[GRASS-SVN] r37386 - grass/trunk/tools/g.html2man
svn_grass at osgeo.org
Fri May 22 21:28:08 EDT 2009
Author: glynn
Date: 2009-05-22 21:28:07 -0400 (Fri, 22 May 2009)
New Revision: 37386
grass/trunk/tools/g.html2man/g.html2man.py
Escape dot and single quote at beginning of a line
Don't remove leading whitespace from pre-formatted text
Discard line breaks from <dt>...</dt>
Modified: grass/trunk/tools/g.html2man/g.html2man.py
--- grass/trunk/tools/g.html2man/g.html2man.py 2009-05-23 01:24:08 UTC (rev 37385)
+++ grass/trunk/tools/g.html2man/g.html2man.py 2009-05-23 01:28:07 UTC (rev 37386)
@@ -197,8 +197,9 @@
in_tr = False,
index = [])
self.stack = []
- self.strip_re = re.compile("\n[ \t]+")
+ self.strip_re = re.compile("^[ \t]+")
self.filename = filename
+ self.at_bol = True
def warning(self, msg):
sys.stderr.write(msg + '\n')
@@ -218,6 +219,8 @@
def show(self, s):
self.stream.write(s)
+ if s != '':
+ self.at_bol = s.endswith('\n')
def pp_with(self, content, var, val):
self.push()
@@ -226,8 +229,11 @@
self.pop()
def fmt(self, format, content, var = None):
-# String.format is only in 2.5+
-# (pre,sep,post) = format.partition("@")
+ # String.partition is only in 2.5+
+ # (pre,sep,post) = format.partition("@")
+ if self.get('no_nl') and '\n' in format:
+ self.warning("can't handle line breaks in <dt>...</dt>")
+ format = "@"
f = format.split('@', 1)
pre = f[0]
if len(f) > 1:
@@ -351,6 +357,8 @@
self.pp(content)
def pp_string(self, content):
+ if content == "":
+ return
s = content
if self.get('no_nl'):
s = s.replace("\n"," ")
@@ -358,15 +366,23 @@
s = s.replace("'", "\\(cq")
s = s.replace("\"", "\\(dq")
s = s.replace("`", "\\(ga")
+ if self.at_bol and s[0] in [".","'"]:
+ s = "\\&" + s
self.show(s)
def pp_text(self, content):
- if content != "":
- if self.get('preformat'):
- self.pp_string(content)
- else:
- s = self.strip_re.sub('\n', content)
- self.pp_string(s)
+ if content == "":
+ return
+ lines = content.splitlines(True)
+ if len(lines) != 1:
+ for line in lines:
+ self.pp_text(line)
+ return
+ else:
+ content = lines[0]
+ if self.at_bol and not self.get('preformat'):
+ content = self.strip_re.sub('', content)
+ self.pp_string(content)
def pp_list(self, content):
for item in content:
@@ -468,7 +484,7 @@
sf.close()
# strip excess whitespace
- blank_re = re.compile("[ \t\n]*\n[ \t\n]*")
+ blank_re = re.compile("[ \t\n]*\n([ \t]*\n)*")
s = blank_re.sub('\n', s)
s = s.lstrip()
