[GRASS-SVN] r39370 - in grass/trunk: lib/vector/Vlib vector/v.edit
svn_grass at osgeo.org
Fri Oct 2 03:22:42 EDT 2009
Author: martinl
Date: 2009-10-02 03:22:40 -0400 (Fri, 02 Oct 2009)
New Revision: 39370
Added:
grass/trunk/vector/v.edit/close.c
Removed:
grass/trunk/vector/v.edit/a2b.c
grass/trunk/lib/vector/Vlib/ascii.c
grass/trunk/vector/v.edit/main.c
grass/trunk/vector/v.edit/proto.h
v.edit: use Vect_read_ascii() from Vlib
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c 2009-10-01 16:32:55 UTC (rev 39369)
+++ grass/trunk/lib/vector/Vlib/ascii.c 2009-10-02 07:22:40 UTC (rev 39370)
@@ -28,7 +28,8 @@
\param ascii pointer to the ASCII file
\param Map pointer to Map_info structure
- \return 0
+ \return number of read features
+ \return -1 on error
int Vect_read_ascii(FILE *ascii, struct Map_info *Map)
@@ -38,14 +39,13 @@
double *yarray;
double *zarray;
double *x, *y, *z;
- int i, n_points, n_coors, n_cats;
+ int i, n_points, n_coors, n_cats, n_lines;
int type;
int alloc_points;
int end_of_file;
struct line_pnts *Points;
struct line_cats *Cats;
- int catn;
- int cat;
+ int catn, cat;
/* Must always use this to create an initialized line_pnts structure */
Points = Vect_new_line_struct();
@@ -58,7 +58,7 @@
yarray = (double *)G_calloc(alloc_points, sizeof(double));
zarray = (double *)G_calloc(alloc_points, sizeof(double));
+ n_lines = 0;
while (G_getl2(buff, BUFFSIZE - 1, ascii) != 0) {
n_cats = 0;
if (buff[0] == '\0') {
@@ -184,12 +184,14 @@
Vect_copy_xyz_to_pnts(Points, xarray, yarray, zarray, n_points))
G_fatal_error(_("Out of memory"));
- if (type > 0)
+ if (type > 0) {
Vect_write_line(Map, type, Points, Cats);
+ n_lines++;
Vect_reset_cats(Cats);
- return 0;
+ return n_lines;
Deleted: grass/trunk/vector/v.edit/a2b.c
--- grass/trunk/vector/v.edit/a2b.c 2009-10-01 16:32:55 UTC (rev 39369)
+++ grass/trunk/vector/v.edit/a2b.c 2009-10-02 07:22:40 UTC (rev 39370)
@@ -1,339 +0,0 @@
- * MODULE: v.edit
- * PURPOSE: Editing vector map.
- * AUTHOR(S): GRASS Development Team
- * Wolf Bergenheim, Jachym Cepicky, Martin Landa
- * COPYRIGHT: (C) 2006-2008 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
- * TODO: 3D support
-#include <string.h>
-#include "global.h"
-#define BUFFSIZE 128
- \brief Add new vector features to the vector map
- Input format is GRASS ASCII vector, the code adopted from v.in.ascii
- \param[in] ascii file containing definition of new vector features
- \param[in] Map vector map
- \param[out] List list of added features (if given)
- \return number of added features
-int asc_to_bin(FILE * ascii, struct Map_info *Map, struct ilist *List)
- char ctype;
- char buff[BUFFSIZE];
- double *xarray;
- double *yarray;
- double *zarray;
- double *x, *y, *z;
- int type, newline;
- int alloc_points;
- int end_of_file;
- int catn;
- int cat;
- int nlines;
- struct line_pnts *Points;
- struct line_cats *Cats;
- nlines = 0;
- Points = Vect_new_line_struct();
- Cats = Vect_new_cats_struct();
- if (List) {
- Vect_reset_list(List);
- end_of_file = 0;
- /*alloc_points = 1000 ; */
- alloc_points = 1;
- xarray = (double *)G_calloc(alloc_points, sizeof(double));
- yarray = (double *)G_calloc(alloc_points, sizeof(double));
- zarray = (double *)G_calloc(alloc_points, sizeof(double));
- while (G_getl2(buff, BUFFSIZE - 1, ascii) != 0) {
- n_cats = 0;
- if (buff[0] == '\0') {
- G_debug(3, "a2b: skipping blank line");
- continue;
- if (sscanf(buff, "%1c%d%d", &ctype, &n_coors, &n_cats) < 2 ||
- n_coors < 0 || n_cats < 0) {
- if (ctype == '#') {
- G_debug(2, "a2b: skipping commented line");
- continue;
- G_warning(_("Error reading ASCII file: '%s'"), buff);
- return -1;
- G_debug(2, "a2b: Skipping commented line");
- continue;
- switch (ctype) {
- case 'A':
- type = GV_BOUNDARY;
- break;
- case 'B':
- break;
- case 'C':
- type = GV_CENTROID;
- break;
- case 'L':
- type = GV_LINE;
- break;
- case 'P':
- type = GV_POINT;
- break;
- case 'F':
- type = GV_FACE;
- break;
- case 'K':
- type = GV_KERNEL;
- break;
- case 'a':
- case 'b':
- case 'c':
- case 'l':
- case 'p':
- type = 0; /* dead -> ignore */
- break;
- default:
- return -1;
- G_debug(5, "feature type = %d", type);
- n_points = 0;
- x = xarray;
- y = yarray;
- z = zarray;
- /* Collect the points */
- for (i = 0; i < n_coors; i++) {
- if (G_getl2(buff, BUFFSIZE - 1, ascii) == 0) {
- G_warning(_("End of ASCII file reached before end of coordinates"));
- return -1;
- G_debug(3, "a2b: skipping blank line while reading vertices");
- i--;
- continue;
- *z = 0;
- if (sscanf(buff, "%lf%lf%lf", x, y, z) < 2) {
- return -1;
- G_debug(5, "coor in: %s -> x = %f y = %f z = %f", G_chop(buff),
- *x, *y, *z);
- n_points++;
- x++;
- y++;
- z++;
- if (n_points >= alloc_points) {
- alloc_points = n_points + 1000;
- xarray =
- (double *)G_realloc((void *)xarray,
- alloc_points * sizeof(double));
- yarray =
- (double *)G_realloc((void *)yarray,
- zarray =
- (double *)G_realloc((void *)zarray,
- x = xarray + n_points;
- y = yarray + n_points;
- z = zarray + n_points;
- /* Collect the cats */
- for (i = 0; i < n_cats; i++) {
- G_warning(_("End of ascii file reached before end of categories"));
- return -1;
- G_debug(3,
- "a2b: skipping blank line while reading category info");
- i--;
- continue;
- if (sscanf(buff, "%u%u", &catn, &cat) != 2) {
- G_warning(_("Error reading categories: '%s'"), buff);
- return -1;
- Vect_cat_set(Cats, catn, cat);
- /* Allocation is handled for line_pnts */
- if (0 >
- Vect_copy_xyz_to_pnts(Points, xarray, yarray, zarray, n_points))
- G_fatal_error(_("Out of memory"));
- if (type > 0) {
- newline = Vect_write_line(Map, type, Points, Cats);
- if (List) {
- Vect_list_append(List, newline);
- nlines++;
- Vect_reset_cats(Cats);
- return nlines;
- \brief Read header of input file
- \param[in] dascii file containing definition of vector features to be added
- \return 0
-int read_head(FILE * dascii, struct Map_info *Map)
- char buff[1024];
- char *ptr;
- for (;;) {
- if (0 == G_getl2(buff, sizeof(buff) - 1, dascii))
- return 0;
- /* Last line of header */
- if (strncmp(buff, "VERTI:", 6) == 0)
- return 0;
- if (!(ptr = G_index(buff, ':')))
- G_fatal_error(_("Unexpected data in vector head: '%s'"), buff);
- ptr++; /* Search for the start of text */
- while (*ptr == ' ')
- ptr++;
- if (strncmp(buff, "ORGANIZATION:", 12) == 0)
- Vect_set_organization(Map, ptr);
- else if (strncmp(buff, "DIGIT DATE:", 11) == 0)
- Vect_set_date(Map, ptr);
- else if (strncmp(buff, "DIGIT NAME:", 11) == 0)
- Vect_set_person(Map, ptr);
- else if (strncmp(buff, "MAP NAME:", 9) == 0)
- Vect_set_map_name(Map, ptr);
- else if (strncmp(buff, "MAP DATE:", 9) == 0)
- Vect_set_map_date(Map, ptr);
- else if (strncmp(buff, "MAP SCALE:", 10) == 0)
- Vect_set_scale(Map, atoi(ptr));
- else if (strncmp(buff, "OTHER INFO:", 11) == 0)
- Vect_set_comment(Map, ptr);
- else if (strncmp(buff, "ZONE:", 5) == 0 ||
- strncmp(buff, "UTM ZONE:", 9) == 0)
- Vect_set_zone(Map, atoi(ptr));
- else if (strncmp(buff, "WEST EDGE:", 10) == 0) {
- else if (strncmp(buff, "EAST EDGE:", 10) == 0) {
- else if (strncmp(buff, "SOUTH EDGE:", 11) == 0) {
- else if (strncmp(buff, "NORTH EDGE:", 11) == 0) {
- else if (strncmp(buff, "MAP THRESH:", 11) == 0)
- Vect_set_thresh(Map, atof(ptr));
- else {
- G_warning(_("Unknown keyword '%s' in vector head"), buff);
- /* NOTREACHED */
- \brief Close lines (boundaries)
- Using threshold distance (-1 for no limit)
- \param[in] ltype vector feature type (line | boundary)
- \param[in] thresh threshold distance
- \return number of modified features
-int close_lines(struct Map_info *Map, int ltype, double thresh)
- int nlines, line, type, nlines_modified, newline;
- int npoints;
- double dist;
- nlines_modified = 0;
- Vect_build_partial(Map, GV_BUILD_BASE);
- nlines = Vect_get_num_lines(Map);
- for (line = 1; line <= nlines; line++) {
- if (!Vect_line_alive(Map, line))
- continue;
- type = Vect_read_line(Map, Points, Cats, line);
- if (!(type & ltype))
- continue;
- npoints = Points->n_points - 1;
- x = Points->x;
- y = Points->y;
- z = Points->z;
- dist = Vect_points_distance(x[npoints], y[npoints], z[npoints],
- x[0], y[0], z[0], WITHOUT_Z);
- if (dist > 0 && (thresh < 0.0 || dist <= thresh)) {
- Vect_line_delete_point(Points, npoints);
- Vect_append_point(Points, x[0], y[0], z[0]);
- newline = Vect_rewrite_line(Map, line, type, Points, Cats);
- if (newline < 0) {
- G_warning(_("Unable to rewrite line %d"), line);
- return -1;
- nlines_modified++;
- Vect_destroy_line_struct(Points);
- Vect_destroy_cats_struct(Cats);
- return nlines_modified;
Copied: grass/trunk/vector/v.edit/close.c (from rev 39369, grass/trunk/vector/v.edit/a2b.c)
--- grass/trunk/vector/v.edit/close.c (rev 0)
+++ grass/trunk/vector/v.edit/close.c 2009-10-02 07:22:40 UTC (rev 39370)
@@ -0,0 +1,67 @@
+#include <string.h>
+#include "global.h"
+ \brief Close lines (boundaries)
+ Using threshold distance (-1 for no limit)
+ \param[in] Map vector map
+ \param[in] ltype vector feature type (line | boundary)
+ \param[in] thresh threshold distance
+ \return number of modified features
+int close_lines(struct Map_info *Map, int ltype, double thresh)
+ int nlines, line, type, nlines_modified, newline;
+ int npoints;
+ double *x, *y, *z;
+ double dist;
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ nlines_modified = 0;
+ Vect_build_partial(Map, GV_BUILD_BASE);
+ nlines = Vect_get_num_lines(Map);
+ for (line = 1; line <= nlines; line++) {
+ if (!Vect_line_alive(Map, line))
+ continue;
+ type = Vect_read_line(Map, Points, Cats, line);
+ if (!(type & ltype))
+ continue;
+ npoints = Points->n_points - 1;
+ x = Points->x;
+ y = Points->y;
+ z = Points->z;
+ dist = Vect_points_distance(x[npoints], y[npoints], z[npoints],
+ x[0], y[0], z[0], WITHOUT_Z);
+ if (dist > 0 && (thresh < 0.0 || dist <= thresh)) {
+ Vect_line_delete_point(Points, npoints);
+ Vect_append_point(Points, x[0], y[0], z[0]);
+ newline = Vect_rewrite_line(Map, line, type, Points, Cats);
+ if (newline < 0) {
+ G_warning(_("Unable to rewrite line %d"), line);
+ return -1;
+ nlines_modified++;
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_cats_struct(Cats);
+ return nlines_modified;
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c 2009-10-01 16:32:55 UTC (rev 39369)
+++ grass/trunk/vector/v.edit/main.c 2009-10-02 07:22:40 UTC (rev 39370)
@@ -233,13 +233,20 @@
case MODE_ADD:
print = 0;
if (!params.header->answer)
- read_head(ascii, &Map);
- struct ilist *List_added;
- List_added = Vect_new_list();
- ret = asc_to_bin(ascii, &Map, List_added);
+ Vect_read_ascii_head(ascii, &Map);
+ int num_lines;
+ num_lines = Vect_get_num_lines(&Map);
+ ret = Vect_read_ascii(ascii, &Map);
G_message(_("%d features added"), ret);
if (ret > 0) {
+ int iline;
+ struct ilist *List_added;
+ List_added = Vect_new_list();
+ for (iline = num_lines + 1; iline <= Vect_get_num_lines(&Map); iline++)
+ Vect_list_append(List_added, iline);
G_verbose_message(_("Threshold value for snapping is %.2f"),
thresh[THRESH_SNAP]);
if (snap != NO_SNAP) { /* apply snapping */
@@ -251,8 +258,8 @@
nclosed = close_lines(&Map, GV_BOUNDARY, thresh[THRESH_SNAP]);
G_message(_("%d boundaries closed"), nclosed);
+ Vect_destroy_list(List_added);
- Vect_destroy_list(List_added);
break;
case MODE_DEL:
ret = Vedit_delete_lines(&Map, List);
Modified: grass/trunk/vector/v.edit/proto.h
--- grass/trunk/vector/v.edit/proto.h 2009-10-01 16:32:55 UTC (rev 39369)
+++ grass/trunk/vector/v.edit/proto.h 2009-10-02 07:22:40 UTC (rev 39370)
@@ -4,9 +4,7 @@
/* args.c */
int parser(int, char *[], struct GParams *, enum mode *);
-/* a2b.c */
-int asc_to_bin(FILE *, struct Map_info *, struct ilist *);
-int read_head(FILE *, struct Map_info *);
+/* close.c */
int close_lines(struct Map_info *, int, double);
/* select.c */
