[GRASS-SVN] r37385 - grass/trunk/raster/r.ros
svn_grass at osgeo.org
Fri May 22 21:24:08 EDT 2009
Author: glynn
Date: 2009-05-22 21:24:08 -0400 (Fri, 22 May 2009)
New Revision: 37385
grass/trunk/raster/r.ros/r.ros.html
Add missing <DD> tag
Modified: grass/trunk/raster/r.ros/r.ros.html
--- grass/trunk/raster/r.ros/r.ros.html 2009-05-23 00:44:37 UTC (rev 37384)
+++ grass/trunk/raster/r.ros/r.ros.html 2009-05-23 01:24:08 UTC (rev 37385)
@@ -66,7 +66,8 @@
<DD>Name of an existing raster map
layer in the user's current mapset search path containing elevation (meters).
-<DT><B>output=</B>name Prefix of new
+<DT><B>output=</B>name
+<DD>Prefix of new
raster map layers in the user's current mapset to contain
<BR> 1) the base (perpendicular) ROS
(cm/minute);
