[GRASS-SVN] r39375 - in grass/trunk: include include/vect
lib/vector/Vlib vector/v.in.ascii vector/v.out.ascii
svn_grass at osgeo.org
Fri Oct 2 11:48:03 EDT 2009
Author: martinl
Date: 2009-10-02 11:48:03 -0400 (Fri, 02 Oct 2009)
New Revision: 39375
Added:
grass/trunk/lib/vector/Vlib/simple_features.c
grass/trunk/include/vect/dig_defines.h
grass/trunk/include/vector.h
grass/trunk/lib/vector/Vlib/ascii.c
grass/trunk/vector/v.in.ascii/main.c
grass/trunk/vector/v.out.ascii/args.c
grass/trunk/vector/v.out.ascii/main.c
very initial simple features API implemented (in progress)
* v.out.ascii format=wkt
* currently only points, lines supported
Modified: grass/trunk/include/vect/dig_defines.h
--- grass/trunk/include/vect/dig_defines.h 2009-10-02 12:04:22 UTC (rev 39374)
+++ grass/trunk/include/vect/dig_defines.h 2009-10-02 15:48:03 UTC (rev 39375)
@@ -225,6 +225,13 @@
/*! \brief GRASS ASCII vector format */
#define GV_ASCII_FORMAT_POINT 0
-#define GV_ASCII_FORMAT_ALL 1
+#define GV_ASCII_FORMAT_STD 1
+#define GV_ASCII_FORMAT_WKT 2
+/*! \brief Simple feature types */
+#define SF_POINT 0x01
+#define SF_LINE 0x02
+#define SF_LINESTRING 0x04
+#define SF_LINEARRING 0x08
#define HEADSTR 50
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h 2009-10-02 12:04:22 UTC (rev 39374)
+++ grass/trunk/include/vector.h 2009-10-02 15:48:03 UTC (rev 39375)
@@ -415,6 +415,11 @@
int, char*, char **);
void Vect_write_ascii_head(FILE *, struct Map_info *);
+/* Simple Features */
+void Vect_sfa_write_line_wkt(const struct line_pnts *, int, int, int, FILE *);
+int Vect_sfa_check_line_type(const struct line_pnts *, int, int, int);
+int Vect_sfa_get_line_type(const struct line_pnts *, int, int);
* Internal functions, MUST NOT be used in modules
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c 2009-10-02 12:04:22 UTC (rev 39374)
+++ grass/trunk/lib/vector/Vlib/ascii.c 2009-10-02 15:48:03 UTC (rev 39375)
@@ -413,8 +413,6 @@
if (format == GV_ASCII_FORMAT_POINT) {
- /*fprintf(ascii, "%c", ctype); */
if (region_flag) {
if ((window.east < Points->x[0]) ||
(window.west > Points->x[0]))
@@ -497,7 +495,7 @@
fprintf(ascii, "\n");
- else {
+ else if (format == GV_ASCII_FORMAT_STD) {
/* FORMAT_STANDARD */
if (ver == 5 && Cats->n_cats > 0)
fprintf(ascii, "%c %d %d\n", ctype, Points->n_points,
@@ -560,6 +558,13 @@
+ else if (format == GV_ASCII_FORMAT_WKT) {
+ /* Well-Known Text */
+ Vect_sfa_write_line_wkt(Points, type, Vect_is_3d(Map), dp, ascii);
+ else {
+ G_fatal_error(_("Unknown format"));
n_lines++;
Added: grass/trunk/lib/vector/Vlib/simple_features.c
--- grass/trunk/lib/vector/Vlib/simple_features.c (rev 0)
+++ grass/trunk/lib/vector/Vlib/simple_features.c 2009-10-02 15:48:03 UTC (rev 39375)
@@ -0,0 +1,164 @@
+ \file vector/Vlib/simple_features.c
+ \brief Vector library - OGC Simple Features Access
+ Note: In progress. Currently on GV_POINT, GV_LINE are supported.
+ Higher level functions for reading/writing/manipulating vectors.
+ (C) 2009 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Martin Landa <landa.martin gmail.com>
+#include <stdio.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+static int check_sftype(const struct line_pnts *, int, int, int);
+static int get_sftype(const struct line_pnts *, int, int);
+static void print_point(const struct line_pnts *, int, int, int, FILE *);
+ \brief Get SF type of given vector feature
+ List of supported feature types:
+ - GV_POINT -> SF_POINT
+ - GV_LINE -> SF_LINE / SF_LINESTRING / SF_LINEARRING
+ \param Points pointer to line_pnts structure
+ \param type feature type (GV_POINT, GV_LINE, ...)
+ \param with_z non-zero value for 3D data
+ \return SF type identificator (see list of supported types)
+ \return -1 on error
+int Vect_sfa_get_line_type(const struct line_pnts *Points, int type, int with_z)
+ return get_sftype(Points, type, with_z);
+ \brief Check SF type
+ E.g. if <em>type</em> is GV_LINE with two or more segments and the
+ start node is identical with the end node, and <em>sftype</em> is
+ SF_LINEARRING, functions returns 1, otherwise 0.
+ \param sftype SF type to be checked (SF_POINT, SF_LINE, ...)
+ \return 1 if type is sftype
+ \return 0 type differs from sftype
+int Vect_sfa_check_line_type(const struct line_pnts *Points, int type, int sftype, int with_z)
+ return check_sftype(Points, type, sftype, with_z);
+ \brief Print feature in Well-Known Text format
+ \param precision floating number precision
+ \param[out] file file where to write the output
+void Vect_sfa_write_line_wkt(const struct line_pnts *Points, int type, int with_z, int precision, FILE *file)
+ int sftype;
+ sftype = Vect_sfa_get_line_type(Points, type, with_z);
+ switch(sftype) {
+ case SF_POINT: {
+ fprintf(file, "POINT(");
+ print_point(Points, 0, with_z, precision, file);
+ fprintf(file, ")\n");
+ break;
+ case SF_LINESTRING: case SF_LINE: case SF_LINEARRING: {
+ int i;
+ if (sftype == SF_LINESTRING)
+ fprintf(file, "LINESTRING(");
+ else if (sftype == SF_LINE)
+ fprintf(file, "LINE(");
+ else
+ fprintf(file, "LINEARRING(");
+ for (i = 0; i < Points->n_points; i++) {
+ print_point(Points, i, with_z, precision, file);
+ if (i < Points->n_points - 1)
+ fprintf(file, ", ");
+ break;
+ default: {
+ G_warning(_("Unknown Simple Features type (%d)"), sftype);
+ break;
+ fflush(file);
+int check_sftype(const struct line_pnts *points, int type, int sftype, int with_z)
+ if (type == GV_POINT && sftype == SF_POINT) {
+ return 1;
+ if (type == GV_LINE) {
+ if (sftype == SF_LINESTRING) {
+ return 1;
+ if (sftype == SF_LINE && Vect_get_num_line_points(points) == 2) {
+ return 1;
+ if (sftype == SF_LINEARRING) {
+ int num = Vect_get_num_line_points(points);
+ if (points->x[0] == points->x[num-1] &&
+ points->y[0] == points->y[num-1]) {
+ if (!with_z) {
+ return 1;
+ else if (points->z[0] == points->z[num-1]) {
+ return 1;
+ return 0;
+int get_sftype(const struct line_pnts *points, int type, int with_z)
+ if (check_sftype(points, type, SF_POINT, with_z))
+ return SF_POINT;
+ if (check_sftype(points, type, SF_LINE, with_z))
+ return SF_LINE;
+ if (check_sftype(points, type, SF_LINEARRING, with_z))
+ return SF_LINEARRING;
+ if (check_sftype(points, type, SF_LINESTRING, with_z))
+ return SF_LINESTRING;
+ return -1;
+void print_point(const struct line_pnts *Points, int index, int with_z, int precision, FILE *file)
+ fprintf(file, "%.*f %.*f", precision, Points->x[index], precision, Points->y[index]);
+ if (with_z)
+ fprintf(file, " %.*f", precision, Points->z[index]);
Property changes on: grass/trunk/lib/vector/Vlib/simple_features.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Modified: grass/trunk/vector/v.in.ascii/main.c
--- grass/trunk/vector/v.in.ascii/main.c 2009-10-02 12:04:22 UTC (rev 39374)
+++ grass/trunk/vector/v.in.ascii/main.c 2009-10-02 15:48:03 UTC (rev 39375)
@@ -173,7 +173,7 @@
if (format_opt->answer[0] == 'p')
format = GV_ASCII_FORMAT_POINT;
else
- format = GV_ASCII_FORMAT_ALL;
+ format = GV_ASCII_FORMAT_STD;
skip_lines = atoi(skip_opt->answer);
if (skip_lines < 0)
Modified: grass/trunk/vector/v.out.ascii/args.c
--- grass/trunk/vector/v.out.ascii/args.c 2009-10-02 12:04:22 UTC (rev 39374)
+++ grass/trunk/vector/v.out.ascii/args.c 2009-10-02 15:48:03 UTC (rev 39375)
@@ -28,7 +28,7 @@
format_opt->type = TYPE_STRING;
format_opt->required = YES;
format_opt->multiple = NO;
- format_opt->options = "point,standard";
+ format_opt->options = "point,standard,wkt";
format_opt->answer = "point";
format_opt->description = _("Output format");
@@ -71,10 +71,12 @@
*input = G_store(input_opt->answer);
*output = G_store(output_opt->answer);
- if (strcmp(format_opt->answer, "point") == 0)
+ if (format_opt->answer[0] == 'p')
*format = GV_ASCII_FORMAT_POINT;
+ else if (format_opt->answer[0] == 's')
+ *format = GV_ASCII_FORMAT_STD;
else
- *format = GV_ASCII_FORMAT_ALL;
+ *format = GV_ASCII_FORMAT_WKT;
if (sscanf(dp_opt->answer, "%d", dp) != 1)
G_fatal_error(_("Failed to interpret 'dp' parameter as an integer"));
/* the field separator */
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c 2009-10-02 12:04:22 UTC (rev 39374)
+++ grass/trunk/vector/v.out.ascii/main.c 2009-10-02 15:48:03 UTC (rev 39375)
@@ -49,7 +49,7 @@
parse_args(argc, argv, &input, &output, &format, &dp, &delim,
&field, &columns, &where, ®ion, &old_format);
- if (format == GV_ASCII_FORMAT_ALL && columns) {
+ if (format == GV_ASCII_FORMAT_STD && columns) {
G_warning(_("Parameter 'column' ignored in standard mode"));
@@ -90,7 +90,7 @@
ascii = stdout;
- if (format == GV_ASCII_FORMAT_ALL) {
+ if (format == GV_ASCII_FORMAT_STD) {
Vect_write_ascii_head(ascii, &Map);
fprintf(ascii, "VERTI:\n");
