[GRASS-SVN] r39371 - in grass/trunk: lib/vector/Vlib
vector/v.out.ascii
svn_grass at osgeo.org
Fri Oct 2 04:21:36 EDT 2009
Author: martinl
Date: 2009-10-02 04:21:35 -0400 (Fri, 02 Oct 2009)
New Revision: 39371
grass/trunk/lib/vector/Vlib/ascii.c
grass/trunk/vector/v.out.ascii/main.c
v.out.ascii: print warning if no features exported (points)
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c 2009-10-02 07:22:40 UTC (rev 39370)
+++ grass/trunk/lib/vector/Vlib/ascii.c 2009-10-02 08:21:35 UTC (rev 39371)
@@ -263,7 +263,7 @@
\param dascii pointer to the ASCII file
\param Map pointer to Map_info structure
- \return 0 on sucess
+ \return number of written features
\return -1 on error
int Vect_write_ascii(FILE *ascii,
@@ -271,7 +271,7 @@
int format, int dp, char *fs, int region_flag,
int field, char* where, char **columns)
- int type, ctype, i, cat, proj;
+ int type, ctype, i, cat, proj, n_lines;
double *xptr, *yptr, *zptr, x, y;
static struct line_pnts *Points;
struct line_cats *Cats;
@@ -289,6 +289,7 @@
/* get the region */
G_get_window(&window);
+ n_lines = 0;
ncats = 0;
cats = NULL;
@@ -347,7 +348,7 @@
db_close_database(driver);
db_shutdown_driver(driver);
- return 0;
+ return n_lines;
if (format == GV_ASCII_FORMAT_POINT && !(type & GV_POINTS))
@@ -407,7 +408,7 @@
break;
default:
ctype = 'X';
- G_warning(_("got type %d"), (int)type);
+ G_warning(_("Uknown feature type %d"), (int)type);
break;
@@ -559,9 +560,11 @@
+ n_lines++;
/* not reached */
+ return n_lines;
int srch(const void *pa, const void *pb)
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c 2009-10-02 07:22:40 UTC (rev 39370)
+++ grass/trunk/vector/v.out.ascii/main.c 2009-10-02 08:21:35 UTC (rev 39371)
@@ -31,7 +31,7 @@
struct Option *input, *output, *format_opt, *dp_opt, *delim_opt,
*field_opt, *column_opt, *where_opt;
struct Flag *verf, *region_flag;
- int format, dp, field;
+ int format, dp, field, ret;
char *fs;
struct Map_info Map;
int ver = 5, pnt = 0;
@@ -182,9 +182,18 @@
output->answer);
- Vect_write_ascii(ascii, att, &Map, ver, format, dp, fs,
- region_flag->answer, field, where_opt->answer,
- column_opt->answers);
+ ret = Vect_write_ascii(ascii, att, &Map, ver, format, dp, fs,
+ region_flag->answer, field, where_opt->answer,
+ column_opt->answers);
+ if (ret < 1) {
+ if (format == GV_ASCII_FORMAT_POINT) {
+ G_warning(_("No points found, nothing to be exported"));
+ else {
+ G_warning(_("No features found, nothing to be exported"));
if (ascii != NULL)
fclose(ascii);
