[GRASS-SVN] r39782 - in grass/trunk/gui/wxpython: . gui_modules xml
Sun Nov 22 12:03:16 EST 2009
Author: martinl
Date: 2009-11-22 12:03:16 -0500 (Sun, 22 Nov 2009)
New Revision: 39782
   grass/trunk/gui/wxpython/gui_modules/goutput.py
   grass/trunk/gui/wxpython/wxgui.py
   grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: run script item added to the menu
       (merge r39781 from devbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2009-11-22 16:57:03 UTC (rev 39781)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2009-11-22 17:03:16 UTC (rev 39782)
@@ -413,17 +413,13 @@
         else:
             # Send any other command to the shell. Send output to
             # console output window
-            # if command is not a GRASS command, treat it like a shell command
-            # process GRASS command with argument
             self.cmdThread.RunCmd(GrassCmd,
                                   onDone,
                                   cmdlist,
                                   self.cmd_stdout, self.cmd_stderr)
             self.btn_abort.Enable()
             self.cmd_output_timer.Start(50)
-            return None
         return None
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2009-11-22 16:57:03 UTC (rev 39781)
+++ grass/trunk/gui/wxpython/wxgui.py	2009-11-22 17:03:16 UTC (rev 39782)
@@ -464,6 +464,28 @@
             cmd = self.GetMenuCmd(event)
         menuform.GUI().ParseCommand(cmd, parentframe=self)
+    def OnRunScript(self, event):
+        """!Run script"""
+        # open dialog and choose script file
+        dlg = wx.FileDialog(parent = self, message = _("Choose script file"),
+                            defaultDir = os.getcwd(), wildcard = "Bash script (*.sh)|*.sh|Python script (*.py)|*.py")
+        filename = None
+        if dlg.ShowModal() == wx.ID_OK:
+            filename = dlg.GetPath()
+        if not filename:
+            return False
+        if not os.path.exists(filename):
+            wx.MessageBox(parent = self,
+                          message = _("Script file '%s' doesn't exist. Operation cancelled.") % filename,
+                          caption = _("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+            return
+        self.goutput.WriteCmdLog(_("Launching script '%s'...") % filename)
+        self.goutput.RunCmd(filename, switchPage = True)
     def OnChangeLocation(self, event):
         """Change current location"""
         dlg = gdialogs.LocationDialog(parent = self)
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2009-11-22 16:57:03 UTC (rev 39781)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2009-11-22 17:03:16 UTC (rev 39782)
@@ -643,6 +643,12 @@
 	</menuitem>
 	<separator />
 	<menuitem>
+	  <label>Launch script</label>
+	  <help>Launches script file.</help>
+	  <handler>self.OnRunScript</handler>
+	</menuitem>
+	<separator />
+	<menuitem>
 	  <label>Quit GUI</label>
 	  <help>Quit wxGUI session</help>
 	  <handler>self.OnCloseWindow</handler>
