[GRASS-SVN] r39781 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules xml
svn_grass at osgeo.org
Sun Nov 22 11:57:04 EST 2009
Author: martinl
Date: 2009-11-22 11:57:03 -0500 (Sun, 22 Nov 2009)
New Revision: 39781
grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: run script item added to the menu
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2009-11-21 19:45:56 UTC (rev 39780)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2009-11-22 16:57:03 UTC (rev 39781)
@@ -415,9 +415,15 @@
# if command is not a GRASS command, treat it like a shell command
try:
- gcmd.Command(cmdlist,
- stdout=self.cmd_stdout,
- stderr=self.cmd_stderr)
+ # gcmd.Command(cmdlist,
+ # stdout=self.cmd_stdout,
+ # stderr=self.cmd_stderr)
+ self.cmdThread.RunCmd(GrassCmd,
+ onDone,
+ cmdlist,
+ self.cmd_stdout, self.cmd_stderr)
+ self.btn_abort.Enable()
+ self.cmd_output_timer.Start(50)
except gcmd.CmdError, e:
print >> sys.stderr, e
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2009-11-21 19:45:56 UTC (rev 39780)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2009-11-22 16:57:03 UTC (rev 39781)
@@ -464,6 +464,28 @@
cmd = self.GetMenuCmd(event)
menuform.GUI().ParseCommand(cmd, parentframe=self)
+ def OnRunScript(self, event):
+ """!Run script"""
+ # open dialog and choose script file
+ dlg = wx.FileDialog(parent = self, message = _("Choose script file"),
+ defaultDir = os.getcwd(), wildcard = "Bash script (*.sh)|*.sh|Python script (*.py)|*.py")
+ filename = None
+ if dlg.ShowModal() == wx.ID_OK:
+ filename = dlg.GetPath()
+ if not filename:
+ return False
+ if not os.path.exists(filename):
+ wx.MessageBox(parent = self,
+ message = _("Script file '%s' doesn't exist. Operation cancelled.") % filename,
+ caption = _("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ return
+ self.goutput.WriteCmdLog(_("Launching script '%s'...") % filename)
+ self.goutput.RunCmd(filename, switchPage = True)
def OnChangeLocation(self, event):
"""Change current location"""
dlg = gdialogs.LocationDialog(parent = self)
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2009-11-21 19:45:56 UTC (rev 39780)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2009-11-22 16:57:03 UTC (rev 39781)
@@ -643,6 +643,12 @@
</menuitem>
<separator />
<menuitem>
+ <label>Launch script</label>
+ <help>Launches script file.</help>
+ <handler>self.OnRunScript</handler>
+ </menuitem>
+ <separator />
+ <menuitem>
<label>Quit GUI</label>
<help>Quit wxGUI session</help>
<handler>self.OnCloseWindow</handler>
