[GRASS-SVN] r39477 - grass/trunk/lib/vector/Vlib
    svn_grass at osgeo.org
    Sat Oct 10 16:48:58 EDT 2009
Author: martinl
Date: 2009-10-10 16:48:57 -0400 (Sat, 10 Oct 2009)
New Revision: 39477
Added:
   grass/trunk/lib/vector/Vlib/write_ogr.c
   grass/trunk/lib/vector/Vlib/open_ogr.c
   grass/trunk/lib/vector/Vlib/read_ogr.c
   grass/trunk/lib/vector/Vlib/write.c
vlib: very initial OGR write support (level 1 only, taken from
v.out.ogr)
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c	2009-10-10 18:50:59 UTC (rev 39476)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c	2009-10-10 20:48:57 UTC (rev 39477)
@@ -51,12 +51,14 @@
     OGRFeatureDefnH Ogr_featuredefn;
     Ogr_layer = NULL;
     if (update) {
 	G_warning(_("Write mode is not supported for OGR format"));
 	return -1;
     if (!Map->fInfo.ogr.dsn) {
 	G_fatal_error(_("OGR datasource not defined"));
 	return -1;
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c	2009-10-10 18:50:59 UTC (rev 39476)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c	2009-10-10 20:48:57 UTC (rev 39477)
@@ -156,7 +156,7 @@
 	Vect_get_constraint_box(Map, &mbox);
     while (1) {
-	/* Read feature to chache if necessary */
+	/* Read feature to cache if necessary */
 	while (Map->fInfo.ogr.lines_next == Map->fInfo.ogr.lines_num) {
 	    hFeature = OGR_L_GetNextFeature(Map->fInfo.ogr.layer);
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c	2009-10-10 18:50:59 UTC (rev 39476)
+++ grass/trunk/lib/vector/Vlib/write.c	2009-10-10 20:48:57 UTC (rev 39477)
@@ -1,5 +1,5 @@
-   \file write.c
+   \file lib/vector/Vlib/write.c
    \brief Vector library - write vector features
@@ -11,7 +11,7 @@
    (>=v2). Read the file COPYING that comes with GRASS for details.
    \author Radim Blazek
-   \author Updated by Martin Landa <landa.martin gmail.com> (restore lines)
+   \author Updated by Martin Landa <landa.martin gmail.com> (restore lines, OGR support)
 #include <grass/config.h>
@@ -66,7 +66,7 @@
     write_dummy, V1_write_line_nat, V2_write_line_nat}
 #ifdef HAVE_OGR
-    write_dummy, write_dummy, write_dummy}
+    write_dummy, V1_write_line_ogr, write_dummy}
 #else
     write_dummy, format_l, format_l}
@@ -110,7 +110,7 @@
-   \brief Writes new feature to the end of file (table)
+   \brief Writes new feature to the end of file
    The function calls G_fatal_error() on error.
@@ -119,7 +119,8 @@
    \param points feature geometry
    \param cats feature categories
-   \return new feature id (level 2) or offset into file where the feature starts (level 1)
+   \return new feature id (level 2)
+   \return offset into file where the feature starts (level 1)
 off_t
 Vect_write_line(struct Map_info *Map,
Added: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c	                        (rev 0)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c	2009-10-10 20:48:57 UTC (rev 39477)
@@ -0,0 +1,215 @@
+   \file vector/Vlib/write_ogr.c
+   \brief Vector library - write vector feature (OGR format)
+   Higher level functions for reading/writing/manipulating vectors.
+   Inspired by v.out.ogr's code.
+   (C) 2009 by the GRASS Development Team
+   This program is free software under the GNU General Public License
+   (>=v2). Read the file COPYING that comes with GRASS for details.
+   \author Martin Landa <landa.martin gmail.com> (2009)
+#include <grass/config.h>
+#include <grass/vector.h>
+#include <grass/dbmi.h>
+#include <grass/glocale.h>
+#ifdef HAVE_OGR
+#include <ogr_api.h>
+static int write_attributes(int, const struct field_info *,
+			    OGRFeatureH);
+  \brief Writes feature on level 1 (OGR format)
+  \param Map pointer to Map_info structure
+  \param type feature type
+  \param points pointer to line_pnts structure (feature geometry)
+  \param cats pointer to line_cats structure (feature categories)
+  \return 0 on success
+  \return -1 on error
+int V1_write_line_ogr(struct Map_info *Map,
+		      int type, const struct line_pnts *points, const struct line_cats *cats)
+    int i, cat;
+    struct field_info *Fi;
+    OGRGeometryH Ogr_geometry;
+    OGRFeatureH Ogr_feature;
+    OGRFeatureDefnH Ogr_featuredefn;
+    if (!Map->fInfo.ogr.layer) {
+	G_warning(_("Unable to write feature, OGR layer not defined"));
+	return -1;
+    /* determine feature's geometry */
+    if (type & (GV_POINTS | GV_KERNEL)) {
+	Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
+    else if (type & GV_LINES) {
+	Ogr_geometry = OGR_G_CreateGeometry(wkbLineString);
+    else if (type & GV_FACE) {
+	Ogr_geometry = OGR_G_CreateGeometry(wkbPolygon25D);
+    else {
+	G_warning("V1_write_line_ogr(): %s (%d)", _("Unsupported feature type"), type);
+	return -1;
+    G_debug(3, "V1_write_line_ogr(): type = %d", type);
+    for (i = 0; i < points->n_points; i++) {
+	OGR_G_AddPoint(Ogr_geometry, points->x[i], points->y[i],
+		       points->z[i]);
+    G_debug(4, "   n_points = %d", points->n_points);
+    Ogr_featuredefn = OGR_L_GetLayerDefn(Map->fInfo.ogr.layer);
+    /* create feature & set geometry */
+    Ogr_feature = OGR_F_Create(Ogr_featuredefn);
+    OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
+    /* write attributes */
+    if (cats->n_cats > 0) {
+	cat = cats->cat[0];
+	if (cats->n_cats > 1) {
+	    G_warning(_("Feature has more categories, using "
+			"category %d (from layer %d)"),
+		      cat, cats->field[0]);
+	Fi = Vect_get_field(Map, cats->field[0]);
+	if (!Fi) {
+	    G_fatal_error(_("Database connection not defined for layer %d"),
+			  cats->field[0]);
+	write_attributes(cat, Fi, Ogr_feature);
+    else { /* no attributes */
+	G_warning(_("Feature has no categories"));
+    /* write feature into layer */
+    OGR_L_CreateFeature(Map->fInfo.ogr.layer, Ogr_feature);
+    /* destroy */
+    OGR_G_DestroyGeometry(Ogr_geometry);
+    OGR_F_Destroy(Ogr_feature);
+    return 0;
+int write_attributes(int cat, const struct field_info *Fi,
+		     OGRFeatureH Ogr_feature)
+    int j, ogrfieldnum;
+    char buf[2000];
+    int ncol, colsqltype, colctype, more;
+    dbDriver *Driver;
+    dbTable *Table;
+    dbString dbstring;
+    dbColumn *Column;
+    dbCursor cursor;
+    dbValue *Value;
+    G_debug(3, "write_attributes(): cat = %d", cat);
+    if (cat < 0) {
+	G_warning ("Feature without category of layer %d", Fi->number);
+	return 0;
+    db_init_string(&dbstring);
+    /* read & set attributes */
+    sprintf(buf, "SELECT * FROM %s WHERE %s = %d", Fi->table, Fi->key,
+	    cat);
+    G_debug(4, "SQL: %s", buf);
+    db_set_string(&dbstring, buf);
+    /* open driver & select data */
+    Driver = db_start_driver(Fi->driver);
+    if (db_open_select_cursor(Driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK) {
+	G_fatal_error(_("Unable to select attributes for category %d"),
+		      cat);
+    if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
+	G_fatal_error(_("Unable to fetch data from table <%s>"),
+		      Fi->table);
+    if (!more) {
+	G_warning (_("No database record for category %d - export of 'cat' disabled"),
+		   cat);
+	return -1;
+    Table = db_get_cursor_table(&cursor);
+    ncol = db_get_table_number_of_columns(Table);
+    for (j = 0; j < ncol; j++) {
+	Column = db_get_table_column(Table, j);
+	Value = db_get_column_value(Column);
+	db_convert_column_value_to_string(Column, &dbstring);	/* for debug only */
+	G_debug(2, "col %d : val = %s", j,
+		db_get_string(&dbstring));
+	colsqltype = db_get_column_sqltype(Column);
+	colctype = db_sqltype_to_Ctype(colsqltype);
+	G_debug(2, "  colctype = %d", colctype);
+	ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature,
+					  db_get_column_name(Column));
+	/* Reset */
+	OGR_F_UnsetField(Ogr_feature, ogrfieldnum);
+	/* prevent writing NULL values */
+	if (!db_test_value_isnull(Value)) {
+	    switch (colctype) {
+	    case DB_C_TYPE_INT:
+		OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum,
+				      db_get_value_int(Value));
+		break;
+	    case DB_C_TYPE_DOUBLE:
+		OGR_F_SetFieldDouble(Ogr_feature, ogrfieldnum,
+				     db_get_value_double(Value));
+		break;
+	    case DB_C_TYPE_STRING:
+		OGR_F_SetFieldString(Ogr_feature, ogrfieldnum,
+				     db_get_value_string(Value));
+		break;
+	    case DB_C_TYPE_DATETIME:
+						  &dbstring);
+		break;
+    db_close_cursor (&cursor);
+    db_close_database(Driver);
+    db_shutdown_driver(Driver);
+    db_free_string(&dbstring);
+    return 1;
+#endif /* HAVE_OGR */
Property changes on: grass/trunk/lib/vector/Vlib/write_ogr.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
