[GRASS-SVN] r39417 - grass/branches/develbranch_6/lib/vector/Vlib
svn_grass at osgeo.org
Mon Oct 5 17:46:26 EDT 2009
Author: neteler
Date: 2009-10-05 17:46:25 -0400 (Mon, 05 Oct 2009)
New Revision: 39417
grass/branches/develbranch_6/lib/vector/Vlib/field.c
avoid compilation error if OGR absent
Modified: grass/branches/develbranch_6/lib/vector/Vlib/field.c
--- grass/branches/develbranch_6/lib/vector/Vlib/field.c 2009-10-05 21:44:16 UTC (rev 39416)
+++ grass/branches/develbranch_6/lib/vector/Vlib/field.c 2009-10-05 21:46:25 UTC (rev 39417)
@@ -31,6 +31,10 @@
#include <gdal_version.h> /* needed for FID detection */
+#ifdef HAVE_OGR
+#include <ogr_api.h>
+#endif
\brief Create and init new dblinks ctructure
@@ -444,7 +448,7 @@
G_debug(3, "Searching for FID column in OGR DB");
if (Map->format == GV_FORMAT_OGR) {
-#if GDAL_VERSION_NUM > 1320 /* seems to be fixed after 1320 release */
+#if GDAL_VERSION_NUM > 1320 && HAVE_OGR /* seems to be fixed after 1320 release */
int layer, nLayers;
OGRDataSourceH Ogr_ds;
OGRLayerH Ogr_layer = NULL;
@@ -594,7 +598,7 @@
-#endif /* GDAL_VERSION_NUM > 1320 */
+#endif /* GDAL_VERSION_NUM > 1320 && HAVE_OGR */
return (1);
else if (Map->format != GV_FORMAT_NATIVE) {
