[GRASS-SVN] r39476 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Oct 10 14:50:59 EDT 2009
Author: cmbarton
Date: 2009-10-10 14:50:59 -0400 (Sat, 10 Oct 2009)
New Revision: 39476
grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
Fixing bugs in raster and vector georectification
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py 2009-10-10 18:50:24 UTC (rev 39475)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py 2009-10-10 18:50:59 UTC (rev 39476)
@@ -207,7 +207,10 @@
# show new display & draw map
+ self.xy_mapdisp.CenterOnScreen()
self.xy_mapdisp.Show()
+ self.gcpmgr.Centre()
+ self.gcpmgr.Raise()
else:
self.Cleanup()
@@ -280,6 +283,9 @@
self.xy_mapdisp = None
self.wizard.Destroy()
+ # clear GCPs from target display
+ self.parent.curr_page.maptree.mapdisplay.MapWindow.UpdateMap(render=False)
class LocationPage(TitledPage):
@@ -435,7 +441,6 @@
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
self.btn_mkgroup = wx.Button(parent=self, id=wx.ID_ANY, label=_("Create/edit group..."))
self.btn_vgroup = wx.Button(parent=self, id=wx.ID_ANY, label=_("Add vector map to group..."))
- self.btn_vgroup.Hide()
btnSizer.Add(item=self.btn_mkgroup,
flag=wx.RIGHT, border=5)
@@ -465,6 +470,9 @@
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
+ # hide vector group button by default
+ self.btn_vgroup.Hide()
def OnGroup(self, event):
self.xygroup = event.GetString()
@@ -493,8 +501,8 @@
"""!Process i.group"""
# update the page
if dcmd:
- gcmd.RunCommand(utils.CmdToTuple(dcmd))
+ gcmd.Command(dcmd)
self.OnEnterPage()
self.Update()
@@ -583,7 +591,7 @@
pos=(1, 1))
self.selection = gselect.Select(self, id=wx.ID_ANY,
- size=globalvar.DIALOG_GSELECT_SIZE)
+ size=globalvar.DIALOG_GSELECT_SIZE, type='cell')
self.sizer.Add(item=self.selection,
flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=5,
@@ -600,6 +608,7 @@
def OnSelection(self,event):
"""!Map to display selected"""
global xy_map
+ global maptype
xy_map = event.GetString()
@@ -608,6 +617,19 @@
else:
wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+ try:
+ # set computational region to match selected map and zoom display to region
+ if maptype == 'cell':
+ p = gcmd.Command(['g.region', 'rast=xy_map'])
+ elif maptype == 'vector':
+ p = gcmd.Command(['g.region', 'vect=xy_map'])
+ if p.returncode == 0:
+ print 'returncode = ', str(p.returncode)
+ self.parent.Map.region = self.parent.Map.GetRegion()
+ except:
+ pass
def OnPageChanging(self, event=None):
global xy_map
@@ -621,7 +643,7 @@
def OnEnterPage(self, event=None):
global maptype
global xy_map
self.selection.SetElementList(maptype,
mapsets = [self.parent.newmapset, ])
@@ -665,6 +687,8 @@
self.xymapset = self.grwiz.gisrc_dict['MAPSET']
self.xygroup = self.grwiz.grouppage.xygroup
self.extension = self.grwiz.grouppage.extension
+ self.outname = ''
+ self.VectGRList = []
self.file = {
'points' : os.path.join(self.grassdatabase,
@@ -703,6 +727,8 @@
self.bkw_rmserror = 0.0
# list map coords and ID of map display they came from
self.mapcoordlist = []
+ # region clipping for georectified map
+ self.clip_to_region = False
self.SetTarget(self.xygroup, self.currentlocation, self.currentmapset)
@@ -737,9 +763,9 @@
sizer.Add(item=self.rb_grmethod, proportion=0,
flag=wx.EXPAND | wx.ALL, border=5)
- self.clip_to_region = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+ self.check = wx.CheckBox(parent=panel, id=wx.ID_ANY,
label=_("clip to computational region in target location"))
- sizer.Add(item=self.clip_to_region, proportion=0,
+ sizer.Add(item=self.check, proportion=0,
box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
@@ -761,6 +787,7 @@
self.Bind(wx.EVT_RADIOBOX, self.OnGRMethod, self.rb_grmethod)
self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
self.Bind(wx.EVT_CLOSE, self.OnQuit)
+ self.Bind(wx.EVT_CHECKBOX, self.ClipRegion, self.check)
panel.SetSizer(sizer)
# sizer.Fit(self)
@@ -769,6 +796,9 @@
"""!Disable georectification mode"""
self.parent.georectifying = None
+ def ClipRegion(self, event):
+ self.clip_to_region = event.IsChecked()
def SetMapDisplay(self, win):
self.mapdisp = win
if self.mapdisp:
@@ -791,8 +821,7 @@
group = tgroup,
location = tlocation,
mapset = tmapset)
- self.grwiz.SwitchEnv('original')
+ self.grwiz.SwitchEnv('original')
def AddGCP(self, event):
@@ -1037,11 +1066,25 @@
switchPage=True)
time.sleep(.1)
+ outmsg = ''
# loop through all vectors in VREF
# and move resulting vector to target location
+ # make sure current mapset has a vector folder
+ if not os.path.isdir(os.path.join(self.grassdatabase,
+ self.currentlocation,
+ self.currentmapset,
+ 'vector')):
+ os.mkdir(os.path.join(self.grassdatabase,
+ 'vector'))
+ self.grwiz.SwitchEnv('new')
+ # make list of vectors to georectify from VREF
f = open(self.file['vgrp'])
vectlist = []
try:
@@ -1052,36 +1095,83 @@
vectlist.append(vect)
finally:
f.close()
+ # georectify each vector in VREF using v.transform
for vect in vectlist:
- self.grwiz.SwitchEnv('new')
self.outname = vect + '_' + self.extension
self.parent.goutput.WriteLog(text = _('Transforming <%s>...') % vect,
switchPage = True)
- xyLayer = []
- for layer in grass.vector_db(map = vect).itervalues():
- xyLayer.append((layer['driver'],
- layer['database'],
- layer['table']))
- self.parent.goutput.RunCmd(['v.transform',
- '--o',
- 'input=%s' % vect,
- 'output=%s' % self.outname,
- 'pointsfile=%s' % self.file['points']],
- switchPage = True,
- onDone = self.OnGeorectDone)
+ msg = err = ''
- dbConnect = grass.db_connection()
- for layer in xyLayer:
- self.parent.goutput.RunCmd(['db.copy',
- '--q',
- '--o',
- 'from_driver=%s' % layer[0],
- 'from_database=%s' % layer[1],
- 'from_table=%s' % layer[2],
- 'to_driver=%s' % dbConnect['driver'],
- 'to_database=%s' % dbConnect['database'],
- 'to_table=%s' % layer[2] + '_' + self.extension])
+ ret, out, err = gcmd.RunCommand('v.transform',
+ flags = '-o',
+ input=vect,
+ output=self.outname,
+ pointsfile=self.file['points'],
+ getErrorMsg=True, read=True)
+ if ret == 0:
+ self.VectGRList.append(self.outname)
+ print err
+ # note: WriteLog doesn't handle GRASS_INFO_PERCENT well, so using a print here
+# self.parent.goutput.WriteLog(text = _(err), switchPage = True)
+ self.parent.goutput.WriteLog(text = _(out), switchPage = True)
+ else:
+ self.parent.goutput.WriteError(_('Georectification of vector map <%s> failed') %
+ self.outname)
+ self.parent.goutput.WriteError(_(err))
+ # FIXME
+ # Copying database information not working.
+ # Does not copy from xy location to current location
+# xyLayer = []
+# for layer in grass.vector_db(map = vect).itervalues():
+# xyLayer.append((layer['driver'],
+# layer['database'],
+# layer['table']))
+# dbConnect = grass.db_connection()
+# print 'db connection =', dbConnect
+# for layer in xyLayer:
+# self.parent.goutput.RunCmd(['db.copy',
+# '--q',
+# '--o',
+# 'from_driver=%s' % layer[0],
+# 'from_database=%s' % layer[1],
+# 'from_table=%s' % layer[2],
+# 'to_driver=%s' % dbConnect['driver'],
+# 'to_database=%s' % dbConnect['database'],
+# 'to_table=%s' % layer[2] + '_' + self.extension])
+ # copy all georectified vectors from source location to current location
+ for name in self.VectGRList:
+ xyvpath = os.path.join(self.grassdatabase,
+ self.xylocation,
+ self.xymapset,
+ 'vector',
+ name)
+ vpath = os.path.join(self.grassdatabase,
+ 'vector',
+ name)
+ if os.path.isdir(vpath):
+ self.parent.goutput.WriteWarning(_('Vector map <%s> already exists. '
+ 'Change extension name and '
+ 'georectify again.') % self.outname)
+ break
+ else:
+ shutil.move(xyvpath, vpath)
+ wx.MessageBox('For all vector maps georectified successfully, ' + '\n' +
+ 'you will need to copy any attribute tables' + '\n' +
+ 'and reconnect them to the georectified vectors')
def OnGeorectDone(self, **kargs):
"""!Print final message"""
global maptype
@@ -1090,45 +1180,14 @@
returncode = kargs['returncode']
- xyvpath = os.path.join(self.grassdatabase,
- self.xylocation,
- self.xymapset,
- 'vector',
- self.outname)
- vpath = os.path.join(self.grassdatabase,
- self.currentlocation,
- self.currentmapset,
- 'vector',
- self.outname)
- if os.path.isdir(vpath):
- self.parent.goutput.WriteWarning(_('Vector map <%s> already exists. '
- 'Change extension name and '
- 'georectify again.') % self.outname)
+ if returncode == 0:
+ print '*****vector list = ' + str(self.VectGRList)
else:
- if returncode == 0:
- if not os.path.isdir(os.path.join(self.grassdatabase,
- 'vector')):
- os.mkdir(os.path.join(self.grassdatabase,
- 'vector'))
- shutil.move(xyvpath, vpath)
- self.parent.goutput.WriteCmdLog(_('Vector map <%s> georectified '
- 'successfully') % self.outname)
- # copy attributes
- self.parent.goutput.WriteLog(_('Copying attributes...'))
- else:
- self.parent.goutput.WriteError(_('Georectification of vector map <%s> failed') %
- self.outname)
- del self.outname
+ self.outname)
def OnSettings(self, event):
"""!Georectifier settings"""
dlg = GrSettingsDialog(parent=self, id=wx.ID_ANY, title=_('Georectifier settings'))
@@ -1358,6 +1417,7 @@
coords.append(self.GetItem(index, i).GetText())
dlg = EditGPC(parent=self, id=wx.ID_ANY, data=coords)
if dlg.ShowModal() == wx.ID_OK:
values = dlg.GetValues() # string
