[GRASS-SVN] r39416 -
grass/branches/releasebranch_6_4/lib/vector/Vlib
svn_grass at osgeo.org
Mon Oct 5 17:44:16 EDT 2009
Author: neteler
Date: 2009-10-05 17:44:16 -0400 (Mon, 05 Oct 2009)
New Revision: 39416
grass/branches/releasebranch_6_4/lib/vector/Vlib/field.c
avoid compilation error if OGR absent
Modified: grass/branches/releasebranch_6_4/lib/vector/Vlib/field.c
--- grass/branches/releasebranch_6_4/lib/vector/Vlib/field.c 2009-10-05 21:22:20 UTC (rev 39415)
+++ grass/branches/releasebranch_6_4/lib/vector/Vlib/field.c 2009-10-05 21:44:16 UTC (rev 39416)
@@ -30,7 +30,12 @@
#include <grass/Vect.h>
#include <gdal_version.h> /* needed for FID detection */
+#include <ogr_api.h>
+#ifdef HAVE_OGR
+#endif
\brief Create and init new dblinks ctructure
@@ -444,7 +449,7 @@
G_debug(3, "Searching for FID column in OGR DB");
if (Map->format == GV_FORMAT_OGR) {
-#if GDAL_VERSION_NUM > 1320 /* seems to be fixed after 1320 release */
+#if GDAL_VERSION_NUM > 1320 && HAVE_OGR /* seems to be fixed after 1320 release */
int layer, nLayers;
OGRDataSourceH Ogr_ds;
OGRLayerH Ogr_layer = NULL;
@@ -594,7 +599,7 @@
-#endif /* GDAL_VERSION_NUM > 1320 */
+#endif /* GDAL_VERSION_NUM > 1320 && HAVE_OGR */
return (1);
else if (Map->format != GV_FORMAT_NATIVE) {
