[GRASS-SVN] r39374 - grass/trunk/vector/v.out.ascii
svn_grass at osgeo.org
Fri Oct 2 08:04:24 EDT 2009
Author: martinl
Date: 2009-10-02 08:04:22 -0400 (Fri, 02 Oct 2009)
New Revision: 39374
Added:
grass/trunk/vector/v.out.ascii/args.c
grass/trunk/vector/v.out.ascii/local_proto.h
grass/trunk/vector/v.out.ascii/main.c
v.out.ascii parse arguments in parse_args()
Added: grass/trunk/vector/v.out.ascii/args.c
--- grass/trunk/vector/v.out.ascii/args.c (rev 0)
+++ grass/trunk/vector/v.out.ascii/args.c 2009-10-02 12:04:22 UTC (rev 39374)
@@ -0,0 +1,110 @@
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+void parse_args(int argc, char **argv,
+ char **input, char**output, int *format, int *dp, char **delim,
+ int *field, char ***columns, char **where, int *region, int *old_format)
+ struct Option *input_opt, *output_opt, *format_opt, *dp_opt, *delim_opt,
+ *field_opt, *column_opt, *where_opt;
+ struct Flag *old_flag, *region_flag;
+ input_opt = G_define_standard_option(G_OPT_V_INPUT);
+ output_opt = G_define_standard_option(G_OPT_F_OUTPUT);
+ output_opt->description =
+ _("Path to resulting ASCII file ('-' for standard output) "
+ "or ASCII vector name if '-o' is defined");
+ output_opt->answer = "-";
+ format_opt = G_define_option();
+ format_opt->key = "format";
+ format_opt->type = TYPE_STRING;
+ format_opt->required = YES;
+ format_opt->multiple = NO;
+ format_opt->options = "point,standard";
+ format_opt->answer = "point";
+ format_opt->description = _("Output format");
+ delim_opt = G_define_standard_option(G_OPT_F_SEP);
+ delim_opt->description = _("Field separator (points mode)");
+ delim_opt->guisection = _("Points");
+ dp_opt = G_define_option();
+ dp_opt->key = "dp";
+ dp_opt->type = TYPE_INTEGER;
+ dp_opt->required = NO;
+ dp_opt->options = "0-32";
+ dp_opt->answer = "8"; /* This value is taken from the lib settings in G_format_easting() */
+ dp_opt->description =
+ _("Number of significant digits (floating point only)");
+ dp_opt->guisection = _("Points");
+ field_opt = G_define_standard_option(G_OPT_V_FIELD);
+ field_opt->guisection = _("Selection");
+ column_opt = G_define_standard_option(G_OPT_DB_COLUMNS);
+ column_opt->description = _("Name of attribute column(s) to be exported (point mode)");
+ column_opt->guisection = _("Points");
+ where_opt = G_define_standard_option(G_OPT_DB_WHERE);
+ where_opt->guisection = _("Selection");
+ old_flag = G_define_flag();
+ old_flag->key = 'o';
+ old_flag->description = _("Create old (version 4) ASCII file");
+ region_flag = G_define_flag();
+ region_flag->key = 'r';
+ region_flag->description =
+ _("Only export points falling within current 3D region (points mode)");
+ region_flag->guisection = _("Points");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ *input = G_store(input_opt->answer);
+ *output = G_store(output_opt->answer);
+ if (strcmp(format_opt->answer, "point") == 0)
+ *format = GV_ASCII_FORMAT_POINT;
+ else
+ *format = GV_ASCII_FORMAT_ALL;
+ if (sscanf(dp_opt->answer, "%d", dp) != 1)
+ G_fatal_error(_("Failed to interpret 'dp' parameter as an integer"));
+ /* the field separator */
+ if (strcmp(delim_opt->answer, "\\t") == 0)
+ *delim = G_store("\t");
+ else if (strcmp(delim_opt->answer, "tab") == 0)
+ else if (strcmp(delim_opt->answer, "space") == 0)
+ *delim = G_store(" ");
+ else if (strcmp(delim_opt->answer, "comma") == 0)
+ *delim = G_store(",");
+ else
+ *delim = G_store(delim_opt->answer);
+ *field = atoi(field_opt->answer);
+ *columns = NULL;
+ if (column_opt->answer) {
+ int i, nopt;
+ nopt = 0;
+ while(column_opt->answers[nopt++])
+ *columns = (char **) G_malloc(nopt * sizeof(char *));
+ for (i = 0; i < nopt - 1; i++)
+ (*columns)[i] = G_store(column_opt->answers[i]);
+ (*columns)[nopt - 1] = NULL;
+ *where = NULL;
+ if (where_opt->answer) {
+ *where = G_store(where_opt->answer);
+ *region = region_flag->answer ? 1 : 0;
+ *old_format = old_flag->answer ? 1 : 0;
Property changes on: grass/trunk/vector/v.out.ascii/args.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Added: grass/trunk/vector/v.out.ascii/local_proto.h
--- grass/trunk/vector/v.out.ascii/local_proto.h (rev 0)
+++ grass/trunk/vector/v.out.ascii/local_proto.h 2009-10-02 12:04:22 UTC (rev 39374)
@@ -0,0 +1,4 @@
+/* args.c */
+void parse_args(int, char **,
+ char **, char**, int *, int *, char **,
+ int *, char ***, char **, int *, int *);
Property changes on: grass/trunk/vector/v.out.ascii/local_proto.h
+ text/x-chdr
Added: svn:keywords
+ Author Date Id
+ native
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c 2009-10-02 08:40:54 UTC (rev 39373)
+++ grass/trunk/vector/v.out.ascii/main.c 2009-10-02 12:04:22 UTC (rev 39374)
@@ -5,14 +5,14 @@
* AUTHOR(S): Michael Higgins, U.S. Army Construction Engineering Research Laboratory
* James Westervelt, U.S. Army Construction Engineering Research Laboratory
* Radim Blazek, ITC-Irst, Trento, Italy
- * Martin Landa, CTU in Prague, Czech Republic (v.out.ascii.db merged)
+ * Martin Landa, CTU in Prague, Czech Republic (v.out.ascii.db merged & update for GRASS7)
- * PURPOSE: v.out.ascii: writes GRASS vector data as ASCII files
+ * PURPOSE: Writes GRASS vector data as ASCII files
* COPYRIGHT: (C) 2000-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that comes
+ * with GRASS for details.
@@ -25,18 +25,18 @@
int main(int argc, char *argv[])
- FILE *ascii, *att;
- struct Option *input, *output, *format_opt, *dp_opt, *delim_opt,
- *field_opt, *column_opt, *where_opt;
- struct Flag *verf, *region_flag;
- int format, dp, field, ret;
- char *fs;
- struct Map_info Map;
- int ver = 5, pnt = 0;
struct GModule *module;
+ struct Map_info Map;
+ FILE *ascii, *att;
+ char *input, *output, *delim, **columns, *where;
+ int format, dp, field, ret, region, old_format;
+ int ver, pnt;
G_gisinit(argv[0]);
module = G_define_module();
@@ -46,120 +46,44 @@
module->description =
_("Converts a GRASS binary vector map to a GRASS ASCII vector map.");
- input = G_define_standard_option(G_OPT_V_INPUT);
+ parse_args(argc, argv, &input, &output, &format, &dp, &delim,
+ &field, &columns, &where, ®ion, &old_format);
- output = G_define_standard_option(G_OPT_F_OUTPUT);
- output->description =
- _("Path to resulting ASCII file ('-' for standard output) "
- "or ASCII vector name if '-o' is defined");
- output->answer = "-";
- format_opt = G_define_option();
- format_opt->key = "format";
- format_opt->type = TYPE_STRING;
- format_opt->required = YES;
- format_opt->multiple = NO;
- format_opt->options = "point,standard";
- format_opt->answer = "point";
- format_opt->description = _("Output format");
- delim_opt = G_define_standard_option(G_OPT_F_SEP);
- delim_opt->description = _("Field separator (points mode)");
- delim_opt->guisection = _("Points");
- dp_opt = G_define_option();
- dp_opt->key = "dp";
- dp_opt->type = TYPE_INTEGER;
- dp_opt->required = NO;
- dp_opt->options = "0-32";
- dp_opt->answer = "8"; /* This value is taken from the lib settings in G_format_easting() */
- dp_opt->description =
- _("Number of significant digits (floating point only)");
- dp_opt->guisection = _("Points");
- field_opt = G_define_standard_option(G_OPT_V_FIELD);
- field_opt->guisection = _("Selection");
- column_opt = G_define_standard_option(G_OPT_DB_COLUMNS);
- column_opt->description = _("Name of attribute column(s) to be exported (point mode)");
- column_opt->guisection = _("Points");
- where_opt = G_define_standard_option(G_OPT_DB_WHERE);
- where_opt->guisection = _("Selection");
- verf = G_define_flag();
- verf->key = 'o';
- verf->description = _("Create old (version 4) ASCII file");
- region_flag = G_define_flag();
- region_flag->key = 'r';
- region_flag->description =
- _("Only export points falling within current 3D region (points mode)");
- region_flag->guisection = _("Points");
- if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
- field = atoi(field_opt->answer);
- if (format_opt->answer[0] == 'p')
- format = GV_ASCII_FORMAT_POINT;
- else
- format = GV_ASCII_FORMAT_ALL;
- if (format == GV_ASCII_FORMAT_ALL && column_opt->answer) {
- G_warning(_("Parameter '%s' ignored in standard mode"),
- column_opt->key);
+ if (format == GV_ASCII_FORMAT_ALL && columns) {
+ G_warning(_("Parameter 'column' ignored in standard mode"));
- if (verf->answer)
+ ver = 5;
+ pnt = 0;
+ if (old_format)
ver = 4;
if (ver == 4 && format == GV_ASCII_FORMAT_POINT) {
G_fatal_error(_("Format 'point' is not supported for old version"));
- if (ver == 4 && strcmp(output->answer, "-") == 0) {
+ if (ver == 4 && strcmp(output, "-") == 0) {
G_fatal_error(_("'output' must be given for old version"));
- /* the field separator */
- fs = delim_opt->answer;
- if (strcmp(fs, "\\t") == 0)
- fs = "\t";
- if (strcmp(fs, "tab") == 0)
- fs = "\t";
- if (strcmp(fs, "space") == 0)
- fs = " ";
- if (strcmp(fs, "comma") == 0)
- fs = ",";
- /*The precision of the output */
- if (dp_opt->answer) {
- if (sscanf(dp_opt->answer, "%d", &dp) != 1)
- G_fatal_error(_("Failed to interpret 'dp' parameter as an integer"));
Vect_set_open_level(1); /* only need level I */
- if (Vect_open_old(&Map, input->answer, "") < 0)
+ if (Vect_open_old(&Map, input, "") < 0)
G_fatal_error(_("Unable to open vector map <%s>"),
- input->answer);
+ input);
- if (strcmp(output->answer, "-") != 0) {
+ if (strcmp(output, "-") != 0) {
if (ver == 4) {
- ascii = G_fopen_new("dig_ascii", output->answer);
+ ascii = G_fopen_new("dig_ascii", output);
- else if (strcmp(output->answer, "-") == 0) {
+ else if (strcmp(output, "-") == 0) {
ascii = stdout;
else {
- ascii = fopen(output->answer, "w");
+ ascii = fopen(output, "w");
if (ascii == NULL) {
- G_fatal_error(_("Unable to open file <%s>"), output->answer);
+ G_fatal_error(_("Unable to open file <%s>"), output);
else {
@@ -174,17 +98,19 @@
/* Open dig_att */
att = NULL;
if (ver == 4 && !pnt) {
- if (G_find_file("dig_att", output->answer, G_mapset()) != NULL)
+ if (G_find_file("dig_att", output, G_mapset()) != NULL)
G_fatal_error(_("dig_att file already exist"));
- if ((att = G_fopen_new("dig_att", output->answer)) == NULL)
+ if ((att = G_fopen_new("dig_att", output)) == NULL)
G_fatal_error(_("Unable to open dig_att file <%s>"),
- output->answer);
+ output);
- ret = Vect_write_ascii(ascii, att, &Map, ver, format, dp, fs,
- region_flag->answer, field, where_opt->answer,
- column_opt->answers);
+ if (where || columns)
+ G_message(_("Fetching data..."));
+ ret = Vect_write_ascii(ascii, att, &Map, ver, format, dp, delim,
+ region, field, where,
+ columns);
if (ret < 1) {
if (format == GV_ASCII_FORMAT_POINT) {
