wxpython/gui_modules/location_wizard.py:2463
msgid "West"
msgstr "Oeste"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2454
+#: ../gui/wxpython/gui_modules/location_wizard.py:2483
msgid "East"
msgstr "Este"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2463
+#: ../gui/wxpython/gui_modules/location_wizard.py:2492
msgid "South"
msgstr "Sur"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2467
+#: ../gui/wxpython/gui_modules/location_wizard.py:2496
msgid "N-S resolution"
msgstr "Resolución N-S"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2475
+#: ../gui/wxpython/gui_modules/location_wizard.py:2504
msgid "E-W resolution"
msgstr "Resolución E-W"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2553
+#: ../gui/wxpython/gui_modules/location_wizard.py:2582
#, python-format
msgid "Invalid value: %s"
msgstr "Valor no válido: %s"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2620
+#: ../gui/wxpython/gui_modules/location_wizard.py:2638
msgid "Select datum transformation"
msgstr "Seleccionar transformación del datum"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2634
+#: ../gui/wxpython/gui_modules/location_wizard.py:2652
msgid "List of datum transformations"
msgstr "Lista de transformaciones del datum"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2638
-msgid "Datums:"
-msgstr "Datums:"
+#: ../gui/wxpython/gui_modules/location_wizard.py:2656
+msgid "Datums (select to see description):"
+msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:109
+#: ../gui/wxpython/gui_modules/georect.py:114
msgid "Setup for georectification"
msgstr "Configuración para georrectificación"
-#: ../gui/wxpython/gui_modules/georect.py:140
-#: ../gui/wxpython/gui_modules/georect.py:146
+#: ../gui/wxpython/gui_modules/georect.py:147
+#: ../gui/wxpython/gui_modules/georect.py:153
msgid "Georectifying setup canceled."
msgstr "Cancelada la configuración de la georrectificación."
-#: ../gui/wxpython/gui_modules/georect.py:184
+#: ../gui/wxpython/gui_modules/georect.py:191
msgid "Set ground control points (GCPs)"
msgstr "Establecer puntos de control sobre el terreno (GCP)"
-#: ../gui/wxpython/gui_modules/georect.py:283
+#: ../gui/wxpython/gui_modules/georect.py:290
msgid "Select map type and location/mapset"
msgstr "Seleccionar tipo de mapa y localización/direcctorio de mapas"
-#: ../gui/wxpython/gui_modules/georect.py:310
+#: ../gui/wxpython/gui_modules/georect.py:318
msgid "Map type to georectify"
msgstr "Tipo de mapa a georrectificar"
-#: ../gui/wxpython/gui_modules/georect.py:311
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:648
+#: ../gui/wxpython/gui_modules/georect.py:319
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:692
msgid "raster"
msgstr "ráster"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:669
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:713
msgid "vector"
msgstr "vectorial"
-#: ../gui/wxpython/gui_modules/georect.py:317
+#: ../gui/wxpython/gui_modules/georect.py:326
msgid "Select source location:"
msgstr "Seleccionar localización de origen:"
-#: ../gui/wxpython/gui_modules/georect.py:328
+#: ../gui/wxpython/gui_modules/georect.py:337
msgid "Select source mapset:"
msgstr "Seleccionar directorio de mapas de origen:"
-#: ../gui/wxpython/gui_modules/georect.py:382
+#: ../gui/wxpython/gui_modules/georect.py:391
msgid "You must select a valid location before selecting a mapset"
msgstr ""
"Debe seleccionar una localización válida antes de seleccionar un directorio "
"de mapas"
-#: ../gui/wxpython/gui_modules/georect.py:393
+#: ../gui/wxpython/gui_modules/georect.py:402
msgid "You must select a valid location and mapset in order to continue"
msgstr ""
"Debe seleccionar una localización y directorio de mapas válidos para "
"continuar"
-#: ../gui/wxpython/gui_modules/georect.py:410
+#: ../gui/wxpython/gui_modules/georect.py:419
msgid "Select image/map group to georectify"
msgstr "Seleccionar grupo de imágenes/mapas a georrectificar"
-#: ../gui/wxpython/gui_modules/georect.py:429
+#: ../gui/wxpython/gui_modules/georect.py:438
msgid "Select group:"
msgstr "Seleccionar grupo:"
-#: ../gui/wxpython/gui_modules/georect.py:440
+#: ../gui/wxpython/gui_modules/georect.py:449
msgid "Create group if none exists"
msgstr "Crear grupo si no existe ninguno"
-#: ../gui/wxpython/gui_modules/georect.py:443
+#: ../gui/wxpython/gui_modules/georect.py:453
msgid "Create/edit group..."
msgstr "Crear/editar grupo..."
-#: ../gui/wxpython/gui_modules/georect.py:449
+#: ../gui/wxpython/gui_modules/georect.py:454
+#, fuzzy
+msgid "Add vector map to group..."
+msgstr "Añadir capa de mapa vectorial"
+#: ../gui/wxpython/gui_modules/georect.py:467
msgid "Extension for output maps:"
msgstr "Extensión para los mapas de salida:"
-#: ../gui/wxpython/gui_modules/georect.py:500
+#: ../gui/wxpython/gui_modules/georect.py:523
msgid "You must select a valid image/map group in order to continue"
msgstr "Debe seleccionar un grupo de imágenes/mapas válido para continuar"
-#: ../gui/wxpython/gui_modules/georect.py:505
+#: ../gui/wxpython/gui_modules/georect.py:528
msgid "You must enter an map name extension in order to continue"
msgstr "Debe introducir una extensión del nombre del mapa para continuar"
-#: ../gui/wxpython/gui_modules/georect.py:550
+#: ../gui/wxpython/gui_modules/georect.py:590
msgid "Select image/map to display for ground control point (GCP) creation"
msgstr ""
"Seleccionar imagen/mapa a visualizar para la creación de puntos de control "
"sobre el terreno (GCP)"
-#: ../gui/wxpython/gui_modules/georect.py:558
+#: ../gui/wxpython/gui_modules/georect.py:598
msgid "Select display image/map:"
msgstr "Seleccionar imagen/mapa a visualizar:"
-#: ../gui/wxpython/gui_modules/georect.py:590
+#: ../gui/wxpython/gui_modules/georect.py:632
msgid "You must select a valid image/map in order to continue"
msgstr "Debe seleccionar una imagen/mapa válido para continuar"
-#: ../gui/wxpython/gui_modules/georect.py:614
+#: ../gui/wxpython/gui_modules/georect.py:657
msgid "Create & manage ground control points"
msgstr "Crear y administrar puntos de control sobre el terreno"
-#: ../gui/wxpython/gui_modules/georect.py:708
+#: ../gui/wxpython/gui_modules/georect.py:751
msgid "Select rectification method for rasters"
msgstr "Seleccionar método de rectificación para rásters"
-#: ../gui/wxpython/gui_modules/georect.py:709
+#: ../gui/wxpython/gui_modules/georect.py:752
msgid "1st order"
msgstr "Primer orden"
msgid "2nd order"
msgstr "Segundo orden"
msgid "3rd order"
msgstr "Tercer orden"
-#: ../gui/wxpython/gui_modules/georect.py:715
+#: ../gui/wxpython/gui_modules/georect.py:758
#, fuzzy
msgid "clip to computational region in target location"
msgstr "Zum"
-#: ../gui/wxpython/gui_modules/georect.py:720
+#: ../gui/wxpython/gui_modules/georect.py:763
msgid "Ground Control Points"
msgstr "Puntos de control sobre el terreno"
-#: ../gui/wxpython/gui_modules/georect.py:787
+#: ../gui/wxpython/gui_modules/georect.py:830
#, python-format
msgid "At least %d GCPs required. Operation cancelled."
msgstr "Se necesitan al menos %d GCP. Operación cancelada."
-#: ../gui/wxpython/gui_modules/georect.py:788
+#: ../gui/wxpython/gui_modules/georect.py:831
msgid "Delete GCP"
msgstr "Borrar GCP"
-#: ../gui/wxpython/gui_modules/georect.py:896
+#: ../gui/wxpython/gui_modules/georect.py:939
#, python-format
msgid "POINTS file <%s> saved"
msgstr "Archivo de PUNTOS <%s> guardado"
-#: ../gui/wxpython/gui_modules/georect.py:897
+#: ../gui/wxpython/gui_modules/georect.py:940
msgid "POINTS file saved"
msgstr "Archivo de PUNTOS guardado"
-#: ../gui/wxpython/gui_modules/georect.py:900
+#: ../gui/wxpython/gui_modules/georect.py:943
msgid "Writing POINTS file failed"
msgstr "Falló la escritura del archivo de PUNTOS"
-#: ../gui/wxpython/gui_modules/georect.py:937
+#: ../gui/wxpython/gui_modules/georect.py:980
msgid "Reading POINTS file failed"
msgstr "Falló la lectura del archivo de PUNTOS"
-#: ../gui/wxpython/gui_modules/georect.py:982
+#: ../gui/wxpython/gui_modules/georect.py:1025
msgid "RMS Error"
msgstr "Error RMS"
-#: ../gui/wxpython/gui_modules/georect.py:983
+#: ../gui/wxpython/gui_modules/georect.py:1026
#, fuzzy
msgid ""
"Insufficient points defined and active (checked) for selected rectification "
@@ -1040,251 +1073,288 @@
"6+ puntos para segundo orden y\n"
"10+ puntos para tercer orden."
-#: ../gui/wxpython/gui_modules/georect.py:1054
+#: ../gui/wxpython/gui_modules/georect.py:1075
+#, fuzzy, python-format
+msgid "Transforming <%s>..."
+msgstr "Transformar imagen"
+#: ../gui/wxpython/gui_modules/georect.py:1122
+msgid ""
+"Vector map <%s> already exists. Change extension name and georectify again."
+msgstr "El archivo de región <%s> ya existe. ¿Quiere sobrescribirlo?"
+#: ../gui/wxpython/gui_modules/georect.py:1137
+#, python-format
+msgid "Vector map <%s> georectified successfully"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1140
+#, fuzzy
+msgid "Copying attributes..."
+msgstr "Cambiar atributos"
+#: ../gui/wxpython/gui_modules/georect.py:1143
+msgid "Georectification of vector map <%s> failed"
+msgstr "vectorial."
+#: ../gui/wxpython/gui_modules/georect.py:1151
msgid "Georectifier settings"
msgstr "Configuración del georrectificador"
-#: ../gui/wxpython/gui_modules/georect.py:1148
+#: ../gui/wxpython/gui_modules/georect.py:1245
#, python-format
msgid "RMS error for selected points forward: %(fwd)s backward: %(bkw)s"
msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1181
+#: ../gui/wxpython/gui_modules/georect.py:1278
msgid "use| X coord"
msgstr "usar| coordenada X"
-#: ../gui/wxpython/gui_modules/georect.py:1182
+#: ../gui/wxpython/gui_modules/georect.py:1279
msgid "Y coord"
msgstr "Coordenada Y"
-#: ../gui/wxpython/gui_modules/georect.py:1183
+#: ../gui/wxpython/gui_modules/georect.py:1280
msgid "E coord"
msgstr "Coordenada E"
-#: ../gui/wxpython/gui_modules/georect.py:1184
+#: ../gui/wxpython/gui_modules/georect.py:1281
msgid "N coord"
msgstr "Coordenada N"
-#: ../gui/wxpython/gui_modules/georect.py:1185
+#: ../gui/wxpython/gui_modules/georect.py:1282
msgid "Forward error"
msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1186
+#: ../gui/wxpython/gui_modules/georect.py:1283
msgid "Backward error"
msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:1286
-#: ../gui/wxpython/gui_modules/georect.py:1394
+#: ../gui/wxpython/gui_modules/georect.py:1383
+#: ../gui/wxpython/gui_modules/georect.py:1525
msgid "Edit GCP"
msgstr "Editar GCP"
-#: ../gui/wxpython/gui_modules/georect.py:1287
+#: ../gui/wxpython/gui_modules/georect.py:1384
msgid "Invalid coordinate value. Operation cancelled."
msgstr "Valor de coordenada no válido. Operación cancelada."
#: ../gui/wxpython/gui_modules/georect.py:1405
+#, fuzzy
+msgid "Create vector map group"
+msgstr "Crear nuevo mapa vectorial"
+#: ../gui/wxpython/gui_modules/georect.py:1478
+#, fuzzy
+msgid "Select vector map(s) to add to group:"
+msgstr "Seleccionar mapa vectorial"
+#: ../gui/wxpython/gui_modules/georect.py:1536
msgid "Ground Control Point"
msgstr "Punto de control sobre el terreno"
-#: ../gui/wxpython/gui_modules/georect.py:1419
+#: ../gui/wxpython/gui_modules/georect.py:1550
msgid "X:"
msgstr "X:"
-#: ../gui/wxpython/gui_modules/georect.py:1420
+#: ../gui/wxpython/gui_modules/georect.py:1551
msgid "Y:"
msgstr "Y:"
-#: ../gui/wxpython/gui_modules/georect.py:1421
+#: ../gui/wxpython/gui_modules/georect.py:1552
msgid "E:"
msgstr "E:"
-#: ../gui/wxpython/gui_modules/georect.py:1422
+#: ../gui/wxpython/gui_modules/georect.py:1553
msgid "N:"
msgstr "N:"
-#: ../gui/wxpython/gui_modules/georect.py:1508
+#: ../gui/wxpython/gui_modules/georect.py:1639
msgid "Symbol settings"
msgstr "Configuración de sÃmbolos"
-#: ../gui/wxpython/gui_modules/georect.py:1517
-#: ../gui/wxpython/gui_modules/nviz_tools.py:558
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1247
+#: ../gui/wxpython/gui_modules/georect.py:1648
+#: ../gui/wxpython/gui_modules/preferences.py:1266
+#: ../gui/wxpython/gui_modules/nviz_tools.py:559
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1248
msgid "Color:"
msgstr "Color:"
-#: ../gui/wxpython/gui_modules/georect.py:1534
-#: ../gui/wxpython/gui_modules/nviz_tools.py:542
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1218
+#: ../gui/wxpython/gui_modules/georect.py:1665
+#: ../gui/wxpython/gui_modules/nviz_tools.py:543
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1219
msgid "Width:"
msgstr "Anchura:"
-#: ../gui/wxpython/gui_modules/georect.py:1562
-#: ../gui/wxpython/gui_modules/profile.py:1007
-#: ../gui/wxpython/gui_modules/profile.py:1352
-#: ../gui/wxpython/gui_modules/preferences.py:836
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1273
+#: ../gui/wxpython/gui_modules/georect.py:1693
+#: ../gui/wxpython/gui_modules/profile.py:1027
+#: ../gui/wxpython/gui_modules/profile.py:1372
+#: ../gui/wxpython/gui_modules/preferences.py:855
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1274
msgid "Apply changes for the current session"
msgstr "Aplicar cambios para la sesión actual"
-#: ../gui/wxpython/gui_modules/georect.py:1564
-#: ../gui/wxpython/gui_modules/profile.py:1009
-#: ../gui/wxpython/gui_modules/profile.py:1354
-#: ../gui/wxpython/gui_modules/preferences.py:838
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1275
+#: ../gui/wxpython/gui_modules/georect.py:1695
+#: ../gui/wxpython/gui_modules/profile.py:1029
+#: ../gui/wxpython/gui_modules/profile.py:1374
+#: ../gui/wxpython/gui_modules/preferences.py:857
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1276
msgid ""
"Apply and save changes to user settings file (default for next sessions)"
msgstr ""
"Aplicar y guardar los cambios en el archivo de configuración del usuario "
"(predeterminado para las próximas sesiones)"
-#: ../gui/wxpython/gui_modules/georect.py:1567
-#: ../gui/wxpython/gui_modules/profile.py:1012
-#: ../gui/wxpython/gui_modules/profile.py:1357
-#: ../gui/wxpython/gui_modules/preferences.py:841
-#: ../gui/wxpython/gui_modules/vdigit.py:1079
+#: ../gui/wxpython/gui_modules/georect.py:1698
+#: ../gui/wxpython/gui_modules/profile.py:1032
+#: ../gui/wxpython/gui_modules/profile.py:1377
+#: ../gui/wxpython/gui_modules/preferences.py:860
+#: ../gui/wxpython/gui_modules/vdigit.py:1102
msgid "Close dialog and ignore changes"
msgstr "Cerrar el diálogo e ignorar los cambios"
-#: ../gui/wxpython/gui_modules/georect.py:1594
+#: ../gui/wxpython/gui_modules/georect.py:1725
#, python-format
msgid "Georectifier settings saved to file '%s'."
msgstr "Configuración del georrectificador guardada en el archivo '%s'."
-#: ../gui/wxpython/gui_modules/menuform.py:139
-#: ../gui/wxpython/gui_modules/menuform.py:1257
+#: ../gui/wxpython/gui_modules/menuform.py:1419
msgid "Select Color"
-#: ../gui/wxpython/gui_modules/menuform.py:187
+#: ../gui/wxpython/gui_modules/menuform.py:329
msgid "unknown"
msgstr "desconocido"
-#: ../gui/wxpython/gui_modules/menuform.py:202
+#: ../gui/wxpython/gui_modules/menuform.py:344
#, python-format
msgid "Parameter not found: %s"
msgstr "No se ha encontrado el parámetro: %s"
-#: ../gui/wxpython/gui_modules/menuform.py:221
+#: ../gui/wxpython/gui_modules/menuform.py:363
#, python-format
msgid "Flag not found: %s"
msgstr "No se ha encontrado la opción: %s"
-#: ../gui/wxpython/gui_modules/menuform.py:255
+#: ../gui/wxpython/gui_modules/menuform.py:397
msgid "<required>"
msgstr "<requerido>"
-#: ../gui/wxpython/gui_modules/menuform.py:256
+#: ../gui/wxpython/gui_modules/menuform.py:398
msgid "Parameter %(name)s (%(desc)s) is missing.\n"
msgstr "nombre"
-#: ../gui/wxpython/gui_modules/menuform.py:627
+#: ../gui/wxpython/gui_modules/menuform.py:769
msgid "Enter parameters for "
msgstr "Introducir parámetro para "
-#: ../gui/wxpython/gui_modules/menuform.py:631
+#: ../gui/wxpython/gui_modules/menuform.py:773
#, fuzzy
msgid " (those in bold typeface are required)"
msgstr "requerido"
-#: ../gui/wxpython/gui_modules/menuform.py:642
+#: ../gui/wxpython/gui_modules/menuform.py:784
msgid "Close this window without executing the command"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:647
+#: ../gui/wxpython/gui_modules/menuform.py:789
msgid "Show manual page of the command"
msgstr "Mostrar página del manual de la orden"
-#: ../gui/wxpython/gui_modules/menuform.py:665
+#: ../gui/wxpython/gui_modules/menuform.py:809
msgid "&Run"
msgstr "Ejecuta&r"
-#: ../gui/wxpython/gui_modules/menuform.py:666
+#: ../gui/wxpython/gui_modules/menuform.py:810
msgid "Run the command"
msgstr "Ejecutar la orden"
-#: ../gui/wxpython/gui_modules/menuform.py:670
+#: ../gui/wxpython/gui_modules/menuform.py:814
msgid "Abort the running command"
msgstr "Abortar la orden que se está ejecutando"
-#: ../gui/wxpython/gui_modules/menuform.py:674
+#: ../gui/wxpython/gui_modules/menuform.py:818
msgid "Copy the current command string to the clipboard"
msgstr "Copiar la cadena actual de la orden al portapapeles"
-#: ../gui/wxpython/gui_modules/menuform.py:706
+#: ../gui/wxpython/gui_modules/menuform.py:850
#: ../gui/wxpython/gui_modules/gdialogs.py:68
-#: ../gui/wxpython/gui_modules/preferences.py:1138
+#: ../gui/wxpython/gui_modules/preferences.py:1170
msgid "Add created map into layer tree"
msgstr "Añadir el mapa creado al árbol de capas"
-#: ../gui/wxpython/gui_modules/menuform.py:715
-#: ../gui/wxpython/gui_modules/preferences.py:1128
+#: ../gui/wxpython/gui_modules/menuform.py:859
+#: ../gui/wxpython/gui_modules/preferences.py:1160
msgid "Close dialog on finish"
msgstr "Cerrar el diálogo al finalizar"
-#: ../gui/wxpython/gui_modules/menuform.py:827
+#: ../gui/wxpython/gui_modules/menuform.py:977
#, python-format
msgid "'%s' copied to clipboard"
msgstr "'%s' copiado al portapapeles"
-#: ../gui/wxpython/gui_modules/menuform.py:886
-#: ../gui/wxpython/gui_modules/menuform.py:899
-#: ../gui/wxpython/gui_modules/menuform.py:1407
+#: ../gui/wxpython/gui_modules/menuform.py:1036
+#: ../gui/wxpython/gui_modules/menuform.py:1049
+#: ../gui/wxpython/gui_modules/menuform.py:1568
msgid "Required"
msgstr "Requerido"
-#: ../gui/wxpython/gui_modules/menuform.py:889
+#: ../gui/wxpython/gui_modules/menuform.py:1039
msgid "Optional"
msgstr "Opcional"
-#: ../gui/wxpython/gui_modules/menuform.py:927 ../gui/wxpython/wxgui.py:310
-#: ../gui/wxpython/wxgui.py:401
+#: ../gui/wxpython/gui_modules/menuform.py:1077 ../gui/wxpython/wxgui.py:318
+#: ../gui/wxpython/wxgui.py:409
msgid "Command output"
msgstr "Salida de la orden"
-#: ../gui/wxpython/gui_modules/menuform.py:934
+#: ../gui/wxpython/gui_modules/menuform.py:1087
msgid "Manual"
msgstr "Manual"
-#: ../gui/wxpython/gui_modules/menuform.py:1009
+#: ../gui/wxpython/gui_modules/menuform.py:1181
msgid "[multiple]"
msgstr "[múltiple]"
-#: ../gui/wxpython/gui_modules/menuform.py:1058
+#: ../gui/wxpython/gui_modules/menuform.py:1228
msgid "Valid range"
msgstr "Intervalo válido"
-#: ../gui/wxpython/gui_modules/menuform.py:1276
+#: ../gui/wxpython/gui_modules/menuform.py:1438
msgid "Transparent"
msgstr "Transparente"
-#: ../gui/wxpython/gui_modules/menuform.py:1293
+#: ../gui/wxpython/gui_modules/menuform.py:1455
#, python-format
msgid "Choose %s"
msgstr "Seleccionar %s"
-#: ../gui/wxpython/gui_modules/menuform.py:1294
+#: ../gui/wxpython/gui_modules/menuform.py:1456
#: ../gui/wxpython/menustrings.py:2
msgid "File"
msgstr "Archivo"
-#: ../gui/wxpython/gui_modules/menuform.py:1628
+#: ../gui/wxpython/gui_modules/menuform.py:1720
msgid "Error in %s"
msgstr "Error"
-#: ../gui/wxpython/gui_modules/menuform.py:1662
+#: ../gui/wxpython/gui_modules/menuform.py:1754
#, python-format
msgid "Unable to fetch interface description for command '%s'."
msgstr "No se puede obtener la descripción de la interfaz para la orden '%s'."
-#: ../gui/wxpython/gui_modules/menuform.py:1746
+#: ../gui/wxpython/gui_modules/menuform.py:1844
#, python-format
msgid "Unable to parse command %s"
msgstr "No se puede analizar la orden %s"
-#: ../gui/wxpython/gui_modules/menuform.py:1835
+#: ../gui/wxpython/gui_modules/menuform.py:1933
#, python-format
msgid "usage: %s <grass command>"
msgstr "uso: %s <grass command>"
@@ -1299,11 +1369,11 @@
msgstr "Mostrar tabla de atributos"
#: ../gui/wxpython/gui_modules/gdialogs.py:127
-#: ../gui/wxpython/menustrings.py:461
+#: ../gui/wxpython/menustrings.py:463
msgid "Create new vector map"
-#: ../gui/wxpython/gui_modules/gdialogs.py:143
+#: ../gui/wxpython/gui_modules/gdialogs.py:142
#, python-format
msgid "Unable to create vector map <%s>."
msgstr "No se puede crear el mapa vectorial <%s>."
@@ -1319,20 +1389,20 @@
msgid "Overwrite?"
msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:205
+#: ../gui/wxpython/gui_modules/gdialogs.py:207
msgid "New vector map <%s> created"
msgstr "Nuevo mapa vectorial"
-#: ../gui/wxpython/gui_modules/gdialogs.py:227
+#: ../gui/wxpython/gui_modules/gdialogs.py:229
msgid "Load region:"
msgstr "Cargar región:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:235
+#: ../gui/wxpython/gui_modules/gdialogs.py:237
msgid "Save region:"
msgstr "Guardar región:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:306
+#: ../gui/wxpython/gui_modules/gdialogs.py:308
#, python-format
msgid ""
"Drag %s with mouse in pointer mode to position.\n"
@@ -1341,7 +1411,7 @@
"Arrastrar %s con el ratón en modo puntero a la posición.\n"
"Doble pulsación para cambiar las opciones."
-#: ../gui/wxpython/gui_modules/gdialogs.py:309
+#: ../gui/wxpython/gui_modules/gdialogs.py:311
msgid ""
"\n"
"Define raster map name for legend in properties dialog."
@@ -1349,25 +1419,25 @@
"\n"
"Definir nombre de mapa ráster para la leyenda en el diálogo de propiedades."
-#: ../gui/wxpython/gui_modules/gdialogs.py:361
+#: ../gui/wxpython/gui_modules/gdialogs.py:363
#, python-format
msgid "Legend of raster map <%s>"
msgstr "Leyenda del mapa ráster <%s>"
-#: ../gui/wxpython/gui_modules/gdialogs.py:484
+#: ../gui/wxpython/gui_modules/gdialogs.py:487
msgid "Enter text:"
msgstr "Introducir texto:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:497
+#: ../gui/wxpython/gui_modules/gdialogs.py:503
msgid "Rotation:"
msgstr "Rotación:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:510
-#: ../gui/wxpython/gui_modules/preferences.py:981
+#: ../gui/wxpython/gui_modules/gdialogs.py:516
+#: ../gui/wxpython/gui_modules/preferences.py:1000
msgid "Set font"
msgstr "Establecer tipo de letra"
-#: ../gui/wxpython/gui_modules/gdialogs.py:521
+#: ../gui/wxpython/gui_modules/gdialogs.py:527
msgid ""
"Drag text with mouse in pointer mode to position.\n"
"Double-click to change options"
@@ -1375,126 +1445,140 @@
"Arrastrar texto con el ratón en modo puntero a la posición.\n"
-#: ../gui/wxpython/gui_modules/gdialogs.py:613
+#: ../gui/wxpython/gui_modules/gdialogs.py:624
msgid "Load"
msgstr "Cargar"
-#: ../gui/wxpython/gui_modules/gdialogs.py:648
+#: ../gui/wxpython/gui_modules/gdialogs.py:653
msgid "Map layer type:"
msgstr "Tipo de capa de mapa:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:659
+#: ../gui/wxpython/gui_modules/gdialogs.py:665
+#, fuzzy
+msgid "Select toggle"
+msgstr "Seleccionar color"
+#: ../gui/wxpython/gui_modules/gdialogs.py:672
msgid "Mapset:"
msgstr "Directorio de mapas:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:672
+#: ../gui/wxpython/gui_modules/gdialogs.py:685
msgid "Filter:"
msgstr "Filtro:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:684
+#: ../gui/wxpython/gui_modules/gdialogs.py:697
msgid "List of maps:"
msgstr "Lista de mapas:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:737
-#: ../gui/wxpython/gui_modules/gdialogs.py:1092
-#: ../gui/wxpython/gui_modules/dbm.py:976
+#: ../gui/wxpython/gui_modules/gdialogs.py:753
+#: ../gui/wxpython/gui_modules/gdialogs.py:1130
+#: ../gui/wxpython/gui_modules/dbm.py:1001
msgid "Select all"
msgstr "Seleccionar todo"
-#: ../gui/wxpython/gui_modules/gdialogs.py:738
-#: ../gui/wxpython/gui_modules/gdialogs.py:1093
-#: ../gui/wxpython/gui_modules/dbm.py:977
+#: ../gui/wxpython/gui_modules/gdialogs.py:754
+#, fuzzy
+msgid "Invert selection"
+msgstr "Cambiar nombre de la localización seleccionada"
+#: ../gui/wxpython/gui_modules/gdialogs.py:755
+#: ../gui/wxpython/gui_modules/gdialogs.py:1131
+#: ../gui/wxpython/gui_modules/dbm.py:1002
msgid "Deselect all"
msgstr "Deseleccionar todo"
-#: ../gui/wxpython/gui_modules/gdialogs.py:795
+#: ../gui/wxpython/gui_modules/gdialogs.py:828
#, fuzzy
msgid "Multiple import"
msgstr "Importación de DXF múltiple"
-#: ../gui/wxpython/gui_modules/gdialogs.py:809
+#: ../gui/wxpython/gui_modules/gdialogs.py:839
msgid "Input DXF file"
msgstr "Archivo DXF de entrada"
-#: ../gui/wxpython/gui_modules/gdialogs.py:810
+#: ../gui/wxpython/gui_modules/gdialogs.py:841
+#, fuzzy
+msgid "Input directory"
+#: ../gui/wxpython/gui_modules/gdialogs.py:846
+msgid " List of %s layers "
+msgstr "Lista de capas"
+#: ../gui/wxpython/gui_modules/gdialogs.py:852
msgid "Choose DXF file:"
msgstr "Seleccionar archivo DXF:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:813
+#: ../gui/wxpython/gui_modules/gdialogs.py:855
msgid "Choose DXF file to import"
msgstr "Seleccionar archivo DXF a importar"
-#: ../gui/wxpython/gui_modules/gdialogs.py:819
+#: ../gui/wxpython/gui_modules/gdialogs.py:861
#, fuzzy
-msgid "Input directory"
-msgstr "Directorio de datos de SIG:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:820
-#, fuzzy
msgid "Choose directory:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:823
+#: ../gui/wxpython/gui_modules/gdialogs.py:864
#, fuzzy
msgid "Choose input directory"
-#: ../gui/wxpython/gui_modules/gdialogs.py:827
+#: ../gui/wxpython/gui_modules/gdialogs.py:868
#, fuzzy
msgid "Select file extension:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:844
+#: ../gui/wxpython/gui_modules/gdialogs.py:885
+#: ../gui/wxpython/gui_modules/ogc_services.py:69
msgid "Add imported layers into layer tree"
msgstr "Añadir las capas importadas al árbol de capas"
-#: ../gui/wxpython/gui_modules/gdialogs.py:852
+#: ../gui/wxpython/gui_modules/gdialogs.py:893
+#: ../gui/wxpython/gui_modules/ogc_services.py:77
msgid "Close dialog"
msgstr "Cerrar diálogo"
-#: ../gui/wxpython/gui_modules/gdialogs.py:855
+#: ../gui/wxpython/gui_modules/gdialogs.py:896
+#: ../gui/wxpython/gui_modules/ogc_services.py:85
msgid "&Import"
msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:856
+#: ../gui/wxpython/gui_modules/gdialogs.py:897
+#: ../gui/wxpython/gui_modules/ogc_services.py:86
msgid "Import selected layers"
msgstr "Importar las capas seleccionadas"
-#: ../gui/wxpython/gui_modules/gdialogs.py:896
-#, fuzzy, python-format
-msgid " List of %s layers "
-msgstr "Lista de capas"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1055
-#: ../gui/wxpython/gui_modules/dbm.py:2090
-#: ../gui/wxpython/gui_modules/dbm.py:2195
-#: ../gui/wxpython/gui_modules/dbm.py:2453
-#: ../gui/wxpython/gui_modules/dbm.py:3263
-#: ../gui/wxpython/gui_modules/vdigit.py:1386
-#: ../gui/wxpython/gui_modules/vdigit.py:1388
-#: ../gui/wxpython/gui_modules/vdigit.py:1769
-#: ../gui/wxpython/gui_modules/vdigit.py:2201
+#: ../gui/wxpython/gui_modules/gdialogs.py:1093
+#: ../gui/wxpython/gui_modules/dbm.py:2099
+#: ../gui/wxpython/gui_modules/dbm.py:2204
+#: ../gui/wxpython/gui_modules/dbm.py:2459
+#: ../gui/wxpython/gui_modules/vdigit.py:1409
+#: ../gui/wxpython/gui_modules/vdigit.py:1411
+#: ../gui/wxpython/gui_modules/vdigit.py:1818
+#: ../gui/wxpython/gui_modules/vdigit.py:2250
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:424
msgid "Layer"
msgstr "Capa"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1056
+#: ../gui/wxpython/gui_modules/gdialogs.py:1094
msgid "Layer name"
msgstr "Nombre de capa"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1057
+#: ../gui/wxpython/gui_modules/gdialogs.py:1095
#, fuzzy
-msgid "Output vector map name"
-msgstr "Nombre del mapa vectorial de salida (editable)"
+msgid "Name for GRASS map"
+msgstr "Nombre para el nuevo mapa vectorial:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1139
+#: ../gui/wxpython/gui_modules/gdialogs.py:1177
msgid "Set Map Layer Opacity"
msgstr "Establecer opacidad de la capa de mapa"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1163
+#: ../gui/wxpython/gui_modules/gdialogs.py:1201
msgid "transparent"
msgstr "transparente"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1166
+#: ../gui/wxpython/gui_modules/gdialogs.py:1204
msgid "opaque"
msgstr "opaco"
@@ -1588,7 +1672,7 @@
msgstr "Mostrar mostrar."
#: ../gui/wxpython/gui_modules/mapdisp.py:183
-#: ../gui/wxpython/gui_modules/preferences.py:1069
+#: ../gui/wxpython/gui_modules/preferences.py:1088
#, fuzzy
msgid "Constrain display resolution to computational settings"
msgstr "mostrar"
@@ -1604,19 +1688,44 @@
msgid "Map Toolbar"
msgstr "Barra de herramientas de mapa"
-#: ../gui/wxpython/gui_modules/mapdisp.py:310
+#: ../gui/wxpython/gui_modules/mapdisp.py:302
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:504
+msgid ""
+"Unable to start vector digitizer.\n"
+"The VDigit python extension was not found or loaded properly.\n"
+"Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
+msgstr ""
+"No se puede iniciar Nviz. No se encontró la extensión de Python para Nviz. "
+"Se vuelve al modo de visualización 2D.\n"
+"\n"
+"Detalles: %s"
+#: ../gui/wxpython/gui_modules/mapdisp.py:306
+#: ../gui/wxpython/gui_modules/mapdisp.py:364
+#: ../gui/wxpython/gui_modules/mapdisp.py:476
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:508
+#: ../gui/wxpython/gui_modules/toolbars.py:163
+#: ../gui/wxpython/gui_modules/toolbars.py:164
+msgid "2D view"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:324
msgid "Vector digitizer toolbar"
msgstr "Barra de herramientas del digitalizador vectorial"
-#: ../gui/wxpython/gui_modules/mapdisp.py:328
+#: ../gui/wxpython/gui_modules/mapdisp.py:342
msgid "Georectification toolbar"
msgstr "Barra de herramientas de georrectificación"
-#: ../gui/wxpython/gui_modules/mapdisp.py:340
-#, python-format
+#: ../gui/wxpython/gui_modules/mapdisp.py:354
msgid ""
-"Unable to start Nviz. The GLCanvas class has not been included with this "
-"build of wxPython! Switching back to 2D display mode.\n"
+"Unable to switch to 3D display mode.\n"
+"The GLCanvas class has not been included with this build of wxPython!\n"
"\n"
"Details: %s"
msgstr ""
@@ -1625,24 +1734,12 @@
"\n"
"Detalles: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:345
-#, python-format
-msgid ""
-"Unable to start Nviz. The OpenGL package was not found. You can get it at "
-"http://PyOpenGL.sourceforge.net. Switching back to 2D display mode.\n"
-"\n"
-"Details: %s"
-msgstr ""
-"No se puede iniciar Zviz. !No se encontró el paquete OpenGL. Puede obtenerlo "
-"en http://PyOpenGL.sourceforge.net. Se vuelve al modo de visualización 2D.\n"
-"\n"
-"Detalles: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:350
+#: ../gui/wxpython/gui_modules/mapdisp.py:359
msgid ""
-"Unable to start Nviz. Python extension for Nviz was not found or loaded "
-"properly. Switching back to 2D display mode.\n"
+"The Nviz python extension was not found or loaded properly.\n"
"\n"
"Details: %s"
msgstr ""
@@ -1651,59 +1748,62 @@
"\n"
"Detalles: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:382
+#: ../gui/wxpython/gui_modules/mapdisp.py:393
msgid "Please wait, loading data..."
msgstr "Por favor espere, cargando datos..."
-#: ../gui/wxpython/gui_modules/mapdisp.py:412
+#: ../gui/wxpython/gui_modules/mapdisp.py:422
msgid "Nviz toolbar"
msgstr "Barra de herramientas de Nviz"
-#: ../gui/wxpython/gui_modules/mapdisp.py:465
-#: ../gui/wxpython/gui_modules/toolbars.py:163
-#: ../gui/wxpython/gui_modules/toolbars.py:164
-msgid "2D view"
-msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:956
+#: ../gui/wxpython/gui_modules/mapdisp.py:967
msgid "Choose a file name to save the image (no need to add extension)"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1001
+#: ../gui/wxpython/gui_modules/mapdisp.py:1012
msgid "Page setup"
msgstr "Configuración de página"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1005
+#: ../gui/wxpython/gui_modules/mapdisp.py:1016
msgid "Print preview"
msgstr "Vista previa de impresión"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1099
+#: ../gui/wxpython/gui_modules/mapdisp.py:1110
msgid "No map layer selected for querying."
msgstr "Ninguna capa de mapa seleccionada para consultar."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1100
-#: ../gui/wxpython/gui_modules/mapdisp.py:1184
-#: ../gui/wxpython/gui_modules/dbm.py:1894
-#: ../gui/wxpython/gui_modules/dbm.py:1914
-#: ../gui/wxpython/gui_modules/dbm.py:2914 ../gui/wxpython/wxgui.py:1154
-#: ../gui/wxpython/wxgui.py:1546
+#: ../gui/wxpython/gui_modules/mapdisp.py:1111
+#: ../gui/wxpython/gui_modules/dbm.py:1903
+#: ../gui/wxpython/gui_modules/dbm.py:1923
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:81 ../gui/wxpython/wxgui.py:1198
+#: ../gui/wxpython/wxgui.py:1591
msgid "Message"
msgstr "Mensaje"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1183
+#: ../gui/wxpython/gui_modules/mapdisp.py:1193
msgid "No vector map selected for querying."
msgstr "Ningún mapa vectorial seleccionado para consultar."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1250
+#: ../gui/wxpython/gui_modules/mapdisp.py:1194
+#: ../gui/wxpython/gui_modules/mapdisp.py:1202
+#, fuzzy
+msgid "Vector querying"
+msgstr "Configuración de tipo de letra"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1201
+msgid "Only vector map from the current mapset can be modified."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1271
msgid "Query raster/vector map(s) (display mode)"
msgstr "Consultar mapa(s) ráster/vectorial (modo visualización)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1258
+#: ../gui/wxpython/gui_modules/mapdisp.py:1279
#, fuzzy
msgid "Query vector map (edit mode)"
msgstr "Consultar mapa vectorial (modo editable)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1372
+#: ../gui/wxpython/gui_modules/mapdisp.py:1394
#, python-format
msgid ""
"Click and drag with left mouse button to measure.%sDouble click with left "
@@ -1712,73 +1812,74 @@
"Pulse y arrastre con el botón izquierdo del ratón para medir. %sDoble clic "
"izquierdo para limpiar."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1379
+#: ../gui/wxpython/gui_modules/mapdisp.py:1401
msgid "Measuring distance"
msgstr "Midiendo distancia"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1383
+#: ../gui/wxpython/gui_modules/mapdisp.py:1405
msgid "Measuring distance:"
msgstr "Midiendo distancia:"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1544
+#: ../gui/wxpython/gui_modules/mapdisp.py:1567
msgid "Scale and North arrow"
msgstr "Escala y flecha de Norte"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1550
+#: ../gui/wxpython/gui_modules/mapdisp.py:1573
msgid "Show/hide scale and North arrow"
msgstr "Mostrar/ocultar escala y flecha de Norte"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1551
+#: ../gui/wxpython/gui_modules/mapdisp.py:1574
msgid "scale object"
msgstr "objeto de escala"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1581
+#: ../gui/wxpython/gui_modules/mapdisp.py:1604
msgid "Show/hide legend"
msgstr "Mostrar/ocultar leyenda"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1582
+#: ../gui/wxpython/gui_modules/mapdisp.py:1605
msgid "legend object"
msgstr "objeto de leyenda"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1654
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:268
-msgid "Zoom to selected map"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1677
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:272
+#, fuzzy
+msgid "Zoom to selected map(s)"
msgstr "Zum al mapa seleccionado"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1658
+#: ../gui/wxpython/gui_modules/mapdisp.py:1681
#, fuzzy
msgid "Zoom to computational region (set with g.region)"
msgstr "Zum"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1662
+#: ../gui/wxpython/gui_modules/mapdisp.py:1685
msgid "Zoom to default region"
msgstr "Zum a la región predeterminada"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1666
+#: ../gui/wxpython/gui_modules/mapdisp.py:1689
msgid "Zoom to saved region"
msgstr "Zum a una región guardada"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1670
+#: ../gui/wxpython/gui_modules/mapdisp.py:1693
#, fuzzy
msgid "Set computational region from display"
msgstr "mostrar"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1674
+#: ../gui/wxpython/gui_modules/mapdisp.py:1697
msgid "Save display geometry to named region"
msgstr "Guardar la geometrÃa de la visualización a la región nombrada"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1756
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:109
+#: ../gui/wxpython/gui_modules/mapdisp.py:1794
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:111
#, fuzzy
msgid "GRASS GIS Map Display: "
msgstr "Mostrar "
-#: ../gui/wxpython/gui_modules/workspace.py:616
+#: ../gui/wxpython/gui_modules/workspace.py:630
#, python-format
msgid "Unable to open file <%s> for reading."
msgstr ""
-#: ../gui/wxpython/gui_modules/workspace.py:629
+#: ../gui/wxpython/gui_modules/workspace.py:643
msgid ""
"Some lines were skipped when reading settings from file <%(file)s>.\n"
@@ -1787,301 +1888,305 @@
"Number of skipped lines: %(line)d"
msgstr "lÃneas lÃneas"
-#: ../gui/wxpython/gui_modules/workspace.py:633
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:2512
+#: ../gui/wxpython/gui_modules/workspace.py:647
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:2561
msgid "Warning"
msgstr "Aviso"
-#: ../gui/wxpython/gui_modules/workspace.py:847
+#: ../gui/wxpython/gui_modules/workspace.py:861
#, python-format
msgid " row %d:"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:65
+#: ../gui/wxpython/gui_modules/profile.py:66
#, fuzzy
msgid "Profile Analysis"
msgstr "Análisis del terreno"
-#: ../gui/wxpython/gui_modules/profile.py:153
-#: ../gui/wxpython/gui_modules/profile.py:272
+#: ../gui/wxpython/gui_modules/profile.py:156
+#: ../gui/wxpython/gui_modules/profile.py:275
msgid "Profile of"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:157
+#: ../gui/wxpython/gui_modules/profile.py:160
#, python-format
msgid "Distance (%s)"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:159
+#: ../gui/wxpython/gui_modules/profile.py:162
msgid "Distance along transect"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:160
+#: ../gui/wxpython/gui_modules/profile.py:163
#, fuzzy
msgid "Cell values"
msgstr "Cambiar valores"
-#: ../gui/wxpython/gui_modules/profile.py:282
+#: ../gui/wxpython/gui_modules/profile.py:320
#, python-format
msgid "Profile of %s"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:312
+#: ../gui/wxpython/gui_modules/profile.py:350
#, fuzzy
msgid "Raster values"
msgstr "ráster"
-#: ../gui/wxpython/gui_modules/profile.py:447
+#: ../gui/wxpython/gui_modules/profile.py:467
msgid "You must draw a transect to profile in the map display window."
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:448
+#: ../gui/wxpython/gui_modules/profile.py:468
msgid "Nothing to profile"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:658
+#: ../gui/wxpython/gui_modules/profile.py:678
#, fuzzy
msgid "Profile text settings"
-#: ../gui/wxpython/gui_modules/profile.py:685
+#: ../gui/wxpython/gui_modules/profile.py:705
#, fuzzy
msgid "Profile settings"
msgstr "Mostrar configuración"
-#: ../gui/wxpython/gui_modules/profile.py:748
+#: ../gui/wxpython/gui_modules/profile.py:768
#, fuzzy
msgid "Select raster map to profile"
msgstr "ráster:"
-#: ../gui/wxpython/gui_modules/profile.py:783
+#: ../gui/wxpython/gui_modules/profile.py:803
#, fuzzy
msgid "Select raster map 1 (required):"
msgstr "ráster"
-#: ../gui/wxpython/gui_modules/profile.py:784
+#: ../gui/wxpython/gui_modules/profile.py:804
#, fuzzy
msgid "Select raster map 2 (optional):"
msgstr "ráster"
-#: ../gui/wxpython/gui_modules/profile.py:785
+#: ../gui/wxpython/gui_modules/profile.py:805
#, fuzzy
msgid "Select raster map 3 (optional):"
msgstr "ráster"
-#: ../gui/wxpython/gui_modules/profile.py:879
+#: ../gui/wxpython/gui_modules/profile.py:899
#, fuzzy
msgid "Text settings"
-#: ../gui/wxpython/gui_modules/profile.py:886
+#: ../gui/wxpython/gui_modules/profile.py:906
msgid "Profile title:"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:896
+#: ../gui/wxpython/gui_modules/profile.py:916
msgid "Title font size (pts):"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:917
+#: ../gui/wxpython/gui_modules/profile.py:937
msgid "Y-axis label:"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:927
+#: ../gui/wxpython/gui_modules/profile.py:947
msgid "Label font size (pts):"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:942
-#: ../gui/wxpython/gui_modules/preferences.py:965
-#: ../gui/wxpython/gui_modules/preferences.py:1605
+#: ../gui/wxpython/gui_modules/profile.py:962
+#: ../gui/wxpython/gui_modules/preferences.py:984
+#: ../gui/wxpython/gui_modules/preferences.py:1638
msgid "Font settings"
-#: ../gui/wxpython/gui_modules/profile.py:950
+#: ../gui/wxpython/gui_modules/profile.py:970
msgid "Font family:"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:964
+#: ../gui/wxpython/gui_modules/profile.py:984
msgid "Style:"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:978
+#: ../gui/wxpython/gui_modules/profile.py:998
msgid "Weight:"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1060
-#: ../gui/wxpython/gui_modules/profile.py:1405
+#: ../gui/wxpython/gui_modules/profile.py:1080
+#: ../gui/wxpython/gui_modules/profile.py:1425
msgid "Profile settings saved to file '%s'."
msgstr "Configuraciones."
-#: ../gui/wxpython/gui_modules/profile.py:1116
+#: ../gui/wxpython/gui_modules/profile.py:1136
#, fuzzy
msgid "Profile line settings"
-#: ../gui/wxpython/gui_modules/profile.py:1126
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:345
+#: ../gui/wxpython/gui_modules/profile.py:1146
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:358
msgid "Profile"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1131
+#: ../gui/wxpython/gui_modules/profile.py:1151
msgid "Line color"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1138
-#: ../gui/wxpython/gui_modules/vdigit.py:1152
+#: ../gui/wxpython/gui_modules/profile.py:1158
+#: ../gui/wxpython/gui_modules/vdigit.py:1175
msgid "Line width"
msgstr "Anchura de lÃnea"
-#: ../gui/wxpython/gui_modules/profile.py:1148
+#: ../gui/wxpython/gui_modules/profile.py:1168
#, fuzzy
msgid "Line style"
-#: ../gui/wxpython/gui_modules/profile.py:1157
-#: ../gui/wxpython/gui_modules/profile.py:1209
+#: ../gui/wxpython/gui_modules/profile.py:1177
+#: ../gui/wxpython/gui_modules/profile.py:1229
msgid "Legend"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1181
+#: ../gui/wxpython/gui_modules/profile.py:1201
msgid "Transect segment marker settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1186
-#: ../gui/wxpython/gui_modules/nviz_tools.py:255
-#: ../gui/wxpython/gui_modules/nviz_tools.py:853
+#: ../gui/wxpython/gui_modules/profile.py:1206
+#: ../gui/wxpython/gui_modules/nviz_tools.py:256
+#: ../gui/wxpython/gui_modules/nviz_tools.py:854
#, fuzzy
msgid "Color"
msgstr "Reglas de color"
-#: ../gui/wxpython/gui_modules/profile.py:1192
+#: ../gui/wxpython/gui_modules/profile.py:1212
msgid "Size"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1201
-#: ../gui/wxpython/gui_modules/profile.py:1247
+#: ../gui/wxpython/gui_modules/profile.py:1221
+#: ../gui/wxpython/gui_modules/profile.py:1267
msgid "Style"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1216
+#: ../gui/wxpython/gui_modules/profile.py:1236
msgid "Type"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1231
+#: ../gui/wxpython/gui_modules/profile.py:1251
#, fuzzy
msgid "Axis settings"
msgstr "ráster"
-#: ../gui/wxpython/gui_modules/profile.py:1237
+#: ../gui/wxpython/gui_modules/profile.py:1257
msgid "X-Axis"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1238
+#: ../gui/wxpython/gui_modules/profile.py:1258
msgid "Y-Axis"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1256
+#: ../gui/wxpython/gui_modules/profile.py:1276
msgid "Custom min"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1264
+#: ../gui/wxpython/gui_modules/profile.py:1284
msgid "Custom max"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1272
+#: ../gui/wxpython/gui_modules/profile.py:1292
#, fuzzy
msgid "Log scale"
msgstr "Rescalar"
-#: ../gui/wxpython/gui_modules/profile.py:1296
+#: ../gui/wxpython/gui_modules/profile.py:1316
#, fuzzy
msgid "Grid and Legend settings"
msgstr "Configuración avanzada"
-#: ../gui/wxpython/gui_modules/profile.py:1301
+#: ../gui/wxpython/gui_modules/profile.py:1321
msgid "Grid color"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1308
+#: ../gui/wxpython/gui_modules/profile.py:1328
msgid "Show grid"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1314
+#: ../gui/wxpython/gui_modules/profile.py:1334
msgid "Legend font size"
msgstr ""
-#: ../gui/wxpython/gui_modules/profile.py:1324
+#: ../gui/wxpython/gui_modules/profile.py:1344
msgid "Show legend"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:366
+#: ../gui/wxpython/gui_modules/preferences.py:380
msgid "Segment break"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:498
+#: ../gui/wxpython/gui_modules/preferences.py:513
msgid "Collapse all except PERMANENT and current"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:499
+#: ../gui/wxpython/gui_modules/preferences.py:514
msgid "Collapse all except PERMANENT"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:500
+#: ../gui/wxpython/gui_modules/preferences.py:515
+msgid "Collapse all except current"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:516
msgid "Collapse all"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:501
+#: ../gui/wxpython/gui_modules/preferences.py:517
msgid "Expand all"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:502
-#: ../gui/wxpython/gui_modules/dbm.py:968
+#: ../gui/wxpython/gui_modules/preferences.py:518
+#: ../gui/wxpython/gui_modules/dbm.py:993
msgid "Edit selected record"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:503
+#: ../gui/wxpython/gui_modules/preferences.py:519
msgid "Display selected"
msgstr "Mostrar lo seleccionado"
-#: ../gui/wxpython/gui_modules/preferences.py:529
+#: ../gui/wxpython/gui_modules/preferences.py:545
msgid "box"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:530
+#: ../gui/wxpython/gui_modules/preferences.py:546
msgid "sphere"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:531
+#: ../gui/wxpython/gui_modules/preferences.py:547
msgid "cube"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:532
+#: ../gui/wxpython/gui_modules/preferences.py:548
msgid "diamond"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:533
+#: ../gui/wxpython/gui_modules/preferences.py:549
msgid "dtree"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:534
+#: ../gui/wxpython/gui_modules/preferences.py:550
msgid "ctree"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:535
+#: ../gui/wxpython/gui_modules/preferences.py:551
#, fuzzy
msgid "aster"
msgstr "ráster"
-#: ../gui/wxpython/gui_modules/preferences.py:536
+#: ../gui/wxpython/gui_modules/preferences.py:552
msgid "gyro"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:537
+#: ../gui/wxpython/gui_modules/preferences.py:553
#, fuzzy
msgid "histogram"
msgstr "Establecer opciones"
-#: ../gui/wxpython/gui_modules/preferences.py:605
+#: ../gui/wxpython/gui_modules/preferences.py:621
#, python-format
msgid ""
"Error: Reading settings from file <%(file)s> failed.\n"
@@ -2089,11 +2194,11 @@
" Line: '%(line)s'"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:637
+#: ../gui/wxpython/gui_modules/preferences.py:653
msgid "Uknown settings file location."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:668
+#: ../gui/wxpython/gui_modules/preferences.py:684
#, python-format
msgid ""
"Writing settings to file <%(file)s> failed.\n"
@@ -2101,543 +2206,550 @@
"Details: %(detail)s"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:767
+#: ../gui/wxpython/gui_modules/preferences.py:786
msgid "Unable to set "
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:802
+#: ../gui/wxpython/gui_modules/preferences.py:821
msgid "User GUI settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:826
+#: ../gui/wxpython/gui_modules/preferences.py:845
msgid "Set to default"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:834
+#: ../gui/wxpython/gui_modules/preferences.py:853
msgid "Revert settings to default and apply changes"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:869
-#: ../gui/wxpython/gui_modules/vdigit.py:1140
-#: ../gui/wxpython/gui_modules/nviz_tools.py:960
+#: ../gui/wxpython/gui_modules/preferences.py:888
+#: ../gui/wxpython/gui_modules/vdigit.py:1163
+#: ../gui/wxpython/gui_modules/nviz_tools.py:961
msgid "General"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:872
+#: ../gui/wxpython/gui_modules/preferences.py:891
msgid "General settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:883
+#: ../gui/wxpython/gui_modules/preferences.py:902
msgid "Element list:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:905
+#: ../gui/wxpython/gui_modules/preferences.py:924
#, fuzzy
msgid "Save current window layout as default"
msgstr "Guardar entorno de trabajo actual como archivo"
-#: ../gui/wxpython/gui_modules/preferences.py:908
+#: ../gui/wxpython/gui_modules/preferences.py:927
msgid ""
"Save current position and size of Layer Manager window and opened Map "
"Display window(s) and use as default for next sessions."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:921
+#: ../gui/wxpython/gui_modules/preferences.py:940
#, fuzzy
msgid "Layer Manager settings"
msgstr "Capa"
-#: ../gui/wxpython/gui_modules/preferences.py:933
+#: ../gui/wxpython/gui_modules/preferences.py:952
msgid "Ask when removing map layer from layer tree"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:943
+#: ../gui/wxpython/gui_modules/preferences.py:962
msgid "Ask when quiting wxGUI or closing display"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:961
-#: ../gui/wxpython/gui_modules/vdigit.py:1147
+#: ../gui/wxpython/gui_modules/preferences.py:980
+#: ../gui/wxpython/gui_modules/vdigit.py:1170
msgid "Display"
msgstr "Mostrar"
-#: ../gui/wxpython/gui_modules/preferences.py:976
+#: ../gui/wxpython/gui_modules/preferences.py:995
msgid "Default font for GRASS displays:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:990
+#: ../gui/wxpython/gui_modules/preferences.py:1009
#, fuzzy
msgid "Default display settings"
msgstr "mostrar"
-#: ../gui/wxpython/gui_modules/preferences.py:1001
+#: ../gui/wxpython/gui_modules/preferences.py:1020
#, fuzzy
msgid "Display driver:"
msgstr "Mostrar:"
-#: ../gui/wxpython/gui_modules/preferences.py:1030
+#: ../gui/wxpython/gui_modules/preferences.py:1049
#, fuzzy
msgid "Statusbar mode:"
msgstr "Código del datum:"
-#: ../gui/wxpython/gui_modules/preferences.py:1050
-#: ../gui/wxpython/gui_modules/nviz_tools.py:966
+#: ../gui/wxpython/gui_modules/preferences.py:1069
+#: ../gui/wxpython/gui_modules/nviz_tools.py:967
#, fuzzy
msgid "Background color:"
msgstr "vectorial"
-#: ../gui/wxpython/gui_modules/preferences.py:1082
+#: ../gui/wxpython/gui_modules/preferences.py:1101
msgid "Enable auto-rendering"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1103
+#: ../gui/wxpython/gui_modules/preferences.py:1114
+#, fuzzy
+msgid "Enable auto-zooming to selected map layer"
+msgstr "ráster."
+#: ../gui/wxpython/gui_modules/preferences.py:1135
msgid "Command"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1106
+#: ../gui/wxpython/gui_modules/preferences.py:1138
msgid "Command dialog settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1118
+#: ../gui/wxpython/gui_modules/preferences.py:1150
msgid "Allow output files to overwrite existing files"
msgstr "Permitir que los archivos de salida sobrescriban archivos existente"
-#: ../gui/wxpython/gui_modules/preferences.py:1148
+#: ../gui/wxpython/gui_modules/preferences.py:1180
msgid "Verbosity level:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1167
+#: ../gui/wxpython/gui_modules/preferences.py:1199
#, fuzzy
msgid "Raster settings"
msgstr "ráster"
-#: ../gui/wxpython/gui_modules/preferences.py:1178
+#: ../gui/wxpython/gui_modules/preferences.py:1210
msgid "Overlay raster maps"
msgstr "Superponer mapas ráster"
-#: ../gui/wxpython/gui_modules/preferences.py:1192
+#: ../gui/wxpython/gui_modules/preferences.py:1224
#, fuzzy
msgid "Vector settings"
-#: ../gui/wxpython/gui_modules/preferences.py:1198
-#: ../gui/wxpython/gui_modules/nviz_tools.py:573
+#: ../gui/wxpython/gui_modules/preferences.py:1230
+#: ../gui/wxpython/gui_modules/nviz_tools.py:574
#, fuzzy
msgid "Display:"
msgstr "Mostrar"
-#: ../gui/wxpython/gui_modules/preferences.py:1220
-#: ../gui/wxpython/gui_modules/vdigit.py:1368
+#: ../gui/wxpython/gui_modules/preferences.py:1252
+#: ../gui/wxpython/gui_modules/vdigit.py:1391
msgid "Attributes"
msgstr "Atributos"
-#: ../gui/wxpython/gui_modules/preferences.py:1228
+#: ../gui/wxpython/gui_modules/preferences.py:1260
msgid "Highlighting"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1244
+#: ../gui/wxpython/gui_modules/preferences.py:1276
#, fuzzy
-msgid "Line width (in pixels)"
+msgid "Line width (in pixels):"
msgstr "LÃnea"
-#: ../gui/wxpython/gui_modules/preferences.py:1267
+#: ../gui/wxpython/gui_modules/preferences.py:1299
msgid "Data browser"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1272
-msgid "Left mouse double click"
+#: ../gui/wxpython/gui_modules/preferences.py:1304
+msgid "Left mouse double click:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1283
-msgid "Encoding"
+#: ../gui/wxpython/gui_modules/preferences.py:1316
+msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1294
+#: ../gui/wxpython/gui_modules/preferences.py:1327
#, fuzzy
msgid "Ask when deleting data record(s) from table"
msgstr "Borrar"
-#: ../gui/wxpython/gui_modules/preferences.py:1315
+#: ../gui/wxpython/gui_modules/preferences.py:1348
#, fuzzy
msgid "Create table"
msgstr "Crear etiquetas"
-#: ../gui/wxpython/gui_modules/preferences.py:1322
-#: ../gui/wxpython/gui_modules/dbm.py:2217
-#: ../gui/wxpython/gui_modules/dbm.py:2249
-#: ../gui/wxpython/gui_modules/dbm.py:2479
-msgid "Key column"
-msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1355
+#, fuzzy
+msgid "Key column:"
+msgstr "Cambiar nombre de columna"
-#: ../gui/wxpython/gui_modules/preferences.py:1348
+#: ../gui/wxpython/gui_modules/preferences.py:1381
#: ../gui/wxpython/menustrings.py:3
msgid "Workspace"
msgstr "Entorno de trabajo"
-#: ../gui/wxpython/gui_modules/preferences.py:1351
+#: ../gui/wxpython/gui_modules/preferences.py:1384
#, fuzzy
msgid "Loading workspace"
msgstr "Guardar entorno de trabajo"
-#: ../gui/wxpython/gui_modules/preferences.py:1363
+#: ../gui/wxpython/gui_modules/preferences.py:1396
msgid "Suppress positioning Map Display Window(s)"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1374
+#: ../gui/wxpython/gui_modules/preferences.py:1407
msgid "Suppress positioning Layer Manager window"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1392
-#: ../gui/wxpython/gui_modules/dbm.py:597
+#: ../gui/wxpython/gui_modules/preferences.py:1425
+#: ../gui/wxpython/gui_modules/dbm.py:616
msgid "Advanced"
msgstr "Avanzado"
-#: ../gui/wxpython/gui_modules/preferences.py:1395
+#: ../gui/wxpython/gui_modules/preferences.py:1428
msgid "Advanced settings"
-#: ../gui/wxpython/gui_modules/preferences.py:1407
+#: ../gui/wxpython/gui_modules/preferences.py:1440
msgid "Place where to store settings:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1428
+#: ../gui/wxpython/gui_modules/preferences.py:1461
msgid "Icon theme:"
msgstr "Tema de iconos:"
-#: ../gui/wxpython/gui_modules/preferences.py:1446
+#: ../gui/wxpython/gui_modules/preferences.py:1479
msgid ""
"Note: For changing the icon theme, you must save the settings and restart "
"this GUI."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1461
+#: ../gui/wxpython/gui_modules/preferences.py:1494
#, fuzzy
msgid "Select default display font"
msgstr "mostrar"
-#: ../gui/wxpython/gui_modules/preferences.py:1485
+#: ../gui/wxpython/gui_modules/preferences.py:1518
msgid "Settings saved to file '%s'."
-#: ../gui/wxpython/gui_modules/preferences.py:1545
+#: ../gui/wxpython/gui_modules/preferences.py:1578
msgid "Key column cannot be empty string."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1612
+#: ../gui/wxpython/gui_modules/preferences.py:1645
#, fuzzy
msgid "Select font:"
msgstr "Seleccionar tipo de letra"
-#: ../gui/wxpython/gui_modules/preferences.py:1716
+#: ../gui/wxpython/gui_modules/preferences.py:1749
msgid "Set/unset access to mapsets in current location"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1730
+#: ../gui/wxpython/gui_modules/preferences.py:1763
#, python-format
msgid ""
"Check mapset to make it accessible, uncheck it to hide it.%sNote: PERMANENT "
"and current mapset are always accessible."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1797
+#: ../gui/wxpython/gui_modules/preferences.py:1830
msgid "Mapset"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1798
+#: ../gui/wxpython/gui_modules/preferences.py:1831
msgid "Owner"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1799
-msgid "Group"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:71
-#: ../gui/wxpython/gui_modules/dbm.py:260
+#: ../gui/wxpython/gui_modules/dbm.py:70
+#: ../gui/wxpython/gui_modules/dbm.py:265
msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:165
+#: ../gui/wxpython/gui_modules/dbm.py:157
msgid "Loading data..."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:184
+#: ../gui/wxpython/gui_modules/dbm.py:164
#, python-format
+msgid ""
+"Attribute table <%s> not found. For creating the table switch to 'Manage "
+"layers' tab."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:176
+#, python-format
msgid "Column <%(column)s> not found in in the table <%(table)s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:235
+#: ../gui/wxpython/gui_modules/dbm.py:238
#, fuzzy
msgid "Can display only 256 columns."
msgstr "mostrar."
-#: ../gui/wxpython/gui_modules/dbm.py:269
+#: ../gui/wxpython/gui_modules/dbm.py:259
+#, fuzzy
+msgid "Unknown value"
+msgstr "desconocido"
+#: ../gui/wxpython/gui_modules/dbm.py:274
#, python-format
msgid ""
-"Error loading attribute data. Record number: %(rec)d. Unable to cast value '%"
-"(val)s' in key column (%(key)s) to integer.\n"
+"Error loading attribute data. Record number: %(rec)d. Unable to convert "
+"value '%(val)s' in key column (%(key)s) to integer.\n"
"\n"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:292
+#: ../gui/wxpython/gui_modules/dbm.py:297
msgid "Limit 100000 records."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:309
-#: ../gui/wxpython/gui_modules/dbm.py:672
-#: ../gui/wxpython/gui_modules/dbm.py:997
-#: ../gui/wxpython/gui_modules/dbm.py:1613
-#: ../gui/wxpython/gui_modules/dbm.py:1635
-#: ../gui/wxpython/gui_modules/dbm.py:1762
+#: ../gui/wxpython/gui_modules/dbm.py:314
+#: ../gui/wxpython/gui_modules/dbm.py:691
+#: ../gui/wxpython/gui_modules/dbm.py:1022
+#: ../gui/wxpython/gui_modules/dbm.py:1654
+#: ../gui/wxpython/gui_modules/dbm.py:1676
+#: ../gui/wxpython/gui_modules/dbm.py:1804
#, python-format
msgid "Number of loaded records: %d"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:441
-#: ../gui/wxpython/gui_modules/dbm.py:3604
+#: ../gui/wxpython/gui_modules/dbm.py:453
+#: ../gui/wxpython/gui_modules/dbm.py:3013
#, fuzzy
msgid "GRASS GIS Attribute Table Manager"
msgstr "Tabla"
-#: ../gui/wxpython/gui_modules/dbm.py:468
+#: ../gui/wxpython/gui_modules/dbm.py:480
msgid ""
"Database connection for vector map <%s> is not defined in DB file. You can "
"define new connection in 'Manage layers' tab."
msgstr "vectorial."
-#: ../gui/wxpython/gui_modules/dbm.py:472
+#: ../gui/wxpython/gui_modules/dbm.py:484
#, fuzzy
msgid "Attribute Table Manager"
msgstr "Tabla"
-#: ../gui/wxpython/gui_modules/dbm.py:503
+#: ../gui/wxpython/gui_modules/dbm.py:515
msgid "Browse data"
msgstr "Explorar datos"
-#: ../gui/wxpython/gui_modules/dbm.py:509
+#: ../gui/wxpython/gui_modules/dbm.py:521
msgid "Manage tables"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:515
+#: ../gui/wxpython/gui_modules/dbm.py:527
msgid "Manage layers"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:518
-msgid "Click here to show database connection information"
-msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:567
+#, fuzzy
+msgid "Attribute data - right-click to edit/manage records"
+msgstr "datos"
-#: ../gui/wxpython/gui_modules/dbm.py:519
-msgid "Click here to hide database connection information"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:555
-#: ../gui/wxpython/gui_modules/dbm.py:685
-#: ../gui/wxpython/gui_modules/dbm.py:2212
-#: ../gui/wxpython/gui_modules/dbm.py:2473
+#: ../gui/wxpython/gui_modules/dbm.py:581
+#: ../gui/wxpython/gui_modules/dbm.py:709
+#: ../gui/wxpython/gui_modules/dbm.py:2221
+#: ../gui/wxpython/gui_modules/dbm.py:2479
msgid "Table"
msgstr "Tabla"
-#: ../gui/wxpython/gui_modules/dbm.py:561
-#, fuzzy
-msgid "Attribute data - right-click to edit/manage records"
-msgstr "datos"
-#: ../gui/wxpython/gui_modules/dbm.py:565
+#: ../gui/wxpython/gui_modules/dbm.py:587
msgid "SQL Query"
msgstr "Consulta SQL"
-#: ../gui/wxpython/gui_modules/dbm.py:588
+#: ../gui/wxpython/gui_modules/dbm.py:607
msgid "Apply SELECT statement and reload data records"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:590
-#: ../gui/wxpython/gui_modules/dbm.py:1869
+#: ../gui/wxpython/gui_modules/dbm.py:609
+#: ../gui/wxpython/gui_modules/dbm.py:1878
msgid "SQL Builder"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:594
+#: ../gui/wxpython/gui_modules/dbm.py:613
msgid "Simple"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:705
+#: ../gui/wxpython/gui_modules/dbm.py:718
+msgid "Database connection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:730
msgid "Table <%s> - right-click to delete column(s)"
msgstr "Tabla"
-#: ../gui/wxpython/gui_modules/dbm.py:718
+#: ../gui/wxpython/gui_modules/dbm.py:743
#, fuzzy
msgid "Manage columns"
msgstr "Administrar colores"
-#: ../gui/wxpython/gui_modules/dbm.py:725
-#: ../gui/wxpython/gui_modules/dbm.py:2037
+#: ../gui/wxpython/gui_modules/dbm.py:750
+#: ../gui/wxpython/gui_modules/dbm.py:2046
msgid "Column name"
msgstr "Nombre de columna"
-#: ../gui/wxpython/gui_modules/dbm.py:736
+#: ../gui/wxpython/gui_modules/dbm.py:761
msgid "Data type"
msgstr "Tipo de datos"
-#: ../gui/wxpython/gui_modules/dbm.py:753
+#: ../gui/wxpython/gui_modules/dbm.py:778
msgid "Data length"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:770
+#: ../gui/wxpython/gui_modules/dbm.py:795
msgid "Add"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:780 ../gui/wxpython/menustrings.py:706
+#: ../gui/wxpython/gui_modules/dbm.py:805 ../gui/wxpython/menustrings.py:708
msgid "Rename column"
-#: ../gui/wxpython/gui_modules/dbm.py:790
+#: ../gui/wxpython/gui_modules/dbm.py:815
msgid "To"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:800
+#: ../gui/wxpython/gui_modules/dbm.py:825
msgid "&Rename"
msgstr "Cambia&r nombre"
-#: ../gui/wxpython/gui_modules/dbm.py:859
+#: ../gui/wxpython/gui_modules/dbm.py:884
msgid "Layers of vector map"
msgstr "Capas de mapa vectorial"
-#: ../gui/wxpython/gui_modules/dbm.py:868
+#: ../gui/wxpython/gui_modules/dbm.py:893
msgid "List of layers"
-#: ../gui/wxpython/gui_modules/dbm.py:972
-#: ../gui/wxpython/gui_modules/dbm.py:1204
+#: ../gui/wxpython/gui_modules/dbm.py:997
+#: ../gui/wxpython/gui_modules/dbm.py:1229
msgid "Insert new record"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:973
+#: ../gui/wxpython/gui_modules/dbm.py:998
msgid "Delete selected record(s)"
msgstr "Borrar registro(s) seleccionado(s)"
-#: ../gui/wxpython/gui_modules/dbm.py:974
+#: ../gui/wxpython/gui_modules/dbm.py:999
msgid "Delete all records"
msgstr "Borrar todos los registros"
-#: ../gui/wxpython/gui_modules/dbm.py:979
+#: ../gui/wxpython/gui_modules/dbm.py:1004
#, fuzzy
msgid "Highlight selected features"
msgstr "Borrar lo seleccionado"
-#: ../gui/wxpython/gui_modules/dbm.py:980
+#: ../gui/wxpython/gui_modules/dbm.py:1005
#, fuzzy
msgid "Highlight selected features and zoom"
-#: ../gui/wxpython/gui_modules/dbm.py:984
-#: ../gui/wxpython/gui_modules/dbm.py:1898
+#: ../gui/wxpython/gui_modules/dbm.py:1009
+#: ../gui/wxpython/gui_modules/dbm.py:1907
#, fuzzy
msgid "Extract selected features"
msgstr "Borrar objeto(s) espacial(es)"
-#: ../gui/wxpython/gui_modules/dbm.py:985
+#: ../gui/wxpython/gui_modules/dbm.py:1010
#, fuzzy
msgid "Delete selected features"
msgstr "Borrar la capa seleccionada"
-#: ../gui/wxpython/gui_modules/dbm.py:991
-#: ../gui/wxpython/gui_modules/dbm.py:1490
-#: ../gui/wxpython/gui_modules/vdigit.py:1934
+#: ../gui/wxpython/gui_modules/dbm.py:1016
+#: ../gui/wxpython/gui_modules/dbm.py:1529
+#: ../gui/wxpython/gui_modules/vdigit.py:1983
msgid "Reload"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1023
+#: ../gui/wxpython/gui_modules/dbm.py:1048
#, python-format
msgid ""
"Selected data records (%d) will permanently deleted from table. Do you want "
"to delete them?"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1026
-#: ../gui/wxpython/gui_modules/dbm.py:1072
+#: ../gui/wxpython/gui_modules/dbm.py:1051
+#: ../gui/wxpython/gui_modules/dbm.py:1097
#, fuzzy
msgid "Delete records"
-#: ../gui/wxpython/gui_modules/dbm.py:1069
+#: ../gui/wxpython/gui_modules/dbm.py:1094
#, python-format
msgid ""
"All data records (%d) will permanently deleted from table. Do you want to "
"delete them?"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1215
+#: ../gui/wxpython/gui_modules/dbm.py:1240
#, python-format
msgid "Record with category number %d already exists in the table."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1225
+#: ../gui/wxpython/gui_modules/dbm.py:1250
#, python-format
msgid "Category number (column %s) is missing."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1233
-#: ../gui/wxpython/gui_modules/dbm.py:1336
+#: ../gui/wxpython/gui_modules/dbm.py:1264
+#: ../gui/wxpython/gui_modules/dbm.py:1371
#, python-format
-msgid "Casting value '%(value)s' to %(type)s failed."
+msgid "Value '%(value)s' needs to be entered as %(type)s."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1244
+#: ../gui/wxpython/gui_modules/dbm.py:1275
msgid "Unable to insert new record."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1313
+#: ../gui/wxpython/gui_modules/dbm.py:1344
msgid "Update existing record"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1348
+#: ../gui/wxpython/gui_modules/dbm.py:1384
msgid "Unable to update existing record."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1432
+#: ../gui/wxpython/gui_modules/dbm.py:1470
#, fuzzy
msgid "Unable to rename column. No column name defined."
msgstr "nombre."
-#: ../gui/wxpython/gui_modules/dbm.py:1441
+#: ../gui/wxpython/gui_modules/dbm.py:1479
#, python-format
msgid ""
"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
"exists in the table <%(table)s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1457
+#: ../gui/wxpython/gui_modules/dbm.py:1496
#, python-format
msgid ""
"Unable to rename column. Column <%(column)s> doesn't exist in the table <%"
"(table)s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1485
+#: ../gui/wxpython/gui_modules/dbm.py:1524
msgid "Drop selected column"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1488
+#: ../gui/wxpython/gui_modules/dbm.py:1527
#, fuzzy
msgid "Drop all columns"
msgstr "columnas"
-#: ../gui/wxpython/gui_modules/dbm.py:1551
+#: ../gui/wxpython/gui_modules/dbm.py:1592
#, fuzzy
msgid "Unable to add column to the table. No column name defined."
msgstr "nombre."
-#: ../gui/wxpython/gui_modules/dbm.py:1573
+#: ../gui/wxpython/gui_modules/dbm.py:1614
#, python-format
msgid "Column <%(column)s> already exists in table <%(table)s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1728
-#: ../gui/wxpython/gui_modules/dbm.py:1751
+#: ../gui/wxpython/gui_modules/dbm.py:1770
+#: ../gui/wxpython/gui_modules/dbm.py:1793
msgid ""
"Loading attribute data failed.\n"
@@ -2645,7 +2757,7 @@
"%s"
-#: ../gui/wxpython/gui_modules/dbm.py:1738
+#: ../gui/wxpython/gui_modules/dbm.py:1780
#, python-format
msgid ""
@@ -2654,259 +2766,196 @@
"%s"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1823
-msgid "Database connection"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1893
+#: ../gui/wxpython/gui_modules/dbm.py:1902
msgid "Nothing to extract."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1913
+#: ../gui/wxpython/gui_modules/dbm.py:1922
msgid "Nothing to delete."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2000
-#: ../gui/wxpython/gui_modules/dbm.py:2395
-#: ../gui/wxpython/gui_modules/dbm.py:2819
+#: ../gui/wxpython/gui_modules/dbm.py:2009
+#: ../gui/wxpython/gui_modules/dbm.py:2401
+#: ../gui/wxpython/gui_modules/dbm.py:2825
#, python-format
msgid "Drop also linked attribute table (%s)"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2201
-#: ../gui/wxpython/gui_modules/dbm.py:2461
+#: ../gui/wxpython/gui_modules/dbm.py:2210
+#: ../gui/wxpython/gui_modules/dbm.py:2467
msgid "Driver"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2206
-#: ../gui/wxpython/gui_modules/dbm.py:2467 ../gui/wxpython/menustrings.py:681
+#: ../gui/wxpython/gui_modules/dbm.py:2215
+#: ../gui/wxpython/gui_modules/dbm.py:2473 ../gui/wxpython/menustrings.py:683
msgid "Database"
msgstr ""
msgid "Key"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2165
+#: ../gui/wxpython/gui_modules/dbm.py:2174
msgid ""
"Unable to determine default DB connection settings. Please define DB "
"connection using db.connect module."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2184
+#: ../gui/wxpython/gui_modules/dbm.py:2193
msgid "Add layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2222
+#: ../gui/wxpython/gui_modules/dbm.py:2226
+#: ../gui/wxpython/gui_modules/dbm.py:2258
+#: ../gui/wxpython/gui_modules/dbm.py:2485
+msgid "Key column"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2231
msgid "Insert record for each category into table"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2237
+#: ../gui/wxpython/gui_modules/dbm.py:2246
msgid "You need to add categories by v.category module."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2244
+#: ../gui/wxpython/gui_modules/dbm.py:2253
msgid "Table name"
msgstr "Nombre de tabla"
-#: ../gui/wxpython/gui_modules/dbm.py:2257
+#: ../gui/wxpython/gui_modules/dbm.py:2266
msgid "&Create table"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2261
+#: ../gui/wxpython/gui_modules/dbm.py:2270
msgid "&Add layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2265
+#: ../gui/wxpython/gui_modules/dbm.py:2274
msgid "&Set default"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2278
+#: ../gui/wxpython/gui_modules/dbm.py:2285
#, fuzzy
msgid "Layer description"
msgstr "Capa"
-#: ../gui/wxpython/gui_modules/dbm.py:2339
+#: ../gui/wxpython/gui_modules/dbm.py:2344
msgid "Table description"
msgstr "Descripción de tabla"
-#: ../gui/wxpython/gui_modules/dbm.py:2378
+#: ../gui/wxpython/gui_modules/dbm.py:2384
#, fuzzy
msgid "Delete layer"
msgstr "&Borrar capa"
-#: ../gui/wxpython/gui_modules/dbm.py:2381
+#: ../gui/wxpython/gui_modules/dbm.py:2387
msgid "Layer to detele"
msgstr "Capa a borrar"
-#: ../gui/wxpython/gui_modules/dbm.py:2402
+#: ../gui/wxpython/gui_modules/dbm.py:2408
msgid "&Delete layer"
-#: ../gui/wxpython/gui_modules/dbm.py:2446
+#: ../gui/wxpython/gui_modules/dbm.py:2452
#, fuzzy
msgid "Modify layer"
msgstr "Añadir capa de cuadrÃcula"
-#: ../gui/wxpython/gui_modules/dbm.py:2518
+#: ../gui/wxpython/gui_modules/dbm.py:2524
msgid "&Modify layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2566
+#: ../gui/wxpython/gui_modules/dbm.py:2572
msgid ""
"Unable to get list of tables.\n"
"Please use db.connect to set database parameters."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2664
+#: ../gui/wxpython/gui_modules/dbm.py:2670
#, fuzzy
msgid "Unable to create new table. Table name or key column name is missing."
msgstr "nombre nombre."
-#: ../gui/wxpython/gui_modules/dbm.py:2671
+#: ../gui/wxpython/gui_modules/dbm.py:2677
msgid "Unable to create new table. Table <%s> already exists in the database."
-#: ../gui/wxpython/gui_modules/dbm.py:2709
+#: ../gui/wxpython/gui_modules/dbm.py:2715
msgid ""
"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
"exists."
msgstr "vectorial vectorial Capa."
-#: ../gui/wxpython/gui_modules/dbm.py:2904
-msgid "Database connection is not defined in DB file."
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2908
-msgid ""
-"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
-"You can disable this message from digitization settings. Or you can create "
-"and link attribute table to the vector map using Attribute Table Manager."
-msgstr "vectorial vectorial vectorial."
-#: ../gui/wxpython/gui_modules/dbm.py:2927
-#, fuzzy
-msgid "Close dialog on submit"
-msgstr "Cerrar"
-#: ../gui/wxpython/gui_modules/dbm.py:2937
-#, fuzzy
-msgid "No attributes found"
-msgstr "datos"
-#: ../gui/wxpython/gui_modules/dbm.py:2943
-msgid "Update attributes"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2945
-msgid "Add attributes"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2947
-msgid "Display attributes"
-msgstr "Visualizar atributos"
-#: ../gui/wxpython/gui_modules/dbm.py:2951
-msgid "&Reload"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2952
-msgid "&Submit"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2968
-#: ../gui/wxpython/gui_modules/vdigit.py:1824
-#, fuzzy
-msgid "Feature id:"
-msgstr "Generar cuadrÃcula"
-#: ../gui/wxpython/gui_modules/dbm.py:3206
-#, fuzzy
-msgid "Unknown"
-msgstr "desconocido"
-#: ../gui/wxpython/gui_modules/dbm.py:3264
-#: ../gui/wxpython/gui_modules/dbm.py:3507
-#: ../gui/wxpython/gui_modules/vdigit.py:1776
-#: ../gui/wxpython/gui_modules/vdigit.py:2202
-msgid "Category"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:3460
-msgid "Submit"
-msgstr ""
#: ../gui/wxpython/gui_modules/sqlbuilder.py:44
#, python-format
msgid "GRASS SQL Builder: %s"
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:310
+#: ../gui/wxpython/gui_modules/goutput.py:322
#, python-format
msgid "Command '%s' not yet implemented."
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:382
+#: ../gui/wxpython/gui_modules/goutput.py:398
msgid "Save file as..."
msgstr "Guardar archivo como..."
-#: ../gui/wxpython/gui_modules/goutput.py:480
+#: ../gui/wxpython/gui_modules/goutput.py:496
msgid ""
"Please note that the data are left in incosistent stage and can be corrupted"
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:483
+#: ../gui/wxpython/gui_modules/goutput.py:499
msgid "Command aborted"
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:490
+#: ../gui/wxpython/gui_modules/goutput.py:506
msgid "Command finished"
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:761
+#: ../gui/wxpython/gui_modules/goutput.py:780
msgid "Unable to encode text. Please set encoding in GUI preferences."
msgstr ""
-#: ../gui/wxpython/gui_modules/globalvar.py:94
+#: ../gui/wxpython/gui_modules/globalvar.py:95
#, fuzzy
msgid "Coordinates"
msgstr "Convertir coordenadas"
-#: ../gui/wxpython/gui_modules/globalvar.py:95
+#: ../gui/wxpython/gui_modules/globalvar.py:96
msgid "Extent"
msgstr ""
-#: ../gui/wxpython/gui_modules/globalvar.py:96
+#: ../gui/wxpython/gui_modules/globalvar.py:97
#, fuzzy
msgid "Comp. region"
-#: ../gui/wxpython/gui_modules/globalvar.py:97
+#: ../gui/wxpython/gui_modules/globalvar.py:98
msgid "Show comp. extent"
msgstr ""
-#: ../gui/wxpython/gui_modules/globalvar.py:98
+#: ../gui/wxpython/gui_modules/globalvar.py:99
#, fuzzy
msgid "Display mode"
msgstr "Mostrar:"
-#: ../gui/wxpython/gui_modules/globalvar.py:99
+#: ../gui/wxpython/gui_modules/globalvar.py:100
#, fuzzy
msgid "Display geometry"
-#: ../gui/wxpython/gui_modules/globalvar.py:100
+#: ../gui/wxpython/gui_modules/globalvar.py:101
#, fuzzy
msgid "Map scale"
-#: ../gui/wxpython/gui_modules/globalvar.py:101
+#: ../gui/wxpython/gui_modules/globalvar.py:102
msgid "Go to"
msgstr ""
@@ -2947,236 +2996,242 @@
msgid "Error: "
msgstr "Error"
-#: ../gui/wxpython/gui_modules/gcmd.py:450
+#: ../gui/wxpython/gui_modules/gcmd.py:440
msgid "Unable to exectute command: '%s'"
-#: ../gui/wxpython/gui_modules/render.py:128
+#: ../gui/wxpython/gui_modules/render.py:136
msgid "<%(name)s>: layer type <%(type)s> is not supported yet."
msgstr "nombre."
-#: ../gui/wxpython/gui_modules/render.py:272
+#: ../gui/wxpython/gui_modules/render.py:283
#, python-format
msgid "Unsupported map layer type '%s'"
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:441
+#: ../gui/wxpython/gui_modules/render.py:453
msgid "GISBASE not set. You must be in GRASS GIS to run this program."
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:465
+#: ../gui/wxpython/gui_modules/render.py:477
msgid "Unable to open file"
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:467
+#: ../gui/wxpython/gui_modules/render.py:479
msgid "wxGUI closed."
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:641
+#: ../gui/wxpython/gui_modules/render.py:656
msgid "Unable to zoom to raster map <%s>."
msgstr "ráster."
-#: ../gui/wxpython/gui_modules/render.py:644
+#: ../gui/wxpython/gui_modules/render.py:659
msgid "Unable to zoom to vector map <%s>."
msgstr "vectorial."
-#: ../gui/wxpython/gui_modules/render.py:956
+#: ../gui/wxpython/gui_modules/render.py:662
+msgid ""
+"Unable to get current geographic extent. Force quiting wxGUI. Please run "
+"manually g.region to fix the problem."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:977
msgid "ERROR: Rendering failed"
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:1002
-#: ../gui/wxpython/gui_modules/render.py:1089
+#: ../gui/wxpython/gui_modules/render.py:1023
+#: ../gui/wxpython/gui_modules/render.py:1110
#, python-format
msgid "Unable to render map layer <%s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:1205
+#: ../gui/wxpython/gui_modules/render.py:1226
#, python-format
msgid "Unable render overlay <%s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:1239
+#: ../gui/wxpython/gui_modules/render.py:1266
#, python-format
msgid "Unable render overlay <%s>"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:119
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:121
msgid "Map Layers"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:253
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:255
msgid "Remove"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:257
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:259
#: ../gui/wxpython/menustrings.py:141
msgid "Rename"
msgstr "Cambiar nombre"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:264
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:268
msgid "Change opacity level"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:266
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:270
msgid "Properties"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:270
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:274
#, fuzzy
-msgid "Set computational region from selected map"
+msgid "Set computational region from selected map(s)"
msgstr "mostrar"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:283
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:290
#, fuzzy
msgid "Show attribute data"
msgstr "datos"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:286
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:293
msgid "Start editing"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:287
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:294
msgid "Stop editing"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:298
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:305
#, fuzzy
msgid "Use as background vector map"
msgstr "vectorial"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:329
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:347
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:336
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:360
msgid "Metadata"
msgstr "Metadatos"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:336
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:349
#, fuzzy
-msgid "Zoom to selected map (ignore NULLs)"
+msgid "Zoom to selected map(s) (ignore NULLs)"
msgstr "Zum"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:338
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:351
#, fuzzy
-msgid "Set computational region from selected map (ignore NULLs)"
+msgid "Set computational region from selected map(s) (ignore NULLs)"
msgstr "mostrar"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:341
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:354
#, fuzzy
msgid "Set color table"
msgstr "Tablas de color"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:343
-#: ../gui/wxpython/menustrings.py:640
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:356
+#: ../gui/wxpython/menustrings.py:642
msgid "Histogram"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:350
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:363
msgid "Nviz properties"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:409
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:440
#, fuzzy
msgid "Unable to create profile of raster map."
msgstr "No se puede crear el mapa vectorial <%s>."
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:441
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:472
#, fuzzy
msgid "Unable to display histogram of raster map."
msgstr "mostrar ráster."
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:522
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:566
#, python-format
msgid "Set opacity <%s>"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:596
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:640
#, fuzzy
msgid "Layer group:"
msgstr "Capa:"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:601
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1152
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:645
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1208
#, fuzzy
msgid "Click to edit layer settings"
msgstr "Pulse aquà para ocultar configuración 3D"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:648
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:651
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:654
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:657
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:660
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:663
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:666
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:669
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:672
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:675
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:678
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:681
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:684
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:687
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:692
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:695
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:698
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:701
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:704
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:707
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:710
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:713
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:716
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:719
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:722
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:725
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:728
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:731
msgid "(double click to set properties)"
msgstr ""
#, fuzzy
msgid "3d raster"
msgstr "ráster"
msgid "RGB"
msgstr ""
msgid "HIS"
msgstr ""
-#: ../gui/wxpython/menustrings.py:283
+#: ../gui/wxpython/menustrings.py:285
msgid "Shaded relief"
msgstr "Relieve sombreado"
#, fuzzy
msgid "raster cell numbers"
msgstr "ráster"
#, fuzzy
msgid "raster flow arrows"
msgstr "ráster"
msgid "thematic map"
msgstr ""
msgid "thematic charts"
msgstr ""
msgid "grid"
msgstr ""
msgid "geodesic line"
msgstr ""
msgid "rhumbline"
msgstr ""
msgid "vector labels"
msgstr "etiquetas vectoriales"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:961
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1008
msgid "Please wait, updating data..."
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1231
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1287
msgid "Map <%s> not found."
msgstr "no se ha encontrado el archivo"
@@ -3192,7 +3247,7 @@
msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1114
+#: ../gui/wxpython/gui_modules/toolbars.py:1118
#, fuzzy
msgid "Digitize"
msgstr "Digitalizar nueva lÃnea"
@@ -3207,83 +3262,83 @@
msgid "Zoom to displayed map"
-#: ../gui/wxpython/gui_modules/toolbars.py:744
+#: ../gui/wxpython/gui_modules/toolbars.py:746
#, fuzzy
msgid "Duplicate attributes"
-#: ../gui/wxpython/gui_modules/toolbars.py:811
+#: ../gui/wxpython/gui_modules/toolbars.py:813
msgid "Digitization settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:821
+#: ../gui/wxpython/gui_modules/toolbars.py:823
#, fuzzy
msgid "Copy features from (background) vector map"
msgstr "vectorial"
-#: ../gui/wxpython/gui_modules/toolbars.py:829
+#: ../gui/wxpython/gui_modules/toolbars.py:831
#, fuzzy
msgid "Flip selected lines/boundaries"
msgstr "Disolver contornos"
-#: ../gui/wxpython/gui_modules/toolbars.py:837
+#: ../gui/wxpython/gui_modules/toolbars.py:839
msgid "Merge selected lines/boundaries"
msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:845
+#: ../gui/wxpython/gui_modules/toolbars.py:847
msgid "Break selected lines/boundaries at intersection"
msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:853
+#: ../gui/wxpython/gui_modules/toolbars.py:855
msgid "Snap selected lines/boundaries (only to nodes)"
msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:861
+#: ../gui/wxpython/gui_modules/toolbars.py:863
#, fuzzy
msgid "Connect selected lines/boundaries"
-#: ../gui/wxpython/gui_modules/toolbars.py:869
+#: ../gui/wxpython/gui_modules/toolbars.py:871
#, fuzzy
msgid "Query features"
msgstr "Elementos más próximos"
-#: ../gui/wxpython/gui_modules/toolbars.py:877
+#: ../gui/wxpython/gui_modules/toolbars.py:879
msgid "Z bulk-labeling of 3D lines"
msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:885
+#: ../gui/wxpython/gui_modules/toolbars.py:887
#, fuzzy
msgid "Feature type conversion"
msgstr "Conversiones de tipos de mapa"
-#: ../gui/wxpython/gui_modules/toolbars.py:1054
-#: ../gui/wxpython/gui_modules/toolbars.py:1146
-#: ../gui/wxpython/gui_modules/toolbars.py:1219
+#: ../gui/wxpython/gui_modules/toolbars.py:1058
+#: ../gui/wxpython/gui_modules/toolbars.py:1150
+#: ../gui/wxpython/gui_modules/toolbars.py:1225
msgid "Select vector map"
msgstr "Seleccionar mapa vectorial"
-#: ../gui/wxpython/gui_modules/toolbars.py:1092
+#: ../gui/wxpython/gui_modules/toolbars.py:1096
#, fuzzy, python-format
msgid "Please wait, opening vector map <%s> for editing..."
msgstr "No hay ningún mapa vectorial seleccionado para editar."
-#: ../gui/wxpython/gui_modules/toolbars.py:1152
+#: ../gui/wxpython/gui_modules/toolbars.py:1156
msgid "Do you want to save changes in vector map <%s>?"
msgstr "vectorial?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1154
+#: ../gui/wxpython/gui_modules/toolbars.py:1158
msgid "Save changes?"
msgstr "¿Guardar cambios?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1161
+#: ../gui/wxpython/gui_modules/toolbars.py:1165
msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
msgstr "Herramientas para limpiar la topologÃa de mapas vectoriales."
-#: ../gui/wxpython/gui_modules/toolbars.py:1225
-#: ../gui/wxpython/gui_modules/toolbars.py:1230
+#: ../gui/wxpython/gui_modules/toolbars.py:1231
+#: ../gui/wxpython/gui_modules/toolbars.py:1236
msgid "New vector map"
msgstr "Nuevo mapa vectorial"
@@ -3304,268 +3359,295 @@
"(Vector->Develop vector map->Create/rebuild topology)."
msgstr "vectorial."
-#: ../gui/wxpython/gui_modules/vdigit.py:650
+#: ../gui/wxpython/gui_modules/vdigit.py:661
#, fuzzy
msgid "Undo failed, data corrupted."
msgstr "datos."
-#: ../gui/wxpython/gui_modules/vdigit.py:1074
+#: ../gui/wxpython/gui_modules/vdigit.py:1097
#, fuzzy
msgid "Apply changes for this session"
msgstr "Aplicar"
-#: ../gui/wxpython/gui_modules/vdigit.py:1077
+#: ../gui/wxpython/gui_modules/vdigit.py:1100
#, fuzzy
msgid "Close dialog and save changes to user settings file"
msgstr "Cerrar guardar"
-#: ../gui/wxpython/gui_modules/vdigit.py:1102
+#: ../gui/wxpython/gui_modules/vdigit.py:1125
msgid "Symbology"
msgstr "SimbologÃa"
-#: ../gui/wxpython/gui_modules/vdigit.py:1170
+#: ../gui/wxpython/gui_modules/vdigit.py:1193
msgid "Snapping"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1176
+#: ../gui/wxpython/gui_modules/vdigit.py:1199
msgid "Snapping threshold"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1192
+#: ../gui/wxpython/gui_modules/vdigit.py:1215
msgid "Snap also to vertex"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1197
-#: ../gui/wxpython/gui_modules/vdigit.py:1525
-#: ../gui/wxpython/gui_modules/vdigit.py:1538
-#: ../gui/wxpython/gui_modules/vdigit.py:1542
+#: ../gui/wxpython/gui_modules/vdigit.py:1220
+#: ../gui/wxpython/gui_modules/vdigit.py:1568
+#: ../gui/wxpython/gui_modules/vdigit.py:1581
+#: ../gui/wxpython/gui_modules/vdigit.py:1585
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1210
+#: ../gui/wxpython/gui_modules/vdigit.py:1233
#, fuzzy
msgid "Select vector features"
msgstr "vectorial"
-#: ../gui/wxpython/gui_modules/vdigit.py:1227
+#: ../gui/wxpython/gui_modules/vdigit.py:1250
msgid "Select threshold"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1240
+#: ../gui/wxpython/gui_modules/vdigit.py:1263
msgid "Select only features inside of selection bounding box"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1242
+#: ../gui/wxpython/gui_modules/vdigit.py:1265
msgid ""
"By default are selected all features overlapping selection bounding box "
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1245
+#: ../gui/wxpython/gui_modules/vdigit.py:1268
msgid "Check for duplicates"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1257
+#: ../gui/wxpython/gui_modules/vdigit.py:1280
#, fuzzy
msgid "Digitize line features"
msgstr "Digitalizar"
-#: ../gui/wxpython/gui_modules/vdigit.py:1260
+#: ../gui/wxpython/gui_modules/vdigit.py:1283
msgid "Break lines at intersection"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1270
+#: ../gui/wxpython/gui_modules/vdigit.py:1293
msgid "Save changes"
msgstr "Guardar cambios"
-#: ../gui/wxpython/gui_modules/vdigit.py:1273
+#: ../gui/wxpython/gui_modules/vdigit.py:1296
#, fuzzy
msgid "Save changes on exit"
-#: ../gui/wxpython/gui_modules/vdigit.py:1286
+#: ../gui/wxpython/gui_modules/vdigit.py:1309
msgid "Query tool"
msgstr "Herramienta de consultas"
-#: ../gui/wxpython/gui_modules/vdigit.py:1293
+#: ../gui/wxpython/gui_modules/vdigit.py:1316
msgid "Choose query tool"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1298
+#: ../gui/wxpython/gui_modules/vdigit.py:1321
msgid "Select by box"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1307
+#: ../gui/wxpython/gui_modules/vdigit.py:1330
msgid "length"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1312
+#: ../gui/wxpython/gui_modules/vdigit.py:1335
msgid "Select lines"
msgstr "Seleccionar lÃneas"
-#: ../gui/wxpython/gui_modules/vdigit.py:1314
#: ../gui/wxpython/gui_modules/vdigit.py:1337
+#: ../gui/wxpython/gui_modules/vdigit.py:1360
msgid "shorter than"
msgstr ""
msgid "longer than"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1330
+#: ../gui/wxpython/gui_modules/vdigit.py:1353
msgid "dangle"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1335
+#: ../gui/wxpython/gui_modules/vdigit.py:1358
msgid "Select dangles"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1375
+#: ../gui/wxpython/gui_modules/vdigit.py:1398
#, fuzzy
msgid "Digitize new feature"
-#: ../gui/wxpython/gui_modules/vdigit.py:1380
+#: ../gui/wxpython/gui_modules/vdigit.py:1403
msgid "Add new record into table"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1386
+#: ../gui/wxpython/gui_modules/vdigit.py:1409
+#: ../gui/wxpython/gui_modules/vdigit.py:1825
+#: ../gui/wxpython/gui_modules/vdigit.py:2251
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:425
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:530
+msgid "Category"
+msgstr ""
msgid "Mode"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1415
+#: ../gui/wxpython/gui_modules/vdigit.py:1438
msgid "Next to use"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1403
+#: ../gui/wxpython/gui_modules/vdigit.py:1426
msgid "Category number"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1413
+#: ../gui/wxpython/gui_modules/vdigit.py:1436
msgid "Category mode"
msgstr ""
msgid "Manual entry"
msgstr ""
msgid "No category"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1428
+#: ../gui/wxpython/gui_modules/vdigit.py:1451
#, fuzzy
+msgid "Digitize new area"
+msgstr "Digitalizar"
+#: ../gui/wxpython/gui_modules/vdigit.py:1456
+msgid "Add centroid to left/right area"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1462
+msgid "Do not attach category to boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1471
+#, fuzzy
msgid "Delete existing feature(s)"
msgstr "Borrar"
-#: ../gui/wxpython/gui_modules/vdigit.py:1433
+#: ../gui/wxpython/gui_modules/vdigit.py:1476
#, fuzzy
msgid "Delete record from table"
msgstr "Borrar"
-#: ../gui/wxpython/gui_modules/vdigit.py:1457
+#: ../gui/wxpython/gui_modules/vdigit.py:1500
msgid "Highlight"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1458
+#: ../gui/wxpython/gui_modules/vdigit.py:1501
msgid "Highlight (duplicates)"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1459
+#: ../gui/wxpython/gui_modules/vdigit.py:1502
msgid "Point"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1460
+#: ../gui/wxpython/gui_modules/vdigit.py:1503
msgid "Line"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1461
+#: ../gui/wxpython/gui_modules/vdigit.py:1504
msgid "Boundary (no area)"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1462
+#: ../gui/wxpython/gui_modules/vdigit.py:1505
msgid "Boundary (one area)"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1463
+#: ../gui/wxpython/gui_modules/vdigit.py:1506
msgid "Boundary (two areas)"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1464
+#: ../gui/wxpython/gui_modules/vdigit.py:1507
msgid "Centroid (in area)"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1465
+#: ../gui/wxpython/gui_modules/vdigit.py:1508
msgid "Centroid (outside area)"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1466
+#: ../gui/wxpython/gui_modules/vdigit.py:1509
msgid "Centroid (duplicate in area)"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1467
+#: ../gui/wxpython/gui_modules/vdigit.py:1510
msgid "Node (one line)"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1468
+#: ../gui/wxpython/gui_modules/vdigit.py:1511
#, fuzzy
msgid "Node (two lines)"
msgstr "LÃneas de flujo"
-#: ../gui/wxpython/gui_modules/vdigit.py:1469
+#: ../gui/wxpython/gui_modules/vdigit.py:1512
msgid "Vertex"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1470
+#: ../gui/wxpython/gui_modules/vdigit.py:1513
msgid "Area (closed boundary + centroid)"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1471
+#: ../gui/wxpython/gui_modules/vdigit.py:1514
#, fuzzy
msgid "Direction"
msgstr "Descripción"
-#: ../gui/wxpython/gui_modules/vdigit.py:1518
+#: ../gui/wxpython/gui_modules/vdigit.py:1561
msgid "Snapping disabled"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1520
+#: ../gui/wxpython/gui_modules/vdigit.py:1563
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1573
+#: ../gui/wxpython/gui_modules/vdigit.py:1616
msgid "Vector digitizer settings saved to file <%s>."
-#: ../gui/wxpython/gui_modules/vdigit.py:1732
+#: ../gui/wxpython/gui_modules/vdigit.py:1781
#, fuzzy
msgid "List of categories - right-click to delete"
msgstr "Tabla"
-#: ../gui/wxpython/gui_modules/vdigit.py:1763
+#: ../gui/wxpython/gui_modules/vdigit.py:1812
msgid "Add new category"
msgstr "Añadir categorÃa nueva"
-#: ../gui/wxpython/gui_modules/vdigit.py:1800
+#: ../gui/wxpython/gui_modules/vdigit.py:1849
#, fuzzy
msgid "Apply changes"
-#: ../gui/wxpython/gui_modules/vdigit.py:1802
+#: ../gui/wxpython/gui_modules/vdigit.py:1851
msgid "Ignore changes and close dialog"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1804
+#: ../gui/wxpython/gui_modules/vdigit.py:1853
#, fuzzy
msgid "Apply changes and close dialog"
msgstr "Aplicar"
-#: ../gui/wxpython/gui_modules/vdigit.py:1894
-#: ../gui/wxpython/gui_modules/vdigit.py:2097
+#: ../gui/wxpython/gui_modules/vdigit.py:1873
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:135
+#, fuzzy
+msgid "Feature id:"
+msgstr "Generar cuadrÃcula"
+#: ../gui/wxpython/gui_modules/vdigit.py:1943
+#: ../gui/wxpython/gui_modules/vdigit.py:2146
#, python-format
msgid ""
"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
@@ -3573,47 +3655,47 @@
"Layer number must be greater then zero."
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1928
+#: ../gui/wxpython/gui_modules/vdigit.py:1977
msgid "Delete selected"
-#: ../gui/wxpython/gui_modules/vdigit.py:1932
+#: ../gui/wxpython/gui_modules/vdigit.py:1981
msgid "Delete all"
msgstr "Borrar todo"
-#: ../gui/wxpython/gui_modules/vdigit.py:2077
+#: ../gui/wxpython/gui_modules/vdigit.py:2126
#, fuzzy
msgid "Unable to update vector map."
msgstr "vectorial."
-#: ../gui/wxpython/gui_modules/vdigit.py:2239
+#: ../gui/wxpython/gui_modules/vdigit.py:2288
msgid "%d lines selected for z bulk-labeling"
msgstr "lÃneas"
-#: ../gui/wxpython/gui_modules/vdigit.py:2242
+#: ../gui/wxpython/gui_modules/vdigit.py:2291
msgid "Set value"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:2249
+#: ../gui/wxpython/gui_modules/vdigit.py:2298
msgid "Starting value"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:2258
+#: ../gui/wxpython/gui_modules/vdigit.py:2307
msgid "Step"
msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:2291
+#: ../gui/wxpython/gui_modules/vdigit.py:2340
#, fuzzy
msgid "List of duplicates"
msgstr "Lista de capas"
-#: ../gui/wxpython/gui_modules/vdigit.py:2384
+#: ../gui/wxpython/gui_modules/vdigit.py:2433
#, fuzzy
msgid "Feature id"
-#: ../gui/wxpython/gui_modules/vdigit.py:2385
+#: ../gui/wxpython/gui_modules/vdigit.py:2434
#, fuzzy
msgid "Layer (Categories)"
msgstr "Actualizar categorÃas"
@@ -3680,76 +3762,76 @@
msgid "Please select attribute column and RGB color column first"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:489
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:526
#, fuzzy
msgid "Loading raster map"
msgstr "vectorial."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:493
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:530
#, fuzzy
msgid "Loading 3d raster map"
msgstr "Añadir mapa ráster 3D"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:499
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:536
#, fuzzy
msgid "failed"
msgstr "Archivo"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:501
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:538
#, python-format
msgid "Unsupported layer type '%s'"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:555
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:592
#, fuzzy
msgid "Unable to unload raster map"
msgstr "ráster."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:556
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:593
#, fuzzy
msgid "Raster map"
msgstr "Mapa ráster:"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:560
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:597
#, fuzzy
msgid "Unable to unload 3d raster map"
msgstr "ráster."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:561
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:598
#, fuzzy
msgid "3d raster map"
msgstr "ráster"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:568
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:605
msgid "unloaded successfully"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:619
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:656
#, python-format
msgid "Loading vector map <%(name)s> (%(type)s) failed"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:670
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:707
msgid "Unable to unload vector map <%(name)s> (%(type)s)"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:673
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:710
#, python-format
msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1195
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1232
#, python-format
msgid "Vector point layer not found (id=%d)"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1197
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1234
#, python-format
msgid "Unable to set data layer properties (id=%d)"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1201
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1238
#, python-format
msgid ""
"Setting data layer properties failed.\n"
@@ -3757,579 +3839,670 @@
"%s"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:43
+#: ../gui/wxpython/gui_modules/nviz_tools.py:40
msgid "Nviz tools"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:114
-#: ../gui/wxpython/gui_modules/nviz_tools.py:988
+#: ../gui/wxpython/gui_modules/nviz_tools.py:115
+#: ../gui/wxpython/gui_modules/nviz_tools.py:989
msgid "View"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:123
+#: ../gui/wxpython/gui_modules/nviz_tools.py:124
msgid "W"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:125
+#: ../gui/wxpython/gui_modules/nviz_tools.py:126
msgid "N"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:132
+#: ../gui/wxpython/gui_modules/nviz_tools.py:133
msgid "S"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:134
+#: ../gui/wxpython/gui_modules/nviz_tools.py:135
msgid "E"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:143
-#: ../gui/wxpython/gui_modules/nviz_tools.py:998
+#: ../gui/wxpython/gui_modules/nviz_tools.py:144
+#: ../gui/wxpython/gui_modules/nviz_tools.py:999
#, fuzzy
msgid "Perspective:"
msgstr "Proyección:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:154
+#: ../gui/wxpython/gui_modules/nviz_tools.py:155
#, fuzzy
msgid "Twist:"
msgstr "Listar"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:168
+#: ../gui/wxpython/gui_modules/nviz_tools.py:169
msgid "Height:"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:175
+#: ../gui/wxpython/gui_modules/nviz_tools.py:176
msgid "Z-exag:"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:189
+#: ../gui/wxpython/gui_modules/nviz_tools.py:190
msgid "Look at:"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:193
+#: ../gui/wxpython/gui_modules/nviz_tools.py:194
#, fuzzy
msgid "top"
msgstr "Superior"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:194
+#: ../gui/wxpython/gui_modules/nviz_tools.py:195
#, fuzzy
msgid "north"
msgstr "Norte"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:195
+#: ../gui/wxpython/gui_modules/nviz_tools.py:196
#, fuzzy
msgid "south"
msgstr "Sur"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:196
+#: ../gui/wxpython/gui_modules/nviz_tools.py:197
#, fuzzy
msgid "east"
msgstr "Oeste"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:197
+#: ../gui/wxpython/gui_modules/nviz_tools.py:198
#, fuzzy
msgid "west"
msgstr "Oeste"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:198
+#: ../gui/wxpython/gui_modules/nviz_tools.py:199
msgid "north-west"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:199
+#: ../gui/wxpython/gui_modules/nviz_tools.py:200
msgid "north-east"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:200
+#: ../gui/wxpython/gui_modules/nviz_tools.py:201
msgid "south-east"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:201
+#: ../gui/wxpython/gui_modules/nviz_tools.py:202
msgid "south-west"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:208
+#: ../gui/wxpython/gui_modules/nviz_tools.py:209
#, fuzzy
msgid "Reset"
msgstr "Oeste"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:209
+#: ../gui/wxpython/gui_modules/nviz_tools.py:210
#, fuzzy
msgid "Reset to default view"
msgstr "Zum a la región predeterminada"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:247
+#: ../gui/wxpython/gui_modules/nviz_tools.py:248
#, fuzzy
msgid "Surface attributes"
msgstr "Cambiar atributos"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:254
+#: ../gui/wxpython/gui_modules/nviz_tools.py:255
msgid "Topography"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:256
-#: ../gui/wxpython/gui_modules/nviz_tools.py:436
-#: ../gui/wxpython/gui_modules/nviz_tools.py:854
-#: ../gui/wxpython/menustrings.py:253
+#: ../gui/wxpython/gui_modules/nviz_tools.py:257
+#: ../gui/wxpython/gui_modules/nviz_tools.py:437
+#: ../gui/wxpython/gui_modules/nviz_tools.py:855
+#: ../gui/wxpython/menustrings.py:255
msgid "Mask"
msgstr "Máscara"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:257
-#: ../gui/wxpython/gui_modules/nviz_tools.py:855
+#: ../gui/wxpython/gui_modules/nviz_tools.py:258
+#: ../gui/wxpython/gui_modules/nviz_tools.py:856
#, fuzzy
msgid "Transparency"
msgstr "Transparente"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:258
-#: ../gui/wxpython/gui_modules/nviz_tools.py:856
+#: ../gui/wxpython/gui_modules/nviz_tools.py:259
+#: ../gui/wxpython/gui_modules/nviz_tools.py:857
msgid "Shininess"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:259
-#: ../gui/wxpython/gui_modules/nviz_tools.py:857
+#: ../gui/wxpython/gui_modules/nviz_tools.py:260
+#: ../gui/wxpython/gui_modules/nviz_tools.py:858
msgid "Emission"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:265
-#: ../gui/wxpython/gui_modules/nviz_tools.py:865
+#: ../gui/wxpython/gui_modules/nviz_tools.py:266
+#: ../gui/wxpython/gui_modules/nviz_tools.py:866
msgid "map"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:267
-#: ../gui/wxpython/gui_modules/nviz_tools.py:870
+#: ../gui/wxpython/gui_modules/nviz_tools.py:268
+#: ../gui/wxpython/gui_modules/nviz_tools.py:871
msgid "unset"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:272
-#: ../gui/wxpython/gui_modules/nviz_tools.py:875
+#: ../gui/wxpython/gui_modules/nviz_tools.py:273
+#: ../gui/wxpython/gui_modules/nviz_tools.py:876
msgid "constant"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:332
-#: ../gui/wxpython/gui_modules/nviz_tools.py:742
+#: ../gui/wxpython/gui_modules/nviz_tools.py:333
+#: ../gui/wxpython/gui_modules/nviz_tools.py:743
msgid "Draw"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:339
-#: ../gui/wxpython/gui_modules/nviz_tools.py:749
+#: ../gui/wxpython/gui_modules/nviz_tools.py:340
+#: ../gui/wxpython/gui_modules/nviz_tools.py:750
#, fuzzy
msgid "Mode:"
msgstr "Código"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:342
+#: ../gui/wxpython/gui_modules/nviz_tools.py:343
msgid "coarse"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:343
+#: ../gui/wxpython/gui_modules/nviz_tools.py:344
msgid "fine"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:344
+#: ../gui/wxpython/gui_modules/nviz_tools.py:345
#, fuzzy
msgid "both"
msgstr "Norte"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:354
-#: ../gui/wxpython/gui_modules/nviz_tools.py:776
+#: ../gui/wxpython/gui_modules/nviz_tools.py:355
+#: ../gui/wxpython/gui_modules/nviz_tools.py:777
#, fuzzy
msgid "Resolution:"
msgstr "Resolución Sup-Inf"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:358
+#: ../gui/wxpython/gui_modules/nviz_tools.py:359
msgid "coarse:"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:370
+#: ../gui/wxpython/gui_modules/nviz_tools.py:371
#, fuzzy
msgid "fine:"
msgstr "Zona:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:385
+#: ../gui/wxpython/gui_modules/nviz_tools.py:386
#, fuzzy
msgid "Coarse style:"
msgstr "Anchura de lÃnea"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:388
+#: ../gui/wxpython/gui_modules/nviz_tools.py:389
msgid "wire"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:389
+#: ../gui/wxpython/gui_modules/nviz_tools.py:390
#, fuzzy
msgid "surface"
msgstr "Superficies de coste"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:398
-#: ../gui/wxpython/gui_modules/nviz_tools.py:763
+#: ../gui/wxpython/gui_modules/nviz_tools.py:399
+#: ../gui/wxpython/gui_modules/nviz_tools.py:764
msgid "Shading:"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:401
-#: ../gui/wxpython/gui_modules/nviz_tools.py:578
-#: ../gui/wxpython/gui_modules/nviz_tools.py:766
+#: ../gui/wxpython/gui_modules/nviz_tools.py:402
+#: ../gui/wxpython/gui_modules/nviz_tools.py:579
+#: ../gui/wxpython/gui_modules/nviz_tools.py:767
msgid "flat"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:402
-#: ../gui/wxpython/gui_modules/nviz_tools.py:767
+#: ../gui/wxpython/gui_modules/nviz_tools.py:403
+#: ../gui/wxpython/gui_modules/nviz_tools.py:768
msgid "gouraud"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:411
+#: ../gui/wxpython/gui_modules/nviz_tools.py:412
#, fuzzy
msgid "Wire color:"
msgstr "Color"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:426
+#: ../gui/wxpython/gui_modules/nviz_tools.py:427
#, fuzzy
msgid "Set to all"
msgstr "Seleccionar todo"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:427
+#: ../gui/wxpython/gui_modules/nviz_tools.py:428
msgid "Use draw settings for all loaded surfaces"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:441
+#: ../gui/wxpython/gui_modules/nviz_tools.py:442
msgid "Mask zeros:"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:445
+#: ../gui/wxpython/gui_modules/nviz_tools.py:446
msgid "by elevation"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:450
+#: ../gui/wxpython/gui_modules/nviz_tools.py:451
#, fuzzy
msgid "by color"
msgstr "Reglas de color"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:465
+#: ../gui/wxpython/gui_modules/nviz_tools.py:466
#, fuzzy
msgid "Position"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:528
+#: ../gui/wxpython/gui_modules/nviz_tools.py:529
#, fuzzy
msgid "Show vector lines"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:536
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1161
+#: ../gui/wxpython/gui_modules/nviz_tools.py:537
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1162
#, fuzzy
msgid "Vector lines"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:577
+#: ../gui/wxpython/gui_modules/nviz_tools.py:578
#, fuzzy
msgid "on surface"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:587
-#: ../gui/wxpython/gui_modules/nviz_tools.py:692
+#: ../gui/wxpython/gui_modules/nviz_tools.py:588
+#: ../gui/wxpython/gui_modules/nviz_tools.py:693
#, fuzzy
msgid "Height above surface:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:622
+#: ../gui/wxpython/gui_modules/nviz_tools.py:623
#, fuzzy
msgid "Show vector points"
msgstr "IDW a partir de puntos vectoriales"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:630
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1186
+#: ../gui/wxpython/gui_modules/nviz_tools.py:631
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1187
#, fuzzy
msgid "Vector points"
msgstr "Perturbar puntos"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:636
+#: ../gui/wxpython/gui_modules/nviz_tools.py:637
#, fuzzy
msgid "Icon size:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:652
+#: ../gui/wxpython/gui_modules/nviz_tools.py:653
#, fuzzy
msgid "width:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:668
+#: ../gui/wxpython/gui_modules/nviz_tools.py:669
#, fuzzy
msgid "symbol:"
msgstr "SimbologÃa"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:681
+#: ../gui/wxpython/gui_modules/nviz_tools.py:682
#, fuzzy
msgid "color:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:752
+#: ../gui/wxpython/gui_modules/nviz_tools.py:753
#, fuzzy
msgid "isosurfaces"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:753
+#: ../gui/wxpython/gui_modules/nviz_tools.py:754
msgid "slides"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:798
+#: ../gui/wxpython/gui_modules/nviz_tools.py:799
#, fuzzy
msgid "List of isosurfaces"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:846
+#: ../gui/wxpython/gui_modules/nviz_tools.py:847
#, fuzzy
msgid "Isosurface attributes"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:852
+#: ../gui/wxpython/gui_modules/nviz_tools.py:853
msgid "Topography level"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1001
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1080
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1110
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1002
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1081
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1111
msgid "(value)"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1013
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1061
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1092
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1014
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1062
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1093
msgid "(step)"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1028
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1029
#, fuzzy
msgid "Position:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1031
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1032
msgid "(x)"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1058
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1059
msgid "Height"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1077
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1078
#, fuzzy
msgid "Twist"
msgstr "Listar"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1107
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1108
msgid "Z-exag"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1122
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1123
msgid "(step):"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1144
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1145
#, fuzzy
msgid "Surface"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1168
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1169
#, fuzzy
msgid "Show lines"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1193
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1194
#, fuzzy
msgid "Show points"
msgstr "Mostrar configuración"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1202
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1203
msgid "Size:"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1233
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1234
msgid "Marker:"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1266
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1267
#, fuzzy
msgid "Default"
msgstr "Borrar"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1271
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1272
#, fuzzy
msgid "Restore default settings"
msgstr "ráster"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1511
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1512
msgid "Nviz settings saved to file <%s>."
msgstr "Configuraciones."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2146
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2148
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2147
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2149
msgid "Level"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2320
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2338
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2356
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2323
#, fuzzy
msgid "Layer properties"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2467
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2440
#, python-format
msgid "Vector map <%s> is 3D"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2470
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2443
#, python-format
msgid "Vector map <%s> is 2D"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2472
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2445
#, python-format
msgid "%(primitives)d primitives (%(points)d points)"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1230
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1263
msgid "Update categories"
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1324
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1850
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1358
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1892
msgid "No vector map selected for editing."
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1325
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1359
#, fuzzy
msgid "Vector digitizer"
msgstr "Barra de herramientas del digitalizador vectorial"
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1970
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:2014
msgid "Z bulk-labeling dialog"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:2449
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:2498
msgid "Zoom to saved region extents"
msgstr "Zum a la extensión de la región guardada"
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:2510
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:2559
#, python-format
msgid "Region file <%s> already exists. Do you want to overwrite it?"
msgstr "El archivo de región <%s> ya existe. ¿Quiere sobrescribirlo?"
-#: ../gui/wxpython/gis_set.py:85
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:71
+msgid "Database connection is not defined in DB file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:75
+#, fuzzy, python-format
+msgid ""
+"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
+"You can disable this message from digitization settings. Or you can create "
+"and link attribute table to the vector map using Attribute Table Manager."
+msgstr "vectorial vectorial vectorial."
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:94
+#, fuzzy
+msgid "Close dialog on submit"
+msgstr "Cerrar"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:104
+#, fuzzy
+msgid "No attributes found"
+msgstr "datos"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:110
+msgid "Update attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:112
+msgid "Add attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:114
+msgid "Display attributes"
+msgstr "Visualizar atributos"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:118
+msgid "&Reload"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:119
+msgid "&Submit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:367
+#, fuzzy
+msgid "Unknown"
+msgstr "desconocido"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:515
+msgid "Submit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/ogc_services.py:38
+#, fuzzy
+msgid "Import data from WMS server"
+msgstr "Descarga e importa datos de servidores WMS."
+#: ../gui/wxpython/gui_modules/ogc_services.py:54
+#, fuzzy
+msgid " Server settings "
+msgstr "ráster"
+#: ../gui/wxpython/gui_modules/ogc_services.py:56
+msgid "Server:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/ogc_services.py:63
+#, fuzzy
+msgid " List of layers "
+msgstr "Lista de capas"
+#: ../gui/wxpython/gui_modules/ogc_services.py:79
+msgid "&Connect"
+msgstr ""
+#: ../gui/wxpython/gui_modules/ogc_services.py:80
+msgid "Connect to the server"
+msgstr ""
+#: ../gui/wxpython/gui_modules/ogc_services.py:237
+#, fuzzy
+msgid "Layer / Style"
+msgstr "Capa a borrar"
+#: ../gui/wxpython/gui_modules/ogc_services.py:238
+#, fuzzy
+msgid "Title"
+msgstr "Archivo"
+#: ../gui/wxpython/gui_modules/ogc_services.py:248
+#, fuzzy
+msgid "Layers"
+msgstr "Capa"
+#: ../gui/wxpython/gis_set.py:84
msgid "Choose project location and mapset"
msgstr ""
-#: ../gui/wxpython/gis_set.py:88
+#: ../gui/wxpython/gis_set.py:87
msgid "Manage"
msgstr ""
-#: ../gui/wxpython/gis_set.py:90
+#: ../gui/wxpython/gis_set.py:89
#, python-format
msgid ""
"Welcome to GRASS GIS %s\n"
"The world's leading open source GIS"
msgstr ""
-#: ../gui/wxpython/gis_set.py:96
+#: ../gui/wxpython/gis_set.py:93
msgid ""
"Select an existing project location and mapset\n"
"or define a new location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:102
+#: ../gui/wxpython/gis_set.py:99
msgid ""
"Project location\n"
"(projection/coordinate system)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:105
+#: ../gui/wxpython/gis_set.py:102
msgid ""
"Accessible mapsets\n"
"(directories of GIS files)"
msgstr ""
-#: ../gui/wxpython/gis_set.py:108
+#: ../gui/wxpython/gis_set.py:105
msgid ""
"Create new mapset\n"
"in selected location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:111
+#: ../gui/wxpython/gis_set.py:108
msgid "Define new location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:114
+#: ../gui/wxpython/gis_set.py:111
#, fuzzy
msgid ""
"Rename/delete selected\n"
"mapset or location"
-#: ../gui/wxpython/gis_set.py:119
+#: ../gui/wxpython/gis_set.py:116
msgid "Start GRASS"
msgstr ""
-#: ../gui/wxpython/gis_set.py:126
+#: ../gui/wxpython/gis_set.py:123
msgid "Create mapset"
msgstr ""
-#: ../gui/wxpython/gis_set.py:130
+#: ../gui/wxpython/gis_set.py:127
#, fuzzy
msgid "Rename mapset"
msgstr "Cambiar nombre del directorio de mapas seleccionado"
#, fuzzy
msgid "Rename location"
msgstr "Cambiar nombre de la localización seleccionada"
-#: ../gui/wxpython/gis_set.py:131
+#: ../gui/wxpython/gis_set.py:128
#, fuzzy
msgid "Delete mapset"
msgstr "Borrar directorio de mapas seleccionado"
#, fuzzy
msgid "Delete location"
msgstr "Borrar localización seleccionada"
-#: ../gui/wxpython/gis_set.py:174
+#: ../gui/wxpython/gis_set.py:172
msgid "Welcome to GRASS GIS"
msgstr "Bienvenido a GRASS GIS"
-#: ../gui/wxpython/gis_set.py:182
+#: ../gui/wxpython/gis_set.py:180
msgid "Enter GRASS session"
msgstr ""
-#: ../gui/wxpython/gis_set.py:208
+#: ../gui/wxpython/gis_set.py:207
#, python-format
msgid "ERROR: Location <%s> not found"
msgstr ""
-#: ../gui/wxpython/gis_set.py:221
+#: ../gui/wxpython/gis_set.py:220
#, python-format
msgid "ERROR: Mapset <%s> not found"
msgstr ""
-#: ../gui/wxpython/gis_set.py:429 ../gui/wxpython/gis_set.py:453
+#: ../gui/wxpython/gis_set.py:419 ../gui/wxpython/gis_set.py:443
msgid ""
"Current name: %s\n"
"Enter new name:"
msgstr "nombre nombre:"
-#: ../gui/wxpython/gis_set.py:430
+#: ../gui/wxpython/gis_set.py:420
msgid "Rename selected mapset"
-#: ../gui/wxpython/gis_set.py:441
+#: ../gui/wxpython/gis_set.py:431
msgid "Unable to rename mapset"
msgstr ""
-#: ../gui/wxpython/gis_set.py:454
+#: ../gui/wxpython/gis_set.py:444
msgid "Rename selected location"
-#: ../gui/wxpython/gis_set.py:467
+#: ../gui/wxpython/gis_set.py:457
msgid "Unable to rename location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:479
+#: ../gui/wxpython/gis_set.py:469
#, python-format
msgid ""
"Do you want to continue with deleting mapset <%(mapset)s> from location <%"
@@ -4338,15 +4511,15 @@
"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
msgstr ""
-#: ../gui/wxpython/gis_set.py:484
+#: ../gui/wxpython/gis_set.py:474
msgid "Delete selected mapset"
-#: ../gui/wxpython/gis_set.py:493
+#: ../gui/wxpython/gis_set.py:483
msgid "Unable to delete mapset"
msgstr ""
-#: ../gui/wxpython/gis_set.py:504
+#: ../gui/wxpython/gis_set.py:494
#, python-format
msgid ""
"Do you want to continue with deleting location <%s>?\n"
@@ -4354,165 +4527,198 @@
"ALL MAPS included in this location will be PERMANENTLY DELETED!"
msgstr ""
-#: ../gui/wxpython/gis_set.py:508
+#: ../gui/wxpython/gis_set.py:498
msgid "Delete selected location"
-#: ../gui/wxpython/gis_set.py:519
+#: ../gui/wxpython/gis_set.py:509
msgid "Unable to delete location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:645
+#: ../gui/wxpython/gis_set.py:657
#, fuzzy
msgid "Choose GIS Data Directory:"
msgstr "Seleccionar directorio de datos de GRASS:"
-#: ../gui/wxpython/gis_set.py:660
+#: ../gui/wxpython/gis_set.py:672
#, fuzzy
msgid "Enter name for new mapset:"
msgstr "nombre:"
-#: ../gui/wxpython/gis_set.py:661
+#: ../gui/wxpython/gis_set.py:673
#, fuzzy
msgid "Create new mapset"
msgstr "Crear nuevo mapa vectorial"
-#: ../gui/wxpython/gis_set.py:674
+#: ../gui/wxpython/gis_set.py:686
#, python-format
msgid "Unable to create new mapset: %s"
msgstr ""
-#: ../gui/wxpython/gis_set.py:705
+#: ../gui/wxpython/gis_set.py:720
msgid "GRASS Quickstart"
msgstr ""
-#: ../gui/wxpython/wxgui.py:96
+#: ../gui/wxpython/gis_set.py:822
+msgid "Starting GRASS for the first time"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:823
+msgid ""
+"GRASS needs a directory in which to store its data. Create one now if you "
+"have not already done so. A popular choice is \"grassdata\", located in your "
+"home directory."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:100
#, fuzzy
-msgid "GRASS GIS Layer Manager (Experimental Prototype)"
-msgstr "Capa"
+msgid "GRASS GIS Layer Manager"
+msgstr "Tabla"
-#: ../gui/wxpython/wxgui.py:306
+#: ../gui/wxpython/wxgui.py:212
+msgid "Cmd >"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:213
+msgid "Click for erasing command prompt"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:314
#, fuzzy
msgid "Map layers for each display"
msgstr "mostrar"
-#: ../gui/wxpython/wxgui.py:414 ../gui/wxpython/wxgui.py:1506
+#: ../gui/wxpython/wxgui.py:422 ../gui/wxpython/wxgui.py:1551
#, fuzzy
msgid "Do you want to save changes in the workspace?"
msgstr "vectorial?"
-#: ../gui/wxpython/wxgui.py:416 ../gui/wxpython/wxgui.py:1508
+#: ../gui/wxpython/wxgui.py:424 ../gui/wxpython/wxgui.py:1553
#, fuzzy
msgid "Do you want to store current settings to workspace file?"
msgstr "Entorno de trabajo?"
-#: ../gui/wxpython/wxgui.py:422
+#: ../gui/wxpython/wxgui.py:430
#, python-format
msgid ""
-"Do you want to close display %d?\n"
+"Do you want to close display %(display)d?\n"
"\n"
-"%s"
+"%(message)s"
msgstr ""
-#: ../gui/wxpython/wxgui.py:424
+#: ../gui/wxpython/wxgui.py:434
#, fuzzy
msgid "Close display"
msgstr "Borrar visualización"
-#: ../gui/wxpython/wxgui.py:468
+#: ../gui/wxpython/wxgui.py:482
msgid "Type GRASS command and run by pressing ENTER"
msgstr ""
-#: ../gui/wxpython/wxgui.py:591
+#: ../gui/wxpython/wxgui.py:610
#, fuzzy
msgid ""
"Current workspace is not empty. Do you want to store current settings to "
"workspace file?"
-#: ../gui/wxpython/wxgui.py:594
+#: ../gui/wxpython/wxgui.py:613
#, fuzzy
msgid "Create new workspace?"
msgstr "Crear nuevo archivo de entorno de trabajo"
-#: ../gui/wxpython/wxgui.py:619
+#: ../gui/wxpython/wxgui.py:638
msgid "Choose workspace file"
msgstr ""
-#: ../gui/wxpython/wxgui.py:683 ../gui/wxpython/wxgui.py:688
+#: ../gui/wxpython/wxgui.py:702 ../gui/wxpython/wxgui.py:707
#, python-format
msgid ""
"Reading workspace file <%s> failed. Invalid file, unable to parse XML "
"document."
msgstr ""
-#: ../gui/wxpython/wxgui.py:693 ../gui/wxpython/wxgui.py:798
-#: ../gui/wxpython/wxgui.py:834
+#: ../gui/wxpython/wxgui.py:712 ../gui/wxpython/wxgui.py:817
+#: ../gui/wxpython/wxgui.py:853
#, fuzzy
msgid "Please wait, loading workspace..."
msgstr "Guardar entorno de trabajo"
-#: ../gui/wxpython/wxgui.py:778
+#: ../gui/wxpython/wxgui.py:797
msgid "Unable to read workspace file"
msgstr ""
-#: ../gui/wxpython/wxgui.py:790 ../gui/wxpython/menustrings.py:15
+#: ../gui/wxpython/wxgui.py:809 ../gui/wxpython/menustrings.py:15
msgid "Load map layers into layer tree"
msgstr "Cargar capas de mapa en el árbol de capas"
-#: ../gui/wxpython/wxgui.py:818
+#: ../gui/wxpython/wxgui.py:837
msgid "Choose GRC file to load"
msgstr ""
-#: ../gui/wxpython/wxgui.py:857
+#: ../gui/wxpython/wxgui.py:876
#, fuzzy
msgid "Choose file to save current workspace"
msgstr "guardar"
-#: ../gui/wxpython/wxgui.py:872 ../gui/wxpython/wxgui.py:889
+#: ../gui/wxpython/wxgui.py:891 ../gui/wxpython/wxgui.py:908
#, python-format
msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
msgstr ""
"El archivo de entorno de trabajo <%s> ya existe. ¿Quiere sobrescribirlo?"
-#: ../gui/wxpython/wxgui.py:874 ../gui/wxpython/wxgui.py:892
+#: ../gui/wxpython/wxgui.py:893 ../gui/wxpython/wxgui.py:911
msgid "Save workspace"
-#: ../gui/wxpython/wxgui.py:911
+#: ../gui/wxpython/wxgui.py:930
#, python-format
msgid "Unable to open workspace file <%s> for writing."
msgstr ""
-#: ../gui/wxpython/wxgui.py:920
+#: ../gui/wxpython/wxgui.py:939
#, python-format
msgid "Writing current settings to workspace file failed (%s)."
msgstr ""
#: ../gui/wxpython/wxgui.py:1115
+#, fuzzy
+msgid "Add various raster-based map layers"
+msgstr "Añadir capa de mapa ráster"
+#: ../gui/wxpython/wxgui.py:1119
+#, fuzzy
+msgid "Add various vector-based map layer"
+msgstr "Añadir capa de mapa vectorial"
+#: ../gui/wxpython/wxgui.py:1136
msgid "Import DXF layers"
msgstr "Importar capas DXF"
-#: ../gui/wxpython/wxgui.py:1121
+#: ../gui/wxpython/wxgui.py:1142
#, fuzzy
msgid "Import GDAL layers"
-#: ../gui/wxpython/wxgui.py:1127
+#: ../gui/wxpython/wxgui.py:1148
#, fuzzy
msgid "Import OGR layers"
-#: ../gui/wxpython/wxgui.py:1152
+#: ../gui/wxpython/wxgui.py:1170
+msgid "Nothing to import. No WMS layer selected."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1196
#, fuzzy
msgid "Attribute management is available only for vector maps."
msgstr "vectorial."
-#: ../gui/wxpython/wxgui.py:1164
+#: ../gui/wxpython/wxgui.py:1208
msgid "Please wait, loading attribute data..."
msgstr ""
-#: ../gui/wxpython/wxgui.py:1475
+#: ../gui/wxpython/wxgui.py:1520
msgid ""
"Do you want to remove map layer(s)\n"
@@ -4520,21 +4726,21 @@
"from layer tree?"
-#: ../gui/wxpython/wxgui.py:1478
+#: ../gui/wxpython/wxgui.py:1523
#, fuzzy
msgid "Do you want to remove selected map layer(s) from layer tree?"
-#: ../gui/wxpython/wxgui.py:1482
+#: ../gui/wxpython/wxgui.py:1527
msgid "Remove map layer"
msgstr ""
-#: ../gui/wxpython/wxgui.py:1515
+#: ../gui/wxpython/wxgui.py:1560
#, fuzzy
msgid "Quit GRASS GUI"
msgstr "Acerca de la GUI wxPython de GRASS"
-#: ../gui/wxpython/wxgui.py:1545
+#: ../gui/wxpython/wxgui.py:1590
msgid "No map layer selected. Operation cancelled."
msgstr ""
@@ -5361,18 +5567,26 @@
msgstr "Cambiar configuración"
#: ../gui/wxpython/menustrings.py:191
+msgid "Change default GUI"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:192
+msgid "Changes the default GRASS graphical user interface (GUI) setting."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:193
msgid "Version"
msgstr "Versión"
-#: ../gui/wxpython/menustrings.py:192
+#: ../gui/wxpython/menustrings.py:194
msgid "Displays version and copyright information."
msgstr "Muestra información de versión y copyright."
-#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:194
+#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:196
msgid "Manage projections"
msgstr "Administrar proyecciones"
-#: ../gui/wxpython/menustrings.py:195
+#: ../gui/wxpython/menustrings.py:197
msgid ""
"Converts co-ordinate system descriptions (i.e. projection information) "
"between various formats (including GRASS format). Can also be used to create "
@@ -5382,119 +5596,119 @@
"proyección) entre varios formatos (incluido el formato GRASS). También puede "
"usarse para crear localizaciones de GRASS."
-#: ../gui/wxpython/menustrings.py:196
+#: ../gui/wxpython/menustrings.py:198
msgid "Projection for current location"
msgstr "Proyección para la localización actual"
-#: ../gui/wxpython/menustrings.py:197
+#: ../gui/wxpython/menustrings.py:199
msgid "Create/edit projection information for current location"
msgstr ""
"Crear/editar la información de la proyección para la localización activa"
-#: ../gui/wxpython/menustrings.py:198
+#: ../gui/wxpython/menustrings.py:200
msgid "Convert coordinates"
-#: ../gui/wxpython/menustrings.py:199
+#: ../gui/wxpython/menustrings.py:201
msgid "Convert coordinates from one projection to another (cs2cs frontend)."
msgstr "Convierte coordenadas de una proyección a otra (interfaz cs2cs)."
-#: ../gui/wxpython/menustrings.py:200
+#: ../gui/wxpython/menustrings.py:202
msgid "Preferences"
msgstr "Configuración"
-#: ../gui/wxpython/menustrings.py:201
+#: ../gui/wxpython/menustrings.py:203
msgid "User GUI preferences (display font, commands, digitizer, etc.)"
msgstr ""
"Preferencias del usuario para la GUI (tipo de letra de visualización, "
"órdenes, digitalizador, etc.)"
-#: ../gui/wxpython/menustrings.py:202
+#: ../gui/wxpython/menustrings.py:204
msgid "Raster"
msgstr "Ráster"
-#: ../gui/wxpython/menustrings.py:203
+#: ../gui/wxpython/menustrings.py:205
msgid "Develop raster map"
msgstr "Desarrollar mapa ráster"
-#: ../gui/wxpython/menustrings.py:204
+#: ../gui/wxpython/menustrings.py:206
msgid "Digitize raster (requires XTerm)"
msgstr "Digitalizar ráster (requiere XTerm)"
-#: ../gui/wxpython/menustrings.py:205
+#: ../gui/wxpython/menustrings.py:207
msgid "Digitize raster map"
msgstr "Digitalizar mapa ráster"
-#: ../gui/wxpython/menustrings.py:206
+#: ../gui/wxpython/menustrings.py:208
msgid "Compress/decompress"
msgstr "Comprimir/descomprimir"
-#: ../gui/wxpython/menustrings.py:207
+#: ../gui/wxpython/menustrings.py:209
msgid "Compresses and decompresses raster maps."
msgstr "Comprime y descomprime mapas ráster."
-#: ../gui/wxpython/menustrings.py:208
+#: ../gui/wxpython/menustrings.py:210
msgid "Region boundaries"
msgstr "Contornos de región"
-#: ../gui/wxpython/menustrings.py:209
+#: ../gui/wxpython/menustrings.py:211
msgid "Sets the boundary definitions for a raster map."
msgstr "Establece las definiciones de los bordes para un mapa ráster."
-#: ../gui/wxpython/menustrings.py:210
+#: ../gui/wxpython/menustrings.py:212
msgid "Manage NULL values"
msgstr "Administrar valores NULOS"
-#: ../gui/wxpython/menustrings.py:211
+#: ../gui/wxpython/menustrings.py:213
msgid "Creates explicitly the NULL-value bitmap file."
msgstr "Crea de forma explÃcita el archivo de mapa de bits de valor NULO."
-#: ../gui/wxpython/menustrings.py:212
+#: ../gui/wxpython/menustrings.py:214
msgid "Quantization"
msgstr "Quantización"
-#: ../gui/wxpython/menustrings.py:213
+#: ../gui/wxpython/menustrings.py:215
msgid "Produces the quantization file for a floating-point map."
msgstr "Produce el archivo de cuantización para un mapa de coma flotante."
-#: ../gui/wxpython/menustrings.py:214
+#: ../gui/wxpython/menustrings.py:216
msgid "Timestamp"
msgstr "Marca de tiempo"
-#: ../gui/wxpython/menustrings.py:215
+#: ../gui/wxpython/menustrings.py:217
msgid "Print/add/remove a timestamp for a raster map."
msgstr "Imprimir/añadir/eliminar marca de tiempo para un mapa ráster."
-#: ../gui/wxpython/menustrings.py:216
+#: ../gui/wxpython/menustrings.py:218
msgid "Resample using aggregate statistics"
msgstr "Volver a muestrear utilizando estadÃstica de conjuntos"
-#: ../gui/wxpython/menustrings.py:217
+#: ../gui/wxpython/menustrings.py:219
msgid "Resamples raster map layers using aggregation."
msgstr "Vuelve a muestrear capas de mapa ráster usando agregación."
-#: ../gui/wxpython/menustrings.py:218
+#: ../gui/wxpython/menustrings.py:220
msgid "Resample using multiple methods"
msgstr "Volver a muestrear utilizando varios métodos"
-#: ../gui/wxpython/menustrings.py:219
+#: ../gui/wxpython/menustrings.py:221
msgid "Resamples raster map layers using interpolation."
msgstr "Remuestrea capas de mapas ráster usando interpolación."
-#: ../gui/wxpython/menustrings.py:220
+#: ../gui/wxpython/menustrings.py:222
msgid "Resample using nearest neighbor"
msgstr "Volver a muestrear utilizando el vecino más próximo"
-#: ../gui/wxpython/menustrings.py:221
+#: ../gui/wxpython/menustrings.py:223
msgid "GRASS raster map layer data resampling capability."
msgstr "Capacidad de remuestreo de datos de capa de mapa ráster de GRASS."
-#: ../gui/wxpython/menustrings.py:222
+#: ../gui/wxpython/menustrings.py:224
#, fuzzy
msgid "Resample using spline tension"
msgstr "Volver a muestrear usando tensión spline"
-#: ../gui/wxpython/menustrings.py:223
+#: ../gui/wxpython/menustrings.py:225
msgid ""
"Reinterpolates and optionally computes topographic analysis from input "
"raster map to a new raster map (possibly with different resolution) using "
@@ -5504,49 +5718,49 @@
"entrada a un nuevo mapa ráster (posiblemente con distinta resolución) "
"usando ."
-#: ../gui/wxpython/menustrings.py:224
+#: ../gui/wxpython/menustrings.py:226
msgid "Support file maintenance"
msgstr "Soportar mantenimiento de archivos"
-#: ../gui/wxpython/menustrings.py:225
+#: ../gui/wxpython/menustrings.py:227
msgid "Allows creation and/or modification of raster map layer support files."
msgstr ""
"Permite la creación y/o modificación de archivos de soporte de capas de "
"mapas ráster."
-#: ../gui/wxpython/menustrings.py:226
+#: ../gui/wxpython/menustrings.py:228
msgid "Update map statistics"
msgstr "Actualizar estadÃsticas de mapa"
-#: ../gui/wxpython/menustrings.py:227
+#: ../gui/wxpython/menustrings.py:229
msgid "Update raster map statistics"
msgstr "Actualizar estadÃsticas del mapa ráster"
-#: ../gui/wxpython/menustrings.py:228
+#: ../gui/wxpython/menustrings.py:230
#, fuzzy
msgid "Link to GDAL"
msgstr "Enlazar a OGR"
-#: ../gui/wxpython/menustrings.py:229
+#: ../gui/wxpython/menustrings.py:231
#, fuzzy
msgid "Link GDAL supported raster file to a binary raster map layer."
msgstr ""
"Importar archivo ráster soportado por GDAL a una capa de mapa ráster binario."
-#: ../gui/wxpython/menustrings.py:230
+#: ../gui/wxpython/menustrings.py:232
msgid "Reproject raster"
msgstr "Reproyectar ráster"
-#: ../gui/wxpython/menustrings.py:231
+#: ../gui/wxpython/menustrings.py:233
msgid "Re-projects a raster map from one location to the current location."
msgstr ""
"Reproyecta un mapa ráster desde una localización a la localización actual."
-#: ../gui/wxpython/menustrings.py:232
+#: ../gui/wxpython/menustrings.py:234
msgid "Tiling"
msgstr "Teselado"
-#: ../gui/wxpython/menustrings.py:233
+#: ../gui/wxpython/menustrings.py:235
msgid ""
"Produces tilings of the source projection for use in the destination region "
"and projection."
@@ -5554,59 +5768,59 @@
"Produce teselado de la proyección del origen para usarlo en la región y "
"proyección de destino."
-#: ../gui/wxpython/menustrings.py:234 ../gui/wxpython/menustrings.py:495
+#: ../gui/wxpython/menustrings.py:236 ../gui/wxpython/menustrings.py:497
msgid "Manage colors"
msgstr "Administrar colores"
-#: ../gui/wxpython/menustrings.py:235 ../gui/wxpython/menustrings.py:496
+#: ../gui/wxpython/menustrings.py:237 ../gui/wxpython/menustrings.py:498
msgid "Color tables"
-#: ../gui/wxpython/menustrings.py:236
+#: ../gui/wxpython/menustrings.py:238
msgid "Creates/modifies the color table associated with a raster map layer."
msgstr "Crea/modifica la tabla de colores asociada a una capa de mapa ráster."
-#: ../gui/wxpython/menustrings.py:237
+#: ../gui/wxpython/menustrings.py:239
#, fuzzy
msgid "Color tables (stddev)"
-#: ../gui/wxpython/menustrings.py:238
+#: ../gui/wxpython/menustrings.py:240
msgid "Set color rules based on stddev from a map's mean value."
msgstr ""
-#: ../gui/wxpython/menustrings.py:239 ../gui/wxpython/menustrings.py:498
+#: ../gui/wxpython/menustrings.py:241 ../gui/wxpython/menustrings.py:500
msgid "Color rules"
-#: ../gui/wxpython/menustrings.py:240 ../gui/wxpython/menustrings.py:499
+#: ../gui/wxpython/menustrings.py:242 ../gui/wxpython/menustrings.py:501
msgid "Set colors interactively by entering color rules"
msgstr "Establecer colores de forma interactiva introduciendo reglas de color"
-#: ../gui/wxpython/menustrings.py:241
+#: ../gui/wxpython/menustrings.py:243
msgid "Blend 2 color rasters"
msgstr "Mezclar 2 ráster en color"
-#: ../gui/wxpython/menustrings.py:242
+#: ../gui/wxpython/menustrings.py:244
msgid "Blends color components of two raster maps by a given ratio."
msgstr ""
"Mezcla los componentes de color de dos mapas ráster en la proporción indicada"
-#: ../gui/wxpython/menustrings.py:243
+#: ../gui/wxpython/menustrings.py:245
msgid "Create RGB"
msgstr "Crear RGB"
-#: ../gui/wxpython/menustrings.py:244
+#: ../gui/wxpython/menustrings.py:246
msgid ""
"Combines red, green and blue map layers into a single composite map layer."
msgstr ""
"Combina capas de mapa roja, verde y azul en una sola capa de mapa compuesto."
-#: ../gui/wxpython/menustrings.py:245 ../gui/wxpython/menustrings.py:614
+#: ../gui/wxpython/menustrings.py:247 ../gui/wxpython/menustrings.py:616
msgid "RGB to HIS"
msgstr "RGB a HIS"
-#: ../gui/wxpython/menustrings.py:246
+#: ../gui/wxpython/menustrings.py:248
msgid ""
"Generates red, green and blue raster map layers combining hue, intensity and "
"saturation (HIS) values from user-specified input raster map layers."
@@ -5615,21 +5829,21 @@
"intensidad y saturación (HIS) a partir de capas de mapa ráster de entrada "
"especificadas por el usuario."
-#: ../gui/wxpython/menustrings.py:247
+#: ../gui/wxpython/menustrings.py:249
msgid "Query by coordinates"
msgstr "Consultar por coordenadas"
-#: ../gui/wxpython/menustrings.py:248
+#: ../gui/wxpython/menustrings.py:250
msgid "Queries raster map layers on their category values and category labels."
msgstr ""
"Consulta capas de mapa ráster en sus valores de categorÃa y etiquetas de "
"categorÃa."
-#: ../gui/wxpython/menustrings.py:249
+#: ../gui/wxpython/menustrings.py:251
msgid "Buffer rasters"
msgstr "Hacer buffer de ráster"
-#: ../gui/wxpython/menustrings.py:250
+#: ../gui/wxpython/menustrings.py:252
msgid ""
"Creates a raster map layer showing buffer zones surrounding cells that "
"contain non-NULL category values."
@@ -5637,35 +5851,35 @@
"Crea una capa de mapa ráster que muestra zonas de buffer que rodean celdas "
"que contienen valores de categorÃa no NULOS."
-#: ../gui/wxpython/menustrings.py:251
+#: ../gui/wxpython/menustrings.py:253
msgid "Closest points"
msgstr "Puntos más cercanos"
-#: ../gui/wxpython/menustrings.py:252
+#: ../gui/wxpython/menustrings.py:254
msgid "Locates the closest points between objects in two raster maps."
msgstr "Localiza los puntos más próximos entre objetos en dos mapas ráster."
-#: ../gui/wxpython/menustrings.py:254
+#: ../gui/wxpython/menustrings.py:256
msgid "Create a MASK for limiting raster operation"
msgstr "Crear una MÃSCARA para limitar la operación ráster"
-#: ../gui/wxpython/menustrings.py:255
+#: ../gui/wxpython/menustrings.py:257
msgid "Map calculator"
msgstr "Calculadora de mapas"
-#: ../gui/wxpython/menustrings.py:256
+#: ../gui/wxpython/menustrings.py:258
msgid "Map calculator for raster map algebra"
msgstr "Calculadora de mapas para álgebra de mapas ráster"
-#: ../gui/wxpython/menustrings.py:257
+#: ../gui/wxpython/menustrings.py:259
msgid "Neighborhood analysis"
msgstr "Análisis del vecino más próximo"
-#: ../gui/wxpython/menustrings.py:258
+#: ../gui/wxpython/menustrings.py:260
msgid "Moving window"
msgstr "Moviendo la ventana"
-#: ../gui/wxpython/menustrings.py:259
+#: ../gui/wxpython/menustrings.py:261
msgid ""
"Makes each cell category value a function of the category values assigned to "
"the cells around it, and stores new cell values in an output raster map "
@@ -5675,11 +5889,11 @@
"categorÃa asignados a las celdas a su alrededor y guarda los nuevos valores "
"de celda en una capa de mapa ráster de salida."
-#: ../gui/wxpython/menustrings.py:260
+#: ../gui/wxpython/menustrings.py:262
msgid "Neighborhood points"
msgstr "Puntos de vecindario"
-#: ../gui/wxpython/menustrings.py:261
+#: ../gui/wxpython/menustrings.py:263
msgid ""
"Makes each cell value a function of the attribute values assigned to the "
"vector points or centroids around it, and stores new cell values in an "
@@ -5689,15 +5903,15 @@
"asignados a los puntos vectoriales o centroides a su alrededor y guarda los "
"nuevos valores de celda en una capa de mapa ráster de salida."
-#: ../gui/wxpython/menustrings.py:262
+#: ../gui/wxpython/menustrings.py:264
msgid "Overlay rasters"
msgstr "Superponer ráster"
-#: ../gui/wxpython/menustrings.py:263
+#: ../gui/wxpython/menustrings.py:265
msgid "Cross product"
msgstr "Cruzar productos"
-#: ../gui/wxpython/menustrings.py:264
+#: ../gui/wxpython/menustrings.py:266
msgid ""
"Creates a cross product of the category values from multiple raster map "
"layers."
@@ -5705,11 +5919,11 @@
"Crea un producto cruzado de los valores de categorÃa a partir de múltiples "
"capas de mapa ráster."
-#: ../gui/wxpython/menustrings.py:265
+#: ../gui/wxpython/menustrings.py:267
msgid "Raster series"
msgstr "Series de ráster"
-#: ../gui/wxpython/menustrings.py:266
+#: ../gui/wxpython/menustrings.py:268
msgid ""
"Makes each output cell value a function of the values assigned to the "
"corresponding cells in the input raster map layers."
@@ -5717,12 +5931,12 @@
"Hace cada valor de celda de salida una función de los valores asignados a "
"las celdas correspondientes en las capas de mapa ráster de entrada."
-#: ../gui/wxpython/menustrings.py:267
+#: ../gui/wxpython/menustrings.py:269
#, fuzzy
msgid "Patch raster maps"
msgstr "ráster"
-#: ../gui/wxpython/menustrings.py:268
+#: ../gui/wxpython/menustrings.py:270
msgid ""
"Creates a composite raster map layer by using known category values from one "
"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
@@ -5731,23 +5945,23 @@
"de una (o más) capa(s) de mapa para rellenar áreas \"sin datos\" en otra "
"capa de mapa."
-#: ../gui/wxpython/menustrings.py:269
+#: ../gui/wxpython/menustrings.py:271
msgid "Statistical overlay"
msgstr "Superposición estadÃstica"
-#: ../gui/wxpython/menustrings.py:270
+#: ../gui/wxpython/menustrings.py:272
msgid "Calculates category or object oriented statistics."
msgstr "Calcula estadÃsticas orientadas a categorÃas u objetos."
-#: ../gui/wxpython/menustrings.py:271
+#: ../gui/wxpython/menustrings.py:273
msgid "Solar radiance and shadows"
msgstr "Radiación solar y sombras"
-#: ../gui/wxpython/menustrings.py:272
+#: ../gui/wxpython/menustrings.py:274
msgid "Solar irradiance and irradiation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:273
+#: ../gui/wxpython/menustrings.py:275
msgid ""
"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
"for given day, latitude, surface and atmospheric conditions. Solar "
@@ -5766,11 +5980,11 @@
"irradiancia. El efecto de sombreo de la topografÃa se puede incorporar "
"opcionalmente."
-#: ../gui/wxpython/menustrings.py:274
+#: ../gui/wxpython/menustrings.py:276
msgid "Shadows map"
msgstr "Mapa de sombras"
-#: ../gui/wxpython/menustrings.py:275
+#: ../gui/wxpython/menustrings.py:277
#, fuzzy
msgid ""
"Calculates cast shadow areas from sun position and DEM. Either A: exact sun "
@@ -5778,15 +5992,15 @@
"sunmask itself."
msgstr "Calcula áreas a."
-#: ../gui/wxpython/menustrings.py:276
+#: ../gui/wxpython/menustrings.py:278
msgid "Terrain analysis"
msgstr "Análisis del terreno"
-#: ../gui/wxpython/menustrings.py:277
+#: ../gui/wxpython/menustrings.py:279
msgid "Cumulative movement costs"
msgstr "Costes acumulados de movimientos"
-#: ../gui/wxpython/menustrings.py:278
+#: ../gui/wxpython/menustrings.py:280
msgid ""
"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
"between different geographic locations on an input elevation raster map "
@@ -5799,11 +6013,11 @@
"representan elevación combinada con una capa de mapa ráster de entrada cuyos "
"valores de celda representan coste de fricción."
-#: ../gui/wxpython/menustrings.py:279
+#: ../gui/wxpython/menustrings.py:281
msgid "Cost surface"
-#: ../gui/wxpython/menustrings.py:280
+#: ../gui/wxpython/menustrings.py:282
msgid ""
"Outputs a raster map layer showing the cumulative cost of moving between "
"different geographic locations on an input raster map layer whose cell "
@@ -5813,25 +6027,25 @@
"entre diferentes localizaciones geográficas en una capa de mapa ráster de "
"entrada cuyos valores de categorÃa de celdas representan coste."
-#: ../gui/wxpython/menustrings.py:281
+#: ../gui/wxpython/menustrings.py:283
msgid "Least cost route or flow"
msgstr "Ruta o corriente de costes mÃnimos"
-#: ../gui/wxpython/menustrings.py:282
+#: ../gui/wxpython/menustrings.py:284
msgid "Traces a flow through an elevation model on a raster map layer."
msgstr ""
"Traza un flujo mediante un modelo de elevación sobre una capa de mapa ráster."
-#: ../gui/wxpython/menustrings.py:284
+#: ../gui/wxpython/menustrings.py:286
msgid "Creates shaded relief map from an elevation map (DEM)."
msgstr ""
"Crea un mapa compartido de relieve a partir de un mapa de elevaciones (DEM)."
-#: ../gui/wxpython/menustrings.py:285
+#: ../gui/wxpython/menustrings.py:287
msgid "Slope and aspect"
msgstr "Pendiente y orientación"
-#: ../gui/wxpython/menustrings.py:286
+#: ../gui/wxpython/menustrings.py:288
msgid ""
"Generates raster map layers of slope, aspect, curvatures and partial "
"derivatives from a raster map layer of true elevation values. Aspect is "
@@ -5841,11 +6055,11 @@
"derivadas parciales a partir de una capa de mapa ráster de valores reales de "
"elevación. La orientación se calcula en sentido horario desde el Este."
-#: ../gui/wxpython/menustrings.py:287
+#: ../gui/wxpython/menustrings.py:289
msgid "Terrain parameters"
msgstr "Parámetros del terreno"
-#: ../gui/wxpython/menustrings.py:288
+#: ../gui/wxpython/menustrings.py:290
msgid ""
"Uses a multi-scale approach by taking fitting quadratic parameters to any "
"size window (via least squares)."
@@ -5853,51 +6067,51 @@
"Utiliza una aproximación multiescala tomando parámetros cuadráticos que se "
"ajusten a cualquier tamaño de ventana (vÃa las menores esquinas)."
-#: ../gui/wxpython/menustrings.py:289
+#: ../gui/wxpython/menustrings.py:291
msgid "Textural features"
msgstr "Entidades de textura"
-#: ../gui/wxpython/menustrings.py:290
+#: ../gui/wxpython/menustrings.py:292
msgid "Generate images with textural features from a raster map."
msgstr "Genera imágenes con elementos texturales a partir de un mapa ráster."
-#: ../gui/wxpython/menustrings.py:291
+#: ../gui/wxpython/menustrings.py:293
msgid "Visibility"
msgstr "Visibilidad"
-#: ../gui/wxpython/menustrings.py:292
+#: ../gui/wxpython/menustrings.py:294
msgid "Line-of-sight raster analysis program."
msgstr "Programa de análisis ráster de lÃnea visual."
-#: ../gui/wxpython/menustrings.py:293
+#: ../gui/wxpython/menustrings.py:295
#, fuzzy
msgid "Distance to features"
msgstr "Elementos más próximos"
-#: ../gui/wxpython/menustrings.py:294
+#: ../gui/wxpython/menustrings.py:296
#, fuzzy
msgid "Generates a raster map layer of distance to features in input layer."
msgstr ""
"Genera una capa de mapa ráster con áreas contiguas incrementadas en una "
"celda."
-#: ../gui/wxpython/menustrings.py:295
+#: ../gui/wxpython/menustrings.py:297
msgid "Horizon angle"
msgstr ""
-#: ../gui/wxpython/menustrings.py:296
+#: ../gui/wxpython/menustrings.py:298
msgid "Horizon angle computation from a digital elevation model."
msgstr ""
-#: ../gui/wxpython/menustrings.py:297
+#: ../gui/wxpython/menustrings.py:299
msgid "Transform features"
msgstr "Transformar objetos espaciales"
-#: ../gui/wxpython/menustrings.py:298
+#: ../gui/wxpython/menustrings.py:300
msgid "Clump"
msgstr "Agrupar"
-#: ../gui/wxpython/menustrings.py:299
+#: ../gui/wxpython/menustrings.py:301
msgid ""
"Recategorizes data in a raster map layer by grouping cells that form "
"physically discrete areas into unique categories."
@@ -5905,35 +6119,35 @@
"Recategoriza datos en una capa de mapa ráster agrupando celdas que forman "
"áreas fÃsicamente discretas en categorÃas únicas."
-#: ../gui/wxpython/menustrings.py:300
+#: ../gui/wxpython/menustrings.py:302
msgid "Grow"
msgstr "Incrementar"
-#: ../gui/wxpython/menustrings.py:301
+#: ../gui/wxpython/menustrings.py:303
msgid "Generates a raster map layer with contiguous areas grown by one cell."
msgstr ""
"celda."
-#: ../gui/wxpython/menustrings.py:302
+#: ../gui/wxpython/menustrings.py:304
msgid "Thin"
msgstr "Adelgazar"
-#: ../gui/wxpython/menustrings.py:303
+#: ../gui/wxpython/menustrings.py:305
msgid "Thins non-zero cells that denote linear features in a raster map layer."
msgstr ""
"Adelgaza celdas no cero que indican elementos lineales en una capa de mapa "
"ráster."
-#: ../gui/wxpython/menustrings.py:304
+#: ../gui/wxpython/menustrings.py:306
msgid "Hydrologic modeling"
msgstr "Modelo hidrológico"
-#: ../gui/wxpython/menustrings.py:305
+#: ../gui/wxpython/menustrings.py:307
msgid "Carve stream channels"
msgstr "Canales de corrientes de excavación"
-#: ../gui/wxpython/menustrings.py:306
+#: ../gui/wxpython/menustrings.py:308
msgid ""
"Takes vector stream data, transforms it to raster and subtracts depth from "
"the output DEM."
@@ -5941,19 +6155,19 @@
"Toma datos de corriente vectorial, los transforma a ráster y resta la "
"profundidad del MDT de salida."
-#: ../gui/wxpython/menustrings.py:307
+#: ../gui/wxpython/menustrings.py:309
msgid "Fill lake"
msgstr "Rellenar lago"
-#: ../gui/wxpython/menustrings.py:308
+#: ../gui/wxpython/menustrings.py:310
msgid "Fills lake from seed at given level"
msgstr ""
-#: ../gui/wxpython/menustrings.py:309
+#: ../gui/wxpython/menustrings.py:311
msgid "Depressionless map and flowlines"
msgstr "Mapa sin depresiones y lÃneas de flujos"
-#: ../gui/wxpython/menustrings.py:310
+#: ../gui/wxpython/menustrings.py:312
msgid ""
"Filters and generates a depressionless elevation map and a flow direction "
"map from a given elevation layer."
@@ -5961,19 +6175,19 @@
"Filtra y genera un mapa de elevación sin depresiones y un mapa de dirección "
"de flujo a partir de una capa de elevación dada."
-#: ../gui/wxpython/menustrings.py:311
+#: ../gui/wxpython/menustrings.py:313
msgid "Flow accumulation"
msgstr "Acumulación de flujos"
-#: ../gui/wxpython/menustrings.py:312
+#: ../gui/wxpython/menustrings.py:314
msgid "Flow computation for massive grids (Float version)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:313
+#: ../gui/wxpython/menustrings.py:315
msgid "Flow lines"
-#: ../gui/wxpython/menustrings.py:314
+#: ../gui/wxpython/menustrings.py:316
msgid ""
"Construction of slope curves (flowlines), flowpath lengths, and flowline "
"densities (upslope areas) from a raster digital elevation model (DEM)"
@@ -5982,85 +6196,85 @@
"flujo y densidades de lÃneas de flujo (áreas pendiente arriba) a partir de "
"un modelo de elevación digital (MDT) ráster"
-#: ../gui/wxpython/menustrings.py:315
+#: ../gui/wxpython/menustrings.py:317
msgid "SIMWE Overland flow modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:316
+#: ../gui/wxpython/menustrings.py:318
msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
msgstr ""
"Modelo hidrológico de flujo superficial basado en el concepto de dualidad "
"partÃcula-terreno (SIMWE)"
-#: ../gui/wxpython/menustrings.py:317
+#: ../gui/wxpython/menustrings.py:319
msgid "SIMWE Sediment flux modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:318
+#: ../gui/wxpython/menustrings.py:320
msgid ""
"Sediment transport and erosion/deposition simulation using path sampling "
"method (SIMWE)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:319
+#: ../gui/wxpython/menustrings.py:321
msgid "Topographic index map"
msgstr "Mapa de Ãndice topográfico"
-#: ../gui/wxpython/menustrings.py:320
+#: ../gui/wxpython/menustrings.py:322
msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
msgstr ""
"Crea mapa de Ãndices topográficos [ln(a/tan(beta))] a partir de mapa de "
"elevación."
-#: ../gui/wxpython/menustrings.py:321
+#: ../gui/wxpython/menustrings.py:323
msgid "TOPMODEL simulation"
msgstr "Simulación TOPMODEL"
-#: ../gui/wxpython/menustrings.py:322
+#: ../gui/wxpython/menustrings.py:324
msgid "Simulates TOPMODEL which is a physically based hydrologic model."
msgstr "Simula TOPMODEL que es un modelo hidrológico basado fÃsicamente."
-#: ../gui/wxpython/menustrings.py:323
+#: ../gui/wxpython/menustrings.py:325
msgid "Watershed subbasins"
msgstr "Delimitación de sub-cuencas hidrográficas"
-#: ../gui/wxpython/menustrings.py:324
+#: ../gui/wxpython/menustrings.py:326
msgid "Generates a raster map layer showing watershed subbasins."
msgstr "Genera una capa de mapa ráster mostrando subcuencas hidrográficas."
-#: ../gui/wxpython/menustrings.py:325
+#: ../gui/wxpython/menustrings.py:327
msgid "Watershed analysis"
msgstr "Análisis de cuencas hidrográficas"
-#: ../gui/wxpython/menustrings.py:326
+#: ../gui/wxpython/menustrings.py:328
msgid "Watershed basin analysis program."
msgstr "Programa de análisis de cuenca hidrográfica."
-#: ../gui/wxpython/menustrings.py:327
+#: ../gui/wxpython/menustrings.py:329
msgid "Watershed basin creation"
msgstr "Creación de cuencas hidrográficas"
-#: ../gui/wxpython/menustrings.py:328
+#: ../gui/wxpython/menustrings.py:330
msgid "Watershed basin creation program."
msgstr "Programa de creación de cuenca hidrográfica."
-#: ../gui/wxpython/menustrings.py:329
+#: ../gui/wxpython/menustrings.py:331
msgid "Landscape structure modeling"
msgstr "Modelado de la estructura del paisaje"
-#: ../gui/wxpython/menustrings.py:330
+#: ../gui/wxpython/menustrings.py:332
msgid "Set up (requires XTerm)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:331 ../gui/wxpython/menustrings.py:339
+#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:341
msgid "Set up sampling and analysis framework"
msgstr "Ajustar el muestreo y analizar un entorno de trabajo"
-#: ../gui/wxpython/menustrings.py:332
+#: ../gui/wxpython/menustrings.py:334
msgid "Analyze landscape"
msgstr "Analizar paisaje"
-#: ../gui/wxpython/menustrings.py:333
+#: ../gui/wxpython/menustrings.py:335
msgid ""
"Contains a set of measures for attributes, diversity, texture, "
"juxtaposition, and edge."
@@ -6068,11 +6282,11 @@
"Contiene un conjunto de medidas para atributos, diversidad, textura, "
"yuxtaposición y borde."
-#: ../gui/wxpython/menustrings.py:334
+#: ../gui/wxpython/menustrings.py:336
msgid "Analyze patches"
msgstr "Analizar parcelas"
-#: ../gui/wxpython/menustrings.py:335
+#: ../gui/wxpython/menustrings.py:337
msgid ""
"Calculates attribute, patch size, core (interior) size, shape, fractal "
"dimension, and perimeter measures for sets of patches in a landscape."
@@ -6081,11 +6295,11 @@
"dimensión fractal y medidas del perÃmetro para conjuntos de parches en un "
"paisaje."
-#: ../gui/wxpython/menustrings.py:336
+#: ../gui/wxpython/menustrings.py:338
msgid "Output"
msgstr "Salida"
-#: ../gui/wxpython/menustrings.py:337
+#: ../gui/wxpython/menustrings.py:339
msgid ""
"Displays the boundary of each r.le patch and shows how the boundary is "
"traced, displays the attribute, size, perimeter and shape indices for each "
@@ -6095,39 +6309,39 @@
"contorno, muestra los atributos, tamaño, perÃmetro e Ãndices de forma para "
"cada parche y guarda los datos en un fichero de salida."
-#: ../gui/wxpython/menustrings.py:338
+#: ../gui/wxpython/menustrings.py:340
msgid "Landscape patch analysis"
msgstr "Analizar parcelas del paisaje"
-#: ../gui/wxpython/menustrings.py:340
+#: ../gui/wxpython/menustrings.py:342
msgid "Configuration editor for r.li.'index'"
msgstr "Editor de configuración para el Ãndice r.li"
-#: ../gui/wxpython/menustrings.py:341
+#: ../gui/wxpython/menustrings.py:343
msgid "Edge density"
msgstr "Densidad de borde"
-#: ../gui/wxpython/menustrings.py:342
+#: ../gui/wxpython/menustrings.py:344
msgid ""
"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
"Calcula el Ãndice de densidad de borde en un mapa ráster usando un algoritmo "
"de 4 vecinos"
-#: ../gui/wxpython/menustrings.py:343
+#: ../gui/wxpython/menustrings.py:345
msgid "Contrast weighted edge density"
msgstr "Calcular Ãndice de densidad de borde"
-#: ../gui/wxpython/menustrings.py:344
+#: ../gui/wxpython/menustrings.py:346
#, fuzzy
msgid "Calculates contrast weighted edge density index on a raster map"
msgstr "Calcula ráster"
-#: ../gui/wxpython/menustrings.py:345
+#: ../gui/wxpython/menustrings.py:347
msgid "Patch area mean"
msgstr ""
-#: ../gui/wxpython/menustrings.py:346
+#: ../gui/wxpython/menustrings.py:348
msgid ""
"Calculates mean patch size index on a raster map, using a 4 neighbour "
"algorithm"
@@ -6135,98 +6349,98 @@
"Calcula el Ãndice de tamaño medio de parche en un mapa ráster usando un "
"algoritmo de 4 vecinos"
-#: ../gui/wxpython/menustrings.py:347
+#: ../gui/wxpython/menustrings.py:349
msgid "Patch area range"
msgstr "Rango de superficie de parcela"
-#: ../gui/wxpython/menustrings.py:348
+#: ../gui/wxpython/menustrings.py:350
msgid "Calculates range of patch area size on a raster map"
msgstr "Calcula el rango de tamaño de área de parche en un mapa ráster"
-#: ../gui/wxpython/menustrings.py:349
+#: ../gui/wxpython/menustrings.py:351
msgid "Patch area Std Dev"
msgstr "Desviación estándar de superficie de parcela"
-#: ../gui/wxpython/menustrings.py:350
+#: ../gui/wxpython/menustrings.py:352
msgid "Calculates standard deviation of patch area a raster map"
msgstr "Calcula la desviación estándar del área de parche en un mapa ráster"
-#: ../gui/wxpython/menustrings.py:351
+#: ../gui/wxpython/menustrings.py:353
msgid "Patch area Coeff Var"
msgstr "Coeficiente de varianza de superficie de parcela"
-#: ../gui/wxpython/menustrings.py:352
+#: ../gui/wxpython/menustrings.py:354
msgid "Calculates coefficient of variation of patch area on a raster map"
msgstr ""
"Calcula el coeficiente de varianza del área de parche en un mapa ráster"
-#: ../gui/wxpython/menustrings.py:353
+#: ../gui/wxpython/menustrings.py:355
msgid "Patch density"
msgstr "Densidad de parcela"
-#: ../gui/wxpython/menustrings.py:354
+#: ../gui/wxpython/menustrings.py:356
msgid ""
"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
"Calcula el Ãndice de densidad de parche sobre un mapa ráster usando un "
-#: ../gui/wxpython/menustrings.py:355
+#: ../gui/wxpython/menustrings.py:357
msgid "Patch number"
msgstr "Número de parcelas"
-#: ../gui/wxpython/menustrings.py:356
+#: ../gui/wxpython/menustrings.py:358
msgid ""
"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
msgstr ""
"Calcula el Ãndice de número de parche en un mapa ráster usando un algoritmo "
"de 4 vecinos."
-#: ../gui/wxpython/menustrings.py:357
+#: ../gui/wxpython/menustrings.py:359
msgid "Dominance's diversity"
msgstr "Diversidad de dominancia"
-#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:364
+#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:366
msgid "Calculates dominance's diversity index on a raster map"
msgstr "Calcula el Ãndice de diversidad de la dominancia en un mapa ráster"
-#: ../gui/wxpython/menustrings.py:359
+#: ../gui/wxpython/menustrings.py:361
msgid "Shannon's diversity"
msgstr "Diversidad de Shannon"
-#: ../gui/wxpython/menustrings.py:360
+#: ../gui/wxpython/menustrings.py:362
msgid "Calculates Shannon's diversity index on a raster map"
msgstr "Calcula el Ãndice de diversidad de Shannon en un mapa ráster"
-#: ../gui/wxpython/menustrings.py:361
+#: ../gui/wxpython/menustrings.py:363
msgid "Simpson's diversity"
msgstr "Diversidad de Simpson"
-#: ../gui/wxpython/menustrings.py:362
+#: ../gui/wxpython/menustrings.py:364
msgid "Calculates Simpson's diversity index on a raster map"
msgstr "Calcula el Ãndice de diversidad de Simpson en un mapa ráster"
-#: ../gui/wxpython/menustrings.py:363
+#: ../gui/wxpython/menustrings.py:365
msgid "Richness"
msgstr ""
-#: ../gui/wxpython/menustrings.py:365
+#: ../gui/wxpython/menustrings.py:367
msgid "Shape index"
msgstr "Ãndice de formas"
-#: ../gui/wxpython/menustrings.py:366
+#: ../gui/wxpython/menustrings.py:368
msgid "Calculates shape index on a raster map"
msgstr "Calcula el Ãndice de forma en un mapa ráster"
-#: ../gui/wxpython/menustrings.py:367
+#: ../gui/wxpython/menustrings.py:369
msgid "Wildfire modeling"
msgstr "Modelado de incendios"
-#: ../gui/wxpython/menustrings.py:368
+#: ../gui/wxpython/menustrings.py:370
msgid "Rate of spread"
msgstr "Relación de propagación"
-#: ../gui/wxpython/menustrings.py:369
+#: ../gui/wxpython/menustrings.py:371
msgid ""
"Generates three, or four raster map layers showing 1) the base "
"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
@@ -6238,11 +6452,11 @@
"3) la dirección de la máxima ROS y (opcional) 4) la distancia spotting "
"potencial máxima."
-#: ../gui/wxpython/menustrings.py:370
+#: ../gui/wxpython/menustrings.py:372
msgid "Least-cost spread paths"
msgstr "Rutas de propagación de menor coste"
-#: ../gui/wxpython/menustrings.py:371
+#: ../gui/wxpython/menustrings.py:373
msgid ""
"Recursively traces the least cost path backwards to cells from which the "
"cumulative cost was determined."
@@ -6250,34 +6464,34 @@
"Traza de forma recursiva la ruta de menor coste de vuelta hacia las celdas "
"desde las que se determinó el coste acumulado."
-#: ../gui/wxpython/menustrings.py:372
+#: ../gui/wxpython/menustrings.py:374
msgid "Anisotropic spread simulation"
msgstr "Simulación de propagación anisotrópica"
-#: ../gui/wxpython/menustrings.py:373
+#: ../gui/wxpython/menustrings.py:375
#, fuzzy
msgid ""
"It optionally produces raster maps to contain backlink UTM coordinates for "
"tracing spread paths."
msgstr "ráster."
-#: ../gui/wxpython/menustrings.py:374
+#: ../gui/wxpython/menustrings.py:376
msgid "Change category values and labels"
msgstr "Cambiar valores de categorÃas y etiquetas"
-#: ../gui/wxpython/menustrings.py:375
+#: ../gui/wxpython/menustrings.py:377
msgid "Interactively edit category values"
msgstr "Editar valores de categorÃa de forma interactiva"
-#: ../gui/wxpython/menustrings.py:376
+#: ../gui/wxpython/menustrings.py:378
msgid "Interactively edit cell values in a raster map."
msgstr "Editar valores de celda de forma interactiva en un mapa ráster."
-#: ../gui/wxpython/menustrings.py:377
+#: ../gui/wxpython/menustrings.py:379
msgid "Reclassify by size"
msgstr "Reclasificar por tamaño"
-#: ../gui/wxpython/menustrings.py:378
+#: ../gui/wxpython/menustrings.py:380
msgid ""
"Reclasses a raster map greater or less than user specified area size (in "
"hectares)"
@@ -6285,20 +6499,20 @@
"Reclasifica un mapa ráster mayor o menor que la superficie indicada por el "
"usuario (en hectáreas)"
-#: ../gui/wxpython/menustrings.py:379
+#: ../gui/wxpython/menustrings.py:381
msgid "Reclassify interactively"
msgstr "Reclasificar de forma interactiva"
-#: ../gui/wxpython/menustrings.py:380
+#: ../gui/wxpython/menustrings.py:382
#, fuzzy
msgid "Reclassify raster categories interactively by entering reclass rules"
msgstr "ráster"
-#: ../gui/wxpython/menustrings.py:381
+#: ../gui/wxpython/menustrings.py:383
msgid "Reclassify using rules file"
msgstr "Reclasificar usando archivo de reglas"
-#: ../gui/wxpython/menustrings.py:382
+#: ../gui/wxpython/menustrings.py:384
msgid ""
"Creates a new map layer whose category values are based upon a "
"reclassification of the categories in an existing raster map layer."
@@ -6306,73 +6520,73 @@
"Crea una nueva capa de mapa cuyos valores de categorÃas están basados en una "
"reclasificación de las categorÃas de una capa de mapa ráster existente."
-#: ../gui/wxpython/menustrings.py:383
+#: ../gui/wxpython/menustrings.py:385
msgid "Recode interactively"
msgstr "Recodificar de forma interactiva"
-#: ../gui/wxpython/menustrings.py:384
+#: ../gui/wxpython/menustrings.py:386
#, fuzzy
msgid ""
"Recode raster categories interactively by entering recode rules (create new "
"raster map)"
msgstr "ráster ráster"
-#: ../gui/wxpython/menustrings.py:385
+#: ../gui/wxpython/menustrings.py:387
msgid "Recode using rules file"
msgstr "Volver a codificar usando archivo de reglas"
-#: ../gui/wxpython/menustrings.py:386
+#: ../gui/wxpython/menustrings.py:388
#, fuzzy
msgid ""
"r.recode.rules - Use ascii rules file to recode categories in raster map"
msgstr "ráster"
-#: ../gui/wxpython/menustrings.py:387
+#: ../gui/wxpython/menustrings.py:389
msgid "Rescale"
msgstr "Rescalar"
-#: ../gui/wxpython/menustrings.py:388
+#: ../gui/wxpython/menustrings.py:390
msgid "Rescales the range of category values in a raster map layer."
msgstr "Rescala el rango de valores de categorÃa en una capa de mapa ráster."
-#: ../gui/wxpython/menustrings.py:389
+#: ../gui/wxpython/menustrings.py:391
msgid "Rescale with histogram"
msgstr "Rescalar con histograma"
-#: ../gui/wxpython/menustrings.py:390
+#: ../gui/wxpython/menustrings.py:392
#, fuzzy
msgid ""
"Rescales histogram equalized the range of category values in a raster map "
"layer."
msgstr "Rescala el histograma ráster."
-#: ../gui/wxpython/menustrings.py:391
+#: ../gui/wxpython/menustrings.py:393
msgid "Concentric circles"
msgstr "CÃrculos concéntricos"
-#: ../gui/wxpython/menustrings.py:392
+#: ../gui/wxpython/menustrings.py:394
msgid "Creates a raster map containing concentric rings around a given point."
msgstr ""
"Crea un mapa ráster que contiene anillos concéntricos alrededor de un punto "
"dado."
-#: ../gui/wxpython/menustrings.py:393
+#: ../gui/wxpython/menustrings.py:395
msgid "Generate random cells"
msgstr "Generar celdas aleatorias"
-#: ../gui/wxpython/menustrings.py:394
+#: ../gui/wxpython/menustrings.py:396
msgid "Random cells"
msgstr "Celdas aleatorias"
-#: ../gui/wxpython/menustrings.py:395
+#: ../gui/wxpython/menustrings.py:397
msgid "Generates random cell values with spatial dependence."
msgstr "Genera valores de celda aleatorios con dependencia espacial."
-#: ../gui/wxpython/menustrings.py:396
+#: ../gui/wxpython/menustrings.py:398
msgid "Random cells and vector points"
msgstr "Celdas aleatorias y puntos vectoriales"
-#: ../gui/wxpython/menustrings.py:397
+#: ../gui/wxpython/menustrings.py:399
msgid ""
"Creates a raster map layer and vector point map containing randomly located "
"sites."
@@ -6380,23 +6594,23 @@
"Crea una capa de mapa ráster y un mapa de puntos vectorial que contiene "
"lugares situados de forma aleatoria."
-#: ../gui/wxpython/menustrings.py:398
+#: ../gui/wxpython/menustrings.py:400
msgid "Generate surfaces"
msgstr "Generar superficies"
-#: ../gui/wxpython/menustrings.py:399
+#: ../gui/wxpython/menustrings.py:401
msgid "Fractal surface"
msgstr "Superficie fractal"
-#: ../gui/wxpython/menustrings.py:400
+#: ../gui/wxpython/menustrings.py:402
msgid "Creates a fractal surface of a given fractal dimension."
msgstr "Crea una superficie fractal de una dimensión fractal dada."
-#: ../gui/wxpython/menustrings.py:401
+#: ../gui/wxpython/menustrings.py:403
msgid "Gaussian kernel density surface"
msgstr ""
-#: ../gui/wxpython/menustrings.py:402
+#: ../gui/wxpython/menustrings.py:404
msgid ""
"Generates a raster density map from vector points data using a moving 2D "
"isotropic Gaussian kernel or optionally generates a vector density map on "
@@ -6406,11 +6620,11 @@
"usando un kernel de Gauss isotrópico 2D en movimiento u opcionalmente genera "
"un mapa vectorial de densidad en una red vectorial con un kernel 1D."
-#: ../gui/wxpython/menustrings.py:403
+#: ../gui/wxpython/menustrings.py:405
msgid "Gaussian deviates surface"
msgstr "Superficie gaussiana derivada"
-#: ../gui/wxpython/menustrings.py:404
+#: ../gui/wxpython/menustrings.py:406
msgid ""
"GRASS module to produce a raster map layer of gaussian deviates whose mean "
"and standard deviation can be expressed by the user. It uses a gaussian "
@@ -6420,11 +6634,11 @@
"gausianas cuyas medias y desviaciones estándar pueden ser expresadas por el "
"usuario. Utiliza un generador de números aleatorios gausiano."
-#: ../gui/wxpython/menustrings.py:405
+#: ../gui/wxpython/menustrings.py:407
msgid "Plane"
msgstr "Plano"
-#: ../gui/wxpython/menustrings.py:406
+#: ../gui/wxpython/menustrings.py:408
msgid ""
"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
"point."
@@ -6432,11 +6646,11 @@
"Crea un mapa ráster plano dando pendiente (inclinación), orientación "
"(azimut) y un punto."
-#: ../gui/wxpython/menustrings.py:407
+#: ../gui/wxpython/menustrings.py:409
msgid "Random deviates surface"
msgstr "Superficie derivada aleatoria"
-#: ../gui/wxpython/menustrings.py:408
+#: ../gui/wxpython/menustrings.py:410
msgid ""
"Produces a raster map layer of uniform random deviates whose range can be "
"expressed by the user."
@@ -6444,59 +6658,59 @@
"Produce una capa de mapa ráster de desviaciones aleatorias uniformes cuyo "
"intervalo puede ser expresado por el usuario."
-#: ../gui/wxpython/menustrings.py:409
+#: ../gui/wxpython/menustrings.py:411
msgid "Random surface with spatial dependence"
msgstr "Superficie aleatoria con dependencia espacial"
-#: ../gui/wxpython/menustrings.py:410
+#: ../gui/wxpython/menustrings.py:412
msgid "Generates random surface(s) with spatial dependence."
msgstr "Genera superficie(s) aleatoria con dependencia espacial."
-#: ../gui/wxpython/menustrings.py:411
+#: ../gui/wxpython/menustrings.py:413
#, fuzzy
msgid "Generate contour lines"
msgstr "lÃneas"
-#: ../gui/wxpython/menustrings.py:412
+#: ../gui/wxpython/menustrings.py:414
msgid ""
"Produces a vector map layer of specified contours from a raster map layer."
msgstr ""
"Produce una capa de mapa vectorial de contornos especificados a partir de "
"una capa de mapa ráster."
-#: ../gui/wxpython/menustrings.py:413
+#: ../gui/wxpython/menustrings.py:415
msgid "Interpolate surfaces"
msgstr "Interpolar superficies"
-#: ../gui/wxpython/menustrings.py:414
+#: ../gui/wxpython/menustrings.py:416
msgid "Bilinear from raster points"
msgstr "Bilineal a partir de puntos ráster"
-#: ../gui/wxpython/menustrings.py:415
+#: ../gui/wxpython/menustrings.py:417
msgid "Bilinear interpolation utility for raster map layers."
msgstr "Utilidad de interpolación bilineal para capas de mapa ráster."
-#: ../gui/wxpython/menustrings.py:416
+#: ../gui/wxpython/menustrings.py:418
msgid "Bilinear and bicubic from vector points"
msgstr "Bilineal y bicúbica a partir de puntos vectoriales"
-#: ../gui/wxpython/menustrings.py:417
+#: ../gui/wxpython/menustrings.py:419
msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
msgstr "Interpolación bicúbica o bilineal con regularización Tykhonov"
-#: ../gui/wxpython/menustrings.py:418
+#: ../gui/wxpython/menustrings.py:420
msgid "IDW from raster points"
msgstr "IDW a partir de puntos ráster"
-#: ../gui/wxpython/menustrings.py:419
+#: ../gui/wxpython/menustrings.py:421
msgid "Surface interpolation utility for raster map layers."
msgstr "Utilidad de interpolación de superficie para capas de mapa ráster."
-#: ../gui/wxpython/menustrings.py:420
+#: ../gui/wxpython/menustrings.py:422
msgid "IDW from vector points"
msgstr "IDW a partir de puntos vectoriales"
-#: ../gui/wxpython/menustrings.py:421
+#: ../gui/wxpython/menustrings.py:423
msgid ""
"Surface interpolation from vector point data by Inverse Distance Squared "
"Weighting."
@@ -6504,20 +6718,20 @@
"Interpolación de superficies a partir de datos de puntos vectoriales "
"mediante Inverse Distance Squared Weighting."
-#: ../gui/wxpython/menustrings.py:422
+#: ../gui/wxpython/menustrings.py:424
msgid "Raster contours"
msgstr "Contornos ráster"
-#: ../gui/wxpython/menustrings.py:423
+#: ../gui/wxpython/menustrings.py:425
msgid "Surface generation program from rasterized contours."
msgstr ""
"Programa de generación de superficies a partir de contornos rasterizados."
-#: ../gui/wxpython/menustrings.py:424
+#: ../gui/wxpython/menustrings.py:426
msgid "Regularized spline tension"
msgstr "Tensión spline regularizada"
-#: ../gui/wxpython/menustrings.py:425
+#: ../gui/wxpython/menustrings.py:427
msgid ""
"Spatial approximation and topographic analysis from given point or isoline "
"data in vector format to floating point raster format using regularized "
@@ -6527,11 +6741,11 @@
"o isolÃneas dados en formato vectorial a formato ráster de coma flotante "
"usando spline regularizada con tensión."
-#: ../gui/wxpython/menustrings.py:426
+#: ../gui/wxpython/menustrings.py:428
msgid "Fill NULL cells"
msgstr "Rellenas celdas NULAS"
-#: ../gui/wxpython/menustrings.py:427
+#: ../gui/wxpython/menustrings.py:429
#, fuzzy
msgid ""
"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
@@ -6539,24 +6753,24 @@
"Rellenar áreas sin datos de los mapas ráster usando la interpolación splines "
"de v.sufr.rst"
-#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:657
+#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:659
msgid "Report and statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:429
+#: ../gui/wxpython/menustrings.py:431
#, fuzzy
msgid "Basic raster metadata"
msgstr "ráster"
-#: ../gui/wxpython/menustrings.py:430
+#: ../gui/wxpython/menustrings.py:432
msgid "Output basic information about a raster map layer."
msgstr "Muestra información básica sobre una capa de mapa ráster."
-#: ../gui/wxpython/menustrings.py:431
+#: ../gui/wxpython/menustrings.py:433
msgid "Manage category information"
msgstr "Administrar información de categorÃa"
-#: ../gui/wxpython/menustrings.py:432
+#: ../gui/wxpython/menustrings.py:434
msgid ""
"Manages category values and labels associated with user-specified raster map "
"layers."
@@ -6564,53 +6778,53 @@
"Administra valores de categorÃa y etiquetas asociados con las capas de mapa "
"ráster especificadas por el usuario."
-#: ../gui/wxpython/menustrings.py:433
+#: ../gui/wxpython/menustrings.py:435
msgid "General statistics"
msgstr "EstadÃsticas generales"
-#: ../gui/wxpython/menustrings.py:434
+#: ../gui/wxpython/menustrings.py:436
msgid "Generates area statistics for raster map layers."
msgstr "Genera estadÃsticas de superficie para capas de mapa ráster."
-#: ../gui/wxpython/menustrings.py:435
+#: ../gui/wxpython/menustrings.py:437
msgid "Quantiles for large data sets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:436
+#: ../gui/wxpython/menustrings.py:438
msgid "Compute quantiles using two passes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:437
+#: ../gui/wxpython/menustrings.py:439
msgid "Range of category values"
msgstr "Intervalo de valores de categorÃa"
-#: ../gui/wxpython/menustrings.py:438
+#: ../gui/wxpython/menustrings.py:440
msgid "Prints terse list of category values found in a raster map layer."
msgstr ""
"Imprime una lista concisa de valores de categorÃa en una capa de mapa ráster."
-#: ../gui/wxpython/menustrings.py:439
+#: ../gui/wxpython/menustrings.py:441
msgid "Sum category values"
msgstr ""
-#: ../gui/wxpython/menustrings.py:440
+#: ../gui/wxpython/menustrings.py:442
msgid "Sums up the raster cell values."
msgstr "Totaliza los valores de las celdas ráster."
-#: ../gui/wxpython/menustrings.py:441
+#: ../gui/wxpython/menustrings.py:443
#, fuzzy
msgid "Sum area by raster map and category"
msgstr "ráster"
-#: ../gui/wxpython/menustrings.py:442
+#: ../gui/wxpython/menustrings.py:444
msgid "Reports statistics for raster map layers."
msgstr "Informa estadÃsticas para capas de mapas ráster."
-#: ../gui/wxpython/menustrings.py:443
+#: ../gui/wxpython/menustrings.py:445
msgid "Statistics for clumped cells"
msgstr ""
-#: ../gui/wxpython/menustrings.py:444
+#: ../gui/wxpython/menustrings.py:446
#, fuzzy
msgid ""
"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
@@ -6618,52 +6832,52 @@
msgstr ""
"Calcula el volumen de datos \"clumps\" GRASS vectorial puntos centroides."
-#: ../gui/wxpython/menustrings.py:445
+#: ../gui/wxpython/menustrings.py:447
msgid "Total corrected area"
msgstr ""
-#: ../gui/wxpython/menustrings.py:446
+#: ../gui/wxpython/menustrings.py:448
msgid "Surface area estimation for rasters."
msgstr "Estimación del área para rásters."
-#: ../gui/wxpython/menustrings.py:447
+#: ../gui/wxpython/menustrings.py:449
#, fuzzy
msgid "Univariate raster statistics"
msgstr "ráster"
-#: ../gui/wxpython/menustrings.py:448
+#: ../gui/wxpython/menustrings.py:450
msgid ""
"Calculates univariate statistics from the non-null cells of a raster map."
msgstr ""
"Calcula estadÃsticas univariantes a partir de celdas no nulas de un mapa "
"ráster."
-#: ../gui/wxpython/menustrings.py:449
+#: ../gui/wxpython/menustrings.py:451
msgid "Sample transects"
msgstr "Muestrear transectos"
-#: ../gui/wxpython/menustrings.py:450
+#: ../gui/wxpython/menustrings.py:452
msgid "Outputs the raster map layer values lying on user-defined line(s)."
msgstr ""
"Saca los valores de la capa de mapa ráster que caen en la lÃnea(s) definida "
"por el usuario."
-#: ../gui/wxpython/menustrings.py:451
+#: ../gui/wxpython/menustrings.py:453
msgid "Sample transects (bearing/distance)"
msgstr "Muestrear transectos (rumbo/distancia)"
-#: ../gui/wxpython/menustrings.py:452
+#: ../gui/wxpython/menustrings.py:454
msgid ""
"Outputs raster map layer values lying along user defined transect line(s)."
msgstr ""
"Produce valores de capa de mapa ráster que caen a lo largo de lÃnea(s) de "
"transecto definidas por el usuario."
-#: ../gui/wxpython/menustrings.py:453
+#: ../gui/wxpython/menustrings.py:455
msgid "Covariance/correlation"
msgstr "Covarianza/correlación"
-#: ../gui/wxpython/menustrings.py:454
+#: ../gui/wxpython/menustrings.py:456
msgid ""
"Outputs a covariance/correlation matrix for user-specified raster map layer"
"(s)."
@@ -6671,19 +6885,19 @@
"Produce una matriz de covarianza/correlación para la capa(s) de mapa ráster "
"especificada por el usuario."
-#: ../gui/wxpython/menustrings.py:455
+#: ../gui/wxpython/menustrings.py:457
msgid "Linear regression"
msgstr "Regresión lineal"
-#: ../gui/wxpython/menustrings.py:456
+#: ../gui/wxpython/menustrings.py:458
msgid "Calculates linear regression from two raster maps: y = a + b*x"
msgstr "Calcula la regresión lineal de dos mapas ráster: y = a + b*x"
-#: ../gui/wxpython/menustrings.py:457
+#: ../gui/wxpython/menustrings.py:459
msgid "Mutual category occurrences"
msgstr ""
-#: ../gui/wxpython/menustrings.py:458
+#: ../gui/wxpython/menustrings.py:460
msgid ""
"Tabulates the mutual occurrence (coincidence) of categories for two raster "
"map layers."
@@ -6691,102 +6905,102 @@
"Tabula la ocurrencia mutua (coincidencia) de categorÃas de dos capas de mapa "
"ráster."
-#: ../gui/wxpython/menustrings.py:459
+#: ../gui/wxpython/menustrings.py:461
msgid "Vector"
msgstr "Vectorial"
-#: ../gui/wxpython/menustrings.py:460
+#: ../gui/wxpython/menustrings.py:462
#, fuzzy
msgid "Develop vector map"
msgstr "vectorial"
-#: ../gui/wxpython/menustrings.py:462
+#: ../gui/wxpython/menustrings.py:464
#, fuzzy
msgid "Create new empty vector map"
msgstr "vectorial"
-#: ../gui/wxpython/menustrings.py:463
+#: ../gui/wxpython/menustrings.py:465
#, fuzzy
msgid "Edit vector map (non-interactively)"
-#: ../gui/wxpython/menustrings.py:464
+#: ../gui/wxpython/menustrings.py:466
msgid ""
"Edits a vector map, allows adding, deleting and modifying selected vector "
"features."
msgstr ""
-#: ../gui/wxpython/menustrings.py:465
+#: ../gui/wxpython/menustrings.py:467
#, fuzzy
msgid "Create or rebuild topology"
msgstr "Crear/reconstruir topologÃa"
-#: ../gui/wxpython/menustrings.py:466
+#: ../gui/wxpython/menustrings.py:468
msgid "Creates topology for GRASS vector map."
msgstr "Crea topologÃa para mapa vectorial de GRASS."
-#: ../gui/wxpython/menustrings.py:467
+#: ../gui/wxpython/menustrings.py:469
#, fuzzy
msgid "Clean vector map"
msgstr "vectorial"
-#: ../gui/wxpython/menustrings.py:468
+#: ../gui/wxpython/menustrings.py:470
msgid "Toolset for cleaning topology of vector map."
msgstr "Herramientas para limpiar la topologÃa de mapas vectoriales."
-#: ../gui/wxpython/menustrings.py:469
+#: ../gui/wxpython/menustrings.py:471
msgid "Smooth or simplify"
msgstr ""
-#: ../gui/wxpython/menustrings.py:470
+#: ../gui/wxpython/menustrings.py:472
msgid "Smooth or simplify lines/boundaries (remove vertices)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:471
+#: ../gui/wxpython/menustrings.py:473
msgid "Convert object types"
msgstr "Convertir tipos objetos"
-#: ../gui/wxpython/menustrings.py:472
+#: ../gui/wxpython/menustrings.py:474
msgid "Change the type of geometry elements."
msgstr "Cambiar el tipo de elementos geométricos."
-#: ../gui/wxpython/menustrings.py:473
+#: ../gui/wxpython/menustrings.py:475
msgid "Add centroids"
msgstr "Añadir centroides"
-#: ../gui/wxpython/menustrings.py:474
+#: ../gui/wxpython/menustrings.py:476
msgid "Adds missing centroids to closed boundaries."
msgstr "Añade los centroides que faltan a contornos cerrados."
-#: ../gui/wxpython/menustrings.py:475
+#: ../gui/wxpython/menustrings.py:477
msgid "Build polylines"
msgstr "Construir polilÃneas"
-#: ../gui/wxpython/menustrings.py:476
+#: ../gui/wxpython/menustrings.py:478
msgid "Builds polylines from lines or boundaries."
msgstr "Construye polilÃneas a partir de lÃneas o contornos."
-#: ../gui/wxpython/menustrings.py:477
+#: ../gui/wxpython/menustrings.py:479
msgid "Split polylines"
msgstr "Dividir polilÃneas"
-#: ../gui/wxpython/menustrings.py:478
+#: ../gui/wxpython/menustrings.py:480
msgid "Creates points/segments from input vector lines and positions."
msgstr "Crea puntos/segmentos a partir de lÃneas y posiciones de entrada."
-#: ../gui/wxpython/menustrings.py:479
+#: ../gui/wxpython/menustrings.py:481
msgid "Parallel lines"
msgstr "LÃneas parelelas"
-#: ../gui/wxpython/menustrings.py:480
+#: ../gui/wxpython/menustrings.py:482
msgid "Create parallel line to input lines"
msgstr "Crear lÃnea paralela a las lÃneas de entrada"
-#: ../gui/wxpython/menustrings.py:481
+#: ../gui/wxpython/menustrings.py:483
msgid "Dissolve boundaries"
msgstr "Disolver contornos"
-#: ../gui/wxpython/menustrings.py:482
+#: ../gui/wxpython/menustrings.py:484
msgid ""
"Dissolves boundaries between adjacent areas sharing a common category number "
"or attribute."
@@ -6794,50 +7008,50 @@
"Disuelve contornos entre áreas adyacentes que comparten un número de "
"categorÃa o atributo común."
-#: ../gui/wxpython/menustrings.py:483
+#: ../gui/wxpython/menustrings.py:485
msgid "Create 3D vector over raster"
msgstr "Crear vectorial 3D sobre ráster"
-#: ../gui/wxpython/menustrings.py:484
+#: ../gui/wxpython/menustrings.py:486
msgid "Converts vector map to 3D by sampling of elevation raster map."
msgstr "Convierte vectorial 2D a vectorial 3D muestreando ráster de elevación."
-#: ../gui/wxpython/menustrings.py:485
+#: ../gui/wxpython/menustrings.py:487
#, fuzzy
msgid "Extrude 3D vector map"
msgstr "vectorial"
-#: ../gui/wxpython/menustrings.py:486
+#: ../gui/wxpython/menustrings.py:488
msgid "Extrudes flat vector object to 3D with defined height."
msgstr "Eleva objetos vectoriales planos a 3D con alturas definidas."
-#: ../gui/wxpython/menustrings.py:487
+#: ../gui/wxpython/menustrings.py:489
msgid "Link to OGR"
-#: ../gui/wxpython/menustrings.py:488
+#: ../gui/wxpython/menustrings.py:490
#, fuzzy
msgid "Creates a new vector as a read-only link to OGR layer."
msgstr ""
"Crear una capa de mapa vectorial nueva combinando otras capas de mapas "
"vectoriales."
-#: ../gui/wxpython/menustrings.py:489
+#: ../gui/wxpython/menustrings.py:491
msgid "Create labels"
msgstr "Crear etiquetas"
-#: ../gui/wxpython/menustrings.py:490
+#: ../gui/wxpython/menustrings.py:492
msgid "Creates paint labels for a vector map from attached attributes."
msgstr ""
"Crea etiquetas de pintura para un mapa vectorial a partir de atributos "
"asociados."
-#: ../gui/wxpython/menustrings.py:491
+#: ../gui/wxpython/menustrings.py:493
#, fuzzy
msgid "Reposition vector map"
msgstr "vectorial"
-#: ../gui/wxpython/menustrings.py:492
+#: ../gui/wxpython/menustrings.py:494
msgid ""
"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
"vector map."
@@ -6845,24 +7059,24 @@
"Realiza una transformación afÃn (shift, escalado o rotación o GPC) sobre un "
"mapa vectorial."
-#: ../gui/wxpython/menustrings.py:493
+#: ../gui/wxpython/menustrings.py:495
msgid "Reproject vector map"
msgstr "Reproyectar mapa vectorial"
-#: ../gui/wxpython/menustrings.py:494
+#: ../gui/wxpython/menustrings.py:496
msgid "Allows projection conversion of vector maps."
msgstr "Permite la conversión de la proyección de mapas vectoriales."
-#: ../gui/wxpython/menustrings.py:497
+#: ../gui/wxpython/menustrings.py:499
msgid ""
"Set color rules for features in a vector using a numeric attribute column."
msgstr ""
-#: ../gui/wxpython/menustrings.py:500
+#: ../gui/wxpython/menustrings.py:502
msgid "Query with attributes"
msgstr "Consultar con atributos"
-#: ../gui/wxpython/menustrings.py:501
+#: ../gui/wxpython/menustrings.py:503
msgid ""
"Selects vector objects from an existing vector map and creates a new map "
"containing only the selected objects."
@@ -6870,64 +7084,64 @@
"Selecciona objetos vectoriales de un vectorial existente y crea un nuevo "
"mapa que contiene sólo los objetos seleccionados."
-#: ../gui/wxpython/menustrings.py:502
+#: ../gui/wxpython/menustrings.py:504
msgid "Query with coordinate(s)"
msgstr "Consultar con coordenada(s)"
-#: ../gui/wxpython/menustrings.py:503
+#: ../gui/wxpython/menustrings.py:505
msgid "Queries a vector map layer at given locations."
msgstr "Consulta una capa de mapa vectorial en las localizaciones dadas."
-#: ../gui/wxpython/menustrings.py:504
+#: ../gui/wxpython/menustrings.py:506
#, fuzzy
msgid "Query with another vector map"
msgstr "Consulta vectorial"
-#: ../gui/wxpython/menustrings.py:505
+#: ../gui/wxpython/menustrings.py:507
msgid "Select features from ainput by features from binput"
msgstr ""
"Seleccionar elementos de la entrada A mediante elementos de la entrada B"
-#: ../gui/wxpython/menustrings.py:506
+#: ../gui/wxpython/menustrings.py:508
msgid "Buffer vectors"
msgstr "Crear áreas de influencia de vectoriales"
-#: ../gui/wxpython/menustrings.py:507
+#: ../gui/wxpython/menustrings.py:509
msgid ""
"Creates a buffer around features of given type (areas must contain centroid)."
msgstr ""
"Crear un buffer alrededor de los elementos de tipo dado (las áreas deben "
"contener centroide)."
-#: ../gui/wxpython/menustrings.py:508
+#: ../gui/wxpython/menustrings.py:510
msgid "Lidar analysis"
msgstr "Análisis lidar"
-#: ../gui/wxpython/menustrings.py:509
+#: ../gui/wxpython/menustrings.py:511
msgid "Detect edges"
msgstr "Detectar bordes"
-#: ../gui/wxpython/menustrings.py:510
+#: ../gui/wxpython/menustrings.py:512
msgid "Detects the object's edges from a LIDAR data set."
msgstr ""
"Detecta los bordes de un objeto a partir de un conjunto de datos LIDAR."
-#: ../gui/wxpython/menustrings.py:511
+#: ../gui/wxpython/menustrings.py:513
msgid "Detect interiors"
msgstr "Detectar interiores"
-#: ../gui/wxpython/menustrings.py:512
+#: ../gui/wxpython/menustrings.py:514
#, fuzzy
msgid ""
"Building contour determination and Region Growing algorithm for determining "
"the building inside"
msgstr "Región"
-#: ../gui/wxpython/menustrings.py:513
+#: ../gui/wxpython/menustrings.py:515
msgid "Correct and reclassify objects"
msgstr "Corregir y reclasificar objetos"
-#: ../gui/wxpython/menustrings.py:514
+#: ../gui/wxpython/menustrings.py:516
msgid ""
"Correction of the v.lidar.growing output. It is the last of the three "
"algorithms for LIDAR filtering."
@@ -6935,32 +7149,32 @@
"Corrección de la salida de v.lidar.growing. Es el último de los tres "
"algoritmos para el filtrado de LIDAR."
-#: ../gui/wxpython/menustrings.py:515
+#: ../gui/wxpython/menustrings.py:517
msgid "Linear referencing"
msgstr "Referencia lineal"
-#: ../gui/wxpython/menustrings.py:516
+#: ../gui/wxpython/menustrings.py:518
msgid "Create LRS"
msgstr "Crear LRS"
-#: ../gui/wxpython/menustrings.py:517
+#: ../gui/wxpython/menustrings.py:519
msgid "Create Linear Reference System"
msgstr "Crear Sistema de Referencia Lineal"
-#: ../gui/wxpython/menustrings.py:518
+#: ../gui/wxpython/menustrings.py:520
msgid "Create stationing"
msgstr "Crear estacionamiento"
-#: ../gui/wxpython/menustrings.py:519
+#: ../gui/wxpython/menustrings.py:521
#, fuzzy
msgid "Create stationing from input lines, and linear reference system"
msgstr "lÃneas"
-#: ../gui/wxpython/menustrings.py:520
+#: ../gui/wxpython/menustrings.py:522
msgid "Create points/segments"
msgstr "Crear puntos/segmentos"
-#: ../gui/wxpython/menustrings.py:521
+#: ../gui/wxpython/menustrings.py:523
msgid ""
"Creates points/segments from input lines, linear reference system and "
"positions read from stdin or a file."
@@ -6968,11 +7182,11 @@
"Crea puntos/segmentos a partir de las lÃneas de entrada, sistema de "
"referencia lineal y posiciones leÃdas de stdin o un archivo."
-#: ../gui/wxpython/menustrings.py:522
+#: ../gui/wxpython/menustrings.py:524
msgid "Find line id and offset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:523
+#: ../gui/wxpython/menustrings.py:525
msgid ""
"Finds line id and real km+offset for given points in vector map using linear "
"reference system."
@@ -6980,26 +7194,26 @@
"Hallar una id de lÃnea y km reales + compensación para puntos especificados "
"en un mapa vectorial empleando sistema de referencia lineal."
-#: ../gui/wxpython/menustrings.py:524
+#: ../gui/wxpython/menustrings.py:526
msgid "Nearest features"
-#: ../gui/wxpython/menustrings.py:525
+#: ../gui/wxpython/menustrings.py:527
#, fuzzy
msgid ""
"Finds the nearest element in vector map 'to' for elements in vector map "
"'from'."
msgstr "vectorial vectorial."
-#: ../gui/wxpython/menustrings.py:526
+#: ../gui/wxpython/menustrings.py:528
msgid "Network analysis"
msgstr "Análisis de redes"
-#: ../gui/wxpython/menustrings.py:527
+#: ../gui/wxpython/menustrings.py:529
msgid "Allocate subnets"
msgstr "Asignar subredes"
-#: ../gui/wxpython/menustrings.py:528
+#: ../gui/wxpython/menustrings.py:530
msgid ""
"Centre node must be opened (costs >= 0). Costs of centre node are used in "
"calculation"
@@ -7007,47 +7221,47 @@
"El nodo central debe estar abierto (costes >=0). Los costes del nodo central "
"se usan en los cálculos."
-#: ../gui/wxpython/menustrings.py:529
+#: ../gui/wxpython/menustrings.py:531
msgid "Network maintenance"
msgstr "Mantenimiento de redes"
-#: ../gui/wxpython/menustrings.py:530
+#: ../gui/wxpython/menustrings.py:532
msgid "Network maintenance."
msgstr "Mantenimiento de redes."
-#: ../gui/wxpython/menustrings.py:531
+#: ../gui/wxpython/menustrings.py:533
msgid "Visibility network"
msgstr "Red de visibilidad"
-#: ../gui/wxpython/menustrings.py:532
+#: ../gui/wxpython/menustrings.py:534
msgid "Visibility graph construction."
msgstr "Construcción de grafos de visibilidad"
-#: ../gui/wxpython/menustrings.py:533
+#: ../gui/wxpython/menustrings.py:535
msgid "Shortest path"
msgstr ""
-#: ../gui/wxpython/menustrings.py:534
+#: ../gui/wxpython/menustrings.py:536
msgid "Finds shortest path on vector network."
msgstr "Encuentra la ruta más corta en una red vectorial."
-#: ../gui/wxpython/menustrings.py:535
+#: ../gui/wxpython/menustrings.py:537
#, fuzzy
msgid "Display shortest route (requires XTerm)"
msgstr "Mostrar"
-#: ../gui/wxpython/menustrings.py:536
+#: ../gui/wxpython/menustrings.py:538
#, fuzzy
msgid ""
"Display shortest route along network between 2 nodes (visualization only, "
"requires XTerm))"
msgstr "Mostrar"
-#: ../gui/wxpython/menustrings.py:537
+#: ../gui/wxpython/menustrings.py:539
msgid "Split net"
msgstr "Dividir red"
-#: ../gui/wxpython/menustrings.py:538
+#: ../gui/wxpython/menustrings.py:540
msgid ""
"Splits net to bands between cost isolines (direction from centre). Centre "
"node must be opened (costs >= 0). Costs of centre node are used in "
@@ -7057,105 +7271,105 @@
"centro). El nodo central debe estar abierto (coste >= 0). Los costes de nodo "
"central se usan en el cálculo."
-#: ../gui/wxpython/menustrings.py:539
+#: ../gui/wxpython/menustrings.py:541
msgid "Steiner tree"
msgstr "Ãrbol de Steiner"
-#: ../gui/wxpython/menustrings.py:540
+#: ../gui/wxpython/menustrings.py:542
msgid ""
"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
"is used in this module so the result may be sub optimal"
msgstr ""
-#: ../gui/wxpython/menustrings.py:541
+#: ../gui/wxpython/menustrings.py:543
msgid "Traveling salesman analysis"
msgstr "Análisis del representante de comercio"
-#: ../gui/wxpython/menustrings.py:542
+#: ../gui/wxpython/menustrings.py:544
#, fuzzy
msgid ""
"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
"created cycle may be sub optimal"
msgstr "Tenga en cuenta que el PVV es"
-#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:544
+#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:546
msgid "Overlay vector maps"
msgstr "Superponer mapas vectoriales"
-#: ../gui/wxpython/menustrings.py:545
+#: ../gui/wxpython/menustrings.py:547
msgid "Overlays two vector maps."
msgstr "Superpone dos mapas vectoriales."
-#: ../gui/wxpython/menustrings.py:546
+#: ../gui/wxpython/menustrings.py:548
#, fuzzy
msgid "Patch vector maps"
msgstr "vectorial"
-#: ../gui/wxpython/menustrings.py:547
+#: ../gui/wxpython/menustrings.py:549
msgid "Create a new vector map layer by combining other vector map layers."
msgstr ""
"vectoriales."
-#: ../gui/wxpython/menustrings.py:548
+#: ../gui/wxpython/menustrings.py:550
msgid "Change attributes"
msgstr "Cambiar atributos"
-#: ../gui/wxpython/menustrings.py:549
+#: ../gui/wxpython/menustrings.py:551
msgid "Manage or report categories"
msgstr "Gestionar o informar de categorÃas"
-#: ../gui/wxpython/menustrings.py:550
+#: ../gui/wxpython/menustrings.py:552
msgid "Attach, delete or report vector categories to map geometry."
msgstr ""
"Adjuntar, borrar o informar categorÃas del vectorial a la geometrÃa del mapa."
-#: ../gui/wxpython/menustrings.py:551
+#: ../gui/wxpython/menustrings.py:553
msgid "Reclassify objects interactively"
msgstr "Reclasificar objetos de forma interactiva"
-#: ../gui/wxpython/menustrings.py:552
+#: ../gui/wxpython/menustrings.py:554
#, fuzzy
msgid "Reclassify vector objects interactively by entering SQL rules"
msgstr "vectorial"
-#: ../gui/wxpython/menustrings.py:553
+#: ../gui/wxpython/menustrings.py:555
msgid "Reclassify objects using rules file"
msgstr ""
-#: ../gui/wxpython/menustrings.py:554
+#: ../gui/wxpython/menustrings.py:556
#, fuzzy
msgid ""
"Changes vector category values for an existing vector map according to "
"results of SQL queries or a value in attribute table column."
-#: ../gui/wxpython/menustrings.py:555
+#: ../gui/wxpython/menustrings.py:557
msgid "Generate area for current region"
msgstr "Generar área para la región actual"
-#: ../gui/wxpython/menustrings.py:556
+#: ../gui/wxpython/menustrings.py:558
msgid "Create a new vector from the current region."
msgstr "Crear un nuevo vectorial a partir de la región actual."
-#: ../gui/wxpython/menustrings.py:557
+#: ../gui/wxpython/menustrings.py:559
msgid "Generate areas from points"
msgstr "Generar áreas a partir de puntos"
-#: ../gui/wxpython/menustrings.py:558
+#: ../gui/wxpython/menustrings.py:560
msgid "Convex hull"
msgstr "Casco convexo"
-#: ../gui/wxpython/menustrings.py:559
+#: ../gui/wxpython/menustrings.py:561
msgid "Uses a GRASS vector points map to produce a convex hull vector map."
msgstr ""
"Usa un mapa vectorial de puntos de GRASS para producir un mapa vectorial ."
-#: ../gui/wxpython/menustrings.py:560
+#: ../gui/wxpython/menustrings.py:562
msgid "Delaunay triangles"
msgstr "Triángulos de Delaunay"
-#: ../gui/wxpython/menustrings.py:561
+#: ../gui/wxpython/menustrings.py:563
msgid ""
"Creates a Delaunay triangulation from an input vector map containing points "
"or centroids."
@@ -7163,11 +7377,11 @@
"Crea una triangulación de Delaunay a partir de un mapa vectorial de entrada "
"que contiene puntos o centroides."
-#: ../gui/wxpython/menustrings.py:562
+#: ../gui/wxpython/menustrings.py:564
msgid "Voronoi diagram/Thiessen polygons"
msgstr "Diagrama de Voronoi/polÃgonos de Thiessen"
-#: ../gui/wxpython/menustrings.py:563
+#: ../gui/wxpython/menustrings.py:565
msgid ""
"Creates a Voronoi diagram from an input vector map containing points or "
"centroids."
@@ -7175,82 +7389,82 @@
"Crea un diagrama de Voronoi a partir de un mapa vectorial de entrada que "
"contiene puntos o centroides."
-#: ../gui/wxpython/menustrings.py:564
+#: ../gui/wxpython/menustrings.py:566
msgid "Generate grid"
msgstr "Generar cuadrÃcula"
-#: ../gui/wxpython/menustrings.py:565
+#: ../gui/wxpython/menustrings.py:567
msgid "Creates a GRASS vector map of a user-defined grid."
msgstr ""
"Crea un mapa vectorial de GRASS de una cuadrÃcula definida por el usuario."
-#: ../gui/wxpython/menustrings.py:566
+#: ../gui/wxpython/menustrings.py:568
msgid "Generate points"
msgstr "Generar puntos"
-#: ../gui/wxpython/menustrings.py:567
+#: ../gui/wxpython/menustrings.py:569
msgid "Generate from database"
msgstr ""
-#: ../gui/wxpython/menustrings.py:568
+#: ../gui/wxpython/menustrings.py:570
msgid ""
"Creates new vector (points) map from database table containing coordinates."
msgstr ""
"Crea un nuevo mapa vectorial (de puntos) a partir de una tabla de base de "
"datos que contiene coordenadas."
-#: ../gui/wxpython/menustrings.py:569
+#: ../gui/wxpython/menustrings.py:571
msgid "Generate points along lines"
msgstr "Generar puntos a lo largo de lÃneas"
-#: ../gui/wxpython/menustrings.py:570
+#: ../gui/wxpython/menustrings.py:572
msgid "Create points along input lines in new vector with 2 layers."
msgstr ""
"Creaa puntos a lo largo de lÃneas de entrada en un nuevo vectorial con 2 "
"capas."
-#: ../gui/wxpython/menustrings.py:571
+#: ../gui/wxpython/menustrings.py:573
msgid "Generate random points"
msgstr "Generar puntos aleatorios"
-#: ../gui/wxpython/menustrings.py:572
+#: ../gui/wxpython/menustrings.py:574
msgid "Randomly generate a 2D/3D vector points map."
msgstr "Genera un mapa de puntos vectorial 2D/3D de GRASS de forma aleatoria."
-#: ../gui/wxpython/menustrings.py:573
+#: ../gui/wxpython/menustrings.py:575
msgid "Perturb points"
msgstr "Perturbar puntos"
-#: ../gui/wxpython/menustrings.py:574
+#: ../gui/wxpython/menustrings.py:576
msgid "Random location perturbations of GRASS vector points"
msgstr ""
"Perturbaciones de localizaciones aleatorias de puntos vectoriales de GRASS"
-#: ../gui/wxpython/menustrings.py:575
+#: ../gui/wxpython/menustrings.py:577
#, fuzzy
msgid "Remove outliers in point sets"
msgstr "Eliminar outliers de conjunto de puntos"
-#: ../gui/wxpython/menustrings.py:576
+#: ../gui/wxpython/menustrings.py:578
#, fuzzy
msgid "Removes outliers from vector point data."
msgstr "Elimina outliers de vectorial datos"
-#: ../gui/wxpython/menustrings.py:577
+#: ../gui/wxpython/menustrings.py:579
#, fuzzy
msgid "Test/training point sets"
msgstr "Test"
-#: ../gui/wxpython/menustrings.py:578
+#: ../gui/wxpython/menustrings.py:580
#, fuzzy
msgid "Randomly partition points into test/train sets."
msgstr "puntos."
-#: ../gui/wxpython/menustrings.py:579
+#: ../gui/wxpython/menustrings.py:581
msgid "Update area attributes from raster"
msgstr "Actualizar atributos de área a partir de ráster"
-#: ../gui/wxpython/menustrings.py:580
+#: ../gui/wxpython/menustrings.py:582
msgid ""
"Calculates univariate statistics from a GRASS raster map based on vector "
"polygons and uploads statistics to new attribute columns."
@@ -7259,73 +7473,73 @@
"basadas en polÃgonos vectoriales y carga las estadÃsticas en nuevas columnas "
"de atributos."
-#: ../gui/wxpython/menustrings.py:581
+#: ../gui/wxpython/menustrings.py:583
msgid "Update point attributes from areas"
msgstr "Actualizar atributos de puntos a partir de áreas"
-#: ../gui/wxpython/menustrings.py:582
+#: ../gui/wxpython/menustrings.py:584
msgid "Uploads vector values at positions of vector points to the table."
msgstr ""
"Carga valores vectoriales en las posiciones de puntos vectoriales a la tabla."
-#: ../gui/wxpython/menustrings.py:583
+#: ../gui/wxpython/menustrings.py:585
msgid "Update point attributes from raster"
msgstr "Actualizar atributos de puntos a partir de ráster"
-#: ../gui/wxpython/menustrings.py:584
+#: ../gui/wxpython/menustrings.py:586
#, fuzzy
msgid "Sample raster maps at point locations"
msgstr "ráster"
-#: ../gui/wxpython/menustrings.py:585
+#: ../gui/wxpython/menustrings.py:587
msgid "Uploads raster values at positions of vector points to the table."
msgstr ""
"Carga valores ráster en las posiciones de puntos vectoriales a la tabla."
-#: ../gui/wxpython/menustrings.py:586
+#: ../gui/wxpython/menustrings.py:588
msgid "Sample raster neighborhood around points"
msgstr "Muestrear 'vecindario' ráster alrededor de puntos"
-#: ../gui/wxpython/menustrings.py:587
+#: ../gui/wxpython/menustrings.py:589
msgid "Samples a raster map at vector point locations."
msgstr "Muestrear un mapa ráster en localizaciones de puntos vectoriales."
-#: ../gui/wxpython/menustrings.py:588
+#: ../gui/wxpython/menustrings.py:590
msgid "Reports and statistics"
msgstr "Informes y estadÃsticas"
-#: ../gui/wxpython/menustrings.py:589
+#: ../gui/wxpython/menustrings.py:591
#, fuzzy
msgid "Basic vector metadata"
msgstr "vectorial"
-#: ../gui/wxpython/menustrings.py:590
+#: ../gui/wxpython/menustrings.py:592
msgid "Outputs basic information about a user-specified vector map layer."
msgstr ""
"Muestra información básica sobre una capa de mapa vectorial especificada por "
"el usuario."
-#: ../gui/wxpython/menustrings.py:591
+#: ../gui/wxpython/menustrings.py:593
msgid "Report topology by category"
msgstr "Informar topologÃa por categorÃa"
-#: ../gui/wxpython/menustrings.py:592
+#: ../gui/wxpython/menustrings.py:594
msgid "Reports geometry statistics for vectors."
msgstr "Informa estadÃsticas de geometrÃa para vectoriales."
-#: ../gui/wxpython/menustrings.py:593
+#: ../gui/wxpython/menustrings.py:595
msgid "Upload or report topology"
msgstr "Cargar o informar topologÃa"
-#: ../gui/wxpython/menustrings.py:594
+#: ../gui/wxpython/menustrings.py:596
msgid "Populate database values from vector features."
msgstr "Poblar valores de base de datos a partir de elementos vectoriales."
-#: ../gui/wxpython/menustrings.py:595
+#: ../gui/wxpython/menustrings.py:597
msgid "Univariate attribute statistics"
msgstr "EstadÃsticas de atributos univariante"
-#: ../gui/wxpython/menustrings.py:596
+#: ../gui/wxpython/menustrings.py:598
msgid ""
"Calculates univariate statistics for attribute. Variance and standard "
"deviation is calculated only for points if specified."
@@ -7333,74 +7547,74 @@
"Calcula estadÃsticas univariante para atributos. La varianza y la desviación "
"estándar sólo se calculan para puntos si se especifica."
-#: ../gui/wxpython/menustrings.py:597
+#: ../gui/wxpython/menustrings.py:599
msgid "Quadrat indices"
msgstr "Ãndices cuadráticos"
-#: ../gui/wxpython/menustrings.py:598
+#: ../gui/wxpython/menustrings.py:600
#, fuzzy
msgid "Indices for quadrat counts of sites lists."
msgstr "lugares"
-#: ../gui/wxpython/menustrings.py:599
+#: ../gui/wxpython/menustrings.py:601
msgid "Test normality"
msgstr "Probar normalidad"
-#: ../gui/wxpython/menustrings.py:600
+#: ../gui/wxpython/menustrings.py:602
msgid "Tests for normality for points."
msgstr "Test de normalidad para puntos."
-#: ../gui/wxpython/menustrings.py:601
+#: ../gui/wxpython/menustrings.py:603
msgid "Imagery"
msgstr ""
-#: ../gui/wxpython/menustrings.py:602
+#: ../gui/wxpython/menustrings.py:604
msgid "Develop images and groups"
msgstr "Crear imágenes y grupos"
-#: ../gui/wxpython/menustrings.py:603
+#: ../gui/wxpython/menustrings.py:605
msgid "Create/edit group"
msgstr "Crear/editar grupo"
-#: ../gui/wxpython/menustrings.py:604
+#: ../gui/wxpython/menustrings.py:606
msgid "Creates, edits, and lists groups and subgroups of imagery files."
msgstr "Crea, edita y lista grupos y subgrupos de archivos de imaginerÃa."
-#: ../gui/wxpython/menustrings.py:605
+#: ../gui/wxpython/menustrings.py:607
msgid "Target group"
msgstr "Grupo objetivo"
-#: ../gui/wxpython/menustrings.py:606
+#: ../gui/wxpython/menustrings.py:608
msgid "Targets an imagery group to a GRASS location and mapset."
msgstr ""
"Destina un grupo de imagen a una localización GRASS y un conjunto de mapas"
-#: ../gui/wxpython/menustrings.py:607
+#: ../gui/wxpython/menustrings.py:609
msgid "Mosaic images"
msgstr "Hacer mosaico de imágenes"
-#: ../gui/wxpython/menustrings.py:608
+#: ../gui/wxpython/menustrings.py:610
msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
msgstr ""
"Hace mosaicos de hasta 4 imágenes y extiende colormap; crea mapas *.mosaico"
-#: ../gui/wxpython/menustrings.py:609
+#: ../gui/wxpython/menustrings.py:611
msgid "Manage image colors"
msgstr "Administrar colores de imágenes"
-#: ../gui/wxpython/menustrings.py:610
+#: ../gui/wxpython/menustrings.py:612
msgid "Color balance for RGB"
msgstr "Equilibrio de color para RGB"
-#: ../gui/wxpython/menustrings.py:611
+#: ../gui/wxpython/menustrings.py:613
msgid "Auto-balancing of colors for LANDSAT images"
msgstr "Balance automático de colores para imágenes LANDSAT"
-#: ../gui/wxpython/menustrings.py:612
+#: ../gui/wxpython/menustrings.py:614
msgid "HIS to RGB"
msgstr "HIS a RGB"
-#: ../gui/wxpython/menustrings.py:613
+#: ../gui/wxpython/menustrings.py:615
msgid ""
"Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color "
"transformation function."
@@ -7408,7 +7622,7 @@
"Función de transformación de color de mapa ráster de matiz-intensidad- "
"saturación (HIS) a rojo-verde-azul (RGB)."
-#: ../gui/wxpython/menustrings.py:615
+#: ../gui/wxpython/menustrings.py:617
msgid ""
"Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color "
"transformation function"
@@ -7416,12 +7630,12 @@
"Función de transformación de color de mapa ráster de rojo-verde-azul (RGB) a "
"matiz-intensidad-saturación (HIS)"
-#: ../gui/wxpython/menustrings.py:616
+#: ../gui/wxpython/menustrings.py:618
#, fuzzy
msgid "Rectify image or raster"
msgstr "ráster"
-#: ../gui/wxpython/menustrings.py:617
+#: ../gui/wxpython/menustrings.py:619
msgid ""
"Rectifies an image by computing a coordinate transformation for each pixel "
"in the image based on the control points"
@@ -7429,34 +7643,34 @@
"Rectifica una imagen computando una transformación de coordenada para cada "
"pixel de la imagen basada en los puntos de control"
-#: ../gui/wxpython/menustrings.py:618
+#: ../gui/wxpython/menustrings.py:620
msgid "Ortho photo rectification (requires Xterm)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:619
+#: ../gui/wxpython/menustrings.py:621
msgid "Ortho Photo rectification"
msgstr ""
-#: ../gui/wxpython/menustrings.py:620
+#: ../gui/wxpython/menustrings.py:622
msgid "Brovey sharpening"
msgstr ""
-#: ../gui/wxpython/menustrings.py:621
+#: ../gui/wxpython/menustrings.py:623
msgid ""
"Brovey transform to merge multispectral and high-res panchromatic channels"
msgstr ""
"Transformación de Brovey para fundir canales multiespectrales y "
"pancromáticos de alta resolución"
-#: ../gui/wxpython/menustrings.py:622
+#: ../gui/wxpython/menustrings.py:624
msgid "Classify image"
msgstr "Clasificar imagen"
-#: ../gui/wxpython/menustrings.py:623
+#: ../gui/wxpython/menustrings.py:625
msgid "Clustering input for unsupervised classification"
msgstr "Entrada de agrupaciones para clasificación no supervisada"
-#: ../gui/wxpython/menustrings.py:624
+#: ../gui/wxpython/menustrings.py:626
msgid ""
"The resulting signature file is used as input for i.maxlik, to generate an "
"unsupervised image classification."
@@ -7464,11 +7678,11 @@
"El archivo de firma resultante se usa como entrada para i.maxlik, para "
"generar una clasificación de imágenes sin supervisión."
-#: ../gui/wxpython/menustrings.py:625
+#: ../gui/wxpython/menustrings.py:627
msgid "Maximum likelihood classification (MLC)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:626
+#: ../gui/wxpython/menustrings.py:628
msgid ""
"Classification is based on the spectral signature information generated by "
"either i.cluster, i.class, or i.gensig."
@@ -7476,11 +7690,11 @@
"Las clasificaciones están basadas en la información de firma espectral "
"generada por i.cluster, i.class o i.gensig."
-#: ../gui/wxpython/menustrings.py:627
+#: ../gui/wxpython/menustrings.py:629
msgid "Sequential maximum a posteriori classification (SMAP)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:628
+#: ../gui/wxpython/menustrings.py:630
msgid ""
"Performs contextual image classification using sequential maximum a "
"posteriori (SMAP) estimation."
@@ -7488,139 +7702,139 @@
"Realiza una clasificación contextual de imágenes utilizando una estimación "
"secuencial máxima a posteriori (SMAP)."
-#: ../gui/wxpython/menustrings.py:629
+#: ../gui/wxpython/menustrings.py:631
msgid "Interactive input for supervised classification (requires Xterm)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:630
+#: ../gui/wxpython/menustrings.py:632
msgid "Interactive input for supervised classification"
msgstr "Clasificación supervisada de entrada interactiva"
-#: ../gui/wxpython/menustrings.py:631
+#: ../gui/wxpython/menustrings.py:633
msgid "Input for supervised MLC"
msgstr "Entrada para MLC supervisado"
-#: ../gui/wxpython/menustrings.py:632
+#: ../gui/wxpython/menustrings.py:634
msgid "Generates statistics for i.maxlik from raster map layer."
msgstr "Genera estadÃsticas para i.maxlik de la capa de mapa ráster."
-#: ../gui/wxpython/menustrings.py:633
+#: ../gui/wxpython/menustrings.py:635
msgid "Input for supervised SMAP"
msgstr "Entrada para SMAP supervisado"
-#: ../gui/wxpython/menustrings.py:634
+#: ../gui/wxpython/menustrings.py:636
#, fuzzy
msgid "Generate statistics for i.smap from raster map layer."
msgstr "ráster."
-#: ../gui/wxpython/menustrings.py:635
+#: ../gui/wxpython/menustrings.py:637
msgid "Filter image"
msgstr "Filtrar imagen"
-#: ../gui/wxpython/menustrings.py:636
+#: ../gui/wxpython/menustrings.py:638
msgid "Edge detection"
msgstr "Detección de bordes"
-#: ../gui/wxpython/menustrings.py:637
+#: ../gui/wxpython/menustrings.py:639
msgid "Zero-crossing \"edge detection\" raster function for image processing."
msgstr ""
"Función ráster \"detección de bordes\" de cruce de ceros para procesamiento "
"de imágenes."
-#: ../gui/wxpython/menustrings.py:638
+#: ../gui/wxpython/menustrings.py:640
#, fuzzy
msgid "Matrix/convolving filter"
msgstr "Filtro de matriz/"
-#: ../gui/wxpython/menustrings.py:639
+#: ../gui/wxpython/menustrings.py:641
msgid "Raster map matrix filter."
msgstr "Filtro de matrices de mapas ráster."
-#: ../gui/wxpython/menustrings.py:641
+#: ../gui/wxpython/menustrings.py:643
msgid "Generate histogram of image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:642
+#: ../gui/wxpython/menustrings.py:644
msgid "Spectral response"
msgstr "Respuesta espectral"
-#: ../gui/wxpython/menustrings.py:643
+#: ../gui/wxpython/menustrings.py:645
msgid ""
"displays spectral response at user specified locations in group or images"
msgstr ""
"muestra la respuesta espectral en localizaciones especificadas por el "
"usuario en grupo o imágenes"
-#: ../gui/wxpython/menustrings.py:644
+#: ../gui/wxpython/menustrings.py:646
msgid "Tasseled cap vegetation index"
msgstr ""
-#: ../gui/wxpython/menustrings.py:645
+#: ../gui/wxpython/menustrings.py:647
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
msgstr "Transformación Tasseled Cap (Kauth Thomas) para datos LANDSAT-TM"
-#: ../gui/wxpython/menustrings.py:646
+#: ../gui/wxpython/menustrings.py:648
msgid "Transform image"
msgstr "Transformar imagen"
-#: ../gui/wxpython/menustrings.py:647
+#: ../gui/wxpython/menustrings.py:649
msgid "Canonical correlation"
msgstr "Correlación canónica"
-#: ../gui/wxpython/menustrings.py:648
+#: ../gui/wxpython/menustrings.py:650
msgid "Canonical components analysis (cca) program for image processing."
msgstr ""
"Programa de análisis de componentes canónicos (cca) para procesamiento de "
"imágenes."
-#: ../gui/wxpython/menustrings.py:649
+#: ../gui/wxpython/menustrings.py:651
msgid "Principal components"
msgstr "Componentes principales"
-#: ../gui/wxpython/menustrings.py:650
+#: ../gui/wxpython/menustrings.py:652
msgid "Principal components analysis (pca) program for image processing."
msgstr ""
"Programa de Análisis de Componentes Principales (PCA) para el procesado de "
"imágenes."
-#: ../gui/wxpython/menustrings.py:651
+#: ../gui/wxpython/menustrings.py:653
msgid "Fast Fourier"
msgstr "Fast Fourier"
-#: ../gui/wxpython/menustrings.py:652
+#: ../gui/wxpython/menustrings.py:654
msgid "Fast Fourier Transform (FFT) for image processing."
msgstr "Transformación Rápida Fourier (FFT) para procesamiento de imagen."
-#: ../gui/wxpython/menustrings.py:653
+#: ../gui/wxpython/menustrings.py:655
msgid "Inverse Fast Fourier"
msgstr "Fast Fourier inversa"
-#: ../gui/wxpython/menustrings.py:654
+#: ../gui/wxpython/menustrings.py:656
msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
msgstr "Transformación Fast Fourier Inversa (ifft) para procesado de imágenes."
-#: ../gui/wxpython/menustrings.py:655
+#: ../gui/wxpython/menustrings.py:657
#, fuzzy
msgid "Atmospheric correction"
-#: ../gui/wxpython/menustrings.py:656
+#: ../gui/wxpython/menustrings.py:658
msgid "Performs atmospheric correction using the 6S algorithm."
msgstr ""
-#: ../gui/wxpython/menustrings.py:658
+#: ../gui/wxpython/menustrings.py:660
msgid "Bit pattern comparison "
msgstr ""
-#: ../gui/wxpython/menustrings.py:659
+#: ../gui/wxpython/menustrings.py:661
msgid "Compares bit patterns with a raster map."
msgstr "Compara patrones de bit con un mapa ráster."
-#: ../gui/wxpython/menustrings.py:660
+#: ../gui/wxpython/menustrings.py:662
msgid "Kappa analysis"
msgstr "Análisis kappa"
-#: ../gui/wxpython/menustrings.py:661
+#: ../gui/wxpython/menustrings.py:663
msgid ""
"Calculate error matrix and kappa parameter for accuracy assessment of "
"classification result."
@@ -7628,60 +7842,60 @@
"Calcular matriz de error y el parámetro kappa para ensayo de precisión del "
"resultado de clasificación."
-#: ../gui/wxpython/menustrings.py:662
+#: ../gui/wxpython/menustrings.py:664
msgid "OIF for LandSat TM"
msgstr "OIF para LandSat TM"
-#: ../gui/wxpython/menustrings.py:663
+#: ../gui/wxpython/menustrings.py:665
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
msgstr "Calcula tabla de Factor de Ãndice Ãptimo para bandas LANDSAT 1-5 y 7"
-#: ../gui/wxpython/menustrings.py:664
+#: ../gui/wxpython/menustrings.py:666
msgid "Volumes"
msgstr ""
-#: ../gui/wxpython/menustrings.py:665
+#: ../gui/wxpython/menustrings.py:667
msgid "Develop volumes"
msgstr ""
-#: ../gui/wxpython/menustrings.py:666
+#: ../gui/wxpython/menustrings.py:668
msgid "Manage 3D NULL values"
msgstr ""
-#: ../gui/wxpython/menustrings.py:667
+#: ../gui/wxpython/menustrings.py:669
msgid "Explicitly create the 3D NULL-value bitmap file."
msgstr "Crear explÃcitamente el archivo de mapa de bits de valor nulo 3D"
-#: ../gui/wxpython/menustrings.py:668
+#: ../gui/wxpython/menustrings.py:670
msgid "Manage timestamp"
msgstr ""
-#: ../gui/wxpython/menustrings.py:669
+#: ../gui/wxpython/menustrings.py:671
msgid "Print/add/remove a timestamp for a 3D raster map"
msgstr "Imprimir/añadir/eliminar una marca de tiempo para un mapa ráster 3D"
-#: ../gui/wxpython/menustrings.py:670
+#: ../gui/wxpython/menustrings.py:672
msgid "3D Mask"
msgstr ""
-#: ../gui/wxpython/menustrings.py:671
+#: ../gui/wxpython/menustrings.py:673
msgid "Establishes the current working 3D raster mask."
msgstr "Establece la máscara ráster 3D de trabajo actual."
-#: ../gui/wxpython/menustrings.py:672
+#: ../gui/wxpython/menustrings.py:674
#, fuzzy
msgid "3D raster map calculator"
msgstr "ráster"
-#: ../gui/wxpython/menustrings.py:673
+#: ../gui/wxpython/menustrings.py:675
msgid "Map calculator for volumetric map algebra"
msgstr ""
-#: ../gui/wxpython/menustrings.py:674
+#: ../gui/wxpython/menustrings.py:676
msgid "Cross section"
msgstr ""
-#: ../gui/wxpython/menustrings.py:675
+#: ../gui/wxpython/menustrings.py:677
msgid ""
"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
"map"
@@ -7689,95 +7903,95 @@
"Crea un mapa ráster 2D de sección cruzada a partir de un mapa ráster 3D "
"basado en mapa 2D de elevación"
-#: ../gui/wxpython/menustrings.py:676
+#: ../gui/wxpython/menustrings.py:678
#, fuzzy
msgid "Interpolate volume from points"
msgstr "puntos"
-#: ../gui/wxpython/menustrings.py:677
+#: ../gui/wxpython/menustrings.py:679
#, fuzzy
msgid ""
"Interpolates point data to a G3D grid volume using regularized spline with "
"tension (RST) algorithm."
msgstr "Interpola datos de puntos a volumen de cuadrÃcula G3D usando"
-#: ../gui/wxpython/menustrings.py:678
+#: ../gui/wxpython/menustrings.py:680
msgid "Report and Statistics"
msgstr "Informes y estadÃstica"
-#: ../gui/wxpython/menustrings.py:679
+#: ../gui/wxpython/menustrings.py:681
msgid "Basic volume metadata"
msgstr ""
-#: ../gui/wxpython/menustrings.py:680
+#: ../gui/wxpython/menustrings.py:682
msgid "Outputs basic information about a user-specified 3D raster map layer."
msgstr ""
"Saca información básica de una capa de mapa ráster 3D especificada por el "
"usuario."
-#: ../gui/wxpython/menustrings.py:682
+#: ../gui/wxpython/menustrings.py:684
msgid "Database information"
msgstr "Información sobre la base de datos"
-#: ../gui/wxpython/menustrings.py:683
+#: ../gui/wxpython/menustrings.py:685
msgid "Describe table"
msgstr "Describir tabla"
-#: ../gui/wxpython/menustrings.py:684
+#: ../gui/wxpython/menustrings.py:686
msgid "Describes a table in detail."
msgstr "Describe una tabla en detalle."
-#: ../gui/wxpython/menustrings.py:685
+#: ../gui/wxpython/menustrings.py:687
msgid "List columns"
msgstr "Listar columnas"
-#: ../gui/wxpython/menustrings.py:686
+#: ../gui/wxpython/menustrings.py:688
msgid "List all columns for a given table."
msgstr "Muestra todas las columnas de una tabla dada."
-#: ../gui/wxpython/menustrings.py:687
+#: ../gui/wxpython/menustrings.py:689
msgid "List drivers"
msgstr "Listar controladores"
-#: ../gui/wxpython/menustrings.py:688
+#: ../gui/wxpython/menustrings.py:690
msgid "List all database drivers."
msgstr "Listar todos los controladores de bases de datos."
-#: ../gui/wxpython/menustrings.py:689
+#: ../gui/wxpython/menustrings.py:691
msgid "List tables"
msgstr "Listar tablas"
-#: ../gui/wxpython/menustrings.py:690
+#: ../gui/wxpython/menustrings.py:692
msgid "Lists all tables for a given database."
msgstr "Lista todas las tablas para una base de datos dada."
-#: ../gui/wxpython/menustrings.py:691
+#: ../gui/wxpython/menustrings.py:693
msgid "Manage databases"
msgstr ""
-#: ../gui/wxpython/menustrings.py:692
+#: ../gui/wxpython/menustrings.py:694
msgid "Connect"
msgstr ""
-#: ../gui/wxpython/menustrings.py:693
+#: ../gui/wxpython/menustrings.py:695
msgid "Prints/sets general DB connection for current mapset and exits."
msgstr ""
"Imprime/establece la conexión general a la base de datos para el directorio "
"de mapas actual y sale."
-#: ../gui/wxpython/menustrings.py:694
+#: ../gui/wxpython/menustrings.py:696
msgid "Login"
msgstr ""
-#: ../gui/wxpython/menustrings.py:695
+#: ../gui/wxpython/menustrings.py:697
msgid "Sets user/password for driver/database."
msgstr "Establece usuario/contraseña para controlador/base de datos."
-#: ../gui/wxpython/menustrings.py:696
+#: ../gui/wxpython/menustrings.py:698
msgid "Copy table"
msgstr "Copiar tabla"
-#: ../gui/wxpython/menustrings.py:697
+#: ../gui/wxpython/menustrings.py:699
#, fuzzy
msgid ""
"Copy a table. Either 'from_table' (optionally with 'where') can be used or "
@@ -7786,11 +8000,11 @@
"Copiar una tabla. Se puede usar tanto la opción 'from_table' (opcionalmente "
"con 'where') como 'select', pero no ambas al mismo tiempo."
-#: ../gui/wxpython/menustrings.py:698
+#: ../gui/wxpython/menustrings.py:700
msgid "New table"
msgstr "Nueva tabla"
-#: ../gui/wxpython/menustrings.py:699
+#: ../gui/wxpython/menustrings.py:701
msgid ""
"Creates and adds a new attribute table to a given layer of an existing "
"vector map."
@@ -7798,20 +8012,20 @@
"Crea y añade una nueva tabla de atributos a una capa dada de un mapa "
"vectorial existente."
-#: ../gui/wxpython/menustrings.py:700
+#: ../gui/wxpython/menustrings.py:702
msgid "Remove table"
msgstr "Eliminar tabla"
-#: ../gui/wxpython/menustrings.py:701
+#: ../gui/wxpython/menustrings.py:703
#, fuzzy
msgid "Drops an attribute table."
msgstr "Mostrar tabla de atributos"
-#: ../gui/wxpython/menustrings.py:702
+#: ../gui/wxpython/menustrings.py:704
msgid "Add columns"
msgstr "Añadir columnas"
-#: ../gui/wxpython/menustrings.py:703
+#: ../gui/wxpython/menustrings.py:705
msgid ""
"Adds one or more columns to the attribute table connected to a given vector "
"map."
@@ -7819,107 +8033,133 @@
"Añade una o más columnas a la tabla de atributos conectada a un mapa "
"vectorial dado."
-#: ../gui/wxpython/menustrings.py:704
+#: ../gui/wxpython/menustrings.py:706
msgid "Change values"
msgstr "Cambiar valores"
-#: ../gui/wxpython/menustrings.py:705
+#: ../gui/wxpython/menustrings.py:707
msgid ""
"Allows to update a column in the attribute table connected to a vector map."
msgstr ""
"Permite actualizar una columna en la tabla de atributos conectada a un mapa "
"vectorial."
-#: ../gui/wxpython/menustrings.py:707
+#: ../gui/wxpython/menustrings.py:709
msgid ""
"Renames a column in the attribute table connected to a given vector map."
msgstr ""
"Cambia el nombre de una columna en la tabla de atributos conectada a un mapa "
"vectorial dado."
-#: ../gui/wxpython/menustrings.py:708
+#: ../gui/wxpython/menustrings.py:710
msgid "Test"
msgstr "Test"
-#: ../gui/wxpython/menustrings.py:709
+#: ../gui/wxpython/menustrings.py:711
msgid "Test database driver, database must exist and set by db.connect."
msgstr ""
"Probar el controlador de base de datos. La base de datos debe existir y "
"estar conectada por db. connect."
-#: ../gui/wxpython/menustrings.py:710
+#: ../gui/wxpython/menustrings.py:712
msgid "Query"
msgstr "Consultas"
-#: ../gui/wxpython/menustrings.py:711
+#: ../gui/wxpython/menustrings.py:713
msgid "Query any table"
msgstr "Consultar cualquier tabla"
-#: ../gui/wxpython/menustrings.py:712
+#: ../gui/wxpython/menustrings.py:714
msgid "Selects data from table."
msgstr "Selecciona datos de una tabla."
-#: ../gui/wxpython/menustrings.py:713
+#: ../gui/wxpython/menustrings.py:715
msgid "Query vector attribute data"
msgstr "Consultar datos de vectorial"
-#: ../gui/wxpython/menustrings.py:714
+#: ../gui/wxpython/menustrings.py:716
msgid "Prints vector map attributes."
msgstr "Imprime atributos de mapa vectorial."
-#: ../gui/wxpython/menustrings.py:715
+#: ../gui/wxpython/menustrings.py:717
msgid "SQL statement"
msgstr "Sentencia SQL"
-#: ../gui/wxpython/menustrings.py:716
+#: ../gui/wxpython/menustrings.py:718
msgid "Executes any SQL statement."
msgstr "Ejecuta cualquier sentencia SQL."
-#: ../gui/wxpython/menustrings.py:717
+#: ../gui/wxpython/menustrings.py:719
#, fuzzy
msgid "Vector database connections"
msgstr "vectorial"
-#: ../gui/wxpython/menustrings.py:718
+#: ../gui/wxpython/menustrings.py:720
msgid "Reconnect vector to database"
msgstr "Volver a conectar vectorial a base de datos"
-#: ../gui/wxpython/menustrings.py:719
+#: ../gui/wxpython/menustrings.py:721
msgid "Reconnects vectors to a new database."
msgstr "Conecta vectoriales a una nueva base de datos."
-#: ../gui/wxpython/menustrings.py:720
+#: ../gui/wxpython/menustrings.py:722
#, fuzzy
msgid "Set vector map - database connection"
msgstr "vectorial"
-#: ../gui/wxpython/menustrings.py:721
+#: ../gui/wxpython/menustrings.py:723
msgid "Prints/sets DB connection for a vector map to attribute table."
msgstr ""
"Imprime/establece la conexión a la base de datos para un mapa vectorial a la "
"tabla de atributos."
-#: ../gui/wxpython/menustrings.py:722
+#: ../gui/wxpython/menustrings.py:724
msgid "Help"
msgstr "Ayuda"
-#: ../gui/wxpython/menustrings.py:723
+#: ../gui/wxpython/menustrings.py:725
msgid "GRASS GIS help"
msgstr ""
-#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:726
+#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:728
msgid "Display the HTML man pages of GRASS"
msgstr "Mostrar las páginas man HTML de GRASS"
-#: ../gui/wxpython/menustrings.py:725
+#: ../gui/wxpython/menustrings.py:727
msgid "GRASS GIS GUI help"
msgstr ""
-#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:728
+#: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:730
msgid "About GRASS GIS"
msgstr ""
+#~ msgid "Unable to read EPGS codes: %s"
+#~ msgstr "No se pueden leer los códigos EPSG: %s"
+#~ msgid "Datums:"
+#~ msgstr "Datums:"
#, fuzzy
+#~ msgid "Output vector map name"
+#~ msgstr "Nombre del mapa vectorial de salida (editable)"
+#~ msgid ""
+#~ "Unable to start Nviz. The OpenGL package was not found. You can get it at "
+#~ "http://PyOpenGL.sourceforge.net. Switching back to 2D display mode.\n"
+#~ "\n"
+#~ "Details: %s"
+#~ msgstr ""
+#~ "No se puede iniciar Zviz. !No se encontró el paquete OpenGL. Puede "
+#~ "obtenerlo en http://PyOpenGL.sourceforge.net. Se vuelve al modo de "
+#~ "visualización 2D.\n"
+#~ "\n"
+#~ "Detalles: %s"
+#, fuzzy
+#~ msgid "GRASS GIS Layer Manager (Experimental Prototype)"
+#~ msgstr "Capa"
+#, fuzzy
#~ msgid "Save current settings?"
#~ msgstr "Guardar?"
@@ -7986,10 +8226,6 @@
#~ msgid "Undo is not implemented in vedit component. Use vdigit instead."
#~ msgstr "Usar."
-#, fuzzy
-#~ msgid "Adding new feature to vector map <%s> failed."
-#~ msgstr "vectorial."
#~ msgid "List of categories"
#~ msgstr "Lista de categorÃas"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_ru.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_ru.po 2009-05-22 15:36:57 UTC (rev 37374)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_ru.po 2009-05-22 15:53:49 UTC (rev 37375)
@@ -6,8 +6,8 @@
msgstr ""
"Project-Id-Version: grasswxpy_ru\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2009-01-09 17:00+0100\n"
-"PO-Revision-Date: 2008-10-10 19:44-0600\n"
+"POT-Creation-Date: 2009-05-22 17:09+0200\n"
+"PO-Revision-Date: 2009-01-27 23:34-0600\n"
"Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
"Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -16,9 +16,8 @@
"X-Generator: KBabel 1.9.1\n"
#: ../gui/wxpython/icons/icon.py:81
-#, fuzzy
msgid "Unable to load icon theme..."
-msgstr "Ðевозможно загÑÑзиÑÑ Ð½Ð°Ð±Ð¾Ñ Ð¸ÐºÐ¾Ð½Ð¾Ðº, иÑполÑзÑÑÑÑÑ ÑÑандаÑÑнÑй..."
+msgstr "Ðевозможно загÑÑзиÑÑ Ð½Ð°Ð±Ð¾Ñ Ð¸ÐºÐ¾Ð½Ð¾Ðº..."
#: ../gui/wxpython/icons/icon.py:141
msgid "Display map"
@@ -105,7 +104,7 @@
msgstr "СоÑ
ÑаниÑÑ Ð´Ð¸Ñплей в PNG Ñайл"
#: ../gui/wxpython/icons/icon.py:176
-#: ../gui/wxpython/gui_modules/mapdisp.py:912
+#: ../gui/wxpython/gui_modules/mapdisp.py:1020
msgid "Print display"
msgstr "РаÑпеÑаÑаÑÑ Ð´Ð¸Ñплей"
@@ -206,7 +205,7 @@
msgstr "ÐобавиÑÑ Ð¿Ð¾Ð´Ð¿Ð¸Ñи"
#: ../gui/wxpython/icons/icon.py:228
-#: ../gui/wxpython/gui_modules/mapdisp.py:1509
+#: ../gui/wxpython/gui_modules/mapdisp.py:1627
msgid "Add text layer"
msgstr "ÐобавиÑÑ ÑекÑÑовÑй Ñлой"
@@ -253,7 +252,7 @@
msgstr "Слева: ÐÑбÑаÑÑ; Ð ÑеÑедине: ÐÑмениÑÑ Ð²ÑбоÑ; СпÑава: ÐодÑвеÑдиÑÑ"
#: ../gui/wxpython/icons/icon.py:248
-#: ../gui/wxpython/gui_modules/toolbars.py:722
+#: ../gui/wxpython/gui_modules/toolbars.py:738
msgid "Copy categories"
msgstr "СкопиÑоваÑÑ ÐºÐ°ÑегоÑии"
@@ -291,7 +290,7 @@
#: ../gui/wxpython/icons/icon.py:272 ../gui/wxpython/icons/icon.py:332
#: ../gui/wxpython/icons/icon.py:336
-#: ../gui/wxpython/gui_modules/nviz_tools.py:945
+#: ../gui/wxpython/gui_modules/nviz_tools.py:950
msgid "Settings"
msgstr "УÑÑановки"
@@ -356,7 +355,7 @@
msgstr "ÐÑбÑаÑÑ ÑвеÑ"
#: ../gui/wxpython/icons/icon.py:306
-#: ../gui/wxpython/gui_modules/gdialogs.py:299
+#: ../gui/wxpython/gui_modules/gdialogs.py:301
msgid "Set options"
msgstr "УÑÑановиÑÑ Ð½Ð°ÑÑÑойки"
@@ -373,8 +372,8 @@
msgstr "ÐÑбÑаÑÑ GCP (ÑоÑÐºÑ Ð¿ÑивÑзки)"
#: ../gui/wxpython/icons/icon.py:314
-#: ../gui/wxpython/gui_modules/georect.py:141
-#: ../gui/wxpython/gui_modules/georect.py:147
+#: ../gui/wxpython/gui_modules/georect.py:148
+#: ../gui/wxpython/gui_modules/georect.py:154
#: ../gui/wxpython/menustrings.py:164
msgid "Georectify"
msgstr "ÐÑовеÑÑи геомеÑÑиÑеÑкÑÑ ÐºÐ¾ÑÑекÑиÑ"
@@ -419,601 +418,634 @@
msgid "Show Nviz settings dialog"
msgstr "ÐоказаÑÑ Ð´Ð¸Ð°Ð»Ð¾Ð³ наÑÑÑойки Nviz"
-#: ../gui/wxpython/gui_modules/location_wizard.py:131
+#: ../gui/wxpython/gui_modules/location_wizard.py:139
msgid "Define GRASS Database and Location Name"
msgstr "УкажиÑе Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
GRASS и название облаÑÑи"
-#: ../gui/wxpython/gui_modules/location_wizard.py:137
-#: ../gui/wxpython/gui_modules/location_wizard.py:1076
-#: ../gui/wxpython/gui_modules/location_wizard.py:1154
-#: ../gui/wxpython/gui_modules/location_wizard.py:1246
-#: ../gui/wxpython/gui_modules/menuform.py:1286
-#: ../gui/wxpython/gui_modules/gdialogs.py:814
-#: ../gui/wxpython/gui_modules/gdialogs.py:824 ../gui/wxpython/gis_set.py:123
+#: ../gui/wxpython/gui_modules/location_wizard.py:145
+#: ../gui/wxpython/gui_modules/location_wizard.py:1088
+#: ../gui/wxpython/gui_modules/location_wizard.py:1166
+#: ../gui/wxpython/gui_modules/location_wizard.py:1261
+#: ../gui/wxpython/gui_modules/menuform.py:1457
+#: ../gui/wxpython/gui_modules/gdialogs.py:856
+#: ../gui/wxpython/gui_modules/gdialogs.py:865 ../gui/wxpython/gis_set.py:121
msgid "Browse"
msgstr "ÐÑоÑмоÑÑ"
-#: ../gui/wxpython/gui_modules/location_wizard.py:145
-#: ../gui/wxpython/gis_set.py:99
+#: ../gui/wxpython/gui_modules/location_wizard.py:153
+#: ../gui/wxpython/gis_set.py:97
msgid "GIS Data Directory:"
msgstr "ÐаÑалог Ñ ÐÐС-даннÑми:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:161
+#: ../gui/wxpython/gui_modules/location_wizard.py:169
msgid "Project Location"
msgstr "РаÑположение пÑоекÑа"
-#: ../gui/wxpython/gui_modules/location_wizard.py:199
+#: ../gui/wxpython/gui_modules/location_wizard.py:207
msgid "Choose GRASS data directory:"
msgstr "ÐÑбеÑиÑе каÑалог Ñ Ð´Ð°Ð½Ð½Ñми GRASS"
-#: ../gui/wxpython/gui_modules/location_wizard.py:210
-#: ../gui/wxpython/gui_modules/location_wizard.py:1839
+#: ../gui/wxpython/gui_modules/location_wizard.py:218
+#: ../gui/wxpython/gui_modules/location_wizard.py:1863
msgid "Location already exists in GRASS Database."
msgstr "ÐблаÑÑÑ Ñже ÑÑÑеÑÑвÑÐµÑ Ð² базе даннÑÑ
GRASS"
-#: ../gui/wxpython/gui_modules/location_wizard.py:213
+#: ../gui/wxpython/gui_modules/location_wizard.py:221
msgid "Unable to create location"
msgstr "Ðевозможно ÑоздаÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ"
-#: ../gui/wxpython/gui_modules/location_wizard.py:217
-#: ../gui/wxpython/gui_modules/location_wizard.py:540
-#: ../gui/wxpython/gui_modules/location_wizard.py:1420
-#: ../gui/wxpython/gui_modules/location_wizard.py:1840
-#: ../gui/wxpython/gui_modules/location_wizard.py:1916
-#: ../gui/wxpython/gui_modules/location_wizard.py:2023
-#: ../gui/wxpython/gui_modules/location_wizard.py:2058
-#: ../gui/wxpython/gui_modules/location_wizard.py:2230
-#: ../gui/wxpython/gui_modules/location_wizard.py:2247
-#: ../gui/wxpython/gui_modules/location_wizard.py:2554
-#: ../gui/wxpython/gui_modules/georect.py:902
-#: ../gui/wxpython/gui_modules/georect.py:939
-#: ../gui/wxpython/gui_modules/gdialogs.py:144
-#: ../gui/wxpython/gui_modules/mapdisp.py:340
-#: ../gui/wxpython/gui_modules/workspace.py:617
-#: ../gui/wxpython/gui_modules/preferences.py:1536
-#: ../gui/wxpython/gui_modules/dbm.py:187
-#: ../gui/wxpython/gui_modules/dbm.py:275
-#: ../gui/wxpython/gui_modules/dbm.py:1246
-#: ../gui/wxpython/gui_modules/dbm.py:1350
-#: ../gui/wxpython/gui_modules/dbm.py:1434
-#: ../gui/wxpython/gui_modules/dbm.py:1446
-#: ../gui/wxpython/gui_modules/dbm.py:1460
-#: ../gui/wxpython/gui_modules/dbm.py:1553
-#: ../gui/wxpython/gui_modules/dbm.py:1575
-#: ../gui/wxpython/gui_modules/dbm.py:1729
-#: ../gui/wxpython/gui_modules/dbm.py:1740
-#: ../gui/wxpython/gui_modules/dbm.py:1752
-#: ../gui/wxpython/gui_modules/dbm.py:2568
-#: ../gui/wxpython/gui_modules/dbm.py:2666
-#: ../gui/wxpython/gui_modules/dbm.py:2673
-#: ../gui/wxpython/gui_modules/dbm.py:2712
+#: ../gui/wxpython/gui_modules/location_wizard.py:225
+#: ../gui/wxpython/gui_modules/location_wizard.py:547
+#: ../gui/wxpython/gui_modules/location_wizard.py:1864
+#: ../gui/wxpython/gui_modules/location_wizard.py:1962
+#: ../gui/wxpython/gui_modules/location_wizard.py:2064
+#: ../gui/wxpython/gui_modules/location_wizard.py:2096
+#: ../gui/wxpython/gui_modules/location_wizard.py:2259
+#: ../gui/wxpython/gui_modules/location_wizard.py:2276
+#: ../gui/wxpython/gui_modules/location_wizard.py:2583
+#: ../gui/wxpython/gui_modules/georect.py:945
+#: ../gui/wxpython/gui_modules/georect.py:982
+#: ../gui/wxpython/gui_modules/gdialogs.py:143
+#: ../gui/wxpython/gui_modules/mapdisp.py:309
+#: ../gui/wxpython/gui_modules/mapdisp.py:367
+#: ../gui/wxpython/gui_modules/workspace.py:631
+#: ../gui/wxpython/gui_modules/preferences.py:1579
+#: ../gui/wxpython/gui_modules/dbm.py:179
+#: ../gui/wxpython/gui_modules/dbm.py:280
+#: ../gui/wxpython/gui_modules/dbm.py:1277
+#: ../gui/wxpython/gui_modules/dbm.py:1386
+#: ../gui/wxpython/gui_modules/dbm.py:1472
+#: ../gui/wxpython/gui_modules/dbm.py:1484
+#: ../gui/wxpython/gui_modules/dbm.py:1499
+#: ../gui/wxpython/gui_modules/dbm.py:1594
+#: ../gui/wxpython/gui_modules/dbm.py:1616
+#: ../gui/wxpython/gui_modules/dbm.py:1771
+#: ../gui/wxpython/gui_modules/dbm.py:1782
+#: ../gui/wxpython/gui_modules/dbm.py:1794
+#: ../gui/wxpython/gui_modules/dbm.py:2574
+#: ../gui/wxpython/gui_modules/dbm.py:2672
+#: ../gui/wxpython/gui_modules/dbm.py:2679
+#: ../gui/wxpython/gui_modules/dbm.py:2718
#: ../gui/wxpython/gui_modules/gcmd.py:66
#: ../gui/wxpython/gui_modules/gcmd.py:92
-#: ../gui/wxpython/gui_modules/render.py:457
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:411
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:443
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1232
-#: ../gui/wxpython/gui_modules/vdigit.py:1897
-#: ../gui/wxpython/gui_modules/vdigit.py:2076
-#: ../gui/wxpython/gui_modules/vdigit.py:2100
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1096
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1727
-#: ../gui/wxpython/gis_set.py:672 ../gui/wxpython/wxgui.py:739
-#: ../gui/wxpython/wxgui.py:871 ../gui/wxpython/wxgui.py:880
+#: ../gui/wxpython/gui_modules/render.py:477
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:442
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:474
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:511
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1288
+#: ../gui/wxpython/gui_modules/vdigit.py:1948
+#: ../gui/wxpython/gui_modules/vdigit.py:2127
+#: ../gui/wxpython/gui_modules/vdigit.py:2151
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1893
+#: ../gui/wxpython/gis_set.py:687 ../gui/wxpython/wxgui.py:799
+#: ../gui/wxpython/wxgui.py:931 ../gui/wxpython/wxgui.py:940
msgid "Error"
msgstr "ÐÑибка"
-#: ../gui/wxpython/gui_modules/location_wizard.py:239
+#: ../gui/wxpython/gui_modules/location_wizard.py:247
msgid "Choose method for creating a new location"
msgstr "ÐÑбеÑиÑе меÑод Ð´Ð»Ñ ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð½Ð¾Ð²Ð¾Ð¹ облаÑÑи"
-#: ../gui/wxpython/gui_modules/location_wizard.py:246
+#: ../gui/wxpython/gui_modules/location_wizard.py:254
msgid "Select coordinate system"
msgstr "ÐÑбеÑиÑе ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑдинаÑ"
-#: ../gui/wxpython/gui_modules/location_wizard.py:249
+#: ../gui/wxpython/gui_modules/location_wizard.py:257
msgid "Select EPSG code of coordinate system"
msgstr "ÐÑбеÑиÑе EPSG-код ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑдинаÑ"
-#: ../gui/wxpython/gui_modules/location_wizard.py:251
+#: ../gui/wxpython/gui_modules/location_wizard.py:259
msgid "Use coordinate system of selected georeferenced file"
msgstr "ÐÑполÑзоваÑÑ ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑÐ´Ð¸Ð½Ð°Ñ Ð²ÑбÑанного Ñайла"
-#: ../gui/wxpython/gui_modules/location_wizard.py:254
+#: ../gui/wxpython/gui_modules/location_wizard.py:262
msgid "Use coordinate system of selected WKT or PRJ file"
msgstr "ÐÑполÑзоваÑÑ ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑÐ´Ð¸Ð½Ð°Ñ Ð²ÑбÑанного WKT или PRJ Ñайла"
-#: ../gui/wxpython/gui_modules/location_wizard.py:257
+#: ../gui/wxpython/gui_modules/location_wizard.py:265
msgid "Create custom PROJ.4 parameters string for coordinate system"
msgstr "СоздаÑÑ ÑÑÑÐ¾ÐºÑ Ð¿Ð°ÑамеÑÑов PROJ.4 Ð´Ð»Ñ ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑдинаÑ"
-#: ../gui/wxpython/gui_modules/location_wizard.py:260
+#: ../gui/wxpython/gui_modules/location_wizard.py:268
msgid "Use arbitrary non-earth coordinate system (XY)"
msgstr "ÐÑполÑзоваÑÑ Ð¿ÑоизволÑнÑÑ ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑÐ´Ð¸Ð½Ð°Ñ (XY)"
-#: ../gui/wxpython/gui_modules/location_wizard.py:332
+#: ../gui/wxpython/gui_modules/location_wizard.py:341
msgid "Choose projection"
msgstr "ÐÑбеÑиÑе пÑоекÑиÑ"
-#: ../gui/wxpython/gui_modules/location_wizard.py:347
-#: ../gui/wxpython/gui_modules/location_wizard.py:771
-#: ../gui/wxpython/gui_modules/location_wizard.py:779
-#: ../gui/wxpython/gui_modules/location_wizard.py:964
-#: ../gui/wxpython/gui_modules/location_wizard.py:1254
+#: ../gui/wxpython/gui_modules/location_wizard.py:356
+#: ../gui/wxpython/gui_modules/location_wizard.py:783
+#: ../gui/wxpython/gui_modules/location_wizard.py:791
+#: ../gui/wxpython/gui_modules/location_wizard.py:976
+#: ../gui/wxpython/gui_modules/location_wizard.py:1269
msgid "Code"
msgstr "Ðод"
msgid "Description"
msgstr "ÐпиÑание"
-#: ../gui/wxpython/gui_modules/location_wizard.py:350
+#: ../gui/wxpython/gui_modules/location_wizard.py:359
msgid "Projection code:"
msgstr "Ðод пÑоекÑии:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:358
-#: ../gui/wxpython/gui_modules/location_wizard.py:793
-#: ../gui/wxpython/gui_modules/location_wizard.py:976
-#: ../gui/wxpython/gui_modules/location_wizard.py:1237
+#: ../gui/wxpython/gui_modules/location_wizard.py:367
+#: ../gui/wxpython/gui_modules/location_wizard.py:805
+#: ../gui/wxpython/gui_modules/location_wizard.py:988
msgid "Search in description:"
msgstr "ÐÑкаÑÑ Ð² опиÑании:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:539
+#: ../gui/wxpython/gui_modules/location_wizard.py:546
#, python-format
msgid "Unable to read list: %s"
msgstr "Ðевозможно пÑоÑиÑаÑÑ ÑпиÑок: %s"
-#: ../gui/wxpython/gui_modules/location_wizard.py:639
-#: ../gui/wxpython/gui_modules/location_wizard.py:1431
+#: ../gui/wxpython/gui_modules/location_wizard.py:651
+#: ../gui/wxpython/gui_modules/location_wizard.py:1455
msgid "Choose method of specifying georeferencing parameters"
msgstr "ÐÑбеÑиÑе меÑод опÑÐµÐ´ÐµÐ»ÐµÐ½Ð¸Ñ Ð¿Ð°ÑамеÑÑов пÑивÑзки"
-#: ../gui/wxpython/gui_modules/location_wizard.py:647
+#: ../gui/wxpython/gui_modules/location_wizard.py:659
msgid "Select datum with associated ellipsoid"
msgstr "ÐÑбеÑиÑе даÑÑм Ñ ÑооÑвеÑÑÑвÑÑÑим ÑллипÑоидом"
-#: ../gui/wxpython/gui_modules/location_wizard.py:650
+#: ../gui/wxpython/gui_modules/location_wizard.py:662
msgid "Select ellipsoid"
msgstr "ÐÑбеÑиÑе ÑллипÑоид"
-#: ../gui/wxpython/gui_modules/location_wizard.py:651
+#: ../gui/wxpython/gui_modules/location_wizard.py:663
msgid "Set zone for UTM projection:"
msgstr "УÑÑановиÑе Ð·Ð¾Ð½Ñ Ð´Ð»Ñ Ð¿ÑоекÑии UTM"
-#: ../gui/wxpython/gui_modules/location_wizard.py:653
+#: ../gui/wxpython/gui_modules/location_wizard.py:665
msgid "Zone:"
msgstr "Ðона:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:656
+#: ../gui/wxpython/gui_modules/location_wizard.py:668
msgid "Hemisphere for zone:"
msgstr "ÐолÑÑаÑие Ð´Ð»Ñ Ð·Ð¾Ð½Ñ:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:744
+#: ../gui/wxpython/gui_modules/location_wizard.py:756
msgid "Specify geodetic datum"
msgstr "УкажиÑе геодезиÑеÑкий даÑÑм"
msgid "Ellipsoid"
msgstr "ÐллипÑоид"
msgid "Datum"
msgstr "ÐаÑÑм"
-#: ../gui/wxpython/gui_modules/location_wizard.py:784
+#: ../gui/wxpython/gui_modules/location_wizard.py:796
msgid "Datum code:"
msgstr "Ðод даÑÑма:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:808
+#: ../gui/wxpython/gui_modules/location_wizard.py:820
msgid "Transformation parameters:"
msgstr "ÐаÑамеÑÑÑ Ð¿ÑеобÑазованиÑ:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:941
+#: ../gui/wxpython/gui_modules/location_wizard.py:953
msgid "Specify ellipsoid"
msgstr "УкажиÑе ÑллипÑоид"
-#: ../gui/wxpython/gui_modules/location_wizard.py:968
+#: ../gui/wxpython/gui_modules/location_wizard.py:980
msgid "Ellipsoid code:"
msgstr "Ðод ÑллипÑоида:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1069
-#: ../gui/wxpython/gui_modules/location_wizard.py:1128
+#: ../gui/wxpython/gui_modules/location_wizard.py:1081
+#: ../gui/wxpython/gui_modules/location_wizard.py:1140
msgid "Select georeferenced file"
msgstr "ÐÑбеÑиÑе пÑивÑзаннÑй Ñайл"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1074
+#: ../gui/wxpython/gui_modules/location_wizard.py:1086
msgid "Georeferenced file:"
msgstr "ÐÑивÑзаннÑй Ñайл:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1147
-#: ../gui/wxpython/gui_modules/location_wizard.py:1206
+#: ../gui/wxpython/gui_modules/location_wizard.py:1159
+#: ../gui/wxpython/gui_modules/location_wizard.py:1218
msgid "Select WKT file"
msgstr "ÐÑбеÑиÑе WKT Ñайл"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1152
+#: ../gui/wxpython/gui_modules/location_wizard.py:1164
msgid "WKT file:"
msgstr "WKT Ñайл:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1225
+#: ../gui/wxpython/gui_modules/location_wizard.py:1237
msgid "Choose EPSG Code"
msgstr "УкажиÑе код EPSG"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1233
+#: ../gui/wxpython/gui_modules/location_wizard.py:1245
msgid "Path to the EPSG-codes file:"
msgstr "ÐÑÑÑ Ðº ÑÐ°Ð¹Ð»Ñ ÐºÐ¾Ð´Ð¾Ð² EPSG:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1235
+#: ../gui/wxpython/gui_modules/location_wizard.py:1247
msgid "EPSG code:"
msgstr "код EPSG:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1247
-msgid "Browse EPSG Codes"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1249
+msgid "Search in"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1252
+#, fuzzy
+msgid "codes"
+msgstr "Ðод"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1253
+#, fuzzy
+msgid "description"
+msgstr "ÐпиÑание"
+#, fuzzy
+msgid "parameters"
+msgstr "ÐаÑамеÑÑÑ"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1262
+#, fuzzy
+msgid "Reload EPSG Codes"
msgstr "ÐÑоÑмоÑÑеÑÑ ÐºÐ¾Ð´Ñ EPSG"
msgid "Parameters"
msgstr "ÐаÑамеÑÑÑ"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1368
+#: ../gui/wxpython/gui_modules/location_wizard.py:1390
msgid "Choose EPSG codes file"
msgstr "ÐÑбÑаÑÑ Ñайл кодов EPSG"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1419
-#, python-format
-msgid "Unable to read EPGS codes: %s"
-msgstr "Ðевозможно пÑоÑиÑаÑÑ ÐºÐ¾Ð´Ñ EPSG: %s"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1439
+#: ../gui/wxpython/gui_modules/location_wizard.py:1463
msgid "Enter PROJ.4 parameters string:"
msgstr "ÐведиÑе ÑÑÑÐ¾ÐºÑ Ð¿Ð°ÑамеÑÑов PROJ.4:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1490
+#: ../gui/wxpython/gui_modules/location_wizard.py:1514
msgid "Summary"
msgstr "ÐÑÐ½Ð¾Ð²Ð½Ð°Ñ Ð¸Ð½ÑоÑмаÑиÑ"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1512
+#: ../gui/wxpython/gui_modules/location_wizard.py:1536
msgid "GRASS Database:"
msgstr "Ðаза даннÑÑ
GRASS:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1518
+#: ../gui/wxpython/gui_modules/location_wizard.py:1542
msgid "Location Name:"
msgstr "ÐÐ¼Ñ Ð¾Ð±Ð»Ð°ÑÑи:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1524
+#: ../gui/wxpython/gui_modules/location_wizard.py:1548
msgid "Projection:"
msgstr "ÐÑоекÑиÑ:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1563
+#: ../gui/wxpython/gui_modules/location_wizard.py:1587
msgid "PROJ.4 definition:"
msgstr "ÐпÑеделение PROJ.4:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1608
+#: ../gui/wxpython/gui_modules/location_wizard.py:1632
#, python-format
msgid "Do you want to create GRASS location <%s>?"
msgstr "ÐÑ Ñ
оÑиÑе ÑоздаÑÑ Ð½Ð¾Ð²ÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ GRASS <%s>?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1609
+#: ../gui/wxpython/gui_modules/location_wizard.py:1633
msgid "Create new location?"
msgstr "СоздаÑÑ Ð½Ð¾Ð²ÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1645
+#: ../gui/wxpython/gui_modules/location_wizard.py:1669
msgid "Define new GRASS Location"
msgstr "ÐпÑеделиÑÑ Ð½Ð¾Ð²ÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ GRASS"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1723
+#: ../gui/wxpython/gui_modules/location_wizard.py:1747
msgid "Do you want to set the default region extents and resolution now?"
msgstr "ÐÑ Ñ
оÑиÑе ÑÑÑановиÑÑ Ð¾Ñ
Ð²Ð°Ñ Ð¸ ÑазÑеÑение Ñегиона ÑейÑаÑ?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1725
+#: ../gui/wxpython/gui_modules/location_wizard.py:1749
#, python-format
msgid "Location <%s> created"
msgstr "ÐблаÑÑÑ <%s> Ñоздана"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1739
+#: ../gui/wxpython/gui_modules/location_wizard.py:1763
#, python-format
msgid "Unable to create new location. Location <%s> not created."
msgstr "Ðевозможно ÑоздаÑÑ Ð½Ð¾Ð²ÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ. ÐблаÑÑÑ <%s> не Ñоздана."
-#: ../gui/wxpython/gui_modules/location_wizard.py:1741
-#: ../gui/wxpython/gui_modules/location_wizard.py:1749
-#: ../gui/wxpython/gis_set.py:127
+#: ../gui/wxpython/gui_modules/location_wizard.py:1765
+#: ../gui/wxpython/gui_modules/location_wizard.py:1773
+#: ../gui/wxpython/gis_set.py:125
msgid "Location wizard"
msgstr "ÐаÑÑÐµÑ ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð¾Ð±Ð»Ð°ÑÑи"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1747
+#: ../gui/wxpython/gui_modules/location_wizard.py:1771
msgid "Location wizard canceled. Location not created."
msgstr "РабоÑа маÑÑеÑа ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð¾Ð±Ð»Ð°ÑÑи пÑеÑвана. ÐблаÑÑÑ Ð½Ðµ Ñоздана."
-#: ../gui/wxpython/gui_modules/location_wizard.py:1837
-#: ../gui/wxpython/gui_modules/location_wizard.py:1915
-#: ../gui/wxpython/gui_modules/location_wizard.py:2022
-#: ../gui/wxpython/gui_modules/location_wizard.py:2095
-#: ../gui/wxpython/gui_modules/location_wizard.py:2125
+#: ../gui/wxpython/gui_modules/location_wizard.py:1861
+#: ../gui/wxpython/gui_modules/location_wizard.py:1961
+#: ../gui/wxpython/gui_modules/location_wizard.py:2063
+#: ../gui/wxpython/gui_modules/location_wizard.py:2131
+#: ../gui/wxpython/gui_modules/location_wizard.py:2159
msgid "Unable to create new location"
msgstr "Ðевозможно ÑоздаÑÑ Ð½Ð¾Ð²ÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1884
+#, python-format
+msgid ""
+"Location <%(loc)s> will be created in GIS data directory <%(dir)s>.You will "
+"need to change the default GIS data directory in the GRASS startup screen."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1889
+#, fuzzy
+msgid "New GIS data directory"
+msgstr "ÐаÑалог Ñ ÐÐС-даннÑми:"
msgid "EPSG code missing."
msgstr "ÐÑÑÑÑÑÑвÑÐµÑ ÐºÐ¾Ð´ EPSG."
-#: ../gui/wxpython/gui_modules/location_wizard.py:2057
+#: ../gui/wxpython/gui_modules/location_wizard.py:2095
msgid "Datum transform is required."
msgstr "ÐеобÑ
одима ÑÑанÑÑоÑмаÑÐ¸Ñ Ð´Ð°ÑÑма."
-#: ../gui/wxpython/gui_modules/location_wizard.py:2096
-#: ../gui/wxpython/gui_modules/location_wizard.py:2126
+#: ../gui/wxpython/gui_modules/location_wizard.py:2132
+#: ../gui/wxpython/gui_modules/location_wizard.py:2160
msgid "file not found"
msgstr "Ñайл не найден"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2152
+#: ../gui/wxpython/gui_modules/location_wizard.py:2181
msgid "Set default region extent and resolution"
msgstr "УÑÑановиÑÑ Ð¾Ñ
Ð²Ð°Ñ Ð¸ ÑазÑеÑение Ñегиона по ÑмолÑаниÑ"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2196
+#: ../gui/wxpython/gui_modules/location_wizard.py:2228
msgid "&Set region"
msgstr "&УÑÑановиÑÑ Ñегион"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2229
+#: ../gui/wxpython/gui_modules/location_wizard.py:2258
msgid "Invalid location selected."
msgstr "Указана непÑавилÑÐ½Ð°Ñ Ð¾Ð±Ð»Ð°ÑÑÑ."
-#: ../gui/wxpython/gui_modules/location_wizard.py:2246
+#: ../gui/wxpython/gui_modules/location_wizard.py:2275
msgid "Invalid region"
msgstr "ÐепÑавилÑнÑй Ñегион"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2276
+#: ../gui/wxpython/gui_modules/location_wizard.py:2305
msgid "Click here to show 3D settings"
msgstr "ÐажмиÑе, ÑÑÐ¾Ð±Ñ Ð¿Ð¾ÐºÐ°Ð·Ð°ÑÑ Ð½Ð°ÑÑÑойки 3D"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2277
+#: ../gui/wxpython/gui_modules/location_wizard.py:2306
msgid "Click here to hide 3D settings"
msgstr "ÐажмиÑе, ÑÑÐ¾Ð±Ñ ÑкÑÑÑÑ Ð½Ð°ÑÑÑойки 3D"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2300
-#: ../gui/wxpython/gui_modules/location_wizard.py:2581
+#: ../gui/wxpython/gui_modules/location_wizard.py:2329
+#: ../gui/wxpython/gui_modules/location_wizard.py:2610
#, python-format
msgid "Rows: %d"
msgstr "СÑÑоки: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2301
-#: ../gui/wxpython/gui_modules/location_wizard.py:2582
+#: ../gui/wxpython/gui_modules/location_wizard.py:2330
+#: ../gui/wxpython/gui_modules/location_wizard.py:2611
#, python-format
msgid "Cols: %d"
msgstr "СÑолбÑÑ: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2302
-#: ../gui/wxpython/gui_modules/location_wizard.py:2583
+#: ../gui/wxpython/gui_modules/location_wizard.py:2331
+#: ../gui/wxpython/gui_modules/location_wizard.py:2612
#, python-format
msgid "Cells: %d"
msgstr "ЯÑейки: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2343
-#: ../gui/wxpython/gui_modules/location_wizard.py:2585
+#: ../gui/wxpython/gui_modules/location_wizard.py:2372
+#: ../gui/wxpython/gui_modules/location_wizard.py:2614
#, python-format
msgid "Depth: %d"
msgstr "ÐлÑбина: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2344
-#: ../gui/wxpython/gui_modules/location_wizard.py:2586
+#: ../gui/wxpython/gui_modules/location_wizard.py:2373
+#: ../gui/wxpython/gui_modules/location_wizard.py:2615
#, python-format
msgid "3D Cells: %d"
msgstr "3D ÑÑейки: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2347
+#: ../gui/wxpython/gui_modules/location_wizard.py:2376
msgid "Top"
msgstr "ÐеÑÑ
-#: ../gui/wxpython/gui_modules/location_wizard.py:2355
+#: ../gui/wxpython/gui_modules/location_wizard.py:2384
msgid "Bottom"
msgstr "Ðиз"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2363
+#: ../gui/wxpython/gui_modules/location_wizard.py:2392
msgid "T-B resolution"
msgstr "ÑазÑеÑение Ð-Ð"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2426
+#: ../gui/wxpython/gui_modules/location_wizard.py:2455
msgid "North"
msgstr "СевеÑ"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2434
+#: ../gui/wxpython/gui_modules/location_wizard.py:2463
msgid "West"
msgstr "Ðапад"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2454
+#: ../gui/wxpython/gui_modules/location_wizard.py:2483
msgid "East"
msgstr "ÐоÑÑок"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2463
+#: ../gui/wxpython/gui_modules/location_wizard.py:2492
msgid "South"
msgstr "Юг"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2467
+#: ../gui/wxpython/gui_modules/location_wizard.py:2496
msgid "N-S resolution"
msgstr "ÑазÑеÑение С-Ю "
-#: ../gui/wxpython/gui_modules/location_wizard.py:2475
+#: ../gui/wxpython/gui_modules/location_wizard.py:2504
msgid "E-W resolution"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2553
+#: ../gui/wxpython/gui_modules/location_wizard.py:2582
#, python-format
msgid "Invalid value: %s"
msgstr "ÐепÑавилÑное знаÑение: %s "
-#: ../gui/wxpython/gui_modules/location_wizard.py:2620
+#: ../gui/wxpython/gui_modules/location_wizard.py:2638
msgid "Select datum transformation"
msgstr "ÐÑбÑаÑÑ ÑÑанÑÑоÑмаÑÐ¸Ñ Ð´Ð°ÑÑма"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2634
+#: ../gui/wxpython/gui_modules/location_wizard.py:2652
msgid "List of datum transformations"
msgstr "СпиÑок ÑÑанÑÑоÑмаÑий даÑÑма"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2638
-msgid "Datums:"
-msgstr "ÐаÑÑмÑ:"
+#: ../gui/wxpython/gui_modules/location_wizard.py:2656
+msgid "Datums (select to see description):"
+msgstr ""
-#: ../gui/wxpython/gui_modules/georect.py:109
+#: ../gui/wxpython/gui_modules/georect.py:114
msgid "Setup for georectification"
msgstr "УÑÑановки Ð´Ð»Ñ Ð¿ÑивÑзки"
-#: ../gui/wxpython/gui_modules/georect.py:140
-#: ../gui/wxpython/gui_modules/georect.py:146
+#: ../gui/wxpython/gui_modules/georect.py:147
+#: ../gui/wxpython/gui_modules/georect.py:153
msgid "Georectifying setup canceled."
msgstr "ÐÑмена наÑÑÑоек пÑивÑзки."
-#: ../gui/wxpython/gui_modules/georect.py:184
+#: ../gui/wxpython/gui_modules/georect.py:191
msgid "Set ground control points (GCPs)"
msgstr "УÑÑановиÑÑ ÑоÑки пÑивÑзки (GCPs)"
-#: ../gui/wxpython/gui_modules/georect.py:283
+#: ../gui/wxpython/gui_modules/georect.py:290
msgid "Select map type and location/mapset"
msgstr "ÐÑбÑаÑÑ Ñип ÑÐ»Ð¾Ñ Ð¸ облаÑÑÑ/набоÑ"
-#: ../gui/wxpython/gui_modules/georect.py:310
+#: ../gui/wxpython/gui_modules/georect.py:318
msgid "Map type to georectify"
msgstr "Тип ÑÐ»Ð¾Ñ Ð´Ð»Ñ Ð¿ÑивÑзки"
-#: ../gui/wxpython/gui_modules/georect.py:311
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:648
+#: ../gui/wxpython/gui_modules/georect.py:319
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:692
msgid "raster"
msgstr "ÑаÑÑÑ"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:669
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:713
msgid "vector"
msgstr "векÑоÑ"
-#: ../gui/wxpython/gui_modules/georect.py:317
+#: ../gui/wxpython/gui_modules/georect.py:326
msgid "Select source location:"
msgstr "ÐÑбÑаÑÑ Ð¸ÑÑ
однÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ:"
-#: ../gui/wxpython/gui_modules/georect.py:328
+#: ../gui/wxpython/gui_modules/georect.py:337
msgid "Select source mapset:"
однÑй набоÑ:"
-#: ../gui/wxpython/gui_modules/georect.py:382
+#: ../gui/wxpython/gui_modules/georect.py:391
msgid "You must select a valid location before selecting a mapset"
msgstr "ÐÑ Ð´Ð¾Ð»Ð¶Ð½Ñ ÑказаÑÑ Ð¿Ð¾Ð´Ñ
одÑÑÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ Ð¿ÐµÑед вÑбоÑом набоÑа"
-#: ../gui/wxpython/gui_modules/georect.py:393
+#: ../gui/wxpython/gui_modules/georect.py:402
msgid "You must select a valid location and mapset in order to continue"
msgstr ""
одÑÑÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ Ð¸ Ð½Ð°Ð±Ð¾Ñ Ð´Ð»Ñ Ñого, ÑÑÐ¾Ð±Ñ Ð¿ÑодолжиÑÑ "
"ÑабоÑÑ"
-#: ../gui/wxpython/gui_modules/georect.py:410
+#: ../gui/wxpython/gui_modules/georect.py:419
msgid "Select image/map group to georectify"
msgstr "ÐÑбÑаÑÑ Ð¸Ð·Ð¾Ð±Ñажение/Ñлой Ð´Ð»Ñ Ð¿ÑивÑзки"
-#: ../gui/wxpython/gui_modules/georect.py:429
+#: ../gui/wxpython/gui_modules/georect.py:438
msgid "Select group:"
msgstr "ÐÑбÑаÑÑ Ð³ÑÑппÑ:"
-#: ../gui/wxpython/gui_modules/georect.py:440
+#: ../gui/wxpython/gui_modules/georect.py:449
msgid "Create group if none exists"
msgstr "ÐÑли гÑÑппа не Ñоздана, ÑоздаÑÑ Ð½Ð¾Ð²ÑÑ"
-#: ../gui/wxpython/gui_modules/georect.py:443
+#: ../gui/wxpython/gui_modules/georect.py:453
msgid "Create/edit group..."
msgstr "СоздаÑÑ/ÑедакÑиÑоваÑÑ Ð³ÑÑппÑ..."
-#: ../gui/wxpython/gui_modules/georect.py:449
+#: ../gui/wxpython/gui_modules/georect.py:454
+#, fuzzy
+msgid "Add vector map to group..."
+msgstr "ÐобавиÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
+#: ../gui/wxpython/gui_modules/georect.py:467
msgid "Extension for output maps:"
msgstr "РаÑÑиÑение Ð´Ð»Ñ Ð²ÑÑ
однÑÑ
Ñлоев:"
-#: ../gui/wxpython/gui_modules/georect.py:500
+#: ../gui/wxpython/gui_modules/georect.py:523
msgid "You must select a valid image/map group in order to continue"
msgstr ""
"ÐÑ Ð´Ð¾Ð»Ð¶Ð½Ñ ÑказаÑÑ Ð¿ÑавилÑнÑÑ Ð³ÑÑÐ¿Ð¿Ñ Ð¸Ð·Ð¾Ð±Ñажений/Ñлоев Ð´Ð»Ñ Ñого, ÑÑÐ¾Ð±Ñ "
"пÑодолжиÑÑ ÑабоÑÑ"
-#: ../gui/wxpython/gui_modules/georect.py:505
+#: ../gui/wxpython/gui_modules/georect.py:528
msgid "You must enter an map name extension in order to continue"
msgstr "ÐÑ Ð´Ð¾Ð»Ð¶Ð½Ñ ÑказаÑÑ ÑаÑÑиÑение ÑÐ»Ð¾Ñ Ð´Ð»Ñ Ñого, ÑÑÐ¾Ð±Ñ Ð¿ÑодолжиÑÑ ÑабоÑÑ"
-#: ../gui/wxpython/gui_modules/georect.py:550
+#: ../gui/wxpython/gui_modules/georect.py:590
msgid "Select image/map to display for ground control point (GCP) creation"
msgstr "ÐÑбÑаÑÑ Ð¸Ð·Ð¾Ð±Ñажение/Ñлой Ð´Ð»Ñ Ð¾ÑобÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð¸ ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ ÑоÑек пÑивÑзки"
-#: ../gui/wxpython/gui_modules/georect.py:558
+#: ../gui/wxpython/gui_modules/georect.py:598
msgid "Select display image/map:"
msgstr "УкажиÑе изобÑажение или Ñлой Ð´Ð»Ñ Ð²Ð¸Ð·ÑализаÑии:"
-#: ../gui/wxpython/gui_modules/georect.py:590
+#: ../gui/wxpython/gui_modules/georect.py:632
msgid "You must select a valid image/map in order to continue"
msgstr ""
"ÐÑ Ð´Ð¾Ð»Ð¶Ð½Ñ ÑказаÑÑ Ð¿ÑавилÑное изобÑажение/Ñлой Ð´Ð»Ñ Ñого, ÑÑÐ¾Ð±Ñ Ð¿ÑодолжиÑÑ "
"ÑабоÑÑ"
-#: ../gui/wxpython/gui_modules/georect.py:614
+#: ../gui/wxpython/gui_modules/georect.py:657
msgid "Create & manage ground control points"
msgstr "СоздаÑÑ Ð¸ ÑпÑавлÑÑÑ ÑоÑками пÑивÑзки"
-#: ../gui/wxpython/gui_modules/georect.py:708
+#: ../gui/wxpython/gui_modules/georect.py:751
msgid "Select rectification method for rasters"
msgstr "ÐÑбÑаÑÑ Ð¼ÐµÑод ÑÑанÑÑоÑмаÑии Ð´Ð»Ñ ÑаÑÑÑовÑÑ
Ñлоев"
-#: ../gui/wxpython/gui_modules/georect.py:709
+#: ../gui/wxpython/gui_modules/georect.py:752
msgid "1st order"
msgstr "1-Ñй ÑÑовенÑ"
msgid "2nd order"
msgstr "2-ой ÑÑовенÑ"
msgid "3rd order"
msgstr "3-ий ÑÑовенÑ"
-#: ../gui/wxpython/gui_modules/georect.py:715
+#: ../gui/wxpython/gui_modules/georect.py:758
msgid "clip to computational region in target location"
msgstr "обÑезаÑÑ Ð¿Ð¾ ÑаÑÑеÑÐ½Ð¾Ð¼Ñ ÑÐµÐ³Ð¸Ð¾Ð½Ñ Ñелевой облаÑÑи"
-#: ../gui/wxpython/gui_modules/georect.py:720
+#: ../gui/wxpython/gui_modules/georect.py:763
msgid "Ground Control Points"
msgstr "ÐонÑÑолÑнÑе ÑоÑки"
-#: ../gui/wxpython/gui_modules/georect.py:787
+#: ../gui/wxpython/gui_modules/georect.py:830
#, python-format
msgid "At least %d GCPs required. Operation cancelled."
msgstr ""
"ÐеобÑ
одимо как минимÑм %d ÑоÑек пÑивÑзки. ÐпеÑаÑÐ¸Ñ Ð½Ðµ Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð²Ñполнена."
-#: ../gui/wxpython/gui_modules/georect.py:788
+#: ../gui/wxpython/gui_modules/georect.py:831
msgid "Delete GCP"
msgstr "УдалиÑÑ GCP"
-#: ../gui/wxpython/gui_modules/georect.py:896
+#: ../gui/wxpython/gui_modules/georect.py:939
#, python-format
msgid "POINTS file <%s> saved"
msgstr "Ñайл POINTS <%s> ÑоÑ
Ñанен"
-#: ../gui/wxpython/gui_modules/georect.py:897
+#: ../gui/wxpython/gui_modules/georect.py:940
msgid "POINTS file saved"
msgstr "Ñайл POINTS ÑоÑ
Ñанен"
-#: ../gui/wxpython/gui_modules/georect.py:900
+#: ../gui/wxpython/gui_modules/georect.py:943
msgid "Writing POINTS file failed"
msgstr "ÐÑибка пÑи запиÑи Ñайла POINTS"
-#: ../gui/wxpython/gui_modules/georect.py:937
+#: ../gui/wxpython/gui_modules/georect.py:980
msgid "Reading POINTS file failed"
msgstr "ÐÑибка пÑи ÑÑении Ñайла POINTS"
-#: ../gui/wxpython/gui_modules/georect.py:982
+#: ../gui/wxpython/gui_modules/georect.py:1025
msgid "RMS Error"
msgstr "оÑибка RMS"
-#: ../gui/wxpython/gui_modules/georect.py:983
+#: ../gui/wxpython/gui_modules/georect.py:1026
+#, fuzzy
msgid ""
"Insufficient points defined and active (checked) for selected rectification "
"method.\n"
"3+ points needed for 1st order,\n"
-"7+ points for 2nd order, and\n"
+"6+ points for 2nd order, and\n"
"10+ points for 3rd order."
msgstr ""
"ÐпÑеделено и акÑивно (вклÑÑено) недоÑÑаÑоÑно ÑоÑек Ð´Ð»Ñ Ð²ÑбÑанного меÑода.\n"
@@ -1021,252 +1053,289 @@
"7+ ÑоÑек нÑжно Ð´Ð»Ñ 2-го поÑÑдка, и\n"
"10+ ÑоÑек нÑжно Ð´Ð»Ñ 3-го поÑÑдка."
-#: ../gui/wxpython/gui_modules/georect.py:1054
+#: ../gui/wxpython/gui_modules/georect.py:1075
+#, fuzzy, python-format
+msgid "Transforming <%s>..."
+msgstr "ТÑанÑÑоÑмиÑоваÑÑ Ð¸Ð·Ð¾Ð±Ñажение"
+#: ../gui/wxpython/gui_modules/georect.py:1122
+msgid ""
+"Vector map <%s> already exists. Change extension name and georectify again."
+msgstr "ÐекÑоÑнÑй Ñлой <%s> в ÑекÑÑем набоÑе Ñже ÑÑÑеÑÑвÑеÑ. ÐеÑезапиÑаÑÑ?"
+#: ../gui/wxpython/gui_modules/georect.py:1137
+msgid "Vector map <%s> georectified successfully"
+msgstr "ÐекÑоÑнÑй Ñлой <%(name)s> (%(type)s) ÑÑпеÑно вÑгÑÑжен"
+#: ../gui/wxpython/gui_modules/georect.py:1140
+#, fuzzy
+msgid "Copying attributes..."
+msgstr "ÐзмениÑÑ Ð°ÑÑибÑÑÑ"
+#: ../gui/wxpython/gui_modules/georect.py:1143
+msgid "Georectification of vector map <%s> failed"
+msgstr "Ðобавление нового обÑекÑа к векÑоÑÐ½Ð¾Ð¼Ñ ÑÐ»Ð¾Ñ <%s> не вÑполнено."
+#: ../gui/wxpython/gui_modules/georect.py:1151
msgid "Georectifier settings"
msgstr "ÐаÑÑÑойки пÑивÑзки"
-#: ../gui/wxpython/gui_modules/georect.py:1148
+#: ../gui/wxpython/gui_modules/georect.py:1245
#, python-format
msgid "RMS error for selected points forward: %(fwd)s backward: %(bkw)s"
msgstr ""
"RMS оÑибка Ð´Ð»Ñ Ð²ÑбÑаннÑÑ
ÑоÑек, пÑÑмое пÑеобÑазование: %(fwd)s обÑаÑное: %"
"(bkw)s"
-#: ../gui/wxpython/gui_modules/georect.py:1181
+#: ../gui/wxpython/gui_modules/georect.py:1278
msgid "use| X coord"
msgstr "иÑполÑзоваÑÑ| кооÑдинаÑа X"
-#: ../gui/wxpython/gui_modules/georect.py:1182
+#: ../gui/wxpython/gui_modules/georect.py:1279
msgid "Y coord"
msgstr "кооÑдинаÑа Y"
-#: ../gui/wxpython/gui_modules/georect.py:1183
+#: ../gui/wxpython/gui_modules/georect.py:1280
msgid "E coord"
msgstr "кооÑдинаÑа E"
-#: ../gui/wxpython/gui_modules/georect.py:1184
+#: ../gui/wxpython/gui_modules/georect.py:1281
msgid "N coord"
msgstr "кооÑдинаÑа N"
-#: ../gui/wxpython/gui_modules/georect.py:1185
+#: ../gui/wxpython/gui_modules/georect.py:1282
msgid "Forward error"
msgstr "ÐÑÑÐ¼Ð°Ñ Ð¾Ñибка"
-#: ../gui/wxpython/gui_modules/georect.py:1186
+#: ../gui/wxpython/gui_modules/georect.py:1283
msgid "Backward error"
msgstr "ÐбÑаÑÐ½Ð°Ñ Ð¾Ñибка"
-#: ../gui/wxpython/gui_modules/georect.py:1286
-#: ../gui/wxpython/gui_modules/georect.py:1394
+#: ../gui/wxpython/gui_modules/georect.py:1383
+#: ../gui/wxpython/gui_modules/georect.py:1525
msgid "Edit GCP"
msgstr "РедакÑиÑоваÑÑ GCP"
-#: ../gui/wxpython/gui_modules/georect.py:1287
+#: ../gui/wxpython/gui_modules/georect.py:1384
msgid "Invalid coordinate value. Operation cancelled."
msgstr "ÐекоÑÑекÑное знаÑение кооÑдинаÑÑ. ÐпеÑаÑÐ¸Ñ Ð¾Ñменена."
#: ../gui/wxpython/gui_modules/georect.py:1405
+#, fuzzy
+msgid "Create vector map group"
+msgstr "СоздаÑÑ Ð½Ð¾Ð²Ñй векÑоÑнÑй Ñлой"
+#: ../gui/wxpython/gui_modules/georect.py:1478
+#, fuzzy
+msgid "Select vector map(s) to add to group:"
+msgstr "ÐÑбÑаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
+#: ../gui/wxpython/gui_modules/georect.py:1536
msgid "Ground Control Point"
msgstr "ТоÑка пÑивÑзки"
-#: ../gui/wxpython/gui_modules/georect.py:1419
+#: ../gui/wxpython/gui_modules/georect.py:1550
msgid "X:"
msgstr "X:"
-#: ../gui/wxpython/gui_modules/georect.py:1420
+#: ../gui/wxpython/gui_modules/georect.py:1551
msgid "Y:"
msgstr "Y:"
-#: ../gui/wxpython/gui_modules/georect.py:1421
+#: ../gui/wxpython/gui_modules/georect.py:1552
msgid "E:"
msgstr "E:"
-#: ../gui/wxpython/gui_modules/georect.py:1422
+#: ../gui/wxpython/gui_modules/georect.py:1553
msgid "N:"
msgstr "N:"
-#: ../gui/wxpython/gui_modules/georect.py:1508
+#: ../gui/wxpython/gui_modules/georect.py:1639
msgid "Symbol settings"
msgstr "ÐаÑÑÑойки Ñимвола"
-#: ../gui/wxpython/gui_modules/georect.py:1517
-#: ../gui/wxpython/gui_modules/nviz_tools.py:554
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1243
+#: ../gui/wxpython/gui_modules/georect.py:1648
+#: ../gui/wxpython/gui_modules/preferences.py:1266
+#: ../gui/wxpython/gui_modules/nviz_tools.py:559
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1248
msgid "Color:"
msgstr "ЦвеÑ:"
-#: ../gui/wxpython/gui_modules/georect.py:1534
-#: ../gui/wxpython/gui_modules/nviz_tools.py:538
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1214
+#: ../gui/wxpython/gui_modules/georect.py:1665
+#: ../gui/wxpython/gui_modules/nviz_tools.py:543
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1219
msgid "Width:"
msgstr "ШиÑина:"
-#: ../gui/wxpython/gui_modules/georect.py:1562
-#: ../gui/wxpython/gui_modules/profile.py:1007
-#: ../gui/wxpython/gui_modules/profile.py:1352
-#: ../gui/wxpython/gui_modules/preferences.py:832
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1269
+#: ../gui/wxpython/gui_modules/georect.py:1693
+#: ../gui/wxpython/gui_modules/profile.py:1027
+#: ../gui/wxpython/gui_modules/profile.py:1372
+#: ../gui/wxpython/gui_modules/preferences.py:855
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1274
msgid "Apply changes for the current session"
msgstr "ÐÑимениÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð´Ð»Ñ ÑÑÑеÑÑвÑÑÑей ÑеÑÑии"
-#: ../gui/wxpython/gui_modules/georect.py:1564
-#: ../gui/wxpython/gui_modules/profile.py:1009
-#: ../gui/wxpython/gui_modules/profile.py:1354
-#: ../gui/wxpython/gui_modules/preferences.py:834
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1271
+#: ../gui/wxpython/gui_modules/georect.py:1695
+#: ../gui/wxpython/gui_modules/profile.py:1029
+#: ../gui/wxpython/gui_modules/profile.py:1374
+#: ../gui/wxpython/gui_modules/preferences.py:857
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1276
msgid ""
"Apply and save changes to user settings file (default for next sessions)"
msgstr ""
"ÐÑимениÑÑ Ð¸ ÑоÑ
ÑаниÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð´Ð»Ñ Ñайла полÑзоваÑелÑÑкиÑ
наÑÑÑоек (бÑÐ´ÐµÑ "
"по-ÑмолÑÐ°Ð½Ð¸Ñ Ð´Ð»Ñ ÑледÑÑÑиÑ
ÑеÑÑий)"
-#: ../gui/wxpython/gui_modules/georect.py:1567
-#: ../gui/wxpython/gui_modules/profile.py:1012
-#: ../gui/wxpython/gui_modules/profile.py:1357
-#: ../gui/wxpython/gui_modules/preferences.py:837
-#: ../gui/wxpython/gui_modules/vdigit.py:1077
+#: ../gui/wxpython/gui_modules/georect.py:1698
+#: ../gui/wxpython/gui_modules/profile.py:1032
+#: ../gui/wxpython/gui_modules/profile.py:1377
+#: ../gui/wxpython/gui_modules/preferences.py:860
+#: ../gui/wxpython/gui_modules/vdigit.py:1102
msgid "Close dialog and ignore changes"
msgstr "ÐакÑÑÑÑ Ð´Ð¸Ð°Ð»Ð¾Ð³Ð¾Ð²Ð¾Ðµ окно и игноÑиÑоваÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ"
-#: ../gui/wxpython/gui_modules/georect.py:1594
+#: ../gui/wxpython/gui_modules/georect.py:1725
#, python-format
msgid "Georectifier settings saved to file '%s'."
msgstr "ÐаÑÑÑойки инÑÑÑÑменÑа пÑивÑзки ÑоÑ
ÑÐ°Ð½ÐµÐ½Ñ Ð² Ñайл '%s'."
-#: ../gui/wxpython/gui_modules/menuform.py:138
-#: ../gui/wxpython/gui_modules/menuform.py:1248
+#: ../gui/wxpython/gui_modules/menuform.py:1419
msgid "Select Color"
-#: ../gui/wxpython/gui_modules/menuform.py:186
+#: ../gui/wxpython/gui_modules/menuform.py:329
msgid "unknown"
msgstr "неизвеÑÑно"
-#: ../gui/wxpython/gui_modules/menuform.py:201
+#: ../gui/wxpython/gui_modules/menuform.py:344
#, python-format
msgid "Parameter not found: %s"
msgstr "ÐаÑамеÑÑ Ð½Ðµ найден: %s"
-#: ../gui/wxpython/gui_modules/menuform.py:220
+#: ../gui/wxpython/gui_modules/menuform.py:363
#, python-format
msgid "Flag not found: %s"
msgstr "Флаг не найден: %s"
-#: ../gui/wxpython/gui_modules/menuform.py:254
+#: ../gui/wxpython/gui_modules/menuform.py:397
msgid "<required>"
msgstr "<ÑÑебÑеÑÑÑ>"
-#: ../gui/wxpython/gui_modules/menuform.py:255
+#: ../gui/wxpython/gui_modules/menuform.py:398
#, python-format
msgid "Parameter %(name)s (%(desc)s) is missing.\n"
msgstr "ÐаÑамеÑÑ %(name)s (%(desc)s) оÑÑÑÑÑÑвÑеÑ.\n"
-#: ../gui/wxpython/gui_modules/menuform.py:626
+#: ../gui/wxpython/gui_modules/menuform.py:769
msgid "Enter parameters for "
msgstr "ÐвеÑÑи паÑамеÑÑÑ Ð´Ð»Ñ"
-#: ../gui/wxpython/gui_modules/menuform.py:630
+#: ../gui/wxpython/gui_modules/menuform.py:773
msgid " (those in bold typeface are required)"
msgstr " (ÑказаннÑе жиÑнÑм ÑÑиÑÑом необÑ
одимÑ)"
-#: ../gui/wxpython/gui_modules/menuform.py:641
+#: ../gui/wxpython/gui_modules/menuform.py:784
msgid "Close this window without executing the command"
-msgstr ""
+msgstr "ÐакÑойÑе ÑÑо окно без вÑÐ¿Ð¾Ð»Ð½ÐµÐ½Ð¸Ñ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ"
-#: ../gui/wxpython/gui_modules/menuform.py:646
+#: ../gui/wxpython/gui_modules/menuform.py:789
msgid "Show manual page of the command"
msgstr "ÐоказаÑÑ Ð¾Ð¿Ð¸Ñание Ð´Ð»Ñ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ"
-#: ../gui/wxpython/gui_modules/menuform.py:664
+#: ../gui/wxpython/gui_modules/menuform.py:809
msgid "&Run"
msgstr "&ÐÑполниÑÑ"
-#: ../gui/wxpython/gui_modules/menuform.py:665
+#: ../gui/wxpython/gui_modules/menuform.py:810
msgid "Run the command"
msgstr "ÐÑполниÑÑ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ"
-#: ../gui/wxpython/gui_modules/menuform.py:669
+#: ../gui/wxpython/gui_modules/menuform.py:814
msgid "Abort the running command"
msgstr "ÐÑмениÑÑ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ"
-#: ../gui/wxpython/gui_modules/menuform.py:673
+#: ../gui/wxpython/gui_modules/menuform.py:818
msgid "Copy the current command string to the clipboard"
msgstr "ÐопиÑоваÑÑ ÑекÑÑÑÑ ÐºÐ¾Ð¼Ð°Ð½Ð´Ð½ÑÑ ÑÑÑÐ¾ÐºÑ Ð² бÑÑÐµÑ Ð¾Ð±Ð¼ÐµÐ½Ð°"
-#: ../gui/wxpython/gui_modules/menuform.py:705
+#: ../gui/wxpython/gui_modules/menuform.py:850
#: ../gui/wxpython/gui_modules/gdialogs.py:68
-#: ../gui/wxpython/gui_modules/preferences.py:1124
+#: ../gui/wxpython/gui_modules/preferences.py:1170
msgid "Add created map into layer tree"
msgstr "ÐобавиÑÑ ÑозданнÑй Ñлой в ÑодеÑжание"
-#: ../gui/wxpython/gui_modules/menuform.py:714
-#: ../gui/wxpython/gui_modules/preferences.py:1114
+#: ../gui/wxpython/gui_modules/menuform.py:859
+#: ../gui/wxpython/gui_modules/preferences.py:1160
msgid "Close dialog on finish"
msgstr "ÐакÑÑÑÑ Ð´Ð¸Ð°Ð»Ð¾Ð³Ð¾Ð²Ð¾Ðµ окно поÑле оконÑÐ°Ð½Ð¸Ñ Ð¾Ð¿ÐµÑаÑии"
-#: ../gui/wxpython/gui_modules/menuform.py:826
+#: ../gui/wxpython/gui_modules/menuform.py:977
#, python-format
msgid "'%s' copied to clipboard"
msgstr "'%s' ÑкопиÑовано в бÑÑÐµÑ Ð¾Ð±Ð¼ÐµÐ½Ð°"
-#: ../gui/wxpython/gui_modules/menuform.py:885
-#: ../gui/wxpython/gui_modules/menuform.py:898
-#: ../gui/wxpython/gui_modules/menuform.py:1394
+#: ../gui/wxpython/gui_modules/menuform.py:1036
+#: ../gui/wxpython/gui_modules/menuform.py:1049
+#: ../gui/wxpython/gui_modules/menuform.py:1568
msgid "Required"
msgstr "ÐеобÑ
одимо"
-#: ../gui/wxpython/gui_modules/menuform.py:888
+#: ../gui/wxpython/gui_modules/menuform.py:1039
msgid "Optional"
msgstr "ÐпÑионнÑй"
-#: ../gui/wxpython/gui_modules/menuform.py:926 ../gui/wxpython/wxgui.py:310
-#: ../gui/wxpython/wxgui.py:401
+#: ../gui/wxpython/gui_modules/menuform.py:1077 ../gui/wxpython/wxgui.py:318
+#: ../gui/wxpython/wxgui.py:409
msgid "Command output"
msgstr "РезÑлÑÑÐ°Ñ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ"
-#: ../gui/wxpython/gui_modules/menuform.py:933
+#: ../gui/wxpython/gui_modules/menuform.py:1087
msgid "Manual"
msgstr "ÐÑÑÑнÑÑ"
-#: ../gui/wxpython/gui_modules/menuform.py:1008
+#: ../gui/wxpython/gui_modules/menuform.py:1181
msgid "[multiple]"
msgstr "[множеÑÑвеннÑй]"
-#: ../gui/wxpython/gui_modules/menuform.py:1057
+#: ../gui/wxpython/gui_modules/menuform.py:1228
msgid "Valid range"
msgstr "ÐÑавилÑнÑй диапазон"
-#: ../gui/wxpython/gui_modules/menuform.py:1267
+#: ../gui/wxpython/gui_modules/menuform.py:1438
msgid "Transparent"
msgstr "ÐÑозÑаÑнÑй"
-#: ../gui/wxpython/gui_modules/menuform.py:1284
+#: ../gui/wxpython/gui_modules/menuform.py:1455
#, python-format
msgid "Choose %s"
msgstr "ÐÑбÑаÑÑ %s"
-#: ../gui/wxpython/gui_modules/menuform.py:1285
+#: ../gui/wxpython/gui_modules/menuform.py:1456
#: ../gui/wxpython/menustrings.py:2
msgid "File"
msgstr "Файл"
-#: ../gui/wxpython/gui_modules/menuform.py:1587
+#: ../gui/wxpython/gui_modules/menuform.py:1720
#, python-format
msgid "Error in %s"
msgstr "ÐÑибка в %s"
-#: ../gui/wxpython/gui_modules/menuform.py:1621
+#: ../gui/wxpython/gui_modules/menuform.py:1754
#, python-format
msgid "Unable to fetch interface description for command '%s'."
msgstr "Ðевозможно полÑÑиÑÑ Ð¾Ð¿Ð¸Ñание инÑеÑÑейÑа Ð´Ð»Ñ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ '%s'."
-#: ../gui/wxpython/gui_modules/menuform.py:1705
+#: ../gui/wxpython/gui_modules/menuform.py:1844
#, python-format
msgid "Unable to parse command %s"
msgstr "Ðевозможно обÑабоÑаÑÑ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ %s"
-#: ../gui/wxpython/gui_modules/menuform.py:1794
+#: ../gui/wxpython/gui_modules/menuform.py:1933
#, python-format
msgid "usage: %s <grass command>"
msgstr "иÑполÑзование: %s <команда grass>"
@@ -1280,11 +1349,11 @@
msgstr "СоздаÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ"
#: ../gui/wxpython/gui_modules/gdialogs.py:127
-#: ../gui/wxpython/menustrings.py:461
+#: ../gui/wxpython/menustrings.py:463
msgid "Create new vector map"
-#: ../gui/wxpython/gui_modules/gdialogs.py:143
+#: ../gui/wxpython/gui_modules/gdialogs.py:142
#, python-format
msgid "Unable to create vector map <%s>."
msgstr "Ðе Ð¼Ð¾Ð³Ñ ÑоздаÑÑ Ð½Ð¾Ð²Ñй векÑоÑнÑй Ñлой <%s>."
@@ -1300,20 +1369,20 @@
msgid "Overwrite?"
msgstr "ÐеÑезапиÑаÑÑ?"
-#: ../gui/wxpython/gui_modules/gdialogs.py:205
+#: ../gui/wxpython/gui_modules/gdialogs.py:207
#, python-format
msgid "New vector map <%s> created"
msgstr "Создан новÑй векÑоÑнÑй Ñлой <%s>"
-#: ../gui/wxpython/gui_modules/gdialogs.py:227
+#: ../gui/wxpython/gui_modules/gdialogs.py:229
msgid "Load region:"
msgstr "ÐагÑÑзиÑÑ Ñегион:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:235
+#: ../gui/wxpython/gui_modules/gdialogs.py:237
msgid "Save region:"
msgstr "СоÑ
ÑаниÑÑ Ñегион:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:306
+#: ../gui/wxpython/gui_modules/gdialogs.py:308
#, python-format
msgid ""
"Drag %s with mouse in pointer mode to position.\n"
@@ -1322,7 +1391,7 @@
"ÐеÑеÑаÑиÑÑ %s Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ Ð¼ÑÑки в Ñежиме ÑказаÑÐµÐ»Ñ Ðº позиÑии.\n"
"Ðвойной ÑелÑок Ð´Ð»Ñ ÑÐ¼ÐµÐ½Ñ Ð½Ð°ÑÑÑоек."
-#: ../gui/wxpython/gui_modules/gdialogs.py:309
+#: ../gui/wxpython/gui_modules/gdialogs.py:311
msgid ""
"\n"
"Define raster map name for legend in properties dialog."
@@ -1330,25 +1399,25 @@
"\n"
"ÐадаÑÑ Ð² окне ÑвойÑÑв Ð¸Ð¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð´Ð»Ñ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
-#: ../gui/wxpython/gui_modules/gdialogs.py:361
+#: ../gui/wxpython/gui_modules/gdialogs.py:363
#, python-format
msgid "Legend of raster map <%s>"
msgstr "Ðегенда ÑаÑÑÑового ÑÐ»Ð¾Ñ <%s>"
-#: ../gui/wxpython/gui_modules/gdialogs.py:484
+#: ../gui/wxpython/gui_modules/gdialogs.py:487
msgid "Enter text:"
msgstr "ÐведиÑе ÑекÑÑ:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:497
+#: ../gui/wxpython/gui_modules/gdialogs.py:503
msgid "Rotation:"
msgstr "ÐовоÑоÑ:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:510
-#: ../gui/wxpython/gui_modules/preferences.py:967
+#: ../gui/wxpython/gui_modules/gdialogs.py:516
+#: ../gui/wxpython/gui_modules/preferences.py:1000
msgid "Set font"
msgstr "УÑÑановиÑе ÑÑиÑÑ"
-#: ../gui/wxpython/gui_modules/gdialogs.py:521
+#: ../gui/wxpython/gui_modules/gdialogs.py:527
msgid ""
"Drag text with mouse in pointer mode to position.\n"
"Double-click to change options"
@@ -1356,120 +1425,135 @@
"ÐеÑеÑаÑиÑе ÑекÑÑ (в Ñежиме ÑказаÑелÑ) в нÑжное меÑÑо.\n"
"ÐÐ»Ñ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð¿Ð°ÑамеÑÑов иÑполÑзÑйÑе двойной клик мÑÑкой"
-#: ../gui/wxpython/gui_modules/gdialogs.py:613
+#: ../gui/wxpython/gui_modules/gdialogs.py:624
msgid "Load"
msgstr "ÐагÑÑзиÑÑ"
-#: ../gui/wxpython/gui_modules/gdialogs.py:648
+#: ../gui/wxpython/gui_modules/gdialogs.py:653
msgid "Map layer type:"
msgstr "Тип ÑлоÑ:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:659
+#: ../gui/wxpython/gui_modules/gdialogs.py:665
+#, fuzzy
+msgid "Select toggle"
+msgstr "ÐÑбÑаÑÑ Ð²Ð¸ÑÑÑие ÑзлÑ"
+#: ../gui/wxpython/gui_modules/gdialogs.py:672
msgid "Mapset:"
msgstr "ÐабоÑ:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:672
+#: ../gui/wxpython/gui_modules/gdialogs.py:685
msgid "Filter:"
msgstr "ФилÑÑÑ:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:684
+#: ../gui/wxpython/gui_modules/gdialogs.py:697
msgid "List of maps:"
msgstr "СпиÑок каÑÑ:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:737
-#: ../gui/wxpython/gui_modules/gdialogs.py:1092
-#: ../gui/wxpython/gui_modules/dbm.py:976
+#: ../gui/wxpython/gui_modules/gdialogs.py:753
+#: ../gui/wxpython/gui_modules/gdialogs.py:1130
+#: ../gui/wxpython/gui_modules/dbm.py:1001
msgid "Select all"
msgstr "ÐÑбÑаÑÑ Ð²Ñе"
-#: ../gui/wxpython/gui_modules/gdialogs.py:738
-#: ../gui/wxpython/gui_modules/gdialogs.py:1093
-#: ../gui/wxpython/gui_modules/dbm.py:977
+#: ../gui/wxpython/gui_modules/gdialogs.py:754
+#, fuzzy
+msgid "Invert selection"
+msgstr "СеÑение"
+#: ../gui/wxpython/gui_modules/gdialogs.py:755
+#: ../gui/wxpython/gui_modules/gdialogs.py:1131
+#: ../gui/wxpython/gui_modules/dbm.py:1002
msgid "Deselect all"
msgstr "СнÑÑÑ Ð²Ñделение Ñо вÑего"
-#: ../gui/wxpython/gui_modules/gdialogs.py:795
+#: ../gui/wxpython/gui_modules/gdialogs.py:828
msgid "Multiple import"
msgstr "ÐмпоÑÑ Ð½ÐµÑколÑкиÑ
Ñлоев"
-#: ../gui/wxpython/gui_modules/gdialogs.py:809
+#: ../gui/wxpython/gui_modules/gdialogs.py:839
msgid "Input DXF file"
msgstr "ÐÑÑ
однÑй Ñайл DXF"
-#: ../gui/wxpython/gui_modules/gdialogs.py:810
+#: ../gui/wxpython/gui_modules/gdialogs.py:841
+msgid "Input directory"
+msgstr "ÐÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð¿Ð°Ð¿ÐºÐ°"
+#: ../gui/wxpython/gui_modules/gdialogs.py:846
+#, python-format
+msgid " List of %s layers "
+msgstr "СпиÑок Ñлоев %s"
+#: ../gui/wxpython/gui_modules/gdialogs.py:852
msgid "Choose DXF file:"
msgstr "ÐÑбÑаÑÑ Ñайл DXF:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:813
+#: ../gui/wxpython/gui_modules/gdialogs.py:855
msgid "Choose DXF file to import"
msgstr "ÐÑбеÑиÑе импоÑÑиÑÑемÑй Ñайл DXF"
-#: ../gui/wxpython/gui_modules/gdialogs.py:819
-msgid "Input directory"
-msgstr "ÐÑÑ
-#: ../gui/wxpython/gui_modules/gdialogs.py:820
+#: ../gui/wxpython/gui_modules/gdialogs.py:861
msgid "Choose directory:"
msgstr "ÐÑбеÑиÑе папкÑ:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:823
+#: ../gui/wxpython/gui_modules/gdialogs.py:864
msgid "Choose input directory"
msgstr "ÐÑбеÑиÑе иÑÑ
однÑÑ Ð¿Ð°Ð¿ÐºÑ"
-#: ../gui/wxpython/gui_modules/gdialogs.py:827
+#: ../gui/wxpython/gui_modules/gdialogs.py:868
msgid "Select file extension:"
msgstr "ÐÑбеÑиÑе ÑаÑÑиÑение Ñайла:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:844
+#: ../gui/wxpython/gui_modules/gdialogs.py:885
+#: ../gui/wxpython/gui_modules/ogc_services.py:69
msgid "Add imported layers into layer tree"
msgstr "ÐобавиÑÑ Ð¸Ð¼Ð¿Ð¾ÑÑиÑованнÑе Ñлои в ÑодеÑжание"
-#: ../gui/wxpython/gui_modules/gdialogs.py:852
+#: ../gui/wxpython/gui_modules/gdialogs.py:893
+#: ../gui/wxpython/gui_modules/ogc_services.py:77
msgid "Close dialog"
msgstr "ÐакÑÑÑÑ Ð´Ð¸Ð°Ð»Ð¾Ð³"
-#: ../gui/wxpython/gui_modules/gdialogs.py:855
+#: ../gui/wxpython/gui_modules/gdialogs.py:896
+#: ../gui/wxpython/gui_modules/ogc_services.py:85
msgid "&Import"
msgstr "&ÐмпоÑÑ"
-#: ../gui/wxpython/gui_modules/gdialogs.py:856
+#: ../gui/wxpython/gui_modules/gdialogs.py:897
+#: ../gui/wxpython/gui_modules/ogc_services.py:86
msgid "Import selected layers"
msgstr "ÐмпоÑÑиÑоваÑÑ Ð²ÑбÑаннÑе Ñлои"
-#: ../gui/wxpython/gui_modules/gdialogs.py:896
-#, python-format
-msgid " List of %s layers "
-msgstr "СпиÑок Ñлоев %s"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1055
-#: ../gui/wxpython/gui_modules/dbm.py:2090
-#: ../gui/wxpython/gui_modules/dbm.py:2195
-#: ../gui/wxpython/gui_modules/dbm.py:2453
-#: ../gui/wxpython/gui_modules/dbm.py:3263
-#: ../gui/wxpython/gui_modules/vdigit.py:1384
-#: ../gui/wxpython/gui_modules/vdigit.py:1386
-#: ../gui/wxpython/gui_modules/vdigit.py:1767
-#: ../gui/wxpython/gui_modules/vdigit.py:2199
+#: ../gui/wxpython/gui_modules/gdialogs.py:1093
+#: ../gui/wxpython/gui_modules/dbm.py:2099
+#: ../gui/wxpython/gui_modules/dbm.py:2204
+#: ../gui/wxpython/gui_modules/dbm.py:2459
+#: ../gui/wxpython/gui_modules/vdigit.py:1409
+#: ../gui/wxpython/gui_modules/vdigit.py:1411
+#: ../gui/wxpython/gui_modules/vdigit.py:1818
+#: ../gui/wxpython/gui_modules/vdigit.py:2250
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:424
msgid "Layer"
msgstr "Слой"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1056
+#: ../gui/wxpython/gui_modules/gdialogs.py:1094
msgid "Layer name"
msgstr "ÐÐ¼Ñ ÑлоÑ"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1057
-msgid "Output vector map name"
-msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного векÑоÑного ÑлоÑ"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1095
+#, fuzzy
+msgid "Name for GRASS map"
+msgstr "ÐÐ¼Ñ Ð´Ð»Ñ Ð½Ð¾Ð²Ð¾Ð³Ð¾ векÑоÑного ÑлоÑ"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1139
+#: ../gui/wxpython/gui_modules/gdialogs.py:1177
msgid "Set Map Layer Opacity"
msgstr "УÑÑановиÑÑ Ð½ÐµÐ¿ÑозÑаÑноÑÑÑ ÑлоÑ"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1163
+#: ../gui/wxpython/gui_modules/gdialogs.py:1201
msgid "transparent"
msgstr "пÑозÑаÑнÑй"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1166
+#: ../gui/wxpython/gui_modules/gdialogs.py:1204
msgid "opaque"
msgstr "непÑозÑаÑнÑй"
@@ -1538,23 +1622,23 @@
msgid "overwrite existing file"
msgstr "пеÑезапиÑаÑÑ ÑÑÑеÑÑвÑÑÑий Ñайл"
-#: ../gui/wxpython/gui_modules/mapdisp.py:89
+#: ../gui/wxpython/gui_modules/mapdisp.py:90
msgid "GRASS GIS - Map display"
msgstr "GRASS GIS - Ðкно ÑлоÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:163
+#: ../gui/wxpython/gui_modules/mapdisp.py:164
msgid "Render"
msgstr "ÐÑÑиÑоваÑÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:166
+#: ../gui/wxpython/gui_modules/mapdisp.py:167
msgid "Enable/disable auto-rendering"
msgstr "ÐклÑÑиÑÑ/вÑклÑÑиÑÑ Ð°Ð²Ñо-пеÑеÑиÑовкÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:169
+#: ../gui/wxpython/gui_modules/mapdisp.py:170
msgid "Show computational extent"
msgstr "ÐоказаÑÑ ÑаÑÑеÑнÑй оÑ
ваÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:174
+#: ../gui/wxpython/gui_modules/mapdisp.py:175
msgid ""
"Show/hide computational region extent (set with g.region). Display region "
"drawn as a blue box inside the computational region, computational region "
@@ -1564,12 +1648,12 @@
"region). ÐоказаÑÑ Ñегион внÑÑÑи ÑаÑÑеÑного Ñегиона Ñиним пÑÑмоÑголÑником, "
"ÑаÑÑеÑнÑй Ñегион внÑÑÑи ÑекÑÑего Ñегиона кÑаÑнÑм пÑÑмоÑголÑником."
-#: ../gui/wxpython/gui_modules/mapdisp.py:182
-#: ../gui/wxpython/gui_modules/preferences.py:1055
+#: ../gui/wxpython/gui_modules/mapdisp.py:183
+#: ../gui/wxpython/gui_modules/preferences.py:1088
msgid "Constrain display resolution to computational settings"
msgstr "ÐÑивеÑÑи ÑазÑеÑение диÑÐ¿Ð»ÐµÑ Ðº наÑÑÑойкам ÑаÑÑеÑа"
-#: ../gui/wxpython/gui_modules/mapdisp.py:186
+#: ../gui/wxpython/gui_modules/mapdisp.py:187
msgid ""
"Constrain display resolution to computational region settings. Default value "
"for new map displays can be set up in 'User GUI settings' dialog."
@@ -1578,23 +1662,48 @@
"ÑмолÑÐ°Ð½Ð¸Ñ Ð´Ð»Ñ Ð½Ð¾Ð²ÑÑ
диÑплеев Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ ÑÑÑановлено Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ "
"'ÐолÑзоваÑелÑÑкиÑ
наÑÑÑоек инÑеÑÑейÑа'."
-#: ../gui/wxpython/gui_modules/mapdisp.py:280
+#: ../gui/wxpython/gui_modules/mapdisp.py:290
msgid "Map Toolbar"
msgstr "ÐÐ°Ð½ÐµÐ»Ñ Ð¸Ð½ÑÑÑÑменÑов каÑÑÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:294
+#: ../gui/wxpython/gui_modules/mapdisp.py:302
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:504
+msgid ""
+"Unable to start vector digitizer.\n"
+"The VDigit python extension was not found or loaded properly.\n"
+"Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
+msgstr ""
+"Ðевозможно запÑÑÑиÑÑ Nviz. Ðе Ð½Ð°Ð¹Ð´ÐµÐ½Ñ Ð¸Ð»Ð¸ бÑли непÑавилÑно загÑÑÐ¶ÐµÐ½Ñ "
+"ÑаÑÑиÑÐµÐ½Ð¸Ñ Python Ð´Ð»Ñ Nviz. ÐозвÑаÑение к 2D ÑежимÑ.\n"
+"\n"
+"ÐодÑобноÑÑи: %s"
+#: ../gui/wxpython/gui_modules/mapdisp.py:306
+#: ../gui/wxpython/gui_modules/mapdisp.py:364
+#: ../gui/wxpython/gui_modules/mapdisp.py:476
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:508
+#: ../gui/wxpython/gui_modules/toolbars.py:163
+#: ../gui/wxpython/gui_modules/toolbars.py:164
+msgid "2D view"
+msgstr "2D вид"
+#: ../gui/wxpython/gui_modules/mapdisp.py:324
msgid "Vector digitizer toolbar"
msgstr "ÐÐ°Ð½ÐµÐ»Ñ Ð¸Ð½ÑÑÑÑменÑов векÑоÑизаÑии"
-#: ../gui/wxpython/gui_modules/mapdisp.py:311
+#: ../gui/wxpython/gui_modules/mapdisp.py:342
msgid "Georectification toolbar"
msgstr "ÐÐ°Ð½ÐµÐ»Ñ Ð¸Ð½ÑÑÑÑменÑов пÑивÑзки"
-#: ../gui/wxpython/gui_modules/mapdisp.py:323
-#, python-format
+#: ../gui/wxpython/gui_modules/mapdisp.py:354
msgid ""
-"Unable to start Nviz. The GLCanvas class has not been included with this "
-"build of wxPython! Switching back to 2D display mode.\n"
+"Unable to switch to 3D display mode.\n"
+"The GLCanvas class has not been included with this build of wxPython!\n"
"\n"
"Details: %s"
msgstr ""
@@ -1603,82 +1712,77 @@
"\n"
"ÐодÑобноÑÑи: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:328
-#, python-format
+#: ../gui/wxpython/gui_modules/mapdisp.py:359
msgid ""
-"Unable to start Nviz. The OpenGL package was not found. You can get it at "
-"http://PyOpenGL.sourceforge.net. Switching back to 2D display mode.\n"
+"The Nviz python extension was not found or loaded properly.\n"
"\n"
"Details: %s"
msgstr ""
-"Ðевозможно запÑÑÑиÑÑ Nviz. Ðе найден Ð¿Ð°ÐºÐµÑ OpenGL. ÐÑ Ð¼Ð¾Ð¶ÐµÑе его загÑÑзиÑÑ "
-"по адÑеÑÑ: http://PyOpenGL.sourceforge.net. ÐозвÑаÑение к 2D ÑежимÑ.\n"
-"\n"
-"ÐодÑобноÑÑи: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:333
-#, python-format
-msgid ""
-"Unable to start Nviz. Python extension for Nviz was not found or loaded "
-"properly. Switching back to 2D display mode.\n"
-"\n"
-"Details: %s"
-msgstr ""
"\n"
"ÐодÑобноÑÑи: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:364
+#: ../gui/wxpython/gui_modules/mapdisp.py:393
msgid "Please wait, loading data..."
msgstr "ÐдиÑе, загÑÑжаÑÑÑÑ Ð´Ð°Ð½Ð½Ñе..."
-#: ../gui/wxpython/gui_modules/mapdisp.py:394
+#: ../gui/wxpython/gui_modules/mapdisp.py:422
msgid "Nviz toolbar"
msgstr "ÐÐ°Ð½ÐµÐ»Ñ Ð¸Ð½ÑÑÑÑменÑов Nviz"
-#: ../gui/wxpython/gui_modules/mapdisp.py:445
-#: ../gui/wxpython/gui_modules/toolbars.py:153
-#: ../gui/wxpython/gui_modules/toolbars.py:154
-msgid "2D view"
+#: ../gui/wxpython/gui_modules/mapdisp.py:967
+msgid "Choose a file name to save the image (no need to add extension)"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:904
+#: ../gui/wxpython/gui_modules/mapdisp.py:1012
msgid "Page setup"
msgstr "ÐаÑамеÑÑÑ ÑÑÑаниÑÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:908
+#: ../gui/wxpython/gui_modules/mapdisp.py:1016
msgid "Print preview"
msgstr "ÐÑедваÑиÑелÑнÑй пÑоÑмоÑÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1004
+#: ../gui/wxpython/gui_modules/mapdisp.py:1110
msgid "No map layer selected for querying."
msgstr "Слои Ð´Ð»Ñ Ð²ÑбоÑки не вÑбÑанÑ."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1005
-#: ../gui/wxpython/gui_modules/mapdisp.py:1089
-#: ../gui/wxpython/gui_modules/dbm.py:1894
-#: ../gui/wxpython/gui_modules/dbm.py:1914
-#: ../gui/wxpython/gui_modules/dbm.py:2914 ../gui/wxpython/wxgui.py:1113
-#: ../gui/wxpython/wxgui.py:1468
+#: ../gui/wxpython/gui_modules/mapdisp.py:1111
+#: ../gui/wxpython/gui_modules/dbm.py:1903
+#: ../gui/wxpython/gui_modules/dbm.py:1923
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:81 ../gui/wxpython/wxgui.py:1198
+#: ../gui/wxpython/wxgui.py:1591
msgid "Message"
msgstr "СообÑение"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1088
+#: ../gui/wxpython/gui_modules/mapdisp.py:1193
msgid "No vector map selected for querying."
msgstr "ÐекÑоÑнÑе Ñлои Ð´Ð»Ñ Ð²ÑбоÑки не вÑбÑанÑ."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1155
+#: ../gui/wxpython/gui_modules/mapdisp.py:1194
+#: ../gui/wxpython/gui_modules/mapdisp.py:1202
+#, fuzzy
+msgid "Vector querying"
+msgstr "ÐаÑÑÑойки векÑоÑа"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1201
+msgid "Only vector map from the current mapset can be modified."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1271
msgid "Query raster/vector map(s) (display mode)"
msgstr ""
"ÐапÑÐ¾Ñ Ðº вÑбÑÐ°Ð½Ð½Ð¾Ð¼Ñ ÑаÑÑÑÐ¾Ð²Ð¾Ð¼Ñ Ð¸Ð»Ð¸ векÑоÑÐ½Ð¾Ð¼Ñ ÑÐ»Ð¾Ñ (ÑлоÑм) в Ñежиме "
"оÑобÑажениÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1163
+#: ../gui/wxpython/gui_modules/mapdisp.py:1279
msgid "Query vector map (edit mode)"
msgstr "ÐапÑÐ¾Ñ Ðº векÑоÑÐ½Ð¾Ð¼Ñ ÑÐ»Ð¾Ñ (в Ñежиме ÑедакÑиÑованиÑ)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1277
+#: ../gui/wxpython/gui_modules/mapdisp.py:1394
#, python-format
msgid ""
"Click and drag with left mouse button to measure.%sDouble click with left "
@@ -1687,66 +1791,72 @@
"ЩелкниÑе и пеÑеÑаÑиÑе левой кнопкой мÑÑи Ð´Ð»Ñ Ð¸Ð·Ð¼ÐµÑениÑ. %sЩелкниÑе Ð´Ð²Ð°Ð¶Ð´Ñ "
"левой кнопкой, ÑÑÐ¾Ð±Ñ Ð¾ÑиÑÑиÑÑ."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1284
+#: ../gui/wxpython/gui_modules/mapdisp.py:1401
msgid "Measuring distance"
msgstr "ÐзмеÑиÑÑ ÑаÑÑÑоÑние"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1288
+#: ../gui/wxpython/gui_modules/mapdisp.py:1405
msgid "Measuring distance:"
msgstr "ÐзмеÑиÑÑ ÑаÑÑÑоÑние:"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1449
+#: ../gui/wxpython/gui_modules/mapdisp.py:1567
msgid "Scale and North arrow"
msgstr "ÐаÑÑÑаб и ÑÑÑелка на ÑевеÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1455
+#: ../gui/wxpython/gui_modules/mapdisp.py:1573
msgid "Show/hide scale and North arrow"
msgstr "ÐоказаÑÑ/ÑбÑаÑÑ Ð¼Ð°ÑÑÑаб и ÑÑÑÐµÐ»ÐºÑ Ð½Ð° ÑевеÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1456
+#: ../gui/wxpython/gui_modules/mapdisp.py:1574
msgid "scale object"
msgstr "обÑÐµÐºÑ Ð¼Ð°ÑÑÑаба"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1486
+#: ../gui/wxpython/gui_modules/mapdisp.py:1604
msgid "Show/hide legend"
msgstr "ÐоказаÑÑ/ÑбÑаÑÑ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1487
+#: ../gui/wxpython/gui_modules/mapdisp.py:1605
msgid "legend object"
msgstr "обÑÐµÐºÑ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1559
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:268
-msgid "Zoom to selected map"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1677
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:272
+#, fuzzy
+msgid "Zoom to selected map(s)"
msgstr "ÐаÑÑÑабиÑоваÑÑ Ð´Ð¾ вÑбÑанного ÑлоÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1563
+#: ../gui/wxpython/gui_modules/mapdisp.py:1681
msgid "Zoom to computational region (set with g.region)"
msgstr ""
"ÐаÑÑÑабиÑоваÑÑ Ð´Ð¾ ÑаÑÑеÑного Ñегиона (ÑÑÑанавливаеÑÑÑ Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ g.region)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1567
+#: ../gui/wxpython/gui_modules/mapdisp.py:1685
msgid "Zoom to default region"
msgstr "ÐаÑÑÑабиÑоваÑÑ Ð´Ð¾ Ñегиона по ÑмолÑаниÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1571
+#: ../gui/wxpython/gui_modules/mapdisp.py:1689
msgid "Zoom to saved region"
msgstr "ÐаÑÑÑабиÑоваÑÑ Ð´Ð¾ ÑоÑ
Ñаненного Ñегиона"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1575
+#: ../gui/wxpython/gui_modules/mapdisp.py:1693
msgid "Set computational region from display"
msgstr "УÑÑановиÑÑ ÑаÑÑеÑнÑй Ñегион ÑавнÑй диÑплеÑ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1579
+#: ../gui/wxpython/gui_modules/mapdisp.py:1697
msgid "Save display geometry to named region"
msgstr "СоÑ
ÑаниÑÑ Ð³ÐµÐ¾Ð¼ÐµÑÑÐ¸Ñ Ð´Ð¸ÑÐ¿Ð»ÐµÑ Ð² Ñегион Ñ Ð½Ð°Ð·Ð²Ð°Ð½Ð¸ÐµÐ¼"
-#: ../gui/wxpython/gui_modules/workspace.py:616
+#: ../gui/wxpython/gui_modules/mapdisp.py:1794
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:111
+msgid "GRASS GIS Map Display: "
+msgstr "GRASS GIS диÑплей ÑлоÑ: "
+#: ../gui/wxpython/gui_modules/workspace.py:630
#, python-format
msgid "Unable to open file <%s> for reading."
msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл <%s> Ð´Ð»Ñ ÑÑениÑ."
-#: ../gui/wxpython/gui_modules/workspace.py:629
+#: ../gui/wxpython/gui_modules/workspace.py:643
#, python-format
msgid ""
"Some lines were skipped when reading settings from file <%(file)s>.\n"
@@ -1759,283 +1869,288 @@
"\n"
"ÐолиÑеÑÑво пÑопÑÑеннÑÑ
ÑÑÑок: %(line)d"
-#: ../gui/wxpython/gui_modules/workspace.py:633
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:2388
+#: ../gui/wxpython/gui_modules/workspace.py:647
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:2561
msgid "Warning"
msgstr "ÐÑедÑпÑеждение"
-#: ../gui/wxpython/gui_modules/workspace.py:787
+#: ../gui/wxpython/gui_modules/workspace.py:861
#, python-format
msgid " row %d:"
msgstr " ÑÑÑока %d:"
-#: ../gui/wxpython/gui_modules/profile.py:65
+#: ../gui/wxpython/gui_modules/profile.py:66
msgid "Profile Analysis"
msgstr "ÐÑоÑилÑнÑй анализ"
-#: ../gui/wxpython/gui_modules/profile.py:153
-#: ../gui/wxpython/gui_modules/profile.py:272
+#: ../gui/wxpython/gui_modules/profile.py:156
+#: ../gui/wxpython/gui_modules/profile.py:275
msgid "Profile of"
msgstr "ÐÑоÑилÑ"
-#: ../gui/wxpython/gui_modules/profile.py:157
+#: ../gui/wxpython/gui_modules/profile.py:160
#, python-format
msgid "Distance (%s)"
msgstr "РаÑÑÑоÑние (%s)"
-#: ../gui/wxpython/gui_modules/profile.py:159
+#: ../gui/wxpython/gui_modules/profile.py:162
msgid "Distance along transect"
msgstr "РаÑÑÑоÑние Ð²Ð´Ð¾Ð»Ñ ÑÑанÑекÑÑ"
-#: ../gui/wxpython/gui_modules/profile.py:160
+#: ../gui/wxpython/gui_modules/profile.py:163
msgid "Cell values"
msgstr "ÐнаÑÐµÐ½Ð¸Ñ ÑÑеек"
-#: ../gui/wxpython/gui_modules/profile.py:282
+#: ../gui/wxpython/gui_modules/profile.py:320
#, python-format
msgid "Profile of %s"
msgstr "ÐÑоÑÐ¸Ð»Ñ %s"
-#: ../gui/wxpython/gui_modules/profile.py:312
+#: ../gui/wxpython/gui_modules/profile.py:350
msgid "Raster values"
msgstr "ÐнаÑÐµÐ½Ð¸Ñ ÑаÑÑÑа"
-#: ../gui/wxpython/gui_modules/profile.py:447
+#: ../gui/wxpython/gui_modules/profile.py:467
msgid "You must draw a transect to profile in the map display window."
msgstr "ÐеобÑ
одимо наÑиÑоваÑÑ ÑÑанÑекÑÑ Ð´Ð»Ñ Ð¿ÑоÑилиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð² окне ÑлоÑ."
-#: ../gui/wxpython/gui_modules/profile.py:448
+#: ../gui/wxpython/gui_modules/profile.py:468
msgid "Nothing to profile"
msgstr "ÐÐµÑ ÑÐ»Ð¾Ñ Ð´Ð»Ñ Ð¿ÑоÑилиÑованиÑ"
-#: ../gui/wxpython/gui_modules/profile.py:658
+#: ../gui/wxpython/gui_modules/profile.py:678
msgid "Profile text settings"
msgstr "ÐаÑÑÑойки ÑекÑÑа пÑоÑилÑ"
-#: ../gui/wxpython/gui_modules/profile.py:685
+#: ../gui/wxpython/gui_modules/profile.py:705
msgid "Profile settings"
msgstr "ÐаÑÑÑойки пÑоÑилÑ"
-#: ../gui/wxpython/gui_modules/profile.py:748
+#: ../gui/wxpython/gui_modules/profile.py:768
msgid "Select raster map to profile"
msgstr "ÐÑбÑаÑÑ ÑаÑÑÑовÑй Ñлой Ð´Ð»Ñ Ð¿ÑоÑилиÑованиÑ"
-#: ../gui/wxpython/gui_modules/profile.py:783
+#: ../gui/wxpython/gui_modules/profile.py:803
msgid "Select raster map 1 (required):"
msgstr "ÐÑбÑаÑÑ ÑаÑÑÑовÑй Ñлой 1 (ÑÑебÑеÑÑÑ):"
-#: ../gui/wxpython/gui_modules/profile.py:784
+#: ../gui/wxpython/gui_modules/profile.py:804
msgid "Select raster map 2 (optional):"
msgstr "ÐÑбÑаÑÑ ÑаÑÑÑовÑй Ñлой 2 (опÑиÑ):"
-#: ../gui/wxpython/gui_modules/profile.py:785
+#: ../gui/wxpython/gui_modules/profile.py:805
msgid "Select raster map 3 (optional):"
msgstr "ÐÑбÑаÑÑ ÑаÑÑÑовÑй Ñлой 3 (опÑиÑ):"
-#: ../gui/wxpython/gui_modules/profile.py:879
+#: ../gui/wxpython/gui_modules/profile.py:899
msgid "Text settings"
msgstr "ÐаÑÑÑойки ÑекÑÑа"
-#: ../gui/wxpython/gui_modules/profile.py:886
+#: ../gui/wxpython/gui_modules/profile.py:906
msgid "Profile title:"
msgstr "Ðаголовок пÑоÑилÑ:"
-#: ../gui/wxpython/gui_modules/profile.py:896
+#: ../gui/wxpython/gui_modules/profile.py:916
msgid "Title font size (pts):"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ ÑÑиÑÑа Ð½Ð°Ð·Ð²Ð°Ð½Ð¸Ñ (pts):"
-#: ../gui/wxpython/gui_modules/profile.py:917
+#: ../gui/wxpython/gui_modules/profile.py:937
msgid "Y-axis label:"
msgstr "подпиÑÑ Ð¾Ñи Y:"
-#: ../gui/wxpython/gui_modules/profile.py:927
+#: ../gui/wxpython/gui_modules/profile.py:947
msgid "Label font size (pts):"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ ÑÑиÑÑа подпиÑи (pts):"
-#: ../gui/wxpython/gui_modules/profile.py:942
-#: ../gui/wxpython/gui_modules/preferences.py:951
-#: ../gui/wxpython/gui_modules/preferences.py:1595
+#: ../gui/wxpython/gui_modules/profile.py:962
+#: ../gui/wxpython/gui_modules/preferences.py:984
+#: ../gui/wxpython/gui_modules/preferences.py:1638
msgid "Font settings"
msgstr "ÐаÑÑÑойки ÑÑиÑÑа"
-#: ../gui/wxpython/gui_modules/profile.py:950
+#: ../gui/wxpython/gui_modules/profile.py:970
msgid "Font family:"
msgstr "СемейÑÑво ÑÑиÑÑов:"
-#: ../gui/wxpython/gui_modules/profile.py:964
+#: ../gui/wxpython/gui_modules/profile.py:984
msgid "Style:"
msgstr "СÑилÑ:"
-#: ../gui/wxpython/gui_modules/profile.py:978
+#: ../gui/wxpython/gui_modules/profile.py:998
msgid "Weight:"
msgstr "ÐеÑ:"
-#: ../gui/wxpython/gui_modules/profile.py:1060
-#: ../gui/wxpython/gui_modules/profile.py:1405
+#: ../gui/wxpython/gui_modules/profile.py:1080
+#: ../gui/wxpython/gui_modules/profile.py:1425
#, python-format
msgid "Profile settings saved to file '%s'."
msgstr "ÐаÑÑÑойки пÑоÑÐ¸Ð»Ñ ÑоÑ
-#: ../gui/wxpython/gui_modules/profile.py:1116
+#: ../gui/wxpython/gui_modules/profile.py:1136
msgid "Profile line settings"
msgstr "ÐаÑÑÑойки линии пÑоÑилÑ"
-#: ../gui/wxpython/gui_modules/profile.py:1126
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:345
+#: ../gui/wxpython/gui_modules/profile.py:1146
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:358
msgid "Profile"
msgstr "ÐÑоÑилÑ"
-#: ../gui/wxpython/gui_modules/profile.py:1131
+#: ../gui/wxpython/gui_modules/profile.py:1151
msgid "Line color"
msgstr "Ð¦Ð²ÐµÑ Ð»Ð¸Ð½Ð¸Ð¸"
-#: ../gui/wxpython/gui_modules/profile.py:1138
-#: ../gui/wxpython/gui_modules/vdigit.py:1150
+#: ../gui/wxpython/gui_modules/profile.py:1158
+#: ../gui/wxpython/gui_modules/vdigit.py:1175
msgid "Line width"
msgstr "ШиÑина линии"
-#: ../gui/wxpython/gui_modules/profile.py:1148
+#: ../gui/wxpython/gui_modules/profile.py:1168
msgid "Line style"
msgstr "СÑÐ¸Ð»Ñ Ð»Ð¸Ð½Ð¸Ð¸"
-#: ../gui/wxpython/gui_modules/profile.py:1157
-#: ../gui/wxpython/gui_modules/profile.py:1209
+#: ../gui/wxpython/gui_modules/profile.py:1177
+#: ../gui/wxpython/gui_modules/profile.py:1229
msgid "Legend"
msgstr "Ðегенда"
-#: ../gui/wxpython/gui_modules/profile.py:1181
+#: ../gui/wxpython/gui_modules/profile.py:1201
msgid "Transect segment marker settings"
msgstr "ÐаÑÑÑойки маÑкеÑа ÑегменÑа ÑÑанÑекÑÑ"
-#: ../gui/wxpython/gui_modules/profile.py:1186
-#: ../gui/wxpython/gui_modules/nviz_tools.py:250
-#: ../gui/wxpython/gui_modules/nviz_tools.py:849
+#: ../gui/wxpython/gui_modules/profile.py:1206
+#: ../gui/wxpython/gui_modules/nviz_tools.py:256
+#: ../gui/wxpython/gui_modules/nviz_tools.py:854
msgid "Color"
msgstr "ЦвеÑ"
-#: ../gui/wxpython/gui_modules/profile.py:1192
+#: ../gui/wxpython/gui_modules/profile.py:1212
msgid "Size"
msgstr "РазмеÑ"
-#: ../gui/wxpython/gui_modules/profile.py:1201
-#: ../gui/wxpython/gui_modules/profile.py:1247
+#: ../gui/wxpython/gui_modules/profile.py:1221
+#: ../gui/wxpython/gui_modules/profile.py:1267
msgid "Style"
msgstr "СÑилÑ"
-#: ../gui/wxpython/gui_modules/profile.py:1216
+#: ../gui/wxpython/gui_modules/profile.py:1236
msgid "Type"
msgstr "Тип"
-#: ../gui/wxpython/gui_modules/profile.py:1231
+#: ../gui/wxpython/gui_modules/profile.py:1251
msgid "Axis settings"
msgstr "ÐаÑÑÑойки оÑей"
-#: ../gui/wxpython/gui_modules/profile.py:1237
+#: ../gui/wxpython/gui_modules/profile.py:1257
msgid "X-Axis"
msgstr "ÐÑÑ X"
-#: ../gui/wxpython/gui_modules/profile.py:1238
+#: ../gui/wxpython/gui_modules/profile.py:1258
msgid "Y-Axis"
msgstr "ÐÑÑ Y"
-#: ../gui/wxpython/gui_modules/profile.py:1256
+#: ../gui/wxpython/gui_modules/profile.py:1276
msgid "Custom min"
msgstr "ÐаданнÑй минимÑм"
-#: ../gui/wxpython/gui_modules/profile.py:1264
+#: ../gui/wxpython/gui_modules/profile.py:1284
msgid "Custom max"
msgstr "ÐаданнÑй макÑимÑм"
-#: ../gui/wxpython/gui_modules/profile.py:1272
+#: ../gui/wxpython/gui_modules/profile.py:1292
msgid "Log scale"
msgstr "ÐогаÑиÑмиÑеÑÐºÐ°Ñ Ñкала"
-#: ../gui/wxpython/gui_modules/profile.py:1296
+#: ../gui/wxpython/gui_modules/profile.py:1316
msgid "Grid and Legend settings"
msgstr "ÐаÑÑÑойки ÑеÑки и легендÑ"
-#: ../gui/wxpython/gui_modules/profile.py:1301
+#: ../gui/wxpython/gui_modules/profile.py:1321
msgid "Grid color"
msgstr "Ð¦Ð²ÐµÑ ÑеÑки"
-#: ../gui/wxpython/gui_modules/profile.py:1308
+#: ../gui/wxpython/gui_modules/profile.py:1328
msgid "Show grid"
msgstr "ÐоказаÑÑ ÑеÑкÑ"
-#: ../gui/wxpython/gui_modules/profile.py:1314
+#: ../gui/wxpython/gui_modules/profile.py:1334
msgid "Legend font size"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ ÑÑиÑÑа легендÑ"
-#: ../gui/wxpython/gui_modules/profile.py:1324
+#: ../gui/wxpython/gui_modules/profile.py:1344
msgid "Show legend"
msgstr "ÐоказаÑÑ Ð»ÐµÐ³ÐµÐ½Ð´Ñ"
-#: ../gui/wxpython/gui_modules/preferences.py:362
+#: ../gui/wxpython/gui_modules/preferences.py:380
msgid "Segment break"
msgstr "РазоÑваÑÑ ÑегменÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:494
+#: ../gui/wxpython/gui_modules/preferences.py:513
msgid "Collapse all except PERMANENT and current"
msgstr "СвеÑнÑÑÑ Ð²Ñе кÑоме PERMANENT и ÑекÑÑего"
-#: ../gui/wxpython/gui_modules/preferences.py:495
+#: ../gui/wxpython/gui_modules/preferences.py:514
msgid "Collapse all except PERMANENT"
msgstr "СвеÑнÑÑÑ Ð²Ñе кÑоме PERMANENT"
-#: ../gui/wxpython/gui_modules/preferences.py:496
+#: ../gui/wxpython/gui_modules/preferences.py:515
+#, fuzzy
+msgid "Collapse all except current"
+msgstr "СвеÑнÑÑÑ Ð²Ñе кÑоме PERMANENT и ÑекÑÑего"
+#: ../gui/wxpython/gui_modules/preferences.py:516
msgid "Collapse all"
msgstr "СвеÑнÑÑÑ Ð²Ñе"
-#: ../gui/wxpython/gui_modules/preferences.py:497
+#: ../gui/wxpython/gui_modules/preferences.py:517
msgid "Expand all"
msgstr "РазвеÑнÑÑÑ Ð²Ñе"
-#: ../gui/wxpython/gui_modules/preferences.py:498
-#: ../gui/wxpython/gui_modules/dbm.py:968
+#: ../gui/wxpython/gui_modules/preferences.py:518
+#: ../gui/wxpython/gui_modules/dbm.py:993
msgid "Edit selected record"
msgstr "РедакÑиÑоваÑÑ Ð²ÑбÑаннÑÑ Ð·Ð°Ð¿Ð¸ÑÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:499
+#: ../gui/wxpython/gui_modules/preferences.py:519
msgid "Display selected"
msgstr "ÐÑобÑазиÑÑ Ð²ÑбÑаннÑе обÑекÑÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:525
+#: ../gui/wxpython/gui_modules/preferences.py:545
msgid "box"
msgstr "пÑÑмоÑголÑник"
-#: ../gui/wxpython/gui_modules/preferences.py:526
+#: ../gui/wxpython/gui_modules/preferences.py:546
msgid "sphere"
msgstr "ÑÑеÑа"
-#: ../gui/wxpython/gui_modules/preferences.py:527
+#: ../gui/wxpython/gui_modules/preferences.py:547
msgid "cube"
msgstr "кÑб"
-#: ../gui/wxpython/gui_modules/preferences.py:528
+#: ../gui/wxpython/gui_modules/preferences.py:548
msgid "diamond"
msgstr "Ñомб"
-#: ../gui/wxpython/gui_modules/preferences.py:529
+#: ../gui/wxpython/gui_modules/preferences.py:549
msgid "dtree"
msgstr "dtree"
-#: ../gui/wxpython/gui_modules/preferences.py:530
+#: ../gui/wxpython/gui_modules/preferences.py:550
msgid "ctree"
msgstr "ctree"
-#: ../gui/wxpython/gui_modules/preferences.py:531
+#: ../gui/wxpython/gui_modules/preferences.py:551
msgid "aster"
msgstr "aster"
-#: ../gui/wxpython/gui_modules/preferences.py:532
+#: ../gui/wxpython/gui_modules/preferences.py:552
msgid "gyro"
msgstr "gyro"
-#: ../gui/wxpython/gui_modules/preferences.py:533
+#: ../gui/wxpython/gui_modules/preferences.py:553
msgid "histogram"
msgstr "гиÑÑогÑамма"
-#: ../gui/wxpython/gui_modules/preferences.py:601
+#: ../gui/wxpython/gui_modules/preferences.py:621
#, python-format
msgid ""
"Error: Reading settings from file <%(file)s> failed.\n"
@@ -2046,11 +2161,11 @@
" ÐодÑобноÑÑи: %(detail)s\n"
" СÑÑоки: '%(line)s'"
-#: ../gui/wxpython/gui_modules/preferences.py:633
+#: ../gui/wxpython/gui_modules/preferences.py:653
msgid "Uknown settings file location."
msgstr "Ðевозможно найÑи Ñайл наÑÑÑоек."
-#: ../gui/wxpython/gui_modules/preferences.py:664
+#: ../gui/wxpython/gui_modules/preferences.py:684
#, python-format
msgid ""
"Writing settings to file <%(file)s> failed.\n"
@@ -2061,41 +2176,41 @@
"\n"
"ÐодÑобноÑÑи: %(detail)s"
-#: ../gui/wxpython/gui_modules/preferences.py:763
+#: ../gui/wxpython/gui_modules/preferences.py:786
msgid "Unable to set "
msgstr "Ðевозможно ÑÑÑановиÑÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:798
+#: ../gui/wxpython/gui_modules/preferences.py:821
msgid "User GUI settings"
msgstr "ÐолÑзоваÑелÑÑкие наÑÑÑойки инÑеÑÑейÑа"
-#: ../gui/wxpython/gui_modules/preferences.py:822
+#: ../gui/wxpython/gui_modules/preferences.py:845
msgid "Set to default"
msgstr "УÑÑановиÑÑ Ð¿Ð¾ ÑмолÑаниÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:830
+#: ../gui/wxpython/gui_modules/preferences.py:853
msgid "Revert settings to default and apply changes"
msgstr "ÐозвÑаÑиÑÑ Ð½Ð°ÑÑÑойки по ÑмолÑÐ°Ð½Ð¸Ñ Ð¸ пÑимениÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ"
-#: ../gui/wxpython/gui_modules/preferences.py:865
-#: ../gui/wxpython/gui_modules/vdigit.py:1138
-#: ../gui/wxpython/gui_modules/nviz_tools.py:956
+#: ../gui/wxpython/gui_modules/preferences.py:888
+#: ../gui/wxpython/gui_modules/vdigit.py:1163
+#: ../gui/wxpython/gui_modules/nviz_tools.py:961
msgid "General"
msgstr "ÐбÑие"
-#: ../gui/wxpython/gui_modules/preferences.py:868
+#: ../gui/wxpython/gui_modules/preferences.py:891
msgid "General settings"
msgstr "ÐбÑие наÑÑÑойки"
-#: ../gui/wxpython/gui_modules/preferences.py:879
+#: ../gui/wxpython/gui_modules/preferences.py:902
msgid "Element list:"
msgstr "СпиÑок ÑлеменÑов:"
-#: ../gui/wxpython/gui_modules/preferences.py:901
+#: ../gui/wxpython/gui_modules/preferences.py:924
msgid "Save current window layout as default"
msgstr "СоÑ
ÑаниÑÑ ÑекÑÑий Ð¼Ð°ÐºÐµÑ Ð¾ÐºÐ½Ð° как Ð¼Ð°ÐºÐµÑ Ð¿Ð¾ ÑмолÑаниÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:904
+#: ../gui/wxpython/gui_modules/preferences.py:927
msgid ""
"Save current position and size of Layer Manager window and opened Map "
"Display window(s) and use as default for next sessions."
@@ -2103,177 +2218,188 @@
"СоÑ
ÑаниÑÑ ÑекÑÑÑÑ Ð¿Ð¾Ð·Ð¸ÑÐ¸Ñ Ð¸ ÑÐ°Ð·Ð¼ÐµÑ ÐенеджеÑа Ñлоев, оÑкÑÑÑÑ Ð¾ÐºÐ½Ð¾(окна) "
"диÑÐ¿Ð»ÐµÑ Ð¸ иÑполÑзоваÑÑ Ð¿Ð¾ ÑмолÑÐ°Ð½Ð¸Ñ Ð´Ð»Ñ ÑледÑÑÑиÑ
ÑеÑÑий."
-#: ../gui/wxpython/gui_modules/preferences.py:917
+#: ../gui/wxpython/gui_modules/preferences.py:940
msgid "Layer Manager settings"
msgstr "ÐаÑÑÑойки ÐенеджеÑа Ñлоев"
-#: ../gui/wxpython/gui_modules/preferences.py:929
+#: ../gui/wxpython/gui_modules/preferences.py:952
msgid "Ask when removing map layer from layer tree"
msgstr "СпÑаÑиваÑÑ ÐºÐ¾Ð³Ð´Ð° Ñлой ÑдалÑеÑÑÑ Ð¸Ð· ÑодеÑжаниÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:947
-#: ../gui/wxpython/gui_modules/vdigit.py:1145
+#: ../gui/wxpython/gui_modules/preferences.py:962
+msgid "Ask when quiting wxGUI or closing display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:980
+#: ../gui/wxpython/gui_modules/vdigit.py:1170
msgid "Display"
msgstr "ÐиÑплей"
-#: ../gui/wxpython/gui_modules/preferences.py:962
+#: ../gui/wxpython/gui_modules/preferences.py:995
msgid "Default font for GRASS displays:"
msgstr "ШÑиÑÑ Ð¿Ð¾ ÑмолÑÐ°Ð½Ð¸Ñ Ð´Ð»Ñ Ð´Ð¸Ñплеев GRASS:"
-#: ../gui/wxpython/gui_modules/preferences.py:976
+#: ../gui/wxpython/gui_modules/preferences.py:1009
msgid "Default display settings"
msgstr "ÐаÑÑÑойки диÑÐ¿Ð»ÐµÑ Ð¿Ð¾ ÑмолÑаниÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:987
+#: ../gui/wxpython/gui_modules/preferences.py:1020
msgid "Display driver:"
msgstr "ÐÑÐ°Ð¹Ð²ÐµÑ Ð´Ð¸ÑплеÑ:"
-#: ../gui/wxpython/gui_modules/preferences.py:1016
+#: ../gui/wxpython/gui_modules/preferences.py:1049
msgid "Statusbar mode:"
msgstr "Режим ÑÑÑоки ÑÑаÑÑÑа:"
-#: ../gui/wxpython/gui_modules/preferences.py:1036
-#: ../gui/wxpython/gui_modules/nviz_tools.py:962
+#: ../gui/wxpython/gui_modules/preferences.py:1069
+#: ../gui/wxpython/gui_modules/nviz_tools.py:967
msgid "Background color:"
msgstr "Ð¦Ð²ÐµÑ Ñона:"
-#: ../gui/wxpython/gui_modules/preferences.py:1068
+#: ../gui/wxpython/gui_modules/preferences.py:1101
msgid "Enable auto-rendering"
msgstr "ÐклÑÑиÑÑ Ð°Ð²Ñо-оÑÑиÑовкÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:1089
+#: ../gui/wxpython/gui_modules/preferences.py:1114
+#, fuzzy
+msgid "Enable auto-zooming to selected map layer"
+msgstr "Ðевозможно маÑÑÑабиÑоваÑÑ ÑаÑÑÑовÑй Ñлой <%s>."
+#: ../gui/wxpython/gui_modules/preferences.py:1135
msgid "Command"
msgstr "Ðоманда"
-#: ../gui/wxpython/gui_modules/preferences.py:1092
+#: ../gui/wxpython/gui_modules/preferences.py:1138
msgid "Command dialog settings"
msgstr "ÐаÑÑÑойки диалога командÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:1104
+#: ../gui/wxpython/gui_modules/preferences.py:1150
msgid "Allow output files to overwrite existing files"
msgstr "РазÑеÑиÑÑ Ð¿ÐµÑезапиÑÑваÑÑ ÑÐ°Ð¹Ð»Ñ Ð¿Ð¾Ð²ÐµÑÑ
Ñже ÑозданнÑÑ
-#: ../gui/wxpython/gui_modules/preferences.py:1134
+#: ../gui/wxpython/gui_modules/preferences.py:1180
msgid "Verbosity level:"
msgstr "УÑÐ¾Ð²ÐµÐ½Ñ Ð¸Ð·Ð±ÑÑоÑноÑÑи инÑоÑмаÑии:"
-#: ../gui/wxpython/gui_modules/preferences.py:1153
+#: ../gui/wxpython/gui_modules/preferences.py:1199
msgid "Raster settings"
msgstr "ÐаÑÑÑойки ÑаÑÑÑа"
-#: ../gui/wxpython/gui_modules/preferences.py:1164
+#: ../gui/wxpython/gui_modules/preferences.py:1210
msgid "Overlay raster maps"
msgstr "ÐаложиÑÑ ÑаÑÑÑовÑе Ñлои"
-#: ../gui/wxpython/gui_modules/preferences.py:1178
+#: ../gui/wxpython/gui_modules/preferences.py:1224
msgid "Vector settings"
-#: ../gui/wxpython/gui_modules/preferences.py:1184
-#: ../gui/wxpython/gui_modules/nviz_tools.py:569
+#: ../gui/wxpython/gui_modules/preferences.py:1230
+#: ../gui/wxpython/gui_modules/nviz_tools.py:574
msgid "Display:"
msgstr "ÐиÑплей:"
-#: ../gui/wxpython/gui_modules/preferences.py:1206
-#: ../gui/wxpython/gui_modules/vdigit.py:1366
+#: ../gui/wxpython/gui_modules/preferences.py:1252
+#: ../gui/wxpython/gui_modules/vdigit.py:1391
msgid "Attributes"
msgstr "ÐÑÑибÑÑÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:1214
+#: ../gui/wxpython/gui_modules/preferences.py:1260
msgid "Highlighting"
msgstr "ÐодÑвеÑка"
-#: ../gui/wxpython/gui_modules/preferences.py:1230
-msgid "Line width (in pixels)"
+#: ../gui/wxpython/gui_modules/preferences.py:1276
+#, fuzzy
+msgid "Line width (in pixels):"
msgstr "ШиÑина линии (в пикÑелÑÑ
-#: ../gui/wxpython/gui_modules/preferences.py:1253
+#: ../gui/wxpython/gui_modules/preferences.py:1299
msgid "Data browser"
msgstr "ÐÑоÑмоÑÑ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/wxpython/gui_modules/preferences.py:1258
-msgid "Left mouse double click"
+#: ../gui/wxpython/gui_modules/preferences.py:1304
+#, fuzzy
+msgid "Left mouse double click:"
msgstr "Ðвойной ÑелÑок левой кнопкой мÑÑи"
-#: ../gui/wxpython/gui_modules/preferences.py:1269
-msgid "Encoding"
+#: ../gui/wxpython/gui_modules/preferences.py:1316
+msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1280
+#: ../gui/wxpython/gui_modules/preferences.py:1327
msgid "Ask when deleting data record(s) from table"
msgstr "СпÑаÑиваÑÑ Ð¿ÐµÑед Ñдалением запиÑей из ÑаблиÑÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:1301
+#: ../gui/wxpython/gui_modules/preferences.py:1348
msgid "Create table"
msgstr "СоздаÑÑ ÑаблиÑÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:1308
-#: ../gui/wxpython/gui_modules/dbm.py:2217
-#: ../gui/wxpython/gui_modules/dbm.py:2249
-#: ../gui/wxpython/gui_modules/dbm.py:2479
-msgid "Key column"
+#: ../gui/wxpython/gui_modules/preferences.py:1355
+#, fuzzy
+msgid "Key column:"
msgstr "ÐлÑÑевое поле"
-#: ../gui/wxpython/gui_modules/preferences.py:1334
+#: ../gui/wxpython/gui_modules/preferences.py:1381
#: ../gui/wxpython/menustrings.py:3
msgid "Workspace"
msgstr "ÐÑоекÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:1337
+#: ../gui/wxpython/gui_modules/preferences.py:1384
msgid "Loading workspace"
msgstr "ÐагÑÑзка пÑоекÑа"
-#: ../gui/wxpython/gui_modules/preferences.py:1349
+#: ../gui/wxpython/gui_modules/preferences.py:1396
msgid "Suppress positioning Map Display Window(s)"
msgstr "ÐодавиÑÑ Ð¿Ð¾Ð·Ð¸ÑиониÑование окон диÑплеев"
-#: ../gui/wxpython/gui_modules/preferences.py:1360
+#: ../gui/wxpython/gui_modules/preferences.py:1407
msgid "Suppress positioning Layer Manager window"
msgstr "ÐодавиÑÑ Ð¿Ð¾Ð·Ð¸ÑиониÑование окна ÐенеджеÑа Ñлоев"
-#: ../gui/wxpython/gui_modules/preferences.py:1378
-#: ../gui/wxpython/gui_modules/dbm.py:597
+#: ../gui/wxpython/gui_modules/preferences.py:1425
+#: ../gui/wxpython/gui_modules/dbm.py:616
msgid "Advanced"
msgstr "РаÑÑиÑеннÑе"
-#: ../gui/wxpython/gui_modules/preferences.py:1381
+#: ../gui/wxpython/gui_modules/preferences.py:1428
msgid "Advanced settings"
msgstr "РаÑÑиÑеннÑе наÑÑÑойки"
-#: ../gui/wxpython/gui_modules/preferences.py:1393
+#: ../gui/wxpython/gui_modules/preferences.py:1440
msgid "Place where to store settings:"
msgstr "ÐеÑÑоположение Ñ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ Ð½Ð°ÑÑÑоек:"
-#: ../gui/wxpython/gui_modules/preferences.py:1414
+#: ../gui/wxpython/gui_modules/preferences.py:1461
msgid "Icon theme:"
msgstr "Тема иконок:"
-#: ../gui/wxpython/gui_modules/preferences.py:1431
-msgid "Note: Requires GUI restart."
-msgstr "ÐÑимеÑание: ÐÑжен пеÑезапÑÑк инÑеÑÑейÑа."
+#: ../gui/wxpython/gui_modules/preferences.py:1479
+msgid ""
+"Note: For changing the icon theme, you must save the settings and restart "
+"this GUI."
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1451
+#: ../gui/wxpython/gui_modules/preferences.py:1494
msgid "Select default display font"
msgstr "ÐÑбÑаÑÑ ÑÑиÑÑ Ð´Ð¸ÑÐ¿Ð»ÐµÑ Ð¿Ð¾ ÑмолÑаниÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:1475
+#: ../gui/wxpython/gui_modules/preferences.py:1518
#, python-format
msgid "Settings saved to file '%s'."
msgstr "ÐаÑÑÑойки ÑоÑ
-#: ../gui/wxpython/gui_modules/preferences.py:1535
+#: ../gui/wxpython/gui_modules/preferences.py:1578
msgid "Key column cannot be empty string."
msgstr "ÐлÑÑевое поле не Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð¿ÑÑÑой ÑÑÑокой."
-#: ../gui/wxpython/gui_modules/preferences.py:1602
+#: ../gui/wxpython/gui_modules/preferences.py:1645
msgid "Select font:"
msgstr "ÐÑбÑаÑÑ ÑÑиÑÑ:"
-#: ../gui/wxpython/gui_modules/preferences.py:1706
+#: ../gui/wxpython/gui_modules/preferences.py:1749
msgid "Set/unset access to mapsets in current location"
msgstr "УÑÑановиÑÑ/ÑнÑÑÑ Ð´Ð¾ÑÑÑп к набоÑам ÑекÑÑей облаÑÑи"
-#: ../gui/wxpython/gui_modules/preferences.py:1720
+#: ../gui/wxpython/gui_modules/preferences.py:1763
#, python-format
msgid ""
"Check mapset to make it accessible, uncheck it to hide it.%sNote: PERMANENT "
@@ -2282,41 +2408,51 @@
"ÐклÑÑиÑÑ Ð´Ð¾ÑÑÑпноÑÑÑ Ð½Ð°Ð±Ð¾Ñа, вÑклÑÑиÑÑ ÑÑÐ¾Ð±Ñ ÐµÐ³Ð¾ ÑкÑÑÑÑ. %sÐамеÑание: "
"PERMANENT и ÑекÑÑий Ð½Ð°Ð±Ð¾Ñ Ð´Ð¾ÑÑÑÐ¿Ð½Ñ Ð²Ñегда."
-#: ../gui/wxpython/gui_modules/preferences.py:1787
+#: ../gui/wxpython/gui_modules/preferences.py:1830
msgid "Mapset"
msgstr "ÐабоÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:1788
+#: ../gui/wxpython/gui_modules/preferences.py:1831
msgid "Owner"
msgstr "ÐладелеÑ"
-#: ../gui/wxpython/gui_modules/preferences.py:1789
-msgid "Group"
-msgstr "ÐÑÑппа"
-#: ../gui/wxpython/gui_modules/dbm.py:71
-#: ../gui/wxpython/gui_modules/dbm.py:260
+#: ../gui/wxpython/gui_modules/dbm.py:70
+#: ../gui/wxpython/gui_modules/dbm.py:265
msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
msgstr ""
+"Ðевозможно ÑаÑкодиÑоваÑÑ Ð·Ð½Ð°Ñение. УÑÑановиÑе кодиÑÐ¾Ð²ÐºÑ Ð² наÑÑÑойкаÑ
GUI "
+"('ÐÑÑибÑÑÑ')."
-#: ../gui/wxpython/gui_modules/dbm.py:165
+#: ../gui/wxpython/gui_modules/dbm.py:157
msgid "Loading data..."
msgstr "ÐагÑÑзка даннÑÑ
-#: ../gui/wxpython/gui_modules/dbm.py:184
+#: ../gui/wxpython/gui_modules/dbm.py:164
#, python-format
+msgid ""
+"Attribute table <%s> not found. For creating the table switch to 'Manage "
+"layers' tab."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:176
+#, python-format
msgid "Column <%(column)s> not found in in the table <%(table)s>."
msgstr "Ðоле <%(column)s> не найдено в ÑаблиÑе <%(table)s>."
-#: ../gui/wxpython/gui_modules/dbm.py:235
+#: ../gui/wxpython/gui_modules/dbm.py:238
msgid "Can display only 256 columns."
msgstr "Ðозможно оÑобÑазиÑÑ ÑолÑко 256 полей."
-#: ../gui/wxpython/gui_modules/dbm.py:269
-#, python-format
+#: ../gui/wxpython/gui_modules/dbm.py:259
+#, fuzzy
+msgid "Unknown value"
+msgstr "ÐеизвеÑÑно"
+#: ../gui/wxpython/gui_modules/dbm.py:274
msgid ""
-"Error loading attribute data. Record number: %(rec)d. Unable to cast value '%"
-"(val)s' in key column (%(key)s) to integer.\n"
+"Error loading attribute data. Record number: %(rec)d. Unable to convert "
+"value '%(val)s' in key column (%(key)s) to integer.\n"
"\n"
"Details: %(detail)s"
msgstr ""
@@ -2325,26 +2461,26 @@
"\n"
-#: ../gui/wxpython/gui_modules/dbm.py:292
+#: ../gui/wxpython/gui_modules/dbm.py:297
msgid "Limit 100000 records."
msgstr "ÐÑедел - 100000 запиÑей."
-#: ../gui/wxpython/gui_modules/dbm.py:309
-#: ../gui/wxpython/gui_modules/dbm.py:672
-#: ../gui/wxpython/gui_modules/dbm.py:997
-#: ../gui/wxpython/gui_modules/dbm.py:1613
-#: ../gui/wxpython/gui_modules/dbm.py:1635
-#: ../gui/wxpython/gui_modules/dbm.py:1762
+#: ../gui/wxpython/gui_modules/dbm.py:314
+#: ../gui/wxpython/gui_modules/dbm.py:691
+#: ../gui/wxpython/gui_modules/dbm.py:1022
+#: ../gui/wxpython/gui_modules/dbm.py:1654
+#: ../gui/wxpython/gui_modules/dbm.py:1676
+#: ../gui/wxpython/gui_modules/dbm.py:1804
#, python-format
msgid "Number of loaded records: %d"
msgstr "ЧиÑло загÑÑженнÑÑ
запиÑей: %d"
-#: ../gui/wxpython/gui_modules/dbm.py:441
-#: ../gui/wxpython/gui_modules/dbm.py:3600
+#: ../gui/wxpython/gui_modules/dbm.py:453
+#: ../gui/wxpython/gui_modules/dbm.py:3013
msgid "GRASS GIS Attribute Table Manager"
msgstr "ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ Ð°ÑÑибÑÑивнÑÑ
ÑÐ°Ð±Ð»Ð¸Ñ GRASS GIS"
-#: ../gui/wxpython/gui_modules/dbm.py:468
+#: ../gui/wxpython/gui_modules/dbm.py:480
#, python-format
msgid ""
"Database connection for vector map <%s> is not defined in DB file. You can "
@@ -2353,151 +2489,143 @@
"Соединение Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
Ð´Ð»Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ <%s> не опÑеделено в Ñайле DB. "
"ÐÑ Ð¼Ð¾Ð¶ÐµÑе ÑоздаÑÑ Ð½Ð¾Ð²Ð¾Ðµ Ñоединение в закладке 'УпÑавление ÑлоÑми'."
-#: ../gui/wxpython/gui_modules/dbm.py:472
+#: ../gui/wxpython/gui_modules/dbm.py:484
msgid "Attribute Table Manager"
msgstr "ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ Ð°ÑÑибÑÑивной ÑаблиÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:503
+#: ../gui/wxpython/gui_modules/dbm.py:515
msgid "Browse data"
msgstr "ÐÑолиÑÑаÑÑ Ð´Ð°Ð½Ð½Ñе"
-#: ../gui/wxpython/gui_modules/dbm.py:509
+#: ../gui/wxpython/gui_modules/dbm.py:521
msgid "Manage tables"
msgstr "УпÑавление ÑаблиÑами"
-#: ../gui/wxpython/gui_modules/dbm.py:515
+#: ../gui/wxpython/gui_modules/dbm.py:527
msgid "Manage layers"
msgstr "УпÑавление ÑлоÑми"
-#: ../gui/wxpython/gui_modules/dbm.py:518
-msgid "Click here to show database connection information"
-msgstr "ÐажмиÑе здеÑÑ, ÑÑÐ¾Ð±Ñ Ð¿Ð¾ÐºÐ°Ð·Ð°ÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ Ñоединении Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
-#: ../gui/wxpython/gui_modules/dbm.py:519
-msgid "Click here to hide database connection information"
-msgstr "ÐажмиÑе здеÑÑ, ÑÑÐ¾Ð±Ñ ÑкÑÑÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ Ñоединении Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
-#: ../gui/wxpython/gui_modules/dbm.py:555
-#: ../gui/wxpython/gui_modules/dbm.py:685
-#: ../gui/wxpython/gui_modules/dbm.py:2212
-#: ../gui/wxpython/gui_modules/dbm.py:2473
-msgid "Table"
-msgstr "ТаблиÑа"
-#: ../gui/wxpython/gui_modules/dbm.py:561
+#: ../gui/wxpython/gui_modules/dbm.py:567
msgid "Attribute data - right-click to edit/manage records"
msgstr ""
"ÐÑÑибÑÑивнÑе даннÑе - Ð´Ð»Ñ ÑедакÑиÑованиÑ/ÑпÑÐ°Ð²Ð»ÐµÐ½Ð¸Ñ Ð·Ð°Ð¿Ð¸ÑÑми нажмиÑе пÑавÑÑ "
"ÐºÐ½Ð¾Ð¿ÐºÑ Ð¼ÑÑи"
-#: ../gui/wxpython/gui_modules/dbm.py:565
+#: ../gui/wxpython/gui_modules/dbm.py:581
+#: ../gui/wxpython/gui_modules/dbm.py:709
+#: ../gui/wxpython/gui_modules/dbm.py:2221
+#: ../gui/wxpython/gui_modules/dbm.py:2479
+msgid "Table"
+msgstr "ТаблиÑа"
+#: ../gui/wxpython/gui_modules/dbm.py:587
msgid "SQL Query"
msgstr "SQL-запÑоÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:588
+#: ../gui/wxpython/gui_modules/dbm.py:607
msgid "Apply SELECT statement and reload data records"
msgstr "ÐÑимениÑÑ Ð²ÑÑажение SELECT и пеÑезагÑÑзиÑÑ Ð·Ð°Ð¿Ð¸Ñи даннÑÑ
-#: ../gui/wxpython/gui_modules/dbm.py:590
-#: ../gui/wxpython/gui_modules/dbm.py:1869
+#: ../gui/wxpython/gui_modules/dbm.py:609
+#: ../gui/wxpython/gui_modules/dbm.py:1878
msgid "SQL Builder"
msgstr "ÐонÑÑÑÑкÑÐ¾Ñ SQL"
-#: ../gui/wxpython/gui_modules/dbm.py:594
+#: ../gui/wxpython/gui_modules/dbm.py:613
msgid "Simple"
msgstr "ÐÑоÑÑой"
-#: ../gui/wxpython/gui_modules/dbm.py:705
+#: ../gui/wxpython/gui_modules/dbm.py:718
+msgid "Database connection"
+msgstr "Соединение Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
+#: ../gui/wxpython/gui_modules/dbm.py:730
#, python-format
msgid "Table <%s> - right-click to delete column(s)"
msgstr ""
"ТаблиÑа <%s> - нажмиÑе пÑавÑÑ ÐºÐ½Ð¾Ð¿ÐºÑ Ð¼ÑÑи Ð´Ð»Ñ ÑÐ´Ð°Ð»ÐµÐ½Ð¸Ñ ÑÑолбÑа (ÑÑолбÑов)"
-#: ../gui/wxpython/gui_modules/dbm.py:718
+#: ../gui/wxpython/gui_modules/dbm.py:743
msgid "Manage columns"
msgstr "УпÑавление ÑÑолбÑами"
-#: ../gui/wxpython/gui_modules/dbm.py:725
-#: ../gui/wxpython/gui_modules/dbm.py:2037
+#: ../gui/wxpython/gui_modules/dbm.py:750
+#: ../gui/wxpython/gui_modules/dbm.py:2046
msgid "Column name"
msgstr "ÐÐ¼Ñ Ð¿Ð¾Ð»Ñ"
-#: ../gui/wxpython/gui_modules/dbm.py:736
+#: ../gui/wxpython/gui_modules/dbm.py:761
msgid "Data type"
msgstr "Тип даннÑÑ
-#: ../gui/wxpython/gui_modules/dbm.py:753
+#: ../gui/wxpython/gui_modules/dbm.py:778
msgid "Data length"
msgstr "ÐбÑем даннÑÑ
-#: ../gui/wxpython/gui_modules/dbm.py:770
+#: ../gui/wxpython/gui_modules/dbm.py:795
msgid "Add"
msgstr "ÐобавиÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:780 ../gui/wxpython/menustrings.py:706
+#: ../gui/wxpython/gui_modules/dbm.py:805 ../gui/wxpython/menustrings.py:708
msgid "Rename column"
msgstr "ÐеÑеименоваÑÑ Ð¿Ð¾Ð»Ðµ"
-#: ../gui/wxpython/gui_modules/dbm.py:790
+#: ../gui/wxpython/gui_modules/dbm.py:815
msgid "To"
msgstr "Ð"
-#: ../gui/wxpython/gui_modules/dbm.py:800
+#: ../gui/wxpython/gui_modules/dbm.py:825
msgid "&Rename"
msgstr "&ÐеÑеименоваÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:859
+#: ../gui/wxpython/gui_modules/dbm.py:884
msgid "Layers of vector map"
msgstr "Слои векÑоÑной каÑÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:868
+#: ../gui/wxpython/gui_modules/dbm.py:893
msgid "List of layers"
msgstr "СпиÑок Ñлоев"
-#: ../gui/wxpython/gui_modules/dbm.py:972
-#: ../gui/wxpython/gui_modules/dbm.py:1204
+#: ../gui/wxpython/gui_modules/dbm.py:997
+#: ../gui/wxpython/gui_modules/dbm.py:1229
msgid "Insert new record"
msgstr "ÐÑÑавиÑÑ Ð½Ð¾Ð²ÑÑ Ð·Ð°Ð¿Ð¸ÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:973
+#: ../gui/wxpython/gui_modules/dbm.py:998
msgid "Delete selected record(s)"
msgstr "УдалиÑÑ Ð²ÑбÑаннÑе запиÑи"
-#: ../gui/wxpython/gui_modules/dbm.py:974
+#: ../gui/wxpython/gui_modules/dbm.py:999
msgid "Delete all records"
msgstr "УдалиÑÑ Ð²Ñе запиÑи"
-#: ../gui/wxpython/gui_modules/dbm.py:979
-#, fuzzy
+#: ../gui/wxpython/gui_modules/dbm.py:1004
msgid "Highlight selected features"
-msgstr "ÐодÑвеÑиÑÑ (дÑбликаÑÑ)"
+msgstr "ÐодÑвеÑиÑÑ Ð²ÑбÑаннÑе обÑекÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:980
-#, fuzzy
+#: ../gui/wxpython/gui_modules/dbm.py:1005
msgid "Highlight selected features and zoom"
-msgstr "ÐÑделиÑÑ Ð²ÑбÑанное и маÑÑÑабиÑоваÑÑ"
+msgstr "ÐÑделиÑÑ Ð²ÑбÑаннÑе обÑекÑÑ Ð¸ маÑÑÑабиÑоваÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:984
-#: ../gui/wxpython/gui_modules/dbm.py:1898
-#, fuzzy
+#: ../gui/wxpython/gui_modules/dbm.py:1009
+#: ../gui/wxpython/gui_modules/dbm.py:1907
msgid "Extract selected features"
-msgstr "ÐÑбÑаннÑй ÑÑагменÑ"
+msgstr "ÐÑделиÑÑ Ð²ÑбÑаннÑе обÑекÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:985
-#, fuzzy
+#: ../gui/wxpython/gui_modules/dbm.py:1010
msgid "Delete selected features"
-msgstr "УдалиÑÑ Ð²ÑбÑаннÑй Ñлой"
+msgstr "УдалиÑÑ Ð²ÑбÑаннÑе обÑекÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:991
-#: ../gui/wxpython/gui_modules/dbm.py:1490
-#: ../gui/wxpython/gui_modules/vdigit.py:1932
+#: ../gui/wxpython/gui_modules/dbm.py:1016
+#: ../gui/wxpython/gui_modules/dbm.py:1529
+#: ../gui/wxpython/gui_modules/vdigit.py:1983
msgid "Reload"
msgstr "ÐагÑÑзиÑÑ Ð·Ð°Ð½Ð¾Ð²Ð¾"
-#: ../gui/wxpython/gui_modules/dbm.py:1023
+#: ../gui/wxpython/gui_modules/dbm.py:1048
#, python-format
msgid ""
"Selected data records (%d) will permanently deleted from table. Do you want "
@@ -2506,12 +2634,12 @@
"ÐÑбÑаннÑе запиÑи (%d) бÑдÑÑ Ð½Ð°Ð²Ñегда ÑÐ´Ð°Ð»ÐµÐ½Ñ Ð¸Ð· ÑаблиÑÑ. ÐÑ Ñ
оÑиÑе иÑ
"ÑдалиÑÑ?"
-#: ../gui/wxpython/gui_modules/dbm.py:1026
-#: ../gui/wxpython/gui_modules/dbm.py:1072
+#: ../gui/wxpython/gui_modules/dbm.py:1051
+#: ../gui/wxpython/gui_modules/dbm.py:1097
msgid "Delete records"
msgstr "УдалиÑÑ Ð·Ð°Ð¿Ð¸Ñи"
-#: ../gui/wxpython/gui_modules/dbm.py:1069
+#: ../gui/wxpython/gui_modules/dbm.py:1094
#, python-format
msgid ""
"All data records (%d) will permanently deleted from table. Do you want to "
@@ -2519,39 +2647,39 @@
msgstr ""
"ÐÑе запиÑи (%d) бÑдÑÑ Ð½Ð°Ð²Ñегда ÑÐ´Ð°Ð»ÐµÐ½Ñ Ð¸Ð· ÑаблиÑÑ. ÐÑ Ñ
оÑиÑе иÑ
ÑдалиÑÑ?"
-#: ../gui/wxpython/gui_modules/dbm.py:1215
+#: ../gui/wxpython/gui_modules/dbm.py:1240
#, python-format
msgid "Record with category number %d already exists in the table."
msgstr "ÐапиÑÑ Ñ Ð½Ð¾Ð¼ÐµÑом каÑегоÑии %d Ñже ÑÑÑеÑÑвÑÐµÑ Ð² ÑаблиÑе."
-#: ../gui/wxpython/gui_modules/dbm.py:1225
+#: ../gui/wxpython/gui_modules/dbm.py:1250
#, python-format
msgid "Category number (column %s) is missing."
msgstr "ÐÑопÑÑен Ð½Ð¾Ð¼ÐµÑ ÐºÐ°ÑегоÑии (поле %s)."
-#: ../gui/wxpython/gui_modules/dbm.py:1233
-#: ../gui/wxpython/gui_modules/dbm.py:1336
-#, python-format
-msgid "Casting value '%(value)s' to %(type)s failed."
+#: ../gui/wxpython/gui_modules/dbm.py:1264
+#: ../gui/wxpython/gui_modules/dbm.py:1371
+#, fuzzy, python-format
+msgid "Value '%(value)s' needs to be entered as %(type)s."
msgstr "ÐÑиведение '%(value)s' к %(type)s пÑеÑвано Ñ Ð¾Ñибкой."
-#: ../gui/wxpython/gui_modules/dbm.py:1244
+#: ../gui/wxpython/gui_modules/dbm.py:1275
msgid "Unable to insert new record."
msgstr "Ðевозможно вÑÑавиÑÑ Ð½Ð¾Ð²ÑÑ Ð·Ð°Ð¿Ð¸ÑÑ."
-#: ../gui/wxpython/gui_modules/dbm.py:1313
+#: ../gui/wxpython/gui_modules/dbm.py:1344
msgid "Update existing record"
msgstr "ÐбновиÑÑ ÑÑÑеÑÑвÑÑÑÑÑ Ð·Ð°Ð¿Ð¸ÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:1348
+#: ../gui/wxpython/gui_modules/dbm.py:1384
msgid "Unable to update existing record."
msgstr "Ðевозможно обновиÑÑ ÑÑÑеÑÑвÑÑÑÑÑ Ð·Ð°Ð¿Ð¸ÑÑ."
-#: ../gui/wxpython/gui_modules/dbm.py:1432
+#: ../gui/wxpython/gui_modules/dbm.py:1470
msgid "Unable to rename column. No column name defined."
msgstr "Ðевозможно пеÑеименоваÑÑ Ð¿Ð¾Ð»Ðµ. Ðе задано Ð¸Ð¼Ñ Ð¿Ð¾Ð»Ñ."
-#: ../gui/wxpython/gui_modules/dbm.py:1441
+#: ../gui/wxpython/gui_modules/dbm.py:1479
#, python-format
msgid ""
"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
@@ -2560,7 +2688,7 @@
"Ðевозможно пеÑеименоваÑÑ Ð¿Ð¾Ð»Ðµ <%(column)s> в <%(columnTo)s>. Ðоле Ñже "
"ÑÑÑеÑÑвÑÐµÑ Ð² ÑаблиÑе <%(table)s>."
-#: ../gui/wxpython/gui_modules/dbm.py:1457
+#: ../gui/wxpython/gui_modules/dbm.py:1496
#, python-format
msgid ""
"Unable to rename column. Column <%(column)s> doesn't exist in the table <%"
@@ -2569,25 +2697,25 @@
"Ðевозможно пеÑеименоваÑÑ Ð¿Ð¾Ð»Ðµ. Ðоле <%(column)s> не ÑÑÑеÑÑвÑÐµÑ Ð² ÑаблиÑе <%"
"(table)s>."
-#: ../gui/wxpython/gui_modules/dbm.py:1485
+#: ../gui/wxpython/gui_modules/dbm.py:1524
msgid "Drop selected column"
msgstr "УдалиÑÑ Ð²ÑбÑанное поле"
-#: ../gui/wxpython/gui_modules/dbm.py:1488
+#: ../gui/wxpython/gui_modules/dbm.py:1527
msgid "Drop all columns"
msgstr "УдалиÑÑ Ð²Ñе полÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:1551
+#: ../gui/wxpython/gui_modules/dbm.py:1592
msgid "Unable to add column to the table. No column name defined."
msgstr "Ðевозможно добавиÑÑ Ð¿Ð¾Ð»Ðµ в ÑаблиÑÑ. Ðе опÑеделено Ð¸Ð¼Ñ Ð¿Ð¾Ð»Ñ."
-#: ../gui/wxpython/gui_modules/dbm.py:1573
+#: ../gui/wxpython/gui_modules/dbm.py:1614
#, python-format
msgid "Column <%(column)s> already exists in table <%(table)s>."
msgstr "Ðоле <%(column)s> Ñже ÑÑÑеÑÑвÑÐµÑ Ð² ÑаблиÑе <%(table)s>."
-#: ../gui/wxpython/gui_modules/dbm.py:1728
-#: ../gui/wxpython/gui_modules/dbm.py:1751
+#: ../gui/wxpython/gui_modules/dbm.py:1770
+#: ../gui/wxpython/gui_modules/dbm.py:1793
#, python-format
msgid ""
"Loading attribute data failed.\n"
@@ -2598,7 +2726,7 @@
"\n"
"%s"
-#: ../gui/wxpython/gui_modules/dbm.py:1738
+#: ../gui/wxpython/gui_modules/dbm.py:1780
#, python-format
msgid ""
@@ -2611,43 +2739,38 @@
"\n"
"%s"
-#: ../gui/wxpython/gui_modules/dbm.py:1823
-msgid "Database connection"
-msgstr "Соединение Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
-#: ../gui/wxpython/gui_modules/dbm.py:1893
+#: ../gui/wxpython/gui_modules/dbm.py:1902
msgid "Nothing to extract."
msgstr "ÐеÑего не вÑбÑано."
-#: ../gui/wxpython/gui_modules/dbm.py:1913
-#, fuzzy
+#: ../gui/wxpython/gui_modules/dbm.py:1922
msgid "Nothing to delete."
-msgstr "ÐеÑего не вÑбÑано."
+msgstr "ÐеÑего ÑдалÑÑÑ."
-#: ../gui/wxpython/gui_modules/dbm.py:2000
-#: ../gui/wxpython/gui_modules/dbm.py:2395
-#: ../gui/wxpython/gui_modules/dbm.py:2819
+#: ../gui/wxpython/gui_modules/dbm.py:2009
+#: ../gui/wxpython/gui_modules/dbm.py:2401
+#: ../gui/wxpython/gui_modules/dbm.py:2825
#, python-format
msgid "Drop also linked attribute table (%s)"
msgstr "УдалиÑÑ ÑвÑзаннÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ (%s)"
-#: ../gui/wxpython/gui_modules/dbm.py:2201
-#: ../gui/wxpython/gui_modules/dbm.py:2461
+#: ../gui/wxpython/gui_modules/dbm.py:2210
+#: ../gui/wxpython/gui_modules/dbm.py:2467
msgid "Driver"
msgstr "ÐÑайвеÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2206
-#: ../gui/wxpython/gui_modules/dbm.py:2467 ../gui/wxpython/menustrings.py:681
+#: ../gui/wxpython/gui_modules/dbm.py:2215
+#: ../gui/wxpython/gui_modules/dbm.py:2473 ../gui/wxpython/menustrings.py:683
msgid "Database"
msgstr "Ðаза даннÑÑ
msgid "Key"
msgstr "ÐлÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2165
+#: ../gui/wxpython/gui_modules/dbm.py:2174
msgid ""
"Unable to determine default DB connection settings. Please define DB "
"connection using db.connect module."
@@ -2655,82 +2778,88 @@
"Ðевозможно опÑеделиÑÑ ÑÑÑановки ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
по ÑмолÑаниÑ. "
"ÐожалÑйÑÑа задайÑе ÑÑÑановки иÑполÑзÑÑ Ð¼Ð¾Ð´ÑÐ»Ñ db.connect."
-#: ../gui/wxpython/gui_modules/dbm.py:2184
+#: ../gui/wxpython/gui_modules/dbm.py:2193
msgid "Add layer"
msgstr "ÐобавиÑÑ Ñлой"
-#: ../gui/wxpython/gui_modules/dbm.py:2222
+#: ../gui/wxpython/gui_modules/dbm.py:2226
+#: ../gui/wxpython/gui_modules/dbm.py:2258
+#: ../gui/wxpython/gui_modules/dbm.py:2485
+msgid "Key column"
+msgstr "ÐлÑÑевое поле"
+#: ../gui/wxpython/gui_modules/dbm.py:2231
msgid "Insert record for each category into table"
-msgstr ""
+msgstr "ÐÑÑавиÑÑ Ð·Ð°Ð¿Ð¸ÑÑ Ð´Ð»Ñ ÐºÐ°Ð¶Ð´Ð¾Ð¹ каÑегоÑии в ÑаблиÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2237
+#: ../gui/wxpython/gui_modules/dbm.py:2246
msgid "You need to add categories by v.category module."
-msgstr ""
+msgstr "ÐÑжно добавиÑÑ ÐºÐ°ÑегоÑии Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ Ð¼Ð¾Ð´ÑÐ»Ñ v.category."
-#: ../gui/wxpython/gui_modules/dbm.py:2244
+#: ../gui/wxpython/gui_modules/dbm.py:2253
msgid "Table name"
msgstr "Ðазвание ÑаблиÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2257
+#: ../gui/wxpython/gui_modules/dbm.py:2266
msgid "&Create table"
msgstr "&СоздаÑÑ ÑаблиÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2261
+#: ../gui/wxpython/gui_modules/dbm.py:2270
msgid "&Add layer"
msgstr "&ÐобавиÑÑ Ñлой"
-#: ../gui/wxpython/gui_modules/dbm.py:2265
+#: ../gui/wxpython/gui_modules/dbm.py:2274
msgid "&Set default"
msgstr "&УÑÑановиÑÑ Ð¿Ð¾ ÑмолÑаниÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2278
+#: ../gui/wxpython/gui_modules/dbm.py:2285
msgid "Layer description"
msgstr "ÐпиÑание ÑлоÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2339
+#: ../gui/wxpython/gui_modules/dbm.py:2344
msgid "Table description"
msgstr "ÐпиÑание ÑаблиÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2378
-#, fuzzy
+#: ../gui/wxpython/gui_modules/dbm.py:2384
msgid "Delete layer"
-msgstr "&УдалиÑÑ Ñлой"
+msgstr "УдалиÑÑ Ñлой"
-#: ../gui/wxpython/gui_modules/dbm.py:2381
+#: ../gui/wxpython/gui_modules/dbm.py:2387
msgid "Layer to detele"
msgstr "Слой Ð´Ð»Ñ ÑдалениÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2402
+#: ../gui/wxpython/gui_modules/dbm.py:2408
msgid "&Delete layer"
-#: ../gui/wxpython/gui_modules/dbm.py:2446
-#, fuzzy
+#: ../gui/wxpython/gui_modules/dbm.py:2452
msgid "Modify layer"
-msgstr "&ÐзмениÑÑ Ñлой"
+msgstr "ÐзмениÑÑ Ñлой"
-#: ../gui/wxpython/gui_modules/dbm.py:2518
+#: ../gui/wxpython/gui_modules/dbm.py:2524
msgid "&Modify layer"
-#: ../gui/wxpython/gui_modules/dbm.py:2566
+#: ../gui/wxpython/gui_modules/dbm.py:2572
msgid ""
"Unable to get list of tables.\n"
"Please use db.connect to set database parameters."
msgstr ""
+"Ðевозможно полÑÑиÑÑ ÑпиÑок ÑаблиÑ.\n"
+"ÐожалÑйÑÑа, иÑполÑзÑйÑе db.connect Ð´Ð»Ñ ÑÑÑановки паÑамеÑÑов Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/wxpython/gui_modules/dbm.py:2664
+#: ../gui/wxpython/gui_modules/dbm.py:2670
msgid "Unable to create new table. Table name or key column name is missing."
msgstr ""
"Ðевозможно ÑоздаÑÑ Ð½Ð¾Ð²ÑÑ ÑаблиÑÑ. ÐÑопÑÑено название ÑаблиÑÑ Ð¸Ð»Ð¸ название "
"клÑÑевого полÑ."
-#: ../gui/wxpython/gui_modules/dbm.py:2671
+#: ../gui/wxpython/gui_modules/dbm.py:2677
#, python-format
msgid "Unable to create new table. Table <%s> already exists in the database."
msgstr "Ðевозможно ÑоздаÑÑ Ð½Ð¾Ð²ÑÑ ÑаблиÑÑ. ТаблиÑа <%s> Ñже еÑÑÑ Ð² базе даннÑÑ
-#: ../gui/wxpython/gui_modules/dbm.py:2709
+#: ../gui/wxpython/gui_modules/dbm.py:2715
#, python-format
msgid ""
"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
@@ -2739,133 +2868,71 @@
"Ðевозможно добавиÑÑ Ð½Ð¾Ð²Ñе Ñлои в векÑоÑнÑÑ ÐºÐ°ÑÑÑ <%(vector)s>. Слой %(layer)"
"d Ñже ÑÑÑеÑÑвÑеÑ."
-#: ../gui/wxpython/gui_modules/dbm.py:2904
-msgid "Database connection is not defined in DB file."
не опÑеделено в Ñайле DB."
-#: ../gui/wxpython/gui_modules/dbm.py:2908
-#, python-format
-msgid ""
-"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
-"You can disable this message from digitization settings. Or you can create "
-"and link attribute table to the vector map using Attribute Table Manager."
-msgstr ""
-"ÐекÑоÑнÑй Ñлой не Ñоединен Ñ Ð°ÑÑибÑÑивной ÑаблиÑей <%(vector)s> найдено. %"
-"(msg)s\n"
-"ÐÑ Ð¼Ð¾Ð¶ÐµÑе оÑклÑÑиÑÑ ÑÑо ÑообÑение ÑеÑез наÑÑÑойки векÑоÑизаÑии. Ðли Ð²Ñ "
-"можеÑе ÑоздаÑÑ Ð¸ ÑвÑзаÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ Ñ Ð²ÐµÐºÑоÑнÑм Ñлоем иÑполÑзÑÑ "
-"ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ Ð°ÑÑибÑÑивнÑÑ
ÑаблиÑ."
-#: ../gui/wxpython/gui_modules/dbm.py:2927
-msgid "Close dialog on submit"
-msgstr "ÐакÑÑÑÑ Ð¾ÐºÐ½Ð¾ поÑле оÑпÑавки."
-#: ../gui/wxpython/gui_modules/dbm.py:2937
-msgid "No attributes found"
-msgstr "ÐÑÑибÑÑов не найдено"
-#: ../gui/wxpython/gui_modules/dbm.py:2943
-msgid "Update attributes"
-msgstr "ÐбновиÑÑ Ð°ÑÑибÑÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2945
-msgid "Add attributes"
-msgstr "ÐобавиÑÑ Ð°ÑÑибÑÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2947
-msgid "Display attributes"
-msgstr "ÐоказаÑÑ Ð°ÑÑибÑÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2951
-msgid "&Reload"
-msgstr "&ÐеÑегÑÑзиÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2952
-msgid "&Submit"
-msgstr "&ÐÑпÑавиÑÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:2968
-#: ../gui/wxpython/gui_modules/vdigit.py:1822
-msgid "Feature id:"
-msgstr "ID обÑекÑа:"
-#: ../gui/wxpython/gui_modules/dbm.py:3206
-msgid "Unknown"
-msgstr "ÐеизвеÑÑно"
-#: ../gui/wxpython/gui_modules/dbm.py:3264
-#: ../gui/wxpython/gui_modules/dbm.py:3503
-#: ../gui/wxpython/gui_modules/vdigit.py:1774
-#: ../gui/wxpython/gui_modules/vdigit.py:2200
-msgid "Category"
-msgstr "ÐаÑегоÑиÑ"
-#: ../gui/wxpython/gui_modules/dbm.py:3456
-msgid "Submit"
-msgstr "ÐÑпÑавиÑÑ"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:44
#, python-format
msgid "GRASS SQL Builder: %s"
msgstr "ÐонÑÑÑÑкÑÐ¾Ñ SQL GRASS: %s"
-#: ../gui/wxpython/gui_modules/goutput.py:310
+#: ../gui/wxpython/gui_modules/goutput.py:322
#, python-format
msgid "Command '%s' not yet implemented."
msgstr "Ðоманда '%s' еÑе не Ñеализована."
-#: ../gui/wxpython/gui_modules/goutput.py:382
+#: ../gui/wxpython/gui_modules/goutput.py:398
msgid "Save file as..."
msgstr "СоÑ
ÑаниÑÑ Ñайл как..."
-#: ../gui/wxpython/gui_modules/goutput.py:484
+#: ../gui/wxpython/gui_modules/goutput.py:496
msgid ""
"Please note that the data are left in incosistent stage and can be corrupted"
msgstr ""
"ÐбÑаÑиÑе внимание, ÑÑо даннÑе оÑÑÐ°Ð²Ð»ÐµÐ½Ñ Ð² непÑавилÑном ÑоÑÑоÑнии и возможно "
"повÑежденÑ"
-#: ../gui/wxpython/gui_modules/goutput.py:487
+#: ../gui/wxpython/gui_modules/goutput.py:499
msgid "Command aborted"
msgstr "ÐпеÑаÑÐ¸Ñ Ð¿ÑеÑвана"
-#: ../gui/wxpython/gui_modules/goutput.py:494
+#: ../gui/wxpython/gui_modules/goutput.py:506
msgid "Command finished"
msgstr "ÐпеÑаÑÐ¸Ñ Ð·Ð°Ð²ÐµÑÑена"
-#: ../gui/wxpython/gui_modules/goutput.py:768
+#: ../gui/wxpython/gui_modules/goutput.py:780
msgid "Unable to encode text. Please set encoding in GUI preferences."
-msgstr ""
+msgstr "Ðевозможно кодиÑоваÑÑ ÑекÑÑ. УÑÑановиÑе кодиÑÐ¾Ð²ÐºÑ Ð² наÑÑÑойкаÑ
GUI"
-#: ../gui/wxpython/gui_modules/globalvar.py:94
+#: ../gui/wxpython/gui_modules/globalvar.py:95
msgid "Coordinates"
msgstr "ÐооÑдинаÑÑ"
-#: ../gui/wxpython/gui_modules/globalvar.py:95
+#: ../gui/wxpython/gui_modules/globalvar.py:96
msgid "Extent"
msgstr "ÐÑ
ваÑ"
-#: ../gui/wxpython/gui_modules/globalvar.py:96
+#: ../gui/wxpython/gui_modules/globalvar.py:97
msgid "Comp. region"
msgstr "РаÑÑеÑнÑй Ñегион"
-#: ../gui/wxpython/gui_modules/globalvar.py:97
+#: ../gui/wxpython/gui_modules/globalvar.py:98
msgid "Show comp. extent"
ваÑ"
-#: ../gui/wxpython/gui_modules/globalvar.py:98
+#: ../gui/wxpython/gui_modules/globalvar.py:99
msgid "Display mode"
msgstr "Режим оÑобÑажениÑ"
-#: ../gui/wxpython/gui_modules/globalvar.py:99
+#: ../gui/wxpython/gui_modules/globalvar.py:100
msgid "Display geometry"
msgstr "ÐоказаÑÑ Ð³ÐµÐ¾Ð¼ÐµÑÑиÑ"
-#: ../gui/wxpython/gui_modules/globalvar.py:100
+#: ../gui/wxpython/gui_modules/globalvar.py:101
msgid "Map scale"
msgstr "ÐаÑÑÑаб каÑÑÑ"
+#: ../gui/wxpython/gui_modules/globalvar.py:102
+msgid "Go to"
+msgstr ""
#: ../gui/wxpython/gui_modules/gcmd.py:102
msgid "Error in command execution '%s'"
@@ -2887,243 +2954,247 @@
msgid "Nviz error"
msgstr "оÑибка Nviz"
-#: ../gui/wxpython/gui_modules/gcmd.py:362
+#: ../gui/wxpython/gui_modules/gcmd.py:356
msgid "Execution failed:"
msgstr "ÐÑполнение пÑеÑвано Ñ Ð¾Ñибкой:"
-#: ../gui/wxpython/gui_modules/gcmd.py:365
+#: ../gui/wxpython/gui_modules/gcmd.py:359
msgid "Details:"
msgstr "ÐодÑобноÑÑи:"
-#: ../gui/wxpython/gui_modules/gcmd.py:367
-#: ../gui/wxpython/gui_modules/gcmd.py:371
+#: ../gui/wxpython/gui_modules/gcmd.py:361
+#: ../gui/wxpython/gui_modules/gcmd.py:365
msgid "Error: "
msgstr "ÐÑибка: "
-#: ../gui/wxpython/gui_modules/gcmd.py:456
+#: ../gui/wxpython/gui_modules/gcmd.py:440
#, python-format
msgid "Unable to exectute command: '%s'"
msgstr "Ðевозможно вÑполниÑÑ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ: '%s'"
-#: ../gui/wxpython/gui_modules/render.py:128
+#: ../gui/wxpython/gui_modules/render.py:136
#, python-format
msgid "<%(name)s>: layer type <%(type)s> is not supported yet."
msgstr "<%(name)s>: Ñип ÑÐ»Ð¾Ñ <%(type)s> пока не поддеÑживаеÑÑÑ."
-#: ../gui/wxpython/gui_modules/render.py:264
+#: ../gui/wxpython/gui_modules/render.py:283
#, python-format
msgid "Unsupported map layer type '%s'"
msgstr "Тип ÑÐ»Ð¾Ñ '%s' не поддеÑживаеÑÑÑ"
-#: ../gui/wxpython/gui_modules/render.py:433
+#: ../gui/wxpython/gui_modules/render.py:453
msgid "GISBASE not set. You must be in GRASS GIS to run this program."
msgstr ""
"GISBASE не ÑÑÑановлена. ÐеобÑ
одимо оÑкÑÑÑÑ GRASS GIS ÑÑÐ¾Ð±Ñ Ð·Ð°Ð¿ÑÑÑиÑÑ "
"пÑогÑаммÑ."
-#: ../gui/wxpython/gui_modules/render.py:457
+#: ../gui/wxpython/gui_modules/render.py:477
msgid "Unable to open file"
msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл"
-#: ../gui/wxpython/gui_modules/render.py:459
+#: ../gui/wxpython/gui_modules/render.py:479
msgid "wxGUI closed."
-msgstr ""
+msgstr "wxGUI закÑÑÑ."
-#: ../gui/wxpython/gui_modules/render.py:633
+#: ../gui/wxpython/gui_modules/render.py:656
#, python-format
msgid "Unable to zoom to raster map <%s>."
-#: ../gui/wxpython/gui_modules/render.py:636
+#: ../gui/wxpython/gui_modules/render.py:659
#, python-format
msgid "Unable to zoom to vector map <%s>."
msgstr "Ðевозможно маÑÑÑабиÑоваÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%s>."
-#: ../gui/wxpython/gui_modules/render.py:948
+#: ../gui/wxpython/gui_modules/render.py:662
+msgid ""
+"Unable to get current geographic extent. Force quiting wxGUI. Please run "
+"manually g.region to fix the problem."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:977
msgid "ERROR: Rendering failed"
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:994
-#: ../gui/wxpython/gui_modules/render.py:1081
+#: ../gui/wxpython/gui_modules/render.py:1023
+#: ../gui/wxpython/gui_modules/render.py:1110
#, python-format
msgid "Unable to render map layer <%s>."
msgstr "Ðевозможно пеÑеÑиÑоваÑÑ Ñлой <%s>."
-#: ../gui/wxpython/gui_modules/render.py:1197
+#: ../gui/wxpython/gui_modules/render.py:1226
#, python-format
msgid "Unable render overlay <%s>."
msgstr "Ðевозможно пеÑеÑиÑоваÑÑ Ð¾Ð²ÐµÑлей <%s>."
-#: ../gui/wxpython/gui_modules/render.py:1231
+#: ../gui/wxpython/gui_modules/render.py:1266
#, python-format
msgid "Unable render overlay <%s>"
msgstr "Ðевозможно пеÑеÑиÑоваÑÑ Ð¾Ð²ÐµÑлей <%s>"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:109
-msgid "GRASS GIS Map Display: "
-msgstr "GRASS GIS диÑплей ÑлоÑ: "
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:119
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:121
msgid "Map Layers"
msgstr "Слои каÑÑÑ"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:253
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:255
msgid "Remove"
msgstr "УдалиÑÑ"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:257
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:259
#: ../gui/wxpython/menustrings.py:141
msgid "Rename"
msgstr "ÐеÑеименоваÑÑ"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:264
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:268
msgid "Change opacity level"
msgstr "ÐзмениÑÑ ÑÑÐ¾Ð²ÐµÐ½Ñ Ð½ÐµÐ¿ÑозÑаÑноÑÑи"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:266
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:270
msgid "Properties"
msgstr "СвойÑÑва"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:270
-msgid "Set computational region from selected map"
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:274
+#, fuzzy
+msgid "Set computational region from selected map(s)"
msgstr "УÑÑановиÑÑ Ñегион ÑавнÑй вÑбÑÐ°Ð½Ð½Ð¾Ð¼Ñ ÑлоÑ"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:283
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:290
msgid "Show attribute data"
msgstr "ÐоказаÑÑ Ð°ÑÑибÑÑивнÑе даннÑе"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:286
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:293
msgid "Start editing"
msgstr "ÐаÑаÑÑ ÑедакÑиÑование"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:287
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:294
msgid "Stop editing"
msgstr "ÐавеÑÑиÑÑ ÑедакÑиÑование"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:298
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:305
msgid "Use as background vector map"
msgstr "ÐÑполÑзоваÑÑ ÐºÐ°Ðº ÑоновÑй векÑоÑнÑй Ñлой"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:329
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:347
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:336
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:360
msgid "Metadata"
msgstr "ÐеÑаданнÑе"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:336
-msgid "Zoom to selected map (ignore NULLs)"
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:349
+#, fuzzy
+msgid "Zoom to selected map(s) (ignore NULLs)"
msgstr "ÐаÑÑÑабиÑоваÑÑ Ð´Ð¾ вÑбÑанного ÑÐ»Ð¾Ñ (игноÑиÑоваÑÑ NULL)"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:338
-msgid "Set computational region from selected map (ignore NULLs)"
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:351
+#, fuzzy
+msgid "Set computational region from selected map(s) (ignore NULLs)"
msgstr "УÑÑановиÑÑ ÑаÑÑеÑнÑй Ñегион ÑавнÑй вÑбÑÐ°Ð½Ð½Ð¾Ð¼Ñ ÑÐ»Ð¾Ñ (игноÑиÑоваÑÑ NULL)"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:341
-#, fuzzy
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:354
msgid "Set color table"
-msgstr "ЦвеÑовÑе ÑаблиÑÑ"
+msgstr "УÑÑановиÑÑ ÑвеÑовÑÑ ÑаблиÑÑ"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:343
-#: ../gui/wxpython/menustrings.py:640
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:356
+#: ../gui/wxpython/menustrings.py:642
msgid "Histogram"
msgstr "ÐиÑÑогÑамма"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:350
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:363
msgid "Nviz properties"
msgstr "ÐаÑÑÑойки NVIZ"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:409
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:440
msgid "Unable to create profile of raster map."
msgstr "Ðевозможно ÑоздаÑÑ Ð¿ÑоÑÐ¸Ð»Ñ ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:441
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:472
msgid "Unable to display histogram of raster map."
msgstr "Ðевозможно оÑобÑазиÑÑ Ð³Ð¸ÑÑогÑÐ°Ð¼Ð¼Ñ ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:522
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:566
#, python-format
msgid "Set opacity <%s>"
msgstr "УÑÑановиÑÑ Ð½ÐµÐ¿ÑозÑаÑноÑÑÑ <%s>"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:596
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:640
msgid "Layer group:"
msgstr "ÐÑÑппа Ñлоев:"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:601
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1152
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:645
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1208
msgid "Click to edit layer settings"
msgstr "ÐажмиÑе, ÑÑÐ¾Ð±Ñ Ð¾ÑÑедакÑиÑоваÑÑ Ð½Ð°ÑÑÑойки ÑлоÑ"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:648
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:651
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:654
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:657
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:660
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:663
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:666
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:669
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:672
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:675
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:678
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:681
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:684
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:687
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:692
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:695
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:698
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:701
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:704
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:707
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:710
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:713
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:716
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:719
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:722
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:725
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:728
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:731
msgid "(double click to set properties)"
msgstr "(иÑполÑзÑйÑе двойной ÑелÑок мÑÑи Ð´Ð»Ñ ÑÑÑановки ÑвойÑÑв)"
msgid "3d raster"
msgstr "3d ÑаÑÑÑ"
msgid "RGB"
msgstr "RGB"
msgid "HIS"
msgstr "HIS"
-#: ../gui/wxpython/menustrings.py:283
+#: ../gui/wxpython/menustrings.py:285
msgid "Shaded relief"
msgstr "Теневой ÑелÑеÑ"
msgid "raster cell numbers"
msgstr "знаÑÐµÐ½Ð¸Ñ ÑÑеек ÑаÑÑÑа"
msgid "raster flow arrows"
msgstr "напÑÐ°Ð²Ð»ÐµÐ½Ð¸Ñ Ð¿Ð¾Ñока ÑаÑÑÑа"
msgid "thematic map"
msgstr "ÑемаÑиÑеÑÐºÐ°Ñ ÐºÐ°ÑÑа"
msgid "thematic charts"
msgstr "ÑемаÑиÑеÑкие диагÑаммÑ"
msgid "grid"
msgstr "ÑеÑка"
msgid "geodesic line"
msgstr "геодезиÑеÑÐºÐ°Ñ Ð»Ð¸Ð½Ð¸Ñ"
msgid "rhumbline"
msgstr "Ð»Ð¸Ð½Ð¸Ñ ÑÑмба"
msgid "vector labels"
msgstr "подпиÑи векÑоÑа"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:961
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1008
msgid "Please wait, updating data..."
msgstr "ÐагÑÑзка обновление даннÑÑ
, пожалÑйÑÑа подождиÑе ..."
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:1231
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1287
#, python-format
msgid "Map <%s> not found."
msgstr "Слой <%s> не найден."
@@ -3134,103 +3205,101 @@
msgid "GRASS %s Map Calculator"
msgstr "GRASS %s ÐалÑкÑлÑÑÐ¾Ñ Ñлоев"
-#: ../gui/wxpython/gui_modules/toolbars.py:154
+#: ../gui/wxpython/gui_modules/toolbars.py:164
msgid "3D view"
-msgstr ""
+msgstr "3D вид"
-#: ../gui/wxpython/gui_modules/toolbars.py:1100
+#: ../gui/wxpython/gui_modules/toolbars.py:1118
msgid "Digitize"
msgstr "ÐÑиÑÑоваÑÑ"
-#: ../gui/wxpython/gui_modules/toolbars.py:341
-#, fuzzy
+#: ../gui/wxpython/gui_modules/toolbars.py:353
msgid "Zoom to map"
-msgstr "ÐаÑÑÑабиÑоваÑÑ Ð´Ð¾ вÑбÑанного ÑлоÑ"
+msgstr "ÐаÑÑÑабиÑоваÑÑ Ð´Ð¾ ÑлоÑ"
-#, fuzzy
msgid "Zoom to displayed map"
+msgstr "ÐаÑÑÑабиÑоваÑÑ Ð´Ð¾ показанного ÑлоÑ"
-#: ../gui/wxpython/gui_modules/toolbars.py:730
+#: ../gui/wxpython/gui_modules/toolbars.py:746
msgid "Duplicate attributes"
msgstr "ÐÑплиÑиÑоваÑÑ Ð°ÑÑибÑÑÑ"
-#: ../gui/wxpython/gui_modules/toolbars.py:797
+#: ../gui/wxpython/gui_modules/toolbars.py:813
msgid "Digitization settings"
msgstr "наÑÑÑойки векÑоÑизаÑии"
-#: ../gui/wxpython/gui_modules/toolbars.py:807
+#: ../gui/wxpython/gui_modules/toolbars.py:823
msgid "Copy features from (background) vector map"
msgstr "ÐопиÑоваÑÑ Ð¾Ð±ÑекÑÑ Ð¸Ð· (Ñонового) векÑоÑного ÑлоÑ"
-#: ../gui/wxpython/gui_modules/toolbars.py:815
+#: ../gui/wxpython/gui_modules/toolbars.py:831
msgid "Flip selected lines/boundaries"
msgstr "РазвеÑнÑÑÑ Ð²ÑбÑаннÑе линии/гÑаниÑÑ"
-#: ../gui/wxpython/gui_modules/toolbars.py:823
+#: ../gui/wxpython/gui_modules/toolbars.py:839
msgid "Merge selected lines/boundaries"
msgstr "ÐбÑединиÑÑ Ð²ÑбÑаннÑе линии/гÑаниÑÑ"
-#: ../gui/wxpython/gui_modules/toolbars.py:831
+#: ../gui/wxpython/gui_modules/toolbars.py:847
msgid "Break selected lines/boundaries at intersection"
msgstr "РазделиÑÑ Ð²ÑбÑаннÑе линии/гÑаниÑÑ Ð² меÑÑе пеÑеÑеÑениÑ"
-#: ../gui/wxpython/gui_modules/toolbars.py:839
+#: ../gui/wxpython/gui_modules/toolbars.py:855
msgid "Snap selected lines/boundaries (only to nodes)"
msgstr "ÐÑилепиÑÑ Ð²ÑбÑаннÑе линии/гÑаниÑÑ (ÑолÑко в ÑзлаÑ
-#: ../gui/wxpython/gui_modules/toolbars.py:847
+#: ../gui/wxpython/gui_modules/toolbars.py:863
msgid "Connect selected lines/boundaries"
msgstr "СоединиÑÑ Ð²ÑбÑаннÑе линии/гÑаниÑÑ"
-#: ../gui/wxpython/gui_modules/toolbars.py:855
+#: ../gui/wxpython/gui_modules/toolbars.py:871
msgid "Query features"
msgstr "ÐапÑÐ¾Ñ Ð¿Ð¾ обÑекÑам"
-#: ../gui/wxpython/gui_modules/toolbars.py:863
+#: ../gui/wxpython/gui_modules/toolbars.py:879
msgid "Z bulk-labeling of 3D lines"
msgstr "ÐаÑÑовое подпиÑÑвание Z 3D линий"
-#: ../gui/wxpython/gui_modules/toolbars.py:871
+#: ../gui/wxpython/gui_modules/toolbars.py:887
msgid "Feature type conversion"
msgstr "ÐонвеÑÑаÑÐ¸Ñ Ñипа обÑекÑа"
-#: ../gui/wxpython/gui_modules/toolbars.py:1040
-#: ../gui/wxpython/gui_modules/toolbars.py:1132
-#: ../gui/wxpython/gui_modules/toolbars.py:1205
+#: ../gui/wxpython/gui_modules/toolbars.py:1058
+#: ../gui/wxpython/gui_modules/toolbars.py:1150
+#: ../gui/wxpython/gui_modules/toolbars.py:1225
msgid "Select vector map"
msgstr "ÐÑбеÑиÑе векÑоÑнÑй Ñлой"
-#: ../gui/wxpython/gui_modules/toolbars.py:1078
+#: ../gui/wxpython/gui_modules/toolbars.py:1096
#, python-format
msgid "Please wait, opening vector map <%s> for editing..."
msgstr ""
"ÐожалÑйÑÑа, подождиÑе, векÑоÑнÑй Ñлой <%s> оÑкÑÑваеÑÑÑ Ð´Ð»Ñ ÑедакÑиÑованиÑ..."
-#: ../gui/wxpython/gui_modules/toolbars.py:1138
+#: ../gui/wxpython/gui_modules/toolbars.py:1156
#, python-format
msgid "Do you want to save changes in vector map <%s>?"
msgstr "СоÑ
ÑаниÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð² векÑоÑном Ñлое <%s>?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1140
+#: ../gui/wxpython/gui_modules/toolbars.py:1158
msgid "Save changes?"
msgstr "СоÑ
ÑаниÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1147
+#: ../gui/wxpython/gui_modules/toolbars.py:1165
#, python-format
msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
msgstr ""
"ÐожалÑйÑÑа, подождиÑе, пÑоизводиÑÑÑ Ð·Ð°ÐºÑÑÑие и пеÑеÑÑÑойка Ñопологии Ð´Ð»Ñ "
"векÑоÑного ÑÐ»Ð¾Ñ <%s>..."
-#: ../gui/wxpython/gui_modules/toolbars.py:1211
-#: ../gui/wxpython/gui_modules/toolbars.py:1216
+#: ../gui/wxpython/gui_modules/toolbars.py:1231
+#: ../gui/wxpython/gui_modules/toolbars.py:1236
msgid "New vector map"
msgstr "ÐовÑй векÑоÑнÑй Ñлой"
-#: ../gui/wxpython/gui_modules/vdigit.py:121
+#: ../gui/wxpython/gui_modules/vdigit.py:123
msgid ""
"Unable to initialize display driver, see README file for more information.\n"
"\n"
@@ -3241,8 +3310,8 @@
"\n"
"ÐодÑобноÑÑи:"
-#: ../gui/wxpython/gui_modules/vdigit.py:127
-#: ../gui/wxpython/gui_modules/vdigit.py:134
+#: ../gui/wxpython/gui_modules/vdigit.py:129
+#: ../gui/wxpython/gui_modules/vdigit.py:136
#, python-format
msgid ""
"Unable to open vector map <%s> for editing.\n"
@@ -3255,256 +3324,282 @@
"Ðозможно даннÑе повÑежденÑ, попÑобÑйÑе запÑÑÑиÑÑ v.build Ð´Ð»Ñ Ð¿ÐµÑеÑÑÑойки "
"Ñопологии (ÐекÑоÑ->ÐбÑабоÑаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой->СоздаÑÑ/пеÑеÑÑÑоиÑÑ ÑопологиÑ)."
-#: ../gui/wxpython/gui_modules/vdigit.py:648
+#: ../gui/wxpython/gui_modules/vdigit.py:661
msgid "Undo failed, data corrupted."
msgstr "ÐÑмена не вÑполнена, даннÑе повÑежденÑ."
-#: ../gui/wxpython/gui_modules/vdigit.py:1072
+#: ../gui/wxpython/gui_modules/vdigit.py:1097
msgid "Apply changes for this session"
msgstr "ÐÑимениÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð´Ð»Ñ ÑÑой ÑеÑÑии"
-#: ../gui/wxpython/gui_modules/vdigit.py:1075
+#: ../gui/wxpython/gui_modules/vdigit.py:1100
msgid "Close dialog and save changes to user settings file"
msgstr "ÐакÑÑÑÑ Ð´Ð¸Ð°Ð»Ð¾Ð³ и ÑоÑ
ÑаниÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð² Ñайле наÑÑÑоек полÑзоваÑелÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1100
+#: ../gui/wxpython/gui_modules/vdigit.py:1125
msgid "Symbology"
msgstr "СимволизаÑиÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1168
+#: ../gui/wxpython/gui_modules/vdigit.py:1193
msgid "Snapping"
msgstr "ÐÑилипание"
-#: ../gui/wxpython/gui_modules/vdigit.py:1174
+#: ../gui/wxpython/gui_modules/vdigit.py:1199
msgid "Snapping threshold"
msgstr "ÐоÑог пÑилипаниÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1190
+#: ../gui/wxpython/gui_modules/vdigit.py:1215
msgid "Snap also to vertex"
msgstr "ÐÑилипаÑÑ Ñакже к ÑзлÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1195
-#: ../gui/wxpython/gui_modules/vdigit.py:1523
-#: ../gui/wxpython/gui_modules/vdigit.py:1536
-#: ../gui/wxpython/gui_modules/vdigit.py:1540
+#: ../gui/wxpython/gui_modules/vdigit.py:1220
+#: ../gui/wxpython/gui_modules/vdigit.py:1568
+#: ../gui/wxpython/gui_modules/vdigit.py:1581
+#: ../gui/wxpython/gui_modules/vdigit.py:1585
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s"
msgstr "ÐоÑог пÑÐ¸Ð»Ð¸Ð¿Ð°Ð½Ð¸Ñ Ñавен %(value).1f %(units)s"
-#: ../gui/wxpython/gui_modules/vdigit.py:1208
+#: ../gui/wxpython/gui_modules/vdigit.py:1233
msgid "Select vector features"
msgstr "ÐÑбÑаÑÑ Ð²ÐµÐºÑоÑнÑе обÑекÑÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1225
+#: ../gui/wxpython/gui_modules/vdigit.py:1250
msgid "Select threshold"
msgstr "ÐÑбеÑиÑе поÑоговое знаÑение"
-#: ../gui/wxpython/gui_modules/vdigit.py:1238
+#: ../gui/wxpython/gui_modules/vdigit.py:1263
msgid "Select only features inside of selection bounding box"
msgstr "ÐÑбÑаÑÑ ÑолÑко обÑекÑÑ Ð² пÑеделаÑ
оÑ
ваÑа"
-#: ../gui/wxpython/gui_modules/vdigit.py:1240
+#: ../gui/wxpython/gui_modules/vdigit.py:1265
msgid ""
"By default are selected all features overlapping selection bounding box "
msgstr "Ðо ÑмолÑÐ°Ð½Ð¸Ñ Ð²ÑбиÑаÑÑÑÑ Ð²Ñе обÑекÑÑ Ð¿ÐµÑеÑекаÑÑиеÑÑ Ñ Ð¾Ñ
ваÑом"
-#: ../gui/wxpython/gui_modules/vdigit.py:1243
+#: ../gui/wxpython/gui_modules/vdigit.py:1268
msgid "Check for duplicates"
msgstr "ÐÑовеÑка дÑбликаÑов"
-#: ../gui/wxpython/gui_modules/vdigit.py:1255
+#: ../gui/wxpython/gui_modules/vdigit.py:1280
msgid "Digitize line features"
msgstr "ÐекÑоÑизоваÑÑ Ð»Ð¸Ð½ÐµÐ¹Ð½Ñе обÑекÑÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1258
+#: ../gui/wxpython/gui_modules/vdigit.py:1283
msgid "Break lines at intersection"
msgstr "РазбиÑÑ Ð»Ð¸Ð½Ð¸Ð¸ в меÑÑаÑ
пеÑеÑеÑениÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1268
+#: ../gui/wxpython/gui_modules/vdigit.py:1293
msgid "Save changes"
msgstr "СоÑ
ÑаниÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1271
+#: ../gui/wxpython/gui_modules/vdigit.py:1296
msgid "Save changes on exit"
msgstr "СоÑ
ÑаниÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð¿Ñи вÑÑ
оде"
-#: ../gui/wxpython/gui_modules/vdigit.py:1284
+#: ../gui/wxpython/gui_modules/vdigit.py:1309
msgid "Query tool"
msgstr "ÐапÑоÑÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1291
+#: ../gui/wxpython/gui_modules/vdigit.py:1316
msgid "Choose query tool"
msgstr "ÐÑбÑаÑÑ Ð¸Ð½ÑÑÑÑÐ¼ÐµÐ½Ñ Ð·Ð°Ð¿ÑоÑов"
-#: ../gui/wxpython/gui_modules/vdigit.py:1296
+#: ../gui/wxpython/gui_modules/vdigit.py:1321
msgid "Select by box"
msgstr "ÐÑбÑаÑÑ Ð¿ÑÑмоÑголÑником"
-#: ../gui/wxpython/gui_modules/vdigit.py:1305
+#: ../gui/wxpython/gui_modules/vdigit.py:1330
msgid "length"
msgstr "длина"
-#: ../gui/wxpython/gui_modules/vdigit.py:1310
+#: ../gui/wxpython/gui_modules/vdigit.py:1335
msgid "Select lines"
msgstr "ÐÑбÑаÑÑ Ð»Ð¸Ð½Ð¸Ð¸"
-#: ../gui/wxpython/gui_modules/vdigit.py:1312
-#: ../gui/wxpython/gui_modules/vdigit.py:1335
+#: ../gui/wxpython/gui_modules/vdigit.py:1337
+#: ../gui/wxpython/gui_modules/vdigit.py:1360
msgid "shorter than"
msgstr "коÑоÑе Ñем"
msgid "longer than"
msgstr "длиннее Ñем"
-#: ../gui/wxpython/gui_modules/vdigit.py:1328
+#: ../gui/wxpython/gui_modules/vdigit.py:1353
msgid "dangle"
msgstr "виÑÑÑий Ñзел"
-#: ../gui/wxpython/gui_modules/vdigit.py:1333
+#: ../gui/wxpython/gui_modules/vdigit.py:1358
msgid "Select dangles"
msgstr "ÐÑбÑаÑÑ Ð²Ð¸ÑÑÑие ÑзлÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1373
+#: ../gui/wxpython/gui_modules/vdigit.py:1398
msgid "Digitize new feature"
msgstr "СоздаÑÑ Ð½Ð¾Ð²Ñй обÑекÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1378
+#: ../gui/wxpython/gui_modules/vdigit.py:1403
msgid "Add new record into table"
msgstr "ÐобавиÑÑ Ð½Ð¾Ð²ÑÑ Ð·Ð°Ð¿Ð¸ÑÑ Ð² ÑаблиÑÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1384
+#: ../gui/wxpython/gui_modules/vdigit.py:1409
+#: ../gui/wxpython/gui_modules/vdigit.py:1825
+#: ../gui/wxpython/gui_modules/vdigit.py:2251
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:425
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:530
+msgid "Category"
+msgstr "ÐаÑегоÑиÑ"
msgid "Mode"
msgstr "Режим"
-#: ../gui/wxpython/gui_modules/vdigit.py:1413
+#: ../gui/wxpython/gui_modules/vdigit.py:1438
msgid "Next to use"
msgstr "ÐÑполÑзоваÑÑ ÑледÑÑÑий "
-#: ../gui/wxpython/gui_modules/vdigit.py:1401
+#: ../gui/wxpython/gui_modules/vdigit.py:1426
msgid "Category number"
msgstr "ÐÐ¾Ð¼ÐµÑ ÐºÐ°ÑегоÑии"
-#: ../gui/wxpython/gui_modules/vdigit.py:1411
+#: ../gui/wxpython/gui_modules/vdigit.py:1436
msgid "Category mode"
msgstr "Режим каÑегоÑий"
msgid "Manual entry"
msgstr "Ð ÑÑной ввод"
msgid "No category"
msgstr "ÐÐµÑ ÐºÐ°ÑегоÑий"
-#: ../gui/wxpython/gui_modules/vdigit.py:1426
+#: ../gui/wxpython/gui_modules/vdigit.py:1451
+#, fuzzy
+msgid "Digitize new area"
+msgstr "СоздаÑÑ Ð½Ð¾Ð²Ñй обÑекÑ"
+#: ../gui/wxpython/gui_modules/vdigit.py:1456
+msgid "Add centroid to left/right area"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1462
+msgid "Do not attach category to boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1471
msgid "Delete existing feature(s)"
msgstr "УдалиÑÑ ÑÑÑеÑÑвÑÑÑий обÑекÑ(Ñ)"
-#: ../gui/wxpython/gui_modules/vdigit.py:1431
+#: ../gui/wxpython/gui_modules/vdigit.py:1476
msgid "Delete record from table"
msgstr "УдалиÑÑ Ð·Ð°Ð¿Ð¸ÑÑ Ð¸Ð· ÑаблиÑÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1455
+#: ../gui/wxpython/gui_modules/vdigit.py:1500
msgid "Highlight"
msgstr "ÐодÑвеÑка"
-#: ../gui/wxpython/gui_modules/vdigit.py:1456
+#: ../gui/wxpython/gui_modules/vdigit.py:1501
msgid "Highlight (duplicates)"
-#: ../gui/wxpython/gui_modules/vdigit.py:1457
+#: ../gui/wxpython/gui_modules/vdigit.py:1502
msgid "Point"
msgstr "ТоÑка"
-#: ../gui/wxpython/gui_modules/vdigit.py:1458
+#: ../gui/wxpython/gui_modules/vdigit.py:1503
msgid "Line"
msgstr "ÐиниÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1459
+#: ../gui/wxpython/gui_modules/vdigit.py:1504
msgid "Boundary (no area)"
msgstr "ÐÑаниÑа (без полигона)"
-#: ../gui/wxpython/gui_modules/vdigit.py:1460
+#: ../gui/wxpython/gui_modules/vdigit.py:1505
msgid "Boundary (one area)"
msgstr "ÐÑаниÑа (один полигон)"
-#: ../gui/wxpython/gui_modules/vdigit.py:1461
+#: ../gui/wxpython/gui_modules/vdigit.py:1506
msgid "Boundary (two areas)"
msgstr "ÐÑаниÑа (два полигона)"
-#: ../gui/wxpython/gui_modules/vdigit.py:1462
+#: ../gui/wxpython/gui_modules/vdigit.py:1507
msgid "Centroid (in area)"
msgstr "ЦенÑÑоид (в полигоне)"
-#: ../gui/wxpython/gui_modules/vdigit.py:1463
+#: ../gui/wxpython/gui_modules/vdigit.py:1508
msgid "Centroid (outside area)"
msgstr "ЦенÑÑоид (вне полигона)"
-#: ../gui/wxpython/gui_modules/vdigit.py:1464
+#: ../gui/wxpython/gui_modules/vdigit.py:1509
msgid "Centroid (duplicate in area)"
msgstr "ЦенÑÑоид (дÑбликаÑÑ Ð² полигоне)"
-#: ../gui/wxpython/gui_modules/vdigit.py:1465
+#: ../gui/wxpython/gui_modules/vdigit.py:1510
msgid "Node (one line)"
msgstr "Узел (одна линиÑ)"
-#: ../gui/wxpython/gui_modules/vdigit.py:1466
+#: ../gui/wxpython/gui_modules/vdigit.py:1511
msgid "Node (two lines)"
msgstr "Узел (две линии)"
-#: ../gui/wxpython/gui_modules/vdigit.py:1467
+#: ../gui/wxpython/gui_modules/vdigit.py:1512
msgid "Vertex"
msgstr "Узел"
-#: ../gui/wxpython/gui_modules/vdigit.py:1468
+#: ../gui/wxpython/gui_modules/vdigit.py:1513
msgid "Area (closed boundary + centroid)"
msgstr "Ðолигон (замкнÑÑÐ°Ñ Ð³ÑаниÑа + ÑенÑÑоид)"
-#: ../gui/wxpython/gui_modules/vdigit.py:1469
+#: ../gui/wxpython/gui_modules/vdigit.py:1514
msgid "Direction"
msgstr "ÐапÑавление"
-#: ../gui/wxpython/gui_modules/vdigit.py:1516
+#: ../gui/wxpython/gui_modules/vdigit.py:1561
msgid "Snapping disabled"
msgstr "ÐÑилипание оÑклÑÑено"
-#: ../gui/wxpython/gui_modules/vdigit.py:1518
+#: ../gui/wxpython/gui_modules/vdigit.py:1563
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
msgstr ""
"ÐоÑог пÑÐ¸Ð»Ð¸Ð¿Ð°Ð½Ð¸Ñ Ñавен %(value).1f %(units)s (оÑновано на ÑаÑÑеÑном "
"ÑазÑеÑении)"
-#: ../gui/wxpython/gui_modules/vdigit.py:1571
+#: ../gui/wxpython/gui_modules/vdigit.py:1616
#, python-format
msgid "Vector digitizer settings saved to file <%s>."
msgstr "ÐаÑÑÑойки инÑÑÑÑменÑа векÑоÑизаÑии ÑоÑ
ÑÐ°Ð½ÐµÐ½Ñ Ð² Ñайл <%s>."
-#: ../gui/wxpython/gui_modules/vdigit.py:1730
+#: ../gui/wxpython/gui_modules/vdigit.py:1781
msgid "List of categories - right-click to delete"
msgstr "СпиÑок каÑегоÑий - нажмиÑе пÑавÑÑ ÐºÐ½Ð¾Ð¿ÐºÑ Ð´Ð»Ñ ÑдалениÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1761
+#: ../gui/wxpython/gui_modules/vdigit.py:1812
msgid "Add new category"
msgstr "ÐобавиÑÑ Ð½Ð¾Ð²ÑÑ ÐºÐ°ÑегоÑиÑ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1798
+#: ../gui/wxpython/gui_modules/vdigit.py:1849
msgid "Apply changes"
msgstr "ÐÑимениÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ"
-#: ../gui/wxpython/gui_modules/vdigit.py:1800
+#: ../gui/wxpython/gui_modules/vdigit.py:1851
msgid "Ignore changes and close dialog"
msgstr "ÐгноÑиÑоваÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð¸ закÑÑÑÑ Ð´Ð¸Ð°Ð»Ð¾Ð³"
-#: ../gui/wxpython/gui_modules/vdigit.py:1802
+#: ../gui/wxpython/gui_modules/vdigit.py:1853
msgid "Apply changes and close dialog"
msgstr "ÐÑимениÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ Ð¸ закÑÑÑÑ Ð´Ð¸Ð°Ð»Ð¾Ð³"
-#: ../gui/wxpython/gui_modules/vdigit.py:1892
-#: ../gui/wxpython/gui_modules/vdigit.py:2095
+#: ../gui/wxpython/gui_modules/vdigit.py:1873
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:135
+msgid "Feature id:"
+msgstr "ID обÑекÑа:"
+#: ../gui/wxpython/gui_modules/vdigit.py:1943
+#: ../gui/wxpython/gui_modules/vdigit.py:2146
#, python-format
msgid ""
"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
@@ -3515,93 +3610,87 @@
"ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ Ð¸ каÑегоÑии Ð´Ð¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ ÑелÑми ÑиÑлами.\n"
"ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ Ð´Ð¾Ð»Ð¶ÐµÐ½ бÑÑÑ Ð±Ð¾Ð»ÑÑе нÑлÑ."
-#: ../gui/wxpython/gui_modules/vdigit.py:1926
+#: ../gui/wxpython/gui_modules/vdigit.py:1977
msgid "Delete selected"
msgstr "УдалиÑÑ Ð²ÑбÑанное"
-#: ../gui/wxpython/gui_modules/vdigit.py:1930
+#: ../gui/wxpython/gui_modules/vdigit.py:1981
msgid "Delete all"
msgstr "УдалиÑÑ Ð²Ñе"
-#: ../gui/wxpython/gui_modules/vdigit.py:2075
+#: ../gui/wxpython/gui_modules/vdigit.py:2126
msgid "Unable to update vector map."
msgstr "Ðевозможно обновиÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой."
-#: ../gui/wxpython/gui_modules/vdigit.py:2237
+#: ../gui/wxpython/gui_modules/vdigit.py:2288
#, python-format
msgid "%d lines selected for z bulk-labeling"
msgstr "%d линии вÑбÑÐ°Ð½Ñ Ð´Ð»Ñ Ð¼Ð°ÑÑового подпиÑÑÐ²Ð°Ð½Ð¸Ñ z"
-#: ../gui/wxpython/gui_modules/vdigit.py:2240
+#: ../gui/wxpython/gui_modules/vdigit.py:2291
msgid "Set value"
msgstr "УÑÑановиÑÑ Ð·Ð½Ð°Ñение"
-#: ../gui/wxpython/gui_modules/vdigit.py:2247
+#: ../gui/wxpython/gui_modules/vdigit.py:2298
msgid "Starting value"
msgstr "ÐаÑалÑное знаÑение"
-#: ../gui/wxpython/gui_modules/vdigit.py:2256
+#: ../gui/wxpython/gui_modules/vdigit.py:2307
msgid "Step"
msgstr "Шаг"
-#: ../gui/wxpython/gui_modules/vdigit.py:2289
+#: ../gui/wxpython/gui_modules/vdigit.py:2340
msgid "List of duplicates"
msgstr "СпиÑок дÑбликаÑов"
-#: ../gui/wxpython/gui_modules/vdigit.py:2382
+#: ../gui/wxpython/gui_modules/vdigit.py:2433
msgid "Feature id"
msgstr "ID обÑекÑа"
-#: ../gui/wxpython/gui_modules/vdigit.py:2383
+#: ../gui/wxpython/gui_modules/vdigit.py:2434
msgid "Layer (Categories)"
msgstr "Слой (ÐаÑегоÑии)"
#: ../gui/wxpython/gui_modules/colorrules.py:94
-#, fuzzy
msgid "Create new color table for raster map"
-msgstr "СоздаÑÑ Ð½Ð¾Ð²ÑÑ ÑаблиÑÑ ÑвеÑов иÑполÑзÑÑ ÑвеÑовÑе пÑавила"
+msgstr "СоздаÑÑ Ð½Ð¾Ð²ÑÑ ÑаблиÑÑ ÑвеÑов Ð´Ð»Ñ ÑаÑÑÑового ÑлоÑ"
#: ../gui/wxpython/gui_modules/colorrules.py:96
#: ../gui/wxpython/gui_modules/colorrules.py:389
msgid "Enter raster cat values or percents"
-msgstr ""
+msgstr "ÐведиÑе знаÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий ÑаÑÑÑа или пÑоÑенÑÑ"
#: ../gui/wxpython/gui_modules/colorrules.py:98
-#, fuzzy
msgid "Create new color table for vector map"
+msgstr "СоздаÑÑ Ð½Ð¾Ð²ÑÑ ÑаблиÑÑ ÑвеÑов Ð´Ð»Ñ Ð²ÐµÐºÑоÑного ÑлоÑ"
#: ../gui/wxpython/gui_modules/colorrules.py:100
msgid "Enter vector attribute values or ranges (n or n1 to n2)"
-msgstr ""
+msgstr "ÐведиÑе знаÑÐµÐ½Ð¸Ñ Ð°ÑÑибÑÑов векÑоÑа или Ð´Ð¸Ð°Ð¿Ð°Ð·Ð¾Ð½Ñ (n или n1 до n2)"
#: ../gui/wxpython/gui_modules/colorrules.py:111
-#, fuzzy
msgid "Select raster map:"
-msgstr "ÐеÑекодиÑÐ¾Ð²Ð°Ð½Ð½Ð°Ñ ÑаÑÑÑовÑй Ñлой:"
+msgstr "ÐÑбÑаÑÑ ÑаÑÑÑовÑй Ñлой:"
#: ../gui/wxpython/gui_modules/colorrules.py:113
-#, fuzzy
msgid "Select vector map:"
-msgstr "ÐÑбеÑиÑе векÑоÑнÑй Ñлой"
+msgstr "ÐÑбÑаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
#: ../gui/wxpython/gui_modules/colorrules.py:122
msgid "replace existing color table"
msgstr "замениÑÑ ÑÑÑеÑÑвÑÑÑÑÑ ÑвеÑовÑÑ ÑаблиÑÑ"
#: ../gui/wxpython/gui_modules/colorrules.py:128
-#, fuzzy
msgid "Layer:"
-msgstr "Слой"
+msgstr "Слой:"
#: ../gui/wxpython/gui_modules/colorrules.py:130
-#, fuzzy
msgid "Attribute column:"
-msgstr "ÐÑÑибÑÑÑ"
+msgstr "Ðоле аÑÑибÑÑов:"
#: ../gui/wxpython/gui_modules/colorrules.py:132
msgid "RGB color column:"
-msgstr ""
+msgstr "ЦвеÑовое поле RGB:"
#: ../gui/wxpython/gui_modules/colorrules.py:161
msgid "Preview"
@@ -3611,74 +3700,75 @@
#, python-format
msgid "Enter raster cat values or percents (range = %(min)d-%(max)d)"
msgstr ""
+"ÐведиÑе знаÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий ÑаÑÑÑа или пÑоÑенÑÑ (диапазон = %(min)d-%(max)d)"
#: ../gui/wxpython/gui_modules/colorrules.py:468
msgid "Please select attribute column and RGB color column first"
-msgstr ""
+msgstr "ÐожалÑйÑÑа, ÑнаÑала вÑбеÑиÑе поле аÑÑибÑÑов и поле ÑвеÑа RGB"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:479
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:526
msgid "Loading raster map"
msgstr "ÐагÑÑзка ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:483
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:530
msgid "Loading 3d raster map"
msgstr "ÐагÑÑзка 3d ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:489
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:536
msgid "failed"
msgstr "оÑибка"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:491
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:538
#, python-format
msgid "Unsupported layer type '%s'"
msgstr "Тип ÑÐ»Ð¾Ñ Ð½Ðµ поддеÑживаеÑÑÑ '%s'"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:545
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:592
msgid "Unable to unload raster map"
msgstr "Ðевозможно вÑгÑÑзиÑÑ ÑаÑÑÑовÑй Ñлой"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:546
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:593
msgid "Raster map"
msgstr "РаÑÑÑовÑй Ñлой"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:550
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:597
msgid "Unable to unload 3d raster map"
msgstr "Ðевозможно вÑгÑÑзиÑÑ 3d ÑаÑÑÑовÑй Ñлой"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:551
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:598
msgid "3d raster map"
msgstr "3d ÑаÑÑÑовÑй Ñлой"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:558
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:605
msgid "unloaded successfully"
msgstr "ÑÑпеÑно вÑгÑÑжено"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:609
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:656
#, python-format
msgid "Loading vector map <%(name)s> (%(type)s) failed"
msgstr "Ðе ÑдалоÑÑ Ð·Ð°Ð³ÑÑзиÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%(name)s> (%(type)s)"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:660
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:707
#, python-format
msgid "Unable to unload vector map <%(name)s> (%(type)s)"
msgstr "Ðевозможно вÑгÑÑзиÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой <%(name)s> (%(type)s)"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:663
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:710
#, python-format
msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
msgstr "ÐекÑоÑнÑй Ñлой <%(name)s> (%(type)s) ÑÑпеÑно вÑгÑÑжен"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1185
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1232
#, python-format
msgid "Vector point layer not found (id=%d)"
msgstr "ТоÑеÑнÑй векÑоÑнÑй Ñлой не найден (id=%d)"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1187
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1234
#, python-format
msgid "Unable to set data layer properties (id=%d)"
msgstr "Ðевозможно ÑÑÑановиÑÑ ÑвойÑÑва ÑÐ»Ð¾Ñ Ð´Ð°Ð½Ð½ÑÑ
(id=%d)"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1191
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1238
#, python-format
msgid ""
"Setting data layer properties failed.\n"
@@ -3693,410 +3783,508 @@
msgid "Nviz tools"
msgstr "ÐнÑÑÑÑменÑÑ NVIZ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:109
-#: ../gui/wxpython/gui_modules/nviz_tools.py:984
+#: ../gui/wxpython/gui_modules/nviz_tools.py:115
+#: ../gui/wxpython/gui_modules/nviz_tools.py:989
msgid "View"
msgstr "Ðид"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:118
+#: ../gui/wxpython/gui_modules/nviz_tools.py:124
msgid "W"
msgstr "Ð"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:120
+#: ../gui/wxpython/gui_modules/nviz_tools.py:126
msgid "N"
msgstr "С:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:127
+#: ../gui/wxpython/gui_modules/nviz_tools.py:133
msgid "S"
msgstr "Ю"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:129
+#: ../gui/wxpython/gui_modules/nviz_tools.py:135
msgid "E"
msgstr "Ð:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:138
-#: ../gui/wxpython/gui_modules/nviz_tools.py:994
+#: ../gui/wxpython/gui_modules/nviz_tools.py:144
+#: ../gui/wxpython/gui_modules/nviz_tools.py:999
msgid "Perspective:"
msgstr "ÐеÑÑпекÑива:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:149
+#: ../gui/wxpython/gui_modules/nviz_tools.py:155
msgid "Twist:"
msgstr "ÐиÑок:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:163
+#: ../gui/wxpython/gui_modules/nviz_tools.py:169
msgid "Height:"
msgstr "ÐÑÑоÑа:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:170
+#: ../gui/wxpython/gui_modules/nviz_tools.py:176
msgid "Z-exag:"
msgstr "коÑÑÑиÑÐ¸ÐµÐ½Ñ Ð¼Ð°ÑÑÑабиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Z:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:184
+#: ../gui/wxpython/gui_modules/nviz_tools.py:190
msgid "Look at:"
msgstr "ÐбзоÑ:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:188
+#: ../gui/wxpython/gui_modules/nviz_tools.py:194
msgid "top"
msgstr "веÑÑ
-#: ../gui/wxpython/gui_modules/nviz_tools.py:189
+#: ../gui/wxpython/gui_modules/nviz_tools.py:195
msgid "north"
msgstr "ÑевеÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:190
+#: ../gui/wxpython/gui_modules/nviz_tools.py:196
msgid "south"
msgstr "Ñг"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:191
+#: ../gui/wxpython/gui_modules/nviz_tools.py:197
msgid "east"
msgstr "воÑÑок"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:192
+#: ../gui/wxpython/gui_modules/nviz_tools.py:198
msgid "west"
msgstr "запад"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:193
+#: ../gui/wxpython/gui_modules/nviz_tools.py:199
msgid "north-west"
msgstr "ÑевеÑо-запад"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:194
+#: ../gui/wxpython/gui_modules/nviz_tools.py:200
msgid "north-east"
msgstr "ÑевеÑо-воÑÑок"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:195
+#: ../gui/wxpython/gui_modules/nviz_tools.py:201
msgid "south-east"
msgstr "Ñго-воÑÑок"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:196
+#: ../gui/wxpython/gui_modules/nviz_tools.py:202
msgid "south-west"
msgstr "Ñго-запад"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:203
+#: ../gui/wxpython/gui_modules/nviz_tools.py:209
msgid "Reset"
msgstr "СбÑоÑиÑÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:204
+#: ../gui/wxpython/gui_modules/nviz_tools.py:210
msgid "Reset to default view"
msgstr "ÐеÑнÑÑÑÑÑ Ðº Ð²Ð¸Ð´Ñ Ð¿Ð¾ ÑмолÑаниÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:242
+#: ../gui/wxpython/gui_modules/nviz_tools.py:248
msgid "Surface attributes"
msgstr "ÐаÑамеÑÑÑ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑи"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:249
+#: ../gui/wxpython/gui_modules/nviz_tools.py:255
msgid "Topography"
msgstr "ТопогÑаÑиÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:251
-#: ../gui/wxpython/gui_modules/nviz_tools.py:432
-#: ../gui/wxpython/gui_modules/nviz_tools.py:850
-#: ../gui/wxpython/menustrings.py:253
+#: ../gui/wxpython/gui_modules/nviz_tools.py:257
+#: ../gui/wxpython/gui_modules/nviz_tools.py:437
+#: ../gui/wxpython/gui_modules/nviz_tools.py:855
+#: ../gui/wxpython/menustrings.py:255
msgid "Mask"
msgstr "ÐаÑкиÑоваÑÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:252
-#: ../gui/wxpython/gui_modules/nviz_tools.py:851
+#: ../gui/wxpython/gui_modules/nviz_tools.py:258
+#: ../gui/wxpython/gui_modules/nviz_tools.py:856
msgid "Transparency"
msgstr "ÐÑозÑаÑноÑÑÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:253
-#: ../gui/wxpython/gui_modules/nviz_tools.py:852
+#: ../gui/wxpython/gui_modules/nviz_tools.py:259
+#: ../gui/wxpython/gui_modules/nviz_tools.py:857
msgid "Shininess"
msgstr "ЯÑкоÑÑÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:254
-#: ../gui/wxpython/gui_modules/nviz_tools.py:853
+#: ../gui/wxpython/gui_modules/nviz_tools.py:260
+#: ../gui/wxpython/gui_modules/nviz_tools.py:858
msgid "Emission"
msgstr "ÐÑбÑоÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:260
-#: ../gui/wxpython/gui_modules/nviz_tools.py:861
+#: ../gui/wxpython/gui_modules/nviz_tools.py:266
+#: ../gui/wxpython/gui_modules/nviz_tools.py:866
msgid "map"
msgstr "Ñлой"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:262
-#: ../gui/wxpython/gui_modules/nviz_tools.py:866
+#: ../gui/wxpython/gui_modules/nviz_tools.py:268
+#: ../gui/wxpython/gui_modules/nviz_tools.py:871
msgid "unset"
msgstr "ÑнÑÑÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:267
-#: ../gui/wxpython/gui_modules/nviz_tools.py:871
+#: ../gui/wxpython/gui_modules/nviz_tools.py:273
+#: ../gui/wxpython/gui_modules/nviz_tools.py:876
msgid "constant"
msgstr "поÑÑоÑннаÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:327
-#: ../gui/wxpython/gui_modules/nviz_tools.py:738
+#: ../gui/wxpython/gui_modules/nviz_tools.py:333
+#: ../gui/wxpython/gui_modules/nviz_tools.py:743
msgid "Draw"
msgstr "РиÑоваÑÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:334
-#: ../gui/wxpython/gui_modules/nviz_tools.py:745
+#: ../gui/wxpython/gui_modules/nviz_tools.py:340
+#: ../gui/wxpython/gui_modules/nviz_tools.py:750
msgid "Mode:"
msgstr "Режим:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:337
+#: ../gui/wxpython/gui_modules/nviz_tools.py:343
msgid "coarse"
msgstr "гÑÑбо"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:338
+#: ../gui/wxpython/gui_modules/nviz_tools.py:344
msgid "fine"
msgstr "ÑоÑнÑй"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:339
+#: ../gui/wxpython/gui_modules/nviz_tools.py:345
msgid "both"
msgstr "оба"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:349
-#: ../gui/wxpython/gui_modules/nviz_tools.py:772
+#: ../gui/wxpython/gui_modules/nviz_tools.py:355
+#: ../gui/wxpython/gui_modules/nviz_tools.py:777
msgid "Resolution:"
msgstr "РазÑеÑение:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:353
+#: ../gui/wxpython/gui_modules/nviz_tools.py:359
msgid "coarse:"
msgstr "гÑÑбо:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:365
+#: ../gui/wxpython/gui_modules/nviz_tools.py:371
msgid "fine:"
msgstr "ÑоÑно:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:380
+#: ../gui/wxpython/gui_modules/nviz_tools.py:386
msgid "Coarse style:"
msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:383
+#: ../gui/wxpython/gui_modules/nviz_tools.py:389
msgid "wire"
msgstr "каÑкаÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:384
+#: ../gui/wxpython/gui_modules/nviz_tools.py:390
msgid "surface"
msgstr "повеÑÑ
ноÑÑÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:393
-#: ../gui/wxpython/gui_modules/nviz_tools.py:759
+#: ../gui/wxpython/gui_modules/nviz_tools.py:399
+#: ../gui/wxpython/gui_modules/nviz_tools.py:764
msgid "Shading:"
msgstr "Тени:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:396
-#: ../gui/wxpython/gui_modules/nviz_tools.py:574
-#: ../gui/wxpython/gui_modules/nviz_tools.py:762
+#: ../gui/wxpython/gui_modules/nviz_tools.py:402
+#: ../gui/wxpython/gui_modules/nviz_tools.py:579
+#: ../gui/wxpython/gui_modules/nviz_tools.py:767
msgid "flat"
msgstr "плоÑкий"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:397
-#: ../gui/wxpython/gui_modules/nviz_tools.py:763
+#: ../gui/wxpython/gui_modules/nviz_tools.py:403
+#: ../gui/wxpython/gui_modules/nviz_tools.py:768
msgid "gouraud"
msgstr "gouraud"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:406
+#: ../gui/wxpython/gui_modules/nviz_tools.py:412
msgid "Wire color:"
msgstr "Ð¦Ð²ÐµÑ ÐºÐ°ÑкаÑа:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:421
-msgid "All"
-msgstr "ÐÑе"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:427
+msgid "Set to all"
+msgstr "УÑÑановиÑÑ Ð´Ð»Ñ Ð²ÑеÑ
-#: ../gui/wxpython/gui_modules/nviz_tools.py:422
-msgid "Use for all loaded surfaces"
-msgstr "ÐÑполÑзоваÑÑ Ð´Ð»Ñ Ð²ÑеÑ
загÑÑженнÑÑ
повеÑÑ
ноÑÑей"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:428
+msgid "Use draw settings for all loaded surfaces"
+msgstr "ÐÑполÑзоваÑÑ Ð½Ð°ÑÑÑойки оÑÑиÑовки Ð´Ð»Ñ Ð²ÑеÑ
загÑÑженнÑÑ
повеÑÑ
ноÑÑей"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:437
+#: ../gui/wxpython/gui_modules/nviz_tools.py:442
msgid "Mask zeros:"
msgstr "ÐаÑкиÑоваÑÑ Ð½Ñли:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:441
+#: ../gui/wxpython/gui_modules/nviz_tools.py:446
msgid "by elevation"
msgstr "по вÑÑоÑе"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:446
+#: ../gui/wxpython/gui_modules/nviz_tools.py:451
msgid "by color"
msgstr "по ÑвеÑÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:461
+#: ../gui/wxpython/gui_modules/nviz_tools.py:466
msgid "Position"
msgstr "Ðоложение"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:524
+#: ../gui/wxpython/gui_modules/nviz_tools.py:529
msgid "Show vector lines"
msgstr "ÐоказаÑÑ Ð²ÐµÐºÑоÑнÑе линии"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:532
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1157
+#: ../gui/wxpython/gui_modules/nviz_tools.py:537
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1162
msgid "Vector lines"
msgstr "ÐекÑоÑнÑе линии"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:573
+#: ../gui/wxpython/gui_modules/nviz_tools.py:578
msgid "on surface"
msgstr "на повеÑÑ
ноÑÑи"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:583
-#: ../gui/wxpython/gui_modules/nviz_tools.py:688
-#, fuzzy
+#: ../gui/wxpython/gui_modules/nviz_tools.py:588
+#: ../gui/wxpython/gui_modules/nviz_tools.py:693
msgid "Height above surface:"
msgstr "ÐÑÑоÑа над повеÑÑ
ноÑÑÑÑ:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:618
+#: ../gui/wxpython/gui_modules/nviz_tools.py:623
msgid "Show vector points"
msgstr "ÐоказаÑÑ Ð²ÐµÐºÑоÑнÑе ÑоÑки"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:626
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1182
+#: ../gui/wxpython/gui_modules/nviz_tools.py:631
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1187
msgid "Vector points"
msgstr "ÐекÑоÑнÑе ÑоÑки"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:632
+#: ../gui/wxpython/gui_modules/nviz_tools.py:637
msgid "Icon size:"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ Ð¸ÐºÐ¾Ð½ÐºÐ¸:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:648
+#: ../gui/wxpython/gui_modules/nviz_tools.py:653
msgid "width:"
msgstr "ÑиÑина:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:664
+#: ../gui/wxpython/gui_modules/nviz_tools.py:669
msgid "symbol:"
msgstr "Ñимвол:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:677
+#: ../gui/wxpython/gui_modules/nviz_tools.py:682
msgid "color:"
msgstr "ÑвеÑ:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:748
+#: ../gui/wxpython/gui_modules/nviz_tools.py:753
msgid "isosurfaces"
msgstr "изоповеÑÑ
ноÑÑÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:749
+#: ../gui/wxpython/gui_modules/nviz_tools.py:754
msgid "slides"
msgstr "ÑлайдÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:794
+#: ../gui/wxpython/gui_modules/nviz_tools.py:799
msgid "List of isosurfaces"
msgstr "ÑпиÑок изоповеÑÑ
ноÑÑей"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:842
+#: ../gui/wxpython/gui_modules/nviz_tools.py:847
msgid "Isosurface attributes"
msgstr "ÐаÑамеÑÑÑ Ð¸Ð·Ð¾Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑи"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:848
+#: ../gui/wxpython/gui_modules/nviz_tools.py:853
msgid "Topography level"
msgstr "УÑÐ¾Ð²ÐµÐ½Ñ ÑопогÑаÑии"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:997
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1076
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1106
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1002
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1081
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1111
msgid "(value)"
msgstr "(знаÑение)"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1009
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1057
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1088
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1014
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1062
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1093
msgid "(step)"
msgstr "(Ñаг)"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1024
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1029
msgid "Position:"
msgstr "Ðоложение:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1027
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1032
msgid "(x)"
msgstr "(x)"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1054
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1059
msgid "Height"
msgstr "ÐÑÑоÑа"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1073
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1078
msgid "Twist"
msgstr "ÐиÑок"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1103
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1108
msgid "Z-exag"
msgstr "коÑÑÑиÑÐ¸ÐµÐ½Ñ Ð¼Ð°ÑÑÑабиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Z"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1118
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1123
msgid "(step):"
msgstr "(Ñаг):"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1140
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1145
msgid "Surface"
msgstr "ÐовеÑÑ
ноÑÑÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1164
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1169
msgid "Show lines"
msgstr "ÐоказаÑÑ Ð»Ð¸Ð½Ð¸Ð¸"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1189
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1194
msgid "Show points"
msgstr "ÐоказаÑÑ ÑоÑки"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1198
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1203
msgid "Size:"
msgstr "РазмеÑ:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1229
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1234
msgid "Marker:"
msgstr "ÐаÑкеÑ:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1262
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1267
msgid "Default"
msgstr "Ðо ÑмолÑаниÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1267
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1272
msgid "Restore default settings"
msgstr "ÐоÑÑÑановиÑÑ Ð½Ð°ÑÑÑойки по ÑмолÑаниÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1507
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1512
#, python-format
msgid "Nviz settings saved to file <%s>."
msgstr "ÐаÑÑÑойки Nviz ÑоÑ
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2122
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2124
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2147
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2149
msgid "Level"
msgstr "УÑовенÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2296
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2314
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2332
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2323
msgid "Layer properties"
msgstr "СвойÑÑва ÑлоÑ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2443
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2440
#, python-format
msgid "Vector map <%s> is 3D"
msgstr "ÐекÑоÑнÑй Ñлой <%s> не 3D"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2446
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2443
#, python-format
msgid "Vector map <%s> is 2D"
msgstr "ÐекÑоÑнÑй Ñлой <%s> 2D"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2448
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2445
#, python-format
msgid "%(primitives)d primitives (%(points)d points)"
msgstr "%(primitives)d пÑимиÑивов (%(points)d ÑоÑек)"
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1095
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1726
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1263
+msgid "Update categories"
+msgstr "ÐбновиÑÑ ÐºÐ°ÑегоÑии"
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1358
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1892
msgid "No vector map selected for editing."
msgstr "ÐекÑоÑнÑй Ñлой не вÑбÑан Ð´Ð»Ñ ÑедакÑиÑованиÑ."
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1244
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1251
-msgid "Update categories"
-msgstr "ÐбновиÑÑ ÐºÐ°ÑегоÑии"
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1359
+#, fuzzy
+msgid "Vector digitizer"
+msgstr "ÐÑибка векÑоÑизаÑии"
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1846
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:2014
msgid "Z bulk-labeling dialog"
msgstr "диалог маÑÑовой подпиÑи Z"
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:2325
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:2498
msgid "Zoom to saved region extents"
msgstr "ÐаÑÑÑабиÑоваÑÑ Ð´Ð¾ оÑ
ваÑа ÑоÑ
ÑаненнÑÑ
Ñегионов"
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:2386
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:2559
#, python-format
msgid "Region file <%s> already exists. Do you want to overwrite it?"
msgstr "Файл Ñегиона <%s> Ñже ÑÑÑеÑÑвÑеÑ. ÐеÑезапиÑаÑÑ?"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:71
+msgid "Database connection is not defined in DB file."
+msgstr "Соединение Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:75
+#, python-format
+msgid ""
+"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
+"You can disable this message from digitization settings. Or you can create "
+"and link attribute table to the vector map using Attribute Table Manager."
+msgstr ""
+"ÐекÑоÑнÑй Ñлой не Ñоединен Ñ Ð°ÑÑибÑÑивной ÑаблиÑей <%(vector)s> найдено. %"
+"(msg)s\n"
+"ÐÑ Ð¼Ð¾Ð¶ÐµÑе оÑклÑÑиÑÑ ÑÑо ÑообÑение ÑеÑез наÑÑÑойки векÑоÑизаÑии. Ðли Ð²Ñ "
+"можеÑе ÑоздаÑÑ Ð¸ ÑвÑзаÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ Ñ Ð²ÐµÐºÑоÑнÑм Ñлоем иÑполÑзÑÑ "
+"ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ Ð°ÑÑибÑÑивнÑÑ
ÑаблиÑ."
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:94
+msgid "Close dialog on submit"
+msgstr "ÐакÑÑÑÑ Ð¾ÐºÐ½Ð¾ поÑле оÑпÑавки."
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:104
+msgid "No attributes found"
+msgstr "ÐÑÑибÑÑов не найдено"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:110
+msgid "Update attributes"
+msgstr "ÐбновиÑÑ Ð°ÑÑибÑÑÑ"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:112
+msgid "Add attributes"
+msgstr "ÐобавиÑÑ Ð°ÑÑибÑÑÑ"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:114
+msgid "Display attributes"
+msgstr "ÐоказаÑÑ Ð°ÑÑибÑÑÑ"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:118
+msgid "&Reload"
+msgstr "&ÐеÑегÑÑзиÑÑ"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:119
+msgid "&Submit"
+msgstr "&ÐÑпÑавиÑÑ"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:367
+msgid "Unknown"
+msgstr "ÐеизвеÑÑно"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:515
+msgid "Submit"
+msgstr "ÐÑпÑавиÑÑ"
+#: ../gui/wxpython/gui_modules/ogc_services.py:38
+#, fuzzy
+msgid "Import data from WMS server"
+msgstr "ÐагÑÑзиÑÑ Ð¸ импоÑÑиÑоваÑÑ Ð´Ð°Ð½Ð½Ñе Ñ ÑеÑвеÑов WMS."
+#: ../gui/wxpython/gui_modules/ogc_services.py:54
+#, fuzzy
+msgid " Server settings "
+msgstr "ÐбÑие наÑÑÑойки"
+#: ../gui/wxpython/gui_modules/ogc_services.py:56
+#, fuzzy
+msgid "Server:"
+msgstr "ÐÑайвеÑ"
+#: ../gui/wxpython/gui_modules/ogc_services.py:63
+#, fuzzy
+msgid " List of layers "
+msgstr "СпиÑок Ñлоев"
+#: ../gui/wxpython/gui_modules/ogc_services.py:79
+#, fuzzy
+msgid "&Connect"
+msgstr "СвÑзÑ"
+#: ../gui/wxpython/gui_modules/ogc_services.py:80
+msgid "Connect to the server"
+msgstr ""
+#: ../gui/wxpython/gui_modules/ogc_services.py:237
+#, fuzzy
+msgid "Layer / Style"
+msgstr "Слой Ð´Ð»Ñ ÑдалениÑ"
+#: ../gui/wxpython/gui_modules/ogc_services.py:238
+#, fuzzy
+msgid "Title"
+msgstr "Файл"
+#: ../gui/wxpython/gui_modules/ogc_services.py:248
+#, fuzzy
+msgid "Layers"
+msgstr "Слой"
#: ../gui/wxpython/gis_set.py:84
msgid "Choose project location and mapset"
msgstr "ÐÑбиÑиÑе облаÑÑÑ Ð¿ÑоекÑа и набоÑ"
@@ -4114,7 +4302,7 @@
"ÐобÑо пожаловаÑÑ Ð² ÐÐС GRASS %s\n"
"ÐедÑÑÐ°Ñ ÑÐ²Ð¾Ð±Ð¾Ð´Ð½Ð°Ñ ÐÐС"
-#: ../gui/wxpython/gis_set.py:95
+#: ../gui/wxpython/gis_set.py:93
msgid ""
"Select an existing project location and mapset\n"
"or define a new location"
@@ -4122,7 +4310,7 @@
"ÐÑбеÑиÑе ÑÑÑеÑÑвÑÑÑÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ Ð¿ÑоекÑа и набоÑ\n"
"или задайÑе новÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ"
-#: ../gui/wxpython/gis_set.py:101
+#: ../gui/wxpython/gis_set.py:99
msgid ""
"Project location\n"
"(projection/coordinate system)"
@@ -4130,7 +4318,7 @@
"ÐблаÑÑÑ Ð¿ÑоекÑа\n"
"(пÑоекÑиÑ/ÑиÑÑема кооÑдинаÑ)"
-#: ../gui/wxpython/gis_set.py:104
+#: ../gui/wxpython/gis_set.py:102
msgid ""
"Accessible mapsets\n"
"(directories of GIS files)"
@@ -4138,7 +4326,7 @@
"ÐоÑÑÑпнÑе набоÑÑ\n"
"(каÑалоги GIS-Ñайлов)"
-#: ../gui/wxpython/gis_set.py:107
+#: ../gui/wxpython/gis_set.py:105
msgid ""
"Create new mapset\n"
"in selected location"
@@ -4146,11 +4334,11 @@
"СоздаÑÑ Ð½Ð¾Ð²Ñй набоÑ\n"
"в вÑбÑанной облаÑÑи"
-#: ../gui/wxpython/gis_set.py:110
+#: ../gui/wxpython/gis_set.py:108
msgid "Define new location"
msgstr "ÐпÑеделиÑÑ Ð½Ð¾Ð²ÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ"
-#: ../gui/wxpython/gis_set.py:113
+#: ../gui/wxpython/gis_set.py:111
msgid ""
"Rename/delete selected\n"
"mapset or location"
@@ -4158,49 +4346,49 @@
"ÐеÑеименоваÑÑ/ÑдалиÑÑ Ð²ÑбÑаннÑй\n"
"Ð½Ð°Ð±Ð¾Ñ Ð¸Ð»Ð¸ облаÑÑÑ"
-#: ../gui/wxpython/gis_set.py:118
+#: ../gui/wxpython/gis_set.py:116
msgid "Start GRASS"
msgstr "ÐапÑÑÑиÑÑ GRASS"
-#: ../gui/wxpython/gis_set.py:125
+#: ../gui/wxpython/gis_set.py:123
msgid "Create mapset"
msgstr "СоздаÑÑ Ð½Ð°Ð±Ð¾Ñ"
-#: ../gui/wxpython/gis_set.py:129
+#: ../gui/wxpython/gis_set.py:127
msgid "Rename mapset"
msgstr "ÐеÑеименоваÑÑ Ð½Ð°Ð±Ð¾Ñ"
msgid "Rename location"
msgstr "ÐеÑеименоваÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ"
-#: ../gui/wxpython/gis_set.py:130
+#: ../gui/wxpython/gis_set.py:128
msgid "Delete mapset"
msgstr "УдалиÑÑ Ð½Ð°Ð±Ð¾Ñ"
msgid "Delete location"
msgstr "УдалиÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ"
-#: ../gui/wxpython/gis_set.py:173
+#: ../gui/wxpython/gis_set.py:172
msgid "Welcome to GRASS GIS"
msgstr "ÐобÑо пожаловаÑÑ Ð² ÐÐС GRASS"
-#: ../gui/wxpython/gis_set.py:181
+#: ../gui/wxpython/gis_set.py:180
msgid "Enter GRASS session"
msgstr "ÐÑ
од в ÑеÑÑÐ¸Ñ GRASS"
-#: ../gui/wxpython/gis_set.py:206
+#: ../gui/wxpython/gis_set.py:207
#, python-format
msgid "ERROR: Location <%s> not found"
msgstr "ÐШÐÐÐÐ: ÐблаÑÑÑ <%s> не найдена"
-#: ../gui/wxpython/gis_set.py:218
+#: ../gui/wxpython/gis_set.py:220
#, python-format
msgid "ERROR: Mapset <%s> not found"
msgstr "ÐШÐÐÐÐ: ÐÐ°Ð±Ð¾Ñ <%s> не найден"
-#: ../gui/wxpython/gis_set.py:426 ../gui/wxpython/gis_set.py:450
+#: ../gui/wxpython/gis_set.py:419 ../gui/wxpython/gis_set.py:443
#, python-format
msgid ""
"Current name: %s\n"
@@ -4209,23 +4397,23 @@
"ТекÑÑее имÑ: %s\n"
"ÐведиÑе новое имÑ:"
-#: ../gui/wxpython/gis_set.py:427
+#: ../gui/wxpython/gis_set.py:420
msgid "Rename selected mapset"
msgstr "ÐеÑеименоваÑÑ Ð²ÑбÑаннÑй набоÑ"
-#: ../gui/wxpython/gis_set.py:438
+#: ../gui/wxpython/gis_set.py:431
msgid "Unable to rename mapset"
msgstr "Ðевозможно пеÑеименоваÑÑ Ð½Ð°Ð±Ð¾Ñ"
-#: ../gui/wxpython/gis_set.py:451
+#: ../gui/wxpython/gis_set.py:444
msgid "Rename selected location"
msgstr "ÐеÑеименоваÑÑ Ð²ÑбÑаннÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ"
-#: ../gui/wxpython/gis_set.py:464
+#: ../gui/wxpython/gis_set.py:457
msgid "Unable to rename location"
msgstr "Ðевозможно пеÑеименоваÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ"
-#: ../gui/wxpython/gis_set.py:476
+#: ../gui/wxpython/gis_set.py:469
#, python-format
msgid ""
"Do you want to continue with deleting mapset <%(mapset)s> from location <%"
@@ -4237,15 +4425,15 @@
"\n"
"ÐСРСÐÐРвÑ
одÑÑие в ÑоÑÑав набоÑа бÑдÑÑ Ð£ÐÐÐÐÐЫ!"
-#: ../gui/wxpython/gis_set.py:481
+#: ../gui/wxpython/gis_set.py:474
msgid "Delete selected mapset"
msgstr "УдалиÑÑ Ð²ÑбÑаннÑй набоÑ"
-#: ../gui/wxpython/gis_set.py:490
+#: ../gui/wxpython/gis_set.py:483
msgid "Unable to delete mapset"
msgstr "Ðевозможно ÑдалиÑÑ Ð½Ð°Ð±Ð¾Ñ"
-#: ../gui/wxpython/gis_set.py:501
+#: ../gui/wxpython/gis_set.py:494
#, python-format
msgid ""
"Do you want to continue with deleting location <%s>?\n"
@@ -4256,62 +4444,107 @@
"\n"
"ÐСРСÐÐРвÑ
одÑÑие в ÑоÑÑав облаÑÑи бÑдÑÑ Ð£ÐÐÐÐÐЫ!"
-#: ../gui/wxpython/gis_set.py:505
+#: ../gui/wxpython/gis_set.py:498
msgid "Delete selected location"
msgstr "УдалиÑÑ Ð²ÑбÑаннÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ"
-#: ../gui/wxpython/gis_set.py:516
+#: ../gui/wxpython/gis_set.py:509
msgid "Unable to delete location"
msgstr "Ðевозможно ÑдалиÑÑ Ð¾Ð±Ð»Ð°ÑÑÑ"
-#: ../gui/wxpython/gis_set.py:642
+#: ../gui/wxpython/gis_set.py:657
msgid "Choose GIS Data Directory:"
msgstr "ÐÑбеÑиÑе каÑалог Ñ ÐÐС-даннÑми:"
-#: ../gui/wxpython/gis_set.py:657
+#: ../gui/wxpython/gis_set.py:672
msgid "Enter name for new mapset:"
msgstr "ÐведиÑе Ð¸Ð¼Ñ Ð´Ð»Ñ Ð½Ð¾Ð²Ð¾Ð³Ð¾ набоÑа:"
-#: ../gui/wxpython/gis_set.py:658
+#: ../gui/wxpython/gis_set.py:673
msgid "Create new mapset"
msgstr "СоздаÑÑ Ð½Ð¾Ð²Ñй набоÑ"
-#: ../gui/wxpython/gis_set.py:671
+#: ../gui/wxpython/gis_set.py:686
#, python-format
msgid "Unable to create new mapset: %s"
msgstr "Ðевозможно ÑоздаÑÑ Ð½Ð¾Ð²Ñй набоÑ: %s"
-#: ../gui/wxpython/gis_set.py:702
+#: ../gui/wxpython/gis_set.py:720
msgid "GRASS Quickstart"
msgstr "ÐÑÑÑÑое введение в GRASS"
-#: ../gui/wxpython/wxgui.py:96
-msgid "GRASS GIS Layer Manager (Experimental Prototype)"
-msgstr "ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ Ñлоев ÐÐС GRASS (ÐкÑпеÑименÑалÑнÑй пÑоÑоÑип)"
+#: ../gui/wxpython/gis_set.py:822
+msgid "Starting GRASS for the first time"
+msgstr ""
-#: ../gui/wxpython/wxgui.py:306
+#: ../gui/wxpython/gis_set.py:823
+msgid ""
+"GRASS needs a directory in which to store its data. Create one now if you "
+"have not already done so. A popular choice is \"grassdata\", located in your "
+"home directory."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:100
+#, fuzzy
+msgid "GRASS GIS Layer Manager"
+msgstr "ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ Ð°ÑÑибÑÑивнÑÑ
ÑÐ°Ð±Ð»Ð¸Ñ GRASS GIS"
+#: ../gui/wxpython/wxgui.py:212
+msgid "Cmd >"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:213
+msgid "Click for erasing command prompt"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:314
msgid "Map layers for each display"
msgstr "Слои Ð´Ð»Ñ ÐºÐ°Ð¶Ð´Ð¾Ð³Ð¾ диÑплеÑ"
-#: ../gui/wxpython/wxgui.py:437
+#: ../gui/wxpython/wxgui.py:422 ../gui/wxpython/wxgui.py:1551
+#, fuzzy
+msgid "Do you want to save changes in the workspace?"
+msgstr "СоÑ
+#: ../gui/wxpython/wxgui.py:424 ../gui/wxpython/wxgui.py:1553
+#, fuzzy
+msgid "Do you want to store current settings to workspace file?"
+msgstr "ÐÑÐ¾ÐµÐºÑ Ð½Ðµ пÑÑÑ. СоÑ
ÑаниÑÑ ÑекÑÑие наÑÑÑойки в Ñайл пÑоекÑа?"
+#: ../gui/wxpython/wxgui.py:430
+#, python-format
+msgid ""
+"Do you want to close display %(display)d?\n"
+"\n"
+"%(message)s"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:434
+#, fuzzy
+msgid "Close display"
+msgstr "ÐÑиÑÑиÑÑ ÑодеÑжимое диÑплеÑ"
+#: ../gui/wxpython/wxgui.py:482
msgid "Type GRASS command and run by pressing ENTER"
msgstr "ÐведиÑе ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ GRASS и запÑÑÑиÑе ее, нажав ENTER"
-#: ../gui/wxpython/wxgui.py:560
+#: ../gui/wxpython/wxgui.py:610
+#, fuzzy
msgid ""
-"Workspace is not empty. Do you want to store current settings to workspace "
-"file?"
+"Current workspace is not empty. Do you want to store current settings to "
+"workspace file?"
-#: ../gui/wxpython/wxgui.py:563
-msgid "Save current settings?"
-msgstr "СоÑ
ÑаниÑÑ ÑекÑÑие наÑÑÑойки?"
+#: ../gui/wxpython/wxgui.py:613
+#, fuzzy
+msgid "Create new workspace?"
+msgstr "СоздаÑÑ Ñайл ÑабоÑей облаÑÑи"
-#: ../gui/wxpython/wxgui.py:578
+#: ../gui/wxpython/wxgui.py:638
msgid "Choose workspace file"
msgstr "ÐÑбеÑиÑе Ñайл пÑоекÑа"
-#: ../gui/wxpython/wxgui.py:642 ../gui/wxpython/wxgui.py:647
+#: ../gui/wxpython/wxgui.py:702 ../gui/wxpython/wxgui.py:707
#, python-format
msgid ""
"Reading workspace file <%s> failed. Invalid file, unable to parse XML "
@@ -4320,84 +4553,105 @@
"Ðе ÑдалоÑÑ Ð¿ÑоÑиÑаÑÑ Ñайл <%s>. ÐовÑежденнÑй Ñайл, невозможно обÑабоÑаÑÑ "
"докÑÐ¼ÐµÐ½Ñ XML."
-#: ../gui/wxpython/wxgui.py:652 ../gui/wxpython/wxgui.py:757
-#: ../gui/wxpython/wxgui.py:793
+#: ../gui/wxpython/wxgui.py:712 ../gui/wxpython/wxgui.py:817
+#: ../gui/wxpython/wxgui.py:853
msgid "Please wait, loading workspace..."
msgstr "ÐагÑÑзка пÑоекÑа, пожалÑйÑÑа подождиÑе ..."
-#: ../gui/wxpython/wxgui.py:737
+#: ../gui/wxpython/wxgui.py:797
msgid "Unable to read workspace file"
msgstr "Ðевозможно пÑоÑиÑаÑÑ Ñайл пÑоекÑа"
-#: ../gui/wxpython/wxgui.py:749 ../gui/wxpython/menustrings.py:15
+#: ../gui/wxpython/wxgui.py:809 ../gui/wxpython/menustrings.py:15
msgid "Load map layers into layer tree"
msgstr "ÐагÑÑзиÑÑ Ñлои в ÑодеÑжание"
-#: ../gui/wxpython/wxgui.py:777
+#: ../gui/wxpython/wxgui.py:837
msgid "Choose GRC file to load"
msgstr "ÐÑбеÑиÑе загÑÑжаемÑй Ñайл GRC"
-#: ../gui/wxpython/wxgui.py:816
+#: ../gui/wxpython/wxgui.py:876
msgid "Choose file to save current workspace"
msgstr "ÐÑбеÑиÑе Ñайл Ð´Ð»Ñ ÑоÑ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ ÑекÑÑего пÑоекÑа"
-#: ../gui/wxpython/wxgui.py:831 ../gui/wxpython/wxgui.py:848
+#: ../gui/wxpython/wxgui.py:891 ../gui/wxpython/wxgui.py:908
#, python-format
msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
msgstr "Файл пÑоекÑа <%s> Ñже ÑÑÑеÑÑвÑеÑ. ÐеÑезапиÑаÑÑ ÑÑÐ¾Ñ Ñайл?"
-#: ../gui/wxpython/wxgui.py:833 ../gui/wxpython/wxgui.py:851
+#: ../gui/wxpython/wxgui.py:893 ../gui/wxpython/wxgui.py:911
msgid "Save workspace"
msgstr "СоÑ
ÑаниÑÑ Ð¿ÑоекÑ"
-#: ../gui/wxpython/wxgui.py:870
+#: ../gui/wxpython/wxgui.py:930
#, python-format
msgid "Unable to open workspace file <%s> for writing."
msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл пÑоекÑа <%s> Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи."
-#: ../gui/wxpython/wxgui.py:879
+#: ../gui/wxpython/wxgui.py:939
#, python-format
msgid "Writing current settings to workspace file failed (%s)."
msgstr "СоÑ
Ñанение ÑекÑÑиÑ
наÑÑÑоек в Ñайл пÑоекÑа не ÑдалоÑÑ (%s)."
-#: ../gui/wxpython/wxgui.py:1074
+#: ../gui/wxpython/wxgui.py:1115
+#, fuzzy
+msgid "Add various raster-based map layers"
+msgstr "ÐобавиÑÑ ÑаÑÑÑовÑй Ñлой"
+#: ../gui/wxpython/wxgui.py:1119
+#, fuzzy
+msgid "Add various vector-based map layer"
+msgstr "ÐобавиÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
+#: ../gui/wxpython/wxgui.py:1136
msgid "Import DXF layers"
msgstr "ÐмпоÑÑ Ñлоев DXF"
-#: ../gui/wxpython/wxgui.py:1080
+#: ../gui/wxpython/wxgui.py:1142
msgid "Import GDAL layers"
msgstr "ÐмпоÑÑ Ñлоев GDAL"
-#: ../gui/wxpython/wxgui.py:1086
+#: ../gui/wxpython/wxgui.py:1148
msgid "Import OGR layers"
msgstr "ÐмпоÑÑ Ñлоев OGR"
-#: ../gui/wxpython/wxgui.py:1111
+#: ../gui/wxpython/wxgui.py:1170
+msgid "Nothing to import. No WMS layer selected."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1196
msgid "Attribute management is available only for vector maps."
msgstr "УпÑавление аÑÑибÑÑами доÑÑÑпно ÑолÑко Ð´Ð»Ñ Ð²ÐµÐºÑоÑнÑÑ
Ñлоев."
-#: ../gui/wxpython/wxgui.py:1123
+#: ../gui/wxpython/wxgui.py:1208
msgid "Please wait, loading attribute data..."
msgstr "ÐагÑÑзка аÑÑибÑÑивнÑÑ
даннÑÑ
, пожалÑйÑÑа подождиÑе..."
-#: ../gui/wxpython/wxgui.py:1434
-#, fuzzy, python-format
+#: ../gui/wxpython/wxgui.py:1520
+#, python-format
msgid ""
"Do you want to remove map layer(s)\n"
"%s\n"
"from layer tree?"
-msgstr "УдалиÑÑ Ñлой %s из деÑева Ñлоев?"
+msgstr ""
+"УдалиÑÑ Ñлой (Ñлои)\n"
+"%s\n"
+"из ÑпиÑка Ñлоев?"
-#: ../gui/wxpython/wxgui.py:1437
-#, fuzzy
+#: ../gui/wxpython/wxgui.py:1523
msgid "Do you want to remove selected map layer(s) from layer tree?"
-msgstr "УдалиÑÑ Ð²ÑбÑаннÑй Ñлой из ÑодеÑжаниÑ?"
+msgstr "УдалиÑÑ Ð²ÑбÑаннÑй Ñлой (Ñлои) из ÑпиÑка Ñлоев?"
-#: ../gui/wxpython/wxgui.py:1441
+#: ../gui/wxpython/wxgui.py:1527
msgid "Remove map layer"
msgstr "УдалиÑÑ Ñлой"
-#: ../gui/wxpython/wxgui.py:1467
+#: ../gui/wxpython/wxgui.py:1560
+#, fuzzy
+msgid "Quit GRASS GUI"
+msgstr "Ð ÐÐС GRASS"
+#: ../gui/wxpython/wxgui.py:1590
msgid "No map layer selected. Operation cancelled."
msgstr "Ðе вÑбÑан Ñлой. ÐпеÑаÑÐ¸Ñ Ð¿ÑеÑвана."
@@ -4420,8 +4674,9 @@
#: ../gui/wxpython/menustrings.py:8
+#, fuzzy
msgid "Save"
-msgstr ""
+msgstr "СоÑ
#: ../gui/wxpython/menustrings.py:9
#, fuzzy
@@ -5191,18 +5446,27 @@
msgstr "ÐзмениÑÑ Ð½Ð°ÑÑÑойки"
#: ../gui/wxpython/menustrings.py:191
+#, fuzzy
+msgid "Change default GUI"
+msgstr "&УÑÑановиÑÑ Ð¿Ð¾ ÑмолÑаниÑ"
+#: ../gui/wxpython/menustrings.py:192
+msgid "Changes the default GRASS graphical user interface (GUI) setting."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:193
msgid "Version"
msgstr "ÐеÑÑиÑ"
-#: ../gui/wxpython/menustrings.py:192
+#: ../gui/wxpython/menustrings.py:194
msgid "Displays version and copyright information."
msgstr "ÐоказаÑÑ Ð²ÐµÑÑÐ¸Ñ Ð¸ инÑоÑмаÑÐ¸Ñ Ð¾ копиÑайÑе."
-#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:194
+#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:196
msgid "Manage projections"
msgstr "УпÑавление пÑоекÑиÑми"
-#: ../gui/wxpython/menustrings.py:195
+#: ../gui/wxpython/menustrings.py:197
msgid ""
"Converts co-ordinate system descriptions (i.e. projection information) "
"between various formats (including GRASS format). Can also be used to create "
@@ -5212,117 +5476,117 @@
"Ð¼ÐµÐ¶Ð´Ñ ÑазлиÑнÑми ÑоÑмаÑами (вклÑÑÐ°Ñ ÑоÑÐ¼Ð°Ñ GRASS). ÐÐ¾Ð¶ÐµÑ Ñак же иÑполÑзовано "
"Ð´Ð»Ñ Ð¾Ð±Ð»Ð°ÑÑей GRASS."
-#: ../gui/wxpython/menustrings.py:196
+#: ../gui/wxpython/menustrings.py:198
msgid "Projection for current location"
msgstr "ÐÑоекÑÐ¸Ñ Ð´Ð»Ñ ÑекÑÑей облаÑÑи"
-#: ../gui/wxpython/menustrings.py:197
+#: ../gui/wxpython/menustrings.py:199
msgid "Create/edit projection information for current location"
msgstr "СоздаÑÑ/ÑедакÑиÑоваÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ пÑоекÑии Ð´Ð»Ñ ÑекÑÑей облаÑÑи"
-#: ../gui/wxpython/menustrings.py:198
+#: ../gui/wxpython/menustrings.py:200
msgid "Convert coordinates"
msgstr "ÐонвеÑÑиÑоваÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ"
-#: ../gui/wxpython/menustrings.py:199
+#: ../gui/wxpython/menustrings.py:201
msgid "Convert coordinates from one projection to another (cs2cs frontend)."
msgstr ""
"ÐонвеÑÑиÑоваÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ Ð¸Ð· одной пÑоекÑии в дÑÑгÑÑ (иÑполÑзÑÐµÑ cs2cs)"
-#: ../gui/wxpython/menustrings.py:200
+#: ../gui/wxpython/menustrings.py:202
msgid "Preferences"
msgstr "ÐаÑÑÑойки"
-#: ../gui/wxpython/menustrings.py:201
+#: ../gui/wxpython/menustrings.py:203
msgid "User GUI preferences (display font, commands, digitizer, etc.)"
msgstr ""
"ÐолÑзоваÑелÑÑкие наÑÑÑойки инÑеÑÑейÑа (ÑÑиÑÑ, командÑ, оÑиÑÑовка и Ñ.д.)"
-#: ../gui/wxpython/menustrings.py:202
+#: ../gui/wxpython/menustrings.py:204
msgid "Raster"
msgstr "РаÑÑÑ"
-#: ../gui/wxpython/menustrings.py:203
+#: ../gui/wxpython/menustrings.py:205
msgid "Develop raster map"
msgstr "ÐбÑабоÑаÑÑ ÑаÑÑÑовÑй Ñлой"
-#: ../gui/wxpython/menustrings.py:204
+#: ../gui/wxpython/menustrings.py:206
msgid "Digitize raster (requires XTerm)"
msgstr "ÐекÑоÑизоваÑÑ ÑаÑÑÑ (ÑÑебÑÐµÑ XTerm)"
-#: ../gui/wxpython/menustrings.py:205
+#: ../gui/wxpython/menustrings.py:207
msgid "Digitize raster map"
msgstr "ÐекÑоÑизоваÑÑ ÑаÑÑÑовÑй Ñлой"
-#: ../gui/wxpython/menustrings.py:206
+#: ../gui/wxpython/menustrings.py:208
msgid "Compress/decompress"
msgstr "СжаÑÑ/ÑаÑпаковаÑÑ"
-#: ../gui/wxpython/menustrings.py:207
+#: ../gui/wxpython/menustrings.py:209
msgid "Compresses and decompresses raster maps."
msgstr "СжаÑÑ Ð¸ ÑаÑпаковаÑÑ ÑаÑÑÑовÑе Ñлои."
-#: ../gui/wxpython/menustrings.py:208
+#: ../gui/wxpython/menustrings.py:210
msgid "Region boundaries"
msgstr "ÐÑаниÑÑ Ñегиона"
-#: ../gui/wxpython/menustrings.py:209
+#: ../gui/wxpython/menustrings.py:211
msgid "Sets the boundary definitions for a raster map."
msgstr "УÑÑановиÑÑ Ð³ÑаниÑÑ Ð´Ð»Ñ ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:210
+#: ../gui/wxpython/menustrings.py:212
msgid "Manage NULL values"
msgstr "УпÑавление знаÑениÑми NULL"
-#: ../gui/wxpython/menustrings.py:211
+#: ../gui/wxpython/menustrings.py:213
msgid "Creates explicitly the NULL-value bitmap file."
msgstr "СоздаÑÑ Ð±Ð¸ÑмÑп Ñайл Ñ NULL-знаÑениÑми."
-#: ../gui/wxpython/menustrings.py:212
+#: ../gui/wxpython/menustrings.py:214
msgid "Quantization"
msgstr "ÐванÑование"
-#: ../gui/wxpython/menustrings.py:213
+#: ../gui/wxpython/menustrings.py:215
msgid "Produces the quantization file for a floating-point map."
msgstr "СоздаÑÑ Ñайл кванÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð´Ð»Ñ ÑÐ»Ð¾Ñ Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей запÑÑой."
-#: ../gui/wxpython/menustrings.py:214
+#: ../gui/wxpython/menustrings.py:216
msgid "Timestamp"
msgstr "ÐÑÐµÐ¼ÐµÐ½Ð½Ð°Ñ Ð¼ÐµÑка"
-#: ../gui/wxpython/menustrings.py:215
+#: ../gui/wxpython/menustrings.py:217
msgid "Print/add/remove a timestamp for a raster map."
msgstr "ÐÑвеÑÑи/добавиÑÑ/ÑдалиÑÑ Ð²ÑеменнÑÑ Ð¼ÐµÑÐºÑ ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:216
+#: ../gui/wxpython/menustrings.py:218
msgid "Resample using aggregate statistics"
msgstr "ÐеÑеÑÑÐµÑ Ñ Ð¸ÑполÑзованием ÑÑаÑиÑÑики агÑегаÑии"
-#: ../gui/wxpython/menustrings.py:217
+#: ../gui/wxpython/menustrings.py:219
msgid "Resamples raster map layers using aggregation."
msgstr "ÐеÑеÑÑÐµÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ñ Ð¸ÑполÑзованием агÑегаÑии."
-#: ../gui/wxpython/menustrings.py:218
+#: ../gui/wxpython/menustrings.py:220
msgid "Resample using multiple methods"
msgstr "ÐеÑеÑÑÐµÑ Ð¸ÑполÑзÑÑ ÑазлиÑнÑе меÑодÑ"
-#: ../gui/wxpython/menustrings.py:219
+#: ../gui/wxpython/menustrings.py:221
msgid "Resamples raster map layers using interpolation."
msgstr "ÐеÑеÑÑÐµÑ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¸ÑполÑзÑÑ Ð¸Ð½ÑеÑполÑÑиÑ."
-#: ../gui/wxpython/menustrings.py:220
+#: ../gui/wxpython/menustrings.py:222
msgid "Resample using nearest neighbor"
msgstr "ÐеÑеÑÑÐµÑ Ð¸ÑполÑзÑÑ Ð¼ÐµÑод ближайÑего ÑоÑеда"
-#: ../gui/wxpython/menustrings.py:221
+#: ../gui/wxpython/menustrings.py:223
msgid "GRASS raster map layer data resampling capability."
msgstr "ÐозможноÑÑи пеÑеÑÑеÑа ÑаÑÑÑового ÑÐ»Ð¾Ñ GRASS."
-#: ../gui/wxpython/menustrings.py:222
+#: ../gui/wxpython/menustrings.py:224
msgid "Resample using spline tension"
msgstr "ÐеÑеÑÑÐµÑ Ñ Ð¸ÑполÑзованием Ñплайнов"
-#: ../gui/wxpython/menustrings.py:223
+#: ../gui/wxpython/menustrings.py:225
msgid ""
"Reinterpolates and optionally computes topographic analysis from input "
"raster map to a new raster map (possibly with different resolution) using "
@@ -5332,45 +5596,45 @@
"Ñ Ð¿Ð¾Ð»ÑÑением нового ÑаÑÑÑового ÑÐ»Ð¾Ñ (возможно Ñ Ð´ÑÑгим ÑазÑеÑением) "
"иÑполÑзÑÑ ÑÐ¿Ð»Ð°Ð¹Ð½Ñ Ñо Ñглаживанием."
-#: ../gui/wxpython/menustrings.py:224
+#: ../gui/wxpython/menustrings.py:226
msgid "Support file maintenance"
msgstr "Ðбновление Ñайла поддеÑжки"
-#: ../gui/wxpython/menustrings.py:225
+#: ../gui/wxpython/menustrings.py:227
msgid "Allows creation and/or modification of raster map layer support files."
msgstr "ÐозволÑÐµÑ Ñоздание и/или модиÑикаÑÐ¸Ñ Ñайлов поддеÑжки ÑаÑÑÑовÑÑ
Ñлоев."
-#: ../gui/wxpython/menustrings.py:226
+#: ../gui/wxpython/menustrings.py:228
msgid "Update map statistics"
msgstr "ÐбновиÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:227
+#: ../gui/wxpython/menustrings.py:229
msgid "Update raster map statistics"
msgstr "ÐбновиÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:228
+#: ../gui/wxpython/menustrings.py:230
#, fuzzy
msgid "Link to GDAL"
msgstr "СвÑзаÑÑ Ñ OGR"
-#: ../gui/wxpython/menustrings.py:229
+#: ../gui/wxpython/menustrings.py:231
#, fuzzy
msgid "Link GDAL supported raster file to a binary raster map layer."
msgstr "ÐмпоÑÑ ÑаÑÑÑа поддеÑживаемÑй GDAL в бинаÑнÑй ÑаÑÑÑовÑй Ñлой."
-#: ../gui/wxpython/menustrings.py:230
+#: ../gui/wxpython/menustrings.py:232
msgid "Reproject raster"
msgstr "ÐеÑепÑоекÑиÑоваÑÑ ÑаÑÑÑ"
-#: ../gui/wxpython/menustrings.py:231
+#: ../gui/wxpython/menustrings.py:233
msgid "Re-projects a raster map from one location to the current location."
msgstr "ÐеÑепÑоекÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой из одной облаÑÑи в ÑекÑÑÑÑ."
-#: ../gui/wxpython/menustrings.py:232
+#: ../gui/wxpython/menustrings.py:234
msgid "Tiling"
msgstr "Тайлинг"
-#: ../gui/wxpython/menustrings.py:233
+#: ../gui/wxpython/menustrings.py:235
msgid ""
"Produces tilings of the source projection for use in the destination region "
"and projection."
@@ -5378,59 +5642,59 @@
"СоздаÑÑ ÑÐ°Ð¹Ð»Ñ Ð² иÑÑ
одной пÑоекÑии Ð´Ð»Ñ Ð¸ÑполÑÐ·Ð¾Ð²Ð°Ð½Ð¸Ñ Ñ Ð²ÑÑ
однÑм Ñегионом и "
"пÑоекÑией."
-#: ../gui/wxpython/menustrings.py:234 ../gui/wxpython/menustrings.py:495
+#: ../gui/wxpython/menustrings.py:236 ../gui/wxpython/menustrings.py:497
msgid "Manage colors"
msgstr "УпÑавлÑÑÑ ÑвеÑами"
-#: ../gui/wxpython/menustrings.py:235 ../gui/wxpython/menustrings.py:496
+#: ../gui/wxpython/menustrings.py:237 ../gui/wxpython/menustrings.py:498
msgid "Color tables"
msgstr "ЦвеÑовÑе ÑаблиÑÑ"
-#: ../gui/wxpython/menustrings.py:236
+#: ../gui/wxpython/menustrings.py:238
msgid "Creates/modifies the color table associated with a raster map layer."
msgstr "СоздаÑÑ/измениÑÑ ÑвеÑовÑÑ ÑаблиÑÑ ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:237
+#: ../gui/wxpython/menustrings.py:239
#, fuzzy
msgid "Color tables (stddev)"
-#: ../gui/wxpython/menustrings.py:238
+#: ../gui/wxpython/menustrings.py:240
msgid "Set color rules based on stddev from a map's mean value."
msgstr ""
-#: ../gui/wxpython/menustrings.py:239 ../gui/wxpython/menustrings.py:498
+#: ../gui/wxpython/menustrings.py:241 ../gui/wxpython/menustrings.py:500
msgid "Color rules"
msgstr "ЦвеÑовÑе пÑавила"
-#: ../gui/wxpython/menustrings.py:240 ../gui/wxpython/menustrings.py:499
+#: ../gui/wxpython/menustrings.py:242 ../gui/wxpython/menustrings.py:501
msgid "Set colors interactively by entering color rules"
msgstr "ÐнÑеÑакÑивно ÑÑÑановиÑÑ ÑвеÑа ввода ÑвеÑовÑе пÑавила"
-#: ../gui/wxpython/menustrings.py:241
+#: ../gui/wxpython/menustrings.py:243
msgid "Blend 2 color rasters"
msgstr "СмеÑаÑÑ 2 ÑвеÑнÑÑ
ÑаÑÑÑа"
-#: ../gui/wxpython/menustrings.py:242
+#: ../gui/wxpython/menustrings.py:244
msgid "Blends color components of two raster maps by a given ratio."
msgstr ""
"СмеÑаÑÑ ÑвеÑовÑе компоненÑÑ Ð´Ð²ÑÑ
ÑаÑÑÑовÑÑ
Ñлоев иÑполÑзÑÑ Ð·Ð°Ð´Ð°Ð½Ð½Ð¾Ðµ "
"ÑооÑноÑение."
-#: ../gui/wxpython/menustrings.py:243
+#: ../gui/wxpython/menustrings.py:245
msgid "Create RGB"
msgstr "СоздаÑÑ RGB"
-#: ../gui/wxpython/menustrings.py:244
+#: ../gui/wxpython/menustrings.py:246
msgid ""
"Combines red, green and blue map layers into a single composite map layer."
msgstr "ÐомбиниÑоваÑÑ ÐºÑаÑнÑй, зеленÑй и Ñиний Ñлои в единÑй композиÑнÑй Ñлой."
-#: ../gui/wxpython/menustrings.py:245 ../gui/wxpython/menustrings.py:614
+#: ../gui/wxpython/menustrings.py:247 ../gui/wxpython/menustrings.py:616
msgid "RGB to HIS"
msgstr "RGB в HIS"
-#: ../gui/wxpython/menustrings.py:246
+#: ../gui/wxpython/menustrings.py:248
msgid ""
"Generates red, green and blue raster map layers combining hue, intensity and "
"saturation (HIS) values from user-specified input raster map layers."
@@ -5438,19 +5702,19 @@
"СоздаÑÑ ÐºÑаÑнÑй, зеленÑй и Ñиний Ñлои комбинаÑией знаÑений Ñона, ÑÑкоÑÑи и "
"наÑÑÑенноÑÑи (HIS) из заданнÑÑ
ÑаÑÑÑовÑÑ
Ñлоев."
-#: ../gui/wxpython/menustrings.py:247
+#: ../gui/wxpython/menustrings.py:249
msgid "Query by coordinates"
msgstr "ÐапÑÐ¾Ñ Ð¿Ð¾ кооÑдинаÑам"
-#: ../gui/wxpython/menustrings.py:248
+#: ../gui/wxpython/menustrings.py:250
msgid "Queries raster map layers on their category values and category labels."
msgstr "ÐапÑаÑÐ¸Ð²Ð°ÐµÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий и подпиÑи ÑаÑÑÑовÑÑ
Ñлоев."
-#: ../gui/wxpython/menustrings.py:249
+#: ../gui/wxpython/menustrings.py:251
msgid "Buffer rasters"
msgstr "ÐÑÑеÑизиÑоваÑÑ ÑаÑÑÑÑ"
-#: ../gui/wxpython/menustrings.py:250
+#: ../gui/wxpython/menustrings.py:252
msgid ""
"Creates a raster map layer showing buffer zones surrounding cells that "
"contain non-NULL category values."
@@ -5458,35 +5722,35 @@
"СоздаÑÑ ÑаÑÑÑовÑй Ñлой показÑваÑÑий ÑаÑÑÑовÑе Ð·Ð¾Ð½Ñ Ð¾ÐºÑÑжаÑÑие ÑÑейки "
"ÑодеÑжаÑие не-NULL знаÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑии."
-#: ../gui/wxpython/menustrings.py:251
+#: ../gui/wxpython/menustrings.py:253
msgid "Closest points"
msgstr "ÐлижайÑие ÑоÑки"
-#: ../gui/wxpython/menustrings.py:252
+#: ../gui/wxpython/menustrings.py:254
msgid "Locates the closest points between objects in two raster maps."
msgstr "ÐаÑ
Ð¾Ð´Ð¸Ñ Ð±Ð»Ð¸Ð¶Ð°Ð¹Ñие ÑоÑки Ð¼ÐµÐ¶Ð´Ñ Ð¾Ð±ÑекÑами двÑÑ
ÑаÑÑÑов."
-#: ../gui/wxpython/menustrings.py:254
+#: ../gui/wxpython/menustrings.py:256
msgid "Create a MASK for limiting raster operation"
msgstr "СоздаÑÑ MASK Ð´Ð»Ñ Ð¾Ð³ÑаниÑÐµÐ½Ð¸Ñ ÑаÑÑÑовÑÑ
опеÑаÑий"
-#: ../gui/wxpython/menustrings.py:255
+#: ../gui/wxpython/menustrings.py:257
msgid "Map calculator"
msgstr "РаÑÑÑовÑй калÑкÑлÑÑоÑ"
-#: ../gui/wxpython/menustrings.py:256
+#: ../gui/wxpython/menustrings.py:258
msgid "Map calculator for raster map algebra"
msgstr "ÐалÑкÑлÑÑÐ¾Ñ Ð´Ð»Ñ ÑаÑÑÑовой алгебÑÑ"
-#: ../gui/wxpython/menustrings.py:257
+#: ../gui/wxpython/menustrings.py:259
msgid "Neighborhood analysis"
msgstr "Ðнализ ÑоÑедÑÑва"
-#: ../gui/wxpython/menustrings.py:258
+#: ../gui/wxpython/menustrings.py:260
msgid "Moving window"
msgstr "ÐлаваÑÑее окно"
-#: ../gui/wxpython/menustrings.py:259
+#: ../gui/wxpython/menustrings.py:261
msgid ""
"Makes each cell category value a function of the category values assigned to "
"the cells around it, and stores new cell values in an output raster map "
@@ -5495,11 +5759,11 @@
"ÐадаÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÑÑеек, как ÑÑнкÑÐ¸Ñ Ð·Ð½Ð°Ñений каÑегоÑий ÑÑеек вокÑÑг, "
"ÑоÑ
ÑаниÑÑ Ð½Ð¾Ð²Ñе знаÑÐµÐ½Ð¸Ñ Ð² вÑÑ
одном ÑаÑÑÑовом Ñлое."
-#: ../gui/wxpython/menustrings.py:260
+#: ../gui/wxpython/menustrings.py:262
msgid "Neighborhood points"
msgstr "СоÑедние ÑоÑки"
-#: ../gui/wxpython/menustrings.py:261
+#: ../gui/wxpython/menustrings.py:263
msgid ""
"Makes each cell value a function of the attribute values assigned to the "
"vector points or centroids around it, and stores new cell values in an "
@@ -5508,26 +5772,26 @@
"ÐадаÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÑÑеек, как ÑÑнкÑÐ¸Ñ Ð·Ð½Ð°Ñений аÑÑибÑÑов векÑоÑнÑÑ
ÑоÑек или "
"ÑенÑÑоидов вокÑÑг ниÑ
, ÑоÑ
-#: ../gui/wxpython/menustrings.py:262
+#: ../gui/wxpython/menustrings.py:264
msgid "Overlay rasters"
msgstr "ÐаложиÑÑ ÑаÑÑÑÑ"
-#: ../gui/wxpython/menustrings.py:263
+#: ../gui/wxpython/menustrings.py:265
msgid "Cross product"
msgstr "ÐÑоÑÑ-пÑодÑкÑ"
-#: ../gui/wxpython/menustrings.py:264
+#: ../gui/wxpython/menustrings.py:266
msgid ""
"Creates a cross product of the category values from multiple raster map "
"layers."
msgstr ""
"СоздаÑÑ ÐºÑоÑÑ-пÑодÑÐºÑ Ð·Ð½Ð°Ñений каÑегоÑий из неÑколÑкиÑ
ÑаÑÑÑовÑÑ
Ñлоев."
-#: ../gui/wxpython/menustrings.py:265
+#: ../gui/wxpython/menustrings.py:267
msgid "Raster series"
msgstr "СеÑии ÑаÑÑÑов"
-#: ../gui/wxpython/menustrings.py:266
+#: ../gui/wxpython/menustrings.py:268
msgid ""
"Makes each output cell value a function of the values assigned to the "
"corresponding cells in the input raster map layers."
@@ -5535,11 +5799,11 @@
"ÐадаÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ð´Ð»Ñ Ð½Ð¾Ð²ÑÑ
ÑÑеек, как ÑÑнкÑÐ¸Ñ Ð·Ð½Ð°Ñений ÑÑеек иÑÑ
однÑÑ
"ÑаÑÑÑовÑÑ
Ñлое."
-#: ../gui/wxpython/menustrings.py:267
+#: ../gui/wxpython/menustrings.py:269
msgid "Patch raster maps"
msgstr "ÐалаÑаÑÑ ÑаÑÑÑовÑе Ñлои"
-#: ../gui/wxpython/menustrings.py:268
+#: ../gui/wxpython/menustrings.py:270
msgid ""
"Creates a composite raster map layer by using known category values from one "
"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
@@ -5547,23 +5811,23 @@
"СоздаÑÑ ÐºÐ¾Ð¼Ð¿Ð¾Ð·Ð¸ÑнÑй ÑаÑÑÑовÑй Ñлой иÑполÑзÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий ÑÑеек из "
"одного (или неÑколÑкиÑ
) Ñлоев Ð´Ð»Ñ Ð·Ð°Ð¿Ð¾Ð»Ð½ÐµÐ½Ð¸Ñ Ð·Ð½Ð°Ñений \"no data\" ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:269
+#: ../gui/wxpython/menustrings.py:271
msgid "Statistical overlay"
msgstr "СÑаÑиÑÑиÑеÑкое наложение"
-#: ../gui/wxpython/menustrings.py:270
+#: ../gui/wxpython/menustrings.py:272
msgid "Calculates category or object oriented statistics."
msgstr "РаÑÑÑиÑаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð¿Ð¾ каÑегоÑиÑм или обÑекÑам."
-#: ../gui/wxpython/menustrings.py:271
+#: ../gui/wxpython/menustrings.py:273
msgid "Solar radiance and shadows"
msgstr "СолнеÑÐ½Ð°Ñ Ð¾ÑвеÑенноÑÑÑ Ð¸ Ñени"
-#: ../gui/wxpython/menustrings.py:272
+#: ../gui/wxpython/menustrings.py:274
msgid "Solar irradiance and irradiation"
msgstr "СолнеÑÐ½Ð°Ñ Ð¾ÑвеÑенноÑÑÑ Ð¸ иÑÑадиаÑиÑ"
-#: ../gui/wxpython/menustrings.py:273
+#: ../gui/wxpython/menustrings.py:275
msgid ""
"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
"for given day, latitude, surface and atmospheric conditions. Solar "
@@ -5581,11 +5845,11 @@
"оÑвеÑÐµÐ½Ð¸Ñ ÑолнÑем и/или irradiance. ÐÐ¾Ð¶ÐµÑ Ð±ÑÑÑ Ñакже ÑÑÑен заÑенÑÑÑий ÑÑÑÐµÐºÑ "
"ÑелÑеÑа."
-#: ../gui/wxpython/menustrings.py:274
+#: ../gui/wxpython/menustrings.py:276
msgid "Shadows map"
msgstr "Слой Ñеней"
-#: ../gui/wxpython/menustrings.py:275
+#: ../gui/wxpython/menustrings.py:277
msgid ""
"Calculates cast shadow areas from sun position and DEM. Either A: exact sun "
"position is specified, or B: date/time to calculate the sun position by r."
@@ -5595,15 +5859,15 @@
"бÑÑÑ ÑÐºÐ°Ð·Ð°Ð½Ñ Ð»Ð¸Ð±Ð¾ Ð: ÑоÑное положение ÑолнÑа, либо Ð: даÑа/вÑÐµÐ¼Ñ Ð´Ð»Ñ ÐºÐ¾ÑоÑÑÑ
"надо ÑаÑÑÑиÑаÑÑ Ð¿Ð¾Ð»Ð¾Ð¶ÐµÐ½Ð¸Ðµ ÑолнÑа Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ r.sunmask."
-#: ../gui/wxpython/menustrings.py:276
+#: ../gui/wxpython/menustrings.py:278
msgid "Terrain analysis"
msgstr "Ðнализ ÑелÑеÑа"
-#: ../gui/wxpython/menustrings.py:277
+#: ../gui/wxpython/menustrings.py:279
msgid "Cumulative movement costs"
msgstr "ÐÑмÑлÑÑÐ¸Ð²Ð½Ð°Ñ Ñена пеÑемеÑениÑ"
-#: ../gui/wxpython/menustrings.py:278
+#: ../gui/wxpython/menustrings.py:280
msgid ""
"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
"between different geographic locations on an input elevation raster map "
@@ -5615,11 +5879,11 @@
"знаÑÐµÐ½Ð¸Ñ ÑÑеек коÑоÑого пÑедÑÑавлÑÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ð²ÑÑÐ¾Ñ ÐºÐ¾Ð¼Ð±Ð¸Ð½Ð¸ÑованнÑе Ñо "
"знаÑениÑми ÑаÑÑ
одов на пÑеодоление Ñ Ð´ÑÑгого ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:279
+#: ../gui/wxpython/menustrings.py:281
msgid "Cost surface"
msgstr "СÑоимоÑÑÐ½Ð°Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ"
-#: ../gui/wxpython/menustrings.py:280
+#: ../gui/wxpython/menustrings.py:282
msgid ""
"Outputs a raster map layer showing the cumulative cost of moving between "
"different geographic locations on an input raster map layer whose cell "
@@ -5629,23 +5893,23 @@
"ÑазнÑми меÑÑоположениÑми иÑÑ
одного ÑаÑÑÑового Ñлой, ÑÑи ÑÑейки имеÑÑ "
"знаÑение ÑÑоимоÑÑи."
-#: ../gui/wxpython/menustrings.py:281
+#: ../gui/wxpython/menustrings.py:283
msgid "Least cost route or flow"
msgstr "ÐÑÑÑ Ð¸Ð»Ð¸ поÑок наименÑÑей ÑÑоимоÑÑи "
-#: ../gui/wxpython/menustrings.py:282
+#: ../gui/wxpython/menustrings.py:284
msgid "Traces a flow through an elevation model on a raster map layer."
msgstr "ÐоÑÑÑоиÑÑ Ð¿Ð¾Ñок по модели ÑелÑеÑа на оÑнове ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:284
+#: ../gui/wxpython/menustrings.py:286
msgid "Creates shaded relief map from an elevation map (DEM)."
msgstr "СоздаÑÑ Ñлой Ñеневого ÑелÑеÑа из ÑÐ»Ð¾Ñ ÑелÑеÑа (DEM)."
-#: ../gui/wxpython/menustrings.py:285
+#: ../gui/wxpython/menustrings.py:287
msgid "Slope and aspect"
msgstr "ÐÑÑÑизна и ÑкÑпозиÑиÑ"
-#: ../gui/wxpython/menustrings.py:286
+#: ../gui/wxpython/menustrings.py:288
msgid ""
"Generates raster map layers of slope, aspect, curvatures and partial "
"derivatives from a raster map layer of true elevation values. Aspect is "
@@ -5655,11 +5919,11 @@
"пÑоизводнÑÑ
Ñклона иполÑзÑÑ ÑаÑÑÑовÑй Ñлой вÑÑоÑ. ÐкÑпозиÑÐ¸Ñ Ð²ÑÑиÑлÑеÑÑÑ "
"пÑоÑÑив ÑаÑовой ÑÑÑелки наÑÐ¸Ð½Ð°Ñ Ñ Ð²Ð¾ÑÑока."
-#: ../gui/wxpython/menustrings.py:287
+#: ../gui/wxpython/menustrings.py:289
msgid "Terrain parameters"
msgstr "ÐаÑамеÑÑÑ ÑелÑеÑа"
-#: ../gui/wxpython/menustrings.py:288
+#: ../gui/wxpython/menustrings.py:290
msgid ""
"Uses a multi-scale approach by taking fitting quadratic parameters to any "
"size window (via least squares)."
@@ -5667,51 +5931,51 @@
"ÐÑполÑзоваÑÑ Ð¼ÑлÑÑи-маÑÑÑабнÑй подÑ
од иÑполÑзÑÑ ÑаÑÑеÑнÑе квадÑаÑиÑнÑе "
"паÑамеÑÑÑ Ð´Ð»Ñ Ð¾ÐºÐ¾Ð½ лÑбÑÑ
ÑазмеÑов (меÑод наименÑÑиÑ
квадÑаÑов)"
-#: ../gui/wxpython/menustrings.py:289
+#: ../gui/wxpython/menustrings.py:291
msgid "Textural features"
msgstr "ТекÑÑÑÑнÑе пÑизнаки"
-#: ../gui/wxpython/menustrings.py:290
+#: ../gui/wxpython/menustrings.py:292
msgid "Generate images with textural features from a raster map."
msgstr "СоздаÑÑ Ð¸Ð·Ð¾Ð±ÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ñ ÑекÑÑÑÑнÑми пÑизнаками Ð´Ð»Ñ ÑаÑÑÑовÑÑ
Ñлоев."
-#: ../gui/wxpython/menustrings.py:291
+#: ../gui/wxpython/menustrings.py:293
msgid "Visibility"
msgstr "ÐидимоÑÑÑ"
-#: ../gui/wxpython/menustrings.py:292
+#: ../gui/wxpython/menustrings.py:294
msgid "Line-of-sight raster analysis program."
msgstr "ÐÑогÑамма ÑаÑÑÑового анализа линии видимоÑÑи."
-#: ../gui/wxpython/menustrings.py:293
+#: ../gui/wxpython/menustrings.py:295
#, fuzzy
msgid "Distance to features"
msgstr "ÐлижайÑие обÑекÑÑ"
-#: ../gui/wxpython/menustrings.py:294
+#: ../gui/wxpython/menustrings.py:296
#, fuzzy
msgid "Generates a raster map layer of distance to features in input layer."
msgstr ""
"СоздаÑÑ ÑаÑÑÑовÑй Ñлой Ñ Ð¿ÑоÑÑженнÑми зонами вÑÑаÑеннÑми вокÑÑг единиÑнÑÑ
"ÑÑеек."
-#: ../gui/wxpython/menustrings.py:295
+#: ../gui/wxpython/menustrings.py:297
msgid "Horizon angle"
msgstr ""
-#: ../gui/wxpython/menustrings.py:296
+#: ../gui/wxpython/menustrings.py:298
msgid "Horizon angle computation from a digital elevation model."
msgstr ""
-#: ../gui/wxpython/menustrings.py:297
+#: ../gui/wxpython/menustrings.py:299
msgid "Transform features"
msgstr "ТÑанÑÑоÑмиÑоваÑÑ Ð¾Ð±ÑекÑÑ"
-#: ../gui/wxpython/menustrings.py:298
+#: ../gui/wxpython/menustrings.py:300
msgid "Clump"
msgstr "ÐлаÑÑеÑизаÑиÑ"
-#: ../gui/wxpython/menustrings.py:299
+#: ../gui/wxpython/menustrings.py:301
msgid ""
"Recategorizes data in a raster map layer by grouping cells that form "
"physically discrete areas into unique categories."
@@ -5719,35 +5983,35 @@
"ÐбÑединÑÐµÑ ÑÑейки иÑÑ
одного ÑаÑÑÑа обÑазÑÑÑие диÑкÑеÑнÑе облаÑÑи и назнаÑÐ°ÐµÑ "
"им ÑникалÑнÑе каÑегоÑии."
-#: ../gui/wxpython/menustrings.py:300
+#: ../gui/wxpython/menustrings.py:302
msgid "Grow"
msgstr "ÐÑÑаÑÑиÑÑ"
-#: ../gui/wxpython/menustrings.py:301
+#: ../gui/wxpython/menustrings.py:303
msgid "Generates a raster map layer with contiguous areas grown by one cell."
msgstr ""
"ÑÑеек."
-#: ../gui/wxpython/menustrings.py:302
+#: ../gui/wxpython/menustrings.py:304
msgid "Thin"
msgstr "ÐÑоÑедиÑÑ"
-#: ../gui/wxpython/menustrings.py:303
+#: ../gui/wxpython/menustrings.py:305
msgid "Thins non-zero cells that denote linear features in a raster map layer."
msgstr ""
"ÐÑоÑедиÑÑ Ð½Ðµ-нÑлевÑе ÑÑейки пÑедÑÑавлÑÑÑие линейнÑе обÑекÑÑ Ð½Ð° ÑаÑÑÑовом "
"Ñлое."
-#: ../gui/wxpython/menustrings.py:304
+#: ../gui/wxpython/menustrings.py:306
msgid "Hydrologic modeling"
msgstr "ÐидÑологиÑеÑкое моделиÑование"
-#: ../gui/wxpython/menustrings.py:305
+#: ../gui/wxpython/menustrings.py:307
msgid "Carve stream channels"
msgstr "ÐÑоÑезаÑÑ ÐºÐ°Ð½Ð°Ð»Ñ Ð²Ð¾Ð´Ð¾Ñоков"
-#: ../gui/wxpython/menustrings.py:306
+#: ../gui/wxpython/menustrings.py:308
msgid ""
"Takes vector stream data, transforms it to raster and subtracts depth from "
"the output DEM."
@@ -5755,19 +6019,19 @@
"ÐÑбÑаÑÑ Ð²ÐµÐºÑоÑнÑе водоÑоки, ÑÑанÑÑоÑмиÑоваÑÑ Ð¸Ñ
в ÑаÑÑÑ Ð¸ вÑÑеÑÑÑ Ð³Ð»ÑÐ±Ð¸Ð½Ñ Ð¸Ð· "
"вÑÑ
одного DEM."
-#: ../gui/wxpython/menustrings.py:307
+#: ../gui/wxpython/menustrings.py:309
msgid "Fill lake"
msgstr "ÐаполниÑÑ Ð¾Ð·ÐµÑо"
-#: ../gui/wxpython/menustrings.py:308
+#: ../gui/wxpython/menustrings.py:310
msgid "Fills lake from seed at given level"
msgstr "ÐаполниÑÑ Ð¾Ð·ÐµÑо из заÑÑавки на заданном ÑÑовне"
-#: ../gui/wxpython/menustrings.py:309
+#: ../gui/wxpython/menustrings.py:311
msgid "Depressionless map and flowlines"
msgstr "Слой без депÑеÑÑий и линии ÑÑока"
-#: ../gui/wxpython/menustrings.py:310
+#: ../gui/wxpython/menustrings.py:312
msgid ""
"Filters and generates a depressionless elevation map and a flow direction "
"map from a given elevation layer."
@@ -5775,19 +6039,19 @@
"ÐÑÑилÑÑÑоваÑÑ Ð¸ ÑоздаÑÑ Ñлой вÑÑÐ¾Ñ Ð±ÐµÐ· депÑеÑÑий и Ñлой напÑавлений поÑоков "
"из имеÑÑегоÑÑ ÑÐ»Ð¾Ñ Ð²ÑÑоÑ."
-#: ../gui/wxpython/menustrings.py:311
+#: ../gui/wxpython/menustrings.py:313
msgid "Flow accumulation"
msgstr "ÐккÑмÑлÑÑÐ¸Ñ ÑÑока"
-#: ../gui/wxpython/menustrings.py:312
+#: ../gui/wxpython/menustrings.py:314
msgid "Flow computation for massive grids (Float version)."
msgstr "РаÑÑÐµÑ Ð¿Ð¾Ñока Ð´Ð»Ñ Ð¼Ð°ÑÑивнÑÑ
гÑидов (веÑÑÐ¸Ñ Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей запÑÑой)"
-#: ../gui/wxpython/menustrings.py:313
+#: ../gui/wxpython/menustrings.py:315
msgid "Flow lines"
msgstr "Ðинии ÑÑока"
-#: ../gui/wxpython/menustrings.py:314
+#: ../gui/wxpython/menustrings.py:316
msgid ""
"Construction of slope curves (flowlines), flowpath lengths, and flowline "
"densities (upslope areas) from a raster digital elevation model (DEM)"
@@ -5795,21 +6059,21 @@
"РаÑÑÐµÑ ÐºÑÑÑÐ¸Ð·Ð½Ñ Ñклонов (линий ÑÑока), Ð´Ð»Ð¸Ð½Ñ ÑÑока и плоÑноÑÑи поÑоков из "
"ÑаÑÑÑовой ÑиÑÑовой модели ÑелÑеÑа (ЦÐÐ )"
-#: ../gui/wxpython/menustrings.py:315
+#: ../gui/wxpython/menustrings.py:317
msgid "SIMWE Overland flow modeling"
msgstr "SIMWE моделиÑование повеÑÑ
ноÑÑного ÑÑока"
-#: ../gui/wxpython/menustrings.py:316
+#: ../gui/wxpython/menustrings.py:318
msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
msgstr ""
"ÐидÑологиÑеÑÐºÐ°Ñ ÑимÑлÑÑÐ¸Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑного ÑÑока Ñ Ð¸ÑполÑзованием меÑода "
"вÑбоÑа ÑÑаекÑоÑий (SIMWE)"
-#: ../gui/wxpython/menustrings.py:317
+#: ../gui/wxpython/menustrings.py:319
msgid "SIMWE Sediment flux modeling"
msgstr "SIMWE-моделиÑование наноÑнÑÑ
поÑоков "
-#: ../gui/wxpython/menustrings.py:318
+#: ../gui/wxpython/menustrings.py:320
msgid ""
"Sediment transport and erosion/deposition simulation using path sampling "
"method (SIMWE)"
@@ -5817,63 +6081,63 @@
"СимÑлÑÑÐ¸Ñ Ð¿ÐµÑеноÑа и ÑÑозии/оÑÐ»Ð¾Ð¶ÐµÐ½Ð¸Ñ Ð½Ð°Ð½Ð¾Ñов иÑполÑзÑÑ Ð¼ÐµÑод линейной "
"вÑбоÑки (SIMWE)"
-#: ../gui/wxpython/menustrings.py:319
+#: ../gui/wxpython/menustrings.py:321
msgid "Topographic index map"
msgstr "Слой индекÑа ÑелÑеÑа"
-#: ../gui/wxpython/menustrings.py:320
+#: ../gui/wxpython/menustrings.py:322
msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
msgstr "Ð¡Ð¾Ð·Ð´Ð°ÐµÑ Ñлой индекÑа ÑелÑеÑа [ln(a/tan(beta))] ÑÐ»Ð¾Ñ Ð²ÑÑоÑ"
-#: ../gui/wxpython/menustrings.py:321
+#: ../gui/wxpython/menustrings.py:323
msgid "TOPMODEL simulation"
msgstr "СимÑлÑÑÐ¸Ñ TOPMODEL"
-#: ../gui/wxpython/menustrings.py:322
+#: ../gui/wxpython/menustrings.py:324
msgid "Simulates TOPMODEL which is a physically based hydrologic model."
msgstr "СимÑлиÑÑÐµÑ ÑизиÑеÑки обоÑнованнÑÑ Ð³Ð¸Ð´ÑологиÑеÑкÑÑ Ð¼Ð¾Ð´ÐµÐ»Ñ TOPMODEL."
-#: ../gui/wxpython/menustrings.py:323
+#: ../gui/wxpython/menustrings.py:325
msgid "Watershed subbasins"
msgstr "ÐодоÑбоÑнÑе ÑÑббаÑÑейнÑ"
-#: ../gui/wxpython/menustrings.py:324
+#: ../gui/wxpython/menustrings.py:326
msgid "Generates a raster map layer showing watershed subbasins."
msgstr "СоздаÑÑ ÑаÑÑÑовÑй Ñлой, показÑваÑÑий водоÑбоÑнÑе ÑÑббаÑÑейнÑ"
-#: ../gui/wxpython/menustrings.py:325
+#: ../gui/wxpython/menustrings.py:327
msgid "Watershed analysis"
msgstr "Ðнализ водоÑбоÑов"
-#: ../gui/wxpython/menustrings.py:326
+#: ../gui/wxpython/menustrings.py:328
msgid "Watershed basin analysis program."
msgstr "ÐÑогÑамма анализа водоÑбоÑного баÑÑейна."
-#: ../gui/wxpython/menustrings.py:327
+#: ../gui/wxpython/menustrings.py:329
msgid "Watershed basin creation"
msgstr "Создание водоÑбоÑного баÑÑейна"
-#: ../gui/wxpython/menustrings.py:328
+#: ../gui/wxpython/menustrings.py:330
msgid "Watershed basin creation program."
msgstr "ÐÑогÑамма ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ Ð²Ð¾Ð´Ð¾ÑбоÑного баÑÑейна."
-#: ../gui/wxpython/menustrings.py:329
+#: ../gui/wxpython/menustrings.py:331
msgid "Landscape structure modeling"
msgstr "СÑÑÑкÑÑÑное моделиÑование ландÑаÑÑа"
-#: ../gui/wxpython/menustrings.py:330
+#: ../gui/wxpython/menustrings.py:332
msgid "Set up (requires XTerm)"
msgstr "УÑÑановиÑÑ (ÑÑебÑеÑÑÑ XTerm)"
-#: ../gui/wxpython/menustrings.py:331 ../gui/wxpython/menustrings.py:339
+#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:341
msgid "Set up sampling and analysis framework"
msgstr "ÐадаÑÑ ÑÑ
ÐµÐ¼Ñ Ð°Ð½Ð°Ð»Ð¸Ð·Ð° и ÑÑмплинга"
-#: ../gui/wxpython/menustrings.py:332
+#: ../gui/wxpython/menustrings.py:334
msgid "Analyze landscape"
msgstr "ÐÑовеÑÑи анализ ландÑаÑÑа"
-#: ../gui/wxpython/menustrings.py:333
+#: ../gui/wxpython/menustrings.py:335
msgid ""
"Contains a set of measures for attributes, diversity, texture, "
"juxtaposition, and edge."
@@ -5881,11 +6145,11 @@
"СодеÑÐ¶Ð¸Ñ Ð½Ð°Ð±Ð¾Ñ Ð¸Ð·Ð¼ÐµÑений по аÑÑибÑÑам, ÑазнообÑазиÑ, ÑекÑÑÑÑе, "
"ÑопÑикоÑÐ½Ð¾Ð²ÐµÐ½Ð¸Ñ Ð¸ гÑаниÑам."
-#: ../gui/wxpython/menustrings.py:334
+#: ../gui/wxpython/menustrings.py:336
msgid "Analyze patches"
msgstr "ÐÑоанализиÑоваÑÑ ÑÑаÑÑки"
-#: ../gui/wxpython/menustrings.py:335
+#: ../gui/wxpython/menustrings.py:337
msgid ""
"Calculates attribute, patch size, core (interior) size, shape, fractal "
"dimension, and perimeter measures for sets of patches in a landscape."
@@ -5893,11 +6157,11 @@
"РаÑÑÑиÑаÑÑ Ð°ÑÑибÑÑÑ, ÑÐ°Ð·Ð¼ÐµÑ ÑÑаÑÑка, ÑÐ°Ð·Ð¼ÐµÑ ÑдÑа, ÑоÑмÑ, ÑÑакÑалÑнÑÑ "
"ÑазмеÑноÑÑÑ Ð¸ пеÑимеÑÑ Ð´Ð»Ñ Ð½Ð°Ð±Ð¾Ñа ÑÑаÑÑков ландÑаÑÑа."
-#: ../gui/wxpython/menustrings.py:336
+#: ../gui/wxpython/menustrings.py:338
msgid "Output"
msgstr "ÐÑвод"
-#: ../gui/wxpython/menustrings.py:337
+#: ../gui/wxpython/menustrings.py:339
msgid ""
"Displays the boundary of each r.le patch and shows how the boundary is "
"traced, displays the attribute, size, perimeter and shape indices for each "
@@ -5907,38 +6171,38 @@
"оÑобÑÐ°Ð¶Ð°ÐµÑ Ð°ÑÑибÑÑÑ, ÑазмеÑ, пеÑимеÑÑ Ð¸ индекÑÑ ÑоÑÐ¼Ñ Ð´Ð»Ñ ÐºÐ°Ð¶Ð´Ð¾Ð³Ð¾ пÑÑна и "
"ÑоÑ
ÑанÑÐµÑ Ð´Ð°Ð½Ð½Ñе в вÑÑ
одной Ñайл."
-#: ../gui/wxpython/menustrings.py:338
+#: ../gui/wxpython/menustrings.py:340
msgid "Landscape patch analysis"
msgstr "Ðнализ ÑÑаÑÑков ландÑаÑÑа"
-#: ../gui/wxpython/menustrings.py:340
+#: ../gui/wxpython/menustrings.py:342
msgid "Configuration editor for r.li.'index'"
msgstr "РедакÑÐ¾Ñ ÐºÐ¾Ð½ÑигÑÑаÑии Ð´Ð»Ñ r.li.'index'"
-#: ../gui/wxpython/menustrings.py:341
+#: ../gui/wxpython/menustrings.py:343
msgid "Edge density"
msgstr "ÐлоÑноÑÑÑ Ð³ÑаниÑ"
-#: ../gui/wxpython/menustrings.py:342
+#: ../gui/wxpython/menustrings.py:344
msgid ""
"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
"РаÑÑÑиÑаÑÑ Ð¸Ð½Ð´ÐµÐºÑ Ð¿Ð»Ð¾ÑноÑÑи гÑÐ°Ð½Ð¸Ñ ÑаÑÑÑового ÑлоÑ, иÑполÑзÑÑ Ð°Ð»Ð³Ð¾ÑиÑм 4-Ñ
"ближайÑиÑ
ÑоÑедей"
-#: ../gui/wxpython/menustrings.py:343
+#: ../gui/wxpython/menustrings.py:345
msgid "Contrast weighted edge density"
msgstr "ÐлоÑноÑÑÑ Ð³ÑÐ°Ð½Ð¸Ñ Ð²Ð·Ð²ÐµÑÐµÐ½Ð½Ð°Ñ Ð¿Ð¾ конÑÑаÑÑÑ"
-#: ../gui/wxpython/menustrings.py:344
+#: ../gui/wxpython/menustrings.py:346
msgid "Calculates contrast weighted edge density index on a raster map"
msgstr "ÐÑÑиÑлиÑÑ Ð¿Ð»Ð¾ÑноÑÑÑ Ð³ÑÐ°Ð½Ð¸Ñ Ð²Ð·Ð²ÐµÑеннÑÑ Ð¿Ð¾ конÑÑаÑÑÑ Ð´Ð»Ñ ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:345
+#: ../gui/wxpython/menustrings.py:347
msgid "Patch area mean"
msgstr "СÑеднÑÑ Ð¿Ð»Ð¾ÑÐ°Ð´Ñ ÑÑаÑÑка"
-#: ../gui/wxpython/menustrings.py:346
+#: ../gui/wxpython/menustrings.py:348
msgid ""
"Calculates mean patch size index on a raster map, using a 4 neighbour "
"algorithm"
@@ -5946,97 +6210,97 @@
"ÐÑÑиÑлиÑÑ Ð¸Ð½Ð´ÐµÐºÑ ÑÑеднего ÑазмеÑа ÑÑаÑÑка Ð´Ð»Ñ ÑаÑÑÑа, иÑполÑзÑÑ Ð°Ð»Ð³Ð¾ÑиÑм 4 "
"ближайÑиÑ
ÑоÑедей."
-#: ../gui/wxpython/menustrings.py:347
+#: ../gui/wxpython/menustrings.py:349
msgid "Patch area range"
msgstr "Ðиапазон плоÑадей ÑÑаÑÑков"
-#: ../gui/wxpython/menustrings.py:348
+#: ../gui/wxpython/menustrings.py:350
msgid "Calculates range of patch area size on a raster map"
msgstr "РаÑÑÑиÑаÑÑ Ð´Ð¸Ð°Ð¿Ð°Ð·Ð¾Ð½ плоÑадей ÑÑаÑÑков ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:349
+#: ../gui/wxpython/menustrings.py:351
msgid "Patch area Std Dev"
msgstr "СÑандаÑÑное оÑклонение плоÑади ÑÑаÑÑков"
-#: ../gui/wxpython/menustrings.py:350
+#: ../gui/wxpython/menustrings.py:352
msgid "Calculates standard deviation of patch area a raster map"
msgstr "РаÑÑÑиÑаÑÑ ÑÑандаÑÑное оÑклонение плоÑади ÑÑаÑÑков ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:351
+#: ../gui/wxpython/menustrings.py:353
msgid "Patch area Coeff Var"
msgstr "ÐоÑÑÑиÑÐ¸ÐµÐ½Ñ Ð²Ð°ÑиаÑии плоÑади ÑÑаÑÑка"
-#: ../gui/wxpython/menustrings.py:352
+#: ../gui/wxpython/menustrings.py:354
msgid "Calculates coefficient of variation of patch area on a raster map"
msgstr "РаÑÑÑиÑÑÐ²Ð°ÐµÑ ÐºÐ¾ÑÑÑиÑÐ¸ÐµÐ½Ñ Ð²Ð°ÑиаÑии плоÑади ÑÑаÑÑка ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:353
+#: ../gui/wxpython/menustrings.py:355
msgid "Patch density"
msgstr "ÐлоÑноÑÑÑ ÑÑаÑÑков"
-#: ../gui/wxpython/menustrings.py:354
+#: ../gui/wxpython/menustrings.py:356
msgid ""
"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
"РаÑÑÑиÑаÑÑ Ð¸Ð½Ð´ÐµÐºÑ Ð¿Ð»Ð¾ÑноÑÑи ÑÑаÑÑков ÑаÑÑÑового ÑлоÑ, иÑполÑзÑÑ Ð°Ð»Ð³Ð¾ÑиÑм 4-Ñ
"ближайÑиÑ
ÑоÑедей"
-#: ../gui/wxpython/menustrings.py:355
+#: ../gui/wxpython/menustrings.py:357
msgid "Patch number"
msgstr "ÐолиÑеÑÑво ÑÑаÑÑков"
-#: ../gui/wxpython/menustrings.py:356
+#: ../gui/wxpython/menustrings.py:358
msgid ""
"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
msgstr ""
"РаÑÑÑиÑаÑÑ Ð¸Ð½Ð´ÐµÐºÑ ÐºÐ¾Ð»Ð¸ÑеÑÑва ÑÑаÑÑков ÑаÑÑÑового ÑлоÑ, иÑполÑзÑÑ Ð°Ð»Ð³Ð¾ÑиÑм 4-"
"Ñ
ближайÑиÑ
ÑоÑедей"
-#: ../gui/wxpython/menustrings.py:357
+#: ../gui/wxpython/menustrings.py:359
msgid "Dominance's diversity"
msgstr "ÐоминанÑное ÑазнообÑазие"
-#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:364
+#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:366
msgid "Calculates dominance's diversity index on a raster map"
msgstr "РаÑÑÑиÑаÑÑ Ð¸Ð½Ð´ÐµÐºÑ Ð´Ð¾Ð¼Ð¸Ð½Ð°Ð½Ñного ÑазнообÑÐ°Ð·Ð¸Ñ ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:359
+#: ../gui/wxpython/menustrings.py:361
msgid "Shannon's diversity"
msgstr "РазнообÑазие Шеннона"
-#: ../gui/wxpython/menustrings.py:360
+#: ../gui/wxpython/menustrings.py:362
msgid "Calculates Shannon's diversity index on a raster map"
msgstr "РаÑÑÑиÑаÑÑ Ð¸Ð½Ð´ÐµÐºÑ ÑазнообÑÐ°Ð·Ð¸Ñ Ð¨ÐµÐ½Ð½Ð¾Ð½Ð° Ð´Ð»Ñ ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:361
+#: ../gui/wxpython/menustrings.py:363
msgid "Simpson's diversity"
msgstr "РазнообÑазие СимпÑона"
-#: ../gui/wxpython/menustrings.py:362
+#: ../gui/wxpython/menustrings.py:364
msgid "Calculates Simpson's diversity index on a raster map"
msgstr "РаÑÑÑиÑаÑÑ Ð¸Ð½Ð´ÐµÐºÑ ÑазнообÑÐ°Ð·Ð¸Ñ Ð¡Ð¸Ð¼Ð¿Ñона Ð´Ð»Ñ ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:363
+#: ../gui/wxpython/menustrings.py:365
msgid "Richness"
msgstr "ÐогаÑÑÑво"
-#: ../gui/wxpython/menustrings.py:365
+#: ../gui/wxpython/menustrings.py:367
msgid "Shape index"
msgstr "ÐÐ½Ð´ÐµÐºÑ ÑоÑмÑ"
-#: ../gui/wxpython/menustrings.py:366
+#: ../gui/wxpython/menustrings.py:368
msgid "Calculates shape index on a raster map"
msgstr "РаÑÑÑиÑаÑÑ Ð¸Ð½Ð´ÐµÐºÑ ÑоÑÐ¼Ñ Ð´Ð»Ñ ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:367
+#: ../gui/wxpython/menustrings.py:369
msgid "Wildfire modeling"
msgstr "ÐоделиÑование пожаÑов"
-#: ../gui/wxpython/menustrings.py:368
+#: ../gui/wxpython/menustrings.py:370
msgid "Rate of spread"
msgstr "СкоÑоÑÑÑ ÑаÑпÑоÑÑÑанениÑ"
-#: ../gui/wxpython/menustrings.py:369
+#: ../gui/wxpython/menustrings.py:371
msgid ""
"Generates three, or four raster map layers showing 1) the base "
"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
@@ -6048,11 +6312,11 @@
"ROS, 3) напÑавление макÑималÑной ROS, и опÑионалÑно 4) макÑималÑное "
"ÑаÑÑÑоÑние поÑенÑиалÑного обнаÑÑжениÑ."
-#: ../gui/wxpython/menustrings.py:370
+#: ../gui/wxpython/menustrings.py:372
msgid "Least-cost spread paths"
msgstr "ТÑаекÑоÑии минималÑной ÑÑоимоÑÑи ÑаÑпÑоÑÑÑанениÑ"
-#: ../gui/wxpython/menustrings.py:371
+#: ../gui/wxpython/menustrings.py:373
msgid ""
"Recursively traces the least cost path backwards to cells from which the "
"cumulative cost was determined."
@@ -6060,11 +6324,11 @@
"РекÑÑÑивно пÑоÑледиÑÑ Ð¿ÑÑÑ Ð½Ð°Ð¸Ð¼ÐµÐ½ÑÑей ÑÑоимоÑÑи к ÑÑейкам Ð´Ð»Ñ ÐºÐ¾ÑоÑÑÑ
бÑла "
"опÑеделена кÑмÑлÑÑÐ¸Ð²Ð½Ð°Ñ ÑÑоимоÑÑÑ."
-#: ../gui/wxpython/menustrings.py:372
+#: ../gui/wxpython/menustrings.py:374
msgid "Anisotropic spread simulation"
msgstr "ÐоделиÑование анизоÑÑопного ÑаÑпÑоÑÑÑанениÑ"
-#: ../gui/wxpython/menustrings.py:373
+#: ../gui/wxpython/menustrings.py:375
msgid ""
"It optionally produces raster maps to contain backlink UTM coordinates for "
"tracing spread paths."
@@ -6072,23 +6336,23 @@
"Ðо вÑбоÑÑ ÑÐ¾Ð·Ð´Ð°ÐµÑ ÑаÑÑÑовÑе Ñлои ÑодеÑжаÑие ÑвÑзнÑе UTM кооÑдинаÑÑ Ð´Ð»Ñ "
"оÑÑÐ»ÐµÐ¶Ð¸Ð²Ð°Ð½Ð¸Ñ Ð¿ÑÑей ÑаÑпÑоÑÑÑанениÑ."
-#: ../gui/wxpython/menustrings.py:374
+#: ../gui/wxpython/menustrings.py:376
msgid "Change category values and labels"
msgstr "ÐзмениÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий и подпиÑи"
-#: ../gui/wxpython/menustrings.py:375
+#: ../gui/wxpython/menustrings.py:377
msgid "Interactively edit category values"
msgstr "ÐнÑеÑакÑивное ÑедакÑиÑование знаÑений каÑегоÑий"
-#: ../gui/wxpython/menustrings.py:376
+#: ../gui/wxpython/menustrings.py:378
msgid "Interactively edit cell values in a raster map."
msgstr "ÐнÑеÑакÑивно ÑедакÑиÑоваÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÑÑеек ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:377
+#: ../gui/wxpython/menustrings.py:379
msgid "Reclassify by size"
msgstr "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ Ð¿Ð¾ ÑазмеÑÑ"
-#: ../gui/wxpython/menustrings.py:378
+#: ../gui/wxpython/menustrings.py:380
msgid ""
"Reclasses a raster map greater or less than user specified area size (in "
"hectares)"
@@ -6096,21 +6360,21 @@
"ÐеÑеклаÑÑиÑиÑиÑоваÑÑ ÑаÑÑÑовÑй Ñлой болÑÑе или менÑÑе Ñем плоÑÐ°Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ð°Ñ "
"полÑзоваÑелем (в гекÑаÑаÑ
-#: ../gui/wxpython/menustrings.py:379
+#: ../gui/wxpython/menustrings.py:381
msgid "Reclassify interactively"
msgstr "ÐнÑеÑакÑÐ¸Ð²Ð½Ð°Ñ Ð¿ÐµÑеклаÑÑиÑикаÑиÑ"
-#: ../gui/wxpython/menustrings.py:380
+#: ../gui/wxpython/menustrings.py:382
msgid "Reclassify raster categories interactively by entering reclass rules"
msgstr ""
"ÐнÑеÑакÑивно пеÑеклаÑÑиÑиÑиÑоваÑÑ ÐºÐ°ÑегоÑии ÑаÑÑÑа пÑÑем Ð²Ð²ÐµÐ´ÐµÐ½Ð¸Ñ Ð¿Ñавил "
"пеÑеклаÑÑиÑикаÑии"
-#: ../gui/wxpython/menustrings.py:381
+#: ../gui/wxpython/menustrings.py:383
msgid "Reclassify using rules file"
msgstr "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ, иÑполÑзÑÑ Ñайл пÑавил"
-#: ../gui/wxpython/menustrings.py:382
+#: ../gui/wxpython/menustrings.py:384
msgid ""
"Creates a new map layer whose category values are based upon a "
"reclassification of the categories in an existing raster map layer."
@@ -6118,11 +6382,11 @@
"СоздаÑÑ Ð½Ð¾Ð²Ñй ÑаÑÑÑовÑй Ñлой, ÑÑи знаÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий бÑдÑÑ Ð¾ÑÐ½Ð¾Ð²Ð°Ð½Ñ Ð½Ð° "
"пеÑеклаÑÑиÑикаÑии каÑегоÑий ÑÑÑеÑÑвÑÑÑего ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:383
+#: ../gui/wxpython/menustrings.py:385
msgid "Recode interactively"
msgstr "ÐнÑеÑакÑÐ¸Ð²Ð½Ð°Ñ Ð¿ÐµÑекодиÑовка"
-#: ../gui/wxpython/menustrings.py:384
+#: ../gui/wxpython/menustrings.py:386
msgid ""
"Recode raster categories interactively by entering recode rules (create new "
"raster map)"
@@ -6130,30 +6394,30 @@
"ÐÑполниÑÑ Ð¸Ð½ÑеÑакÑивнÑÑ Ð¿ÐµÑекодиÑÐ¾Ð²ÐºÑ ÐºÐ°ÑегоÑий ÑаÑÑÑа пÑÑем Ð²Ð²ÐµÐ´ÐµÐ½Ð¸Ñ Ð¿Ñавил "
"пеÑекодиÑовки (ÑоздаÑÑ Ð½Ð¾Ð²Ñй ÑаÑÑÑовÑй Ñлой)"
-#: ../gui/wxpython/menustrings.py:385
+#: ../gui/wxpython/menustrings.py:387
msgid "Recode using rules file"
msgstr "ÐеÑекодиÑоваÑÑ, иÑполÑзÑÑ Ñайл пÑавил"
-#: ../gui/wxpython/menustrings.py:386
+#: ../gui/wxpython/menustrings.py:388
msgid ""
"r.recode.rules - Use ascii rules file to recode categories in raster map"
msgstr ""
"r.recode.rules - иÑполÑзÑйÑе ascii-Ñайл пÑавил Ð´Ð»Ñ Ñого, ÑÑÐ¾Ð±Ñ "
"пеÑекодиÑоваÑÑ ÐºÐ°ÑегоÑии в ÑаÑÑÑовом Ñлое"
-#: ../gui/wxpython/menustrings.py:387
+#: ../gui/wxpython/menustrings.py:389
msgid "Rescale"
msgstr "ÐзмениÑÑ Ð¼Ð°ÑÑÑаб"
-#: ../gui/wxpython/menustrings.py:388
+#: ../gui/wxpython/menustrings.py:390
msgid "Rescales the range of category values in a raster map layer."
msgstr "ÐзмениÑÑ Ð¼Ð°ÑÑÑаб знаÑений каÑегоÑий ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:389
+#: ../gui/wxpython/menustrings.py:391
msgid "Rescale with histogram"
msgstr "ÐзмениÑÑ Ð¼Ð°ÑÑÑаб Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ Ð³Ð¸ÑÑогÑаммÑ"
-#: ../gui/wxpython/menustrings.py:390
+#: ../gui/wxpython/menustrings.py:392
msgid ""
"Rescales histogram equalized the range of category values in a raster map "
"layer."
@@ -6161,35 +6425,35 @@
"ÐаÑÑÑабиÑоваÑÑ Ð³Ð¸ÑÑогÑÐ°Ð¼Ð¼Ñ ÑÑÐ°Ð²Ð½Ð¸Ð²Ð°Ð½Ð¸Ñ Ð´Ð¸Ð°Ð¿Ð°Ð·Ð¾Ð½Ð° знаÑений каÑегоÑий в "
"ÑаÑÑÑовом Ñлое."
-#: ../gui/wxpython/menustrings.py:391
+#: ../gui/wxpython/menustrings.py:393
msgid "Concentric circles"
msgstr "ÐонÑенÑÑиÑеÑкие окÑÑжноÑÑи"
-#: ../gui/wxpython/menustrings.py:392
+#: ../gui/wxpython/menustrings.py:394
msgid "Creates a raster map containing concentric rings around a given point."
msgstr ""
"СоздаÑÑ ÑаÑÑÑовÑй Ñлой, ÑодеÑжаÑий конÑенÑÑиÑеÑкие окÑÑжноÑÑи вокÑÑг данной "
"ÑоÑки"
-#: ../gui/wxpython/menustrings.py:393
+#: ../gui/wxpython/menustrings.py:395
msgid "Generate random cells"
msgstr "ÐенеÑиÑоваÑÑ ÑлÑÑайнÑе ÑÑейки"
-#: ../gui/wxpython/menustrings.py:394
+#: ../gui/wxpython/menustrings.py:396
msgid "Random cells"
msgstr "СлÑÑайнÑе ÑÑейки"
-#: ../gui/wxpython/menustrings.py:395
+#: ../gui/wxpython/menustrings.py:397
msgid "Generates random cell values with spatial dependence."
msgstr ""
"ÐенеÑиÑоваÑÑ ÑлÑÑайнÑе знаÑÐµÐ½Ð¸Ñ Ð´Ð»Ñ ÑÑеек Ñ ÑÑеÑом пÑоÑÑÑанÑÑвенной "
"завиÑимоÑÑи."
-#: ../gui/wxpython/menustrings.py:396
+#: ../gui/wxpython/menustrings.py:398
msgid "Random cells and vector points"
msgstr "СлÑÑайнÑе ÑÑейки и векÑоÑнÑе ÑоÑки"
-#: ../gui/wxpython/menustrings.py:397
+#: ../gui/wxpython/menustrings.py:399
msgid ""
"Creates a raster map layer and vector point map containing randomly located "
"sites."
@@ -6197,23 +6461,23 @@
"СоздаÑÑ ÑаÑÑÑовÑй Ñлой или векÑоÑнÑй ÑоÑеÑнÑй Ñлой, ÑодеÑжаÑий ÑлÑÑайно "
"ÑаÑположеннÑе обÑекÑÑ."
-#: ../gui/wxpython/menustrings.py:398
+#: ../gui/wxpython/menustrings.py:400
msgid "Generate surfaces"
msgstr "ÐенеÑиÑоваÑÑ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑи"
-#: ../gui/wxpython/menustrings.py:399
+#: ../gui/wxpython/menustrings.py:401
msgid "Fractal surface"
msgstr "ФÑакÑалÑÐ½Ð°Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ"
-#: ../gui/wxpython/menustrings.py:400
+#: ../gui/wxpython/menustrings.py:402
msgid "Creates a fractal surface of a given fractal dimension."
msgstr "СоздаÑÑ ÑÑакÑалÑнÑÑ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ Ð·Ð°Ð´Ð°Ð½Ð½Ð¾Ð¹ ÑÑакÑалÑной ÑазмеÑноÑÑи."
-#: ../gui/wxpython/menustrings.py:401
+#: ../gui/wxpython/menustrings.py:403
msgid "Gaussian kernel density surface"
msgstr "ÐовеÑÑ
ноÑÑÑ Ð¿Ð»Ð¾ÑноÑÑи ÑÑнкÑии ÐаÑÑÑа"
-#: ../gui/wxpython/menustrings.py:402
+#: ../gui/wxpython/menustrings.py:404
msgid ""
"Generates a raster density map from vector points data using a moving 2D "
"isotropic Gaussian kernel or optionally generates a vector density map on "
@@ -6223,11 +6487,11 @@
"гаÑÑÑово ÑдÑо или по вÑбоÑÑ ÑоздаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой плоÑноÑÑи Ð´Ð»Ñ Ð²ÐµÐºÑоÑной "
"ÑеÑи Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ 1D ÑдÑа."
-#: ../gui/wxpython/menustrings.py:403
+#: ../gui/wxpython/menustrings.py:405
msgid "Gaussian deviates surface"
msgstr "ÐовеÑÑ
ноÑÑÑ ÐаÑÑÑовÑÑ
оÑклонений"
-#: ../gui/wxpython/menustrings.py:404
+#: ../gui/wxpython/menustrings.py:406
msgid ""
"GRASS module to produce a raster map layer of gaussian deviates whose mean "
"and standard deviation can be expressed by the user. It uses a gaussian "
@@ -6237,11 +6501,11 @@
"ÑÑандаÑÑное оÑклонение Ð·Ð°Ð´Ð°Ð½Ñ Ð¿Ð¾Ð»ÑзоваÑелем. ÐÑполÑзÑем гаÑÑÑов генеÑаÑÐ¾Ñ "
"ÑлÑÑайнÑÑ
ÑиÑел."
-#: ../gui/wxpython/menustrings.py:405
+#: ../gui/wxpython/menustrings.py:407
msgid "Plane"
msgstr "ÐлоÑкоÑÑÑ"
-#: ../gui/wxpython/menustrings.py:406
+#: ../gui/wxpython/menustrings.py:408
msgid ""
"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
"point."
@@ -6249,11 +6513,11 @@
"СоздаÑÑ ÑаÑÑÑовÑй Ñлой Ð·Ð½Ð°Ñ Ð¿Ð°Ð´ÐµÐ½Ð¸Ðµ (наклонение), ÑкÑпозиÑÐ¸Ñ (азимÑÑ) и Ð¾Ð´Ð½Ñ "
"ÑоÑкÑ."
-#: ../gui/wxpython/menustrings.py:407
+#: ../gui/wxpython/menustrings.py:409
msgid "Random deviates surface"
msgstr "ÐовеÑÑ
ноÑÑÑ ÑлÑÑайнÑÑ
оÑклонений"
-#: ../gui/wxpython/menustrings.py:408
+#: ../gui/wxpython/menustrings.py:410
msgid ""
"Produces a raster map layer of uniform random deviates whose range can be "
"expressed by the user."
@@ -6261,57 +6525,57 @@
"СоздаÑÑ ÑаÑÑÑовÑй Ñлой ÑавномеÑнÑÑ
ÑлÑÑайнÑÑ
оÑклонений, Ñ Ð´Ð¸Ð°Ð¿Ð°Ð·Ð¾Ð½Ð¾Ð¼ "
"опÑеделеннÑм полÑзоваÑелем."
-#: ../gui/wxpython/menustrings.py:409
+#: ../gui/wxpython/menustrings.py:411
msgid "Random surface with spatial dependence"
msgstr "СлÑÑÐ°Ð¹Ð½Ð°Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ Ñ Ð¿ÑоÑÑÑанÑÑвенной завиÑимоÑÑÑÑ"
-#: ../gui/wxpython/menustrings.py:410
+#: ../gui/wxpython/menustrings.py:412
msgid "Generates random surface(s) with spatial dependence."
msgstr "СоздаÑÑ ÑлÑÑайнÑÑ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ(и) Ñ Ð¿ÑоÑÑÑанÑÑвенной завиÑимоÑÑÑÑ."
-#: ../gui/wxpython/menustrings.py:411
+#: ../gui/wxpython/menustrings.py:413
msgid "Generate contour lines"
msgstr "СоздаÑÑ Ð¸Ð·Ð¾Ð»Ð¸Ð½Ð¸Ð¸"
-#: ../gui/wxpython/menustrings.py:412
+#: ../gui/wxpython/menustrings.py:414
msgid ""
"Produces a vector map layer of specified contours from a raster map layer."
msgstr "Ð¡Ð¾Ð·Ð´Ð°ÐµÑ Ð²ÐµÐºÑоÑнÑй Ñлой заданнÑÑ
изолиний из ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:413
+#: ../gui/wxpython/menustrings.py:415
msgid "Interpolate surfaces"
msgstr "ÐнÑеÑполиÑоваÑÑ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑи"
-#: ../gui/wxpython/menustrings.py:414
+#: ../gui/wxpython/menustrings.py:416
msgid "Bilinear from raster points"
msgstr "ÐÐ¸Ð»Ð¸Ð½ÐµÐ¹Ð½Ð°Ñ Ð¸Ð½ÑеÑполÑÑÐ¸Ñ ÑаÑÑÑовÑÑ
ÑоÑек"
-#: ../gui/wxpython/menustrings.py:415
+#: ../gui/wxpython/menustrings.py:417
msgid "Bilinear interpolation utility for raster map layers."
msgstr "УÑилиÑа билинейной инÑеÑполÑÑии Ð´Ð»Ñ ÑаÑÑÑовÑÑ
Ñлоев."
-#: ../gui/wxpython/menustrings.py:416
+#: ../gui/wxpython/menustrings.py:418
msgid "Bilinear and bicubic from vector points"
msgstr "ÐÐ¸Ð»Ð¸Ð½ÐµÐ¹Ð½Ð°Ñ Ð¸ бикÑбиÑеÑÐºÐ°Ñ Ð¸Ð½ÑеÑполÑÑÐ¸Ñ Ð²ÐµÐºÑоÑнÑÑ
ÑоÑек"
-#: ../gui/wxpython/menustrings.py:417
+#: ../gui/wxpython/menustrings.py:419
msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
msgstr ""
"ÐикÑбиÑеÑÐºÐ°Ñ Ð¸Ð»Ð¸ Ð±Ð¸Ð»Ð¸Ð½ÐµÐ¹Ð½Ð°Ñ Ð¸Ð½ÑеÑполÑÑÐ¸Ñ Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ ÑегÑлÑÑизаÑии ТиÑ
онова."
-#: ../gui/wxpython/menustrings.py:418
+#: ../gui/wxpython/menustrings.py:420
msgid "IDW from raster points"
msgstr "IDW из ÑаÑÑÑовÑÑ
ÑоÑек"
-#: ../gui/wxpython/menustrings.py:419
+#: ../gui/wxpython/menustrings.py:421
msgid "Surface interpolation utility for raster map layers."
msgstr "УÑилиÑа инÑеÑполÑÑии повеÑÑ
ноÑÑи Ð´Ð»Ñ ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:420
+#: ../gui/wxpython/menustrings.py:422
msgid "IDW from vector points"
msgstr "IDW из векÑоÑнÑÑ
ÑоÑек"
-#: ../gui/wxpython/menustrings.py:421
+#: ../gui/wxpython/menustrings.py:423
msgid ""
"Surface interpolation from vector point data by Inverse Distance Squared "
"Weighting."
@@ -6319,19 +6583,19 @@
"ÐнÑеÑполÑÑÐ¸Ñ Ð²ÐµÐºÑоÑнÑÑ
ÑоÑеÑнÑÑ
даннÑÑ
Ñ Ð¸ÑполÑзованием Inverse Distance "
"Squared Weighting."
-#: ../gui/wxpython/menustrings.py:422
+#: ../gui/wxpython/menustrings.py:424
msgid "Raster contours"
msgstr "РаÑÑÑовÑе изолинии"
-#: ../gui/wxpython/menustrings.py:423
+#: ../gui/wxpython/menustrings.py:425
msgid "Surface generation program from rasterized contours."
msgstr "ÐÑогÑамма генеÑиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑи из ÑаÑÑеÑизованнÑÑ
изолиний."
-#: ../gui/wxpython/menustrings.py:424
+#: ../gui/wxpython/menustrings.py:426
msgid "Regularized spline tension"
msgstr "Сплайн-инÑеÑполÑÑÐ¸Ñ (Regularized spline tension)"
-#: ../gui/wxpython/menustrings.py:425
+#: ../gui/wxpython/menustrings.py:427
msgid ""
"Spatial approximation and topographic analysis from given point or isoline "
"data in vector format to floating point raster format using regularized "
@@ -6341,32 +6605,32 @@
"векÑоÑнÑÑ
ÑоÑек или изолиний в ÑаÑÑÑовÑй ÑоÑÐ¼Ð°Ñ Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей запÑÑой, "
"иÑполÑзÑÑ Ñплайн-инÑеÑполÑÑиÑ."
-#: ../gui/wxpython/menustrings.py:426
+#: ../gui/wxpython/menustrings.py:428
msgid "Fill NULL cells"
msgstr "ÐаполниÑÑ NULL-ÑÑейки"
-#: ../gui/wxpython/menustrings.py:427
+#: ../gui/wxpython/menustrings.py:429
msgid ""
"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
msgstr "ÐаполниÑÑ no-data знаÑениÑми, иÑполÑзÑÑ Ñплайн-инÑеÑполÑÑÐ¸Ñ v.surf.rst"
-#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:657
+#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:659
msgid "Report and statistics"
msgstr "ÐÑÑÐµÑ Ð¸ ÑÑаÑиÑÑика"
-#: ../gui/wxpython/menustrings.py:429
+#: ../gui/wxpython/menustrings.py:431
msgid "Basic raster metadata"
msgstr "ÐÑновнÑе меÑаданнÑе ÑаÑÑÑа"
-#: ../gui/wxpython/menustrings.py:430
+#: ../gui/wxpython/menustrings.py:432
msgid "Output basic information about a raster map layer."
msgstr "ÐÑÐ½Ð¾Ð²Ð½Ð°Ñ Ð²ÑÑ
Ð¾Ð´Ð½Ð°Ñ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ ÑаÑÑÑовом Ñлое."
-#: ../gui/wxpython/menustrings.py:431
+#: ../gui/wxpython/menustrings.py:433
msgid "Manage category information"
msgstr "УпÑавление инÑоÑмаÑией о каÑегоÑиÑÑ
-#: ../gui/wxpython/menustrings.py:432
+#: ../gui/wxpython/menustrings.py:434
msgid ""
"Manages category values and labels associated with user-specified raster map "
"layers."
@@ -6374,51 +6638,51 @@
"УпÑавление знаÑениÑми каÑегоÑий и подпиÑÑми, ÑвÑзаннÑми Ñ ÑаÑÑÑовÑми ÑлоÑми "
"опÑеделеннÑми полÑзоваÑелем."
-#: ../gui/wxpython/menustrings.py:433
+#: ../gui/wxpython/menustrings.py:435
msgid "General statistics"
msgstr "ÐбÑÐ°Ñ ÑÑаÑиÑÑика"
-#: ../gui/wxpython/menustrings.py:434
+#: ../gui/wxpython/menustrings.py:436
msgid "Generates area statistics for raster map layers."
msgstr "ÐоказаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð¿Ð¾ плоÑади Ð´Ð»Ñ ÑаÑÑÑовÑÑ
Ñлоев."
-#: ../gui/wxpython/menustrings.py:435
+#: ../gui/wxpython/menustrings.py:437
msgid "Quantiles for large data sets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:436
+#: ../gui/wxpython/menustrings.py:438
msgid "Compute quantiles using two passes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:437
+#: ../gui/wxpython/menustrings.py:439
msgid "Range of category values"
msgstr "РазбÑÐ¾Ñ Ð·Ð½Ð°Ñений каÑегоÑий"
-#: ../gui/wxpython/menustrings.py:438
+#: ../gui/wxpython/menustrings.py:440
msgid "Prints terse list of category values found in a raster map layer."
msgstr "ÐÑвеÑÑи кÑаÑкий ÑпиÑок знаÑений каÑегоÑий, найденнÑÑ
в ÑаÑÑÑовом Ñлое."
-#: ../gui/wxpython/menustrings.py:439
+#: ../gui/wxpython/menustrings.py:441
msgid "Sum category values"
msgstr "СÑммиÑоваÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий"
-#: ../gui/wxpython/menustrings.py:440
+#: ../gui/wxpython/menustrings.py:442
msgid "Sums up the raster cell values."
msgstr "СÑммиÑоваÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÑÑеек ÑаÑÑÑа."
-#: ../gui/wxpython/menustrings.py:441
+#: ../gui/wxpython/menustrings.py:443
msgid "Sum area by raster map and category"
msgstr "СÑммиÑоваÑÑ Ð¿Ð»Ð¾ÑÐ°Ð´Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð¿Ð¾ каÑегоÑиÑм"
-#: ../gui/wxpython/menustrings.py:442
+#: ../gui/wxpython/menustrings.py:444
msgid "Reports statistics for raster map layers."
msgstr "ÐоказаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð´Ð»Ñ ÑаÑÑÑовÑÑ
Ñлоев."
-#: ../gui/wxpython/menustrings.py:443
+#: ../gui/wxpython/menustrings.py:445
msgid "Statistics for clumped cells"
msgstr "СÑаÑиÑÑика Ð´Ð»Ñ Ð³ÑÑÐ¿Ð¿Ñ ÑÑеек"
-#: ../gui/wxpython/menustrings.py:444
+#: ../gui/wxpython/menustrings.py:446
msgid ""
"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
"vector points map containing the calculated centroids of these clumps."
@@ -6426,49 +6690,49 @@
"ÐоÑÑиÑаÑÑ Ð¾Ð±Ñем гÑÑпп и (еÑли необÑ
одимо) ÑоздаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой GRASS, "
"ÑодеÑжаÑий ÑенÑÑÐ¾Ð¸Ð´Ñ ÑÑиÑ
гÑÑпп."
-#: ../gui/wxpython/menustrings.py:445
+#: ../gui/wxpython/menustrings.py:447
msgid "Total corrected area"
msgstr "ÐбÑÐ°Ñ ÐºÐ¾ÑÑекÑиÑÐ¾Ð²Ð°Ð½Ð½Ð°Ñ Ð¿Ð»Ð¾ÑадÑ"
-#: ../gui/wxpython/menustrings.py:446
+#: ../gui/wxpython/menustrings.py:448
msgid "Surface area estimation for rasters."
msgstr "ÐÑенка плоÑади повеÑÑ
ноÑÑи Ð´Ð»Ñ ÑаÑÑÑов."
-#: ../gui/wxpython/menustrings.py:447
+#: ../gui/wxpython/menustrings.py:449
msgid "Univariate raster statistics"
msgstr "ÐдномеÑÐ½Ð°Ñ ÑÑаÑиÑÑика ÑаÑÑÑа"
-#: ../gui/wxpython/menustrings.py:448
+#: ../gui/wxpython/menustrings.py:450
msgid ""
"Calculates univariate statistics from the non-null cells of a raster map."
msgstr "РаÑÑÑиÑаÑÑ Ð¾Ð´Ð½Ð¾Ð¼ÐµÑнÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð´Ð»Ñ Ð½ÐµÐ½ÑлевÑÑ
-#: ../gui/wxpython/menustrings.py:449
+#: ../gui/wxpython/menustrings.py:451
msgid "Sample transects"
msgstr "ÐолÑÑиÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ñ ÑÑанÑекÑ"
-#: ../gui/wxpython/menustrings.py:450
+#: ../gui/wxpython/menustrings.py:452
msgid "Outputs the raster map layer values lying on user-defined line(s)."
msgstr ""
"ÐÑвеÑÑи знаÑÐµÐ½Ð¸Ñ ÑаÑÑÑового ÑлоÑ, лежаÑие на линии (линиÑÑ
), заданнÑÑ
"полÑзоваÑелем."
-#: ../gui/wxpython/menustrings.py:451
+#: ../gui/wxpython/menustrings.py:453
msgid "Sample transects (bearing/distance)"
msgstr "ÐолÑÑиÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ñ ÑÑанÑÐµÐºÑ (азимÑÑ/ÑаÑÑÑоÑние)"
-#: ../gui/wxpython/menustrings.py:452
+#: ../gui/wxpython/menustrings.py:454
msgid ""
"Outputs raster map layer values lying along user defined transect line(s)."
msgstr ""
"ÐÑвеÑÑи знаÑÐµÐ½Ð¸Ñ ÑаÑÑÑового ÑлоÑ, лежаÑие Ð²Ð´Ð¾Ð»Ñ Ð»Ð¸Ð½Ð¸Ð¸ ÑазÑеза (ÑазÑезов), "
"заданнÑÑ
полÑзоваÑелем."
-#: ../gui/wxpython/menustrings.py:453
+#: ../gui/wxpython/menustrings.py:455
msgid "Covariance/correlation"
msgstr "ÐоваÑиаÑиÑ/коÑÑелÑÑиÑ"
-#: ../gui/wxpython/menustrings.py:454
+#: ../gui/wxpython/menustrings.py:456
msgid ""
"Outputs a covariance/correlation matrix for user-specified raster map layer"
"(s)."
@@ -6476,117 +6740,117 @@
"ÐÑвеÑÑи маÑÑиÑÑ ÐºÐ¾ÑÑеллÑÑии/коваÑиаÑии Ð´Ð»Ñ ÑаÑÑÑового ÑлоÑ(ев), "
"неопÑеделенного полÑзоваÑелем."
-#: ../gui/wxpython/menustrings.py:455
+#: ../gui/wxpython/menustrings.py:457
msgid "Linear regression"
msgstr "ÐÐ¸Ð½ÐµÐ¹Ð½Ð°Ñ ÑегÑеÑÑиÑ"
-#: ../gui/wxpython/menustrings.py:456
+#: ../gui/wxpython/menustrings.py:458
msgid "Calculates linear regression from two raster maps: y = a + b*x"
msgstr "РаÑÑÑиÑаÑÑ Ð»Ð¸Ð½ÐµÐ¹Ð½ÑÑ ÑегÑеÑÑÐ¸Ñ Ð´Ð»Ñ Ð´Ð²ÑÑ
ÑаÑÑÑовÑÑ
Ñлоев: y = a + b*x"
-#: ../gui/wxpython/menustrings.py:457
+#: ../gui/wxpython/menustrings.py:459
msgid "Mutual category occurrences"
msgstr "Совпадение обÑиÑ
каÑегоÑий"
-#: ../gui/wxpython/menustrings.py:458
+#: ../gui/wxpython/menustrings.py:460
msgid ""
"Tabulates the mutual occurrence (coincidence) of categories for two raster "
"map layers."
msgstr "СоздаÑÑ ÑаблиÑÑ Ð²Ð·Ð°Ð¸Ð¼Ð½ÑÑ
Ñовпадений каÑегоÑий двÑÑ
ÑаÑÑÑовÑÑ
Ñлоев."
-#: ../gui/wxpython/menustrings.py:459
+#: ../gui/wxpython/menustrings.py:461
msgid "Vector"
msgstr "ÐекÑоÑ"
-#: ../gui/wxpython/menustrings.py:460
+#: ../gui/wxpython/menustrings.py:462
msgid "Develop vector map"
msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
-#: ../gui/wxpython/menustrings.py:462
+#: ../gui/wxpython/menustrings.py:464
msgid "Create new empty vector map"
msgstr "СоздаÑÑ Ð½Ð¾Ð²Ñй пÑÑÑой векÑоÑнÑй Ñлой"
-#: ../gui/wxpython/menustrings.py:463
+#: ../gui/wxpython/menustrings.py:465
#, fuzzy
msgid "Edit vector map (non-interactively)"
-#: ../gui/wxpython/menustrings.py:464
+#: ../gui/wxpython/menustrings.py:466
msgid ""
"Edits a vector map, allows adding, deleting and modifying selected vector "
"features."
msgstr ""
-#: ../gui/wxpython/menustrings.py:465
+#: ../gui/wxpython/menustrings.py:467
#, fuzzy
msgid "Create or rebuild topology"
msgstr "СоздаÑÑ/поÑÑÑоиÑÑ ÑопологиÑ"
-#: ../gui/wxpython/menustrings.py:466
+#: ../gui/wxpython/menustrings.py:468
msgid "Creates topology for GRASS vector map."
msgstr "СоздаÑÑ ÑÐ¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð´Ð»Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ GRASS"
-#: ../gui/wxpython/menustrings.py:467
+#: ../gui/wxpython/menustrings.py:469
msgid "Clean vector map"
msgstr "ÐÑиÑÑиÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
-#: ../gui/wxpython/menustrings.py:468
+#: ../gui/wxpython/menustrings.py:470
msgid "Toolset for cleaning topology of vector map."
msgstr "ÐÐ°Ð±Ð¾Ñ Ð¸Ð½ÑÑÑÑменÑов Ð´Ð»Ñ Ð¿Ñавки Ñопологии векÑоÑного ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:469
+#: ../gui/wxpython/menustrings.py:471
msgid "Smooth or simplify"
msgstr ""
-#: ../gui/wxpython/menustrings.py:470
+#: ../gui/wxpython/menustrings.py:472
msgid "Smooth or simplify lines/boundaries (remove vertices)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:471
+#: ../gui/wxpython/menustrings.py:473
msgid "Convert object types"
msgstr "ÐонвеÑÑиÑоваÑÑ ÑÐ¸Ð¿Ñ Ð¾Ð±ÑекÑов"
-#: ../gui/wxpython/menustrings.py:472
+#: ../gui/wxpython/menustrings.py:474
msgid "Change the type of geometry elements."
msgstr "ÐзмениÑÑ Ñип геомеÑÑиÑеÑкиÑ
ÑлеменÑов."
-#: ../gui/wxpython/menustrings.py:473
+#: ../gui/wxpython/menustrings.py:475
msgid "Add centroids"
msgstr "ÐобавиÑÑ ÑенÑÑоидÑ"
-#: ../gui/wxpython/menustrings.py:474
+#: ../gui/wxpython/menustrings.py:476
msgid "Adds missing centroids to closed boundaries."
msgstr "ÐобавиÑÑ Ð¿ÑопÑÑеннÑе ÑенÑÑÐ¾Ð¸Ð´Ñ Ðº замкнÑÑÑм гÑаниÑам."
-#: ../gui/wxpython/menustrings.py:475
+#: ../gui/wxpython/menustrings.py:477
msgid "Build polylines"
msgstr "ÐоÑÑÑоиÑÑ Ð¿Ð¾Ð»Ð¸Ð»Ð¸Ð½Ð¸Ð¸"
-#: ../gui/wxpython/menustrings.py:476
+#: ../gui/wxpython/menustrings.py:478
msgid "Builds polylines from lines or boundaries."
msgstr "ÐоÑÑÑоиÑÑ Ð¿Ð¾Ð»Ð¸Ð»Ð¸Ð½Ð¸Ð¸ из линий или гÑаниÑ."
-#: ../gui/wxpython/menustrings.py:477
+#: ../gui/wxpython/menustrings.py:479
msgid "Split polylines"
msgstr "РазделиÑÑ Ð¿Ð¾Ð»Ð¸Ð»Ð¸Ð½Ð¸Ð¸"
-#: ../gui/wxpython/menustrings.py:478
+#: ../gui/wxpython/menustrings.py:480
msgid "Creates points/segments from input vector lines and positions."
msgstr "СоздаÑÑ ÑоÑки/Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ñ Ð¸Ð· иÑÑ
однÑÑ
векÑоÑнÑÑ
линий и ÑоÑек."
-#: ../gui/wxpython/menustrings.py:479
+#: ../gui/wxpython/menustrings.py:481
msgid "Parallel lines"
msgstr "ÐаÑаллелÑнÑе линии"
-#: ../gui/wxpython/menustrings.py:480
+#: ../gui/wxpython/menustrings.py:482
msgid "Create parallel line to input lines"
msgstr "СоздаÑÑ Ð¿Ð°ÑаллелÑнÑе линии Ð´Ð»Ñ Ð¸ÑÑ
однÑÑ
линий"
-#: ../gui/wxpython/menustrings.py:481
+#: ../gui/wxpython/menustrings.py:483
msgid "Dissolve boundaries"
msgstr "УдалиÑÑ Ð³ÑаниÑÑ"
-#: ../gui/wxpython/menustrings.py:482
+#: ../gui/wxpython/menustrings.py:484
msgid ""
"Dissolves boundaries between adjacent areas sharing a common category number "
"or attribute."
@@ -6594,47 +6858,47 @@
"УбÑаÑÑ Ð³ÑаниÑÑ Ð¼ÐµÐ¶Ð´Ñ Ð¿ÑилегаÑÑими полигонами имеÑÑими одинаковое знаÑение "
"каÑегоÑии или аÑÑибÑÑа."
-#: ../gui/wxpython/menustrings.py:483
+#: ../gui/wxpython/menustrings.py:485
msgid "Create 3D vector over raster"
msgstr "СоздаÑÑ 3D-векÑÐ¾Ñ Ð¿Ð¾Ð²ÐµÑÑ
ÑаÑÑÑа"
-#: ../gui/wxpython/menustrings.py:484
+#: ../gui/wxpython/menustrings.py:486
msgid "Converts vector map to 3D by sampling of elevation raster map."
msgstr ""
"ÐонвеÑÑиÑоваÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой в ÑÑеÑ
меÑнÑй, иÑполÑзÑÑ Ð´Ð°Ð½Ð½ÑÑ
о ÑелÑеÑе Ñ "
"ÑаÑÑÑовой каÑÑÑ Ð²ÑÑоÑ."
-#: ../gui/wxpython/menustrings.py:485
+#: ../gui/wxpython/menustrings.py:487
msgid "Extrude 3D vector map"
msgstr "ÐÑдвинÑÑÑ ÑÑеÑ
меÑнÑй векÑоÑнÑй Ñлой"
-#: ../gui/wxpython/menustrings.py:486
+#: ../gui/wxpython/menustrings.py:488
msgid "Extrudes flat vector object to 3D with defined height."
msgstr "ÐÑдвинÑÑÑ Ð² 3D плоÑкий векÑоÑнÑй обÑÐµÐºÑ Ð½Ð° заданнÑÑ Ð²ÑÑоÑÑ."
-#: ../gui/wxpython/menustrings.py:487
+#: ../gui/wxpython/menustrings.py:489
msgid "Link to OGR"
-#: ../gui/wxpython/menustrings.py:488
+#: ../gui/wxpython/menustrings.py:490
#, fuzzy
msgid "Creates a new vector as a read-only link to OGR layer."
msgstr ""
"СоздаÑÑ Ð½Ð¾Ð²Ñй векÑоÑнÑй Ñлой пÑÑем комбиниÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð´ÑÑгиÑ
векÑоÑнÑÑ
Ñлоев."
-#: ../gui/wxpython/menustrings.py:489
+#: ../gui/wxpython/menustrings.py:491
msgid "Create labels"
msgstr "СоздаÑÑ Ð¿Ð¾Ð´Ð¿Ð¸Ñи"
-#: ../gui/wxpython/menustrings.py:490
+#: ../gui/wxpython/menustrings.py:492
msgid "Creates paint labels for a vector map from attached attributes."
msgstr "СоздаÑÑ Ð¿Ð¾Ð´Ð¿Ð¸Ñи-ÑиÑÑнки Ð´Ð»Ñ Ð²ÐµÐºÑоÑного ÑлоÑ, иÑполÑзÑÑ Ð°ÑÑибÑÑÑ."
-#: ../gui/wxpython/menustrings.py:491
+#: ../gui/wxpython/menustrings.py:493
msgid "Reposition vector map"
msgstr "ÐеÑемеÑÑиÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
-#: ../gui/wxpython/menustrings.py:492
+#: ../gui/wxpython/menustrings.py:494
msgid ""
"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
"vector map."
@@ -6642,24 +6906,24 @@
"ÐÑполниÑÑ Ð°ÑÑинное пÑеобÑазование векÑоÑного ÑÐ»Ð¾Ñ (пеÑемеÑение, маÑÑÑаб и "
"вÑаÑение, или GPC)."
-#: ../gui/wxpython/menustrings.py:493
+#: ../gui/wxpython/menustrings.py:495
msgid "Reproject vector map"
msgstr "ÐеÑепÑоекÑиÑоваÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой"
-#: ../gui/wxpython/menustrings.py:494
+#: ../gui/wxpython/menustrings.py:496
msgid "Allows projection conversion of vector maps."
msgstr "РазÑеÑиÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ðµ пÑоекÑии векÑоÑнÑÑ
Ñлоев."
-#: ../gui/wxpython/menustrings.py:497
+#: ../gui/wxpython/menustrings.py:499
msgid ""
"Set color rules for features in a vector using a numeric attribute column."
msgstr ""
-#: ../gui/wxpython/menustrings.py:500
+#: ../gui/wxpython/menustrings.py:502
msgid "Query with attributes"
msgstr "ÐапÑÐ¾Ñ Ð°ÑÑибÑÑов"
-#: ../gui/wxpython/menustrings.py:501
+#: ../gui/wxpython/menustrings.py:503
msgid ""
"Selects vector objects from an existing vector map and creates a new map "
"containing only the selected objects."
@@ -6667,60 +6931,60 @@
"ÐÑбÑаÑÑ Ð²ÐµÐºÑоÑнÑе обÑекÑÑ Ð¸Ð· ÑÑÑеÑÑвÑÑÑего векÑоÑного ÑÐ»Ð¾Ñ Ð¸ ÑоздаÑÑ Ð½Ð¾Ð²Ñй "
"Ñлой, ÑодеÑжаÑий ÑолÑко вÑбÑаннÑе обÑекÑÑ."
-#: ../gui/wxpython/menustrings.py:502
+#: ../gui/wxpython/menustrings.py:504
msgid "Query with coordinate(s)"
msgstr "ÐапÑÐ¾Ñ Ð¿Ð¾ кооÑдинаÑами"
-#: ../gui/wxpython/menustrings.py:503
+#: ../gui/wxpython/menustrings.py:505
msgid "Queries a vector map layer at given locations."
msgstr "СоздаÑÑ Ð·Ð°Ð¿ÑÐ¾Ñ Ðº векÑоÑÐ½Ð¾Ð¼Ñ ÑÐ»Ð¾Ñ Ð² заданнÑÑ
меÑÑоположениÑÑ
-#: ../gui/wxpython/menustrings.py:504
+#: ../gui/wxpython/menustrings.py:506
msgid "Query with another vector map"
msgstr "ÐапÑÐ¾Ñ Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ Ð´ÑÑгого векÑоÑного ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:505
+#: ../gui/wxpython/menustrings.py:507
msgid "Select features from ainput by features from binput"
msgstr "ÐÑбÑаÑÑ Ð¾Ð±ÑекÑÑ Ð¸Ð· ainut по обÑекÑам из binput"
-#: ../gui/wxpython/menustrings.py:506
+#: ../gui/wxpython/menustrings.py:508
msgid "Buffer vectors"
msgstr "ÐÑÑеÑизоваÑÑ Ð²ÐµÐºÑоÑа"
-#: ../gui/wxpython/menustrings.py:507
+#: ../gui/wxpython/menustrings.py:509
msgid ""
"Creates a buffer around features of given type (areas must contain centroid)."
msgstr ""
"СоздаÑÑ Ð±ÑÑÐµÑ Ð²Ð¾ÐºÑÑг обÑекÑов данного Ñипа (плоÑаднÑе обÑекÑÑ Ð´Ð¾Ð»Ð¶Ð½Ñ "
"ÑодеÑжаÑÑ ÑенÑÑоидÑ)."
-#: ../gui/wxpython/menustrings.py:508
+#: ../gui/wxpython/menustrings.py:510
msgid "Lidar analysis"
msgstr "Ðнализ даннÑÑ
LIDAR"
-#: ../gui/wxpython/menustrings.py:509
+#: ../gui/wxpython/menustrings.py:511
msgid "Detect edges"
msgstr "ÐпÑеделиÑÑ Ð³ÑаниÑÑ"
-#: ../gui/wxpython/menustrings.py:510
+#: ../gui/wxpython/menustrings.py:512
msgid "Detects the object's edges from a LIDAR data set."
msgstr "ÐпÑеделиÑÑ Ð³ÑаниÑÑ Ð¾Ð±ÑекÑа из набоÑа даннÑÑ
LIDAR."
-#: ../gui/wxpython/menustrings.py:511
+#: ../gui/wxpython/menustrings.py:513
msgid "Detect interiors"
msgstr "ÐпÑеделиÑÑ Ð²Ð½ÑÑÑенние обÑекÑÑ"
-#: ../gui/wxpython/menustrings.py:512
+#: ../gui/wxpython/menustrings.py:514
msgid ""
"Building contour determination and Region Growing algorithm for determining "
"the building inside"
msgstr "ÐпÑеделение гÑаниÑÑ ÑÑÑÐ¾ÐµÐ½Ð¸Ñ Ð¸ алгоÑиÑм ÑоÑÑа Ð´Ð»Ñ Ð¾Ð¿ÑÐµÐ´ÐµÐ»ÐµÐ½Ð¸Ñ ÑÑÑоениÑ"
-#: ../gui/wxpython/menustrings.py:513
+#: ../gui/wxpython/menustrings.py:515
msgid "Correct and reclassify objects"
msgstr "ÐÑпÑавиÑÑ Ð¸ пеÑеклаÑÑиÑиÑиÑоваÑÑ Ð¾Ð±ÑекÑÑ"
-#: ../gui/wxpython/menustrings.py:514
+#: ../gui/wxpython/menustrings.py:516
msgid ""
"Correction of the v.lidar.growing output. It is the last of the three "
"algorithms for LIDAR filtering."
@@ -6728,31 +6992,31 @@
"ÐÑпÑавление ÑезÑлÑÑаÑа v.lidar.growing. ÐÑо поÑледний из ÑÑеÑ
алгоÑиÑмов "
"Ð´Ð»Ñ ÑилÑÑÑаÑии LIDAR."
-#: ../gui/wxpython/menustrings.py:515
+#: ../gui/wxpython/menustrings.py:517
msgid "Linear referencing"
msgstr "ÐÐ¸Ð½ÐµÐ¹Ð½Ð°Ñ Ð¿ÑивÑзка"
-#: ../gui/wxpython/menustrings.py:516
+#: ../gui/wxpython/menustrings.py:518
msgid "Create LRS"
msgstr "СоздаÑÑ LRS"
-#: ../gui/wxpython/menustrings.py:517
+#: ../gui/wxpython/menustrings.py:519
msgid "Create Linear Reference System"
msgstr "ÐадаÑÑ Ð»Ð¸Ð½ÐµÐ¹Ð½ÑÑ ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑдинаÑ"
-#: ../gui/wxpython/menustrings.py:518
+#: ../gui/wxpython/menustrings.py:520
msgid "Create stationing"
msgstr "СоздаÑÑ ÑÑанÑии"
-#: ../gui/wxpython/menustrings.py:519
+#: ../gui/wxpython/menustrings.py:521
msgid "Create stationing from input lines, and linear reference system"
msgstr "СоздаÑÑ ÑÑанÑии из иÑÑ
однÑÑ
линий и линейнÑÑ ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑдинаÑ"
-#: ../gui/wxpython/menustrings.py:520
+#: ../gui/wxpython/menustrings.py:522
msgid "Create points/segments"
msgstr "СоздаÑÑ ÑоÑки/ÑегменÑÑ"
-#: ../gui/wxpython/menustrings.py:521
+#: ../gui/wxpython/menustrings.py:523
msgid ""
"Creates points/segments from input lines, linear reference system and "
"positions read from stdin or a file."
@@ -6760,11 +7024,11 @@
"СоздаÑÑ ÑоÑки/ÑегменÑÑ Ð¸Ð· вÑ
однÑÑ
линий, ÑиÑÑÐµÐ¼Ñ Ð»Ð¸Ð½ÐµÐ¹Ð½ÑÑ
кооÑÐ´Ð¸Ð½Ð°Ñ Ð¸ ÑоÑек, "
"ÑÑиÑÑваемÑÑ
из stdin или Ñайла."
-#: ../gui/wxpython/menustrings.py:522
+#: ../gui/wxpython/menustrings.py:524
msgid "Find line id and offset"
msgstr "ÐайÑи id-Ð½Ð¾Ð¼ÐµÑ Ð»Ð¸Ð½Ð¸Ð¸ и ÑмеÑÑиÑÑ"
-#: ../gui/wxpython/menustrings.py:523
+#: ../gui/wxpython/menustrings.py:525
msgid ""
"Finds line id and real km+offset for given points in vector map using linear "
"reference system."
@@ -6772,11 +7036,11 @@
"ÐайÑи ID линии и ÑеалÑнÑй киломеÑÑаж+оÑÑÐµÑ Ð´Ð»Ñ Ð·Ð°Ð´Ð°Ð½Ð½ÑÑ
ÑоÑек векÑоÑного "
"ÑÐ»Ð¾Ñ Ð¸ÑполÑзÑÑ ÑиÑÑÐµÐ¼Ñ Ð»Ð¸Ð½ÐµÐ¹Ð½ÑÑ
кооÑдинаÑ."
-#: ../gui/wxpython/menustrings.py:524
+#: ../gui/wxpython/menustrings.py:526
msgid "Nearest features"
-#: ../gui/wxpython/menustrings.py:525
+#: ../gui/wxpython/menustrings.py:527
msgid ""
"Finds the nearest element in vector map 'to' for elements in vector map "
"'from'."
@@ -6784,15 +7048,15 @@
"ÐайÑи ближайÑий ÑÐ»ÐµÐ¼ÐµÐ½Ñ Ð² ÑезÑлÑÑиÑÑÑÑем векÑоÑном Ñлое Ð´Ð»Ñ ÑлеменÑов в "
"иÑÑ
одном векÑоÑном Ñлое."
-#: ../gui/wxpython/menustrings.py:526
+#: ../gui/wxpython/menustrings.py:528
msgid "Network analysis"
msgstr "СеÑевой анализ"
-#: ../gui/wxpython/menustrings.py:527
+#: ../gui/wxpython/menustrings.py:529
msgid "Allocate subnets"
msgstr "ÐайÑи подÑеÑи"
-#: ../gui/wxpython/menustrings.py:528
+#: ../gui/wxpython/menustrings.py:530
msgid ""
"Centre node must be opened (costs >= 0). Costs of centre node are used in "
"calculation"
@@ -6800,35 +7064,35 @@
"ЦенÑÑалÑнÑй Ñзел должен бÑÑÑ Ð¾ÑкÑÑÑ (знаÑение>=0). Цена в ÑенÑÑалÑном Ñзле "
"иÑполÑзÑеÑÑÑ Ð¿Ñи ÑаÑÑеÑе."
-#: ../gui/wxpython/menustrings.py:529
+#: ../gui/wxpython/menustrings.py:531
msgid "Network maintenance"
msgstr "ÐбÑлÑживание ÑеÑи"
-#: ../gui/wxpython/menustrings.py:530
+#: ../gui/wxpython/menustrings.py:532
msgid "Network maintenance."
msgstr "ÐбÑлÑживание ÑеÑи."
-#: ../gui/wxpython/menustrings.py:531
+#: ../gui/wxpython/menustrings.py:533
msgid "Visibility network"
msgstr "СеÑÑ Ð²Ð¸Ð´Ð¸Ð¼Ð¾ÑÑи"
-#: ../gui/wxpython/menustrings.py:532
+#: ../gui/wxpython/menustrings.py:534
msgid "Visibility graph construction."
msgstr "Создание гÑаÑа видимоÑÑи."
-#: ../gui/wxpython/menustrings.py:533
+#: ../gui/wxpython/menustrings.py:535
msgid "Shortest path"
msgstr "ÐÑаÑÑайÑий пÑÑÑ"
-#: ../gui/wxpython/menustrings.py:534
+#: ../gui/wxpython/menustrings.py:536
msgid "Finds shortest path on vector network."
msgstr "ÐайÑи кÑаÑÑайÑий пÑÑÑ Ð¿Ð¾ векÑоÑной ÑеÑи"
-#: ../gui/wxpython/menustrings.py:535
+#: ../gui/wxpython/menustrings.py:537
msgid "Display shortest route (requires XTerm)"
msgstr "ÐоказаÑÑ ÐºÑаÑÑайÑий пÑÑÑ (ÑÑебÑеÑÑÑ XTerm)"
-#: ../gui/wxpython/menustrings.py:536
+#: ../gui/wxpython/menustrings.py:538
msgid ""
"Display shortest route along network between 2 nodes (visualization only, "
"requires XTerm))"
@@ -6836,11 +7100,11 @@
"ÐоказаÑÑ ÐºÑаÑÑайÑий пÑÑÑ Ð²Ð´Ð¾Ð»Ñ ÑеÑи Ð¼ÐµÐ¶Ð´Ñ 2 Ñзлами (ÑолÑко визÑализаÑиÑ, "
"ÑÑебÑеÑÑÑ XTerm)"
-#: ../gui/wxpython/menustrings.py:537
+#: ../gui/wxpython/menustrings.py:539
msgid "Split net"
msgstr "РазделиÑÑ ÑеÑÑ"
-#: ../gui/wxpython/menustrings.py:538
+#: ../gui/wxpython/menustrings.py:540
msgid ""
"Splits net to bands between cost isolines (direction from centre). Centre "
"node must be opened (costs >= 0). Costs of centre node are used in "
@@ -6850,11 +7114,11 @@
-#: ../gui/wxpython/menustrings.py:539
+#: ../gui/wxpython/menustrings.py:541
msgid "Steiner tree"
msgstr "ÐеÑево ШÑейнеÑа"
-#: ../gui/wxpython/menustrings.py:540
+#: ../gui/wxpython/menustrings.py:542
msgid ""
"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
"is used in this module so the result may be sub optimal"
@@ -6863,11 +7127,11 @@
"поÑÑÐ¾Ð¼Ñ Ð² ÑÑом модÑле иÑполÑзÑеÑÑÑ ÑвÑиÑÑиÑеÑкий алгоÑиÑм, Ñак ÑÑо ÑезÑлÑÑÐ°Ñ "
"Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ ÑÑбопÑималÑнÑм"
-#: ../gui/wxpython/menustrings.py:541
+#: ../gui/wxpython/menustrings.py:543
msgid "Traveling salesman analysis"
msgstr "Ðнализ коммивоÑжеÑа"
-#: ../gui/wxpython/menustrings.py:542
+#: ../gui/wxpython/menustrings.py:544
msgid ""
"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
"created cycle may be sub optimal"
@@ -6875,51 +7139,51 @@
"ÐамеÑÑÑе ÑÑо TSP ÑвлÑеÑÑÑ NP-hard, поÑÑÐ¾Ð¼Ñ Ð² ÑÑом модÑле иÑполÑзÑеÑÑÑ "
"ÑвÑиÑÑиÑеÑкий алгоÑиÑм, Ñак ÑÑо ÑозданнÑй Ñикл Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ ÑÑбопÑималÑнÑм"
-#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:544
+#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:546
msgid "Overlay vector maps"
msgstr "ÐаложиÑÑ Ð²ÐµÐºÑоÑнÑе Ñлои"
-#: ../gui/wxpython/menustrings.py:545
+#: ../gui/wxpython/menustrings.py:547
msgid "Overlays two vector maps."
msgstr "ÐаложиÑÑ Ð´Ð²Ð° векÑоÑнÑÑ
ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:546
+#: ../gui/wxpython/menustrings.py:548
msgid "Patch vector maps"
msgstr "ÐекÑоÑнÑе Ñлои ÑÑаÑÑков"
-#: ../gui/wxpython/menustrings.py:547
+#: ../gui/wxpython/menustrings.py:549
msgid "Create a new vector map layer by combining other vector map layers."
msgstr ""
векÑоÑнÑÑ
Ñлоев."
-#: ../gui/wxpython/menustrings.py:548
+#: ../gui/wxpython/menustrings.py:550
msgid "Change attributes"
msgstr "ÐзмениÑÑ Ð°ÑÑибÑÑÑ"
-#: ../gui/wxpython/menustrings.py:549
+#: ../gui/wxpython/menustrings.py:551
msgid "Manage or report categories"
msgstr "УпÑавлÑÑÑ Ð¸Ð»Ð¸ вÑвеÑÑи каÑегоÑии"
-#: ../gui/wxpython/menustrings.py:550
+#: ../gui/wxpython/menustrings.py:552
msgid "Attach, delete or report vector categories to map geometry."
msgstr ""
"ÐÑикÑепиÑÑ, ÑдалиÑÑ Ð¸Ð»Ð¸ вÑвеÑÑи векÑоÑнÑе каÑегоÑии Ð´Ð»Ñ Ð³ÐµÐ¾Ð¼ÐµÑÑии ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:551
+#: ../gui/wxpython/menustrings.py:553
msgid "Reclassify objects interactively"
msgstr "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ Ð¾Ð±ÑекÑÑ Ð² инÑеÑакÑивном Ñежиме"
-#: ../gui/wxpython/menustrings.py:552
+#: ../gui/wxpython/menustrings.py:554
msgid "Reclassify vector objects interactively by entering SQL rules"
msgstr ""
"ÐеÑеклаÑÑиÑиÑиÑоваÑÑ Ð²ÐµÐºÑоÑнÑе обÑекÑÑ Ð² инÑеÑакÑивном Ñежиме пÑÑем Ð²Ð²ÐµÐ´ÐµÐ½Ð¸Ñ "
"команд SQL"
-#: ../gui/wxpython/menustrings.py:553
+#: ../gui/wxpython/menustrings.py:555
msgid "Reclassify objects using rules file"
msgstr "ÐеÑеклаÑÑиÑиÑиÑоваÑÑ Ð¾Ð±ÑекÑÑ, иÑполÑзÑÑ Ñайл пÑавил"
-#: ../gui/wxpython/menustrings.py:554
+#: ../gui/wxpython/menustrings.py:556
msgid ""
"Changes vector category values for an existing vector map according to "
"results of SQL queries or a value in attribute table column."
@@ -6927,32 +7191,32 @@
"ÐзмениÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ð²ÐµÐºÑоÑнÑÑ
каÑегоÑий Ð´Ð»Ñ Ð¸Ð¼ÐµÑÑегоÑÑ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ "
"ÑоглаÑно ÑезÑлÑÑаÑам SQL-запÑоÑов или знаÑÐµÐ½Ð¸Ñ Ð² поле аÑÑибÑÑивной ÑаблиÑÑ."
-#: ../gui/wxpython/menustrings.py:555
+#: ../gui/wxpython/menustrings.py:557
msgid "Generate area for current region"
msgstr "СоздаÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ñ Ð´Ð»Ñ Ð´Ð°Ð½Ð½Ð¾Ð³Ð¾ Ñегиона"
-#: ../gui/wxpython/menustrings.py:556
+#: ../gui/wxpython/menustrings.py:558
msgid "Create a new vector from the current region."
msgstr "СоздаÑÑ Ð½Ð¾Ð²Ñй векÑоÑнÑй Ñлой из данного Ñегиона."
-#: ../gui/wxpython/menustrings.py:557
+#: ../gui/wxpython/menustrings.py:559
msgid "Generate areas from points"
msgstr "СоздаÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ñ Ð¸Ð· ÑоÑек"
-#: ../gui/wxpython/menustrings.py:558
+#: ../gui/wxpython/menustrings.py:560
msgid "Convex hull"
msgstr "ÐонвекÑнÑй полигон"
-#: ../gui/wxpython/menustrings.py:559
+#: ../gui/wxpython/menustrings.py:561
msgid "Uses a GRASS vector points map to produce a convex hull vector map."
msgstr ""
"ÐÑполÑзоваÑÑ Ð²ÐµÐºÑоÑнÑе ÑоÑки GRASS Ð´Ð»Ñ ÑÐ¾Ð·Ð´Ð°Ð½Ð¸Ñ ÑÐ»Ð¾Ñ Ñ ÐºÐ¾Ð½Ð²ÐµÐºÑнÑм полигоном."
-#: ../gui/wxpython/menustrings.py:560
+#: ../gui/wxpython/menustrings.py:562
msgid "Delaunay triangles"
msgstr "ТÑеÑголÑники ÐелонÑ"
-#: ../gui/wxpython/menustrings.py:561
+#: ../gui/wxpython/menustrings.py:563
msgid ""
"Creates a Delaunay triangulation from an input vector map containing points "
"or centroids."
@@ -6960,11 +7224,11 @@
"ÐоÑÑÑоиÑÑ ÑÑиангÑлÑÑÐ¸Ñ ÐÐµÐ»Ð¾Ð½Ñ Ð½Ð° оÑнове иÑÑ
одного векÑоÑного ÑлоÑ, "
"ÑодеÑжаÑего ÑоÑки или ÑенÑÑоидÑ."
-#: ../gui/wxpython/menustrings.py:562
+#: ../gui/wxpython/menustrings.py:564
msgid "Voronoi diagram/Thiessen polygons"
msgstr "ÐиагÑамма ÐоÑоного/ÐÐ¾Ð»Ð¸Ð³Ð¾Ð½Ñ Ð¢Ð¸ÑÑена"
-#: ../gui/wxpython/menustrings.py:563
+#: ../gui/wxpython/menustrings.py:565
msgid ""
"Creates a Voronoi diagram from an input vector map containing points or "
"centroids."
@@ -6972,74 +7236,74 @@
"ÐоÑÑÑоиÑÑ Ð´Ð¸Ð°Ð³ÑÐ°Ð¼Ð¼Ñ ÐоÑоного на оÑнове иÑÑ
-#: ../gui/wxpython/menustrings.py:564
+#: ../gui/wxpython/menustrings.py:566
msgid "Generate grid"
msgstr "СоздаÑÑ Ð³Ñид"
-#: ../gui/wxpython/menustrings.py:565
+#: ../gui/wxpython/menustrings.py:567
msgid "Creates a GRASS vector map of a user-defined grid."
msgstr "СоздаÑÑ Ð²ÐµÐºÑоÑнÑй Ñлой GRASS из заданного полÑзоваÑелем гÑида."
-#: ../gui/wxpython/menustrings.py:566
+#: ../gui/wxpython/menustrings.py:568
msgid "Generate points"
msgstr "СоздаÑÑ ÑоÑки"
-#: ../gui/wxpython/menustrings.py:567
+#: ../gui/wxpython/menustrings.py:569
msgid "Generate from database"
msgstr "СоздаÑÑ Ð¸Ð· Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/wxpython/menustrings.py:568
+#: ../gui/wxpython/menustrings.py:570
msgid ""
"Creates new vector (points) map from database table containing coordinates."
msgstr ""
"СоздаÑÑ Ð½Ð¾Ð²Ñй векÑоÑнÑй (ÑоÑеÑнÑй) Ñлой из ÑаблиÑÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
, ÑодеÑжаÑей "
"кооÑдинаÑÑ."
-#: ../gui/wxpython/menustrings.py:569
+#: ../gui/wxpython/menustrings.py:571
msgid "Generate points along lines"
msgstr "СоздаÑÑ ÑоÑки Ð²Ð´Ð¾Ð»Ñ Ð»Ð¸Ð½Ð¸Ð¹"
-#: ../gui/wxpython/menustrings.py:570
+#: ../gui/wxpython/menustrings.py:572
msgid "Create points along input lines in new vector with 2 layers."
msgstr "СоздаÑÑ ÑоÑки Ð²Ð´Ð¾Ð»Ñ Ð¸ÑÑ
однÑÑ
линий в новÑй векÑÐ¾Ñ Ñ Ð´Ð²ÑÐ¼Ñ ÑлоÑми."
-#: ../gui/wxpython/menustrings.py:571
+#: ../gui/wxpython/menustrings.py:573
msgid "Generate random points"
msgstr "СоздаÑÑ ÑлÑÑайнÑе ÑоÑки"
-#: ../gui/wxpython/menustrings.py:572
+#: ../gui/wxpython/menustrings.py:574
msgid "Randomly generate a 2D/3D vector points map."
msgstr "Создание ÑлÑÑайнÑÑ
2D/3D Ñлоев ÑоÑек."
-#: ../gui/wxpython/menustrings.py:573
+#: ../gui/wxpython/menustrings.py:575
msgid "Perturb points"
msgstr "СмеÑÑиÑÑ Ð¿Ð¾Ð»Ð¾Ð¶ÐµÐ½Ð¸Ðµ ÑоÑек"
-#: ../gui/wxpython/menustrings.py:574
+#: ../gui/wxpython/menustrings.py:576
msgid "Random location perturbations of GRASS vector points"
msgstr "СлÑÑайное ÑмеÑение меÑÑоположений векÑоÑнÑÑ
ÑоÑек GRASS"
-#: ../gui/wxpython/menustrings.py:575
+#: ../gui/wxpython/menustrings.py:577
msgid "Remove outliers in point sets"
msgstr "УдалиÑÑ Ð¾Ð±Ð¾ÑобленнÑе ÑоÑки из набоÑа"
-#: ../gui/wxpython/menustrings.py:576
+#: ../gui/wxpython/menustrings.py:578
msgid "Removes outliers from vector point data."
msgstr "УдалиÑÑ Ð¾Ð±Ð¾ÑобленнÑе ÑоÑки из векÑоÑнÑÑ
ÑоÑеÑнÑÑ
даннÑÑ
-#: ../gui/wxpython/menustrings.py:577
+#: ../gui/wxpython/menustrings.py:579
msgid "Test/training point sets"
msgstr "ÐÑовеÑоÑнÑе/ÑÑениÑовоÑнÑе набоÑÑ ÑоÑек"
-#: ../gui/wxpython/menustrings.py:578
+#: ../gui/wxpython/menustrings.py:580
msgid "Randomly partition points into test/train sets."
msgstr "СлÑÑайно ÑазделиÑÑ ÑоÑки в пÑовеÑоÑнÑе/ÑÑениÑовоÑнÑе набоÑÑ."
-#: ../gui/wxpython/menustrings.py:579
+#: ../gui/wxpython/menustrings.py:581
msgid "Update area attributes from raster"
msgstr "ÐбновиÑÑ Ð°ÑÑибÑÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ð° из ÑаÑÑÑа"
-#: ../gui/wxpython/menustrings.py:580
+#: ../gui/wxpython/menustrings.py:582
msgid ""
"Calculates univariate statistics from a GRASS raster map based on vector "
"polygons and uploads statistics to new attribute columns."
@@ -7047,71 +7311,71 @@
"РаÑÑÑиÑаÑÑ Ð¾Ð´Ð½Ð¾Ð¼ÐµÑнÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð¸Ð· ÑаÑÑÑового ÑÐ»Ð¾Ñ GRASS, иÑполÑзÑÑ "
"векÑоÑнÑе полигонÑ, и загÑÑзиÑÑ ÐµÐµ в новÑе Ð¿Ð¾Ð»Ñ Ð°ÑÑибÑÑов."
-#: ../gui/wxpython/menustrings.py:581
+#: ../gui/wxpython/menustrings.py:583
msgid "Update point attributes from areas"
msgstr "ÐбновиÑÑ Ð°ÑÑибÑÑÑ ÑоÑек иÑполÑзÑÑ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ñ"
-#: ../gui/wxpython/menustrings.py:582
+#: ../gui/wxpython/menustrings.py:584
msgid "Uploads vector values at positions of vector points to the table."
msgstr "ÐагÑÑзиÑÑ Ð² ÑаблиÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ð²ÐµÐºÑоÑа в ÑоÑкаÑ
векÑоÑного ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:583
+#: ../gui/wxpython/menustrings.py:585
msgid "Update point attributes from raster"
msgstr "ÐбновиÑÑ Ð°ÑÑибÑÑÑ ÑоÑки иÑполÑзÑÑ ÑаÑÑÑ."
-#: ../gui/wxpython/menustrings.py:584
+#: ../gui/wxpython/menustrings.py:586
msgid "Sample raster maps at point locations"
msgstr ""
"ÐолÑÑиÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÑаÑÑÑовÑÑ
Ñлоев в меÑÑоположениÑÑ
, опÑеделеннÑÑ
векÑоÑнÑми "
"ÑоÑками"
-#: ../gui/wxpython/menustrings.py:585
+#: ../gui/wxpython/menustrings.py:587
msgid "Uploads raster values at positions of vector points to the table."
msgstr "ÐагÑÑзиÑÑ Ð² ÑаблиÑÑ ÑаÑÑÑовÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð² ÑоÑкаÑ
векÑоÑного ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:586
+#: ../gui/wxpython/menustrings.py:588
msgid "Sample raster neighborhood around points"
msgstr "ÐолÑÑаÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÑаÑÑÑа в окÑеÑÑноÑÑÑÑ
ÑоÑек"
-#: ../gui/wxpython/menustrings.py:587
+#: ../gui/wxpython/menustrings.py:589
msgid "Samples a raster map at vector point locations."
msgstr ""
"ÐолÑÑиÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð² меÑÑоположениÑÑ
, опÑеделеннÑÑ
векÑоÑнÑми "
"ÑоÑками."
-#: ../gui/wxpython/menustrings.py:588
+#: ../gui/wxpython/menustrings.py:590
msgid "Reports and statistics"
msgstr "ÐÑÑеÑÑ Ð¸ ÑÑаÑиÑÑика"
-#: ../gui/wxpython/menustrings.py:589
+#: ../gui/wxpython/menustrings.py:591
msgid "Basic vector metadata"
msgstr "ÐÑновнÑе векÑоÑнÑе меÑаданнÑе"
-#: ../gui/wxpython/menustrings.py:590
+#: ../gui/wxpython/menustrings.py:592
msgid "Outputs basic information about a user-specified vector map layer."
msgstr "ÐÑвеÑÑи оÑновнÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ векÑоÑном Ñлое, вÑбÑанном полÑзоваÑелем."
-#: ../gui/wxpython/menustrings.py:591
+#: ../gui/wxpython/menustrings.py:593
msgid "Report topology by category"
msgstr "ÐоказаÑÑ ÑÐ¾Ð¿Ð¾Ð»Ð¾Ð³Ð¸Ñ Ð¿Ð¾ каÑегоÑии"
-#: ../gui/wxpython/menustrings.py:592
+#: ../gui/wxpython/menustrings.py:594
msgid "Reports geometry statistics for vectors."
msgstr "ÐоказаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð³ÐµÐ¾Ð¼ÐµÑÑии Ð´Ð»Ñ Ð²ÐµÐºÑоÑов."
-#: ../gui/wxpython/menustrings.py:593
+#: ../gui/wxpython/menustrings.py:595
msgid "Upload or report topology"
msgstr "ÐагÑÑзиÑÑ Ð¸Ð»Ð¸ показаÑÑ ÑопологиÑ"
-#: ../gui/wxpython/menustrings.py:594
+#: ../gui/wxpython/menustrings.py:596
msgid "Populate database values from vector features."
msgstr "ÐаполниÑÑ Ð·Ð½Ð°ÑÐµÐ½Ð¸Ñ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
из векÑоÑнÑÑ
обÑекÑов."
-#: ../gui/wxpython/menustrings.py:595
+#: ../gui/wxpython/menustrings.py:597
msgid "Univariate attribute statistics"
msgstr "ÐдномеÑÐ½Ð°Ñ Ð°ÑÑибÑÑÐ¸Ð²Ð½Ð°Ñ ÑÑаÑиÑÑика"
-#: ../gui/wxpython/menustrings.py:596
+#: ../gui/wxpython/menustrings.py:598
msgid ""
"Calculates univariate statistics for attribute. Variance and standard "
"deviation is calculated only for points if specified."
@@ -7119,90 +7383,90 @@
"РаÑÑÑиÑаÑÑ Ð¾Ð´Ð½Ð¾Ð¼ÐµÑнÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð´Ð»Ñ Ð°ÑÑибÑÑов. ÐаÑиаÑÐ¸Ñ Ð¸ ÑÑандаÑÑное "
"оÑклонение ÑаÑÑÑиÑÑваеÑÑÑ ÑолÑко Ð´Ð»Ñ Ð²ÑделеннÑÑ
ÑоÑек."
-#: ../gui/wxpython/menustrings.py:597
+#: ../gui/wxpython/menustrings.py:599
msgid "Quadrat indices"
msgstr "ÐвадÑаÑиÑеÑкие индекÑÑ"
-#: ../gui/wxpython/menustrings.py:598
+#: ../gui/wxpython/menustrings.py:600
msgid "Indices for quadrat counts of sites lists."
msgstr "ÐндекÑÑ Ð´Ð»Ñ ÐºÐ²Ð°Ð´ÑаÑов ÑÑеÑа ÑпиÑка меÑÑоположений."
-#: ../gui/wxpython/menustrings.py:599
+#: ../gui/wxpython/menustrings.py:601
msgid "Test normality"
msgstr "ТеÑÑ Ð½Ð¾ÑмалÑноÑÑи"
-#: ../gui/wxpython/menustrings.py:600
+#: ../gui/wxpython/menustrings.py:602
msgid "Tests for normality for points."
msgstr "ТеÑÑ Ð½Ð¾ÑмалÑноÑÑи Ð´Ð»Ñ ÑоÑек."
-#: ../gui/wxpython/menustrings.py:601
+#: ../gui/wxpython/menustrings.py:603
msgid "Imagery"
msgstr "ÐзобÑажениÑ"
-#: ../gui/wxpython/menustrings.py:602
+#: ../gui/wxpython/menustrings.py:604
msgid "Develop images and groups"
msgstr "ÐбÑабоÑаÑÑ Ð¸Ð·Ð¾Ð±ÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð¸ гÑÑппÑ"
-#: ../gui/wxpython/menustrings.py:603
+#: ../gui/wxpython/menustrings.py:605
msgid "Create/edit group"
msgstr "СоздаÑÑ/ÑедакÑиÑоваÑÑ Ð³ÑÑппÑ"
-#: ../gui/wxpython/menustrings.py:604
+#: ../gui/wxpython/menustrings.py:606
msgid "Creates, edits, and lists groups and subgroups of imagery files."
msgstr ""
"СоздаÑÑ, ÑедакÑиÑоваÑÑ Ð¸ показаÑÑ ÑпиÑок гÑÑпп и подгÑÑпп Ñайлов изобÑажений."
-#: ../gui/wxpython/menustrings.py:605
+#: ../gui/wxpython/menustrings.py:607
msgid "Target group"
msgstr "Ð¦ÐµÐ»ÐµÐ²Ð°Ñ Ð³ÑÑппа"
-#: ../gui/wxpython/menustrings.py:606
+#: ../gui/wxpython/menustrings.py:608
msgid "Targets an imagery group to a GRASS location and mapset."
msgstr "ÐеÑемеÑÑиÑÑ Ð³ÑÑÐ¿Ð¿Ñ Ð¸Ð·Ð¾Ð±Ñажений в облаÑÑÑ Ð¸ Ð½Ð°Ð±Ð¾Ñ GRASS."
-#: ../gui/wxpython/menustrings.py:607
+#: ../gui/wxpython/menustrings.py:609
msgid "Mosaic images"
msgstr "ÐозаиÑиÑоваÑÑ Ð¸Ð·Ð¾Ð±ÑажениÑ"
-#: ../gui/wxpython/menustrings.py:608
+#: ../gui/wxpython/menustrings.py:610
msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
msgstr ""
"ÐозаиÑиÑоваÑÑ Ð´Ð¾ 4 изобÑажений и ÑаÑÑиÑиÑÑ ÑвеÑовÑÑ ÑаблиÑÑ; ÑоздаеÑÑÑ Ñлой "
"*.mosaic"
-#: ../gui/wxpython/menustrings.py:609
+#: ../gui/wxpython/menustrings.py:611
msgid "Manage image colors"
msgstr "УпÑавление ÑвеÑами изобÑажениÑ"
-#: ../gui/wxpython/menustrings.py:610
+#: ../gui/wxpython/menustrings.py:612
msgid "Color balance for RGB"
msgstr "ЦвеÑовой Ð±Ð°Ð»Ð°Ð½Ñ RGB"
-#: ../gui/wxpython/menustrings.py:611
+#: ../gui/wxpython/menustrings.py:613
msgid "Auto-balancing of colors for LANDSAT images"
msgstr "ÐвÑомаÑиÑеÑÐºÐ°Ñ Ð±Ð°Ð»Ð°Ð½ÑиÑовка ÑвеÑов Ð´Ð»Ñ Ð¸Ð·Ð¾Ð±ÑÐ°Ð¶ÐµÐ½Ð¸Ñ LANDSAT"
-#: ../gui/wxpython/menustrings.py:612
+#: ../gui/wxpython/menustrings.py:614
msgid "HIS to RGB"
msgstr "HIS в RGB"
-#: ../gui/wxpython/menustrings.py:613
+#: ../gui/wxpython/menustrings.py:615
msgid ""
"Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color "
"transformation function."
msgstr "HIS или RGB ÑÑанÑÑоÑмаÑÐ¸Ñ ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:615
+#: ../gui/wxpython/menustrings.py:617
msgid ""
"Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color "
"transformation function"
msgstr "RGB или HIS ÑÑанÑÑоÑмаÑÐ¸Ñ ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:616
+#: ../gui/wxpython/menustrings.py:618
msgid "Rectify image or raster"
msgstr "РекÑиÑиÑиÑоваÑÑ Ð¸Ð·Ð¾Ð±Ñажение или ÑаÑÑÑ"
-#: ../gui/wxpython/menustrings.py:617
+#: ../gui/wxpython/menustrings.py:619
msgid ""
"Rectifies an image by computing a coordinate transformation for each pixel "
"in the image based on the control points"
@@ -7210,34 +7474,34 @@
"РекÑиÑиÑиÑоваÑÑ Ð¸Ð·Ð¾Ð±Ñажение пÑÑем ÑÑанÑÑоÑмаÑии кооÑÐ´Ð¸Ð½Ð°Ñ Ð´Ð»Ñ ÐºÐ°Ð¶Ð´Ð¾Ð³Ð¾ "
"пикÑела, иÑполÑзÑÑ ÐºÐ¾Ð½ÑÑолÑнÑе ÑоÑки"
-#: ../gui/wxpython/menustrings.py:618
+#: ../gui/wxpython/menustrings.py:620
msgid "Ortho photo rectification (requires Xterm)"
msgstr "ÐÑÑоÑоÑоÑÑанÑÑоÑмаÑÐ¸Ñ (ÑÑебÑеÑÑÑ Xterm)"
-#: ../gui/wxpython/menustrings.py:619
+#: ../gui/wxpython/menustrings.py:621
msgid "Ortho Photo rectification"
msgstr "ÐÑÑоÑоÑоÑÑанÑÑоÑмаÑиÑ"
-#: ../gui/wxpython/menustrings.py:620
+#: ../gui/wxpython/menustrings.py:622
msgid "Brovey sharpening"
msgstr "ÑвелиÑение ÑезкоÑÑи по ÐÑÑви"
-#: ../gui/wxpython/menustrings.py:621
+#: ../gui/wxpython/menustrings.py:623
msgid ""
"Brovey transform to merge multispectral and high-res panchromatic channels"
msgstr ""
"ТÑанÑÑоÑмиÑование по ÐÑÑви Ð´Ð»Ñ Ð¿Ð¾ÑледÑÑÑего обÑÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ð¼ÑлÑÑиÑпекÑÑалÑнÑÑ
и "
"панÑ
ÑомаÑиÑеÑкиÑ
каналов вÑÑокого ÑазÑеÑениÑ"
-#: ../gui/wxpython/menustrings.py:622
+#: ../gui/wxpython/menustrings.py:624
msgid "Classify image"
msgstr "ÐлаÑÑиÑиÑиÑоваÑÑ Ð¸Ð·Ð¾Ð±Ñажение"
-#: ../gui/wxpython/menustrings.py:623
+#: ../gui/wxpython/menustrings.py:625
msgid "Clustering input for unsupervised classification"
msgstr "ÐлаÑÑеÑизаÑÐ¸Ñ Ð¸ÑÑ
однÑÑ
даннÑÑ
Ð´Ð»Ñ ÐºÐ»Ð°ÑÑиÑикаÑии без обÑÑениÑ"
-#: ../gui/wxpython/menustrings.py:624
+#: ../gui/wxpython/menustrings.py:626
msgid ""
"The resulting signature file is used as input for i.maxlik, to generate an "
"unsupervised image classification."
@@ -7245,11 +7509,11 @@
"ÐÑÑ
одной Ñайл ÑÑалонов, иÑполÑзÑемÑй как иÑÑ
однÑй Ð´Ð»Ñ i.maxlik, Ð´Ð»Ñ Ñого "
"клаÑÑиÑикаÑии без обÑÑениÑ."
-#: ../gui/wxpython/menustrings.py:625
+#: ../gui/wxpython/menustrings.py:627
msgid "Maximum likelihood classification (MLC)"
msgstr "ÐлаÑÑиÑикаÑÐ¸Ñ Ð¼Ð°ÐºÑималÑного Ð¿Ð¾Ð´Ð¾Ð±Ð¸Ñ (MLC)"
-#: ../gui/wxpython/menustrings.py:626
+#: ../gui/wxpython/menustrings.py:628
msgid ""
"Classification is based on the spectral signature information generated by "
"either i.cluster, i.class, or i.gensig."
@@ -7257,11 +7521,11 @@
"ÐлаÑÑиÑикаÑÐ¸Ñ Ð¾Ñнована на ÑпекÑÑалÑной инÑоÑмаÑии ÑÑалонов, полÑÑеннÑÑ
Ñ "
"помоÑÑÑ Ð»Ð¸Ð±Ð¾ i.cluster, либо i.class, либо i.gensig."
-#: ../gui/wxpython/menustrings.py:627
+#: ../gui/wxpython/menustrings.py:629
msgid "Sequential maximum a posteriori classification (SMAP)"
msgstr "Sequential maximum a posteriori classification (SMAP)"
-#: ../gui/wxpython/menustrings.py:628
+#: ../gui/wxpython/menustrings.py:630
msgid ""
"Performs contextual image classification using sequential maximum a "
"posteriori (SMAP) estimation."
@@ -7269,134 +7533,134 @@
"ÐÑоизвеÑÑи конÑекÑÑнÑÑ ÐºÐ»Ð°ÑÑиÑикаÑÐ¸Ñ Ð¸Ð·Ð¾Ð±ÑÐ°Ð¶ÐµÐ½Ð¸Ñ Ð¸ÑполÑзÑÑ Ð¾ÑÐµÐ½ÐºÑ sequential "
"maximum a posteriori (SMAP)."
-#: ../gui/wxpython/menustrings.py:629
+#: ../gui/wxpython/menustrings.py:631
msgid "Interactive input for supervised classification (requires Xterm)"
msgstr "ÐнÑеÑакÑивнÑй ввод Ð´Ð»Ñ ÐºÐ»Ð°ÑÑиÑикаÑии Ñ Ð¾Ð±ÑÑением (ÑÑебÑеÑÑÑ Xterm)"
-#: ../gui/wxpython/menustrings.py:630
+#: ../gui/wxpython/menustrings.py:632
msgid "Interactive input for supervised classification"
msgstr "ÐнÑеÑакÑивнÑй ввод Ð´Ð»Ñ ÐºÐ»Ð°ÑÑиÑикаÑии Ñ Ð¾Ð±ÑÑением"
-#: ../gui/wxpython/menustrings.py:631
+#: ../gui/wxpython/menustrings.py:633
msgid "Input for supervised MLC"
msgstr "ÐÑÑ
однÑе даннÑе Ð´Ð»Ñ MLC Ñ Ð¾Ð±ÑÑением"
-#: ../gui/wxpython/menustrings.py:632
+#: ../gui/wxpython/menustrings.py:634
msgid "Generates statistics for i.maxlik from raster map layer."
msgstr "СоздаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð´Ð»Ñ i.maxlik из ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:633
+#: ../gui/wxpython/menustrings.py:635
msgid "Input for supervised SMAP"
msgstr "ÐÑ
однÑе даннÑе Ð´Ð»Ñ SMAP Ñ Ð¾Ð±ÑÑением"
-#: ../gui/wxpython/menustrings.py:634
+#: ../gui/wxpython/menustrings.py:636
msgid "Generate statistics for i.smap from raster map layer."
msgstr "СоздаÑÑ ÑÑаÑиÑÑÐ¸ÐºÑ Ð´Ð»Ñ i.smap из ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:635
+#: ../gui/wxpython/menustrings.py:637
msgid "Filter image"
msgstr "ФилÑÑÑоваÑÑ Ð¸Ð·Ð¾Ð±Ñажение"
-#: ../gui/wxpython/menustrings.py:636
+#: ../gui/wxpython/menustrings.py:638
msgid "Edge detection"
msgstr "ÐпÑеделение гÑаниÑ"
-#: ../gui/wxpython/menustrings.py:637
+#: ../gui/wxpython/menustrings.py:639
msgid "Zero-crossing \"edge detection\" raster function for image processing."
msgstr ""
"РаÑÑÑÐ¾Ð²Ð°Ñ ÑÑнкÑÐ¸Ñ Ð´Ð»Ñ Ð¾Ð±ÑабоÑки изобÑажений \"опÑеделение гÑаний\" Ñ "
"пеÑеÑеÑением нÑлевого знаÑениÑ."
-#: ../gui/wxpython/menustrings.py:638
+#: ../gui/wxpython/menustrings.py:640
msgid "Matrix/convolving filter"
msgstr "ÐаÑÑиÑнÑй/ÑвеÑнÑÑÑй ÑилÑÑÑ"
-#: ../gui/wxpython/menustrings.py:639
+#: ../gui/wxpython/menustrings.py:641
msgid "Raster map matrix filter."
msgstr "ÐаÑÑиÑнÑй ÑилÑÑÑ ÑаÑÑÑового ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:641
+#: ../gui/wxpython/menustrings.py:643
msgid "Generate histogram of image"
msgstr "СоздаÑÑ Ð³Ð¸ÑÑогÑÐ°Ð¼Ð¼Ñ Ð¸Ð·Ð¾Ð±ÑажениÑ"
-#: ../gui/wxpython/menustrings.py:642
+#: ../gui/wxpython/menustrings.py:644
msgid "Spectral response"
msgstr "СпекÑÑалÑÐ½Ð°Ñ Ñ
аÑакÑеÑиÑÑика"
-#: ../gui/wxpython/menustrings.py:643
+#: ../gui/wxpython/menustrings.py:645
msgid ""
"displays spectral response at user specified locations in group or images"
msgstr ""
"ÐоказаÑÑ ÑпекÑÑалÑное оÑÑажение Ð´Ð»Ñ Ð³ÑÑпп или изобÑажений, опÑеделеннÑÑ
"полÑзоваÑелем"
-#: ../gui/wxpython/menustrings.py:644
+#: ../gui/wxpython/menustrings.py:646
msgid "Tasseled cap vegetation index"
msgstr "ÐÐ½Ð´ÐµÐºÑ Ð²ÐµÐ³ÐµÑаÑии Tasseled cap"
-#: ../gui/wxpython/menustrings.py:645
+#: ../gui/wxpython/menustrings.py:647
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
msgstr "ТÑанÑÑоÑмаÑÐ¸Ñ Tasseled Cap (Kauth Thomas) Ð´Ð»Ñ Ð´Ð°Ð½Ð½ÑÑ
LANDSAT-TM"
-#: ../gui/wxpython/menustrings.py:646
+#: ../gui/wxpython/menustrings.py:648
msgid "Transform image"
msgstr "ТÑанÑÑоÑмиÑоваÑÑ Ð¸Ð·Ð¾Ð±Ñажение"
-#: ../gui/wxpython/menustrings.py:647
+#: ../gui/wxpython/menustrings.py:649
msgid "Canonical correlation"
msgstr "ÐанониÑеÑÐºÐ°Ñ ÐºÐ¾ÑÑелÑÑиÑ"
-#: ../gui/wxpython/menustrings.py:648
+#: ../gui/wxpython/menustrings.py:650
msgid "Canonical components analysis (cca) program for image processing."
msgstr ""
"ÐÑогÑамма канониÑеÑкого компоненÑного анализа (cca) Ð´Ð»Ñ Ð¾Ð±ÑабоÑки изобÑажений"
-#: ../gui/wxpython/menustrings.py:649
+#: ../gui/wxpython/menustrings.py:651
msgid "Principal components"
msgstr "ÐлавнÑе компоненÑÑ"
-#: ../gui/wxpython/menustrings.py:650
+#: ../gui/wxpython/menustrings.py:652
msgid "Principal components analysis (pca) program for image processing."
msgstr "ÐÑогÑамма анализа главнÑÑ
ÐºÐ¾Ð¼Ð¿Ð¾Ð½ÐµÐ½Ñ (pca) Ð´Ð»Ñ Ð¾Ð±ÑабоÑки изобÑажений."
-#: ../gui/wxpython/menustrings.py:651
+#: ../gui/wxpython/menustrings.py:653
msgid "Fast Fourier"
msgstr "ÐÑÑÑÑое пÑеобÑазование ФÑÑÑе"
-#: ../gui/wxpython/menustrings.py:652
+#: ../gui/wxpython/menustrings.py:654
msgid "Fast Fourier Transform (FFT) for image processing."
msgstr "ÐÑÑÑÑое пÑеобÑазование ФÑÑÑе (FFT) Ð´Ð»Ñ Ð¾Ð±ÑабоÑки изобÑажений."
-#: ../gui/wxpython/menustrings.py:653
+#: ../gui/wxpython/menustrings.py:655
msgid "Inverse Fast Fourier"
msgstr "ÐбÑаÑное бÑÑÑÑое пÑеобÑазование ФÑÑÑе"
-#: ../gui/wxpython/menustrings.py:654
+#: ../gui/wxpython/menustrings.py:656
msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
msgstr ""
"ÐбÑаÑное бÑÑÑÑое пÑеобÑазование ФÑÑÑе (IFFT) Ð´Ð»Ñ Ð¾Ð±ÑабоÑки изобÑажений/"
-#: ../gui/wxpython/menustrings.py:655
+#: ../gui/wxpython/menustrings.py:657
msgid "Atmospheric correction"
msgstr "ÐÑмоÑÑеÑÐ½Ð°Ñ ÐºÐ¾ÑÑекÑиÑ"
-#: ../gui/wxpython/menustrings.py:656
+#: ../gui/wxpython/menustrings.py:658
msgid "Performs atmospheric correction using the 6S algorithm."
msgstr "ÐÑоизвеÑÑи аÑмоÑÑеÑнÑÑ ÐºÐ¾ÑÑекÑÐ¸Ñ Ð¸ÑполÑзÑÑ Ð°Ð»Ð³Ð¾ÑиÑм 6S."
-#: ../gui/wxpython/menustrings.py:658
+#: ../gui/wxpython/menustrings.py:660
msgid "Bit pattern comparison "
msgstr "ÐиÑовое ÑÑавнение Ñаблонов"
-#: ../gui/wxpython/menustrings.py:659
+#: ../gui/wxpython/menustrings.py:661
msgid "Compares bit patterns with a raster map."
msgstr "СÑавниÑÑ Ð±Ð¸ÑовÑе ÑÐ°Ð±Ð»Ð¾Ð½Ñ Ñ ÑаÑÑÑовÑм Ñлоем."
-#: ../gui/wxpython/menustrings.py:660
+#: ../gui/wxpython/menustrings.py:662
msgid "Kappa analysis"
msgstr "Ðаппа анализ"
-#: ../gui/wxpython/menustrings.py:661
+#: ../gui/wxpython/menustrings.py:663
msgid ""
"Calculate error matrix and kappa parameter for accuracy assessment of "
"classification result."
@@ -7404,60 +7668,60 @@
"РаÑÑÑиÑаÑÑ Ð¼Ð°ÑÑиÑÑ Ð¾Ñибок и паÑамеÑÑ ÐºÐ°Ð¿Ð¿Ð° Ð´Ð»Ñ Ð¾Ñенки ÑоÑноÑÑи ÑезÑлÑÑаÑов "
"клаÑÑиÑикаÑии."
-#: ../gui/wxpython/menustrings.py:662
+#: ../gui/wxpython/menustrings.py:664
msgid "OIF for LandSat TM"
msgstr "OIF Ð´Ð»Ñ LandSat TM"
-#: ../gui/wxpython/menustrings.py:663
+#: ../gui/wxpython/menustrings.py:665
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
msgstr ""
"РаÑÑÑиÑаÑÑ ÑаблиÑÑ Optimum-Index-Factor Ð´Ð»Ñ ÐºÐ°Ð½Ð°Ð»Ð¾Ð² LANDSAT TM 1-5 и 7"
-#: ../gui/wxpython/menustrings.py:664
+#: ../gui/wxpython/menustrings.py:666
msgid "Volumes"
msgstr "ÐбÑемÑ"
-#: ../gui/wxpython/menustrings.py:665
+#: ../gui/wxpython/menustrings.py:667
msgid "Develop volumes"
msgstr "ÐбÑабоÑаÑÑ Ð¾Ð±ÑемÑ"
-#: ../gui/wxpython/menustrings.py:666
+#: ../gui/wxpython/menustrings.py:668
msgid "Manage 3D NULL values"
msgstr "УпÑавлÑÑÑ 3D NULL знаÑениÑми"
-#: ../gui/wxpython/menustrings.py:667
+#: ../gui/wxpython/menustrings.py:669
msgid "Explicitly create the 3D NULL-value bitmap file."
msgstr "СоздаÑÑ 3D биÑмÑп Ñайл Ñ NULL-знаÑениÑми."
-#: ../gui/wxpython/menustrings.py:668
+#: ../gui/wxpython/menustrings.py:670
msgid "Manage timestamp"
msgstr "УпÑавление вÑеменной меÑкой"
-#: ../gui/wxpython/menustrings.py:669
+#: ../gui/wxpython/menustrings.py:671
msgid "Print/add/remove a timestamp for a 3D raster map"
msgstr "ÐÑвеÑÑи/добавиÑÑ/ÑдалиÑÑ Ð²ÑеменнÑÑ Ð¼ÐµÑÐºÑ Ð´Ð»Ñ 3D ÑаÑÑÑового ÑлоÑ"
-#: ../gui/wxpython/menustrings.py:670
+#: ../gui/wxpython/menustrings.py:672
msgid "3D Mask"
msgstr "3D маÑка"
-#: ../gui/wxpython/menustrings.py:671
+#: ../gui/wxpython/menustrings.py:673
msgid "Establishes the current working 3D raster mask."
msgstr "УÑÑановиÑÑ ÑекÑÑÑÑ ÑÑеÑ
меÑнÑÑ ÑаÑÑÑовÑÑ Ð¼Ð°ÑкÑ."
-#: ../gui/wxpython/menustrings.py:672
+#: ../gui/wxpython/menustrings.py:674
msgid "3D raster map calculator"
msgstr "3D ÑаÑÑÑовÑй калÑкÑлÑÑоÑ"
-#: ../gui/wxpython/menustrings.py:673
+#: ../gui/wxpython/menustrings.py:675
msgid "Map calculator for volumetric map algebra"
msgstr "ÐалÑкÑлÑÑÐ¾Ñ Ñлоев Ð´Ð»Ñ Ð¾Ð±Ñемной алгебÑÑ"
-#: ../gui/wxpython/menustrings.py:674
+#: ../gui/wxpython/menustrings.py:676
msgid "Cross section"
msgstr "СеÑение"
-#: ../gui/wxpython/menustrings.py:675
+#: ../gui/wxpython/menustrings.py:677
msgid ""
"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
"map"
@@ -7465,11 +7729,11 @@
"СоздаÑÑ ÑекÑÑий двÑмеÑнÑй ÑаÑÑÑовÑй Ñлой из ÑÑеÑ
меÑного ÑаÑÑÑового ÑÐ»Ð¾Ñ Ð½Ð° "
"оÑнове двÑмеÑной каÑÑÑ Ð²ÑÑоÑ"
-#: ../gui/wxpython/menustrings.py:676
+#: ../gui/wxpython/menustrings.py:678
msgid "Interpolate volume from points"
msgstr "ÐнÑеÑполиÑоваÑÑ Ð¾Ð±Ñем по ÑоÑкам"
-#: ../gui/wxpython/menustrings.py:677
+#: ../gui/wxpython/menustrings.py:679
msgid ""
"Interpolates point data to a G3D grid volume using regularized spline with "
"tension (RST) algorithm."
@@ -7477,82 +7741,82 @@
"ÐнÑеÑполиÑоваÑÑ ÑоÑеÑнÑе даннÑе в G3D обÑемнÑй гÑид, иÑполÑзÑÑ Ð°Ð»Ð³Ð¾ÑиÑм "
"Ñплайн-инÑеÑполÑÑии (RST)."
-#: ../gui/wxpython/menustrings.py:678
+#: ../gui/wxpython/menustrings.py:680
msgid "Report and Statistics"
-#: ../gui/wxpython/menustrings.py:679
+#: ../gui/wxpython/menustrings.py:681
msgid "Basic volume metadata"
msgstr "ÐÑновнÑе меÑаданнÑе обÑема"
-#: ../gui/wxpython/menustrings.py:680
+#: ../gui/wxpython/menustrings.py:682
msgid "Outputs basic information about a user-specified 3D raster map layer."
msgstr ""
"ÐÑвеÑÑи оÑновнÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ ÑÑеÑ
меÑном векÑоÑном Ñлое, заданном "
"полÑзоваÑелем."
-#: ../gui/wxpython/menustrings.py:682
+#: ../gui/wxpython/menustrings.py:684
msgid "Database information"
msgstr "ÐнÑоÑмаÑÐ¸Ñ Ð¾ базе даннÑÑ
-#: ../gui/wxpython/menustrings.py:683
+#: ../gui/wxpython/menustrings.py:685
msgid "Describe table"
msgstr "ÐпиÑаÑÑ ÑаблиÑÑ"
-#: ../gui/wxpython/menustrings.py:684
+#: ../gui/wxpython/menustrings.py:686
msgid "Describes a table in detail."
msgstr "ÐеÑалÑно опиÑаÑÑ ÑаблиÑÑ"
-#: ../gui/wxpython/menustrings.py:685
+#: ../gui/wxpython/menustrings.py:687
msgid "List columns"
msgstr "СпиÑок полей"
-#: ../gui/wxpython/menustrings.py:686
+#: ../gui/wxpython/menustrings.py:688
msgid "List all columns for a given table."
msgstr "СпиÑок вÑеÑ
полей Ð´Ð»Ñ Ð´Ð°Ð½Ð½Ð¾Ð¹ ÑаблиÑÑ."
-#: ../gui/wxpython/menustrings.py:687
+#: ../gui/wxpython/menustrings.py:689
msgid "List drivers"
msgstr "СпиÑок дÑайвеÑов"
-#: ../gui/wxpython/menustrings.py:688
+#: ../gui/wxpython/menustrings.py:690
msgid "List all database drivers."
msgstr "СпиÑок вÑеÑ
дÑайвеÑов Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/wxpython/menustrings.py:689
+#: ../gui/wxpython/menustrings.py:691
msgid "List tables"
msgstr "СпиÑок ÑаблиÑ"
-#: ../gui/wxpython/menustrings.py:690
+#: ../gui/wxpython/menustrings.py:692
msgid "Lists all tables for a given database."
msgstr "СпиÑок вÑеÑ
ÑÐ°Ð±Ð»Ð¸Ñ Ð´Ð»Ñ Ð´Ð°Ð½Ð½Ð¾Ð¹ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/wxpython/menustrings.py:691
+#: ../gui/wxpython/menustrings.py:693
msgid "Manage databases"
msgstr "УпÑавление базами даннÑÑ
-#: ../gui/wxpython/menustrings.py:692
+#: ../gui/wxpython/menustrings.py:694
msgid "Connect"
msgstr "СвÑзÑ"
-#: ../gui/wxpython/menustrings.py:693
+#: ../gui/wxpython/menustrings.py:695
msgid "Prints/sets general DB connection for current mapset and exits."
msgstr ""
"ÐÑвеÑÑи/ÑÑÑановиÑÑ Ð¾Ð±ÑÑÑ ÑвÑÐ·Ñ Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
Ð´Ð»Ñ ÑекÑÑего набоÑа и вÑйÑи."
-#: ../gui/wxpython/menustrings.py:694
+#: ../gui/wxpython/menustrings.py:696
msgid "Login"
msgstr "Ðогин"
-#: ../gui/wxpython/menustrings.py:695
+#: ../gui/wxpython/menustrings.py:697
msgid "Sets user/password for driver/database."
msgstr "УÑÑановиÑÑ Ð¸Ð¼Ñ Ð¿Ð¾Ð»ÑзоваÑелÑ/паÑÐ¾Ð»Ñ Ð´Ð»Ñ Ð´ÑайвеÑа/Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/wxpython/menustrings.py:696
+#: ../gui/wxpython/menustrings.py:698
msgid "Copy table"
msgstr "ÐопиÑоваÑÑ ÑаблиÑÑ"
-#: ../gui/wxpython/menustrings.py:697
+#: ../gui/wxpython/menustrings.py:699
#, fuzzy
msgid ""
"Copy a table. Either 'from_table' (optionally with 'where') can be used or "
@@ -7561,11 +7825,11 @@
"ÐопиÑоваÑÑ ÑаблиÑÑ, иÑполÑзÑÑ Ð»Ð¸Ð±Ð¾ 'from_table' (еÑли необÑ
одимо Ñ "
"'where'), либо опÑÐ¸Ñ 'select', но не 'from_table' и 'select' одновÑеменно."
-#: ../gui/wxpython/menustrings.py:698
+#: ../gui/wxpython/menustrings.py:700
msgid "New table"
msgstr "ÐÐ¾Ð²Ð°Ñ ÑаблиÑа"
-#: ../gui/wxpython/menustrings.py:699
+#: ../gui/wxpython/menustrings.py:701
msgid ""
"Creates and adds a new attribute table to a given layer of an existing "
"vector map."
@@ -7573,19 +7837,19 @@
"СоздаÑÑ Ð¸ добавиÑÑ Ð½Ð¾Ð²ÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ Ð² даннÑй Ñлой ÑÑÑеÑÑвÑÑÑего "
"векÑоÑного ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:700
+#: ../gui/wxpython/menustrings.py:702
msgid "Remove table"
msgstr "УдалиÑÑ ÑаблиÑÑ"
-#: ../gui/wxpython/menustrings.py:701
+#: ../gui/wxpython/menustrings.py:703
msgid "Drops an attribute table."
msgstr "УдалиÑÑ Ð°ÑÑибÑÑивнÑÑ ÑаблиÑÑ."
-#: ../gui/wxpython/menustrings.py:702
+#: ../gui/wxpython/menustrings.py:704
msgid "Add columns"
msgstr "ÐобавиÑÑ Ð¿Ð¾Ð»Ðµ"
-#: ../gui/wxpython/menustrings.py:703
+#: ../gui/wxpython/menustrings.py:705
msgid ""
"Adds one or more columns to the attribute table connected to a given vector "
"map."
@@ -7593,103 +7857,137 @@
"ÐобавиÑÑ Ð¾Ð´Ð½Ð¾ или более полей к аÑÑибÑÑивной ÑаблиÑе, ÑвÑзанной Ñ Ð·Ð°Ð´Ð°Ð½Ð½Ñм "
"векÑоÑнÑм Ñлоем."
-#: ../gui/wxpython/menustrings.py:704
+#: ../gui/wxpython/menustrings.py:706
msgid "Change values"
msgstr "ÐзмениÑÑ Ð·Ð½Ð°ÑениÑ"
-#: ../gui/wxpython/menustrings.py:705
+#: ../gui/wxpython/menustrings.py:707
msgid ""
"Allows to update a column in the attribute table connected to a vector map."
msgstr "ÐбновиÑÑ Ð¿Ð¾Ð»Ðµ в аÑÑибÑÑивной ÑаблиÑе, ÑвÑзанной Ñ Ð²ÐµÐºÑоÑнÑм Ñлоем."
-#: ../gui/wxpython/menustrings.py:707
+#: ../gui/wxpython/menustrings.py:709
msgid ""
"Renames a column in the attribute table connected to a given vector map."
msgstr ""
"ÐеÑеименоваÑÑ Ð¿Ð¾Ð»Ðµ в аÑÑибÑÑивной ÑаблиÑе, ÑвÑзанной Ñ Ð´Ð°Ð½Ð½Ñм векÑоÑнÑм "
"Ñлоем."
-#: ../gui/wxpython/menustrings.py:708
+#: ../gui/wxpython/menustrings.py:710
msgid "Test"
msgstr "ТеÑÑ"
-#: ../gui/wxpython/menustrings.py:709
+#: ../gui/wxpython/menustrings.py:711
msgid "Test database driver, database must exist and set by db.connect."
msgstr ""
"ÐÑоÑеÑÑиÑоваÑÑ Ð´ÑÐ°Ð¹Ð²ÐµÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
. Ðаза даннÑÑ
должна ÑÑÑеÑÑвоваÑÑ Ð¸ бÑÑÑ "
"загÑÑжена Ñ Ð¿Ð¾Ð¼Ð¾ÑÑÑ db.connect."
-#: ../gui/wxpython/menustrings.py:710
+#: ../gui/wxpython/menustrings.py:712
msgid "Query"
msgstr "ÐапÑоÑ"
-#: ../gui/wxpython/menustrings.py:711
+#: ../gui/wxpython/menustrings.py:713
msgid "Query any table"
msgstr "СделаÑÑ Ð·Ð°Ð¿ÑÐ¾Ñ Ðº лÑбой ÑаблиÑе"
-#: ../gui/wxpython/menustrings.py:712
+#: ../gui/wxpython/menustrings.py:714
msgid "Selects data from table."
msgstr "ÐÑбÑаÑÑ Ð´Ð°Ð½Ð½Ñе из ÑаблиÑÑ"
-#: ../gui/wxpython/menustrings.py:713
+#: ../gui/wxpython/menustrings.py:715
msgid "Query vector attribute data"
msgstr "СделаÑÑ Ð·Ð°Ð¿ÑÐ¾Ñ Ðº векÑоÑнÑм аÑÑибÑÑивнÑм даннÑм"
-#: ../gui/wxpython/menustrings.py:714
+#: ../gui/wxpython/menustrings.py:716
msgid "Prints vector map attributes."
msgstr "ÐÑвеÑÑи аÑÑибÑÑÑ Ð²ÐµÐºÑоÑного ÑлоÑ."
-#: ../gui/wxpython/menustrings.py:715
+#: ../gui/wxpython/menustrings.py:717
msgid "SQL statement"
msgstr "ÐпеÑаÑÐ¾Ñ SQL"
-#: ../gui/wxpython/menustrings.py:716
+#: ../gui/wxpython/menustrings.py:718
msgid "Executes any SQL statement."
msgstr "ÐÑполниÑÑ Ð»Ñбой опеÑаÑÐ¾Ñ SQL."
-#: ../gui/wxpython/menustrings.py:717
+#: ../gui/wxpython/menustrings.py:719
msgid "Vector database connections"
msgstr "СвÑзи векÑоÑнÑÑ
баз даннÑÑ
-#: ../gui/wxpython/menustrings.py:718
+#: ../gui/wxpython/menustrings.py:720
msgid "Reconnect vector to database"
msgstr "СвÑзаÑÑ Ð·Ð°Ð½Ð¾Ð²Ð¾ векÑоÑнÑй Ñлой и Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/wxpython/menustrings.py:719
+#: ../gui/wxpython/menustrings.py:721
msgid "Reconnects vectors to a new database."
msgstr "СвÑзаÑÑ Ð·Ð°Ð½Ð¾Ð²Ð¾ векÑоÑнÑе Ñлои и новÑÑ Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
-#: ../gui/wxpython/menustrings.py:720
+#: ../gui/wxpython/menustrings.py:722
msgid "Set vector map - database connection"
msgstr "УÑÑановиÑÑ ÑвÑÐ·Ñ Ð²ÐµÐºÑоÑнÑй Ñлой - база даннÑÑ
-#: ../gui/wxpython/menustrings.py:721
+#: ../gui/wxpython/menustrings.py:723
msgid "Prints/sets DB connection for a vector map to attribute table."
msgstr ""
"ÐÑвеÑÑи/ÑÑÑановиÑÑ Ð´Ð»Ñ Ð²ÐµÐºÑоÑного ÑÐ»Ð¾Ñ ÑвÑÐ·Ñ Ñ Ð°ÑÑибÑÑивной ÑаблиÑей Ð±Ð°Ð·Ñ "
"даннÑÑ
-#: ../gui/wxpython/menustrings.py:722
+#: ../gui/wxpython/menustrings.py:724
msgid "Help"
msgstr "ÐомоÑÑ"
-#: ../gui/wxpython/menustrings.py:723
+#: ../gui/wxpython/menustrings.py:725
msgid "GRASS GIS help"
msgstr "ÐомоÑÑ ÐÐС GRASS"
-#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:726
+#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:728
msgid "Display the HTML man pages of GRASS"
msgstr "ÐоказаÑÑ HTML-ÑÑÑаниÑÑ Ð¿Ð¾Ð¼Ð¾Ñи GRASS"
-#: ../gui/wxpython/menustrings.py:725
+#: ../gui/wxpython/menustrings.py:727
msgid "GRASS GIS GUI help"
msgstr "помоÑÑ Ð¿Ð¾ инÑеÑÑейÑÑ ÐÐС GRASS"
-#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:728
+#: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:730
msgid "About GRASS GIS"
msgstr "Ð ÐÐС GRASS"
#~ msgid ""
+#~ "Unable to start Nviz. The OpenGL package was not found. You can get it at "
+#~ "http://PyOpenGL.sourceforge.net. Switching back to 2D display mode.\n"
+#~ "\n"
+#~ "Details: %s"
+#~ msgstr ""
+#~ "Ðевозможно запÑÑÑиÑÑ Nviz. Ðе найден Ð¿Ð°ÐºÐµÑ OpenGL. ÐÑ Ð¼Ð¾Ð¶ÐµÑе его "
+#~ "загÑÑзиÑÑ Ð¿Ð¾ адÑеÑÑ: http://PyOpenGL.sourceforge.net. ÐозвÑаÑение к 2D "
+#~ "ÑежимÑ.\n"
+#~ "\n"
+#~ "ÐодÑобноÑÑи: %s"
+#~ msgid "Click here to show database connection information"
+#~ msgstr ""
+#~ "ÐажмиÑе здеÑÑ, ÑÑÐ¾Ð±Ñ Ð¿Ð¾ÐºÐ°Ð·Ð°ÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ Ñоединении Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
+#~ msgid "Click here to hide database connection information"
+#~ msgstr "ÐажмиÑе здеÑÑ, ÑÑÐ¾Ð±Ñ ÑкÑÑÑÑ Ð¸Ð½ÑоÑмаÑÐ¸Ñ Ð¾ Ñоединении Ñ Ð±Ð°Ð·Ð¾Ð¹ даннÑÑ
+#~ msgid "Encoding"
+#~ msgstr "ÐодиÑовка"
+#~ msgid "Note: Requires GUI restart."
+#~ msgstr "ÐÑимеÑание: ÐÑжен пеÑезапÑÑк инÑеÑÑейÑа."
+#~ msgid "Group"
+#~ msgstr "ÐÑÑппа"
+#~ msgid "Unable to read EPGS codes: %s"
+#~ msgstr "Ðевозможно пÑоÑиÑаÑÑ ÐºÐ¾Ð´Ñ EPSG: %s"
+#~ msgid "Datums:"
+#~ msgstr "ÐаÑÑмÑ:"
+#~ msgid ""
#~ "File <%(file)s>: Unable to get list of DXF layers.\n"
#~ "\n"
#~ "%(details)s"
@@ -7698,6 +7996,15 @@
#~ "\n"
#~ "%(details)s"
+#~ msgid "Output vector map name"
+#~ msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного векÑоÑного ÑлоÑ"
+#~ msgid "GRASS GIS Layer Manager (Experimental Prototype)"
+#~ msgstr "ÐÐµÐ½ÐµÐ´Ð¶ÐµÑ Ñлоев ÐÐС GRASS (ÐкÑпеÑименÑалÑнÑй пÑоÑоÑип)"
+#~ msgid "Save current settings?"
+#~ msgstr "СоÑ
ÑаниÑÑ ÑекÑÑие наÑÑÑойки?"
#~ msgid "New workspace"
#~ msgstr "ÐовÑй пÑоекÑ"
@@ -7716,6 +8023,10 @@
#~ msgid "Save current workspace as file"
#~ msgstr "СоÑ
ÑаниÑÑ ÑекÑÑий пÑÐ¾ÐµÐºÑ ÐºÐ°Ðº Ñайл"
+#, fuzzy
+#~ msgid "Close current workspace"
+#~ msgstr "ÐакÑÑÑÑ ÑекÑÑий Ñайл пÑоекÑа"
#~ msgid "Close current workspace file"
@@ -7737,6 +8048,9 @@
#~ msgid "Modify selected layer"
#~ msgstr "ÐзмениÑÑ Ð²ÑбÑаннÑй Ñлой"
+#~ msgid "All"
+#~ msgstr "ÐÑе"
#~ msgid "Cancel the command settings and ignore changes"
#~ msgstr "ÐÑмениÑÑ ÑÑÑановки ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ Ð¸ игноÑиÑоваÑÑ Ð¸Ð·Ð¼ÐµÐ½ÐµÐ½Ð¸Ñ"
@@ -7771,9 +8085,6 @@
#~ msgid "Undo is not implemented in vedit component. Use vdigit instead."
#~ msgstr "ÐÑмена не Ñеализована в компоненÑе vedit. ÐÑполÑзÑйÑе vdigit."
-#~ msgid "Adding new feature to vector map <%s> failed."
-#~ msgstr "Ðобавление нового обÑекÑа к векÑоÑÐ½Ð¾Ð¼Ñ ÑÐ»Ð¾Ñ <%s> не вÑполнено."
#~ msgid "This vector map is used for snapping and copying features."
#~ msgstr "ÐекÑоÑнÑй Ñлой иÑполÑзÑемÑй Ð´Ð»Ñ Ð¿ÑÐ¸Ð»Ð¸Ð¿Ð°Ð½Ð¸Ñ Ð¸ копиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð¾Ð±ÑекÑов."
